[geos-commits] [SCM] GEOS branch master updated. baa5f0cae661136dfa03ee3ef5ea93ccf7959192
git at osgeo.org
git at osgeo.org
Tue Dec 18 09:14:05 PST 2018
the project "GEOS".
via baa5f0cae661136dfa03ee3ef5ea93ccf7959192 (commit)
from 21c88492fd359612add729d09fdb45dd1bf7dd0d (commit)
revisions in full, below.
commit baa5f0cae661136dfa03ee3ef5ea93ccf7959192
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Dec 18 09:13:48 2018 -0800
Add some doco
JTS 7a4b7367fd63f545c3ead99583669ab2fbd21676
diff --git a/include/geos/algorithm/Orientation.h b/include/geos/algorithm/Orientation.h
index e0ac45b..d051da2 100644
--- a/include/geos/algorithm/Orientation.h
+++ b/include/geos/algorithm/Orientation.h
@@ -27,7 +27,15 @@ namespace geos {
namespace algorithm { // geos::algorithm
-* Functions to compute the orientation of points, lines and rings.
+* Functions to compute the orientation of basic geometric structures
+* including point triplets (triangles) and rings.
+* Orientation is a fundamental property of planar geometries
+* (and more generally geometry on two-dimensional manifolds).
+* Orientation is notoriously subject to numerical precision errors
+* in the case of collinear or nearly collinear points.
+* JTS uses extended-precision arithmetic to increase
+* the robustness of the computation.
* @author Martin Davis
@@ -46,16 +54,15 @@ public:
- * Returns the index of the direction of the point <code>q</code>
- * relative to a vector specified by <code>p1-p2</code>.
- * @param p1 the origin point of the vector
- * @param p2 the final point of the vector
- * @param q the point to compute the direction to
- * @return 1 if q is counter-clockwise (left) from p1-p2
- * @return -1 if q is clockwise (right) from p1-p2
- * @return 0 if q is collinear with p1-p2
+ * Returns the orientation index of the direction of the point q relative to
+ * a directed infinite line specified by p1-p2.
+ * The index indicates whether the point lies to the
+ * {@link #Orientation::LEFT} or {@link #Orientation::RIGHT}
+ * of the line, or lies on it {@link #Orientation::COLLINEAR}.
+ * The index also indicates the orientation of the triangle formed
+ * by the three points
+ * ( {@link #Orientation::COUNTERCLOCKWISE},
+ * {@link #Orientation::CLOCKWISE}, or {@link #Orientation::STRAIGHT} )
static int index(const geom::Coordinate &p1,
const geom::Coordinate &p2, const geom::Coordinate &q);
@@ -63,11 +70,11 @@ public:
* Computes whether a ring defined by an array of {@link Coordinate}s is
* oriented counter-clockwise.
- * <ul>
- * <li>The list of points is assumed to have the first and last points equal.
- * <li>This will handle coordinate lists which contain repeated points.
- * </ul>
- * This algorithm is <b>only</b> guaranteed to work with valid rings. If the
+ * - The list of points is assumed to have the first and last points equal.
+ * - This will handle coordinate lists which contain repeated points.
+ * This algorithm is *only<* guaranteed to work with valid rings. If the
* ring is invalid (e.g. self-crosses or touches), the computed result may not
* be correct.
Summary of changes:
include/geos/algorithm/Orientation.h | 39 +++++++++++++++++++++---------------
1 file changed, 23 insertions(+), 16 deletions(-)
hooks/post-receive
More information about the geos-commits
