[geos-commits] [SCM] GEOS branch master updated. 4c70abae2c76eacd6d30d0c503066556a5067b42
Fri Aug 16 13:07:18 PDT 2019
the project "GEOS".
       via  4c70abae2c76eacd6d30d0c503066556a5067b42 (commit)
      from  3133734b73aec52c70643c41fc43f19cfb5f680f (commit)
revisions in full, below.
commit 4c70abae2c76eacd6d30d0c503066556a5067b42
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Aug 16 13:06:57 2019 -0700
    Port https://github.com/locationtech/jts/pull/441
diff --git a/src/noding/snapround/MCIndexPointSnapper.cpp b/src/noding/snapround/MCIndexPointSnapper.cpp
index b798eaa..c6be26b 100644
--- a/src/noding/snapround/MCIndexPointSnapper.cpp
+++ b/src/noding/snapround/MCIndexPointSnapper.cpp
@@ -51,28 +51,39 @@ public:
         isNodeAddedVar(false)
+    * Reports whether the HotPixel caused a node to be added in any target
+    * segmentString (including its own). If so, the HotPixel must be added as a
+    * node as well.
+    * @return true if a node was added in any target segmentString.
     bool
     isNodeAdded() const
         return isNodeAddedVar;
+    * Check if a segment of the monotone chain intersects
+    * the hot pixel vertex and introduce a snap node if so.
+    * Optimized to avoid noding segments which
+    * contain the vertex (which otherwise
+    * would cause every vertex to be noded).
     void
     select(chain::MonotoneChain& mc, size_t startIndex) override
         // This is casting away 'constness'!
         NodedSegmentString& ss = *(static_cast<NodedSegmentString*>(mc.getContext()));
-        // don't snap a vertex to itself
-        if(parentEdge) {
-            if(&ss == parentEdge && startIndex == vertexIndex) {
+        if (parentEdge == &ss) {
+            // exit if hotpixel is equal to endpoint of target segment
+            if (startIndex == vertexIndex || startIndex + 1 == vertexIndex)
                 return;
-        //isNodeAddedVar = SimpleSnapRounder::addSnappedNode(hotPixel, ss, startIndex);
-        isNodeAddedVar = hotPixel.addSnappedNode(ss, startIndex);
+        // snap and record if a node was created
+        isNodeAddedVar |= hotPixel.addSnappedNode(ss, startIndex);
     void
Summary of changes:
 src/noding/snapround/MCIndexPointSnapper.cpp | 27 +++++++++++++++++++--------
 1 file changed, 19 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
