[geos-commits] [SCM] GEOS branch master updated. ee833c55b1c1466ea44fe2adbde451b486b57392
git at osgeo.org
git at osgeo.org
Fri Nov 30 10:42:33 PST 2018
the project "GEOS".
via ee833c55b1c1466ea44fe2adbde451b486b57392 (commit)
from b5eb5cd30df17480a55d81e8c087049d03c13ef3 (commit)
revisions in full, below.
commit ee833c55b1c1466ea44fe2adbde451b486b57392
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 30 10:42:21 2018 -0800
Reformatting pass
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 624de71..6be7a4d 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -99,27 +99,27 @@ std::unique_ptr<const PreparedGeometry> prepare( const geom::Geometry *g ) {
// Copy from geos/util/math.cpp
double java_math_round(double val)
- double n;
- double f = std::fabs(std::modf(val, &n));
- if (val >= 0)
- if (f < 0.5) {
- return std::floor(val);
- } else if (f > 0.5) {
- return std::ceil(val);
- } else {
- return (n + 1.0);
- } else {
- if (f < 0.5) {
- } else {
- return n;
+ double n;
+ double f = std::fabs(std::modf(val, &n));
+ if (val >= 0)
+ if (f < 0.5) {
+ return std::floor(val);
+ } else if (f > 0.5) {
+ return std::ceil(val);
+ } else {
+ return (n + 1.0);
+ } else {
+ if (f < 0.5) {
+ } else {
+ return n;
} // java_math_round
@@ -196,10 +196,10 @@ checkBufferSuccess(geom::Geometry const& gRes, geom::Geometry const& gRealRes, d
if ( gRes.getGeometryTypeId() != gRealRes.getGeometryTypeId() )
std::cerr << "Expected result is of type "
- << gRes.getGeometryType()
- << "; obtained result is of type "
- << gRealRes.getGeometryType()
- << std::endl;
+ << gRes.getGeometryType()
+ << "; obtained result is of type "
+ << gRealRes.getGeometryType()
+ << std::endl;
success=0;
break;
@@ -208,19 +208,19 @@ checkBufferSuccess(geom::Geometry const& gRes, geom::Geometry const& gRealRes, d
if ( gRes.getDimension() != 2 )
std::cerr << "Don't know how to validate "
- << "result of buffer operation "
- << "when expected result is not an "
- << "areal type."
- << std::endl;
+ << "result of buffer operation "
+ << "when expected result is not an "
+ << "areal type."
+ << std::endl;
geos::xmltester::BufferResultMatcher matcher;
if ( ! matcher.isBufferResultMatch(gRealRes,
- gRes,
- dist) )
+ gRes,
+ dist) )
-std::cerr << "BufferResultMatcher FAILED" << std::endl;
+ std::cerr << "BufferResultMatcher FAILED" << std::endl;
success=0;
break;
@@ -233,7 +233,7 @@ std::cerr << "BufferResultMatcher FAILED" << std::endl;
static int
checkSingleSidedBufferSuccess(geom::Geometry& gRes,
- geom::Geometry& gRealRes, double dist)
+ geom::Geometry& gRealRes, double dist)
int success = 1;
do
@@ -242,20 +242,20 @@ checkSingleSidedBufferSuccess(geom::Geometry& gRes,
- << std::endl;
+ << std::endl;
success=0;
break;
geos::xmltester::SingleSidedBufferResultMatcher matcher;
- gRes,
- dist) )
+ gRes,
+ dist) )
-std::cerr << "SingleSidedBufferResultMatcher FAILED" << std::endl;
+ std::cerr << "SingleSidedBufferResultMatcher FAILED" << std::endl;
success=0;
break;
@@ -342,7 +342,7 @@ XMLTester::printTest(bool success, const std::string& expected_result, const std
std::cout << *curr_file <<":";
std::cout << " case" << caseCount << ":";
std::cout << " test" << testCount << ": "
- << opSignature;
+ << opSignature;
std::cout << ": " << (success?"ok.":"failed.");
std::cout << " (" << std::setprecision(15) << java_math_round(prof.getTot()/1000) << " ms)" << std::endl;
@@ -376,17 +376,17 @@ XMLTester::run(const std::string &source)
std::cout << "CREATE TABLE \"" << normalize_filename(*curr_file) << "\""
<< "( caseno integer, testno integer, "
- << " operation varchar, description varchar, "
- << " a geometry, b geometry, expected geometry, "
- << " obtained geometry, result bool )"
+ << " operation varchar, description varchar, "
+ << " a geometry, b geometry, expected geometry, "
+ << " obtained geometry, result bool )"
- // NOTE: qgis 0.7.4 require oids for proper operations.
- // The 'WITH OIDS' parameter is supported back to
- // PostgreSQL 7.2, so if you run an older version
- // rebuild with the next line commented out.
- << " WITH OIDS"
+ // NOTE: qgis 0.7.4 require oids for proper operations.
+ // The 'WITH OIDS' parameter is supported back to
+ // PostgreSQL 7.2, so if you run an older version
+ // rebuild with the next line commented out.
+ << " WITH OIDS"
- << ";" << std::endl;
+ << ";" << std::endl;
++testFileCount;
@@ -407,7 +407,7 @@ XMLTester::run(const std::string &source)
const tinyxml2::XMLNode* node = xml.FirstChildElement("run");
if ( ! node )
- throw(runtime_error("Document has no childs"));
+ throw(runtime_error("Document has no childs"));
parseRun(node);
@@ -475,8 +475,8 @@ XMLTester::parseRun(const tinyxml2::XMLNode* node)
const tinyxml2::XMLNode* casenode;
for ( casenode = node->FirstChildElement("case");
- casenode;
- casenode = casenode->NextSiblingElement("case") )
+ casenode;
+ casenode = casenode->NextSiblingElement("case") )
try {
parseCase(casenode);
@@ -538,11 +538,11 @@ XMLTester::testValid(const geom::Geometry* g, const std::string& label)
operation::valid::TopologyValidationError *err = ivo.getValidationError();
std::cerr << *curr_file << ":"
- << " case" << caseCount << ":"
- << " test" << testCount << ": "
- << opSignature << ": "
- << " invalid geometry (" << label
- << "): " << err->toString() << std::endl;
+ << " case" << caseCount << ":"
+ << " test" << testCount << ": "
+ << opSignature << ": "
+ << " invalid geometry (" << label
+ << "): " << err->toString() << std::endl;
return valid;
@@ -567,27 +567,27 @@ XMLTester::parseGeometry(const std::string &in, const char* label)
switch (first_char)
- case '0':
- case '1':
- case '2':
- case '3':
- case '4':
- case '5':
- case '6':
- case '7':
- case '8':
- case '9':
- case 'A':
- case 'B':
- case 'C':
- case 'D':
- case 'E':
- case 'F':
- ret = wkbreader->readHEX(is);
- break;
- default:
- ret = wktreader->read(in);
- break;
+ case '0':
+ case '1':
+ case '2':
+ case '3':
+ case '4':
+ case '5':
+ case '6':
+ case '7':
+ case '8':
+ case '9':
+ case 'A':
+ case 'B':
+ case 'C':
+ case 'D':
+ case 'E':
+ case 'F':
+ ret = wkbreader->readHEX(is);
+ break;
+ default:
+ ret = wktreader->read(in);
+ break;
if ( testValidInput ) testValid(ret, std::string(label));
@@ -670,8 +670,8 @@ XMLTester::parseCase(const tinyxml2::XMLNode* node)
const tinyxml2::XMLNode* testnode;
for ( testnode = node->FirstChildElement("test");
- testnode;
- testnode = testnode->NextSiblingElement("test") )
+ testnode;
+ testnode = testnode->NextSiblingElement("test") )
parseTest(testnode);
@@ -750,8 +750,8 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
std::stringstream p_tmp;
p_tmp << "op of test " << testCount
- << " of case " << caseCount
- << " has no expected result child";
+ << " of case " << caseCount
+ << " has no expected result child";
throw(runtime_error(p_tmp.str()));
opRes = resnode->Value();
@@ -1186,7 +1186,7 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
BufferParameters params;
if ( opArg3 != "" ) {
- params.setQuadrantSegments(std::atoi(opArg3.c_str()));
+ params.setQuadrantSegments(std::atoi(opArg3.c_str()));
@@ -1224,7 +1224,7 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
BufferParameters params ;
params.setJoinStyle( BufferParameters::JOIN_ROUND ) ;
- params.setQuadrantSegments( std::atoi(opArg3.c_str()));
+ params.setQuadrantSegments( std::atoi(opArg3.c_str()));
bool leftSide = true ;
@@ -1235,14 +1235,14 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
BufferBuilder bufBuilder( params ) ;
gRealRes.reset( bufBuilder.bufferLineSingleSided(
- p_gT, dist, leftSide ) ) ;
+ p_gT, dist, leftSide ) ) ;
profile.stop();
gRealRes->normalize();
// Validate the single sided buffer operation
success = checkSingleSidedBufferSuccess(*gRes,
- *gRealRes, dist);
+ *gRealRes, dist);
actual_result=printGeom(gRealRes.get());
expected_result=printGeom(gRes.get());
@@ -1270,7 +1270,7 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
params.setJoinStyle(BufferParameters::JOIN_MITRE);
BufferOp op(p_gT, params);
@@ -1393,13 +1393,13 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
if ( verbose > 1 )
- std::cerr << "Running intersection for areatest" << std::endl;
+ std::cerr << "Running intersection for areatest" << std::endl;
#ifndef USE_BINARYOP
GeomPtr gI(gA->intersection(gB));
#else
GeomPtr gI = BinaryOp(gA, gB,
- overlayOp(OverlayOp::opINTERSECTION));
+ overlayOp(OverlayOp::opINTERSECTION));
#endif
if ( testValidOutput )
@@ -1409,14 +1409,14 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
if ( verbose > 1 )
- std::cerr << "Running difference(A,B) for areatest" << std::endl;
+ std::cerr << "Running difference(A,B) for areatest" << std::endl;
GeomPtr gDab(gA->difference(gB));
#else
GeomPtr gDab = BinaryOp(gA, gB,
- overlayOp(OverlayOp::opDIFFERENCE));
+ overlayOp(OverlayOp::opDIFFERENCE));
#endif
@@ -1426,14 +1426,14 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
if ( verbose > 1 )
- std::cerr << "Running difference(B,A) for areatest" << std::endl;
+ std::cerr << "Running difference(B,A) for areatest" << std::endl;
GeomPtr gDba(gB->difference(gA));
#else
GeomPtr gDba = BinaryOp(gB, gA,
#endif
@@ -1443,14 +1443,14 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
if ( verbose > 1 )
- std::cerr << "Running symdifference for areatest" << std::endl;
+ std::cerr << "Running symdifference for areatest" << std::endl;
GeomPtr gSD(gA->symDifference(gB));
#else
GeomPtr gSD = BinaryOp(gA, gB,
- overlayOp(OverlayOp::opSYMDIFFERENCE));
+ overlayOp(OverlayOp::opSYMDIFFERENCE));
#endif
@@ -1460,14 +1460,14 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
if ( verbose > 1 )
- std::cerr << "Running union for areatest" << std::endl;
+ std::cerr << "Running union for areatest" << std::endl;
GeomPtr gU(gA->Union(gB));
#else
GeomPtr gU = BinaryOp(gA, gB,
- overlayOp(OverlayOp::opUNION));
+ overlayOp(OverlayOp::opUNION));
#endif
double areaA = gA->getArea();
@@ -1537,7 +1537,8 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
geom::Geometry *g1 = opArg1 == "B" ? gB : gA;
geom::Geometry *g2 = opArg2 == "B" ? gB : gA;
double distO = g1->distance(g2);
- std::stringstream ss; ss << distO;
+ std::stringstream ss;
+ ss << distO;
actual_result = ss.str();
// TODO: Use a tolerance ?
@@ -1558,8 +1559,8 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
catch (const std::exception &e)
std::cerr<<"EXCEPTION on case "<<caseCount
- <<" test "<<testCount<<": "<<e.what()
- <<std::endl;
+ <<" test "<<testCount<<": "<<e.what()
+ <<std::endl;
actual_result = e.what();
catch (...)
@@ -1628,7 +1629,7 @@ usage(char *me, int exitcode, std::ostream &os)
void
request_interrupt(int)
- geos::util::Interrupt::request();
+ geos::util::Interrupt::request();
int
@@ -1642,60 +1643,60 @@ main(int argC, char* argV[])
#endif
- if ( argC < 2 ) usage(argV[0], 1, std::cerr);
+ if ( argC < 2 ) usage(argV[0], 1, std::cerr);
- signal(15, request_interrupt);
+ signal(15, request_interrupt);
- XMLTester tester;
- tester.setVerbosityLevel(verbose);
+ XMLTester tester;
+ tester.setVerbosityLevel(verbose);
- for (int i=1; i<argC; ++i)
- // increment verbosity level
- if ( ! std::strcmp(argV[i], "-v" ) )
+ for (int i=1; i<argC; ++i)
- ++verbose;
- continue;
- if ( ! std::strcmp(argV[i], "--test-valid-output" ) )
- tester.testOutputValidity(true);
- continue;
- if ( ! std::strcmp(argV[i], "--sql-output" ) )
- sql_output = true;
- tester.setSQLOutput(sql_output);
- continue;
- if ( ! std::strcmp(argV[i], "--wkb-output" ) )
- tester.setHEXWKBOutput(sql_output);
- continue;
- if ( ! std::strcmp(argV[i], "--test-valid-input" ) )
- tester.testInputValidity(true);
- continue;
+ // increment verbosity level
+ if ( ! std::strcmp(argV[i], "-v" ) )
+ ++verbose;
+ continue;
+ if ( ! std::strcmp(argV[i], "--test-valid-output" ) )
+ tester.testOutputValidity(true);
+ continue;
+ if ( ! std::strcmp(argV[i], "--sql-output" ) )
+ sql_output = true;
+ tester.setSQLOutput(sql_output);
+ continue;
+ if ( ! std::strcmp(argV[i], "--wkb-output" ) )
+ tester.setHEXWKBOutput(sql_output);
+ continue;
+ if ( ! std::strcmp(argV[i], "--test-valid-input" ) )
+ tester.testInputValidity(true);
+ continue;
- std::string source = argV[i];
+ std::string source = argV[i];
- try {
- tester.run(source);
- } catch (const std::exception& exc) {
- std::cerr<<exc.what()<<std::endl;
+ try {
+ tester.run(source);
+ } catch (const std::exception& exc) {
+ std::cerr<<exc.what()<<std::endl;
- if ( ! sql_output ) tester.resultSummary(std::cout);
- else tester.resultSummary(std::cerr);
+ if ( ! sql_output ) tester.resultSummary(std::cout);
+ else tester.resultSummary(std::cerr);
- io::Unload::Release();
+ io::Unload::Release();
- return tester.getFailuresCount();
+ return tester.getFailuresCount();
#if defined(_MSC_VER) && defined(GEOS_TEST_USE_STACKWALKER)
Summary of changes:
tests/xmltester/XMLTester.cpp | 293 +++++++++++++++++++++---------------------
1 file changed, 147 insertions(+), 146 deletions(-)
hooks/post-receive
More information about the geos-commits
