[geos-commits] [SCM] GEOS branch master updated. f13e1508efebf5ececd9ea0c13a61e34db4e62f1
git at osgeo.org
git at osgeo.org
Tue Dec 18 14:24:43 PST 2018
the project "GEOS".
via f13e1508efebf5ececd9ea0c13a61e34db4e62f1 (commit)
from baa5f0cae661136dfa03ee3ef5ea93ccf7959192 (commit)
revisions in full, below.
commit f13e1508efebf5ececd9ea0c13a61e34db4e62f1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Dec 18 14:24:20 2018 -0800
Move CGAlgorithms point location functions to PointLocation
JTS 555e2cbc45ce6207e3b4df9842cbb25220c494d5
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 383e468..a478639 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -44,7 +44,7 @@
#include <geos/io/WKTWriter.h>
#include <geos/io/WKBWriter.h>
#include <geos/algorithm/BoundaryNodeRule.h>
-#include <geos/algorithm/CGAlgorithms.h>
+#include <geos/algorithm/Orientation.h>
#include <geos/algorithm/MinimumDiameter.h>
#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
@@ -6776,7 +6776,7 @@ int GEOSOrientationIndex_r(GEOSContextHandle_t extHandle,
GEOSContextHandleInternal_t *handle = 0;
using geos::geom::Coordinate;
- using geos::algorithm::CGAlgorithms;
+ using geos::algorithm::Orientation;
if ( 0 == extHandle )
@@ -6794,7 +6794,7 @@ int GEOSOrientationIndex_r(GEOSContextHandle_t extHandle,
Coordinate A(Ax, Ay);
Coordinate B(Bx, By);
Coordinate P(Px, Py);
- return CGAlgorithms::orientationIndex(A, B, P);
+ return Orientation::index(A, B, P);
catch (const std::exception &e)
diff --git a/include/geos/algorithm/Angle.h b/include/geos/algorithm/Angle.h
index 9b6d00c..314d5e4 100644
--- a/include/geos/algorithm/Angle.h
+++ b/include/geos/algorithm/Angle.h
@@ -20,7 +20,7 @@
#define GEOS_ALGORITHM_ANGLE_H
#include <geos/export.h>
-#include <geos/algorithm/CGAlgorithms.h> // for constants
+#include <geos/algorithm/Orientation.h> // for constants
// Forward declarations
namespace geos {
@@ -45,13 +45,13 @@ public:
static const double PI_OVER_4; // PI / 4.0;
/// Constant representing counterclockwise orientation
- static const int COUNTERCLOCKWISE = CGAlgorithms::COUNTERCLOCKWISE;
+ static const int COUNTERCLOCKWISE = Orientation::COUNTERCLOCKWISE;
/// Constant representing clockwise orientation
- static const int CLOCKWISE = CGAlgorithms::CLOCKWISE;
+ static const int CLOCKWISE = Orientation::CLOCKWISE;
/// Constant representing no orientation
- static const int NONE = CGAlgorithms::COLLINEAR;
+ static const int NONE = Orientation::COLLINEAR;
/// Converts from radians to degrees.
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 113c1fb..0906469 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -28,6 +28,7 @@ geos_HEADERS = \
MinimumDiameter.h \
NotRepresentableException.h \
Orientation.h \
+ PointLocation.h \
PointLocator.h \
RayCrossingCounter.h \
RayCrossingCounterDD.h \
diff --git a/include/geos/algorithm/PointLocation.h b/include/geos/algorithm/PointLocation.h
new file mode 100644
index 0000000..7761d4c
--- /dev/null
+++ b/include/geos/algorithm/PointLocation.h
@@ -0,0 +1,105 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2018 Paul Ramsey <pramsey at cleverlephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/PointLocation.java @ 2017-09-04
+#ifndef GEOS_ALGORITHM_POINTLOCATION_H
+#define GEOS_ALGORITHM_POINTLOCATION_H
+#include <geos/export.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+namespace geos {
+namespace algorithm { // geos::algorithm
+ * Functions for locating points within basic geometric
+ * structures such as lines and rings.
+ * @author Martin Davis
+class GEOS_DLL PointLocation {
+public:
+ * Tests whether a point lies on the line defined by a list of
+ * coordinates.
+ * @param p the point to test
+ * @param line the line coordinates
+ * @return true if the point is a vertex of the line or lies in the interior
+ * of a line segment in the line
+ //static bool isOnLine(const Coordinate &p, const std::vector<Coordinate> &line);
+ * {@link CoordinateSequence}.
+ static bool isOnLine(const geom::Coordinate &p, const geom::CoordinateSequence *line);
+ * Tests whether a point lies inside or on a ring. The ring may be oriented in
+ * either direction. A point lying exactly on the ring boundary is considered
+ * to be inside the ring.
+ * This method does *not* first check the point against the envelope of
+ * the ring.
+ * @param p
+ * point to check for ring inclusion
+ * @param ring
+ * an array of coordinates representing the ring (which must have
+ * first point identical to last point)
+ * @return true if p is inside ring
+ * @see locatePointInRing
+ static bool isInRing(const geom::Coordinate &p, const std::vector<const geom::Coordinate*> &ring);
+ static bool isInRing(const geom::Coordinate &p, const geom::CoordinateSequence *ring);
+ * Determines whether a point lies in the interior, on the boundary, or in the
+ * exterior of a ring. The ring may be oriented in either direction.
+ * the ring.
+ * @param p
+ * @param ring
+ * @return the {@link Location} of p relative to the ring
+ static int locateInRing(const geom::Coordinate &p, const std::vector<const geom::Coordinate*> &ring);
+ static int locateInRing(const geom::Coordinate &p, const geom::CoordinateSequence &ring);
+} // namespace geos::algorithm
+#endif // GEOS_ALGORITHM_POINTLOCATION_H
diff --git a/include/geos/geosAlgorithm.h b/include/geos/geosAlgorithm.h
index d77d2b4..1b1224b 100644
--- a/include/geos/geosAlgorithm.h
+++ b/include/geos/geosAlgorithm.h
@@ -26,7 +26,6 @@
#ifndef GEOS_ALGORITHM_H
#define GEOS_ALGORITHM_H
-//#include <geos/algorithm/CGAlgorithms.h>
//#include <geos/algorithm/ConvexHull.h>
//#include <geos/algorithm/HCoordinate.h>
//#include <geos/algorithm/InteriorPointArea.h>
diff --git a/include/geos/operation/buffer/BufferInputLineSimplifier.h b/include/geos/operation/buffer/BufferInputLineSimplifier.h
index 00ad99f..89d128d 100644
--- a/include/geos/operation/buffer/BufferInputLineSimplifier.h
+++ b/include/geos/operation/buffer/BufferInputLineSimplifier.h
@@ -20,7 +20,6 @@
#define GEOS_OP_BUFFER_BUFFERINPUTLINESIMPLIFIER_H
#include <geos/geom/CoordinateSequence.h> // complete type required
-#include <geos/algorithm/CGAlgorithms.h> // for enum
#include <memory>
#include <vector> // for composition
diff --git a/src/algorithm/Angle.cpp b/src/algorithm/Angle.cpp
index 2087b38..c05e758 100644
--- a/src/algorithm/Angle.cpp
+++ b/src/algorithm/Angle.cpp
@@ -19,7 +19,6 @@
#include <cmath>
#include <geos/algorithm/Angle.h>
namespace geos {
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index 1f026e3..5022ee2 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -54,6 +54,9 @@ int CGAlgorithmsDD::orientationIndex(const Coordinate& p1,
const Coordinate& p2,
const Coordinate& q)
+ if (ISNAN(q.x) || ISNAN(q.y) || !FINITE(q.x) || !FINITE(q.y)) {
+ throw util::IllegalArgumentException("CGAlgorithmsDD::orientationIndex encountered NaN/Inf numbers");
static DD const zero(0.0);
DD dx1 = DD(p2.x) + DD(-p1.x);
DD dy1 = DD(p2.y) + DD(-p1.y);
diff --git a/src/algorithm/ConvexHull.cpp b/src/algorithm/ConvexHull.cpp
index 8da34c4..80a634b 100644
--- a/src/algorithm/ConvexHull.cpp
+++ b/src/algorithm/ConvexHull.cpp
@@ -19,7 +19,7 @@
+#include <geos/algorithm/PointLocation.h>
#include <geos/geom/GeometryFactory.h>
@@ -203,7 +203,7 @@ ConvexHull::reduce(Coordinate::ConstVect &pts)
for (size_t i=0, n=pts.size(); i<n; ++i)
- if ( !CGAlgorithms::isPointInRing(*(pts[i]), polyPts) )
+ if ( !PointLocation::isInRing(*(pts[i]), polyPts) )
reducedSet.insert(pts[i]);
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index 0ca981a..61b7a47 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -20,6 +20,7 @@
#include <geos/platform.h>
#include <geos/algorithm/LineIntersector.h>
#include <geos/algorithm/NotRepresentableException.h>
//#include <geos/algorithm/CentralEndpointIntersector.h>
@@ -337,8 +338,8 @@ LineIntersector::computeIntersection(const Coordinate& p,const Coordinate& p1,co
// do between check first, since it is faster than the orientation test
if(Envelope::intersects(p1,p2,p)) {
- if ((CGAlgorithms::orientationIndex(p1,p2,p)==0)&&
- (CGAlgorithms::orientationIndex(p2,p1,p)==0)) {
+ if ((Orientation::index(p1,p2,p)==0)&&
+ (Orientation::index(p2,p1,p)==0)) {
isProperVar=true;
if ((p==p1)||(p==p2)) // 2d only test
@@ -370,8 +371,8 @@ bool
LineIntersector::hasIntersection(const Coordinate& p, const Coordinate& p1, const Coordinate& p2)
return true;
@@ -401,8 +402,8 @@ LineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,cons
// for each endpoint, compute which side of the other segment it lies
// if both endpoints lie on the same side of the other segment,
// the segments do not intersect
- int Pq1=CGAlgorithms::orientationIndex(p1,p2,q1);
- int Pq2=CGAlgorithms::orientationIndex(p1,p2,q2);
+ int Pq1=Orientation::index(p1,p2,q1);
+ int Pq2=Orientation::index(p1,p2,q2);
if ((Pq1>0 && Pq2>0) || (Pq1<0 && Pq2<0))
@@ -412,8 +413,8 @@ LineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,cons
return NO_INTERSECTION;
- int Qp1=CGAlgorithms::orientationIndex(q1,q2,p1);
- int Qp2=CGAlgorithms::orientationIndex(q1,q2,p2);
+ int Qp1=Orientation::index(q1,q2,p1);
+ int Qp2=Orientation::index(q1,q2,p2);
if ((Qp1>0 && Qp2>0)||(Qp1<0 && Qp2<0)) {
#if GEOS_DEBUG
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index 7c9f7f9..fc1a1bb 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -26,6 +26,7 @@ libalgorithm_la_SOURCES = \
MinimumDiameter.cpp \
NotRepresentableException.cpp \
Orientation.cpp \
+ PointLocation.cpp \
PointLocator.cpp \
RayCrossingCounter.cpp \
RayCrossingCounterDD.cpp \
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index dcedac0..13a7215 100644
--- a/src/algorithm/Orientation.cpp
+++ b/src/algorithm/Orientation.cpp
@@ -20,7 +20,6 @@
#include <vector>
#include <geos/algorithm/CGAlgorithmsDD.h>
diff --git a/src/algorithm/PointLocation.cpp b/src/algorithm/PointLocation.cpp
index 0000000..682c0c1
--- /dev/null
+++ b/src/algorithm/PointLocation.cpp
@@ -0,0 +1,87 @@
+#include <cmath>
+#include <vector>
+#include <geos/algorithm/LineIntersector.h>
+#include <geos/algorithm/RayCrossingCounter.h>
+#include <geos/geom/Location.h>
+#include <geos/util/IllegalArgumentException.h>
+namespace geos {
+namespace algorithm { // geos.algorithm
+/* public static */
+bool
+PointLocation::isOnLine(const geom::Coordinate& p, const geom::CoordinateSequence* pt)
+ size_t ptsize = pt->getSize();
+ if (ptsize == 0)
+ return false;
+ const geom::Coordinate *pp = &(pt->getAt(0));
+ for(size_t i = 1; i < ptsize; ++i)
+ const geom::Coordinate &p1 = pt->getAt(i);
+ if (LineIntersector::hasIntersection(p, *pp, p1))
+ return true;
+ pp = &p1;
+ return false;
+bool
+PointLocation::isInRing(const geom::Coordinate &p,
+ const std::vector<const geom::Coordinate*> &ring)
+ return PointLocation::locateInRing(p, ring) != geom::Location::EXTERIOR;
+bool
+ const geom::CoordinateSequence *ring)
+ return PointLocation::locateInRing(p, *ring) != geom::Location::EXTERIOR;
+int
+PointLocation::locateInRing(const geom::Coordinate &p,
+ return RayCrossingCounter::locatePointInRing(p, ring);
+int
+ const geom::CoordinateSequence &ring)
+} // namespace geos.algorithm
diff --git a/src/algorithm/PointLocator.cpp b/src/algorithm/PointLocator.cpp
index 448dd85..ff57507 100644
--- a/src/algorithm/PointLocator.cpp
+++ b/src/algorithm/PointLocator.cpp
@@ -18,7 +18,7 @@
#include <geos/algorithm/PointLocator.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/Point.h>
#include <geos/geom/LineString.h>
@@ -131,14 +131,15 @@ PointLocator::locate(const Coordinate& p, const LineString *l)
if (!l->getEnvelopeInternal()->intersects(p))
return Location::EXTERIOR;
- const CoordinateSequence* pt=l->getCoordinatesRO();
+ const CoordinateSequence* seq = l->getCoordinatesRO();
if (! l->isClosed()) {
- if ((p==pt->getAt(0)) || (p==pt->getAt(pt->getSize()-1))) {
+ if ((p == seq->getAt(0)) || (p == seq->getAt(seq->getSize()-1))) {
return Location::BOUNDARY;
- if (CGAlgorithms::isOnLine(p,pt))
+ if (PointLocation::isOnLine(p, seq)) {
return Location::INTERIOR;
@@ -152,10 +153,12 @@ PointLocator::locateInPolygonRing(const Coordinate& p, const LinearRing *ring)
const CoordinateSequence *cl = ring->getCoordinatesRO();
- if (CGAlgorithms::isOnLine(p,cl))
+ if (PointLocation::isOnLine(p,cl)) {
- if (CGAlgorithms::isPointInRing(p,cl))
+ if (PointLocation::isInRing(p,cl)) {
diff --git a/src/algorithm/SimplePointInRing.cpp b/src/algorithm/SimplePointInRing.cpp
index b4bf72c..b45a446 100644
--- a/src/algorithm/SimplePointInRing.cpp
+++ b/src/algorithm/SimplePointInRing.cpp
@@ -14,7 +14,7 @@
#include <geos/algorithm/SimplePointInRing.h>
#include <geos/geom/LinearRing.h>
@@ -35,7 +35,7 @@ SimplePointInRing::~SimplePointInRing(){
bool SimplePointInRing::isInside(const geom::Coordinate& pt){
- return CGAlgorithms::isPointInRing(pt,pts);
+ return PointLocation::isInRing(pt,pts);
diff --git a/src/algorithm/distance/DiscreteHausdorffDistance.cpp b/src/algorithm/distance/DiscreteHausdorffDistance.cpp
index 7e8fc3b..745cc0f 100644
--- a/src/algorithm/distance/DiscreteHausdorffDistance.cpp
+++ b/src/algorithm/distance/DiscreteHausdorffDistance.cpp
@@ -19,13 +19,6 @@
-//#include <geos/geom/Geometry.h>
-//#include <geos/geom/Polygon.h>
-//#include <geos/geom/GeometryCollection.h>
-//#include <geos/geom/Location.h>
-//#include <geos/geom/LineString.h>
#include <typeinfo>
#include <cassert>
diff --git a/src/algorithm/locate/SimplePointInAreaLocator.cpp b/src/algorithm/locate/SimplePointInAreaLocator.cpp
index b20ef58..a5d1029 100644
--- a/src/algorithm/locate/SimplePointInAreaLocator.cpp
+++ b/src/algorithm/locate/SimplePointInAreaLocator.cpp
@@ -13,7 +13,7 @@
#include <geos/algorithm/locate/SimplePointInAreaLocator.h>
@@ -73,7 +73,7 @@ SimplePointInAreaLocator::locatePointInPolygon(const Coordinate& p, const Polygo
const LineString *shell=poly->getExteriorRing();
const CoordinateSequence *cl;
cl = shell->getCoordinatesRO();
- int shellLoc = CGAlgorithms::locatePointInRing(p,*cl);
+ int shellLoc = PointLocation::locateInRing(p,*cl);
if (shellLoc != Location::INTERIOR)
return shellLoc;
@@ -82,7 +82,7 @@ SimplePointInAreaLocator::locatePointInPolygon(const Coordinate& p, const Polygo
const LineString *hole = poly->getInteriorRingN(i);
cl = hole->getCoordinatesRO();
- int holeLoc = CGAlgorithms::locatePointInRing(p,*cl);
+ int holeLoc = PointLocation::locateInRing(p,*cl);
if (holeLoc == Location::BOUNDARY)
if (holeLoc == Location::INTERIOR)
diff --git a/src/geom/GeometryCollection.cpp b/src/geom/GeometryCollection.cpp
index 3ead8fa..91cdd4d 100644
--- a/src/geom/GeometryCollection.cpp
+++ b/src/geom/GeometryCollection.cpp
@@ -18,7 +18,6 @@
#include <geos/geom/CoordinateSequenceFilter.h>
diff --git a/src/geom/LineSegment.cpp b/src/geom/LineSegment.cpp
index 96f0fed..c7d29a2 100644
--- a/src/geom/LineSegment.cpp
+++ b/src/geom/LineSegment.cpp
@@ -24,7 +24,7 @@
#include <geos/geom/CoordinateArraySequence.h> // should we really be using this?
@@ -165,8 +165,8 @@ LineSegment::equalsTopo(const LineSegment& other) const
int
LineSegment::orientationIndex(const LineSegment& seg) const
- int orient0 = algorithm::CGAlgorithms::orientationIndex(p0, p1, seg.p0);
- int orient1 = algorithm::CGAlgorithms::orientationIndex(p0, p1, seg.p1);
+ int orient0 = algorithm::Orientation::index(p0, p1, seg.p0);
+ int orient1 = algorithm::Orientation::index(p0, p1, seg.p1);
// this handles the case where the points are L or collinear
if (orient0 >= 0 && orient1 >= 0)
return std::max(orient0, orient1);
diff --git a/src/geom/MultiLineString.cpp b/src/geom/MultiLineString.cpp
index 3aab661..5f875d3 100644
--- a/src/geom/MultiLineString.cpp
+++ b/src/geom/MultiLineString.cpp
@@ -18,7 +18,6 @@
#include <geos/geomgraph/GeometryGraph.h>
#include <geos/geom/MultiLineString.h>
diff --git a/src/geomgraph/EdgeRing.cpp b/src/geomgraph/EdgeRing.cpp
index 1c602f8..aa60a1e 100644
--- a/src/geomgraph/EdgeRing.cpp
+++ b/src/geomgraph/EdgeRing.cpp
@@ -20,7 +20,7 @@
#include <geos/util/Assert.h>
#include <geos/util/TopologyException.h>
#include <geos/geomgraph/EdgeRing.h>
#include <geos/geomgraph/DirectedEdge.h>
@@ -380,7 +380,7 @@ EdgeRing::containsPoint(const Coordinate& p)
assert(env);
if ( ! env->contains(p) ) return false;
- if ( ! CGAlgorithms::isPointInRing(p, ring->getCoordinatesRO()) )
+ if ( ! PointLocation::isInRing(p, ring->getCoordinatesRO()) )
return false;
for (vector<EdgeRing*>::iterator i=holes.begin(); i<holes.end(); ++i)
diff --git a/src/operation/buffer/OffsetCurveBuilder.cpp b/src/operation/buffer/OffsetCurveBuilder.cpp
index 54b48ba..0bf5c35 100644
--- a/src/operation/buffer/OffsetCurveBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveBuilder.cpp
@@ -22,7 +22,6 @@
#include <cmath>
#include <vector>
#include <geos/operation/buffer/OffsetCurveBuilder.h>
#include <geos/operation/buffer/BufferInputLineSimplifier.h>
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index 3178c46..217d250 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -12,7 +12,7 @@
#include <geos/operation/intersection/RectangleIntersection.h>
#include <geos/operation/intersection/Rectangle.h>
@@ -35,6 +35,7 @@
using geos::operation::intersection::Rectangle;
using geos::operation::intersection::RectangleIntersectionBuilder;
using namespace geos::geom;
+using namespace geos::algorithm;
namespace geos {
namespace operation { // geos::operation
namespace intersection { // geos::operation::intersection
@@ -125,8 +126,6 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString * gi,
RectangleIntersectionBuilder & parts,
const Rectangle & rect)
- using namespace geos::geom;
auto n = gi->getNumPoints();
if(gi == nullptr || n<1)
@@ -470,14 +469,13 @@ RectangleIntersection::clip_polygon_to_polygons(const geom::Polygon * g,
// If there were no intersections, the outer ring might be
// completely outside.
if( parts.empty() )
Coordinate rectCenter(rect.xmin(), rect.ymin());
rectCenter.x += (rect.xmax()-rect.xmin())/2;
rectCenter.y += (rect.ymax()-rect.ymin())/2;
- if ( CGAlgorithms::locatePointInRing(rectCenter,
+ if ( PointLocation::locateInRing(rectCenter,
*g->getExteriorRing()->getCoordinatesRO())
!= Location::INTERIOR )
@@ -525,11 +523,11 @@ RectangleIntersection::clip_polygon_to_polygons(const geom::Polygon * g,
else
- if( CGAlgorithms::isPointInRing(rectCenter,
+ if( PointLocation::isInRing(rectCenter,
g->getInteriorRingN(i)->getCoordinatesRO()) )
// Completely inside the hole
diff --git a/src/operation/intersection/RectangleIntersectionBuilder.cpp b/src/operation/intersection/RectangleIntersectionBuilder.cpp
index a83ab0b..a80cb5e 100644
--- a/src/operation/intersection/RectangleIntersectionBuilder.cpp
+++ b/src/operation/intersection/RectangleIntersectionBuilder.cpp
@@ -21,7 +21,7 @@
#include <cmath> // for fabs()
@@ -472,14 +472,14 @@ RectangleIntersectionBuilder::reconnectPolygons(const Rectangle & rect)
else
+ using geos::algorithm::PointLocation;
geom::Coordinate c;
hole->getCoordinatesRO()->getAt(0, c);
for (ShellAndHolesList::iterator p_i=exterior.begin(), p_e=exterior.end(); p_i!=p_e; ++p_i)
ShellAndHoles &p = *p_i;
const CoordinateSequence *shell_cs = p.first->getCoordinatesRO();
- if( CGAlgorithms::isPointInRing(c, shell_cs) )
+ if( PointLocation::isInRing(c, shell_cs) )
// add hole to shell
p.second->push_back(hole->clone());
diff --git a/src/operation/overlay/PolygonBuilder.cpp b/src/operation/overlay/PolygonBuilder.cpp
index f46bd52..f3ea383 100644
--- a/src/operation/overlay/PolygonBuilder.cpp
+++ b/src/operation/overlay/PolygonBuilder.cpp
@@ -28,7 +28,7 @@
#include <geos/util/GEOSException.h>
#include <geos/util.h>
@@ -348,7 +348,7 @@ PolygonBuilder::findEdgeRingContaining(EdgeRing *testEr,
Coordinate testPt = operation::polygonize::EdgeRing::ptNotInList(testRing->getCoordinatesRO(), tsrcs);
bool isContained=false;
- if(CGAlgorithms::isPointInRing(testPt, tsrcs))
+ if(PointLocation::isInRing(testPt, tsrcs))
isContained=true;
// check if this new containing ring is smaller than
diff --git a/src/operation/polygonize/EdgeRing.cpp b/src/operation/polygonize/EdgeRing.cpp
index 52503f1..437d302 100644
--- a/src/operation/polygonize/EdgeRing.cpp
+++ b/src/operation/polygonize/EdgeRing.cpp
@@ -26,7 +26,7 @@
#include <geos/geom/Envelope.h>
#include <geos/geom/CoordinateSequenceFactory.h>
#include <geos/util.h> // TODO: drop this, includes too much
@@ -78,7 +78,7 @@ EdgeRing::findEdgeRingContaining(EdgeRing *testEr,
// TODO: don't copy testPt !
testPt = ptNotInList(testRing->getCoordinatesRO(), tryCoords);
- if ( CGAlgorithms::isPointInRing(testPt, tryCoords) ) {
+ if ( PointLocation::isInRing(testPt, tryCoords) ) {
isContained=true;
diff --git a/src/operation/valid/IndexedNestedRingTester.cpp b/src/operation/valid/IndexedNestedRingTester.cpp
index 16c3886..c0bd588 100644
--- a/src/operation/valid/IndexedNestedRingTester.cpp
+++ b/src/operation/valid/IndexedNestedRingTester.cpp
@@ -19,7 +19,7 @@
#include "IndexedNestedRingTester.h"
#include <geos/geom/LinearRing.h> // for use
-#include <geos/algorithm/CGAlgorithms.h> // for use
+#include <geos/algorithm/PointLocation.h> // for use
#include <geos/operation/valid/IsValidOp.h> // for use (findPtNotNode)
#include <geos/index/strtree/STRtree.h> // for use
@@ -81,7 +81,7 @@ IndexedNestedRingTester::isNonNested()
// the search ring
assert(innerRingPt!=nullptr);
- bool isInside = algorithm::CGAlgorithms::isPointInRing(
+ bool isInside = algorithm::PointLocation::isInRing(
*innerRingPt, searchRingPts);
if (isInside) {
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index a77732f..c7a3d18 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -23,8 +23,8 @@
#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
#include <geos/operation/valid/ConnectedInteriorTester.h>
#include <geos/operation/valid/ConsistentAreaTester.h>
@@ -506,7 +506,7 @@ IsValidOp::checkShellNotNested(const LinearRing *shell, const Polygon *p,
// is outside the polygon
if (shellPt==nullptr) return;
- bool insidePolyShell=CGAlgorithms::isPointInRing(*shellPt, polyPts);
+ bool insidePolyShell=PointLocation::isInRing(*shellPt, polyPts);
if (!insidePolyShell) return;
// if no holes, this is an error!
@@ -555,7 +555,7 @@ IsValidOp::checkShellInsideHole(const LinearRing *shell,
// if point is on shell but not hole, check that the shell is
// inside the hole
if (shellPt) {
- bool insideHole=CGAlgorithms::isPointInRing(*shellPt, holePts);
+ bool insideHole=PointLocation::isInRing(*shellPt, holePts);
if (!insideHole) return shellPt;
@@ -564,7 +564,7 @@ IsValidOp::checkShellInsideHole(const LinearRing *shell,
// if point is on hole but not shell, check that the hole is
// outside the shell
if (holePt) {
- bool insideShell=CGAlgorithms::isPointInRing(*holePt, shellPts);
+ bool insideShell=PointLocation::isInRing(*holePt, shellPts);
if (insideShell) return holePt;
return nullptr;
diff --git a/src/operation/valid/QuadtreeNestedRingTester.cpp b/src/operation/valid/QuadtreeNestedRingTester.cpp
index 897bba5..e8889e5 100644
--- a/src/operation/valid/QuadtreeNestedRingTester.cpp
+++ b/src/operation/valid/QuadtreeNestedRingTester.cpp
@@ -20,7 +20,7 @@
#include <geos/operation/valid/QuadtreeNestedRingTester.h>
#include <geos/index/quadtree/Quadtree.h>
@@ -97,7 +97,7 @@ QuadtreeNestedRingTester::isNonNested()
// Unable to find a ring point not a node of the search ring
- bool isInside=CGAlgorithms::isPointInRing(*innerRingPt,searchRingPts);
+ bool isInside=PointLocation::isInRing(*innerRingPt,searchRingPts);
if (isInside) {
* innerRingPt is const just because the input
diff --git a/src/operation/valid/SimpleNestedRingTester.cpp b/src/operation/valid/SimpleNestedRingTester.cpp
index 7f23044..31aa8f0 100644
--- a/src/operation/valid/SimpleNestedRingTester.cpp
+++ b/src/operation/valid/SimpleNestedRingTester.cpp
@@ -19,7 +19,7 @@
#include <geos/operation/valid/SimpleNestedRingTester.h>
@@ -49,7 +49,7 @@ SimpleNestedRingTester::isNonNested()
if (isInside) {
diff --git a/src/operation/valid/SweeplineNestedRingTester.cpp b/src/operation/valid/SweeplineNestedRingTester.cpp
index d72821f..298f66e 100644
--- a/src/operation/valid/SweeplineNestedRingTester.cpp
+++ b/src/operation/valid/SweeplineNestedRingTester.cpp
@@ -21,7 +21,7 @@
#include <geos/index/sweepline/SweepLineInterval.h>
#include <geos/index/sweepline/SweepLineIndex.h>
#include <cassert>
@@ -85,7 +85,7 @@ SweeplineNestedRingTester::isInside(LinearRing *innerRing,LinearRing *searchRing
- bool p_isInside=CGAlgorithms::isPointInRing(*innerRingPt,searchRingPts);
+ bool p_isInside = PointLocation::isInRing(*innerRingPt,searchRingPts);
if (p_isInside) {
diff --git a/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp b/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
index 2e62f85..2007ae3 100644
--- a/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
@@ -1,10 +1,10 @@
-// Test Suite for CGAlgorithms::isPointInRing() function
+// Test Suite for PointLocation::isInRing() function
// tut
#include <tut/tut.hpp>
// geos
@@ -45,7 +45,7 @@ namespace tut
typedef test_group<test_ispointinring_data> group;
typedef group::object object;
- group test_ispointintring_group("geos::algorithm::CGAlgorithms::isPointInRing");
+ group test_ispointintring_group("geos::algorithm::PointLocation::isInRing");
// Test Cases
@@ -62,7 +62,7 @@ namespace tut
geos::geom::Coordinate pt(10, 10);
cs_ = geom->getCoordinates();
- bool isInRing = CGAlgorithms::isPointInRing(pt, cs_);
+ bool isInRing = PointLocation::isInRing(pt, cs_);
ensure_equals( true, isInRing );
@@ -80,7 +80,7 @@ namespace tut
geos::geom::Coordinate pt(0, 0);
diff --git a/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp b/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
index c5d1aba..0f9718a 100644
--- a/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
@@ -1,10 +1,10 @@
-// Test Suite for CGAlgorithms::signedArea() function
+// Test Suite for Area::ofRingSigned() function
// tut
// geos
+#include <geos/algorithm/Area.h>
@@ -49,7 +49,7 @@ namespace tut
typedef test_group<test_signedarea_data> group;
- group test_signedarea_group("geos::algorithm::CGAlgorithms::signedArea");
+ group test_signedarea_group("geos::algorithm::Area::ofRingSigned");
// Test Cases
@@ -64,7 +64,7 @@ namespace tut
GeometryPtr geom(reader_.read(wkt));
- double area = CGAlgorithms::signedArea(cs_);
+ double area = Area::ofRingSigned(cs_);
ensure_equals( area, 8400 );
@@ -78,7 +78,7 @@ namespace tut
ensure_equals( area, -2400 );
@@ -92,7 +92,7 @@ namespace tut
diff --git a/tests/unit/algorithm/LocatePointInRingTest.cpp b/tests/unit/algorithm/LocatePointInRingTest.cpp
index fe0f61e..49c054f 100644
--- a/tests/unit/algorithm/LocatePointInRingTest.cpp
+++ b/tests/unit/algorithm/LocatePointInRingTest.cpp
@@ -6,7 +6,7 @@
// geos
#include <geos/io/WKTReader.h>
#include <geos/algorithm/RayCrossingCounterDD.h>
#include <geos/geom/PrecisionModel.h>
@@ -56,7 +56,7 @@ namespace tut
std::unique_ptr<Geometry> geom(reader.read(wkt));
const Polygon *poly = dynamic_cast<Polygon*>(geom.get());
const CoordinateSequence* cs = poly->getExteriorRing()->getCoordinatesRO();
- int loc = CGAlgorithms::locatePointInRing(pt, *cs);
+ int loc = PointLocation::locateInRing(pt, *cs);
ensure_equals(loc, expected);
diff --git a/tests/unit/algorithm/OrientationIndexFailureTest.cpp b/tests/unit/algorithm/OrientationIndexFailureTest.cpp
index 47668b1..ddd20c2 100644
--- a/tests/unit/algorithm/OrientationIndexFailureTest.cpp
+++ b/tests/unit/algorithm/OrientationIndexFailureTest.cpp
@@ -1,12 +1,11 @@
-// Test Suite for geos::algorithm::CGAlgorithmsDD
+// Test Suite for geos::algorithm::Orientation
// Ported from JTS junit/algorithm/OrientationIndexFailureTest.java
// geos
-#include <geos/algorithm/CGAlgorithmsDD.h>
// std
#include <sstream>
#include <string>
@@ -31,10 +30,10 @@ namespace tut
static int checkOrientation(Coordinate &c1, Coordinate &c2, Coordinate &c3)
- int orient0 = CGAlgorithmsDD::orientationIndex(c1, c2, c3);
- int orient1 = CGAlgorithmsDD::orientationIndex(c2, c3, c1);
- int orient2 = CGAlgorithmsDD::orientationIndex(c3, c1, c2);
- return (orient0 == orient1) && (orient0 == orient2);
+ int orient0 = Orientation::index(c1, c2, c3);
+ int orient1 = Orientation::index(c2, c3, c1);
+ int orient2 = Orientation::index(c3, c1, c2);
+ return (orient0 == orient1) && (orient0 == orient2);
diff --git a/tests/unit/algorithm/RobustLineIntersectorTest.cpp b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
index f57ab91..68763ac 100644
--- a/tests/unit/algorithm/RobustLineIntersectorTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
@@ -6,7 +6,7 @@
#include <geos/io/WKBReader.h>
@@ -24,7 +24,7 @@
using namespace geos::geom; //
using geos::algorithm::LineIntersector;
-using geos::algorithm::CGAlgorithms;
+using geos::algorithm::PointLocation;
@@ -244,7 +244,7 @@ namespace tut
GeomPtr p ( factory->createPoint(q) );
ensure(!l->intersects(p.get()));
- ensure(!CGAlgorithms::isOnLine(q, cs));
+ ensure(!PointLocation::isOnLine(q, cs));
ensure_equals(Orientation::index(p1, p2, q), -1);
Summary of changes:
capi/geos_ts_c.cpp | 6 +-
include/geos/algorithm/Angle.h | 8 +-
include/geos/algorithm/Makefile.am | 1 +
include/geos/algorithm/PointLocation.h | 105 +++++++++++++++++++++
include/geos/geosAlgorithm.h | 1 -
.../operation/buffer/BufferInputLineSimplifier.h | 1 -
src/algorithm/Angle.cpp | 1 -
src/algorithm/CGAlgorithmsDD.cpp | 3 +
src/algorithm/ConvexHull.cpp | 4 +-
src/algorithm/LineIntersector.cpp | 17 ++--
src/algorithm/Makefile.am | 1 +
src/algorithm/Orientation.cpp | 1 -
src/algorithm/PointLocation.cpp | 87 +++++++++++++++++
src/algorithm/PointLocator.cpp | 15 +--
src/algorithm/SimplePointInRing.cpp | 4 +-
.../distance/DiscreteHausdorffDistance.cpp | 7 --
src/algorithm/locate/SimplePointInAreaLocator.cpp | 6 +-
src/geom/GeometryCollection.cpp | 1 -
src/geom/LineSegment.cpp | 6 +-
src/geom/MultiLineString.cpp | 1 -
src/geomgraph/EdgeRing.cpp | 4 +-
src/operation/buffer/OffsetCurveBuilder.cpp | 1 -
.../intersection/RectangleIntersection.cpp | 12 +--
.../intersection/RectangleIntersectionBuilder.cpp | 6 +-
src/operation/overlay/PolygonBuilder.cpp | 4 +-
src/operation/polygonize/EdgeRing.cpp | 4 +-
src/operation/valid/IndexedNestedRingTester.cpp | 4 +-
src/operation/valid/IsValidOp.cpp | 8 +-
src/operation/valid/QuadtreeNestedRingTester.cpp | 4 +-
src/operation/valid/SimpleNestedRingTester.cpp | 4 +-
src/operation/valid/SweeplineNestedRingTester.cpp | 4 +-
.../algorithm/CGAlgorithms/isPointInRingTest.cpp | 10 +-
.../unit/algorithm/CGAlgorithms/signedAreaTest.cpp | 12 +--
tests/unit/algorithm/LocatePointInRingTest.cpp | 4 +-
.../unit/algorithm/OrientationIndexFailureTest.cpp | 13 ++-
tests/unit/algorithm/RobustLineIntersectorTest.cpp | 6 +-
36 files changed, 280 insertions(+), 96 deletions(-)
create mode 100644 include/geos/algorithm/PointLocation.h
create mode 100644 src/algorithm/PointLocation.cpp
hooks/post-receive
More information about the geos-commits
