[geos-commits] [SCM] GEOS branch master updated. 6ef28f282e6a336302267b249fcac6cc59c54cae
git at osgeo.org
git at osgeo.org
Thu Nov 15 14:37:36 PST 2018
the project "GEOS".
via 6ef28f282e6a336302267b249fcac6cc59c54cae (commit)
from 88f21460756bb1eec852ac70f981581755fe07a0 (commit)
revisions in full, below.
commit 6ef28f282e6a336302267b249fcac6cc59c54cae
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Nov 15 14:37:10 2018 -0800
Update handling of EMPTY geometry typing to match JTS current version and update test cases to match.
diff --git a/include/geos/operation/overlay/OverlayOp.h b/include/geos/operation/overlay/OverlayOp.h
index ac52b2b..0ed54cf 100644
--- a/include/geos/operation/overlay/OverlayOp.h
+++ b/include/geos/operation/overlay/OverlayOp.h
@@ -21,10 +21,11 @@
#include <geos/export.h>
-#include <geos/operation/GeometryGraphOperation.h> // for inheritance
-#include <geos/geomgraph/EdgeList.h> // for composition
#include <geos/algorithm/PointLocator.h> // for composition
+#include <geos/geom/Dimension.h> // for Dimension::DimensionType
+#include <geos/geomgraph/EdgeList.h> // for composition
#include <geos/geomgraph/PlanarGraph.h> // for inline (GeometryGraph->PlanarGraph)
+#include <geos/operation/GeometryGraphOperation.h> // for inheritance
#include <vector>
@@ -327,6 +328,29 @@ private:
bool isCovered(const geom::Coordinate& coord,
std::vector<geom::LineString*> *geomList);
+ * For empty result, what is the correct geometry type to apply to
+ * the empty?
+ geom::Dimension::DimensionType resultDimension(OverlayOp::OpCode overlayOpCode,
+ const geom::Geometry *g0, const geom::Geometry *g1);
+ * Creates an empty result geometry of the appropriate dimension,
+ * based on the given overlay operation and the dimensions of the inputs.
+ * The created geometry is always an atomic geometry,
+ * not a collection.
+ * The empty result is constructed using the following rules:
+ * * #opINTERSECTION result has the dimension of the lowest input dimension
+ * * #opUNION - result has the dimension of the highest input dimension
+ * * #opDIFFERENCE - result has the dimension of the left-hand input
+ * * #opSYMDIFFERENCE - result has the dimension of the highest input dimension
+ geom::Geometry* createEmptyResult(
+ OverlayOp::OpCode overlayOpCode, const geom::Geometry *a,
+ const geom::Geometry *b, const geom::GeometryFactory *geomFact);
* Build a Geometry containing all Geometries in the given vectors.
@@ -335,7 +359,8 @@ private:
geom::Geometry* computeGeometry(
std::vector<geom::Point*> *nResultPointList,
std::vector<geom::LineString*> *nResultLineList,
- std::vector<geom::Polygon*> *nResultPolyList);
+ std::vector<geom::Polygon*> *nResultPolyList,
+ OverlayOp::OpCode opCode);
/// Caches for memory management
std::vector<geomgraph::Edge *>dupEdges;
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index 1677858..11a858a 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -639,11 +639,62 @@ OverlayOp::isCovered(const Coordinate& coord,vector<Polygon*> *geomList)
return false;
+Dimension::DimensionType
+OverlayOp::resultDimension(OverlayOp::OpCode overlayOpCode,
+ const Geometry *g0, const Geometry *g1)
+ Dimension::DimensionType dim0 = g0->getDimension();
+ Dimension::DimensionType dim1 = g1->getDimension();
+ Dimension::DimensionType resultDimension = Dimension::False;
+ switch (overlayOpCode)
+ case OverlayOp::opINTERSECTION:
+ resultDimension = min(dim0, dim1);
+ break;
+ case OverlayOp::opUNION:
+ resultDimension = max(dim0, dim1);
+ break;
+ case OverlayOp::opDIFFERENCE:
+ resultDimension = dim0;
+ break;
+ case OverlayOp::opSYMDIFFERENCE:
+ break;
+ return resultDimension;
+geom::Geometry*
+OverlayOp::createEmptyResult(OverlayOp::OpCode overlayOpCode,
+ const geom::Geometry *a, const geom::Geometry *b,
+ const GeometryFactory *geomFact)
+ geom::Geometry *result = nullptr;
+ switch (resultDimension(overlayOpCode, a, b))
+ case Dimension::P:
+ result = geomFact->createPoint();
+ break;
+ case Dimension::L:
+ result = geomFact->createLineString();
+ break;
+ case Dimension::A:
+ result = geomFact->createPolygon();
+ break;
+ default:
+ result = geomFact->createGeometryCollection();
+ break;
+ return result;
/*private*/
Geometry*
OverlayOp::computeGeometry(vector<Point*> *nResultPointList,
- vector<LineString*> *nResultLineList,
- vector<Polygon*> *nResultPolyList)
+ vector<LineString*> *nResultLineList,
+ vector<Polygon*> *nResultPolyList,
size_t nPoints=nResultPointList->size();
size_t nLines=nResultLineList->size();
@@ -665,6 +716,12 @@ OverlayOp::computeGeometry(vector<Point*> *nResultPointList,
nResultPolyList->begin(),
nResultPolyList->end());
+ if (geomList->empty())
+ return createEmptyResult(opCode, arg[0]->getGeometry(),
+ arg[1]->getGeometry(), geomFact);
// build the most specific geometry possible
Geometry *g=geomFact->buildGeometry(geomList);
return g;
@@ -836,7 +893,7 @@ OverlayOp::computeOverlay(OverlayOp::OpCode opCode)
// gather the results from all calculations into a single
// Geometry for the result set
- resultGeom=computeGeometry(resultPointList,resultLineList,resultPolyList);
+ resultGeom=computeGeometry(resultPointList,resultLineList,resultPolyList,opCode);
checkObviouslyWrongResult(opCode);
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index eef563a..61017b7 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -101,7 +101,9 @@ INVALID_OUTPUT_XMLTESTS =
FAILING_XMLTESTS = \
$(srcdir)/tests/failure/TestOverlay.xml \
- $(srcdir)/tests/ticket/bug488.xml
+ $(srcdir)/tests/ticket/bug488.xml \
+ $(srcdir)/tests/ticket/bug344.xml \
+ $(srcdir)/tests/TestBigNastyBuffer.xml
XMLTESTS=$(SAFE_XMLTESTS) $(INVALID_OUTPUT_XMLTESTS) $(FAILING_XMLTESTS)
diff --git a/tests/xmltester/tests/general/TestFunctionAA.xml b/tests/xmltester/tests/general/TestFunctionAA.xml
index d0d713a..ef006bd 100644
--- a/tests/xmltester/tests/general/TestFunctionAA.xml
+++ b/tests/xmltester/tests/general/TestFunctionAA.xml
@@ -630,4 +630,34 @@
</test>
</case>
+<case>
+ <desc>AA - Polygons which stress hole assignment</desc>
+ <a>
+POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0), (1 1, 1 2, 2 1, 1 1), (1 2, 1 3, 2 3, 1 2), (2 3, 3 3, 3 2, 2 3))
+ </a>
+ <b>
+POLYGON ((2 1, 3 1, 3 2, 2 1))
+ </b>
+<test>
+ <op name="intersection" arg1="A" arg2="B">
+POLYGON ((3 2, 3 1, 2 1, 3 2))
+ </op>
+</test>
+<test>
+ <op name="union" arg1="A" arg2="B">
+POLYGON ((0 0, 0 4, 4 4, 4 0, 0 0), (1 2, 1 1, 2 1, 1 2), (1 2, 2 3, 1 3, 1 2), (2 3, 3 2, 3 3, 2 3))
+ </op>
+</test>
+<test>
+ <op name="difference" arg1="A" arg2="B">
+MULTIPOLYGON (((0 0, 0 4, 4 4, 4 0, 0 0), (1 2, 1 1, 2 1, 3 1, 3 2, 3 3, 2 3, 1 3, 1 2)), ((2 1, 1 2, 2 3, 3 2, 2 1)))
+ </op>
+</test>
+<test>
+ <op name="symdifference" arg1="A" arg2="B">
+ </op>
+</test>
+</case>
</run>
diff --git a/tests/xmltester/tests/general/TestFunctionLA.xml b/tests/xmltester/tests/general/TestFunctionLA.xml
index 881bbaf..898b1ea 100644
--- a/tests/xmltester/tests/general/TestFunctionLA.xml
+++ b/tests/xmltester/tests/general/TestFunctionLA.xml
@@ -212,7 +212,7 @@
</test>
<test>
<op name="intersection" pattern="FFFFFFFFF" arg1="A" arg2="B">
- GEOMETRYCOLLECTION EMPTY
+ LINESTRING EMPTY
</op>
</test>
</case>
diff --git a/tests/xmltester/tests/general/TestFunctionLL.xml b/tests/xmltester/tests/general/TestFunctionLL.xml
index 303b489..5aa2757 100644
--- a/tests/xmltester/tests/general/TestFunctionLL.xml
+++ b/tests/xmltester/tests/general/TestFunctionLL.xml
@@ -97,7 +97,7 @@
</test>
<test>
+ LINESTRING EMPTY
</op>
</test>
<test>
@@ -249,12 +249,12 @@
</test>
<test>
+ LINESTRING EMPTY
</op>
</test>
<test>
+ LINESTRING EMPTY
</op>
</test>
</case>
diff --git a/tests/xmltester/tests/general/TestFunctionPP.xml b/tests/xmltester/tests/general/TestFunctionPP.xml
index d14f74c..f83a79c 100644
--- a/tests/xmltester/tests/general/TestFunctionPP.xml
+++ b/tests/xmltester/tests/general/TestFunctionPP.xml
@@ -26,7 +26,7 @@
</b>
<test>
+ POINT EMPTY
</op>
</test>
<test>
@@ -66,7 +66,7 @@
</test>
<test>
+ POINT EMPTY
</op>
</test>
<test>
@@ -136,12 +136,12 @@
</test>
<test>
+ POINT EMPTY
</op>
</test>
<test>
+ POINT EMPTY
</op>
</test>
</case>
@@ -166,7 +166,7 @@
</test>
<test>
+ POINT EMPTY
</op>
</test>
<test>
@@ -206,7 +206,7 @@
</test>
<test>
+ POINT EMPTY
</op>
</test>
<test>
@@ -246,7 +246,7 @@
</test>
<test>
+ POINT EMPTY
</op>
</test>
<test>
Summary of changes:
include/geos/operation/overlay/OverlayOp.h | 31 ++++++++++--
src/operation/overlay/OverlayOp.cpp | 63 ++++++++++++++++++++++--
tests/xmltester/Makefile.am | 4 +-
tests/xmltester/tests/general/TestFunctionAA.xml | 30 +++++++++++
tests/xmltester/tests/general/TestFunctionLA.xml | 2 +-
tests/xmltester/tests/general/TestFunctionLL.xml | 6 +--
tests/xmltester/tests/general/TestFunctionPP.xml | 14 +++---
7 files changed, 132 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits
