[geos-commits] [SCM] GEOS branch master updated. 66392736c9e0748a10ab41ee8a379634c379c3c9
git at osgeo.org
git at osgeo.org
Wed Dec 12 09:17:24 PST 2018
the project "GEOS".
via 66392736c9e0748a10ab41ee8a379634c379c3c9 (commit)
from b61e66308e8d2b00ac025ac9ad4ab78b55d5f1d7 (commit)
revisions in full, below.
commit 66392736c9e0748a10ab41ee8a379634c379c3c9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Dec 12 09:16:44 2018 -0800
Move to 0.9.4 prerelease version of ttmath in hopes of getting
past regression failure on g++ 4.8
diff --git a/include/geos/algorithm/ttmath/COPYRIGHT b/include/geos/algorithm/ttmath/COPYRIGHT
index 15bec4e..3111d0b 100644
--- a/include/geos/algorithm/ttmath/COPYRIGHT
+++ b/include/geos/algorithm/ttmath/COPYRIGHT
@@ -1,4 +1,4 @@
-Copyright (c) 2006-2012, Tomasz Sowa
+Copyright (c) 2006-2017, Tomasz Sowa
All rights reserved.
Redistribution and use in source and binary forms, with or without
diff --git a/include/geos/algorithm/ttmath/ttmath.h b/include/geos/algorithm/ttmath/ttmath.h
index ee40e6e..94630a7 100644
--- a/include/geos/algorithm/ttmath/ttmath.h
+++ b/include/geos/algorithm/ttmath/ttmath.h
@@ -1,11 +1,11 @@
* This file is a part of TTMath Bignum Library
- * and is distributed under the (new) BSD licence.
+ * and is distributed under the 3-Clause BSD Licence.
* Author: Tomasz Sowa <t.sowa at ttmath.org>
- * Copyright (c) 2006-2012, Tomasz Sowa
+ * Copyright (c) 2006-2017, Tomasz Sowa
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
@@ -79,10 +79,12 @@ namespace ttmath
this function skips the fraction from x
- e.g 2.2 = 2
- 2.7 = 2
- -2.2 = 2
- -2.7 = 2
+ samples
+ - 2.2 = 2
+ - 2.7 = 2
+ - -2.2 = 2
+ - -2.7 = 2
template<class ValueType>
ValueType SkipFraction(const ValueType & x)
@@ -96,10 +98,12 @@ namespace ttmath
this function rounds to the nearest integer value
- e.g 2.2 = 2
- 2.7 = 3
- -2.2 = -2
- -2.7 = -3
+ samples
+ - 2.2 = 2
+ - 2.7 = 3
+ - -2.2 = -2
+ - -2.7 = -3
ValueType Round(const ValueType & x, ErrorCode * err = 0)
@@ -127,12 +131,12 @@ namespace ttmath
this function returns a value representing the smallest integer
that is greater than or equal to x
- Ceil(-3.7) = -3
- Ceil(-3.1) = -3
- Ceil(-3.0) = -3
- Ceil(4.0) = 4
- Ceil(4.2) = 5
- Ceil(4.8) = 5
+ - Ceil(-3.7) = -3
+ - Ceil(-3.1) = -3
+ - Ceil(-3.0) = -3
+ - Ceil(4.0) = 4
+ - Ceil(4.2) = 5
+ - Ceil(4.8) = 5
ValueType Ceil(const ValueType & x, ErrorCode * err = 0)
@@ -174,12 +178,12 @@ namespace ttmath
this function returns a value representing the largest integer
that is less than or equal to x
- Floor(-3.6) = -4
- Floor(-3.1) = -4
- Floor(-3) = -3
- Floor(2) = 2
- Floor(2.3) = 2
- Floor(2.8) = 2
+ - Floor(-3.6) = -4
+ - Floor(-3.1) = -4
+ - Floor(-3) = -3
+ - Floor(2) = 2
+ - Floor(2.3) = 2
+ - Floor(2.8) = 2
ValueType Floor(const ValueType & x, ErrorCode * err = 0)
@@ -346,6 +350,9 @@ namespace ttmath
this namespace consists of auxiliary functions
(something like 'private' in a class)
+ this is excluded from doxygen documentation
+ (option EXCLUDE_SYMBOLS in doxygen.cfg)
namespace auxiliaryfunctions
@@ -1611,15 +1618,16 @@ namespace ttmath
minutes and seconds must be greater than or equal zero
result:
- if d>=0 : result= d + ((s/60)+m)/60
- if d<0 : result= d - ((s/60)+m)/60
+ - if d>=0 : result= d + ((s/60)+m)/60
+ - if d<0 : result= d - ((s/60)+m)/60
((s/60)+m)/60 = (s+60*m)/3600 (second version is faster because
there's only one division)
- for example:
- DegToDeg(10, 30, 0) = 10.5
- DegToDeg(10, 24, 35.6)=10.4098(8)
+ samples:
+ - DegToDeg(10, 30, 0) = 10.5
+ - DegToDeg(10, 24, 35.6)=10.4098(8)
ValueType DegToDeg( const ValueType & d, const ValueType & m, const ValueType & s,
@@ -2050,18 +2058,19 @@ namespace ttmath
- indexth Root of x
+ caltulate the index'th Root of x
index must be integer and not negative <0;1;2;3....)
- if index==0 the result is one
- if x==0 the result is zero and we assume root(0;0) is not defined
+ - if index==0 the result is one
+ - if x==0 the result is zero and we assume root(0;0) is not defined
- if index is even (2;4;6...) the result is x^(1/index) and x>0
- if index is odd (1;2;3;...) the result is either
- -(abs(x)^(1/index)) if x<0 or
- x^(1/index)) if x>0
+ - if index is even (2;4;6...) the result is x^(1/index) and x>0
+ - if index is odd (1;2;3;...) the result is either
+ - -(abs(x)^(1/index)) if x<0, or
+ - x^(1/index)) if x>0
- (for index==1 the result is equal x)
+ - for index==1 the result is equal x
ValueType Root(ValueType x, const ValueType & index, ErrorCode * err = 0)
@@ -2119,8 +2128,10 @@ namespace ttmath
absolute value of x
- e.g. -2 = 2
- 2 = 2
+ samples:
+ - -2 = 2
+ - 2 = 2
ValueType Abs(const ValueType & x)
@@ -2134,9 +2145,11 @@ namespace ttmath
it returns the sign of the value
- e.g. -2 = -1
- 0 = 0
- 10 = 1
+ samples:
+ - -2 = -1
+ - 0 = 0
+ - 10 = 1
ValueType Sgn(ValueType x)
@@ -2150,11 +2163,11 @@ namespace ttmath
the remainder from a division
- e.g.
- mod( 12.6 ; 3) = 0.6 because 12.6 = 3*4 + 0.6
- mod(-12.6 ; 3) = -0.6 bacause -12.6 = 3*(-4) + (-0.6)
- mod( 12.6 ; -3) = 0.6
- mod(-12.6 ; -3) = -0.6
+ samples:
+ - mod( 12.6 ; 3) = 0.6 because 12.6 = 3*4 + 0.6
+ - mod(-12.6 ; 3) = -0.6 bacause -12.6 = 3*(-4) + (-0.6)
+ - mod( 12.6 ; -3) = 0.6
+ - mod(-12.6 ; -3) = -0.6
ValueType Mod(ValueType a, const ValueType & b, ErrorCode * err = 0)
@@ -2186,7 +2199,8 @@ namespace ttmath
this function is used to store factorials in a given container
'more' means how many values should be added at the end
- e.g.
+ sample:
std::vector<ValueType> fact;
SetFactorialSequence(fact, 3);
// now the container has three values: 1 1 2
@@ -2221,7 +2235,8 @@ namespace ttmath
an auxiliary function used to calculate Bernoulli numbers
this function returns a sum:
- sum(m) = sum_{k=0}^{m-1} {2^k * (m k) * B(k)} k in [0, m-1] (m k) means binomial coefficient = (m! / (k! * (m-k)!))
+ sum(m) = sum_{k=0}^{m-1} {2^k * (m k) * B(k)} k in [0, m-1] (m k) means binomial coefficient = (m! / (k! * (m-k)!))
you should have sufficient factorials in cgamma.fact
(cgamma.fact should have at least m items)
@@ -2275,9 +2290,10 @@ namespace ttmath
start is >= 2
- we use the recurrence formula:
- B(m) = 1 / (2*(1 - 2^m)) * sum(m)
- where sum(m) is calculated by SetBernoulliNumbersSum()
+ we use the recurrence formula:
+ B(m) = 1 / (2*(1 - 2^m)) * sum(m)
+ where sum(m) is calculated by SetBernoulliNumbersSum()
bool SetBernoulliNumbersMore(CGamma<ValueType> & cgamma, uint start, const volatile StopCalculating * stop = 0)
@@ -2330,7 +2346,8 @@ namespace ttmath
returns false if there was a stop signal,
- e.g.
+ sample:
typedef Big<1,2> MyBig;
CGamma<MyBig> cgamma;
SetBernoulliNumbers(cgamma, 3);
@@ -2377,9 +2394,11 @@ namespace ttmath
an auxiliary function used to calculate the Gamma() function
we calculate a sum:
sum(n) = sum_{m=2} { B(m) / ( (m^2 - m) * n^(m-1) ) } = 1/(12*n) - 1/(360*n^3) + 1/(1260*n^5) + ...
- B(m) means a mth Bernoulli number
- the sum starts from m=2, we calculate as long as the value will not change after adding a next part
+ B(m) means a mth Bernoulli number
+ the sum starts from m=2, we calculate as long as the value will not change after adding a next part
ValueType GammaFactorialHighSum(const ValueType & n, CGamma<ValueType> & cgamma, ErrorCode & err,
@@ -2440,9 +2459,11 @@ namespace ttmath
we calculate a helper function GammaFactorialHigh() by using Stirling's series:
- n! = (n/e)^n * sqrt(2*pi*n) * exp( sum(n) )
- where n is a real number (not only an integer) and is sufficient large (greater than TTMATH_GAMMA_BOUNDARY)
- and sum(n) is calculated by GammaFactorialHighSum()
+ n! = (n/e)^n * sqrt(2*pi*n) * exp( sum(n) )
+ where n is a real number (not only an integer) and is sufficient large (greater than TTMATH_GAMMA_BOUNDARY)
+ and sum(n) is calculated by GammaFactorialHighSum()
ValueType GammaFactorialHigh(const ValueType & n, CGamma<ValueType> & cgamma, ErrorCode & err,
@@ -2494,7 +2515,8 @@ namespace ttmath
we use this function when n is integer and a small value (from 0 to TTMATH_GAMMA_BOUNDARY]
we use the formula:
- gamma(n) = (n-1)! = 1 * 2 * 3 * ... * (n-1)
+ gamma(n) = (n-1)! = 1 * 2 * 3 * ... * (n-1)
ValueType GammaPlusLowIntegerInt(uint n, CGamma<ValueType> & cgamma)
@@ -2545,11 +2567,12 @@ namespace ttmath
we use this function when n is a small value (from 0 to TTMATH_GAMMA_BOUNDARY]
we use a recurrence formula:
gamma(z+1) = z * gamma(z)
then: gamma(z) = gamma(z+1) / z
- e.g.
- gamma(3.89) = gamma(2001.89) / ( 3.89 * 4.89 * 5.89 * ... * 1999.89 * 2000.89 )
+ samples:
+ - gamma(3.89) = gamma(2001.89) / ( 3.89 * 4.89 * 5.89 * ... * 1999.89 * 2000.89 )
ValueType GammaPlusLow(ValueType n, CGamma<ValueType> & cgamma, ErrorCode & err, const volatile StopCalculating * stop)
@@ -2640,11 +2663,13 @@ namespace ttmath
it's multithread safe, you should create a CGamma<> object and use it whenever you call the Gamma()
e.g.
MyBig x=234, y=345.53;
std::cout << Gamma(x, cgamma) << std::endl;
std::cout << Gamma(y, cgamma) << std::endl;
in the CGamma<> object the function stores some coefficients (factorials, Bernoulli numbers),
and they will be reused in next calls to the function
@@ -2768,11 +2793,13 @@ namespace ttmath
it's multithread safe, you should create a CGamma<> object and use it whenever you call the Factorial()
e.g.
MyBig x=234, y=54345;
std::cout << Factorial(x, cgamma) << std::endl;
std::cout << Factorial(y, cgamma) << std::endl;
diff --git a/include/geos/algorithm/ttmath/ttmathbig.h b/include/geos/algorithm/ttmath/ttmathbig.h
index 45793b4..1425c71 100644
--- a/include/geos/algorithm/ttmath/ttmathbig.h
+++ b/include/geos/algorithm/ttmath/ttmathbig.h
@@ -1,11 +1,11 @@
@@ -66,19 +66,19 @@ class Big
value = mantissa * 2^exponent
- exponent - an integer value with a sign
- mantissa - an integer value without a sing
+ - exponent - an integer value with a sign
+ - mantissa - an integer value without a sing
mantissa must be pushed into the left side that is the highest bit from
mantissa must be one (of course if there's another value than zero) -- this job
- (pushing bits into the left side) making Standardizing() method
+ (pushing bits into the left side) is doing by Standardizing() method
for example:
if we want to store value one (1) into our Big object we must:
- set mantissa to 1
- set exponent to 0
- set info to 0
- and call method Standardizing()
+ - set mantissa to 1
+ - set exponent to 0
+ - set info to 0
+ - and call method Standardizing()
@@ -135,12 +135,12 @@ public:
returning the string represents the currect type of the library
we have following types:
- asm_vc_32 - with asm code designed for Microsoft Visual C++ (32 bits)
- asm_gcc_32 - with asm code designed for GCC (32 bits)
- asm_vc_64 - with asm for VC (64 bit)
- asm_gcc_64 - with asm for GCC (64 bit)
- no_asm_32 - pure C++ version (32 bit) - without any asm code
- no_asm_64 - pure C++ version (64 bit) - without any asm code
+ - asm_vc_32 - with asm code designed for Microsoft Visual C++ (32 bits)
+ - asm_gcc_32 - with asm code designed for GCC (32 bits)
+ - asm_vc_64 - with asm for VC (64 bit)
+ - asm_gcc_64 - with asm for GCC (64 bit)
+ - no_asm_32 - pure C++ version (32 bit) - without any asm code
+ - no_asm_64 - pure C++ version (64 bit) - without any asm code
static const char * LibTypeStr()
@@ -392,6 +392,8 @@ public:
void SetPi()
+ // IMPROVE ME
+ // give some compiler-time warning when the size of mantissa is greater than the builtin size of the mantissa pi
SetMantissaPi();
info = 0;
exponent = -sint(man)*sint(TTMATH_BITS_PER_UINT) + 2;
@@ -403,6 +405,8 @@ public:
void Set05Pi()
+ // IMPROVE ME
SetMantissaPi();
info = 0;
exponent = -sint(man)*sint(TTMATH_BITS_PER_UINT) + 1;
@@ -414,6 +418,8 @@ public:
void Set2Pi()
+ // IMPROVE ME
SetMantissaPi();
info = 0;
exponent = -sint(man)*sint(TTMATH_BITS_PER_UINT) + 3;
@@ -669,9 +675,9 @@ public:
this method clears the sign
(there'll be an absolute value)
- e.g.
- -1 -> 1
- 2 -> 2
+ samples
+ - -1 -> 1
+ - 2 -> 2
void Abs()
@@ -681,9 +687,11 @@ public:
this method remains the 'sign' of the value
- e.g. -2 = -1
- 0 = 0
- 10 = 1
+ samples
+ - -2 = -1
+ - 0 = 0
+ - 10 = 1
void Sgn()
@@ -708,9 +716,9 @@ public:
this method sets the sign
- e.g.
- -1 -> -1
- 2 -> -2
+ samples
+ - -1 -> -1
+ - 2 -> -2
we do not check whether there is a zero or not, if you're using this method
you must be sure that the value is (or will be afterwards) different from zero
@@ -725,9 +733,9 @@ public:
this method changes the sign
when there is a value of zero then the sign is not changed
- e.g.
- -1 -> 1
- 2 -> -2
+ samples
+ - -1 -> 1
+ - 2 -> -2
void ChangeSign()
@@ -750,8 +758,8 @@ private:
this method does the half-to-even rounding (banker's rounding)
if is_half is:
- true - that means the rest was equal the half (0.5 decimal)
- false - that means the rest was greater than a half (greater than 0.5 decimal)
+ - true - that means the rest was equal the half (0.5 decimal)
+ - false - that means the rest was greater than a half (greater than 0.5 decimal)
if the rest was less than a half then don't call this method
(the rounding should does nothing then)
@@ -977,10 +985,11 @@ public:
bitwise AND
this and ss2 must be >= 0
return values:
- 0 - ok
- 1 - carry
- 2 - this or ss2 was negative
+ - 0 - ok
+ - 1 - carry
+ - 2 - this or ss2 was negative
uint BitAnd(Big<exp, man> ss2)
@@ -1036,9 +1045,10 @@ public:
return values:
- 0 - ok
- 1 - carry
+ - 0 - ok
+ - 1 - carry
uint BitOr(Big<exp, man> ss2)
@@ -1091,9 +1101,10 @@ public:
return values:
- 0 - ok
- 1 - carry
+ - 0 - ok
+ - 1 - carry
uint BitXor(Big<exp, man> ss2)
@@ -1244,8 +1255,8 @@ private:
call this method only if the highest bit is set - you have to test it beforehand
return:
- true - tab was equal the half (0.5 decimal)
- false - tab was greater than a half (greater than 0.5 decimal)
+ - true - tab was equal the half (0.5 decimal)
+ - false - tab was greater than a half (greater than 0.5 decimal)
bool CheckGreaterOrEqualHalf(uint * tab, uint len)
@@ -1361,9 +1372,9 @@ private:
division this = this / ss2
return value:
- 0 - ok
- 1 - carry (in a division carry can be as well)
- 2 - improper argument (ss2 is zero)
+ - 0 - ok
+ - 1 - carry (in a division carry can be as well)
+ - 2 - improper argument (ss2 is zero)
uint DivRef(const Big<exp, man> & ss2, bool round = true)
@@ -1434,9 +1445,9 @@ public:
return value:
- 0 - ok
+ - 0 - ok
uint Div(const Big<exp, man> & ss2, bool round = true)
@@ -1492,21 +1503,20 @@ private:
public:
- the remainder from a division
+ caltulate the remainder from a division
- e.g.
- 12.6 mod 3 = 0.6 because 12.6 = 3*4 + 0.6
- -12.6 mod 3 = -0.6 bacause -12.6 = 3*(-4) + (-0.6)
- 12.6 mod -3 = 0.6
- -12.6 mod -3 = -0.6
+ samples
+ - 12.6 mod 3 = 0.6 because 12.6 = 3*4 + 0.6
+ - -12.6 mod 3 = -0.6 bacause -12.6 = 3*(-4) + (-0.6)
+ - 12.6 mod -3 = 0.6
+ - -12.6 mod -3 = -0.6
- it means:
in other words: this(old) = ss2 * q + this(new)
return value:
- 0 - ok
- 1 - carry
+ - 0 - ok
+ - 1 - carry
uint Mod(const Big<exp, man> & ss2)
@@ -1548,9 +1558,9 @@ public:
binary algorithm (r-to-l)
return values:
- 0 - ok
- 1 - carry
- 2 - incorrect arguments (0^0)
+ - 0 - ok
+ - 1 - carry
+ - 2 - incorrect arguments (0^0)
template<uint pow_size>
uint Pow(UInt<pow_size> pow)
@@ -1600,9 +1610,9 @@ public:
p can be negative
return values:
- 0 - ok
- 1 - carry
- 2 - incorrect arguments 0^0 or 0^(-something)
+ - 0 - ok
+ - 1 - carry
+ - 2 - incorrect arguments 0^0 or 0^(-something)
uint Pow(Int<pow_size> pow)
@@ -1640,9 +1650,9 @@ public:
if pow has a fraction the fraction is skipped (not used in calculation)
return values:
- 0 - ok
- 1 - carry
+ - 0 - ok
+ - 1 - carry
uint PowUInt(Big<exp, man> pow)
@@ -1696,9 +1706,9 @@ public:
pow can be negative
return values:
- 0 - ok
- 1 - carry
+ - 0 - ok
+ - 1 - carry
uint PowInt(const Big<exp, man> & pow)
@@ -1732,9 +1742,9 @@ public:
pow can be negative and with fraction
return values:
- 0 - ok
- 1 - carry
- 2 - incorrect argument ('this' <= 0)
+ - 0 - ok
+ - 1 - carry
+ - 2 - incorrect argument ('this' <= 0)
uint PowFrac(const Big<exp, man> & pow)
@@ -1762,9 +1772,9 @@ public:
return values:
- 0 - ok
- 1 - carry
- 2 - incorrect argument ('this' or 'pow')
+ - 0 - ok
+ - 1 - carry
+ - 2 - incorrect argument ('this' or 'pow')
uint Pow(const Big<exp, man> & pow)
@@ -1799,9 +1809,10 @@ public:
this function calculates the square root
e.g. let this=9 then this.Sqrt() gives 3
- return: 0 - ok
- 1 - carry
- 2 - improper argument (this<0 or NaN)
+ return:
+ - 0 - ok
+ - 1 - carry
+ - 2 - improper argument (this<0 or NaN)
uint Sqrt()
@@ -1924,8 +1935,11 @@ public:
Exponent this = exp(x) = e^x
we're using the fact that our value is stored in form of:
x = mantissa * 2^exponent
then
e^x = e^(mantissa* 2^exponent) or
e^x = (e^mantissa)^(2^exponent)
@@ -2094,17 +2108,20 @@ public:
(a logarithm with the base equal 'e')
then
ln(x) = ln (mantissa * 2^exponent) = ln (mantissa) + (exponent * ln (2))
the mantissa we'll show as a value from range <1,2) because the logarithm
is decreasing too fast when 'x' is going to 0
return values:
- 0 - ok
- 1 - overflow (carry)
- 2 - incorrect argument (x<=0)
+ - 0 - ok
+ - 1 - overflow (carry)
+ - 2 - incorrect argument (x<=0)
uint Ln(const Big<exp,man> & x)
@@ -2142,13 +2159,14 @@ public:
Logarithm from 'x' with a 'base'
we're using the formula:
Log(x) with 'base' = ln(x) / ln(base)
return values:
- 0 - ok
- 1 - overflow
- 3 - incorrect base (a<=0 lub a=1)
+ - 0 - ok
+ - 1 - overflow
+ - 3 - incorrect base (a<=0 or a=1)
uint Log(const Big<exp,man> & x, const Big<exp,man> & base)
@@ -2565,21 +2583,21 @@ public:
right. The first bit is the sign bit, S, the next eleven bits are the
exponent bits, 'E', and the final 52 bits are the fraction 'F':
- S EEEEEEEEEEE FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
- 0 1 11 12 63
+ S EEEEEEEEEEE FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
+ 0 1 11 12 63
The value V represented by the word may be determined as follows:
- * If E=2047 and F is nonzero, then V=NaN ("Not a number")
- * If E=2047 and F is zero and S is 1, then V=-Infinity
- * If E=2047 and F is zero and S is 0, then V=Infinity
- * If 0<E<2047 then V=(-1)**S * 2 ** (E-1023) * (1.F) where "1.F" is intended
+ - If E=2047 and F is nonzero, then V=NaN ("Not a number")
+ - If E=2047 and F is zero and S is 1, then V=-Infinity
+ - If E=2047 and F is zero and S is 0, then V=Infinity
+ - If 0<E<2047 then V=(-1)**S * 2 ** (E-1023) * (1.F) where "1.F" is intended
to represent the binary number created by prefixing F with an implicit
leading 1 and a binary point.
- * If E=0 and F is nonzero, then V=(-1)**S * 2 ** (-1022) * (0.F) These are
+ - If E=0 and F is nonzero, then V=(-1)**S * 2 ** (-1022) * (0.F) These are
"unnormalized" values.
- * If E=0 and F is zero and S is 1, then V=-0
- * If E=0 and F is zero and S is 0, then V=0
+ - If E=0 and F is zero and S is 1, then V=-0
+ - If E=0 and F is zero and S is 0, then V=0
#ifdef TTMATH_PLATFORM32
@@ -2805,6 +2823,7 @@ public:
if the value is too big:
'result' will be +/-infinity (depending on the sign)
if the value is too small:
'result' will be 0
@@ -2832,22 +2851,23 @@ private:
The first bit is the sign bit, S, the next eight bits are the exponent bits, 'E',
and the final 23 bits are the fraction 'F':
- S EEEEEEEE FFFFFFFFFFFFFFFFFFFFFFF
- 0 1 8 9 31
+ S EEEEEEEE FFFFFFFFFFFFFFFFFFFFFFF
+ 0 1 8 9 31
- * If E=255 and F is nonzero, then V=NaN ("Not a number")
- * If E=255 and F is zero and S is 1, then V=-Infinity
- * If E=255 and F is zero and S is 0, then V=Infinity
- * If 0<E<255 then V=(-1)**S * 2 ** (E-127) * (1.F) where "1.F" is intended to represent
- the binary number created by prefixing F with an implicit leading 1 and a binary point.
- * If E=0 and F is nonzero, then V=(-1)**S * 2 ** (-126) * (0.F) These are "unnormalized" values.
+ - If E=255 and F is nonzero, then V=NaN ("Not a number")
+ - If E=255 and F is zero and S is 1, then V=-Infinity
+ - If E=255 and F is zero and S is 0, then V=Infinity
+ - If 0<E<255 then V=(-1)**S * 2 ** (E-127) * (1.F) where "1.F" is intended to represent
+ the binary number created by prefixing F with an implicit leading 1 and a binary point.
+ - If E=0 and F is nonzero, then V=(-1)**S * 2 ** (-126) * (0.F) These are "unnormalized" values.
bool IsInf(float value) const
+ // CHECK ME
// need testing on a 64 bit machine
union
@@ -2875,6 +2895,7 @@ public:
'result' will be 0
@@ -2892,11 +2913,12 @@ public:
this method converts from this class into the 'float'
- 'result' will be +/-infinity (depending on the sign)
- and the method returns 1
+ - 'result' will be +/-infinity (depending on the sign)
+ - and the method returns 1
- 'result' will be 0
+ - 'result' will be 0
uint ToFloat(float & result) const
@@ -2929,11 +2951,12 @@ public:
this method converts from this class into the 'double'
uint ToDouble(double & result) const
@@ -3666,11 +3689,10 @@ public:
a method for converting into a string
struct Conv is defined in ttmathtypes.h, look there for more information about parameters
- output:
- return value:
- 0 - ok and 'result' will be an object of type std::string (or std::wstring) which holds the value
- 1 - if there is a carry (it shoudn't be in a normal situation - if it is that means there
- is somewhere an error in the library)
+ return value:
+ - 0 - ok and 'result' will be an object of type std::string (or std::wstring) which holds the value
+ - 1 - if there is a carry (it shoudn't be in a normal situation - if it is that means there
+ is somewhere an error in the library)
uint ToString( std::string & result,
uint base = 10,
@@ -4215,10 +4237,12 @@ private:
if( exponent <= -sint(man*TTMATH_BITS_PER_UINT) )
// if 'exponent' is <= than '-sint(man*TTMATH_BITS_PER_UINT)'
// it means that we must cut the whole mantissa
// (there'll not be any of the valid bits)
return 1;
// e will be from (-man*TTMATH_BITS_PER_UINT, 0>
sint e = -( exponent.ToInt() );
@@ -4265,9 +4289,9 @@ private:
a special method used to calculate the new mantissa and exponent
when the 'base' is equal 4, 8 or 16
- when base is 4 then bits is 2
- when base is 8 then bits is 3
- when base is 16 then bits is 4
+ - when base is 4 then bits is 2
+ - when base is 8 then bits is 3
+ - when base is 16 then bits is 4
(and the algorithm can be used with a base greater than 16)
template<class string_type>
@@ -5151,7 +5175,10 @@ private:
// we could break the parsing somewhere in the middle of the string,
// but the result (value) still can be good
// we should set a correct value of 'source' now
- for( ; Misc::CharToDigit(*source, conv.base) != -1 ; ++source );
+ while( Misc::CharToDigit(*source, conv.base) != -1 )
+ ++source;
power_ = power;
c += base_.Pow(power_);
@@ -5384,8 +5411,10 @@ public:
if( ss2.IsZero() )
// this!=0 and ss2==0
return false;
// we're using the fact that all bits in mantissa are pushed
// into the left side -- Standardizing()
@@ -5408,16 +5437,22 @@ public:
if( IsZero() )
if( ss2.IsZero() )
// we've got two zeroes
return false;
else
// this==0 and ss2!=0
return false;
if( ss2.IsZero() )
return true;
@@ -5440,16 +5475,22 @@ public:
if( IsZero() )
if( ss2.IsZero() )
return true;
else
return false;
if( ss2.IsZero() )
return false;
if( exponent==ss2.exponent && mantissa==ss2.mantissa )
return true;
@@ -5461,12 +5502,16 @@ public:
bool operator<(const Big<exp,man> & ss2) const
if( IsSign() && !ss2.IsSign() )
// this<0 and ss2>=0
return true;
if( !IsSign() && ss2.IsSign() )
// this>=0 and ss2<0
return false;
// both signs are the same
@@ -5489,12 +5534,16 @@ public:
bool operator>(const Big<exp,man> & ss2) const
return false;
return true;
@@ -5730,13 +5779,13 @@ public:
this method makes an integer value by skipping any fractions
- for example:
- 10.7 will be 10
- 12.1 -- 12
- -20.2 -- 20
- -20.9 -- 20
- -0.7 -- 0
- 0.8 -- 0
+ samples:
+ - 10.7 will be 10
+ - 12.1 -- 12
+ - -20.2 -- 20
+ - -20.9 -- 20
+ - -0.7 -- 0
+ - 0.8 -- 0
void SkipFraction()
@@ -5768,9 +5817,9 @@ public:
this method remains only a fraction from the value
- for example:
- 30.56 will be 0.56
- -12.67 -- -0.67
+ samples:
+ - 30.56 will be 0.56
+ - -12.67 will be -0.67
void RemainFraction()
@@ -5811,7 +5860,7 @@ public:
this method returns true if the value is integer
(there is no a fraction)
- (we don't check nan)
+ (we don't check NaN)
bool IsInteger() const
@@ -5853,12 +5902,11 @@ public:
this method rounds to the nearest integer value
(it returns a carry if it was)
- for example:
- 2.3 = 2
- 2.8 = 3
- -2.3 = -2
- -2.8 = 3
+ samples:
+ - 2.3 = 2
+ - 2.8 = 3
+ - -2.3 = -2
+ - -2.8 = 3
uint Round()
diff --git a/include/geos/algorithm/ttmath/ttmathdec.h b/include/geos/algorithm/ttmath/ttmathdec.h
index 92d3e39..ec2c753 100644
--- a/include/geos/algorithm/ttmath/ttmathdec.h
+++ b/include/geos/algorithm/ttmath/ttmathdec.h
@@ -1,6 +1,6 @@
diff --git a/include/geos/algorithm/ttmath/ttmathint.h b/include/geos/algorithm/ttmath/ttmathint.h
index ad306f0..7188184 100644
--- a/include/geos/algorithm/ttmath/ttmathint.h
+++ b/include/geos/algorithm/ttmath/ttmathint.h
@@ -1,11 +1,11 @@
- * Copyright (c) 2006-2011, Tomasz Sowa
@@ -55,8 +55,8 @@ namespace ttmath
\brief Int implements a big integer value with a sign
value_size - how many bytes specify our value
- on 32bit platforms: value_size=1 -> 4 bytes -> 32 bits
- on 64bit platforms: value_size=1 -> 8 bytes -> 64 bits
+ - on 32bit platforms: value_size=1 -> 4 bytes -> 32 bits
+ - on 64bit platforms: value_size=1 -> 8 bytes -> 64 bits
value_size = 1,2,3,4,5,6....
template<uint value_size>
@@ -131,8 +131,9 @@ public:
- e.g. 1 -> -1
- -2 -> -2
+ samples
+ - 1 -> -1
+ - -2 -> -2
from a positive value we make a negative value,
if the value is negative we do nothing
@@ -290,10 +291,10 @@ public:
this = p1(=this) - p2
- when p1>=0 i p2>=0 carry will never be set
- when p1<0 i p2<0 carry will never be set
- when p1>=0 i p2<0 carry is set when the highest bit of value is set
- when p1<0 i p2>=0 carry is set when the highest bit of value is clear
+ - when p1>=0 i p2>=0 carry will never be set
+ - when p1<0 i p2<0 carry will never be set
+ - when p1>=0 i p2<0 carry is set when the highest bit of value is set
+ - when p1<0 i p2>=0 carry is set when the highest bit of value is clear
uint Sub(const Int<value_size> & ss2)
@@ -465,14 +466,14 @@ public:
returned values:
- 0 - ok
- 1 - division by zero
+ - 0 - ok
+ - 1 - division by zero
for example: (result means 'this')
- 20 / 3 --> result: 6 remainder: 2
- -20 / 3 --> result: -6 remainder: -2
- 20 / -3 --> result: -6 remainder: 2
- -20 / -3 --> result: 6 remainder: -2
+ - 20 / 3 --> result: 6 remainder: 2
+ - -20 / 3 --> result: -6 remainder: -2
+ - 20 / -3 --> result: -6 remainder: 2
+ - -20 / -3 --> result: 6 remainder: -2
in other words: this(old) = ss2 * this(new)(result) + remainder
@@ -509,14 +510,14 @@ public:
division this = this / ss2 (ss2 is int)
returned values:
- 0 - ok
+ - 0 - ok
@@ -600,9 +601,9 @@ public:
power this = this ^ pow
return values:
- 0 - ok
- 1 - carry
+ - 0 - ok
+ - 1 - carry
uint Pow(Int<value_size> pow)
@@ -812,7 +813,7 @@ public:
a copy constructor
- Int(const Int<value_size> & u)
+ Int(const Int<value_size> & u) : UInt<value_size>()
FromInt(u);
diff --git a/include/geos/algorithm/ttmath/ttmathmisc.h b/include/geos/algorithm/ttmath/ttmathmisc.h
index 330a43a..c9e1560 100644
--- a/include/geos/algorithm/ttmath/ttmathmisc.h
+++ b/include/geos/algorithm/ttmath/ttmathmisc.h
@@ -1,6 +1,6 @@
@@ -171,10 +171,10 @@ static void SkipWhiteCharacters(const char_type * & c)
this static method converts one character into its value
for example:
- 1 -> 1
- 8 -> 8
- A -> 10
- f -> 15
+ - 1 -> 1
+ - 8 -> 8
+ - A -> 10
+ - f -> 15
this method don't check whether c is correct or not
@@ -195,9 +195,9 @@ return c-'A'+10;
(if there can't be a correct value it returns -1)
for example:
- c=2, base=10 -> function returns 2
- c=A, base=10 -> function returns -1
- c=A, base=16 -> function returns 10
+ - c=2, base=10 -> function returns 2
+ - c=A, base=10 -> function returns -1
+ - c=A, base=16 -> function returns 10
static sint CharToDigit(uint c, uint base)
@@ -228,10 +228,10 @@ return sint(c);
(we don't have to get a base)
for example:
- 1 -> 1
- 8 -> 8
- 10 -> A
- 15 -> F
+ - 1 -> 1
+ - 8 -> 8
+ - 10 -> A
+ - 15 -> F
static uint DigitToChar(uint digit)
diff --git a/include/geos/algorithm/ttmath/ttmathobjects.h b/include/geos/algorithm/ttmath/ttmathobjects.h
index c35026b..2902c9a 100644
--- a/include/geos/algorithm/ttmath/ttmathobjects.h
+++ b/include/geos/algorithm/ttmath/ttmathobjects.h
@@ -1,11 +1,11 @@
* This file is a part of TTMath Mathematical Library
- * Copyright (c) 2006-2010, Tomasz Sowa
@@ -81,7 +81,7 @@ public:
// (if there's a variable this 'param' is ignored)
int param;
- Item() {}
+ Item() { param = 0; }
Item(const std::string & v, int p) : value(v), param(p) {}
@@ -484,7 +484,7 @@ public:
if( i == table.end() )
- value.empty();
+ value.clear();
*param = 0;
return err_unknown_object;
@@ -723,14 +723,17 @@ public:
in multithreaded environment you can provide an object of this class to
the Gamma() or Factorial() function, e.g;
typedef Big<1, 3> MyBig;
MyBig x = 123456;
std::cout << Gamma(x, cgamma);
each thread should have its own CGamma<> object
in a single-thread environment a CGamma<> object is a static variable
- in a second version of Gamma() and you don't have to explicitly use it, e.g.
+ and you don't have to explicitly use it, e.g.
MyBig x = 123456;
std::cout << Gamma(x);
diff --git a/include/geos/algorithm/ttmath/ttmathparser.h b/include/geos/algorithm/ttmath/ttmathparser.h
index ce07120..d9b7ce7 100644
--- a/include/geos/algorithm/ttmath/ttmathparser.h
+++ b/include/geos/algorithm/ttmath/ttmathparser.h
@@ -1,11 +1,11 @@
@@ -1781,7 +1781,7 @@ Conv conv;
this method returns true if 'character' is a proper first digit for the value (or a comma -- can be first too)
-bool ValueStarts(int character, int base)
+bool ValueStarts(int character, int character_base)
if( character == comma )
return true;
@@ -1789,7 +1789,7 @@ bool ValueStarts(int character, int base)
if( comma2!=0 && character==comma2 )
return true;
- if( Misc::CharToDigit(character, base) != -1 )
+ if( Misc::CharToDigit(character, character_base) != -1 )
return true;
return false;
@@ -1975,7 +1975,7 @@ typename OperatorsTable::iterator iter_old, iter_new;
if( iter_new == operators_table.end() || !IsSubstring(iter_new->first, oper) )
- oper.erase( --oper.end() ); // we've got mininum one element
+ oper.erase(oper.begin() + oper.size() - 1); // we've got mininum one element
if( iter_old != operators_table.end() && iter_old->first == oper )
@@ -2604,7 +2604,7 @@ void SetBase(int b)
void SetDegRadGrad(int angle)
- if( angle >= 0 || angle <= 2 )
+ if( angle >= 0 && angle <= 2 )
deg_rad_grad = angle;
diff --git a/include/geos/algorithm/ttmath/ttmaththreads.h b/include/geos/algorithm/ttmath/ttmaththreads.h
index 586227f..57c3650 100644
--- a/include/geos/algorithm/ttmath/ttmaththreads.h
+++ b/include/geos/algorithm/ttmath/ttmaththreads.h
@@ -1,6 +1,6 @@
@@ -59,24 +59,6 @@
- this is a simple skeleton of a program in multithreads environment:
- #define TTMATH_MULTITHREADS
- #include<ttmath/ttmath.h>
- TTMATH_MULTITHREADS_HELPER
- int main()
- make sure that macro TTMATH_MULTITHREADS is defined and (somewhere in *.cpp file)
- use TTMATH_MULTITHREADS_HELPER macro (outside of any classes/functions/namespaces scope)
namespace ttmath
@@ -186,12 +168,32 @@ namespace ttmath
- objects of this class are used to synchronize
+ \brief objects of this class are used to synchronize
+ this is a simple skeleton of a program in multithreads environment:
+ #define TTMATH_MULTITHREADS
+ #include<ttmath/ttmath.h>
+ TTMATH_MULTITHREADS_HELPER
+ int main()
+ make sure that macro TTMATH_MULTITHREADS is defined and (somewhere in *.cpp file)
+ use TTMATH_MULTITHREADS_HELPER macro (outside of any classes/functions/namespaces scope)
class ThreadLock
public:
+ lock the current thread
+ it uses a global mutex created by TTMATH_MULTITHREADS_HELPER macro
bool Lock()
if( pthread_mutex_lock(&ttmath_mutex) != 0 )
diff --git a/include/geos/algorithm/ttmath/ttmathtypes.h b/include/geos/algorithm/ttmath/ttmathtypes.h
index 3d9ddbe..56a06b6 100644
--- a/include/geos/algorithm/ttmath/ttmathtypes.h
+++ b/include/geos/algorithm/ttmath/ttmathtypes.h
@@ -1,11 +1,11 @@
@@ -64,17 +64,42 @@
- the version of the library
+ the major version of the library
- TTMATH_PRERELEASE_VER is either zero or one
- zero means that this is the release version of the library
- (one means something like beta)
+ the version present to the end user is constructed in this way:
+ TTMATH_MAJOR_VER.TTMATH_MINOR_VER.TTMATH_REVISION_VER.[prerelease if TTMATH_PRERELEASE_VER==1]
#define TTMATH_MAJOR_VER 0
+ the minor version of the library
#define TTMATH_MINOR_VER 9
-#define TTMATH_REVISION_VER 3
-#define TTMATH_PRERELEASE_VER 0
+ the revision version of the library
+#define TTMATH_REVISION_VER 4
+ TTMATH_PRERELEASE_VER is either zero or one
+ zero means that this is the release version of the library
+ (one means something like beta)
+#define TTMATH_PRERELEASE_VER 1
@@ -202,15 +227,19 @@ namespace ttmath
#else
- on 64bit platforms one word (uint, sint) will be equal 64bits
#ifdef _MSC_VER
/* in VC 'long' type has 32 bits, __int64 is VC extension */
typedef unsigned __int64 uint;
typedef signed __int64 sint;
#else
+ on 64bit platforms one word (uint, sint) will be equal 64bits
typedef unsigned long uint;
typedef signed long sint;
#endif
@@ -317,12 +346,12 @@ namespace ttmath
lib type codes:
enum LibTypeCode
@@ -407,10 +436,11 @@ namespace ttmath
default: true
e.g.
- Conv c;
- c.base_round = false;
- Big<1, 1> a = "0.1"; // decimal input
- std::cout << a.ToString(c) << std::endl; // the result is: 0.099999999
+ Conv c;
+ c.base_round = false;
+ Big<1, 1> a = "0.1"; // decimal input
+ std::cout << a.ToString(c) << std::endl; // the result is: 0.099999999
bool base_round;
diff --git a/include/geos/algorithm/ttmath/ttmathuint.h b/include/geos/algorithm/ttmath/ttmathuint.h
index d00a0d7..9b64745 100644
--- a/include/geos/algorithm/ttmath/ttmathuint.h
+++ b/include/geos/algorithm/ttmath/ttmathuint.h
@@ -1,11 +1,11 @@
@@ -65,8 +65,8 @@ namespace ttmath
\brief UInt implements a big integer value without a sign
@@ -637,13 +637,13 @@ public:
this method looks for the highest set bit
result:
- if 'this' is not zero:
- return value - true
- 'table_id' - the index of a word <0..value_size-1>
+ - if 'this' is not zero:
+ return value - true,
+ 'table_id' - the index of a word <0..value_size-1>,
'index' - the index of this set bit in the word <0..TTMATH_BITS_PER_UINT)
- if 'this' is zero:
- return value - false
+ - if 'this' is zero:
+ return value - false,
both 'table_id' and 'index' are zero
bool FindLeadingBit(uint & table_id, uint & index) const
@@ -669,13 +669,13 @@ public:
this method looks for the smallest set bit
result:
bool FindLowestBit(uint & table_id, uint & index) const
@@ -955,17 +955,20 @@ public:
switch( algorithm )
case 1:
- return Mul1Big(ss2, result);
+ Mul1Big(ss2, result);
+ break;
case 2:
- return Mul2Big(ss2, result);
+ Mul2Big(ss2, result);
+ break;
case 3:
- return Mul3Big(ss2, result);
+ Mul3Big(ss2, result);
+ break;
case 100:
default:
- return MulFastestBig(ss2, result);
+ MulFastestBig(ss2, result);
@@ -1184,17 +1187,23 @@ public:
Karatsuba multiplication:
Assume we have:
this = x = x1*B^m + x0
ss2 = y = y1*B^m + y0
where x0 and y0 are less than B^m
the product from multiplication we can show as:
x*y = (x1*B^m + x0)(y1*B^m + y0) = z2*B^(2m) + z1*B^m + z0
where
z2 = x1*y1
z1 = x1*y0 + x0*y1
- z0 = x0*y0
+ z0 = x0*y0
this is standard schoolbook algorithm with O(n^2), Karatsuba observed that z1 can be given in other form:
z1 = (x1 + x0)*(y1 + y0) - z2 - z0 / z1 = (x1*y1 + x1*y0 + x0*y1 + x0*y0) - x1*y1 - x0*y0 = x1*y0 + x0*y1 /
and to calculate the multiplication we need only three multiplications (with some additions and subtractions)
Our objects 'this' and 'ss2' we divide into two parts and by using recurrence we calculate the multiplication.
@@ -1313,6 +1322,11 @@ private:
//we have the stop point in Mul3Big2() method
#endif
+#if defined(__GNUC__) && !defined(__clang__)
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Wunused-but-set-variable"
+#endif
an auxiliary method for calculating the Karatsuba multiplication
@@ -1447,6 +1461,9 @@ private:
+#pragma GCC diagnostic pop
+#endif
#ifdef _MSC_VER
#pragma warning (default : 4717)
@@ -1493,7 +1510,10 @@ public:
void MulFastestBig(const UInt<value_size> & ss2, UInt<value_size*2> & result)
if( value_size < TTMATH_USE_KARATSUBA_MULTIPLICATION_FROM_SIZE )
+ return;
uint x1size = value_size, x2size = value_size;
uint x1start = 0, x2start = 0;
@@ -1515,9 +1535,12 @@ public:
uint distancex2 = x2size - x2start;
if( distancex1 < 3 || distancex2 < 3 )
// either 'this' or 'ss2' have only 2 (or 1) items different from zero (side by side)
// (this condition in the future can be improved)
- return Mul2Big3<value_size>(table, ss2.table, result, x1start, x1size, x2start, x2size);
+ Mul2Big3<value_size>(table, ss2.table, result, x1start, x1size, x2start, x2size);
+ return;
// Karatsuba multiplication
@@ -1595,10 +1618,10 @@ public:
return values:
- 0 - ok
- 'this' will be the quotient
- 'remainder' - remainder
+ - 0 - ok
+ - 'this' will be the quotient
+ - 'remainder' - remainder
uint Div( const UInt<value_size> & divisor,
UInt<value_size> * remainder = 0,
@@ -1629,9 +1652,9 @@ private:
return values:
- 0 - none has to be done
- 2 - division should be made
+ - 0 - none has to be done
+ - 2 - division should be made
uint Div_StandardTest( const UInt<value_size> & v,
uint & m, uint & n,
@@ -1677,13 +1700,13 @@ private:
return values:
- 0 - ok
- 'm' - is the index (from 0) of last non-zero word in table ('this')
- 'n' - is the index (from 0) of last non-zero word in v.table
- 1 - v is zero
- 2 - 'this' is zero
- 3 - 'this' is smaller than v
- 4 - 'this' is equal v
+ - 0 - ok
+ - 'm' - is the index (from 0) of last non-zero word in table ('this')
+ - 'n' - is the index (from 0) of last non-zero word in v.table
+ - 1 - v is zero
+ - 2 - 'this' is zero
+ - 3 - 'this' is smaller than v
+ - 4 - 'this' is equal v
if the return value is different than zero the 'm' and 'n' are undefined
@@ -1724,7 +1747,7 @@ public:
the first division algorithm
- radix 2
+ (radix 2)
uint Div1(const UInt<value_size> & divisor, UInt<value_size> * remainder = 0)
@@ -1747,7 +1770,7 @@ public:
- radix 2
+ (radix 2)
uint Div1(const UInt<value_size> & divisor, UInt<value_size> & remainder)
@@ -1833,8 +1856,8 @@ public:
the second division algorithm
return values:
- 0 - ok
+ - 0 - ok
uint Div2(const UInt<value_size> & divisor, UInt<value_size> * remainder = 0)
@@ -1854,8 +1877,8 @@ public:
return values:
- 0 - ok
+ - 0 - ok
uint Div2(const UInt<value_size> & divisor, UInt<value_size> & remainder)
@@ -1869,8 +1892,8 @@ private:
return values:
- 0 - ok
+ - 0 - ok
uint Div2Ref(const UInt<value_size> & divisor, UInt<value_size> * remainder = 0)
@@ -1901,9 +1924,9 @@ private:
return values:
- 0 - we've calculated the division
- 2 - we have to still calculate
+ - 0 - we've calculated the division
+ - 2 - we have to still calculate
uint Div2_Calculate(const UInt<value_size> & divisor, UInt<value_size> * remainder,
@@ -1945,9 +1968,9 @@ private:
return values:
uint Div2_FindLeadingBitsAndCheck( const UInt<value_size> & divisor,
@@ -2014,7 +2037,7 @@ private:
return values:
- true if divisor is equal or greater than 'this'
+ - true if divisor is equal or greater than 'this'
bool Div2_DivisorGreaterOrEqual( const UInt<value_size> & divisor,
@@ -2261,8 +2284,8 @@ private:
the bits from 'this' we're moving the same times as 'v')
return values:
- d - how many times we've moved
- return - the next-left value from 'this' (that after table[value_size-1])
+ - d - how many times we've moved
+ - return - the next-left value from 'this' (that after table[value_size-1])
uint Div3_Normalize(UInt<value_size> & v, uint n, uint & d)
@@ -2395,9 +2418,9 @@ public:
return values:
- 0 - ok
- 1 - carry
- 2 - incorrect argument (0^0)
+ - 0 - ok
+ - 1 - carry
+ - 2 - incorrect argument (0^0)
uint Pow(UInt<value_size> pow)
@@ -2475,6 +2498,7 @@ public:
this method sets n first bits to value zero
@@ -3310,7 +3334,7 @@ public:
if( negative )
result = '-';
- digits_d = table_id; // for not making an overflow in uint type
+ digits_d = static_cast<double>(table_id); // for not making an overflow in uint type
digits_d *= TTMATH_BITS_PER_UINT;
digits_d += index + 1;
digits_d *= ToStringLog2(b);
@@ -4140,7 +4164,7 @@ public:
- this specialization is needed in order to not confused the compiler "error: ISO C++ forbids zero-size array"
+ this specialization is needed in order to not confuse the compiler "error: ISO C++ forbids zero-size array"
when compiling Mul3Big2() method
template<>
diff --git a/include/geos/algorithm/ttmath/ttmathuint_noasm.h b/include/geos/algorithm/ttmath/ttmathuint_noasm.h
index 07c73fc..96ab494 100644
--- a/include/geos/algorithm/ttmath/ttmathuint_noasm.h
+++ b/include/geos/algorithm/ttmath/ttmathuint_noasm.h
@@ -1,6 +1,6 @@
@@ -39,15 +39,16 @@
#define headerfilettmathuint_noasm
-#ifdef TTMATH_NOASM
\file ttmathuint_noasm.h
- \brief template class UInt<uint> with methods without any assembler code
+ \brief template class UInt<uint> with methods without any assembler code (used for no-asm version of ttmath)
this file is included at the end of ttmathuint.h
+#ifdef TTMATH_NOASM
namespace ttmath
@@ -55,12 +56,12 @@ namespace ttmath
const char * UInt<value_size>::LibTypeStr()
@@ -156,12 +157,17 @@ namespace ttmath
and returns a carry (if it was)
if we've got (value_size=3):
table[0] = 10;
table[1] = 30;
- table[2] = 5;
+ table[2] = 5;
and we call:
AddInt(2,1)
then it'll be:
table[0] = 10;
table[1] = 30 + 2;
table[2] = 5;
@@ -199,17 +205,23 @@ namespace ttmath
x1 - lower word, x2 - higher word
for example if we've got value_size equal 4 and:
table[0] = 3
table[1] = 4
table[2] = 5
table[3] = 6
then let
x1 = 10
x2 = 20
and
index = 1
the result of this method will be:
table[0] = 3
table[1] = 4 + x1 = 14
table[2] = 5 + x2 = 25
@@ -245,19 +257,20 @@ namespace ttmath
this static method addes one vector to the other
'ss1' is larger in size or equal to 'ss2'
- ss1 points to the first (larger) vector
- ss2 points to the second vector
- ss1_size - size of the ss1 (and size of the result too)
- ss2_size - size of the ss2
- result - is the result vector (which has size the same as ss1: ss1_size)
- Example: ss1_size is 5, ss2_size is 3
- ss1: ss2: result (output):
- 5 1 5+1
- 4 3 4+3
- 2 7 2+7
- 6 6
- 9 9
+ - ss1 points to the first (larger) vector
+ - ss2 points to the second vector
+ - ss1_size - size of the ss1 (and size of the result too)
+ - ss2_size - size of the ss2
+ - result - is the result vector (which has size the same as ss1: ss1_size)
+ Example: ss1_size is 5, ss2_size is 3
+ ss1: ss2: result (output):
+ 5 1 5+1
+ 4 3 4+3
+ 2 7 2+7
+ 6 6
+ 9 9
of course the carry is propagated and will be returned from the last item
(this method is used by the Karatsuba multiplication algorithm)
@@ -342,12 +355,17 @@ namespace ttmath
table[0] = 10;
table[1] = 30;
table[2] = 5;
and we call:
SubInt(2,1)
then it'll be:
table[0] = 10;
table[1] = 30 - 2;
table[2] = 5;
@@ -377,19 +395,19 @@ namespace ttmath
this static method subtractes one vector from the other
- 5 1 5-1
- 4 3 4-3
- 2 7 2-7
- 6 6-1 (the borrow from previous item)
- 9 9
+ 5 1 5-1
+ 4 3 4-3
+ 2 7 2-7
+ 6 6-1 (the borrow from previous item)
+ 9 9
return (carry): 0
of course the carry (borrow) is propagated and will be returned from the last item
@@ -622,9 +640,11 @@ namespace ttmath
bit is from <0,TTMATH_BITS_PER_UINT-1>
e.g.
- uint x = 100;
- uint bit = SetBitInWord(x, 3);
- now: x = 108 and bit = 0
+ uint x = 100;
+ uint bit = SetBitInWord(x, 3);
+ now: x = 108 and bit = 0
uint UInt<value_size>::SetBitInWord(uint & value, uint bit)
@@ -657,10 +677,11 @@ namespace ttmath
multiplication: result_high:result_low = a * b
- result_high - higher word of the result
- result_low - lower word of the result
+ - result_high - higher word of the result
+ - result_low - lower word of the result
this methos never returns a carry
this method is used in the second version of the multiplication algorithms
diff --git a/include/geos/algorithm/ttmath/ttmathuint_x86.h b/include/geos/algorithm/ttmath/ttmathuint_x86.h
index 1dd087f..811b225 100644
--- a/include/geos/algorithm/ttmath/ttmathuint_x86.h
+++ b/include/geos/algorithm/ttmath/ttmathuint_x86.h
@@ -1,6 +1,6 @@
@@ -35,16 +35,10 @@
* THE POSSIBILITY OF SUCH DAMAGE.
#ifndef headerfilettmathuint_x86
#define headerfilettmathuint_x86
-#ifndef TTMATH_NOASM
-#ifdef TTMATH_PLATFORM32
\file ttmathuint_x86.h
\brief template class UInt<uint> with assembler code for 32bit x86 processors
@@ -53,6 +47,12 @@
+#ifndef TTMATH_NOASM
+#ifdef TTMATH_PLATFORM32
\brief a namespace for the TTMath library
@@ -62,13 +62,14 @@ namespace ttmath
@@ -210,12 +211,17 @@ namespace ttmath
e.g.
table[0] = 10;
table[1] = 30;
- table[2] = 5;
+ table[2] = 5;
and we call:
AddInt(2,1)
then it'll be:
table[0] = 10;
table[1] = 30 + 2;
table[2] = 5;
@@ -314,17 +320,23 @@ namespace ttmath
table[0] = 3
table[1] = 4
table[2] = 5
table[3] = 6
then let
x1 = 10
x2 = 20
and
index = 1
table[0] = 3
@@ -653,12 +665,17 @@ namespace ttmath
e.g.
table[0] = 10;
table[1] = 30;
table[2] = 5;
and we call:
SubInt(2,1)
then it'll be:
table[0] = 10;
table[1] = 30 - 2;
table[2] = 5;
@@ -1405,9 +1422,10 @@ namespace ttmath
bit is from <0,31>
e.g.
- uint x = 100;
+ uint x = 100;
diff --git a/include/geos/algorithm/ttmath/ttmathuint_x86_64.h b/include/geos/algorithm/ttmath/ttmathuint_x86_64.h
index 188fc5e..7ec501d 100644
--- a/include/geos/algorithm/ttmath/ttmathuint_x86_64.h
+++ b/include/geos/algorithm/ttmath/ttmathuint_x86_64.h
@@ -1,6 +1,6 @@
@@ -51,6 +51,21 @@
+ \file ttmathuint_x86_64_msvc.asm
+ \brief some asm routines for x86_64 when using Microsoft compiler
+ this file should be first compiled:
+ - compile with debug info: ml64.exe /c /Zd /Zi ttmathuint_x86_64_msvc.asm
+ - compile without debug info: ml64.exe /c ttmathuint_x86_64_msvc.asm
+ this creates ttmathuint_x86_64_msvc.obj file which can be linked with your program
+ (you can use win64_assemble.bat file from ttmath subdirectory)
#ifndef __GNUC__
#include <intrin.h>
#endif
@@ -195,12 +210,17 @@ namespace ttmath
table[0] = 10;
table[1] = 30;
- table[2] = 5;
+ table[2] = 5;
and we call:
AddInt(2,1)
then it'll be:
table[0] = 10;
table[1] = 30 + 2;
table[2] = 5;
@@ -265,17 +285,23 @@ namespace ttmath
table[0] = 3
table[1] = 4
table[2] = 5
table[3] = 6
then let
x1 = 10
x2 = 20
and
index = 1
table[0] = 3
@@ -341,19 +367,19 @@ namespace ttmath
- 5 1 5+1
- 4 3 4+3
- 2 7 2+7
- 6 6
- 9 9
+ 5 1 5+1
+ 4 3 4+3
+ 2 7 2+7
+ 6 6
+ 9 9
@@ -483,12 +509,17 @@ namespace ttmath
***this method is created only on a 64bit platform***
table[0] = 10;
table[1] = 30;
table[2] = 5;
and we call:
SubInt(2,1)
then it'll be:
table[0] = 10;
table[1] = 30 - 2;
table[2] = 5;
@@ -545,19 +576,19 @@ namespace ttmath
- 5 1 5-1
- 4 3 4-3
- 2 7 2-7
- 9 9
+ 5 1 5-1
+ 4 3 4-3
+ 2 7 2-7
+ 9 9
return (carry): 0
@@ -1029,8 +1060,8 @@ namespace ttmath
diff --git a/include/geos/algorithm/ttmath/ttmathuint_x86_64_msvc.asm b/include/geos/algorithm/ttmath/ttmathuint_x86_64_msvc.asm
index b7c85c2..2f23a63 100644
--- a/include/geos/algorithm/ttmath/ttmathuint_x86_64_msvc.asm
+++ b/include/geos/algorithm/ttmath/ttmathuint_x86_64_msvc.asm
@@ -1,11 +1,11 @@
; This file is a part of TTMath Bignum Library
-; and is distributed under the (new) BSD licence.
-; Author: Christian Kaiser <chk at online.de>
+; and is distributed under the 3-Clause BSD Licence.
+; Author: Christian Kaiser <chk at online.de>, Tomasz Sowa <t.sowa at ttmath.org>
-; Copyright (c) 2009, Christian Kaiser
+; Copyright (c) 2009-2017, Christian Kaiser, Tomasz Sowa
; All rights reserved.
; Redistribution and use in source and binary forms, with or without
@@ -41,6 +41,9 @@
; this creates ttmathuint_x86_64_msvc.obj file which can be linked with your program
+; doxygen info is put to ttmathuint_x86_64.h file
PUBLIC ttmath_adc_x64
PUBLIC ttmath_addindexed_x64
PUBLIC ttmath_addindexed2_x64
@@ -151,12 +154,12 @@ ttmath_addindexed2_x64 PROC
; rdx = b (value size)
; r8 = nPos
; r9 = nValue1
- ; [esp+0x28] = nValue2
+ ; [rsp+0x28] = nValue2
xor rax, rax ; return value
mov r11, rcx ; table
sub rdx, r8 ; rdx = remaining count of uints
- mov r10, [esp+028h] ; r10 = nValue2
+ mov r10, [rsp+028h] ; r10 = nValue2
add qword ptr [r11 + r8 * 8], r9
lea r8, [r8+1]
@@ -194,9 +197,9 @@ ttmath_addvector_x64 PROC
; rdx = ss2
; r8 = ss1_size
; r9 = ss2_size
- ; [esp+0x28] = result
+ ; [rsp+0x28] = result
sub r8, r9
xor r11, r11 ; r11=0, cf=0
@@ -316,9 +319,9 @@ ttmath_subvector_x64 PROC
; rdx = ss2
; r8 = ss1_size
; r9 = ss2_size
sub r8, r9
Summary of changes:
include/geos/algorithm/ttmath/COPYRIGHT | 2 +-
include/geos/algorithm/ttmath/ttmath.h | 145 ++++++----
include/geos/algorithm/ttmath/ttmathbig.h | 322 ++++++++++++---------
include/geos/algorithm/ttmath/ttmathdec.h | 2 +-
include/geos/algorithm/ttmath/ttmathint.h | 53 ++--
include/geos/algorithm/ttmath/ttmathmisc.h | 24 +-
include/geos/algorithm/ttmath/ttmathobjects.h | 13 +-
include/geos/algorithm/ttmath/ttmathparser.h | 12 +-
include/geos/algorithm/ttmath/ttmaththreads.h | 42 +--
include/geos/algorithm/ttmath/ttmathtypes.h | 72 +++--
include/geos/algorithm/ttmath/ttmathuint.h | 138 +++++----
include/geos/algorithm/ttmath/ttmathuint_noasm.h | 105 ++++---
include/geos/algorithm/ttmath/ttmathuint_x86.h | 52 ++--
include/geos/algorithm/ttmath/ttmathuint_x86_64.h | 91 ++++--
.../algorithm/ttmath/ttmathuint_x86_64_msvc.asm | 21 +-
15 files changed, 651 insertions(+), 443 deletions(-)
hooks/post-receive
More information about the geos-commits
