[geos-commits] [SCM] GEOS branch master updated. 19b855acb843ca745aaa6f46c1791c2ac30c4ee8
git at osgeo.org
git at osgeo.org
Wed Nov 28 11:25:54 PST 2018
the project "GEOS".
via 19b855acb843ca745aaa6f46c1791c2ac30c4ee8 (commit)
from c8244b4e8e25cc3eac65481d1fff97f4748569a7 (commit)
revisions in full, below.
commit 19b855acb843ca745aaa6f46c1791c2ac30c4ee8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Nov 28 11:25:26 2018 -0800
Implement updated JTS hole assignment code, and associated tests.
diff --git a/src/operation/overlay/PolygonBuilder.cpp b/src/operation/overlay/PolygonBuilder.cpp
index 87ce0b8..739fcff 100644
--- a/src/operation/overlay/PolygonBuilder.cpp
+++ b/src/operation/overlay/PolygonBuilder.cpp
@@ -21,6 +21,7 @@
#include <geos/operation/overlay/OverlayOp.h>
#include <geos/operation/overlay/MaximalEdgeRing.h>
#include <geos/operation/overlay/MinimalEdgeRing.h>
+#include <geos/operation/polygonize/EdgeRing.h>
#include <geos/geomgraph/Node.h>
#include <geos/geomgraph/NodeMap.h>
#include <geos/geomgraph/DirectedEdgeStar.h>
@@ -44,7 +45,6 @@ using namespace geos::geomgraph;
using namespace geos::algorithm;
using namespace geos::geom;
namespace geos {
namespace operation { // geos.operation
namespace overlay { // geos.operation.overlay
@@ -331,30 +331,34 @@ PolygonBuilder::findEdgeRingContaining(EdgeRing *testEr,
LinearRing *testRing=testEr->getLinearRing();
const Envelope *testEnv=testRing->getEnvelopeInternal();
- const Coordinate& testPt=testRing->getCoordinateN(0);
+ Coordinate testPt=testRing->getCoordinateN(0);
EdgeRing *minShell=nullptr;
- const Envelope *minEnv=nullptr;
+ const Envelope *minShellEnv=nullptr;
for(size_t i=0, n=newShellList.size(); i<n; i++)
- LinearRing *lr=nullptr;
EdgeRing *tryShell=newShellList[i];
- LinearRing *tryRing=tryShell->getLinearRing();
- const Envelope *tryEnv=tryRing->getEnvelopeInternal();
- if (minShell!=nullptr) {
- lr=minShell->getLinearRing();
- minEnv=lr->getEnvelopeInternal();
+ LinearRing *tryShellRing=tryShell->getLinearRing();
+ const Envelope *tryShellEnv=tryShellRing->getEnvelopeInternal();
+ // the hole envelope cannot equal the shell envelope
+ // (also guards against testing rings against themselves)
+ if (tryShellEnv->equals(testEnv)) continue;
+ // hole must be contained in shell
+ if (!tryShellEnv->contains(testEnv)) continue;
+ const CoordinateSequence *tsrcs = tryShellRing->getCoordinatesRO();
+ testPt = operation::polygonize::EdgeRing::ptNotInList(testRing->getCoordinatesRO(), tsrcs);
bool isContained=false;
- const CoordinateSequence *rcl = tryRing->getCoordinatesRO();
- if (tryEnv->contains(testEnv)
- && CGAlgorithms::isPointInRing(testPt,rcl))
- isContained=true;
+ if(CGAlgorithms::isPointInRing(testPt, tsrcs))
+ isContained=true;
// check if this new containing ring is smaller than
// the current minimum ring
if (isContained) {
if (minShell==nullptr
- || minEnv->contains(tryEnv)) {
+ || minShellEnv->contains(tryShellEnv)) {
minShell=tryShell;
+ minShellEnv=minShell->getLinearRing()->getEnvelopeInternal();
diff --git a/tests/xmltester/tests/general/TestFunctionAA.xml b/tests/xmltester/tests/general/TestFunctionAA.xml
index d0d713a..ef006bd 100644
--- a/tests/xmltester/tests/general/TestFunctionAA.xml
+++ b/tests/xmltester/tests/general/TestFunctionAA.xml
@@ -630,4 +630,34 @@
</test>
</case>
+<case>
+ <desc>AA - Polygons which stress hole assignment</desc>
+ <a>
+POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0), (1 1, 1 2, 2 1, 1 1), (1 2, 1 3, 2 3, 1 2), (2 3, 3 3, 3 2, 2 3))
+ </a>
+ <b>
+POLYGON ((2 1, 3 1, 3 2, 2 1))
+ </b>
+<test>
+ <op name="intersection" arg1="A" arg2="B">
+POLYGON ((3 2, 3 1, 2 1, 3 2))
+ </op>
+</test>
+<test>
+ <op name="union" arg1="A" arg2="B">
+POLYGON ((0 0, 0 4, 4 4, 4 0, 0 0), (1 2, 1 1, 2 1, 1 2), (1 2, 2 3, 1 3, 1 2), (2 3, 3 2, 3 3, 2 3))
+ </op>
+</test>
+<test>
+ <op name="difference" arg1="A" arg2="B">
+MULTIPOLYGON (((0 0, 0 4, 4 4, 4 0, 0 0), (1 2, 1 1, 2 1, 3 1, 3 2, 3 3, 2 3, 1 3, 1 2)), ((2 1, 1 2, 2 3, 3 2, 2 1)))
+ </op>
+</test>
+<test>
+ <op name="symdifference" arg1="A" arg2="B">
+ </op>
+</test>
+</case>
</run>
Summary of changes:
src/operation/overlay/PolygonBuilder.cpp | 34 +++++++++++++-----------
tests/xmltester/tests/general/TestFunctionAA.xml | 30 +++++++++++++++++++++
2 files changed, 49 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits
