[geos-commits] [SCM] GEOS branch master updated. 2e3ef091c0c5f6e157e60af3e7f6d762aab83b6c
git at osgeo.org
git at osgeo.org
Mon Dec 2 17:32:11 PST 2019
the project "GEOS".
via 2e3ef091c0c5f6e157e60af3e7f6d762aab83b6c (commit)
via b5cc0ccee7f8c671765062675655b9ba77455ceb (commit)
via 3326a5c3ee3cb114b9d50ba250437963e90d8053 (commit)
via 736e38ba78535df389b344a636feb1b40b4d45ee (commit)
via 1a2c5d6e5bda9781fa57ec63f6b5cf8ba340b45a (commit)
from cc774dbbd130abf278b94f6887b046b82e23b8c1 (commit)
revisions in full, below.
commit 2e3ef091c0c5f6e157e60af3e7f6d762aab83b6c
Merge: cc774db b5cc0cc
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Dec 2 20:31:25 2019 -0500
Merge remote-tracking branch 'nilason/docs-minor-stylistic-fixes'
commit b5cc0ccee7f8c671765062675655b9ba77455ceb
Author: nila <n_larsson at yahoo.com>
Date: Tue Sep 24 16:27:27 2019 +0200
Make correct comment block indentation
diff --git a/include/geos/algorithm/Distance.h b/include/geos/algorithm/Distance.h
index 8f0523d..a46f95b 100644
--- a/include/geos/algorithm/Distance.h
+++ b/include/geos/algorithm/Distance.h
@@ -36,19 +36,19 @@ class GEOS_DLL Distance {
public:
- * Computes the distance from a line segment AB to a line segment CD
- * Note: NON-ROBUST!
- * @param A
- * a point of one line
- * @param B
- * the second point of (must be different to A)
- * @param C
- * one point of the line
- * @param D
- * another point of the line (must be different to A)
+ * Computes the distance from a line segment AB to a line segment CD
+ * Note: NON-ROBUST!
+ * @param A
+ * a point of one line
+ * @param B
+ * the second point of (must be different to A)
+ * @param C
+ * one point of the line
+ * @param D
+ * another point of the line (must be different to A)
// formerly distanceLineLine
static double segmentToSegment(const geom::Coordinate& A,
const geom::Coordinate& B,
diff --git a/include/geos/algorithm/Intersection.h b/include/geos/algorithm/Intersection.h
index 2cfd4ff..58ed717 100644
--- a/include/geos/algorithm/Intersection.h
+++ b/include/geos/algorithm/Intersection.h
@@ -23,27 +23,26 @@ namespace geos {
namespace algorithm { // geos::algorithm
/** \brief
-* Computes the intersection point of two lines.
-* If the lines are parallel or collinear this case is detected
-* and <code>null</code> is returned.
-* <p>
-* In general it is not possible to accurately compute
-* the intersection point of two lines, due to
-* numerical roundoff.
-* This is particularly true when the input lines are nearly parallel.
-* This routine uses numerical conditioning on the input values
-* to ensure that the computed value should be very close to the correct value.
-* @param p1 an endpoint of line 1
-* @param p2 an endpoint of line 1
-* @param q1 an endpoint of line 2
-* @param q2 an endpoint of line 2
-* @return the intersection point between the lines, if there is one,
-* or null if the lines are parallel or collinear
-* @see CGAlgorithmsDD#intersection(Coordinate, Coordinate, Coordinate, Coordinate)
+ * Computes the intersection point of two lines.
+ * If the lines are parallel or collinear this case is detected
+ * and <code>null</code> is returned.
+ * <p>
+ * In general it is not possible to accurately compute
+ * the intersection point of two lines, due to
+ * numerical roundoff.
+ * This is particularly true when the input lines are nearly parallel.
+ * This routine uses numerical conditioning on the input values
+ * to ensure that the computed value should be very close to the correct value.
+ * @param p1 an endpoint of line 1
+ * @param p2 an endpoint of line 1
+ * @param q1 an endpoint of line 2
+ * @param q2 an endpoint of line 2
+ * @return the intersection point between the lines, if there is one,
+ * or null if the lines are parallel or collinear
+ * @see CGAlgorithmsDD#intersection(Coordinate, Coordinate, Coordinate, Coordinate)
class GEOS_DLL Intersection {
public:
diff --git a/include/geos/algorithm/Length.h b/include/geos/algorithm/Length.h
index 0ec6f8f..56696f3 100644
--- a/include/geos/algorithm/Length.h
+++ b/include/geos/algorithm/Length.h
@@ -27,20 +27,19 @@ namespace geos {
/** \brief
-* Functions for computing length.
-* @author Martin Davis
+ * Functions for computing length.
+ * @author Martin Davis
class GEOS_DLL Length {
public:
- * Computes the length of a linestring specified by a sequence of points.
- * @param ring the points specifying the linestring
- * @return the length of the linestring
+ * Computes the length of a linestring specified by a sequence of points.
+ * @param ring the points specifying the linestring
+ * @return the length of the linestring
static double ofLine(const geom::CoordinateSequence* ring);
diff --git a/include/geos/algorithm/Orientation.h b/include/geos/algorithm/Orientation.h
index bad90c7..168b0e4 100644
--- a/include/geos/algorithm/Orientation.h
+++ b/include/geos/algorithm/Orientation.h
@@ -64,7 +64,7 @@ public:
* by the three points
* ( `Orientation::COUNTERCLOCKWISE`,
* `Orientation::CLOCKWISE`, or `Orientation::STRAIGHT` )
static int index(const geom::Coordinate& p1, const geom::Coordinate& p2,
const geom::Coordinate& q);
@@ -83,7 +83,7 @@ public:
* @return `true` if the ring is oriented counter-clockwise.
* @throws IllegalArgumentException
* if there are too few points to determine orientation (< 4)
static bool isCCW(const geom::CoordinateSequence* ring);
diff --git a/include/geos/algorithm/PointLocation.h b/include/geos/algorithm/PointLocation.h
index 01647f3..65b5d9a 100644
--- a/include/geos/algorithm/PointLocation.h
+++ b/include/geos/algorithm/PointLocation.h
@@ -45,7 +45,7 @@ public:
* @param line the line coordinates
* @return true if the point is a vertex of the line or lies in the interior
* of a line segment in the line
static bool isOnLine(const geom::Coordinate& p, const geom::CoordinateSequence* line);
/** \brief
@@ -68,17 +68,17 @@ public:
static bool isInRing(const geom::Coordinate& p, const geom::CoordinateSequence* ring);
/** \brief
- * Determines whether a point lies in the interior, on the boundary, or in the
- * exterior of a ring. The ring may be oriented in either direction.
- * This method does *not* first check the point against the envelope of
- * the ring.
- * @param p point to check for ring inclusion
- * @param ring an array of coordinates representing the ring (which must have
- * first point identical to last point)
+ * Determines whether a point lies in the interior, on the boundary, or in the
+ * exterior of a ring. The ring may be oriented in either direction.
+ * This method does *not* first check the point against the envelope of
+ * the ring.
+ * @param p point to check for ring inclusion
+ * @param ring an array of coordinates representing the ring (which must have
+ * first point identical to last point)
* @return the [Location](@ref geom::Location) of p relative to the ring
static geom::Location locateInRing(const geom::Coordinate& p, const std::vector<const geom::Coordinate*>& ring);
static geom::Location locateInRing(const geom::Coordinate& p, const geom::CoordinateSequence& ring);
diff --git a/include/geos/geom/prep/PreparedPolygonContains.h b/include/geos/geom/prep/PreparedPolygonContains.h
index 6b1be77..f6e25b5 100644
--- a/include/geos/geom/prep/PreparedPolygonContains.h
+++ b/include/geos/geom/prep/PreparedPolygonContains.h
@@ -90,12 +90,12 @@ public:
protected:
- * Computes the full topological <tt>contains</tt> predicate.
- * Used when short-circuit tests are not conclusive.
- * @param geom the test geometry
- * @return true if this prepared polygon contains the test geometry
+ * Computes the full topological <tt>contains</tt> predicate.
+ * Used when short-circuit tests are not conclusive.
+ * @param geom the test geometry
+ * @return true if this prepared polygon contains the test geometry
bool fullTopologicalPredicate(const geom::Geometry* geom) override;
diff --git a/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h b/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
index bea7270..da2c6ab 100644
--- a/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
+++ b/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
@@ -30,14 +30,12 @@ namespace quadedge { //geos.triangulate.quadedge
class QuadEdgeSubdivision;
/** \brief
-* Locates {@link QuadEdge}s in a {@link QuadEdgeSubdivision},
-* optimizing the search by starting in the
-* locality of the last edge found.
-* @author JTS: Martin Davis
-* @author Benjamin Campbell
+ * Locates {@link QuadEdge}s in a {@link QuadEdgeSubdivision}, optimizing the
+ * search by starting in the locality of the last edge found.
+ * @author JTS: Martin Davis
+ * @author Benjamin Campbell
class LastFoundQuadEdgeLocator : public QuadEdgeLocator {
private:
QuadEdgeSubdivision* subdiv;
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index e1b4e7b..c931fbd 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -182,10 +182,10 @@ MinimumBoundingCircle::computeCirclePoints()
return;
- * The problem is simplified by reducing to the convex hull.
- * Computing the convex hull also has the useful effect of eliminating duplicate points
+ * The problem is simplified by reducing to the convex hull.
+ * Computing the convex hull also has the useful effect of eliminating duplicate points
std::unique_ptr<Geometry> convexHull(input->convexHull());
std::unique_ptr<CoordinateSequence> cs(convexHull->getCoordinates());
@@ -197,9 +197,9 @@ MinimumBoundingCircle::computeCirclePoints()
pts.pop_back();
- * Optimization for the trivial case where the CH has fewer than 3 points
+ * Optimization for the trivial case where the CH has fewer than 3 points
if(pts.size() <= 2) {
extremalPts = pts;
return;
@@ -211,13 +211,13 @@ MinimumBoundingCircle::computeCirclePoints()
// find a point Q such that the angle that PQ makes with the x-axis is minimal
Coordinate Q = pointWitMinAngleWithX(pts, P);
- * Iterate over the remaining points to find
- * a pair or triplet of points which determine the minimal circle.
- * By the design of the algorithm,
- * at most <tt>pts.length</tt> iterations are required to terminate
- * with a correct result.
+ * Iterate over the remaining points to find
+ * a pair or triplet of points which determine the minimal circle.
+ * By the design of the algorithm,
+ * at most <tt>pts.length</tt> iterations are required to terminate
+ * with a correct result.
size_t i = 0, n = pts.size();
while(i++ < n) {
Coordinate R = pointWithMinAngleWithSegment(pts, P, Q);
diff --git a/src/geom/util/PointExtracter.cpp b/src/geom/util/PointExtracter.cpp
index 5dc74b9..79f6154 100644
--- a/src/geom/util/PointExtracter.cpp
+++ b/src/geom/util/PointExtracter.cpp
@@ -33,9 +33,9 @@ PointExtracter::getPoints(const Geometry& geom, Point::ConstVect& ret)
-* Constructs a PointExtracterFilter with a list in which
-* to store Points found.
+ * Constructs a PointExtracterFilter with a list in which
+ * to store Points found.
PointExtracter::PointExtracter(Point::ConstVect& newComps)
comps(newComps)
diff --git a/src/geomgraph/Position.cpp b/src/geomgraph/Position.cpp
index 275f3c4..7072170 100644
--- a/src/geomgraph/Position.cpp
+++ b/src/geomgraph/Position.cpp
@@ -31,9 +31,9 @@ namespace geos {
namespace geomgraph { // geos.geomgraph
-* Returns LEFT if the position is RIGHT, RIGHT if the position is LEFT, or the position
-* otherwise.
+ * Returns LEFT if the position is RIGHT, RIGHT if the position is LEFT, or the position
+ * otherwise.
int
Position::opposite(int position)
diff --git a/src/geomgraph/index/MonotoneChainIndexer.cpp b/src/geomgraph/index/MonotoneChainIndexer.cpp
index 8867176..6235632 100644
--- a/src/geomgraph/index/MonotoneChainIndexer.cpp
+++ b/src/geomgraph/index/MonotoneChainIndexer.cpp
@@ -47,8 +47,8 @@ MonotoneChainIndexer::getChainStartIndices(const CoordinateSequence* pts,
-* @return the index of the last point in the monotone chain
+ * @return the index of the last point in the monotone chain
size_t
MonotoneChainIndexer::findChainEnd(const CoordinateSequence* pts, size_t start)
diff --git a/src/index/bintree/Bintree.cpp b/src/index/bintree/Bintree.cpp
index 45b8641..2a92ebc 100644
--- a/src/index/bintree/Bintree.cpp
+++ b/src/index/bintree/Bintree.cpp
@@ -131,8 +131,8 @@ Bintree::query(double x)
-* min and max may be the same value
+ * min and max may be the same value
vector<void*>*
Bintree::query(Interval* interval)
diff --git a/src/noding/snapround/MCIndexPointSnapper.cpp b/src/noding/snapround/MCIndexPointSnapper.cpp
index 3215efc..60e10cb 100644
--- a/src/noding/snapround/MCIndexPointSnapper.cpp
+++ b/src/noding/snapround/MCIndexPointSnapper.cpp
@@ -53,12 +53,12 @@ public:
- * Reports whether the HotPixel caused a node to be added in any target
- * segmentString (including its own). If so, the HotPixel must be added as a
- * node as well.
- * @return true if a node was added in any target segmentString.
+ * Reports whether the HotPixel caused a node to be added in any target
+ * segmentString (including its own). If so, the HotPixel must be added as a
+ * node as well.
+ * @return true if a node was added in any target segmentString.
bool
isNodeAdded() const
@@ -66,12 +66,12 @@ public:
- * Check if a segment of the monotone chain intersects
- * the hot pixel vertex and introduce a snap node if so.
- * Optimized to avoid noding segments which
- * contain the vertex (which otherwise
- * would cause every vertex to be noded).
+ * Check if a segment of the monotone chain intersects
+ * the hot pixel vertex and introduce a snap node if so.
+ * Optimized to avoid noding segments which
+ * contain the vertex (which otherwise
+ * would cause every vertex to be noded).
void
select(chain::MonotoneChain& mc, size_t startIndex) override
diff --git a/src/operation/distance/ConnectedElementPointFilter.cpp b/src/operation/distance/ConnectedElementPointFilter.cpp
index d0ef70c..e214ee6 100644
--- a/src/operation/distance/ConnectedElementPointFilter.cpp
+++ b/src/operation/distance/ConnectedElementPointFilter.cpp
@@ -33,10 +33,10 @@ namespace operation { // geos.operation
namespace distance { // geos.operation.distance
-* Returns a list containing a Coordinate from each Polygon, LineString, and Point
-* found inside the specified geometry. Thus, if the specified geometry is
-* not a GeometryCollection, an empty list will be returned.
+ * Returns a list containing a Coordinate from each Polygon, LineString, and Point
+ * found inside the specified geometry. Thus, if the specified geometry is
+ * not a GeometryCollection, an empty list will be returned.
vector<const Coordinate*>*
ConnectedElementPointFilter::getCoordinates(const Geometry* geom)
diff --git a/src/operation/distance/DistanceOp.cpp b/src/operation/distance/DistanceOp.cpp
index 923dfc3..dcdc594 100644
--- a/src/operation/distance/DistanceOp.cpp
+++ b/src/operation/distance/DistanceOp.cpp
@@ -99,10 +99,10 @@ DistanceOp::DistanceOp(const Geometry& g0, const Geometry& g1, double tdist)
-* Report the distance between the closest points on the input geometries.
-* @return the distance between the geometries
+ * Report the distance between the closest points on the input geometries.
+ * @return the distance between the geometries
double
DistanceOp::distance()
diff --git a/src/operation/distance/GeometryLocation.cpp b/src/operation/distance/GeometryLocation.cpp
index 2125c3c..593a908 100644
--- a/src/operation/distance/GeometryLocation.cpp
+++ b/src/operation/distance/GeometryLocation.cpp
@@ -28,9 +28,9 @@ namespace operation { // geos.operation
-* Constructs a GeometryLocation specifying a point on a geometry, as well as the
-* segment that the point is on (or INSIDE_AREA if the point is not on a segment).
+ * Constructs a GeometryLocation specifying a point on a geometry, as well as the
+ * segment that the point is on (or INSIDE_AREA if the point is not on a segment).
GeometryLocation::GeometryLocation(const Geometry* newComponent, size_t newSegIndex, const Coordinate& newPt)
component = newComponent;
@@ -40,8 +40,8 @@ GeometryLocation::GeometryLocation(const Geometry* newComponent, size_t newSegIn
-* Constructs a GeometryLocation specifying a point inside an area geometry.
+ * Constructs a GeometryLocation specifying a point inside an area geometry.
GeometryLocation::GeometryLocation(const Geometry* newComponent, const Coordinate& newPt)
@@ -51,27 +51,27 @@ GeometryLocation::GeometryLocation(const Geometry* newComponent, const Coordinat
-* Returns the geometry associated with this location.
+ * Returns the geometry associated with this location.
const Geometry*
GeometryLocation::getGeometryComponent()
return component;
-* Returns the segment index for this location. If the location is inside an
-* area, the index will have the value INSIDE_AREA;
-* @return the segment index for the location, or INSIDE_AREA
+ * Returns the segment index for this location. If the location is inside an
+ * area, the index will have the value INSIDE_AREA;
+ * @return the segment index for the location, or INSIDE_AREA
size_t
GeometryLocation::getSegmentIndex()
return segIndex;
-* Returns the location.
+ * Returns the location.
Coordinate&
GeometryLocation::getCoordinate()
diff --git a/src/operation/linemerge/LineMergeEdge.cpp b/src/operation/linemerge/LineMergeEdge.cpp
index 28b5b5f..0a77404 100644
--- a/src/operation/linemerge/LineMergeEdge.cpp
+++ b/src/operation/linemerge/LineMergeEdge.cpp
@@ -26,8 +26,8 @@ namespace operation { // geos.operation
namespace linemerge { // geos.operation.linemerge
-* Constructs a LineMergeEdge with vertices given by the specified LineString.
+ * Constructs a LineMergeEdge with vertices given by the specified LineString.
LineMergeEdge::LineMergeEdge(const LineString* newLine):
line(newLine)
diff --git a/src/operation/polygonize/BuildArea.cpp b/src/operation/polygonize/BuildArea.cpp
index 6b4b923..0b996a2 100644
--- a/src/operation/polygonize/BuildArea.cpp
+++ b/src/operation/polygonize/BuildArea.cpp
@@ -160,32 +160,32 @@ unique_ptr<geom::Geometry> BuildArea::build(const geom::Geometry* geom) {
- * Polygonizer returns a polygon for each face in the built topology.
- * This means that for any face with holes we'll have other faces
- * representing each hole. We can imagine a parent-child relationship
- * between these faces.
- * In order to maximize the number of visible rings in output we
- * only use those faces which have an even number of parents.
- * Example:
- * | L0 | L0 has no parents
- * | | L1 | | L1 is an hole of L0
- * | | |L2 | | | L2 is an hole of L1 (which is an hole of L0)
- * See http://trac.osgeo.org/postgis/ticket/1806
+ * Polygonizer returns a polygon for each face in the built topology.
+ * This means that for any face with holes we'll have other faces
+ * representing each hole. We can imagine a parent-child relationship
+ * between these faces.
+ * In order to maximize the number of visible rings in output we
+ * only use those faces which have an even number of parents.
+ * Example:
+ * | L0 | L0 has no parents
+ * | | L1 | | L1 is an hole of L0
+ * | | |L2 | | | L2 is an hole of L1 (which is an hole of L0)
+ * See http://trac.osgeo.org/postgis/ticket/1806
/* Prepare face structures for later analysis */
std::vector<std::unique_ptr<Face>> faces;
diff --git a/src/operation/relate/EdgeEndBundle.cpp b/src/operation/relate/EdgeEndBundle.cpp
index fce941b..54580bd 100644
--- a/src/operation/relate/EdgeEndBundle.cpp
+++ b/src/operation/relate/EdgeEndBundle.cpp
@@ -69,10 +69,10 @@ EdgeEndBundle::insert(EdgeEnd* e)
-* This computes the overall edge label for the set of
-* edges in this EdgeStubBundle. It essentially merges
-* the ON and side labels for each edge. These labels must be compatible
+ * This computes the overall edge label for the set of
+ * edges in this EdgeStubBundle. It essentially merges
+ * the ON and side labels for each edge. These labels must be compatible
void
EdgeEndBundle::computeLabel(
const algorithm::BoundaryNodeRule& boundaryNodeRule)
@@ -134,8 +134,8 @@ EdgeEndBundle::computeLabelOn(int geomIndex, const algorithm::BoundaryNodeRule&
-* Compute the labelling for each side
+ * Compute the labelling for each side
void
EdgeEndBundle::computeLabelSides(int geomIndex)
@@ -144,19 +144,19 @@ EdgeEndBundle::computeLabelSides(int geomIndex)
-* To compute the summary label for a side, the algorithm is:
-* FOR all edges
-* IF any edge's location is INTERIOR for the side, side location = INTERIOR
-* ELSE IF there is at least one EXTERIOR attribute, side location = EXTERIOR
-* ELSE side location = NULL
-* <br>
-* Note that it is possible for two sides to have apparently contradictory information
-* i.e. one edge side may indicate that it is in the interior of a geometry, while
-* another edge side may indicate the exterior of the same geometry. This is
-* not an incompatibility - GeometryCollections may contain two Polygons that touch
-* along an edge. This is the reason for Interior-primacy rule above - it
-* results in the summary label having the Geometry interior on <b>both</b> sides.
+ * To compute the summary label for a side, the algorithm is:
+ * FOR all edges
+ * IF any edge's location is INTERIOR for the side, side location = INTERIOR
+ * ELSE IF there is at least one EXTERIOR attribute, side location = EXTERIOR
+ * ELSE side location = NULL
+ * <br>
+ * Note that it is possible for two sides to have apparently contradictory information
+ * i.e. one edge side may indicate that it is in the interior of a geometry, while
+ * another edge side may indicate the exterior of the same geometry. This is
+ * not an incompatibility - GeometryCollections may contain two Polygons that touch
+ * along an edge. This is the reason for Interior-primacy rule above - it
+ * results in the summary label having the Geometry interior on <b>both</b> sides.
void
EdgeEndBundle::computeLabelSide(int geomIndex, int side)
diff --git a/src/operation/relate/RelateComputer.cpp b/src/operation/relate/RelateComputer.cpp
index afae6f1..9d1f136 100644
--- a/src/operation/relate/RelateComputer.cpp
+++ b/src/operation/relate/RelateComputer.cpp
@@ -205,7 +205,7 @@ RelateComputer::computeIM()
labelNodeEdges();
* Compute the labeling for isolated components.
* Isolated components are components that do not touch any
* other components in the graph.
@@ -249,22 +249,22 @@ RelateComputer::computeProperIntersectionIM(SegmentIntersector* intersector, Int
bool hasProper = intersector->hasProperIntersection();
bool hasProperInterior = intersector->hasProperInteriorIntersection();
// For Geometry's of dim 0 there can never be proper intersections.
- * If edge segments of Areas properly intersect, the areas must properly overlap.
+ * If edge segments of Areas properly intersect, the areas must properly overlap.
if(dimA == 2 && dimB == 2) {
if(hasProper) {
imX->setAtLeast("212101212");
- * If an Line segment properly intersects an edge segment of an Area,
- * it follows that the Interior of the Line intersects the Boundary of the Area.
- * If the intersection is a proper <i>interior</i> intersection, then
- * there is an Interior-Interior intersection too.
- * Note that it does not follow that the Interior of the Line intersects the Exterior
- * of the Area, since there may be another Area component which contains the rest of the Line.
+ * If an Line segment properly intersects an edge segment of an Area,
+ * it follows that the Interior of the Line intersects the Boundary of the Area.
+ * If the intersection is a proper *interior* intersection, then
+ * there is an Interior-Interior intersection too.
+ * Note that it does not follow that the Interior of the Line intersects the Exterior
+ * of the Area, since there may be another Area component which contains the rest of the Line.
else if(dimA == 2 && dimB == 1) {
if(hasProper) {
imX->setAtLeast("FFF0FFFF2");
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index dd9a1a3..dcbaa11 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -439,11 +439,11 @@ IsValidOp::checkHolesInShell(const Polygon* p, GeometryGraph* graph)
if (hole->isEmpty()) continue;
const Coordinate* holePt = findPtNotNode(hole->getCoordinatesRO(), shell, graph);
- * If no non-node hole vertex can be found, the hole must
- * split the polygon into disconnected interiors.
- * This will be caught by a subsequent check.
+ * If no non-node hole vertex can be found, the hole must
+ * split the polygon into disconnected interiors.
+ * This will be caught by a subsequent check.
if (holePt == nullptr) return;
bool outside = isShellEmpty || (Location::EXTERIOR == ipial.locate(holePt));
if (outside) {
@@ -547,7 +547,7 @@ IsValidOp::checkShellNotNested(const LinearRing* shell, const Polygon* p,
return;
* Check if the shell is inside one of the holes.
* This is the case if one of the calls to checkShellInsideHole
* returns a null coordinate.
diff --git a/src/planargraph/Edge.cpp b/src/planargraph/Edge.cpp
index 9e84e13..ae7bf82 100644
--- a/src/planargraph/Edge.cpp
+++ b/src/planargraph/Edge.cpp
@@ -42,9 +42,9 @@ Edge::setDirectedEdges(DirectedEdge* de0, DirectedEdge* de1)
-* Returns one of the DirectedEdges associated with this Edge.
-* @param i 0 or 1
+ * Returns one of the DirectedEdges associated with this Edge.
+ * @param i 0 or 1
DirectedEdge*
Edge::getDirEdge(int i)
@@ -70,9 +70,9 @@ Edge::getDirEdge(Node* fromNode)
-* If <code>node</code> is one of the two nodes associated with this Edge,
-* returns the other node; otherwise returns null.
+ * If <code>node</code> is one of the two nodes associated with this Edge,
+ * returns the other node; otherwise returns null.
Node*
Edge::getOppositeNode(Node* node)
diff --git a/tests/bigtest/GeometryTestFactory.cpp b/tests/bigtest/GeometryTestFactory.cpp
index b286413..ca7f337 100644
--- a/tests/bigtest/GeometryTestFactory.cpp
+++ b/tests/bigtest/GeometryTestFactory.cpp
@@ -63,12 +63,12 @@ GeometryTestFactory::createBox(double minx, double miny, int nSide, double segLe
-* Creates a circle
-* @param x the centre x coord
-* @param y the centre y coord
-* @param size the size of the envelope of the star
-* @param nPts the number of points in the star
+ * Creates a circle
+ * @param x the centre x coord
+ * @param y the centre y coord
+ * @param size the size of the envelope of the star
+ * @param nPts the number of points in the star
CoordinateSequence*
GeometryTestFactory::createCircle(double basex, double basey, double size, int nPts)
@@ -93,14 +93,14 @@ GeometryTestFactory::createCircle(GeometryFactory* fact, double basex, double ba
-* Creates a star from a "circular" sine wave
-* @param basex the centre x coord
-* @param basey the centre y coord
-* @param armLen the length of an arm of the star
-* @param nArms the number of arms of the star
+ * Creates a star from a "circular" sine wave
+ * @param basex the centre x coord
+ * @param basey the centre y coord
+ * @param armLen the length of an arm of the star
+ * @param nArms the number of arms of the star
CoordinateSequence*
GeometryTestFactory::createSineStar(double basex, double basey, double size, double armLen, int nArms, int nPts)
diff --git a/tools/astyle/ASBeautifier.cpp b/tools/astyle/ASBeautifier.cpp
index 10317dd..541de9c 100755
--- a/tools/astyle/ASBeautifier.cpp
+++ b/tools/astyle/ASBeautifier.cpp
@@ -521,10 +521,10 @@ void ASBeautifier::setSpaceIndentation(int length)
-* indent continuation lines using a number of indents.
-* @param indent number of indents per line.
+ * indent continuation lines using a number of indents.
+ * @param indent number of indents per line.
void ASBeautifier::setContinuationIndentation(int indent)
continuationIndent = indent;
@@ -586,11 +586,11 @@ void ASBeautifier::setBraceIndent(bool state)
-* set the state of the brace indent VTK option. If true, braces will
-* be indented one additional indent, except for the opening brace.
-* @param state state of option.
+ * set the state of the brace indent VTK option. If true, braces will
+ * be indented one additional indent, except for the opening brace.
+ * @param state state of option.
void ASBeautifier::setBraceIndentVtk(bool state)
// need to set both of these
@@ -666,10 +666,10 @@ void ASBeautifier::setNamespaceIndent(bool state)
-* set the state of the indent after parens option.
+ * set the state of the indent after parens option.
void ASBeautifier::setAfterParenIndent(bool state)
shouldIndentAfterParen = state;
@@ -770,10 +770,10 @@ bool ASBeautifier::getForceTabIndentation() const
-* Get the state of the Objective-C align method colon option.
-* @return state of shouldAlignMethodColon option.
+ * Get the state of the Objective-C align method colon option.
+ * @return state of shouldAlignMethodColon option.
bool ASBeautifier::getAlignMethodColon() const
return shouldAlignMethodColon;
@@ -800,11 +800,11 @@ bool ASBeautifier::getBraceIndent() const
-* Get the state of the namespace indentation option. If true, blocks
-* of the 'namespace' statement will be indented one additional indent.
-* @return state of namespaceIndent option.
+ * Get the state of the namespace indentation option. If true, blocks
+ * of the 'namespace' statement will be indented one additional indent.
+ * @return state of namespaceIndent option.
bool ASBeautifier::getNamespaceIndent() const
return namespaceIndent;
@@ -1349,8 +1349,8 @@ void ASBeautifier::registerContinuationIndent(const string& line, int i, int spa
-* Register a continuation indent for a class header or a class initializer colon.
+ * Register a continuation indent for a class header or a class initializer colon.
void ASBeautifier::registerContinuationIndentColon(const string& line, int i, int tabIncrementIn)
assert(line[i] == ':');
diff --git a/tools/astyle/ASEnhancer.cpp b/tools/astyle/ASEnhancer.cpp
index cb197a9..fe0adde 100755
--- a/tools/astyle/ASEnhancer.cpp
+++ b/tools/astyle/ASEnhancer.cpp
@@ -246,7 +246,7 @@ size_t ASEnhancer::findCaseColon(const string& line, size_t caseIndex) const
-* indent a line by a given number of tabsets
+ * indent a line by a given number of tabsets
* by inserting leading whitespace to the line argument.
* @param line a reference to the line to indent.
diff --git a/tools/astyle/ASFormatter.cpp b/tools/astyle/ASFormatter.cpp
index bd1a004..7d7284c 100755
--- a/tools/astyle/ASFormatter.cpp
+++ b/tools/astyle/ASFormatter.cpp
@@ -2076,13 +2076,13 @@ void ASFormatter::setBreakElseIfsMode(bool state)
-* set comma padding mode.
-* options:
-* true statement commas and semicolons will be padded with spaces around them.
-* false statement commas and semicolons will not be padded.
-* @param state the padding mode.
+ * set comma padding mode.
+ * options:
+ * true statement commas and semicolons will be padded with spaces around them.
+ * false statement commas and semicolons will not be padded.
+ * @param state the padding mode.
void ASFormatter::setCommaPaddingMode(bool state)
shouldPadCommas = state;
@@ -2177,11 +2177,11 @@ void ASFormatter::setParensUnPaddingMode(bool state)
-* set the state of the preprocessor indentation option.
-* If true, #ifdef blocks at level 0 will be indented.
+ * set the state of the preprocessor indentation option.
+ * If true, #ifdef blocks at level 0 will be indented.
void ASFormatter::setPreprocBlockIndent(bool state)
shouldIndentPreprocBlock = state;
@@ -2327,17 +2327,17 @@ void ASFormatter::setBreakOneLineBlocksMode(bool state)
-* set one line headers breaking mode
+ * set one line headers breaking mode
void ASFormatter::setBreakOneLineHeadersMode(bool state)
shouldBreakOneLineHeaders = state;
-* set option to break/not break lines consisting of multiple statements.
-* @param state true = break, false = don't break.
+ * set option to break/not break lines consisting of multiple statements.
+ * @param state true = break, false = don't break.
void ASFormatter::setBreakOneLineStatementsMode(bool state)
@@ -3084,10 +3084,10 @@ bool ASFormatter::isNumericVariable(string word) const
-* check if a colon is a class initializer separator
-* @return whether it is a class initializer separator
+ * check if a colon is a class initializer separator
+ * @return whether it is a class initializer separator
bool ASFormatter::isClassInitializer() const
assert(currentChar == ':');
@@ -3712,11 +3712,11 @@ bool ASFormatter::isNextCharOpeningBrace(int startChar) const
-* Check if operator and, pointer, and reference padding is disabled.
-* Disabling is done thru a NOPAD tag in an ending comment.
-* @return true if the formatting on this line is disabled.
+ * Check if operator and, pointer, and reference padding is disabled.
+ * Disabling is done thru a NOPAD tag in an ending comment.
+ * @return true if the formatting on this line is disabled.
bool ASFormatter::isOperatorPaddingDisabled() const
size_t commentStart = currentLine.find("//", charNum);
@@ -3740,9 +3740,9 @@ bool ASFormatter::isOperatorPaddingDisabled() const
-* Determine if an opening array-type brace should have a leading space pad.
-* This is to identify C++11 uniform initializers.
+ * Determine if an opening array-type brace should have a leading space pad.
+ * This is to identify C++11 uniform initializers.
bool ASFormatter::isUniformInitializerBrace() const
if (isCStyle() && !isInEnum && !isImmediatelyPostPreprocessor)
@@ -3756,8 +3756,8 @@ bool ASFormatter::isUniformInitializerBrace() const
-* Determine if there is a following statement on the current line.
+ * Determine if there is a following statement on the current line.
bool ASFormatter::isMultiStatementLine() const
assert((isImmediatelyPostHeader || foundClosingHeader));
@@ -4691,11 +4691,11 @@ void ASFormatter::padParens()
-* add or remove space padding to objective-c method prefix (- or +)
-* if this is a '(' it begins a return type
-* these options have precedence over the padParens methods
-* the padParens method has already been called, this method adjusts
+ * add or remove space padding to objective-c method prefix (- or +)
+ * if this is a '(' it begins a return type
+ * these options have precedence over the padParens methods
+ * the padParens method has already been called, this method adjusts
void ASFormatter::padObjCMethodPrefix()
assert(isInObjCMethodDefinition && isImmediatelyPostObjCMethodPrefix);
@@ -4735,10 +4735,10 @@ void ASFormatter::padObjCMethodPrefix()
-* add or remove space padding to objective-c parens
+ * add or remove space padding to objective-c parens
void ASFormatter::padObjCReturnType()
assert(currentChar == ')' && isInObjCReturnType);
@@ -4785,10 +4785,10 @@ void ASFormatter::padObjCReturnType()
void ASFormatter::padObjCParamType()
assert((currentChar == '(' || currentChar == ')') && isInObjCMethodDefinition);
@@ -5529,8 +5529,8 @@ void ASFormatter::convertTabToSpaces()
-* is it ok to break this block?
+ * is it ok to break this block?
bool ASFormatter::isOkToBreakBlock(BraceType braceType) const
// Actually, there should not be an ARRAY_TYPE brace here.
@@ -5550,8 +5550,8 @@ bool ASFormatter::isOkToBreakBlock(BraceType braceType) const
-* check if a sharp header is a paren or non-paren header
+ * check if a sharp header is a paren or non-paren header
bool ASFormatter::isSharpStyleWithParen(const string* header) const
return (isSharpStyle() && peekNextChar() == '('
@@ -6902,12 +6902,12 @@ bool ASFormatter::isStructAccessModified(const string& firstLine, size_t index)
-* Look ahead in the file to see if a preprocessor block is indentable.
-* @param firstLine a reference to the line to indent.
-* @param index the current line index.
-* @return true if the block is indentable.
+ * Look ahead in the file to see if a preprocessor block is indentable.
+ * @param firstLine a reference to the line to indent.
+ * @param index the current line index.
+ * @return true if the block is indentable.
bool ASFormatter::isIndentablePreprocessorBlock(const string& firstLine, size_t index)
assert(firstLine[index] == '#');
diff --git a/tools/astyle/ASResource.cpp b/tools/astyle/ASResource.cpp
index e2fc772..d392a2b 100755
--- a/tools/astyle/ASResource.cpp
+++ b/tools/astyle/ASResource.cpp
@@ -327,11 +327,11 @@ void ASResource::buildIndentableHeaders(vector<const string*>* indentableHeaders
-* Build the vector of indentable macros pairs.
-* Initialized by ASFormatter, used by ONLY ASEnhancer.cpp
-* @param indentableMacros a reference to the vector to be built.
+ * Build the vector of indentable macros pairs.
+ * Initialized by ASFormatter, used by ONLY ASEnhancer.cpp
+ * @param indentableMacros a reference to the vector to be built.
void ASResource::buildIndentableMacros(vector<const pair<const string, const string>* >* indentableMacros)
const size_t elements = 10;
diff --git a/tools/astyle/astyle_main.cpp b/tools/astyle/astyle_main.cpp
index 98dfadf..69ef995 100755
--- a/tools/astyle/astyle_main.cpp
+++ b/tools/astyle/astyle_main.cpp
@@ -125,11 +125,11 @@ ASStreamIterator<T>::~ASStreamIterator()
-* get the length of the input stream.
-* streamLength variable is set by the constructor.
-* @return length of the input file stream, converted to an int.
+ * get the length of the input stream.
+ * streamLength variable is set by the constructor.
+ * @return length of the input file stream, converted to an int.
template<typename T>
int ASStreamIterator<T>::getStreamLength() const
commit 3326a5c3ee3cb114b9d50ba250437963e90d8053
Date: Thu Oct 3 14:23:21 2019 +0200
Remove doxygen style comment block start tag
from in-code comment blocks.
diff --git a/benchmarks/algorithm/InteriorPointAreaPerfTest.cpp b/benchmarks/algorithm/InteriorPointAreaPerfTest.cpp
index 9d47ba1..56ea68f 100644
--- a/benchmarks/algorithm/InteriorPointAreaPerfTest.cpp
+++ b/benchmarks/algorithm/InteriorPointAreaPerfTest.cpp
@@ -53,7 +53,7 @@ public:
std::unique_ptr<geos::geom::Polygon> sinePoly =
createSineStar(origin, SIZE, nPts);
* Make the geometry "crinkly" by rounding off the points.
* This defeats the MonotoneChain optimization in the full relate
* algorithm, and provides a more realistic test.
diff --git a/benchmarks/operation/predicate/RectangleIntersectsPerfTest.cpp b/benchmarks/operation/predicate/RectangleIntersectsPerfTest.cpp
index 9ff3b31..8ecfea5 100644
--- a/benchmarks/operation/predicate/RectangleIntersectsPerfTest.cpp
+++ b/benchmarks/operation/predicate/RectangleIntersectsPerfTest.cpp
@@ -52,7 +52,7 @@ public:
createSineStar(origin, size, nPts)->getBoundary()
diff --git a/src/algorithm/Area.cpp b/src/algorithm/Area.cpp
index 81c76bb..1b3692a 100644
--- a/src/algorithm/Area.cpp
+++ b/src/algorithm/Area.cpp
@@ -48,7 +48,7 @@ Area::ofRingSigned(const std::vector<geom::Coordinate>& ring)
double sum = 0.0;
* Based on the Shoelace formula.
* http://en.wikipedia.org/wiki/Shoelace_formula
@@ -70,10 +70,10 @@ Area::ofRingSigned(const geom::CoordinateSequence* ring)
if(n < 3) {
return 0.0;
- * Based on the Shoelace formula.
- * http://en.wikipedia.org/wiki/Shoelace_formula
+ * Based on the Shoelace formula.
+ * http://en.wikipedia.org/wiki/Shoelace_formula
geom::Coordinate p0, p1, p2;
p1 = ring->getAt(0);
p2 = ring->getAt(1);
diff --git a/src/algorithm/ConvexHull.cpp b/src/algorithm/ConvexHull.cpp
index 734459d..e0fd924 100644
--- a/src/algorithm/ConvexHull.cpp
+++ b/src/algorithm/ConvexHull.cpp
@@ -190,7 +190,7 @@ ConvexHull::reduce(Coordinate::ConstVect& pts)
Coordinate::ConstSet reducedSet;
reducedSet.insert(polyPts.begin(), polyPts.end());
* Add all unique points not in the interior poly.
* CGAlgorithms.isPointInRing is not defined for points
* actually on the ring, but this doesn't matter since
diff --git a/src/algorithm/InteriorPointArea.cpp b/src/algorithm/InteriorPointArea.cpp
index 1ddddac..c455948 100644
--- a/src/algorithm/InteriorPointArea.cpp
+++ b/src/algorithm/InteriorPointArea.cpp
@@ -151,11 +151,11 @@ public:
vector<double> crossings;
* This results in returning a null Coordinate
if (polygon.isEmpty()) return;
* set default interior point in case polygon has zero area
interiorPoint = *polygon.getCoordinate();
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index 3d631a9..e87814f 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -435,7 +435,7 @@ LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2,
return computeCollinearIntersection(p1, p2, q1, q2);
* At this point we know that there is a single intersection point
* (since the lines are not collinear).
@@ -493,7 +493,7 @@ LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2,
#endif
* Now check to see if any endpoint lies on the interior of the other segment.
else if(Pq1 == 0) {
index 2a6a508..e1b4e7b 100644
@@ -275,9 +275,9 @@ MinimumBoundingCircle::pointWitMinAngleWithX(std::vector<Coordinate>& pts, Coord
continue;
- * The sin of the angle is a simpler proxy for the angle itself
+ * The sin of the angle is a simpler proxy for the angle itself
double dx = p.x - P.x;
double dy = p.y - P.y;
if(dy < 0) {
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index a2139b5..3def504 100644
--- a/src/algorithm/Orientation.cpp
+++ b/src/algorithm/Orientation.cpp
@@ -97,7 +97,7 @@ Orientation::isCCW(const geom::CoordinateSequence* ring)
int disc = Orientation::index(*prev, *hiPt, *next);
* If disc is exactly 0, lines are collinear.
* There are two possible cases:
* (1) the lines lie along the x axis in opposite directions
diff --git a/src/algorithm/distance/DiscreteHausdorffDistance.cpp b/src/algorithm/distance/DiscreteHausdorffDistance.cpp
index 78ddae3..9b3fb9d 100644
--- a/src/algorithm/distance/DiscreteHausdorffDistance.cpp
+++ b/src/algorithm/distance/DiscreteHausdorffDistance.cpp
@@ -32,7 +32,7 @@ void
DiscreteHausdorffDistance::MaxDensifiedByFractionDistanceFilter::filter_ro(
const geom::CoordinateSequence& seq, size_t index)
* This logic also handles skipping Point geometries
if(index == 0) {
diff --git a/src/algorithm/locate/SimplePointInAreaLocator.cpp b/src/algorithm/locate/SimplePointInAreaLocator.cpp
index 93e9482..e6ba6b2 100644
--- a/src/algorithm/locate/SimplePointInAreaLocator.cpp
+++ b/src/algorithm/locate/SimplePointInAreaLocator.cpp
@@ -44,7 +44,7 @@ SimplePointInAreaLocator::locate(const Coordinate& p, const Geometry* geom)
return Location::EXTERIOR;
* Do a fast check against the geometry envelope first
if (! geom->getEnvelopeInternal()->intersects(p))
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index aa99659..b583f6e 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -303,7 +303,7 @@ Geometry::intersects(const Geometry* g) const
#endif
* TODO: (MD) Add optimizations:
* - for P-A case:
@@ -523,9 +523,9 @@ Geometry::convexHull() const
Geometry::intersection(const Geometry* other) const
- * TODO: MD - add optimization for P-A case using Point-In-Polygon
+ * TODO: MD - add optimization for P-A case using Point-In-Polygon
// special case: if one input is empty ==> empty
if(isEmpty() || other->isEmpty()) {
diff --git a/src/geom/prep/PreparedLineStringIntersects.cpp b/src/geom/prep/PreparedLineStringIntersects.cpp
index 4d128ba..e6e05b9 100644
--- a/src/geom/prep/PreparedLineStringIntersects.cpp
+++ b/src/geom/prep/PreparedLineStringIntersects.cpp
@@ -35,7 +35,7 @@ namespace prep { // geos.geom.prep
bool
PreparedLineStringIntersects::isAnyTestPointInTarget(const geom::Geometry* testGeom) const
* This could be optimized by using the segment index on the lineal target.
* However, it seems like the L/P case would be pretty rare in practice.
diff --git a/src/geom/prep/PreparedPolygonContainsProperly.cpp b/src/geom/prep/PreparedPolygonContainsProperly.cpp
index 89ec3b3..358eb29 100644
--- a/src/geom/prep/PreparedPolygonContainsProperly.cpp
+++ b/src/geom/prep/PreparedPolygonContainsProperly.cpp
@@ -67,7 +67,7 @@ PreparedPolygonContainsProperly::containsProperly(const geom::Geometry* geom)
return false;
* Given that no segments intersect, if any vertex of the target
* is contained in some test component.
* the test is NOT properly contained.
diff --git a/src/geomgraph/DirectedEdgeStar.cpp b/src/geomgraph/DirectedEdgeStar.cpp
index 6929582..c0ff38d 100644
--- a/src/geomgraph/DirectedEdgeStar.cpp
+++ b/src/geomgraph/DirectedEdgeStar.cpp
@@ -366,7 +366,7 @@ DirectedEdgeStar::findCoveredLineEdges()
// Since edges are stored in CCW order around the node,
// as we move around the ring we move from the right to the left side of the edge
* Find first DirectedEdge of result area (if any).
* The interior of the result is on the RHS of the edge,
* so the start location will be:
@@ -401,7 +401,7 @@ DirectedEdgeStar::findCoveredLineEdges()
return;
* move around ring, keeping track of the current location
* (Interior or Exterior) for the result area.
* If L edges are found, mark them as covered if they are in the interior
diff --git a/src/geomgraph/EdgeEndStar.cpp b/src/geomgraph/EdgeEndStar.cpp
index b3a67ff..342c4d8 100644
--- a/src/geomgraph/EdgeEndStar.cpp
+++ b/src/geomgraph/EdgeEndStar.cpp
@@ -105,7 +105,7 @@ EdgeEndStar::computeLabelling(std::vector<GeometryGraph*>* geomGraph)
propagateSideLabels(0);
propagateSideLabels(1);
* If there are edges that still have null labels for a geometry
* this must be because there are no area edges for that geometry
* incident on this node.
@@ -322,7 +322,7 @@ EdgeEndStar::propagateSideLabels(int geomIndex)
currLoc = leftLoc;
else {
* RHS is null - LHS must be null too.
* This must be an edge from the other
* geometry, which has no location
diff --git a/src/geomgraph/index/SimpleSweepLineIntersector.cpp b/src/geomgraph/index/SimpleSweepLineIntersector.cpp
index bd8eea6..a054113 100644
--- a/src/geomgraph/index/SimpleSweepLineIntersector.cpp
+++ b/src/geomgraph/index/SimpleSweepLineIntersector.cpp
@@ -132,7 +132,7 @@ SimpleSweepLineIntersector::processOverlaps(size_t start, size_t end, SweepLineE
SweepLineSegment* ss0 = (SweepLineSegment*) ev0->getObject();
* Since we might need to test for self-intersections,
* include current insert event object in list of event objects to test.
* Last index can be skipped, because it must be a Delete event.
index 879dfba..45b8641 100644
@@ -136,10 +136,10 @@ Bintree::query(double x)
vector<void*>*
- * the items that are matched are all items in intervals
- * which overlap the query interval
+ * the items that are matched are all items in intervals
+ * which overlap the query interval
vector<void*>* foundItems = new vector<void*>();
query(interval, foundItems);
return foundItems;
diff --git a/src/index/bintree/Root.cpp b/src/index/bintree/Root.cpp
index d42fe43..46d08cf 100644
--- a/src/index/bintree/Root.cpp
+++ b/src/index/bintree/Root.cpp
@@ -37,13 +37,13 @@ Root::insert(Interval* itemInterval, void* item)
return;
* the item must be contained in one interval, so insert it into the
* tree for that interval (which may not yet exist)
Node* node = subnode[index];
* If the subnode doesn't exist or this item is not contained in it,
* have to expand the tree upward to contain the item.
@@ -52,10 +52,10 @@ Root::insert(Interval* itemInterval, void* item)
// delete subnode[index];
subnode[index] = largerNode;
- * At this point we have a subnode which exists and must contain
- * contains the env for the item. Insert the item into the tree.
+ * At this point we have a subnode which exists and must contain
+ * contains the env for the item. Insert the item into the tree.
insertContained(subnode[index], itemInterval, item);
//System.out.println("depth = " + root.depth() + " size = " + root.size());
@@ -67,7 +67,7 @@ Root::insertContained(Node* tree, Interval* itemInterval, void* item)
assert(tree->getInterval()->contains(itemInterval));
* Do NOT create a new node for zero-area intervals - this would lead
* to infinite recursion. Instead, use a heuristic of simply returning
* the smallest existing node containing the query
diff --git a/src/index/intervalrtree/SortedPackedIntervalRTree.cpp b/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
index bb5604e..633069f 100644
--- a/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
+++ b/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
@@ -37,10 +37,10 @@ SortedPackedIntervalRTree::init()
if(root != nullptr)
return;
- * if leaves is empty then nothing has been inserted.
- * In this case it is safe to leave the tree in an open state
+ * if leaves is empty then nothing has been inserted.
+ * In this case it is safe to leave the tree in an open state
if (leaves.empty()) return;
root = buildTree();
diff --git a/src/index/quadtree/Root.cpp b/src/index/quadtree/Root.cpp
index 46f5ed3..516b816 100644
--- a/src/index/quadtree/Root.cpp
+++ b/src/index/quadtree/Root.cpp
@@ -116,7 +116,7 @@ Root::insertContained(Node* tree, const Envelope* itemEnv, void* item)
assert(tree->getEnvelope()->contains(itemEnv));
* Do NOT create a new quad for zero-area envelopes - this would lead
* the smallest existing quad containing the query
diff --git a/src/index/strtree/BoundablePair.cpp b/src/index/strtree/BoundablePair.cpp
index 1322365..60409b7 100644
--- a/src/index/strtree/BoundablePair.cpp
+++ b/src/index/strtree/BoundablePair.cpp
@@ -92,7 +92,7 @@ BoundablePair::expandToQueue(BoundablePairQueue& priQ, double minDistance)
bool isComp1 = isComposite(boundable1);
bool isComp2 = isComposite(boundable2);
* HEURISTIC: If both boundables are composite,
* choose the one with largest area to expand.
* Otherwise, simply expand whichever is composite.
diff --git a/src/index/strtree/SIRtree.cpp b/src/index/strtree/SIRtree.cpp
index 4e4981c..c7692bf 100644
--- a/src/index/strtree/SIRtree.cpp
+++ b/src/index/strtree/SIRtree.cpp
@@ -128,8 +128,8 @@ SIRtree::createNode(int level)
-* Inserts an item having the given bounds into the tree.
+ * Inserts an item having the given bounds into the tree.
void
SIRtree::insert(double x1, double x2, void* item)
diff --git a/src/index/strtree/STRtree.cpp b/src/index/strtree/STRtree.cpp
index 8e9868e..7186dbc 100644
--- a/src/index/strtree/STRtree.cpp
+++ b/src/index/strtree/STRtree.cpp
@@ -226,7 +226,7 @@ STRtree::nearestNeighbour(BoundablePair* initBndPair, double maxDistance)
BoundablePair* bndPair = priQ.top();
double currentDistance = bndPair->getDistance();
* If the distance for the first node in the queue
* is >= the current minimum distance, all other nodes
* in the queue must also have a greater distance.
@@ -239,7 +239,7 @@ STRtree::nearestNeighbour(BoundablePair* initBndPair, double maxDistance)
priQ.pop();
* If the pair members are leaves
* then their distance is the exact lower bound.
* Update the distanceLowerBound to reflect this
@@ -251,7 +251,7 @@ STRtree::nearestNeighbour(BoundablePair* initBndPair, double maxDistance)
minPair = bndPair;
else {
* Otherwise, expand one side of the pair,
* (the choice of which side to expand is heuristically determined)
* and insert the new expanded pairs into the queue
@@ -307,32 +307,32 @@ bool STRtree::isWithinDistance(BoundablePair* initBndPair, double maxDistance)
- * If the distance for the first pair in the queue
- * is >= maxDistance, other pairs
- * in the queue must also have a greater distance.
- * So can conclude no items are within the distance
- * and terminate with false
+ * If the distance for the first pair in the queue
+ * is >= maxDistance, other pairs
+ * in the queue must also have a greater distance.
+ * So can conclude no items are within the distance
+ * and terminate with false
if (currentDistance > maxDistance)
return false;
- * There must be some pair of items in the nodes which
- * are closer than the max distance,
- * so can terminate with true.
- * NOTE: using the Envelope MinMaxDistance would provide a tighter bound,
- * but not sure how to compute this!
+ * There must be some pair of items in the nodes which
+ * are closer than the max distance,
+ * so can terminate with true.
+ * NOTE: using the Envelope MinMaxDistance would provide a tighter bound,
+ * but not sure how to compute this!
if (bndPair->maximumDistance() <= maxDistance)
return true;
- * If the pair members are leaves
- * then their distance is an upper bound.
- * Update the distanceUpperBound to reflect this
+ * If the pair members are leaves
+ * then their distance is an upper bound.
+ * Update the distanceUpperBound to reflect this
if (bndPair->isLeaves()) {
distanceUpperBound = currentDistance;
@@ -342,11 +342,11 @@ bool STRtree::isWithinDistance(BoundablePair* initBndPair, double maxDistance)
return true;
else {
- * Otherwise, expand one side of the pair,
- * and insert the expanded pairs into the queue.
- * The choice of which side to expand is determined heuristically.
+ * Otherwise, expand one side of the pair,
+ * and insert the expanded pairs into the queue.
+ * The choice of which side to expand is determined heuristically.
bndPair->expandToQueue(priQ, distanceUpperBound);
diff --git a/src/index/sweepline/SweepLineIndex.cpp b/src/index/sweepline/SweepLineIndex.cpp
index cccbc3b..269242b 100644
--- a/src/index/sweepline/SweepLineIndex.cpp
+++ b/src/index/sweepline/SweepLineIndex.cpp
@@ -83,7 +83,7 @@ void
SweepLineIndex::processOverlaps(size_t start, size_t end,
SweepLineInterval* s0, SweepLineOverlapAction* action)
diff --git a/src/linearref/ExtractLineByLocation.cpp b/src/linearref/ExtractLineByLocation.cpp
index 634c9a3..6490f08 100644
--- a/src/linearref/ExtractLineByLocation.cpp
+++ b/src/linearref/ExtractLineByLocation.cpp
@@ -120,7 +120,7 @@ ExtractLineByLocation::computeLine(const LinearLocation& start, const LinearLoca
newCoordinateArray.add(start.getCoordinate(line));
* Ensure there is enough coordinates to build a valid line.
* Make a 2-point line with duplicate coordinates, if necessary.
* There will always be at least one coordinate in the coordList.
diff --git a/src/linearref/LengthIndexOfPoint.cpp b/src/linearref/LengthIndexOfPoint.cpp
index 2391b64..a1350ce 100644
--- a/src/linearref/LengthIndexOfPoint.cpp
+++ b/src/linearref/LengthIndexOfPoint.cpp
@@ -71,7 +71,7 @@ LengthIndexOfPoint::indexOfAfter(const Coordinate& inputPt, double minIndex) con
double closestAfter = indexOfFromStart(inputPt, minIndex);
* Return the minDistanceLocation found.
* This will not be null, since it was initialized to minLocation
diff --git a/src/linearref/LengthLocationMap.cpp b/src/linearref/LengthLocationMap.cpp
index 2ce89ac..d715ae5 100644
--- a/src/linearref/LengthLocationMap.cpp
+++ b/src/linearref/LengthLocationMap.cpp
@@ -84,7 +84,7 @@ LengthLocationMap::getLocationForward(double length) const
LinearIterator it(linearGeom);
while(it.hasNext()) {
* Special handling is required for the situation when the
* length references exactly to a component endpoint.
* In this case, the endpoint location of the current component
diff --git a/src/linearref/LocationIndexOfPoint.cpp b/src/linearref/LocationIndexOfPoint.cpp
index 23a837f..c959a7d 100644
--- a/src/linearref/LocationIndexOfPoint.cpp
+++ b/src/linearref/LocationIndexOfPoint.cpp
@@ -113,7 +113,7 @@ LocationIndexOfPoint::indexOfAfter(const Coordinate& inputPt,
LinearLocation closestAfter = indexOfFromStart(inputPt, minIndex);
diff --git a/src/noding/IteratedNoder.cpp b/src/noding/IteratedNoder.cpp
index 7718bf5..fbb9139 100644
--- a/src/noding/IteratedNoder.cpp
+++ b/src/noding/IteratedNoder.cpp
@@ -78,7 +78,7 @@ IteratedNoder::computeNodes(SegmentString::NonConstVect* segStrings)
nodingIterationCount++;
int nodesCreated = numInteriorIntersections;
* Fail if the number of nodes created is not declining.
* However, allow a few iterations at least before doing this
diff --git a/src/noding/MCIndexNoder.cpp b/src/noding/MCIndexNoder.cpp
index 8b6bb52..05117ad 100644
--- a/src/noding/MCIndexNoder.cpp
+++ b/src/noding/MCIndexNoder.cpp
@@ -75,7 +75,7 @@ MCIndexNoder::intersectChains()
MonotoneChain* testChain = static_cast<MonotoneChain*>(hit);
assert(testChain);
* following test makes sure we only compare each
* pair of chains once and that we don't compare a
* chain to itself
diff --git a/src/noding/NodingIntersectionFinder.cpp b/src/noding/NodingIntersectionFinder.cpp
index 81f5f23..f043f53 100644
--- a/src/noding/NodingIntersectionFinder.cpp
+++ b/src/noding/NodingIntersectionFinder.cpp
@@ -102,7 +102,7 @@ NodingIntersectionFinder::processIntersections(
return;
* If enabled, only test end segments (on either segString).
if(isCheckEndSegmentsOnly) {
diff --git a/src/operation/buffer/BufferInputLineSimplifier.cpp b/src/operation/buffer/BufferInputLineSimplifier.cpp
index 3acd552..aa281e0 100644
--- a/src/operation/buffer/BufferInputLineSimplifier.cpp
+++ b/src/operation/buffer/BufferInputLineSimplifier.cpp
@@ -79,7 +79,7 @@ BufferInputLineSimplifier::simplify(double nDistanceTol)
bool
BufferInputLineSimplifier::deleteShallowConcavities()
* Do not simplify end line segments of the line string.
* This ensures that end caps are generated consistently.
diff --git a/src/operation/buffer/BufferParameters.cpp b/src/operation/buffer/BufferParameters.cpp
index 1a88d3b..852b62a 100644
--- a/src/operation/buffer/BufferParameters.cpp
+++ b/src/operation/buffer/BufferParameters.cpp
@@ -90,7 +90,7 @@ BufferParameters::setQuadrantSegments(int quadSegs)
quadrantSegments = quadSegs;
* Indicates how to construct fillets.
* If qs >= 1, fillet is round, and qs indicates number of
* segments to use to approximate a quarter-circle.
@@ -112,7 +112,7 @@ BufferParameters::setQuadrantSegments(int quadSegs)
quadrantSegments = 1;
* If join style was set by the quadSegs value,
* use the default for the actual quadrantSegments value.
diff --git a/src/operation/buffer/BufferSubgraph.cpp b/src/operation/buffer/BufferSubgraph.cpp
index 9efb623..b2ca203 100644
--- a/src/operation/buffer/BufferSubgraph.cpp
+++ b/src/operation/buffer/BufferSubgraph.cpp
@@ -108,7 +108,7 @@ BufferSubgraph::add(Node* node, vector<Node*>* nodeStack)
dirEdgeList.push_back(de);
DirectedEdge* sym = de->getSym();
Node* symNode = sym->getNode();
* NOTE: this is a depth-first traversal of the graph.
* This will cause a large depth of recursion.
* It might be better to do a breadth-first traversal.
@@ -216,7 +216,7 @@ BufferSubgraph::findResultEdges()
for(size_t i = 0, n = dirEdgeList.size(); i < n; ++i) {
DirectedEdge* de = dirEdgeList[i];
* Select edges which have an interior depth on the RHS
* and an exterior depth on the LHS.
* Note that because of weird rounding effects there may be
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 9605ec1..06f1634 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -84,7 +84,7 @@ OffsetSegmentGenerator::OffsetSegmentGenerator(
// the points are rounded as they are inserted into the curve line
filletAngleQuantum = PI / 2.0 / bufParams.getQuadrantSegments();
* Non-round joins cause issues with short closing segments,
* so don't use them. In any case, non-round joins
* only really make sense for relatively small buffer distances.
@@ -108,7 +108,7 @@ OffsetSegmentGenerator::init(double newDistance)
segList.reset();
segList.setPrecisionModel(precisionModel);
* Choose the min vertex separation as a small fraction of
* the offset distance.
@@ -322,7 +322,7 @@ OffsetSegmentGenerator::createSquare(const Coordinate& p, double p_distance)
void
OffsetSegmentGenerator::addCollinear(bool addStartPoint)
* This test could probably be done more efficiently,
* but the situation of exact collinearity should be fairly rare.
@@ -330,13 +330,13 @@ OffsetSegmentGenerator::addCollinear(bool addStartPoint)
li.computeIntersection(s0, s1, s1, s2);
auto numInt = li.getIntersectionNum();
* if numInt is<2, the lines are parallel and in the same direction.
* In this case the point can be ignored, since the offset lines
* will also be parallel.
if(numInt >= 2) {
* Segments are collinear but reversing.
* Add an "end-cap" fillet
* all the way around to other direction
@@ -364,7 +364,7 @@ OffsetSegmentGenerator::addCollinear(bool addStartPoint)
void
OffsetSegmentGenerator::addOutsideTurn(int orientation, bool addStartPoint)
* Heuristic: If offset endpoints are very close together,
* just use one of them as the corner vertex.
* This avoids problems with computing mitre corners in the case
@@ -429,13 +429,13 @@ OffsetSegmentGenerator::addInsideTurn(int orientation, bool addStartPoint)
// (But not too short, since that would defeat it's purpose).
// This is the purpose of the closingSegLengthFactor heuristic value.
* The intersection test above is vulnerable to robustness errors;
- * i.e. it may be that the offsets should intersect very close to
- * their endpoints, but aren't reported as such due to rounding.
- * To handle this situation appropriately, we use the following test:
- * If the offset points are very close, don't add closing segments
- * but simply use one of the offset points
+ * i.e. it may be that the offsets should intersect very close to
+ * their endpoints, but aren't reported as such due to rounding.
+ * To handle this situation appropriately, we use the following test:
+ * If the offset points are very close, don't add closing segments
+ * but simply use one of the offset points
if(offset0.p1.distance(offset1.p0) <
@@ -481,7 +481,7 @@ OffsetSegmentGenerator::addMitreJoin(const geom::Coordinate& p,
const geom::LineSegment& p_offset1,
double p_distance)
* This computation is unstable if the offset segments are nearly collinear.
* However, this situation should have been eliminated earlier by the check
* for whether the offset segment endpoints are almost coincident
diff --git a/src/operation/buffer/SubgraphDepthLocater.cpp b/src/operation/buffer/SubgraphDepthLocater.cpp
index 9c8ec42..e1f9698 100644
--- a/src/operation/buffer/SubgraphDepthLocater.cpp
+++ b/src/operation/buffer/SubgraphDepthLocater.cpp
@@ -107,13 +107,13 @@ public:
int
compareTo(const DepthSegment& other) const
* try and compute a determinate orientation for the segments.
* Test returns 1 if other is left of this (i.e. this > other)
int orientIndex = upwardSeg.orientationIndex(&(other.upwardSeg));
* If comparison between this and other is indeterminate,
* try the opposite call order.
* orientationIndex value is 1 if this is left of other,
@@ -213,7 +213,7 @@ SubgraphDepthLocater::findStabbedSegments(
vector<DepthSegment*>& stabbedSegments)
* Check all forward DirectedEdges only. This is still general,
* because each Edge has a forward DirectedEdge.
index 0c038ef..923dfc3 100644
@@ -294,7 +294,7 @@ DistanceOp::computeFacetDistance()
array<unique_ptr<GeometryLocation>, 2> locGeom;
* Geometries are not wholly inside, so compute distance from lines
* and points of one to lines and points of the other
diff --git a/src/operation/linemerge/LineSequencer.cpp b/src/operation/linemerge/LineSequencer.cpp
index 7eb82e6..f4e6edb 100644
--- a/src/operation/linemerge/LineSequencer.cpp
+++ b/src/operation/linemerge/LineSequencer.cpp
@@ -73,7 +73,7 @@ LineSequencer::isSequenced(const Geometry* geom)
const Coordinate* startNode = &(line.getCoordinateN(0));
const Coordinate* endNode = &(line.getCoordinateN(line.getNumPoints() - 1));
* If this linestring is connected to a previous subgraph,
* geom is not sequenced
diff --git a/src/operation/overlay/PointBuilder.cpp b/src/operation/overlay/PointBuilder.cpp
index 851f9c2..c92325f 100644
--- a/src/operation/overlay/PointBuilder.cpp
+++ b/src/operation/overlay/PointBuilder.cpp
@@ -79,7 +79,7 @@ PointBuilder::extractNonCoveredResultNodes(OverlayOp::OpCode opCode)
if(n->getEdges()->getDegree() == 0 ||
opCode == OverlayOp::opINTERSECTION) {
* For nodes on edges, only INTERSECTION can result
* in edge nodes being included even
* if none of their incident edges are included
diff --git a/src/operation/overlay/snap/GeometrySnapper.cpp b/src/operation/overlay/snap/GeometrySnapper.cpp
index 1760919..adffeb3 100644
--- a/src/operation/overlay/snap/GeometrySnapper.cpp
+++ b/src/operation/overlay/snap/GeometrySnapper.cpp
@@ -161,7 +161,7 @@ GeometrySnapper::computeOverlaySnapTolerance(const geom::Geometry& g)
double snapTolerance = computeSizeBasedSnapTolerance(g);
* Overlay is carried out in the precision model
* of the two inputs.
* If this precision model is of type FIXED, then the snap tolerance
@@ -199,7 +199,7 @@ GeometrySnapper::snap(const geom::Geometry& g0,
GeometrySnapper snapper0(g0);
snapGeom.first = snapper0.snapTo(g1, snapTolerance);
* Snap the second geometry to the snapped first geometry
* (this strategy minimizes the number of possible different
* points in the result)
diff --git a/src/operation/overlay/snap/LineStringSnapper.cpp b/src/operation/overlay/snap/LineStringSnapper.cpp
index a06b99d..aadef3b 100644
--- a/src/operation/overlay/snap/LineStringSnapper.cpp
+++ b/src/operation/overlay/snap/LineStringSnapper.cpp
@@ -406,7 +406,7 @@ LineStringSnapper::findSegmentToSnap(
cerr << " Checking segment " << seg << endl;
#endif
* Check if the snap pt is equal to one of
* the segment endpoints.
diff --git a/src/operation/predicate/RectangleContains.cpp b/src/operation/predicate/RectangleContains.cpp
index adb1c83..4c6d282 100644
--- a/src/operation/predicate/RectangleContains.cpp
+++ b/src/operation/predicate/RectangleContains.cpp
@@ -133,7 +133,7 @@ RectangleContains::isLineSegmentContainedInBoundary(const Coordinate& p0,
* Either
* both x and y values are different
* or
diff --git a/src/operation/relate/RelateNodeGraph.cpp b/src/operation/relate/RelateNodeGraph.cpp
index 0477aaf..f3bb52e 100644
--- a/src/operation/relate/RelateNodeGraph.cpp
+++ b/src/operation/relate/RelateNodeGraph.cpp
@@ -61,13 +61,13 @@ RelateNodeGraph::build(GeometryGraph* geomGraph)
// compute nodes for intersections between previously noded edges
computeIntersectionNodes(geomGraph, 0);
* Copy the labelling for the nodes in the parent Geometry. These override
* any labels determined by intersections.
copyNodesAndLabels(geomGraph, 0);
* Build EdgeEnds for all intersections.
EdgeEndBuilder eeBuilder;
diff --git a/src/operation/union/CascadedUnion.cpp b/src/operation/union/CascadedUnion.cpp
index 5cae112..f320df1 100644
--- a/src/operation/union/CascadedUnion.cpp
+++ b/src/operation/union/CascadedUnion.cpp
@@ -47,7 +47,7 @@ CascadedUnion::Union()
geomFactory = inputGeoms->front()->getFactory();
* A spatial index to organize the collection
* into groups of close geometries.
* This makes unioning more efficient, since vertices are more likely
@@ -71,7 +71,7 @@ geom::Geometry*
CascadedUnion::unionTree(
index::strtree::ItemsList* geomTree)
* Recursively unions all subtrees in the list into single geometries.
* The result is a list of Geometry's only
diff --git a/src/operation/union/OverlapUnion.cpp b/src/operation/union/OverlapUnion.cpp
index 49f43c4..1014bce 100644
--- a/src/operation/union/OverlapUnion.cpp
+++ b/src/operation/union/OverlapUnion.cpp
@@ -37,7 +37,7 @@ std::unique_ptr<Geometry>
OverlapUnion::doUnion()
Envelope overlapEnv = overlapEnvelope(g0, g1);
* If no overlap, can just combine the geometries
if (overlapEnv.isNull()) {
@@ -112,7 +112,7 @@ OverlapUnion::unionFull(const Geometry* geom0, const Geometry* geom1)
return geom0->Union(geom1);
catch (geos::util::TopologyException &) {
* If the overlay union fails,
* try a buffer union, which often succeeds
diff --git a/src/operation/union/UnaryUnionOp.cpp b/src/operation/union/UnaryUnionOp.cpp
index df60a05..be861c8 100644
--- a/src/operation/union/UnaryUnionOp.cpp
+++ b/src/operation/union/UnaryUnionOp.cpp
@@ -72,7 +72,7 @@ UnaryUnionOp::Union()
return ret;
* For points and lines, only a single union operation is
* required, since the OGC model allowings self-intersecting
* MultiPoint and MultiLineStrings.
@@ -115,7 +115,7 @@ UnaryUnionOp::Union()
polygons.end()));
* Performing two unions is somewhat inefficient,
* but is mitigated by unioning lines and points first
diff --git a/src/operation/valid/ConnectedInteriorTester.cpp b/src/operation/valid/ConnectedInteriorTester.cpp
index be73d9a..a2770f3 100644
--- a/src/operation/valid/ConnectedInteriorTester.cpp
+++ b/src/operation/valid/ConnectedInteriorTester.cpp
@@ -253,7 +253,7 @@ ConnectedInteriorTester::visitInteriorRing(const LineString* ring, PlanarGraph&
const CoordinateSequence* pts = ring->getCoordinatesRO();
const Coordinate& pt0 = pts->getAt(0);
* Find first point in coord list different to initial point.
* Need special check since the first point may be repeated.
diff --git a/src/operation/valid/ConsistentAreaTester.cpp b/src/operation/valid/ConsistentAreaTester.cpp
index 445add1..325aae3 100644
--- a/src/operation/valid/ConsistentAreaTester.cpp
+++ b/src/operation/valid/ConsistentAreaTester.cpp
@@ -61,14 +61,14 @@ ConsistentAreaTester::isNodeConsistentArea()
using geomgraph::index::SegmentIntersector;
* To fully check validity, it is necessary to
* compute ALL intersections, including self-intersections within a single edge.
unique_ptr<SegmentIntersector> intersector(geomGraph->computeSelfNodes(&li, true, true));
- * A proper intersection means that the area is not consistent.
+ * A proper intersection means that the area is not consistent.
if(intersector->hasProperIntersection()) {
invalidPoint = intersector->getProperIntersectionPoint();
return false;
diff --git a/src/operation/valid/IndexedNestedRingTester.cpp b/src/operation/valid/IndexedNestedRingTester.cpp
index 26f7ea4..6ce774a 100644
--- a/src/operation/valid/IndexedNestedRingTester.cpp
+++ b/src/operation/valid/IndexedNestedRingTester.cpp
@@ -63,7 +63,7 @@ IndexedNestedRingTester::isNonNested()
searchRing,
graph);
* If no non-node pts can be found, this means
* that the searchRing touches ALL of the innerRing vertices.
* This indicates an invalid polygon, since either
diff --git a/src/precision/GeometryPrecisionReducer.cpp b/src/precision/GeometryPrecisionReducer.cpp
index 4717af3..e4d824d 100644
--- a/src/precision/GeometryPrecisionReducer.cpp
+++ b/src/precision/GeometryPrecisionReducer.cpp
@@ -46,7 +46,7 @@ GeometryPrecisionReducer::reducePointwise(const Geometry& geom)
GeometryEditor geomEdit(newFactory);
* For polygonal geometries, collapses are always removed, in order
* to produce correct topology
@@ -102,7 +102,7 @@ GeometryPrecisionReducer::GeometryPrecisionReducer(const GeometryFactory& change
GeometryPrecisionReducer::fixPolygonalTopology(const geom::Geometry& geom)
* If precision model was *not* changed, need to flip
* geometry to targetPM, buffer in that model, then flip back
diff --git a/src/precision/PrecisionReducerCoordinateOperation.cpp b/src/precision/PrecisionReducerCoordinateOperation.cpp
index 91649df..ce76bbb 100644
--- a/src/precision/PrecisionReducerCoordinateOperation.cpp
+++ b/src/precision/PrecisionReducerCoordinateOperation.cpp
@@ -59,7 +59,7 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
// much as possible.
std::unique_ptr<CoordinateSequence> noRepeatedCoords = operation::valid::RepeatedPointRemover::removeRepeatedPoints(reducedCoords.get());
* Check to see if the removal of repeated points
* collapsed the coordinate List to an invalid length
* for the type of the parent geometry.
diff --git a/src/precision/SimpleGeometryPrecisionReducer.cpp b/src/precision/SimpleGeometryPrecisionReducer.cpp
index 6b22555..b4fe2dc 100644
--- a/src/precision/SimpleGeometryPrecisionReducer.cpp
+++ b/src/precision/SimpleGeometryPrecisionReducer.cpp
@@ -135,7 +135,7 @@ SimpleGeometryPrecisionReducer::SimpleGeometryPrecisionReducer(
//newPrecisionModel = pm;
* Sets whether the reduction will result in collapsed components
* being removed completely, or simply being collapsed to an (invalid)
* Geometry of the same type.
diff --git a/src/simplify/TaggedLineStringSimplifier.cpp b/src/simplify/TaggedLineStringSimplifier.cpp
index 64ebed3..f778cc9 100644
--- a/src/simplify/TaggedLineStringSimplifier.cpp
+++ b/src/simplify/TaggedLineStringSimplifier.cpp
@@ -113,7 +113,7 @@ TaggedLineStringSimplifier::simplifySection(std::size_t i,
bool isValidToSimplify = true;
* Following logic ensures that there is enough points in the
* output line.
* If there is already more points than the minimum, there's
diff --git a/src/triangulate/IncrementalDelaunayTriangulator.cpp b/src/triangulate/IncrementalDelaunayTriangulator.cpp
index d20421d..d4cf79d 100644
--- a/src/triangulate/IncrementalDelaunayTriangulator.cpp
+++ b/src/triangulate/IncrementalDelaunayTriangulator.cpp
@@ -44,7 +44,7 @@ IncrementalDelaunayTriangulator::insertSites(const VertexList& vertices)
QuadEdge&
IncrementalDelaunayTriangulator::insertSite(const Vertex& v)
* This code is based on Guibas and Stolfi (1985), with minor modifications
* and a bug fix from Dani Lischinski (Graphic Gems 1993). (The modification
* I believe is the test for the inserted site falling exactly on an
@@ -68,7 +68,7 @@ IncrementalDelaunayTriangulator::insertSite(const Vertex& v)
subdiv->remove(e->oNext());
* Connect the new point to the vertices of the containing triangle
* (or quadrilateral, if the new point fell on an existing edge.)
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index bc4a1ba..1a4e249 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -152,7 +152,7 @@ QuadEdgeSubdivision::locateFromEdge(const Vertex& v,
for(;;) {
++iter;
* So far it has always been the case that failure to locate indicates an
* invalid subdivision. So just fail completely. (An alternative would be
* to perform an exhaustive search for the containing triangle, but this
diff --git a/tests/unit/precision/GeometryPrecisionReducerTest.cpp b/tests/unit/precision/GeometryPrecisionReducerTest.cpp
index f82446e..27c0093 100644
--- a/tests/unit/precision/GeometryPrecisionReducerTest.cpp
+++ b/tests/unit/precision/GeometryPrecisionReducerTest.cpp
@@ -109,7 +109,7 @@ void object::test<4>
GeometryPtr g1(reader_.read("POLYGON (( 0 0, 0 1.4, .4 .4, .4 0, 0 0 ))"));
diff --git a/tests/xmltester/BufferResultMatcher.cpp b/tests/xmltester/BufferResultMatcher.cpp
index 735c535..54570e3 100644
--- a/tests/xmltester/BufferResultMatcher.cpp
+++ b/tests/xmltester/BufferResultMatcher.cpp
@@ -41,7 +41,7 @@ BufferResultMatcher::isBufferResultMatch(const geom::Geometry& actualBuffer,
return true;
* MD - need some more checks here - symDiffArea won't catch
* very small holes ("tears")
* near the edge of computed buffers (which can happen
commit 736e38ba78535df389b344a636feb1b40b4d45ee
Author: nila <n_larsson at yahoo.com>
Date: Thu Oct 3 13:30:19 2019 +0200
Fix correct doxygen comment block style
diff --git a/include/geos/algorithm/Angle.h b/include/geos/algorithm/Angle.h
index d329a78..c8aec27 100644
--- a/include/geos/algorithm/Angle.h
+++ b/include/geos/algorithm/Angle.h
@@ -53,14 +53,14 @@ public:
static const int NONE = Orientation::COLLINEAR;
/// Converts from radians to degrees.
/// @param radians an angle in radians
/// @return the angle in degrees
static double toDegrees(double radians);
/// Converts from degrees to radians.
/// @param angleDegrees an angle in degrees
/// @return the angle in radians
@@ -69,7 +69,7 @@ public:
/// \brief
/// Returns the angle of the vector from p0 to p1,
/// relative to the positive X-axis.
/// The angle is normalized to be in the range [ -Pi, Pi ].
/// @return the normalized angle (in radians) that p0-p1 makes
@@ -90,7 +90,7 @@ public:
static double angle(const geom::Coordinate& p);
/// Tests whether the angle between p0-p1-p2 is acute.
/// An angle is acute if it is less than 90 degrees.
/// Note: this implementation is not precise (determistic) for
@@ -105,7 +105,7 @@ public:
const geom::Coordinate& p2);
/// Tests whether the angle between p0-p1-p2 is obtuse.
/// An angle is obtuse if it is greater than 90 degrees.
@@ -120,7 +120,7 @@ public:
/// Returns the unoriented smallest angle between two vectors.
/// The computed angle will be in the range [0, Pi).
/// @param tip1 the tip of one vector
@@ -133,7 +133,7 @@ public:
const geom::Coordinate& tip2);
/// Returns the oriented smallest angle between two vectors.
/// The computed angle will be in the range (-Pi, Pi].
/// A positive result corresponds to a counterclockwise rotation
/// from v1 to v2;
@@ -149,7 +149,7 @@ public:
/// Computes the interior angle between two segments of a ring.
/// The ring is assumed to be oriented in a clockwise direction.
/// The computed angle will be in the range [0, 2Pi]
@@ -207,7 +207,7 @@ public:
/// Computes the unoriented smallest difference between two angles.
/// The angles are assumed to be normalized to the range [-Pi, Pi].
/// The result will be in the range [0, Pi].
diff --git a/include/geos/algorithm/LineIntersector.h b/include/geos/algorithm/LineIntersector.h
index 94b041a..771a524 100644
--- a/include/geos/algorithm/LineIntersector.h
+++ b/include/geos/algorithm/LineIntersector.h
@@ -56,7 +56,7 @@ public:
/// Computes the "edge distance" of an intersection point p in an edge.
/// The edge distance is a metric of the point along the edge.
/// The metric used is a robust and easy to compute metric function.
/// It is <b>not</b> equivalent to the usual Euclidean metric.
@@ -106,7 +106,7 @@ public:
bool isInteriorIntersection(int inputLineIndex);
/// Force computed intersection to be rounded to a given precision model.
/// No getter is provided, because the precision model is not required
/// to be specified.
/// @param newPM the PrecisionModel to use for rounding
@@ -118,14 +118,14 @@ public:
/// Compute the intersection of a point p and the line p1-p2.
/// This function computes the boolean value of the hasIntersection test.
/// The actual value of the intersection (if there is one)
/// is equal to the value of <code>p</code>.
void computeIntersection(const geom::Coordinate& p, const geom::Coordinate& p1, const geom::Coordinate& p2);
- /// Same as above but doen's compute intersection point. Faster.
+ /// Same as above but doesn't compute intersection point. Faster.
static bool hasIntersection(const geom::Coordinate& p, const geom::Coordinate& p1, const geom::Coordinate& p2);
// These are deprecated, due to ambiguous naming
@@ -164,7 +164,7 @@ public:
/// Returns the number of intersection points found.
/// This will be either 0, 1 or 2.
size_t
@@ -175,7 +175,7 @@ public:
/// Returns the intIndex'th intersection point
/// @param intIndex is 0 or 1
/// @return the intIndex'th intersection point
@@ -187,7 +187,7 @@ public:
/// Returns false if both numbers are zero.
/// @return true if both numbers are positive or if both numbers are negative.
static bool isSameSignAndNonZero(double a, double b);
diff --git a/include/geos/geom.h b/include/geos/geom.h
index 9a555b4..86d54e2 100644
--- a/include/geos/geom.h
+++ b/include/geos/geom.h
@@ -91,7 +91,7 @@
namespace geos {
/// Contains the <CODE>Geometry</CODE> interface hierarchy and supporting classes.
/// The Java Topology Suite (JTS) is a Java API that implements a core
/// set of spatial data operations using an explicit precision model
/// and robust geometric algorithms. JTS is int ended to be used in the
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index 0b4297e..d255713 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -160,7 +160,7 @@ public:
CoordinateSequence* c);
/// Return position of a Coordinate, or -1 if not found
/// FIXME: return std::size_t, using numeric_limits<std::size_t>::max
/// as 'not found' value.
diff --git a/include/geos/geom/Dimension.h b/include/geos/geom/Dimension.h
index 0cf0dd8..17d7ce5 100644
--- a/include/geos/geom/Dimension.h
+++ b/include/geos/geom/Dimension.h
@@ -22,7 +22,7 @@ namespace geos {
namespace geom { // geos::geom
/// Constants representing the dimensions of a point, a curve and a surface.
/// Also, constants representing the dimensions of the empty geometry and
/// non-empty geometries, and a wildcard dimension meaning "any dimension".
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index a33d03f..85a1f58 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -153,7 +153,7 @@ public:
const Geometry* exemplar) const;
/// Converts an Envelope to a Geometry.
/// Returned Geometry can be a Point, a Polygon or an EMPTY geom.
std::unique_ptr<Geometry> toGeometry(const Envelope* envelope) const;
@@ -415,7 +415,7 @@ public:
void destroyGeometry(Geometry* g) const;
/// Request that the instance is deleted.
/// It will really be deleted only after last child Geometry is
/// deleted. Do not use the instance anymore after calling this function
/// (unless you're a live child!).
diff --git a/include/geos/geom/LineSegment.h b/include/geos/geom/LineSegment.h
index 38191d9..8928750 100644
--- a/include/geos/geom/LineSegment.h
+++ b/include/geos/geom/LineSegment.h
@@ -90,13 +90,13 @@ public:
double getLength() const;
/// Tests whether the segment is horizontal.
/// @return <code>true</code> if the segment is horizontal
bool isHorizontal() const;
/// Tests whether the segment is vertical.
/// @return <code>true</code> if the segment is vertical
bool isVertical() const;
diff --git a/include/geos/geom/MultiPolygon.h b/include/geos/geom/MultiPolygon.h
index e8f482b..9deab86 100644
--- a/include/geos/geom/MultiPolygon.h
+++ b/include/geos/geom/MultiPolygon.h
@@ -49,7 +49,7 @@ namespace geom { // geos::geom
#endif
/// Models a collection of {@link Polygon}s.
/// As per the OGC SFS specification,
/// the Polygons in a MultiPolygon may not overlap,
/// and may only touch at single points.
diff --git a/include/geos/geom/PrecisionModel.h b/include/geos/geom/PrecisionModel.h
index f196522..7ba0c9b 100644
--- a/include/geos/geom/PrecisionModel.h
+++ b/include/geos/geom/PrecisionModel.h
PrecisionModel(void);
/// Creates a PrecisionModel specifying an explicit precision model type.
/// If the model type is FIXED the scale factor will default to 1.
/// @param nModelType the type of the precision model
@@ -165,7 +165,7 @@ public:
/// The maximum precise value representable in a double.
/// Since IEE754 double-precision numbers allow 53 bits of mantissa,
/// the value is equal to 2^53 - 1.
/// This provides <i>almost</i> 16 decimal digits of precision.
@@ -190,7 +190,7 @@ public:
void makePrecise(Coordinate* coord) const;
/// Tests whether the precision model supports floating point
/// @return <code>true</code> if the precision model supports
/// floating point
@@ -199,7 +199,7 @@ public:
/// \brief
/// Returns the maximum number of significant digits provided by
/// this precision model.
/// Intended for use by routines which need to print out precise
/// values.
@@ -209,7 +209,7 @@ public:
int getMaximumSignificantDigits() const;
/// Gets the type of this PrecisionModel
/// @return the type of this PrecisionModel
Type getType() const;
@@ -218,7 +218,7 @@ public:
double getScale() const;
/// Returns the x-offset used to obtain a precise coordinate.
/// @return the amount by which to subtract the x-coordinate before
/// multiplying by the scale
/// @deprecated Offsets are no longer used
@@ -226,7 +226,7 @@ public:
double getOffsetX() const;
/// Returns the y-offset used to obtain a precise coordinate.
/// @return the amount by which to subtract the y-coordinate before
@@ -281,7 +281,7 @@ public:
/// \brief
/// Compares this PrecisionModel object with the specified object
/// for order.
/// A PrecisionModel is greater than another if it provides greater
/// precision.
/// The comparison is based on the value returned by the
diff --git a/include/geos/geomgraph/DirectedEdge.h b/include/geos/geomgraph/DirectedEdge.h
index 5f2ba1e..9671801 100644
--- a/include/geos/geomgraph/DirectedEdge.h
+++ b/include/geos/geomgraph/DirectedEdge.h
@@ -85,7 +85,7 @@ public:
int getDepthDelta() const;
/// Marks both DirectedEdges attached to a given Edge.
/// This is used for edges corresponding to lines, which will only
/// appear oriented in a single direction in the result.
diff --git a/include/geos/geomgraph/EdgeIntersection.h b/include/geos/geomgraph/EdgeIntersection.h
index 5684b97..f8deadf 100644
--- a/include/geos/geomgraph/EdgeIntersection.h
+++ b/include/geos/geomgraph/EdgeIntersection.h
@@ -102,7 +102,7 @@ public:
/// Strict weak ordering operator for EdgeIntersection
/// This is the C++ equivalent of JTS's compareTo
inline bool
operator< (const EdgeIntersection& ei1, const EdgeIntersection& ei2)
diff --git a/include/geos/geomgraph/EdgeRing.h b/include/geos/geomgraph/EdgeRing.h
index f38117a..c117967 100644
--- a/include/geos/geomgraph/EdgeRing.h
+++ b/include/geos/geomgraph/EdgeRing.h
@@ -71,7 +71,7 @@ public:
bool isHole();
* Return a pointer to the LinearRing owned by
* this object. Make a copy if you need it beyond
* this objects's lifetime.
@@ -145,7 +145,7 @@ protected:
const geom::GeometryFactory* geometryFactory;
- /// throw(const TopologyException &)
+ /// @throws util::TopologyException
void computePoints(DirectedEdge* newStart);
void mergeLabel(const Label& deLabel);
diff --git a/include/geos/noding/OrientedCoordinateArray.h b/include/geos/noding/OrientedCoordinateArray.h
index 7b648ec..2d05ac2 100644
--- a/include/geos/noding/OrientedCoordinateArray.h
+++ b/include/geos/noding/OrientedCoordinateArray.h
@@ -88,7 +88,7 @@ private:
* @param pts the array to test
* @return <code>true</code> if the points are oriented forwards
- * @return <code>false</code if the points are oriented in reverse
+ * @return <code>false</code> if the points are oriented in reverse
static bool orientation(const geom::CoordinateSequence& pts);
@@ -100,7 +100,7 @@ private:
/// Strict weak ordering operator for OrientedCoordinateArray
inline bool
operator< (const OrientedCoordinateArray& oca1,
diff --git a/include/geos/noding/SegmentNode.h b/include/geos/noding/SegmentNode.h
index ef2712e..bf85019 100644
--- a/include/geos/noding/SegmentNode.h
+++ b/include/geos/noding/SegmentNode.h
@@ -66,7 +66,7 @@ public:
size_t segmentIndex;
/// Construct a node on the given NodedSegmentString
/// @param ss the parent NodedSegmentString
/// @param nCoord the coordinate of the intersection, will be copied
diff --git a/include/geos/noding/SegmentString.h b/include/geos/noding/SegmentString.h
index 407efa7..53a2cb8 100644
--- a/include/geos/noding/SegmentString.h
+++ b/include/geos/noding/SegmentString.h
@@ -93,7 +93,7 @@ public:
/// \brief
/// Return a pointer to the CoordinateSequence associated
/// with this SegmentString.
/// @note The CoordinateSequence is owned by this SegmentString!
virtual geom::CoordinateSequence* getCoordinates() const = 0;
diff --git a/include/geos/operation/buffer/BufferBuilder.h b/include/geos/operation/buffer/BufferBuilder.h
index 3a0174c..ded0ba7 100644
--- a/include/geos/operation/buffer/BufferBuilder.h
+++ b/include/geos/operation/buffer/BufferBuilder.h
@@ -222,7 +222,7 @@ private:
/// \brief
/// Return the externally-set noding::Noder OR a newly created
/// one using the given precisionModel.
/// NOTE: if an externally-set noding::Noder is available no
/// check is performed to ensure it will use the
/// given PrecisionModel
diff --git a/include/geos/operation/buffer/BufferParameters.h b/include/geos/operation/buffer/BufferParameters.h
index 9f70690..7ace587 100644
--- a/include/geos/operation/buffer/BufferParameters.h
+++ b/include/geos/operation/buffer/BufferParameters.h
@@ -87,7 +87,7 @@ public:
/// \brief
/// The default number of facets into which to divide a fillet
/// of 90 degrees.
/// A value of 8 gives less than 2% max error in the buffer distance.
/// For a max error of < 1%, use QS = 12.
/// For a max error of < 0.1%, use QS = 18.
@@ -95,7 +95,7 @@ public:
static const int DEFAULT_QUADRANT_SEGMENTS = 8;
/// The default mitre limit
/// Allows fairly pointy mitres.
static const double DEFAULT_MITRE_LIMIT; // 5.0 (in .cpp file)
@@ -104,7 +104,7 @@ public:
BufferParameters();
/// Creates a set of parameters with the given quadrantSegments value.
/// @param quadrantSegments the number of quadrant segments to use
BufferParameters(int quadrantSegments);
@@ -112,7 +112,7 @@ public:
/// \brief
/// given quadrantSegments and endCapStyle values.
/// @param endCapStyle the end cap style to use
@@ -121,7 +121,7 @@ public:
/// \brief
/// given parameter values.
/// @param joinStyle the join style to use
@@ -131,7 +131,7 @@ public:
JoinStyle joinStyle, double mitreLimit);
/// Gets the number of quadrant segments which will be used
/// @return the number of quadrant segments
int
@@ -143,7 +143,7 @@ public:
/// \brief
/// Sets the number of line segments used to approximate
/// an angle fillet.
/// - If <tt>quadSegs</tt> >= 1, joins are round,
/// and <tt>quadSegs</tt> indicates the number of
/// segments to use to approximate a quarter-circle.
@@ -166,15 +166,13 @@ public:
/// (in other words, the computed buffer curve is always inside
/// the true curve).
- /// @param quadSegs the number of segments in a
- /// fillet for a quadrant
+ /// @param quadSegs the number of segments in a fillet for a quadrant
void setQuadrantSegments(int quadSegs);
/// \brief
/// Computes the maximum distance error due to a given level
/// of approximation to a true arc.
/// @param quadSegs the number of segments used to approximate
/// a quarter-circle
/// @return the error of approximation
@@ -182,7 +180,7 @@ public:
static double bufferDistanceError(int quadSegs);
/// Gets the end cap style.
/// @return the end cap style
EndCapStyle
@@ -192,7 +190,7 @@ public:
/// Specifies the end cap style of the generated buffer.
/// The styles supported are CAP_ROUND, CAP_BUTT,
/// and CAP_SQUARE.
@@ -207,7 +205,7 @@ public:
/// Gets the join style.
/// @return the join style
JoinStyle
@@ -219,10 +217,10 @@ public:
/// \brief
/// Sets the join style for outside (reflex) corners between
/// line segments.
/// Allowable values are JOIN_ROUND (which is the default),
/// JOIN_MITRE and JOIN_BEVEL.
/// @param style the code for the join style
void
@@ -232,7 +230,7 @@ public:
/// Gets the mitre ratio limit.
/// @return the limit value
double
@@ -242,7 +240,7 @@ public:
/// Sets the limit on the mitre ratio used for very sharp corners.
/// The mitre ratio is the ratio of the distance from the corner
/// to the end of the mitred offset corner.
/// When two line segments meet at a sharp angle,
diff --git a/include/geos/operation/buffer/BufferSubgraph.h b/include/geos/operation/buffer/BufferSubgraph.h
index 9e4c4e1..2393299 100644
--- a/include/geos/operation/buffer/BufferSubgraph.h
+++ b/include/geos/operation/buffer/BufferSubgraph.h
@@ -80,7 +80,7 @@ private:
void addReachable(geomgraph::Node* startNode);
/// Adds the argument node and all its out edges to the subgraph
/// @param node the node to add
/// @param nodeStack the current set of nodes being traversed
diff --git a/include/geos/operation/buffer/OffsetSegmentGenerator.h b/include/geos/operation/buffer/OffsetSegmentGenerator.h
index f9974a6..97b53b2 100644
--- a/include/geos/operation/buffer/OffsetSegmentGenerator.h
+++ b/include/geos/operation/buffer/OffsetSegmentGenerator.h
@@ -94,7 +94,7 @@ public:
const geom::Coordinate& nS2, int nSide);
/// Get coordinates by taking ownership of them
/// After this call, the coordinates reference in
/// this object are dropped. Calling twice will
/// segfault...
@@ -203,7 +203,7 @@ private:
int closingSegLengthFactor; // 1;
/// Owned by this object, destroyed by dtor
/// This actually gets created multiple times
/// and each of the old versions is pushed
/// to the ptLists std::vector to ensure all
@@ -237,7 +237,7 @@ private:
void addCollinear(bool addStartPoint);
/// The mitre will be beveled if it exceeds the mitre ratio limit.
/// @param offset0 the first offset segment
/// @param offset1 the second offset segment
/// @param distance the offset distance
@@ -248,7 +248,7 @@ private:
double distance);
/// Adds a limited mitre join connecting the two reflex offset segments.
/// A limited mitre is a mitre which is beveled at the distance
/// determined by the mitre ratio limit.
@@ -265,7 +265,7 @@ private:
/// \brief
/// Adds a bevel join connecting the two offset segments
/// around a reflex corner.
@@ -289,14 +289,14 @@ private:
static const double SIMPLIFY_FACTOR; // 100.0;
/// Adds the offset points for an outside (convex) turn
/// @param orientation
/// @param addStartPoint
void addOutsideTurn(int orientation, bool addStartPoint);
/// Adds the offset points for an inside (concave) turn
diff --git a/include/geos/operation/buffer/OffsetSegmentString.h b/include/geos/operation/buffer/OffsetSegmentString.h
index c5f699b..b474703 100644
--- a/include/geos/operation/buffer/OffsetSegmentString.h
+++ b/include/geos/operation/buffer/OffsetSegmentString.h
@@ -34,7 +34,7 @@ namespace operation { // geos.operation
namespace buffer { // geos.operation.buffer
/// A dynamic list of the vertices in a constructed offset curve.
/// Automatically removes close vertices
/// which are closer than a given tolerance.
@@ -154,7 +154,7 @@ public:
/// Check that points are a ring
/// add the startpoint again if they are not
void
closeRing()
@@ -172,7 +172,7 @@ public:
/// segfault...
diff --git a/include/geos/operation/linemerge/EdgeString.h b/include/geos/operation/linemerge/EdgeString.h
index 47fce19..e25d653 100644
--- a/include/geos/operation/linemerge/EdgeString.h
+++ b/include/geos/operation/linemerge/EdgeString.h
@@ -60,7 +60,7 @@ private:
geom::CoordinateArraySequence* coordinates;
geom::CoordinateSequence* getCoordinates();
public:
* \brief
* Constructs an EdgeString with the given factory used to
* convert this EdgeString to a LineString
@@ -74,7 +74,7 @@ public:
void add(LineMergeDirectedEdge* directedEdge);
* Converts this EdgeString into a LineString.
geom::LineString* toLineString();
diff --git a/include/geos/operation/overlay/OverlayOp.h b/include/geos/operation/overlay/OverlayOp.h
index 6132f65..24dd64b 100644
--- a/include/geos/operation/overlay/OverlayOp.h
+++ b/include/geos/operation/overlay/OverlayOp.h
@@ -63,7 +63,7 @@ namespace operation { // geos::operation
namespace overlay { // geos::operation::overlay
/// \brief Computes the geometric overlay of two Geometry.
/// The overlay can be used to determine any
/// boolean combination of the geometries.
@@ -72,7 +72,7 @@ class GEOS_DLL OverlayOp: public GeometryGraphOperation {
public:
/// \brief The spatial functions supported by this class.
/// These operations implement various boolean combinations of
/// the resultants of the overlay.
@@ -116,13 +116,13 @@ public:
static bool isResultOfOp(const geomgraph::Label& label, OpCode opCode);
/// \brief This method will handle arguments of Location.NULL correctly
/// @return true if the locations correspond to the opCode
static bool isResultOfOp(geom::Location loc0, geom::Location loc1, OpCode opCode);
/// \brief Construct an OverlayOp with the given Geometry args.
/// Ownership of passed args will remain to caller, and
/// the OverlayOp won't change them in any way.
diff --git a/include/geos/operation/overlay/snap/LineStringSnapper.h b/include/geos/operation/overlay/snap/LineStringSnapper.h
index 7b675f0..65358d7 100644
--- a/include/geos/operation/overlay/snap/LineStringSnapper.h
+++ b/include/geos/operation/overlay/snap/LineStringSnapper.h
@@ -119,7 +119,7 @@ private:
/// \brief
/// Finds a src segment which snaps to (is close to) the given snap
/// point.
/// Only a single segment is selected for snapping.
/// This prevents multiple segments snapping to the same snap vertex,
/// which would almost certainly cause invalid geometry
diff --git a/include/geos/operation/overlay/validate/FuzzyPointLocator.h b/include/geos/operation/overlay/validate/FuzzyPointLocator.h
index 13f2fbe..c029a8a 100644
--- a/include/geos/operation/overlay/validate/FuzzyPointLocator.h
+++ b/include/geos/operation/overlay/validate/FuzzyPointLocator.h
@@ -77,7 +77,7 @@ private:
std::unique_ptr<geom::Geometry> getLineWork(const geom::Geometry& geom);
/// Extracts linework for polygonal components.
/// @param geom the geometry from which to extract
/// @return a lineal geometry containing the extracted linework
std::unique_ptr<geom::Geometry> extractLineWork(const geom::Geometry& geom);
diff --git a/include/geos/operation/sharedpaths/SharedPathsOp.h b/include/geos/operation/sharedpaths/SharedPathsOp.h
index 7275b48..4ca31c3 100644
--- a/include/geos/operation/sharedpaths/SharedPathsOp.h
+++ b/include/geos/operation/sharedpaths/SharedPathsOp.h
@@ -70,7 +70,7 @@ public:
typedef std::vector<geom::LineString*> PathList;
/// Find paths shared between two linear geometries
/// @param g1
/// First geometry. Must be linear.
PathList& oppositeDirection);
/// Constructor
/// @param g1
@@ -103,7 +103,7 @@ public:
SharedPathsOp(const geom::Geometry& g1, const geom::Geometry& g2);
/// Get shared paths
/// @param sameDirection
/// Shared edges having the same direction are pushed
/// onto this vector. They'll be of type geom::LineString.
@@ -122,7 +122,7 @@ public:
private:
/// Get all the linear intersections
/// Ownership of linestring pushed to the given container
/// is transferred to caller. See clearEdges for a deep
/// release if you need one.
@@ -130,7 +130,7 @@ private:
void findLinearIntersections(PathList& to);
/// Check if the given edge goes forward or backward on the given line.
/// PRECONDITION: It is assumed the edge fully lays on the geometry
bool isForward(const geom::LineString& edge,
diff --git a/include/geos/planargraph/Subgraph.h b/include/geos/planargraph/Subgraph.h
index d5a4748..13ba384 100644
--- a/include/geos/planargraph/Subgraph.h
+++ b/include/geos/planargraph/Subgraph.h
@@ -39,7 +39,7 @@ namespace geos {
namespace planargraph { // geos.planargraph
/// \brief A subgraph of a PlanarGraph.
/// A subgraph may contain any subset of {@link Edge}s
/// from the parent graph.
/// It will also automatically contain all {@link DirectedEdge}s
diff --git a/include/geos/precision/PrecisionReducerCoordinateOperation.h b/include/geos/precision/PrecisionReducerCoordinateOperation.h
index 83fe7ec..2c4cf1c 100644
--- a/include/geos/precision/PrecisionReducerCoordinateOperation.h
+++ b/include/geos/precision/PrecisionReducerCoordinateOperation.h
@@ -55,7 +55,7 @@ public:
/// Ownership of returned CoordinateSequence to caller
/// virtual function
std::unique_ptr<geom::CoordinateSequence> edit(const geom::CoordinateSequence* coordinates,
const geom::Geometry* geom) override;
diff --git a/include/geos/simplify/TaggedLineString.h b/include/geos/simplify/TaggedLineString.h
index 1a3c8bf..f6aa95d 100644
--- a/include/geos/simplify/TaggedLineString.h
+++ b/include/geos/simplify/TaggedLineString.h
@@ -53,9 +53,7 @@ namespace simplify { // geos::simplify
/** \brief
- * Contains and owns a list of TaggedLineSegments
+ * Contains and owns a list of TaggedLineSegments.
class GEOS_DLL TaggedLineString {
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 3458d70..977618c 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -252,11 +252,11 @@ WKTWriter::appendLineStringTaggedText(const LineString* lineString, int p_level,
appendLineStringText(lineString, p_level, false, writer);
- * Converts a <code>LinearRing</code> to <LinearRing Tagged Text>
+ * Converts a `LinearRing` to \<LinearRing Tagged Text\>
* format, then appends it to the writer.
- * @param linearRing the <code>LinearRing</code> to process
+ * @param linearRing the `LinearRing` to process
* @param writer the output writer to append to
void
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index 56f59c0..d23c899 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -332,7 +332,7 @@ OffsetCurveSetBuilder::isErodedCompletely(const LinearRing* ring,
return true;
* The following is a heuristic test to determine whether an
* inside buffer will be eroded completely->
* It is based on the fact that the minimum diameter of the ring
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index 877d697..df1e654 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -795,7 +795,7 @@ OverlayOp::computeOverlay(OverlayOp::OpCode opCode)
GEOS_CHECK_FOR_INTERRUPTS();
#ifdef ENABLE_EDGE_NODING_VALIDATOR // {
* Check that the noding completed correctly.
* This test is slow, but necessary in order to catch
diff --git a/src/operation/predicate/RectangleIntersects.cpp b/src/operation/predicate/RectangleIntersects.cpp
index 7736f1e..c8ad09f 100644
--- a/src/operation/predicate/RectangleIntersects.cpp
+++ b/src/operation/predicate/RectangleIntersects.cpp
@@ -20,7 +20,7 @@
#include <geos/operation/predicate/RectangleIntersects.h>
#include <geos/operation/predicate/SegmentIntersectionTester.h>
-/// for EnvelopeIntersectsVisitor inheritance
+// for EnvelopeIntersectsVisitor inheritance
#include <geos/geom/util/ShortCircuitedGeometryVisitor.h>
#include <geos/geom/util/LinearComponentExtracter.h>
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 44a1d32..d9bd493 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -99,14 +99,14 @@ namespace geos {
namespace geounion { // geos.operation.geounion
void
GeometryListHolder::deleteItem(geom::Geometry* item)
delete item;
geom::Geometry*
CascadedPolygonUnion::Union(std::vector<geom::Polygon*>* polys)
@@ -136,7 +136,7 @@ CascadedPolygonUnion::Union()
geomFactory = inputPolys->front()->getFactory();
@@ -160,7 +160,7 @@ geom::Geometry*
CascadedPolygonUnion::unionTree(
index 54e82ac..6b22555 100644
@@ -89,7 +89,7 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
commit 1a2c5d6e5bda9781fa57ec63f6b5cf8ba340b45a
Date: Tue Sep 24 16:28:57 2019 +0200
Add space before doxygen tag
diff --git a/include/geos/algorithm/Centroid.h b/include/geos/algorithm/Centroid.h
index e6d49fc..c70ff67 100644
--- a/include/geos/algorithm/Centroid.h
+++ b/include/geos/algorithm/Centroid.h
@@ -36,7 +36,7 @@ class CoordinateSequence;
namespace geos {
namespace algorithm { // geos::algorithm
-/**\brief
+/** \brief
* Computes the centroid of a [Geometry](@ref geom::Geometry) of any dimension.
* If the geometry is nomimally of higher dimension, but contains only
diff --git a/include/geos/operation/polygonize/EdgeRing.h b/include/geos/operation/polygonize/EdgeRing.h
index 56113c2..211bd11 100644
--- a/include/geos/operation/polygonize/EdgeRing.h
+++ b/include/geos/operation/polygonize/EdgeRing.h
@@ -59,7 +59,7 @@ namespace geos {
namespace polygonize { // geos::operation::polygonize
-/**\brief
+/** \brief
* Represents a ring of PolygonizeDirectedEdge which form
* a ring of a polygon. The ring may be either an outer shell or a hole.
Summary of changes:
benchmarks/algorithm/InteriorPointAreaPerfTest.cpp | 2 +-
.../predicate/RectangleIntersectsPerfTest.cpp | 2 +-
include/geos/algorithm/Angle.h | 18 ++--
include/geos/algorithm/Centroid.h | 2 +-
include/geos/algorithm/Distance.h | 26 ++---
include/geos/algorithm/Intersection.h | 41 ++++----
include/geos/algorithm/Length.h | 19 ++--
include/geos/algorithm/LineIntersector.h | 14 +--
include/geos/algorithm/Orientation.h | 4 +-
include/geos/algorithm/PointLocation.h | 22 ++---
include/geos/geom.h | 2 +-
include/geos/geom/CoordinateSequence.h | 2 +-
include/geos/geom/Dimension.h | 2 +-
include/geos/geom/GeometryFactory.h | 4 +-
include/geos/geom/LineSegment.h | 4 +-
include/geos/geom/MultiPolygon.h | 2 +-
include/geos/geom/PrecisionModel.h | 16 +--
include/geos/geom/prep/PreparedPolygonContains.h | 12 +--
include/geos/geomgraph/DirectedEdge.h | 2 +-
include/geos/geomgraph/EdgeIntersection.h | 2 +-
include/geos/geomgraph/EdgeRing.h | 4 +-
include/geos/noding/OrientedCoordinateArray.h | 4 +-
include/geos/noding/SegmentNode.h | 2 +-
include/geos/noding/SegmentString.h | 2 +-
include/geos/operation/buffer/BufferBuilder.h | 2 +-
include/geos/operation/buffer/BufferParameters.h | 34 +++----
include/geos/operation/buffer/BufferSubgraph.h | 2 +-
.../geos/operation/buffer/OffsetSegmentGenerator.h | 14 +--
.../geos/operation/buffer/OffsetSegmentString.h | 6 +-
include/geos/operation/linemerge/EdgeString.h | 4 +-
include/geos/operation/overlay/OverlayOp.h | 8 +-
.../operation/overlay/snap/LineStringSnapper.h | 2 +-
.../operation/overlay/validate/FuzzyPointLocator.h | 2 +-
include/geos/operation/polygonize/EdgeRing.h | 2 +-
include/geos/operation/sharedpaths/SharedPathsOp.h | 10 +-
include/geos/planargraph/Subgraph.h | 2 +-
.../PrecisionReducerCoordinateOperation.h | 2 +-
include/geos/simplify/TaggedLineString.h | 4 +-
.../quadedge/LastFoundQuadEdgeLocator.h | 14 ++-
src/algorithm/Area.cpp | 10 +-
src/algorithm/ConvexHull.cpp | 2 +-
src/algorithm/InteriorPointArea.cpp | 4 +-
src/algorithm/LineIntersector.cpp | 4 +-
src/algorithm/MinimumBoundingCircle.cpp | 34 +++----
src/algorithm/Orientation.cpp | 2 +-
.../distance/DiscreteHausdorffDistance.cpp | 2 +-
src/algorithm/locate/SimplePointInAreaLocator.cpp | 2 +-
src/geom/Geometry.cpp | 8 +-
src/geom/prep/PreparedLineStringIntersects.cpp | 2 +-
src/geom/prep/PreparedPolygonContainsProperly.cpp | 2 +-
src/geom/util/PointExtracter.cpp | 6 +-
src/geomgraph/DirectedEdgeStar.cpp | 4 +-
src/geomgraph/EdgeEndStar.cpp | 4 +-
src/geomgraph/Position.cpp | 6 +-
src/geomgraph/index/MonotoneChainIndexer.cpp | 4 +-
src/geomgraph/index/SimpleSweepLineIntersector.cpp | 2 +-
src/index/bintree/Bintree.cpp | 12 +--
src/index/bintree/Root.cpp | 14 +--
.../intervalrtree/SortedPackedIntervalRTree.cpp | 8 +-
src/index/quadtree/Root.cpp | 2 +-
src/index/strtree/BoundablePair.cpp | 2 +-
src/index/strtree/SIRtree.cpp | 4 +-
src/index/strtree/STRtree.cpp | 56 +++++------
src/index/sweepline/SweepLineIndex.cpp | 2 +-
src/io/WKTWriter.cpp | 6 +-
src/linearref/ExtractLineByLocation.cpp | 2 +-
src/linearref/LengthIndexOfPoint.cpp | 2 +-
src/linearref/LengthLocationMap.cpp | 2 +-
src/linearref/LocationIndexOfPoint.cpp | 2 +-
src/noding/IteratedNoder.cpp | 2 +-
src/noding/MCIndexNoder.cpp | 2 +-
src/noding/NodingIntersectionFinder.cpp | 2 +-
src/noding/snapround/MCIndexPointSnapper.cpp | 24 ++---
src/operation/buffer/BufferInputLineSimplifier.cpp | 2 +-
src/operation/buffer/BufferParameters.cpp | 4 +-
src/operation/buffer/BufferSubgraph.cpp | 4 +-
src/operation/buffer/OffsetCurveSetBuilder.cpp | 2 +-
src/operation/buffer/OffsetSegmentGenerator.cpp | 26 ++---
src/operation/buffer/SubgraphDepthLocater.cpp | 6 +-
.../distance/ConnectedElementPointFilter.cpp | 8 +-
src/operation/distance/DistanceOp.cpp | 10 +-
src/operation/distance/GeometryLocation.cpp | 28 +++---
src/operation/linemerge/LineMergeEdge.cpp | 4 +-
src/operation/linemerge/LineSequencer.cpp | 2 +-
src/operation/overlay/OverlayOp.cpp | 2 +-
src/operation/overlay/PointBuilder.cpp | 2 +-
src/operation/overlay/snap/GeometrySnapper.cpp | 4 +-
src/operation/overlay/snap/LineStringSnapper.cpp | 2 +-
src/operation/polygonize/BuildArea.cpp | 52 +++++-----
src/operation/predicate/RectangleContains.cpp | 2 +-
src/operation/predicate/RectangleIntersects.cpp | 2 +-
src/operation/relate/EdgeEndBundle.cpp | 38 ++++----
src/operation/relate/RelateComputer.cpp | 24 ++---
src/operation/relate/RelateNodeGraph.cpp | 4 +-
src/operation/union/CascadedPolygonUnion.cpp | 8 +-
src/operation/union/CascadedUnion.cpp | 4 +-
src/operation/union/OverlapUnion.cpp | 4 +-
src/operation/union/UnaryUnionOp.cpp | 4 +-
src/operation/valid/ConnectedInteriorTester.cpp | 2 +-
src/operation/valid/ConsistentAreaTester.cpp | 8 +-
src/operation/valid/IndexedNestedRingTester.cpp | 2 +-
src/operation/valid/IsValidOp.cpp | 12 +--
src/planargraph/Edge.cpp | 12 +--
src/precision/GeometryPrecisionReducer.cpp | 4 +-
.../PrecisionReducerCoordinateOperation.cpp | 2 +-
src/precision/SimpleGeometryPrecisionReducer.cpp | 4 +-
src/simplify/TaggedLineStringSimplifier.cpp | 2 +-
.../IncrementalDelaunayTriangulator.cpp | 4 +-
src/triangulate/quadedge/QuadEdgeSubdivision.cpp | 2 +-
tests/bigtest/GeometryTestFactory.cpp | 28 +++---
.../precision/GeometryPrecisionReducerTest.cpp | 2 +-
tests/xmltester/BufferResultMatcher.cpp | 2 +-
tools/astyle/ASBeautifier.cpp | 48 ++++-----
tools/astyle/ASEnhancer.cpp | 2 +-
tools/astyle/ASFormatter.cpp | 108 ++++++++++-----------
tools/astyle/ASResource.cpp | 10 +-
tools/astyle/astyle_main.cpp | 10 +-
117 files changed, 532 insertions(+), 540 deletions(-)
hooks/post-receive
More information about the geos-commits
