[geos-commits] [SCM] GEOS branch master updated. 7aa3da4fefd2bafbfdc69c43eec70759e99147b2
git at osgeo.org
git at osgeo.org
Fri Aug 31 07:40:26 PDT 2018
the project "GEOS".
via 7aa3da4fefd2bafbfdc69c43eec70759e99147b2 (commit)
via 8c380db59ec5183bd7e2fc8545e93ce692f680e2 (commit)
from 4919f0d85f0d2aee8cce8e6a59cf019db4335cb6 (commit)
revisions in full, below.
commit 7aa3da4fefd2bafbfdc69c43eec70759e99147b2
Merge: 4919f0d 8c380db
Author: dbaston <dbaston at gmail.com>
Date: Fri Aug 31 07:40:26 2018 -0700
Merge branch 'fix-issue908' of cvvergara/geos into master
commit 8c380db59ec5183bd7e2fc8545e93ce692f680e2
Author: cvvergara <vicky at georepublic.de>
Date: Sun Aug 5 18:20:47 2018 -0500
removing -V from ctest execution Closes #908
diff --git a/appveyor.yml b/appveyor.yml
index be58f37..65df124 100644
--- a/appveyor.yml
+++ b/appveyor.yml
@@ -1,4 +1,4 @@
-version: 1.0.{build}
+version: 1.0.{build}
image: Visual Studio 2017
@@ -74,7 +74,7 @@ build_script:
test_script:
- ps: 'Write-Host "Running tests:" -ForegroundColor Magenta'
- - if "%BUILDER%"=="CMake" ctest -V --output-on-failure -C %CONFIGURATION%
+ - if "%BUILDER%"=="CMake" ctest --output-on-failure -C %CONFIGURATION%
- if "%BUILDER%"=="NMake" echo *** NMake does NOT build tests ***
# If you need to debug AppVeyor session (https://www.appveyor.com/docs/how-to/rdp-to-build-worker), then:
diff --git a/tools/ci/common.sh b/tools/ci/common.sh
index 4d078ef..5611b0e 100644
--- a/tools/ci/common.sh
+++ b/tools/ci/common.sh
@@ -6,7 +6,7 @@
# This is free software; you can redistribute and/or modify it under
# the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
+# by the Free Software Foundation.
# See the COPYING file for more information.
if [[ "$TRAVIS" != "true" ]] ; then
@@ -31,12 +31,12 @@ tmstamp()
run_make()
- [ $TCI_NUMTHREADS -gt 0 ] && make -j $TCI_NUMTHREADS || make
+ [ $TCI_NUMTHREADS -gt 0 ] && make -j $TCI_NUMTHREADS || make
run_test()
[ -f CMakeCache.txt ] && \
- ctest -V --output-on-failure . || \
+ ctest --output-on-failure . || \
make check
Summary of changes:
appveyor.yml | 4 ++--
tools/ci/common.sh | 6 +++---
2 files changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits
