[geos-commits] [SCM] GEOS branch master updated. 4919f0d85f0d2aee8cce8e6a59cf019db4335cb6
git at osgeo.org
git at osgeo.org
Thu Aug 30 18:40:53 PDT 2018
the project "GEOS".
via 4919f0d85f0d2aee8cce8e6a59cf019db4335cb6 (commit)
via 55d8d35b2a399deb324239573881d947fca49061 (commit)
from 8a9600bb2e617c788fdcdad8eb9e9045925bbd23 (commit)
revisions in full, below.
commit 4919f0d85f0d2aee8cce8e6a59cf019db4335cb6
Merge: 8a9600b 55d8d35
Author: cvvergara <vicky at georepublic.de>
Date: Thu Aug 30 18:40:53 2018 -0700
Merge branch 'fix-issue-849' of cvvergara/geos into master
commit 55d8d35b2a399deb324239573881d947fca49061
Date: Thu Jul 19 08:55:19 2018 -0500
Closes #849, Using empty() instead of comparing size() vs 0
diff --git a/src/linearref/ExtractLineByLocation.cpp b/src/linearref/ExtractLineByLocation.cpp
index 6acc12b..e044955 100644
--- a/src/linearref/ExtractLineByLocation.cpp
+++ b/src/linearref/ExtractLineByLocation.cpp
@@ -106,7 +106,7 @@ LineString* ExtractLineByLocation::computeLine(const LinearLocation& start, cons
if (lastSegmentIndex >= coordinates->size())
- assert(coordinates->size() > 0);
+ assert(!coordinates->isEmpty());
lastSegmentIndex = coordinates->size() - indexStep;
@@ -126,7 +126,7 @@ LineString* ExtractLineByLocation::computeLine(const LinearLocation& start, cons
// ensure there is at least one coordinate in the result
- if (newCoordinateArray.size() == 0)
+ if (newCoordinateArray.isEmpty())
newCoordinateArray.add(start.getCoordinate(line));
diff --git a/tests/unit/tut/tut_console_reporter.hpp b/tests/unit/tut/tut_console_reporter.hpp
index 28ee4ca..c30459e 100644
--- a/tests/unit/tut/tut_console_reporter.hpp
+++ b/tests/unit/tut/tut_console_reporter.hpp
@@ -160,7 +160,7 @@ public:
os << std::endl;
- if (not_passed.size() > 0)
+ if (!not_passed.empty())
not_passed_list::const_iterator i = not_passed.begin();
while (i != not_passed.end())
diff --git a/tests/unit/tut/tut_cppunit_reporter.hpp b/tests/unit/tut/tut_cppunit_reporter.hpp
index 25d3adb..35e3059 100644
--- a/tests/unit/tut/tut_cppunit_reporter.hpp
+++ b/tests/unit/tut/tut_cppunit_reporter.hpp
@@ -84,7 +84,7 @@ public:
*stream_ << "<?xml version=\"1.0\" encoding=\"utf-8\" standalone=\"yes\" ?>" << std::endl
<< "<TestRun>" << std::endl;
- if (failed_tests_.size() > 0)
+ if (!failed_tests_.empty())
*stream_ << " <FailedTests>" << std::endl;
@@ -145,7 +145,7 @@ public:
/* *********************** passed tests ***************************** */
- if (passed_tests_.size() > 0) {
+ if (!passed_tests_.empty()) {
*stream_ << " <SuccessfulTests>" << std::endl;
for (unsigned int i=0; i<passed_tests_.size(); i++)
diff --git a/tests/xmltester/Stackwalker.cpp b/tests/xmltester/Stackwalker.cpp
index 8816d35..e376e11 100644
--- a/tests/xmltester/Stackwalker.cpp
+++ b/tests/xmltester/Stackwalker.cpp
@@ -1435,7 +1435,7 @@ static bool GetModuleListTH32(ModuleList& modules, DWORD pid, FILE *fLogFile)
CloseHandle(hSnap);
FreeLibrary(hToolhelp);
- return modules.size() != 0;
+ return !modules.empty();
} // GetModuleListTH32
@@ -1526,7 +1526,7 @@ cleanup:
free(tt);
free(hMods);
} // GetModuleListPSAPI
@@ -2067,7 +2067,7 @@ static void ShowStackRM( HANDLE hThread, CONTEXT& c, FILE *fLogFile, PREAD_PROCE
- if ( symSearchPath.size() > 0 ) // if we added anything, we have a trailing semicolon
+ if ( !symSearchPath.empty() ) // if we added anything, we have a trailing semicolon
symSearchPath = symSearchPath.substr( 0, symSearchPath.size() - 1 );
// why oh why does SymInitialize() want a writeable string?
Summary of changes:
src/linearref/ExtractLineByLocation.cpp | 4 ++--
tests/unit/tut/tut_console_reporter.hpp | 2 +-
tests/unit/tut/tut_cppunit_reporter.hpp | 4 ++--
tests/xmltester/Stackwalker.cpp | 6 +++---
4 files changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits
