[geos-commits] [SCM] GEOS branch master updated. 31afc5d8d87c131168b38a1679aa57ec81f69bd4
git at osgeo.org
git at osgeo.org
Tue Nov 27 16:49:00 PST 2018
the project "GEOS".
via 31afc5d8d87c131168b38a1679aa57ec81f69bd4 (commit)
from dddda853c784296ba9f3742e1659e8140c0e8a33 (commit)
revisions in full, below.
commit 31afc5d8d87c131168b38a1679aa57ec81f69bd4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Nov 27 16:48:39 2018 -0800
Harmonize CMake tests with autotools, using --test-valid-output
on the XML tests
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index aec0e66..d60ac34 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -105,7 +105,7 @@ if(GEOS_ENABLE_TESTS)
${XMLTESTS_DIR}/safe/16595.xml
${XMLTESTS_DIR}/safe/16596.xml)
- add_test(test_xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_xmltester ${SAVE_XMLTESTS})
+ add_test(test_xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_xmltester --test-valid-output ${SAVE_XMLTESTS})
set(STATUS_RESULT "ON")
endif()
Summary of changes:
tests/xmltester/CMakeLists.txt | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
