[geos-commits] [SCM] GEOS branch master updated. 5ce4076b7e67f8f978ad34f0127728957edc1c3a
git at osgeo.org
git at osgeo.org
Mon Dec 17 12:14:38 PST 2018
the project "GEOS".
via 5ce4076b7e67f8f978ad34f0127728957edc1c3a (commit)
from c821855f5cb1841e027b22aa8d8f733f37412165 (commit)
revisions in full, below.
commit 5ce4076b7e67f8f978ad34f0127728957edc1c3a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Dec 17 12:14:19 2018 -0800
Move length functions to Length class
JTS 1b7bb75fcdeb1cbde1fe6c6deb2cde18929868d7
diff --git a/include/geos/algorithm/Length.h b/include/geos/algorithm/Length.h
new file mode 100644
index 0000000..4af0b77
--- /dev/null
+++ b/include/geos/algorithm/Length.h
@@ -0,0 +1,53 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2018 Paul Ramsey <pramsey at cleverlephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/Length.java @ 2017-09-04
+#ifndef GEOS_ALGORITHM_LENGTH_H
+#define GEOS_ALGORITHM_LENGTH_H
+#include <geos/export.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+namespace geos {
+namespace algorithm { // geos::algorithm
+* Functions for computing length.
+* @author Martin Davis
+class GEOS_DLL Length {
+public:
+ * Computes the length of a linestring specified by a sequence of points.
+ * @param pts the points specifying the linestring
+ * @return the length of the linestring
+ static double ofLine(const geom::CoordinateSequence *ring);
+} // namespace geos::algorithm
+#endif // GEOS_ALGORITHM_LENGTH_H
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 0c9d319..2791033 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -24,6 +24,7 @@ geos_HEADERS = \
InteriorPointLine.h \
InteriorPointPoint.h \
LineIntersector.h \
+ Length.h \
MinimumDiameter.h \
NotRepresentableException.h \
PointLocator.h \
diff --git a/src/algorithm/Length.cpp b/src/algorithm/Length.cpp
index 0000000..dfb71cb
--- /dev/null
+++ b/src/algorithm/Length.cpp
@@ -0,0 +1,61 @@
+#include <cmath>
+#include <vector>
+#include <geos/algorithm/Length.h>
+namespace geos {
+namespace algorithm { // geos.algorithm
+/* public static */
+double
+Length::ofLine(const geom::CoordinateSequence *pts)
+ // optimized for processing CoordinateSequences
+ size_t n = pts->size();
+ if (n <= 1)
+ return 0.0;
+ double len = 0.0;
+ geom::Coordinate p;
+ p = pts->getAt(0);
+ double x0 = p.x;
+ double y0 = p.y;
+ for (size_t i = 1; i < n; i++) {
+ p = pts->getAt(i);
+ double x1 = p.x;
+ double y1 = p.y;
+ double dx = x1 - x0;
+ double dy = y1 - y0;
+ len += std::sqrt(dx * dx + dy * dy);
+ x0 = x1;
+ y0 = y1;
+ return len;
+} // namespace geos.algorithm
+} //namespace geos
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index 7f84e78..d316f85 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -22,6 +22,7 @@ libalgorithm_la_SOURCES = \
InteriorPointLine.cpp \
InteriorPointPoint.cpp \
LineIntersector.cpp \
+ Length.cpp \
MinimumDiameter.cpp \
NotRepresentableException.cpp \
PointLocator.cpp \
diff --git a/src/geom/LineString.cpp b/src/geom/LineString.cpp
index 14bc1c1..30bcab8 100644
--- a/src/geom/LineString.cpp
+++ b/src/geom/LineString.cpp
@@ -19,7 +19,7 @@
#include <geos/util/IllegalArgumentException.h>
-#include <geos/algorithm/CGAlgorithms.h>
#include <geos/geom/CoordinateSequenceFactory.h>
@@ -375,7 +375,7 @@ LineString::getCoordinate() const
double
LineString::getLength() const
- return CGAlgorithms::length(points.get());
+ return Length::ofLine(points.get());
void
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 9064b1f..2dcbd1c 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -49,6 +49,7 @@ geos_unit_SOURCES = \
algorithm/distance/DiscreteFrechetDistanceTest.cpp \
algorithm/distance/DiscreteHausdorffDistanceTest.cpp \
algorithm/InteriorPointAreaTest.cpp \
+ algorithm/LengthTest.cpp \
algorithm/LocatePointInRingTest.cpp \
algorithm/MinimumDiameterTest.cpp \
algorithm/OrientationIndexFailureTest.cpp \
diff --git a/tests/unit/algorithm/AreaTest.cpp b/tests/unit/algorithm/AreaTest.cpp
index 0c4b209..bc8cc65 100644
--- a/tests/unit/algorithm/AreaTest.cpp
+++ b/tests/unit/algorithm/AreaTest.cpp
@@ -80,23 +80,6 @@ namespace tut
- // using geos::geom::LineString;
- // Geometry::Ptr lineGeom(reader_.read("LINESTRING (30 220, 240 220, 240 220)"));
- // LineString::Ptr line(dynamic_cast<LineString*>(lineGeom.release()));
- // ensure(nullptr != line.get());
- // Geometry::Ptr hullGeom(reader_.read("LINESTRING (30 220, 240 220)"));
- // LineString::Ptr convexHull(dynamic_cast<LineString*>(hullGeom.release()));
- // ensure(nullptr != convexHull.get());
- // geom_ = line->convexHull();
- // ensure( convexHull->equalsExact(geom_) );
typedef test_group<test_area_data> group;
typedef group::object object;
diff --git a/tests/unit/algorithm/LengthTest.cpp b/tests/unit/algorithm/LengthTest.cpp
index 0000000..8b277f7
--- /dev/null
+++ b/tests/unit/algorithm/LengthTest.cpp
@@ -0,0 +1,91 @@
+// Test Suite for geos::algorithm::Length
+// Ported from JTS junit/algorithm/LengthTest.java
+#include <tut/tut.hpp>
+// geos
+#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/Dimension.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/io/WKTReader.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+using namespace geos;
+using namespace geos::geom;
+namespace tut
+ // Test Group
+ // dummy data, not used
+ struct test_length_data {
+ geos::geom::Geometry *geom_;
+ geos::geom::PrecisionModel pm_;
+ geos::geom::GeometryFactory::Ptr factory_;
+ geos::io::WKTReader reader_;
+ test_length_data():
+ geom_(nullptr),
+ pm_(1),
+ factory_(GeometryFactory::create(&pm_, 0)), reader_(factory_.get())
+ assert(nullptr == geom_);
+ ~test_length_data()
+ factory_->destroyGeometry(geom_);
+ geom_ = nullptr;
+ void checkLengthOfLine(std::string wkt, double expectedLength) {
+ std::unique_ptr<Geometry> lineGeom(reader_.read(wkt));
+ std::unique_ptr<LineString> line(dynamic_cast<LineString*>(lineGeom.release()));
+ ensure(nullptr != line.get());
+ const CoordinateSequence *lineSeq = line->getCoordinatesRO();
+ double actual = algorithm::Length::ofLine(lineSeq);
+ ensure_equals(actual, expectedLength);
+ // void checkLengthOfLine(String wkt, double expectedLen) {
+ // LineString ring = (LineString) read(wkt);
+ // CoordinateSequence pts = ring.getCoordinateSequence();
+ // double actual = Length.ofLine(pts);
+ // assertEquals(actual, expectedLen);
+ typedef test_group<test_length_data> group;
+ typedef group::object object;
+ group test_length_group("geos::algorithm::Length");
+ // Test Cases
+ template<>
+ template<>
+ void object::test<1>()
+ checkLengthOfLine("LINESTRING (100 200, 200 200, 200 100, 100 100, 100 200)", 400.0);
+} // namespace tut
Summary of changes:
include/geos/algorithm/Length.h | 53 +++++++++++++++++++++
include/geos/algorithm/Makefile.am | 1 +
src/algorithm/Length.cpp | 61 +++++++++++++++++++++++++
src/algorithm/Makefile.am | 1 +
src/geom/LineString.cpp | 4 +-
tests/unit/Makefile.am | 1 +
tests/unit/algorithm/AreaTest.cpp | 17 -------
tests/unit/algorithm/LengthTest.cpp | 91 +++++++++++++++++++++++++++++++++++++
8 files changed, 210 insertions(+), 19 deletions(-)
create mode 100644 include/geos/algorithm/Length.h
create mode 100644 src/algorithm/Length.cpp
create mode 100644 tests/unit/algorithm/LengthTest.cpp
hooks/post-receive
More information about the geos-commits
