[geos-commits] [SCM] GEOS branch master updated. 88f21460756bb1eec852ac70f981581755fe07a0
git at osgeo.org
git at osgeo.org
Wed Nov 14 11:06:08 PST 2018
the project "GEOS".
via 88f21460756bb1eec852ac70f981581755fe07a0 (commit)
from 30c710a1a97b8bac64c275f56480eaf1fbb3ca04 (commit)
revisions in full, below.
commit 88f21460756bb1eec852ac70f981581755fe07a0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Nov 14 09:49:13 2018 -0800
Update Centroid algorithm to match JTS, and accompanying test file
diff --git a/include/geos/algorithm/Centroid.h b/include/geos/algorithm/Centroid.h
index 16b7ae8..9f7d268 100644
--- a/include/geos/algorithm/Centroid.h
+++ b/include/geos/algorithm/Centroid.h
@@ -113,7 +113,7 @@ private:
void add(const geom::Geometry& geom);
- void setBasePoint(const geom::Coordinate& basePt);
+ void setAreaBasePoint(const geom::Coordinate& basePt);
void add(const geom::Polygon& poly);
diff --git a/src/algorithm/Centroid.cpp b/src/algorithm/Centroid.cpp
index 727e98a..c5f31ab 100644
--- a/src/algorithm/Centroid.cpp
+++ b/src/algorithm/Centroid.cpp
@@ -88,10 +88,9 @@ Centroid::add(const Geometry& geom)
/* private */
void
-Centroid::setBasePoint(const Coordinate& basePt)
+Centroid::setAreaBasePoint(const Coordinate& basePt)
- if ( ! areaBasePt.get() )
- areaBasePt.reset( new Coordinate(basePt) );
+ areaBasePt.reset( new Coordinate(basePt) );
/* private */
@@ -110,7 +109,7 @@ Centroid::addShell(const CoordinateSequence& pts)
size_t len = pts.size();
if (len > 0)
- setBasePoint(pts[0]);
+ setAreaBasePoint(pts[0]);
bool isPositiveArea = ! CGAlgorithms::isCCW(&pts);
for (size_t i = 0; i < len - 1; ++i) {
addTriangle(*areaBasePt, pts[i], pts[i+1], isPositiveArea);
diff --git a/tests/xmltester/tests/general/TestCentroid.xml b/tests/xmltester/tests/general/TestCentroid.xml
index 40a6846..068b617 100644
--- a/tests/xmltester/tests/general/TestCentroid.xml
+++ b/tests/xmltester/tests/general/TestCentroid.xml
@@ -26,6 +26,12 @@
</case>
<case>
+ <desc>mP - repeated points</desc>
+ <a> MULTIPOINT((10 10), (10 10), (10 10), (18 18)) </a>
+<test><op name="getCentroid" arg1="A" > POINT(12 12) </op></test>
+</case>
+<case>
<desc>L - single segment</desc>
<a> LINESTRING(10 10, 20 20) </a>
<test><op name="getCentroid" arg1="A" > POINT(15 15) </op></test>
@@ -236,6 +242,30 @@
<test><op name="getCentroid" arg1="A" > POINT (56.52883333335 25.21033333335) </op></test>
</case>
+<case>
+ <desc>A - almost degenerate MultiPolygon</desc>
+ <a>
+ MULTIPOLYGON (((
+ -92.661322 36.58994900000003,
+ -92.66132199999993 36.58994900000005,
+ -92.66132199999993 36.589949000000004,
+ -92.661322 36.589949,
+ -92.661322 36.58994900000003)),
+ -92.65560500000008 36.58708800000005,
+ -92.65560499999992 36.58708800000005,
+ -92.65560499998745 36.587087999992576,
+ -92.655605 36.587088,
+ -92.65512450000065 36.586800000000466,
+ -92.65512449999994 36.58680000000004,
+ -92.65512449998666 36.5867999999905,
+ </a>
+ <test><op name="getCentroid" arg1="A" >POINT (-92.6553838608954 36.58695407733924)</op></test>
+</case>
</run>
Summary of changes:
include/geos/algorithm/Centroid.h | 2 +-
src/algorithm/Centroid.cpp | 7 +++---
tests/xmltester/tests/general/TestCentroid.xml | 32 +++++++++++++++++++++++++-
3 files changed, 35 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
