[geos-commits] [SCM] GEOS branch master updated. 93f1a02f00e2a4714ac8658523ed89f352a9ac7f
git at osgeo.org
git at osgeo.org
Fri Nov 30 12:34:17 PST 2018
the project "GEOS".
via 93f1a02f00e2a4714ac8658523ed89f352a9ac7f (commit)
from ee833c55b1c1466ea44fe2adbde451b486b57392 (commit)
revisions in full, below.
commit 93f1a02f00e2a4714ac8658523ed89f352a9ac7f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 30 12:33:48 2018 -0800
Add TestMinimumClearance.xml to test set and
update the XMLTester to support "minclearance" and
"minclearanceline" tests
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index f9004ab..2de1ffd 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -81,6 +81,7 @@ if(GEOS_ENABLE_TESTS)
${XMLTESTS_DIR}/general/TestFunctionPLPrec.xml
${XMLTESTS_DIR}/general/TestFunctionPP.xml
${XMLTESTS_DIR}/general/TestInteriorPoint.xml
+ ${XMLTESTS_DIR}/general/TestMinimumClearance.xml
${XMLTESTS_DIR}/general/TestPreparedPointPredicate.xml
${XMLTESTS_DIR}/general/TestPreparedPolygonPredicate.xml
${XMLTESTS_DIR}/general/TestPreparedPredicatesWithGeometryCollection.xml
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index 5a01f1b..a882f1e 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -49,6 +49,7 @@ SAFE_XMLTESTS= \
$(srcdir)/tests/general/TestFunctionPLPrec.xml \
$(srcdir)/tests/general/TestFunctionPP.xml \
$(srcdir)/tests/general/TestInteriorPoint.xml \
+ $(srcdir)/tests/general/TestMinimumClearance.xml \
$(srcdir)/tests/general/TestPreparedPointPredicate.xml \
$(srcdir)/tests/general/TestPreparedPolygonPredicate.xml \
$(srcdir)/tests/general/TestPreparedPredicatesWithGeometryCollection.xml \
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 6be7a4d..60733c0 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -40,6 +40,7 @@
#include <geos/operation/buffer/BufferBuilder.h>
#include <geos/operation/buffer/BufferParameters.h>
#include <geos/operation/buffer/BufferOp.h>
+#include <geos/precision/MinimumClearance.h>
#include <geos/util.h>
#include <geos/util/Interrupt.h>
//#include <geos/geomgraph.h>
@@ -1544,6 +1545,49 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
// TODO: Use a tolerance ?
success = ( distO == distE ) ? 1 : 0;
+ else if (opName=="minclearance")
+ char* rest;
+ double minclearanceE = std::strtod(opRes.c_str(), &rest);
+ if ( rest == opRes.c_str() )
+ throw std::runtime_error("malformed testcase: missing expected result in 'minclearance' op");
+ geom::Geometry *g1 = opArg1 == "B" ? gB : gA;
+ precision::MinimumClearance mc(g1);
+ double minclearanceO = mc.getDistance();
+ std::stringstream ss;
+ ss << minclearanceO;
+ actual_result = ss.str();
+ // Hack for Inf/1.7976931348623157E308 comparison
+ if (minclearanceO > 1.7976931348623157E308)
+ minclearanceO = 1.7976931348623157E308;
+ // TODO: Use a tolerance ?
+ success = ( minclearanceO == minclearanceE ) ? 1 : 0;
+ else if (opName=="minclearanceline")
+ double tol = 0.0000001;
+ GeomPtr lineE(parseGeometry(opRes, "expected"));
+ if (!lineE)
+ throw std::runtime_error("malformed testcase: missing expected result in 'minclearanceline' op");
+ std::unique_ptr<geom::Geometry> lineO = mc.getLine();
+ lineO.get()->normalize();
+ lineE.get()->normalize();
+ actual_result=printGeom(lineO.get());
+ success = lineE.get()->equalsExact(lineO.get(), tol) ? 1 : 0;
else
diff --git a/tests/xmltester/tests/general/TestMinimumClearance.xml b/tests/xmltester/tests/general/TestMinimumClearance.xml
new file mode 100644
index 0000000..d770180
--- /dev/null
+++ b/tests/xmltester/tests/general/TestMinimumClearance.xml
@@ -0,0 +1,89 @@
+<run>
+ <precisionModel type="FLOATING" />
+<case>
+ <desc>P - empty point</desc>
+ <a> POINT EMPTY </a>
+<test><op name="minClearance" arg1='A' > 1.7976931348623157E308 </op></test>
+<test><op name="minClearanceLine" arg1='A' > LINESTRING EMPTY </op></test>
+</case>
+<case>
+ <desc>P - single point</desc>
+ <a> POINT (100 100) </a>
+</case>
+<case>
+ <desc>mP - points</desc>
+ <a> MULTIPOINT ( (100 100), (10 100) ) </a>
+<test><op name="minClearance" arg1='A' > 90 </op></test>
+<test><op name="minClearanceLine" arg1='A' > LINESTRING (100 100, 10 100) </op></test>
+</case>
+<case>
+ <desc>mP - two identical points</desc>
+ <a> MULTIPOINT ( (100 100), (100 100) ) </a>
+</case>
+<case>
+ <a> MULTIPOINT ((100 100), (10 100), (30 100)) </a>
+<test><op name="minClearance" arg1='A' > 20 </op></test>
+<test><op name="minClearanceLine" arg1='A' > LINESTRING (10 100, 30 100) </op></test>
+</case>
+<case>
+ <desc>L - linestring</desc>
+ <a> LINESTRING (100 100, 200 100, 200 200, 150 150) </a>
+<test><op name="minClearance" arg1='A' > 50 </op></test>
+<test><op name="minClearanceLine" arg1='A' > LINESTRING (150 150, 150 100) </op></test>
+</case>
+<case>
+ <desc>L - empty linestring</desc>
+ <a> LINESTRING EMPTY </a>
+</case>
+<case>
+ <desc>ML - linestring</desc>
+ <a> MULTILINESTRING ((100 100, 200 100, 200 200, 150 150),
+ (100 200, 150 170)) </a>
+<test><op name="minClearance" arg1='A' > 14.142135623730951 </op></test>
+<test><op name="minClearanceLine" arg1='A' > LINESTRING (150 170, 160 160) </op></test>
+</case>
+<case>
+ <desc>A - empty polygon</desc>
+ <a> POLYGON EMPTY </a>
+</case>
+<case>
+ <desc>A - single polygon #1</desc>
+ <a> POLYGON ((100 100, 300 100, 200 200, 100 100)) </a>
+<test><op name="minClearance" arg1='A' > 100 </op></test>
+<test><op name="minClearanceLine" arg1='A' > LINESTRING (200 200, 200 100) </op></test>
+</case>
+<case>
+ <desc>A - single polygon #2</desc>
+ <a> POLYGON ((300 400, 100 350, 250 320, 50 250, 298 200, 50 150, 150 100, 300 50, 300 50, 300 50, 300 400)) </a>
+<test><op name="minClearance" arg1='A' > 2 </op></test>
+<test><op name="minClearanceLine" arg1='A' > LINESTRING (298 200, 300 200) </op></test>
+</case>
+<case>
+ <desc>mA - multiple polygons</desc>
+ <a> MULTIPOLYGON (((100 100, 300 100, 200 200, 100 100)), ((150 250, 250 250, 200 220, 150 250))) </a>
+<test><op name="minClearanceLine" arg1='A' > LINESTRING (200 200, 200 220) </op></test>
+</case>
+</run>
Summary of changes:
tests/xmltester/CMakeLists.txt | 1 +
tests/xmltester/Makefile.am | 1 +
tests/xmltester/XMLTester.cpp | 44 +++++++++++
.../tests/general/TestMinimumClearance.xml | 89 ++++++++++++++++++++++
4 files changed, 135 insertions(+)
create mode 100644 tests/xmltester/tests/general/TestMinimumClearance.xml
hooks/post-receive
More information about the geos-commits
