[geos-commits] [SCM] GEOS branch master updated. b578411ff0434fe0397fe4a0ecad727c5e41e825
Fri Sep 21 04:51:55 PDT 2018
the project "GEOS".
       via  b578411ff0434fe0397fe4a0ecad727c5e41e825 (commit)
       via  9ba8f5ee2516c39c1037442383182b846b15ed3b (commit)
       via  7a5f23ab15b45041271cc2c34852ea08689cfa3a (commit)
      from  93932020d371a2fc571dd9141328b751bf8f0272 (commit)
revisions in full, below.
commit b578411ff0434fe0397fe4a0ecad727c5e41e825
Merge: 9393202 9ba8f5e
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Sep 21 07:51:37 2018 -0400
    Merge branch 'sir-sigurd-empty-crash-isccw'
commit 9ba8f5ee2516c39c1037442383182b846b15ed3b
Merge: 9393202 7a5f23a
Date:   Fri Sep 21 07:51:19 2018 -0400
    Merge branch 'empty-crash-isccw' of https://github.com/sir-sigurd/libgeos into sir-sigurd-empty-crash-isccw
commit 7a5f23ab15b45041271cc2c34852ea08689cfa3a
Author: Sergey Fedoseev <fedoseev.sergey at gmail.com>
Date:   Fri Sep 21 01:34:07 2018 +0500
    Fix #927 -- Fixed crash in GEOSCoordSeq_isCCW() when used with empty coordseq.
diff --git a/src/algorithm/CGAlgorithms.cpp b/src/algorithm/CGAlgorithms.cpp
index f425a1b..8b62a77 100644
--- a/src/algorithm/CGAlgorithms.cpp
+++ b/src/algorithm/CGAlgorithms.cpp
@@ -99,15 +99,15 @@ CGAlgorithms::isOnLine(const Coordinate& p, const CoordinateSequence* pt)
 bool
 CGAlgorithms::isCCW(const CoordinateSequence* ring)
-	// # of points without closing endpoint
-	const std::size_t nPts=ring->getSize()-1;
 	// sanity check
-	if (nPts < 3)
+	if (ring->getSize() < 4)
 		throw util::IllegalArgumentException("Ring has fewer than 3 points, so orientation cannot be determined");
+	// # of points without closing endpoint
+	const std::size_t nPts=ring->getSize()-1;
 	// find highest point
 	const Coordinate *hiPt=&ring->getAt(0);
 	size_t hiIndex = 0;
diff --git a/tests/unit/capi/GEOSCoordSeqTest.cpp b/tests/unit/capi/GEOSCoordSeqTest.cpp
index 54af433..ff9324a 100644
--- a/tests/unit/capi/GEOSCoordSeqTest.cpp
+++ b/tests/unit/capi/GEOSCoordSeqTest.cpp
@@ -322,5 +322,15 @@ namespace tut
         ensure_equals(GEOSCoordSeq_isCCW(cs_, &ccw), 0);
+    template<>
+    template<>
+    void object::test<10>() {
+        // no orientation
+        cs_ = GEOSCoordSeq_create(0, 0);
+        char ccw;
+        ensure_equals(GEOSCoordSeq_isCCW(cs_, &ccw), 0);
 } // namespace tut
Summary of changes:
 src/algorithm/CGAlgorithms.cpp       |  8 ++++----
 tests/unit/capi/GEOSCoordSeqTest.cpp | 10 ++++++++++
 2 files changed, 14 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
