[geos-commits] [SCM] geos branch master updated. d43e678578cfc60d02fbb051319d65e638474515
git at osgeo.org
git at osgeo.org
Wed Jan 10 00:35:34 PST 2018
the project "geos".
via d43e678578cfc60d02fbb051319d65e638474515 (commit)
via 62380be288dc5cd2e6b5e8afc69e7b9e716546dc (commit)
via ed57b476690b07f1e8b51b015ec35ac6970aac7e (commit)
from e99ed9d1996b6fd491a6462c54dfc83cacb5a997 (commit)
revisions in full, below.
commit d43e678578cfc60d02fbb051319d65e638474515
Author: cvvergara <vicky at georepublic.de>
Date: Tue Jan 9 00:59:55 2018 -0600
cmake: improving handling version
diff --git a/CMakeLists.txt b/CMakeLists.txt
index df91af3..1944c80 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -17,10 +17,13 @@ if(NOT CMAKE_VERSION)
"${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}")
endif()
+if(POLICY CMP0048)
+ cmake_policy(SET CMP0048 NEW)
+endif()
# Set GEOS project
-project(GEOS LANGUAGES C CXX)
+project(GEOS VERSION 3.7.0 LANGUAGES C CXX)
# Add custom GEOS modules for CMake
list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
@@ -40,10 +43,9 @@ message(STATUS "Setting C++ requirement to C++${CMAKE_CXX_STANDARD}")
# GEOS release version
# GEOS C++ library SONAME will use these encoding ABI break at every release
-set(VERSION_MAJOR 3)
-set(VERSION_MINOR 7)
-set(VERSION_PATCH 0dev)
-set(VERSION "${VERSION_MAJOR}.${VERSION_MINOR}.${VERSION_PATCH}")
+set(GEOS_VERSION_PATCH "${GEOS_VERSION_PATCH}dev")
+set(GEOS_VERSION "${GEOS_VERSION_MAJOR}.${GEOS_VERSION_MINOR}.${GEOS_VERSION_PATCH}")
+set(VERSION "${GEOS_VERSION}")
# JTS_PORT is the version of JTS this release is bound to
set(JTS_PORT 1.13.0)
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 751b80d..2deae01 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -36,7 +36,8 @@
- VERSION_MAJOR for SUBSTANTIAL additions or C lib ABI break
[ THIS MUST BE CAREFULLY AVOIDED ]
- In main CMakeLists.txt main one
- - VERSION_MAJOR, VERSION_MINOR, VERSION_PATCH
+ - CHANGE the line: project(GEOS VERSION <mayor>.<minor>.<micro> LANGUAGES C CXX)
+ - CHANGE the line: set(GEOS_VERSION_PATCH "${GEOS_VERSION_PATCH}dev")
- CAPI_INTERFACE_*
12. Update wiki page https://trac.osgeo.org/geos/ at Download section
commit 62380be288dc5cd2e6b5e8afc69e7b9e716546dc
Date: Tue Jan 9 01:33:23 2018 -0600
getting stricter with warnings
index 1a8f7d9..df91af3 100644
@@ -129,10 +129,10 @@ if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
"Forcing IEEE 754 using flag -ffloat-store - ${GEOS_ENABLE_FLOATSTORE}")
# Warnings specification
- set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall -Wno-long-long")
+ set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall -Wno-long-long -fno-implicit-inline-templates -Wconversion -pedantic -W -Wunused -Wuninitialized -Wextra -Wdouble-promotion")
# Turn on Position Independent Code generation for GEOS C shared library
- set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -fPIC")
+ set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -fPIC -Wall -Wconversion -pedantic -Wmissing-prototypes -W -Wunused -Wuninitialized -Wextra -Wdouble-promotion")
# Enable glibc ISO C99 features (macros isfinite, isnan)
set(CMAKE_REQUIRED_DEFINITIONS "${CMAKE_REQUIRED_DEFINITIONS} -D_ISOC99_SOURCE=1")
commit ed57b476690b07f1e8b51b015ec35ac6970aac7e
Date: Tue Jan 9 01:17:05 2018 -0600
removing -ansi and fPIC from C++ compilation
index 8a5b2d4..1a8f7d9 100644
@@ -118,7 +118,7 @@ endif()
# General options
- set(CMAKE_CXX_FLAGS "-pedantic -ansi ${CMAKE_CXX_FLAGS}")
+ set(CMAKE_C_FLAGS "-pedantic -ansi ${CMAKE_C_FLAGS}")
# Numerical stability
if(GEOS_ENABLE_FLOATSTORE)
@@ -132,7 +132,7 @@ if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
- set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fPIC")
+ set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -fPIC")
Summary of changes:
CMakeLists.txt | 18 ++++++++++--------
HOWTO_RELEASE | 3 ++-
2 files changed, 12 insertions(+), 9 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
