[geos-commits] [SCM] GEOS branch master updated. b61e66308e8d2b00ac025ac9ad4ab78b55d5f1d7
git at osgeo.org
git at osgeo.org
Tue Dec 11 14:32:35 PST 2018
the project "GEOS".
via b61e66308e8d2b00ac025ac9ad4ab78b55d5f1d7 (commit)
from 72b256ec6d6c5f321c2db65d3d1aa5e586f65f8c (commit)
revisions in full, below.
commit b61e66308e8d2b00ac025ac9ad4ab78b55d5f1d7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Dec 11 14:32:12 2018 -0800
Blind port for RayCrossingCounterDD and some minor
changes to existing files
diff --git a/.gitignore b/.gitignore
index 40bf331..3539e0a 100644
--- a/.gitignore
+++ b/.gitignore
@@ -35,6 +35,7 @@ tests/perf/operation/predicate/RectangleIntersectsPerfTest
tests/perf/capi/memleak_mp_prep
tests/perf/ClassSizes
include/geos/platform.h
+include/geos/platform.h.disabled
include/geos/stamp-h2
include/geos/version.h
include/stamp-h1
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index 20e9972..d67660e 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -54,7 +54,8 @@ public:
enum {
RIGHT=-1,
LEFT=1,
- STRAIGHT=0
+ STRAIGHT=0,
+ FAILURE=2
@@ -96,11 +97,11 @@ public:
const geom::Coordinate& pb,
const geom::Coordinate& pc);
- static int signum(double x)
+ static int orientation(double x)
- if (x > 0) return 1;
- if (x < 0) return -1;
- return 0;
+ if (x < 0) return CGAlgorithmsDD::RIGHT;
+ if (x > 0) return CGAlgorithmsDD::LEFT;
+ return CGAlgorithmsDD::STRAIGHT;
static void intersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index d88faa9..5df8b26 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -11,27 +11,28 @@ EXTRA_DIST =
geosdir = $(includedir)/geos/algorithm
geos_HEADERS = \
- Angle.h \
- BoundaryNodeRule.h \
- CentralEndpointIntersector.h \
- Centroid.h \
- CentroidArea.h \
- CentroidLine.h \
- CentroidPoint.h \
- CGAlgorithms.h \
- ConvexHull.h \
- ConvexHull.inl \
- HCoordinate.h \
- InteriorPointArea.h \
- InteriorPointLine.h \
- InteriorPointPoint.h \
- LineIntersector.h \
- MCPointInRing.h \
- MinimumDiameter.h \
- NotRepresentableException.h \
- PointInRing.h \
- PointLocator.h \
- RayCrossingCounter.h \
- RobustDeterminant.h \
- SimplePointInRing.h \
- SIRtreePointInRing.h
+ Angle.h \
+ BoundaryNodeRule.h \
+ CentralEndpointIntersector.h \
+ Centroid.h \
+ CentroidArea.h \
+ CentroidLine.h \
+ CentroidPoint.h \
+ CGAlgorithms.h \
+ ConvexHull.h \
+ ConvexHull.inl \
+ HCoordinate.h \
+ InteriorPointArea.h \
+ InteriorPointLine.h \
+ InteriorPointPoint.h \
+ LineIntersector.h \
+ MCPointInRing.h \
+ MinimumDiameter.h \
+ NotRepresentableException.h \
+ PointInRing.h \
+ PointLocator.h \
+ RayCrossingCounter.h \
+ RayCrossingCounterDD.h \
+ RobustDeterminant.h \
+ SimplePointInRing.h \
+ SIRtreePointInRing.h
diff --git a/include/geos/algorithm/RayCrossingCounterDD.h b/include/geos/algorithm/RayCrossingCounterDD.h
new file mode 100644
index 0000000..1bb431b
--- /dev/null
+++ b/include/geos/algorithm/RayCrossingCounterDD.h
@@ -0,0 +1,167 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2018 Paul Ramsey <pramsey at cleverelephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/RayCrossingCounterDD.java rev. 1.2 (JTS-1.9)
+#ifndef GEOS_ALGORITHM_RAYCROSSINGCOUNTERDD_H
+#define GEOS_ALGORITHM_RAYCROSSINGCOUNTERDD_H
+#include <geos/export.h>
+#include <geos/algorithm/ttmath/ttmath.h>
+#include <vector>
+// forward declarations
+namespace geos {
+namespace geom {
+class Coordinate;
+class CoordinateSequence;
+namespace geos {
+namespace algorithm {
+ * Counts the number of segments crossed by a horizontal ray extending to the right
+ * from a given point, in an incremental fashion.
+ * This can be used to determine whether a point lies in a {@link Polygonal} geometry.
+ * The class determines the situation where the point lies exactly on a segment.
+ * When being used for Point-In-Polygon determination, this case allows short-circuiting
+ * the evaluation.
+ * <p>
+ * This class handles polygonal geometries with any number of shells and holes.
+ * The orientation of the shell and hole rings is unimportant.
+ * In order to compute a correct location for a given polygonal geometry,
+ * it is essential that <b>all</b> segments are counted which
+ * <ul>
+ * <li>touch the ray
+ * <li>lie in in any ring which may contain the point
+ * </ul>
+ * The only exception is when the point-on-segment situation is detected, in which
+ * case no further processing is required.
+ * The implication of the above rule is that segments
+ * which can be a priori determined to <i>not</i> touch the ray
+ * (i.e. by a test of their bounding box or Y-extent)
+ * do not need to be counted. This allows for optimization by indexing.
+class GEOS_DLL RayCrossingCounterDD {
+private:
+ const geom::Coordinate& point;
+ int crossingCount;
+ // true if the test point lies on an input segment
+ bool isPointOnSegment;
+ // Declare type as noncopyable
+ RayCrossingCounterDD(const RayCrossingCounterDD& other) = delete;
+ RayCrossingCounterDD& operator=(const RayCrossingCounterDD& rhs) = delete;
+public:
+ * Determines the {@link Location} of a point in a ring.
+ * This method is an exemplar of how to use this class.
+ * @param p the point to test
+ * @param ring an array of Coordinates forming a ring
+ * @return the location of the point in the ring
+ static int locatePointInRing(const geom::Coordinate& p,
+ const geom::CoordinateSequence& ring);
+ /// Semantically equal to the above, just different args encoding
+ const std::vector<const geom::Coordinate*>& ring);
+ /** \brief
+ * Returns the index of the direction of the point <code>q</code>
+ * relative to a vector specified by <code>p1-p2</code>.
+ * @param p1 the origin point of the vector
+ * @param p2 the final point of the vector
+ * @param q the point to compute the direction to
+ * @return 1 if q is counter-clockwise (left) from p1-p2
+ * @return -1 if q is clockwise (right) from p1-p2
+ * @return 0 if q is collinear with p1-p2
+ static int orientationIndex(const geom::Coordinate& p1,
+ const geom::Coordinate& p2,
+ const geom::Coordinate& q);
+ RayCrossingCounterDD(const geom::Coordinate& p_point):
+ point(p_point),
+ crossingCount(0),
+ isPointOnSegment(false)
+ * Counts a segment
+ * @param p1 an endpoint of the segment
+ * @param p2 another endpoint of the segment
+ void countSegment(const geom::Coordinate& p1,
+ const geom::Coordinate& p2);
+ * Reports whether the point lies exactly on one of the supplied segments.
+ * This method may be called at any time as segments are processed.
+ * If the result of this method is <tt>true</tt>,
+ * no further segments need be supplied, since the result
+ * will never change again.
+ * @return true if the point lies exactly on a segment
+ bool isOnSegment()
+ return isPointOnSegment;
+ * Gets the {@link Location} of the point relative to
+ * the ring, polygon
+ * or multipolygon from which the processed segments were provided.
+ * <p>
+ * This method only determines the correct location
+ * if <b>all</b> relevant segments must have been processed.
+ * @return the Location of the point
+ int getLocation();
+ * Tests whether the point lies in or on
+ * <p>
+ * @return true if the point lies in or on the supplied polygon
+ bool isPointInPolygon();
+} // geos::algorithm
+} // geos
+#endif // GEOS_ALGORITHM_RAYCROSSINGCOUNTERDD_H
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index 6663691..dedd617 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -22,27 +22,28 @@
#include <sstream>
using namespace geos::geom;
+using namespace geos::algorithm;
namespace {
double const DP_SAFE_EPSILON = 1e-15;
-inline int SigNumDD(DD const& dd)
+inline int OrientationDD(DD const& dd)
static DD const zero(0.0);
if (dd < zero)
- return -1;
+ return CGAlgorithmsDD::RIGHT;
if (dd > zero)
- return 1;
+ return CGAlgorithmsDD::LEFT;
- return 0;
-inline std::string ToStringDD(DD const& dd)
- return dd.ToString();
+// inline std::string ToStringDD(DD const& dd)
+// return dd.ToString();
namespace geos {
@@ -52,6 +53,7 @@ int CGAlgorithmsDD::orientationIndex(const Coordinate& p1,
const Coordinate& p2,
const Coordinate& q)
+ static DD const zero(0.0);
DD dx1 = DD(p2.x) + DD(-p1.x);
DD dy1 = DD(p2.y) + DD(-p1.y);
DD dx2 = DD(q.x) + DD(-p2.x);
@@ -59,7 +61,7 @@ int CGAlgorithmsDD::orientationIndex(const Coordinate& p1,
DD mx1y2(dx1 * dy2);
DD my1x2(dy1 * dx2);
DD d = mx1y2 - my1x2;
- return SigNumDD(d);
+ return OrientationDD(d);
int CGAlgorithmsDD::signOfDet2x2(DD &x1, DD &y1, DD &x2, DD &y2)
@@ -67,7 +69,7 @@ int CGAlgorithmsDD::signOfDet2x2(DD &x1, DD &y1, DD &x2, DD &y2)
DD mx1y2(x1 * y2);
DD my1x2(y1 * x2);
int CGAlgorithmsDD::orientationIndexFilter(const Coordinate& pa,
@@ -81,7 +83,7 @@ int CGAlgorithmsDD::orientationIndexFilter(const Coordinate& pa,
if (detleft > 0.0) {
if (detright <= 0.0) {
- return signum(det);
+ return orientation(det);
else {
detsum = detleft + detright;
@@ -89,21 +91,21 @@ int CGAlgorithmsDD::orientationIndexFilter(const Coordinate& pa,
else if (detleft < 0.0) {
if (detright >= 0.0) {
else {
detsum = -detleft - detright;
else {
double const errbound = DP_SAFE_EPSILON * detsum;
if ((det >= errbound) || (-det >= errbound)) {
- return 2;
+ return CGAlgorithmsDD::FAILURE;
void CGAlgorithmsDD::intersection(const Coordinate& p1, const Coordinate& p2,
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index a9181ff..f735bce 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -1,43 +1,40 @@
-# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
SUBDIRS = \
- locate \
- distance
+ locate \
+ distance
noinst_LTLIBRARIES = libalgorithm.la
-AM_CPPFLAGS = -I$(top_srcdir)/include
+AM_CPPFLAGS = -I$(top_srcdir)/include
libalgorithm_la_SOURCES = \
- Angle.cpp \
- BoundaryNodeRule.cpp \
- Centroid.cpp \
- CentroidArea.cpp \
- CentroidLine.cpp \
- CentroidPoint.cpp \
- CGAlgorithms.cpp \
- CGAlgorithmsDD.cpp \
- ConvexHull.cpp \
- HCoordinate.cpp \
- InteriorPointArea.cpp \
- InteriorPointLine.cpp \
- InteriorPointPoint.cpp \
- LineIntersector.cpp \
- MCPointInRing.cpp \
- MinimumDiameter.cpp \
- NotRepresentableException.cpp \
- PointLocator.cpp \
- RayCrossingCounter.cpp \
- RobustDeterminant.cpp \
- SimplePointInRing.cpp \
- SIRtreePointInRing.cpp
+ Angle.cpp \
+ BoundaryNodeRule.cpp \
+ Centroid.cpp \
+ CentroidArea.cpp \
+ CentroidLine.cpp \
+ CentroidPoint.cpp \
+ CGAlgorithms.cpp \
+ CGAlgorithmsDD.cpp \
+ ConvexHull.cpp \
+ HCoordinate.cpp \
+ InteriorPointArea.cpp \
+ InteriorPointLine.cpp \
+ InteriorPointPoint.cpp \
+ LineIntersector.cpp \
+ MCPointInRing.cpp \
+ MinimumDiameter.cpp \
+ NotRepresentableException.cpp \
+ PointLocator.cpp \
+ RayCrossingCounter.cpp \
+ RayCrossingCounterDD.cpp \
+ RobustDeterminant.cpp \
+ SimplePointInRing.cpp \
+ SIRtreePointInRing.cpp
-# Deprecated files
-# (http://geos.osgeo.org/pipermail/geos-devel/2006-March/001828.html):
-#NonRobustLineIntersector.cpp
-#RobustLineIntersector.cpp
-libalgorithm_la_LIBADD = \
- locate/liblocation.la \
- distance/libdistance.la
+libalgorithm_la_LIBADD = \
+ locate/liblocation.la \
+ distance/libdistance.la
diff --git a/src/algorithm/RayCrossingCounterDD.cpp b/src/algorithm/RayCrossingCounterDD.cpp
index 0000000..44a7bf6
--- /dev/null
+++ b/src/algorithm/RayCrossingCounterDD.cpp
@@ -0,0 +1,171 @@
+#include <geos/algorithm/RayCrossingCounterDD.h>
+#include <geos/algorithm/CGAlgorithmsDD.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Location.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+namespace geos {
+// private:
+// protected:
+// public:
+/*static*/
+int
+RayCrossingCounterDD::locatePointInRing(const geom::Coordinate& point,
+ RayCrossingCounterDD rcc(point);
+ for (std::size_t i = 1, ni = ring.size(); i < ni; i++) {
+ const geom::Coordinate & p1 = ring[ i - 1 ];
+ const geom::Coordinate & p2 = ring[ i ];
+ rcc.countSegment(p1, p2);
+ if (rcc.isOnSegment())
+ return rcc.getLocation();
+/*static*/
+int
+ const geom::Coordinate & p1 = *ring[ i - 1 ];
+ const geom::Coordinate & p2 = *ring[ i ];
+/*public static*/
+int
+RayCrossingCounterDD::orientationIndex(const geom::Coordinate& p1,
+ const geom::Coordinate& p2, const geom::Coordinate& q)
+ return CGAlgorithmsDD::orientationIndex(p1, p2, q);
+void
+RayCrossingCounterDD::countSegment(const geom::Coordinate& p1,
+ // For each segment, check if it crosses
+ // a horizontal ray running from the test point in
+ // the positive x direction.
+ // check if the segment is strictly to the left of the test point
+ if (p1.x < point.x && p2.x < point.x)
+ return;
+ // check if the point is equal to the current ring vertex
+ if (point.x == p2.x && point.y == p2.y) {
+ isPointOnSegment = true;
+ return;
+ // For horizontal segments, check if the point is on the segment.
+ // Otherwise, horizontal segments are not counted.
+ if (p1.y == point.y && p2.y == point.y) {
+ double minx = p1.x;
+ double maxx = p2.x;
+ if (minx > maxx) {
+ minx = p2.x;
+ maxx = p1.x;
+ if (point.x >= minx && point.x <= maxx)
+ return;
+ // Evaluate all non-horizontal segments which cross a horizontal ray
+ // to the right of the test pt.
+ // To avoid double-counting shared vertices, we use the convention that
+ // - an upward edge includes its starting endpoint, and excludes its
+ // final endpoint
+ // - a downward edge excludes its starting endpoint, and includes its
+ // final endpoint
+ if (((p1.y > point.y) && (p2.y <= point.y)) ||
+ ((p2.y > point.y) && (p1.y <= point.y))) {
+ // For an upward edge, orientationIndex will be positive when p1->p2
+ // crosses ray. Conversely, downward edges should have negative sign.
+ int sign = CGAlgorithmsDD::orientationIndex(p1, p2, point);
+ if (sign == CGAlgorithmsDD::STRAIGHT) {
+ return;
+ if (p2.y < p1.y)
+ sign = -sign;
+ // The segment crosses the ray if the sign is strictly positive.
+ if (sign == CGAlgorithmsDD::LEFT)
+ crossingCount++;
+int
+RayCrossingCounterDD::getLocation()
+ if (isPointOnSegment)
+ return geom::Location::BOUNDARY;
+ // The point is in the interior of the ring if the number
+ // of X-crossings is odd.
+ if ((crossingCount % 2) == 1)
+ return geom::Location::INTERIOR;
+ return geom::Location::EXTERIOR;
+bool
+RayCrossingCounterDD::isPointInPolygon()
+ return getLocation() != geom::Location::EXTERIOR;
+} // geos
diff --git a/src/geom/util/Densifier.cpp b/src/geom/util/Densifier.cpp
index 11fd73b..ff427a5 100644
--- a/src/geom/util/Densifier.cpp
+++ b/src/geom/util/Densifier.cpp
@@ -106,7 +106,6 @@ Densifier::densifyPoints(const Coordinate::Vect pts, double distanceTolerance, c
geom::LineSegment seg;
geom::CoordinateList coordList;
- geom::CoordinateList::iterator it = coordList.begin();
for (Coordinate::Vect::const_iterator it=pts.begin(), itEnd=pts.end()-1; it < itEnd; ++it)
Summary of changes:
.gitignore | 1 +
include/geos/algorithm/CGAlgorithmsDD.h | 11 +-
include/geos/algorithm/Makefile.am | 49 ++++----
include/geos/algorithm/RayCrossingCounterDD.h | 167 +++++++++++++++++++++++++
src/algorithm/CGAlgorithmsDD.cpp | 32 ++---
src/algorithm/Makefile.am | 63 +++++-----
src/algorithm/RayCrossingCounterDD.cpp | 171 ++++++++++++++++++++++++++
src/geom/util/Densifier.cpp | 1 -
8 files changed, 417 insertions(+), 78 deletions(-)
create mode 100644 include/geos/algorithm/RayCrossingCounterDD.h
create mode 100644 src/algorithm/RayCrossingCounterDD.cpp
hooks/post-receive
More information about the geos-commits
