[geos-commits] [SCM] GEOS branch 3.7 updated. 6f305213fd544d21a09d5c802d8ac82cef576687
git at osgeo.org
git at osgeo.org
Wed Aug 21 13:02:02 PDT 2019
the project "GEOS".
The branch, 3.7 has been updated
via 6f305213fd544d21a09d5c802d8ac82cef576687 (commit)
from e1399c268db52c43b1c55df582e12c6c93cd44b2 (commit)
revisions in full, below.
commit 6f305213fd544d21a09d5c802d8ac82cef576687
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Aug 21 13:01:28 2019 -0700
Port fix to regression in union algorithm from master
diff --git a/NEWS b/NEWS
index 59788c3..97cbdd9 100644
--- a/NEWS
+++ b/NEWS
@@ -2,7 +2,7 @@ Changes in 3.7.3dev
2019-XX-XX
- Bug fixes / improvements
+ - Union performance regression (#867 Paul Ramsey)
Changes in 3.7.2
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 56b43c4..23a1aaf 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -260,7 +260,7 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
check_valid(*g1Int, "unionUsingEnvelopeIntersection g1Int");
#endif
- std::unique_ptr<geom::Geometry> u(unionActual(g0Int.get(), g1Int.get()));
+ std::unique_ptr<geom::Geometry> unionCommon(unionActual(g0Int.get(), g1Int.get()));
#if GEOS_DEBUG_CASCADED_UNION
if ( ! check_valid(*u, "unionUsingEnvelopeIntersection unionActual return") )
@@ -278,7 +278,7 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
#endif
- if ( disjointPolys.empty() ) return u.release();
+ if ( disjointPolys.empty() ) return unionCommon.release();
for ( size_t i=0; i<disjointPolys.size(); ++i )
@@ -288,28 +288,36 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
#endif
- // TODO: find, in disjointPolys, those which now have their
- // environment intersect the environment of the union "u"
- // and collect them in another vector to be unioned
+ geom::Envelope const* unionCommonEnv = unionCommon->getEnvelopeInternal(); // TODO: check for EMPTY ?
std::vector<geom::Geometry*> polysOn;
std::vector<geom::Geometry*> polysOff;
- geom::Envelope const* uEnv = u->getEnvelopeInternal(); // TODO: check for EMPTY ?
- extractByEnvelope(*uEnv, disjointPolys, polysOn, polysOff);
+ extractByEnvelope(*unionCommonEnv, disjointPolys, polysOn, polysOff);
std::cerr << "unionUsingEnvelopeIntersection: " << polysOn.size() << "/" << disjointPolys.size() << " polys intersect union of final thing" << std::endl;
#endif
+ // If the union of the interacting geometries
+ // is contained in the envelope of the inputs
+ // (and this is highly likely unless overlay robustness failure occurs)
+ // it is safe to combine with the disjoint polygons
+ geom::Envelope beforeUnionEnv( *(g0Int->getEnvelopeInternal()) );
+ beforeUnionEnv.expandToInclude( g1Int->getEnvelopeInternal() );
+ bool isUnionSafe = beforeUnionEnv.contains(unionCommonEnv);
+ //if (! isUnionSafe) std::cerr << "Found unsafe union" << std::endl;
std::unique_ptr<geom::Geometry> ret;
- if ( polysOn.empty() ) {
- disjointPolys.push_back(u.get());
+ if(polysOn.empty() || isUnionSafe) {
+ disjointPolys.push_back(unionCommon.get());
ret.reset( geom::util::GeometryCombiner::combine(disjointPolys));
} else {
+ // The union envelope changed (e.g. due to snapping heuristics)
+ // so to be safe must union everything (which is slow, but infrequent)
// TODO: could be further tweaked to only union with polysOn
// and combine with polysOff, but then it'll need again to
// recurse in the check for disjoint/intersecting
- ret.reset( geom::util::GeometryCombiner::combine(disjointPolys) );
- ret.reset( unionActual(ret.get(), u.get()) );
+ std::unique_ptr<geom::Geometry> disjointCombined( geom::util::GeometryCombiner::combine(disjointPolys) );
+ ret.reset( unionActual( disjointCombined.get(), unionCommon.get() ) );
Summary of changes:
NEWS | 2 +-
src/operation/union/CascadedPolygonUnion.cpp | 30 ++++++++++++++++++----------
2 files changed, 20 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits
