[geos-commits] [SCM] GEOS branch master updated. f6a0efd1f243f7edd6dec5e346e57f4f7a1fc17d
git at osgeo.org
git at osgeo.org
Mon Nov 19 07:05:26 PST 2018
the project "GEOS".
via f6a0efd1f243f7edd6dec5e346e57f4f7a1fc17d (commit)
via 23db5ed049bf5c149c2c048094602908932d9979 (commit)
from 70a9773c5d61b419e7f6a7cfb87b28c71fc8c13e (commit)
revisions in full, below.
commit f6a0efd1f243f7edd6dec5e346e57f4f7a1fc17d
Merge: 70a9773 23db5ed
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Nov 19 10:05:08 2018 -0500
Merge branch 'trac-919'
commit 23db5ed049bf5c149c2c048094602908932d9979
Date: Thu Nov 15 22:05:04 2018 -0500
Fix memory leak in SIRtree
Resolves #919
diff --git a/include/geos/index/strtree/SIRtree.h b/include/geos/index/strtree/SIRtree.h
index 54f7895..9e9c275 100644
--- a/include/geos/index/strtree/SIRtree.h
+++ b/include/geos/index/strtree/SIRtree.h
@@ -76,6 +76,12 @@ public:
std::vector<void*>* query(double x) { return query(x,x); }
+ * Disable copy construction and assignment. Apparently needed to make this
+ * class compile under MSVC. (See https://stackoverflow.com/q/29565299)
+ SIRtree(const SIRtree&) = delete;
+ SIRtree& operator=(const SIRtree&) = delete;
protected:
@@ -98,8 +104,8 @@ protected:
std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input) override;
private:
IntersectsOp* intersectsOp;
+ std::vector<std::unique_ptr<Interval>> intervals;
diff --git a/src/index/strtree/SIRtree.cpp b/src/index/strtree/SIRtree.cpp
index 4c8452f..06343e2 100644
--- a/src/index/strtree/SIRtree.cpp
+++ b/src/index/strtree/SIRtree.cpp
@@ -127,8 +127,10 @@ SIRtree::createNode(int level)
* Inserts an item having the given bounds into the tree.
-void SIRtree::insert(double x1, double x2,void* item) {
- AbstractSTRtree::insert(new Interval(min(x1,x2),max(x1, x2)),item);
+void SIRtree::insert(double x1, double x2, void* item) {
+ std::unique_ptr<Interval> i{new Interval(std::min(x1,x2), std::max(x1, x2))};
+ AbstractSTRtree::insert(i.get(), item);
+ intervals.push_back(std::move(i));
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 3c84675..17efa4d 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -79,6 +79,7 @@ geos_unit_SOURCES = \
geom/TriangleTest.cpp \
geom/util/GeometryExtracterTest.cpp \
index/quadtree/DoubleBitsTest.cpp \
+ index/strtree/SIRtreeTest.cpp \
io/ByteOrderValuesTest.cpp \
io/WKBReaderTest.cpp \
io/WKBWriterTest.cpp \
diff --git a/tests/unit/index/strtree/SIRtreeTest.cpp b/tests/unit/index/strtree/SIRtreeTest.cpp
new file mode 100644
index 0000000..0ae842e
--- /dev/null
+++ b/tests/unit/index/strtree/SIRtreeTest.cpp
@@ -0,0 +1,34 @@
+#include <tut/tut.hpp>
+// geos
+#include <geos/index/strtree/SIRtree.h>
+using namespace geos::index::strtree;
+namespace tut
+ // dummy data, not used
+ struct test_sirtree_data {};
+ using group = test_group<test_sirtree_data>;
+ using object = group::object;
+ group test_sirtree_group("geos::index::strtree::SIRtree");
+ // Test Cases
+ // Make sure no memory is leaked.
+ // See https://trac.osgeo.org/geos/ticket/919
+ template<>
+ template<>
+ void object::test<1>()
+ SIRtree t;
+ double value = 3;
+ t.insert(1, 5, &value);
+} // namespace tut
Summary of changes:
include/geos/index/strtree/SIRtree.h | 8 +++++++-
src/index/strtree/SIRtree.cpp | 6 ++++--
tests/unit/Makefile.am | 1 +
tests/unit/index/strtree/SIRtreeTest.cpp | 34 ++++++++++++++++++++++++++++++++
4 files changed, 46 insertions(+), 3 deletions(-)
create mode 100644 tests/unit/index/strtree/SIRtreeTest.cpp
hooks/post-receive
More information about the geos-commits
