[geos-commits] [SCM] GEOS branch master updated. f640fe0d8674aa8eea1506349d697a9cb7824431
Thu Oct 18 22:38:40 PDT 2018
the project "GEOS".
       via  f640fe0d8674aa8eea1506349d697a9cb7824431 (commit)
       via  e2b85688c9e043a096a0161f59cb6fa9c142f868 (commit)
      from  d9546f690bcf2bb35c197265602731c8f6f8ca48 (commit)
revisions in full, below.
commit f640fe0d8674aa8eea1506349d697a9cb7824431
Merge: d9546f6 e2b8568
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Oct 18 22:38:40 2018 -0700
    Merge branch 'master' of johnkharvey/geos into master
    https://lists.osgeo.org/pipermail/postgis-devel/2018-September/027371.html
    No reason we need to require autoconf 2.64, downgrade to 2.63
commit e2b85688c9e043a096a0161f59cb6fa9c142f868
Author: John K. Harvey <john.harvey at crunchydata.com>
Date:   Tue Oct 2 14:07:26 2018 -0400
    'make check' passes with autoconf 2.63.
diff --git a/configure.ac b/configure.ac
index 65ddddd..c15b196 100644
--- a/configure.ac
+++ b/configure.ac
@@ -2,7 +2,7 @@ dnl
 dnl configure.in - autoconf input template to produce ./configure script
 dnl
 dnl version 2.52 is required for Cygwin libtool support
-AC_PREREQ([2.52])
+AC_PREREQ([2.63])
 dnl local vars to hold user's preferences --------------------------------
 AC_INIT([include/geos.h])
diff --git a/macros/ax_check_compile_flag.m4 b/macros/ax_check_compile_flag.m4
index ca36397..89d3b93 100755
--- a/macros/ax_check_compile_flag.m4
+++ b/macros/ax_check_compile_flag.m4
@@ -58,7 +58,7 @@
 #serial 4
 AC_DEFUN([AX_CHECK_COMPILE_FLAG],
-[AC_PREREQ(2.64)dnl for _AC_LANG_PREFIX and AS_VAR_IF
+[AC_PREREQ(2.63)dnl for _AC_LANG_PREFIX and AS_VAR_IF
 AS_VAR_PUSHDEF([CACHEVAR],[ax_cv_check_[]_AC_LANG_ABBREV[]flags_$4_$1])dnl
 AC_CACHE_CHECK([whether _AC_LANG compiler accepts $1], CACHEVAR, [
   ax_check_save_flags=$[]_AC_LANG_PREFIX[]FLAGS
Summary of changes:
 configure.ac                    | 2 +-
 macros/ax_check_compile_flag.m4 | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
