[geos-commits] [SCM] GEOS branch master updated. 6f960a291b0fe91bcd2f7dae2551cffc7875b3c9
git at osgeo.org
git at osgeo.org
Wed Dec 12 10:29:45 PST 2018
the project "GEOS".
via 6f960a291b0fe91bcd2f7dae2551cffc7875b3c9 (commit)
from f2278c485d191afd7219a3877b9eb97a6d52e438 (commit)
revisions in full, below.
commit 6f960a291b0fe91bcd2f7dae2551cffc7875b3c9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Dec 12 10:29:38 2018 -0800
Reformat IsValidOp
diff --git a/include/geos/operation/valid/IsValidOp.h b/include/geos/operation/valid/IsValidOp.h
index 9bcd639..09bb588 100644
--- a/include/geos/operation/valid/IsValidOp.h
+++ b/include/geos/operation/valid/IsValidOp.h
@@ -27,27 +27,27 @@
// Forward declarations
namespace geos {
- namespace util {
- class TopologyValidationError;
- namespace geom {
- class CoordinateSequence;
- class GeometryFactory;
- class Geometry;
- class Point;
- class LinearRing;
- class LineString;
- class Polygon;
- class GeometryCollection;
- class MultiPolygon;
- class MultiLineString;
- namespace geomgraph {
- class DirectedEdge;
- class EdgeIntersectionList;
- class PlanarGraph;
- class GeometryGraph;
+namespace util {
+class TopologyValidationError;
+namespace geom {
+class CoordinateSequence;
+class GeometryFactory;
+class Geometry;
+class Point;
+class LinearRing;
+class LineString;
+class Polygon;
+class GeometryCollection;
+class MultiPolygon;
+class MultiLineString;
+namespace geomgraph {
+class DirectedEdge;
+class EdgeIntersectionList;
+class PlanarGraph;
+class GeometryGraph;
namespace geos {
@@ -59,215 +59,216 @@ namespace valid { // geos::operation::valid
* method for {@link Geometry}s.
class GEOS_DLL IsValidOp {
-friend class Unload;
+ friend class Unload;
private:
- /// the base Geometry to be validated
- const geom::Geometry *parentGeometry;
- bool isChecked;
- // CHECKME: should this really be a pointer ?
- TopologyValidationError* validErr;
- // This is the version using 'isChecked' flag
- void checkValid();
- void checkValid(const geom::Geometry *g);
- void checkValid(const geom::Point *g);
- void checkValid(const geom::LinearRing *g);
- void checkValid(const geom::LineString *g);
- void checkValid(const geom::Polygon *g);
- void checkValid(const geom::MultiPolygon *g);
- void checkValid(const geom::GeometryCollection *gc);
- void checkConsistentArea(geomgraph::GeometryGraph *graph);
- * Check that there is no ring which self-intersects
- * (except of course at its endpoints).
- * This is required by OGC topology rules (but not by other models
- * such as ESRI SDE, which allow inverted shells and exverted holes).
- * @param graph the topology graph of the geometry
- void checkNoSelfIntersectingRings(geomgraph::GeometryGraph *graph);
- * check that a ring does not self-intersect, except at its endpoints.
- * Algorithm is to count the number of times each node along edge
- * occurs.
- * If any occur more than once, that must be a self-intersection.
- void checkNoSelfIntersectingRing(
- geomgraph::EdgeIntersectionList &eiList);
- void checkTooFewPoints(geomgraph::GeometryGraph *graph);
- * Test that each hole is inside the polygon shell.
- * This routine assumes that the holes have previously been tested
- * to ensure that all vertices lie on the shell or inside it.
- * A simple test of a single point in the hole can be used,
- * provide the point is chosen such that it does not lie on the
- * boundary of the shell.
- * @param p the polygon to be tested for hole inclusion
- * @param graph a geomgraph::GeometryGraph incorporating the polygon
- void checkHolesInShell(const geom::Polygon *p,
- geomgraph::GeometryGraph *graph);
- * Tests that no hole is nested inside another hole.
- * This routine assumes that the holes are disjoint.
- * To ensure this, holes have previously been tested
- * to ensure that:
- * - they do not partially overlap
- * (checked by <code>checkRelateConsistency</code>)
- * - they are not identical
- void checkHolesNotNested(const geom::Polygon *p,
- * Tests that no element polygon is wholly in the interior of another
- * element polygon.
- * Preconditions:
- * - shells do not partially overlap
- * - shells do not touch along an edge
- * - no duplicate rings exist
- * This routine relies on the fact that while polygon shells
- * may touch at one or more vertices, they cannot touch at
- * ALL vertices.
- void checkShellsNotNested(const geom::MultiPolygon *mp,
- * Check if a shell is incorrectly nested within a polygon.
- * This is the case if the shell is inside the polygon shell,
- * but not inside a polygon hole.
- * (If the shell is inside a polygon hole, the nesting is valid.)
- * The algorithm used relies on the fact that the rings must be
- * properly contained.
- * E.g. they cannot partially overlap (this has been previously
- * checked by <code>checkRelateConsistency</code>
- void checkShellNotNested(const geom::LinearRing *shell,
- const geom::Polygon *p,
- * This routine checks to see if a shell is properly contained
- * in a hole.
- * It assumes that the edges of the shell and hole do not
- * properly intersect.
- * @return <code>null</code> if the shell is properly contained, or
- * a Coordinate which is not inside the hole if it is not
- const geom::Coordinate *checkShellInsideHole(
- const geom::LinearRing *shell,
- const geom::LinearRing *hole,
- void checkConnectedInteriors(geomgraph::GeometryGraph &graph);
- void checkInvalidCoordinates(const geom::CoordinateSequence *cs);
- void checkInvalidCoordinates(const geom::Polygon *poly);
- void checkClosedRings(const geom::Polygon *poly);
- void checkClosedRing(const geom::LinearRing *ring);
- bool isSelfTouchingRingFormingHoleValid;
+ /// the base Geometry to be validated
+ const geom::Geometry *parentGeometry;
+ bool isChecked;
+ // CHECKME: should this really be a pointer ?
+ TopologyValidationError* validErr;
+ // This is the version using 'isChecked' flag
+ void checkValid();
+ void checkValid(const geom::Geometry *g);
+ void checkValid(const geom::Point *g);
+ void checkValid(const geom::LinearRing *g);
+ void checkValid(const geom::LineString *g);
+ void checkValid(const geom::Polygon *g);
+ void checkValid(const geom::MultiPolygon *g);
+ void checkValid(const geom::GeometryCollection *gc);
+ void checkConsistentArea(geomgraph::GeometryGraph *graph);
+ * Check that there is no ring which self-intersects
+ * (except of course at its endpoints).
+ * This is required by OGC topology rules (but not by other models
+ * such as ESRI SDE, which allow inverted shells and exverted holes).
+ * @param graph the topology graph of the geometry
+ void checkNoSelfIntersectingRings(geomgraph::GeometryGraph *graph);
+ * check that a ring does not self-intersect, except at its endpoints.
+ * Algorithm is to count the number of times each node along edge
+ * occurs.
+ * If any occur more than once, that must be a self-intersection.
+ void checkNoSelfIntersectingRing(
+ geomgraph::EdgeIntersectionList &eiList);
+ void checkTooFewPoints(geomgraph::GeometryGraph *graph);
+ * Test that each hole is inside the polygon shell.
+ * This routine assumes that the holes have previously been tested
+ * to ensure that all vertices lie on the shell or inside it.
+ * A simple test of a single point in the hole can be used,
+ * provide the point is chosen such that it does not lie on the
+ * boundary of the shell.
+ * @param p the polygon to be tested for hole inclusion
+ * @param graph a geomgraph::GeometryGraph incorporating the polygon
+ void checkHolesInShell(const geom::Polygon *p,
+ geomgraph::GeometryGraph *graph);
+ * Tests that no hole is nested inside another hole.
+ * This routine assumes that the holes are disjoint.
+ * To ensure this, holes have previously been tested
+ * to ensure that:
+ * - they do not partially overlap
+ * (checked by <code>checkRelateConsistency</code>)
+ * - they are not identical
+ void checkHolesNotNested(const geom::Polygon *p,
+ * Tests that no element polygon is wholly in the interior of another
+ * element polygon.
+ * Preconditions:
+ * - shells do not partially overlap
+ * - shells do not touch along an edge
+ * - no duplicate rings exist
+ * This routine relies on the fact that while polygon shells
+ * may touch at one or more vertices, they cannot touch at
+ * ALL vertices.
+ void checkShellsNotNested(const geom::MultiPolygon *mp,
+ * Check if a shell is incorrectly nested within a polygon.
+ * This is the case if the shell is inside the polygon shell,
+ * but not inside a polygon hole.
+ * (If the shell is inside a polygon hole, the nesting is valid.)
+ * The algorithm used relies on the fact that the rings must be
+ * properly contained.
+ * E.g. they cannot partially overlap (this has been previously
+ * checked by <code>checkRelateConsistency</code>
+ void checkShellNotNested(const geom::LinearRing *shell,
+ const geom::Polygon *p,
+ * This routine checks to see if a shell is properly contained
+ * in a hole.
+ * It assumes that the edges of the shell and hole do not
+ * properly intersect.
+ * @return <code>null</code> if the shell is properly contained, or
+ * a Coordinate which is not inside the hole if it is not
+ const geom::Coordinate *checkShellInsideHole(
+ const geom::LinearRing *shell,
+ const geom::LinearRing *hole,
+ void checkConnectedInteriors(geomgraph::GeometryGraph &graph);
+ void checkInvalidCoordinates(const geom::CoordinateSequence *cs);
+ void checkInvalidCoordinates(const geom::Polygon *poly);
+ void checkClosedRings(const geom::Polygon *poly);
+ void checkClosedRing(const geom::LinearRing *ring);
+ bool isSelfTouchingRingFormingHoleValid;
public:
- * Find a point from the list of testCoords
- * that is NOT a node in the edge for the list of searchCoords
- * @return the point found, or NULL if none found
- static const geom::Coordinate *findPtNotNode(
- const geom::CoordinateSequence *testCoords,
- const geom::LinearRing *searchRing,
- * Checks whether a coordinate is valid for processing.
- * Coordinates are valid iff their x and y coordinates are in the
- * range of the floating point representation.
- * @param coord the coordinate to validate
- * @return <code>true</code> if the coordinate is valid
- static bool isValid(const geom::Coordinate &coord);
- * Tests whether a {@link Geometry} is valid.
- * @param geom the Geometry to test
- * @return true if the geometry is valid
- static bool isValid(const geom::Geometry &geom);
- IsValidOp(const geom::Geometry *geom)
- parentGeometry(geom),
- isChecked(false),
- validErr(nullptr),
- isSelfTouchingRingFormingHoleValid(false)
- /// TODO: validErr can't be a pointer!
- virtual ~IsValidOp() {
- delete validErr;
- bool isValid();
- TopologyValidationError* getValidationError();
- /** \brief
- * Sets whether polygons using <b>Self-Touching Rings</b> to form
- * holes are reported as valid.
- * If this flag is set, the following Self-Touching conditions
- * are treated as being valid:
- * <ul>
- * <li>the shell ring self-touches to create a hole touching the shell
- * <li>a hole ring self-touches to create two holes touching at a point
- * </ul>
- * <p>
- * The default (following the OGC SFS standard)
- * is that this condition is <b>not</b> valid (<code>false</code>).
- * <p>
- * This does not affect whether Self-Touching Rings
- * disconnecting the polygon interior are considered valid
- * (these are considered to be <b>invalid</b> under the SFS,
- * and many other spatial models as well).
- * This includes "bow-tie" shells,
- * which self-touch at a single point causing the interior to
- * be disconnected,
- * and "C-shaped" holes which self-touch at a single point causing
- * an island to be formed.
- * @param isValid states whether geometry with this condition is valid
- void setSelfTouchingRingFormingHoleValid(bool p_isValid)
- isSelfTouchingRingFormingHoleValid = p_isValid;
+ * Find a point from the list of testCoords
+ * that is NOT a node in the edge for the list of searchCoords
+ * @return the point found, or NULL if none found
+ static const geom::Coordinate *findPtNotNode(
+ const geom::CoordinateSequence *testCoords,
+ const geom::LinearRing *searchRing,
+ * Checks whether a coordinate is valid for processing.
+ * Coordinates are valid iff their x and y coordinates are in the
+ * range of the floating point representation.
+ * @param coord the coordinate to validate
+ * @return <code>true</code> if the coordinate is valid
+ static bool isValid(const geom::Coordinate &coord);
+ * Tests whether a {@link Geometry} is valid.
+ * @param geom the Geometry to test
+ * @return true if the geometry is valid
+ static bool isValid(const geom::Geometry &geom);
+ IsValidOp(const geom::Geometry *geom)
+ parentGeometry(geom),
+ isChecked(false),
+ validErr(nullptr),
+ isSelfTouchingRingFormingHoleValid(false)
+ /// TODO: validErr can't be a pointer!
+ virtual ~IsValidOp()
+ delete validErr;
+ bool isValid();
+ TopologyValidationError* getValidationError();
+ /** \brief
+ * Sets whether polygons using <b>Self-Touching Rings</b> to form
+ * holes are reported as valid.
+ * If this flag is set, the following Self-Touching conditions
+ * are treated as being valid:
+ * <ul>
+ * <li>the shell ring self-touches to create a hole touching the shell
+ * <li>a hole ring self-touches to create two holes touching at a point
+ * </ul>
+ * <p>
+ * The default (following the OGC SFS standard)
+ * is that this condition is <b>not</b> valid (<code>false</code>).
+ * <p>
+ * This does not affect whether Self-Touching Rings
+ * disconnecting the polygon interior are considered valid
+ * (these are considered to be <b>invalid</b> under the SFS,
+ * and many other spatial models as well).
+ * This includes "bow-tie" shells,
+ * which self-touch at a single point causing the interior to
+ * be disconnected,
+ * and "C-shaped" holes which self-touch at a single point causing
+ * an island to be formed.
+ * @param isValid states whether geometry with this condition is valid
+ void setSelfTouchingRingFormingHoleValid(bool p_isValid)
+ isSelfTouchingRingFormingHoleValid = p_isValid;
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index 54a7a39..08b3149 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -64,92 +64,90 @@ namespace valid { // geos.operation.valid
const Coordinate *
IsValidOp::findPtNotNode(const CoordinateSequence *testCoords,
- const LinearRing *searchRing, GeometryGraph *graph)
+ const LinearRing *searchRing, GeometryGraph *graph)
- // find edge corresponding to searchRing.
- Edge *searchEdge=graph->findEdge(searchRing);
- // find a point in the testCoords which is not a node of the searchRing
- EdgeIntersectionList &eiList=searchEdge->getEdgeIntersectionList();
- // somewhat inefficient - is there a better way? (Use a node map, for instance?)
- auto npts = testCoords->getSize();
- for(unsigned int i=0; i<npts; ++i)
- const Coordinate& pt=testCoords->getAt(i);
- if (!eiList.isIntersection(pt)) {
- return &pt;
- return nullptr;
+ // find edge corresponding to searchRing.
+ Edge *searchEdge=graph->findEdge(searchRing);
+ // find a point in the testCoords which is not a node of the searchRing
+ EdgeIntersectionList &eiList=searchEdge->getEdgeIntersectionList();
+ // somewhat inefficient - is there a better way? (Use a node map, for instance?)
+ auto npts = testCoords->getSize();
+ for(unsigned int i=0; i<npts; ++i) {
+ const Coordinate& pt=testCoords->getAt(i);
+ if (!eiList.isIntersection(pt)) {
+ return &pt;
+ return nullptr;
bool
IsValidOp::isValid()
- checkValid();
- return validErr==nullptr;
+ checkValid();
+ return validErr==nullptr;
/* static public */
bool
IsValidOp::isValid(const Coordinate &coord)
- if (! FINITE(coord.x) ) return false;
- if (! FINITE(coord.y) ) return false;
- return true;
+ if (! FINITE(coord.x) ) return false;
+ if (! FINITE(coord.y) ) return false;
+ return true;
/* static public */
bool
IsValidOp::isValid(const Geometry &g)
- IsValidOp op(&g);
- return op.isValid();
+ IsValidOp op(&g);
+ return op.isValid();
TopologyValidationError *
IsValidOp::getValidationError()
- checkValid();
- return validErr;
+ checkValid();
+ return validErr;
void
IsValidOp::checkValid()
- if (isChecked) return;
- checkValid(parentGeometry);
- isChecked=true;
+ if (isChecked) return;
+ checkValid(parentGeometry);
+ isChecked=true;
void
IsValidOp::checkValid(const Geometry *g)
- assert( validErr == nullptr );
- if (nullptr == g)
- return;
- // empty geometries are always valid!
- if (g->isEmpty()) return;
- if ( const Point* x1 = dynamic_cast<const Point*>(g) )
- checkValid(x1);
- // LineString also handles LinearRings, so we check LinearRing first
- else if ( const LinearRing* x2 = dynamic_cast<const LinearRing*>(g) )
- checkValid(x2);
- else if ( const LineString* x3 = dynamic_cast<const LineString*>(g) )
- checkValid(x3);
- else if ( const Polygon* x4 = dynamic_cast<const Polygon*>(g) )
- checkValid(x4);
- else if ( const MultiPolygon* x5 = dynamic_cast<const MultiPolygon*>(g) )
- checkValid(x5);
- else if ( const GeometryCollection* x6 =
- dynamic_cast<const GeometryCollection*>(g) )
- checkValid(x6);
- else throw util::UnsupportedOperationException();
+ assert( validErr == nullptr );
+ if (nullptr == g)
+ return;
+ // empty geometries are always valid!
+ if (g->isEmpty()) return;
+ if ( const Point* x1 = dynamic_cast<const Point*>(g) )
+ checkValid(x1);
+ // LineString also handles LinearRings, so we check LinearRing first
+ else if ( const LinearRing* x2 = dynamic_cast<const LinearRing*>(g) )
+ checkValid(x2);
+ else if ( const LineString* x3 = dynamic_cast<const LineString*>(g) )
+ checkValid(x3);
+ else if ( const Polygon* x4 = dynamic_cast<const Polygon*>(g) )
+ checkValid(x4);
+ else if ( const MultiPolygon* x5 = dynamic_cast<const MultiPolygon*>(g) )
+ checkValid(x5);
+ else if ( const GeometryCollection* x6 =
+ dynamic_cast<const GeometryCollection*>(g) ) {
+ checkValid(x6);
+ else throw util::UnsupportedOperationException();
@@ -158,7 +156,7 @@ IsValidOp::checkValid(const Geometry *g)
void
IsValidOp::checkValid(const Point *g)
- checkInvalidCoordinates(g->getCoordinatesRO());
+ checkInvalidCoordinates(g->getCoordinatesRO());
@@ -167,31 +165,32 @@ IsValidOp::checkValid(const Point *g)
void
IsValidOp::checkValid(const LineString *g)
- if (validErr != nullptr) return;
+ if (validErr != nullptr) return;
- GeometryGraph graph(0,g);
- checkTooFewPoints(&graph);
+ GeometryGraph graph(0, g);
+ checkTooFewPoints(&graph);
* Checks validity of a LinearRing.
void
-IsValidOp::checkValid(const LinearRing *g){
+IsValidOp::checkValid(const LinearRing *g)
- checkClosedRing(g);
+ checkClosedRing(g);
- GeometryGraph graph(0, g);
- if (validErr!=nullptr) return;
+ if (validErr!=nullptr) return;
- LineIntersector li;
- delete graph.computeSelfNodes(&li, true, true);
- checkNoSelfIntersectingRings(&graph);
+ LineIntersector li;
+ delete graph.computeSelfNodes(&li, true, true);
+ checkNoSelfIntersectingRings(&graph);
@@ -201,107 +200,102 @@ IsValidOp::checkValid(const LinearRing *g){
void
IsValidOp::checkValid(const Polygon *g)
- checkInvalidCoordinates(g);
+ checkInvalidCoordinates(g);
- checkClosedRings(g);
+ checkClosedRings(g);
- checkConsistentArea(&graph);
+ checkConsistentArea(&graph);
- if (!isSelfTouchingRingFormingHoleValid) {
+ if (!isSelfTouchingRingFormingHoleValid) {
- checkHolesInShell(g,&graph);
+ checkHolesInShell(g, &graph);
- checkHolesNotNested(g,&graph);
+ checkHolesNotNested(g, &graph);
- checkConnectedInteriors(graph);
+ checkConnectedInteriors(graph);
void
IsValidOp::checkValid(const MultiPolygon *g)
- auto ngeoms = g->getNumGeometries();
- vector<const Polygon *>polys(ngeoms);
+ auto ngeoms = g->getNumGeometries();
+ vector<const Polygon *>polys(ngeoms);
- for (size_t i=0; i < ngeoms; ++i)
- const Polygon *p = dynamic_cast<const Polygon *>(g->getGeometryN(i));
+ for (size_t i=0; i < ngeoms; ++i) {
+ const Polygon *p = dynamic_cast<const Polygon *>(g->getGeometryN(i));
- checkInvalidCoordinates(p);
+ checkInvalidCoordinates(p);
- checkClosedRings(p);
+ checkClosedRings(p);
- polys[i]=p;
+ polys[i]=p;
- for(unsigned int i=0; i<ngeoms; ++i)
- const Polygon *p=polys[i];
- checkHolesInShell(p, &graph);
+ for(unsigned int i=0; i<ngeoms; ++i) {
+ const Polygon *p=polys[i];
+ checkHolesInShell(p, &graph);
- checkHolesNotNested(p, &graph);
+ checkHolesNotNested(p, &graph);
- checkShellsNotNested(g,&graph);
+ checkShellsNotNested(g, &graph);
void
IsValidOp::checkValid(const GeometryCollection *gc)
- for(size_t i = 0, ngeoms=gc->getNumGeometries(); i < ngeoms; ++i)
- const Geometry *g=gc->getGeometryN(i);
- checkValid(g);
+ for(size_t i = 0, ngeoms=gc->getNumGeometries(); i < ngeoms; ++i) {
+ const Geometry *g=gc->getGeometryN(i);
+ checkValid(g);
void
IsValidOp::checkTooFewPoints(GeometryGraph *graph)
- if (graph->hasTooFewPoints()) {
- validErr=new TopologyValidationError(
- TopologyValidationError::eTooFewPoints,
- graph->getInvalidPoint());
- return;
+ if (graph->hasTooFewPoints()) {
+ validErr=new TopologyValidationError(
+ TopologyValidationError::eTooFewPoints,
+ graph->getInvalidPoint());
+ return;
@@ -315,23 +309,21 @@ IsValidOp::checkTooFewPoints(GeometryGraph *graph)
void
IsValidOp::checkConsistentArea(GeometryGraph *graph)
- ConsistentAreaTester cat(graph);
- bool isValidArea=cat.isNodeConsistentArea();
- if (!isValidArea)
- TopologyValidationError::eSelfIntersection,
- cat.getInvalidPoint());
- return;
- if (cat.hasDuplicateRings())
- TopologyValidationError::eDuplicatedRings,
+ ConsistentAreaTester cat(graph);
+ bool isValidArea=cat.isNodeConsistentArea();
+ if (!isValidArea) {
+ TopologyValidationError::eSelfIntersection,
+ cat.getInvalidPoint());
+ return;
+ if (cat.hasDuplicateRings()) {
+ TopologyValidationError::eDuplicatedRings,
@@ -339,268 +331,258 @@ IsValidOp::checkConsistentArea(GeometryGraph *graph)
void
IsValidOp::checkNoSelfIntersectingRings(GeometryGraph *graph)
- vector<Edge*> *edges=graph->getEdges();
- for(unsigned int i=0; i<edges->size(); ++i)
- Edge *e=(*edges)[i];
- checkNoSelfIntersectingRing(e->getEdgeIntersectionList());
- if(validErr!=nullptr) return;
+ vector<Edge*> *edges=graph->getEdges();
+ for(unsigned int i=0; i<edges->size(); ++i) {
+ Edge *e=(*edges)[i];
+ checkNoSelfIntersectingRing(e->getEdgeIntersectionList());
+ if(validErr!=nullptr) return;
/*private*/
void
IsValidOp::checkNoSelfIntersectingRing(EdgeIntersectionList &eiList)
- set<const Coordinate*,CoordinateLessThen>nodeSet;
- bool isFirst=true;
- EdgeIntersectionList::iterator it=eiList.begin();
- EdgeIntersectionList::iterator end=eiList.end();
- for(; it!=end; ++it)
- EdgeIntersection *ei=*it;
- if (isFirst) {
- isFirst=false;
- continue;
- if (nodeSet.find(&ei->coord)!=nodeSet.end()) {
- TopologyValidationError::eRingSelfIntersection,
- ei->coord);
- return;
- } else {
- nodeSet.insert(&ei->coord);
+ set<const Coordinate*, CoordinateLessThen>nodeSet;
+ bool isFirst=true;
+ EdgeIntersectionList::iterator it=eiList.begin();
+ EdgeIntersectionList::iterator end=eiList.end();
+ for(; it!=end; ++it) {
+ EdgeIntersection *ei=*it;
+ if (isFirst) {
+ isFirst=false;
+ continue;
+ if (nodeSet.find(&ei->coord)!=nodeSet.end()) {
+ TopologyValidationError::eRingSelfIntersection,
+ ei->coord);
+ return;
+ else {
+ nodeSet.insert(&ei->coord);
/*private*/
void
IsValidOp::checkHolesInShell(const Polygon *p, GeometryGraph *graph)
- assert(dynamic_cast<const LinearRing*>(p->getExteriorRing()));
+ assert(dynamic_cast<const LinearRing*>(p->getExteriorRing()));
- const LinearRing *shell = static_cast<const LinearRing*>(
- p->getExteriorRing());
+ const LinearRing *shell = static_cast<const LinearRing*>(
+ p->getExteriorRing());
const Geometry *shellgeom = static_cast<const Geometry*>(shell);
- auto nholes = p->getNumInteriorRing();
- if(shell->isEmpty())
- for(size_t i = 0; i < nholes; ++i)
- p->getInteriorRingN(i)));
- const LinearRing *hole=static_cast<const LinearRing*>(
- p->getInteriorRingN(i));
- if(!hole->isEmpty())
- TopologyValidationError::eHoleOutsideShell);
- return;
- // all interiors also empty or none exist
- return;
- //SimplePointInRing pir(shell);
- //SIRtreePointInRing pir(shell);
- // MCPointInRing pir(shell);
+ auto nholes = p->getNumInteriorRing();
+ if(shell->isEmpty()) {
+ for(size_t i = 0; i < nholes; ++i) {
+ p->getInteriorRingN(i)));
+ const LinearRing *hole=static_cast<const LinearRing*>(
+ p->getInteriorRingN(i));
+ if(!hole->isEmpty()) {
+ TopologyValidationError::eHoleOutsideShell);
+ return;
+ // all interiors also empty or none exist
+ return;
+ //SimplePointInRing pir(shell);
+ //SIRtreePointInRing pir(shell);
+ // MCPointInRing pir(shell);
locate::IndexedPointInAreaLocator ipial(*shellgeom);
- const Coordinate *holePt=findPtNotNode(
- hole->getCoordinatesRO(), shell, graph);
- * If no non-node hole vertex can be found, the hole must
- * split the polygon into disconnected interiors.
- * This will be caught by a subsequent check.
- if (holePt == nullptr) return;
- bool outside = (geom::Location::EXTERIOR == ipial.locate(holePt));
- if (outside) {
- TopologyValidationError::eHoleOutsideShell,
- *holePt);
- return;
+ const Coordinate *holePt=findPtNotNode(
+ hole->getCoordinatesRO(), shell, graph);
+ * If no non-node hole vertex can be found, the hole must
+ * split the polygon into disconnected interiors.
+ * This will be caught by a subsequent check.
+ if (holePt == nullptr) return;
+ bool outside = (geom::Location::EXTERIOR == ipial.locate(holePt));
+ if (outside) {
+ TopologyValidationError::eHoleOutsideShell,
+ *holePt);
+ return;
/*private*/
void
IsValidOp::checkHolesNotNested(const Polygon *p, GeometryGraph *graph)
- //SimpleNestedRingTester nestedTester(graph);
- //SweeplineNestedRingTester nestedTester(graph);
- //QuadtreeNestedRingTester nestedTester(graph);
- IndexedNestedRingTester nestedTester(graph);
- const LinearRing *innerHole=static_cast<const LinearRing*>(
- //empty holes always pass
- if(innerHole->isEmpty()) continue;
- nestedTester.add(innerHole);
- bool isNonNested=nestedTester.isNonNested();
- if (!isNonNested)
- TopologyValidationError::eNestedHoles,
- *(nestedTester.getNestedPoint()));
+ //SimpleNestedRingTester nestedTester(graph);
+ //SweeplineNestedRingTester nestedTester(graph);
+ //QuadtreeNestedRingTester nestedTester(graph);
+ IndexedNestedRingTester nestedTester(graph);
+ const LinearRing *innerHole=static_cast<const LinearRing*>(
+ //empty holes always pass
+ if(innerHole->isEmpty()) continue;
+ nestedTester.add(innerHole);
+ bool isNonNested=nestedTester.isNonNested();
+ if (!isNonNested) {
+ TopologyValidationError::eNestedHoles,
+ *(nestedTester.getNestedPoint()));
/*private*/
void
IsValidOp::checkShellsNotNested(const MultiPolygon *mp, GeometryGraph *graph)
- for(size_t i = 0, ngeoms = mp->getNumGeometries(); i < ngeoms; ++i)
- const Polygon *p=dynamic_cast<const Polygon *>(
- mp->getGeometryN(i));
- assert(p);
+ for(size_t i = 0, ngeoms = mp->getNumGeometries(); i < ngeoms; ++i) {
+ const Polygon *p=dynamic_cast<const Polygon *>(
+ mp->getGeometryN(i));
+ assert(p);
- const LinearRing *shell=dynamic_cast<const LinearRing*>(
- assert(shell);
+ const LinearRing *shell=dynamic_cast<const LinearRing*>(
+ assert(shell);
- for(size_t j = 0; j < ngeoms; ++j)
- if (i==j) continue;
+ for(size_t j = 0; j < ngeoms; ++j) {
+ if (i==j) continue;
- const Polygon *p2 = dynamic_cast<const Polygon *>(
- mp->getGeometryN(j));
- assert(p2);
+ const Polygon *p2 = dynamic_cast<const Polygon *>(
+ mp->getGeometryN(j));
+ assert(p2);
- if (shell->isEmpty() || p2->isEmpty()) continue;
+ if (shell->isEmpty() || p2->isEmpty()) continue;
- checkShellNotNested(shell, p2, graph);
+ checkShellNotNested(shell, p2, graph);
/*private*/
void
IsValidOp::checkShellNotNested(const LinearRing *shell, const Polygon *p,
- GeometryGraph *graph)
+ GeometryGraph *graph)
- const CoordinateSequence *shellPts=shell->getCoordinatesRO();
- // test if shell is inside polygon shell
- p->getExteriorRing()));
- const LinearRing *polyShell=static_cast<const LinearRing*>(
- const CoordinateSequence *polyPts=polyShell->getCoordinatesRO();
- const Coordinate *shellPt=findPtNotNode(shellPts,polyShell,graph);
- // if no point could be found, we can assume that the shell
- // is outside the polygon
- if (shellPt==nullptr) return;
- bool insidePolyShell=CGAlgorithms::isPointInRing(*shellPt, polyPts);
- if (!insidePolyShell) return;
- // if no holes, this is an error!
- if (nholes<=0) {
- TopologyValidationError::eNestedShells,
- *shellPt);
- return;
- * Check if the shell is inside one of the holes.
- * This is the case if one of the calls to checkShellInsideHole
- * returns a null coordinate.
- * Otherwise, the shell is not properly contained in a hole, which is
- * an error.
- const Coordinate *badNestedPt=nullptr;
- for(size_t i = 0; i < nholes; ++i) {
- badNestedPt = checkShellInsideHole(shell, hole, graph);
- if (badNestedPt==nullptr) return;
- TopologyValidationError::eNestedShells, *badNestedPt
+ const CoordinateSequence *shellPts=shell->getCoordinatesRO();
+ // test if shell is inside polygon shell
+ p->getExteriorRing()));
+ const LinearRing *polyShell=static_cast<const LinearRing*>(
+ const CoordinateSequence *polyPts=polyShell->getCoordinatesRO();
+ const Coordinate *shellPt=findPtNotNode(shellPts, polyShell, graph);
+ // if no point could be found, we can assume that the shell
+ // is outside the polygon
+ if (shellPt==nullptr) return;
+ bool insidePolyShell=CGAlgorithms::isPointInRing(*shellPt, polyPts);
+ if (!insidePolyShell) return;
+ // if no holes, this is an error!
+ if (nholes<=0) {
+ TopologyValidationError::eNestedShells,
+ *shellPt);
+ return;
+ * Check if the shell is inside one of the holes.
+ * This is the case if one of the calls to checkShellInsideHole
+ * returns a null coordinate.
+ * Otherwise, the shell is not properly contained in a hole, which is
+ * an error.
+ const Coordinate *badNestedPt=nullptr;
+ badNestedPt = checkShellInsideHole(shell, hole, graph);
+ if (badNestedPt==nullptr) return;
+ TopologyValidationError::eNestedShells, *badNestedPt
/*private*/
const Coordinate *
IsValidOp::checkShellInsideHole(const LinearRing *shell,
- const LinearRing *hole,
+ const LinearRing *hole,
- const CoordinateSequence *holePts=hole->getCoordinatesRO();
- // TODO: improve performance of this - by sorting pointlists
- // for instance?
- const Coordinate *shellPt=findPtNotNode(shellPts, hole, graph);
- // if point is on shell but not hole, check that the shell is
- // inside the hole
- if (shellPt) {
- bool insideHole=CGAlgorithms::isPointInRing(*shellPt, holePts);
- if (!insideHole) return shellPt;
- const Coordinate *holePt=findPtNotNode(holePts, shell, graph);
- // if point is on hole but not shell, check that the hole is
- // outside the shell
- if (holePt) {
- bool insideShell=CGAlgorithms::isPointInRing(*holePt, shellPts);
- if (insideShell) return holePt;
- return nullptr;
- assert(0); // points in shell and hole appear to be equal
- return nullptr;
+ const CoordinateSequence *holePts=hole->getCoordinatesRO();
+ // TODO: improve performance of this - by sorting pointlists
+ // for instance?
+ const Coordinate *shellPt=findPtNotNode(shellPts, hole, graph);
+ // if point is on shell but not hole, check that the shell is
+ // inside the hole
+ if (shellPt) {
+ bool insideHole=CGAlgorithms::isPointInRing(*shellPt, holePts);
+ if (!insideHole) return shellPt;
+ const Coordinate *holePt=findPtNotNode(holePts, shell, graph);
+ // if point is on hole but not shell, check that the hole is
+ // outside the shell
+ if (holePt) {
+ bool insideShell=CGAlgorithms::isPointInRing(*holePt, shellPts);
+ if (insideShell) return holePt;
+ return nullptr;
+ assert(0); // points in shell and hole appear to be equal
+ return nullptr;
/*private*/
void
IsValidOp::checkConnectedInteriors(GeometryGraph &graph)
- ConnectedInteriorTester cit(graph);
- if (!cit.isInteriorsConnected())
- TopologyValidationError::eDisconnectedInterior,
- cit.getCoordinate());
+ ConnectedInteriorTester cit(graph);
+ if (!cit.isInteriorsConnected()) {
+ TopologyValidationError::eDisconnectedInterior,
+ cit.getCoordinate());
@@ -608,64 +590,59 @@ IsValidOp::checkConnectedInteriors(GeometryGraph &graph)
void
IsValidOp::checkInvalidCoordinates(const CoordinateSequence *cs)
- auto size = cs->size();
- for (size_t i = 0; i < size; ++i)
- if (! isValid(cs->getAt(i)) )
- validErr = new TopologyValidationError(
- TopologyValidationError::eInvalidCoordinate,
- cs->getAt(i));
- return;
+ auto size = cs->size();
+ for (size_t i = 0; i < size; ++i) {
+ if (! isValid(cs->getAt(i)) ) {
+ validErr = new TopologyValidationError(
+ TopologyValidationError::eInvalidCoordinate,
+ cs->getAt(i));
+ return;
/*private*/
void
IsValidOp::checkInvalidCoordinates(const Polygon *poly)
- checkInvalidCoordinates(poly->getExteriorRing()->getCoordinatesRO());
- auto nholes = poly->getNumInteriorRing();
- for (size_t i = 0; i < nholes; ++i)
- poly->getInteriorRingN(i)->getCoordinatesRO()
+ checkInvalidCoordinates(poly->getExteriorRing()->getCoordinatesRO());
+ auto nholes = poly->getNumInteriorRing();
+ for (size_t i = 0; i < nholes; ++i) {
+ poly->getInteriorRingN(i)->getCoordinatesRO()
/*private*/
void
IsValidOp::checkClosedRings(const Polygon *poly)
- const LinearRing *lr=(const LinearRing *)poly->getExteriorRing();
- checkClosedRing(lr);
- if (validErr) return;
- lr=(const LinearRing *)poly->getInteriorRingN(i);
+ const LinearRing *lr=(const LinearRing *)poly->getExteriorRing();
+ checkClosedRing(lr);
+ if (validErr) return;
+ lr=(const LinearRing *)poly->getInteriorRingN(i);
/*private*/
void
IsValidOp::checkClosedRing(const LinearRing *ring)
- if ( ! ring->isClosed() && ! ring->isEmpty() )
- TopologyValidationError::eRingNotClosed,
- ring->getCoordinateN(0));
+ if ( ! ring->isClosed() && ! ring->isEmpty() ) {
+ TopologyValidationError::eRingNotClosed,
+ ring->getCoordinateN(0));
} // namespace geos.operation.valid
Summary of changes:
include/geos/operation/valid/IsValidOp.h | 455 +++++++++---------
src/operation/valid/IsValidOp.cpp | 775 +++++++++++++++----------------
2 files changed, 604 insertions(+), 626 deletions(-)
hooks/post-receive
More information about the geos-commits
