[geos-commits] [SCM] GEOS branch master updated. 52c516f3682c9ae4effc957aebc89176eacfac49
Sun Sep 23 18:23:25 PDT 2018
the project "GEOS".
       via  52c516f3682c9ae4effc957aebc89176eacfac49 (commit)
       via  3b745fdb83d8293d998a7b958bbf1adf99ecc0ae (commit)
       via  18505af1103cdafb2178f2f0eb8e1a10cfa16d2d (commit)
      from  b578411ff0434fe0397fe4a0ecad727c5e41e825 (commit)
revisions in full, below.
commit 52c516f3682c9ae4effc957aebc89176eacfac49
Merge: b578411 3b745fd
Author: Daniel Baston <dbaston at gmail.com>
Date:   Sun Sep 23 21:22:57 2018 -0400
    Merge branch 'sir-sigurd-empty-crash-interpolate'
commit 3b745fdb83d8293d998a7b958bbf1adf99ecc0ae
Merge: b578411 18505af
Date:   Sun Sep 23 21:22:31 2018 -0400
    Merge branch 'empty-crash-interpolate' of https://github.com/sir-sigurd/libgeos into sir-sigurd-empty-crash-interpolate
commit 18505af1103cdafb2178f2f0eb8e1a10cfa16d2d
Author: Sergey Fedoseev <fedoseev.sergey at gmail.com>
Date:   Fri Sep 21 01:34:07 2018 +0500
    Fix #926: Fixed crash in GEOSInterpolate() when used with empty LineString.
diff --git a/src/linearref/LinearLocation.cpp b/src/linearref/LinearLocation.cpp
index b413b76..3c1c452 100644
--- a/src/linearref/LinearLocation.cpp
+++ b/src/linearref/LinearLocation.cpp
@@ -194,6 +194,9 @@ LinearLocation::getCoordinate(const Geometry* linearGeom) const
 	if ( ! lineComp ) {
 		throw util::IllegalArgumentException("LinearLocation::getCoordinate only works with LineString geometries");
+	if (linearGeom->isEmpty()) {
+		return Coordinate::getNull();
 	Coordinate p0 = lineComp->getCoordinateN(segmentIndex);
 	if (segmentIndex >= lineComp->getNumPoints() - 1)
 		return p0;
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 8f02cc4..3c84675 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -168,7 +168,8 @@ geos_unit_SOURCES = \
 	capi/GEOSReverseTest.cpp \
 	capi/GEOSUnaryUnionTest.cpp \
 	capi/GEOSisValidDetailTest.cpp \
-	capi/GEOSisClosedTest.cpp
+	capi/GEOSisClosedTest.cpp \
+	capi/GEOSInterpolateTest.cpp
 noinst_HEADERS = \
 	utility.h
diff --git a/tests/unit/capi/GEOSInterpolateTest.cpp b/tests/unit/capi/GEOSInterpolateTest.cpp
new file mode 100644
index 0000000..b5cacc2
--- /dev/null
+++ b/tests/unit/capi/GEOSInterpolateTest.cpp
@@ -0,0 +1,68 @@
+// Test Suite for C-API LineString interpolate functions
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cmath>
+namespace tut
+    // Test Group
+    // Common data used in test cases.
+    struct test_capiinterpolate_data
+        GEOSGeometry* geom1_;
+        static void notice(const char *fmt, ...)
+            std::fprintf( stdout, "NOTICE: ");
+            va_list ap;
+            va_start(ap, fmt);
+            std::vfprintf(stdout, fmt, ap);
+            va_end(ap);
+            std::fprintf(stdout, "\n");
+        test_capiinterpolate_data()
+            : geom1_(nullptr)
+            initGEOS(notice, notice);
+        ~test_capiinterpolate_data()
+            GEOSGeom_destroy(geom1_);
+            geom1_ = nullptr;
+            finishGEOS();
+    typedef test_group<test_capiinterpolate_data> group;
+    typedef group::object object;
+    group test_capiinterpolate_group("capi::GEOSInterpolate");
+    // Test Cases
+    template<>
+    template<>
+    void object::test<1>()
+        geom1_ = GEOSGeomFromWKT("LINESTRING EMPTY");
+        GEOSGeometry *geom2 = GEOSInterpolate(geom1_, 1);
+        ensure_equals(GEOSisEmpty(geom2), 1);
+        GEOSGeom_destroy(geom2);
+} // namespace tut
diff --git a/tests/unit/linearref/LengthIndexedLineTest.cpp b/tests/unit/linearref/LengthIndexedLineTest.cpp
index b9aebb6..23c5e3a 100644
--- a/tests/unit/linearref/LengthIndexedLineTest.cpp
+++ b/tests/unit/linearref/LengthIndexedLineTest.cpp
@@ -470,5 +470,15 @@ void object::test<28>()
 #endif
+template<>
+template<>
+void object::test<29>()
+    GeomPtr linearGeom(reader.read("LINESTRING EMPTY"));
+    LengthIndexedLine indexedLine(linearGeom.get());
+    Coordinate pt = indexedLine.extractPoint(100);
+    ensure(pt.isNull());
 } // namespace tut
Summary of changes:
 src/linearref/LinearLocation.cpp                   |  3 ++
 tests/unit/Makefile.am                             |  3 +-
 ...EOSSimplifyTest.cpp => GEOSInterpolateTest.cpp} | 34 ++++++++--------------
 tests/unit/linearref/LengthIndexedLineTest.cpp     | 10 +++++++
 4 files changed, 27 insertions(+), 23 deletions(-)
 copy tests/unit/capi/{GEOSSimplifyTest.cpp => GEOSInterpolateTest.cpp} (56%)
hooks/post-receive
More information about the geos-commits mailing list
