[geos-commits] [SCM] GEOS branch 3.7 updated. 3afc83d36f6d60da747b475d3223d8268f53e3f1
Fri Sep 21 04:58:08 PDT 2018
the project "GEOS".
The branch, 3.7 has been updated
       via  3afc83d36f6d60da747b475d3223d8268f53e3f1 (commit)
       via  3d7a9e859697d028b85f16de9a27d16b5ecabc4a (commit)
      from  f99c6c66ad69f3c3eb17f306e697169fab9607dd (commit)
revisions in full, below.
commit 3afc83d36f6d60da747b475d3223d8268f53e3f1
Merge: 3d7a9e8 f99c6c6
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Sep 21 07:57:36 2018 -0400
    Merge branch '3.7' of https://git.osgeo.org/gitea/geos/geos into 3.7
commit 3d7a9e859697d028b85f16de9a27d16b5ecabc4a
Author: Sergey Fedoseev <fedoseev.sergey at gmail.com>
Date:   Fri Sep 21 01:34:07 2018 +0500
    Fix #927 -- Fixed crash in GEOSCoordSeq_isCCW() when used with empty coordseq.
diff --git a/NEWS b/NEWS
index 54b7e53..f4519c7 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,11 @@
+Changes in 3.7.1
+2018-XX-XX
+- Bug fixes / improvements
+  - Fix crash in GEOSCoordSeq_isCCW with empty coordseq
+    (#927, Sergey Fedoseev)
 3.7.0 changes
 2018-09-10
 - New things:
diff --git a/src/algorithm/CGAlgorithms.cpp b/src/algorithm/CGAlgorithms.cpp
index 29154ac..1110141 100644
--- a/src/algorithm/CGAlgorithms.cpp
+++ b/src/algorithm/CGAlgorithms.cpp
@@ -99,15 +99,15 @@ CGAlgorithms::isOnLine(const Coordinate& p, const CoordinateSequence* pt)
 bool
 CGAlgorithms::isCCW(const CoordinateSequence* ring)
-	// # of points without closing endpoint
-	const std::size_t nPts=ring->getSize()-1;
 	// sanity check
-	if (nPts < 3)
+	if (ring->getSize() < 4)
 		throw util::IllegalArgumentException("Ring has fewer than 3 points, so orientation cannot be determined");
+	// # of points without closing endpoint
+	const std::size_t nPts=ring->getSize()-1;
 	// find highest point
 	const Coordinate *hiPt=&ring->getAt(0);
 	int hiIndex=0;
diff --git a/tests/unit/capi/GEOSCoordSeqTest.cpp b/tests/unit/capi/GEOSCoordSeqTest.cpp
index 54af433..ff9324a 100644
--- a/tests/unit/capi/GEOSCoordSeqTest.cpp
+++ b/tests/unit/capi/GEOSCoordSeqTest.cpp
@@ -322,5 +322,15 @@ namespace tut
         ensure_equals(GEOSCoordSeq_isCCW(cs_, &ccw), 0);
+    template<>
+    template<>
+    void object::test<10>() {
+        // no orientation
+        cs_ = GEOSCoordSeq_create(0, 0);
+        char ccw;
+        ensure_equals(GEOSCoordSeq_isCCW(cs_, &ccw), 0);
 } // namespace tut
Summary of changes:
 NEWS                                 |  8 ++++++++
 src/algorithm/CGAlgorithms.cpp       |  8 ++++----
 tests/unit/capi/GEOSCoordSeqTest.cpp | 10 ++++++++++
 3 files changed, 22 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
