[geos-commits] [SCM] GEOS branch master updated. 0db862d111f7106157be5e662af4f16e70dbbc34
git at osgeo.org
git at osgeo.org
Wed Dec 12 14:27:05 PST 2018
the project "GEOS".
via 0db862d111f7106157be5e662af4f16e70dbbc34 (commit)
via c9328418a83202759f5b2da952ea00af7b4cfabb (commit)
from 6f960a291b0fe91bcd2f7dae2551cffc7875b3c9 (commit)
revisions in full, below.
commit 0db862d111f7106157be5e662af4f16e70dbbc34
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Dec 12 14:26:47 2018 -0800
Add autotools support for new LocatePointInRingTest
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index b6cc377..b3db843 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -48,6 +48,7 @@ geos_unit_SOURCES = \
algorithm/distance/DiscreteFrechetDistanceTest.cpp \
algorithm/distance/DiscreteHausdorffDistanceTest.cpp \
algorithm/InteriorPointAreaTest.cpp \
+ algorithm/LocatePointInRingTest.cpp \
algorithm/MinimumDiameterTest.cpp \
algorithm/OrientationIndexFailureTest.cpp \
algorithm/PointLocatorTest.cpp \
commit c9328418a83202759f5b2da952ea00af7b4cfabb
Date: Wed Dec 12 13:45:54 2018 -0800
Add JTS tests from 9fa51113caeea33551fa8ee2f25fcbab60090004
diff --git a/tests/unit/algorithm/LocatePointInRingTest.cpp b/tests/unit/algorithm/LocatePointInRingTest.cpp
new file mode 100644
index 0000000..4efddb7
--- /dev/null
+++ b/tests/unit/algorithm/LocatePointInRingTest.cpp
@@ -0,0 +1,181 @@
+// Test Suite for geos::algorithm::PointLocator
+// Ported from JTS junit/algorithm/PointLocator.java
+#include <tut/tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+#include <geos/algorithm/PointLocator.h>
+#include <geos/algorithm/CGAlgorithms.h>
+#include <geos/algorithm/RayCrossingCounterDD.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h> // required for use in unique_ptr
+#include <geos/geom/Polygon.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/Coordinate.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+namespace geos {
+ namespace geom {
+ class Geometry;
+using namespace geos::geom; // for Location
+using namespace geos::algorithm; // for Location
+namespace tut
+ // Test Group
+ // dummy data, not used
+ struct test_locatepointinring_data {};
+ typedef test_group<test_locatepointinring_data> group;
+ typedef group::object object;
+ group test_locatepointinring_group("geos::algorithm::LocatePointInRing");
+ // These are static to avoid namespace pollution
+ // The struct test_*_data above is probably there
+ // for the same reason...
+ static PrecisionModel pm;
+ static GeometryFactory::Ptr gf = GeometryFactory::create(&pm);
+ static geos::io::WKTReader reader(gf.get());
+ typedef std::unique_ptr<Geometry> GeomPtr;
+ static void runPtLocator(int expected, const Coordinate& pt,
+ const std::string& wkt)
+ std::unique_ptr<Geometry> geom(reader.read(wkt));
+ const Polygon *poly = dynamic_cast<Polygon*>(geom.get());
+ const CoordinateSequence* cs = poly->getExteriorRing()->getCoordinatesRO();
+ int loc = CGAlgorithms::locatePointInRing(pt, *cs);
+ ensure_equals(loc, expected);
+ static void runPtLocatorDD(int expected, const Coordinate& pt,
+ int loc = RayCrossingCounterDD::locatePointInRing(pt, *cs);
+ const std::string wkt_comb("POLYGON ((0 0, 0 10, 4 5, 6 10, 7 5, 9 10, 10 5, 13 5, 15 10, 16 3, 17 10, 18 3, 25 10, 30 10, 30 0, 15 0, 14 5, 13 0, 9 0, 8 5, 6 0, 0 0))");
+ const std::string wkt_rpts("POLYGON ((0 0, 0 10, 2 5, 2 5, 2 5, 2 5, 2 5, 3 10, 6 10, 8 5, 8 5, 8 5, 8 5, 10 10, 10 5, 10 5, 10 5, 10 5, 10 0, 0 0))");
+ // Test Cases
+ // 1 - Test box
+ template<>
+ template<>
+ void object::test<1>()
+ runPtLocator(
+ Location::INTERIOR,
+ Coordinate(10, 10),
+ "POLYGON ((0 0, 0 20, 20 20, 20 0, 0 0))");
+ // 2 - Test complex ring
+ template<>
+ template<>
+ void object::test<2>()
+ runPtLocator(
+ Coordinate(0, 0),
+ "POLYGON ((-40 80, -40 -80, 20 0, 20 -100, 40 40, 80 -80, 100 80, 140 -20, 120 140, 40 180, 60 40, 0 120, -20 -20, -40 80))");
+ // 3 - Comb tests
+ template<>
+ template<>
+ void object::test<3>()
+ runPtLocator(Location::BOUNDARY, Coordinate(0, 0), wkt_comb);
+ runPtLocator(Location::BOUNDARY, Coordinate(0, 1), wkt_comb);
+ // at vertex
+ runPtLocator(Location::BOUNDARY, Coordinate(4, 5), wkt_comb);
+ runPtLocator(Location::BOUNDARY, Coordinate(8, 5), wkt_comb);
+ // on horizontal segment
+ runPtLocator(Location::BOUNDARY, Coordinate(11, 5), wkt_comb);
+ // on vertical segment
+ runPtLocator(Location::BOUNDARY, Coordinate(30, 5), wkt_comb);
+ // on angled segment
+ runPtLocator(Location::BOUNDARY, Coordinate(22, 7), wkt_comb);
+ runPtLocator(Location::INTERIOR, Coordinate(1, 5), wkt_comb);
+ runPtLocator(Location::INTERIOR, Coordinate(5, 5), wkt_comb);
+ runPtLocator(Location::INTERIOR, Coordinate(1, 7), wkt_comb);
+ runPtLocator(Location::EXTERIOR, Coordinate(12, 10), wkt_comb);
+ runPtLocator(Location::EXTERIOR, Coordinate(16, 5), wkt_comb);
+ runPtLocator(Location::EXTERIOR, Coordinate(35, 5), wkt_comb);
+ // 4 - repeated points
+ template<>
+ template<>
+ void object::test<4>()
+ runPtLocator(Location::BOUNDARY, Coordinate(0, 0), wkt_rpts);
+ runPtLocator(Location::BOUNDARY, Coordinate(0, 1), wkt_rpts);
+ // at vertex
+ runPtLocator(Location::BOUNDARY, Coordinate(2, 5), wkt_rpts);
+ runPtLocator(Location::BOUNDARY, Coordinate(8, 5), wkt_rpts);
+ runPtLocator(Location::BOUNDARY, Coordinate(10, 5), wkt_rpts);
+ runPtLocator(Location::INTERIOR, Coordinate(1, 5), wkt_rpts);
+ runPtLocator(Location::INTERIOR, Coordinate(3, 5), wkt_rpts);
+ // 5 - robustness
+ template<>
+ template<>
+ void object::test<5>()
+ runPtLocatorDD(Location::EXTERIOR,
+ Coordinate(25.374625374625374, 128.35564435564436),
+ "POLYGON ((0.0 0.0, 0.0 172.0, 100.0 0.0, 0.0 0.0))");
+ // 6 - robustness
+ template<>
+ template<>
+ void object::test<6>()
+ runPtLocatorDD(Location::INTERIOR,
+ Coordinate(97.96039603960396, 782.0),
+ "POLYGON ((642.0 815.0, 69.0 764.0, 394.0 966.0, 642.0 815.0))");
+ // 7 - robustness
+ template<>
+ template<>
+ void object::test<7>()
+ Coordinate(3.166572116932842, 48.5390194687463),
+ "POLYGON ((2.152214146946829 50.470470727186765, 18.381941666723034 19.567250592139274, 2.390837642830135 49.228045261718165, 2.152214146946829 50.470470727186765))");
+} // namespace tut
Summary of changes:
tests/unit/Makefile.am | 1 +
tests/unit/algorithm/LocatePointInRingTest.cpp | 181 +++++++++++++++++++++++++
2 files changed, 182 insertions(+)
create mode 100644 tests/unit/algorithm/LocatePointInRingTest.cpp
hooks/post-receive
More information about the geos-commits
