[geos-commits] [SCM] GEOS branch master updated. 21ea8486666968ec8c723c582e60d96639caa310
Mon Apr 8 13:43:28 PDT 2019
the project "GEOS".
       via  21ea8486666968ec8c723c582e60d96639caa310 (commit)
      from  43959918201670cd1e72913cf4cffb07b4666708 (commit)
revisions in full, below.
commit 21ea8486666968ec8c723c582e60d96639caa310
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 8 13:43:00 2019 -0700
    Add envelope check to SimplePointInAreaLocator
    Port JTS commit 74a9b9d52440f024cd56f90c8c39fea4709cbee2
    https://github.com/locationtech/jts/pull/355
diff --git a/include/geos/algorithm/locate/SimplePointInAreaLocator.h b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
index 2b51986..5a52a06 100644
--- a/include/geos/algorithm/locate/SimplePointInAreaLocator.h
+++ b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
@@ -33,16 +33,22 @@ namespace locate { // geos::algorithm::locate
 /** \brief
  * Computes the location of points
- * relative to an areal {@link Geometry},
- * using a simple O(n) algorithm.
+ * relative to a {@link Polygonal} {@link Geometry},
+ * using a simple <tt>O(n)</tt> algorithm.
- * This algorithm is suitable for use in cases where
- * only one or a few points will be tested against a given area.
+ * The algorithm used reports
+ * if a point lies in the interior, exterior,
+ * or exactly on the boundary of the Geometry.
- * The algorithm used is only guaranteed to return correct results
- * for points which are <b>not</b> on the boundary of the Geometry.
+ * Instance methods are provided to implement
+ * the interface {@link PointInAreaLocator}.
+ * However, they provide no performance
+ * advantage over the class methods.
- * @version 1.7
+ * This algorithm is suitable for use in cases where
+ * only a few points will be tested.
+ * If many points will be tested,
+ * {@link IndexedPointInAreaLocator} may provide better performance.
 class SimplePointInAreaLocator : public PointOnGeometryLocator {
@@ -53,6 +59,12 @@ public:
     * Determines the {@link Location} of a point in a {@link Polygon}.
+    * The return value is one of:
+    * - {@link Location.INTERIOR} if the point is in the geometry interior
+    * - {@link Location.BOUNDARY} if the point lies exactly on the boundary
+    * - {@link Location.EXTERIOR} if the point is outside the geometry
     * Computes {@link Location::BOUNDARY} if the point lies exactly
     * on the polygon boundary.
@@ -62,6 +74,19 @@ public:
     static int locatePointInPolygon(const geom::Coordinate& p,
                                     const geom::Polygon* poly);
+    * Determines whether a point is contained in a {@link Geometry},
+    * or lies on its boundary.
+    * This is a convenience method for
+    *  Location.EXTERIOR != locate(p, geom)
+    * @param p the point to test
+    * @param geom the geometry to test
+    * @return true if the point lies in or on the geometry
+    static bool isContained(const geom::Coordinate& p,
+                            const geom::Geometry* geom);
     SimplePointInAreaLocator(const geom::Geometry* p_g)
         :	g(p_g)
diff --git a/src/algorithm/locate/SimplePointInAreaLocator.cpp b/src/algorithm/locate/SimplePointInAreaLocator.cpp
index 8f9a971..b08ebc1 100644
--- a/src/algorithm/locate/SimplePointInAreaLocator.cpp
+++ b/src/algorithm/locate/SimplePointInAreaLocator.cpp
@@ -44,9 +44,21 @@ SimplePointInAreaLocator::locate(const Coordinate& p, const Geometry* geom)
         return Location::EXTERIOR;
+     * Do a fast check against the geometry envelope first
+    if (! geom->getEnvelopeInternal()->intersects(p))
+        return Location::EXTERIOR;
     return locateInGeometry(p, geom);
+bool
+SimplePointInAreaLocator::isContained(const Coordinate& p, const Geometry* geom)
+    return Location::EXTERIOR != locate(p, geom);
 int
 SimplePointInAreaLocator::locateInGeometry(const Coordinate& p, const Geometry* geom)
Summary of changes:
 .../algorithm/locate/SimplePointInAreaLocator.h    | 39 ++++++++++++++++++----
 src/algorithm/locate/SimplePointInAreaLocator.cpp  | 12 +++++++
 2 files changed, 44 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
