[geos-commits] [SCM] GEOS branch master updated. cda30a1b8d4374b873c2ebcceac1878f87df8126
git at osgeo.org
git at osgeo.org
Mon Dec 17 12:21:25 PST 2018
the project "GEOS".
via cda30a1b8d4374b873c2ebcceac1878f87df8126 (commit)
from 5ce4076b7e67f8f978ad34f0127728957edc1c3a (commit)
revisions in full, below.
commit cda30a1b8d4374b873c2ebcceac1878f87df8126
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Dec 17 12:20:56 2018 -0800
Add some robustness failure tests
(Unfortunately these currently fail on GEOS)
JTS 5b30e1334e5999461eb3d9b80c51375ffa53f810
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index a1c1435..0ea8f77 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -145,6 +145,7 @@ if(GEOS_ENABLE_TESTS)
set(FAILING_XMLTESTS
${XMLTESTS_DIR}/ticket/bug488.xml
${XMLTESTS_DIR}/ticket/bug344.xml
+ ${XMLTESTS_DIR}/robust/TestRobustRelateFloat.xml
${XMLTESTS_DIR}/TestBigNastyBuffer.xml
${XMLTESTS_DIR}/failure/TestOverlay.xml
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index ace4c84..2f7cff5 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -116,6 +116,7 @@ FAILING_XMLTESTS = \
$(srcdir)/tests/failure/TestOverlay.xml \
$(srcdir)/tests/ticket/bug488.xml \
$(srcdir)/tests/ticket/bug344.xml \
+ $(srcdir)/tests/robust/TestRobustRelateFloat.xml \
$(srcdir)/tests/TestBigNastyBuffer.xml
XMLTESTS=$(SAFE_XMLTESTS) $(INVALID_OUTPUT_XMLTESTS) $(FAILING_XMLTESTS)
diff --git a/tests/xmltester/tests/robust/TestRobustRelateFloat.xml b/tests/xmltester/tests/robust/TestRobustRelateFloat.xml
new file mode 100644
index 0000000..5ac5abb
--- /dev/null
+++ b/tests/xmltester/tests/robust/TestRobustRelateFloat.xml
@@ -0,0 +1,38 @@
+<run>
+ <precisionModel type="FLOATING" />
+ <case>
+ <desc>
+ A/P - Point is on boundary of polygon.
+ Orientation algorithms (including CGAlgorithmsDD) fail by incorrectly reporting the point to not be on the boundary.
+ See https://trac.osgeo.org/geos/ticket/841
+ </desc>
+ <a>
+ POLYGON ((0 0, 1 0, 0 1, 0 0))
+ </a>
+ <b>
+ POINT (0.95 0.05)
+ </b>
+ <test>
+ <op name="contains" arg1="A" arg2="B">false</op>
+ </test>
+ </case>
+ <case>
+ <desc>
+ L/L - Line A contains Line B.
+ Fails due to imprecision of computed self-node in A.
+ See https://trac.osgeo.org/geos/ticket/572
+ </desc>
+ <a>
+ LINESTRING (1 0, 0 2, 0 0, 2 2)
+ </a>
+ <b>
+ LINESTRING (0 0, 2 2)
+ </b>
+ <test>
+ <op name="contains" arg1="A" arg2="B">true</op>
+ </test>
+ </case>
+</run>
Summary of changes:
tests/xmltester/CMakeLists.txt | 1 +
tests/xmltester/Makefile.am | 1 +
.../tests/robust/TestRobustRelateFloat.xml | 38 ++++++++++++++++++++++
3 files changed, 40 insertions(+)
create mode 100644 tests/xmltester/tests/robust/TestRobustRelateFloat.xml
hooks/post-receive
More information about the geos-commits
