[geos-commits] [SCM] GEOS branch master updated. 4b2f28c250cbb734605e13de3b3ceba289a438c9
Tue Aug 20 15:52:39 PDT 2019
the project "GEOS".
       via  4b2f28c250cbb734605e13de3b3ceba289a438c9 (commit)
      from  4c70abae2c76eacd6d30d0c503066556a5067b42 (commit)
revisions in full, below.
commit 4b2f28c250cbb734605e13de3b3ceba289a438c9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Aug 20 15:52:11 2019 -0700
    Port JTS PR 462
    https://github.com/locationtech/jts/pull/462/
diff --git a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
index f66b9a4..10541a1 100644
--- a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
+++ b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
@@ -54,6 +54,7 @@ private:
     class IntervalIndexedGeometry {
     private:
         index::intervalrtree::SortedPackedIntervalRTree index;
+        bool isEmpty;
         void init(const geom::Geometry& g);
         void addLine(const geom::CoordinateSequence* pts);
diff --git a/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h b/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
index 2aab524..e12442a 100644
--- a/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
+++ b/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
@@ -52,6 +52,13 @@ class SortedPackedIntervalRTree {
 private:
     std::vector<IntervalRTreeLeafNode> leaves;
     std::vector<IntervalRTreeBranchNode> branches;
+    * If root is null that indicates
+    * that the tree has not yet been built,
+    * OR nothing has been added to the tree.
+    * In both cases, the tree is still open for insertions.
     const IntervalRTreeNode* root = nullptr;
     int level = 0;
diff --git a/src/algorithm/locate/IndexedPointInAreaLocator.cpp b/src/algorithm/locate/IndexedPointInAreaLocator.cpp
index 410fa36..181ecf5 100644
--- a/src/algorithm/locate/IndexedPointInAreaLocator.cpp
+++ b/src/algorithm/locate/IndexedPointInAreaLocator.cpp
@@ -38,8 +38,12 @@ namespace locate {
 // private:
 IndexedPointInAreaLocator::IntervalIndexedGeometry::IntervalIndexedGeometry(const geom::Geometry& g)
+    : isEmpty(0)
-    init(g);
+    if (g.isEmpty())
+        isEmpty = true;
+    else
+        init(g);
 void
@@ -119,6 +123,8 @@ IndexedPointInAreaLocator::SegmentVisitor::visitItem(void* item)
 void
 IndexedPointInAreaLocator::IntervalIndexedGeometry::query(double min, double max, index::ItemVisitor* visitor)
+    if (isEmpty)
+        return;
     index.query(min, max, visitor);
diff --git a/src/index/intervalrtree/SortedPackedIntervalRTree.cpp b/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
index b2b8b86..a01ab37 100644
--- a/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
+++ b/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
@@ -34,9 +34,15 @@ namespace intervalrtree {
 void
 SortedPackedIntervalRTree::init()
-    if(root != nullptr) {
+    // Already built
+    if(root != nullptr)
         return;
+    * if leaves is empty then nothing has been inserted.
+    * In this case it is safe to leave the tree in an open state
+    if (leaves.size() == 0) return;
     root = buildTree();
@@ -112,6 +118,10 @@ SortedPackedIntervalRTree::query(double min, double max, index::ItemVisitor* vis
     init();
+    // if root is null tree must be empty
+    if (root == nullptr)
+      return;
     root->query(min, max, visitor);
Summary of changes:
 include/geos/algorithm/locate/IndexedPointInAreaLocator.h  |  1 +
 .../geos/index/intervalrtree/SortedPackedIntervalRTree.h   |  7 +++++++
 src/algorithm/locate/IndexedPointInAreaLocator.cpp         |  8 +++++++-
 src/index/intervalrtree/SortedPackedIntervalRTree.cpp      | 14 ++++++++++++--
 4 files changed, 27 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
