[geos-commits] [SCM] GEOS branch 3.7 updated. 15d9fd34fbe1d5f0f4a8cad085d2954ca0638914
Mon Nov 19 07:06:59 PST 2018
the project "GEOS".
The branch, 3.7 has been updated
       via  15d9fd34fbe1d5f0f4a8cad085d2954ca0638914 (commit)
       via  8f07342e71f9218d2ec2a9463e83b39271a26e17 (commit)
      from  4c2ab3589a50e180075432beee104d7c5c534d9c (commit)
revisions in full, below.
commit 15d9fd34fbe1d5f0f4a8cad085d2954ca0638914
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Nov 19 10:06:47 2018 -0500
    Add NEWS entry for #919
diff --git a/NEWS b/NEWS
index 59bc181..6b19423 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ Changes in 3.7.1
     (#926, Sergey Fedoseev)
   - Fix crash in GEOSUnaryUnion with empty LineString
     (#928, Sergey Fedoseev)
+  - Fix memory leak in SIRtree::insert (#919, Dan Baston)
   - Reduce required autoconf to 2.63
     (#56, John Harvey)
   - Fix incorrect return values on error from GEOSLength
commit 8f07342e71f9218d2ec2a9463e83b39271a26e17
Date:   Thu Nov 15 22:05:04 2018 -0500
    Resolves #919
diff --git a/include/geos/index/strtree/SIRtree.h b/include/geos/index/strtree/SIRtree.h
index 54f7895..9e9c275 100644
--- a/include/geos/index/strtree/SIRtree.h
+++ b/include/geos/index/strtree/SIRtree.h
@@ -76,6 +76,12 @@ public:
 	std::vector<void*>* query(double x) { return query(x,x); }
+	 * Disable copy construction and assignment. Apparently needed to make this
+	 * class compile under MSVC. (See https://stackoverflow.com/q/29565299)
+	 SIRtree(const SIRtree&) = delete;
+	 SIRtree& operator=(const SIRtree&) = delete;
 protected:
@@ -98,8 +104,8 @@ protected:
 	std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input) override;
 private:
 	IntersectsOp* intersectsOp;
+	std::vector<std::unique_ptr<Interval>> intervals;
diff --git a/src/index/strtree/SIRtree.cpp b/src/index/strtree/SIRtree.cpp
index b5a2cbd..78be293 100644
--- a/src/index/strtree/SIRtree.cpp
+++ b/src/index/strtree/SIRtree.cpp
@@ -127,8 +127,10 @@ SIRtree::createNode(int level)
 * Inserts an item having the given bounds into the tree.
-void SIRtree::insert(double x1, double x2,void* item) {
-	AbstractSTRtree::insert(new Interval(min(x1,x2),max(x1, x2)),item);
+void SIRtree::insert(double x1, double x2, void* item) {
+	std::unique_ptr<Interval> i{new Interval(std::min(x1,x2), std::max(x1, x2))};
+	AbstractSTRtree::insert(i.get(), item);
+	intervals.push_back(std::move(i));
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 3c84675..17efa4d 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -79,6 +79,7 @@ geos_unit_SOURCES = \
 	geom/TriangleTest.cpp \
 	geom/util/GeometryExtracterTest.cpp \
 	index/quadtree/DoubleBitsTest.cpp \
+	index/strtree/SIRtreeTest.cpp \
 	io/ByteOrderValuesTest.cpp \
 	io/WKBReaderTest.cpp \
 	io/WKBWriterTest.cpp \
diff --git a/tests/unit/index/strtree/SIRtreeTest.cpp b/tests/unit/index/strtree/SIRtreeTest.cpp
new file mode 100644
index 0000000..0ae842e
--- /dev/null
+++ b/tests/unit/index/strtree/SIRtreeTest.cpp
@@ -0,0 +1,34 @@
+#include <tut/tut.hpp>
+// geos
+#include <geos/index/strtree/SIRtree.h>
+using namespace geos::index::strtree;
+namespace tut
+    // dummy data, not used
+    struct test_sirtree_data {};
+    using group = test_group<test_sirtree_data>;
+    using object = group::object;
+    group test_sirtree_group("geos::index::strtree::SIRtree");
+    // Test Cases
+    // Make sure no memory is leaked.
+    // See https://trac.osgeo.org/geos/ticket/919
+    template<>
+    template<>
+    void object::test<1>()
+        SIRtree t;
+        double value = 3;
+        t.insert(1, 5, &value);
+} // namespace tut
Summary of changes:
 NEWS                                     |  1 +
 include/geos/index/strtree/SIRtree.h     |  8 +++++++-
 src/index/strtree/SIRtree.cpp            |  6 ++++--
 tests/unit/Makefile.am                   |  1 +
 tests/unit/index/strtree/SIRtreeTest.cpp | 34 ++++++++++++++++++++++++++++++++
 5 files changed, 47 insertions(+), 3 deletions(-)
 create mode 100644 tests/unit/index/strtree/SIRtreeTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
