[geos-commits] [SCM] GEOS branch master updated. f7867f9e6ff5379a14dd78890925e7ecd1bf22dc
Wed Sep 19 06:43:22 PDT 2018
the project "GEOS".
       via  f7867f9e6ff5379a14dd78890925e7ecd1bf22dc (commit)
       via  754c4cd6deb6c9a9c7340756add260b247a13ddc (commit)
      from  33e771633cab9ae248b769b89385b624371545d8 (commit)
revisions in full, below.
commit f7867f9e6ff5379a14dd78890925e7ecd1bf22dc
Merge: 33e7716 754c4cd
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Sep 19 09:43:06 2018 -0400
    Merge branch 'no-exception-pointers'
commit 754c4cd6deb6c9a9c7340756add260b247a13ddc
Date:   Tue Sep 18 11:14:20 2018 -0400
    Avoid throwing exceptions as pointers
diff --git a/src/algorithm/locate/IndexedPointInAreaLocator.cpp b/src/algorithm/locate/IndexedPointInAreaLocator.cpp
index 637767f..d670f55 100644
--- a/src/algorithm/locate/IndexedPointInAreaLocator.cpp
+++ b/src/algorithm/locate/IndexedPointInAreaLocator.cpp
@@ -103,7 +103,7 @@ IndexedPointInAreaLocator::IndexedPointInAreaLocator( const geom::Geometry & g)
 	if (	typeid( areaGeom) != typeid( geom::Polygon)
 		&&	typeid( areaGeom) != typeid( geom::MultiPolygon) )
-		throw new util::IllegalArgumentException("Argument must be Polygonal");
+		throw util::IllegalArgumentException("Argument must be Polygonal");
 	//areaGeom = g;
diff --git a/src/index/intervalrtree/SortedPackedIntervalRTree.cpp b/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
index eda819b..7df33de 100644
--- a/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
+++ b/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
@@ -129,7 +129,7 @@ void
 SortedPackedIntervalRTree::insert( double min, double max, void * item)
 	if (root != nullptr)
-		throw new util::UnsupportedOperationException( "Index cannot be added to once it has been queried");
+		throw util::UnsupportedOperationException( "Index cannot be added to once it has been queried");
 	leaves->push_back( new IntervalRTreeLeafNode( min, max, item));
diff --git a/src/index/strtree/BoundablePair.cpp b/src/index/strtree/BoundablePair.cpp
index 4ec0b7b..8e42d87 100644
--- a/src/index/strtree/BoundablePair.cpp
+++ b/src/index/strtree/BoundablePair.cpp
@@ -97,7 +97,7 @@ void BoundablePair::expandToQueue(BoundablePairQueue & priQ, double minDistance)
 		return;
-	throw new geos::util::IllegalArgumentException("neither boundable is composite");
+	throw geos::util::IllegalArgumentException("neither boundable is composite");
 void BoundablePair::expand(const Boundable* bndComposite, const Boundable* bndOther, BoundablePairQueue & priQ, double minDistance) {
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index 53a4711..219f4e0 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -56,8 +56,7 @@ QuadEdgeSubdivision::getTriangleEdges(const QuadEdge &startQE,
     triEdge[1] = &triEdge[0]->lNext();
     triEdge[2] = &triEdge[1]->lNext();
     if (&triEdge[2]->lNext() != triEdge[0]) {
-        throw new
-            util::IllegalArgumentException("Edges do not form a triangle");
+        throw util::IllegalArgumentException("Edges do not form a triangle");
Summary of changes:
 src/algorithm/locate/IndexedPointInAreaLocator.cpp    | 2 +-
 src/index/intervalrtree/SortedPackedIntervalRTree.cpp | 2 +-
 src/index/strtree/BoundablePair.cpp                   | 2 +-
 src/triangulate/quadedge/QuadEdgeSubdivision.cpp      | 3 +--
 4 files changed, 4 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
