[geos-commits] [SCM] GEOS branch master updated. 72b256ec6d6c5f321c2db65d3d1aa5e586f65f8c
git at osgeo.org
git at osgeo.org
Tue Dec 11 13:57:53 PST 2018
the project "GEOS".
via 72b256ec6d6c5f321c2db65d3d1aa5e586f65f8c (commit)
from 6f46a0ba7c8c9194bbc14ded2ecbaaa9bf0c1630 (commit)
revisions in full, below.
commit 72b256ec6d6c5f321c2db65d3d1aa5e586f65f8c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Dec 11 13:57:41 2018 -0800
Reformat CGAlgorithmsDD
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index 2b581b7..20e9972 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -29,10 +29,10 @@ typedef ttmath::Big<TTMATH_BITS(32), TTMATH_BITS(128)> DD;
// Forward declarations
namespace geos {
- namespace geom {
- class Coordinate;
- class CoordinateSequence;
+namespace geom {
+class Coordinate;
+class CoordinateSequence;
namespace geos {
@@ -45,17 +45,17 @@ class GEOS_DLL CGAlgorithmsDD {
public:
- enum {
- CLOCKWISE=-1,
- COLLINEAR=0,
- COUNTERCLOCKWISE=1
+ enum {
+ CLOCKWISE=-1,
+ COLLINEAR=0,
+ COUNTERCLOCKWISE=1
- enum {
- RIGHT=-1,
- LEFT=1,
- STRAIGHT=0
+ enum {
+ RIGHT=-1,
+ LEFT=1,
+ STRAIGHT=0
* Returns the index of the direction of the point <code>q</code> relative to
@@ -96,20 +96,21 @@ public:
const geom::Coordinate& pb,
const geom::Coordinate& pc);
- static int signum(double x) {
+ static int signum(double x)
if (x > 0) return 1;
if (x < 0) return -1;
return 0;
static void intersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
- const geom::Coordinate& q1, const geom::Coordinate& q2,
- geom::Coordinate &rv);
+ const geom::Coordinate& q1, const geom::Coordinate& q2,
+ geom::Coordinate &rv);
protected:
- static int signOfDet2x2(DD &x1, DD &y1, DD &x2, DD &y2);
+ static int signOfDet2x2(DD &x1, DD &y1, DD &x2, DD &y2);
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index ecc95d3..6663691 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -25,24 +25,24 @@ using namespace geos::geom;
namespace {
- double const DP_SAFE_EPSILON = 1e-15;
+double const DP_SAFE_EPSILON = 1e-15;
- inline int SigNumDD(DD const& dd)
- static DD const zero(0.0);
- if (dd < zero)
- return -1;
+inline int SigNumDD(DD const& dd)
+ static DD const zero(0.0);
+ if (dd < zero)
+ return -1;
- if (dd > zero)
- return 1;
+ if (dd > zero)
+ return 1;
- return 0;
+ return 0;
- inline std::string ToStringDD(DD const& dd)
- return dd.ToString();
+inline std::string ToStringDD(DD const& dd)
+ return dd.ToString();
namespace geos {
@@ -82,16 +82,20 @@ int CGAlgorithmsDD::orientationIndexFilter(const Coordinate& pa,
if (detleft > 0.0) {
if (detright <= 0.0) {
return signum(det);
- } else {
+ else {
detsum = detleft + detright;
- } else if (detleft < 0.0) {
+ else if (detleft < 0.0) {
if (detright >= 0.0) {
return signum(det);
- } else {
+ else {
detsum = -detleft - detright;
- } else {
+ else {
return signum(det);
Summary of changes:
include/geos/algorithm/CGAlgorithmsDD.h | 37 +++++++++++++++---------------
src/algorithm/CGAlgorithmsDD.cpp | 40 ++++++++++++++++++---------------
2 files changed, 41 insertions(+), 36 deletions(-)
hooks/post-receive
More information about the geos-commits
