[geos-commits] [SCM] GEOS branch master updated. c4608a954937ef2c6b6ec452f5f9cf9ff63efb6f
git at osgeo.org
git at osgeo.org
Wed Dec 12 10:12:50 PST 2018
the project "GEOS".
via c4608a954937ef2c6b6ec452f5f9cf9ff63efb6f (commit)
from 66392736c9e0748a10ab41ee8a379634c379c3c9 (commit)
revisions in full, below.
commit c4608a954937ef2c6b6ec452f5f9cf9ff63efb6f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Dec 12 10:12:23 2018 -0800
Turn off ASM for gcc < 5 and 32-bit builds, as there's
something that gcc hates in there when building with
PIC
diff --git a/include/geos/algorithm/ttmath/ttmathtypes.h b/include/geos/algorithm/ttmath/ttmathtypes.h
index 56a06b6..3aaef4a 100644
--- a/include/geos/algorithm/ttmath/ttmathtypes.h
+++ b/include/geos/algorithm/ttmath/ttmathtypes.h
@@ -4,20 +4,20 @@
* Author: Tomasz Sowa <t.sowa at ttmath.org>
* Copyright (c) 2006-2017, Tomasz Sowa
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* * Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name Tomasz Sowa nor the names of contributors to this
* project may be used to endorse or promote products derived
* from this software without specific prior written permission.
@@ -42,7 +42,7 @@
\file ttmathtypes.h
\brief constants used in the library
As our library is written in header files (templates) we cannot use
constants like 'const int' etc. because we should have some source files
*.cpp to define this variables. Only what we can have are constants
@@ -165,6 +165,12 @@
#define TTMATH_NOASM
#endif
+ /* 32-bit gcc < 5 doesn't like to build the ASM with PIC enabled as */
+ /* we do for GEOS */
+ #if defined __GNUC__ && __GNUC__ < 5 && !defined __x86_64__ && !defined _M_X64
+ #define TTMATH_NOASM
+ #endif
#endif
@@ -219,7 +225,7 @@ namespace ttmath
#define TTMATH_BUILTIN_VARIABLES_SIZE 256u
- this macro returns the number of machine words
+ this macro returns the number of machine words
capable to hold min_bits bits
e.g. TTMATH_BITS(128) returns 4
@@ -241,7 +247,7 @@ namespace ttmath
on 64bit platforms one word (uint, sint) will be equal 64bits
typedef signed long sint;
- #endif
+ #endif
on 64bit platforms we do not define ulint and slint
@@ -271,7 +277,7 @@ namespace ttmath
#define TTMATH_BUILTIN_VARIABLES_SIZE 128ul
e.g. TTMATH_BITS(128) returns 2
@@ -454,7 +460,7 @@ namespace ttmath
for example when the value is:
12.345678 and 'round' is 4
- then the result will be
+ then the result will be
12.3457 (the last digit was rounded)
sint round;
@@ -477,7 +483,7 @@ namespace ttmath
- additional comma operator (used only when reading)
+ additional comma operator (used only when reading)
if you don't want it just set it to zero
default is a comma ','
@@ -533,9 +539,9 @@ namespace ttmath
this simple class can be used in multithreading model
(you can write your own class derived from this one)
- for example: in some functions like Factorial()
- /at the moment only Factorial/ you can give a pointer to
- the 'stop object', if the method WasStopSignal() of this
+ for example: in some functions like Factorial()
+ /at the moment only Factorial/ you can give a pointer to
+ the 'stop object', if the method WasStopSignal() of this
object returns true that means we should break the calculating
and return
@@ -584,7 +590,7 @@ namespace ttmath
** from version 0.9.2 this macro is removed from all methods
in public interface so you don't have to worry about it **
- If you compile with gcc you can get a small benefit
+ If you compile with gcc you can get a small benefit
from using method Where() (it returns std::string) with
the name and the line of a file where the macro TTMATH_REFERENCE_ASSERT
was used)
@@ -616,7 +622,7 @@ namespace ttmath
(if the condition in it is false) throw an exception
of this type
- if you compile with gcc you can get a small benefit
+ if you compile with gcc you can get a small benefit
the name and the line of a file where the macro TTMATH_ASSERT
was used)
Summary of changes:
include/geos/algorithm/ttmath/ttmathtypes.h | 38 +++++++++++++++++------------
1 file changed, 22 insertions(+), 16 deletions(-)
hooks/post-receive
More information about the geos-commits
