[geos-commits] [SCM] geos branch master updated. 227ad17e4a9ef8d009d16240de492d4b5df70bcc
git at osgeo.org
git at osgeo.org
Sat Jan 13 12:29:18 PST 2018
the project "geos".
via 227ad17e4a9ef8d009d16240de492d4b5df70bcc (commit)
from d43e678578cfc60d02fbb051319d65e638474515 (commit)
revisions in full, below.
commit 227ad17e4a9ef8d009d16240de492d4b5df70bcc
Author: Sandro Santilli <strk at kbt.io>
Date: Sat Jan 13 21:15:02 2018 +0100
Fix -Wmisleading-indentation warnings
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 01142f8..91e6f4f 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -151,8 +151,8 @@ Polygon::getCoordinateDimension() const
int dimension=2;
- if( shell != nullptr )
- dimension = max(dimension,shell->getCoordinateDimension());
+ if( shell != nullptr )
+ dimension = max(dimension,shell->getCoordinateDimension());
size_t nholes=holes->size();
for (size_t i=0; i<nholes; ++i)
diff --git a/src/io/WKBWriter.cpp b/src/io/WKBWriter.cpp
index 42debda..141da97 100644
--- a/src/io/WKBWriter.cpp
+++ b/src/io/WKBWriter.cpp
@@ -82,9 +82,9 @@ WKBWriter::writeHEX(const Geometry &g, ostream &os)
void
WKBWriter::write(const Geometry &g, ostream &os)
- outputDimension = defaultOutputDimension;
- if( outputDimension > g.getCoordinateDimension() )
- outputDimension = g.getCoordinateDimension();
+ outputDimension = defaultOutputDimension;
+ if( outputDimension > g.getCoordinateDimension() )
+ outputDimension = g.getCoordinateDimension();
outStream = &os;
@@ -250,10 +250,10 @@ void
WKBWriter::writeGeometryType(int typeId, int SRID)
int flag3D = (outputDimension == 3) ? 0x80000000 : 0;
- int typeInt = typeId | flag3D;
+ int typeInt = typeId | flag3D;
- if (includeSRID && SRID != 0)
- typeInt = typeInt | 0x20000000;
+ if (includeSRID && SRID != 0)
+ typeInt = typeInt | 0x20000000;
writeInt(typeInt);
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index 441b4ed..1547183 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -156,9 +156,9 @@ WKTReader::getNextEmptyOrOpener(StringTokenizer *tokenizer)
string nextWord=getNextWord(tokenizer);
- // Skip the Z, M or ZM of an SF1.2 3/4 dim coordinate.
- if (nextWord == "Z" || nextWord == "M" || nextWord == "ZM" )
- nextWord = getNextWord(tokenizer);
+ // Skip the Z, M or ZM of an SF1.2 3/4 dim coordinate.
+ if (nextWord == "Z" || nextWord == "M" || nextWord == "ZM" )
+ nextWord = getNextWord(tokenizer);
if (nextWord=="EMPTY" || nextWord=="(") {
return nextWord;
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 2c540b7..578d0bf 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -236,8 +236,8 @@ WKTWriter::appendPointTaggedText(const Coordinate* coordinate, int level,
Writer *writer)
writer->write("POINT ");
- if( outputDimension == 3 && !old3D && coordinate != nullptr )
- writer->write( "Z " );
+ if( outputDimension == 3 && !old3D && coordinate != nullptr )
+ writer->write( "Z " );
appendPointText(coordinate, level, writer);
@@ -247,8 +247,8 @@ WKTWriter::appendLineStringTaggedText(const LineString *lineString, int level,
Writer *writer)
writer->write("LINESTRING ");
- if( outputDimension == 3 && !old3D && !lineString->isEmpty() )
+ if( outputDimension == 3 && !old3D && !lineString->isEmpty() )
appendLineStringText(lineString, level, false, writer);
@@ -262,43 +262,43 @@ WKTWriter::appendLineStringTaggedText(const LineString *lineString, int level,
void WKTWriter::appendLinearRingTaggedText(const LinearRing* linearRing, int level, Writer *writer) {
writer->write("LINEARRING ");
- if( outputDimension == 3 && !old3D && !linearRing->isEmpty() )
+ if( outputDimension == 3 && !old3D && !linearRing->isEmpty() )
appendLineStringText((LineString*)linearRing, level, false, writer);
void WKTWriter::appendPolygonTaggedText(const Polygon *polygon, int level, Writer *writer) {
writer->write("POLYGON ");
- if( outputDimension == 3 && !old3D && !polygon->isEmpty())
+ if( outputDimension == 3 && !old3D && !polygon->isEmpty())
appendPolygonText(polygon, level, false, writer);
void WKTWriter::appendMultiPointTaggedText(const MultiPoint *multipoint, int level, Writer *writer) {
writer->write("MULTIPOINT ");
- if( outputDimension == 3 && !old3D && !multipoint->isEmpty() )
+ if( outputDimension == 3 && !old3D && !multipoint->isEmpty() )
appendMultiPointText(multipoint, level, writer);
void WKTWriter::appendMultiLineStringTaggedText(const MultiLineString *multiLineString, int level,Writer *writer) {
writer->write("MULTILINESTRING ");
- if( outputDimension == 3 && !old3D && !multiLineString->isEmpty() )
+ if( outputDimension == 3 && !old3D && !multiLineString->isEmpty() )
appendMultiLineStringText(multiLineString, level, false, writer);
void WKTWriter::appendMultiPolygonTaggedText(const MultiPolygon *multiPolygon, int level, Writer *writer) {
writer->write("MULTIPOLYGON ");
- if( outputDimension == 3 && !old3D && !multiPolygon->isEmpty() )
+ if( outputDimension == 3 && !old3D && !multiPolygon->isEmpty() )
appendMultiPolygonText(multiPolygon, level, writer);
void WKTWriter::appendGeometryCollectionTaggedText(const GeometryCollection *geometryCollection, int level,Writer *writer) {
writer->write("GEOMETRYCOLLECTION ");
- if( outputDimension == 3 && !old3D && !geometryCollection->isEmpty() )
+ if( outputDimension == 3 && !old3D && !geometryCollection->isEmpty() )
appendGeometryCollectionText(geometryCollection, level, writer);
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index 88578e2..784d712 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -124,10 +124,10 @@ IsValidOp::checkValid()
void
IsValidOp::checkValid(const Geometry *g)
- assert( validErr == nullptr );
+ assert( validErr == nullptr );
- if (nullptr == g)
- return;
+ if (nullptr == g)
+ return;
// empty geometries are always valid!
if (g->isEmpty()) return;
Summary of changes:
src/geom/Polygon.cpp | 4 ++--
src/io/WKBWriter.cpp | 12 ++++++------
src/io/WKTReader.cpp | 6 +++---
src/io/WKTWriter.cpp | 32 ++++++++++++++++----------------
src/operation/valid/IsValidOp.cpp | 6 +++---
5 files changed, 30 insertions(+), 30 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
