[geos-commits] [SCM] GEOS branch master updated. 8124f173f33c7c14a97ae9fa9a2a2767aa2d38d6
Mon Apr 8 14:10:03 PDT 2019
the project "GEOS".
       via  8124f173f33c7c14a97ae9fa9a2a2767aa2d38d6 (commit)
      from  21ea8486666968ec8c723c582e60d96639caa310 (commit)
revisions in full, below.
commit 8124f173f33c7c14a97ae9fa9a2a2767aa2d38d6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 8 14:09:39 2019 -0700
    Harmonize with JTS empty handling
    JTS d810c3a1385d6c4213cada4a474f3d1f6cc08b47
    https://github.com/locationtech/jts/pull/360
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index 7e3f1cc..a91e90e 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -433,58 +433,38 @@ IsValidOp::checkHolesInShell(const Polygon* p, GeometryGraph* graph)
     const LinearRing* shell = static_cast<const LinearRing*>(
                                   p->getExteriorRing());
     const Geometry* shellgeom = static_cast<const Geometry*>(shell);
-    auto nholes = p->getNumInteriorRing();
-    if(shell->isEmpty()) {
-        for(size_t i = 0; i < nholes; ++i) {
-            assert(dynamic_cast<const LinearRing*>(
-                       p->getInteriorRingN(i)));
-            const LinearRing* hole = static_cast<const LinearRing*>(
-                                         p->getInteriorRingN(i));
-            if(!hole->isEmpty()) {
-                validErr = new TopologyValidationError(
-                    TopologyValidationError::eHoleOutsideShell);
-                return;
-        // all interiors also empty or none exist
-        return;
+    bool isShellEmpty = shell->isEmpty();
     locate::IndexedPointInAreaLocator ipial(*shellgeom);
+    auto nholes = p->getNumInteriorRing();
-        const Coordinate* holePt = findPtNotNode(
-                                       hole->getCoordinatesRO(), shell, graph);
+        if (hole->isEmpty()) continue;
+        const Coordinate* holePt = findPtNotNode(hole->getCoordinatesRO(), shell, graph);
-         * If no non-node hole vertex can be found, the hole must
-         * split the polygon into disconnected interiors.
-         * This will be caught by a subsequent check.
-        if(holePt == nullptr) {
-            return;
-        bool outside = (geom::Location::EXTERIOR == ipial.locate(holePt));
-        if(outside) {
+        * If no non-node hole vertex can be found, the hole must
+        * split the polygon into disconnected interiors.
+        * This will be caught by a subsequent check.
+        if (holePt == nullptr) return;
+        bool outside = isShellEmpty || (Location::EXTERIOR == ipial.locate(holePt));
+        if (outside) {
-                TopologyValidationError::eHoleOutsideShell,
-                *holePt);
+                TopologyValidationError::eHoleOutsideShell);
             return;
 /*private*/
@@ -497,7 +477,7 @@ IsValidOp::checkHolesNotNested(const Polygon* p, GeometryGraph* graph)
     IndexedNestedRingTester nestedTester(graph);
+    for (size_t i = 0; i < nholes; ++i) {
@@ -505,7 +485,7 @@ IsValidOp::checkHolesNotNested(const Polygon* p, GeometryGraph* graph)
         //empty holes always pass
-        if(innerHole->isEmpty()) {
+        if (innerHole->isEmpty()) {
             continue;
@@ -513,7 +493,7 @@ IsValidOp::checkHolesNotNested(const Polygon* p, GeometryGraph* graph)
     bool isNonNested = nestedTester.isNonNested();
-    if(!isNonNested) {
+    if (!isNonNested) {
             TopologyValidationError::eNestedHoles,
             *(nestedTester.getNestedPoint()));
@@ -524,31 +504,30 @@ IsValidOp::checkHolesNotNested(const Polygon* p, GeometryGraph* graph)
 void
 IsValidOp::checkShellsNotNested(const MultiPolygon* mp, GeometryGraph* graph)
-    for(size_t i = 0, ngeoms = mp->getNumGeometries(); i < ngeoms; ++i) {
+    for (size_t i = 0, ngeoms = mp->getNumGeometries(); i < ngeoms; ++i) {
         const Polygon* p = dynamic_cast<const Polygon*>(
                                mp->getGeometryN(i));
-        assert(p);
         const LinearRing* shell = dynamic_cast<const LinearRing*>(
-        assert(shell);
-        for(size_t j = 0; j < ngeoms; ++j) {
-            if(i == j) {
+        if (shell->isEmpty()) return;
+        for (size_t j = 0; j < ngeoms; ++j) {
+            if (i == j) {
                 continue;
             const Polygon* p2 = dynamic_cast<const Polygon*>(
                                     mp->getGeometryN(j));
-            assert(p2);
-            if(shell->isEmpty() || p2->isEmpty()) {
+            if (p2->isEmpty()) {
                 continue;
             checkShellNotNested(shell, p2, graph);
-            if(validErr != nullptr) {
+            if (validErr != nullptr) {
                 return;
Summary of changes:
 src/operation/valid/IsValidOp.cpp | 69 ++++++++++++++-------------------------
 1 file changed, 24 insertions(+), 45 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
