[geos-commits] [SCM] GEOS branch master updated. a921e178f7556fcdca466186b152c4e46a43da96
git at osgeo.org
git at osgeo.org
Mon Dec 2 19:54:26 PST 2019
the project "GEOS".
via a921e178f7556fcdca466186b152c4e46a43da96 (commit)
from 2e3ef091c0c5f6e157e60af3e7f6d762aab83b6c (commit)
revisions in full, below.
commit a921e178f7556fcdca466186b152c4e46a43da96
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Dec 2 22:05:14 2019 -0500
Fix a few clang conversion warnings
diff --git a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
index 9f850de..68da373 100644
--- a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
@@ -109,7 +109,7 @@ void object::test<3>
geoms.push_back(GEOSGeom_createEmptyPoint_r(handle_));
// takes ownership of individual geometries
geom_ = GEOSGeom_createCollection_r(handle_, GEOS_MULTIPOINT,
- geoms.data(), static_cast<int>(geoms.size()));
+ geoms.data(), static_cast<unsigned int>(geoms.size()));
ensure_equals(static_cast<size_t>(GEOSGetNumGeometries_r(handle_, geom_)), geoms.size());
diff --git a/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp b/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp
index 9987750..eb5e51e 100644
--- a/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp
+++ b/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp
@@ -133,10 +133,10 @@ void object::test<6>
FixedSizeCoordinateSequence<1> a(2);
a.setAt({ 1, 2, 3 }, 0);
- ensure_equals(a.getDimension(), 2);
+ ensure_equals(a.getDimension(), 2u);
auto b = a.clone();
- ensure_equals(b->getDimension(), 2);
+ ensure_equals(b->getDimension(), 2u);
ensure(a.getAt(0).equals3D(b->getAt(0)));
diff --git a/tests/unit/noding/SegmentNodeTest.cpp b/tests/unit/noding/SegmentNodeTest.cpp
index d3cc2b7..dbde476 100644
--- a/tests/unit/noding/SegmentNodeTest.cpp
+++ b/tests/unit/noding/SegmentNodeTest.cpp
@@ -54,7 +54,7 @@ void object::test<1>
// Create coordinates sequence
const size_t coords_size = 2;
- auto cs = geos::detail::make_unique<geos::geom::CoordinateArraySequence>(0, coords_size);
+ auto cs = geos::detail::make_unique<geos::geom::CoordinateArraySequence>(0u, coords_size);
ensure(nullptr != cs.get());
diff --git a/tests/unit/operation/buffer/BufferBuilderTest.cpp b/tests/unit/operation/buffer/BufferBuilderTest.cpp
index d8f9b04..e3f4613 100644
--- a/tests/unit/operation/buffer/BufferBuilderTest.cpp
+++ b/tests/unit/operation/buffer/BufferBuilderTest.cpp
@@ -89,7 +89,7 @@ void object::test<1>
params.setEndCapStyle(BufferParameters::CAP_FLAT);
params.setQuadrantSegments(8);
params.setJoinStyle(BufferParameters::JOIN_MITRE);
- params.setMitreLimit(5.57F);
+ params.setMitreLimit(5.57);
//params.setSingleSided(true); // DO NOT switch for non-areal input, see ticket #633
BufferBuilder builder(params);
ensure(distance > 0);
Summary of changes:
tests/unit/capi/GEOSGeom_createCollectionTest.cpp | 2 +-
tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp | 4 ++--
tests/unit/noding/SegmentNodeTest.cpp | 2 +-
tests/unit/operation/buffer/BufferBuilderTest.cpp | 2 +-
4 files changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits
