[geos-commits] [SCM] GEOS branch master updated. 1ba1e6cba3e877d4f42525272b2c9f12b04977f8
Thu Sep 20 10:22:53 PDT 2018
the project "GEOS".
       via  1ba1e6cba3e877d4f42525272b2c9f12b04977f8 (commit)
       via  066e5290dbe5332320910e8de2ebb101a5d42a0c (commit)
       via  4c714189907c9f95516c34b5b373e13e2ad1b6bb (commit)
      from  f7867f9e6ff5379a14dd78890925e7ecd1bf22dc (commit)
revisions in full, below.
commit 1ba1e6cba3e877d4f42525272b2c9f12b04977f8
Merge: f7867f9 066e529
Author: Daniel Baston <dbaston at gmail.com>
Date:   Thu Sep 20 13:22:34 2018 -0400
    Merge branch 'indexed-point-in-area-reduce-heap'
commit 066e5290dbe5332320910e8de2ebb101a5d42a0c
Date:   Thu Sep 20 13:22:16 2018 -0400
    Remove unneeded constructor call
diff --git a/src/algorithm/locate/IndexedPointInAreaLocator.cpp b/src/algorithm/locate/IndexedPointInAreaLocator.cpp
index dbc1e35..47fbed5 100644
--- a/src/algorithm/locate/IndexedPointInAreaLocator.cpp
+++ b/src/algorithm/locate/IndexedPointInAreaLocator.cpp
@@ -36,8 +36,7 @@ namespace locate {
 // private:
-IndexedPointInAreaLocator::IntervalIndexedGeometry::IntervalIndexedGeometry( const geom::Geometry & g) :
-index{index::intervalrtree::SortedPackedIntervalRTree()}
+IndexedPointInAreaLocator::IntervalIndexedGeometry::IntervalIndexedGeometry( const geom::Geometry & g)
 	init( g);
commit 4c714189907c9f95516c34b5b373e13e2ad1b6bb
Date:   Tue Sep 18 12:34:35 2018 -0400
    Minimize heap allocations in IndexedPointInAreaLocator
diff --git a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
index 369b042..c6bb288 100644
--- a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
+++ b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
@@ -4,6 +4,7 @@
  * http://geos.osgeo.org
  * Copyright (C) 2006 Refractions Research Inc.
+ * Copyright (C) 2018 Daniel Baston <dbaston at gmail.com>
  * This is free software; you can redistribute and/or modify it under
  * the terms of the GNU Lesser General Public Licence as published
@@ -18,7 +19,9 @@
 #include <geos/algorithm/locate/PointOnGeometryLocator.h> // inherited
 #include <geos/index/ItemVisitor.h> // inherited
+#include <geos/index/intervalrtree/SortedPackedIntervalRTree.h> // inherited
+#include <memory>
 #include <vector> // composition
 namespace geos {
@@ -31,11 +34,6 @@ namespace geos {
 		class CoordinateSequence;
 		class LineSegment;
-	namespace index {
-		namespace intervalrtree {
-			class SortedPackedIntervalRTree;
 namespace geos {
@@ -58,17 +56,16 @@ private:
 	class IntervalIndexedGeometry
 	private:
-		index::intervalrtree::SortedPackedIntervalRTree * index;
+		index::intervalrtree::SortedPackedIntervalRTree index;
 		void init( const geom::Geometry & g);
-		void addLine( geom::CoordinateSequence * pts);
+		void addLine(const geom::CoordinateSequence * pts);
-		// To keep track of allocated LineSegments
-		std::vector< geom::LineSegment* > allocatedSegments;
+		// To keep track of LineSegments
+		std::vector< geom::LineSegment > segments;
 	public:
 		IntervalIndexedGeometry( const geom::Geometry & g);
-		~IntervalIndexedGeometry();
 		void query(double min, double max, index::ItemVisitor * visitor);
@@ -92,7 +89,7 @@ private:
 	const geom::Geometry & areaGeom;
-	IntervalIndexedGeometry * index;
+	std::unique_ptr<IntervalIndexedGeometry> index;
 	void buildIndex( const geom::Geometry & g);
@@ -107,8 +104,6 @@ public:
 	IndexedPointInAreaLocator( const geom::Geometry & g);
-	~IndexedPointInAreaLocator() override;
 	 * Determines the {@link Location} of a point in an areal {@link Geometry}.
index d670f55..dbc1e35 100644
@@ -4,6 +4,7 @@
  * Copyright (C) 2001-2002 Vivid Solutions Inc.
@@ -35,51 +36,35 @@ namespace locate {
 // private:
+IndexedPointInAreaLocator::IntervalIndexedGeometry::IntervalIndexedGeometry( const geom::Geometry & g) :
+index{index::intervalrtree::SortedPackedIntervalRTree()}
-	index = new index::intervalrtree::SortedPackedIntervalRTree();
 	init( g);
-IndexedPointInAreaLocator::IntervalIndexedGeometry::~IntervalIndexedGeometry( )
-	delete index;
-	for ( size_t i = 0, ni = allocatedSegments.size(); i < ni; ++i )
-		delete allocatedSegments[i];
 void
 IndexedPointInAreaLocator::IntervalIndexedGeometry::init( const geom::Geometry & g)
 	geom::LineString::ConstVect lines;
 	geom::util::LinearComponentExtracter::getLines( g, lines);
-	for ( size_t i = 0, ni = lines.size(); i < ni; i++ )
-		const geom::LineString * line = lines[ i ];
-		geom::CoordinateSequence * pts = line->getCoordinates();
-		addLine( pts);
+	for (const geom::LineString* line : lines) {
+		addLine(line->getCoordinatesRO());
-		delete pts;
+	for (geom::LineSegment & seg : segments) {
+		index.insert(
+			std::min( seg.p0.y, seg.p1.y),
+			std::max( seg.p0.y, seg.p1.y),
+            &seg);
 void
-IndexedPointInAreaLocator::IntervalIndexedGeometry::addLine( geom::CoordinateSequence * pts)
+IndexedPointInAreaLocator::IntervalIndexedGeometry::addLine(const geom::CoordinateSequence * pts)
-	for ( size_t i = 1, ni = pts->size(); i < ni; i++ )
-		geom::LineSegment * seg = new geom::LineSegment( (*pts)[ i - 1 ], (*pts)[ i ]);
-		double const min = std::min( seg->p0.y, seg->p1.y);
-		double const max = std::max( seg->p0.y, seg->p1.y);
-		// NOTE: seg ownership still ours
-		allocatedSegments.push_back(seg);
-		index->insert( min, max, seg);
+	for (size_t i = 1, ni = pts->size(); i < ni; i++) {
+		segments.emplace_back((*pts)[i - 1], (*pts)[i]);
@@ -87,7 +72,7 @@ IndexedPointInAreaLocator::IntervalIndexedGeometry::addLine( geom::CoordinateSeq
 void
 IndexedPointInAreaLocator::buildIndex( const geom::Geometry & g)
-	index = new IndexedPointInAreaLocator::IntervalIndexedGeometry( g);
+	index = std::unique_ptr<IntervalIndexedGeometry>(new IntervalIndexedGeometry(g));
@@ -105,16 +90,9 @@ IndexedPointInAreaLocator::IndexedPointInAreaLocator( const geom::Geometry & g)
 		&&	typeid( areaGeom) != typeid( geom::MultiPolygon) )
 		throw util::IllegalArgumentException("Argument must be Polygonal");
-	//areaGeom = g;
 	buildIndex( areaGeom);
-IndexedPointInAreaLocator::~IndexedPointInAreaLocator()
-	delete index;
 int
 IndexedPointInAreaLocator::locate( const geom::Coordinate * /*const*/ p)
@@ -130,15 +108,15 @@ IndexedPointInAreaLocator::locate( const geom::Coordinate * /*const*/ p)
 void
 IndexedPointInAreaLocator::SegmentVisitor::visitItem( void * item)
-	geom::LineSegment * seg = (geom::LineSegment *)item;
+	geom::LineSegment* seg = static_cast<geom::LineSegment*>(item);
-	counter->countSegment( (*seg)[ 0 ], (*seg)[ 1 ]);
+	counter->countSegment(seg->p0, seg->p1);
 void
 IndexedPointInAreaLocator::IntervalIndexedGeometry::query( double min, double max, index::ItemVisitor * visitor)
-	index->query( min, max, visitor);
+	index.query( min, max, visitor);
Summary of changes:
 .../algorithm/locate/IndexedPointInAreaLocator.h   | 21 ++++-----
 src/algorithm/locate/IndexedPointInAreaLocator.cpp | 55 +++++++---------------
 2 files changed, 24 insertions(+), 52 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
