[geos-commits] [SCM] GEOS branch master updated. dddda853c784296ba9f3742e1659e8140c0e8a33
Tue Nov 27 15:38:44 PST 2018
the project "GEOS".
       via  dddda853c784296ba9f3742e1659e8140c0e8a33 (commit)
      from  a1d4d13b81f340bfebe80a9891353b04029b3c4a (commit)
revisions in full, below.
commit dddda853c784296ba9f3742e1659e8140c0e8a33
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Nov 27 15:37:45 2018 -0800
    Harmonize with JTS isSimple behaviour for GeometryCollection
    and Polygons, which is that an area with non-simple rings
    is itself non-simple, and a collection with a non-simple
    component is non-simple.
diff --git a/include/geos/geom/LinearRing.h b/include/geos/geom/LinearRing.h
index 0b1cebf..085b3ea 100644
--- a/include/geos/geom/LinearRing.h
+++ b/include/geos/geom/LinearRing.h
@@ -97,16 +97,6 @@ public:
 	int getBoundaryDimension() const override;
-	/** \brief
-	 * Returns <code>true</code>, since by definition LinearRings
-	 * are always simple.
-	 * @return <code>true</code>
-	 * @see Geometry::isSimple
-	bool isSimple() const override;
 	bool isClosed() const override;
 	std::string getGeometryType() const override;
diff --git a/include/geos/geom/MultiPolygon.h b/include/geos/geom/MultiPolygon.h
index 9aaae1a..9f91393 100644
--- a/include/geos/geom/MultiPolygon.h
+++ b/include/geos/geom/MultiPolygon.h
@@ -83,8 +83,6 @@ public:
 	GeometryTypeId getGeometryTypeId() const override;
 	bool equalsExact(const Geometry *other, double tolerance=0) const override;
 	Geometry *clone() const override;
diff --git a/include/geos/geom/Polygon.h b/include/geos/geom/Polygon.h
index eb15715..a62bd47 100644
--- a/include/geos/geom/Polygon.h
+++ b/include/geos/geom/Polygon.h
@@ -106,14 +106,6 @@ public:
 	bool isEmpty() const override;
-	/** \brief
-	 * Tests if a valid polygon is simple.
-	 * This method always returns true, since a valid polygon is always simple
 	/// Returns the exterior ring (shell)
 	const LineString* getExteriorRing() const;
@@ -132,6 +124,8 @@ public:
 	void apply_ro(GeometryFilter *filter) const override;
 	void apply_rw(CoordinateSequenceFilter& filter) override;
 	void apply_ro(CoordinateSequenceFilter& filter) const override;
+	void apply_rw(GeometryComponentFilter *filter) override;
+	void apply_ro(GeometryComponentFilter *filter) const override;
 	Geometry* convexHull() const override;
@@ -148,10 +142,6 @@ public:
  	/// Returns the perimeter of this <code>Polygon</code>
 	double getLength() const override;
-	void apply_rw(GeometryComponentFilter *filter) override;
-	void apply_ro(GeometryComponentFilter *filter) const override;
 	bool isRectangle() const override;
 protected:
diff --git a/include/geos/operation/IsSimpleOp.h b/include/geos/operation/IsSimpleOp.h
index 8375e25..ccc2bca 100644
--- a/include/geos/operation/IsSimpleOp.h
+++ b/include/geos/operation/IsSimpleOp.h
@@ -39,9 +39,12 @@ namespace geos {
 	namespace geom {
 		class LineString;
+		class LinearRing;
 		class MultiLineString;
 		class MultiPoint;
 		class Geometry;
+		class Polygon;
+		class GeometryCollection;
 		struct CoordinateLessThen;
 	namespace geomgraph {
@@ -193,6 +196,10 @@ private:
 	bool hasClosedEndpointIntersection(geomgraph::GeometryGraph &graph);
+	bool computeSimple(const geom::Geometry *geom);
+  bool isSimplePolygonal(const geom::Geometry *geom);
+	bool isSimpleGeometryCollection(const geom::GeometryCollection *col);
 	 * Add an endpoint to the map, creating an entry for it if none exists
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index 1ceb813..571520a 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -861,7 +861,6 @@ Geometry::apply_rw(GeometryComponentFilter *filter)
 bool
 Geometry::isSimple() const
-	checkNotGeometryCollection(this);
 	operation::IsSimpleOp op(*this);
 	return op.isSimple();
diff --git a/src/geom/LinearRing.cpp b/src/geom/LinearRing.cpp
index e74e795..01e10f3 100644
--- a/src/geom/LinearRing.cpp
+++ b/src/geom/LinearRing.cpp
@@ -92,12 +92,6 @@ LinearRing::getBoundaryDimension() const
 bool
-LinearRing::isSimple() const
-	return true;
-bool
 LinearRing::isClosed() const
 	if ( points->isEmpty() ) {
diff --git a/src/geom/MultiPolygon.cpp b/src/geom/MultiPolygon.cpp
index 5ed93a5..84fce6a 100644
--- a/src/geom/MultiPolygon.cpp
+++ b/src/geom/MultiPolygon.cpp
@@ -60,10 +60,6 @@ string MultiPolygon::getGeometryType() const {
 	return "MultiPolygon";
-bool MultiPolygon::isSimple() const {
-	return true;
 Geometry* MultiPolygon::getBoundary() const {
 	if (isEmpty()) {
 		return getFactory()->createMultiLineString();
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 90028fe..85082c7 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -175,12 +175,6 @@ Polygon::isEmpty() const
 	return shell->isEmpty();
-bool
-Polygon::isSimple() const
-	return true;
 const LineString*
 Polygon::getExteriorRing() const
diff --git a/src/operation/IsSimpleOp.cpp b/src/operation/IsSimpleOp.cpp
index c279636..614a6dc 100644
--- a/src/operation/IsSimpleOp.cpp
+++ b/src/operation/IsSimpleOp.cpp
@@ -29,8 +29,12 @@
 #include <geos/geom/Geometry.h>
 #include <geos/geom/MultiPoint.h>
 #include <geos/geom/MultiLineString.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/LinearRing.h>
 #include <geos/geom/Point.h>
+#include <geos/geom/GeometryCollection.h>
 #include <geos/geom/Coordinate.h>
+#include <geos/geom/util/LinearComponentExtracter.h>
 #include <set>
 #include <cassert>
@@ -40,6 +44,7 @@ using namespace geos::algorithm;
 using namespace geos::geomgraph;
 using namespace geos::geomgraph::index;
 using namespace geos::geom;
+using namespace geos::geom::util;
 namespace geos {
 namespace operation { // geos.operation
@@ -107,18 +112,7 @@ bool
 IsSimpleOp::isSimple()
 	nonSimpleLocation.reset();
-	if ( dynamic_cast<const LineString*>(geom) )
-		return isSimpleLinearGeometry(geom);
-	if ( dynamic_cast<const MultiLineString*>(geom) )
-	const MultiPoint* mp = dynamic_cast<const MultiPoint*>(geom);
-	if ( mp ) return isSimpleMultiPoint(*mp);
-	// all other geometry types are simple by definition
-	return true;
+	return computeSimple(geom);
@@ -171,7 +165,7 @@ IsSimpleOp::isSimpleLinearGeometry(const Geometry *p_geom)
 	if (p_geom->isEmpty()) return true;
 	GeometryGraph graph(0,p_geom);
 	LineIntersector li;
-	std::unique_ptr<SegmentIntersector> si (graph.computeSelfNodes(&li,true));
+	std::unique_ptr<SegmentIntersector> si(graph.computeSelfNodes(&li,true));
 	// if no self-intersection, must be simple
 	if (!si->hasIntersection()) return true;
@@ -220,6 +214,65 @@ IsSimpleOp::hasNonEndpointIntersection(GeometryGraph &graph)
 /*private*/
 bool
+IsSimpleOp::computeSimple(const geom::Geometry *geom)
+	nonSimpleLocation.reset();
+	if (dynamic_cast<const LineString*>(geom))
+		return isSimpleLinearGeometry(geom);
+	if (dynamic_cast<const LinearRing*>(geom))
+	if (dynamic_cast<const MultiLineString*>(geom))
+	if (dynamic_cast<const Polygon*>(geom))
+		return isSimplePolygonal(geom);
+	const MultiPoint* mp = dynamic_cast<const MultiPoint*>(geom);
+	if (mp) return isSimpleMultiPoint(*mp);
+	// This must be after MultiPoint test, as MultiPoint can
+	// cast cleanly into GeometryCollection
+	const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(geom);
+	if (gc)
+		return isSimpleGeometryCollection(gc);
+	// all other geometry types are simple by definition
+	return true;
+/*private*/
+bool
+IsSimpleOp::isSimpleGeometryCollection(const geom::GeometryCollection *col)
+	GeometryCollection::const_iterator it;
+	for (it = col->begin(); it < col->end(); ++it)
+		const geom::Geometry *geom = *it;
+		if (!computeSimple(geom)) return false;
+	return true;
+/*private*/
+bool
+IsSimpleOp::isSimplePolygonal(const geom::Geometry *geom)
+	LineString::ConstVect rings;
+	LinearComponentExtracter::getLines(*geom, rings);
+	for (const geom::LineString *ring : rings)
+			if(!isSimpleLinearGeometry(ring))
+				return false;
+	return true;
+/*private*/
+bool
 IsSimpleOp::hasClosedEndpointIntersection(GeometryGraph &graph)
 	map<const Coordinate*,EndpointInfo*,CoordinateLessThen> endPoints;
diff --git a/tests/unit/geom/GeometryFactoryTest.cpp b/tests/unit/geom/GeometryFactoryTest.cpp
index bc83067..bb127d8 100644
--- a/tests/unit/geom/GeometryFactoryTest.cpp
+++ b/tests/unit/geom/GeometryFactoryTest.cpp
@@ -811,18 +811,6 @@ reader_(factory_.get())
 		ensure( "createGeometryCollection() returned null pointer.", col != nullptr );
 		ensure( col->isEmpty() );
 		ensure( col->isValid() );
-		try
-			ensure( !col->isSimple() );
-			fail("IllegalArgumentException expected");
-		catch ( geos::util::IllegalArgumentException const& e )
-			const char* msg = e.what(); // ok
-			ensure( msg != nullptr );
 		ensure( col->getCentroid() == nullptr );
 		ensure_equals( col->getGeometryTypeId(), geos::geom::GEOS_GEOMETRYCOLLECTION );
 		ensure_equals( col->getDimension(), geos::geom::Dimension::False );
diff --git a/tests/xmltester/tests/general/TestSimple.xml b/tests/xmltester/tests/general/TestSimple.xml
index eca2f4b..a21bbbd 100644
--- a/tests/xmltester/tests/general/TestSimple.xml
+++ b/tests/xmltester/tests/general/TestSimple.xml
@@ -242,9 +242,9 @@
 </case>
 <case>
-  <desc>A</desc>
+  <desc>LR - valid ring</desc>
   <a>
-    POLYGON ((180 260, 80 300, 40 180, 160 120, 180 260))
+    LINEARRING (100 300, 200 300, 200 200, 100 200, 100 300)
   </a>
 <test>
   <op name="isSimple" arg1="A">
@@ -254,28 +254,57 @@
 </case>
 <case>
-  <desc>A - empty</desc>
+  <desc>LR - ring with self-intersection</desc>
   <a>
-    POLYGON EMPTY
+    LINEARRING (100 300, 200 300, 100 200, 200 200, 100 300)
   </a>
 <test>
-    true
+    false
   </op>
 </test>
 </case>
 <case>
-  <desc>mA</desc>
+  <desc>A - valid polygon</desc>
+  <a>
+    POLYGON ((180 260, 80 300, 40 180, 160 120, 180 260))
+  </a>
+<test>
+  <op name="isSimple" arg1="A"> true </op>
+</test>
+</case>
+<case>
+  <desc>A - invalid bowtie polygon</desc>
+  <a>
+    POLYGON ((100 100, 100 200, 200 100, 200 200, 100 100))
+  </a>
+<test>
+  <op name="isSimple" arg1="A"> false </op>
+</test>
+</case>
+<case>
+  <desc>A - empty</desc>
+  <a>
+    POLYGON EMPTY
+  </a>
+<test>
+</test>
+</case>
+<case>
+  <desc>mA - valid polygon</desc>
   <a>
     MULTIPOLYGON (((240 160, 140 220, 80 60, 220 40, 240 160)),
   ((160 380, 100 240, 20 380, 160 380),
     (120 340, 60 360, 80 320, 120 340)))
   </a>
 <test>
-  <op name="isSimple" arg1="A">
-    true
-  </op>
 </test>
 </case>
@@ -287,9 +316,41 @@
   </a>
 <test>
-    true
-  </op>
+</test>
+</case>
+<case>
+  <desc>mA - with an invalid bowtie element</desc>
+  <a>
+MULTIPOLYGON (((100 100, 100 200, 200 100, 200 200, 100 100)), ((100 400, 200 400, 200 300, 100 300, 100 400)))
+</a>
+<test>
+</test>
+</case>
+<case>
+  <desc>GC - all components simple</desc>
+  <a>
+GEOMETRYCOLLECTION (POLYGON ((100 200, 200 200, 200 100, 100 100, 100 200)),
+  LINESTRING (100 300, 200 250),
+  POINT (250 250),
+  POINT (250 150))</a>
+<test>
+</test>
+</case>
+<case>
+  <desc>GC - one non-simple component</desc>
+  <a>
+GEOMETRYCOLLECTION (POLYGON ((100 100, 100 200, 200 100, 200 200, 100 100)),
+  POINT (250 250),
+<test>
 </test>
 </case>
Summary of changes:
 include/geos/geom/LinearRing.h               | 10 ----
 include/geos/geom/MultiPolygon.h             |  2 -
 include/geos/geom/Polygon.h                  | 14 +----
 include/geos/operation/IsSimpleOp.h          |  7 +++
 src/geom/Geometry.cpp                        |  1 -
 src/geom/LinearRing.cpp                      |  6 --
 src/geom/MultiPolygon.cpp                    |  4 --
 src/geom/Polygon.cpp                         |  6 --
 src/operation/IsSimpleOp.cpp                 | 79 +++++++++++++++++++++-----
 tests/unit/geom/GeometryFactoryTest.cpp      | 12 ----
 tests/xmltester/tests/general/TestSimple.xml | 85 ++++++++++++++++++++++++----
 11 files changed, 148 insertions(+), 78 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
