[geos-commits] [SCM] GEOS branch master updated. 8bc1ea0f8019bcb83c60126e7883ae428ea7c677
git at osgeo.org
git at osgeo.org
Wed Nov 28 11:55:37 PST 2018
the project "GEOS".
via 8bc1ea0f8019bcb83c60126e7883ae428ea7c677 (commit)
from 19b855acb843ca745aaa6f46c1791c2ac30c4ee8 (commit)
revisions in full, below.
commit 8bc1ea0f8019bcb83c60126e7883ae428ea7c677
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Nov 28 11:55:21 2018 -0800
Update TestRectanglePredicate.xml to current JTS version
diff --git a/tests/xmltester/tests/general/TestRectanglePredicate.xml b/tests/xmltester/tests/general/TestRectanglePredicate.xml
index 5546bc4..254f1e7 100644
--- a/tests/xmltester/tests/general/TestRectanglePredicate.xml
+++ b/tests/xmltester/tests/general/TestRectanglePredicate.xml
@@ -12,7 +12,7 @@
(100 200, 100 140, 180 140, 180 200, 100 200))
</b>
<test> <op name="intersects" arg1="A" arg2="B"> false </op> </test>
-<test> <op name="contains" arg1="A" arg2="B"> false </op> </test>
+<test> <op name="contains" arg1="A" arg2="B"> false </op> </test>
</case>
<case>
@@ -24,7 +24,7 @@
POLYGON((10 10, 10 90, 90 90, 90 10, 10 10))
</b>
<test> <op name="intersects" arg1="A" arg2="B"> true </op> </test>
-<test> <op name="contains" arg1="A" arg2="B"> true </op> </test>
+<test> <op name="contains" arg1="A" arg2="B"> true </op> </test>
</case>
<case>
@@ -36,7 +36,7 @@
POLYGON ((60 180, -100 120, -140 60, -40 20, -100 -80, 40 -20, 140 -100, 140 40, 260 160, 80 120, 60 180))
</b>
</case>
<case>
@@ -49,14 +49,14 @@
((20 280, 0 180, 180 160, 200 280, 20 280)))
</b>
-<test> <op name="within" arg1="A" arg2="B"> true </op> </test>
-<test> <op name="covers" arg1="A" arg2="B"> false </op> </test>
-<test> <op name="coveredBy" arg1="A" arg2="B"> true </op> </test>
+<test> <op name="within" arg1="A" arg2="B"> true </op> </test>
+<test> <op name="covers" arg1="A" arg2="B"> false </op> </test>
+<test> <op name="coveredBy" arg1="A" arg2="B"> true </op> </test>
</case>
<case>
- <desc>L overlaps thru Y axis side</desc>
+ <desc>L overlaps through Y axis side</desc>
<a>
POLYGON((0 0, 100 0, 100 100, 0 100, 0 0))
</a>
@@ -67,16 +67,81 @@
</case>
<case>
- <desc>L overlaps thru X axis side</desc>
+ <desc>L overlaps through X axis side</desc>
<a>
</a>
<b>
LINESTRING(10 10, 10 2000)
</b>
-<test> <op name="intersects" arg1="A" arg2="B"> true </op> </test>
+<test> <op name="intersects" arg1="A" arg2="B"> true </op> </test>
+</case>
+<case>
+ <desc>L on upward diagonal crosses</desc>
+ <a>
+ POLYGON((0 0, 100 0, 100 100, 0 100, 0 0))
+ </a>
+ <b>
+ LINESTRING (60 120, -20 20)
+ </b>
+</case>
+<case>
+ <desc>L on downward diagonal crosses</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING (50 120, 120 50)
+ </b>
+</case>
+<case>
+ <desc>L on downward diagonal does not intersect</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING (70 140, 150 50)
+ </b>
+<test> <op name="intersects" arg1="A" arg2="B"> false </op> </test>
+</case>
+<case>
+ <desc>L with many segments crosses</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING (110 160, 150 70, 110 -20, 130 80, 90 150, 60 -20, 38 128)
+ </b>
+</case>
+<case>
+ <desc>L with many segments does not intersect</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING (110 160, 150 70, 110 -20, 130 80, 90 150, 90 110, 38 128)
+ </b>
</case>
<case>
@@ -87,8 +152,8 @@
<b>
LINESTRING( 10 10, -10 -20 )
</b>
</case>
<case>
@@ -100,9 +165,9 @@
LINESTRING( 10 0, 90 0 )
</b>
-<test> <op name="covers" arg1="A" arg2="B"> true </op> </test>
-<test> <op name="coveredBy" arg1="B" arg2="A"> true </op> </test>
+<test> <op name="covers" arg1="A" arg2="B"> true </op> </test>
+<test> <op name="coveredBy" arg1="B" arg2="A"> true </op> </test>
</case>
<case>
@@ -114,9 +179,9 @@
LINESTRING( 10 0, 100 0, 100 50 )
</b>
</case>
<case>
@@ -128,9 +193,9 @@
LINESTRING( 10 0, 100 0, 100 100, 50 100 )
</b>
</case>
<case>
@@ -142,9 +207,9 @@
MULTILINESTRING( (10 0, 20 0), (10 10, 20 20) )
</b>
</case>
<case>
@@ -156,7 +221,7 @@
MULTILINESTRING( (10 10, 10 20), (200 10, 200 20) )
</b>
</case>
<case>
@@ -168,9 +233,9 @@
POINT(100 50)
</b>
</case>
<case>
@@ -182,9 +247,9 @@
POINT(50 100)
</b>
</case>
<case>
@@ -196,9 +261,9 @@
POINT(60 60)
</b>
</case>
<case>
@@ -210,9 +275,27 @@
MULTIPOINT((50 100), (60 60))
</b>
+</case>
+<case>
+ <desc>GC as argument</desc>
+ <a>
+ </a>
+ <b>
+ GEOMETRYCOLLECTION (
+ POLYGON((10 10, 10 90, 90 90, 90 10, 10 10)),
+ LINESTRING(10 10, 10 20),
+ MULTIPOINT((50 100), (60 60))
+ </b>
</case>
Summary of changes:
.../tests/general/TestRectanglePredicate.xml | 161 ++++++++++++++++-----
1 file changed, 122 insertions(+), 39 deletions(-)
hooks/post-receive
More information about the geos-commits
