[geos-commits] [SCM] GEOS branch master updated. f43aa53d27b3889823365317fcf4ff45e60dc90f
git at osgeo.org
git at osgeo.org
Fri Feb 1 11:22:48 PST 2019
the project "GEOS".
via f43aa53d27b3889823365317fcf4ff45e60dc90f (commit)
from a252dd31edfe3e67271de4903cf94a1694d5bb33 (commit)
revisions in full, below.
commit f43aa53d27b3889823365317fcf4ff45e60dc90f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Feb 1 11:18:06 2019 -0800
Apply 4-spaces standard indenting,
120 column wrapping, and some basic
consistency around parens, operators and
function signatures. Code now matches
editorconfig so patches should largely
lack whitespace noise, and folks trying
to "match the code around" should find
it easier to figure out what "match"
means.
Per https://lists.osgeo.org/pipermail/geos-devel/2018-September/008539.html
diff --git a/.astylerc b/.astylerc
new file mode 100644
index 0000000..fb05c50
--- /dev/null
+++ b/.astylerc
@@ -0,0 +1,12 @@
+--style=stroustrup
+--indent=spaces=4
+--max-code-length=120
+--lineend=linux
+--unpad-paren
+--pad-oper
+--align-pointer=type
+--align-reference=type
+--break-closing-braces
+--add-braces
+--break-return-type
+--break-after-logical
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 421862b..2f00af5 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -13,12 +13,12 @@
cmake_minimum_required(VERSION 3.1.3)
if(NOT CMAKE_VERSION)
- set(CMAKE_VERSION
- "${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}")
+ set(CMAKE_VERSION
+ "${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}")
endif()
if(POLICY CMP0048)
- cmake_policy(SET CMP0048 NEW)
+ cmake_policy(SET CMP0048 NEW)
endif()
# Set GEOS project
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index cd22cd4..9f72e40 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -89,146 +89,144 @@ GEOSContextHandle_t handle = NULL;
extern "C" {
-void
-initGEOS (GEOSMessageHandler nf, GEOSMessageHandler ef)
- if ( ! handle )
- handle = initGEOS_r( nf, ef );
- else
- GEOSContext_setNoticeHandler_r(handle, nf);
- GEOSContext_setErrorHandler_r(handle, ef);
- geos::util::Interrupt::cancel();
-void
-finishGEOS ()
- if (handle != NULL) {
- finishGEOS_r( handle );
- handle = NULL;
-GEOSInterruptCallback*
-GEOS_interruptRegisterCallback(GEOSInterruptCallback* cb)
- return geos::util::Interrupt::registerCallback(cb);
-void
-GEOS_interruptRequest()
- geos::util::Interrupt::request();
-void
-GEOS_interruptCancel()
-void
-GEOSFree (void* buffer)
- GEOSFree_r( handle, buffer );
-** relate()-related functions
-** return 0 = false, 1 = true, 2 = error occured
-char
-GEOSDisjoint(const Geometry *g1, const Geometry *g2)
- return GEOSDisjoint_r( handle, g1, g2 );
-char
-GEOSTouches(const Geometry *g1, const Geometry *g2)
- return GEOSTouches_r( handle, g1, g2 );
-char
-GEOSIntersects(const Geometry *g1, const Geometry *g2)
- return GEOSIntersects_r( handle, g1, g2 );
-char
-GEOSCrosses(const Geometry *g1, const Geometry *g2)
- return GEOSCrosses_r( handle, g1, g2 );
-char
-GEOSWithin(const Geometry *g1, const Geometry *g2)
- return GEOSWithin_r( handle, g1, g2 );
+ void
+ initGEOS(GEOSMessageHandler nf, GEOSMessageHandler ef)
+ if(! handle) {
+ handle = initGEOS_r(nf, ef);
+ else {
+ GEOSContext_setNoticeHandler_r(handle, nf);
+ GEOSContext_setErrorHandler_r(handle, ef);
+ geos::util::Interrupt::cancel();
+ void
+ finishGEOS()
+ if(handle != NULL) {
+ finishGEOS_r(handle);
+ handle = NULL;
+ GEOSInterruptCallback*
+ GEOS_interruptRegisterCallback(GEOSInterruptCallback* cb)
+ return geos::util::Interrupt::registerCallback(cb);
+ void
+ GEOS_interruptRequest()
+ geos::util::Interrupt::request();
+ void
+ GEOS_interruptCancel()
+ void
+ GEOSFree(void* buffer)
+ GEOSFree_r(handle, buffer);
+ ** relate()-related functions
+ ** return 0 = false, 1 = true, 2 = error occured
+ char
+ GEOSDisjoint(const Geometry* g1, const Geometry* g2)
+ return GEOSDisjoint_r(handle, g1, g2);
+ char
+ GEOSTouches(const Geometry* g1, const Geometry* g2)
+ return GEOSTouches_r(handle, g1, g2);
+ char
+ GEOSIntersects(const Geometry* g1, const Geometry* g2)
+ return GEOSIntersects_r(handle, g1, g2);
+ char
+ GEOSCrosses(const Geometry* g1, const Geometry* g2)
+ return GEOSCrosses_r(handle, g1, g2);
+ char
+ GEOSWithin(const Geometry* g1, const Geometry* g2)
+ return GEOSWithin_r(handle, g1, g2);
// call g1->contains(g2)
// returns 0 = false
// 1 = true
// 2 = error was trapped
-char
-GEOSContains(const Geometry *g1, const Geometry *g2)
- return GEOSContains_r( handle, g1, g2 );
-char
-GEOSOverlaps(const Geometry *g1, const Geometry *g2)
- return GEOSOverlaps_r( handle, g1, g2 );
-char
-GEOSCovers(const Geometry *g1, const Geometry *g2)
- return GEOSCovers_r( handle, g1, g2 );
-char
-GEOSCoveredBy(const Geometry *g1, const Geometry *g2)
- return GEOSCoveredBy_r( handle, g1, g2 );
+ char
+ GEOSContains(const Geometry* g1, const Geometry* g2)
+ return GEOSContains_r(handle, g1, g2);
+ char
+ GEOSOverlaps(const Geometry* g1, const Geometry* g2)
+ return GEOSOverlaps_r(handle, g1, g2);
+ char
+ GEOSCovers(const Geometry* g1, const Geometry* g2)
+ return GEOSCovers_r(handle, g1, g2);
+ char
+ GEOSCoveredBy(const Geometry* g1, const Geometry* g2)
+ return GEOSCoveredBy_r(handle, g1, g2);
// low-level relate functions
-char
-GEOSRelatePattern(const Geometry *g1, const Geometry *g2, const char *pat)
- return GEOSRelatePattern_r( handle, g1, g2, pat );
+ char
+ GEOSRelatePattern(const Geometry* g1, const Geometry* g2, const char* pat)
+ return GEOSRelatePattern_r(handle, g1, g2, pat);
-char
-GEOSRelatePatternMatch(const char *mat, const char *pat)
- return GEOSRelatePatternMatch_r( handle, mat, pat );
+ char
+ GEOSRelatePatternMatch(const char* mat, const char* pat)
+ return GEOSRelatePatternMatch_r(handle, mat, pat);
-char *
-GEOSRelate(const Geometry *g1, const Geometry *g2)
- return GEOSRelate_r( handle, g1, g2 );
+ char*
+ GEOSRelate(const Geometry* g1, const Geometry* g2)
+ return GEOSRelate_r(handle, g1, g2);
-char *
-GEOSRelateBoundaryNodeRule(const Geometry *g1, const Geometry *g2, int bnr)
- return GEOSRelateBoundaryNodeRule_r( handle, g1, g2, bnr );
+ char*
+ GEOSRelateBoundaryNodeRule(const Geometry* g1, const Geometry* g2, int bnr)
+ return GEOSRelateBoundaryNodeRule_r(handle, g1, g2, bnr);
@@ -236,167 +234,167 @@ GEOSRelateBoundaryNodeRule(const Geometry *g1, const Geometry *g2, int bnr)
-char
-GEOSisValid(const Geometry *g)
- return GEOSisValid_r( handle, g );
+ char
+ GEOSisValid(const Geometry* g)
+ return GEOSisValid_r(handle, g);
-char *
-GEOSisValidReason(const Geometry *g)
- return GEOSisValidReason_r( handle, g );
+ char*
+ GEOSisValidReason(const Geometry* g)
+ return GEOSisValidReason_r(handle, g);
-char
-GEOSisValidDetail(const Geometry *g, int flags,
- char** reason, Geometry ** location)
- return GEOSisValidDetail_r( handle, g, flags, reason, location );
+ char
+ GEOSisValidDetail(const Geometry* g, int flags,
+ char** reason, Geometry** location)
+ return GEOSisValidDetail_r(handle, g, flags, reason, location);
// general purpose
-char
-GEOSEquals(const Geometry *g1, const Geometry *g2)
- return GEOSEquals_r( handle, g1, g2 );
-char
-GEOSEqualsExact(const Geometry *g1, const Geometry *g2, double tolerance)
- return GEOSEqualsExact_r( handle, g1, g2, tolerance );
-int
-GEOSDistance(const Geometry *g1, const Geometry *g2, double *dist)
- return GEOSDistance_r( handle, g1, g2, dist );
-int
-GEOSDistanceIndexed(const Geometry *g1, const Geometry *g2, double *dist)
- return GEOSDistanceIndexed_r( handle, g1, g2, dist );
-int
-GEOSHausdorffDistance(const Geometry *g1, const Geometry *g2, double *dist)
- return GEOSHausdorffDistance_r( handle, g1, g2, dist );
-int
-GEOSHausdorffDistanceDensify(const Geometry *g1, const Geometry *g2, double densifyFrac, double *dist)
- return GEOSHausdorffDistanceDensify_r( handle, g1, g2, densifyFrac, dist );
-int
-GEOSFrechetDistance(const Geometry *g1, const Geometry *g2, double *dist)
- return GEOSFrechetDistance_r( handle, g1, g2, dist );
-int
-GEOSFrechetDistanceDensify(const Geometry *g1, const Geometry *g2, double densifyFrac, double *dist)
- return GEOSFrechetDistanceDensify_r( handle, g1, g2, densifyFrac, dist );
-int
-GEOSArea(const Geometry *g, double *area)
- return GEOSArea_r( handle, g, area );
-int
-GEOSLength(const Geometry *g, double *length)
- return GEOSLength_r( handle, g, length );
-CoordinateSequence *
-GEOSNearestPoints(const Geometry *g1, const Geometry *g2)
- return GEOSNearestPoints_r( handle, g1, g2 );
-Geometry *
-GEOSGeomFromWKT(const char *wkt)
- return GEOSGeomFromWKT_r( handle, wkt );
-char *
-GEOSGeomToWKT(const Geometry *g)
- return GEOSGeomToWKT_r( handle, g );
+ char
+ GEOSEquals(const Geometry* g1, const Geometry* g2)
+ return GEOSEquals_r(handle, g1, g2);
+ char
+ GEOSEqualsExact(const Geometry* g1, const Geometry* g2, double tolerance)
+ return GEOSEqualsExact_r(handle, g1, g2, tolerance);
+ int
+ GEOSDistance(const Geometry* g1, const Geometry* g2, double* dist)
+ return GEOSDistance_r(handle, g1, g2, dist);
+ int
+ GEOSDistanceIndexed(const Geometry* g1, const Geometry* g2, double* dist)
+ return GEOSDistanceIndexed_r(handle, g1, g2, dist);
+ int
+ GEOSHausdorffDistance(const Geometry* g1, const Geometry* g2, double* dist)
+ return GEOSHausdorffDistance_r(handle, g1, g2, dist);
+ int
+ GEOSHausdorffDistanceDensify(const Geometry* g1, const Geometry* g2, double densifyFrac, double* dist)
+ return GEOSHausdorffDistanceDensify_r(handle, g1, g2, densifyFrac, dist);
+ int
+ GEOSFrechetDistance(const Geometry* g1, const Geometry* g2, double* dist)
+ return GEOSFrechetDistance_r(handle, g1, g2, dist);
+ int
+ GEOSFrechetDistanceDensify(const Geometry* g1, const Geometry* g2, double densifyFrac, double* dist)
+ return GEOSFrechetDistanceDensify_r(handle, g1, g2, densifyFrac, dist);
+ int
+ GEOSArea(const Geometry* g, double* area)
+ return GEOSArea_r(handle, g, area);
+ int
+ GEOSLength(const Geometry* g, double* length)
+ return GEOSLength_r(handle, g, length);
+ CoordinateSequence*
+ GEOSNearestPoints(const Geometry* g1, const Geometry* g2)
+ return GEOSNearestPoints_r(handle, g1, g2);
+ Geometry*
+ GEOSGeomFromWKT(const char* wkt)
+ return GEOSGeomFromWKT_r(handle, wkt);
+ char*
+ GEOSGeomToWKT(const Geometry* g)
+ return GEOSGeomToWKT_r(handle, g);
// Remember to free the result!
-unsigned char *
-GEOSGeomToWKB_buf(const Geometry *g, size_t *size)
- return GEOSGeomToWKB_buf_r( handle, g, size );
-Geometry *
-GEOSGeomFromWKB_buf(const unsigned char *wkb, size_t size)
- return GEOSGeomFromWKB_buf_r( handle, wkb, size );
-/* Read/write wkb hex values. Returned geometries are
- owned by the caller.*/
-unsigned char *
-GEOSGeomToHEX_buf(const Geometry *g, size_t *size)
- return GEOSGeomToHEX_buf_r( handle, g, size );
-Geometry *
-GEOSGeomFromHEX_buf(const unsigned char *hex, size_t size)
- return GEOSGeomFromHEX_buf_r( handle, hex, size );
-char
-GEOSisEmpty(const Geometry *g)
- return GEOSisEmpty_r( handle, g );
-char
-GEOSisSimple(const Geometry *g)
- return GEOSisSimple_r( handle, g );
-char
-GEOSisRing(const Geometry *g)
- return GEOSisRing_r( handle, g );
+ unsigned char*
+ GEOSGeomToWKB_buf(const Geometry* g, size_t* size)
+ return GEOSGeomToWKB_buf_r(handle, g, size);
+ Geometry*
+ GEOSGeomFromWKB_buf(const unsigned char* wkb, size_t size)
+ return GEOSGeomFromWKB_buf_r(handle, wkb, size);
+ /* Read/write wkb hex values. Returned geometries are
+ owned by the caller.*/
+ unsigned char*
+ GEOSGeomToHEX_buf(const Geometry* g, size_t* size)
+ return GEOSGeomToHEX_buf_r(handle, g, size);
+ Geometry*
+ GEOSGeomFromHEX_buf(const unsigned char* hex, size_t size)
+ return GEOSGeomFromHEX_buf_r(handle, hex, size);
+ char
+ GEOSisEmpty(const Geometry* g)
+ return GEOSisEmpty_r(handle, g);
+ char
+ GEOSisSimple(const Geometry* g)
+ return GEOSisSimple_r(handle, g);
+ char
+ GEOSisRing(const Geometry* g)
+ return GEOSisRing_r(handle, g);
//free the result of this
-char *
-GEOSGeomType(const Geometry *g)
- return GEOSGeomType_r( handle, g );
+ char*
+ GEOSGeomType(const Geometry* g)
+ return GEOSGeomType_r(handle, g);
// Return postgis geometry type index
-int
-GEOSGeomTypeId(const Geometry *g)
- return GEOSGeomTypeId_r( handle, g );
+ int
+ GEOSGeomTypeId(const Geometry* g)
+ return GEOSGeomTypeId_r(handle, g);
@@ -405,132 +403,132 @@ GEOSGeomTypeId(const Geometry *g)
// GEOS functions that return geometries
-Geometry *
-GEOSEnvelope(const Geometry *g)
- return GEOSEnvelope_r( handle, g );
-Geometry *
-GEOSIntersection(const Geometry *g1, const Geometry *g2)
- return GEOSIntersection_r( handle, g1, g2 );
-Geometry *
-GEOSBuffer(const Geometry *g, double width, int quadrantsegments)
- return GEOSBuffer_r( handle, g, width, quadrantsegments );
-Geometry *
-GEOSBufferWithStyle(const Geometry *g, double width, int quadsegs,
- int endCapStyle, int joinStyle, double mitreLimit)
- return GEOSBufferWithStyle_r( handle, g, width, quadsegs, endCapStyle,
- joinStyle, mitreLimit );
-Geometry *
-GEOSSingleSidedBuffer(const Geometry *g, double width, int quadsegs,
- int joinStyle, double mitreLimit, int leftSide)
- return GEOSSingleSidedBuffer_r( handle, g, width, quadsegs,
- joinStyle, mitreLimit, leftSide );
-Geometry *
-GEOSOffsetCurve(const Geometry *g, double width, int quadsegs,
- int joinStyle, double mitreLimit)
- return GEOSOffsetCurve_r( handle, g, width, quadsegs,
-Geometry *
-GEOSConvexHull(const Geometry *g)
- return GEOSConvexHull_r( handle, g );
-Geometry *
-GEOSMinimumRotatedRectangle(const Geometry *g)
- return GEOSMinimumRotatedRectangle_r( handle, g );
-Geometry *
-GEOSMinimumWidth(const Geometry *g)
- return GEOSMinimumWidth_r( handle, g );
-Geometry *
-GEOSMinimumClearanceLine(const Geometry *g)
- return GEOSMinimumClearanceLine_r( handle, g );
-int
-GEOSMinimumClearance(const Geometry *g, double *d)
- return GEOSMinimumClearance_r( handle, g, d);
-Geometry *
-GEOSDifference(const Geometry *g1, const Geometry *g2)
- return GEOSDifference_r( handle, g1, g2 );
-Geometry *
-GEOSBoundary(const Geometry *g)
- return GEOSBoundary_r( handle, g );
-Geometry *
-GEOSSymDifference(const Geometry *g1, const Geometry *g2)
- return GEOSSymDifference_r( handle, g1, g2 );
-Geometry *
-GEOSUnion(const Geometry *g1, const Geometry *g2)
- return GEOSUnion_r( handle, g1, g2 );
-Geometry *
-GEOSUnaryUnion(const Geometry *g)
- return GEOSUnaryUnion_r( handle, g);
-Geometry *
-GEOSNode(const Geometry *g)
- return GEOSNode_r( handle, g );
-Geometry *
-GEOSUnionCascaded(const Geometry *g)
- return GEOSUnionCascaded_r( handle, g );
-Geometry *
-GEOSPointOnSurface(const Geometry *g)
- return GEOSPointOnSurface_r( handle, g );
-Geometry *
-GEOSClipByRect(const Geometry *g, double xmin, double ymin, double xmax, double ymax)
- return GEOSClipByRect_r( handle, g, xmin, ymin, xmax, ymax );
+ Geometry*
+ GEOSEnvelope(const Geometry* g)
+ return GEOSEnvelope_r(handle, g);
+ Geometry*
+ GEOSIntersection(const Geometry* g1, const Geometry* g2)
+ return GEOSIntersection_r(handle, g1, g2);
+ Geometry*
+ GEOSBuffer(const Geometry* g, double width, int quadrantsegments)
+ return GEOSBuffer_r(handle, g, width, quadrantsegments);
+ Geometry*
+ GEOSBufferWithStyle(const Geometry* g, double width, int quadsegs,
+ int endCapStyle, int joinStyle, double mitreLimit)
+ return GEOSBufferWithStyle_r(handle, g, width, quadsegs, endCapStyle,
+ joinStyle, mitreLimit);
+ Geometry*
+ GEOSSingleSidedBuffer(const Geometry* g, double width, int quadsegs,
+ int joinStyle, double mitreLimit, int leftSide)
+ return GEOSSingleSidedBuffer_r(handle, g, width, quadsegs,
+ joinStyle, mitreLimit, leftSide);
+ Geometry*
+ GEOSOffsetCurve(const Geometry* g, double width, int quadsegs,
+ int joinStyle, double mitreLimit)
+ return GEOSOffsetCurve_r(handle, g, width, quadsegs,
+ Geometry*
+ GEOSConvexHull(const Geometry* g)
+ return GEOSConvexHull_r(handle, g);
+ Geometry*
+ GEOSMinimumRotatedRectangle(const Geometry* g)
+ return GEOSMinimumRotatedRectangle_r(handle, g);
+ Geometry*
+ GEOSMinimumWidth(const Geometry* g)
+ return GEOSMinimumWidth_r(handle, g);
+ Geometry*
+ GEOSMinimumClearanceLine(const Geometry* g)
+ return GEOSMinimumClearanceLine_r(handle, g);
+ int
+ GEOSMinimumClearance(const Geometry* g, double* d)
+ return GEOSMinimumClearance_r(handle, g, d);
+ Geometry*
+ GEOSDifference(const Geometry* g1, const Geometry* g2)
+ return GEOSDifference_r(handle, g1, g2);
+ Geometry*
+ GEOSBoundary(const Geometry* g)
+ return GEOSBoundary_r(handle, g);
+ Geometry*
+ GEOSSymDifference(const Geometry* g1, const Geometry* g2)
+ return GEOSSymDifference_r(handle, g1, g2);
+ Geometry*
+ GEOSUnion(const Geometry* g1, const Geometry* g2)
+ return GEOSUnion_r(handle, g1, g2);
+ Geometry*
+ GEOSUnaryUnion(const Geometry* g)
+ return GEOSUnaryUnion_r(handle, g);
+ Geometry*
+ GEOSNode(const Geometry* g)
+ return GEOSNode_r(handle, g);
+ Geometry*
+ GEOSUnionCascaded(const Geometry* g)
+ return GEOSUnionCascaded_r(handle, g);
+ Geometry*
+ GEOSPointOnSurface(const Geometry* g)
+ return GEOSPointOnSurface_r(handle, g);
+ Geometry*
+ GEOSClipByRect(const Geometry* g, double xmin, double ymin, double xmax, double ymax)
+ return GEOSClipByRect_r(handle, g, xmin, ymin, xmax, ymax);
@@ -539,880 +537,880 @@ GEOSClipByRect(const Geometry *g, double xmin, double ymin, double xmax, double
-void
-GEOSGeom_destroy(Geometry *a)
- return GEOSGeom_destroy_r( handle, a );
+ void
+ GEOSGeom_destroy(Geometry* a)
+ return GEOSGeom_destroy_r(handle, a);
-int
-GEOSGetNumCoordinates(const Geometry *g)
- return GEOSGetNumCoordinates_r( handle, g );
+ int
+ GEOSGetNumCoordinates(const Geometry* g)
+ return GEOSGetNumCoordinates_r(handle, g);
+ * Return -1 on exception, 0 otherwise.
+ * Converts Geometry to normal form (or canonical form).
+ int
+ GEOSNormalize(Geometry* g)
+ return GEOSNormalize_r(handle, g);
- * Return -1 on exception, 0 otherwise.
- * Converts Geometry to normal form (or canonical form).
-int
-GEOSNormalize(Geometry *g)
- return GEOSNormalize_r( handle, g );
-int
-GEOSGetNumInteriorRings(const Geometry *g)
- return GEOSGetNumInteriorRings_r( handle, g );
+ int
+ GEOSGetNumInteriorRings(const Geometry* g)
+ return GEOSGetNumInteriorRings_r(handle, g);
// returns -1 on error and 1 for non-multi geometries
-int
-GEOSGetNumGeometries(const Geometry *g)
- return GEOSGetNumGeometries_r( handle, g );
+ int
+ GEOSGetNumGeometries(const Geometry* g)
+ return GEOSGetNumGeometries_r(handle, g);
- * Call only on GEOMETRYCOLLECTION or MULTI*.
- * Return a pointer to the internal Geometry.
-const Geometry *
-GEOSGetGeometryN(const Geometry *g, int n)
- return GEOSGetGeometryN_r( handle, g, n );
+ * Call only on GEOMETRYCOLLECTION or MULTI*.
+ * Return a pointer to the internal Geometry.
+ const Geometry*
+ GEOSGetGeometryN(const Geometry* g, int n)
+ return GEOSGetGeometryN_r(handle, g, n);
- * Call only on LINESTRING
- * Returns NULL on exception
-Geometry *
-GEOSGeomGetPointN(const Geometry *g, int n)
- return GEOSGeomGetPointN_r(handle, g, n);
+ * Call only on LINESTRING
+ * Returns NULL on exception
+ Geometry*
+ GEOSGeomGetPointN(const Geometry* g, int n)
+ return GEOSGeomGetPointN_r(handle, g, n);
-Geometry *
-GEOSGeomGetStartPoint(const Geometry *g)
- return GEOSGeomGetStartPoint_r(handle, g);
+ Geometry*
+ GEOSGeomGetStartPoint(const Geometry* g)
+ return GEOSGeomGetStartPoint_r(handle, g);
-Geometry *
-GEOSGeomGetEndPoint(const Geometry *g)
- return GEOSGeomGetEndPoint_r(handle, g);
+ Geometry*
+ GEOSGeomGetEndPoint(const Geometry* g)
+ return GEOSGeomGetEndPoint_r(handle, g);
- * return 2 on exception, 1 on true, 0 on false
-char
-GEOSisClosed(const Geometry *g)
- return GEOSisClosed_r(handle, g);
+ * return 2 on exception, 1 on true, 0 on false
+ char
+ GEOSisClosed(const Geometry* g)
+ return GEOSisClosed_r(handle, g);
- * returns 0 on exception, otherwise 1
-int
-GEOSGeomGetLength(const Geometry *g, double *length)
- return GEOSGeomGetLength_r(handle, g, length);
+ * returns 0 on exception, otherwise 1
+ int
+ GEOSGeomGetLength(const Geometry* g, double* length)
+ return GEOSGeomGetLength_r(handle, g, length);
- * returns -1 on exception
-int
-GEOSGeomGetNumPoints(const Geometry *g)
- return GEOSGeomGetNumPoints_r(handle, g);
+ * returns -1 on exception
+ int
+ GEOSGeomGetNumPoints(const Geometry* g)
+ return GEOSGeomGetNumPoints_r(handle, g);
- * For POINT
-int
-GEOSGeomGetX(const Geometry *g, double *x)
- return GEOSGeomGetX_r(handle, g, x);
+ * For POINT
+ int
+ GEOSGeomGetX(const Geometry* g, double* x)
+ return GEOSGeomGetX_r(handle, g, x);
- * For POINT
-int
-GEOSGeomGetY(const Geometry *g, double *y)
- return GEOSGeomGetY_r(handle, g, y);
+ * For POINT
+ int
+ GEOSGeomGetY(const Geometry* g, double* y)
+ return GEOSGeomGetY_r(handle, g, y);
- * For POINT
-int
-GEOSGeomGetZ(const Geometry *g1, double *z)
- return GEOSGeomGetZ_r(handle, g1, z);
+ * For POINT
+ int
+ GEOSGeomGetZ(const Geometry* g1, double* z)
+ return GEOSGeomGetZ_r(handle, g1, z);
- * Call only on polygon
- * Return a copy of the internal Geometry.
-const Geometry *
-GEOSGetExteriorRing(const Geometry *g)
- return GEOSGetExteriorRing_r( handle, g );
+ * Call only on polygon
+ * Return a copy of the internal Geometry.
+ const Geometry*
+ GEOSGetExteriorRing(const Geometry* g)
+ return GEOSGetExteriorRing_r(handle, g);
- * Return a pointer to internal storage, do not destroy it.
-const Geometry *
-GEOSGetInteriorRingN(const Geometry *g, int n)
- return GEOSGetInteriorRingN_r( handle, g, n );
-Geometry *
-GEOSGetCentroid(const Geometry *g)
- return GEOSGetCentroid_r( handle, g );
-Geometry *
-GEOSGeom_createCollection(int type, Geometry **geoms, unsigned int ngeoms)
- return GEOSGeom_createCollection_r( handle, type, geoms, ngeoms );
-Geometry *
-GEOSPolygonize(const Geometry * const * g, unsigned int ngeoms)
- return GEOSPolygonize_r( handle, g, ngeoms );
-Geometry *
-GEOSPolygonizer_getCutEdges(const Geometry * const * g, unsigned int ngeoms)
- return GEOSPolygonizer_getCutEdges_r( handle, g, ngeoms );
-GEOSGeometry *
-GEOSPolygonize_full(const GEOSGeometry* input,
- GEOSGeometry** cuts, GEOSGeometry** dangles, GEOSGeometry** invalid)
- return GEOSPolygonize_full_r(handle, input, cuts, dangles, invalid );
-Geometry *
-GEOSLineMerge(const Geometry *g)
- return GEOSLineMerge_r( handle, g );
-Geometry *
-GEOSReverse(const Geometry *g)
- return GEOSReverse_r( handle, g );
-int
-GEOSGetSRID(const Geometry *g)
- return GEOSGetSRID_r( handle, g );
-void
-GEOSSetSRID(Geometry *g, int srid)
- return GEOSSetSRID_r( handle, g, srid );
-void *
-GEOSGeom_getUserData(const Geometry *g)
- return GEOSGeom_getUserData_r( handle, g );
-void
-GEOSGeom_setUserData(Geometry *g, void* userData)
- return GEOSGeom_setUserData_r( handle, g, userData );
-char
-GEOSHasZ(const Geometry *g)
- return GEOSHasZ_r( handle, g );
-int
-GEOS_getWKBOutputDims()
- return GEOS_getWKBOutputDims_r( handle );
-int
-GEOS_setWKBOutputDims(int newdims)
- return GEOS_setWKBOutputDims_r( handle, newdims );
-int
-GEOS_getWKBByteOrder()
- return GEOS_getWKBByteOrder_r( handle );
-int
-GEOS_setWKBByteOrder(int byteOrder)
- return GEOS_setWKBByteOrder_r( handle, byteOrder );
-GEOSCoordSeq_create(unsigned int size, unsigned int dims)
- return GEOSCoordSeq_create_r( handle, size, dims );
-int
-GEOSCoordSeq_setOrdinate(CoordinateSequence *s, unsigned int idx, unsigned int dim, double val)
- return GEOSCoordSeq_setOrdinate_r( handle, s, idx, dim, val );
-int
-GEOSCoordSeq_setX(CoordinateSequence *s, unsigned int idx, double val)
- return GEOSCoordSeq_setOrdinate(s, idx, 0, val);
-int
-GEOSCoordSeq_setY(CoordinateSequence *s, unsigned int idx, double val)
- return GEOSCoordSeq_setOrdinate(s, idx, 1, val);
-int
-GEOSCoordSeq_setZ(CoordinateSequence *s, unsigned int idx, double val)
- return GEOSCoordSeq_setOrdinate(s, idx, 2, val);
-GEOSCoordSeq_clone(const CoordinateSequence *s)
- return GEOSCoordSeq_clone_r( handle, s );
-int
-GEOSCoordSeq_getOrdinate(const CoordinateSequence *s, unsigned int idx, unsigned int dim, double *val)
- return GEOSCoordSeq_getOrdinate_r( handle, s, idx, dim, val );
-int
-GEOSCoordSeq_getX(const CoordinateSequence *s, unsigned int idx, double *val)
- return GEOSCoordSeq_getOrdinate(s, idx, 0, val);
-int
-GEOSCoordSeq_getY(const CoordinateSequence *s, unsigned int idx, double *val)
- return GEOSCoordSeq_getOrdinate(s, idx, 1, val);
-int
-GEOSCoordSeq_getZ(const CoordinateSequence *s, unsigned int idx, double *val)
- return GEOSCoordSeq_getOrdinate(s, idx, 2, val);
-int
-GEOSCoordSeq_getSize(const CoordinateSequence *s, unsigned int *size)
- return GEOSCoordSeq_getSize_r( handle, s, size );
-int
-GEOSCoordSeq_getDimensions(const CoordinateSequence *s, unsigned int *dims)
- return GEOSCoordSeq_getDimensions_r( handle, s, dims );
-int
-GEOSCoordSeq_isCCW(const CoordinateSequence *s, char *is_ccw)
- return GEOSCoordSeq_isCCW_r(handle, s, is_ccw);
-void
-GEOSCoordSeq_destroy(CoordinateSequence *s)
- return GEOSCoordSeq_destroy_r( handle, s );
-const CoordinateSequence *
-GEOSGeom_getCoordSeq(const Geometry *g)
- return GEOSGeom_getCoordSeq_r( handle, g );
-Geometry *
-GEOSGeom_createPoint(CoordinateSequence *cs)
- return GEOSGeom_createPoint_r( handle, cs );
-Geometry *
-GEOSGeom_createLinearRing(CoordinateSequence *cs)
- return GEOSGeom_createLinearRing_r( handle, cs );
-Geometry *
-GEOSGeom_createLineString(CoordinateSequence *cs)
- return GEOSGeom_createLineString_r( handle, cs );
-Geometry *
-GEOSGeom_createPolygon(Geometry *shell, Geometry **holes, unsigned int nholes)
- return GEOSGeom_createPolygon_r( handle, shell, holes, nholes );
-Geometry *
-GEOSGeom_clone(const Geometry *g)
- return GEOSGeom_clone_r( handle, g );
-GEOSGeometry *
-GEOSGeom_setPrecision(const GEOSGeometry *g, double gridSize, int flags)
- return GEOSGeom_setPrecision_r(handle, g, gridSize, flags);
-double
-GEOSGeom_getPrecision(const GEOSGeometry *g)
- return GEOSGeom_getPrecision_r(handle, g);
-int
-GEOSGeom_getDimensions(const Geometry *g)
- return GEOSGeom_getDimensions_r( handle, g );
-int
-GEOSGeom_getCoordinateDimension(const Geometry *g)
- return GEOSGeom_getCoordinateDimension_r( handle, g );
-int GEOS_DLL GEOSGeom_getXMin(const GEOSGeometry* g, double* value)
- return GEOSGeom_getXMin_r(handle, g, value);
-int GEOS_DLL GEOSGeom_getYMin(const GEOSGeometry* g, double* value)
- return GEOSGeom_getYMin_r(handle, g, value);
-int GEOS_DLL GEOSGeom_getXMax(const GEOSGeometry* g, double* value)
- return GEOSGeom_getXMax_r(handle, g, value);
-int GEOS_DLL GEOSGeom_getYMax(const GEOSGeometry* g, double* value)
- return GEOSGeom_getYMax_r(handle, g, value);
-Geometry *
-GEOSSimplify(const Geometry *g, double tolerance)
- return GEOSSimplify_r( handle, g, tolerance );
-Geometry *
-GEOSTopologyPreserveSimplify(const Geometry *g, double tolerance)
- return GEOSTopologyPreserveSimplify_r( handle, g, tolerance );
-/* WKT Reader */
-WKTReader *
-GEOSWKTReader_create()
- return GEOSWKTReader_create_r( handle );
-void
-GEOSWKTReader_destroy(WKTReader *reader)
- GEOSWKTReader_destroy_r( handle, reader );
-Geometry*
-GEOSWKTReader_read(WKTReader *reader, const char *wkt)
- return GEOSWKTReader_read_r( handle, reader, wkt );
-/* WKT Writer */
-WKTWriter *
-GEOSWKTWriter_create()
- return GEOSWKTWriter_create_r( handle );
-void
-GEOSWKTWriter_destroy(WKTWriter *Writer)
- GEOSWKTWriter_destroy_r( handle, Writer );
-char*
-GEOSWKTWriter_write(WKTWriter *writer, const Geometry *geom)
- return GEOSWKTWriter_write_r( handle, writer, geom );
-void
-GEOSWKTWriter_setTrim(WKTWriter *writer, char trim)
- GEOSWKTWriter_setTrim_r(handle, writer, trim);
-void
-GEOSWKTWriter_setRoundingPrecision(WKTWriter *writer, int precision)
- return GEOSWKTWriter_setRoundingPrecision_r(handle, writer, precision);
-void
-GEOSWKTWriter_setOutputDimension(WKTWriter *writer, int dim)
- GEOSWKTWriter_setOutputDimension_r(handle, writer, dim);
-int
-GEOSWKTWriter_getOutputDimension(WKTWriter *writer)
- return GEOSWKTWriter_getOutputDimension_r(handle, writer);
-void
-GEOSWKTWriter_setOld3D(WKTWriter *writer, int useOld3D)
- GEOSWKTWriter_setOld3D_r(handle, writer, useOld3D);
-/* WKB Reader */
-WKBReader *
-GEOSWKBReader_create()
- return GEOSWKBReader_create_r( handle );
-void
-GEOSWKBReader_destroy(WKBReader *reader)
- GEOSWKBReader_destroy_r( handle, reader );
-Geometry*
-GEOSWKBReader_read(WKBReader *reader, const unsigned char *wkb, size_t size)
- return GEOSWKBReader_read_r( handle, reader, wkb, size );
-Geometry*
-GEOSWKBReader_readHEX(WKBReader *reader, const unsigned char *hex, size_t size)
- return GEOSWKBReader_readHEX_r( handle, reader, hex, size );
-/* WKB Writer */
-WKBWriter *
-GEOSWKBWriter_create()
- return GEOSWKBWriter_create_r( handle );
-void
-GEOSWKBWriter_destroy(WKBWriter *Writer)
- GEOSWKBWriter_destroy_r( handle, Writer );
-/* The caller owns the result */
-unsigned char*
-GEOSWKBWriter_write(WKBWriter *writer, const Geometry *geom, size_t *size)
- return GEOSWKBWriter_write_r( handle, writer, geom, size );
-unsigned char*
-GEOSWKBWriter_writeHEX(WKBWriter *writer, const Geometry *geom, size_t *size)
- return GEOSWKBWriter_writeHEX_r( handle, writer, geom, size );
-int
-GEOSWKBWriter_getOutputDimension(const GEOSWKBWriter* writer)
- return GEOSWKBWriter_getOutputDimension_r( handle, writer );
-void
-GEOSWKBWriter_setOutputDimension(GEOSWKBWriter* writer, int newDimension)
- GEOSWKBWriter_setOutputDimension_r( handle, writer, newDimension );
-int
-GEOSWKBWriter_getByteOrder(const GEOSWKBWriter* writer)
- return GEOSWKBWriter_getByteOrder_r( handle, writer );
-void
-GEOSWKBWriter_setByteOrder(GEOSWKBWriter* writer, int newByteOrder)
- GEOSWKBWriter_setByteOrder_r( handle, writer, newByteOrder );
-char
-GEOSWKBWriter_getIncludeSRID(const GEOSWKBWriter* writer)
- return GEOSWKBWriter_getIncludeSRID_r( handle, writer );
-void
-GEOSWKBWriter_setIncludeSRID(GEOSWKBWriter* writer, const char newIncludeSRID)
- GEOSWKBWriter_setIncludeSRID_r( handle, writer, newIncludeSRID );
+ * Return a pointer to internal storage, do not destroy it.
+ const Geometry*
+ GEOSGetInteriorRingN(const Geometry* g, int n)
+ return GEOSGetInteriorRingN_r(handle, g, n);
+ Geometry*
+ GEOSGetCentroid(const Geometry* g)
+ return GEOSGetCentroid_r(handle, g);
-// Prepared Geometry
+ Geometry*
+ GEOSGeom_createCollection(int type, Geometry** geoms, unsigned int ngeoms)
+ return GEOSGeom_createCollection_r(handle, type, geoms, ngeoms);
+ Geometry*
+ GEOSPolygonize(const Geometry* const* g, unsigned int ngeoms)
+ return GEOSPolygonize_r(handle, g, ngeoms);
+ Geometry*
+ GEOSPolygonizer_getCutEdges(const Geometry* const* g, unsigned int ngeoms)
+ return GEOSPolygonizer_getCutEdges_r(handle, g, ngeoms);
+ GEOSGeometry*
+ GEOSPolygonize_full(const GEOSGeometry* input,
+ GEOSGeometry** cuts, GEOSGeometry** dangles, GEOSGeometry** invalid)
+ return GEOSPolygonize_full_r(handle, input, cuts, dangles, invalid);
+ Geometry*
+ GEOSLineMerge(const Geometry* g)
+ return GEOSLineMerge_r(handle, g);
+ Geometry*
+ GEOSReverse(const Geometry* g)
+ return GEOSReverse_r(handle, g);
+ int
+ GEOSGetSRID(const Geometry* g)
+ return GEOSGetSRID_r(handle, g);
+ void
+ GEOSSetSRID(Geometry* g, int srid)
+ return GEOSSetSRID_r(handle, g, srid);
-const geos::geom::prep::PreparedGeometry*
-GEOSPrepare(const Geometry *g)
- return GEOSPrepare_r( handle, g );
-void
-GEOSPreparedGeom_destroy(const geos::geom::prep::PreparedGeometry *a)
- GEOSPreparedGeom_destroy_r( handle, a );
-char
-GEOSPreparedContains(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
- return GEOSPreparedContains_r( handle, pg1, g2 );
-char
-GEOSPreparedContainsProperly(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
- return GEOSPreparedContainsProperly_r( handle, pg1, g2 );
-char
-GEOSPreparedCoveredBy(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
- return GEOSPreparedCoveredBy_r( handle, pg1, g2 );
-char
-GEOSPreparedCovers(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
- return GEOSPreparedCovers_r( handle, pg1, g2 );
-char
-GEOSPreparedCrosses(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
- return GEOSPreparedCrosses_r( handle, pg1, g2 );
-char
-GEOSPreparedDisjoint(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
- return GEOSPreparedDisjoint_r( handle, pg1, g2 );
-char
-GEOSPreparedIntersects(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
- return GEOSPreparedIntersects_r( handle, pg1, g2 );
-char
-GEOSPreparedOverlaps(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
- return GEOSPreparedOverlaps_r( handle, pg1, g2 );
-char
-GEOSPreparedTouches(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
- return GEOSPreparedTouches_r( handle, pg1, g2 );
-char
-GEOSPreparedWithin(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
- return GEOSPreparedWithin_r( handle, pg1, g2 );
-STRtree *
-GEOSSTRtree_create (size_t nodeCapacity)
- return GEOSSTRtree_create_r( handle, nodeCapacity );
-void
-GEOSSTRtree_insert (geos::index::strtree::STRtree *tree,
- const geos::geom::Geometry *g,
- void *item)
- GEOSSTRtree_insert_r( handle, tree, g, item );
-void
-GEOSSTRtree_query (geos::index::strtree::STRtree *tree,
- GEOSQueryCallback cb,
- void *userdata)
- GEOSSTRtree_query_r( handle, tree, g, cb, userdata );
-const GEOSGeometry *
-GEOSSTRtree_nearest (geos::index::strtree::STRtree *tree,
- const geos::geom::Geometry *g)
- return GEOSSTRtree_nearest_r( handle, tree, g);
-const void* GEOSSTRtree_nearest_generic(GEOSSTRtree *tree,
- const void* item,
- const GEOSGeometry* itemEnvelope,
- GEOSDistanceCallback distancefn,
- void* userdata)
- return GEOSSTRtree_nearest_generic_r( handle, tree, item, itemEnvelope, distancefn, userdata);
-void
-GEOSSTRtree_iterate(geos::index::strtree::STRtree *tree,
- GEOSQueryCallback callback,
- void *userdata)
- GEOSSTRtree_iterate_r( handle, tree, callback, userdata );
-char
-GEOSSTRtree_remove (geos::index::strtree::STRtree *tree,
- void *item)
- return GEOSSTRtree_remove_r( handle, tree, g, item );
-void
-GEOSSTRtree_destroy (geos::index::strtree::STRtree *tree)
- GEOSSTRtree_destroy_r( handle, tree );
-double
-GEOSProject (const geos::geom::Geometry *g,
- const geos::geom::Geometry *p)
- return GEOSProject_r (handle, g, p);
-geos::geom::Geometry *
-GEOSInterpolate (const geos::geom::Geometry *g,
- double d)
- return GEOSInterpolate_r(handle, g, d);
-double
-GEOSProjectNormalized (const geos::geom::Geometry *g,
- return GEOSProjectNormalized_r (handle, g, p);
-GEOSInterpolateNormalized (const geos::geom::Geometry *g,
- double d)
- return GEOSInterpolateNormalized_r(handle, g, d);
-GEOSGeom_extractUniquePoints (const geos::geom::Geometry *g)
- return GEOSGeom_extractUniquePoints_r(handle, g);
-GEOSGeom_createEmptyCollection(int type)
- return GEOSGeom_createEmptyCollection_r(handle, type);
-GEOSGeom_createEmptyPoint()
- return GEOSGeom_createEmptyPoint_r(handle);
-GEOSGeom_createEmptyLineString()
- return GEOSGeom_createEmptyLineString_r(handle);
-GEOSGeom_createEmptyPolygon()
- return GEOSGeom_createEmptyPolygon_r(handle);
-int
-GEOSOrientationIndex(double Ax, double Ay, double Bx, double By,
- double Px, double Py)
- return GEOSOrientationIndex_r(handle, Ax, Ay, Bx, By, Px, Py);
-GEOSGeometry *
-GEOSSharedPaths(const GEOSGeometry* g1, const GEOSGeometry* g2)
- return GEOSSharedPaths_r(handle, g1, g2);
-GEOSGeometry *
-GEOSSnap(const GEOSGeometry* g1, const GEOSGeometry* g2, double tolerance)
- return GEOSSnap_r(handle, g1, g2, tolerance);
-GEOSBufferParams*
-GEOSBufferParams_create()
- return GEOSBufferParams_create_r(handle);
-void
-GEOSBufferParams_destroy(GEOSBufferParams* p)
- return GEOSBufferParams_destroy_r(handle, p);
-int
-GEOSBufferParams_setEndCapStyle(GEOSBufferParams* p, int style)
- return GEOSBufferParams_setEndCapStyle_r(handle, p, style);
-int
-GEOSBufferParams_setJoinStyle(GEOSBufferParams* p, int joinStyle)
- return GEOSBufferParams_setJoinStyle_r(handle, p, joinStyle);
-int
-GEOSBufferParams_setMitreLimit(GEOSBufferParams* p, double l)
- return GEOSBufferParams_setMitreLimit_r(handle, p, l);
-int
-GEOSBufferParams_setQuadrantSegments(GEOSBufferParams* p, int joinStyle)
- return GEOSBufferParams_setQuadrantSegments_r(handle, p, joinStyle);
-int
-GEOSBufferParams_setSingleSided(GEOSBufferParams* p, int singleSided)
- return GEOSBufferParams_setSingleSided_r(handle, p, singleSided);
-Geometry*
-GEOSBufferWithParams(const Geometry* g, const GEOSBufferParams* p, double w)
- return GEOSBufferWithParams_r(handle, g, p, w);
-Geometry *
-GEOSDelaunayTriangulation(const Geometry *g, double tolerance, int onlyEdges)
- return GEOSDelaunayTriangulation_r(handle, g, tolerance, onlyEdges);
-Geometry*
-GEOSVoronoiDiagram(const Geometry *g, const Geometry *env, double tolerance, int onlyEdges)
- return GEOSVoronoiDiagram_r(handle, g, env, tolerance, onlyEdges);
-int
-GEOSSegmentIntersection(double ax0, double ay0, double ax1, double ay1,
- double bx0, double by0, double bx1, double by1,
- double* cx, double* cy)
- return GEOSSegmentIntersection_r(handle,
- ax0, ay0, ax1, ay1,
- bx0, by0, bx1, by1,
- cx, cy);
+ void*
+ GEOSGeom_getUserData(const Geometry* g)
+ return GEOSGeom_getUserData_r(handle, g);
+ void
+ GEOSGeom_setUserData(Geometry* g, void* userData)
+ return GEOSGeom_setUserData_r(handle, g, userData);
+ char
+ GEOSHasZ(const Geometry* g)
+ return GEOSHasZ_r(handle, g);
+ int
+ GEOS_getWKBOutputDims()
+ return GEOS_getWKBOutputDims_r(handle);
+ int
+ GEOS_setWKBOutputDims(int newdims)
+ return GEOS_setWKBOutputDims_r(handle, newdims);
+ int
+ GEOS_getWKBByteOrder()
+ return GEOS_getWKBByteOrder_r(handle);
+ int
+ GEOS_setWKBByteOrder(int byteOrder)
+ return GEOS_setWKBByteOrder_r(handle, byteOrder);
+ GEOSCoordSeq_create(unsigned int size, unsigned int dims)
+ return GEOSCoordSeq_create_r(handle, size, dims);
+ int
+ GEOSCoordSeq_setOrdinate(CoordinateSequence* s, unsigned int idx, unsigned int dim, double val)
+ return GEOSCoordSeq_setOrdinate_r(handle, s, idx, dim, val);
+ int
+ GEOSCoordSeq_setX(CoordinateSequence* s, unsigned int idx, double val)
+ return GEOSCoordSeq_setOrdinate(s, idx, 0, val);
+ int
+ GEOSCoordSeq_setY(CoordinateSequence* s, unsigned int idx, double val)
+ return GEOSCoordSeq_setOrdinate(s, idx, 1, val);
+ int
+ GEOSCoordSeq_setZ(CoordinateSequence* s, unsigned int idx, double val)
+ return GEOSCoordSeq_setOrdinate(s, idx, 2, val);
+ GEOSCoordSeq_clone(const CoordinateSequence* s)
+ return GEOSCoordSeq_clone_r(handle, s);
+ int
+ GEOSCoordSeq_getOrdinate(const CoordinateSequence* s, unsigned int idx, unsigned int dim, double* val)
+ return GEOSCoordSeq_getOrdinate_r(handle, s, idx, dim, val);
+ int
+ GEOSCoordSeq_getX(const CoordinateSequence* s, unsigned int idx, double* val)
+ return GEOSCoordSeq_getOrdinate(s, idx, 0, val);
+ int
+ GEOSCoordSeq_getY(const CoordinateSequence* s, unsigned int idx, double* val)
+ return GEOSCoordSeq_getOrdinate(s, idx, 1, val);
+ int
+ GEOSCoordSeq_getZ(const CoordinateSequence* s, unsigned int idx, double* val)
+ return GEOSCoordSeq_getOrdinate(s, idx, 2, val);
+ int
+ GEOSCoordSeq_getSize(const CoordinateSequence* s, unsigned int* size)
+ return GEOSCoordSeq_getSize_r(handle, s, size);
+ int
+ GEOSCoordSeq_getDimensions(const CoordinateSequence* s, unsigned int* dims)
+ return GEOSCoordSeq_getDimensions_r(handle, s, dims);
+ int
+ GEOSCoordSeq_isCCW(const CoordinateSequence* s, char* is_ccw)
+ return GEOSCoordSeq_isCCW_r(handle, s, is_ccw);
+ void
+ GEOSCoordSeq_destroy(CoordinateSequence* s)
+ return GEOSCoordSeq_destroy_r(handle, s);
+ const CoordinateSequence*
+ GEOSGeom_getCoordSeq(const Geometry* g)
+ return GEOSGeom_getCoordSeq_r(handle, g);
+ Geometry*
+ GEOSGeom_createPoint(CoordinateSequence* cs)
+ return GEOSGeom_createPoint_r(handle, cs);
+ Geometry*
+ GEOSGeom_createLinearRing(CoordinateSequence* cs)
+ return GEOSGeom_createLinearRing_r(handle, cs);
+ Geometry*
+ GEOSGeom_createLineString(CoordinateSequence* cs)
+ return GEOSGeom_createLineString_r(handle, cs);
+ Geometry*
+ GEOSGeom_createPolygon(Geometry* shell, Geometry** holes, unsigned int nholes)
+ return GEOSGeom_createPolygon_r(handle, shell, holes, nholes);
+ Geometry*
+ GEOSGeom_clone(const Geometry* g)
+ return GEOSGeom_clone_r(handle, g);
+ GEOSGeometry*
+ GEOSGeom_setPrecision(const GEOSGeometry* g, double gridSize, int flags)
+ return GEOSGeom_setPrecision_r(handle, g, gridSize, flags);
+ double
+ GEOSGeom_getPrecision(const GEOSGeometry* g)
+ return GEOSGeom_getPrecision_r(handle, g);
+ int
+ GEOSGeom_getDimensions(const Geometry* g)
+ return GEOSGeom_getDimensions_r(handle, g);
+ int
+ GEOSGeom_getCoordinateDimension(const Geometry* g)
+ return GEOSGeom_getCoordinateDimension_r(handle, g);
+ int GEOS_DLL GEOSGeom_getXMin(const GEOSGeometry* g, double* value)
+ return GEOSGeom_getXMin_r(handle, g, value);
+ int GEOS_DLL GEOSGeom_getYMin(const GEOSGeometry* g, double* value)
+ return GEOSGeom_getYMin_r(handle, g, value);
+ int GEOS_DLL GEOSGeom_getXMax(const GEOSGeometry* g, double* value)
+ return GEOSGeom_getXMax_r(handle, g, value);
+ int GEOS_DLL GEOSGeom_getYMax(const GEOSGeometry* g, double* value)
+ return GEOSGeom_getYMax_r(handle, g, value);
+ Geometry*
+ GEOSSimplify(const Geometry* g, double tolerance)
+ return GEOSSimplify_r(handle, g, tolerance);
+ Geometry*
+ GEOSTopologyPreserveSimplify(const Geometry* g, double tolerance)
+ return GEOSTopologyPreserveSimplify_r(handle, g, tolerance);
+ /* WKT Reader */
+ WKTReader*
+ GEOSWKTReader_create()
+ return GEOSWKTReader_create_r(handle);
+ void
+ GEOSWKTReader_destroy(WKTReader* reader)
+ GEOSWKTReader_destroy_r(handle, reader);
+ Geometry*
+ GEOSWKTReader_read(WKTReader* reader, const char* wkt)
+ return GEOSWKTReader_read_r(handle, reader, wkt);
+ /* WKT Writer */
+ WKTWriter*
+ GEOSWKTWriter_create()
+ return GEOSWKTWriter_create_r(handle);
+ void
+ GEOSWKTWriter_destroy(WKTWriter* Writer)
+ GEOSWKTWriter_destroy_r(handle, Writer);
+ char*
+ GEOSWKTWriter_write(WKTWriter* writer, const Geometry* geom)
+ return GEOSWKTWriter_write_r(handle, writer, geom);
+ void
+ GEOSWKTWriter_setTrim(WKTWriter* writer, char trim)
+ GEOSWKTWriter_setTrim_r(handle, writer, trim);
+ void
+ GEOSWKTWriter_setRoundingPrecision(WKTWriter* writer, int precision)
+ return GEOSWKTWriter_setRoundingPrecision_r(handle, writer, precision);
+ void
+ GEOSWKTWriter_setOutputDimension(WKTWriter* writer, int dim)
+ GEOSWKTWriter_setOutputDimension_r(handle, writer, dim);
+ int
+ GEOSWKTWriter_getOutputDimension(WKTWriter* writer)
+ return GEOSWKTWriter_getOutputDimension_r(handle, writer);
+ void
+ GEOSWKTWriter_setOld3D(WKTWriter* writer, int useOld3D)
+ GEOSWKTWriter_setOld3D_r(handle, writer, useOld3D);
+ /* WKB Reader */
+ WKBReader*
+ GEOSWKBReader_create()
+ return GEOSWKBReader_create_r(handle);
+ void
+ GEOSWKBReader_destroy(WKBReader* reader)
+ GEOSWKBReader_destroy_r(handle, reader);
+ Geometry*
+ GEOSWKBReader_read(WKBReader* reader, const unsigned char* wkb, size_t size)
+ return GEOSWKBReader_read_r(handle, reader, wkb, size);
+ Geometry*
+ GEOSWKBReader_readHEX(WKBReader* reader, const unsigned char* hex, size_t size)
+ return GEOSWKBReader_readHEX_r(handle, reader, hex, size);
+ /* WKB Writer */
+ WKBWriter*
+ GEOSWKBWriter_create()
+ return GEOSWKBWriter_create_r(handle);
+ void
+ GEOSWKBWriter_destroy(WKBWriter* Writer)
+ GEOSWKBWriter_destroy_r(handle, Writer);
+ /* The caller owns the result */
+ unsigned char*
+ GEOSWKBWriter_write(WKBWriter* writer, const Geometry* geom, size_t* size)
+ return GEOSWKBWriter_write_r(handle, writer, geom, size);
+ unsigned char*
+ GEOSWKBWriter_writeHEX(WKBWriter* writer, const Geometry* geom, size_t* size)
+ return GEOSWKBWriter_writeHEX_r(handle, writer, geom, size);
+ int
+ GEOSWKBWriter_getOutputDimension(const GEOSWKBWriter* writer)
+ return GEOSWKBWriter_getOutputDimension_r(handle, writer);
+ void
+ GEOSWKBWriter_setOutputDimension(GEOSWKBWriter* writer, int newDimension)
+ GEOSWKBWriter_setOutputDimension_r(handle, writer, newDimension);
+ int
+ GEOSWKBWriter_getByteOrder(const GEOSWKBWriter* writer)
+ return GEOSWKBWriter_getByteOrder_r(handle, writer);
+ void
+ GEOSWKBWriter_setByteOrder(GEOSWKBWriter* writer, int newByteOrder)
+ GEOSWKBWriter_setByteOrder_r(handle, writer, newByteOrder);
+ char
+ GEOSWKBWriter_getIncludeSRID(const GEOSWKBWriter* writer)
+ return GEOSWKBWriter_getIncludeSRID_r(handle, writer);
+ void
+ GEOSWKBWriter_setIncludeSRID(GEOSWKBWriter* writer, const char newIncludeSRID)
+ GEOSWKBWriter_setIncludeSRID_r(handle, writer, newIncludeSRID);
+// Prepared Geometry
+ const geos::geom::prep::PreparedGeometry*
+ GEOSPrepare(const Geometry* g)
+ return GEOSPrepare_r(handle, g);
+ void
+ GEOSPreparedGeom_destroy(const geos::geom::prep::PreparedGeometry* a)
+ GEOSPreparedGeom_destroy_r(handle, a);
+ char
+ GEOSPreparedContains(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+ return GEOSPreparedContains_r(handle, pg1, g2);
+ char
+ GEOSPreparedContainsProperly(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+ return GEOSPreparedContainsProperly_r(handle, pg1, g2);
+ char
+ GEOSPreparedCoveredBy(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+ return GEOSPreparedCoveredBy_r(handle, pg1, g2);
+ char
+ GEOSPreparedCovers(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+ return GEOSPreparedCovers_r(handle, pg1, g2);
+ char
+ GEOSPreparedCrosses(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+ return GEOSPreparedCrosses_r(handle, pg1, g2);
+ char
+ GEOSPreparedDisjoint(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+ return GEOSPreparedDisjoint_r(handle, pg1, g2);
+ char
+ GEOSPreparedIntersects(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+ return GEOSPreparedIntersects_r(handle, pg1, g2);
+ char
+ GEOSPreparedOverlaps(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+ return GEOSPreparedOverlaps_r(handle, pg1, g2);
+ char
+ GEOSPreparedTouches(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+ return GEOSPreparedTouches_r(handle, pg1, g2);
+ char
+ GEOSPreparedWithin(const geos::geom::prep::PreparedGeometry* pg1, const Geometry* g2)
+ return GEOSPreparedWithin_r(handle, pg1, g2);
+ STRtree*
+ GEOSSTRtree_create(size_t nodeCapacity)
+ return GEOSSTRtree_create_r(handle, nodeCapacity);
+ void
+ GEOSSTRtree_insert(geos::index::strtree::STRtree* tree,
+ const geos::geom::Geometry* g,
+ void* item)
+ GEOSSTRtree_insert_r(handle, tree, g, item);
+ void
+ GEOSSTRtree_query(geos::index::strtree::STRtree* tree,
+ GEOSQueryCallback cb,
+ void* userdata)
+ GEOSSTRtree_query_r(handle, tree, g, cb, userdata);
+ const GEOSGeometry*
+ GEOSSTRtree_nearest(geos::index::strtree::STRtree* tree,
+ const geos::geom::Geometry* g)
+ return GEOSSTRtree_nearest_r(handle, tree, g);
+ const void* GEOSSTRtree_nearest_generic(GEOSSTRtree* tree,
+ const void* item,
+ const GEOSGeometry* itemEnvelope,
+ GEOSDistanceCallback distancefn,
+ void* userdata)
+ return GEOSSTRtree_nearest_generic_r(handle, tree, item, itemEnvelope, distancefn, userdata);
+ void
+ GEOSSTRtree_iterate(geos::index::strtree::STRtree* tree,
+ GEOSQueryCallback callback,
+ void* userdata)
+ GEOSSTRtree_iterate_r(handle, tree, callback, userdata);
+ char
+ GEOSSTRtree_remove(geos::index::strtree::STRtree* tree,
+ void* item)
+ return GEOSSTRtree_remove_r(handle, tree, g, item);
+ void
+ GEOSSTRtree_destroy(geos::index::strtree::STRtree* tree)
+ GEOSSTRtree_destroy_r(handle, tree);
+ double
+ GEOSProject(const geos::geom::Geometry* g,
+ const geos::geom::Geometry* p)
+ return GEOSProject_r(handle, g, p);
+ geos::geom::Geometry*
+ GEOSInterpolate(const geos::geom::Geometry* g,
+ double d)
+ return GEOSInterpolate_r(handle, g, d);
+ double
+ GEOSProjectNormalized(const geos::geom::Geometry* g,
+ return GEOSProjectNormalized_r(handle, g, p);
+ GEOSInterpolateNormalized(const geos::geom::Geometry* g,
+ double d)
+ return GEOSInterpolateNormalized_r(handle, g, d);
+ GEOSGeom_extractUniquePoints(const geos::geom::Geometry* g)
+ return GEOSGeom_extractUniquePoints_r(handle, g);
+ GEOSGeom_createEmptyCollection(int type)
+ return GEOSGeom_createEmptyCollection_r(handle, type);
+ GEOSGeom_createEmptyPoint()
+ return GEOSGeom_createEmptyPoint_r(handle);
+ GEOSGeom_createEmptyLineString()
+ return GEOSGeom_createEmptyLineString_r(handle);
+ GEOSGeom_createEmptyPolygon()
+ return GEOSGeom_createEmptyPolygon_r(handle);
+ int
+ GEOSOrientationIndex(double Ax, double Ay, double Bx, double By,
+ double Px, double Py)
+ return GEOSOrientationIndex_r(handle, Ax, Ay, Bx, By, Px, Py);
+ GEOSGeometry*
+ GEOSSharedPaths(const GEOSGeometry* g1, const GEOSGeometry* g2)
+ return GEOSSharedPaths_r(handle, g1, g2);
+ GEOSGeometry*
+ GEOSSnap(const GEOSGeometry* g1, const GEOSGeometry* g2, double tolerance)
+ return GEOSSnap_r(handle, g1, g2, tolerance);
+ GEOSBufferParams*
+ GEOSBufferParams_create()
+ return GEOSBufferParams_create_r(handle);
+ void
+ GEOSBufferParams_destroy(GEOSBufferParams* p)
+ return GEOSBufferParams_destroy_r(handle, p);
+ int
+ GEOSBufferParams_setEndCapStyle(GEOSBufferParams* p, int style)
+ return GEOSBufferParams_setEndCapStyle_r(handle, p, style);
+ int
+ GEOSBufferParams_setJoinStyle(GEOSBufferParams* p, int joinStyle)
+ return GEOSBufferParams_setJoinStyle_r(handle, p, joinStyle);
+ int
+ GEOSBufferParams_setMitreLimit(GEOSBufferParams* p, double l)
+ return GEOSBufferParams_setMitreLimit_r(handle, p, l);
+ int
+ GEOSBufferParams_setQuadrantSegments(GEOSBufferParams* p, int joinStyle)
+ return GEOSBufferParams_setQuadrantSegments_r(handle, p, joinStyle);
+ int
+ GEOSBufferParams_setSingleSided(GEOSBufferParams* p, int singleSided)
+ return GEOSBufferParams_setSingleSided_r(handle, p, singleSided);
+ Geometry*
+ GEOSBufferWithParams(const Geometry* g, const GEOSBufferParams* p, double w)
+ return GEOSBufferWithParams_r(handle, g, p, w);
+ Geometry*
+ GEOSDelaunayTriangulation(const Geometry* g, double tolerance, int onlyEdges)
+ return GEOSDelaunayTriangulation_r(handle, g, tolerance, onlyEdges);
+ Geometry*
+ GEOSVoronoiDiagram(const Geometry* g, const Geometry* env, double tolerance, int onlyEdges)
+ return GEOSVoronoiDiagram_r(handle, g, env, tolerance, onlyEdges);
+ int
+ GEOSSegmentIntersection(double ax0, double ay0, double ax1, double ay1,
+ double bx0, double by0, double bx1, double by1,
+ double* cx, double* cy)
+ return GEOSSegmentIntersection_r(handle,
+ ax0, ay0, ax1, ay1,
+ bx0, by0, bx1, by1,
+ cx, cy);
} /* extern "C" */
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 7b69c46..ca0625a 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -152,37 +152,36 @@ using geos::algorithm::distance::DiscreteFrechetDistance;
typedef std::unique_ptr<Geometry> GeomPtr;
-typedef struct GEOSContextHandle_HS
- const GeometryFactory *geomFactory;
+typedef struct GEOSContextHandle_HS {
+ const GeometryFactory* geomFactory;
char msgBuffer[1024];
GEOSMessageHandler noticeMessageOld;
GEOSMessageHandler_r noticeMessageNew;
- void *noticeData;
+ void* noticeData;
GEOSMessageHandler errorMessageOld;
GEOSMessageHandler_r errorMessageNew;
- void *errorData;
+ void* errorData;
int WKBOutputDims;
int WKBByteOrder;
int initialized;
GEOSContextHandle_HS()
- geomFactory(0),
- noticeMessageOld(0),
- noticeMessageNew(0),
- noticeData(0),
- errorMessageOld(0),
- errorMessageNew(0),
- errorData(0)
- memset(msgBuffer, 0, sizeof(msgBuffer));
- geomFactory = GeometryFactory::getDefaultInstance();
- WKBOutputDims = 2;
- WKBByteOrder = getMachineByteOrder();
- setNoticeHandler(NULL);
- setErrorHandler(NULL);
- initialized = 1;
+ geomFactory(0),
+ noticeMessageOld(0),
+ noticeMessageNew(0),
+ noticeData(0),
+ errorMessageOld(0),
+ errorMessageNew(0),
+ errorData(0)
+ memset(msgBuffer, 0, sizeof(msgBuffer));
+ geomFactory = GeometryFactory::getDefaultInstance();
+ WKBOutputDims = 2;
+ WKBByteOrder = getMachineByteOrder();
+ setNoticeHandler(NULL);
+ setErrorHandler(NULL);
+ initialized = 1;
GEOSMessageHandler
@@ -208,7 +207,8 @@ typedef struct GEOSContextHandle_HS
- setNoticeHandler(GEOSMessageHandler_r nf, void *userData) {
+ setNoticeHandler(GEOSMessageHandler_r nf, void* userData)
GEOSMessageHandler_r f = noticeMessageNew;
noticeMessageOld = NULL;
noticeMessageNew = nf;
@@ -218,7 +218,7 @@ typedef struct GEOSContextHandle_HS
- setErrorHandler(GEOSMessageHandler_r ef, void *userData)
+ setErrorHandler(GEOSMessageHandler_r ef, void* userData)
GEOSMessageHandler_r f = errorMessageNew;
errorMessageOld = NULL;
@@ -231,43 +231,45 @@ typedef struct GEOSContextHandle_HS
void
NOTICE_MESSAGE(string fmt, ...)
- if (NULL == noticeMessageOld && NULL == noticeMessageNew) {
- return;
- va_list args;
- va_start(args, fmt);
- int result = vsnprintf(msgBuffer, sizeof(msgBuffer) - 1, fmt.c_str(), args);
- va_end(args);
+ if(NULL == noticeMessageOld && NULL == noticeMessageNew) {
+ return;
- if (result > 0) {
- if (noticeMessageOld) {
- noticeMessageOld("%s", msgBuffer);
- } else {
- noticeMessageNew(msgBuffer, noticeData);
+ va_list args;
+ va_start(args, fmt);
+ int result = vsnprintf(msgBuffer, sizeof(msgBuffer) - 1, fmt.c_str(), args);
+ va_end(args);
+ if(result > 0) {
+ if(noticeMessageOld) {
+ noticeMessageOld("%s", msgBuffer);
+ else {
+ noticeMessageNew(msgBuffer, noticeData);
void
ERROR_MESSAGE(string fmt, ...)
- if (NULL == errorMessageOld && NULL == errorMessageNew) {
- return;
- va_list args;
- va_end(args);
+ if(NULL == errorMessageOld && NULL == errorMessageNew) {
+ return;
- if (result > 0) {
- if (errorMessageOld) {
- errorMessageOld("%s", msgBuffer);
- } else {
- errorMessageNew(msgBuffer, errorData);
+ va_list args;
+ va_end(args);
+ if(result > 0) {
+ if(errorMessageOld) {
+ errorMessageOld("%s", msgBuffer);
+ else {
+ errorMessageNew(msgBuffer, errorData);
} GEOSContextHandleInternal_t;
@@ -276,27 +278,31 @@ typedef struct GEOSContextHandle_HS
// extern "C" block.
class CAPI_ItemVisitor : public geos::index::ItemVisitor {
GEOSQueryCallback callback;
- void *userdata;
- public:
- CAPI_ItemVisitor (GEOSQueryCallback cb, void *ud)
+ void* userdata;
+public:
+ CAPI_ItemVisitor(GEOSQueryCallback cb, void* ud)
: ItemVisitor(), callback(cb), userdata(ud) {}
- void visitItem (void *item) override { callback(item, userdata); }
+ void
+ visitItem(void* item) override
+ callback(item, userdata);
//## PROTOTYPES #############################################
-extern "C" const char GEOS_DLL *GEOSjtsport();
-extern "C" char GEOS_DLL *GEOSasText(Geometry *g1);
+extern "C" const char GEOS_DLL* GEOSjtsport();
+extern "C" char GEOS_DLL* GEOSasText(Geometry* g1);
namespace { // anonymous
-char* gstrdup_s(const char* str, const std::size_t size)
+char*
+gstrdup_s(const char* str, const std::size_t size)
char* out = static_cast<char*>(malloc(size + 1));
- if (0 != out)
+ if(0 != out) {
// as no strlen call necessary, memcpy may be faster than strcpy
std::memcpy(out, str, size + 1);
@@ -304,15 +310,15 @@ char* gstrdup_s(const char* str, const std::size_t size)
assert(0 != out);
// we haven't been checking allocation before ticket #371
- if (0 == out)
+ if(0 == out) {
throw(std::runtime_error("Failed to allocate memory for duplicate string"));
return out;
-char* gstrdup(std::string const& str)
+char*
+gstrdup(std::string const& str)
return gstrdup_s(str.c_str(), str.size());
@@ -321,589 +327,522 @@ char* gstrdup(std::string const& str)
extern "C" {
-GEOSContextHandle_t
-initGEOS_r(GEOSMessageHandler nf, GEOSMessageHandler ef)
- GEOSContextHandle_t handle = GEOS_init_r();
+ GEOSContextHandle_t
+ initGEOS_r(GEOSMessageHandler nf, GEOSMessageHandler ef)
+ GEOSContextHandle_t handle = GEOS_init_r();
- if (0 != handle) {
+ if(0 != handle) {
- return handle;
+ return handle;
-GEOS_init_r()
- GEOSContextHandleInternal_t *handle = new GEOSContextHandleInternal_t();
+ GEOS_init_r()
+ GEOSContextHandleInternal_t* handle = new GEOSContextHandleInternal_t();
- return static_cast<GEOSContextHandle_t>(handle);
+ return static_cast<GEOSContextHandle_t>(handle);
-GEOSMessageHandler
-GEOSContext_setNoticeHandler_r(GEOSContextHandle_t extHandle, GEOSMessageHandler nf)
- GEOSContextHandleInternal_t *handle = 0;
- handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
- if ( 0 == handle->initialized )
+ GEOSMessageHandler
+ GEOSContext_setNoticeHandler_r(GEOSContextHandle_t extHandle, GEOSMessageHandler nf)
- return NULL;
+ GEOSContextHandleInternal_t* handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if(0 == handle->initialized) {
+ return NULL;
- return handle->setNoticeHandler(nf);
+ return handle->setNoticeHandler(nf);
-GEOSMessageHandler
-GEOSContext_setErrorHandler_r(GEOSContextHandle_t extHandle, GEOSMessageHandler nf)
+ GEOSContext_setErrorHandler_r(GEOSContextHandle_t extHandle, GEOSMessageHandler nf)
- return NULL;
+ return NULL;
- return handle->setErrorHandler(nf);
+ return handle->setErrorHandler(nf);
-GEOSMessageHandler_r
-GEOSContext_setNoticeMessageHandler_r(GEOSContextHandle_t extHandle, GEOSMessageHandler_r nf, void *userData) {
+ GEOSMessageHandler_r
+ GEOSContext_setNoticeMessageHandler_r(GEOSContextHandle_t extHandle, GEOSMessageHandler_r nf, void* userData)
- return NULL;
+ return NULL;
- return handle->setNoticeHandler(nf, userData);
+ return handle->setNoticeHandler(nf, userData);
-GEOSContext_setErrorMessageHandler_r(GEOSContextHandle_t extHandle, GEOSMessageHandler_r ef, void *userData)
+ GEOSContext_setErrorMessageHandler_r(GEOSContextHandle_t extHandle, GEOSMessageHandler_r ef, void* userData)
- return NULL;
+ return NULL;
- return handle->setErrorHandler(ef, userData);
+ return handle->setErrorHandler(ef, userData);
-void
-finishGEOS_r(GEOSContextHandle_t extHandle)
- // Fix up freeing handle w.r.t. malloc above
- delete extHandle;
- extHandle = NULL;
+ void
+ finishGEOS_r(GEOSContextHandle_t extHandle)
+ // Fix up freeing handle w.r.t. malloc above
+ delete extHandle;
+ extHandle = NULL;
-void
-GEOS_finish_r(GEOSContextHandle_t extHandle)
- finishGEOS_r(extHandle);
+ void
+ GEOS_finish_r(GEOSContextHandle_t extHandle)
+ finishGEOS_r(extHandle);
-void
-GEOSFree_r (GEOSContextHandle_t extHandle, void* buffer)
- assert(0 != extHandle);
+ void
+ GEOSFree_r(GEOSContextHandle_t extHandle, void* buffer)
+ assert(0 != extHandle);
- free(buffer);
+ free(buffer);
// relate()-related functions
// return 0 = false, 1 = true, 2 = error occurred
-char
-GEOSDisjoint_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
- if ( 0 == extHandle )
- return 2;
- if ( handle->initialized == 0 )
+ char
+ GEOSDisjoint_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return 2;
+ if(0 == extHandle) {
+ return 2;
- try
- bool result = g1->disjoint(g2);
- return result;
+ if(handle->initialized == 0) {
+ return 2;
- // TODO: mloskot is going to replace these double-catch block
- // with a macro to remove redundant code in this and
- // following functions.
- catch (const std::exception &e)
- handle->ERROR_MESSAGE("%s", e.what());
- catch (...)
- handle->ERROR_MESSAGE("Unknown exception thrown");
+ try {
+ bool result = g1->disjoint(g2);
+ return result;
- return 2;
+ // TODO: mloskot is going to replace these double-catch block
+ // with a macro to remove redundant code in this and
+ // following functions.
+ catch(const std::exception& e) {
+ handle->ERROR_MESSAGE("%s", e.what());
+ catch(...) {
+ handle->ERROR_MESSAGE("Unknown exception thrown");
-char
-GEOSTouches_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
return 2;
+ char
+ GEOSTouches_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return 2;
+ return 2;
- try
- bool result = g1->touches(g2);
- return result;
- catch (...)
+ return 2;
- return 2;
+ try {
+ bool result = g1->touches(g2);
+ return result;
+ catch(...) {
-char
-GEOSIntersects_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
return 2;
+ char
+ GEOSIntersects_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return 2;
+ return 2;
- try
- bool result = g1->intersects(g2);
- return result;
- catch (...)
+ return 2;
- return 2;
+ try {
+ bool result = g1->intersects(g2);
+ return result;
+ catch(...) {
-char
-GEOSCrosses_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
return 2;
+ char
+ GEOSCrosses_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return 2;
+ return 2;
- try
- bool result = g1->crosses(g2);
- return result;
- catch (...)
+ return 2;
- return 2;
+ try {
+ bool result = g1->crosses(g2);
+ return result;
+ catch(...) {
-char
-GEOSWithin_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
return 2;
+ char
+ GEOSWithin_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return 2;
+ return 2;
- try
- bool result = g1->within(g2);
- return result;
- catch (...)
+ return 2;
- return 2;
+ try {
+ bool result = g1->within(g2);
+ return result;
+ catch(...) {
+ return 2;
// 1 = true
-char
-GEOSContains_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
+ char
+ GEOSContains_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return 2;
+ return 2;
+ return 2;
+ try {
+ bool result = g1->contains(g2);
+ return result;
+ catch(...) {
return 2;
- try
- bool result = g1->contains(g2);
- return result;
- catch (...)
+ char
+ GEOSOverlaps_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
+ return 2;
- return 2;
+ return 2;
-char
-GEOSOverlaps_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
- return 2;
+ try {
+ bool result = g1->overlaps(g2);
+ return result;
+ catch(...) {
return 2;
- try
+ char
+ GEOSCovers_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- bool result = g1->overlaps(g2);
- return result;
- catch (...)
+ return 2;
- return 2;
+ return 2;
-char
-GEOSCovers_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
- return 2;
+ try {
+ bool result = g1->covers(g2);
+ return result;
+ catch(...) {
return 2;
- try
- bool result = g1->covers(g2);
- return result;
- catch (...)
+ char
+ GEOSCoveredBy_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
+ return 2;
- return 2;
+ return 2;
-char
-GEOSCoveredBy_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
- return 2;
+ try {
+ bool result = g1->coveredBy(g2);
+ return result;
+ catch(...) {
return 2;
- try
- bool result = g1->coveredBy(g2);
- return result;
- catch (...)
- return 2;
-char
-GEOSRelatePattern_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, const char *pat)
+ char
+ GEOSRelatePattern_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, const char* pat)
- return 2;
- return 2;
- try
- std::string s(pat);
- bool result = g1->relate(g2, s);
- return result;
- catch (...)
+ return 2;
- return 2;
+ return 2;
-char
-GEOSRelatePatternMatch_r(GEOSContextHandle_t extHandle, const char *mat,
- const char *pat)
- return 2;
+ try {
+ std::string s(pat);
+ bool result = g1->relate(g2, s);
+ return result;
+ catch(...) {
return 2;
- try
+ char
+ GEOSRelatePatternMatch_r(GEOSContextHandle_t extHandle, const char* mat,
+ const char* pat)
- using geos::geom::IntersectionMatrix;
+ return 2;
- std::string m(mat);
- std::string p(pat);
- IntersectionMatrix im(m);
+ return 2;
- bool result = im.matches(p);
- return result;
- catch (...)
+ try {
+ using geos::geom::IntersectionMatrix;
- return 2;
+ std::string m(mat);
+ std::string p(pat);
+ IntersectionMatrix im(m);
-char *
-GEOSRelate_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
- return NULL;
+ bool result = im.matches(p);
+ return result;
+ catch(...) {
- return NULL;
+ return 2;
- try
+ char*
+ GEOSRelate_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
+ return NULL;
- IntersectionMatrix* im = g1->relate(g2);
- if (0 == im)
- return 0;
+ return NULL;
- char *result = gstrdup(im->toString());
+ try {
- delete im;
- im = 0;
+ IntersectionMatrix* im = g1->relate(g2);
+ if(0 == im) {
+ return 0;
- return result;
- catch (...)
+ char* result = gstrdup(im->toString());
- return NULL;
+ delete im;
+ im = 0;
+ return result;
+ catch(...) {
-char *
-GEOSRelateBoundaryNodeRule_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, int bnr)
return NULL;
+ char*
+ GEOSRelateBoundaryNodeRule_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, int bnr)
- return NULL;
+ return NULL;
- try
- using geos::operation::relate::RelateOp;
- using geos::algorithm::BoundaryNodeRule;
- IntersectionMatrix* im;
- switch (bnr) {
- case GEOSRELATE_BNR_MOD2: /* same as OGC */
- im = RelateOp::relate(g1, g2,
- BoundaryNodeRule::getBoundaryRuleMod2());
- break;
- case GEOSRELATE_BNR_ENDPOINT:
- BoundaryNodeRule::getBoundaryEndPoint());
- break;
- case GEOSRELATE_BNR_MULTIVALENT_ENDPOINT:
- BoundaryNodeRule::getBoundaryMultivalentEndPoint());
- break;
- case GEOSRELATE_BNR_MONOVALENT_ENDPOINT:
- BoundaryNodeRule::getBoundaryMonovalentEndPoint());
- break;
- default:
- handle->ERROR_MESSAGE("Invalid boundary node rule %d", bnr);
- return 0;
- break;
+ return NULL;
- if (0 == im) return 0;
+ try {
+ using geos::operation::relate::RelateOp;
+ using geos::algorithm::BoundaryNodeRule;
+ IntersectionMatrix* im;
+ switch(bnr) {
+ case GEOSRELATE_BNR_MOD2: /* same as OGC */
+ im = RelateOp::relate(g1, g2,
+ BoundaryNodeRule::getBoundaryRuleMod2());
+ break;
+ case GEOSRELATE_BNR_ENDPOINT:
+ BoundaryNodeRule::getBoundaryEndPoint());
+ break;
+ case GEOSRELATE_BNR_MULTIVALENT_ENDPOINT:
+ BoundaryNodeRule::getBoundaryMultivalentEndPoint());
+ break;
+ case GEOSRELATE_BNR_MONOVALENT_ENDPOINT:
+ BoundaryNodeRule::getBoundaryMonovalentEndPoint());
+ break;
+ default:
+ handle->ERROR_MESSAGE("Invalid boundary node rule %d", bnr);
+ return 0;
+ break;
+ if(0 == im) {
+ return 0;
- delete im;
- im = 0;
+ delete im;
+ im = 0;
- return result;
- catch (...)
+ return result;
+ catch(...) {
- return NULL;
+ return NULL;
@@ -912,2482 +851,2156 @@ GEOSRelateBoundaryNodeRule_r(GEOSContextHandle_t extHandle, const Geometry *g1,
-char
-GEOSisValid_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return 2;
+ char
+ GEOSisValid_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- return 2;
+ return 2;
- try
- using geos::operation::valid::IsValidOp;
- using geos::operation::valid::TopologyValidationError;
+ return 2;
- IsValidOp ivo(g1);
- TopologyValidationError *err = ivo.getValidationError();
- if ( err )
- handle->NOTICE_MESSAGE("%s", err->toString().c_str());
- return 0;
+ try {
+ using geos::operation::valid::IsValidOp;
+ using geos::operation::valid::TopologyValidationError;
+ IsValidOp ivo(g1);
+ TopologyValidationError* err = ivo.getValidationError();
+ if(err) {
+ handle->NOTICE_MESSAGE("%s", err->toString().c_str());
+ return 0;
+ else {
+ return 1;
- else
- return 1;
+ catch(...) {
- catch (...)
- return 2;
-char *
-GEOSisValidReason_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return NULL;
- return NULL;
+ return 2;
- try
+ char*
+ GEOSisValidReason_r(GEOSContextHandle_t extHandle, const Geometry* g1)
+ return NULL;
- char* result = 0;
- char const* const validstr = "Valid Geometry";
+ return NULL;
- if (0 != err)
- std::ostringstream ss;
- ss.precision(15);
- ss << err->getCoordinate();
- const std::string errloc = ss.str();
- std::string errmsg(err->getMessage());
- errmsg += "[" + errloc + "]";
- result = gstrdup(errmsg);
- else
- result = gstrdup(std::string(validstr));
+ try {
+ char* result = 0;
+ char const* const validstr = "Valid Geometry";
+ if(0 != err) {
+ std::ostringstream ss;
+ ss.precision(15);
+ ss << err->getCoordinate();
+ const std::string errloc = ss.str();
+ std::string errmsg(err->getMessage());
+ errmsg += "[" + errloc + "]";
+ result = gstrdup(errmsg);
+ else {
+ result = gstrdup(std::string(validstr));
+ return result;
+ catch(...) {
- return result;
- catch (...)
+ return 0;
- return 0;
-char
-GEOSisValidDetail_r(GEOSContextHandle_t extHandle, const Geometry *g,
- int flags, char** reason, Geometry ** location)
+ char
+ GEOSisValidDetail_r(GEOSContextHandle_t extHandle, const Geometry* g,
+ int flags, char** reason, Geometry** location)
- return 2;
+ return 2;
- return 2;
+ return 2;
- try
+ try {
+ IsValidOp ivo(g);
+ if(flags & GEOSVALID_ALLOW_SELFTOUCHING_RING_FORMING_HOLE) {
+ ivo.setSelfTouchingRingFormingHoleValid(true);
+ if(0 != err) {
+ if(location) {
+ *location = handle->geomFactory->createPoint(err->getCoordinate());
+ if(reason) {
+ *reason = gstrdup(errmsg);
+ return 0;
+ if(location) {
+ *location = 0;
+ if(reason) {
+ *reason = 0;
+ return 1; /* valid */
- IsValidOp ivo(g);
- if ( flags & GEOSVALID_ALLOW_SELFTOUCHING_RING_FORMING_HOLE ) {
- ivo.setSelfTouchingRingFormingHoleValid(true);
- if (0 != err)
- if ( location ) {
- *location = handle->geomFactory->createPoint(err->getCoordinate());
- if ( reason ) {
- *reason = gstrdup(errmsg);
- return 0;
+ catch(...) {
- if ( location ) *location = 0;
- if ( reason ) *reason = 0;
- return 1; /* valid */
- catch (...)
+ return 2; /* exception */
- return 2; /* exception */
// general purpose
-char
-GEOSEquals_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
+ char
+ GEOSEquals_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return 2;
+ return 2;
+ return 2;
+ try {
+ bool result = g1->equals(g2);
+ return result;
+ catch(...) {
return 2;
- try
- bool result = g1->equals(g2);
- return result;
- catch (...)
+ char
+ GEOSEqualsExact_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double tolerance)
+ return 2;
- return 2;
+ return 2;
-char
-GEOSEqualsExact_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, double tolerance)
- return 2;
+ try {
+ bool result = g1->equalsExact(g2, tolerance);
+ return result;
+ catch(...) {
return 2;
- try
- bool result = g1->equalsExact(g2, tolerance);
- return result;
- catch (...)
+ int
+ GEOSDistance_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double* dist)
+ assert(0 != dist);
- return 2;
+ return 0;
-int
-GEOSDistance_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, double *dist)
- assert(0 != dist);
+ return 0;
- return 0;
+ try {
+ *dist = g1->distance(g2);
+ return 1;
+ catch(...) {
return 0;
- try
- *dist = g1->distance(g2);
- return 1;
- catch (...)
+ int
+ GEOSDistanceIndexed_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double* dist)
- return 0;
+ return 0;
-int
-GEOSDistanceIndexed_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, double *dist)
+ return 0;
- return 0;
+ try {
+ *dist = IndexedFacetDistance::distance(g1, g2);
+ return 1;
+ catch(...) {
return 0;
- try
- *dist = IndexedFacetDistance::distance(g1, g2);
- return 1;
- catch (...)
+ int
+ GEOSHausdorffDistance_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double* dist)
- return 0;
+ return 0;
-int
-GEOSHausdorffDistance_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, double *dist)
+ return 0;
- return 0;
+ try {
+ *dist = DiscreteHausdorffDistance::distance(*g1, *g2);
+ return 1;
+ catch(...) {
return 0;
- try
- *dist = DiscreteHausdorffDistance::distance(*g1, *g2);
- return 1;
+ int
+ GEOSHausdorffDistanceDensify_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2,
+ double densifyFrac, double* dist)
- catch (...)
- return 0;
+ return 0;
-int
-GEOSHausdorffDistanceDensify_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, double densifyFrac, double *dist)
+ return 0;
- return 0;
+ try {
+ *dist = DiscreteHausdorffDistance::distance(*g1, *g2, densifyFrac);
+ return 1;
+ catch(...) {
return 0;
- try
- *dist = DiscreteHausdorffDistance::distance(*g1, *g2, densifyFrac);
- return 1;
- catch (...)
+ int
+ GEOSFrechetDistance_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double* dist)
- return 0;
+ return 0;
-int
-GEOSFrechetDistance_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, double *dist)
+ return 0;
- return 0;
+ try {
+ *dist = DiscreteFrechetDistance::distance(*g1, *g2);
+ return 1;
+ catch(...) {
return 0;
- try
+ int
+ GEOSFrechetDistanceDensify_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double densifyFrac,
+ double* dist)
- *dist = DiscreteFrechetDistance::distance(*g1, *g2);
- return 1;
- catch (...)
- return 0;
+ return 0;
-int
-GEOSFrechetDistanceDensify_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2, double densifyFrac, double *dist)
+ return 0;
- return 0;
+ try {
+ *dist = DiscreteFrechetDistance::distance(*g1, *g2, densifyFrac);
+ return 1;
+ catch(...) {
return 0;
- try
- *dist = DiscreteFrechetDistance::distance(*g1, *g2, densifyFrac);
- return 1;
- catch (...)
+ int
+ GEOSArea_r(GEOSContextHandle_t extHandle, const Geometry* g, double* area)
+ assert(0 != area);
- return 0;
+ return 0;
-int
-GEOSArea_r(GEOSContextHandle_t extHandle, const Geometry *g, double *area)
- assert(0 != area);
+ return 0;
- return 0;
+ try {
+ *area = g->getArea();
+ return 1;
+ catch(...) {
return 0;
- try
- *area = g->getArea();
- return 1;
+ int
+ GEOSLength_r(GEOSContextHandle_t extHandle, const Geometry* g, double* length)
- catch (...)
+ assert(0 != length);
- return 0;
+ return 0;
-int
-GEOSLength_r(GEOSContextHandle_t extHandle, const Geometry *g, double *length)
- assert(0 != length);
+ return 0;
- return 0;
+ try {
+ *length = g->getLength();
+ return 1;
+ catch(...) {
return 0;
- try
- *length = g->getLength();
- return 1;
- catch (...)
+ CoordinateSequence*
+ GEOSNearestPoints_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
+ return NULL;
- return 0;
+ return NULL;
-CoordinateSequence *
-GEOSNearestPoints_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
- return NULL;
+ try {
+ if(g1->isEmpty() || g2->isEmpty()) {
+ return 0;
+ return geos::operation::distance::DistanceOp::nearestPoints(g1, g2);
+ catch(...) {
return NULL;
- try
- if (g1->isEmpty() || g2->isEmpty()) return 0;
- return geos::operation::distance::DistanceOp::nearestPoints(g1, g2);
- catch (...)
+ Geometry*
+ GEOSGeomFromWKT_r(GEOSContextHandle_t extHandle, const char* wkt)
+ return NULL;
- return NULL;
+ return NULL;
+ try {
+ const std::string wktstring(wkt);
+ WKTReader r(static_cast<GeometryFactory const*>(handle->geomFactory));
-Geometry *
-GEOSGeomFromWKT_r(GEOSContextHandle_t extHandle, const char *wkt)
- return NULL;
+ Geometry* g = r.read(wktstring);
+ return g;
+ catch(...) {
return NULL;
- try
+ char*
+ GEOSGeomToWKT_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- const std::string wktstring(wkt);
- WKTReader r(static_cast<GeometryFactory const*>(handle->geomFactory));
+ return NULL;
- Geometry *g = r.read(wktstring);
- return g;
- catch (...)
+ return NULL;
- return NULL;
+ try {
-char *
-GEOSGeomToWKT_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ char* result = gstrdup(g1->toString());
+ return result;
+ catch(...) {
return NULL;
+// Remember to free the result!
+ unsigned char*
+ GEOSGeomToWKB_buf_r(GEOSContextHandle_t extHandle, const Geometry* g, size_t* size)
- return NULL;
+ assert(0 != size);
- try
+ return NULL;
- char *result = gstrdup(g1->toString());
- return result;
- catch (...)
- return NULL;
+ return NULL;
-// Remember to free the result!
-unsigned char *
-GEOSGeomToWKB_buf_r(GEOSContextHandle_t extHandle, const Geometry *g, size_t *size)
- assert(0 != size);
+ using geos::io::WKBWriter;
+ try {
+ int byteOrder = handle->WKBByteOrder;
+ WKBWriter w(handle->WKBOutputDims, byteOrder);
+ std::ostringstream os(std::ios_base::binary);
+ w.write(*g, os);
+ std::string wkbstring(os.str());
+ const std::size_t len = wkbstring.length();
+ unsigned char* result = 0;
+ result = static_cast<unsigned char*>(malloc(len));
+ if(0 != result) {
+ std::memcpy(result, wkbstring.c_str(), len);
+ *size = len;
+ return result;
+ catch(...) {
return NULL;
+ Geometry*
+ GEOSGeomFromWKB_buf_r(GEOSContextHandle_t extHandle, const unsigned char* wkb, size_t size)
+ return NULL;
+ return NULL;
+ using geos::io::WKBReader;
+ try {
+ std::string wkbstring(reinterpret_cast<const char*>(wkb), size); // make it binary !
+ WKBReader r(*(static_cast<GeometryFactory const*>(handle->geomFactory)));
+ std::istringstream is(std::ios_base::binary);
+ is.str(wkbstring);
+ is.seekg(0, std::ios::beg); // rewind reader pointer
+ Geometry* g = r.read(is);
+ return g;
+ catch(...) {
return NULL;
- using geos::io::WKBWriter;
- try
+ /* Read/write wkb hex values. Returned geometries are
+ owned by the caller.*/
+ unsigned char*
+ GEOSGeomToHEX_buf_r(GEOSContextHandle_t extHandle, const Geometry* g, size_t* size)
- int byteOrder = handle->WKBByteOrder;
- WKBWriter w(handle->WKBOutputDims, byteOrder);
- std::ostringstream os(std::ios_base::binary);
- w.write(*g, os);
- std::string wkbstring(os.str());
- const std::size_t len = wkbstring.length();
+ return NULL;
- unsigned char* result = 0;
- result = static_cast<unsigned char*>(malloc(len));
- if (0 != result)
- std::memcpy(result, wkbstring.c_str(), len);
- *size = len;
+ return NULL;
- return result;
- catch (...)
- return NULL;
+ try {
+ w.writeHEX(*g, os);
+ std::string hexstring(os.str());
+ char* result = gstrdup(hexstring);
+ if(0 != result) {
+ *size = hexstring.length();
+ return reinterpret_cast<unsigned char*>(result);
+ catch(...) {
-Geometry *
-GEOSGeomFromWKB_buf_r(GEOSContextHandle_t extHandle, const unsigned char *wkb, size_t size)
return NULL;
+ Geometry*
+ GEOSGeomFromHEX_buf_r(GEOSContextHandle_t extHandle, const unsigned char* hex, size_t size)
- return NULL;
+ return NULL;
- using geos::io::WKBReader;
- try
- std::string wkbstring(reinterpret_cast<const char*>(wkb), size); // make it binary !
- WKBReader r(*(static_cast<GeometryFactory const*>(handle->geomFactory)));
- std::istringstream is(std::ios_base::binary);
- is.str(wkbstring);
- is.seekg(0, std::ios::beg); // rewind reader pointer
- Geometry *g = r.read(is);
- return g;
- catch (...)
+ return NULL;
- return NULL;
+ try {
+ std::string hexstring(reinterpret_cast<const char*>(hex), size);
+ is.str(hexstring);
-/* Read/write wkb hex values. Returned geometries are
- owned by the caller.*/
-unsigned char *
-GEOSGeomToHEX_buf_r(GEOSContextHandle_t extHandle, const Geometry *g, size_t *size)
- return NULL;
+ Geometry* g = r.readHEX(is);
+ return g;
+ catch(...) {
return NULL;
- try
+ char
+ GEOSisEmpty_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- w.writeHEX(*g, os);
- std::string hexstring(os.str());
- char *result = gstrdup(hexstring);
- if (0 != result)
- *size = hexstring.length();
+ return 2;
- return reinterpret_cast<unsigned char*>(result);
- catch (...)
- return NULL;
-Geometry *
-GEOSGeomFromHEX_buf_r(GEOSContextHandle_t extHandle, const unsigned char *hex, size_t size)
- return NULL;
- return NULL;
- try
- std::string hexstring(reinterpret_cast<const char*>(hex), size);
- is.str(hexstring);
- Geometry *g = r.readHEX(is);
- return g;
- catch (...)
+ return 2;
- return NULL;
+ try {
+ return g1->isEmpty();
+ catch(...) {
-char
-GEOSisEmpty_r(GEOSContextHandle_t extHandle, const Geometry *g1)
return 2;
+ char
+ GEOSisSimple_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- return 2;
+ return 2;
- try
- return g1->isEmpty();
- catch (...)
+ return 2;
- return 2;
+ try {
+ return g1->isSimple();
+ return 2;
-char
-GEOSisSimple_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return 2;
+ catch(...) {
+ return 2;
+ char
+ GEOSisRing_r(GEOSContextHandle_t extHandle, const Geometry* g)
- return 2;
+ return 2;
- try
- return g1->isSimple();
- return 2;
+ return 2;
- catch (...)
- return 2;
+ try {
+ const LineString* ls = dynamic_cast<const LineString*>(g);
+ if(ls) {
+ return (ls->isRing());
+ else {
+ return 0;
+ return 2;
-char
-GEOSisRing_r(GEOSContextHandle_t extHandle, const Geometry *g)
- return 2;
+ catch(...) {
+ return 2;
- return 2;
- try
- const LineString *ls = dynamic_cast<const LineString *>(g);
- if ( ls ) {
- return (ls->isRing());
- } else {
- return 0;
- return 2;
- catch (...)
+//free the result of this
+ char*
+ GEOSGeomType_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- return 2;
+ return NULL;
+ return NULL;
+ try {
+ std::string s = g1->getGeometryType();
-//free the result of this
-char *
-GEOSGeomType_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return NULL;
+ char* result = gstrdup(s);
+ return result;
+ catch(...) {
return NULL;
- try
- std::string s = g1->getGeometryType();
- char *result = gstrdup(s);
- return result;
- catch (...)
+// Return postgis geometry type index
+ int
+ GEOSGeomTypeId_r(GEOSContextHandle_t extHandle, const Geometry* g1)
+ return -1;
- return NULL;
+ return -1;
-// Return postgis geometry type index
-int
-GEOSGeomTypeId_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return -1;
+ try {
+ return g1->getGeometryTypeId();
+ catch(...) {
return -1;
- try
- return g1->getGeometryTypeId();
- catch (...)
- return -1;
// GEOS functions that return geometries
-Geometry *
-GEOSEnvelope_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ Geometry*
+ GEOSEnvelope_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- return NULL;
+ return NULL;
+ return NULL;
+ try {
+ Geometry* g3 = g1->getEnvelope();
+ return g3;
+ catch(...) {
return NULL;
- try
- Geometry *g3 = g1->getEnvelope();
- return g3;
- catch (...)
+ Geometry*
+ GEOSIntersection_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
+ return NULL;
- return NULL;
+ return NULL;
-Geometry *
-GEOSIntersection_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
- return NULL;
+ try {
+ return g1->intersection(g2);
+ catch(...) {
return NULL;
- try
+ Geometry*
+ GEOSBuffer_r(GEOSContextHandle_t extHandle, const Geometry* g1, double width, int quadrantsegments)
- return g1->intersection(g2);
- catch (...)
+ return NULL;
- return NULL;
+ return NULL;
-Geometry *
-GEOSBuffer_r(GEOSContextHandle_t extHandle, const Geometry *g1, double width, int quadrantsegments)
- return NULL;
+ try {
+ Geometry* g3 = g1->buffer(width, quadrantsegments);
+ return g3;
+ catch(...) {
return NULL;
- try
- Geometry *g3 = g1->buffer(width, quadrantsegments);
- return g3;
- catch (...)
+ Geometry*
+ GEOSBufferWithStyle_r(GEOSContextHandle_t extHandle, const Geometry* g1, double width, int quadsegs, int endCapStyle,
+ int joinStyle, double mitreLimit)
+ using geos::operation::buffer::BufferParameters;
+ using geos::operation::buffer::BufferOp;
+ using geos::util::IllegalArgumentException;
- return NULL;
+ return NULL;
-Geometry *
-GEOSBufferWithStyle_r(GEOSContextHandle_t extHandle, const Geometry *g1, double width, int quadsegs, int endCapStyle, int joinStyle, double mitreLimit)
- using geos::operation::buffer::BufferParameters;
- using geos::operation::buffer::BufferOp;
- using geos::util::IllegalArgumentException;
+ return NULL;
- return NULL;
+ try {
+ BufferParameters bp;
+ bp.setQuadrantSegments(quadsegs);
+ if(endCapStyle > BufferParameters::CAP_SQUARE) {
+ throw IllegalArgumentException("Invalid buffer endCap style");
+ bp.setEndCapStyle(
+ static_cast<BufferParameters::EndCapStyle>(endCapStyle)
+ if(joinStyle > BufferParameters::JOIN_BEVEL) {
+ throw IllegalArgumentException("Invalid buffer join style");
+ bp.setJoinStyle(
+ static_cast<BufferParameters::JoinStyle>(joinStyle)
+ bp.setMitreLimit(mitreLimit);
+ BufferOp op(g1, bp);
+ Geometry* g3 = op.getResultGeometry(width);
+ return g3;
+ catch(...) {
return NULL;
- try
+ Geometry*
+ GEOSOffsetCurve_r(GEOSContextHandle_t extHandle, const Geometry* g1, double width, int quadsegs, int joinStyle,
+ double mitreLimit)
- BufferParameters bp;
- bp.setQuadrantSegments(quadsegs);
- if ( endCapStyle > BufferParameters::CAP_SQUARE )
- throw IllegalArgumentException("Invalid buffer endCap style");
+ return NULL;
- bp.setEndCapStyle(
- static_cast<BufferParameters::EndCapStyle>(endCapStyle)
- if ( joinStyle > BufferParameters::JOIN_BEVEL )
- throw IllegalArgumentException("Invalid buffer join style");
+ return NULL;
- bp.setJoinStyle(
- static_cast<BufferParameters::JoinStyle>(joinStyle)
- bp.setMitreLimit(mitreLimit);
- BufferOp op(g1, bp);
- Geometry *g3 = op.getResultGeometry(width);
- return g3;
- catch (...)
- return NULL;
-Geometry *
-GEOSOffsetCurve_r(GEOSContextHandle_t extHandle, const Geometry *g1, double width, int quadsegs, int joinStyle, double mitreLimit)
- if ( 0 == extHandle ) return NULL;
+ try {
+ bp.setEndCapStyle(BufferParameters::CAP_FLAT);
- if ( 0 == handle->initialized ) return NULL;
+ bp.setJoinStyle(
- try
- bp.setEndCapStyle( BufferParameters::CAP_FLAT );
+ bool isLeftSide = true;
+ if(width < 0) {
+ isLeftSide = false;
+ width = -width;
+ BufferBuilder bufBuilder(bp);
+ Geometry* g3 = bufBuilder.bufferLineSingleSided(g1, width, isLeftSide);
+ return g3;
- bp.setJoinStyle(
- bool isLeftSide = true;
- if ( width < 0 ) {
- isLeftSide = false;
- width = -width;
+ catch(...) {
- BufferBuilder bufBuilder (bp);
- Geometry *g3 = bufBuilder.bufferLineSingleSided(g1, width, isLeftSide);
- return g3;
- catch (...)
+ return NULL;
- return NULL;
-/* @deprecated in 3.3.0 */
-Geometry *
-GEOSSingleSidedBuffer_r(GEOSContextHandle_t extHandle, const Geometry *g1, double width, int quadsegs, int joinStyle, double mitreLimit, int leftSide)
- try
+ /* @deprecated in 3.3.0 */
+ Geometry*
+ GEOSSingleSidedBuffer_r(GEOSContextHandle_t extHandle, const Geometry* g1, double width, int quadsegs, int joinStyle,
+ double mitreLimit, int leftSide)
+ return NULL;
+ return NULL;
- bp.setJoinStyle(
- bool isLeftSide = leftSide == 0 ? false : true;
+ try {
- return g3;
- catch (...)
+ bp.setJoinStyle(
- return NULL;
+ bool isLeftSide = leftSide == 0 ? false : true;
-Geometry *
-GEOSConvexHull_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return NULL;
+ return g3;
+ catch(...) {
return NULL;
- try
- Geometry *g3 = g1->convexHull();
- return g3;
- catch (...)
+ Geometry*
+ GEOSConvexHull_r(GEOSContextHandle_t extHandle, const Geometry* g1)
+ return NULL;
- return NULL;
+ return NULL;
+ try {
+ Geometry* g3 = g1->convexHull();
+ return g3;
+ catch(...) {
-Geometry *
-GEOSMinimumRotatedRectangle_r(GEOSContextHandle_t extHandle, const Geometry *g)
return NULL;
- return NULL;
- try
+ Geometry*
+ GEOSMinimumRotatedRectangle_r(GEOSContextHandle_t extHandle, const Geometry* g)
- geos::algorithm::MinimumDiameter m(g);
+ return NULL;
- Geometry *g3 = m.getMinimumRectangle();
- return g3;
- catch (...)
+ return NULL;
- return NULL;
+ try {
+ geos::algorithm::MinimumDiameter m(g);
-Geometry *
-GEOSMinimumWidth_r(GEOSContextHandle_t extHandle, const Geometry *g)
- return NULL;
+ Geometry* g3 = m.getMinimumRectangle();
+ return g3;
+ catch(...) {
return NULL;
- try
+ Geometry*
+ GEOSMinimumWidth_r(GEOSContextHandle_t extHandle, const Geometry* g)
+ return NULL;
- Geometry *g3 = m.getDiameter();
- return g3;
- catch (...)
+ return NULL;
- return NULL;
+ try {
+ Geometry* g3 = m.getDiameter();
+ return g3;
+ catch(...) {
-Geometry *
-GEOSMinimumClearanceLine_r(GEOSContextHandle_t extHandle, const Geometry *g)
return NULL;
+ Geometry*
+ GEOSMinimumClearanceLine_r(GEOSContextHandle_t extHandle, const Geometry* g)
+ return NULL;
+ return NULL;
+ try {
+ geos::precision::MinimumClearance mc(g);
+ return mc.getLine().release();
+ catch(...) {
return NULL;
- try
- geos::precision::MinimumClearance mc(g);
- return mc.getLine().release();
- catch (...)
+ int
+ GEOSMinimumClearance_r(GEOSContextHandle_t extHandle, const Geometry* g, double* d)
+ return 2;
- return NULL;
+ return 2;
-int
-GEOSMinimumClearance_r(GEOSContextHandle_t extHandle, const Geometry *g, double *d)
- return 2;
+ try {
+ double res = mc.getDistance();
+ *d = res;
+ return 0;
+ catch(...) {
return 2;
- try
- double res = mc.getDistance();
- *d = res;
- return 0;
- catch (...)
+ Geometry*
+ GEOSDifference_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
+ return NULL;
- return 2;
+ return NULL;
+ try {
+ return g1->difference(g2);
+ catch(...) {
-Geometry *
-GEOSDifference_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
return NULL;
+ Geometry*
+ GEOSBoundary_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- return NULL;
+ return NULL;
- try
- return g1->difference(g2);
- catch (...)
+ return NULL;
- return NULL;
+ try {
+ Geometry* g3 = g1->getBoundary();
+ return g3;
+ catch(...) {
-Geometry *
-GEOSBoundary_r(GEOSContextHandle_t extHandle, const Geometry *g1)
return NULL;
+ Geometry*
+ GEOSSymDifference_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return NULL;
+ return NULL;
- try
- Geometry *g3 = g1->getBoundary();
- return g3;
- catch (...)
+ return NULL;
- return NULL;
+ try {
+ return g1->symDifference(g2);
+ return NULL;
-Geometry *
-GEOSSymDifference_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
- return NULL;
+ catch(...) {
+ return NULL;
+ Geometry*
+ GEOSUnion_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return NULL;
+ return NULL;
- try
- return g1->symDifference(g2);
- return NULL;
+ return NULL;
- catch (...)
- return NULL;
+ try {
+ return g1->Union(g2);
+#if VERBOSE_EXCEPTIONS
+ std::ostringstream s;
+ s << "Exception on GEOSUnion with following inputs:" << std::endl;
+ s << "A: " << g1->toString() << std::endl;
+ s << "B: " << g2->toString() << std::endl;
+ handle->NOTICE_MESSAGE("%s", s.str().c_str());
+#endif // VERBOSE_EXCEPTIONS
+ catch(...) {
-Geometry *
-GEOSUnion_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
return NULL;
+ Geometry*
+ GEOSUnaryUnion_r(GEOSContextHandle_t extHandle, const Geometry* g)
- return NULL;
+ return NULL;
- try
- return g1->Union(g2);
+ return NULL;
+ try {
+ GeomPtr g3(g->Union());
+ return g3.release();
- std::ostringstream s;
- s << "Exception on GEOSUnion with following inputs:" << std::endl;
- s << "A: "<<g1->toString() << std::endl;
- s << "B: "<<g2->toString() << std::endl;
- handle->NOTICE_MESSAGE("%s", s.str().c_str());
+ s << "Exception on GEOSUnaryUnion with following inputs:" << std::endl;
- catch (...)
- return NULL;
+ catch(...) {
-Geometry *
-GEOSUnaryUnion_r(GEOSContextHandle_t extHandle, const Geometry *g)
return NULL;
+ Geometry*
+ GEOSNode_r(GEOSContextHandle_t extHandle, const Geometry* g)
- return NULL;
+ return NULL;
- try
- GeomPtr g3 ( g->Union() );
- return g3.release();
+ return NULL;
+ try {
+ std::unique_ptr<Geometry> g3 = geos::noding::GeometryNoder::node(*g);
- s << "Exception on GEOSUnaryUnion with following inputs:" << std::endl;
- catch (...)
- return NULL;
+ catch(...) {
-Geometry *
-GEOSNode_r(GEOSContextHandle_t extHandle, const Geometry *g)
return NULL;
+ Geometry*
+ GEOSUnionCascaded_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- return NULL;
- try
- std::unique_ptr<Geometry> g3 = geos::noding::GeometryNoder::node(*g);
-#if VERBOSE_EXCEPTIONS
-#endif // VERBOSE_EXCEPTIONS
- catch (...)
+ return NULL;
- return NULL;
+ return NULL;
-Geometry *
-GEOSUnionCascaded_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return NULL;
+ try {
+ const geos::geom::MultiPolygon* p = dynamic_cast<const geos::geom::MultiPolygon*>(g1);
+ if(! p) {
+ handle->ERROR_MESSAGE("Invalid argument (must be a MultiPolygon)");
+ return NULL;
+ using geos::operation::geounion::CascadedPolygonUnion;
+ return CascadedPolygonUnion::Union(p);
+ catch(...) {
return NULL;
- try
+ Geometry*
+ GEOSPointOnSurface_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- const geos::geom::MultiPolygon *p = dynamic_cast<const geos::geom::MultiPolygon *>(g1);
- if ( ! p )
- handle->ERROR_MESSAGE("Invalid argument (must be a MultiPolygon)");
return NULL;
- using geos::operation::geounion::CascadedPolygonUnion;
- return CascadedPolygonUnion::Union(p);
- catch (...)
+ return NULL;
- return NULL;
+ try {
+ Geometry* ret = g1->getInteriorPoint();
+ if(! ret) {
+ const GeometryFactory* gf = handle->geomFactory;
+ // return an empty point
+ return gf->createPoint();
+ return ret;
+ catch(...) {
-Geometry *
-GEOSPointOnSurface_r(GEOSContextHandle_t extHandle, const Geometry *g1)
return NULL;
+ Geometry*
+ GEOSClipByRect_r(GEOSContextHandle_t extHandle, const Geometry* g, double xmin, double ymin, double xmax, double ymax)
- return NULL;
+ return NULL;
- try
- Geometry *ret = g1->getInteriorPoint();
- if ( ! ret )
- const GeometryFactory* gf = handle->geomFactory;
- // return an empty point
- return gf->createPoint();
+ return NULL;
- return ret;
- catch (...)
- return NULL;
+ try {
+ using geos::operation::intersection::Rectangle;
+ using geos::operation::intersection::RectangleIntersection;
+ Rectangle rect(xmin, ymin, xmax, ymax);
+ std::unique_ptr<Geometry> g3 = RectangleIntersection::clip(*g, rect);
+ s << "Exception on GEOSClipByRect with following inputs:" << std::endl;
+ catch(...) {
-Geometry *
-GEOSClipByRect_r(GEOSContextHandle_t extHandle, const Geometry *g, double xmin, double ymin, double xmax, double ymax)
return NULL;
- return NULL;
+// memory management functions
- try
- using geos::operation::intersection::Rectangle;
- using geos::operation::intersection::RectangleIntersection;
- Rectangle rect(xmin, ymin, xmax, ymax);
- std::unique_ptr<Geometry> g3 = RectangleIntersection::clip(*g, rect);
- s << "Exception on GEOSClipByRect with following inputs:" << std::endl;
- catch (...)
+ void
+ GEOSGeom_destroy_r(GEOSContextHandle_t extHandle, Geometry* a)
- return NULL;
+ // FIXME: mloskot: Does this try-catch around delete means that
+ // destructors in GEOS may throw? If it does, this is a serious
+ // violation of "never throw an exception from a destructor" principle
-// memory management functions
+ try {
+ delete a;
+ return;
-void
-GEOSGeom_destroy_r(GEOSContextHandle_t extHandle, Geometry *a)
+ return;
- // FIXME: mloskot: Does this try-catch around delete means that
- // destructors in GEOS may throw? If it does, this is a serious
- // violation of "never throw an exception from a destructor" principle
+ catch(...) {
+ return;
- try
- delete a;
+ return;
+ void
+ GEOSGeom_setUserData_r(GEOSContextHandle_t extHandle, Geometry* g, void* userData)
+ assert(0 != g);
return;
return;
+ g->setUserData(userData);
- catch (...)
+ void
+ GEOSSetSRID_r(GEOSContextHandle_t extHandle, Geometry* g, int srid)
+ assert(0 != g);
return;
return;
-void
-GEOSGeom_setUserData_r(GEOSContextHandle_t extHandle, Geometry *g, void* userData)
- assert(0 != g);
- return;
- return;
+ g->setSRID(srid);
- g->setUserData(userData);
-void
-GEOSSetSRID_r(GEOSContextHandle_t extHandle, Geometry *g, int srid)
- assert(0 != g);
- return;
+ int
+ GEOSGetNumCoordinates_r(GEOSContextHandle_t extHandle, const Geometry* g)
- return;
+ assert(0 != g);
- g->setSRID(srid);
+ return -1;
+ return -1;
-int
-GEOSGetNumCoordinates_r(GEOSContextHandle_t extHandle, const Geometry *g)
- assert(0 != g);
+ try {
+ return static_cast<int>(g->getNumPoints());
+ catch(...) {
return -1;
+ * Return -1 on exception, 0 otherwise.
+ * Converts Geometry to normal form (or canonical form).
+ int
+ GEOSNormalize_r(GEOSContextHandle_t extHandle, Geometry* g)
- return -1;
+ assert(0 != g);
- try
- return static_cast<int>(g->getNumPoints());
- catch (...)
+ return -1;
- return -1;
+ return -1;
- * Return -1 on exception, 0 otherwise.
- * Converts Geometry to normal form (or canonical form).
-int
-GEOSNormalize_r(GEOSContextHandle_t extHandle, Geometry *g)
- assert(0 != g);
+ try {
+ g->normalize();
+ return 0; // SUCCESS
+ catch(...) {
return -1;
+ int
+ GEOSGetNumInteriorRings_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- return -1;
+ return -1;
- try
- g->normalize();
- return 0; // SUCCESS
- catch (...)
+ return -1;
- return -1;
+ try {
+ const Polygon* p = dynamic_cast<const Polygon*>(g1);
+ if(! p) {
+ handle->ERROR_MESSAGE("Argument is not a Polygon");
+ return -1;
+ return static_cast<int>(p->getNumInteriorRing());
+ catch(...) {
-int
-GEOSGetNumInteriorRings_r(GEOSContextHandle_t extHandle, const Geometry *g1)
return -1;
- return -1;
- try
+// returns -1 on error and 1 for non-multi geometries
+ int
+ GEOSGetNumGeometries_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- const Polygon *p = dynamic_cast<const Polygon *>(g1);
- if ( ! p )
- handle->ERROR_MESSAGE("Argument is not a Polygon");
return -1;
- return static_cast<int>(p->getNumInteriorRing());
- catch (...)
- return -1;
+ return -1;
+ try {
+ return static_cast<int>(g1->getNumGeometries());
+ catch(...) {
-// returns -1 on error and 1 for non-multi geometries
-int
-GEOSGetNumGeometries_r(GEOSContextHandle_t extHandle, const Geometry *g1)
return -1;
- return -1;
- try
+ * Call only on GEOMETRYCOLLECTION or MULTI*.
+ * Return a pointer to the internal Geometry.
+ const Geometry*
+ GEOSGetGeometryN_r(GEOSContextHandle_t extHandle, const Geometry* g1, int n)
- return static_cast<int>(g1->getNumGeometries());
- catch (...)
+ return NULL;
- return -1;
+ return NULL;
+ try {
+ return g1->getGeometryN(n);
+ catch(...) {
- * Call only on GEOMETRYCOLLECTION or MULTI*.
- * Return a pointer to the internal Geometry.
-const Geometry *
-GEOSGetGeometryN_r(GEOSContextHandle_t extHandle, const Geometry *g1, int n)
return NULL;
+ * Call only on LINESTRING
+ * Returns NULL on exception
+ Geometry*
+ GEOSGeomGetPointN_r(GEOSContextHandle_t extHandle, const Geometry* g1, int n)
- return NULL;
+ return NULL;
- try
- return g1->getGeometryN(n);
- catch (...)
+ return NULL;
- return NULL;
+ try {
+ using geos::geom::LineString;
+ const LineString* ls = dynamic_cast<const LineString*>(g1);
+ if(! ls) {
+ handle->ERROR_MESSAGE("Argument is not a LineString");
+ return NULL;
+ return ls->getPointN(n);
+ catch(...) {
- * Call only on LINESTRING
- * Returns NULL on exception
-Geometry *
-GEOSGeomGetPointN_r(GEOSContextHandle_t extHandle, const Geometry *g1, int n)
return NULL;
+ Geometry*
+ GEOSGeomGetStartPoint_r(GEOSContextHandle_t extHandle, const Geometry* g1)
+ return NULL;
+ return NULL;
+ try {
+ if(! ls) {
+ return NULL;
+ return ls->getStartPoint();
+ catch(...) {
return NULL;
- try
- using geos::geom::LineString;
- const LineString *ls = dynamic_cast<const LineString *>(g1);
- if ( ! ls )
- handle->ERROR_MESSAGE("Argument is not a LineString");
- return NULL;
- return ls->getPointN(n);
- catch (...)
+ Geometry*
+ GEOSGeomGetEndPoint_r(GEOSContextHandle_t extHandle, const Geometry* g1)
+ return NULL;
- return NULL;
+ return NULL;
-Geometry *
-GEOSGeomGetStartPoint_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return NULL;
+ try {
+ if(! ls) {
+ return NULL;
+ return ls->getEndPoint();
+ catch(...) {
return NULL;
- try
- if ( ! ls )
- return NULL;
- return ls->getStartPoint();
- catch (...)
+ * Call only on LINESTRING or MULTILINESTRING
+ * return 2 on exception, 1 on true, 0 on false
+ char
+ GEOSisClosed_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- return NULL;
+ return 2;
-Geometry *
-GEOSGeomGetEndPoint_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return NULL;
+ return 2;
- return NULL;
+ try {
+ using geos::geom::MultiLineString;
- try
- if ( ! ls )
- return NULL;
- return ls->getEndPoint();
- catch (...)
+ if(ls) {
+ return ls->isClosed();
- return NULL;
+ const MultiLineString* mls = dynamic_cast<const MultiLineString*>(g1);
+ if(mls) {
+ return mls->isClosed();
- * Call only on LINESTRING or MULTILINESTRING
- * return 2 on exception, 1 on true, 0 on false
-char
-GEOSisClosed_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return 2;
+ handle->ERROR_MESSAGE("Argument is not a LineString or MultiLineString");
+ return 2;
+ catch(...) {
return 2;
- try
- using geos::geom::MultiLineString;
- if ( ls ) {
- return ls->isClosed();
- const MultiLineString *mls = dynamic_cast<const MultiLineString *>(g1);
- if ( mls ) {
- return mls->isClosed();
- handle->ERROR_MESSAGE("Argument is not a LineString or MultiLineString");
- return 2;
- catch (...)
+ * return 0 on exception, otherwise 1
+ int
+ GEOSGeomGetLength_r(GEOSContextHandle_t extHandle, const Geometry* g1, double* length)
+ return 0;
- return 2;
+ return 0;
- * return 0 on exception, otherwise 1
-int
-GEOSGeomGetLength_r(GEOSContextHandle_t extHandle, const Geometry *g1, double *length)
- return 0;
+ try {
+ if(! ls) {
+ return 0;
+ *length = ls->getLength();
+ return 1;
+ catch(...) {
return 0;
- try
- if ( ! ls )
- return 0;
- *length = ls->getLength();
- return 1;
- catch (...)
+ int
+ GEOSGeomGetNumPoints_r(GEOSContextHandle_t extHandle, const Geometry* g1)
+ return -1;
- return 0;
+ return -1;
-int
-GEOSGeomGetNumPoints_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return -1;
+ try {
+ if(! ls) {
+ return -1;
+ return static_cast<int>(ls->getNumPoints());
+ catch(...) {
return -1;
- try
- if ( ! ls )
- return -1;
- return static_cast<int>(ls->getNumPoints());
- catch (...)
+ * For POINT
+ * returns 0 on exception, otherwise 1
+ int
+ GEOSGeomGetX_r(GEOSContextHandle_t extHandle, const Geometry* g1, double* x)
+ return 0;
- return -1;
+ return 0;
- * For POINT
- * returns 0 on exception, otherwise 1
-int
-GEOSGeomGetX_r(GEOSContextHandle_t extHandle, const Geometry *g1, double *x)
- return 0;
+ try {
+ using geos::geom::Point;
+ const Point* po = dynamic_cast<const Point*>(g1);
+ if(! po) {
+ handle->ERROR_MESSAGE("Argument is not a Point");
+ return 0;
+ *x = po->getX();
+ return 1;
+ catch(...) {
return 0;
- try
- using geos::geom::Point;
- const Point *po = dynamic_cast<const Point *>(g1);
- if ( ! po )
- handle->ERROR_MESSAGE("Argument is not a Point");
- return 0;
- *x = po->getX();
- return 1;
+ * For POINT
+ int
+ GEOSGeomGetY_r(GEOSContextHandle_t extHandle, const Geometry* g1, double* y)
- catch (...)
+ return 0;
- return 0;
+ return 0;
- * For POINT
-int
-GEOSGeomGetY_r(GEOSContextHandle_t extHandle, const Geometry *g1, double *y)
- return 0;
+ try {
+ if(! po) {
+ return 0;
+ *y = po->getY();
+ return 1;
+ catch(...) {
return 0;
- try
- if ( ! po )
- return 0;
- *y = po->getY();
- return 1;
- catch (...)
+ * For POINT
+ int
+ GEOSGeomGetZ_r(GEOSContextHandle_t extHandle, const Geometry* g1, double* z)
+ return 0;
- return 0;
+ return 0;
- * For POINT
-int
-GEOSGeomGetZ_r(GEOSContextHandle_t extHandle, const Geometry *g1, double *z)
- return 0;
+ try {
+ if(! po) {
+ return 0;
+ *z = po->getZ();
+ return 1;
+ catch(...) {
return 0;
- try
+ * Call only on polygon
+ * Return a copy of the internal Geometry.
+ const Geometry*
+ GEOSGetExteriorRing_r(GEOSContextHandle_t extHandle, const Geometry* g1)
- if ( ! po )
- return 0;
+ return NULL;
- *z = po->getZ();
- return 1;
- catch (...)
- return 0;
+ return NULL;
- * Call only on polygon
- * Return a copy of the internal Geometry.
-const Geometry *
-GEOSGetExteriorRing_r(GEOSContextHandle_t extHandle, const Geometry *g1)
- return NULL;
+ try {
+ if(! p) {
+ handle->ERROR_MESSAGE("Invalid argument (must be a Polygon)");
+ return NULL;
+ return p->getExteriorRing();
+ catch(...) {
return NULL;
- try
+ * Return a pointer to internal storage, do not destroy it.
+ const Geometry*
+ GEOSGetInteriorRingN_r(GEOSContextHandle_t extHandle, const Geometry* g1, int n)
- if ( ! p )
- handle->ERROR_MESSAGE("Invalid argument (must be a Polygon)");
return NULL;
- return p->getExteriorRing();
- catch (...)
- return NULL;
+ return NULL;
- * Return a pointer to internal storage, do not destroy it.
-const Geometry *
-GEOSGetInteriorRingN_r(GEOSContextHandle_t extHandle, const Geometry *g1, int n)
- return NULL;
+ try {
+ if(! p) {
+ return NULL;
+ return p->getInteriorRingN(n);
+ catch(...) {
return NULL;
- try
+ Geometry*
+ GEOSGetCentroid_r(GEOSContextHandle_t extHandle, const Geometry* g)
- if ( ! p )
return NULL;
- return p->getInteriorRingN(n);
- catch (...)
- return NULL;
+ return NULL;
-Geometry *
-GEOSGetCentroid_r(GEOSContextHandle_t extHandle, const Geometry *g)
- return NULL;
+ try {
+ Geometry* ret = g->getCentroid();
+ if(0 == ret) {
+ return ret;
+ catch(...) {
return NULL;
- try
+ Geometry*
+ GEOSGeom_createEmptyCollection_r(GEOSContextHandle_t extHandle, int type)
- Geometry *ret = g->getCentroid();
- if (0 == ret)
- const GeometryFactory *gf = handle->geomFactory;
+ return NULL;
- return ret;
- catch (...)
- return NULL;
-Geometry *
-GEOSGeom_createEmptyCollection_r(GEOSContextHandle_t extHandle, int type)
- return NULL;
- return NULL;
+ return NULL;
#ifdef GEOS_DEBUG
- char buf[256];
- sprintf(buf, "createCollection: requested type %d", type);
- handle->NOTICE_MESSAGE("%s", buf);// TODO: Can handle->NOTICE_MESSAGE format that directly?
+ char buf[256];
+ sprintf(buf, "createCollection: requested type %d", type);
+ handle->NOTICE_MESSAGE("%s", buf);// TODO: Can handle->NOTICE_MESSAGE format that directly?
#endif
- try
+ try {
- Geometry *g = 0;
- switch (type)
+ Geometry* g = 0;
+ switch(type) {
case GEOS_GEOMETRYCOLLECTION:
g = gf->createGeometryCollection();
break;
@@ -3404,52 +3017,46 @@ GEOSGeom_createEmptyCollection_r(GEOSContextHandle_t extHandle, int type)
handle->ERROR_MESSAGE("Unsupported type request for GEOSGeom_createEmptyCollection_r");
g = 0;
+ return g;
+ catch(...) {
- return g;
+ return 0;
- catch (...)
+ Geometry*
+ GEOSGeom_createCollection_r(GEOSContextHandle_t extHandle, int type, Geometry** geoms, unsigned int ngeoms)
- return 0;
-Geometry *
-GEOSGeom_createCollection_r(GEOSContextHandle_t extHandle, int type, Geometry **geoms, unsigned int ngeoms)
- return NULL;
+ return NULL;
- return NULL;
+ return NULL;
#ifdef GEOS_DEBUG
- char buf[256];
- sprintf(buf, "PostGIS2GEOS_collection: requested type %d, ngeoms: %d",
- type, ngeoms);
+ char buf[256];
+ sprintf(buf, "PostGIS2GEOS_collection: requested type %d, ngeoms: %d",
+ type, ngeoms);
#endif
- try
- std::vector<Geometry*>* vgeoms = new std::vector<Geometry*>(geoms, geoms + ngeoms);
+ try {
+ std::vector<Geometry*>* vgeoms = new std::vector<Geometry*>(geoms, geoms + ngeoms);
- Geometry *g = 0;
- switch (type)
+ Geometry* g = 0;
+ switch(type) {
g = gf->createGeometryCollection(vgeoms);
break;
@@ -3467,3757 +3074,3362 @@ GEOSGeom_createCollection_r(GEOSContextHandle_t extHandle, int type, Geometry **
delete vgeoms;
g = 0;
- return g;
- catch (...)
- return 0;
+ return g;
+ catch(...) {
-Geometry *
-GEOSPolygonize_r(GEOSContextHandle_t extHandle, const Geometry * const * g, unsigned int ngeoms)
return 0;
+ Geometry*
+ GEOSPolygonize_r(GEOSContextHandle_t extHandle, const Geometry* const* g, unsigned int ngeoms)
- return 0;
- Geometry *out = 0;
+ return 0;
- try
- // Polygonize
- using geos::operation::polygonize::Polygonizer;
- Polygonizer plgnzr;
- for (std::size_t i = 0; i < ngeoms; ++i)
- plgnzr.add(g[i]);
+ return 0;
+ Geometry* out = 0;
+ try {
+ // Polygonize
+ using geos::operation::polygonize::Polygonizer;
+ Polygonizer plgnzr;
+ for(std::size_t i = 0; i < ngeoms; ++i) {
+ plgnzr.add(g[i]);
#if GEOS_DEBUG
- handle->NOTICE_MESSAGE("geometry vector added to polygonizer");
+ handle->NOTICE_MESSAGE("geometry vector added to polygonizer");
#endif
- std::vector<Polygon*> *polys = plgnzr.getPolygons();
- assert(0 != polys);
+ std::vector<Polygon*>* polys = plgnzr.getPolygons();
+ assert(0 != polys);
#if GEOS_DEBUG
- handle->NOTICE_MESSAGE("output polygons got");
+ handle->NOTICE_MESSAGE("output polygons got");
#endif
- // We need a vector of Geometry pointers, not Polygon pointers.
- // STL vector doesn't allow transparent upcast of this
- // nature, so we explicitly convert.
- // (it's just a waste of processor and memory, btw)
- // XXX mloskot: Why not to extent GeometryFactory to accept
- // vector of polygons or extend Polygonizer to return list of Geometry*
- // or add a wrapper which semantic is similar to:
- // std::vector<as_polygon<Geometry*> >
- std::vector<Geometry*> *polyvec = new std::vector<Geometry *>(polys->size());
- for (std::size_t i = 0; i < polys->size(); ++i)
- (*polyvec)[i] = (*polys)[i];
- delete polys;
- polys = 0;
+ // We need a vector of Geometry pointers, not Polygon pointers.
+ // STL vector doesn't allow transparent upcast of this
+ // nature, so we explicitly convert.
+ // (it's just a waste of processor and memory, btw)
+ // XXX mloskot: Why not to extent GeometryFactory to accept
+ // vector of polygons or extend Polygonizer to return list of Geometry*
+ // or add a wrapper which semantic is similar to:
+ // std::vector<as_polygon<Geometry*> >
+ std::vector<Geometry*>* polyvec = new std::vector<Geometry*>(polys->size());
+ for(std::size_t i = 0; i < polys->size(); ++i) {
+ (*polyvec)[i] = (*polys)[i];
+ delete polys;
+ polys = 0;
- // The below takes ownership of the passed vector,
- // so we must *not* delete it
- out = gf->createGeometryCollection(polyvec);
- catch (...)
- return out;
+ // The below takes ownership of the passed vector,
+ // so we must *not* delete it
+ out = gf->createGeometryCollection(polyvec);
+ catch(...) {
-Geometry *
-GEOSPolygonizer_getCutEdges_r(GEOSContextHandle_t extHandle, const Geometry * const * g, unsigned int ngeoms)
- return 0;
+ return out;
+ Geometry*
+ GEOSPolygonizer_getCutEdges_r(GEOSContextHandle_t extHandle, const Geometry* const* g, unsigned int ngeoms)
- return 0;
+ return 0;
- try
- // Polygonize
- plgnzr.add(g[i]);
+ return 0;
-#if GEOS_DEBUG
-#endif
- const std::vector<const LineString *>& lines = plgnzr.getCutEdges();
+ try {
+ // Polygonize
+ plgnzr.add(g[i]);
#if GEOS_DEBUG
#endif
- // XXX mloskot: See comment for GEOSPolygonize_r
- std::vector<Geometry*> *linevec = new std::vector<Geometry *>(lines.size());
- for (std::size_t i = 0, n=lines.size(); i < n; ++i)
- (*linevec)[i] = lines[i]->clone();
- out = gf->createGeometryCollection(linevec);
- catch (...)
- return out;
-Geometry *
-GEOSPolygonize_full_r(GEOSContextHandle_t extHandle, const Geometry* g,
- Geometry** cuts, Geometry** dangles, Geometry** invalid)
- return 0;
- return 0;
- try
- // Polygonize
- for (std::size_t i = 0; i <g->getNumGeometries(); ++i)
- plgnzr.add(g->getGeometryN(i));
+ const std::vector<const LineString*>& lines = plgnzr.getCutEdges();
#if GEOS_DEBUG
#endif
- if ( cuts ) {
- *cuts = gf->createGeometryCollection(linevec);
- if ( dangles ) {
- const std::vector<const LineString *>& lines = plgnzr.getDangles();
- *dangles = gf->createGeometryCollection(linevec);
+ // XXX mloskot: See comment for GEOSPolygonize_r
+ std::vector<Geometry*>* linevec = new std::vector<Geometry*>(lines.size());
- if ( invalid ) {
+ for(std::size_t i = 0, n = lines.size(); i < n; ++i) {
+ (*linevec)[i] = lines[i]->clone();
- const std::vector<LineString *>& lines = plgnzr.getInvalidRingLines();
- *invalid = gf->createGeometryCollection(linevec);
- delete polys;
- return gf->createGeometryCollection(polyvec);
- return 0;
- catch (...)
- return 0;
+ out = gf->createGeometryCollection(linevec);
+ catch(...) {
-Geometry *
-GEOSLineMerge_r(GEOSContextHandle_t extHandle, const Geometry *g)
- return 0;
+ return out;
+ Geometry*
+ GEOSPolygonize_full_r(GEOSContextHandle_t extHandle, const Geometry* g,
+ Geometry** cuts, Geometry** dangles, Geometry** invalid)
- return 0;
+ return 0;
- try
- using geos::operation::linemerge::LineMerger;
- LineMerger lmrgr;
- lmrgr.add(g);
+ return 0;
- std::vector<LineString *>* lines = lmrgr.getMergedLineStrings();
- assert(0 != lines);
+ try {
+ // Polygonize
+ for(std::size_t i = 0; i < g->getNumGeometries(); ++i) {
+ plgnzr.add(g->getGeometryN(i));
#if GEOS_DEBUG
- handle->NOTICE_MESSAGE("output lines got");
#endif
- std::vector<Geometry *>*geoms = new std::vector<Geometry *>(lines->size());
- for (std::vector<Geometry *>::size_type i = 0; i < lines->size(); ++i)
- (*geoms)[i] = (*lines)[i];
- delete lines;
- lines = 0;
- out = gf->buildGeometry(geoms);
- // XXX: old version
- //out = gf->createGeometryCollection(geoms);
- catch (...)
- return out;
-Geometry *
-GEOSReverse_r(GEOSContextHandle_t extHandle, const Geometry *g)
- assert(0 != g);
- return nullptr;
- return nullptr;
- try
- return g->reverse();
- catch (...)
- return nullptr;
- void*
-GEOSGeom_getUserData_r(GEOSContextHandle_t extHandle, const Geometry *g)
- assert(0 != g);
- return 0;
- return 0;
- try
- return g->getUserData();
- catch (...)
- return NULL;
-int
-GEOSGetSRID_r(GEOSContextHandle_t extHandle, const Geometry *g)
- assert(0 != g);
- return 0;
- return 0;
- try
- return g->getSRID();
- catch (...)
- return 0;
-const char* GEOSversion()
- static char version[256];
- sprintf(version, "%s " GEOS_REVISION, GEOS_CAPI_VERSION);
- return version;
-const char* GEOSjtsport()
- return GEOS_JTS_PORT;
-char
-GEOSHasZ_r(GEOSContextHandle_t extHandle, const Geometry *g)
- assert(0 != g);
- return -1;
- return -1;
- if (g->isEmpty())
- return false;
- assert(0 != g->getCoordinate());
- double az = g->getCoordinate()->z;
- //handle->ERROR_MESSAGE("ZCoord: %g", az);
- return static_cast<char>(std::isfinite(az));
-int
-GEOS_getWKBOutputDims_r(GEOSContextHandle_t extHandle)
- return -1;
- return -1;
- return handle->WKBOutputDims;
-int
-GEOS_setWKBOutputDims_r(GEOSContextHandle_t extHandle, int newdims)
- return -1;
- return -1;
- if ( newdims < 2 || newdims > 3 )
- handle->ERROR_MESSAGE("WKB output dimensions out of range 2..3");
- const int olddims = handle->WKBOutputDims;
- handle->WKBOutputDims = newdims;
- return olddims;
-int
-GEOS_getWKBByteOrder_r(GEOSContextHandle_t extHandle)
- return -1;
- return -1;
- return handle->WKBByteOrder;
-int
-GEOS_setWKBByteOrder_r(GEOSContextHandle_t extHandle, int byteOrder)
- return -1;
- return -1;
- const int oldByteOrder = handle->WKBByteOrder;
- handle->WKBByteOrder = byteOrder;
- return oldByteOrder;
-GEOSCoordSeq_create_r(GEOSContextHandle_t extHandle, unsigned int size, unsigned int dims)
- return NULL;
- return NULL;
- try
- return gf->getCoordinateSequenceFactory()->create(size, dims);
- catch (...)
- return NULL;
-int
-GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t extHandle, CoordinateSequence *cs,
- unsigned int idx, unsigned int dim, double val)
- assert(0 != cs);
- return 0;
- return 0;
- try
- cs->setOrdinate(idx, dim, val);
- return 1;
- catch (...)
- return 0;
-int
-GEOSCoordSeq_setX_r(GEOSContextHandle_t extHandle, CoordinateSequence *s, unsigned int idx, double val)
- return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 0, val);
-int
-GEOSCoordSeq_setY_r(GEOSContextHandle_t extHandle, CoordinateSequence *s, unsigned int idx, double val)
- return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 1, val);
-int
-GEOSCoordSeq_setZ_r(GEOSContextHandle_t extHandle, CoordinateSequence *s, unsigned int idx, double val)
- return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 2, val);
+ if(cuts) {
-GEOSCoordSeq_clone_r(GEOSContextHandle_t extHandle, const CoordinateSequence *cs)
- assert(0 != cs);
- return NULL;
+ *cuts = gf->createGeometryCollection(linevec);
- return NULL;
+ if(dangles) {
- try
- return cs->clone();
- catch (...)
+ const std::vector<const LineString*>& lines = plgnzr.getDangles();
- return NULL;
+ *dangles = gf->createGeometryCollection(linevec);
-int
-GEOSCoordSeq_getOrdinate_r(GEOSContextHandle_t extHandle, const CoordinateSequence *cs,
- unsigned int idx, unsigned int dim, double *val)
- assert(0 != cs);
- assert(0 != val);
+ if(invalid) {
- return 0;
+ const std::vector<LineString*>& lines = plgnzr.getInvalidRingLines();
- return 0;
+ *invalid = gf->createGeometryCollection(linevec);
- try
- double d = cs->getOrdinate(idx, dim);
- *val = d;
+ delete polys;
- return 1;
- catch (...)
- return 0;
-int
-GEOSCoordSeq_getX_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s, unsigned int idx, double *val)
- return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 0, val);
-int
-GEOSCoordSeq_getY_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s, unsigned int idx, double *val)
- return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 1, val);
-int
-GEOSCoordSeq_getZ_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s, unsigned int idx, double *val)
- return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 2, val);
-int
-GEOSCoordSeq_getSize_r(GEOSContextHandle_t extHandle, const CoordinateSequence *cs, unsigned int *size)
- assert(0 != cs);
- return 0;
+ return gf->createGeometryCollection(polyvec);
- GEOSContextHandleInternal_t *handle = 0;
- handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
- return 0;
- try
- const std::size_t sz = cs->getSize();
- *size = static_cast<unsigned int>(sz);
- return 1;
- catch (...)
- return 0;
-int
-GEOSCoordSeq_getDimensions_r(GEOSContextHandle_t extHandle, const CoordinateSequence *cs, unsigned int *dims)
- assert(0 != cs);
- assert(0 != dims);
- return 0;
- return 0;
- try
- const std::size_t dim = cs->getDimension();
- *dims = static_cast<unsigned int>(dim);
- return 1;
+ return 0;
+ catch(...) {
+ return 0;
- catch (...)
+ Geometry*
+ GEOSLineMerge_r(GEOSContextHandle_t extHandle, const Geometry* g)
+ return 0;
- return 0;
+ GEOSContextHandleInternal_t* handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if(0 == handle->initialized) {
+ return 0;
-int
-GEOSCoordSeq_isCCW_r(GEOSContextHandle_t extHandle, const CoordinateSequence *cs, char *val)
- assert(cs != nullptr);
- assert(val != nullptr);
- if (extHandle == nullptr) {
- return 0;
+ try {
+ using geos::operation::linemerge::LineMerger;
+ LineMerger lmrgr;
+ lmrgr.add(g);
- GEOSContextHandleInternal_t *handle = nullptr;
- return 0;
- try
- *val = geos::algorithm::Orientation::isCCW(cs);
- return 1;
+ std::vector<LineString*>* lines = lmrgr.getMergedLineStrings();
+ assert(0 != lines);
- catch (...)
+#if GEOS_DEBUG
+ handle->NOTICE_MESSAGE("output lines got");
+#endif
- return 0;
+ std::vector<Geometry*>* geoms = new std::vector<Geometry*>(lines->size());
+ for(std::vector<Geometry*>::size_type i = 0; i < lines->size(); ++i) {
+ (*geoms)[i] = (*lines)[i];
+ delete lines;
+ lines = 0;
-void
-GEOSCoordSeq_destroy_r(GEOSContextHandle_t extHandle, CoordinateSequence *s)
+ out = gf->buildGeometry(geoms);
- try
- delete s;
- return;
+ // XXX: old version
+ //out = gf->createGeometryCollection(geoms);
- return;
+ catch(...) {
+ return out;
- catch (...)
+ Geometry*
+ GEOSReverse_r(GEOSContextHandle_t extHandle, const Geometry* g)
- return;
+ assert(0 != g);
+ return nullptr;
- return;
+ return nullptr;
-const CoordinateSequence *
-GEOSGeom_getCoordSeq_r(GEOSContextHandle_t extHandle, const Geometry *g)
- return 0;
+ try {
+ return g->reverse();
+ catch(...) {
- return 0;
+ return nullptr;
- try
+ void*
+ GEOSGeom_getUserData_r(GEOSContextHandle_t extHandle, const Geometry* g)
+ assert(0 != g);
- if ( ls )
- return ls->getCoordinatesRO();
+ if(0 == extHandle) {
+ return 0;
- const Point *p = dynamic_cast<const Point *>(g);
- if ( p )
- return p->getCoordinatesRO();
+ return 0;
- handle->ERROR_MESSAGE("Geometry must be a Point or LineString");
- return 0;
- catch (const std::exception &e)
- handle->ERROR_MESSAGE("%s", e.what());
- catch (...)
- handle->ERROR_MESSAGE("Unknown exception thrown");
- return 0;
+ try {
+ return g->getUserData();
+ catch(...) {
-Geometry *
-GEOSGeom_createEmptyPoint_r(GEOSContextHandle_t extHandle)
return NULL;
+ int
+ GEOSGetSRID_r(GEOSContextHandle_t extHandle, const Geometry* g)
- return NULL;
+ assert(0 != g);
- try
- catch (...)
+ return 0;
- return NULL;
+ return 0;
-Geometry *
-GEOSGeom_createPoint_r(GEOSContextHandle_t extHandle, CoordinateSequence *cs)
- return 0;
+ try {
+ return g->getSRID();
+ catch(const std::exception& e) {
+ handle->ERROR_MESSAGE("%s", e.what());
+ catch(...) {
+ handle->ERROR_MESSAGE("Unknown exception thrown");
return 0;
- try
- return gf->createPoint(cs);
- catch (...)
+ const char* GEOSversion()
+ static char version[256];
+ sprintf(version, "%s " GEOS_REVISION, GEOS_CAPI_VERSION);
+ return version;
- return 0;
-Geometry *
-GEOSGeom_createLinearRing_r(GEOSContextHandle_t extHandle, CoordinateSequence *cs)
+ const char* GEOSjtsport()
- return NULL;
+ return GEOS_JTS_PORT;
+ char
+ GEOSHasZ_r(GEOSContextHandle_t extHandle, const Geometry* g)
- return NULL;
+ assert(0 != g);
- try
+ return -1;
- return gf->createLinearRing(cs);
- catch (...)
+ return -1;
- return NULL;
+ if(g->isEmpty()) {
+ return false;
+ assert(0 != g->getCoordinate());
-Geometry *
-GEOSGeom_createEmptyLineString_r(GEOSContextHandle_t extHandle)
- return NULL;
+ double az = g->getCoordinate()->z;
+ //handle->ERROR_MESSAGE("ZCoord: %g", az);
- return NULL;
+ return static_cast<char>(std::isfinite(az));
- try
- return gf->createLineString();
- catch (...)
+ int
+ GEOS_getWKBOutputDims_r(GEOSContextHandle_t extHandle)
+ return -1;
- return NULL;
+ return -1;
-Geometry *
-GEOSGeom_createLineString_r(GEOSContextHandle_t extHandle, CoordinateSequence *cs)
- return NULL;
+ return handle->WKBOutputDims;
+ int
+ GEOS_setWKBOutputDims_r(GEOSContextHandle_t extHandle, int newdims)
- return NULL;
+ return -1;
- try
+ return -1;
- return gf->createLineString(cs);
- catch (...)
+ if(newdims < 2 || newdims > 3) {
+ handle->ERROR_MESSAGE("WKB output dimensions out of range 2..3");
- return NULL;
+ const int olddims = handle->WKBOutputDims;
+ handle->WKBOutputDims = newdims;
-Geometry *
-GEOSGeom_createEmptyPolygon_r(GEOSContextHandle_t extHandle)
- return NULL;
+ return olddims;
+ int
+ GEOS_getWKBByteOrder_r(GEOSContextHandle_t extHandle)
- return NULL;
+ return -1;
- try
- return gf->createPolygon();
+ return -1;
+ return handle->WKBByteOrder;
- catch (...)
+ int
+ GEOS_setWKBByteOrder_r(GEOSContextHandle_t extHandle, int byteOrder)
+ return -1;
- return NULL;
+ return -1;
-Geometry *
-GEOSGeom_createPolygon_r(GEOSContextHandle_t extHandle, Geometry *shell, Geometry **holes, unsigned int nholes)
- // FIXME: holes must be non-nullptr or may be nullptr?
- //assert(0 != holes);
+ const int oldByteOrder = handle->WKBByteOrder;
+ handle->WKBByteOrder = byteOrder;
- return NULL;
+ return oldByteOrder;
- return NULL;
- try
+ GEOSCoordSeq_create_r(GEOSContextHandle_t extHandle, unsigned int size, unsigned int dims)
- using geos::geom::LinearRing;
- std::vector<Geometry *> *vholes = new std::vector<Geometry *>(holes, holes + nholes);
- LinearRing *nshell = dynamic_cast<LinearRing *>(shell);
- if ( ! nshell )
- handle->ERROR_MESSAGE("Shell is not a LinearRing");
- delete vholes;
return NULL;
- return gf->createPolygon(nshell, vholes);
- catch (...)
- return NULL;
-Geometry *
-GEOSGeom_clone_r(GEOSContextHandle_t extHandle, const Geometry *g)
- assert(0 != g);
+ return NULL;
- return NULL;
+ try {
+ return gf->getCoordinateSequenceFactory()->create(size, dims);
+ catch(...) {
return NULL;
- try
- return g->clone();
- catch (...)
+ int
+ GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs,
+ unsigned int idx, unsigned int dim, double val)
- return NULL;
+ assert(0 != cs);
+ return 0;
-GEOSGeometry *
-GEOSGeom_setPrecision_r(GEOSContextHandle_t extHandle, const GEOSGeometry *g,
- double gridSize, int flags)
- using namespace geos::geom;
+ return 0;
- assert(0 != g);
+ try {
+ cs->setOrdinate(idx, dim, val);
+ return 1;
+ catch(...) {
- return NULL;
+ return 0;
+ int
+ GEOSCoordSeq_setX_r(GEOSContextHandle_t extHandle, CoordinateSequence* s, unsigned int idx, double val)
- return NULL;
+ return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 0, val);
- try
+ int
+ GEOSCoordSeq_setY_r(GEOSContextHandle_t extHandle, CoordinateSequence* s, unsigned int idx, double val)
- const PrecisionModel *pm = g->getPrecisionModel();
- double cursize = pm->isFloating() ? 0 : 1.0/pm->getScale();
- std::unique_ptr<PrecisionModel> newpm;
- if ( gridSize ) newpm.reset( new PrecisionModel(1.0/gridSize) );
- else newpm.reset( new PrecisionModel() );
- GeometryFactory::Ptr gf =
- GeometryFactory::create( newpm.get(), g->getSRID() );
- Geometry *ret;
- if ( gridSize && cursize != gridSize )
- // We need to snap the geometry
- GeometryPrecisionReducer reducer( *gf );
- reducer.setPointwise( flags & GEOS_PREC_NO_TOPO );
- reducer.setRemoveCollapsedComponents( ! (flags & GEOS_PREC_KEEP_COLLAPSED) );
- ret = reducer.reduce( *g ).release();
- else
- // No need or willing to snap, just change the factory
- ret = gf->createGeometry(g);
- return ret;
+ return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 1, val);
+ int
+ GEOSCoordSeq_setZ_r(GEOSContextHandle_t extHandle, CoordinateSequence* s, unsigned int idx, double val)
+ return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 2, val);
- catch (...)
+ GEOSCoordSeq_clone_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs)
+ assert(0 != cs);
- return NULL;
+ return NULL;
-double
-GEOSGeom_getPrecision_r(GEOSContextHandle_t extHandle, const GEOSGeometry *g)
+ return NULL;
- assert(0 != g);
+ try {
+ return cs->clone();
+ catch(...) {
- return -1;
+ return NULL;
+ int
+ GEOSCoordSeq_getOrdinate_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs,
+ unsigned int idx, unsigned int dim, double* val)
- return -1;
+ assert(0 != cs);
+ assert(0 != val);
- try
- return cursize;
- catch (...)
+ return 0;
- return -1;
+ return 0;
+ try {
+ double d = cs->getOrdinate(idx, dim);
+ *val = d;
+ return 1;
+ catch(...) {
-int
-GEOSGeom_getDimensions_r(GEOSContextHandle_t extHandle, const Geometry *g)
return 0;
+ int
+ GEOSCoordSeq_getX_r(GEOSContextHandle_t extHandle, const CoordinateSequence* s, unsigned int idx, double* val)
- return 0;
+ return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 0, val);
- try
+ int
+ GEOSCoordSeq_getY_r(GEOSContextHandle_t extHandle, const CoordinateSequence* s, unsigned int idx, double* val)
- return (int) g->getDimension();
+ return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 1, val);
+ int
+ GEOSCoordSeq_getZ_r(GEOSContextHandle_t extHandle, const CoordinateSequence* s, unsigned int idx, double* val)
+ return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 2, val);
- catch (...)
+ int
+ GEOSCoordSeq_getSize_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int* size)
+ assert(0 != cs);
- return 0;
+ return 0;
-int
-GEOSGeom_getCoordinateDimension_r(GEOSContextHandle_t extHandle, const Geometry *g)
- return 0;
+ return 0;
+ try {
+ const std::size_t sz = cs->getSize();
+ *size = static_cast<unsigned int>(sz);
+ return 1;
+ catch(...) {
return 0;
- try
- return g->getCoordinateDimension();
+ int
+ GEOSCoordSeq_getDimensions_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int* dims)
- catch (...)
+ assert(0 != cs);
+ assert(0 != dims);
- return 0;
+ return 0;
-int
-GEOSGeom_getXMin_r(GEOSContextHandle_t extHandle, const Geometry *g, double *value)
- return 0;
+ return 0;
+ try {
+ const std::size_t dim = cs->getDimension();
+ *dims = static_cast<unsigned int>(dim);
+ return 1;
+ catch(...) {
return 0;
- try
+ int
+ GEOSCoordSeq_isCCW_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, char* val)
- if (g->isEmpty())
+ assert(cs != nullptr);
+ assert(val != nullptr);
+ if(extHandle == nullptr) {
return 0;
- *value = g->getEnvelopeInternal()->getMinX();
- return 1;
- catch (...)
+ GEOSContextHandleInternal_t* handle = nullptr;
+ return 0;
+ try {
+ *val = geos::algorithm::Orientation::isCCW(cs);
+ return 1;
- return 0;
+ catch(...) {
-int
-GEOSGeom_getXMax_r(GEOSContextHandle_t extHandle, const Geometry *g, double *value)
return 0;
+ void
+ GEOSCoordSeq_destroy_r(GEOSContextHandle_t extHandle, CoordinateSequence* s)
- return 0;
+ try {
+ delete s;
+ return;
+ return;
+ catch(...) {
+ return;
+ return;
- try
+ const CoordinateSequence*
+ GEOSGeom_getCoordSeq_r(GEOSContextHandle_t extHandle, const Geometry* g)
- if (g->isEmpty())
return 0;
- *value = g->getEnvelopeInternal()->getMaxX();
- return 1;
- catch (...)
+ return 0;
- return 0;
+ try {
+ if(ls) {
+ return ls->getCoordinatesRO();
+ const Point* p = dynamic_cast<const Point*>(g);
+ if(p) {
+ return p->getCoordinatesRO();
+ handle->ERROR_MESSAGE("Geometry must be a Point or LineString");
+ return 0;
+ catch(...) {
-int
-GEOSGeom_getYMin_r(GEOSContextHandle_t extHandle, const Geometry *g, double *value)
return 0;
+ Geometry*
+ GEOSGeom_createEmptyPoint_r(GEOSContextHandle_t extHandle)
- return 0;
+ return NULL;
+ return NULL;
+ try {
+ catch(...) {
+ return NULL;
- try
+ Geometry*
+ GEOSGeom_createPoint_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs)
- if (g->isEmpty())
return 0;
- *value = g->getEnvelopeInternal()->getMinY();
- return 1;
- catch (...)
+ return 0;
- return 0;
+ try {
+ return gf->createPoint(cs);
+ catch(...) {
-int
-GEOSGeom_getYMax_r(GEOSContextHandle_t extHandle, const Geometry *g, double *value)
return 0;
+ Geometry*
+ GEOSGeom_createLinearRing_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs)
- return 0;
+ return NULL;
- try
- if (g->isEmpty())
- return 0;
+ return NULL;
- *value = g->getEnvelopeInternal()->getMaxY();
- return 1;
- catch (...)
+ try {
- return 0;
+ return gf->createLinearRing(cs);
+ catch(...) {
-Geometry *
-GEOSSimplify_r(GEOSContextHandle_t extHandle, const Geometry *g1, double tolerance)
return NULL;
+ Geometry*
+ GEOSGeom_createEmptyLineString_r(GEOSContextHandle_t extHandle)
- return NULL;
+ return NULL;
- try
- using namespace geos::simplify;
- Geometry::Ptr g(DouglasPeuckerSimplifier::simplify(g1, tolerance));
- return g.release();
- catch (...)
+ return NULL;
- return NULL;
+ try {
+ return gf->createLineString();
+ catch(...) {
-Geometry *
-GEOSTopologyPreserveSimplify_r(GEOSContextHandle_t extHandle, const Geometry *g1, double tolerance)
return NULL;
+ Geometry*
+ GEOSGeom_createLineString_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs)
+ return NULL;
+ return NULL;
+ try {
+ return gf->createLineString(cs);
+ catch(...) {
return NULL;
- try
- Geometry::Ptr g(TopologyPreservingSimplifier::simplify(g1, tolerance));
- catch (...)
+ Geometry*
+ GEOSGeom_createEmptyPolygon_r(GEOSContextHandle_t extHandle)
+ return NULL;
- return NULL;
+ return NULL;
+ try {
+ return gf->createPolygon();
+ catch(...) {
-/* WKT Reader */
-WKTReader *
-GEOSWKTReader_create_r(GEOSContextHandle_t extHandle)
return NULL;
+ Geometry*
+ GEOSGeom_createPolygon_r(GEOSContextHandle_t extHandle, Geometry* shell, Geometry** holes, unsigned int nholes)
+ // FIXME: holes must be non-nullptr or may be nullptr?
+ //assert(0 != holes);
+ return NULL;
+ return NULL;
+ try {
+ using geos::geom::LinearRing;
+ std::vector<Geometry*>* vholes = new std::vector<Geometry*>(holes, holes + nholes);
+ LinearRing* nshell = dynamic_cast<LinearRing*>(shell);
+ if(! nshell) {
+ handle->ERROR_MESSAGE("Shell is not a LinearRing");
+ delete vholes;
+ return NULL;
+ return gf->createPolygon(nshell, vholes);
+ catch(...) {
return NULL;
- try
- using geos::io::WKTReader;
- return new WKTReader((GeometryFactory*)handle->geomFactory);
+ Geometry*
+ GEOSGeom_clone_r(GEOSContextHandle_t extHandle, const Geometry* g)
- catch (...)
+ assert(0 != g);
- return NULL;
+ return NULL;
-void
-GEOSWKTReader_destroy_r(GEOSContextHandle_t extHandle, WKTReader *reader)
+ return NULL;
- try
- delete reader;
+ try {
+ return g->clone();
+ catch(...) {
+ return NULL;
+ GEOSGeometry*
+ GEOSGeom_setPrecision_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g,
+ double gridSize, int flags)
- return;
+ using namespace geos::geom;
+ assert(0 != g);
+ return NULL;
- return;
+ return NULL;
+ try {
+ const PrecisionModel* pm = g->getPrecisionModel();
+ double cursize = pm->isFloating() ? 0 : 1.0 / pm->getScale();
+ std::unique_ptr<PrecisionModel> newpm;
+ if(gridSize) {
+ newpm.reset(new PrecisionModel(1.0 / gridSize));
+ else {
+ newpm.reset(new PrecisionModel());
+ GeometryFactory::Ptr gf =
+ GeometryFactory::create(newpm.get(), g->getSRID());
+ Geometry* ret;
+ if(gridSize && cursize != gridSize) {
+ // We need to snap the geometry
+ GeometryPrecisionReducer reducer(*gf);
+ reducer.setPointwise(flags & GEOS_PREC_NO_TOPO);
+ reducer.setRemoveCollapsedComponents(!(flags & GEOS_PREC_KEEP_COLLAPSED));
+ ret = reducer.reduce(*g).release();
+ else {
+ // No need or willing to snap, just change the factory
+ ret = gf->createGeometry(g);
+ return ret;
+ catch(...) {
+ return NULL;
- catch (...)
+ double
+ GEOSGeom_getPrecision_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g)
- return;
+ assert(0 != g);
+ return -1;
- return;
+ return -1;
+ try {
+ return cursize;
+ catch(...) {
+ return -1;
+ int
+ GEOSGeom_getDimensions_r(GEOSContextHandle_t extHandle, const Geometry* g)
+ return 0;
-Geometry*
-GEOSWKTReader_read_r(GEOSContextHandle_t extHandle, WKTReader *reader, const char *wkt)
- assert(0 != reader);
+ return 0;
- return 0;
+ try {
+ return (int) g->getDimension();
+ catch(...) {
return 0;
- try
- Geometry *g = reader->read(wktstring);
- return g;
- catch (...)
+ int
+ GEOSGeom_getCoordinateDimension_r(GEOSContextHandle_t extHandle, const Geometry* g)
+ return 0;
- return 0;
+ return 0;
-/* WKT Writer */
-WKTWriter *
-GEOSWKTWriter_create_r(GEOSContextHandle_t extHandle)
- return 0;
+ try {
+ return g->getCoordinateDimension();
+ catch(...) {
return 0;
- try
+ int
+ GEOSGeom_getXMin_r(GEOSContextHandle_t extHandle, const Geometry* g, double* value)
- using geos::io::WKTWriter;
- return new WKTWriter();
- catch (...)
+ return 0;
- return 0;
+ return 0;
-void
-GEOSWKTWriter_destroy_r(GEOSContextHandle_t extHandle, WKTWriter *Writer)
+ try {
+ return 0;
+ *value = g->getEnvelopeInternal()->getMinX();
+ return 1;
+ catch(...) {
- try
- delete Writer;
+ return 0;
+ int
+ GEOSGeom_getXMax_r(GEOSContextHandle_t extHandle, const Geometry* g, double* value)
- return;
+ return 0;
- return;
+ return 0;
+ try {
+ return 0;
+ *value = g->getEnvelopeInternal()->getMaxX();
+ return 1;
+ catch(...) {
+ return 0;
- catch (...)
+ int
+ GEOSGeom_getYMin_r(GEOSContextHandle_t extHandle, const Geometry* g, double* value)
- return;
+ return 0;
- return;
+ return 0;
+ try {
+ return 0;
-char*
-GEOSWKTWriter_write_r(GEOSContextHandle_t extHandle, WKTWriter *writer, const Geometry *geom)
- assert(0 != writer);
+ *value = g->getEnvelopeInternal()->getMinY();
+ return 1;
+ catch(...) {
- return NULL;
+ return 0;
+ int
+ GEOSGeom_getYMax_r(GEOSContextHandle_t extHandle, const Geometry* g, double* value)
- return NULL;
+ return 0;
- try
- std::string sgeom(writer->write(geom));
- char *result = gstrdup(sgeom);
- return result;
- catch (...)
+ return 0;
- return NULL;
+ try {
+ return 0;
-void
-GEOSWKTWriter_setTrim_r(GEOSContextHandle_t extHandle, WKTWriter *writer, char trim)
+ *value = g->getEnvelopeInternal()->getMaxY();
+ return 1;
+ catch(...) {
- return;
+ return 0;
+ Geometry*
+ GEOSSimplify_r(GEOSContextHandle_t extHandle, const Geometry* g1, double tolerance)
- return;
+ return NULL;
- writer->setTrim(0 != trim);
+ return NULL;
-void
-GEOSWKTWriter_setRoundingPrecision_r(GEOSContextHandle_t extHandle, WKTWriter *writer, int precision)
+ try {
+ using namespace geos::simplify;
+ Geometry::Ptr g(DouglasPeuckerSimplifier::simplify(g1, tolerance));
+ return g.release();
+ catch(...) {
- return;
+ return NULL;
+ Geometry*
+ GEOSTopologyPreserveSimplify_r(GEOSContextHandle_t extHandle, const Geometry* g1, double tolerance)
- return;
+ return NULL;
- writer->setRoundingPrecision(precision);
+ return NULL;
-void
-GEOSWKTWriter_setOutputDimension_r(GEOSContextHandle_t extHandle, WKTWriter *writer, int dim)
+ try {
+ Geometry::Ptr g(TopologyPreservingSimplifier::simplify(g1, tolerance));
+ catch(...) {
- return;
+ return NULL;
- return;
- try
- writer->setOutputDimension(dim);
- catch (...)
+ /* WKT Reader */
+ WKTReader*
+ GEOSWKTReader_create_r(GEOSContextHandle_t extHandle)
+ return NULL;
-int
-GEOSWKTWriter_getOutputDimension_r(GEOSContextHandle_t extHandle, WKTWriter *writer)
+ return NULL;
- return -1;
+ try {
+ using geos::io::WKTReader;
+ return new WKTReader((GeometryFactory*)handle->geomFactory);
+ catch(...) {
- return -1;
+ return NULL;
- int dim = -1;
- try
- dim = writer->getOutputDimension();
- catch (...)
+ void
+ GEOSWKTReader_destroy_r(GEOSContextHandle_t extHandle, WKTReader* reader)
- return dim;
-void
-GEOSWKTWriter_setOld3D_r(GEOSContextHandle_t extHandle, WKTWriter *writer, int useOld3D)
+ try {
+ delete reader;
+ return;
- return;
+ return;
- return;
+ catch(...) {
+ return;
- writer->setOld3D(0 != useOld3D);
+ return;
-/* WKB Reader */
-WKBReader *
-GEOSWKBReader_create_r(GEOSContextHandle_t extHandle)
- return NULL;
- return NULL;
- try
- return new WKBReader(*(GeometryFactory*)handle->geomFactory);
- catch (...)
+ Geometry*
+ GEOSWKTReader_read_r(GEOSContextHandle_t extHandle, WKTReader* reader, const char* wkt)
- return NULL;
+ assert(0 != reader);
-void
-GEOSWKBReader_destroy_r(GEOSContextHandle_t extHandle, WKBReader *reader)
- try
- delete reader;
- return;
+ return 0;
- return;
+ return 0;
- catch (...)
- return;
+ try {
+ const std::string wktstring(wkt);
+ Geometry* g = reader->read(wktstring);
+ return g;
- return;
+ catch(...) {
-struct membuf : public std::streambuf
- membuf(char* s, std::size_t n)
- setg(s, s, s + n);
-Geometry*
-GEOSWKBReader_read_r(GEOSContextHandle_t extHandle, WKBReader *reader, const unsigned char *wkb, size_t size)
- assert(0 != wkb);
return 0;
+ /* WKT Writer */
+ WKTWriter*
+ GEOSWKTWriter_create_r(GEOSContextHandle_t extHandle)
+ return 0;
+ return 0;
+ try {
+ using geos::io::WKTWriter;
+ return new WKTWriter();
+ catch(...) {
return 0;
- try
+ void
+ GEOSWKTWriter_destroy_r(GEOSContextHandle_t extHandle, WKTWriter* Writer)
- //std::string wkbstring(reinterpret_cast<const char*>(wkb), size); // make it binary !
- //std::istringstream is(std::ios_base::binary);
- //is.str(wkbstring);
- //is.seekg(0, std::ios::beg); // rewind reader pointer
- // http://stackoverflow.com/questions/2079912/simpler-way-to-create-a-c-memorystream-from-char-size-t-without-copying-t
- membuf mb((char*)wkb, size);
- istream is(&mb);
- Geometry *g = reader->read(is);
- return g;
- catch (...)
+ try {
+ delete Writer;
+ return;
- return 0;
+ return;
-Geometry*
-GEOSWKBReader_readHEX_r(GEOSContextHandle_t extHandle, WKBReader *reader, const unsigned char *hex, size_t size)
- assert(0 != hex);
+ catch(...) {
+ return;
- return 0;
+ return;
- return 0;
- try
- std::istringstream is(std::ios_base::binary);
- is.seekg(0, std::ios::beg); // rewind reader pointer
- Geometry *g = reader->readHEX(is);
- return g;
+ char*
+ GEOSWKTWriter_write_r(GEOSContextHandle_t extHandle, WKTWriter* writer, const Geometry* geom)
- catch (...)
+ assert(0 != writer);
- return 0;
+ return NULL;
-/* WKB Writer */
-WKBWriter *
-GEOSWKBWriter_create_r(GEOSContextHandle_t extHandle)
- return NULL;
+ return NULL;
+ try {
+ std::string sgeom(writer->write(geom));
+ char* result = gstrdup(sgeom);
+ return result;
+ catch(...) {
return NULL;
- try
- using geos::io::WKBWriter;
- return new WKBWriter();
- catch (...)
+ void
+ GEOSWKTWriter_setTrim_r(GEOSContextHandle_t extHandle, WKTWriter* writer, char trim)
- return NULL;
+ return;
-void
-GEOSWKBWriter_destroy_r(GEOSContextHandle_t extHandle, WKBWriter *Writer)
+ return;
- try
- delete Writer;
+ writer->setTrim(0 != trim);
+ void
+ GEOSWKTWriter_setRoundingPrecision_r(GEOSContextHandle_t extHandle, WKTWriter* writer, int precision)
return;
return;
+ writer->setRoundingPrecision(precision);
- catch (...)
+ void
+ GEOSWKTWriter_setOutputDimension_r(GEOSContextHandle_t extHandle, WKTWriter* writer, int dim)
return;
return;
+ try {
+ writer->setOutputDimension(dim);
+ catch(...) {
+ int
+ GEOSWKTWriter_getOutputDimension_r(GEOSContextHandle_t extHandle, WKTWriter* writer)
-/* The caller owns the result */
-unsigned char*
-GEOSWKBWriter_write_r(GEOSContextHandle_t extHandle, WKBWriter *writer, const Geometry *geom, size_t *size)
- assert(0 != geom);
- assert(0 != size);
+ return -1;
- return NULL;
+ return -1;
- return NULL;
+ int dim = -1;
+ try {
+ dim = writer->getOutputDimension();
+ catch(...) {
+ return dim;
- try
+ void
+ GEOSWKTWriter_setOld3D_r(GEOSContextHandle_t extHandle, WKTWriter* writer, int useOld3D)
- std::ostringstream os(std::ios_base::binary);
- writer->write(*geom, os);
- const std::string& wkbstring = os.str();
- const std::size_t len = wkbstring.length();
+ return;
- unsigned char *result = NULL;
- result = (unsigned char*) malloc(len);
- std::memcpy(result, wkbstring.c_str(), len);
- *size = len;
- return result;
+ return;
+ writer->setOld3D(0 != useOld3D);
- catch (...)
+ /* WKB Reader */
+ WKBReader*
+ GEOSWKBReader_create_r(GEOSContextHandle_t extHandle)
- return NULL;
+ return NULL;
-unsigned char*
-GEOSWKBWriter_writeHEX_r(GEOSContextHandle_t extHandle, WKBWriter *writer, const Geometry *geom, size_t *size)
+ return NULL;
- return NULL;
+ using geos::io::WKBReader;
+ try {
+ return new WKBReader(*(GeometryFactory*)handle->geomFactory);
+ catch(...) {
return NULL;
- try
+ void
+ GEOSWKBReader_destroy_r(GEOSContextHandle_t extHandle, WKBReader* reader)
- writer->writeHEX(*geom, os);
- std::string wkbstring(os.str());
- *size = len;
- return result;
- catch (...)
+ try {
+ delete reader;
+ return;
- return NULL;
+ return;
-int
-GEOSWKBWriter_getOutputDimension_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
+ catch(...) {
+ return;
- return 0;
+ return;
- int ret = 0;
- if ( 0 != handle->initialized )
- try
+ struct membuf : public std::streambuf {
+ membuf(char* s, std::size_t n)
- ret = writer->getOutputDimension();
+ setg(s, s, s + n);
- catch (...)
+ Geometry*
+ GEOSWKBReader_read_r(GEOSContextHandle_t extHandle, WKBReader* reader, const unsigned char* wkb, size_t size)
+ assert(0 != wkb);
+ return 0;
- return ret;
+ return 0;
-void
-GEOSWKBWriter_setOutputDimension_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, int newDimension)
+ try {
+ //std::string wkbstring(reinterpret_cast<const char*>(wkb), size); // make it binary !
+ //std::istringstream is(std::ios_base::binary);
+ //is.str(wkbstring);
+ //is.seekg(0, std::ios::beg); // rewind reader pointer
- return;
+ // http://stackoverflow.com/questions/2079912/simpler-way-to-create-a-c-memorystream-from-char-size-t-without-copying-t
+ membuf mb((char*)wkb, size);
+ istream is(&mb);
- try
- writer->setOutputDimension(newDimension);
+ Geometry* g = reader->read(is);
+ return g;
- catch (...)
+ catch(...) {
-int
-GEOSWKBWriter_getByteOrder_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
return 0;
- int ret = 0;
+ Geometry*
+ GEOSWKBReader_readHEX_r(GEOSContextHandle_t extHandle, WKBReader* reader, const unsigned char* hex, size_t size)
- try
- ret = writer->getByteOrder();
+ assert(0 != hex);
- catch (...)
+ return 0;
- return ret;
-void
-GEOSWKBWriter_setByteOrder_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, int newByteOrder)
+ return 0;
- return;
+ try {
+ std::string hexstring(reinterpret_cast<const char*>(hex), size);
+ std::istringstream is(std::ios_base::binary);
+ is.str(hexstring);
+ is.seekg(0, std::ios::beg); // rewind reader pointer
- try
- writer->setByteOrder(newByteOrder);
+ Geometry* g = reader->readHEX(is);
+ return g;
- catch (...)
+ catch(...) {
-char
-GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
+ return 0;
+ /* WKB Writer */
+ WKBWriter*
+ GEOSWKBWriter_create_r(GEOSContextHandle_t extHandle)
- return -1;
+ return NULL;
- int ret = -1;
+ return NULL;
- try
- int srid = writer->getIncludeSRID();
- ret = srid;
+ try {
+ using geos::io::WKBWriter;
+ return new WKBWriter();
- catch (...)
+ catch(...) {
+ return NULL;
- return static_cast<char>(ret);
+ void
+ GEOSWKBWriter_destroy_r(GEOSContextHandle_t extHandle, WKBWriter* Writer)
-void
-GEOSWKBWriter_setIncludeSRID_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, const char newIncludeSRID)
+ try {
+ delete Writer;
+ return;
- return;
+ return;
- try
- writer->setIncludeSRID(newIncludeSRID);
- catch (...)
+ catch(...) {
+ return;
+ return;
-// Prepared Geometry
-const geos::geom::prep::PreparedGeometry*
-GEOSPrepare_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ /* The caller owns the result */
+ unsigned char*
+ GEOSWKBWriter_write_r(GEOSContextHandle_t extHandle, WKBWriter* writer, const Geometry* geom, size_t* size)
- return 0;
+ assert(0 != geom);
+ assert(0 != size);
- return 0;
+ return NULL;
+ return NULL;
- const geos::geom::prep::PreparedGeometry* prep = 0;
+ try {
+ std::ostringstream os(std::ios_base::binary);
+ writer->write(*geom, os);
- try
- prep = geos::geom::prep::PreparedGeometryFactory::prepare(g);
- catch (...)
+ const std::string& wkbstring = os.str();
+ const std::size_t len = wkbstring.length();
+ unsigned char* result = NULL;
+ result = (unsigned char*) malloc(len);
+ std::memcpy(result, wkbstring.c_str(), len);
+ *size = len;
+ return result;
+ catch(...) {
+ return NULL;
- return prep;
-void
-GEOSPreparedGeom_destroy_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry *a)
- try
+ unsigned char*
+ GEOSWKBWriter_writeHEX_r(GEOSContextHandle_t extHandle, WKBWriter* writer, const Geometry* geom, size_t* size)
- delete a;
- if ( 0 == extHandle )
- return;
+ return NULL;
- if ( 0 == handle->initialized )
- return;
+ return NULL;
+ try {
+ writer->writeHEX(*geom, os);
+ std::string wkbstring(os.str());
+ *size = len;
+ return result;
+ catch(...) {
+ return NULL;
- catch (...)
+ int
+ GEOSWKBWriter_getOutputDimension_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
- return;
+ return 0;
+ int ret = 0;
- return;
+ if(0 != handle->initialized) {
+ try {
+ ret = writer->getOutputDimension();
+ catch(...) {
+ return ret;
-char
-GEOSPreparedContains_r(GEOSContextHandle_t extHandle,
- const geos::geom::prep::PreparedGeometry *pg, const Geometry *g)
- assert(0 != pg);
- assert(0 != g);
+ void
+ GEOSWKBWriter_setOutputDimension_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, int newDimension)
- return 2;
- return 2;
+ return;
- try
- bool result = pg->contains(g);
- return result;
+ try {
+ writer->setOutputDimension(newDimension);
+ catch(...) {
- catch (...)
+ int
+ GEOSWKBWriter_getByteOrder_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
- return 2;
+ return 0;
-char
-GEOSPreparedContainsProperly_r(GEOSContextHandle_t extHandle,
- assert(0 != pg);
- assert(0 != g);
+ int ret = 0;
- return 2;
+ try {
+ ret = writer->getByteOrder();
+ catch(...) {
- return 2;
+ return ret;
- try
- bool result = pg->containsProperly(g);
- return result;
- catch (...)
+ void
+ GEOSWKBWriter_setByteOrder_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, int newByteOrder)
- return 2;
-char
-GEOSPreparedCoveredBy_r(GEOSContextHandle_t extHandle,
- assert(0 != pg);
- assert(0 != g);
+ return;
- return 2;
+ try {
+ writer->setByteOrder(newByteOrder);
+ catch(...) {
+ char
+ GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
- return 2;
- try
- bool result = pg->coveredBy(g);
- return result;
- catch (...)
+ return -1;
- return 2;
+ int ret = -1;
-char
-GEOSPreparedCovers_r(GEOSContextHandle_t extHandle,
- assert(0 != pg);
- assert(0 != g);
+ try {
+ int srid = writer->getIncludeSRID();
+ ret = srid;
+ catch(...) {
- return 2;
+ return static_cast<char>(ret);
+ void
+ GEOSWKBWriter_setIncludeSRID_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, const char newIncludeSRID)
- return 2;
- try
- bool result = pg->covers(g);
- return result;
- catch (...)
+ return;
- return 2;
+ try {
+ writer->setIncludeSRID(newIncludeSRID);
+ catch(...) {
-char
-GEOSPreparedCrosses_r(GEOSContextHandle_t extHandle,
- assert(0 != pg);
- assert(0 != g);
- return 2;
+// Prepared Geometry
+ const geos::geom::prep::PreparedGeometry*
+ GEOSPrepare_r(GEOSContextHandle_t extHandle, const Geometry* g)
- return 2;
+ return 0;
- try
- bool result = pg->crosses(g);
- return result;
- catch (...)
+ return 0;
- return 2;
+ const geos::geom::prep::PreparedGeometry* prep = 0;
-char
-GEOSPreparedDisjoint_r(GEOSContextHandle_t extHandle,
- assert(0 != pg);
- assert(0 != g);
+ try {
+ prep = geos::geom::prep::PreparedGeometryFactory::prepare(g);
+ catch(...) {
- return 2;
+ return prep;
+ void
+ GEOSPreparedGeom_destroy_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry* a)
- return 2;
- try
- bool result = pg->disjoint(g);
- return result;
- catch (...)
+ try {
+ delete a;
+ return;
- return 2;
+ return;
-char
-GEOSPreparedIntersects_r(GEOSContextHandle_t extHandle,
- assert(0 != pg);
- assert(0 != g);
+ catch(...) {
+ return;
- return 2;
+ return;
- return 2;
- try
- bool result = pg->intersects(g);
- return result;
+ char
+ GEOSPreparedContains_r(GEOSContextHandle_t extHandle,
+ const geos::geom::prep::PreparedGeometry* pg, const Geometry* g)
- catch (...)
+ assert(0 != pg);
+ assert(0 != g);
- return 2;
+ return 2;
-char
-GEOSPreparedOverlaps_r(GEOSContextHandle_t extHandle,
- assert(0 != pg);
- assert(0 != g);
+ return 2;
- return 2;
+ try {
+ bool result = pg->contains(g);
+ return result;
+ catch(...) {
return 2;
- try
- bool result = pg->overlaps(g);
- return result;
- catch (...)
+ char
+ GEOSPreparedContainsProperly_r(GEOSContextHandle_t extHandle,
+ assert(0 != pg);
+ assert(0 != g);
- return 2;
+ return 2;
-char
-GEOSPreparedTouches_r(GEOSContextHandle_t extHandle,
- assert(0 != pg);
- assert(0 != g);
+ return 2;
- return 2;
+ try {
+ bool result = pg->containsProperly(g);
+ return result;
+ catch(...) {
return 2;
- try
- bool result = pg->touches(g);
- return result;
- catch (...)
+ char
+ GEOSPreparedCoveredBy_r(GEOSContextHandle_t extHandle,
+ assert(0 != pg);
+ assert(0 != g);
- return 2;
+ return 2;
-char
-GEOSPreparedWithin_r(GEOSContextHandle_t extHandle,
- assert(0 != pg);
- assert(0 != g);
+ return 2;
- return 2;
+ try {
+ bool result = pg->coveredBy(g);
+ return result;
+ catch(...) {
return 2;
- try
- bool result = pg->within(g);
- return result;
- catch (...)
+ char
+ GEOSPreparedCovers_r(GEOSContextHandle_t extHandle,
+ assert(0 != pg);
+ assert(0 != g);
- return 2;
+ return 2;
-// STRtree
+ return 2;
-geos::index::strtree::STRtree *
-GEOSSTRtree_create_r(GEOSContextHandle_t extHandle,
- size_t nodeCapacity)
- return 0;
+ try {
+ bool result = pg->covers(g);
+ return result;
+ catch(...) {
- return 0;
+ return 2;
- geos::index::strtree::STRtree *tree = 0;
- try
+ char
+ GEOSPreparedCrosses_r(GEOSContextHandle_t extHandle,
- tree = new geos::index::strtree::STRtree(nodeCapacity);
- catch (...)
+ assert(0 != pg);
+ assert(0 != g);
- return tree;
+ return 2;
-void
-GEOSSTRtree_insert_r(GEOSContextHandle_t extHandle,
- geos::index::strtree::STRtree *tree,
- const geos::geom::Geometry *g,
- void *item)
- assert(tree != 0);
- assert(g != 0);
+ return 2;
+ try {
+ bool result = pg->crosses(g);
+ return result;
+ catch(...) {
- try
- tree->insert(g->getEnvelopeInternal(), item);
+ return 2;
+ char
+ GEOSPreparedDisjoint_r(GEOSContextHandle_t extHandle,
- return;
+ assert(0 != pg);
+ assert(0 != g);
+ return 2;
- return;
+ return 2;
- catch (...)
- return;
+ try {
+ bool result = pg->disjoint(g);
+ return result;
- return;
+ catch(...) {
+ return 2;
-void
-GEOSSTRtree_query_r(GEOSContextHandle_t extHandle,
- GEOSQueryCallback callback,
- void *userdata)
- assert(g != 0);
- assert(callback != 0);
- try
- CAPI_ItemVisitor visitor(callback, userdata);
- tree->query(g->getEnvelopeInternal(), visitor);
+ char
+ GEOSPreparedIntersects_r(GEOSContextHandle_t extHandle,
- return;
+ assert(0 != pg);
+ assert(0 != g);
+ return 2;
- return;
+ return 2;
- catch (...)
- return;
+ try {
+ bool result = pg->intersects(g);
+ return result;
- return;
+ catch(...) {
+ return 2;
-const GEOSGeometry *
-GEOSSTRtree_nearest_r(GEOSContextHandle_t extHandle,
- const geos::geom::Geometry* geom)
- return (const GEOSGeometry*) GEOSSTRtree_nearest_generic_r( extHandle, tree, geom, geom, nullptr, nullptr);
+ char
+ GEOSPreparedOverlaps_r(GEOSContextHandle_t extHandle,
+ assert(0 != pg);
+ assert(0 != g);
-const void *
-GEOSSTRtree_nearest_generic_r(GEOSContextHandle_t extHandle,
- const void* item,
- const geos::geom::Geometry* itemEnvelope,
- GEOSDistanceCallback distancefn,
- void* userdata)
- using namespace geos::index::strtree;
+ return 2;
+ return 2;
- struct CustomItemDistance : public ItemDistance {
- CustomItemDistance(GEOSDistanceCallback p_distancefn, void* p_userdata)
- : m_distancefn(p_distancefn), m_userdata(p_userdata) {}
+ try {
+ bool result = pg->overlaps(g);
+ return result;
+ catch(...) {
- GEOSDistanceCallback m_distancefn;
- void* m_userdata;
+ return 2;
- double distance(const ItemBoundable* item1, const ItemBoundable* item2) override {
- const void* a = item1->getItem();
- const void* b = item2->getItem();
- double d;
+ char
+ GEOSPreparedTouches_r(GEOSContextHandle_t extHandle,
+ assert(0 != pg);
+ assert(0 != g);
- if (!m_distancefn(a, b, &d, m_userdata)) {
- throw std::runtime_error(std::string("Failed to compute distance."));
+ return 2;
- return d;
+ return 2;
- try
- if (distancefn) {
- CustomItemDistance itemDistance(distancefn, userdata);
- return tree->nearestNeighbour(itemEnvelope->getEnvelopeInternal(), item, &itemDistance);
- } else {
- GeometryItemDistance itemDistance = GeometryItemDistance();
+ try {
+ bool result = pg->touches(g);
+ return result;
- return NULL;
- return NULL;
+ catch(...) {
+ return 2;
- catch (...)
+ char
+ GEOSPreparedWithin_r(GEOSContextHandle_t extHandle,
- return NULL;
+ assert(0 != pg);
+ assert(0 != g);
+ return 2;
- return NULL;
+ return 2;
+ try {
+ bool result = pg->within(g);
+ return result;
+ catch(...) {
- return NULL;
+ return 2;
-void
-GEOSSTRtree_iterate_r(GEOSContextHandle_t extHandle,
- void *userdata)
+// STRtree
- try
+ geos::index::strtree::STRtree*
+ GEOSSTRtree_create_r(GEOSContextHandle_t extHandle,
+ size_t nodeCapacity)
- tree->iterate(visitor);
- return;
+ return 0;
- return;
+ return 0;
+ geos::index::strtree::STRtree* tree = 0;
+ try {
+ tree = new geos::index::strtree::STRtree(nodeCapacity);
+ catch(...) {
+ return tree;
- catch (...)
+ void
+ GEOSSTRtree_insert_r(GEOSContextHandle_t extHandle,
+ geos::index::strtree::STRtree* tree,
+ const geos::geom::Geometry* g,
+ void* item)
- return;
+ assert(tree != 0);
+ assert(g != 0);
+ try {
+ tree->insert(g->getEnvelopeInternal(), item);
+ return;
- return;
+ return;
+ catch(...) {
+ return;
+ return;
-char
-GEOSSTRtree_remove_r(GEOSContextHandle_t extHandle,
- void *item)
- assert(0 != tree);
- assert(0 != g);
+ void
+ GEOSSTRtree_query_r(GEOSContextHandle_t extHandle,
+ GEOSQueryCallback callback,
+ void* userdata)
+ assert(g != 0);
+ assert(callback != 0);
+ try {
+ CAPI_ItemVisitor visitor(callback, userdata);
+ tree->query(g->getEnvelopeInternal(), visitor);
+ return;
- return 2;
+ return;
- return 2;
+ catch(...) {
+ return;
- try
- bool result = tree->remove(g->getEnvelopeInternal(), item);
- return result;
+ return;
+ const GEOSGeometry*
+ GEOSSTRtree_nearest_r(GEOSContextHandle_t extHandle,
+ const geos::geom::Geometry* geom)
+ return (const GEOSGeometry*) GEOSSTRtree_nearest_generic_r(extHandle, tree, geom, geom, nullptr, nullptr);
- catch (...)
+ const void*
+ GEOSSTRtree_nearest_generic_r(GEOSContextHandle_t extHandle,
+ const void* item,
+ const geos::geom::Geometry* itemEnvelope,
+ GEOSDistanceCallback distancefn,
+ void* userdata)
+ using namespace geos::index::strtree;
- return 2;
-void
-GEOSSTRtree_destroy_r(GEOSContextHandle_t extHandle,
- geos::index::strtree::STRtree *tree)
+ struct CustomItemDistance : public ItemDistance {
+ CustomItemDistance(GEOSDistanceCallback p_distancefn, void* p_userdata)
+ : m_distancefn(p_distancefn), m_userdata(p_userdata) {}
- try
- delete tree;
+ GEOSDistanceCallback m_distancefn;
+ void* m_userdata;
+ double
+ distance(const ItemBoundable* item1, const ItemBoundable* item2) override
+ const void* a = item1->getItem();
+ const void* b = item2->getItem();
+ double d;
+ if(!m_distancefn(a, b, &d, m_userdata)) {
+ throw std::runtime_error(std::string("Failed to compute distance."));
+ return d;
+ try {
+ if(distancefn) {
+ CustomItemDistance itemDistance(distancefn, userdata);
+ return tree->nearestNeighbour(itemEnvelope->getEnvelopeInternal(), item, &itemDistance);
+ else {
+ GeometryItemDistance itemDistance = GeometryItemDistance();
+ return NULL;
+ return NULL;
+ catch(...) {
+ return NULL;
+ return NULL;
+ return NULL;
- return;
+ void
+ GEOSSTRtree_iterate_r(GEOSContextHandle_t extHandle,
+ void* userdata)
+ try {
+ tree->iterate(visitor);
+ return;
- return;
+ return;
+ catch(...) {
+ return;
+ return;
- catch (...)
+ char
+ GEOSSTRtree_remove_r(GEOSContextHandle_t extHandle,
+ void* item)
- return;
+ assert(0 != tree);
+ assert(0 != g);
+ return 2;
- return;
+ return 2;
-double
-GEOSProject_r(GEOSContextHandle_t extHandle,
- const Geometry *g,
- const Geometry *p)
- if ( 0 == extHandle ) return -1.0;
- reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
- if ( handle->initialized == 0 ) return -1.0;
+ try {
+ bool result = tree->remove(g->getEnvelopeInternal(), item);
+ return result;
+ catch(...) {
- const geos::geom::Point* point = dynamic_cast<const geos::geom::Point*>(p);
- if (!point) {
- handle->ERROR_MESSAGE("third argument of GEOSProject_r must be Point*");
- return -1.0;
+ return 2;
- const geos::geom::Coordinate* inputPt = p->getCoordinate();
+ void
+ GEOSSTRtree_destroy_r(GEOSContextHandle_t extHandle,
+ geos::index::strtree::STRtree* tree)
- try {
- return geos::linearref::LengthIndexedLine(g).project(*inputPt);
- } catch (const std::exception &e) {
- return -1.0;
- } catch (...) {
- return -1.0;
+ try {
+ delete tree;
+ return;
+ return;
-Geometry*
-GEOSInterpolate_r(GEOSContextHandle_t extHandle, const Geometry *g, double d)
- if ( 0 == extHandle ) return 0;
- if ( handle->initialized == 0 ) return 0;
- try {
- geos::linearref::LengthIndexedLine lil(g);
- geos::geom::Coordinate coord = lil.extractPoint(d);
- Geometry* point = gf->createPoint(coord);
- return point;
- return 0;
- } catch (...) {
- return 0;
+ catch(...) {
+ return;
+ return;
-double
-GEOSProjectNormalized_r(GEOSContextHandle_t extHandle, const Geometry *g,
- double length;
- GEOSLength_r(extHandle, g, &length);
- return GEOSProject_r(extHandle, g, p) / length;
+ double
+ GEOSProject_r(GEOSContextHandle_t extHandle,
+ const Geometry* g,
+ const Geometry* p)
+ return -1.0;
+ reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if(handle->initialized == 0) {
+ return -1.0;
+ const geos::geom::Point* point = dynamic_cast<const geos::geom::Point*>(p);
+ if(!point) {
+ handle->ERROR_MESSAGE("third argument of GEOSProject_r must be Point*");
+ return -1.0;
-Geometry*
-GEOSInterpolateNormalized_r(GEOSContextHandle_t extHandle, const Geometry *g,
- double d)
- double length;
- return GEOSInterpolate_r(extHandle, g, d * length);
+ const geos::geom::Coordinate* inputPt = p->getCoordinate();
-GEOSGeometry*
-GEOSGeom_extractUniquePoints_r(GEOSContextHandle_t extHandle,
- const GEOSGeometry* g)
+ try {
+ return geos::linearref::LengthIndexedLine(g).project(*inputPt);
+ return -1.0;
+ catch(...) {
+ return -1.0;
- using namespace geos::util;
- try
+ Geometry*
+ GEOSInterpolate_r(GEOSContextHandle_t extHandle, const Geometry* g, double d)
+ return 0;
+ return 0;
+ try {
+ geos::linearref::LengthIndexedLine lil(g);
+ geos::geom::Coordinate coord = lil.extractPoint(d);
+ const GeometryFactory* gf = handle->geomFactory;
+ Geometry* point = gf->createPoint(coord);
+ return point;
+ return 0;
+ catch(...) {
+ return 0;
- /* 1: extract points */
- std::vector<const Coordinate*> coords;
- UniqueCoordinateArrayFilter filter(coords);
- g->apply_ro(&filter);
- /* 2: for each point, create a geometry and put into a vector */
- std::vector<Geometry*>* points = new std::vector<Geometry*>();
- points->reserve(coords.size());
- const GeometryFactory* factory = g->getFactory();
- for (std::vector<const Coordinate*>::iterator it=coords.begin(),
- itE=coords.end();
- it != itE; ++it)
+ double
+ GEOSProjectNormalized_r(GEOSContextHandle_t extHandle, const Geometry* g,
- Geometry* point = factory->createPoint(*(*it));
- points->push_back(point);
+ double length;
+ GEOSLength_r(extHandle, g, &length);
+ return GEOSProject_r(extHandle, g, p) / length;
- /* 3: create a multipoint */
- return factory->createMultiPoint(points);
+ Geometry*
+ GEOSInterpolateNormalized_r(GEOSContextHandle_t extHandle, const Geometry* g,
+ double d)
- return 0;
+ double length;
+ return GEOSInterpolate_r(extHandle, g, d * length);
- catch (...)
+ GEOSGeometry*
+ GEOSGeom_extractUniquePoints_r(GEOSContextHandle_t extHandle,
+ const GEOSGeometry* g)
- return 0;
+ return 0;
+ return 0;
-int GEOSOrientationIndex_r(GEOSContextHandle_t extHandle,
- double Ax, double Ay, double Bx, double By, double Px, double Py)
+ using namespace geos::util;
- using geos::geom::Coordinate;
- using geos::algorithm::Orientation;
+ try {
- return 2;
+ /* 1: extract points */
+ std::vector<const Coordinate*> coords;
+ UniqueCoordinateArrayFilter filter(coords);
+ g->apply_ro(&filter);
- return 2;
+ /* 2: for each point, create a geometry and put into a vector */
+ std::vector<Geometry*>* points = new std::vector<Geometry*>();
+ points->reserve(coords.size());
+ const GeometryFactory* factory = g->getFactory();
+ for(std::vector<const Coordinate*>::iterator it = coords.begin(),
+ itE = coords.end();
+ it != itE; ++it) {
+ Geometry* point = factory->createPoint(*(*it));
+ points->push_back(point);
+ /* 3: create a multipoint */
+ return factory->createMultiPoint(points);
+ return 0;
+ catch(...) {
+ return 0;
- try
- Coordinate A(Ax, Ay);
- Coordinate B(Bx, By);
- Coordinate P(Px, Py);
- return Orientation::index(A, B, P);
- return 2;
- catch (...)
+ int GEOSOrientationIndex_r(GEOSContextHandle_t extHandle,
+ double Ax, double Ay, double Bx, double By, double Px, double Py)
- return 2;
-GEOSGeometry *
-GEOSSharedPaths_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1, const GEOSGeometry* g2)
- using namespace geos::operation::sharedpaths;
+ using geos::geom::Coordinate;
+ using geos::algorithm::Orientation;
+ return 2;
- SharedPathsOp::PathList forw, back;
- try {
- SharedPathsOp::sharedPathsOp(*g1, *g2, forw, back);
- SharedPathsOp::clearEdges(forw);
- SharedPathsOp::clearEdges(back);
- return 0;
- catch (...)
- return 0;
+ return 2;
+ try {
+ Coordinate A(Ax, Ay);
+ Coordinate B(Bx, By);
+ Coordinate P(Px, Py);
+ return Orientation::index(A, B, P);
+ return 2;
+ catch(...) {
+ return 2;
- // Now forw and back have the geoms we want to use to construct
- // our output GeometryCollections...
+ GEOSGeometry*
+ GEOSSharedPaths_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1, const GEOSGeometry* g2)
+ using namespace geos::operation::sharedpaths;
- const GeometryFactory* factory = g1->getFactory();
- size_t count;
+ return 0;
+ return 0;
- std::unique_ptr< std::vector<Geometry*> > out1(
- new std::vector<Geometry*>()
- count = forw.size();
- out1->reserve(count);
- for (size_t i=0; i<count; ++i) {
- out1->push_back(forw[i]);
- std::unique_ptr<Geometry> out1g (
- factory->createMultiLineString(out1.release())
+ SharedPathsOp::PathList forw, back;
+ try {
+ SharedPathsOp::sharedPathsOp(*g1, *g2, forw, back);
+ SharedPathsOp::clearEdges(forw);
+ SharedPathsOp::clearEdges(back);
+ return 0;
+ catch(...) {
+ return 0;
- std::unique_ptr< std::vector<Geometry*> > out2(
- count = back.size();
- out2->reserve(count);
- out2->push_back(back[i]);
- std::unique_ptr<Geometry> out2g (
- factory->createMultiLineString(out2.release())
+ // Now forw and back have the geoms we want to use to construct
+ // our output GeometryCollections...
- std::unique_ptr< std::vector<Geometry*> > out(
- out->reserve(2);
- out->push_back(out1g.release());
- out->push_back(out2g.release());
+ const GeometryFactory* factory = g1->getFactory();
+ size_t count;
- std::unique_ptr<Geometry> outg (
- factory->createGeometryCollection(out.release())
+ std::unique_ptr< std::vector<Geometry*> > out1(
+ new std::vector<Geometry*>()
+ count = forw.size();
+ out1->reserve(count);
+ for(size_t i = 0; i < count; ++i) {
+ out1->push_back(forw[i]);
+ std::unique_ptr<Geometry> out1g(
+ factory->createMultiLineString(out1.release())
- return outg.release();
+ std::unique_ptr< std::vector<Geometry*> > out2(
+ count = back.size();
+ out2->reserve(count);
+ out2->push_back(back[i]);
+ std::unique_ptr<Geometry> out2g(
+ factory->createMultiLineString(out2.release())
+ std::unique_ptr< std::vector<Geometry*> > out(
+ out->reserve(2);
+ out->push_back(out1g.release());
+ out->push_back(out2g.release());
-GEOSGeometry *
-GEOSSnap_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1,
- const GEOSGeometry* g2, double tolerance)
- using namespace geos::operation::overlay::snap;
+ std::unique_ptr<Geometry> outg(
+ factory->createGeometryCollection(out.release())
+ return outg.release();
- try{
- GeometrySnapper snapper( *g1 );
- std::unique_ptr<Geometry> ret = snapper.snapTo(*g2, tolerance);
- return ret.release();
+ GEOSGeometry*
+ GEOSSnap_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1,
+ const GEOSGeometry* g2, double tolerance)
- return 0;
+ using namespace geos::operation::overlay::snap;
+ return 0;
+ return 0;
+ try {
+ GeometrySnapper snapper(*g1);
+ std::unique_ptr<Geometry> ret = snapper.snapTo(*g2, tolerance);
+ return ret.release();
+ return 0;
+ catch(...) {
+ return 0;
- catch (...)
+ BufferParameters*
+ GEOSBufferParams_create_r(GEOSContextHandle_t extHandle)
- return 0;
+ return NULL;
-BufferParameters *
-GEOSBufferParams_create_r(GEOSContextHandle_t extHandle)
- if ( 0 == extHandle ) return NULL;
+ return NULL;
- if ( 0 == handle->initialized ) return NULL;
+ try {
+ BufferParameters* p = new BufferParameters();
+ return p;
+ catch(...) {
- try
- BufferParameters *p = new BufferParameters();
- return p;
+ return 0;
- catch (...)
+ void
+ GEOSBufferParams_destroy_r(GEOSContextHandle_t extHandle, BufferParameters* p)
+ (void)extHandle;
+ delete p;
- return 0;
+ int
+ GEOSBufferParams_setEndCapStyle_r(GEOSContextHandle_t extHandle,
+ GEOSBufferParams* p, int style)
+ return 0;
-void
-GEOSBufferParams_destroy_r(GEOSContextHandle_t extHandle, BufferParameters* p)
- (void)extHandle;
- delete p;
+ return 0;
-int
-GEOSBufferParams_setEndCapStyle_r(GEOSContextHandle_t extHandle,
- GEOSBufferParams* p, int style)
+ try {
+ if(style > BufferParameters::CAP_SQUARE) {
+ throw IllegalArgumentException("Invalid buffer endCap style");
+ p->setEndCapStyle(static_cast<BufferParameters::EndCapStyle>(style));
+ return 1;
+ catch(...) {
- if ( 0 == handle->initialized ) return 0;
+ return 0;
- try
+ int
+ GEOSBufferParams_setJoinStyle_r(GEOSContextHandle_t extHandle,
- if ( style > BufferParameters::CAP_SQUARE )
- throw IllegalArgumentException("Invalid buffer endCap style");
+ return 0;
- p->setEndCapStyle(static_cast<BufferParameters::EndCapStyle>(style));
- return 1;
- catch (...)
- return 0;
+ return 0;
-int
-GEOSBufferParams_setJoinStyle_r(GEOSContextHandle_t extHandle,
+ try {
+ if(style > BufferParameters::JOIN_BEVEL) {
+ throw IllegalArgumentException("Invalid buffer join style");
+ p->setJoinStyle(static_cast<BufferParameters::JoinStyle>(style));
+ return 1;
+ catch(...) {
+ return 0;
- try
+ int
+ GEOSBufferParams_setMitreLimit_r(GEOSContextHandle_t extHandle,
+ GEOSBufferParams* p, double limit)
- if ( style > BufferParameters::JOIN_BEVEL ) {
- throw IllegalArgumentException("Invalid buffer join style");
+ return 0;
- p->setJoinStyle(static_cast<BufferParameters::JoinStyle>(style));
- return 1;
- catch (...)
- return 0;
-int
-GEOSBufferParams_setMitreLimit_r(GEOSContextHandle_t extHandle,
- GEOSBufferParams* p, double limit)
+ return 0;
+ try {
+ p->setMitreLimit(limit);
+ return 1;
+ catch(...) {
- try
- p->setMitreLimit(limit);
- return 1;
- catch (...)
+ return 0;
- return 0;
+ int
+ GEOSBufferParams_setQuadrantSegments_r(GEOSContextHandle_t extHandle,
+ GEOSBufferParams* p, int segs)
+ return 0;
-int
-GEOSBufferParams_setQuadrantSegments_r(GEOSContextHandle_t extHandle,
- GEOSBufferParams* p, int segs)
+ return 0;
+ try {
+ p->setQuadrantSegments(segs);
+ return 1;
+ catch(...) {
- try
- p->setQuadrantSegments(segs);
- return 1;
- catch (...)
+ return 0;
- return 0;
+ int
+ GEOSBufferParams_setSingleSided_r(GEOSContextHandle_t extHandle,
+ GEOSBufferParams* p, int ss)
+ return 0;
-int
-GEOSBufferParams_setSingleSided_r(GEOSContextHandle_t extHandle,
- GEOSBufferParams* p, int ss)
+ return 0;
+ try {
+ p->setSingleSided((ss != 0));
+ return 1;
+ catch(...) {
- try
- p->setSingleSided( (ss != 0) );
- return 1;
- catch (...)
+ return 0;
- return 0;
+ Geometry*
+ GEOSBufferWithParams_r(GEOSContextHandle_t extHandle, const Geometry* g1, const BufferParameters* bp, double width)
+ using geos::operation::buffer::BufferOp;
-Geometry *
-GEOSBufferWithParams_r(GEOSContextHandle_t extHandle, const Geometry *g1, const BufferParameters* bp, double width)
- using geos::operation::buffer::BufferOp;
+ return NULL;
+ return NULL;
+ try {
+ BufferOp op(g1, *bp);
+ Geometry* g3 = op.getResultGeometry(width);
+ return g3;
+ catch(...) {
- try
- BufferOp op(g1, *bp);
- Geometry *g3 = op.getResultGeometry(width);
- return g3;
- catch (...)
+ return NULL;
- return NULL;
+ Geometry*
+ GEOSDelaunayTriangulation_r(GEOSContextHandle_t extHandle, const Geometry* g1, double tolerance, int onlyEdges)
+ return NULL;
-Geometry *
-GEOSDelaunayTriangulation_r(GEOSContextHandle_t extHandle, const Geometry *g1, double tolerance, int onlyEdges)
+ return NULL;
+ using geos::triangulate::DelaunayTriangulationBuilder;
- using geos::triangulate::DelaunayTriangulationBuilder;
+ try {
+ DelaunayTriangulationBuilder builder;
+ builder.setTolerance(tolerance);
+ builder.setSites(*g1);
- try
- DelaunayTriangulationBuilder builder;
- builder.setTolerance(tolerance);
- builder.setSites(*g1);
+ if(onlyEdges) {
+ return builder.getEdges(*g1->getFactory()).release();
+ else {
+ return builder.getTriangles(*g1->getFactory()).release();
- if ( onlyEdges ) return builder.getEdges( *g1->getFactory() ).release();
- else return builder.getTriangles( *g1->getFactory() ).release();
+ catch(...) {
+ return NULL;
+ Geometry*
+ GEOSVoronoiDiagram_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* env, double tolerance,
+ int onlyEdges)
+ return NULL;
+ return NULL;
+ using geos::triangulate::VoronoiDiagramBuilder;
+ try {
+ VoronoiDiagramBuilder builder;
+ if(env) {
+ builder.setClipEnvelope(env->getEnvelopeInternal());
+ if(onlyEdges) {
+ return builder.getDiagramEdges(*g1->getFactory()).release();
+ else {
+ return builder.getDiagram(*g1->getFactory()).release();
+ catch(...) {
+ return NULL;
- catch (...)
+ int
+ GEOSSegmentIntersection_r(GEOSContextHandle_t extHandle,
+ double ax0, double ay0, double ax1, double ay1,
+ double bx0, double by0, double bx1, double by1,
+ double* cx, double* cy)
+ return 0;
- return NULL;
-Geometry*
-GEOSVoronoiDiagram_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *env, double tolerance ,int onlyEdges)
- using geos::triangulate::VoronoiDiagramBuilder;
- try
- VoronoiDiagramBuilder builder;
- if(env) builder.setClipEnvelope(env->getEnvelopeInternal());
- if(onlyEdges) return builder.getDiagramEdges(*g1->getFactory()).release();
- else return builder.getDiagram(*g1->getFactory()).release();
- catch(const std::exception &e)
- catch(...)
- return NULL;
+ return 0;
-int
-GEOSSegmentIntersection_r(GEOSContextHandle_t extHandle,
- double ax0, double ay0, double ax1, double ay1,
- double bx0, double by0, double bx1, double by1,
- double* cx, double* cy)
+ try {
+ geos::geom::LineSegment a(ax0, ay0, ax1, ay1);
+ geos::geom::LineSegment b(bx0, by0, bx1, by1);
+ geos::geom::Coordinate isect;
+ bool intersects = a.intersection(b, isect);
- try
- geos::geom::LineSegment a(ax0, ay0, ax1, ay1);
- geos::geom::LineSegment b(bx0, by0, bx1, by1);
- geos::geom::Coordinate isect;
+ if(!intersects) {
+ return -1;
- bool intersects = a.intersection(b, isect);
+ *cx = isect.x;
+ *cy = isect.y;
- if (!intersects)
- return -1;
+ return 1;
+ catch(...) {
- *cx = isect.x;
- *cy = isect.y;
- return 1;
- catch(...)
+ return 0;
- return 0;
} /* extern "C" */
diff --git a/doc/example.cpp b/doc/example.cpp
index 799ac4a..3756e32 100644
--- a/doc/example.cpp
+++ b/doc/example.cpp
@@ -73,7 +73,7 @@ using geos::util::IllegalArgumentException;
// Prototypes
-void wkt_print_geoms(vector<Geometry *> *geoms);
+void wkt_print_geoms(vector<Geometry*>* geoms);
// This object will be used to construct our geometries.
@@ -92,104 +92,108 @@ GeometryFactory::Ptr global_factory;
// - compare input and output geometries for equality
// - remove debugging lines (on stream state)
-void WKBtest(vector<Geometry*>*geoms)
+void
+WKBtest(vector<Geometry*>* geoms)
- stringstream s(ios_base::binary|ios_base::in|ios_base::out);
- io::WKBReader wkbReader(*global_factory);
- io::WKBWriter wkbWriter;
- Geometry *gout;
+ stringstream s(ios_base::binary | ios_base::in | ios_base::out);
+ io::WKBReader wkbReader(*global_factory);
+ io::WKBWriter wkbWriter;
+ Geometry* gout;
#if DEBUG_STREAM_STATE
- cout<<"WKBtest: machine byte order: "<<BYTE_ORDER<<endl;
+ cout << "WKBtest: machine byte order: " << BYTE_ORDER << endl;
#endif
- unsigned int ngeoms=geoms->size();
- for (unsigned int i=0; i<ngeoms; ++i)
- Geometry *gin = (*geoms)[i];
+ unsigned int ngeoms = geoms->size();
+ for(unsigned int i = 0; i < ngeoms; ++i) {
+ Geometry* gin = (*geoms)[i];
- cout<<"State of stream before WRITE: ";
- cout<<"p:"<<s.tellp()<<" g:"<<s.tellg()<<
- " good:"<<s.good()<<
- " eof:"<<s.eof()<<
- " bad:"<<s.bad()<<
- " fail:"<<s.fail()<<endl;
+ cout << "State of stream before WRITE: ";
+ cout << "p:" << s.tellp() << " g:" << s.tellg() <<
+ " good:" << s.good() <<
+ " eof:" << s.eof() <<
+ " bad:" << s.bad() <<
+ " fail:" << s.fail() << endl;
#endif
- cout<<"State of stream after SEEKP: ";
+ cout << "State of stream after SEEKP: ";
#endif
- wkbWriter.write(*gin, s);
+ wkbWriter.write(*gin, s);
- cout<<"wkbWriter wrote and reached ";
- cout<<"p:"<<s.tellp()<<" g:"<<s.tellg()<<endl;
- cout<<"State of stream before DUMP: ";
+ cout << "wkbWriter wrote and reached ";
+ cout << "p:" << s.tellp() << " g:" << s.tellg() << endl;
+ cout << "State of stream before DUMP: ";
#endif
- cout<<"State of stream after DUMP: ";
+ cout << "State of stream after DUMP: ";
#endif
- s.seekg(0, ios::beg); // rewind reader pointer
+ s.seekg(0, ios::beg); // rewind reader pointer
- cout<<"State of stream before READ: ";
+ cout << "State of stream before READ: ";
#endif
- gout = wkbReader.read(s);
+ gout = wkbReader.read(s);
- cout<<"State of stream after READ: ";
+ cout << "State of stream after READ: ";
#endif
- gin->normalize();
- gout->normalize();
- int failed = gin->compareTo(gout);
- if ( failed ) cout<<"{"<<i<<"} (WKB) ";
- else cout<<"["<<i<<"] (WKB) ";
+ gin->normalize();
+ gout->normalize();
+ int failed = gin->compareTo(gout);
+ if(failed) {
+ cout << "{" << i << "} (WKB) ";
+ else {
+ cout << "[" << i << "] (WKB) ";
- io::WKBReader::printHEX(s, cout);
- cout<<endl;
+ io::WKBReader::printHEX(s, cout);
+ cout << endl;
- if ( failed ) {
- io::WKTWriter wkt;
- cout<<" IN: "<<wkt.write(gin)<<endl;
- cout<<" OUT: "<<wkt.write(gout)<<endl;
+ if(failed) {
+ io::WKTWriter wkt;
+ cout << " IN: " << wkt.write(gin) << endl;
+ cout << " OUT: " << wkt.write(gout) << endl;
- s.seekp(0, ios::beg); // rewind writer pointer
+ s.seekp(0, ios::beg); // rewind writer pointer
- delete gout;
+ delete gout;
@@ -198,161 +202,161 @@ void WKBtest(vector<Geometry*>*geoms)
// format to stdout. As a side-effect, will test WKB
// output and input, using the WKBtest function.
void
-wkt_print_geoms(vector<Geometry *> *geoms)
+wkt_print_geoms(vector<Geometry*>* geoms)
- WKBtest(geoms); // test WKB parser
- // WKT-print given geometries
- io::WKTWriter *wkt = new io::WKTWriter();
- for (unsigned int i=0; i<geoms->size(); i++) {
- const Geometry *g = (*geoms)[i];
- string tmp=wkt->write(g);
- cout<<"["<<i<<"] (WKT) "<<tmp<<endl;
- delete wkt;
+ WKBtest(geoms); // test WKB parser
+ // WKT-print given geometries
+ io::WKTWriter* wkt = new io::WKTWriter();
+ for(unsigned int i = 0; i < geoms->size(); i++) {
+ const Geometry* g = (*geoms)[i];
+ string tmp = wkt->write(g);
+ cout << "[" << i << "] (WKT) " << tmp << endl;
+ delete wkt;
// This is the simpler geometry you can get: a point.
-Point *
+Point*
create_point(double x, double y)
- Coordinate c(x, y);
- Point *p = global_factory->createPoint(c);
- return p;
+ Coordinate c(x, y);
+ Point* p = global_factory->createPoint(c);
+ return p;
// This function will create a LinearString
// geometry with the shape of the letter U
// having top-left corner at given coordinates
// and 'side' height and width
-LineString *
+LineString*
create_ushaped_linestring(double xoffset, double yoffset, double side)
- // We will use a coordinate list to build the linestring
- CoordinateSequence *cl = new CoordinateArraySequence();
+ // We will use a coordinate list to build the linestring
+ CoordinateSequence* cl = new CoordinateArraySequence();
- cl->add(Coordinate(xoffset, yoffset));
- cl->add(Coordinate(xoffset, yoffset+side));
- cl->add(Coordinate(xoffset+side, yoffset+side));
- cl->add(Coordinate(xoffset+side, yoffset));
+ cl->add(Coordinate(xoffset, yoffset));
+ cl->add(Coordinate(xoffset, yoffset + side));
+ cl->add(Coordinate(xoffset + side, yoffset + side));
+ cl->add(Coordinate(xoffset + side, yoffset));
- // Now that we have a CoordinateSequence we can create
- // the linestring.
- // The newly created LineString will take ownership
- // of the CoordinateSequence.
- LineString *ls = global_factory->createLineString(cl);
+ // Now that we have a CoordinateSequence we can create
+ // the linestring.
+ // The newly created LineString will take ownership
+ // of the CoordinateSequence.
+ LineString* ls = global_factory->createLineString(cl);
- // This is what you do if you want the new LineString
- // to make a copy of your CoordinateSequence:
- // LineString *ls = global_factory->createLineString(*cl);
+ // This is what you do if you want the new LineString
+ // to make a copy of your CoordinateSequence:
+ // LineString *ls = global_factory->createLineString(*cl);
- return ls; // our LineString
+ return ls; // our LineString
// This function will create a LinearRing
// geometry rapresenting a square with the given origin
// and side
-LinearRing *
+LinearRing*
create_square_linearring(double xoffset, double yoffset, double side)
- // We will use a coordinate list to build the linearring
- // the linearring.
- // The newly created LinearRing will take ownership
- LinearRing *lr = global_factory->createLinearRing(cl);
- // This is what you do if you want the new LinearRing
- // LinearRing *lr = global_factory->createLinearRing(*cl);
- return lr; // our LinearRing
+ // We will use a coordinate list to build the linearring
+ // the linearring.
+ // The newly created LinearRing will take ownership
+ LinearRing* lr = global_factory->createLinearRing(cl);
+ // This is what you do if you want the new LinearRing
+ // LinearRing *lr = global_factory->createLinearRing(*cl);
+ return lr; // our LinearRing
// This function will create a Polygon
// and side and with a central hole 1/3 sided.
-Polygon *
+Polygon*
create_square_polygon(double xoffset, double yoffset, double side)
- // We need a LinearRing for the polygon shell
- LinearRing *outer = create_square_linearring(xoffset,yoffset,side);
- // And another for the hole
- LinearRing *inner = create_square_linearring(xoffset+(side/3),
- yoffset+(side/3),(side/3));
- // If we need to specify any hole, we do it using
- // a vector of Geometry pointers (I don't know why
- // not LinearRings)
- vector<Geometry *> *holes = new vector<Geometry *>;
- // We add the newly created geometry to the vector
- // of holes.
- holes->push_back(inner);
- // And finally we call the polygon constructor.
- // Both the outer LinearRing and the vector of holes
- // will be referenced by the resulting Polygon object,
- // thus we CANNOT delete them, neither the holes, nor
- // the vector containing their pointers, nor the outer
- // LinearRing. Everything will be deleted at Polygon
- // deletion time (this is inconsistent with LinearRing
- // behaviour... what should we do?).
- Polygon *poly = global_factory->createPolygon(outer, holes);
- return poly;
+ // We need a LinearRing for the polygon shell
+ LinearRing* outer = create_square_linearring(xoffset, yoffset, side);
+ // And another for the hole
+ LinearRing* inner = create_square_linearring(xoffset + (side / 3),
+ yoffset + (side / 3), (side / 3));
+ // If we need to specify any hole, we do it using
+ // a vector of Geometry pointers (I don't know why
+ // not LinearRings)
+ vector<Geometry*>* holes = new vector<Geometry*>;
+ // We add the newly created geometry to the vector
+ // of holes.
+ holes->push_back(inner);
+ // And finally we call the polygon constructor.
+ // Both the outer LinearRing and the vector of holes
+ // will be referenced by the resulting Polygon object,
+ // thus we CANNOT delete them, neither the holes, nor
+ // the vector containing their pointers, nor the outer
+ // LinearRing. Everything will be deleted at Polygon
+ // deletion time (this is inconsistent with LinearRing
+ // behaviour... what should we do?).
+ Polygon* poly = global_factory->createPolygon(outer, holes);
+ return poly;
// This function will create a GeometryCollection
// containing copies of all Geometries in given vector.
-GeometryCollection *
-create_simple_collection(vector<Geometry *> *geoms)
+GeometryCollection*
+create_simple_collection(vector<Geometry*>* geoms)
- return global_factory->createGeometryCollection(*geoms);
- // if you wanted to transfer ownership of vector end
- // its elements you should have call:
- // return global_factory->createGeometryCollection(geoms);
+ return global_factory->createGeometryCollection(*geoms);
+ // if you wanted to transfer ownership of vector end
+ // its elements you should have call:
+ // return global_factory->createGeometryCollection(geoms);
// This function uses GeometricShapeFactory to render
// a circle having given center and radius
-Polygon *
+Polygon*
create_circle(double centerX, double centerY, double radius)
- geos::util::GeometricShapeFactory shapefactory(global_factory.get());
- shapefactory.setCentre(Coordinate(centerX, centerY));
- shapefactory.setSize(radius);
- // same as:
- // shapefactory.setHeight(radius);
- // shapefactory.setWidth(radius);
- return shapefactory.createCircle();
+ geos::util::GeometricShapeFactory shapefactory(global_factory.get());
+ shapefactory.setCentre(Coordinate(centerX, centerY));
+ shapefactory.setSize(radius);
+ // same as:
+ // shapefactory.setHeight(radius);
+ // shapefactory.setWidth(radius);
+ return shapefactory.createCircle();
// an ellipse having given center and axis size
-Polygon *
+Polygon*
create_ellipse(double centerX, double centerY, double width, double height)
- shapefactory.setHeight(height);
- shapefactory.setWidth(width);
+ shapefactory.setHeight(height);
+ shapefactory.setWidth(width);
@@ -360,16 +364,16 @@ create_ellipse(double centerX, double centerY, double width, double height)
// a rectangle having lower-left corner at given coordinates
// and given sizes.
-Polygon *
+Polygon*
create_rectangle(double llX, double llY, double width, double height)
- shapefactory.setBase(Coordinate(llX, llY));
- shapefactory.setNumPoints(4); // we don't need more then 4 points for a rectangle...
- // can use setSize for a square
- return shapefactory.createRectangle();
+ shapefactory.setBase(Coordinate(llX, llY));
+ shapefactory.setNumPoints(4); // we don't need more then 4 points for a rectangle...
+ // can use setSize for a square
+ return shapefactory.createRectangle();
@@ -377,75 +381,76 @@ create_rectangle(double llX, double llY, double width, double height)
// an arc having lower-left corner at given coordinates,
// given sizes and given angles.
-LineString *
+LineString*
create_arc(double llX, double llY, double width, double height, double startang, double endang)
- // shapefactory.setNumPoints(100); // the default (100 pts)
- return shapefactory.createArc(startang, endang);
+ // shapefactory.setNumPoints(100); // the default (100 pts)
+ return shapefactory.createArc(startang, endang);
unique_ptr<Polygon>
create_sinestar(double cx, double cy, double size, int nArms, double armLenRat)
- geos::geom::util::SineStarFactory fact(global_factory.get());
- fact.setCentre(Coordinate(cx, cy));
- fact.setSize(size);
- fact.setNumPoints(nArms*5);
- fact.setArmLengthRatio(armLenRat);
- fact.setNumArms(nArms);
- return fact.createSineStar();
+ geos::geom::util::SineStarFactory fact(global_factory.get());
+ fact.setCentre(Coordinate(cx, cy));
+ fact.setSize(size);
+ fact.setNumPoints(nArms * 5);
+ fact.setArmLengthRatio(armLenRat);
+ fact.setNumArms(nArms);
+ return fact.createSineStar();
// Start reading here
-void do_all()
+void
+do_all()
- vector<Geometry *> *geoms = new vector<Geometry *>;
- vector<Geometry *> *newgeoms;
+ vector<Geometry*>* geoms = new vector<Geometry*>;
+ vector<Geometry*>* newgeoms;
- // Define a precision model using 0,0 as the reference origin
- // and 2.0 as coordinates scale.
- PrecisionModel *pm = new PrecisionModel(2.0, 0, 0);
+ // Define a precision model using 0,0 as the reference origin
+ // and 2.0 as coordinates scale.
+ PrecisionModel* pm = new PrecisionModel(2.0, 0, 0);
- // Initialize global factory with defined PrecisionModel
- // and a SRID of -1 (undefined).
- global_factory = GeometryFactory::create(pm, -1);
+ // Initialize global factory with defined PrecisionModel
+ // and a SRID of -1 (undefined).
+ global_factory = GeometryFactory::create(pm, -1);
- // We do not need PrecisionMode object anymore, it has
- // been copied to global_factory private storage
- delete pm;
+ // We do not need PrecisionMode object anymore, it has
+ // been copied to global_factory private storage
+ delete pm;
// GEOMETRY CREATION
- // Read function bodies to see the magic behind them
- geoms->push_back(create_point(150, 350));
- geoms->push_back(create_square_linearring(0,0,100));
- geoms->push_back(create_ushaped_linestring(60,60,100));
- geoms->push_back(create_square_polygon(0,200,300));
- geoms->push_back(create_square_polygon(0,250,300));
- geoms->push_back(create_simple_collection(geoms));
+ // Read function bodies to see the magic behind them
+ geoms->push_back(create_point(150, 350));
+ geoms->push_back(create_square_linearring(0, 0, 100));
+ geoms->push_back(create_ushaped_linestring(60, 60, 100));
+ geoms->push_back(create_square_polygon(0, 200, 300));
+ geoms->push_back(create_square_polygon(0, 250, 300));
+ geoms->push_back(create_simple_collection(geoms));
#if GEOMETRIC_SHAPES
- // These ones use a GeometricShapeFactory
- geoms->push_back(create_circle(0, 0, 10));
- geoms->push_back(create_ellipse(0, 0, 8, 12));
- geoms->push_back(create_rectangle(-5, -5, 10, 10)); // a square
- geoms->push_back(create_rectangle(-5, -5, 10, 20)); // a rectangle
- // The upper-right quarter of a vertical ellipse
- geoms->push_back(create_arc(0, 0, 10, 20, 0, M_PI/2));
- geoms->push_back(create_sinestar(10, 10, 100, 5, 2).release()); // a sine star
+ // These ones use a GeometricShapeFactory
+ geoms->push_back(create_circle(0, 0, 10));
+ geoms->push_back(create_ellipse(0, 0, 8, 12));
+ geoms->push_back(create_rectangle(-5, -5, 10, 10)); // a square
+ geoms->push_back(create_rectangle(-5, -5, 10, 20)); // a rectangle
+ // The upper-right quarter of a vertical ellipse
+ geoms->push_back(create_arc(0, 0, 10, 20, 0, M_PI / 2));
+ geoms->push_back(create_sinestar(10, 10, 100, 5, 2).release()); // a sine star
#endif
- // Print all geoms.
- cout<<"--------HERE ARE THE BASE GEOMS ----------"<<endl;
- wkt_print_geoms(geoms);
+ // Print all geoms.
+ cout << "--------HERE ARE THE BASE GEOMS ----------" << endl;
+ wkt_print_geoms(geoms);
#if UNARY_OPERATIONS
@@ -454,71 +459,71 @@ void do_all()
// UNARY OPERATIONS
- // CENTROID
- // Find centroid of each base geometry
- newgeoms = new vector<Geometry *>;
- Geometry *g = (*geoms)[i];
- newgeoms->push_back( g->getCentroid() );
- // Print all convex hulls
- cout<<endl<<"------- AND HERE ARE THEIR CENTROIDS -----"<<endl;
- wkt_print_geoms(newgeoms);
- // Delete the centroids
- for (unsigned int i=0; i<newgeoms->size(); i++) {
- delete (*newgeoms)[i];
- delete newgeoms;
- // BUFFER
- try {
- Geometry *g2 = g->buffer(10);
- newgeoms->push_back(g2);
- catch (const GEOSException& exc) {
- cerr <<"GEOS Exception: geometry "<<i<<"->buffer(10): "<<exc.what()<<"\n";
- cout<<endl<<"--------HERE COMES THE BUFFERED GEOMS ----------"<<endl;
- delete newgeoms;
- // CONVEX HULL
- // Make convex hulls of geometries
- newgeoms->push_back( g->convexHull() );
- cout<<endl<<"--------HERE COMES THE HULLS----------"<<endl;
- // Delete the hulls
- delete newgeoms;
+ // CENTROID
+ // Find centroid of each base geometry
+ newgeoms = new vector<Geometry*>;
+ Geometry* g = (*geoms)[i];
+ newgeoms->push_back(g->getCentroid());
+ // Print all convex hulls
+ cout << endl << "------- AND HERE ARE THEIR CENTROIDS -----" << endl;
+ wkt_print_geoms(newgeoms);
+ // Delete the centroids
+ for(unsigned int i = 0; i < newgeoms->size(); i++) {
+ delete(*newgeoms)[i];
+ delete newgeoms;
+ // BUFFER
+ try {
+ Geometry* g2 = g->buffer(10);
+ newgeoms->push_back(g2);
+ catch(const GEOSException& exc) {
+ cerr << "GEOS Exception: geometry " << i << "->buffer(10): " << exc.what() << "\n";
+ cout << endl << "--------HERE COMES THE BUFFERED GEOMS ----------" << endl;
+ delete newgeoms;
+ // CONVEX HULL
+ // Make convex hulls of geometries
+ newgeoms->push_back(g->convexHull());
+ cout << endl << "--------HERE COMES THE HULLS----------" << endl;
+ // Delete the hulls
+ delete newgeoms;
#endif // UNARY_OPERATIONS
@@ -528,348 +533,392 @@ void do_all()
// RELATIONAL OPERATORS
-cout<<"-------------------------------------------------------------------------------"<<endl;
-cout<<"RELATIONAL OPERATORS"<<endl;
- // DISJOINT
- cout<<endl;
- cout<<" DISJOINT ";
- cout<<"\t["<<i<<"]";
- cout<<endl;
- Geometry *g1 = (*geoms)[i];
- cout<<" ["<<i<<"]\t";
- for (unsigned int j=0; j<geoms->size(); j++) {
- Geometry *g2 = (*geoms)[j];
- try {
- if ( g1->disjoint(g2) ) cout<<" 1\t";
- else cout<<" 0\t";
- // Geometry Collection is not a valid argument
- catch (const IllegalArgumentException& exc) {
- cout<<" X\t";
- catch (const std::exception& exc) {
- cerr<<exc.what()<<endl;
- cout<<endl;
- // TOUCHES
- cout<<endl;
- cout<<" TOUCHES ";
- cout<<endl;
- try {
- if ( g1->touches(g2) ) cout<<" 1\t";
- cout<<" X\t";
- cout<<endl;
- // INTERSECTS
- cout<<endl;
- cout<<" INTERSECTS ";
- cout<<endl;
- try {
- if ( g1->intersects(g2) ) cout<<" 1\t";
- cout<<" X\t";
- cout<<endl;
- // CROSSES
- cout<<endl;
- cout<<" CROSSES ";
- cout<<endl;
- try {
- if ( g1->crosses(g2) ) cout<<" 1\t";
- cout<<" X\t";
- cout<<endl;
- // WITHIN
- cout<<endl;
- cout<<" WITHIN ";
- cout<<endl;
- try {
- if ( g1->within(g2) ) cout<<" 1\t";
- cout<<" X\t";
- cout<<endl;
- // CONTAINS
- cout<<endl;
- cout<<" CONTAINS ";
- cout<<endl;
- try {
- if ( g1->contains(g2) ) cout<<" 1\t";
- cout<<" X\t";
- cout<<endl;
- // OVERLAPS
- cout<<endl;
- cout<<" OVERLAPS ";
- cout<<endl;
- try {
- if ( g1->overlaps(g2) ) cout<<" 1\t";
- cout<<" X\t";
- cout<<endl;
- // RELATE
- cout<<endl;
- cout<<" RELATE ";
- cout<<endl;
- IntersectionMatrix *im=NULL;
- try {
- // second argument is intersectionPattern
- string pattern = "212101212";
- if ( g1->relate(g2, pattern) ) cout<<" 1\t";
- // get the intersectionMatrix itself
- im=g1->relate(g2);
- delete im; // delete afterwards
- cout<<" X\t";
- cout<<endl;
- // EQUALS
- cout<<endl;
- cout<<" EQUALS ";
- cout<<endl;
- try {
- if ( g1->equals(g2) ) cout<<" 1\t";
- cout<<" X\t";
- cout<<endl;
- // EQUALS_EXACT
- cout<<endl;
- cout<<"EQUALS_EXACT ";
- cout<<endl;
- try {
- // second argument is a tolerance
- if ( g1->equalsExact(g2, 0.5) ) cout<<" 1\t";
- cout<<" X\t";
- cout<<endl;
- // IS_WITHIN_DISTANCE
- cout<<endl;
- cout<<"IS_WITHIN_DIST";
- cout<<endl;
- try {
- // second argument is the distance
- if ( g1->isWithinDistance(g2,2) ) cout<<" 1\t";
- cout<<" X\t";
- cout<<endl;
+ cout << "-------------------------------------------------------------------------------" << endl;
+ cout << "RELATIONAL OPERATORS" << endl;
+ // DISJOINT
+ cout << endl;
+ cout << " DISJOINT ";
+ cout << "\t[" << i << "]";
+ cout << endl;
+ Geometry* g1 = (*geoms)[i];
+ cout << " [" << i << "]\t";
+ for(unsigned int j = 0; j < geoms->size(); j++) {
+ Geometry* g2 = (*geoms)[j];
+ try {
+ if(g1->disjoint(g2)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ // Geometry Collection is not a valid argument
+ catch(const IllegalArgumentException& exc) {
+ cout << " X\t";
+ catch(const std::exception& exc) {
+ cerr << exc.what() << endl;
+ cout << endl;
+ // TOUCHES
+ cout << endl;
+ cout << " TOUCHES ";
+ cout << endl;
+ try {
+ if(g1->touches(g2)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ cout << " X\t";
+ cout << endl;
+ // INTERSECTS
+ cout << endl;
+ cout << " INTERSECTS ";
+ cout << endl;
+ try {
+ if(g1->intersects(g2)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ cout << " X\t";
+ cout << endl;
+ // CROSSES
+ cout << endl;
+ cout << " CROSSES ";
+ cout << endl;
+ try {
+ if(g1->crosses(g2)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ cout << " X\t";
+ cout << endl;
+ // WITHIN
+ cout << endl;
+ cout << " WITHIN ";
+ cout << endl;
+ try {
+ if(g1->within(g2)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ cout << " X\t";
+ cout << endl;
+ // CONTAINS
+ cout << endl;
+ cout << " CONTAINS ";
+ cout << endl;
+ try {
+ if(g1->contains(g2)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ cout << " X\t";
+ cout << endl;
+ // OVERLAPS
+ cout << endl;
+ cout << " OVERLAPS ";
+ cout << endl;
+ try {
+ if(g1->overlaps(g2)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ cout << " X\t";
+ cout << endl;
+ // RELATE
+ cout << endl;
+ cout << " RELATE ";
+ cout << endl;
+ IntersectionMatrix* im = NULL;
+ try {
+ // second argument is intersectionPattern
+ string pattern = "212101212";
+ if(g1->relate(g2, pattern)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ // get the intersectionMatrix itself
+ im = g1->relate(g2);
+ delete im; // delete afterwards
+ cout << " X\t";
+ cout << endl;
+ // EQUALS
+ cout << endl;
+ cout << " EQUALS ";
+ cout << endl;
+ try {
+ if(g1->equals(g2)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ cout << " X\t";
+ cout << endl;
+ // EQUALS_EXACT
+ cout << endl;
+ cout << "EQUALS_EXACT ";
+ cout << endl;
+ try {
+ // second argument is a tolerance
+ if(g1->equalsExact(g2, 0.5)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ cout << " X\t";
+ cout << endl;
+ // IS_WITHIN_DISTANCE
+ cout << endl;
+ cout << "IS_WITHIN_DIST";
+ cout << endl;
+ try {
+ // second argument is the distance
+ if(g1->isWithinDistance(g2, 2)) {
+ cout << " 1\t";
+ else {
+ cout << " 0\t";
+ cout << " X\t";
+ cout << endl;
#endif // RELATIONAL_OPERATORS
@@ -879,235 +928,233 @@ cout<<"-------------------------------------------------------------------------
// COMBINATIONS
-cout<<endl;
-cout<<"COMBINATIONS"<<endl;
- // UNION
- // Make unions of all geoms
- for (unsigned int i=0; i<geoms->size()-1; i++) {
- for (unsigned int j=i+1; j<geoms->size(); j++) {
- try {
- Geometry *g3 = g1->Union(g2);
- newgeoms->push_back(g3);
- // It's illegal to union a collection ...
- catch (const IllegalArgumentException& ill) {
- //cerr <<ill.toString()<<"\n";
- // Print all unions
- cout<<endl<<"----- AND HERE ARE SOME UNION COMBINATIONS ------"<<endl;
- // Delete the resulting geoms
- delete newgeoms;
- // INTERSECTION
- // Compute intersection of adhiacent geometries
- try {
- Geometry *g3 = g1->intersection(g2);
- // Collection are illegal as intersection argument
- cout<<endl<<"----- HERE ARE SOME INTERSECTIONS COMBINATIONS ------"<<endl;
- delete newgeoms;
- // DIFFERENCE
- // Compute difference of adhiacent geometries
- try {
- Geometry *g3 = g1->difference(g2);
- // Collection are illegal as difference argument
- cout<<endl<<"----- HERE ARE SOME DIFFERENCE COMBINATIONS ------"<<endl;
- delete newgeoms;
- // SYMMETRIC DIFFERENCE
- // Compute symmetric difference of adhiacent geometries
- try {
- Geometry *g3 = g1->symDifference(g2);
- // Collection are illegal as symdifference argument
- cout<<endl<<"----- HERE ARE SYMMETRIC DIFFERENCES ------"<<endl;
- delete newgeoms;
+ cout << endl;
+ cout << "COMBINATIONS" << endl;
+ // UNION
+ // Make unions of all geoms
+ for(unsigned int i = 0; i < geoms->size() - 1; i++) {
+ for(unsigned int j = i + 1; j < geoms->size(); j++) {
+ try {
+ Geometry* g3 = g1->Union(g2);
+ newgeoms->push_back(g3);
+ // It's illegal to union a collection ...
+ catch(const IllegalArgumentException& ill) {
+ //cerr <<ill.toString()<<"\n";
+ // Print all unions
+ cout << endl << "----- AND HERE ARE SOME UNION COMBINATIONS ------" << endl;
+ // Delete the resulting geoms
+ delete newgeoms;
+ // INTERSECTION
+ // Compute intersection of adhiacent geometries
+ try {
+ Geometry* g3 = g1->intersection(g2);
+ // Collection are illegal as intersection argument
+ cout << endl << "----- HERE ARE SOME INTERSECTIONS COMBINATIONS ------" << endl;
+ delete newgeoms;
+ // DIFFERENCE
+ // Compute difference of adhiacent geometries
+ try {
+ Geometry* g3 = g1->difference(g2);
+ // Collection are illegal as difference argument
+ cout << endl << "----- HERE ARE SOME DIFFERENCE COMBINATIONS ------" << endl;
+ delete newgeoms;
+ // SYMMETRIC DIFFERENCE
+ // Compute symmetric difference of adhiacent geometries
+ try {
+ Geometry* g3 = g1->symDifference(g2);
+ // Collection are illegal as symdifference argument
+ cout << endl << "----- HERE ARE SYMMETRIC DIFFERENCES ------" << endl;
+ delete newgeoms;
#endif // COMBINATIONS
#if LINEMERGE
- // LINEMERGE
- LineMerger lm;
- lm.add(geoms);
- vector<LineString *> *mls = lm.getMergedLineStrings();
- for (unsigned int i=0; i<mls->size(); i++)
- newgeoms->push_back((*mls)[i]);
- delete mls;
- cout<<endl<<"----- HERE IS THE LINEMERGE OUTPUT ------"<<endl;
- delete newgeoms;
+ // LINEMERGE
+ LineMerger lm;
+ lm.add(geoms);
+ vector<LineString*>* mls = lm.getMergedLineStrings();
+ for(unsigned int i = 0; i < mls->size(); i++) {
+ newgeoms->push_back((*mls)[i]);
+ delete mls;
+ cout << endl << "----- HERE IS THE LINEMERGE OUTPUT ------" << endl;
+ delete newgeoms;
#endif // LINEMERGE
#if POLYGONIZE
- // POLYGONIZE
- Polygonizer plgnzr;
- plgnzr.add(geoms);
- vector<Polygon *> *polys = plgnzr.getPolygons();
- for (unsigned int i=0; i<polys->size(); i++)
- newgeoms->push_back((*polys)[i]);
- delete polys;
- cout<<endl<<"----- HERE IS POLYGONIZE OUTPUT ------"<<endl;
- delete newgeoms;
+ // POLYGONIZE
+ Polygonizer plgnzr;
+ plgnzr.add(geoms);
+ vector<Polygon*>* polys = plgnzr.getPolygons();
+ for(unsigned int i = 0; i < polys->size(); i++) {
+ newgeoms->push_back((*polys)[i]);
+ delete polys;
+ cout << endl << "----- HERE IS POLYGONIZE OUTPUT ------" << endl;
+ delete newgeoms;
#endif // POLYGONIZE
- // CLEANUP
+ // CLEANUP
- // Delete base geometries
- delete (*geoms)[i];
- delete geoms;
+ // Delete base geometries
+ delete(*geoms)[i];
+ delete geoms;
int
main()
- cout<<"GEOS "<<geosversion()<<" ported from JTS "<<jtsport()<<endl;
- try
- do_all();
- // All exception thrown by GEOS are subclasses of this
- // one, so this is a catch-all
- cerr <<"GEOS Exception: "<<exc.what()<<"\n";
- exit(1);
- catch (const exception &e)
- cerr <<"Standard exception thrown: "<<e.what()<<endl;
- exit(1);
- // and this is a catch-all non standard ;)
- catch (...)
- cerr <<"unknown exception trown!\n";
- exit(1);
- // Unload is no more necessary
- //io::Unload::Release();
- exit(0);
+ cout << "GEOS " << geosversion() << " ported from JTS " << jtsport() << endl;
+ try {
+ do_all();
+ // All exception thrown by GEOS are subclasses of this
+ // one, so this is a catch-all
+ cerr << "GEOS Exception: " << exc.what() << "\n";
+ exit(1);
+ catch(const exception& e) {
+ cerr << "Standard exception thrown: " << e.what() << endl;
+ exit(1);
+ // and this is a catch-all non standard ;)
+ catch(...) {
+ cerr << "unknown exception trown!\n";
+ exit(1);
+ // Unload is no more necessary
+ //io::Unload::Release();
+ exit(0);
diff --git a/include/geos/algorithm/Angle.h b/include/geos/algorithm/Angle.h
index 314d5e4..d329a78 100644
--- a/include/geos/algorithm/Angle.h
+++ b/include/geos/algorithm/Angle.h
@@ -24,9 +24,9 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -36,188 +36,187 @@ namespace algorithm { // geos::algorithm
/// Unless otherwise noted, methods in this class express angles in radians.
-class GEOS_DLL Angle
+class GEOS_DLL Angle {
public:
- static const double PI_TIMES_2; // 2.0 * PI;
- static const double PI_OVER_2; // PI / 2.0;
- static const double PI_OVER_4; // PI / 4.0;
- /// Constant representing counterclockwise orientation
- static const int COUNTERCLOCKWISE = Orientation::COUNTERCLOCKWISE;
- /// Constant representing clockwise orientation
- static const int CLOCKWISE = Orientation::CLOCKWISE;
- /// Constant representing no orientation
- static const int NONE = Orientation::COLLINEAR;
- /// Converts from radians to degrees.
- /// @param radians an angle in radians
- /// @return the angle in degrees
- static double toDegrees(double radians);
- /// Converts from degrees to radians.
- /// @param angleDegrees an angle in degrees
- /// @return the angle in radians
- static double toRadians(double angleDegrees);
- /// \brief
- /// Returns the angle of the vector from p0 to p1,
- /// relative to the positive X-axis.
- /// The angle is normalized to be in the range [ -Pi, Pi ].
- /// @return the normalized angle (in radians) that p0-p1 makes
- /// with the positive x-axis.
- static double angle(const geom::Coordinate& p0,
- const geom::Coordinate& p1);
- /// \brief
- /// Returns the angle that the vector from (0,0) to p,
- /// The angle is normalized to be in the range ( -Pi, Pi ].
- /// @return the normalized angle (in radians) that p makes
- static double angle(const geom::Coordinate& p);
- /// Tests whether the angle between p0-p1-p2 is acute.
- /// An angle is acute if it is less than 90 degrees.
- /// Note: this implementation is not precise (determistic) for
- /// angles very close to 90 degrees.
- /// @param p0 an endpoint of the angle
- /// @param p1 the base of the angle
- /// @param p2 the other endpoint of the angle
- static bool isAcute(const geom::Coordinate& p0,
- const geom::Coordinate& p1,
- const geom::Coordinate& p2);
- /// Tests whether the angle between p0-p1-p2 is obtuse.
- /// An angle is obtuse if it is greater than 90 degrees.
- static bool isObtuse(const geom::Coordinate& p0,
- /// Returns the unoriented smallest angle between two vectors.
- /// The computed angle will be in the range [0, Pi).
- /// @param tip1 the tip of one vector
- /// @param tail the tail of each vector
- /// @param tip2 the tip of the other vector
- /// @return the angle between tail-tip1 and tail-tip2
- static double angleBetween(const geom::Coordinate& tip1,
- const geom::Coordinate& tail,
- const geom::Coordinate& tip2);
- /// Returns the oriented smallest angle between two vectors.
- /// The computed angle will be in the range (-Pi, Pi].
- /// A positive result corresponds to a counterclockwise rotation
- /// from v1 to v2;
- /// a negative result corresponds to a clockwise rotation.
- /// @param tip1 the tip of v1
- /// @param tip2 the tip of v2
- /// @return the angle between v1 and v2, relative to v1
- static double angleBetweenOriented(const geom::Coordinate& tip1,
- /// Computes the interior angle between two segments of a ring.
- /// The ring is assumed to be oriented in a clockwise direction.
- /// The computed angle will be in the range [0, 2Pi]
- /// @param p0
- /// a point of the ring
- /// @param p1
- /// the next point of the ring
- /// @param p2
- /// @return the interior angle based at <code>p1</code>
- static double interiorAngle(const geom::Coordinate& p0,
- /// \brief
- /// Returns whether an angle must turn clockwise or counterclockwise
- /// to overlap another angle.
- /// @param ang1 an angle (in radians)
- /// @param ang2 an angle (in radians)
- /// @return whether a1 must turn CLOCKWISE, COUNTERCLOCKWISE or
- /// NONE to overlap a2.
- static int getTurn(double ang1, double ang2);
- /// \brief
- /// Computes the normalized value of an angle, which is the
- /// equivalent angle in the range ( -Pi, Pi ].
- /// @param angle the angle to normalize
- /// @return an equivalent angle in the range (-Pi, Pi]
- static double normalize(double angle);
- /// \brief
- /// Computes the normalized positive value of an angle,
- /// which is the equivalent angle in the range [ 0, 2*Pi ).
- /// E.g.:
- /// - normalizePositive(0.0) = 0.0
- /// - normalizePositive(-PI) = PI
- /// - normalizePositive(-2PI) = 0.0
- /// - normalizePositive(-3PI) = PI
- /// - normalizePositive(-4PI) = 0
- /// - normalizePositive(PI) = PI
- /// - normalizePositive(2PI) = 0.0
- /// - normalizePositive(3PI) = PI
- /// - normalizePositive(4PI) = 0.0
- /// @param angle the angle to normalize, in radians
- /// @return an equivalent positive angle
- static double normalizePositive(double angle);
- /// Computes the unoriented smallest difference between two angles.
- /// The angles are assumed to be normalized to the range [-Pi, Pi].
- /// The result will be in the range [0, Pi].
- /// @param ang1 the angle of one vector (in [-Pi, Pi] )
- /// @param ang2 the angle of the other vector (in range [-Pi, Pi] )
- /// @return the angle (in radians) between the two vectors
- /// (in range [0, Pi] )
- static double diff(double ang1, double ang2);
+ static const double PI_TIMES_2; // 2.0 * PI;
+ static const double PI_OVER_2; // PI / 2.0;
+ static const double PI_OVER_4; // PI / 4.0;
+ /// Constant representing counterclockwise orientation
+ static const int COUNTERCLOCKWISE = Orientation::COUNTERCLOCKWISE;
+ /// Constant representing clockwise orientation
+ static const int CLOCKWISE = Orientation::CLOCKWISE;
+ /// Constant representing no orientation
+ static const int NONE = Orientation::COLLINEAR;
+ /// Converts from radians to degrees.
+ /// @param radians an angle in radians
+ /// @return the angle in degrees
+ static double toDegrees(double radians);
+ /// Converts from degrees to radians.
+ /// @param angleDegrees an angle in degrees
+ /// @return the angle in radians
+ static double toRadians(double angleDegrees);
+ /// \brief
+ /// Returns the angle of the vector from p0 to p1,
+ /// relative to the positive X-axis.
+ /// The angle is normalized to be in the range [ -Pi, Pi ].
+ /// @return the normalized angle (in radians) that p0-p1 makes
+ /// with the positive x-axis.
+ static double angle(const geom::Coordinate& p0,
+ const geom::Coordinate& p1);
+ /// \brief
+ /// Returns the angle that the vector from (0,0) to p,
+ /// The angle is normalized to be in the range ( -Pi, Pi ].
+ /// @return the normalized angle (in radians) that p makes
+ static double angle(const geom::Coordinate& p);
+ /// Tests whether the angle between p0-p1-p2 is acute.
+ /// An angle is acute if it is less than 90 degrees.
+ /// Note: this implementation is not precise (determistic) for
+ /// angles very close to 90 degrees.
+ /// @param p0 an endpoint of the angle
+ /// @param p1 the base of the angle
+ /// @param p2 the other endpoint of the angle
+ static bool isAcute(const geom::Coordinate& p0,
+ const geom::Coordinate& p1,
+ const geom::Coordinate& p2);
+ /// Tests whether the angle between p0-p1-p2 is obtuse.
+ /// An angle is obtuse if it is greater than 90 degrees.
+ static bool isObtuse(const geom::Coordinate& p0,
+ /// Returns the unoriented smallest angle between two vectors.
+ /// The computed angle will be in the range [0, Pi).
+ /// @param tip1 the tip of one vector
+ /// @param tail the tail of each vector
+ /// @param tip2 the tip of the other vector
+ /// @return the angle between tail-tip1 and tail-tip2
+ static double angleBetween(const geom::Coordinate& tip1,
+ const geom::Coordinate& tail,
+ const geom::Coordinate& tip2);
+ /// Returns the oriented smallest angle between two vectors.
+ /// The computed angle will be in the range (-Pi, Pi].
+ /// A positive result corresponds to a counterclockwise rotation
+ /// from v1 to v2;
+ /// a negative result corresponds to a clockwise rotation.
+ /// @param tip1 the tip of v1
+ /// @param tip2 the tip of v2
+ /// @return the angle between v1 and v2, relative to v1
+ static double angleBetweenOriented(const geom::Coordinate& tip1,
+ /// Computes the interior angle between two segments of a ring.
+ /// The ring is assumed to be oriented in a clockwise direction.
+ /// The computed angle will be in the range [0, 2Pi]
+ /// @param p0
+ /// a point of the ring
+ /// @param p1
+ /// the next point of the ring
+ /// @param p2
+ /// @return the interior angle based at <code>p1</code>
+ static double interiorAngle(const geom::Coordinate& p0,
+ /// \brief
+ /// Returns whether an angle must turn clockwise or counterclockwise
+ /// to overlap another angle.
+ /// @param ang1 an angle (in radians)
+ /// @param ang2 an angle (in radians)
+ /// @return whether a1 must turn CLOCKWISE, COUNTERCLOCKWISE or
+ /// NONE to overlap a2.
+ static int getTurn(double ang1, double ang2);
+ /// \brief
+ /// Computes the normalized value of an angle, which is the
+ /// equivalent angle in the range ( -Pi, Pi ].
+ /// @param angle the angle to normalize
+ /// @return an equivalent angle in the range (-Pi, Pi]
+ static double normalize(double angle);
+ /// \brief
+ /// Computes the normalized positive value of an angle,
+ /// which is the equivalent angle in the range [ 0, 2*Pi ).
+ /// E.g.:
+ /// - normalizePositive(0.0) = 0.0
+ /// - normalizePositive(-PI) = PI
+ /// - normalizePositive(-2PI) = 0.0
+ /// - normalizePositive(-3PI) = PI
+ /// - normalizePositive(-4PI) = 0
+ /// - normalizePositive(PI) = PI
+ /// - normalizePositive(2PI) = 0.0
+ /// - normalizePositive(3PI) = PI
+ /// - normalizePositive(4PI) = 0.0
+ /// @param angle the angle to normalize, in radians
+ /// @return an equivalent positive angle
+ static double normalizePositive(double angle);
+ /// Computes the unoriented smallest difference between two angles.
+ /// The angles are assumed to be normalized to the range [-Pi, Pi].
+ /// The result will be in the range [0, Pi].
+ /// @param ang1 the angle of one vector (in [-Pi, Pi] )
+ /// @param ang2 the angle of the other vector (in range [-Pi, Pi] )
+ /// @return the angle (in radians) between the two vectors
+ /// (in range [0, Pi] )
+ static double diff(double ang1, double ang2);
diff --git a/include/geos/algorithm/Area.h b/include/geos/algorithm/Area.h
index 71e4bd9..83e37a2 100644
--- a/include/geos/algorithm/Area.h
+++ b/include/geos/algorithm/Area.h
@@ -36,7 +36,7 @@ public:
* @param ring the coordinates forming the ring
* @return the area of the ring
- static double ofRing(const std::vector<geom::Coordinate> &ring);
+ static double ofRing(const std::vector<geom::Coordinate>& ring);
* Computes the area for a ring.
@@ -44,7 +44,7 @@ public:
- static double ofRing(const geom::CoordinateSequence *ring);
+ static double ofRing(const geom::CoordinateSequence* ring);
* Computes the signed area for a ring. The signed area is positive if the
@@ -55,7 +55,7 @@ public:
* the coordinates forming the ring
* @return the signed area of the ring
- static double ofRingSigned(const std::vector<geom::Coordinate> &ring);
+ static double ofRingSigned(const std::vector<geom::Coordinate>& ring);
@@ -66,7 +66,7 @@ public:
- static double ofRingSigned(const geom::CoordinateSequence *ring);
+ static double ofRingSigned(const geom::CoordinateSequence* ring);
diff --git a/include/geos/algorithm/BoundaryNodeRule.h b/include/geos/algorithm/BoundaryNodeRule.h
index 77f3221..3a7b294 100644
--- a/include/geos/algorithm/BoundaryNodeRule.h
+++ b/include/geos/algorithm/BoundaryNodeRule.h
@@ -51,61 +51,62 @@ class GEOS_DLL BoundaryNodeRule {
public:
- // virtual classes should always have a virtual destructor..
- virtual ~BoundaryNodeRule() {}
- * Tests whether a point that lies in <tt>boundaryCount</tt>
- * geometry component boundaries is considered to form part of
- * the boundary of the parent geometry.
- * @param boundaryCount the number of component boundaries that
- * this point occurs in
- * @return true if points in this number of boundaries lie in
- * the parent boundary
- virtual bool isInBoundary(int boundaryCount) const=0;
- /** \brief
- * The Mod-2 Boundary Node Rule (which is the rule specified
- * in the OGC SFS).
- * @see Mod2BoundaryNodeRule
- //static const BoundaryNodeRule& MOD2_BOUNDARY_RULE;
+ // virtual classes should always have a virtual destructor..
+ virtual
+ ~BoundaryNodeRule() {}
+ * Tests whether a point that lies in <tt>boundaryCount</tt>
+ * geometry component boundaries is considered to form part of
+ * the boundary of the parent geometry.
+ * @param boundaryCount the number of component boundaries that
+ * this point occurs in
+ * @return true if points in this number of boundaries lie in
+ * the parent boundary
+ virtual bool isInBoundary(int boundaryCount) const = 0;
+ /** \brief
+ * The Mod-2 Boundary Node Rule (which is the rule specified
+ * in the OGC SFS).
+ * @see Mod2BoundaryNodeRule
+ //static const BoundaryNodeRule& MOD2_BOUNDARY_RULE;
static const BoundaryNodeRule& getBoundaryRuleMod2();
- /** \brief
- * The Endpoint Boundary Node Rule.
- * @see EndPointBoundaryNodeRule
- //static const BoundaryNodeRule& ENDPOINT_BOUNDARY_RULE;
+ /** \brief
+ * The Endpoint Boundary Node Rule.
+ * @see EndPointBoundaryNodeRule
+ //static const BoundaryNodeRule& ENDPOINT_BOUNDARY_RULE;
static const BoundaryNodeRule& getBoundaryEndPoint();
- /** \brief
- * The MultiValent Endpoint Boundary Node Rule.
- * @see MultiValentEndPointBoundaryNodeRule
- //static const BoundaryNodeRule& MULTIVALENT_ENDPOINT_BOUNDARY_RULE;
+ /** \brief
+ * The MultiValent Endpoint Boundary Node Rule.
+ * @see MultiValentEndPointBoundaryNodeRule
+ //static const BoundaryNodeRule& MULTIVALENT_ENDPOINT_BOUNDARY_RULE;
static const BoundaryNodeRule& getBoundaryMultivalentEndPoint();
- /** \brief
- * The Monovalent Endpoint Boundary Node Rule.
- * @see MonoValentEndPointBoundaryNodeRule
- //static const BoundaryNodeRule& MONOVALENT_ENDPOINT_BOUNDARY_RULE;
+ /** \brief
+ * The Monovalent Endpoint Boundary Node Rule.
+ * @see MonoValentEndPointBoundaryNodeRule
+ //static const BoundaryNodeRule& MONOVALENT_ENDPOINT_BOUNDARY_RULE;
static const BoundaryNodeRule& getBoundaryMonovalentEndPoint();
- /** \brief
- * The Boundary Node Rule specified by the OGC Simple Features
- * Specification, which is the same as the Mod-2 rule.
- //static const BoundaryNodeRule& OGC_SFS_BOUNDARY_RULE;
+ /** \brief
+ * The Boundary Node Rule specified by the OGC Simple Features
+ * Specification, which is the same as the Mod-2 rule.
+ //static const BoundaryNodeRule& OGC_SFS_BOUNDARY_RULE;
static const BoundaryNodeRule& getBoundaryOGCSFS();
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index 3c46b23..8b2cb50 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -47,16 +47,16 @@ class GEOS_DLL CGAlgorithmsDD {
public:
enum {
- CLOCKWISE=-1,
- COLLINEAR=0,
- COUNTERCLOCKWISE=1
+ CLOCKWISE = -1,
+ COLLINEAR = 0,
+ COUNTERCLOCKWISE = 1
enum {
- RIGHT=-1,
- LEFT=1,
- STRAIGHT=0,
- FAILURE=2
+ RIGHT = -1,
+ LEFT = 1,
+ STRAIGHT = 0,
+ FAILURE = 2
@@ -98,23 +98,28 @@ public:
const geom::Coordinate& pb,
const geom::Coordinate& pc);
- static int orientation(double x)
+ static int
+ orientation(double x)
- if (x < 0) return CGAlgorithmsDD::RIGHT;
- if (x > 0) return CGAlgorithmsDD::LEFT;
+ if(x < 0) {
+ return CGAlgorithmsDD::RIGHT;
+ if(x > 0) {
+ return CGAlgorithmsDD::LEFT;
return CGAlgorithmsDD::STRAIGHT;
static void intersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
const geom::Coordinate& q1, const geom::Coordinate& q2,
- geom::Coordinate &rv);
+ geom::Coordinate& rv);
static int signOfDet2x2(double dx1, double dy1, double dx2, double dy2);
protected:
- static int signOfDet2x2(DD &x1, DD &y1, DD &x2, DD &y2);
+ static int signOfDet2x2(DD& x1, DD& y1, DD& x2, DD& y2);
diff --git a/include/geos/algorithm/CentralEndpointIntersector.h b/include/geos/algorithm/CentralEndpointIntersector.h
index 2c78b72..f70b092 100644
--- a/include/geos/algorithm/CentralEndpointIntersector.h
+++ b/include/geos/algorithm/CentralEndpointIntersector.h
@@ -32,9 +32,9 @@
namespace geos {
- namespace geom {
- //class PrecisionModel;
+namespace geom {
+//class PrecisionModel;
namespace geos {
@@ -63,88 +63,94 @@ class GEOS_DLL CentralEndpointIntersector {
public:
- static const geom::Coordinate& getIntersection(const geom::Coordinate& p00,
- const geom::Coordinate& p01, const geom::Coordinate& p10,
- const geom::Coordinate& p11)
- CentralEndpointIntersector intor(p00, p01, p10, p11);
- return intor.getIntersection();
- CentralEndpointIntersector(const geom::Coordinate& p00,
- const geom::Coordinate& p10,
- _pts(4)
- _pts[0]=p00;
- _pts[1]=p01;
- _pts[2]=p10;
- _pts[3]=p11;
- compute();
- const geom::Coordinate& getIntersection() const
- return _intPt;
+ static const geom::Coordinate&
+ getIntersection(const geom::Coordinate& p00,
+ const geom::Coordinate& p01, const geom::Coordinate& p10,
+ const geom::Coordinate& p11)
+ CentralEndpointIntersector intor(p00, p01, p10, p11);
+ return intor.getIntersection();
+ CentralEndpointIntersector(const geom::Coordinate& p00,
+ const geom::Coordinate& p10,
+ _pts(4)
+ _pts[0] = p00;
+ _pts[1] = p01;
+ _pts[2] = p10;
+ _pts[3] = p11;
+ compute();
+ getIntersection() const
+ return _intPt;
private:
- // This is likely overkill.. we'll be allocating heap
- // memory at every call !
- std::vector<geom::Coordinate> _pts;
- geom::Coordinate _intPt;
- void compute()
- geom::Coordinate centroid = average(_pts);
- _intPt = findNearestPoint(centroid, _pts);
- static geom::Coordinate average(
- const std::vector<geom::Coordinate>& pts)
- geom::Coordinate avg(0, 0);
- size_t n = pts.size();
- if ( ! n ) return avg;
- for (std::size_t i=0; i<n; ++i)
- avg.x += pts[i].x;
- avg.y += pts[i].y;
- avg.x /= n;
- avg.y /= n;
- return avg;
- * Determines a point closest to the given point.
- * @param p the point to compare against
- * @param p1 a potential result point
- * @param p2 a potential result point
- * @param q1 a potential result point
- * @param q2 a potential result point
- * @return the point closest to the input point p
- geom::Coordinate findNearestPoint(const geom::Coordinate& p,
- const std::vector<geom::Coordinate>& pts) const
- double minDist = std::numeric_limits<double>::max();
- geom::Coordinate result = geom::Coordinate::getNull();
- for (std::size_t i = 0, n=pts.size(); i < n; ++i) {
- double dist = p.distance(pts[i]);
- if (dist < minDist) {
- minDist = dist;
- result = pts[i];
- return result;
+ // This is likely overkill.. we'll be allocating heap
+ // memory at every call !
+ std::vector<geom::Coordinate> _pts;
+ geom::Coordinate _intPt;
+ void
+ compute()
+ geom::Coordinate centroid = average(_pts);
+ _intPt = findNearestPoint(centroid, _pts);
+ static geom::Coordinate
+ average(
+ const std::vector<geom::Coordinate>& pts)
+ geom::Coordinate avg(0, 0);
+ size_t n = pts.size();
+ if(! n) {
+ return avg;
+ for(std::size_t i = 0; i < n; ++i) {
+ avg.x += pts[i].x;
+ avg.y += pts[i].y;
+ avg.x /= n;
+ avg.y /= n;
+ return avg;
+ * Determines a point closest to the given point.
+ * @param p the point to compare against
+ * @param p1 a potential result point
+ * @param p2 a potential result point
+ * @param q1 a potential result point
+ * @param q2 a potential result point
+ * @return the point closest to the input point p
+ geom::Coordinate
+ findNearestPoint(const geom::Coordinate& p,
+ const std::vector<geom::Coordinate>& pts) const
+ double minDist = std::numeric_limits<double>::max();
+ geom::Coordinate result = geom::Coordinate::getNull();
+ for(std::size_t i = 0, n = pts.size(); i < n; ++i) {
+ double dist = p.distance(pts[i]);
+ if(dist < minDist) {
+ minDist = dist;
+ result = pts[i];
+ return result;
} // namespace geos::algorithm
diff --git a/include/geos/algorithm/Centroid.h b/include/geos/algorithm/Centroid.h
index 9f7d268..e2eae3d 100644
--- a/include/geos/algorithm/Centroid.h
+++ b/include/geos/algorithm/Centroid.h
@@ -25,11 +25,11 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Polygon;
- class CoordinateSequence;
+namespace geom {
+class Geometry;
+class Polygon;
+class CoordinateSequence;
@@ -62,93 +62,95 @@ class GEOS_DLL Centroid {
public:
- * Computes the centroid point of a geometry.
- * @param geom the geometry to use
- * @param cent will be set to the centroid point, if any
- * @return true if a centroid could be computed,
- * false otherwise (empty geom)
- static bool getCentroid(const geom::Geometry& geom, geom::Coordinate& cent);
- * Creates a new instance for computing the centroid of a geometry
- Centroid(const geom::Geometry& geom)
- areasum2(0.0),
- totalLength(0.0),
- ptCount(0)
- add(geom);
- * Gets the computed centroid.
- bool getCentroid(geom::Coordinate& cent) const;
+ * Computes the centroid point of a geometry.
+ * @param geom the geometry to use
+ * @param cent will be set to the centroid point, if any
+ * @return true if a centroid could be computed,
+ * false otherwise (empty geom)
+ static bool getCentroid(const geom::Geometry& geom, geom::Coordinate& cent);
+ * Creates a new instance for computing the centroid of a geometry
+ Centroid(const geom::Geometry& geom)
+ areasum2(0.0),
+ totalLength(0.0),
+ ptCount(0)
+ add(geom);
+ * Gets the computed centroid.
+ bool getCentroid(geom::Coordinate& cent) const;
private:
- std::unique_ptr<geom::Coordinate> areaBasePt;
- geom::Coordinate triangleCent3;
- geom::Coordinate cg3;
- geom::Coordinate lineCentSum;
- geom::Coordinate ptCentSum;
- double areasum2;
- double totalLength;
- int ptCount;
- * Adds a Geometry to the centroid total.
- * @param geom the geometry to add
- void add(const geom::Geometry& geom);
- void setAreaBasePoint(const geom::Coordinate& basePt);
- void add(const geom::Polygon& poly);
- void addShell(const geom::CoordinateSequence& pts);
- void addHole(const geom::CoordinateSequence& pts);
- void addTriangle(const geom::Coordinate& p0, const geom::Coordinate& p1, const geom::Coordinate& p2, bool isPositiveArea);
- * Computes three times the centroid of the triangle p1-p2-p3.
- * The factor of 3 is
- * left in to permit division to be avoided until later.
- static void centroid3(const geom::Coordinate& p1, const geom::Coordinate& p2, const geom::Coordinate& p3, geom::Coordinate& c );
- * Returns twice the signed area of the triangle p1-p2-p3.
- * The area is positive if the triangle is oriented CCW, and negative if CW.
- static double area2(const geom::Coordinate& p1, const geom::Coordinate& p2, const geom::Coordinate& p3 );
- * Adds the line segments defined by an array of coordinates
- * to the linear centroid accumulators.
- * @param pts an array of {@link Coordinate}s
- void addLineSegments(const geom::CoordinateSequence& pts);
- * Adds a point to the point centroid accumulator.
- * @param pt a {@link Coordinate}
- void addPoint(const geom::Coordinate& pt);
+ std::unique_ptr<geom::Coordinate> areaBasePt;
+ geom::Coordinate triangleCent3;
+ geom::Coordinate cg3;
+ geom::Coordinate lineCentSum;
+ geom::Coordinate ptCentSum;
+ double areasum2;
+ double totalLength;
+ int ptCount;
+ * Adds a Geometry to the centroid total.
+ * @param geom the geometry to add
+ void add(const geom::Geometry& geom);
+ void setAreaBasePoint(const geom::Coordinate& basePt);
+ void add(const geom::Polygon& poly);
+ void addShell(const geom::CoordinateSequence& pts);
+ void addHole(const geom::CoordinateSequence& pts);
+ void addTriangle(const geom::Coordinate& p0, const geom::Coordinate& p1, const geom::Coordinate& p2,
+ bool isPositiveArea);
+ * Computes three times the centroid of the triangle p1-p2-p3.
+ * The factor of 3 is
+ * left in to permit division to be avoided until later.
+ static void centroid3(const geom::Coordinate& p1, const geom::Coordinate& p2, const geom::Coordinate& p3,
+ geom::Coordinate& c);
+ * Returns twice the signed area of the triangle p1-p2-p3.
+ * The area is positive if the triangle is oriented CCW, and negative if CW.
+ static double area2(const geom::Coordinate& p1, const geom::Coordinate& p2, const geom::Coordinate& p3);
+ * Adds the line segments defined by an array of coordinates
+ * to the linear centroid accumulators.
+ * @param pts an array of {@link Coordinate}s
+ void addLineSegments(const geom::CoordinateSequence& pts);
+ * Adds a point to the point centroid accumulator.
+ * @param pt a {@link Coordinate}
+ void addPoint(const geom::Coordinate& pt);
diff --git a/include/geos/algorithm/ConvexHull.h b/include/geos/algorithm/ConvexHull.h
index 161b1f8..6b687a1 100644
--- a/include/geos/algorithm/ConvexHull.h
+++ b/include/geos/algorithm/ConvexHull.h
@@ -34,11 +34,11 @@
namespace geos {
- namespace geom {
- class Geometry;
- class GeometryFactory;
+namespace geom {
+class Geometry;
+class GeometryFactory;
namespace geos {
@@ -57,125 +57,125 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL ConvexHull {
private:
- const geom::GeometryFactory *geomFactory;
- geom::Coordinate::ConstVect inputPts;
- void extractCoordinates(const geom::Geometry *geom);
- /// Create a CoordinateSequence from the Coordinate::ConstVect
- /// This is needed to construct the geometries.
- /// Here coordinate copies happen
- /// The returned object is newly allocated !NO EXCEPTION SAFE!
- geom::CoordinateSequence *toCoordinateSequence(geom::Coordinate::ConstVect &cv);
- void computeOctPts(const geom::Coordinate::ConstVect &src,
- geom::Coordinate::ConstVect &tgt);
- bool computeOctRing(const geom::Coordinate::ConstVect &src,
- * Uses a heuristic to reduce the number of points scanned
- * to compute the hull.
- * The heuristic is to find a polygon guaranteed to
- * be in (or on) the hull, and eliminate all points inside it.
- * A quadrilateral defined by the extremal points
- * in the four orthogonal directions
- * can be used, but even more inclusive is
- * to use an octilateral defined by the points in the
- * 8 cardinal directions.
- * Note that even if the method used to determine the polygon
- * vertices is not 100% robust, this does not affect the
- * robustness of the convex hull.
- * To satisfy the requirements of the Graham Scan algorithm,
- * the resulting array has at least 3 entries.
- * @param pts The vector of const Coordinate pointers
- * to be reduced (to at least 3 elements)
- * WARNING: the parameter will be modified
- void reduce(geom::Coordinate::ConstVect &pts);
- /// parameter will be modified
- void padArray3(geom::Coordinate::ConstVect &pts);
- void preSort(geom::Coordinate::ConstVect &pts);
- * Given two points p and q compare them with respect to their radial
- * ordering about point o. First checks radial ordering.
- * If points are collinear, the comparison is based
- * on their distance to the origin.
- * p < q iff
- * - ang(o-p) < ang(o-q) (e.g. o-p-q is CCW)
- * - or ang(o-p) == ang(o-q) && dist(o,p) < dist(o,q)
- * @param o the origin
- * @param p a point
- * @param q another point
- * @return -1, 0 or 1 depending on whether p is less than,
- * equal to or greater than q
- int polarCompare(const geom::Coordinate &o,
- const geom::Coordinate &p, const geom::Coordinate &q);
- void grahamScan(const geom::Coordinate::ConstVect &c,
- geom::Coordinate::ConstVect &ps);
- * @param vertices the vertices of a linear ring,
- * which may or may not be
- * flattened (i.e. vertices collinear)
- * @return a 2-vertex LineString if the vertices are
- * collinear; otherwise, a Polygon with unnecessary
- * (collinear) vertices removed
- geom::Geometry* lineOrPolygon(const geom::Coordinate::ConstVect &vertices);
- * Write in 'cleaned' a version of 'input' with collinear
- * vertexes removed.
- void cleanRing(const geom::Coordinate::ConstVect &input,
- geom::Coordinate::ConstVect &cleaned);
- * @return whether the three coordinates are collinear
- * and c2 lies between c1 and c3 inclusive
- bool isBetween(const geom::Coordinate& c1, const geom::Coordinate& c2, const geom::Coordinate& c3);
+ const geom::GeometryFactory* geomFactory;
+ geom::Coordinate::ConstVect inputPts;
+ void extractCoordinates(const geom::Geometry* geom);
+ /// Create a CoordinateSequence from the Coordinate::ConstVect
+ /// This is needed to construct the geometries.
+ /// Here coordinate copies happen
+ /// The returned object is newly allocated !NO EXCEPTION SAFE!
+ geom::CoordinateSequence* toCoordinateSequence(geom::Coordinate::ConstVect& cv);
+ void computeOctPts(const geom::Coordinate::ConstVect& src,
+ geom::Coordinate::ConstVect& tgt);
+ bool computeOctRing(const geom::Coordinate::ConstVect& src,
+ * Uses a heuristic to reduce the number of points scanned
+ * to compute the hull.
+ * The heuristic is to find a polygon guaranteed to
+ * be in (or on) the hull, and eliminate all points inside it.
+ * A quadrilateral defined by the extremal points
+ * in the four orthogonal directions
+ * can be used, but even more inclusive is
+ * to use an octilateral defined by the points in the
+ * 8 cardinal directions.
+ * Note that even if the method used to determine the polygon
+ * vertices is not 100% robust, this does not affect the
+ * robustness of the convex hull.
+ * To satisfy the requirements of the Graham Scan algorithm,
+ * the resulting array has at least 3 entries.
+ * @param pts The vector of const Coordinate pointers
+ * to be reduced (to at least 3 elements)
+ * WARNING: the parameter will be modified
+ void reduce(geom::Coordinate::ConstVect& pts);
+ /// parameter will be modified
+ void padArray3(geom::Coordinate::ConstVect& pts);
+ void preSort(geom::Coordinate::ConstVect& pts);
+ * Given two points p and q compare them with respect to their radial
+ * ordering about point o. First checks radial ordering.
+ * If points are collinear, the comparison is based
+ * on their distance to the origin.
+ * p < q iff
+ * - ang(o-p) < ang(o-q) (e.g. o-p-q is CCW)
+ * - or ang(o-p) == ang(o-q) && dist(o,p) < dist(o,q)
+ * @param o the origin
+ * @param p a point
+ * @param q another point
+ * @return -1, 0 or 1 depending on whether p is less than,
+ * equal to or greater than q
+ int polarCompare(const geom::Coordinate& o,
+ const geom::Coordinate& p, const geom::Coordinate& q);
+ void grahamScan(const geom::Coordinate::ConstVect& c,
+ geom::Coordinate::ConstVect& ps);
+ * @param vertices the vertices of a linear ring,
+ * which may or may not be
+ * flattened (i.e. vertices collinear)
+ * @return a 2-vertex LineString if the vertices are
+ * collinear; otherwise, a Polygon with unnecessary
+ * (collinear) vertices removed
+ geom::Geometry* lineOrPolygon(const geom::Coordinate::ConstVect& vertices);
+ * Write in 'cleaned' a version of 'input' with collinear
+ * vertexes removed.
+ void cleanRing(const geom::Coordinate::ConstVect& input,
+ geom::Coordinate::ConstVect& cleaned);
+ * @return whether the three coordinates are collinear
+ * and c2 lies between c1 and c3 inclusive
+ bool isBetween(const geom::Coordinate& c1, const geom::Coordinate& c2, const geom::Coordinate& c3);
public:
- * Create a new convex hull construction for the input Geometry.
- ConvexHull(const geom::Geometry *newGeometry);
- ~ConvexHull();
- * Returns a Geometry that represents the convex hull of
- * the input geometry.
- * The returned geometry contains the minimal number of points
- * needed to represent the convex hull.
- * In particular, no more than two consecutive points
- * will be collinear.
- * @return if the convex hull contains 3 or more points,
- * a Polygon; 2 points, a LineString;
- * 1 point, a Point; 0 points, an empty GeometryCollection.
- geom::Geometry* getConvexHull();
+ * Create a new convex hull construction for the input Geometry.
+ ConvexHull(const geom::Geometry* newGeometry);
+ ~ConvexHull();
+ * Returns a Geometry that represents the convex hull of
+ * the input geometry.
+ * The returned geometry contains the minimal number of points
+ * needed to represent the convex hull.
+ * In particular, no more than two consecutive points
+ * will be collinear.
+ * @return if the convex hull contains 3 or more points,
+ * a Polygon; 2 points, a LineString;
+ * 1 point, a Point; 0 points, an empty GeometryCollection.
+ geom::Geometry* getConvexHull();
diff --git a/include/geos/algorithm/ConvexHull.inl b/include/geos/algorithm/ConvexHull.inl
index da092af..fef99e5 100644
--- a/include/geos/algorithm/ConvexHull.inl
+++ b/include/geos/algorithm/ConvexHull.inl
@@ -28,11 +28,11 @@ namespace geos {
INLINE
-ConvexHull::ConvexHull(const geom::Geometry *newGeometry)
- geomFactory(newGeometry->getFactory())
+ConvexHull::ConvexHull(const geom::Geometry* newGeometry)
+ geomFactory(newGeometry->getFactory())
- extractCoordinates(newGeometry);
+ extractCoordinates(newGeometry);
INLINE
@@ -41,10 +41,10 @@ ConvexHull::~ConvexHull()
INLINE void
-ConvexHull::extractCoordinates(const geom::Geometry *geom)
+ConvexHull::extractCoordinates(const geom::Geometry* geom)
- util::UniqueCoordinateArrayFilter filter(inputPts);
- geom->apply_ro(&filter);
+ util::UniqueCoordinateArrayFilter filter(inputPts);
+ geom->apply_ro(&filter);
diff --git a/include/geos/algorithm/Distance.h b/include/geos/algorithm/Distance.h
index 34e2373..c9e54a6 100644
--- a/include/geos/algorithm/Distance.h
+++ b/include/geos/algorithm/Distance.h
@@ -65,7 +65,7 @@ public:
* @return the minimum distance between the point and the line segments
static double pointToSegmentString(const geom::Coordinate& p,
- const geom::CoordinateSequence *seq);
+ const geom::CoordinateSequence* seq);
* Computes the distance from a point p to a line segment AB
diff --git a/include/geos/algorithm/HCoordinate.h b/include/geos/algorithm/HCoordinate.h
index 897a104..f2a0fc3 100644
--- a/include/geos/algorithm/HCoordinate.h
+++ b/include/geos/algorithm/HCoordinate.h
@@ -26,9 +26,9 @@
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -45,52 +45,52 @@ class GEOS_DLL HCoordinate {
public:
- friend std::ostream& operator<< (std::ostream& o, const HCoordinate& c);
+ friend std::ostream& operator<< (std::ostream& o, const HCoordinate& c);
- /** \brief
- * Computes the (approximate) intersection point between two line
- * segments using homogeneous coordinates.
- * Note that this algorithm is
- * not numerically stable; i.e. it can produce intersection points which
- * lie outside the envelope of the line segments themselves. In order
- * to increase the precision of the calculation input points should be
- * normalized before passing them to this routine.
- static void intersection(const geom::Coordinate &p1,
- const geom::Coordinate &p2,
- const geom::Coordinate &q1,
- const geom::Coordinate &q2,
- geom::Coordinate &ret);
+ /** \brief
+ * Computes the (approximate) intersection point between two line
+ * segments using homogeneous coordinates.
+ * Note that this algorithm is
+ * not numerically stable; i.e. it can produce intersection points which
+ * lie outside the envelope of the line segments themselves. In order
+ * to increase the precision of the calculation input points should be
+ * normalized before passing them to this routine.
+ static void intersection(const geom::Coordinate& p1,
+ const geom::Coordinate& p2,
+ const geom::Coordinate& q1,
+ const geom::Coordinate& q2,
+ geom::Coordinate& ret);
- double x,y,w;
+ double x, y, w;
- HCoordinate();
+ HCoordinate();
- HCoordinate(double _x, double _y, double _w);
+ HCoordinate(double _x, double _y, double _w);
- HCoordinate(const geom::Coordinate& p);
+ HCoordinate(const geom::Coordinate& p);
- /** \brief
- * Constructs a homogeneous coordinate which is the intersection
- * of the lines define by the homogenous coordinates represented
- * by two {@link Coordinate}s.
- * @param p1
- * @param p2
- HCoordinate(const geom::Coordinate& p1, const geom::Coordinate& p2);
+ /** \brief
+ * Constructs a homogeneous coordinate which is the intersection
+ * of the lines define by the homogenous coordinates represented
+ * by two {@link Coordinate}s.
+ * @param p1
+ * @param p2
+ HCoordinate(const geom::Coordinate& p1, const geom::Coordinate& p2);
- HCoordinate(const geom::Coordinate& p1, const geom::Coordinate& p2,
- const geom::Coordinate& q1, const geom::Coordinate& q2);
+ HCoordinate(const geom::Coordinate& p1, const geom::Coordinate& p2,
+ const geom::Coordinate& q1, const geom::Coordinate& q2);
- HCoordinate(const HCoordinate &p1, const HCoordinate &p2);
+ HCoordinate(const HCoordinate& p1, const HCoordinate& p2);
- double getX() const;
+ double getX() const;
- double getY() const;
+ double getY() const;
- void getCoordinate(geom::Coordinate &ret) const;
+ void getCoordinate(geom::Coordinate& ret) const;
diff --git a/include/geos/algorithm/InteriorPointArea.h b/include/geos/algorithm/InteriorPointArea.h
index b5a01b0..3a1bfd5 100644
--- a/include/geos/algorithm/InteriorPointArea.h
+++ b/include/geos/algorithm/InteriorPointArea.h
@@ -26,12 +26,12 @@
namespace geos {
- namespace geom {
- class Geometry;
- class LineString;
- class GeometryCollection;
+namespace geom {
+class Geometry;
+class LineString;
+class GeometryCollection;
@@ -64,51 +64,51 @@ class GEOS_DLL InteriorPointArea {
private:
- bool foundInterior;
+ bool foundInterior;
- const geom::GeometryFactory *factory;
+ const geom::GeometryFactory* factory;
- geom::Coordinate interiorPoint;
+ geom::Coordinate interiorPoint;
- double maxWidth;
+ double maxWidth;
- void add(const geom::Geometry *geom);
+ void add(const geom::Geometry* geom);
- const geom::Geometry *widestGeometry(const geom::Geometry *geometry);
+ const geom::Geometry* widestGeometry(const geom::Geometry* geometry);
- const geom::Geometry *widestGeometry(const geom::GeometryCollection *gc);
+ const geom::Geometry* widestGeometry(const geom::GeometryCollection* gc);
- geom::LineString *horizontalBisector(const geom::Geometry *geometry);
+ geom::LineString* horizontalBisector(const geom::Geometry* geometry);
public:
- * Creates a new interior point finder
- * for an areal geometry.
- * @param g an areal geometry
- InteriorPointArea(const geom::Geometry *g);
+ * Creates a new interior point finder
+ * for an areal geometry.
+ * @param g an areal geometry
+ InteriorPointArea(const geom::Geometry* g);
- ~InteriorPointArea();
+ ~InteriorPointArea();
- * Gets the computed interior point.
- * @return the coordinate of an interior point
- bool getInteriorPoint(geom::Coordinate& ret) const;
+ * Gets the computed interior point.
+ * @return the coordinate of an interior point
+ bool getInteriorPoint(geom::Coordinate& ret) const;
private:
- /** \brief
- * Finds an interior point of a Polygon
- * @param geometry the geometry to analyze
- * @return the midpoint of the largest intersection between the geometry and
- * a line halfway down its envelope
- void addPolygon(const geom::Geometry *geometry);
+ /** \brief
+ * Finds an interior point of a Polygon
+ * @param geometry the geometry to analyze
+ * @return the midpoint of the largest intersection between the geometry and
+ * a line halfway down its envelope
+ void addPolygon(const geom::Geometry* geometry);
diff --git a/include/geos/algorithm/InteriorPointLine.h b/include/geos/algorithm/InteriorPointLine.h
index 3eb5156..ff43f64 100644
--- a/include/geos/algorithm/InteriorPointLine.h
+++ b/include/geos/algorithm/InteriorPointLine.h
@@ -25,10 +25,10 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
@@ -48,33 +48,33 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL InteriorPointLine {
public:
- InteriorPointLine(const geom::Geometry *g);
+ InteriorPointLine(const geom::Geometry* g);
- ~InteriorPointLine();
+ ~InteriorPointLine();
- //Coordinate* getInteriorPoint() const;
+ //Coordinate* getInteriorPoint() const;
private:
- bool hasInterior;
+ bool hasInterior;
- geom::Coordinate centroid;
+ geom::Coordinate centroid;
- double minDistance;
+ double minDistance;
- void addInterior(const geom::Geometry *geom);
+ void addInterior(const geom::Geometry* geom);
- void addInterior(const geom::CoordinateSequence *pts);
+ void addInterior(const geom::CoordinateSequence* pts);
- void addEndpoints(const geom::Geometry *geom);
+ void addEndpoints(const geom::Geometry* geom);
- void addEndpoints(const geom::CoordinateSequence *pts);
+ void addEndpoints(const geom::CoordinateSequence* pts);
- void add(const geom::Coordinate& point);
+ void add(const geom::Coordinate& point);
diff --git a/include/geos/algorithm/InteriorPointPoint.h b/include/geos/algorithm/InteriorPointPoint.h
index 043a179..1de7cf7 100644
--- a/include/geos/algorithm/InteriorPointPoint.h
+++ b/include/geos/algorithm/InteriorPointPoint.h
@@ -21,9 +21,9 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
namespace geos {
@@ -41,30 +41,30 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL InteriorPointPoint {
private:
- bool hasInterior;
+ bool hasInterior;
- * Tests the point(s) defined by a Geometry for the best inside point.
- * If a Geometry is not of dimension 0 it is not tested.
+ * Tests the point(s) defined by a Geometry for the best inside point.
+ * If a Geometry is not of dimension 0 it is not tested.
- void add(const geom::Coordinate *point);
+ void add(const geom::Coordinate* point);
public:
- InteriorPointPoint(const geom::Geometry *g);
+ InteriorPointPoint(const geom::Geometry* g);
- ~InteriorPointPoint() {}
+ ~InteriorPointPoint() {}
diff --git a/include/geos/algorithm/Length.h b/include/geos/algorithm/Length.h
index 4af0b77..4d1a13f 100644
--- a/include/geos/algorithm/Length.h
+++ b/include/geos/algorithm/Length.h
@@ -41,7 +41,7 @@ public:
* @param pts the points specifying the linestring
* @return the length of the linestring
- static double ofLine(const geom::CoordinateSequence *ring);
+ static double ofLine(const geom::CoordinateSequence* ring);
diff --git a/include/geos/algorithm/LineIntersector.h b/include/geos/algorithm/LineIntersector.h
index 293a1ef..8702459 100644
--- a/include/geos/algorithm/LineIntersector.h
+++ b/include/geos/algorithm/LineIntersector.h
@@ -27,9 +27,9 @@
namespace geos {
- namespace geom {
- class PrecisionModel;
+namespace geom {
+class PrecisionModel;
namespace geos {
@@ -49,312 +49,334 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL LineIntersector {
public:
- /// \brief
- /// Return a Z value being the interpolation of Z from p0 and p1 at
- /// the given point p
- static double interpolateZ(const geom::Coordinate &p, const geom::Coordinate &p0, const geom::Coordinate &p1);
- /// Computes the "edge distance" of an intersection point p in an edge.
- /// The edge distance is a metric of the point along the edge.
- /// The metric used is a robust and easy to compute metric function.
- /// It is <b>not</b> equivalent to the usual Euclidean metric.
- /// It relies on the fact that either the x or the y ordinates of the
- /// points in the edge are unique, depending on whether the edge is longer in
- /// the horizontal or vertical direction.
- /// NOTE: This function may produce incorrect distances
- /// for inputs where p is not precisely on p1-p2
- /// (E.g. p = (139,9) p1 = (139,10), p2 = (280,1) produces distanct
- /// 0.0, which is incorrect.
- /// My hypothesis is that the function is safe to use for points which are the
- /// result of <b>rounding</b> points which lie on the line,
- /// but not safe to use for <b>truncated</b> points.
- static double computeEdgeDistance(const geom::Coordinate& p, const geom::Coordinate& p0, const geom::Coordinate& p1);
- static double nonRobustComputeEdgeDistance(const geom::Coordinate& p,const geom::Coordinate& p1,const geom::Coordinate& p2);
- LineIntersector(const geom::PrecisionModel* initialPrecisionModel=nullptr)
- precisionModel(initialPrecisionModel),
- result(0),
- isProperVar(false)
- ~LineIntersector() {}
- /** \brief
- * Tests whether either intersection point is an interior point of
- * one of the input segments.
- * @return <code>true</code> if either intersection point is in
- * the interior of one of the input segments
- bool isInteriorIntersection();
- /** \brief
- * of the specified input segment.
- * the interior of the input segment
- bool isInteriorIntersection(int inputLineIndex);
- /// Force computed intersection to be rounded to a given precision model.
- /// No getter is provided, because the precision model is not required
- /// to be specified.
- /// @param precisionModel the PrecisionModel to use for rounding
- void setPrecisionModel(const geom::PrecisionModel *newPM) {
- precisionModel=newPM;
- /// Compute the intersection of a point p and the line p1-p2.
- /// This function computes the boolean value of the hasIntersection test.
- /// The actual value of the intersection (if there is one)
- /// is equal to the value of <code>p</code>.
- void computeIntersection(const geom::Coordinate& p, const geom::Coordinate& p1, const geom::Coordinate& p2);
- /// Same as above but doen's compute intersection point. Faster.
- static bool hasIntersection(const geom::Coordinate& p,const geom::Coordinate& p1,const geom::Coordinate& p2);
- // These are deprecated, due to ambiguous naming
- enum {
- DONT_INTERSECT=0,
- DO_INTERSECT=1,
- COLLINEAR=2
- enum {
- /// Indicates that line segments do not intersect
- NO_INTERSECTION=0,
- /// Indicates that line segments intersect in a single point
- POINT_INTERSECTION=1,
- /// Indicates that line segments intersect in a line segment
- COLLINEAR_INTERSECTION=2
- /// Computes the intersection of the lines p1-p2 and p3-p4
- void computeIntersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
- const geom::Coordinate& p3, const geom::Coordinate& p4);
- std::string toString() const;
- * Tests whether the input geometries intersect.
- * @return true if the input geometries intersect
- bool hasIntersection() const { return result!=NO_INTERSECTION; }
- /// Returns the number of intersection points found.
- /// This will be either 0, 1 or 2.
- size_t getIntersectionNum() const { return result; }
- /// Returns the intIndex'th intersection point
- /// @param intIndex is 0 or 1
- /// @return the intIndex'th intersection point
- const geom::Coordinate& getIntersection(size_t intIndex) const {
- return intPt[intIndex];
- /// Returns false if both numbers are zero.
- /// @return true if both numbers are positive or if both numbers are negative.
- static bool isSameSignAndNonZero(double a,double b);
- /** \brief
- * Test whether a point is a intersection point of two line segments.
- * Note that if the intersection is a line segment, this method only tests for
- * equality with the endpoints of the intersection segment.
- * It does <b>not</b> return true if
- * the input point is internal to the intersection segment.
- * @return true if the input point is one of the intersection points.
- bool isIntersection(const geom::Coordinate& pt) const;
- /** \brief
- * Tests whether an intersection is proper.
- * The intersection between two line segments is considered proper if
- * they intersect in a single point in the interior of both segments
- * (e.g. the intersection is a single point and is not equal to any of the
- * endpoints).
- * The intersection between a point and a line segment is considered proper
- * if the point lies in the interior of the segment (e.g. is not equal to
- * either of the endpoints).
- * @return true if the intersection is proper
- bool isProper() const {
- return hasIntersection()&&isProperVar;
- /** \brief
- * Computes the intIndex'th intersection point in the direction of
- * a specified input line segment
- * @param segmentIndex is 0 or 1
- * @param intIndex is 0 or 1
- * @return the intIndex'th intersection point in the direction of the
- * specified input line segment
- const geom::Coordinate& getIntersectionAlongSegment(int segmentIndex,int intIndex);
- /** \brief
- * Computes the index of the intIndex'th intersection point in the direction of
- * @return the index of the intersection point along the segment (0 or 1)
- int getIndexAlongSegment(int segmentIndex,int intIndex);
- /** \brief
- * Computes the "edge distance" of an intersection point along the specified
- * input line segment.
- * @return the edge distance of the intersection point
- double getEdgeDistance(size_t geomIndex, size_t intIndex) const;
+ /// \brief
+ /// Return a Z value being the interpolation of Z from p0 and p1 at
+ /// the given point p
+ static double interpolateZ(const geom::Coordinate& p, const geom::Coordinate& p0, const geom::Coordinate& p1);
+ /// Computes the "edge distance" of an intersection point p in an edge.
+ /// The edge distance is a metric of the point along the edge.
+ /// The metric used is a robust and easy to compute metric function.
+ /// It is <b>not</b> equivalent to the usual Euclidean metric.
+ /// It relies on the fact that either the x or the y ordinates of the
+ /// points in the edge are unique, depending on whether the edge is longer in
+ /// the horizontal or vertical direction.
+ /// NOTE: This function may produce incorrect distances
+ /// for inputs where p is not precisely on p1-p2
+ /// (E.g. p = (139,9) p1 = (139,10), p2 = (280,1) produces distanct
+ /// 0.0, which is incorrect.
+ /// My hypothesis is that the function is safe to use for points which are the
+ /// result of <b>rounding</b> points which lie on the line,
+ /// but not safe to use for <b>truncated</b> points.
+ static double computeEdgeDistance(const geom::Coordinate& p, const geom::Coordinate& p0, const geom::Coordinate& p1);
+ static double nonRobustComputeEdgeDistance(const geom::Coordinate& p, const geom::Coordinate& p1,
+ LineIntersector(const geom::PrecisionModel* initialPrecisionModel = nullptr)
+ precisionModel(initialPrecisionModel),
+ result(0),
+ isProperVar(false)
+ ~LineIntersector() {}
+ /** \brief
+ * Tests whether either intersection point is an interior point of
+ * one of the input segments.
+ * @return <code>true</code> if either intersection point is in
+ * the interior of one of the input segments
+ bool isInteriorIntersection();
+ /** \brief
+ * of the specified input segment.
+ * the interior of the input segment
+ bool isInteriorIntersection(int inputLineIndex);
+ /// Force computed intersection to be rounded to a given precision model.
+ /// No getter is provided, because the precision model is not required
+ /// to be specified.
+ /// @param precisionModel the PrecisionModel to use for rounding
+ void
+ setPrecisionModel(const geom::PrecisionModel* newPM)
+ precisionModel = newPM;
+ /// Compute the intersection of a point p and the line p1-p2.
+ /// This function computes the boolean value of the hasIntersection test.
+ /// The actual value of the intersection (if there is one)
+ /// is equal to the value of <code>p</code>.
+ void computeIntersection(const geom::Coordinate& p, const geom::Coordinate& p1, const geom::Coordinate& p2);
+ /// Same as above but doen's compute intersection point. Faster.
+ static bool hasIntersection(const geom::Coordinate& p, const geom::Coordinate& p1, const geom::Coordinate& p2);
+ // These are deprecated, due to ambiguous naming
+ enum {
+ DONT_INTERSECT = 0,
+ DO_INTERSECT = 1,
+ COLLINEAR = 2
+ enum {
+ /// Indicates that line segments do not intersect
+ NO_INTERSECTION = 0,
+ /// Indicates that line segments intersect in a single point
+ POINT_INTERSECTION = 1,
+ /// Indicates that line segments intersect in a line segment
+ COLLINEAR_INTERSECTION = 2
+ /// Computes the intersection of the lines p1-p2 and p3-p4
+ void computeIntersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
+ const geom::Coordinate& p3, const geom::Coordinate& p4);
+ std::string toString() const;
+ * Tests whether the input geometries intersect.
+ * @return true if the input geometries intersect
+ bool
+ hasIntersection() const
+ return result != NO_INTERSECTION;
+ /// Returns the number of intersection points found.
+ /// This will be either 0, 1 or 2.
+ size_t
+ getIntersectionNum() const
+ return result;
+ /// Returns the intIndex'th intersection point
+ /// @param intIndex is 0 or 1
+ /// @return the intIndex'th intersection point
+ getIntersection(size_t intIndex) const
+ return intPt[intIndex];
+ /// Returns false if both numbers are zero.
+ /// @return true if both numbers are positive or if both numbers are negative.
+ static bool isSameSignAndNonZero(double a, double b);
+ /** \brief
+ * Test whether a point is a intersection point of two line segments.
+ * Note that if the intersection is a line segment, this method only tests for
+ * equality with the endpoints of the intersection segment.
+ * It does <b>not</b> return true if
+ * the input point is internal to the intersection segment.
+ * @return true if the input point is one of the intersection points.
+ bool isIntersection(const geom::Coordinate& pt) const;
+ /** \brief
+ * Tests whether an intersection is proper.
+ * The intersection between two line segments is considered proper if
+ * they intersect in a single point in the interior of both segments
+ * (e.g. the intersection is a single point and is not equal to any of the
+ * endpoints).
+ * The intersection between a point and a line segment is considered proper
+ * if the point lies in the interior of the segment (e.g. is not equal to
+ * either of the endpoints).
+ * @return true if the intersection is proper
+ bool
+ isProper() const
+ return hasIntersection() && isProperVar;
+ /** \brief
+ * Computes the intIndex'th intersection point in the direction of
+ * a specified input line segment
+ * @param segmentIndex is 0 or 1
+ * @param intIndex is 0 or 1
+ * @return the intIndex'th intersection point in the direction of the
+ * specified input line segment
+ const geom::Coordinate& getIntersectionAlongSegment(int segmentIndex, int intIndex);
+ /** \brief
+ * Computes the index of the intIndex'th intersection point in the direction of
+ * @return the index of the intersection point along the segment (0 or 1)
+ int getIndexAlongSegment(int segmentIndex, int intIndex);
+ /** \brief
+ * Computes the "edge distance" of an intersection point along the specified
+ * input line segment.
+ * @return the edge distance of the intersection point
+ double getEdgeDistance(size_t geomIndex, size_t intIndex) const;
private:
- void intersectionWithNormalization(const geom::Coordinate& p1,
- const geom::Coordinate& p2,
- const geom::Coordinate& q2,
- geom::Coordinate &ret) const;
- * If makePrecise is true, computed intersection coordinates
- * will be made precise using Coordinate#makePrecise
- const geom::PrecisionModel *precisionModel;
- size_t result;
- const geom::Coordinate *inputLines[2][2];
- * We store real Coordinates here because
- * we must compute the Z of intersection point.
- geom::Coordinate intPt[2];
- * The indexes of the endpoints of the intersection lines, in order along
- * the corresponding line
- int intLineIndex[2][2];
- bool isProperVar;
- //Coordinate &pa;
- //Coordinate &pb;
- bool isCollinear() const { return result==COLLINEAR_INTERSECTION; }
- int computeIntersect(const geom::Coordinate& p1,const geom::Coordinate& p2,const geom::Coordinate& q1,const geom::Coordinate& q2);
- bool isEndPoint() const {
- return hasIntersection()&&!isProperVar;
- void computeIntLineIndex();
- void computeIntLineIndex(int segmentIndex);
- int computeCollinearIntersection(const geom::Coordinate& p1,
- const geom::Coordinate& p2, const geom::Coordinate& q1,
- const geom::Coordinate& q2);
- /** \brief
- * This method computes the actual value of the intersection point.
- * To obtain the maximum precision from the intersection calculation,
- * the coordinates are normalized by subtracting the minimum
- * ordinate values (in absolute value). This has the effect of
- * removing common significant digits from the calculation to
- * maintain more bits of precision.
- void intersection(const geom::Coordinate& p1,
- double smallestInAbsValue(double x1, double x2,
- double x3, double x4) const;
- * Test whether a point lies in the envelopes of both input segments.
- * A correctly computed intersection point should return true
- * for this test.
- * Since this test is for debugging purposes only, no attempt is
- * made to optimize the envelope test.
- * @return true if the input point lies within both
- * input segment envelopes
- bool isInSegmentEnvelopes(const geom::Coordinate& intPt) const;
- /** \brief
- * Normalize the supplied coordinates to
- * so that the midpoint of their intersection envelope
- * lies at the origin.
- * @param n00
- * @param n01
- * @param n10
- * @param n11
- * @param normPt
- void normalizeToEnvCentre(geom::Coordinate &n00, geom::Coordinate &n01,
- geom::Coordinate &n10, geom::Coordinate &n11,
- geom::Coordinate &normPt) const;
- * Computes a segment intersection using homogeneous coordinates.
- * Round-off error can cause the raw computation to fail,
- * (usually due to the segments being approximately parallel).
- * If this happens, a reasonable approximation is computed instead.
- * @param p1 a segment endpoint
- * @param p2 a segment endpoint
- * @param q1 a segment endpoint
- * @param q2 a segment endpoint
- * @param intPt the computed intersection point is stored there
- void safeHCoordinateIntersection(const geom::Coordinate& p1,
- geom::Coordinate& intPt) const;
+ void intersectionWithNormalization(const geom::Coordinate& p1,
+ geom::Coordinate& ret) const;
+ * If makePrecise is true, computed intersection coordinates
+ * will be made precise using Coordinate#makePrecise
+ const geom::PrecisionModel* precisionModel;
+ size_t result;
+ const geom::Coordinate* inputLines[2][2];
+ * We store real Coordinates here because
+ * we must compute the Z of intersection point.
+ geom::Coordinate intPt[2];
+ * The indexes of the endpoints of the intersection lines, in order along
+ * the corresponding line
+ int intLineIndex[2][2];
+ bool isProperVar;
+ //Coordinate &pa;
+ //Coordinate &pb;
+ bool
+ isCollinear() const
+ return result == COLLINEAR_INTERSECTION;
+ int computeIntersect(const geom::Coordinate& p1, const geom::Coordinate& p2, const geom::Coordinate& q1,
+ const geom::Coordinate& q2);
+ bool
+ isEndPoint() const
+ return hasIntersection() && !isProperVar;
+ void computeIntLineIndex();
+ void computeIntLineIndex(int segmentIndex);
+ int computeCollinearIntersection(const geom::Coordinate& p1,
+ const geom::Coordinate& p2, const geom::Coordinate& q1,
+ /** \brief
+ * This method computes the actual value of the intersection point.
+ * To obtain the maximum precision from the intersection calculation,
+ * the coordinates are normalized by subtracting the minimum
+ * ordinate values (in absolute value). This has the effect of
+ * removing common significant digits from the calculation to
+ * maintain more bits of precision.
+ void intersection(const geom::Coordinate& p1,
+ double smallestInAbsValue(double x1, double x2,
+ double x3, double x4) const;
+ * Test whether a point lies in the envelopes of both input segments.
+ * A correctly computed intersection point should return true
+ * for this test.
+ * Since this test is for debugging purposes only, no attempt is
+ * made to optimize the envelope test.
+ * @return true if the input point lies within both
+ * input segment envelopes
+ bool isInSegmentEnvelopes(const geom::Coordinate& intPt) const;
+ /** \brief
+ * Normalize the supplied coordinates to
+ * so that the midpoint of their intersection envelope
+ * lies at the origin.
+ * @param n00
+ * @param n01
+ * @param n10
+ * @param n11
+ * @param normPt
+ void normalizeToEnvCentre(geom::Coordinate& n00, geom::Coordinate& n01,
+ geom::Coordinate& n10, geom::Coordinate& n11,
+ geom::Coordinate& normPt) const;
+ * Computes a segment intersection using homogeneous coordinates.
+ * Round-off error can cause the raw computation to fail,
+ * (usually due to the segments being approximately parallel).
+ * If this happens, a reasonable approximation is computed instead.
+ * @param p1 a segment endpoint
+ * @param p2 a segment endpoint
+ * @param q1 a segment endpoint
+ * @param q2 a segment endpoint
+ * @param intPt the computed intersection point is stored there
+ void safeHCoordinateIntersection(const geom::Coordinate& p1,
+ geom::Coordinate& intPt) const;
diff --git a/include/geos/algorithm/MinimumBoundingCircle.h b/include/geos/algorithm/MinimumBoundingCircle.h
index 6ba76d2..cc99891 100644
--- a/include/geos/algorithm/MinimumBoundingCircle.h
+++ b/include/geos/algorithm/MinimumBoundingCircle.h
@@ -44,7 +44,7 @@ class GEOS_DLL MinimumBoundingCircle {
private:
// member variables
- const geom::Geometry *input;
+ const geom::Geometry* input;
std::vector<geom::Coordinate> extremalPts;
geom::Coordinate centre;
double radius;
@@ -55,12 +55,12 @@ private:
geom::Coordinate lowestPoint(std::vector<geom::Coordinate>& pts);
geom::Coordinate pointWitMinAngleWithX(std::vector<geom::Coordinate>& pts, geom::Coordinate& P);
geom::Coordinate pointWithMinAngleWithSegment(std::vector<geom::Coordinate>& pts,
- geom::Coordinate& P, geom::Coordinate& Q);
+ geom::Coordinate& P, geom::Coordinate& Q);
public:
- MinimumBoundingCircle(const geom::Geometry *geom):
+ MinimumBoundingCircle(const geom::Geometry* geom):
input(nullptr),
radius(0.0)
@@ -68,7 +68,7 @@ public:
centre.setNull();
- ~MinimumBoundingCircle() {};
+ ~MinimumBoundingCircle() {};
* Gets a geometry which represents the Minimum Bounding Circle.
diff --git a/include/geos/algorithm/MinimumDiameter.h b/include/geos/algorithm/MinimumDiameter.h
index d8d38b7..92141ab 100644
--- a/include/geos/algorithm/MinimumDiameter.h
+++ b/include/geos/algorithm/MinimumDiameter.h
@@ -24,13 +24,13 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Geometry;
- class LineSegment;
- class LineString;
- class Coordinate;
+namespace geom {
+class Geometry;
+class LineSegment;
+class LineString;
+class Coordinate;
@@ -64,112 +64,112 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL MinimumDiameter {
private:
- const geom::Geometry* inputGeom;
- bool isConvex;
+ const geom::Geometry* inputGeom;
+ bool isConvex;
- geom::CoordinateSequence* convexHullPts;
+ geom::CoordinateSequence* convexHullPts;
- geom::LineSegment* minBaseSeg;
- geom::Coordinate* minWidthPt;
- int minPtIndex;
- double minWidth;
- void computeMinimumDiameter();
- void computeWidthConvex(const geom::Geometry* geom);
+ geom::LineSegment* minBaseSeg;
+ geom::Coordinate* minWidthPt;
+ int minPtIndex;
+ double minWidth;
+ void computeMinimumDiameter();
+ void computeWidthConvex(const geom::Geometry* geom);
- * Compute the width information for a ring of {@link geom::Coordinate}s.
- * Leaves the width information in the instance variables.
- * @param pts
- * @return
- void computeConvexRingMinDiameter(const geom::CoordinateSequence *pts);
+ * Compute the width information for a ring of {@link geom::Coordinate}s.
+ * Leaves the width information in the instance variables.
+ * @param pts
+ * @return
+ void computeConvexRingMinDiameter(const geom::CoordinateSequence* pts);
- unsigned int findMaxPerpDistance(const geom::CoordinateSequence* pts,
- geom::LineSegment* seg, unsigned int startIndex);
+ unsigned int findMaxPerpDistance(const geom::CoordinateSequence* pts,
+ geom::LineSegment* seg, unsigned int startIndex);
- static unsigned int getNextIndex(const geom::CoordinateSequence* pts,
- unsigned int index);
+ static unsigned int getNextIndex(const geom::CoordinateSequence* pts,
+ unsigned int index);
- static double computeC(double a, double b, const geom::Coordinate &p);
+ static double computeC(double a, double b, const geom::Coordinate& p);
- static geom::LineSegment computeSegmentForLine(double a, double b, double c);
+ static geom::LineSegment computeSegmentForLine(double a, double b, double c);
public:
- ~MinimumDiameter();
- /** \brief
- * Compute a minimum diameter for a giver {@link Geometry}.
- * @param geom a Geometry
- MinimumDiameter(const geom::Geometry* newInputGeom);
- /** \brief
- * Compute a minimum diameter for a given Geometry,
- * with a hint if the Geometry is convex
- * (e.g. a convex Polygon or LinearRing,
- * or a two-point LineString, or a Point).
- * @param geom a Geometry which is convex
- * @param isConvex <code>true</code> if the input geometry is convex
- MinimumDiameter(const geom::Geometry* newInputGeom,
- const bool newIsConvex);
- /** \brief
- * Gets the length of the minimum diameter of the input Geometry
- * @return the length of the minimum diameter
- double getLength();
- /** \brief
- * Gets the {@link geom::Coordinate} forming one end of the minimum diameter
- * @return a coordinate forming one end of the minimum diameter
- geom::Coordinate* getWidthCoordinate();
- /** \brief
- * Gets the segment forming the base of the minimum diameter
- * @return the segment forming the base of the minimum diameter
- geom::LineString* getSupportingSegment();
- /** \brief
- * Gets a LineString which is a minimum diameter
- * @return a LineString which is a minimum diameter
- geom::LineString* getDiameter();
- * Gets the minimum rectangular Polygon which encloses the input geometry. The rectangle has width
- * equal to the minimum diameter, and a longer length. If the convex hill of the input is degenerate
- * (a line or point) a LineString or Point is returned.
- * The minimum rectangle can be used as an extremely generalized representation for the given
- * geometry.
- * @return the minimum rectangle enclosing the input (or a line or point if degenerate)
- geom::Geometry* getMinimumRectangle();
- * Gets the minimum rectangle enclosing a geometry.
- * @return the minimum rectangle enclosing the geometry
- static geom::Geometry* getMinimumRectangle(geom::Geometry* geom);
- * Gets the length of the minimum diameter enclosing a geometry
- * @return the length of the minimum diameter of the geometry
- static geom::Geometry* getMinimumDiameter(geom::Geometry* geom);
+ ~MinimumDiameter();
+ /** \brief
+ * Compute a minimum diameter for a giver {@link Geometry}.
+ * @param geom a Geometry
+ MinimumDiameter(const geom::Geometry* newInputGeom);
+ /** \brief
+ * Compute a minimum diameter for a given Geometry,
+ * with a hint if the Geometry is convex
+ * (e.g. a convex Polygon or LinearRing,
+ * or a two-point LineString, or a Point).
+ * @param geom a Geometry which is convex
+ * @param isConvex <code>true</code> if the input geometry is convex
+ MinimumDiameter(const geom::Geometry* newInputGeom,
+ const bool newIsConvex);
+ /** \brief
+ * Gets the length of the minimum diameter of the input Geometry
+ * @return the length of the minimum diameter
+ double getLength();
+ /** \brief
+ * Gets the {@link geom::Coordinate} forming one end of the minimum diameter
+ * @return a coordinate forming one end of the minimum diameter
+ geom::Coordinate* getWidthCoordinate();
+ /** \brief
+ * Gets the segment forming the base of the minimum diameter
+ * @return the segment forming the base of the minimum diameter
+ geom::LineString* getSupportingSegment();
+ /** \brief
+ * Gets a LineString which is a minimum diameter
+ * @return a LineString which is a minimum diameter
+ geom::LineString* getDiameter();
+ * Gets the minimum rectangular Polygon which encloses the input geometry. The rectangle has width
+ * equal to the minimum diameter, and a longer length. If the convex hill of the input is degenerate
+ * (a line or point) a LineString or Point is returned.
+ * The minimum rectangle can be used as an extremely generalized representation for the given
+ * geometry.
+ * @return the minimum rectangle enclosing the input (or a line or point if degenerate)
+ geom::Geometry* getMinimumRectangle();
+ * Gets the minimum rectangle enclosing a geometry.
+ * @return the minimum rectangle enclosing the geometry
+ static geom::Geometry* getMinimumRectangle(geom::Geometry* geom);
+ * Gets the length of the minimum diameter enclosing a geometry
+ * @return the length of the minimum diameter of the geometry
+ static geom::Geometry* getMinimumDiameter(geom::Geometry* geom);
diff --git a/include/geos/algorithm/NotRepresentableException.h b/include/geos/algorithm/NotRepresentableException.h
index f8a0fa7..6e44fba 100644
--- a/include/geos/algorithm/NotRepresentableException.h
+++ b/include/geos/algorithm/NotRepresentableException.h
@@ -34,9 +34,9 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL NotRepresentableException: public util::GEOSException {
public:
- NotRepresentableException();
- NotRepresentableException(std::string msg);
- ~NotRepresentableException() throw() override {}
+ NotRepresentableException();
+ NotRepresentableException(std::string msg);
+ ~NotRepresentableException() throw() override {}
diff --git a/include/geos/algorithm/Orientation.h b/include/geos/algorithm/Orientation.h
index 1dea230..db9d6e7 100644
--- a/include/geos/algorithm/Orientation.h
+++ b/include/geos/algorithm/Orientation.h
@@ -45,12 +45,12 @@ public:
/* A value that indicates an orientation or turn */
enum {
- CLOCKWISE=-1,
- COLLINEAR=0,
- COUNTERCLOCKWISE=1,
- RIGHT=-1,
- LEFT=1,
- STRAIGHT=0
+ CLOCKWISE = -1,
+ COLLINEAR = 0,
+ COUNTERCLOCKWISE = 1,
+ RIGHT = -1,
+ LEFT = 1,
+ STRAIGHT = 0
@@ -64,8 +64,8 @@ public:
* ( {@link #Orientation::COUNTERCLOCKWISE},
* {@link #Orientation::CLOCKWISE}, or {@link #Orientation::STRAIGHT} )
- static int index(const geom::Coordinate &p1, const geom::Coordinate &p2,
- const geom::Coordinate &q);
+ static int index(const geom::Coordinate& p1, const geom::Coordinate& p2,
+ const geom::Coordinate& q);
* Computes whether a ring defined by an array of {@link Coordinate}s is
diff --git a/include/geos/algorithm/PointInRing.h b/include/geos/algorithm/PointInRing.h
index 1541636..6561bc3 100644
--- a/include/geos/algorithm/PointInRing.h
+++ b/include/geos/algorithm/PointInRing.h
@@ -20,18 +20,19 @@
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
-class GEOS_DLL PointInRing{
+class GEOS_DLL PointInRing {
public:
- virtual ~PointInRing(){}
- virtual bool isInside(const geom::Coordinate& pt)=0;
+ virtual
+ ~PointInRing() {}
+ virtual bool isInside(const geom::Coordinate& pt) = 0;
diff --git a/include/geos/algorithm/PointLocation.h b/include/geos/algorithm/PointLocation.h
index 7761d4c..0732d29 100644
--- a/include/geos/algorithm/PointLocation.h
+++ b/include/geos/algorithm/PointLocation.h
@@ -56,7 +56,7 @@ public:
* @return true if the point is a vertex of the line or lies in the interior
* of a line segment in the line
- static bool isOnLine(const geom::Coordinate &p, const geom::CoordinateSequence *line);
+ static bool isOnLine(const geom::Coordinate& p, const geom::CoordinateSequence* line);
* Tests whether a point lies inside or on a ring. The ring may be oriented in
@@ -75,8 +75,8 @@ public:
* @see locatePointInRing
- static bool isInRing(const geom::Coordinate &p, const std::vector<const geom::Coordinate*> &ring);
- static bool isInRing(const geom::Coordinate &p, const geom::CoordinateSequence *ring);
+ static bool isInRing(const geom::Coordinate& p, const std::vector<const geom::Coordinate*>& ring);
+ static bool isInRing(const geom::Coordinate& p, const geom::CoordinateSequence* ring);
* Determines whether a point lies in the interior, on the boundary, or in the
@@ -92,8 +92,8 @@ public:
* first point identical to last point)
* @return the {@link Location} of p relative to the ring
- static int locateInRing(const geom::Coordinate &p, const std::vector<const geom::Coordinate*> &ring);
- static int locateInRing(const geom::Coordinate &p, const geom::CoordinateSequence &ring);
+ static int locateInRing(const geom::Coordinate& p, const std::vector<const geom::Coordinate*>& ring);
+ static int locateInRing(const geom::Coordinate& p, const geom::CoordinateSequence& ring);
diff --git a/include/geos/algorithm/PointLocator.h b/include/geos/algorithm/PointLocator.h
index 9bbe0a4..644b6dd 100644
--- a/include/geos/algorithm/PointLocator.h
+++ b/include/geos/algorithm/PointLocator.h
@@ -25,14 +25,14 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Geometry;
- class LinearRing;
- class LineString;
- class Polygon;
- class Point;
+namespace geom {
+class Coordinate;
+class Geometry;
+class LinearRing;
+class LineString;
+class Polygon;
+class Point;
namespace geos {
@@ -56,48 +56,50 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL PointLocator {
public:
- PointLocator() {}
- ~PointLocator() {}
- * Computes the topological relationship (Location) of a single point
- * to a Geometry. It handles both single-element and multi-element Geometries.
- * The algorithm for multi-part Geometriestakes into account the SFS
- * Boundary Determination rule.
- * @return the Location of the point relative to the input Geometry
- int locate(const geom::Coordinate& p, const geom::Geometry *geom);
- * Convenience method to test a point for intersection with
- * a Geometry
- * @param p the coordinate to test
- * @param geom the Geometry to test
- * @return <code>true</code> if the point is in the interior or boundary of the Geometry
- bool intersects(const geom::Coordinate& p, const geom::Geometry *geom) {
- return locate(p, geom) != geom::Location::EXTERIOR;
+ PointLocator() {}
+ ~PointLocator() {}
+ * Computes the topological relationship (Location) of a single point
+ * to a Geometry. It handles both single-element and multi-element Geometries.
+ * The algorithm for multi-part Geometriestakes into account the SFS
+ * Boundary Determination rule.
+ * @return the Location of the point relative to the input Geometry
+ int locate(const geom::Coordinate& p, const geom::Geometry* geom);
+ * Convenience method to test a point for intersection with
+ * a Geometry
+ * @param p the coordinate to test
+ * @param geom the Geometry to test
+ * @return <code>true</code> if the point is in the interior or boundary of the Geometry
+ bool
+ intersects(const geom::Coordinate& p, const geom::Geometry* geom)
+ return locate(p, geom) != geom::Location::EXTERIOR;
private:
- bool isIn; // true if the point lies in or on any Geometry element
+ bool isIn; // true if the point lies in or on any Geometry element
- int numBoundaries; // the number of sub-elements whose boundaries the point lies in
+ int numBoundaries; // the number of sub-elements whose boundaries the point lies in
- void computeLocation(const geom::Coordinate& p, const geom::Geometry *geom);
+ void computeLocation(const geom::Coordinate& p, const geom::Geometry* geom);
- void updateLocationInfo(int loc);
+ void updateLocationInfo(int loc);
- int locate(const geom::Coordinate& p, const geom::Point *pt);
+ int locate(const geom::Coordinate& p, const geom::Point* pt);
- int locate(const geom::Coordinate& p, const geom::LineString *l);
+ int locate(const geom::Coordinate& p, const geom::LineString* l);
- int locateInPolygonRing(const geom::Coordinate& p, const geom::LinearRing *ring);
+ int locateInPolygonRing(const geom::Coordinate& p, const geom::LinearRing* ring);
- int locate(const geom::Coordinate& p, const geom::Polygon *poly);
+ int locate(const geom::Coordinate& p, const geom::Polygon* poly);
diff --git a/include/geos/algorithm/RayCrossingCounter.h b/include/geos/algorithm/RayCrossingCounter.h
index 9891f37..fe5dc88 100644
--- a/include/geos/algorithm/RayCrossingCounter.h
+++ b/include/geos/algorithm/RayCrossingCounter.h
@@ -26,10 +26,10 @@
// forward declarations
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
@@ -63,14 +63,13 @@ namespace algorithm {
* @author Martin Davis
-class GEOS_DLL RayCrossingCounter
+class GEOS_DLL RayCrossingCounter {
private:
- const geom::Coordinate& point;
+ const geom::Coordinate& point;
- int crossingCount;
+ int crossingCount;
- // true if the test point lies on an input segment
+ // true if the test point lies on an input segment
bool isPointOnSegment;
// Declare type as noncopyable
@@ -78,89 +77,90 @@ private:
RayCrossingCounter& operator=(const RayCrossingCounter& rhs) = delete;
public:
- * Determines the {@link Location} of a point in a ring.
- * This method is an exemplar of how to use this class.
- * @param p the point to test
- * @param ring an array of Coordinates forming a ring
- * @return the location of the point in the ring
- static int locatePointInRing(const geom::Coordinate& p,
- const geom::CoordinateSequence& ring);
- /// Semantically equal to the above, just different args encoding
- const std::vector<const geom::Coordinate*>& ring);
- /** \brief
- * Returns the index of the direction of the point <code>q</code>
- * relative to a vector specified by <code>p1-p2</code>.
- * @param p1 the origin point of the vector
- * @param p2 the final point of the vector
- * @param q the point to compute the direction to
- * @return 1 if q is counter-clockwise (left) from p1-p2
- * @return -1 if q is clockwise (right) from p1-p2
- * @return 0 if q is collinear with p1-p2
- static int orientationIndex(const geom::Coordinate& p1,
- const geom::Coordinate& q);
- RayCrossingCounter(const geom::Coordinate& p_point)
- : point( p_point),
- crossingCount( 0),
- isPointOnSegment( false)
- * Counts a segment
- * @param p1 an endpoint of the segment
- * @param p2 another endpoint of the segment
- void countSegment(const geom::Coordinate& p1,
- const geom::Coordinate& p2);
- * Reports whether the point lies exactly on one of the supplied segments.
- * This method may be called at any time as segments are processed.
- * If the result of this method is <tt>true</tt>,
- * no further segments need be supplied, since the result
- * will never change again.
- * @return true if the point lies exactly on a segment
- bool isOnSegment()
- return isPointOnSegment;
- * Gets the {@link Location} of the point relative to
- * the ring, polygon
- * or multipolygon from which the processed segments were provided.
- * <p>
- * This method only determines the correct location
- * if <b>all</b> relevant segments must have been processed.
- int getLocation();
- * Tests whether the point lies in or on
- * <p>
- * @return true if the point lies in or on the supplied polygon
- bool isPointInPolygon();
+ * Determines the {@link Location} of a point in a ring.
+ * This method is an exemplar of how to use this class.
+ * @param p the point to test
+ * @param ring an array of Coordinates forming a ring
+ * @return the location of the point in the ring
+ static int locatePointInRing(const geom::Coordinate& p,
+ const geom::CoordinateSequence& ring);
+ /// Semantically equal to the above, just different args encoding
+ const std::vector<const geom::Coordinate*>& ring);
+ /** \brief
+ * Returns the index of the direction of the point <code>q</code>
+ * relative to a vector specified by <code>p1-p2</code>.
+ * @param p1 the origin point of the vector
+ * @param p2 the final point of the vector
+ * @param q the point to compute the direction to
+ * @return 1 if q is counter-clockwise (left) from p1-p2
+ * @return -1 if q is clockwise (right) from p1-p2
+ * @return 0 if q is collinear with p1-p2
+ static int orientationIndex(const geom::Coordinate& p1,
+ RayCrossingCounter(const geom::Coordinate& p_point)
+ : point(p_point),
+ crossingCount(0),
+ isPointOnSegment(false)
+ * Counts a segment
+ * @param p1 an endpoint of the segment
+ * @param p2 another endpoint of the segment
+ void countSegment(const geom::Coordinate& p1,
+ const geom::Coordinate& p2);
+ * Reports whether the point lies exactly on one of the supplied segments.
+ * This method may be called at any time as segments are processed.
+ * If the result of this method is <tt>true</tt>,
+ * no further segments need be supplied, since the result
+ * will never change again.
+ * @return true if the point lies exactly on a segment
+ bool
+ isOnSegment()
+ return isPointOnSegment;
+ * Gets the {@link Location} of the point relative to
+ * the ring, polygon
+ * or multipolygon from which the processed segments were provided.
+ * <p>
+ * This method only determines the correct location
+ * if <b>all</b> relevant segments must have been processed.
+ int getLocation();
+ * Tests whether the point lies in or on
+ * <p>
+ * @return true if the point lies in or on the supplied polygon
+ bool isPointInPolygon();
diff --git a/include/geos/algorithm/RayCrossingCounterDD.h b/include/geos/algorithm/RayCrossingCounterDD.h
index 1bb431b..bc2ddf0 100644
--- a/include/geos/algorithm/RayCrossingCounterDD.h
+++ b/include/geos/algorithm/RayCrossingCounterDD.h
@@ -130,7 +130,8 @@ public:
+ bool
+ isOnSegment()
diff --git a/include/geos/algorithm/RobustDeterminant.h b/include/geos/algorithm/RobustDeterminant.h
index a873e01..b481a8d 100644
--- a/include/geos/algorithm/RobustDeterminant.h
+++ b/include/geos/algorithm/RobustDeterminant.h
@@ -51,15 +51,15 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL RobustDeterminant {
public:
- /** \brief
- * Computes the sign of the determinant of the 2x2 matrix
- * with the given entries, in a robust way.
- * @return -1 if the determinant is negative,
- * @return 1 if the determinant is positive,
- * @return 0 if the determinant is 0.
- static int signOfDet2x2(double x1,double y1,double x2,double y2);
+ /** \brief
+ * Computes the sign of the determinant of the 2x2 matrix
+ * with the given entries, in a robust way.
+ * @return -1 if the determinant is negative,
+ * @return 1 if the determinant is positive,
+ * @return 0 if the determinant is 0.
+ static int signOfDet2x2(double x1, double y1, double x2, double y2);
} // namespace geos::algorithm
diff --git a/include/geos/algorithm/SimplePointInRing.h b/include/geos/algorithm/SimplePointInRing.h
index 05cfeda..b5bd6a3 100644
--- a/include/geos/algorithm/SimplePointInRing.h
+++ b/include/geos/algorithm/SimplePointInRing.h
@@ -21,11 +21,11 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class LinearRing;
- class CoordinateSequence;
+namespace geom {
+class Coordinate;
+class LinearRing;
+class CoordinateSequence;
namespace geos {
@@ -33,11 +33,11 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL SimplePointInRing: public PointInRing {
public:
- SimplePointInRing(geom::LinearRing *ring);
- ~SimplePointInRing() override;
- bool isInside(const geom::Coordinate& pt) override;
+ SimplePointInRing(geom::LinearRing* ring);
+ ~SimplePointInRing() override;
+ bool isInside(const geom::Coordinate& pt) override;
private:
- const geom::CoordinateSequence* pts;
+ const geom::CoordinateSequence* pts;
diff --git a/include/geos/algorithm/distance/DiscreteFrechetDistance.h b/include/geos/algorithm/distance/DiscreteFrechetDistance.h
index ba7b30b..b1dacee 100644
--- a/include/geos/algorithm/distance/DiscreteFrechetDistance.h
+++ b/include/geos/algorithm/distance/DiscreteFrechetDistance.h
@@ -40,19 +40,19 @@
#endif
namespace geos {
- namespace algorithm {
- //class RayCrossingCounter;
- namespace geom {
- class Geometry;
- class Coordinate;
- //class CoordinateSequence;
- namespace index {
- namespace intervalrtree {
- //class SortedPackedIntervalRTree;
+namespace algorithm {
+//class RayCrossingCounter;
+namespace geom {
+class Geometry;
+class Coordinate;
+//class CoordinateSequence;
+namespace index {
+namespace intervalrtree {
+//class SortedPackedIntervalRTree;
namespace geos {
@@ -103,69 +103,71 @@ namespace distance { // geos::algorithm::distance
* DFD(A, B') = 282.842712474619
* </pre>
-class GEOS_DLL DiscreteFrechetDistance
+class GEOS_DLL DiscreteFrechetDistance {
public:
- static double distance(const geom::Geometry& g0,
- const geom::Geometry& g1);
- const geom::Geometry& g1, double densifyFrac);
- DiscreteFrechetDistance(const geom::Geometry& p_g0,
- const geom::Geometry& p_g1)
- g0(p_g0),
- g1(p_g1),
- ptDist(),
- densifyFrac(0.0)
- * Sets the fraction by which to densify each segment.
- * Each segment will be (virtually) split into a number of equal-length
- * subsegments, whose fraction of the total length is closest
- * to the given fraction.
- * @param dFrac
- void setDensifyFraction(double dFrac)
- if ( dFrac > 1.0 || dFrac <= 0.0 )
- throw util::IllegalArgumentException(
- "Fraction is not in range (0.0 - 1.0]");
- densifyFrac = dFrac;
- double distance()
- compute(g0, g1);
- return ptDist.getDistance();
- const std::vector<geom::Coordinate> getCoordinates() const
- return ptDist.getCoordinates();
+ static double distance(const geom::Geometry& g0,
+ const geom::Geometry& g1);
+ const geom::Geometry& g1, double densifyFrac);
+ DiscreteFrechetDistance(const geom::Geometry& p_g0,
+ const geom::Geometry& p_g1)
+ g0(p_g0),
+ g1(p_g1),
+ ptDist(),
+ densifyFrac(0.0)
+ * Sets the fraction by which to densify each segment.
+ * Each segment will be (virtually) split into a number of equal-length
+ * subsegments, whose fraction of the total length is closest
+ * to the given fraction.
+ * @param dFrac
+ void
+ setDensifyFraction(double dFrac)
+ if(dFrac > 1.0 || dFrac <= 0.0) {
+ throw util::IllegalArgumentException(
+ "Fraction is not in range (0.0 - 1.0]");
+ densifyFrac = dFrac;
+ double
+ distance()
+ compute(g0, g1);
+ return ptDist.getDistance();
+ const std::vector<geom::Coordinate>
+ getCoordinates() const
+ return ptDist.getCoordinates();
private:
- geom::Coordinate getSegementAt(const geom::CoordinateSequence& seq, size_t index);
+ geom::Coordinate getSegementAt(const geom::CoordinateSequence& seq, size_t index);
- PointPairDistance& getFrecheDistance(std::vector< std::vector<PointPairDistance> >& ca, size_t i, size_t j, const geom::CoordinateSequence& p, const geom::CoordinateSequence& q);
+ PointPairDistance& getFrecheDistance(std::vector< std::vector<PointPairDistance> >& ca, size_t i, size_t j,
+ const geom::CoordinateSequence& p, const geom::CoordinateSequence& q);
- void compute(const geom::Geometry& discreteGeom, const geom::Geometry& geom);
+ void compute(const geom::Geometry& discreteGeom, const geom::Geometry& geom);
- const geom::Geometry& g0;
+ const geom::Geometry& g0;
- const geom::Geometry& g1;
+ const geom::Geometry& g1;
- PointPairDistance ptDist;
+ PointPairDistance ptDist;
- /// Value of 0.0 indicates that no densification should take place
+ /// Value of 0.0 indicates that no densification should take place
double densifyFrac; // = 0.0;
diff --git a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
index 77d8535..10a8bef 100644
--- a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
+++ b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
@@ -37,19 +37,19 @@
#endif
namespace geos {
- namespace geom {
- class Geometry;
- class Coordinate;
- namespace index {
+namespace geom {
+class Geometry;
+class Coordinate;
+namespace index {
namespace geos {
@@ -97,148 +97,161 @@ namespace distance { // geos::algorithm::distance
* HD(A, B) ~= 47.8
* </pre>
-class GEOS_DLL DiscreteHausdorffDistance
+class GEOS_DLL DiscreteHausdorffDistance {
public:
- DiscreteHausdorffDistance(const geom::Geometry& p_g0,
- g0(p_g0),
- g1(p_g1),
- ptDist(),
- densifyFrac(0.0)
- * @param dFrac
- double distance()
- compute(g0, g1);
- double orientedDistance()
- computeOrientedDistance(g0, g1, ptDist);
- class MaxPointDistanceFilter : public geom::CoordinateFilter
- public:
- MaxPointDistanceFilter(const geom::Geometry& p_geom)
- geom(p_geom)
- void filter_ro(const geom::Coordinate* pt) override
- minPtDist.initialize();
- DistanceToPoint::computeDistance(geom, *pt,
- minPtDist);
- maxPtDist.setMaximum(minPtDist);
- const PointPairDistance& getMaxPointDistance() const
- return maxPtDist;
- private:
- PointPairDistance maxPtDist;
- PointPairDistance minPtDist;
- DistanceToPoint euclideanDist;
- const geom::Geometry& geom;
+ DiscreteHausdorffDistance(const geom::Geometry& p_g0,
+ g0(p_g0),
+ g1(p_g1),
+ ptDist(),
+ densifyFrac(0.0)
+ * @param dFrac
+ void
+ double
+ distance()
+ compute(g0, g1);
+ double
+ orientedDistance()
+ computeOrientedDistance(g0, g1, ptDist);
+ class MaxPointDistanceFilter : public geom::CoordinateFilter {
+ public:
+ MaxPointDistanceFilter(const geom::Geometry& p_geom)
+ geom(p_geom)
+ void
+ filter_ro(const geom::Coordinate* pt) override
+ minPtDist.initialize();
+ DistanceToPoint::computeDistance(geom, *pt,
+ minPtDist);
+ maxPtDist.setMaximum(minPtDist);
+ const PointPairDistance&
+ getMaxPointDistance() const
+ return maxPtDist;
+ private:
+ PointPairDistance maxPtDist;
+ PointPairDistance minPtDist;
+ DistanceToPoint euclideanDist;
+ const geom::Geometry& geom;
MaxPointDistanceFilter(const MaxPointDistanceFilter& other);
MaxPointDistanceFilter& operator=(const MaxPointDistanceFilter& rhs);
- class MaxDensifiedByFractionDistanceFilter
- : public geom::CoordinateSequenceFilter
- public:
- MaxDensifiedByFractionDistanceFilter(
- const geom::Geometry& p_geom, double fraction)
- geom(p_geom),
- numSubSegs( std::size_t(util::round(1.0/fraction)) )
- void filter_ro(const geom::CoordinateSequence& seq,
- std::size_t index) override;
- bool isGeometryChanged() const override { return false; }
- bool isDone() const override { return false; }
- const PointPairDistance& getMaxPointDistance() const {
- return maxPtDist;
- private:
- std::size_t numSubSegs; // = 0;
+ class MaxDensifiedByFractionDistanceFilter
+ : public geom::CoordinateSequenceFilter {
+ public:
+ MaxDensifiedByFractionDistanceFilter(
+ const geom::Geometry& p_geom, double fraction)
+ geom(p_geom),
+ numSubSegs(std::size_t(util::round(1.0 / fraction)))
+ void filter_ro(const geom::CoordinateSequence& seq,
+ std::size_t index) override;
+ bool
+ isGeometryChanged() const override
+ return false;
+ bool
+ isDone() const override
+ return false;
+ return maxPtDist;
+ private:
+ std::size_t numSubSegs; // = 0;
MaxDensifiedByFractionDistanceFilter(const MaxDensifiedByFractionDistanceFilter& other);
MaxDensifiedByFractionDistanceFilter& operator=(const MaxDensifiedByFractionDistanceFilter& rhs);
private:
- void compute(const geom::Geometry& p_g0,
- computeOrientedDistance(p_g0, p_g1, ptDist);
- computeOrientedDistance(p_g1, p_g0, ptDist);
+ void
+ compute(const geom::Geometry& p_g0,
+ computeOrientedDistance(p_g0, p_g1, ptDist);
+ computeOrientedDistance(p_g1, p_g0, ptDist);
- void computeOrientedDistance(const geom::Geometry& discreteGeom,
- const geom::Geometry& geom,
- PointPairDistance& ptDist);
+ void computeOrientedDistance(const geom::Geometry& discreteGeom,
+ const geom::Geometry& geom,
+ PointPairDistance& ptDist);
diff --git a/include/geos/algorithm/distance/DistanceToPoint.h b/include/geos/algorithm/distance/DistanceToPoint.h
index e8692f6..6864baf 100644
--- a/include/geos/algorithm/distance/DistanceToPoint.h
+++ b/include/geos/algorithm/distance/DistanceToPoint.h
@@ -22,17 +22,17 @@
#include <geos/geom/LineSegment.h> // for composition
namespace geos {
- namespace distance {
- class PointPairDistance;
- namespace geom {
- class Geometry;
- class Coordinate;
- class LineString;
- class Polygon;
+namespace distance {
+class PointPairDistance;
+namespace geom {
+class Geometry;
+class Coordinate;
+class LineString;
+class Polygon;
namespace geos {
@@ -44,27 +44,26 @@ namespace distance { // geos::algorithm::distance
* Also computes two points which are separated by the distance.
-class DistanceToPoint
+class DistanceToPoint {
public:
- DistanceToPoint() {}
+ DistanceToPoint() {}
- static void computeDistance(const geom::Geometry& geom,
- const geom::Coordinate& pt,
+ static void computeDistance(const geom::Geometry& geom,
+ const geom::Coordinate& pt,
- static void computeDistance(const geom::LineString& geom,
+ static void computeDistance(const geom::LineString& geom,
- static void computeDistance(const geom::LineSegment& geom,
+ static void computeDistance(const geom::LineSegment& geom,
- static void computeDistance(const geom::Polygon& geom,
+ static void computeDistance(const geom::Polygon& geom,
diff --git a/include/geos/algorithm/distance/PointPairDistance.h b/include/geos/algorithm/distance/PointPairDistance.h
index 6c4bc62..effcc5e 100644
--- a/include/geos/algorithm/distance/PointPairDistance.h
+++ b/include/geos/algorithm/distance/PointPairDistance.h
@@ -34,107 +34,119 @@ namespace distance { // geos::algorithm::distance
* Provides methods to update with a new point pair with
* either maximum or minimum distance.
-class PointPairDistance
+class PointPairDistance {
public:
- PointPairDistance()
- pt(2),
- distance(DoubleNotANumber),
- isNull(true)
- assert(pt.size() == 2);
- void initialize()
- isNull = true;
- void initialize(const geom::Coordinate& p0, const geom::Coordinate& p1)
- pt[0] = p0;
- pt[1] = p1;
- distance = p0.distance(p1);
- isNull = false;
- double getDistance() const
- return distance;
- const std::vector<geom::Coordinate>& getCoordinates() const
- return pt;
- const geom::Coordinate& getCoordinate(size_t i) const
- assert(i<pt.size());
- return pt[i];
- void setMaximum(const PointPairDistance& ptDist)
- setMaximum(ptDist.pt[0], ptDist.pt[1]);
- void setMaximum(const geom::Coordinate& p0, const geom::Coordinate& p1)
- if (isNull) {
- initialize(p0, p1);
- return;
- double dist = p0.distance(p1);
- if (dist > distance)
- initialize(p0, p1, dist);
- void setMinimum(const PointPairDistance& ptDist)
- setMinimum(ptDist.pt[0], ptDist.pt[1]);
- void setMinimum(const geom::Coordinate& p0, const geom::Coordinate& p1)
- if (isNull) {
- return;
- if (dist < distance)
- bool getIsNull()
- return isNull;
+ PointPairDistance()
+ pt(2),
+ distance(DoubleNotANumber),
+ isNull(true)
+ assert(pt.size() == 2);
+ void
+ initialize()
+ isNull = true;
+ void
+ initialize(const geom::Coordinate& p0, const geom::Coordinate& p1)
+ pt[0] = p0;
+ pt[1] = p1;
+ distance = p0.distance(p1);
+ isNull = false;
+ double
+ getDistance() const
+ return distance;
+ const std::vector<geom::Coordinate>&
+ return pt;
+ getCoordinate(size_t i) const
+ assert(i < pt.size());
+ return pt[i];
+ void
+ setMaximum(const PointPairDistance& ptDist)
+ setMaximum(ptDist.pt[0], ptDist.pt[1]);
+ void
+ setMaximum(const geom::Coordinate& p0, const geom::Coordinate& p1)
+ if(isNull) {
+ initialize(p0, p1);
+ return;
+ double dist = p0.distance(p1);
+ if(dist > distance) {
+ initialize(p0, p1, dist);
+ void
+ setMinimum(const PointPairDistance& ptDist)
+ setMinimum(ptDist.pt[0], ptDist.pt[1]);
+ void
+ setMinimum(const geom::Coordinate& p0, const geom::Coordinate& p1)
+ if(isNull) {
+ return;
+ if(dist < distance) {
+ bool
+ getIsNull()
+ return isNull;
private:
- * Initializes the points, avoiding recomputing the distance.
- * @param p0
- * @param p1
- * @param dist the distance between p0 and p1
- void initialize(const geom::Coordinate& p0, const geom::Coordinate& p1,
- double dist)
- pt[0] = p0;
- pt[1] = p1;
- distance = dist;
- isNull = false;
- std::vector<geom::Coordinate> pt;
- double distance;
- bool isNull;
+ * Initializes the points, avoiding recomputing the distance.
+ * @param p0
+ * @param p1
+ * @param dist the distance between p0 and p1
+ void
+ initialize(const geom::Coordinate& p0, const geom::Coordinate& p1,
+ double dist)
+ pt[0] = p0;
+ pt[1] = p1;
+ distance = dist;
+ isNull = false;
+ std::vector<geom::Coordinate> pt;
+ double distance;
+ bool isNull;
} // geos::algorithm::distance
diff --git a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
index 591241c..00ebbc0 100644
--- a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
+++ b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
@@ -51,48 +51,45 @@ namespace locate { // geos::algorithm::locate
* {@link Polygonal} and {@link LinearRing} geometries
* are supported.
-class IndexedPointInAreaLocator : public PointOnGeometryLocator
+class IndexedPointInAreaLocator : public PointOnGeometryLocator {
private:
- class IntervalIndexedGeometry
+ class IntervalIndexedGeometry {
private:
index::intervalrtree::SortedPackedIntervalRTree index;
- void init(const geom::Geometry & g);
- void addLine(const geom::CoordinateSequence * pts);
+ void init(const geom::Geometry& g);
+ void addLine(const geom::CoordinateSequence* pts);
// To keep track of LineSegments
std::vector< geom::LineSegment > segments;
public:
- IntervalIndexedGeometry(const geom::Geometry & g);
+ IntervalIndexedGeometry(const geom::Geometry& g);
- void query(double min, double max, index::ItemVisitor * visitor);
+ void query(double min, double max, index::ItemVisitor* visitor);
- class SegmentVisitor : public index::ItemVisitor
+ class SegmentVisitor : public index::ItemVisitor {
private:
- algorithm::RayCrossingCounter * counter;
+ algorithm::RayCrossingCounter* counter;
public:
- SegmentVisitor(algorithm::RayCrossingCounter * p_counter)
+ SegmentVisitor(algorithm::RayCrossingCounter* p_counter)
: counter(p_counter)
~SegmentVisitor() override
- void visitItem(void * item) override;
+ void visitItem(void* item) override;
- const geom::Geometry & areaGeom;
+ const geom::Geometry& areaGeom;
std::unique_ptr<IntervalIndexedGeometry> index;
- void buildIndex(const geom::Geometry & g);
+ void buildIndex(const geom::Geometry& g);
IndexedPointInAreaLocator(const IndexedPointInAreaLocator& other) = delete;
@@ -106,7 +103,7 @@ public:
* @param g the Geometry to locate in
- IndexedPointInAreaLocator(const geom::Geometry & g);
+ IndexedPointInAreaLocator(const geom::Geometry& g);
* Determines the {@link Location} of a point in an areal {@link Geometry}.
@@ -114,7 +111,7 @@ public:
* @return the location of the point in the geometry
- int locate(const geom::Coordinate * /*const*/ p) override;
+ int locate(const geom::Coordinate* /*const*/ p) override;
diff --git a/include/geos/algorithm/locate/PointOnGeometryLocator.h b/include/geos/algorithm/locate/PointOnGeometryLocator.h
index 58f149d..c06fd8a 100644
--- a/include/geos/algorithm/locate/PointOnGeometryLocator.h
+++ b/include/geos/algorithm/locate/PointOnGeometryLocator.h
@@ -17,9 +17,9 @@
#define GEOS_ALGORITHM_LOCATE_POINTONGEOMETRYLOCATOR_H
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -32,21 +32,21 @@ namespace locate { // geos::algorithm::locate
-class PointOnGeometryLocator
+class PointOnGeometryLocator {
private:
protected:
public:
- virtual ~PointOnGeometryLocator()
+ virtual
+ ~PointOnGeometryLocator()
- * Determines the {@link Location} of a point in an areal {@link Geometry}.
- * @return the location of the point in the geometry
- virtual int locate( const geom::Coordinate * /*const*/ p) =0;
+ * Determines the {@link Location} of a point in an areal {@link Geometry}.
+ * @return the location of the point in the geometry
+ virtual int locate(const geom::Coordinate* /*const*/ p) = 0;
} // geos::algorithm::locate
diff --git a/include/geos/algorithm/locate/SimplePointInAreaLocator.h b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
index 4020230..2b51986 100644
--- a/include/geos/algorithm/locate/SimplePointInAreaLocator.h
+++ b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
@@ -44,13 +44,12 @@ namespace locate { // geos::algorithm::locate
* @version 1.7
-class SimplePointInAreaLocator : public PointOnGeometryLocator
+class SimplePointInAreaLocator : public PointOnGeometryLocator {
public:
static int locate(const geom::Coordinate& p,
- const geom::Geometry *geom);
+ const geom::Geometry* geom);
* Determines the {@link Location} of a point in a {@link Polygon}.
@@ -62,13 +61,14 @@ public:
* @return the Location of the point in the polygon
static int locatePointInPolygon(const geom::Coordinate& p,
- const geom::Polygon *poly);
+ const geom::Polygon* poly);
- SimplePointInAreaLocator(const geom::Geometry * p_g)
+ SimplePointInAreaLocator(const geom::Geometry* p_g)
: g(p_g)
- int locate(const geom::Coordinate * p) override
+ int
+ locate(const geom::Coordinate* p) override
return locate(*p, g);
@@ -76,9 +76,9 @@ public:
private:
static int locateInGeometry(const geom::Coordinate& p,
- const geom::Geometry * g;
+ const geom::Geometry* g;
diff --git a/include/geos/geom/BinaryOp.h b/include/geos/geom/BinaryOp.h
index 272d33f..c973900 100644
--- a/include/geos/geom/BinaryOp.h
+++ b/include/geos/geom/BinaryOp.h
@@ -168,49 +168,48 @@ namespace geos {
namespace geom { // geos::geom
inline bool
-check_valid(const Geometry& g, const std::string& label, bool doThrow=false, bool validOnly=false)
+check_valid(const Geometry& g, const std::string& label, bool doThrow = false, bool validOnly = false)
- if ( dynamic_cast<const Lineal*>(&g) ) {
- if ( ! validOnly ) {
- operation::IsSimpleOp sop(g, algorithm::BoundaryNodeRule::getBoundaryEndPoint());
- if ( ! sop.isSimple() )
- if ( doThrow ) {
- throw geos::util::TopologyException(
- label + " is not simple");
+ if(dynamic_cast<const Lineal*>(&g)) {
+ if(! validOnly) {
+ operation::IsSimpleOp sop(g, algorithm::BoundaryNodeRule::getBoundaryEndPoint());
+ if(! sop.isSimple()) {
+ if(doThrow) {
+ throw geos::util::TopologyException(
+ label + " is not simple");
+ return false;
- return false;
- } else {
- operation::valid::IsValidOp ivo(&g);
- if ( ! ivo.isValid() )
- using operation::valid::TopologyValidationError;
- TopologyValidationError* err = ivo.getValidationError();
+ else {
+ operation::valid::IsValidOp ivo(&g);
+ if(! ivo.isValid()) {
+ using operation::valid::TopologyValidationError;
+ TopologyValidationError* err = ivo.getValidationError();
#ifdef GEOS_DEBUG_BINARYOP
- std::cerr << label << " is INVALID: "
- << err->toString()
- << " (" << std::setprecision(20)
- << err->getCoordinate() << ")"
- << std::endl
+ std::cerr << label << " is INVALID: "
+ << err->toString()
+ << " (" << std::setprecision(20)
+ << err->getCoordinate() << ")"
+ << std::endl
#ifdef GEOS_DEBUG_BINARYOP_PRINT_INVALID
- << "<A>" << std::endl
- << g.toString()
- << std::endl
- << "</A>" << std::endl
-#endif
-#endif
- if ( doThrow ) {
- label + " is invalid: " + err->toString(),
- err->getCoordinate());
- return false;
+ << "<A>" << std::endl
+ << g.toString()
+ << std::endl
+ << "</A>" << std::endl
+#endif
+#endif
+ if(doThrow) {
+ label + " is invalid: " + err->toString(),
+ err->getCoordinate());
+ return false;
- return true;
+ return true;
@@ -222,44 +221,48 @@ check_valid(const Geometry& g, const std::string& label, bool doThrow=false, boo
inline std::unique_ptr<Geometry>
fix_self_intersections(std::unique_ptr<Geometry> g, const std::string& label)
- ::geos::ignore_unused_variable_warning(label);
+ ::geos::ignore_unused_variable_warning(label);
- std::cerr << label << " fix_self_intersection (UnaryUnion)" << std::endl;
+ std::cerr << label << " fix_self_intersection (UnaryUnion)" << std::endl;
#endif
- // Only multi-components can be fixed by UnaryUnion
- if ( ! dynamic_cast<const GeometryCollection*>(g.get()) ) return g;
+ // Only multi-components can be fixed by UnaryUnion
+ if(! dynamic_cast<const GeometryCollection*>(g.get())) {
+ return g;
- using operation::valid::IsValidOp;
+ using operation::valid::IsValidOp;
- IsValidOp ivo(g.get());
+ IsValidOp ivo(g.get());
- // Polygon is valid, nothing to do
- if ( ivo.isValid() ) return g;
+ // Polygon is valid, nothing to do
+ if(ivo.isValid()) {
+ return g;
- // Not all invalidities can be fixed by this code
+ // Not all invalidities can be fixed by this code
- switch ( err->getErrorType() ) {
+ switch(err->getErrorType()) {
case TopologyValidationError::eRingSelfIntersection:
case TopologyValidationError::eTooFewPoints: // collapsed lines
- std::cerr << label << " ATTEMPT_TO_FIX: " << err->getErrorType() << ": " << *g << std::endl;
+ std::cerr << label << " ATTEMPT_TO_FIX: " << err->getErrorType() << ": " << *g << std::endl;
#endif
- g = g->Union();
+ g = g->Union();
- std::cerr << label << " ATTEMPT_TO_FIX succeeded.. " << std::endl;
+ std::cerr << label << " ATTEMPT_TO_FIX succeeded.. " << std::endl;
#endif
- return g;
+ return g;
case TopologyValidationError::eSelfIntersection:
- // this one is within a single component, won't be fixed
+ // this one is within a single component, won't be fixed
default:
- std::cerr << label << " invalidity is: " << err->getErrorType() << std::endl;
+ std::cerr << label << " invalidity is: " << err->getErrorType() << std::endl;
#endif
- return g;
+ return g;
@@ -270,200 +273,196 @@ fix_self_intersections(std::unique_ptr<Geometry> g, const std::string& label)
template <class BinOp>
-SnapOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
+SnapOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
- typedef std::unique_ptr<Geometry> GeomPtr;
+ typedef std::unique_ptr<Geometry> GeomPtr;
- //using geos::precision::GeometrySnapper;
- using geos::operation::overlay::snap::GeometrySnapper;
+ //using geos::precision::GeometrySnapper;
+ using geos::operation::overlay::snap::GeometrySnapper;
- // Snap tolerance must be computed on the original
- // (not commonbits-removed) geoms
- double snapTolerance = GeometrySnapper::computeOverlaySnapTolerance(*g0, *g1);
+ // Snap tolerance must be computed on the original
+ // (not commonbits-removed) geoms
+ double snapTolerance = GeometrySnapper::computeOverlaySnapTolerance(*g0, *g1);
#if GEOS_DEBUG_BINARYOP
- std::cerr<< std::setprecision(20) << "Computed snap tolerance: "<<snapTolerance<<std::endl;
+ std::cerr << std::setprecision(20) << "Computed snap tolerance: " << snapTolerance << std::endl;
#endif
#if CBR_BEFORE_SNAPPING
- // Compute common bits
- geos::precision::CommonBitsRemover cbr;
- cbr.add(g0); cbr.add(g1);
+ // Compute common bits
+ geos::precision::CommonBitsRemover cbr;
+ cbr.add(g0);
+ cbr.add(g1);
- std::cerr<<"Computed common bits: "<<cbr.getCommonCoordinate()<<std::endl;
+ std::cerr << "Computed common bits: " << cbr.getCommonCoordinate() << std::endl;
#endif
- // Now remove common bits
- GeomPtr rG0( cbr.removeCommonBits(g0->clone()) );
- GeomPtr rG1( cbr.removeCommonBits(g1->clone()) );
+ // Now remove common bits
+ GeomPtr rG0(cbr.removeCommonBits(g0->clone()));
+ GeomPtr rG1(cbr.removeCommonBits(g1->clone()));
- check_valid(*rG0, "CBR: removed-bits geom 0");
- check_valid(*rG1, "CBR: removed-bits geom 1");
+ check_valid(*rG0, "CBR: removed-bits geom 0");
+ check_valid(*rG1, "CBR: removed-bits geom 1");
#endif
- const Geometry& operand0 = *rG0;
- const Geometry& operand1 = *rG1;
+ const Geometry& operand0 = *rG0;
+ const Geometry& operand1 = *rG1;
#else // don't CBR before snapping
- const Geometry& operand0 = *g0;
- const Geometry& operand1 = *g1;
+ const Geometry& operand0 = *g0;
+ const Geometry& operand1 = *g1;
#endif
- GeometrySnapper snapper0( operand0 );
- GeomPtr snapG0( snapper0.snapTo(operand1, snapTolerance) );
- //snapG0 = fix_self_intersections(snapG0, "SNAP: snapped geom 0");
+ GeometrySnapper snapper0(operand0);
+ GeomPtr snapG0(snapper0.snapTo(operand1, snapTolerance));
+ //snapG0 = fix_self_intersections(snapG0, "SNAP: snapped geom 0");
- // NOTE: second geom is snapped on the snapped first one
- GeometrySnapper snapper1( operand1 );
- GeomPtr snapG1( snapper1.snapTo(*snapG0, snapTolerance) );
- //snapG1 = fix_self_intersections(snapG1, "SNAP: snapped geom 1");
+ // NOTE: second geom is snapped on the snapped first one
+ GeometrySnapper snapper1(operand1);
+ GeomPtr snapG1(snapper1.snapTo(*snapG0, snapTolerance));
+ //snapG1 = fix_self_intersections(snapG1, "SNAP: snapped geom 1");
- // Run the binary op
- GeomPtr result( _Op(snapG0.get(), snapG1.get()) );
+ // Run the binary op
+ GeomPtr result(_Op(snapG0.get(), snapG1.get()));
- check_valid(*result, "SNAP: result (before common-bits addition");
+ check_valid(*result, "SNAP: result (before common-bits addition");
#endif
- // Add common bits back in
- cbr.addCommonBits( result.get() );
- //result = fix_self_intersections(result, "SNAP: result (after common-bits addition)");
+ // Add common bits back in
+ cbr.addCommonBits(result.get());
+ //result = fix_self_intersections(result, "SNAP: result (after common-bits addition)");
- check_valid(*result, "CBR: result (after common-bits addition)", true);
+ check_valid(*result, "CBR: result (after common-bits addition)", true);
#endif
- return result;
+ return result;
-BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
+BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
- GeomPtr ret;
- geos::util::TopologyException origException;
+ GeomPtr ret;
+ geos::util::TopologyException origException;
#ifdef USE_ORIGINAL_INPUT
- // Try with original input
- try
+ // Try with original input
+ try {
- std::cerr << "Trying with original input." << std::endl;
+ std::cerr << "Trying with original input." << std::endl;
#endif
- ret.reset(_Op(g0, g1));
+ ret.reset(_Op(g0, g1));
#if GEOS_CHECK_ORIGINAL_RESULT_VALIDITY
- check_valid(*ret, "Overlay result between original inputs", true, true);
+ check_valid(*ret, "Overlay result between original inputs", true, true);
#endif
- std::cerr << "Attempt with original input succeeded" << std::endl;
+ std::cerr << "Attempt with original input succeeded" << std::endl;
#endif
- return ret;
- catch (const geos::util::TopologyException& ex)
- origException=ex;
+ return ret;
+ catch(const geos::util::TopologyException& ex) {
+ origException = ex;
- std::cerr << "Original exception: " << ex.what() << std::endl;
+ std::cerr << "Original exception: " << ex.what() << std::endl;
#endif
#endif // USE_ORIGINAL_INPUT
- check_valid(*g0, "Input geom 0", true, true);
- check_valid(*g1, "Input geom 1", true, true);
+ check_valid(*g0, "Input geom 0", true, true);
+ check_valid(*g1, "Input geom 1", true, true);
#if USE_COMMONBITS_POLICY
- // Try removing common bits (possibly obsoleted by snapping below)
- // NOTE: this policy was _later_ implemented
- // in JTS as EnhancedPrecisionOp
- // TODO: consider using the now-ported EnhancedPrecisionOp
- // here too
- try
- GeomPtr rG0;
- GeomPtr rG1;
- precision::CommonBitsRemover cbr;
+ // Try removing common bits (possibly obsoleted by snapping below)
+ // NOTE: this policy was _later_ implemented
+ // in JTS as EnhancedPrecisionOp
+ // TODO: consider using the now-ported EnhancedPrecisionOp
+ // here too
+ try {
+ GeomPtr rG0;
+ GeomPtr rG1;
+ precision::CommonBitsRemover cbr;
- std::cerr << "Trying with Common Bits Remover (CBR)" << std::endl;
+ std::cerr << "Trying with Common Bits Remover (CBR)" << std::endl;
#endif
- cbr.add(g0);
- cbr.add(g1);
+ cbr.add(g0);
+ cbr.add(g1);
- rG0.reset( cbr.removeCommonBits(g0->clone()) );
- rG1.reset( cbr.removeCommonBits(g1->clone()) );
+ rG0.reset(cbr.removeCommonBits(g0->clone()));
+ rG1.reset(cbr.removeCommonBits(g1->clone()));
- check_valid(*rG0, "CBR: geom 0 (after common-bits removal)");
- check_valid(*rG1, "CBR: geom 1 (after common-bits removal)");
+ check_valid(*rG0, "CBR: geom 0 (after common-bits removal)");
+ check_valid(*rG1, "CBR: geom 1 (after common-bits removal)");
#endif
- ret.reset( _Op(rG0.get(), rG1.get()) );
+ ret.reset(_Op(rG0.get(), rG1.get()));
- check_valid(*ret, "CBR: result (before common-bits addition)");
+ check_valid(*ret, "CBR: result (before common-bits addition)");
#endif
- cbr.addCommonBits( ret.get() );
+ cbr.addCommonBits(ret.get());
#if GEOS_CHECK_COMMONBITS_VALIDITY
- check_valid(*ret, "CBR: result (after common-bits addition)", true);
+ check_valid(*ret, "CBR: result (after common-bits addition)", true);
#endif
- std::cerr << "Attempt with CBR succeeded" << std::endl;
+ std::cerr << "Attempt with CBR succeeded" << std::endl;
#endif
- return ret;
+ return ret;
::geos::ignore_unused_variable_warning(ex);
- std::cerr << "CBR: " << ex.what() << std::endl;
+ std::cerr << "CBR: " << ex.what() << std::endl;
#endif
#endif
- // Try with snapping
- // TODO: possible optimization would be reusing the
- // already common-bit-removed inputs and just
- // apply geometry snapping, whereas the current
- // SnapOp function does both.
+ // Try with snapping
+ // TODO: possible optimization would be reusing the
+ // already common-bit-removed inputs and just
+ // apply geometry snapping, whereas the current
+ // SnapOp function does both.
#if USE_SNAPPING_POLICY
- std::cerr << "Trying with snapping " << std::endl;
+ std::cerr << "Trying with snapping " << std::endl;
#endif
- try {
- ret = SnapOp(g0, g1, _Op);
+ try {
+ ret = SnapOp(g0, g1, _Op);
#if GEOS_CHECK_SNAPPINGOP_VALIDITY
- check_valid(*ret, "SNAP: result", true, true);
+ check_valid(*ret, "SNAP: result", true, true);
#endif
- std::cerr << "SnapOp succeeded" << std::endl;
+ std::cerr << "SnapOp succeeded" << std::endl;
#endif
- return ret;
+ return ret;
- std::cerr << "SNAP: " << ex.what() << std::endl;
+ std::cerr << "SNAP: " << ex.what() << std::endl;
#endif
#endif // USE_SNAPPING_POLICY }
@@ -471,85 +470,86 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
#if USE_PRECISION_REDUCTION_POLICY
- // Try reducing precision
- try
- long unsigned int g0scale =
+ // Try reducing precision
+ try {
+ long unsigned int g0scale =
static_cast<long unsigned int>(g0->getFactory()->getPrecisionModel()->getScale());
- long unsigned int g1scale =
+ long unsigned int g1scale =
static_cast<long unsigned int>(g1->getFactory()->getPrecisionModel()->getScale());
- std::cerr << "Original input scales are: "
- << g0scale
- << " and "
- << g1scale
- << std::endl;
+ std::cerr << "Original input scales are: "
+ << g0scale
+ << " and "
+ << g1scale
+ << std::endl;
#endif
- double maxScale = 1e16;
+ double maxScale = 1e16;
- // Don't use a scale bigger than the input one
- if ( g0scale && static_cast<double>(g0scale) < maxScale ) maxScale = static_cast<double>(g0scale);
- if ( g1scale && static_cast<double>(g1scale) < maxScale ) maxScale = static_cast<double>(g1scale);
+ // Don't use a scale bigger than the input one
+ if(g0scale && static_cast<double>(g0scale) < maxScale) {
+ maxScale = static_cast<double>(g0scale);
+ if(g1scale && static_cast<double>(g1scale) < maxScale) {
+ maxScale = static_cast<double>(g1scale);
- for (double scale=maxScale; scale >= 1; scale /= 10)
- PrecisionModel pm(scale);
- GeometryFactory::Ptr gf = GeometryFactory::create(&pm);
+ for(double scale = maxScale; scale >= 1; scale /= 10) {
+ PrecisionModel pm(scale);
+ GeometryFactory::Ptr gf = GeometryFactory::create(&pm);
- std::cerr << "Trying with scale " << scale << std::endl;
+ std::cerr << "Trying with scale " << scale << std::endl;
#endif
- precision::GeometryPrecisionReducer reducer( *gf );
- GeomPtr rG0( reducer.reduce(*g0) );
- GeomPtr rG1( reducer.reduce(*g1) );
+ precision::GeometryPrecisionReducer reducer(*gf);
+ GeomPtr rG0(reducer.reduce(*g0));
+ GeomPtr rG1(reducer.reduce(*g1));
- check_valid(*rG0, "PR: geom 0 (after precision reduction)");
- check_valid(*rG1, "PR: geom 1 (after precision reduction)");
+ check_valid(*rG0, "PR: geom 0 (after precision reduction)");
+ check_valid(*rG1, "PR: geom 1 (after precision reduction)");
#endif
- try
- // restore original precision (least precision between inputs)
- if ( g0->getFactory()->getPrecisionModel()->compareTo( g1->getFactory()->getPrecisionModel() ) < 0 ) {
- ret.reset( g0->getFactory()->createGeometry(ret.get()) );
- else {
- ret.reset( g1->getFactory()->createGeometry(ret.get()) );
+ try {
+ // restore original precision (least precision between inputs)
+ if(g0->getFactory()->getPrecisionModel()->compareTo(g1->getFactory()->getPrecisionModel()) < 0) {
+ ret.reset(g0->getFactory()->createGeometry(ret.get()));
+ else {
+ ret.reset(g1->getFactory()->createGeometry(ret.get()));
#if GEOS_CHECK_PRECISION_REDUCTION_VALIDITY
- check_valid(*ret, "PR: result (after restore of original precision)", true);
+ check_valid(*ret, "PR: result (after restore of original precision)", true);
#endif
- std::cerr << "Attempt with scale " << scale << " succeeded" << std::endl;
+ std::cerr << "Attempt with scale " << scale << " succeeded" << std::endl;
#endif
- return ret;
+ return ret;
- std::cerr << "Reduced with scale (" << scale << "): "
- << ex.what() << std::endl;
+ std::cerr << "Reduced with scale (" << scale << "): "
+ << ex.what() << std::endl;
#endif
- if ( scale == 1 ) throw ex;
+ if(scale == 1) {
+ throw ex;
- std::cerr << "Reduced: " << ex.what() << std::endl;
+ std::cerr << "Reduced: " << ex.what() << std::endl;
#endif
- ::geos::ignore_unused_variable_warning(ex);
+ ::geos::ignore_unused_variable_warning(ex);
#endif
// USE_PRECISION_REDUCTION_POLICY }
@@ -561,64 +561,61 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
#if USE_TP_SIMPLIFY_POLICY
- // Try simplifying
- try
+ // Try simplifying
+ try {
- double maxTolerance = 0.04;
- double minTolerance = 0.01;
- double tolStep = 0.01;
+ double maxTolerance = 0.04;
+ double minTolerance = 0.01;
+ double tolStep = 0.01;
- for (double tol = minTolerance; tol <= maxTolerance; tol += tolStep)
+ for(double tol = minTolerance; tol <= maxTolerance; tol += tolStep) {
- std::cerr << "Trying simplifying with tolerance " << tol << std::endl;
+ std::cerr << "Trying simplifying with tolerance " << tol << std::endl;
#endif
- GeomPtr rG0( simplify::TopologyPreservingSimplifier::simplify(g0, tol) );
- GeomPtr rG1( simplify::TopologyPreservingSimplifier::simplify(g1, tol) );
+ GeomPtr rG0(simplify::TopologyPreservingSimplifier::simplify(g0, tol));
+ GeomPtr rG1(simplify::TopologyPreservingSimplifier::simplify(g1, tol));
- try
- return ret;
- if ( tol >= maxTolerance ) throw ex;
+ try {
+ return ret;
+ if(tol >= maxTolerance) {
+ throw ex;
- std::cerr << "Simplified with tolerance (" << tol << "): "
+ std::cerr << "Simplified with tolerance (" << tol << "): "
#endif
- return ret;
+ return ret;
- std::cerr << "Simplified: " << ex.what() << std::endl;
+ std::cerr << "Simplified: " << ex.what() << std::endl;
#endif
#endif
// USE_TP_SIMPLIFY_POLICY }
- std::cerr << "No attempts worked to union " << std::endl;
- std::cerr << "Input geometries:" << std::endl
- << g0->toString() << std::endl
- << "<B>" << std::endl
- << g1->toString() << std::endl
- << "</B>" << std::endl;
+ std::cerr << "No attempts worked to union " << std::endl;
+ std::cerr << "Input geometries:" << std::endl
+ << g0->toString() << std::endl
+ << "<B>" << std::endl
+ << g1->toString() << std::endl
+ << "</B>" << std::endl;
#endif
- throw origException;
+ throw origException;
diff --git a/include/geos/geom/Coordinate.h b/include/geos/geom/Coordinate.h
index 945ab7b..fdd5bbb 100644
--- a/include/geos/geom/Coordinate.h
+++ b/include/geos/geom/Coordinate.h
@@ -61,79 +61,81 @@ class GEOS_DLL Coordinate {
private:
- static Coordinate _nullCoord;
+ static Coordinate _nullCoord;
public:
- /// A set of const Coordinate pointers
- typedef std::set<const Coordinate *, CoordinateLessThen> ConstSet;
+ /// A set of const Coordinate pointers
+ typedef std::set<const Coordinate*, CoordinateLessThen> ConstSet;
- /// A vector of const Coordinate pointers
- typedef std::vector<const Coordinate *> ConstVect;
+ /// A vector of const Coordinate pointers
+ typedef std::vector<const Coordinate*> ConstVect;
- /// A stack of const Coordinate pointers
- typedef std::stack<const Coordinate *> ConstStack;
+ /// A stack of const Coordinate pointers
+ typedef std::stack<const Coordinate*> ConstStack;
- /// A vector of Coordinate objects (real object, not pointers)
- typedef std::vector<Coordinate> Vect;
+ /// A vector of Coordinate objects (real object, not pointers)
+ typedef std::vector<Coordinate> Vect;
- /// x-coordinate
- double x;
+ /// x-coordinate
+ double x;
- /// y-coordinate
- double y;
+ /// y-coordinate
+ double y;
- /// z-coordinate
- double z;
+ /// z-coordinate
+ double z;
- void setNull();
+ void setNull();
- static Coordinate& getNull();
+ static Coordinate& getNull();
- bool isNull() const;
+ bool isNull() const;
- Coordinate(double xNew=0.0, double yNew=0.0, double zNew=DoubleNotANumber);
+ Coordinate(double xNew = 0.0, double yNew = 0.0, double zNew = DoubleNotANumber);
- bool equals2D(const Coordinate& other) const;
+ bool equals2D(const Coordinate& other) const;
- /// 2D only
- bool equals(const Coordinate& other) const;
+ /// 2D only
+ bool equals(const Coordinate& other) const;
- /// TODO: deprecate this, move logic to CoordinateLessThen instead
- int compareTo(const Coordinate& other) const;
+ /// TODO: deprecate this, move logic to CoordinateLessThen instead
+ int compareTo(const Coordinate& other) const;
- /// 3D comparison
- bool equals3D(const Coordinate& other) const;
+ /// 3D comparison
+ bool equals3D(const Coordinate& other) const;
- /// Returns a string of the form <I>(x,y,z)</I> .
- std::string toString() const;
+ /// Returns a string of the form <I>(x,y,z)</I> .
+ std::string toString() const;
- /// TODO: obsoleted this, can use PrecisionModel::makePrecise(Coordinate*)
- /// instead
- //void makePrecise(const PrecisionModel *pm);
+ /// TODO: obsoleted this, can use PrecisionModel::makePrecise(Coordinate*)
+ /// instead
+ //void makePrecise(const PrecisionModel *pm);
- double distance(const Coordinate& p) const;
+ double distance(const Coordinate& p) const;
- int hashCode() const;
+ int hashCode() const;
- * Returns a hash code for a double value, using the algorithm from
- * Joshua Bloch's book <i>Effective Java</i>
- static int hashCode(double d);
+ * Returns a hash code for a double value, using the algorithm from
+ * Joshua Bloch's book <i>Effective Java</i>
+ static int hashCode(double d);
/// Strict weak ordering Functor for Coordinate
struct GEOS_DLL CoordinateLessThen {
- bool operator()(const Coordinate* a, const Coordinate* b) const;
- bool operator()(const Coordinate& a, const Coordinate& b) const;
+ bool operator()(const Coordinate* a, const Coordinate* b) const;
+ bool operator()(const Coordinate& a, const Coordinate& b) const;
/// Strict weak ordering operator for Coordinate
-inline bool operator<(const Coordinate& a, const Coordinate& b) {
- return CoordinateLessThen()(a,b);
+inline bool
+operator<(const Coordinate& a, const Coordinate& b)
+ return CoordinateLessThen()(a, b);
/// Output function
diff --git a/include/geos/geom/Coordinate.inl b/include/geos/geom/Coordinate.inl
index 46ea94d..49d2b96 100644
--- a/include/geos/geom/Coordinate.inl
+++ b/include/geos/geom/Coordinate.inl
@@ -27,106 +27,126 @@ namespace geom { // geos::geom
INLINE void
Coordinate::setNull()
- x=DoubleNotANumber;
- y=DoubleNotANumber;
- z=DoubleNotANumber;
+ x = DoubleNotANumber;
+ y = DoubleNotANumber;
+ z = DoubleNotANumber;
INLINE bool
Coordinate::isNull() const
- return (std::isnan(x) && std::isnan(y) && std::isnan(z));
+ return (std::isnan(x) && std::isnan(y) && std::isnan(z));
INLINE
Coordinate::Coordinate(double xNew, double yNew, double zNew)
- x(xNew),
- y(yNew),
- z(zNew)
+ x(xNew),
+ y(yNew),
+ z(zNew)
INLINE bool
Coordinate::equals2D(const Coordinate& other) const
- if (x != other.x) return false;
- if (y != other.y) return false;
- return true;
+ if(x != other.x) {
+ return false;
+ if(y != other.y) {
+ return false;
+ return true;
INLINE bool
Coordinate::equals(const Coordinate& other) const
- return equals2D(other);
+ return equals2D(other);
INLINE int
Coordinate::compareTo(const Coordinate& other) const
- if (x < other.x) return -1;
- if (x > other.x) return 1;
- if (y < other.y) return -1;
- if (y > other.y) return 1;
- return 0;
+ if(x < other.x) {
+ return -1;
+ if(x > other.x) {
+ return 1;
+ if(y < other.y) {
+ return -1;
+ if(y > other.y) {
+ return 1;
+ return 0;
INLINE bool
Coordinate::equals3D(const Coordinate& other) const
- return (x == other.x) && ( y == other.y) &&
- ((z == other.z)||(std::isnan(z) && std::isnan(other.z)));
+ return (x == other.x) && (y == other.y) &&
+ ((z == other.z) || (std::isnan(z) && std::isnan(other.z)));
INLINE double
Coordinate::distance(const Coordinate& p) const
- double dx = x - p.x;
- double dy = y - p.y;
- return std::sqrt(dx * dx + dy * dy);
+ double dx = x - p.x;
+ double dy = y - p.y;
+ return std::sqrt(dx * dx + dy * dy);
INLINE int
Coordinate::hashCode() const
- //Algorithm from Effective Java by Joshua Bloch [Jon Aquino]
- int result = 17;
- result = 37 * result + hashCode(x);
- result = 37 * result + hashCode(y);
- return result;
+ //Algorithm from Effective Java by Joshua Bloch [Jon Aquino]
+ int result = 17;
+ result = 37 * result + hashCode(x);
+ result = 37 * result + hashCode(y);
+ return result;
/*static*/
INLINE int
Coordinate::hashCode(double d)
- int64 f = (int64)(d);
- return (int)(f^(f>>32));
+ int64 f = (int64)(d);
+ return (int)(f ^ (f >> 32));
INLINE bool
CoordinateLessThen::operator()(const Coordinate* a, const Coordinate* b) const
- if (a->compareTo(*b)<0) return true;
- else return false;
+ if(a->compareTo(*b) < 0) {
+ return true;
+ else {
+ return false;
INLINE bool
CoordinateLessThen::operator()(const Coordinate& a, const Coordinate& b) const
- if (a.compareTo(b)<0) return true;
+ if(a.compareTo(b) < 0) {
+ return true;
+ else {
+ return false;
INLINE bool
operator==(const Coordinate& a, const Coordinate& b)
- return a.equals2D(b);
+ return a.equals2D(b);
INLINE bool
operator!=(const Coordinate& a, const Coordinate& b)
- return ! a.equals2D(b);
+ return ! a.equals2D(b);
} // namespace geos::geom
diff --git a/include/geos/geom/CoordinateArraySequence.h b/include/geos/geom/CoordinateArraySequence.h
index c080b63..3834f93 100644
--- a/include/geos/geom/CoordinateArraySequence.h
+++ b/include/geos/geom/CoordinateArraySequence.h
@@ -24,9 +24,9 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
@@ -37,89 +37,101 @@ namespace geom { // geos.geom
class GEOS_DLL CoordinateArraySequence : public CoordinateSequence {
public:
- CoordinateArraySequence(const CoordinateArraySequence &cl);
+ CoordinateArraySequence(const CoordinateArraySequence& cl);
- CoordinateArraySequence(const CoordinateSequence &cl);
+ CoordinateArraySequence(const CoordinateSequence& cl);
- CoordinateSequence *clone() const override;
+ CoordinateSequence* clone() const override;
- //const Coordinate& getCoordinate(int pos) const;
- const Coordinate& getAt(std::size_t pos) const override;
+ //const Coordinate& getCoordinate(int pos) const;
+ const Coordinate& getAt(std::size_t pos) const override;
- /// Copy Coordinate at position i to Coordinate c
- void getAt(std::size_t i, Coordinate& c) const override;
+ /// Copy Coordinate at position i to Coordinate c
+ void getAt(std::size_t i, Coordinate& c) const override;
- //int size() const;
- size_t getSize() const override;
+ //int size() const;
+ size_t getSize() const override;
- // @deprecated
- const std::vector<Coordinate>* toVector() const override;
+ // @deprecated
+ const std::vector<Coordinate>* toVector() const override;
- // See dox in CoordinateSequence.h
- void toVector(std::vector<Coordinate>&) const override;
+ // See dox in CoordinateSequence.h
+ void toVector(std::vector<Coordinate>&) const override;
- /// Construct an empty sequence
- CoordinateArraySequence();
+ /// Construct an empty sequence
+ CoordinateArraySequence();
- /// Construct sequence taking ownership of given Coordinate vector
- CoordinateArraySequence(std::vector<Coordinate> *coords,
- std::size_t dimension = 0);
+ /// Construct sequence taking ownership of given Coordinate vector
+ CoordinateArraySequence(std::vector<Coordinate>* coords,
+ std::size_t dimension = 0);
- /// Construct sequence allocating space for n coordinates
- CoordinateArraySequence(std::size_t n, std::size_t dimension = 0);
+ /// Construct sequence allocating space for n coordinates
+ CoordinateArraySequence(std::size_t n, std::size_t dimension = 0);
- ~CoordinateArraySequence() override;
+ ~CoordinateArraySequence() override;
- bool isEmpty() const override { return empty(); }
+ bool
+ isEmpty() const override
+ return empty();
- bool empty() const { return vect->empty(); }
+ bool
+ empty() const
+ return vect->empty();
- /// Reset this CoordinateArraySequence to the empty state
- void clear() { vect->clear(); }
+ /// Reset this CoordinateArraySequence to the empty state
+ void
+ clear()
+ vect->clear();
- void add(const Coordinate& c) override;
+ void add(const Coordinate& c) override;
- void add(const Coordinate& c, bool allowRepeated) override;
+ void add(const Coordinate& c, bool allowRepeated) override;
- /** \brief
- * Inserts the specified coordinate at the specified position in
- * this list.
- * @param i the position at which to insert
- * @param coord the coordinate to insert
- * @param allowRepeated if set to false, repeated coordinates are
- * collapsed
- * NOTE: this is a CoordinateList interface in JTS
- void add(std::size_t i, const Coordinate& coord, bool allowRepeated) override;
+ /** \brief
+ * Inserts the specified coordinate at the specified position in
+ * this list.
+ * @param i the position at which to insert
+ * @param coord the coordinate to insert
+ * @param allowRepeated if set to false, repeated coordinates are
+ * collapsed
+ * NOTE: this is a CoordinateList interface in JTS
+ void add(std::size_t i, const Coordinate& coord, bool allowRepeated) override;
- void setAt(const Coordinate& c, std::size_t pos) override;
+ void setAt(const Coordinate& c, std::size_t pos) override;
- void deleteAt(std::size_t pos) override;
+ void deleteAt(std::size_t pos) override;
- std::string toString() const override;
+ std::string toString() const override;
- void setPoints(const std::vector<Coordinate> &v) override;
+ void setPoints(const std::vector<Coordinate>& v) override;
- double getOrdinate(std::size_t index,
- size_t ordinateIndex) const override;
+ double getOrdinate(std::size_t index,
+ size_t ordinateIndex) const override;
- void setOrdinate(std::size_t index, std::size_t ordinateIndex,
- double value) override;
+ void setOrdinate(std::size_t index, std::size_t ordinateIndex,
+ double value) override;
- void expandEnvelope(Envelope &env) const override;
+ void expandEnvelope(Envelope& env) const override;
std::size_t getDimension() const override;
- void apply_rw(const CoordinateFilter *filter) override;
+ void apply_rw(const CoordinateFilter* filter) override;
- void apply_ro(CoordinateFilter *filter) const override;
+ void apply_ro(CoordinateFilter* filter) const override;
- CoordinateSequence& removeRepeatedPoints() override;
+ CoordinateSequence& removeRepeatedPoints() override;
private:
- std::vector<Coordinate> *vect;
+ std::vector<Coordinate>* vect;
mutable std::size_t dimension;
diff --git a/include/geos/geom/CoordinateArraySequenceFactory.h b/include/geos/geom/CoordinateArraySequenceFactory.h
index 3519480..9bb3abb 100644
--- a/include/geos/geom/CoordinateArraySequenceFactory.h
+++ b/include/geos/geom/CoordinateArraySequenceFactory.h
@@ -25,9 +25,9 @@
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -43,19 +43,19 @@ namespace geom { // geos::geom
class GEOS_DLL CoordinateArraySequenceFactory: public CoordinateSequenceFactory {
public:
- CoordinateSequence *create() const override;
+ CoordinateSequence* create() const override;
- CoordinateSequence *create(std::vector<Coordinate> *coords, std::size_t dims=0) const override;
+ CoordinateSequence* create(std::vector<Coordinate>* coords, std::size_t dims = 0) const override;
- /** @see CoordinateSequenceFactory::create(std::size_t, int) */
- CoordinateSequence *create(std::size_t size, std::size_t dimension=0) const override;
+ /** @see CoordinateSequenceFactory::create(std::size_t, int) */
+ CoordinateSequence* create(std::size_t size, std::size_t dimension = 0) const override;
- CoordinateSequence *create(const CoordinateSequence &coordSeq) const override;
+ CoordinateSequence* create(const CoordinateSequence& coordSeq) const override;
- /** \brief
- * Returns the singleton instance of CoordinateArraySequenceFactory
- static const CoordinateSequenceFactory *instance();
+ /** \brief
+ * Returns the singleton instance of CoordinateArraySequenceFactory
+ static const CoordinateSequenceFactory* instance();
/// This is for backward API compatibility
diff --git a/include/geos/geom/CoordinateArraySequenceFactory.inl b/include/geos/geom/CoordinateArraySequenceFactory.inl
index 5ad0122..39bc0d6 100644
--- a/include/geos/geom/CoordinateArraySequenceFactory.inl
+++ b/include/geos/geom/CoordinateArraySequenceFactory.inl
@@ -7,7 +7,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -22,32 +22,32 @@
namespace geos {
-INLINE CoordinateSequence *
+INLINE CoordinateSequence*
CoordinateArraySequenceFactory::create() const
return new CoordinateArraySequence(
- reinterpret_cast<std::vector<Coordinate>*>(0), 0);
+ reinterpret_cast<std::vector<Coordinate>*>(0), 0);
-CoordinateArraySequenceFactory::create(std::vector<Coordinate> *coords,
- size_t dimension ) const
+CoordinateArraySequenceFactory::create(std::vector<Coordinate>* coords,
+ size_t dimension) const
- return new CoordinateArraySequence(coords,dimension);
+ return new CoordinateArraySequence(coords, dimension);
CoordinateArraySequenceFactory::create(std::size_t size, std::size_t dimension)
- const
+const
- return new CoordinateArraySequence(size,dimension);
+ return new CoordinateArraySequence(size, dimension);
CoordinateArraySequenceFactory::create(const CoordinateSequence& seq)
- const
+const
- return new CoordinateArraySequence(seq);
+ return new CoordinateArraySequence(seq);
diff --git a/include/geos/geom/CoordinateFilter.h b/include/geos/geom/CoordinateFilter.h
index a8b563c..9ea063b 100644
--- a/include/geos/geom/CoordinateFilter.h
+++ b/include/geos/geom/CoordinateFilter.h
@@ -42,21 +42,30 @@ class Coordinate;
class GEOS_DLL CoordinateFilter {
public:
- virtual ~CoordinateFilter() {}
+ virtual
+ ~CoordinateFilter() {}
- * Performs an operation on <code>coord</code>.
- * @param coord a <code>Coordinate</code> to which the filter is applied.
- virtual void filter_rw(Coordinate* /*coord*/) const { assert(0); }
+ * Performs an operation on <code>coord</code>.
+ * @param coord a <code>Coordinate</code> to which the filter is applied.
+ virtual void
+ filter_rw(Coordinate* /*coord*/) const
+ assert(0);
- * Performs an operation with <code>coord</code>.
- virtual void filter_ro(const Coordinate* /*coord*/) { assert(0); }
+ * Performs an operation with <code>coord</code>.
+ virtual void
+ filter_ro(const Coordinate* /*coord*/)
+ assert(0);
diff --git a/include/geos/geom/CoordinateList.h b/include/geos/geom/CoordinateList.h
index b478afb..bb2efc7 100644
--- a/include/geos/geom/CoordinateList.h
+++ b/include/geos/geom/CoordinateList.h
@@ -34,9 +34,9 @@
namespace geos {
- namespace geom {
- //class Coordinate;
+namespace geom {
+//class Coordinate;
@@ -56,137 +56,153 @@ class GEOS_DLL CoordinateList {
public:
- typedef std::list<Coordinate>::iterator iterator;
- typedef std::list<Coordinate>::const_iterator const_iterator;
- friend std::ostream& operator<< (std::ostream& os,
- const CoordinateList& cl);
- /** \brief
- * Constructs a new list from an array of Coordinates, allowing
- * repeated points.
- * (I.e. this constructor produces a {@link CoordinateList} with
- * exactly the same set of points as the input array.)
- * @param v the initial coordinates
- CoordinateList(const std::vector<Coordinate>& v)
- coords(v.begin(), v.end())
- CoordinateList()
- coords()
- size_t size() const
- return coords.size();
- return coords.empty();
- iterator begin()
- return coords.begin();
- iterator end()
- return coords.end();
- const_iterator begin() const
- const_iterator end() const
- /** \brief
- * Inserts the specified coordinate at the specified position in this list.
- * @param pos the position at which to insert
- * @param allowRepeated if set to false, repeated coordinates are collapsed
- * @return an iterator to the newly installed coordinate
- * (or previous, if equal and repeated are not allowed)
- * NOTE: when allowRepeated is false _next_ point is not checked
- * this matches JTS behavior
- iterator insert(iterator pos, const Coordinate& c, bool allowRepeated)
- if ( !allowRepeated && pos != coords.begin() ) {
- iterator prev = pos; --prev;
- if ( c.equals2D(*prev) ) return prev;
- return coords.insert(pos, c);
- iterator insert(iterator pos, const Coordinate& c)
- iterator erase(iterator pos)
- return coords.erase(pos);
- iterator erase(iterator first, iterator last)
- return coords.erase(first, last);
- std::unique_ptr<Coordinate::Vect> toCoordinateArray() const
- std::unique_ptr<Coordinate::Vect> ret(new Coordinate::Vect);
- ret->assign(coords.begin(), coords.end());
- return ret;
- void closeRing()
- if(!coords.empty() && ! (*(coords.begin())).equals(*(coords.rbegin())))
- const Coordinate &c = *(coords.begin());
- coords.insert(coords.end(),c);
+ typedef std::list<Coordinate>::iterator iterator;
+ typedef std::list<Coordinate>::const_iterator const_iterator;
+ friend std::ostream& operator<< (std::ostream& os,
+ const CoordinateList& cl);
+ /** \brief
+ * Constructs a new list from an array of Coordinates, allowing
+ * repeated points.
+ * (I.e. this constructor produces a {@link CoordinateList} with
+ * exactly the same set of points as the input array.)
+ * @param v the initial coordinates
+ CoordinateList(const std::vector<Coordinate>& v)
+ coords(v.begin(), v.end())
+ CoordinateList()
+ coords()
+ size_t
+ size() const
+ return coords.size();
+ bool
+ empty() const
+ return coords.empty();
+ iterator
+ begin()
+ return coords.begin();
+ iterator
+ end()
+ return coords.end();
+ const_iterator
+ begin() const
+ const_iterator
+ end() const
+ /** \brief
+ * Inserts the specified coordinate at the specified position in this list.
+ * @param pos the position at which to insert
+ * @param allowRepeated if set to false, repeated coordinates are collapsed
+ * @return an iterator to the newly installed coordinate
+ * (or previous, if equal and repeated are not allowed)
+ * NOTE: when allowRepeated is false _next_ point is not checked
+ * this matches JTS behavior
+ iterator
+ insert(iterator pos, const Coordinate& c, bool allowRepeated)
+ if(!allowRepeated && pos != coords.begin()) {
+ iterator prev = pos;
+ --prev;
+ if(c.equals2D(*prev)) {
+ return prev;
+ return coords.insert(pos, c);
+ iterator
+ insert(iterator pos, const Coordinate& c)
+ iterator
+ erase(iterator pos)
+ return coords.erase(pos);
+ iterator
+ erase(iterator first, iterator last)
+ return coords.erase(first, last);
+ std::unique_ptr<Coordinate::Vect>
+ toCoordinateArray() const
+ std::unique_ptr<Coordinate::Vect> ret(new Coordinate::Vect);
+ ret->assign(coords.begin(), coords.end());
+ return ret;
+ void
+ closeRing()
+ if(!coords.empty() && !(*(coords.begin())).equals(*(coords.rbegin()))) {
+ const Coordinate& c = *(coords.begin());
+ coords.insert(coords.end(), c);
private:
- std::list<Coordinate> coords;
+ std::list<Coordinate> coords;
inline
-std::ostream& operator<< (std::ostream& os, const CoordinateList& cl)
+std::ostream&
+operator<< (std::ostream& os, const CoordinateList& cl)
- os << "(";
- for (CoordinateList::const_iterator
- it=cl.begin(), end=cl.end();
- it != end;
- ++it)
- const Coordinate& c = *it;
- if ( it != cl.begin() ) os << ", ";
- os << c;
- os << ")";
- return os;
+ os << "(";
+ for(CoordinateList::const_iterator
+ it = cl.begin(), end = cl.end();
+ it != end;
+ ++it) {
+ const Coordinate& c = *it;
+ if(it != cl.begin()) {
+ os << ", ";
+ os << c;
+ os << ")";
+ return os;
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index 30e5491..54654d8 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -26,11 +26,11 @@
namespace geos {
- namespace geom {
- class Envelope;
- class CoordinateFilter;
- class Coordinate;
+namespace geom {
+class Envelope;
+class CoordinateFilter;
+class Coordinate;
namespace geos {
@@ -59,325 +59,344 @@ class GEOS_DLL CoordinateSequence {
protected:
- CoordinateSequence() {}
+ CoordinateSequence() {}
- CoordinateSequence(const CoordinateSequence&) {}
+ CoordinateSequence(const CoordinateSequence&) {}
public:
- typedef std::unique_ptr<CoordinateSequence> Ptr;
- virtual ~CoordinateSequence() {}
- /** \brief
- * Returns a deep copy of this collection.
- virtual CoordinateSequence *clone() const=0;
- /** \brief
- * Returns a read-only reference to Coordinate at position i.
- * Whether or not the Coordinate returned is the actual underlying
- * Coordinate or merely a copy depends on the implementation.
- //virtual const Coordinate& getCoordinate(int i) const=0;
- virtual const Coordinate& getAt(std::size_t i) const=0;
- /// Return last Coordinate in the sequence
- const Coordinate& back() const {
- return getAt(size()-1);
- /// Return first Coordinate in the sequence
- const Coordinate& front() const {
- return getAt(0);
- const Coordinate& operator[] (std::size_t i) const {
- return getAt(i);
- /** \brief
- * Write Coordinate at position i to given Coordinate.
- virtual void getAt(std::size_t i, Coordinate& c) const=0;
- /** \brief
- * Returns the number of Coordinates (actual or otherwise, as
- * this implementation may not store its data in Coordinate objects).
- //virtual int size() const=0;
- virtual std::size_t getSize() const=0;
- size_t size() const { return getSize(); }
- /** \brief
- * Returns a read-only vector with the Coordinates in this collection.
- * Whether or not the Coordinates returned are the actual underlying
- * Coordinates or merely copies depends on the implementation.
- * Note that if this implementation does not store its data as an
- * array of Coordinates, this method will incur a performance penalty
- * because the array needs to be built from scratch.
- * This method is a port of the toCoordinateArray() method of JTS.
- * It is not much used as memory management requires us to
- * know wheter we should or not delete the returned object
- * in a consistent way. Our options are: use shared_ptr<Coordinate>
- * or always keep ownerhips of an eventual newly created vector.
- * We opted for the second, so the returned object is a const, to
- * also ensure that returning an internal pointer doesn't make
- * the object mutable.
- * @deprecated use toVector(std::vector<Coordinate>&) instead
- virtual const std::vector<Coordinate>* toVector() const=0;
- /// Pushes all Coordinates of this sequence onto the provided vector.
- /// This method is a port of the toCoordinateArray() method of JTS.
- virtual void toVector(std::vector<Coordinate>& coords) const=0;
- * \brief Add an array of coordinates
- * @param vc The coordinates
- * are collapsed
- * @return true (as by general collection contract)
- void add(const std::vector<Coordinate>* vc, bool allowRepeated);
- /* This is here for backward compatibility.. */
- //void add(CoordinateSequence *cl,bool allowRepeated,bool direction);
- /** \brief
- * Add an array of coordinates
- * @param cl The coordinates
- * if set to false, repeated coordinates are collapsed
- * @param direction if false, the array is added in reverse order
- void add(const CoordinateSequence *cl, bool allowRepeated,
- bool direction);
- * \brief Add a coordinate
- * @param c The coordinate to add
- * are collapsed
- virtual void add(const Coordinate& c, bool allowRepeated);
- /** \brief
- * this list.
- * collapsed
- virtual void add(std::size_t i, const Coordinate& coord, bool allowRepeated)=0;
- /// Returns <code>true</code> it list contains no coordinates.
- virtual bool isEmpty() const=0;
- /// Add a Coordinate to the list
- virtual void add(const Coordinate& c)=0;
- // Get number of coordinates
- //virtual int getSize() const=0;
- /// Get a reference to Coordinate at position pos
- //virtual const Coordinate& getAt(std::size_t pos) const=0;
- /// Copy Coordinate c to position pos
- virtual void setAt(const Coordinate& c, std::size_t pos)=0;
- /// Delete Coordinate at position pos (list will shrink).
- virtual void deleteAt(std::size_t pos)=0;
- /// Get a string rapresentation of CoordinateSequence
- virtual std::string toString() const=0;
- /// Substitute Coordinate list with a copy of the given vector
- virtual void setPoints(const std::vector<Coordinate> &v)=0;
- /// Returns true if contains any two consecutive points
- bool hasRepeatedPoints() const;
- /// Returns lower-left Coordinate in list
- const Coordinate* minCoordinate() const;
- /// \brief
- /// Returns a new CoordinateSequence being a copy of the input
- /// with any consecutive equal Coordinate removed.
- /// Equality test is 2D based
- /// Ownership of returned object goes to the caller.
- static CoordinateSequence* removeRepeatedPoints(
- const CoordinateSequence *cl);
- /// Remove consecutive equal Coordinates from the sequence
- /// Equality test is 2D based. Returns a reference to self.
- virtual CoordinateSequence& removeRepeatedPoints()=0;
- /** \brief
- * Returns true if given CoordinateSequence contains
- * any two consecutive Coordinate
- static bool hasRepeatedPoints(const CoordinateSequence *cl);
- /** \brief
- * Returns either the given CoordinateSequence if its length
- * is greater than the given amount, or an empty CoordinateSequence.
- static CoordinateSequence* atLeastNCoordinatesOrNothing(std::size_t n,
- CoordinateSequence *c);
- /** \brief
- * Returns lower-left Coordinate in given CoordinateSequence.
- * This is actually the Coordinate with lower X (and Y if needed)
- * ordinate.
- static const Coordinate* minCoordinate(CoordinateSequence *cl);
- /// Return position of a Coordinate, or -1 if not found
- /// FIXME: return std::size_t, using numeric_limits<std::size_t>::max
- /// as 'not found' value.
- static size_t indexOf(const Coordinate *coordinate,
- * \brief
- * Returns true if the two arrays are identical, both null,
- * or pointwise equal
- static bool equals(const CoordinateSequence *cl1,
- const CoordinateSequence *cl2);
- /// Scroll given CoordinateSequence so to start with given Coordinate.
- static void scroll(CoordinateSequence *cl, const Coordinate *firstCoordinate);
- /** \brief
- * Determines which orientation of the {@link Coordinate} array
- * is (overall) increasing.
- * In other words, determines which end of the array is "smaller"
- * (using the standard ordering on {@link Coordinate}).
- * Returns an integer indicating the increasing direction.
- * If the sequence is a palindrome, it is defined to be
- * oriented in a positive direction.
- * @param pts the array of Coordinates to test
- * @return <code>1</code> if the array is smaller at the start
- * or is a palindrome,
- * <code>-1</code> if smaller at the end
- * NOTE: this method is found in CoordinateArrays class for JTS
- static int increasingDirection(const CoordinateSequence& pts);
- /// Reverse Coordinate order in given CoordinateSequence
- static void reverse(CoordinateSequence *cl);
- /// Standard ordinate index values
- enum { X,Y,Z,M };
- * Returns the dimension (number of ordinates in each coordinate)
- * for this sequence.
- * @return the dimension of the sequence.
- virtual std::size_t getDimension() const=0;
- * Returns the ordinate of a coordinate in this sequence.
- * Ordinate indices 0 and 1 are assumed to be X and Y.
- * Ordinates indices greater than 1 have user-defined semantics
- * (for instance, they may contain other dimensions or measure values).
- * @param index the coordinate index in the sequence
- * @param ordinateIndex the ordinate index in the coordinate
- * (in range [0, dimension-1])
- virtual double getOrdinate(std::size_t index, std::size_t ordinateIndex) const=0;
- * Returns ordinate X (0) of the specified coordinate.
- * @param index
- * @return the value of the X ordinate in the index'th coordinate
- virtual double getX(std::size_t index) const { return getOrdinate(index, X); }
- * Returns ordinate Y (1) of the specified coordinate.
- * @param index
- * @return the value of the Y ordinate in the index'th coordinate
- virtual double getY(std::size_t index) const { return getOrdinate(index, Y); }
- * Sets the value for a given ordinate of a coordinate in this sequence.
- * @param value the new ordinate value
- virtual void setOrdinate(std::size_t index, std::size_t ordinateIndex, double value)=0;
- * Expands the given Envelope to include the coordinates in the
- * sequence.
- * Allows implementing classes to optimize access to coordinate values.
- * @param env the envelope to expand
- virtual void expandEnvelope(Envelope &env) const;
- virtual void apply_rw(const CoordinateFilter *filter)=0; //Abstract
- virtual void apply_ro(CoordinateFilter *filter) const=0; //Abstract
- /** \brief
- * Apply a fiter to each Coordinate of this sequence.
- * The filter is expected to provide a .filter(Coordinate&)
- * method.
- * TODO: accept a Functor instead, will be more flexible.
- * actually, define iterators on Geometry
- template <class T>
- void applyCoordinateFilter(T& f)
- Coordinate c;
- for(std::size_t i=0, n=size(); i<n; ++i)
- getAt(i, c);
- f.filter(c);
- setAt(c, i);
+ typedef std::unique_ptr<CoordinateSequence> Ptr;
+ virtual
+ ~CoordinateSequence() {}
+ /** \brief
+ * Returns a deep copy of this collection.
+ virtual CoordinateSequence* clone() const = 0;
+ /** \brief
+ * Returns a read-only reference to Coordinate at position i.
+ * Whether or not the Coordinate returned is the actual underlying
+ * Coordinate or merely a copy depends on the implementation.
+ //virtual const Coordinate& getCoordinate(int i) const=0;
+ virtual const Coordinate& getAt(std::size_t i) const = 0;
+ /// Return last Coordinate in the sequence
+ const Coordinate&
+ back() const
+ return getAt(size() - 1);
+ /// Return first Coordinate in the sequence
+ const Coordinate&
+ front() const
+ return getAt(0);
+ const Coordinate&
+ operator[](std::size_t i) const
+ return getAt(i);
+ /** \brief
+ * Write Coordinate at position i to given Coordinate.
+ virtual void getAt(std::size_t i, Coordinate& c) const = 0;
+ /** \brief
+ * Returns the number of Coordinates (actual or otherwise, as
+ * this implementation may not store its data in Coordinate objects).
+ //virtual int size() const=0;
+ virtual std::size_t getSize() const = 0;
+ size_t
+ size() const
+ return getSize();
+ /** \brief
+ * Returns a read-only vector with the Coordinates in this collection.
+ * Whether or not the Coordinates returned are the actual underlying
+ * Coordinates or merely copies depends on the implementation.
+ * Note that if this implementation does not store its data as an
+ * array of Coordinates, this method will incur a performance penalty
+ * because the array needs to be built from scratch.
+ * This method is a port of the toCoordinateArray() method of JTS.
+ * It is not much used as memory management requires us to
+ * know wheter we should or not delete the returned object
+ * in a consistent way. Our options are: use shared_ptr<Coordinate>
+ * or always keep ownerhips of an eventual newly created vector.
+ * We opted for the second, so the returned object is a const, to
+ * also ensure that returning an internal pointer doesn't make
+ * the object mutable.
+ * @deprecated use toVector(std::vector<Coordinate>&) instead
+ virtual const std::vector<Coordinate>* toVector() const = 0;
+ /// Pushes all Coordinates of this sequence onto the provided vector.
+ /// This method is a port of the toCoordinateArray() method of JTS.
+ virtual void toVector(std::vector<Coordinate>& coords) const = 0;
+ * \brief Add an array of coordinates
+ * @param vc The coordinates
+ * are collapsed
+ * @return true (as by general collection contract)
+ void add(const std::vector<Coordinate>* vc, bool allowRepeated);
+ /* This is here for backward compatibility.. */
+ //void add(CoordinateSequence *cl,bool allowRepeated,bool direction);
+ /** \brief
+ * Add an array of coordinates
+ * @param cl The coordinates
+ * if set to false, repeated coordinates are collapsed
+ * @param direction if false, the array is added in reverse order
+ void add(const CoordinateSequence* cl, bool allowRepeated,
+ bool direction);
+ * \brief Add a coordinate
+ * @param c The coordinate to add
+ * are collapsed
+ virtual void add(const Coordinate& c, bool allowRepeated);
+ /** \brief
+ * this list.
+ * collapsed
+ virtual void add(std::size_t i, const Coordinate& coord, bool allowRepeated) = 0;
+ /// Returns <code>true</code> it list contains no coordinates.
+ virtual bool isEmpty() const = 0;
+ /// Add a Coordinate to the list
+ virtual void add(const Coordinate& c) = 0;
+ // Get number of coordinates
+ //virtual int getSize() const=0;
+ /// Get a reference to Coordinate at position pos
+ //virtual const Coordinate& getAt(std::size_t pos) const=0;
+ /// Copy Coordinate c to position pos
+ virtual void setAt(const Coordinate& c, std::size_t pos) = 0;
+ /// Delete Coordinate at position pos (list will shrink).
+ virtual void deleteAt(std::size_t pos) = 0;
+ /// Get a string rapresentation of CoordinateSequence
+ virtual std::string toString() const = 0;
+ /// Substitute Coordinate list with a copy of the given vector
+ virtual void setPoints(const std::vector<Coordinate>& v) = 0;
+ /// Returns true if contains any two consecutive points
+ bool hasRepeatedPoints() const;
+ /// Returns lower-left Coordinate in list
+ const Coordinate* minCoordinate() const;
+ /// \brief
+ /// Returns a new CoordinateSequence being a copy of the input
+ /// with any consecutive equal Coordinate removed.
+ /// Equality test is 2D based
+ /// Ownership of returned object goes to the caller.
+ static CoordinateSequence* removeRepeatedPoints(
+ const CoordinateSequence* cl);
+ /// Remove consecutive equal Coordinates from the sequence
+ /// Equality test is 2D based. Returns a reference to self.
+ virtual CoordinateSequence& removeRepeatedPoints() = 0;
+ /** \brief
+ * Returns true if given CoordinateSequence contains
+ * any two consecutive Coordinate
+ static bool hasRepeatedPoints(const CoordinateSequence* cl);
+ /** \brief
+ * Returns either the given CoordinateSequence if its length
+ * is greater than the given amount, or an empty CoordinateSequence.
+ static CoordinateSequence* atLeastNCoordinatesOrNothing(std::size_t n,
+ CoordinateSequence* c);
+ /** \brief
+ * Returns lower-left Coordinate in given CoordinateSequence.
+ * This is actually the Coordinate with lower X (and Y if needed)
+ * ordinate.
+ static const Coordinate* minCoordinate(CoordinateSequence* cl);
+ /// Return position of a Coordinate, or -1 if not found
+ /// FIXME: return std::size_t, using numeric_limits<std::size_t>::max
+ /// as 'not found' value.
+ static size_t indexOf(const Coordinate* coordinate,
+ * \brief
+ * Returns true if the two arrays are identical, both null,
+ * or pointwise equal
+ static bool equals(const CoordinateSequence* cl1,
+ const CoordinateSequence* cl2);
+ /// Scroll given CoordinateSequence so to start with given Coordinate.
+ static void scroll(CoordinateSequence* cl, const Coordinate* firstCoordinate);
+ /** \brief
+ * Determines which orientation of the {@link Coordinate} array
+ * is (overall) increasing.
+ * In other words, determines which end of the array is "smaller"
+ * (using the standard ordering on {@link Coordinate}).
+ * Returns an integer indicating the increasing direction.
+ * If the sequence is a palindrome, it is defined to be
+ * oriented in a positive direction.
+ * @param pts the array of Coordinates to test
+ * @return <code>1</code> if the array is smaller at the start
+ * or is a palindrome,
+ * <code>-1</code> if smaller at the end
+ * NOTE: this method is found in CoordinateArrays class for JTS
+ static int increasingDirection(const CoordinateSequence& pts);
+ /// Reverse Coordinate order in given CoordinateSequence
+ static void reverse(CoordinateSequence* cl);
+ /// Standard ordinate index values
+ enum { X, Y, Z, M };
+ * Returns the dimension (number of ordinates in each coordinate)
+ * for this sequence.
+ * @return the dimension of the sequence.
+ virtual std::size_t getDimension() const = 0;
+ * Returns the ordinate of a coordinate in this sequence.
+ * Ordinate indices 0 and 1 are assumed to be X and Y.
+ * Ordinates indices greater than 1 have user-defined semantics
+ * (for instance, they may contain other dimensions or measure values).
+ * @param index the coordinate index in the sequence
+ * @param ordinateIndex the ordinate index in the coordinate
+ * (in range [0, dimension-1])
+ virtual double getOrdinate(std::size_t index, std::size_t ordinateIndex) const = 0;
+ * Returns ordinate X (0) of the specified coordinate.
+ * @param index
+ * @return the value of the X ordinate in the index'th coordinate
+ virtual double
+ getX(std::size_t index) const
+ return getOrdinate(index, X);
+ * Returns ordinate Y (1) of the specified coordinate.
+ * @param index
+ * @return the value of the Y ordinate in the index'th coordinate
+ virtual double
+ getY(std::size_t index) const
+ return getOrdinate(index, Y);
+ * Sets the value for a given ordinate of a coordinate in this sequence.
+ * @param value the new ordinate value
+ virtual void setOrdinate(std::size_t index, std::size_t ordinateIndex, double value) = 0;
+ * Expands the given Envelope to include the coordinates in the
+ * sequence.
+ * Allows implementing classes to optimize access to coordinate values.
+ * @param env the envelope to expand
+ virtual void expandEnvelope(Envelope& env) const;
+ virtual void apply_rw(const CoordinateFilter* filter) = 0; //Abstract
+ virtual void apply_ro(CoordinateFilter* filter) const = 0; //Abstract
+ /** \brief
+ * Apply a fiter to each Coordinate of this sequence.
+ * The filter is expected to provide a .filter(Coordinate&)
+ * method.
+ * TODO: accept a Functor instead, will be more flexible.
+ * actually, define iterators on Geometry
+ template <class T>
+ void
+ applyCoordinateFilter(T& f)
+ Coordinate c;
+ for(std::size_t i = 0, n = size(); i < n; ++i) {
+ getAt(i, c);
+ f.filter(c);
+ setAt(c, i);
diff --git a/include/geos/geom/CoordinateSequenceFactory.h b/include/geos/geom/CoordinateSequenceFactory.h
index 85b5e5b..273e6a8 100644
--- a/include/geos/geom/CoordinateSequenceFactory.h
+++ b/include/geos/geom/CoordinateSequenceFactory.h
@@ -28,10 +28,10 @@
namespace geos {
- namespace geom {
- class CoordinateSequence;
- class Coordinate;
+namespace geom {
+class CoordinateSequence;
+class Coordinate;
namespace geos {
@@ -47,54 +47,54 @@ namespace geom { // geos::geom
class GEOS_DLL CoordinateSequenceFactory {
public:
- /** \brief
- * Returns an empty CoordinateSequence, the dimensions will be autodetected
- * when it is populated.
- virtual CoordinateSequence *create() const=0;
+ /** \brief
+ * Returns an empty CoordinateSequence, the dimensions will be autodetected
+ * when it is populated.
+ virtual CoordinateSequence* create() const = 0;
- /** \brief
- * Returns a CoordinateSequence based on the given array.
- * Whether the array is copied or simply referenced
- * is implementation-dependent.
- * For this reason caller does give up ownership of it.
- * Implementations that will not copy it will need take care
- * of deleting it.
- * This method must handle null arguments by creating
- * an empty sequence.
- * @param coordinates the coordinates
+ /** \brief
+ * Returns a CoordinateSequence based on the given array.
+ * Whether the array is copied or simply referenced
+ * is implementation-dependent.
+ * For this reason caller does give up ownership of it.
+ * Implementations that will not copy it will need take care
+ * of deleting it.
+ * This method must handle null arguments by creating
+ * an empty sequence.
+ * @param coordinates the coordinates
* @param dimension 0, 2 or 3 with 0 indicating unknown at this time.
- std::vector<Coordinate> *coordinates,
- std::size_t dimension=0 ) const=0;
+ std::vector<Coordinate>* coordinates,
+ std::size_t dimension = 0) const = 0;
- /** \brief
- * Creates a CoordinateSequence of the specified size and dimension.
- * For this to be useful, the CoordinateSequence implementation must
- * be mutable.
- * @param size the number of coordinates in the sequence
- * @param dimension the dimension of the coordinates in the sequence
- * (0=unknown, 2, or 3 - ignored if not user specifiable)
- virtual CoordinateSequence *create(std::size_t size,
- std::size_t dimension=0) const=0;
+ /** \brief
+ * Creates a CoordinateSequence of the specified size and dimension.
+ * For this to be useful, the CoordinateSequence implementation must
+ * be mutable.
+ * @param size the number of coordinates in the sequence
+ * @param dimension the dimension of the coordinates in the sequence
+ * (0=unknown, 2, or 3 - ignored if not user specifiable)
+ virtual CoordinateSequence* create(std::size_t size,
- /** \brief
- * Creates a CoordinateSequence which is a copy of the given one.
- * This method must handle null arguments by creating an empty sequence.
- * @param coordSeq the coordinate sequence to copy
- virtual CoordinateSequence *create(const CoordinateSequence &coordSeq) const=0;
+ /** \brief
+ * Creates a CoordinateSequence which is a copy of the given one.
+ * This method must handle null arguments by creating an empty sequence.
+ * @param coordSeq the coordinate sequence to copy
+ virtual CoordinateSequence* create(const CoordinateSequence& coordSeq) const = 0;
- virtual ~CoordinateSequenceFactory();
+ virtual ~CoordinateSequenceFactory();
diff --git a/include/geos/geom/CoordinateSequenceFilter.h b/include/geos/geom/CoordinateSequenceFilter.h
index c778fd8..0741328 100644
--- a/include/geos/geom/CoordinateSequenceFilter.h
+++ b/include/geos/geom/CoordinateSequenceFilter.h
@@ -26,9 +26,9 @@
namespace geos {
- namespace geom {
+namespace geom {
namespace geos {
@@ -59,50 +59,57 @@ class GEOS_DLL CoordinateSequenceFilter {
public:
- virtual ~CoordinateSequenceFilter() {}
- * Performs an operation on a coordinate in a {@link CoordinateSequence}.
- * @param seq the <code>CoordinateSequence</code> to which the filter
- * is applied
- * @param i the index of the coordinate to apply the filter to
- virtual void filter_rw(CoordinateSequence& /*seq*/, std::size_t /*i*/)
- { assert(0); }
- * is applied
- virtual void filter_ro(const CoordinateSequence& /*seq*/, std::size_t /*i*/)
- { assert(0); }
- * Reports whether the application of this filter can be terminated.
- * Once this method returns <tt>false</tt>, it should
- * continue to return <tt>false</tt> on every subsequent call.
- * @return true if the application of this filter can be terminated.
- virtual bool isDone() const = 0;
- * Reports whether the execution of this filter
- * has modified the coordinates of the geometry.
- * If so, {@link Geometry#geometryChanged} will be executed
- * after this filter has finished being executed.
- * Most filters can simply return a constant value reflecting
- * whether they are able to change the coordinates.
- * @return true if this filter has changed the coordinates of the geometry
- virtual bool isGeometryChanged() const = 0;
+ virtual
+ ~CoordinateSequenceFilter() {}
+ * Performs an operation on a coordinate in a {@link CoordinateSequence}.
+ * @param seq the <code>CoordinateSequence</code> to which the filter
+ * is applied
+ * @param i the index of the coordinate to apply the filter to
+ virtual void
+ filter_rw(CoordinateSequence& /*seq*/, std::size_t /*i*/)
+ assert(0);
+ * is applied
+ virtual void
+ filter_ro(const CoordinateSequence& /*seq*/, std::size_t /*i*/)
+ assert(0);
+ * Reports whether the application of this filter can be terminated.
+ * Once this method returns <tt>false</tt>, it should
+ * continue to return <tt>false</tt> on every subsequent call.
+ * @return true if the application of this filter can be terminated.
+ virtual bool isDone() const = 0;
+ * Reports whether the execution of this filter
+ * has modified the coordinates of the geometry.
+ * If so, {@link Geometry#geometryChanged} will be executed
+ * after this filter has finished being executed.
+ * Most filters can simply return a constant value reflecting
+ * whether they are able to change the coordinates.
+ * @return true if this filter has changed the coordinates of the geometry
+ virtual bool isGeometryChanged() const = 0;
diff --git a/include/geos/geom/Dimension.h b/include/geos/geom/Dimension.h
index b501522..0cf0dd8 100644
--- a/include/geos/geom/Dimension.h
+++ b/include/geos/geom/Dimension.h
@@ -28,35 +28,35 @@ namespace geom { // geos::geom
class GEOS_DLL Dimension {
public:
- enum DimensionType {
- /// Dimension value for any dimension (= {FALSE, TRUE}).
- DONTCARE=-3,
+ enum DimensionType {
+ /// Dimension value for any dimension (= {FALSE, TRUE}).
+ DONTCARE = -3,
- /// Dimension value of non-empty geometries (= {P, L, A}).
- True=-2,
+ /// Dimension value of non-empty geometries (= {P, L, A}).
+ True = -2,
- /// Dimension value of the empty geometry (-1).
- False=-1,
+ /// Dimension value of the empty geometry (-1).
+ False = -1,
- /// Dimension value of a point (0).
- P=0,
+ /// Dimension value of a point (0).
+ P = 0,
- /// Dimension value of a curve (1).
- L=1,
+ /// Dimension value of a curve (1).
+ L = 1,
- /// Dimension value of a surface (2).
- A=2
+ /// Dimension value of a surface (2).
+ A = 2
- //static const int P = 0; /// Dimension value of a point (0).
- //static const int L = 1; /// Dimension value of a curve (1).
- //static const int A = 2; /// Dimension value of a surface (2).
- //static const int False = -1; /// Dimension value of the empty geometry (-1).
- //static const int True = -2; /// Dimension value of non-empty geometries (= {P, L, A}).
- //static const int DONTCARE = -3; /// Dimension value for any dimension (= {FALSE, TRUE}).
- static char toDimensionSymbol(int dimensionValue);
+ //static const int P = 0; /// Dimension value of a point (0).
+ //static const int L = 1; /// Dimension value of a curve (1).
+ //static const int A = 2; /// Dimension value of a surface (2).
+ //static const int False = -1; /// Dimension value of the empty geometry (-1).
+ //static const int True = -2; /// Dimension value of non-empty geometries (= {P, L, A}).
+ //static const int DONTCARE = -3; /// Dimension value for any dimension (= {FALSE, TRUE}).
+ static char toDimensionSymbol(int dimensionValue);
- static int toDimensionValue(char dimensionSymbol);
+ static int toDimensionValue(char dimensionSymbol);
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 19821f9..d7de720 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -60,81 +60,81 @@ class GEOS_DLL Envelope {
public:
- friend std::ostream& operator<< (std::ostream& os, const Envelope& o);
- typedef std::unique_ptr<Envelope> Ptr;
- /** \brief
- * Creates a null <code>Envelope</code>.
- Envelope(void);
- /** \brief
- * Creates an <code>Envelope</code> for a region defined by
- * maximum and minimum values.
- * @param x1 the first x-value
- * @param x2 the second x-value
- * @param y1 the first y-value
- * @param y2 the second y-value
- Envelope(double x1, double x2, double y1, double y2);
- /** \brief
- * two Coordinates.
- * @param p1 the first Coordinate
- * @param p2 the second Coordinate
- Envelope(const Coordinate& p1, const Coordinate& p2);
- /** \brief
- * Creates an Envelope for a region defined by a single Coordinate.
- * @param p the Coordinate
- Envelope(const Coordinate& p);
- /// Copy constructor
- Envelope(const Envelope &env);
- /// Assignment operator
- Envelope& operator=(const Envelope& e);
- /** \brief
- * Create an <code>Envelope</code> from an Envelope
- * string representation produced by Envelope.toString()
- Envelope(const std::string &str);
- ~Envelope(void);
- /** \brief
- * Test the point q to see whether it intersects the
- * Envelope defined by p1-p2
- * @param p1 one extremal point of the envelope
- * @param p2 another extremal point of the envelope
- * @param q the point to test for intersection
- * @return <code>true</code> if q intersects the envelope p1-p2
- static bool intersects(const Coordinate& p1, const Coordinate& p2,
- const Coordinate& q);
- /** \brief
- * Test the envelope defined by p1-p2 for intersection
- * with the envelope defined by q1-q2
- * @param p1 one extremal point of the envelope P
- * @param p2 another extremal point of the envelope P
- * @param q1 one extremal point of the envelope Q
- * @param q2 another extremal point of the envelope Q
- * @return <code>true</code> if Q intersects P
- const Coordinate& q1, const Coordinate& q2);
+ friend std::ostream& operator<< (std::ostream& os, const Envelope& o);
+ typedef std::unique_ptr<Envelope> Ptr;
+ /** \brief
+ * Creates a null <code>Envelope</code>.
+ Envelope(void);
+ /** \brief
+ * Creates an <code>Envelope</code> for a region defined by
+ * maximum and minimum values.
+ * @param x1 the first x-value
+ * @param x2 the second x-value
+ * @param y1 the first y-value
+ * @param y2 the second y-value
+ Envelope(double x1, double x2, double y1, double y2);
+ /** \brief
+ * two Coordinates.
+ * @param p1 the first Coordinate
+ * @param p2 the second Coordinate
+ Envelope(const Coordinate& p1, const Coordinate& p2);
+ /** \brief
+ * Creates an Envelope for a region defined by a single Coordinate.
+ * @param p the Coordinate
+ Envelope(const Coordinate& p);
+ /// Copy constructor
+ Envelope(const Envelope& env);
+ /// Assignment operator
+ Envelope& operator=(const Envelope& e);
+ /** \brief
+ * Create an <code>Envelope</code> from an Envelope
+ * string representation produced by Envelope.toString()
+ Envelope(const std::string& str);
+ ~Envelope(void);
+ /** \brief
+ * Test the point q to see whether it intersects the
+ * Envelope defined by p1-p2
+ * @param p1 one extremal point of the envelope
+ * @param p2 another extremal point of the envelope
+ * @param q the point to test for intersection
+ * @return <code>true</code> if q intersects the envelope p1-p2
+ static bool intersects(const Coordinate& p1, const Coordinate& p2,
+ const Coordinate& q);
+ /** \brief
+ * Test the envelope defined by p1-p2 for intersection
+ * with the envelope defined by q1-q2
+ * @param p1 one extremal point of the envelope P
+ * @param p2 another extremal point of the envelope P
+ * @param q1 one extremal point of the envelope Q
+ * @param q2 another extremal point of the envelope Q
+ * @return <code>true</code> if Q intersects P
+ const Coordinate& q1, const Coordinate& q2);
* Check if the extent defined by two extremal points
@@ -146,363 +146,378 @@ public:
bool intersects(const Coordinate& a, const Coordinate& b) const;
- /** \brief
- * Initialize to a null <code>Envelope</code>.
- void init(void);
- /** \brief
- * Initialize an <code>Envelope</code> for a region defined by
- void init(double x1, double x2, double y1, double y2);
- /** \brief
- * Initialize an <code>Envelope</code> to a region defined
- * by two Coordinates.
- void init(const Coordinate& p1, const Coordinate& p2);
- /** \brief
- * by a single Coordinate.
- void init(const Coordinate& p);
- // use assignment operator instead
- //void init(Envelope env);
- /** \brief
- * Makes this <code>Envelope</code> a "null" envelope,
- * that is, the envelope of the empty geometry.
- void setToNull(void);
- /** \brief
- * Returns <code>true</code> if this <code>Envelope</code>
- * is a "null" envelope.
- * @return <code>true</code> if this <code>Envelope</code>
- * is uninitialized or is the envelope of the
- * empty geometry.
- bool isNull(void) const;
- /** \brief
- * Returns the difference between the maximum and minimum x values.
- * @return max x - min x, or 0 if this is a null Envelope
- double getWidth(void) const;
- /** \brief
- * Returns the difference between the maximum and minimum y values.
- * @return max y - min y, or 0 if this is a null Envelope
- double getHeight(void) const;
- * Gets the area of this envelope.
- * @return the area of the envelope
- * @return 0.0 if the envelope is null
- double getArea() const
- return getWidth() * getHeight();
- * Returns the Envelope maximum y-value. min y > max y
- * indicates that this is a null Envelope.
- double getMaxY() const;
- * Returns the Envelope maximum x-value. min x > max x
- double getMaxX() const;
- * Returns the Envelope minimum y-value. min y > max y
- double getMinY() const;
- * Returns the Envelope minimum x-value. min x > max x
- double getMinX() const;
- * Computes the coordinate of the centre of this envelope
- * (as long as it is non-null)
- * @param centre The coordinate to write results into
- * @return NULL is the center could not be found
- * (null envelope).
- bool centre(Coordinate& centre) const;
- * Computes the intersection of two {@link Envelopes}
- * @param env the envelope to intersect with
- * @param result the envelope representing the intersection of
- * the envelopes (this will be the null envelope
- * if either argument is null, or they do not intersect)
- * @return false if not intersection is found
- bool intersection(const Envelope& env, Envelope& result) const;
- /** \brief
- * Translates this envelope by given amounts in the X and Y direction.
- * @param transX the amount to translate along the X axis
- * @param transY the amount to translate along the Y axis
- void translate(double transX, double transY);
- /** \brief
- * Expands this envelope by a given distance in all directions.
- * Both positive and negative distances are supported.
- * @param deltaX the distance to expand the envelope along
- * the X axis
- * @param deltaY the distance to expand the envelope along
- * the Y axis
- void expandBy(double deltaX, double deltaY);
- /** \brief
- * @param distance the distance to expand the envelope
- * @return this envelope
- void expandBy(double p_distance) { expandBy(p_distance, p_distance); }
- /** \brief
- * Enlarges the boundary of the Envelope so that it contains
- * p. Does nothing if p is already on or within the boundaries.
- * @param p the Coordinate to include
- void expandToInclude(const Coordinate& p);
- /** \brief
- * (x,y). Does nothing if (x,y) is already on or within the boundaries.
- * @param x the value to lower the minimum x
- * to or to raise the maximum x to
- * @param y the value to lower the minimum y
- * to or to raise the maximum y to
- void expandToInclude(double x, double y);
- /** \brief
- * <code>other</code>. Does nothing if other is wholly on or
- * within the boundaries.
- * @param other the <code>Envelope</code> to merge with
- void expandToInclude(const Envelope* other);
- /** \brief
- * Tests if the <code>Envelope other</code> lies wholely
- * inside this <code>Envelope</code> (inclusive of the boundary).
- * Note that this is <b>not</b> the same definition as the SFS
- * <tt>contains</tt>, which would exclude the envelope boundary.
- * @param other the <code>Envelope</code> to check
- * @return true if <code>other</code> is contained in this
- * <code>Envelope</code>
- * @see covers(Envelope)
- bool contains(const Envelope& other) const {
- return covers(other);
- bool contains(const Envelope* other) const {
- return contains(*other);
- /** \brief
- * Returns <code>true</code> if the given point lies in
- * or on the envelope.
- * @param p the point which this <code>Envelope</code> is
- * being checked for containing
- * @return <code>true</code> if the point lies in the interior or
- * on the boundary of this <code>Envelope</code>.
- bool contains(const Coordinate& p) const {
- return covers(p.x, p.y);
- /** \brief
- * @param x the x-coordinate of the point which this
- * <code>Envelope</code> is
- * @param y the y-coordinate of the point which this
- * <code>Envelope</code> is being checked for containing
- * @return <code>true</code> if <code>(x, y)</code> lies in
- * the interior or on the boundary of this
- * <code>Envelope</code>.
- bool contains(double x, double y) const {
- return covers(x, y);
- * Check if the point p
- * intersects (lies inside) the region of this Envelope.
- * @param p the Coordinate to be tested
- * @return true if the point intersects this Envelope
- bool intersects(const Coordinate& p) const;
- * Check if the point (x, y)
- * @param x the x-ordinate of the point
- * @param y the y-ordinate of the point
- * @return <code>true</code> if the point intersects this Envelope
- bool intersects(double x, double y) const;
- * Check if the region defined by other Envelope
- * intersects (intersects) the region of this Envelope.
- * @param other the Envelope which this Envelope is
- * being checked for intersection
- * @return true if the Envelopes intersects
- bool intersects(const Envelope* other) const;
- bool intersects(const Envelope& other) const;
- * Tests if the given point lies in or on the envelope.
- *@param x the x-coordinate of the point which this <code>Envelope</code> is
- *@param y the y-coordinate of the point which this <code>Envelope</code> is
- *@return <code>true</code> if <code>(x, y)</code> lies in the interior or
- bool covers(double x, double y) const;
- *@param p the point which this <code>Envelope</code> is
- *@return <code>true</code> if the point lies in the interior or
- bool covers(const Coordinate *p) const;
- * Tests if the <code>Envelope other</code> lies wholely inside
- * this <code>Envelope</code> (inclusive of the boundary).
- * @return true if this <code>Envelope</code> covers the
- bool covers(const Envelope& other) const;
- bool covers(const Envelope* other) const {
- return covers(*other);
- /** \brief
- * Returns <code>true</code> if the <code>Envelope other</code>
- * spatially equals this <code>Envelope</code>.
- * @param other the <code>Envelope</code> which this
- * <code>Envelope</code> is being checked for equality
- * @return <code>true</code> if this and <code>other</code>
- * Envelope objs are spatially equal
- bool equals(const Envelope* other) const;
- /** \brief
- * Returns a <code>string</code> of the form
- * <I>Env[minx:maxx,miny:maxy]</I> .
- * @return a <code>string</code> of the form
- std::string toString(void) const;
- /** \brief
- * Computes the distance between this and another
- * The distance between overlapping Envelopes is 0. Otherwise, the
- * distance is the Euclidean distance between the closest points.
- double distance(const Envelope* env) const;
+ /** \brief
+ * Initialize to a null <code>Envelope</code>.
+ void init(void);
+ /** \brief
+ * Initialize an <code>Envelope</code> for a region defined by
+ void init(double x1, double x2, double y1, double y2);
+ /** \brief
+ * Initialize an <code>Envelope</code> to a region defined
+ * by two Coordinates.
+ void init(const Coordinate& p1, const Coordinate& p2);
+ /** \brief
+ * by a single Coordinate.
+ void init(const Coordinate& p);
+ // use assignment operator instead
+ //void init(Envelope env);
+ /** \brief
+ * Makes this <code>Envelope</code> a "null" envelope,
+ * that is, the envelope of the empty geometry.
+ void setToNull(void);
+ /** \brief
+ * Returns <code>true</code> if this <code>Envelope</code>
+ * is a "null" envelope.
+ * @return <code>true</code> if this <code>Envelope</code>
+ * is uninitialized or is the envelope of the
+ * empty geometry.
+ bool isNull(void) const;
+ /** \brief
+ * Returns the difference between the maximum and minimum x values.
+ * @return max x - min x, or 0 if this is a null Envelope
+ double getWidth(void) const;
+ /** \brief
+ * Returns the difference between the maximum and minimum y values.
+ * @return max y - min y, or 0 if this is a null Envelope
+ double getHeight(void) const;
+ * Gets the area of this envelope.
+ * @return the area of the envelope
+ * @return 0.0 if the envelope is null
+ double
+ getArea() const
+ return getWidth() * getHeight();
+ * Returns the Envelope maximum y-value. min y > max y
+ * indicates that this is a null Envelope.
+ double getMaxY() const;
+ * Returns the Envelope maximum x-value. min x > max x
+ double getMaxX() const;
+ * Returns the Envelope minimum y-value. min y > max y
+ double getMinY() const;
+ * Returns the Envelope minimum x-value. min x > max x
+ double getMinX() const;
+ * Computes the coordinate of the centre of this envelope
+ * (as long as it is non-null)
+ * @param centre The coordinate to write results into
+ * @return NULL is the center could not be found
+ * (null envelope).
+ bool centre(Coordinate& centre) const;
+ * Computes the intersection of two {@link Envelopes}
+ * @param env the envelope to intersect with
+ * @param result the envelope representing the intersection of
+ * the envelopes (this will be the null envelope
+ * if either argument is null, or they do not intersect)
+ * @return false if not intersection is found
+ bool intersection(const Envelope& env, Envelope& result) const;
+ /** \brief
+ * Translates this envelope by given amounts in the X and Y direction.
+ * @param transX the amount to translate along the X axis
+ * @param transY the amount to translate along the Y axis
+ void translate(double transX, double transY);
+ /** \brief
+ * Expands this envelope by a given distance in all directions.
+ * Both positive and negative distances are supported.
+ * @param deltaX the distance to expand the envelope along
+ * the X axis
+ * @param deltaY the distance to expand the envelope along
+ * the Y axis
+ void expandBy(double deltaX, double deltaY);
+ /** \brief
+ * @param distance the distance to expand the envelope
+ * @return this envelope
+ void
+ expandBy(double p_distance)
+ expandBy(p_distance, p_distance);
+ /** \brief
+ * Enlarges the boundary of the Envelope so that it contains
+ * p. Does nothing if p is already on or within the boundaries.
+ * @param p the Coordinate to include
+ void expandToInclude(const Coordinate& p);
+ /** \brief
+ * (x,y). Does nothing if (x,y) is already on or within the boundaries.
+ * @param x the value to lower the minimum x
+ * to or to raise the maximum x to
+ * @param y the value to lower the minimum y
+ * to or to raise the maximum y to
+ void expandToInclude(double x, double y);
+ /** \brief
+ * <code>other</code>. Does nothing if other is wholly on or
+ * within the boundaries.
+ * @param other the <code>Envelope</code> to merge with
+ void expandToInclude(const Envelope* other);
+ /** \brief
+ * Tests if the <code>Envelope other</code> lies wholely
+ * inside this <code>Envelope</code> (inclusive of the boundary).
+ * Note that this is <b>not</b> the same definition as the SFS
+ * <tt>contains</tt>, which would exclude the envelope boundary.
+ * @param other the <code>Envelope</code> to check
+ * @return true if <code>other</code> is contained in this
+ * <code>Envelope</code>
+ * @see covers(Envelope)
+ bool
+ contains(const Envelope& other) const
+ return covers(other);
+ bool
+ contains(const Envelope* other) const
+ return contains(*other);
+ /** \brief
+ * Returns <code>true</code> if the given point lies in
+ * or on the envelope.
+ * @param p the point which this <code>Envelope</code> is
+ * being checked for containing
+ * @return <code>true</code> if the point lies in the interior or
+ * on the boundary of this <code>Envelope</code>.
+ bool
+ contains(const Coordinate& p) const
+ return covers(p.x, p.y);
+ /** \brief
+ * @param x the x-coordinate of the point which this
+ * <code>Envelope</code> is
+ * @param y the y-coordinate of the point which this
+ * <code>Envelope</code> is being checked for containing
+ * @return <code>true</code> if <code>(x, y)</code> lies in
+ * the interior or on the boundary of this
+ * <code>Envelope</code>.
+ bool
+ contains(double x, double y) const
+ return covers(x, y);
+ * Check if the point p
+ * intersects (lies inside) the region of this Envelope.
+ * @param p the Coordinate to be tested
+ * @return true if the point intersects this Envelope
+ bool intersects(const Coordinate& p) const;
+ * Check if the point (x, y)
+ * @param x the x-ordinate of the point
+ * @param y the y-ordinate of the point
+ * @return <code>true</code> if the point intersects this Envelope
+ bool intersects(double x, double y) const;
+ * Check if the region defined by other Envelope
+ * intersects (intersects) the region of this Envelope.
+ * @param other the Envelope which this Envelope is
+ * being checked for intersection
+ * @return true if the Envelopes intersects
+ bool intersects(const Envelope* other) const;
+ bool intersects(const Envelope& other) const;
+ * Tests if the given point lies in or on the envelope.
+ *@param x the x-coordinate of the point which this <code>Envelope</code> is
+ *@param y the y-coordinate of the point which this <code>Envelope</code> is
+ *@return <code>true</code> if <code>(x, y)</code> lies in the interior or
+ bool covers(double x, double y) const;
+ *@param p the point which this <code>Envelope</code> is
+ *@return <code>true</code> if the point lies in the interior or
+ bool covers(const Coordinate* p) const;
+ * Tests if the <code>Envelope other</code> lies wholely inside
+ * this <code>Envelope</code> (inclusive of the boundary).
+ * @return true if this <code>Envelope</code> covers the
+ bool covers(const Envelope& other) const;
+ bool
+ covers(const Envelope* other) const
+ return covers(*other);
+ /** \brief
+ * Returns <code>true</code> if the <code>Envelope other</code>
+ * spatially equals this <code>Envelope</code>.
+ * @param other the <code>Envelope</code> which this
+ * <code>Envelope</code> is being checked for equality
+ * @return <code>true</code> if this and <code>other</code>
+ * Envelope objs are spatially equal
+ bool equals(const Envelope* other) const;
+ /** \brief
+ * Returns a <code>string</code> of the form
+ * <I>Env[minx:maxx,miny:maxy]</I> .
+ * @return a <code>string</code> of the form
+ std::string toString(void) const;
+ /** \brief
+ * Computes the distance between this and another
+ * The distance between overlapping Envelopes is 0. Otherwise, the
+ * distance is the Euclidean distance between the closest points.
+ double distance(const Envelope* env) const;
+ int hashCode() const;
private:
- /** \brief
- * Splits a string into parts based on the supplied delimiters.
- * This is a generic function that really belongs in a utility
- * file somewhere
- std::vector<std::string> split(const std::string &str,
- const std::string &delimiters = " ");
+ /** \brief
+ * Splits a string into parts based on the supplied delimiters.
+ * This is a generic function that really belongs in a utility
+ * file somewhere
+ std::vector<std::string> split(const std::string& str,
+ const std::string& delimiters = " ");
- static double distance(double x0,double y0,double x1,double y1);
+ static double distance(double x0, double y0, double x1, double y1);
- /// the minimum x-coordinate
- double minx;
+ /// the minimum x-coordinate
+ double minx;
- /// the maximum x-coordinate
- double maxx;
+ /// the maximum x-coordinate
+ double maxx;
- /// the minimum y-coordinate
- double miny;
+ /// the minimum y-coordinate
+ double miny;
- /// the maximum y-coordinate
- double maxy;
+ /// the maximum y-coordinate
+ double maxy;
/// Checks if two Envelopes are equal (2D only check)
diff --git a/include/geos/geom/Envelope.inl b/include/geos/geom/Envelope.inl
index fb0a9bc..fa66133 100644
--- a/include/geos/geom/Envelope.inl
+++ b/include/geos/geom/Envelope.inl
@@ -7,7 +7,7 @@
@@ -28,67 +28,81 @@ namespace geom { // geos::geom
/*public*/
INLINE double
-Envelope::getMaxY() const { return maxy; }
+Envelope::getMaxY() const
+ return maxy;
/*public*/
INLINE double
-Envelope::getMaxX() const { return maxx; }
+Envelope::getMaxX() const
+ return maxx;
/*public*/
INLINE double
-Envelope::getMinY() const { return miny; }
+Envelope::getMinY() const
+ return miny;
/*public*/
INLINE double
-Envelope::getMinX() const { return minx; }
+Envelope::getMinX() const
+ return minx;
/*public*/
INLINE bool
Envelope::intersects(const Coordinate& other) const
- return (other.x <= maxx && other.x >= minx &&
- other.y <= maxy && other.y >= miny);
+ return (other.x <= maxx && other.x >= minx &&
+ other.y <= maxy && other.y >= miny);
/*public*/
INLINE bool
Envelope::intersects(const Envelope& other) const
- return intersects(&other);
+ return intersects(&other);
/*public*/
INLINE bool
Envelope::isNull(void) const
- return maxx < minx;
+ return maxx < minx;
/*public*/
INLINE bool
Envelope::intersects(const Envelope* other) const
- // Optimized to reduce function calls
- if ( isNull() || other->isNull() ) return false;
- return !(other->minx > maxx ||
- other->maxx < minx ||
- other->miny > maxy ||
- other->maxy < miny);
+ // Optimized to reduce function calls
+ if(isNull() || other->isNull()) {
+ return false;
+ return !(other->minx > maxx ||
+ other->maxx < minx ||
+ other->miny > maxy ||
+ other->maxy < miny);
/*public*/
INLINE bool
Envelope::intersects(double x, double y) const
- return (x <= maxx && x >= minx && y <= maxy && y >= miny);
+ return (x <= maxx && x >= minx && y <= maxy && y >= miny);
/*public*/
-INLINE bool
-Envelope::covers(const Coordinate *p) const
+INLINE bool
+Envelope::covers(const Coordinate* p) const
- return covers(p->x, p->y);
+ return covers(p->x, p->y);
} // namespace geos::geom
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 4e01b46..64a9967 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -50,21 +50,21 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Coordinate;
- class CoordinateSequenceFilter;
- class GeometryComponentFilter;
- class GeometryFactory;
- class GeometryFilter;
- class IntersectionMatrix;
- class PrecisionModel;
- class Point;
- namespace io { // geos.io
- class Unload;
- } // namespace geos.io
+namespace geom {
+class Coordinate;
+class CoordinateSequenceFilter;
+class GeometryComponentFilter;
+class GeometryFactory;
+class GeometryFilter;
+class IntersectionMatrix;
+class PrecisionModel;
+class Point;
+namespace io { // geos.io
+class Unload;
+} // namespace geos.io
namespace geos {
@@ -72,33 +72,33 @@ namespace geom { // geos::geom
/// Geometry types
enum GeometryTypeId {
- /// a point
- GEOS_POINT,
- /// a linestring
- GEOS_LINESTRING,
- /// a linear ring (linestring with 1st point == last point)
- GEOS_LINEARRING,
- /// a polygon
- GEOS_POLYGON,
- /// a collection of points
- GEOS_MULTIPOINT,
- /// a collection of linestrings
- GEOS_MULTILINESTRING,
- /// a collection of polygons
- GEOS_MULTIPOLYGON,
- /// a collection of heterogeneus geometries
- GEOS_GEOMETRYCOLLECTION
+ /// a point
+ GEOS_POINT,
+ /// a linestring
+ GEOS_LINESTRING,
+ /// a linear ring (linestring with 1st point == last point)
+ GEOS_LINEARRING,
+ /// a polygon
+ GEOS_POLYGON,
+ /// a collection of points
+ GEOS_MULTIPOINT,
+ /// a collection of linestrings
+ GEOS_MULTILINESTRING,
+ /// a collection of polygons
+ GEOS_MULTIPOLYGON,
+ /// a collection of heterogeneus geometries
+ GEOS_GEOMETRYCOLLECTION
enum GeometrySortIndex {
- SORTINDEX_POINT = 0,
- SORTINDEX_MULTIPOINT = 1,
- SORTINDEX_LINESTRING = 2,
- SORTINDEX_LINEARRING = 3,
- SORTINDEX_MULTILINESTRING = 4,
- SORTINDEX_POLYGON = 5,
- SORTINDEX_MULTIPOLYGON = 6,
- SORTINDEX_GEOMETRYCOLLECTION = 7
+ SORTINDEX_POINT = 0,
+ SORTINDEX_MULTIPOINT = 1,
+ SORTINDEX_LINESTRING = 2,
+ SORTINDEX_LINEARRING = 3,
+ SORTINDEX_MULTILINESTRING = 4,
+ SORTINDEX_POLYGON = 5,
+ SORTINDEX_MULTIPOLYGON = 6,
+ SORTINDEX_GEOMETRYCOLLECTION = 7
@@ -188,697 +188,735 @@ class GEOS_DLL Geometry {
public:
- friend class GeometryFactory;
- /// A vector of const Geometry pointers
- using ConstVect = std::vector<const Geometry *>;
- /// A vector of non-const Geometry pointers
- using NonConstVect = std::vector<Geometry *>;
- /// An unique_ptr of Geometry
- using Ptr = std::unique_ptr<Geometry> ;
- /// Make a deep-copy of this Geometry
- virtual Geometry* clone() const=0;
- /// Destroy Geometry and all components
- virtual ~Geometry();
- * \brief
- * Gets the factory which contains the context in which this
- * geometry was created.
- * @return the factory for this geometry
- const GeometryFactory* getFactory() const { return _factory; }
- * \brief
- * A simple scheme for applications to add their own custom data to
- * a Geometry.
- * An example use might be to add an object representing a
- * Coordinate Reference System.
- * Note that user data objects are not present in geometries created
- * by construction methods.
- * @param newUserData an object, the semantics for which are
- * defined by the application using this Geometry
- void setUserData(void* newUserData) { _userData=newUserData; }
- * \brief
- * Gets the user data object for this geometry, if any.
- * @return the user data object, or <code>null</code> if none set
- void* getUserData() const { return _userData; }
- * \brief
- * Returns the ID of the Spatial Reference System used by the
- * <code>Geometry</code>.
- * GEOS supports Spatial Reference System information in the simple way
- * defined in the SFS. A Spatial Reference System ID (SRID) is present
- * in each <code>Geometry</code> object. <code>Geometry</code>
- * provides basic accessor operations for this field, but no others.
- * The SRID is represented as an integer.
- * @return the ID of the coordinate space in which the
- * <code>Geometry</code> is defined.
- virtual int getSRID() const { return SRID; }
- * Sets the ID of the Spatial Reference System used by the
- virtual void setSRID(int newSRID) { SRID=newSRID; }
- * \brief
- * Get the PrecisionModel used to create this Geometry.
- const PrecisionModel* getPrecisionModel() const;
- /// \brief
- /// Returns a vertex of this Geometry,
- /// or NULL if this is the empty geometry
- virtual const Coordinate* getCoordinate() const=0; //Abstract
- * \brief
- * Returns this Geometry vertices.
- * Caller takes ownership of the returned object.
- virtual CoordinateSequence* getCoordinates() const=0; //Abstract
- /// Returns the count of this Geometrys vertices.
- virtual std::size_t getNumPoints() const=0; //Abstract
- /// Returns false if the Geometry not simple.
- virtual bool isSimple() const;
- /// Return a string representation of this Geometry type
- virtual std::string getGeometryType() const=0; //Abstract
- /// Return an integer representation of this Geometry type
- virtual GeometryTypeId getGeometryTypeId() const=0; //Abstract
- /// Returns the number of geometries in this collection
- /// (or 1 if this is not a collection)
- virtual std::size_t getNumGeometries() const { return 1; }
- /// Returns a pointer to the nth Geometry in this collection
- /// (or self if this is not a collection)
- virtual const Geometry* getGeometryN(std::size_t /*n*/) const { return this; }
- * \brief Tests the validity of this <code>Geometry</code>.
- * Subclasses provide their own definition of "valid".
- * @return <code>true</code> if this <code>Geometry</code> is valid
- * @see IsValidOp
- virtual bool isValid() const;
- /// Returns whether or not the set of points in this Geometry is empty.
- virtual bool isEmpty() const=0; //Abstract
- /// Polygon overrides to check for actual rectangle
- virtual bool isRectangle() const { return false; }
- /// Returns the dimension of this Geometry (0=point, 1=line, 2=surface)
- virtual Dimension::DimensionType getDimension() const=0; //Abstract
- /// Returns the coordinate dimension of this Geometry (2=XY, 3=XYZ, 4=XYZM in future).
- virtual int getCoordinateDimension() const=0; //Abstract
- * \brief
- * Returns the boundary, or an empty geometry of appropriate
- * dimension if this <code>Geometry</code> is empty.
- * (In the case of zero-dimensional geometries,
- * an empty GeometryCollection is returned.)
- * For a discussion of this function, see the OpenGIS Simple
- * Features Specification. As stated in SFS Section 2.1.13.1,
- * "the boundary of a Geometry is a set of Geometries of the
- * next lower dimension."
- * @return the closure of the combinatorial boundary
- * of this <code>Geometry</code>.
- * Ownershipof the returned object transferred to caller.
- virtual Geometry* getBoundary() const=0; //Abstract
- /// Returns the dimension of this Geometrys inherent boundary.
- virtual int getBoundaryDimension() const=0; //Abstract
- /// Returns this Geometrys bounding box.
- virtual Geometry* getEnvelope() const;
- /** \brief
- * Returns the minimum and maximum x and y values in this Geometry,
- * or a null Envelope if this Geometry is empty.
- virtual const Envelope* getEnvelopeInternal() const;
- * Tests whether this geometry is disjoint from the specified geometry.
- * The <code>disjoint</code> predicate has the following equivalent
- * definitions:
- * - The two geometries have no point in common
- * - The DE-9IM Intersection Matrix for the two geometries matches
- * <code>[FF*FF****]</code>
- * - <code>! g.intersects(this)</code>
- * (<code>disjoint</code> is the inverse of <code>intersects</code>)
- * @param g the Geometry with which to compare this Geometry
- * @return true if the two <code>Geometry</code>s are disjoint
- * @see Geometry::intersects
- virtual bool disjoint(const Geometry *other) const;
- /** \brief
- * Returns true if the DE-9IM intersection matrix for the two
- * Geometrys is FT*******, F**T***** or F***T****.
- virtual bool touches(const Geometry *other) const;
- /// Returns true if disjoint returns false.
- virtual bool intersects(const Geometry *g) const;
- * Tests whether this geometry crosses the specified geometry.
- * The <code>crosses</code> predicate has the following equivalent
- * definitions:
- * - The geometries have some but not all interior points in common.
- * - <code>[T*T******]</code> (for P/L, P/A, and L/A situations)
- * - <code>[T*****T**]</code> (for L/P, A/P, and A/L situations)
- * - <code>[0********]</code> (for L/L situations)
- * For any other combination of dimensions this predicate returns
- * <code>false</code>.
- * The SFS defined this predicate only for P/L, P/A, L/L, and L/A
- * situations.
- * JTS extends the definition to apply to L/P, A/P and A/L situations
- * as well, in order to make the relation symmetric.
- * @param g the <code>Geometry</code> with which to compare this
- *@return <code>true</code> if the two <code>Geometry</code>s cross.
- virtual bool crosses(const Geometry *g) const;
- /** \brief
- * Geometrys is T*F**F***.
- virtual bool within(const Geometry *g) const;
- /// Returns true if other.within(this) returns true.
- virtual bool contains(const Geometry *g) const;
- /** \brief
- * Geometrys is T*T***T** (for two points or two surfaces)
- * 1*T***T** (for two curves).
- virtual bool overlaps(const Geometry *g) const;
- * \brief
- * Returns true if the elements in the DE-9IM intersection matrix
- * for the two Geometrys match the elements in intersectionPattern.
- * IntersectionPattern elements may be: 0 1 2 T ( = 0, 1 or 2)
- * F ( = -1) * ( = -1, 0, 1 or 2).
- * For more information on the DE-9IM, see the OpenGIS Simple
- * @throws util::IllegalArgumentException if either arg is a collection
- virtual bool relate(const Geometry *g,
- const std::string& intersectionPattern) const;
- bool relate(const Geometry& g, const std::string& intersectionPattern) const
- return relate(&g, intersectionPattern);
- /// Returns the DE-9IM intersection matrix for the two Geometrys.
- virtual IntersectionMatrix* relate(const Geometry *g) const;
- IntersectionMatrix* relate(const Geometry &g) const {
- return relate(&g);
- * \brief
- * Geometrys is T*F**FFF*.
- virtual bool equals(const Geometry *g) const;
- /** \brief
- * Returns <code>true</code> if this geometry covers the
- * specified geometry.
- * The <code>covers</code> predicate has the following
- * equivalent definitions:
- * - Every point of the other geometry is a point of this geometry.
- * - The DE-9IM Intersection Matrix for the two geometries is
- * <code>T*****FF*</code>
- * or <code>*T****FF*</code>
- * or <code>***T**FF*</code>
- * or <code>****T*FF*</code>
- * - <code>g.coveredBy(this)</code>
- * (<code>covers</code> is the inverse of <code>coveredBy</code>)
- * If either geometry is empty, the value of this predicate
- * is <tt>false</tt>.
- * This predicate is similar to {@link #contains},
- * but is more inclusive (i.e. returns <tt>true</tt> for more cases).
- * In particular, unlike <code>contains</code> it does not distinguish
- * between points in the boundary and in the interior of geometries.
- * For most situations, <code>covers</code> should be used in
- * preference to <code>contains</code>.
- * As an added benefit, <code>covers</code> is more amenable to
- * optimization, and hence should be more performant.
- * @param g
- * the <code>Geometry</code> with which to compare this
- * covers <code>g</code>
- * @see Geometry::contains
- * @see Geometry::coveredBy
- bool covers(const Geometry* g) const;
- /** \brief
- * Tests whether this geometry is covered by the
- * The <code>coveredBy</code> predicate has the following
- * - Every point of this geometry is a point of the other geometry.
- * <code>[T*F**F***]</code>
- * or <code>[*TF**F***]</code>
- * or <code>[**FT*F***]</code>
- * or <code>[**F*TF***]</code>
- * - <code>g.covers(this)</code>
- * (<code>coveredBy</code> is the converse of <code>covers</code>)
- * This predicate is similar to {@link #within},
- * this <code>Geometry</code>
- * is covered by <code>g</code>
- * @see Geometry#within
- * @see Geometry#covers
- bool coveredBy(const Geometry* g) const {
- return g->covers(this);
- /// Returns the Well-known Text representation of this Geometry.
- virtual std::string toString() const;
- virtual std::string toText() const;
- /// Returns a buffer region around this Geometry having the given width.
- /// @throws util::TopologyException if a robustness error occurs
- virtual Geometry* buffer(double distance) const;
- /// \brief
- /// given width and with a specified number of segments used
- /// to approximate curves.
- virtual Geometry* buffer(double distance,int quadrantSegments) const;
- /** \brief
- * Computes a buffer area around this geometry having the given
- * width and with a specified accuracy of approximation for circular
- * arcs, and using a specified end cap style.
- * Buffer area boundaries can contain circular arcs.
- * To represent these arcs using linear geometry they must be
- * approximated with line segments.
- * The <code>quadrantSegments</code> argument allows controlling the
- * accuracy of the approximation by specifying the number of line
- * segments used to represent a quadrant of a circle
- * The end cap style specifies the buffer geometry that will be
- * created at the ends of linestrings. The styles provided are:
- * - BufferOp::CAP_ROUND - (default) a semi-circle
- * - BufferOp::CAP_BUTT - a straight line perpendicular to the
- * end segment
- * - BufferOp::CAP_SQUARE - a half-square
- * @param distance the width of the buffer
- * (may be positive, negative or 0)
- * @param quadrantSegments the number of line segments used
- * to represent a quadrant of a circle
- * @param endCapStyle the end cap style to use
- * @return an area geometry representing the buffer region
- * @throws util::TopologyException if a robustness error occurs
- * @see BufferOp
- virtual Geometry* buffer(double distance, int quadrantSegments,
- int endCapStyle) const;
- /// \brief
- /// Returns the smallest convex Polygon that contains
- /// all the points in the Geometry.
- virtual Geometry* convexHull() const;
+ friend class GeometryFactory;
+ /// A vector of const Geometry pointers
+ using ConstVect = std::vector<const Geometry*>;
+ /// A vector of non-const Geometry pointers
+ using NonConstVect = std::vector<Geometry*>;
+ /// An unique_ptr of Geometry
+ using Ptr = std::unique_ptr<Geometry> ;
+ /// Make a deep-copy of this Geometry
+ virtual Geometry* clone() const = 0;
+ /// Destroy Geometry and all components
+ virtual ~Geometry();
+ * \brief
+ * Gets the factory which contains the context in which this
+ * geometry was created.
+ * @return the factory for this geometry
+ const GeometryFactory*
+ getFactory() const
+ return _factory;
+ * \brief
+ * A simple scheme for applications to add their own custom data to
+ * a Geometry.
+ * An example use might be to add an object representing a
+ * Coordinate Reference System.
+ * Note that user data objects are not present in geometries created
+ * by construction methods.
+ * @param newUserData an object, the semantics for which are
+ * defined by the application using this Geometry
+ void
+ setUserData(void* newUserData)
+ _userData = newUserData;
+ * \brief
+ * Gets the user data object for this geometry, if any.
+ * @return the user data object, or <code>null</code> if none set
+ void*
+ getUserData() const
+ return _userData;
+ * \brief
+ * Returns the ID of the Spatial Reference System used by the
+ * <code>Geometry</code>.
+ * GEOS supports Spatial Reference System information in the simple way
+ * defined in the SFS. A Spatial Reference System ID (SRID) is present
+ * in each <code>Geometry</code> object. <code>Geometry</code>
+ * provides basic accessor operations for this field, but no others.
+ * The SRID is represented as an integer.
+ * @return the ID of the coordinate space in which the
+ * <code>Geometry</code> is defined.
+ virtual int
+ getSRID() const
+ return SRID;
+ * Sets the ID of the Spatial Reference System used by the
+ virtual void
+ setSRID(int newSRID)
+ SRID = newSRID;
+ * \brief
+ * Get the PrecisionModel used to create this Geometry.
+ const PrecisionModel* getPrecisionModel() const;
+ /// \brief
+ /// Returns a vertex of this Geometry,
+ /// or NULL if this is the empty geometry
+ virtual const Coordinate* getCoordinate() const = 0; //Abstract
+ * \brief
+ * Returns this Geometry vertices.
+ * Caller takes ownership of the returned object.
+ virtual CoordinateSequence* getCoordinates() const = 0; //Abstract
+ /// Returns the count of this Geometrys vertices.
+ virtual std::size_t getNumPoints() const = 0; //Abstract
+ /// Returns false if the Geometry not simple.
+ virtual bool isSimple() const;
+ /// Return a string representation of this Geometry type
+ virtual std::string getGeometryType() const = 0; //Abstract
+ /// Return an integer representation of this Geometry type
+ virtual GeometryTypeId getGeometryTypeId() const = 0; //Abstract
+ /// Returns the number of geometries in this collection
+ /// (or 1 if this is not a collection)
+ getNumGeometries() const
+ return 1;
+ /// Returns a pointer to the nth Geometry in this collection
+ /// (or self if this is not a collection)
+ virtual const Geometry*
+ getGeometryN(std::size_t /*n*/) const
+ return this;
+ * \brief Tests the validity of this <code>Geometry</code>.
+ * Subclasses provide their own definition of "valid".
+ * @return <code>true</code> if this <code>Geometry</code> is valid
+ * @see IsValidOp
+ virtual bool isValid() const;
+ /// Returns whether or not the set of points in this Geometry is empty.
+ virtual bool isEmpty() const = 0; //Abstract
+ /// Polygon overrides to check for actual rectangle
+ virtual bool
+ isRectangle() const
+ return false;
+ /// Returns the dimension of this Geometry (0=point, 1=line, 2=surface)
+ virtual Dimension::DimensionType getDimension() const = 0; //Abstract
+ /// Returns the coordinate dimension of this Geometry (2=XY, 3=XYZ, 4=XYZM in future).
+ virtual int getCoordinateDimension() const = 0; //Abstract
+ * \brief
+ * Returns the boundary, or an empty geometry of appropriate
+ * dimension if this <code>Geometry</code> is empty.
+ * (In the case of zero-dimensional geometries,
+ * an empty GeometryCollection is returned.)
+ * For a discussion of this function, see the OpenGIS Simple
+ * Features Specification. As stated in SFS Section 2.1.13.1,
+ * "the boundary of a Geometry is a set of Geometries of the
+ * next lower dimension."
+ * @return the closure of the combinatorial boundary
+ * of this <code>Geometry</code>.
+ * Ownershipof the returned object transferred to caller.
+ virtual Geometry* getBoundary() const = 0; //Abstract
+ /// Returns the dimension of this Geometrys inherent boundary.
+ virtual int getBoundaryDimension() const = 0; //Abstract
+ /// Returns this Geometrys bounding box.
+ virtual Geometry* getEnvelope() const;
+ /** \brief
+ * Returns the minimum and maximum x and y values in this Geometry,
+ * or a null Envelope if this Geometry is empty.
+ virtual const Envelope* getEnvelopeInternal() const;
+ * Tests whether this geometry is disjoint from the specified geometry.
+ * The <code>disjoint</code> predicate has the following equivalent
+ * definitions:
+ * - The two geometries have no point in common
+ * - The DE-9IM Intersection Matrix for the two geometries matches
+ * <code>[FF*FF****]</code>
+ * - <code>! g.intersects(this)</code>
+ * (<code>disjoint</code> is the inverse of <code>intersects</code>)
+ * @param g the Geometry with which to compare this Geometry
+ * @return true if the two <code>Geometry</code>s are disjoint
+ * @see Geometry::intersects
+ virtual bool disjoint(const Geometry* other) const;
+ /** \brief
+ * Returns true if the DE-9IM intersection matrix for the two
+ * Geometrys is FT*******, F**T***** or F***T****.
+ virtual bool touches(const Geometry* other) const;
+ /// Returns true if disjoint returns false.
+ virtual bool intersects(const Geometry* g) const;
+ * Tests whether this geometry crosses the specified geometry.
+ * The <code>crosses</code> predicate has the following equivalent
+ * definitions:
+ * - The geometries have some but not all interior points in common.
+ * - <code>[T*T******]</code> (for P/L, P/A, and L/A situations)
+ * - <code>[T*****T**]</code> (for L/P, A/P, and A/L situations)
+ * - <code>[0********]</code> (for L/L situations)
+ * For any other combination of dimensions this predicate returns
+ * <code>false</code>.
+ * The SFS defined this predicate only for P/L, P/A, L/L, and L/A
+ * situations.
+ * JTS extends the definition to apply to L/P, A/P and A/L situations
+ * as well, in order to make the relation symmetric.
+ * @param g the <code>Geometry</code> with which to compare this
+ *@return <code>true</code> if the two <code>Geometry</code>s cross.
+ virtual bool crosses(const Geometry* g) const;
+ /** \brief
+ * Geometrys is T*F**F***.
+ virtual bool within(const Geometry* g) const;
+ /// Returns true if other.within(this) returns true.
+ virtual bool contains(const Geometry* g) const;
+ /** \brief
+ * Geometrys is T*T***T** (for two points or two surfaces)
+ * 1*T***T** (for two curves).
+ virtual bool overlaps(const Geometry* g) const;
+ * \brief
+ * Returns true if the elements in the DE-9IM intersection matrix
+ * for the two Geometrys match the elements in intersectionPattern.
+ * IntersectionPattern elements may be: 0 1 2 T ( = 0, 1 or 2)
+ * F ( = -1) * ( = -1, 0, 1 or 2).
+ * For more information on the DE-9IM, see the OpenGIS Simple
+ * @throws util::IllegalArgumentException if either arg is a collection
+ virtual bool relate(const Geometry* g,
+ const std::string& intersectionPattern) const;
+ bool
+ relate(const Geometry& g, const std::string& intersectionPattern) const
+ return relate(&g, intersectionPattern);
+ /// Returns the DE-9IM intersection matrix for the two Geometrys.
+ virtual IntersectionMatrix* relate(const Geometry* g) const;
+ IntersectionMatrix*
+ relate(const Geometry& g) const
+ return relate(&g);
+ * \brief
+ * Geometrys is T*F**FFF*.
+ virtual bool equals(const Geometry* g) const;
+ /** \brief
+ * Returns <code>true</code> if this geometry covers the
+ * specified geometry.
+ * The <code>covers</code> predicate has the following
+ * equivalent definitions:
+ * - Every point of the other geometry is a point of this geometry.
+ * - The DE-9IM Intersection Matrix for the two geometries is
+ * <code>T*****FF*</code>
+ * or <code>*T****FF*</code>
+ * or <code>***T**FF*</code>
+ * or <code>****T*FF*</code>
+ * - <code>g.coveredBy(this)</code>
+ * (<code>covers</code> is the inverse of <code>coveredBy</code>)
+ * If either geometry is empty, the value of this predicate
+ * is <tt>false</tt>.
+ * This predicate is similar to {@link #contains},
+ * but is more inclusive (i.e. returns <tt>true</tt> for more cases).
+ * In particular, unlike <code>contains</code> it does not distinguish
+ * between points in the boundary and in the interior of geometries.
+ * For most situations, <code>covers</code> should be used in
+ * preference to <code>contains</code>.
+ * As an added benefit, <code>covers</code> is more amenable to
+ * optimization, and hence should be more performant.
+ * @param g
+ * the <code>Geometry</code> with which to compare this
+ * covers <code>g</code>
+ * @see Geometry::contains
+ * @see Geometry::coveredBy
+ bool covers(const Geometry* g) const;
+ /** \brief
+ * Tests whether this geometry is covered by the
+ * The <code>coveredBy</code> predicate has the following
+ * - Every point of this geometry is a point of the other geometry.
+ * <code>[T*F**F***]</code>
+ * or <code>[*TF**F***]</code>
+ * or <code>[**FT*F***]</code>
+ * or <code>[**F*TF***]</code>
+ * - <code>g.covers(this)</code>
+ * (<code>coveredBy</code> is the converse of <code>covers</code>)
+ * This predicate is similar to {@link #within},
+ * this <code>Geometry</code>
+ * is covered by <code>g</code>
+ * @see Geometry#within
+ * @see Geometry#covers
+ bool
+ coveredBy(const Geometry* g) const
+ return g->covers(this);
+ /// Returns the Well-known Text representation of this Geometry.
+ virtual std::string toString() const;
+ virtual std::string toText() const;
+ /// Returns a buffer region around this Geometry having the given width.
+ /// @throws util::TopologyException if a robustness error occurs
+ virtual Geometry* buffer(double distance) const;
+ /// \brief
+ /// given width and with a specified number of segments used
+ /// to approximate curves.
+ virtual Geometry* buffer(double distance, int quadrantSegments) const;
+ /** \brief
+ * Computes a buffer area around this geometry having the given
+ * width and with a specified accuracy of approximation for circular
+ * arcs, and using a specified end cap style.
+ * Buffer area boundaries can contain circular arcs.
+ * To represent these arcs using linear geometry they must be
+ * approximated with line segments.
+ * The <code>quadrantSegments</code> argument allows controlling the
+ * accuracy of the approximation by specifying the number of line
+ * segments used to represent a quadrant of a circle
+ * The end cap style specifies the buffer geometry that will be
+ * created at the ends of linestrings. The styles provided are:
+ * - BufferOp::CAP_ROUND - (default) a semi-circle
+ * - BufferOp::CAP_BUTT - a straight line perpendicular to the
+ * end segment
+ * - BufferOp::CAP_SQUARE - a half-square
+ * @param distance the width of the buffer
+ * (may be positive, negative or 0)
+ * @param quadrantSegments the number of line segments used
+ * to represent a quadrant of a circle
+ * @param endCapStyle the end cap style to use
+ * @return an area geometry representing the buffer region
+ * @throws util::TopologyException if a robustness error occurs
+ * @see BufferOp
+ virtual Geometry* buffer(double distance, int quadrantSegments,
+ int endCapStyle) const;
+ /// \brief
+ /// Returns the smallest convex Polygon that contains
+ /// all the points in the Geometry.
+ virtual Geometry* convexHull() const;
* Computes a new geometry which has all component coordinate sequences
* in reverse order (opposite orientation) to this one.
* @return a reversed geometry
- virtual Geometry* reverse() const=0;
- /** \brief
- * Returns a Geometry representing the points shared by
- * this Geometry and other.
- * @throws util::IllegalArgumentException if either input is a
- * non-empty GeometryCollection
- virtual Geometry* intersection(const Geometry *other) const;
- /** \brief
- * Returns a Geometry representing all the points in this Geometry
- * and other.
- Geometry* Union(const Geometry *other) const;
- // throw(IllegalArgumentException *, TopologyException *);
- * Computes the union of all the elements of this geometry. Heterogeneous
- * {@link GeometryCollection}s are fully supported.
- * The result obeys the following contract:
- * - Unioning a set of {@link LineString}s has the effect of fully noding
- * and dissolving the linework.
- * - Unioning a set of {@link Polygon}s will always
- * return a {@link Polygonal} geometry (unlike {link #union(Geometry)},
- * which may return geometrys of lower dimension if a topology collapse
- * occurred.
- * @return the union geometry
- * @see UnaryUnionOp
- Ptr Union() const;
- * \brief
- * Returns a Geometry representing the points making up this
- * Geometry that do not make up other.
- virtual Geometry* difference(const Geometry *other) const;
- /** \brief
- * Returns a set combining the points in this Geometry not in other,
- * and the points in other not in this Geometry.
- virtual Geometry* symDifference(const Geometry *other) const;
- /** \brief
- * Returns true iff the two Geometrys are of the same type and their
- * vertices corresponding by index are equal up to a specified tolerance.
- virtual bool equalsExact(const Geometry *other, double tolerance=0)
- const=0; //Abstract
- virtual void apply_rw(const CoordinateFilter *filter)=0; //Abstract
- virtual void apply_ro(CoordinateFilter *filter) const=0; //Abstract
- virtual void apply_rw(GeometryFilter *filter);
- virtual void apply_ro(GeometryFilter *filter) const;
- virtual void apply_rw(GeometryComponentFilter *filter);
- virtual void apply_ro(GeometryComponentFilter *filter) const;
- * Performs an operation on the coordinates in this Geometry's
- * CoordinateSequences.
- * If the filter reports that a coordinate value has been changed,
- * {@link #geometryChanged} will be called automatically.
- * @param filter the filter to apply
- virtual void apply_rw(CoordinateSequenceFilter& filter)=0;
- * Performs a read-only operation on the coordinates in this
- * Geometry's CoordinateSequences.
- virtual void apply_ro(CoordinateSequenceFilter& filter) const=0;
- /** \brief
- * Apply a fiter to each component of this geometry.
- * The filter is expected to provide a .filter(const Geometry*)
- * method.
- * I intend similar templated methods to replace
- * all the virtual apply_rw and apply_ro functions...
- * --strk(2005-02-06);
- template <class T>
- void applyComponentFilter(T& f) const
- for(std::size_t i=0, n=getNumGeometries(); i<n; ++i)
- f.filter(getGeometryN(i));
- /// Converts this Geometry to normal form (or canonical form).
- virtual void normalize()=0; //Abstract
- virtual int compareTo(const Geometry *geom) const;
- /** \brief
- * Returns the minimum distance between this Geometry
- * and the Geometry g
- virtual double distance(const Geometry *g) const;
- /// Returns the area of this Geometry.
- virtual double getArea() const;
- /// Returns the length of this Geometry.
- virtual double getLength() const;
- /** \brief
- * Tests whether the distance from this Geometry to another
- * is less than or equal to a specified value.
- * @param geom the Geometry to check the distance to
- * @param cDistance the distance value to compare
- * @return <code>true</code> if the geometries are less than
- * <code>distance</code> apart.
- * @todo doesn't seem to need being virtual, make it concrete
- virtual bool isWithinDistance(const Geometry *geom,
- double cDistance) const;
- /** \brief
- * Computes the centroid of this <code>Geometry</code>.
- * The centroid is equal to the centroid of the set of component
- * Geometries of highest dimension (since the lower-dimension geometries
- * contribute zero "weight" to the centroid)
- * @return a {@link Point} which is the centroid of this Geometry
- virtual Point* getCentroid() const;
- /// Computes the centroid of this Geometry as a Coordinate
- /// Returns false if centroid cannot be computed (EMPTY geometry)
- virtual bool getCentroid(Coordinate& ret) const;
- /** \brief
- * Computes an interior point of this <code>Geometry</code>.
- * An interior point is guaranteed to lie in the interior of the Geometry,
- * if it possible to calculate such a point exactly. Otherwise,
- * the point may lie on the boundary of the geometry.
- * @return a Point which is in the interior of this Geometry, or
- * null if the geometry doesn't have an interior (empty)
- virtual Point* getInteriorPoint() const;
- * \brief
- * Notifies this Geometry that its Coordinates have been changed
- * by an external party (using a CoordinateFilter, for example).
- virtual void geometryChanged();
- * \brief
- * by an external party.
- void geometryChangedAction();
+ virtual Geometry* reverse() const = 0;
+ /** \brief
+ * Returns a Geometry representing the points shared by
+ * this Geometry and other.
+ * @throws util::IllegalArgumentException if either input is a
+ * non-empty GeometryCollection
+ virtual Geometry* intersection(const Geometry* other) const;
+ /** \brief
+ * Returns a Geometry representing all the points in this Geometry
+ * and other.
+ Geometry* Union(const Geometry* other) const;
+ // throw(IllegalArgumentException *, TopologyException *);
+ * Computes the union of all the elements of this geometry. Heterogeneous
+ * {@link GeometryCollection}s are fully supported.
+ * The result obeys the following contract:
+ * - Unioning a set of {@link LineString}s has the effect of fully noding
+ * and dissolving the linework.
+ * - Unioning a set of {@link Polygon}s will always
+ * return a {@link Polygonal} geometry (unlike {link #union(Geometry)},
+ * which may return geometrys of lower dimension if a topology collapse
+ * occurred.
+ * @return the union geometry
+ * @see UnaryUnionOp
+ Ptr Union() const;
+ * \brief
+ * Returns a Geometry representing the points making up this
+ * Geometry that do not make up other.
+ virtual Geometry* difference(const Geometry* other) const;
+ /** \brief
+ * Returns a set combining the points in this Geometry not in other,
+ * and the points in other not in this Geometry.
+ virtual Geometry* symDifference(const Geometry* other) const;
+ /** \brief
+ * Returns true iff the two Geometrys are of the same type and their
+ * vertices corresponding by index are equal up to a specified tolerance.
+ virtual bool equalsExact(const Geometry* other, double tolerance = 0)
+ const = 0; //Abstract
+ virtual void apply_rw(const CoordinateFilter* filter) = 0; //Abstract
+ virtual void apply_ro(CoordinateFilter* filter) const = 0; //Abstract
+ virtual void apply_rw(GeometryFilter* filter);
+ virtual void apply_ro(GeometryFilter* filter) const;
+ virtual void apply_rw(GeometryComponentFilter* filter);
+ virtual void apply_ro(GeometryComponentFilter* filter) const;
+ * Performs an operation on the coordinates in this Geometry's
+ * CoordinateSequences.
+ * If the filter reports that a coordinate value has been changed,
+ * {@link #geometryChanged} will be called automatically.
+ * @param filter the filter to apply
+ virtual void apply_rw(CoordinateSequenceFilter& filter) = 0;
+ * Performs a read-only operation on the coordinates in this
+ * Geometry's CoordinateSequences.
+ virtual void apply_ro(CoordinateSequenceFilter& filter) const = 0;
+ /** \brief
+ * Apply a fiter to each component of this geometry.
+ * The filter is expected to provide a .filter(const Geometry*)
+ * method.
+ * I intend similar templated methods to replace
+ * all the virtual apply_rw and apply_ro functions...
+ * --strk(2005-02-06);
+ template <class T>
+ void
+ applyComponentFilter(T& f) const
+ for(std::size_t i = 0, n = getNumGeometries(); i < n; ++i) {
+ f.filter(getGeometryN(i));
+ /// Converts this Geometry to normal form (or canonical form).
+ virtual void normalize() = 0; //Abstract
+ virtual int compareTo(const Geometry* geom) const;
+ /** \brief
+ * Returns the minimum distance between this Geometry
+ * and the Geometry g
+ virtual double distance(const Geometry* g) const;
+ /// Returns the area of this Geometry.
+ virtual double getArea() const;
+ /// Returns the length of this Geometry.
+ virtual double getLength() const;
+ /** \brief
+ * Tests whether the distance from this Geometry to another
+ * is less than or equal to a specified value.
+ * @param geom the Geometry to check the distance to
+ * @param cDistance the distance value to compare
+ * @return <code>true</code> if the geometries are less than
+ * <code>distance</code> apart.
+ * @todo doesn't seem to need being virtual, make it concrete
+ virtual bool isWithinDistance(const Geometry* geom,
+ double cDistance) const;
+ /** \brief
+ * Computes the centroid of this <code>Geometry</code>.
+ * The centroid is equal to the centroid of the set of component
+ * Geometries of highest dimension (since the lower-dimension geometries
+ * contribute zero "weight" to the centroid)
+ * @return a {@link Point} which is the centroid of this Geometry
+ virtual Point* getCentroid() const;
+ /// Computes the centroid of this Geometry as a Coordinate
+ /// Returns false if centroid cannot be computed (EMPTY geometry)
+ virtual bool getCentroid(Coordinate& ret) const;
+ /** \brief
+ * Computes an interior point of this <code>Geometry</code>.
+ * An interior point is guaranteed to lie in the interior of the Geometry,
+ * if it possible to calculate such a point exactly. Otherwise,
+ * the point may lie on the boundary of the geometry.
+ * @return a Point which is in the interior of this Geometry, or
+ * null if the geometry doesn't have an interior (empty)
+ virtual Point* getInteriorPoint() const;
+ * \brief
+ * Notifies this Geometry that its Coordinates have been changed
+ * by an external party (using a CoordinateFilter, for example).
+ virtual void geometryChanged();
+ * \brief
+ * by an external party.
+ void geometryChangedAction();
protected:
- /// The bounding box of this Geometry
- mutable std::unique_ptr<Envelope> envelope;
+ /// The bounding box of this Geometry
+ mutable std::unique_ptr<Envelope> envelope;
- /// Returns true if the array contains any non-empty Geometrys.
- static bool hasNonEmptyElements(const std::vector<Geometry *>* geometries);
+ /// Returns true if the array contains any non-empty Geometrys.
+ static bool hasNonEmptyElements(const std::vector<Geometry*>* geometries);
- /// Returns true if the CoordinateSequence contains any null elements.
- static bool hasNullElements(const CoordinateSequence* list);
+ /// Returns true if the CoordinateSequence contains any null elements.
+ static bool hasNullElements(const CoordinateSequence* list);
- /// Returns true if the vector contains any null elements.
- static bool hasNullElements(const std::vector<Geometry *>* lrs);
+ /// Returns true if the vector contains any null elements.
+ static bool hasNullElements(const std::vector<Geometry*>* lrs);
// static void reversePointOrder(CoordinateSequence* coordinates);
// static Coordinate& minCoordinate(CoordinateSequence* coordinates);
// static void scroll(CoordinateSequence* coordinates,Coordinate* firstCoordinate);
// static int indexOf(Coordinate* coordinate,CoordinateSequence* coordinates);
- /** \brief
- * Returns whether the two Geometrys are equal, from the point
- * of view of the equalsExact method.
- virtual bool isEquivalentClass(const Geometry *other) const;
+ /** \brief
+ * Returns whether the two Geometrys are equal, from the point
+ * of view of the equalsExact method.
+ virtual bool isEquivalentClass(const Geometry* other) const;
- static void checkNotGeometryCollection(const Geometry *g);
- // throw(IllegalArgumentException *);
+ static void checkNotGeometryCollection(const Geometry* g);
+ // throw(IllegalArgumentException *);
- //virtual void checkEqualSRID(Geometry *other);
+ //virtual void checkEqualSRID(Geometry *other);
- //virtual void checkEqualPrecisionModel(Geometry *other);
+ //virtual void checkEqualPrecisionModel(Geometry *other);
- virtual Envelope::Ptr computeEnvelopeInternal() const=0; //Abstract
+ virtual Envelope::Ptr computeEnvelopeInternal() const = 0; //Abstract
- virtual int compareToSameClass(const Geometry *geom) const=0; //Abstract
+ virtual int compareToSameClass(const Geometry* geom) const = 0; //Abstract
- int compare(std::vector<Coordinate> a, std::vector<Coordinate> b) const;
+ int compare(std::vector<Coordinate> a, std::vector<Coordinate> b) const;
- int compare(std::vector<Geometry *> a, std::vector<Geometry *> b) const;
+ int compare(std::vector<Geometry*> a, std::vector<Geometry*> b) const;
- bool equal(const Coordinate& a, const Coordinate& b,
- double tolerance) const;
- int SRID;
+ bool equal(const Coordinate& a, const Coordinate& b,
+ double tolerance) const;
+ int SRID;
- /// @deprecated
- //Geometry* toInternalGeometry(const Geometry *g) const;
+ /// @deprecated
+ //Geometry* toInternalGeometry(const Geometry *g) const;
- /// @deprecated
- //Geometry* fromInternalGeometry(const Geometry *g) const;
+ /// @deprecated
+ //Geometry* fromInternalGeometry(const Geometry *g) const;
- //virtual bool isRectangle() const { return false; } -- moved to public
+ //virtual bool isRectangle() const { return false; } -- moved to public
- Geometry(const Geometry &geom);
+ Geometry(const Geometry& geom);
- /** \brief
- * Construct a geometry with the given GeometryFactory.
- * Will keep a reference to the factory, so don't
- * delete it until al Geometry objects referring to
- * it are deleted.
- * @param factory
- Geometry(const GeometryFactory *factory);
+ /** \brief
+ * Construct a geometry with the given GeometryFactory.
+ * Will keep a reference to the factory, so don't
+ * delete it until al Geometry objects referring to
+ * it are deleted.
+ * @param factory
+ Geometry(const GeometryFactory* factory);
protected:
- virtual int getSortIndex() const = 0;
+ virtual int getSortIndex() const = 0;
private:
- class GEOS_DLL GeometryChangedFilter : public GeometryComponentFilter
- public:
- void filter_rw(Geometry* geom) override;
+ class GEOS_DLL GeometryChangedFilter : public GeometryComponentFilter {
+ public:
+ void filter_rw(Geometry* geom) override;
- static GeometryChangedFilter geometryChangedFilter;
+ static GeometryChangedFilter geometryChangedFilter;
- /// The GeometryFactory used to create this Geometry
- /// Externally owned
- const GeometryFactory* _factory;
+ /// The GeometryFactory used to create this Geometry
+ /// Externally owned
+ const GeometryFactory* _factory;
- void* _userData;
+ void* _userData;
/// \brief
@@ -888,7 +926,7 @@ private:
GEOS_DLL std::ostream& operator<< (std::ostream& os, const Geometry& geom);
struct GEOS_DLL GeometryGreaterThen {
- bool operator()(const Geometry *first, const Geometry *second);
+ bool operator()(const Geometry* first, const Geometry* second);
@@ -906,9 +944,9 @@ std::string jtsport();
// forbids that construct:
// http://lwg.github.com/issues/lwg-closed.html#2068
struct GeomPtrPair {
- typedef std::unique_ptr<Geometry> GeomPtr;
- GeomPtr first;
- GeomPtr second;
+ typedef std::unique_ptr<Geometry> GeomPtr;
+ GeomPtr first;
+ GeomPtr second;
diff --git a/include/geos/geom/GeometryCollection.h b/include/geos/geom/GeometryCollection.h
index b108837..151997f 100644
--- a/include/geos/geom/GeometryCollection.h
+++ b/include/geos/geom/GeometryCollection.h
@@ -33,11 +33,11 @@
namespace geos {
- namespace geom { // geos::geom
- class Coordinate;
- class CoordinateArraySequence;
+namespace geom { // geos::geom
+class Coordinate;
+class CoordinateArraySequence;
namespace geos {
@@ -55,155 +55,161 @@ namespace geom { // geos::geom
class GEOS_DLL GeometryCollection : public virtual Geometry {
public:
- typedef std::vector<Geometry *>::const_iterator const_iterator;
+ typedef std::vector<Geometry*>::const_iterator const_iterator;
- typedef std::vector<Geometry *>::iterator iterator;
+ typedef std::vector<Geometry*>::iterator iterator;
- const_iterator begin() const;
+ const_iterator begin() const;
- const_iterator end() const;
+ const_iterator end() const;
- * Creates and returns a full copy of this GeometryCollection object.
- * (including all coordinates contained by it).
- * @return a clone of this instance
- Geometry *clone() const override {
- return new GeometryCollection(*this);
+ * Creates and returns a full copy of this GeometryCollection object.
+ * (including all coordinates contained by it).
+ * @return a clone of this instance
+ Geometry*
+ clone() const override
+ return new GeometryCollection(*this);
- ~GeometryCollection() override;
+ ~GeometryCollection() override;
- void setSRID(int) override;
+ void setSRID(int) override;
- * \brief
- * Collects all coordinates of all subgeometries into a
- * CoordinateSequence.
- * Note that the returned coordinates are copies, so
- * you want be able to use them to modify the geometries
- * in place. Also you'll need to delete the CoordinateSequence
- * when finished using it.
- * @return the collected coordinates
- CoordinateSequence* getCoordinates() const override;
+ * \brief
+ * Collects all coordinates of all subgeometries into a
+ * CoordinateSequence.
+ * Note that the returned coordinates are copies, so
+ * you want be able to use them to modify the geometries
+ * in place. Also you'll need to delete the CoordinateSequence
+ * when finished using it.
+ * @return the collected coordinates
+ CoordinateSequence* getCoordinates() const override;
- bool isEmpty() const override;
+ bool isEmpty() const override;
- * \brief
- * Returns the maximum dimension of geometries in this collection
- * (0=point, 1=line, 2=surface)
- * @see Dimension::DimensionType
- Dimension::DimensionType getDimension() const override;
+ * \brief
+ * Returns the maximum dimension of geometries in this collection
+ * (0=point, 1=line, 2=surface)
+ * @see Dimension::DimensionType
+ Dimension::DimensionType getDimension() const override;
- /// Returns coordinate dimension.
- int getCoordinateDimension() const override;
+ /// Returns coordinate dimension.
+ int getCoordinateDimension() const override;
- Geometry* getBoundary() const override;
+ Geometry* getBoundary() const override;
- * \brief
- * Returns the maximum boundary dimension of geometries in
- * this collection.
- int getBoundaryDimension() const override;
+ * \brief
+ * Returns the maximum boundary dimension of geometries in
+ * this collection.
+ int getBoundaryDimension() const override;
- std::size_t getNumPoints() const override;
+ std::size_t getNumPoints() const override;
- std::string getGeometryType() const override;
+ std::string getGeometryType() const override;
- GeometryTypeId getGeometryTypeId() const override;
+ GeometryTypeId getGeometryTypeId() const override;
- bool equalsExact(const Geometry *other,
- double tolerance=0) const override;
+ bool equalsExact(const Geometry* other,
+ double tolerance = 0) const override;
- void apply_ro(CoordinateFilter *filter) const override;
+ void apply_ro(CoordinateFilter* filter) const override;
- void apply_rw(const CoordinateFilter *filter) override;
+ void apply_rw(const CoordinateFilter* filter) override;
- void apply_ro(GeometryFilter *filter) const override;
+ void apply_ro(GeometryFilter* filter) const override;
- void apply_rw(GeometryFilter *filter) override;
+ void apply_rw(GeometryFilter* filter) override;
- void apply_ro(GeometryComponentFilter *filter) const override;
+ void apply_ro(GeometryComponentFilter* filter) const override;
- void apply_rw(GeometryComponentFilter *filter) override;
+ void apply_rw(GeometryComponentFilter* filter) override;
- void apply_rw(CoordinateSequenceFilter& filter) override;
+ void apply_rw(CoordinateSequenceFilter& filter) override;
- void apply_ro(CoordinateSequenceFilter& filter) const override;
+ void apply_ro(CoordinateSequenceFilter& filter) const override;
- void normalize() override;
+ void normalize() override;
- const Coordinate* getCoordinate() const override;
+ const Coordinate* getCoordinate() const override;
- /// Returns the total area of this collection
- double getArea() const override;
+ /// Returns the total area of this collection
+ double getArea() const override;
- /// Returns the total length of this collection
- double getLength() const override;
+ /// Returns the total length of this collection
+ double getLength() const override;
- std::size_t getNumGeometries() const override;
+ std::size_t getNumGeometries() const override;
- const Geometry* getGeometryN(std::size_t n) const override;
+ const Geometry* getGeometryN(std::size_t n) const override;
* Creates a GeometryCollection with
* every component reversed.
* The order of the components in the collection are not reversed.
* @return a GeometryCollection in the reverse order
- Geometry* reverse() const override;
+ Geometry* reverse() const override;
protected:
- GeometryCollection(const GeometryCollection &gc);
- /** \brief
- * Construct a GeometryCollection with the given GeometryFactory.
- * it are deleted.
- * Will take ownership of the Geometry vector.
- * @param newGeoms
- * The <code>Geometry</code>s for this
- * <code>GeometryCollection</code>,
- * or <code>null</code> or an empty array to
- * create the empty geometry.
- * Elements may be empty <code>Geometry</code>s,
- * but not <code>null</code>s.
- * If construction succeed the created object will take
- * ownership of newGeoms vector and elements.
- * If construction fails "IllegalArgumentException *"
- * is thrown and it is your responsibility to delete newGeoms
- * vector and content.
- * @param newFactory the GeometryFactory used to create this geometry
- GeometryCollection(std::vector<Geometry *> *newGeoms, const GeometryFactory *newFactory);
- int getSortIndex() const override { return SORTINDEX_GEOMETRYCOLLECTION; };
- std::vector<Geometry *>* geometries;
- Envelope::Ptr computeEnvelopeInternal() const override;
- int compareToSameClass(const Geometry *gc) const override;
+ GeometryCollection(const GeometryCollection& gc);
+ /** \brief
+ * Construct a GeometryCollection with the given GeometryFactory.
+ * it are deleted.
+ * Will take ownership of the Geometry vector.
+ * @param newGeoms
+ * The <code>Geometry</code>s for this
+ * <code>GeometryCollection</code>,
+ * or <code>null</code> or an empty array to
+ * create the empty geometry.
+ * Elements may be empty <code>Geometry</code>s,
+ * but not <code>null</code>s.
+ * If construction succeed the created object will take
+ * ownership of newGeoms vector and elements.
+ * If construction fails "IllegalArgumentException *"
+ * is thrown and it is your responsibility to delete newGeoms
+ * vector and content.
+ * @param newFactory the GeometryFactory used to create this geometry
+ GeometryCollection(std::vector<Geometry*>* newGeoms, const GeometryFactory* newFactory);
+ int
+ getSortIndex() const override
+ return SORTINDEX_GEOMETRYCOLLECTION;
+ std::vector<Geometry*>* geometries;
+ Envelope::Ptr computeEnvelopeInternal() const override;
+ int compareToSameClass(const Geometry* gc) const override;
diff --git a/include/geos/geom/GeometryCollection.inl b/include/geos/geom/GeometryCollection.inl
index 53ad9d6..b6df063 100644
--- a/include/geos/geom/GeometryCollection.inl
+++ b/include/geos/geom/GeometryCollection.inl
@@ -7,7 +7,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -29,13 +29,13 @@ namespace geom { // geos::geom
INLINE GeometryCollection::const_iterator
GeometryCollection::begin() const
- return geometries->begin();
+ return geometries->begin();
GeometryCollection::end() const
- return geometries->end();
+ return geometries->end();
diff --git a/include/geos/geom/GeometryComponentFilter.h b/include/geos/geom/GeometryComponentFilter.h
index ea37325..514b64f 100644
--- a/include/geos/geom/GeometryComponentFilter.h
+++ b/include/geos/geom/GeometryComponentFilter.h
@@ -19,9 +19,9 @@
#include <geos/inline.h>
namespace geos {
- class Geometry;
+class Geometry;
namespace geos {
@@ -43,16 +43,17 @@ namespace geom { // geos::geom
class GEOS_DLL GeometryComponentFilter {
public:
- * Performs an operation with or on <code>geom</code>.
- * @param geom a <code>Geometry</code> to which the filter
- * is applied.
- virtual void filter_rw(Geometry *geom);
- virtual void filter_ro(const Geometry *geom);
- virtual ~GeometryComponentFilter() {}
+ * Performs an operation with or on <code>geom</code>.
+ * @param geom a <code>Geometry</code> to which the filter
+ * is applied.
+ virtual void filter_rw(Geometry* geom);
+ virtual void filter_ro(const Geometry* geom);
+ virtual
+ ~GeometryComponentFilter() {}
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index 70b8441..8af6aaf 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -33,22 +33,22 @@
#include <cassert>
namespace geos {
- namespace geom {
- class CoordinateSequenceFactory;
- class Coordinate;
- class CoordinateSequence;
- class Envelope;
- class Geometry;
- class GeometryCollection;
- class LineString;
- class LinearRing;
- class MultiLineString;
- class MultiPoint;
- class MultiPolygon;
- class Point;
- class Polygon;
+namespace geom {
+class CoordinateSequenceFactory;
+class Coordinate;
+class CoordinateSequence;
+class Envelope;
+class Geometry;
+class GeometryCollection;
+class LineString;
+class LinearRing;
+class MultiLineString;
+class MultiPoint;
+class MultiPolygon;
+class Point;
+class Polygon;
namespace geos {
@@ -67,416 +67,418 @@ namespace geom { // geos::geom
class GEOS_DLL GeometryFactory {
private:
- struct GeometryFactoryDeleter
- void operator()(GeometryFactory* p) const
- p->destroy();
+ struct GeometryFactoryDeleter {
+ void
+ operator()(GeometryFactory* p) const
+ p->destroy();
public:
- using Ptr = std::unique_ptr<GeometryFactory, GeometryFactoryDeleter>;
- * \brief
- * Constructs a GeometryFactory that generates Geometries having a
- * floating PrecisionModel and a spatial-reference ID of 0.
- static GeometryFactory::Ptr create();
- * \brief
- * the given PrecisionModel, spatial-reference ID, and
- * CoordinateSequence implementation.
- * NOTES:
- * (1) the given PrecisionModel is COPIED
- * (2) the CoordinateSequenceFactory is NOT COPIED
- * and must be available for the whole lifetime
- * of the GeometryFactory
- static GeometryFactory::Ptr create(const PrecisionModel *pm, int newSRID,
- CoordinateSequenceFactory *nCoordinateSequenceFactory);
- * \brief
- * Constructs a GeometryFactory that generates Geometries having the
- * given CoordinateSequence implementation, a double-precision floating
- * PrecisionModel and a spatial-reference ID of 0.
- static GeometryFactory::Ptr create(CoordinateSequenceFactory *nCoordinateSequenceFactory);
- * \brief
- * the given PrecisionModel and the default CoordinateSequence
- * implementation.
- * @param pm the PrecisionModel to use
- static GeometryFactory::Ptr create(const PrecisionModel *pm);
- * \brief
- * the given {@link PrecisionModel} and spatial-reference ID,
- * and the default CoordinateSequence implementation.
- * @param pm the PrecisionModel to use, will be copied internally
- * @param newSRID the SRID to use
- static GeometryFactory::Ptr create(const PrecisionModel* pm, int newSRID);
- * \brief Copy constructor
- * @param gf the GeometryFactory to clone from
- static GeometryFactory::Ptr create(const GeometryFactory &gf);
- * \brief
- * Return a pointer to the default GeometryFactory.
- * This is a global shared object instantiated
- * using default constructor.
- static const GeometryFactory*
- getDefaultInstance();
+ using Ptr = std::unique_ptr<GeometryFactory, GeometryFactoryDeleter>;
+ * \brief
+ * Constructs a GeometryFactory that generates Geometries having a
+ * floating PrecisionModel and a spatial-reference ID of 0.
+ static GeometryFactory::Ptr create();
+ * \brief
+ * the given PrecisionModel, spatial-reference ID, and
+ * CoordinateSequence implementation.
+ * NOTES:
+ * (1) the given PrecisionModel is COPIED
+ * (2) the CoordinateSequenceFactory is NOT COPIED
+ * and must be available for the whole lifetime
+ * of the GeometryFactory
+ static GeometryFactory::Ptr create(const PrecisionModel* pm, int newSRID,
+ CoordinateSequenceFactory* nCoordinateSequenceFactory);
+ * \brief
+ * Constructs a GeometryFactory that generates Geometries having the
+ * given CoordinateSequence implementation, a double-precision floating
+ * PrecisionModel and a spatial-reference ID of 0.
+ static GeometryFactory::Ptr create(CoordinateSequenceFactory* nCoordinateSequenceFactory);
+ * \brief
+ * the given PrecisionModel and the default CoordinateSequence
+ * implementation.
+ * @param pm the PrecisionModel to use
+ static GeometryFactory::Ptr create(const PrecisionModel* pm);
+ * \brief
+ * the given {@link PrecisionModel} and spatial-reference ID,
+ * and the default CoordinateSequence implementation.
+ * @param pm the PrecisionModel to use, will be copied internally
+ * @param newSRID the SRID to use
+ static GeometryFactory::Ptr create(const PrecisionModel* pm, int newSRID);
+ * \brief Copy constructor
+ * @param gf the GeometryFactory to clone from
+ static GeometryFactory::Ptr create(const GeometryFactory& gf);
+ * \brief
+ * Return a pointer to the default GeometryFactory.
+ * This is a global shared object instantiated
+ * using default constructor.
+ static const GeometryFactory*
+ getDefaultInstance();
//Skipped a lot of list to array convertors
- Point* createPointFromInternalCoord(const Coordinate* coord,
- const Geometry *exemplar) const;
+ Point* createPointFromInternalCoord(const Coordinate* coord,
+ const Geometry* exemplar) const;
- /// Converts an Envelope to a Geometry.
- /// Returned Geometry can be a Point, a Polygon or an EMPTY geom.
- Geometry* toGeometry(const Envelope* envelope) const;
+ /// Converts an Envelope to a Geometry.
+ /// Returned Geometry can be a Point, a Polygon or an EMPTY geom.
+ Geometry* toGeometry(const Envelope* envelope) const;
- /// \brief
- /// Returns the PrecisionModel that Geometries created by this
- /// factory will be associated with.
+ /// \brief
+ /// Returns the PrecisionModel that Geometries created by this
+ /// factory will be associated with.
- /// Creates an EMPTY Point
- Point* createPoint() const;
+ /// Creates an EMPTY Point
+ Point* createPoint() const;
- /// Creates a Point using the given Coordinate
- Point* createPoint(const Coordinate& coordinate) const;
+ /// Creates a Point using the given Coordinate
+ Point* createPoint(const Coordinate& coordinate) const;
- /// Creates a Point taking ownership of the given CoordinateSequence
- Point* createPoint(CoordinateSequence *coordinates) const;
+ /// Creates a Point taking ownership of the given CoordinateSequence
+ Point* createPoint(CoordinateSequence* coordinates) const;
- /// Creates a Point with a deep-copy of the given CoordinateSequence.
- Point* createPoint(const CoordinateSequence &coordinates) const;
+ /// Creates a Point with a deep-copy of the given CoordinateSequence.
+ Point* createPoint(const CoordinateSequence& coordinates) const;
- /// Construct an EMPTY GeometryCollection
- GeometryCollection* createGeometryCollection() const;
+ /// Construct an EMPTY GeometryCollection
+ GeometryCollection* createGeometryCollection() const;
- /// Construct the EMPTY Geometry
- Geometry* createEmptyGeometry() const;
+ /// Construct the EMPTY Geometry
+ Geometry* createEmptyGeometry() const;
- /// Construct a GeometryCollection taking ownership of given arguments
- std::vector<Geometry *> *newGeoms) const;
+ /// Construct a GeometryCollection taking ownership of given arguments
+ std::vector<Geometry*>* newGeoms) const;
- /// Constructs a GeometryCollection with a deep-copy of args
- const std::vector<Geometry *> &newGeoms) const;
+ /// Constructs a GeometryCollection with a deep-copy of args
+ const std::vector<Geometry*>& newGeoms) const;
- /// Construct an EMPTY MultiLineString
- MultiLineString* createMultiLineString() const;
- /// Construct a MultiLineString taking ownership of given arguments
- std::vector<Geometry *> *newLines) const;
- /// Construct a MultiLineString with a deep-copy of given arguments
- const std::vector<Geometry *> &fromLines) const;
- /// Construct an EMPTY MultiPolygon
- MultiPolygon* createMultiPolygon() const;
- /// Construct a MultiPolygon taking ownership of given arguments
- MultiPolygon* createMultiPolygon(std::vector<Geometry *> *newPolys) const;
- /// Construct a MultiPolygon with a deep-copy of given arguments
- const std::vector<Geometry *> &fromPolys) const;
- /// Construct an EMPTY LinearRing
- LinearRing* createLinearRing() const;
- /// Construct a LinearRing taking ownership of given arguments
- LinearRing* createLinearRing(CoordinateSequence* newCoords) const;
- std::unique_ptr<Geometry> createLinearRing(
- std::unique_ptr<CoordinateSequence> newCoords) const;
- /// Construct a LinearRing with a deep-copy of given arguments
- const CoordinateSequence& coordinates) const;
- /// Constructs an EMPTY <code>MultiPoint</code>.
- MultiPoint* createMultiPoint() const;
- /// Construct a MultiPoint taking ownership of given arguments
- MultiPoint* createMultiPoint(std::vector<Geometry *> *newPoints) const;
- /// Construct a MultiPoint with a deep-copy of given arguments
- const std::vector<Geometry *> &fromPoints) const;
- /// \brief
- /// Construct a MultiPoint containing a Point geometry
- /// for each Coordinate in the given list.
- const CoordinateSequence &fromCoords) const;
- /// \brief
- /// for each Coordinate in the given vector.
- const std::vector<Coordinate> &fromCoords) const;
- /// Construct an EMPTY Polygon
- Polygon* createPolygon() const;
- /// Construct a Polygon taking ownership of given arguments
- Polygon* createPolygon(LinearRing *shell,
- std::vector<Geometry *> *holes) const;
- /// Construct a Polygon with a deep-copy of given arguments
- Polygon* createPolygon(const LinearRing &shell,
- const std::vector<Geometry *> &holes) const;
- /// Construct an EMPTY LineString
- LineString* createLineString() const;
- /// Copy a LineString
- std::unique_ptr<LineString> createLineString(const LineString& ls) const;
- /// Construct a LineString taking ownership of given argument
- LineString* createLineString(CoordinateSequence* coordinates) const;
- std::unique_ptr<Geometry> createLineString(
- std::unique_ptr<CoordinateSequence> coordinates) const;
- /// Construct a LineString with a deep-copy of given argument
- * Build an appropriate <code>Geometry</code>, <code>MultiGeometry</code>, or
- * <code>GeometryCollection</code> to contain the <code>Geometry</code>s in
- * it.
- * For example:
- * - If <code>geomList</code> contains a single <code>Polygon</code>,
- * the <code>Polygon</code> is returned.
- * - If <code>geomList</code> contains several <code>Polygon</code>s, a
- * <code>MultiPolygon</code> is returned.
- * - If <code>geomList</code> contains some <code>Polygon</code>s and
- * some <code>LineString</code>s, a <code>GeometryCollection</code> is
- * returned.
- * - If <code>geomList</code> is empty, an empty
- * <code>GeometryCollection</code> is returned
- * Note that this method does not "flatten" Geometries in the input,
- * and hence if any MultiGeometries are contained in the input a
- * GeometryCollection containing them will be returned.
- * @param newGeoms the <code>Geometry</code>s to combine
- * @return
- * A <code>Geometry</code> of the "smallest", "most type-specific"
- * class that can contain the elements of <code>geomList</code>.
- * NOTE: the returned Geometry will take ownership of the
- * given vector AND its elements
- Geometry* buildGeometry(std::vector<Geometry *> *geoms) const;
- /// See buildGeometry(std::vector<Geometry *>&) for semantics
- /// Will clone the geometries accessible trough the iterator.
- /// @tparam T an iterator yelding something which casts to const Geometry*
- /// @param from start iterator
- /// @param toofar end iterator
- std::unique_ptr<Geometry> buildGeometry(T from, T toofar) const
- bool isHeterogeneous = false;
- size_t count = 0;
- int geomClass = -1;
- for (T i=from; i != toofar; ++i)
+ /// Construct an EMPTY MultiLineString
+ MultiLineString* createMultiLineString() const;
+ /// Construct a MultiLineString taking ownership of given arguments
+ std::vector<Geometry*>* newLines) const;
+ /// Construct a MultiLineString with a deep-copy of given arguments
+ const std::vector<Geometry*>& fromLines) const;
+ /// Construct an EMPTY MultiPolygon
+ MultiPolygon* createMultiPolygon() const;
+ /// Construct a MultiPolygon taking ownership of given arguments
+ MultiPolygon* createMultiPolygon(std::vector<Geometry*>* newPolys) const;
+ /// Construct a MultiPolygon with a deep-copy of given arguments
+ const std::vector<Geometry*>& fromPolys) const;
+ /// Construct an EMPTY LinearRing
+ LinearRing* createLinearRing() const;
+ /// Construct a LinearRing taking ownership of given arguments
+ LinearRing* createLinearRing(CoordinateSequence* newCoords) const;
+ std::unique_ptr<Geometry> createLinearRing(
+ std::unique_ptr<CoordinateSequence> newCoords) const;
+ /// Construct a LinearRing with a deep-copy of given arguments
+ const CoordinateSequence& coordinates) const;
+ /// Constructs an EMPTY <code>MultiPoint</code>.
+ MultiPoint* createMultiPoint() const;
+ /// Construct a MultiPoint taking ownership of given arguments
+ MultiPoint* createMultiPoint(std::vector<Geometry*>* newPoints) const;
+ /// Construct a MultiPoint with a deep-copy of given arguments
+ const std::vector<Geometry*>& fromPoints) const;
+ /// \brief
+ /// Construct a MultiPoint containing a Point geometry
+ /// for each Coordinate in the given list.
+ const CoordinateSequence& fromCoords) const;
+ /// \brief
+ /// for each Coordinate in the given vector.
+ const std::vector<Coordinate>& fromCoords) const;
+ /// Construct an EMPTY Polygon
+ Polygon* createPolygon() const;
+ /// Construct a Polygon taking ownership of given arguments
+ Polygon* createPolygon(LinearRing* shell,
+ std::vector<Geometry*>* holes) const;
+ /// Construct a Polygon with a deep-copy of given arguments
+ Polygon* createPolygon(const LinearRing& shell,
+ const std::vector<Geometry*>& holes) const;
+ /// Construct an EMPTY LineString
+ LineString* createLineString() const;
+ /// Copy a LineString
+ std::unique_ptr<LineString> createLineString(const LineString& ls) const;
+ /// Construct a LineString taking ownership of given argument
+ LineString* createLineString(CoordinateSequence* coordinates) const;
+ std::unique_ptr<Geometry> createLineString(
+ std::unique_ptr<CoordinateSequence> coordinates) const;
+ /// Construct a LineString with a deep-copy of given argument
+ * Build an appropriate <code>Geometry</code>, <code>MultiGeometry</code>, or
+ * <code>GeometryCollection</code> to contain the <code>Geometry</code>s in
+ * it.
+ * For example:
+ * - If <code>geomList</code> contains a single <code>Polygon</code>,
+ * the <code>Polygon</code> is returned.
+ * - If <code>geomList</code> contains several <code>Polygon</code>s, a
+ * <code>MultiPolygon</code> is returned.
+ * - If <code>geomList</code> contains some <code>Polygon</code>s and
+ * some <code>LineString</code>s, a <code>GeometryCollection</code> is
+ * returned.
+ * - If <code>geomList</code> is empty, an empty
+ * <code>GeometryCollection</code> is returned
+ * Note that this method does not "flatten" Geometries in the input,
+ * and hence if any MultiGeometries are contained in the input a
+ * GeometryCollection containing them will be returned.
+ * @param newGeoms the <code>Geometry</code>s to combine
+ * @return
+ * A <code>Geometry</code> of the "smallest", "most type-specific"
+ * class that can contain the elements of <code>geomList</code>.
+ * NOTE: the returned Geometry will take ownership of the
+ * given vector AND its elements
+ Geometry* buildGeometry(std::vector<Geometry*>* geoms) const;
+ /// See buildGeometry(std::vector<Geometry *>&) for semantics
+ /// Will clone the geometries accessible trough the iterator.
+ /// @tparam T an iterator yelding something which casts to const Geometry*
+ /// @param from start iterator
+ /// @param toofar end iterator
+ buildGeometry(T from, T toofar) const
- ++count;
- const Geometry* g = *i;
- if ( geomClass < 0 ) {
- geomClass = g->getSortIndex();
- else if ( geomClass != g->getSortIndex() ) {
- isHeterogeneous = true;
+ bool isHeterogeneous = false;
+ size_t count = 0;
+ int geomClass = -1;
+ for(T i = from; i != toofar; ++i) {
+ ++count;
+ const Geometry* g = *i;
+ if(geomClass < 0) {
+ geomClass = g->getSortIndex();
+ else if(geomClass != g->getSortIndex()) {
+ isHeterogeneous = true;
+ // for the empty geometry, return an empty GeometryCollection
+ if(count == 0) {
+ return std::unique_ptr<Geometry>(createGeometryCollection());
+ // for the single geometry, return a clone
+ if(count == 1) {
+ return std::unique_ptr<Geometry>((*from)->clone());
+ // Now we know it is a collection
+ // FIXME:
+ // Until we tweak all the createMulti* interfaces
+ // to support taking iterators we'll have to build
+ // a custom vector here.
+ std::vector<Geometry*> fromGeoms;
+ fromGeoms.push_back(const_cast<Geometry*>(g));
+ // for an heterogeneous ...
+ if(isHeterogeneous) {
+ return std::unique_ptr<Geometry>(createGeometryCollection(fromGeoms));
+ // At this point we know the collection is not hetereogenous.
+ if(dynamic_cast<const Polygon*>(*from)) {
+ return std::unique_ptr<Geometry>(createMultiPolygon(fromGeoms));
+ else if(dynamic_cast<const LineString*>(*from)) {
+ return std::unique_ptr<Geometry>(createMultiLineString(fromGeoms));
+ else if(dynamic_cast<const Point*>(*from)) {
+ return std::unique_ptr<Geometry>(createMultiPoint(fromGeoms));
+ // FIXME: Why not to throw an exception? --mloskot
+ assert(0); // buildGeomtry encountered an unkwnon geometry type
+ return std::unique_ptr<Geometry>(); // nullptr
- // for the empty geometry, return an empty GeometryCollection
- if ( count == 0 ) {
- return std::unique_ptr<Geometry>( createGeometryCollection() );
+ /** \brief
+ * This function does the same thing of the omonimouse function
+ * taking vector pointer instead of reference.
+ * The difference is that this version will copy needed data
+ * leaving ownership to the caller.
+ Geometry* buildGeometry(const std::vector<Geometry*>& geoms) const;
- // for the single geometry, return a clone
- if ( count == 1 ) {
- return std::unique_ptr<Geometry>( (*from)->clone() );
+ int getSRID() const;
- // Now we know it is a collection
+ /// \brief
+ /// Returns the CoordinateSequenceFactory associated
+ /// with this GeometryFactory
+ const CoordinateSequenceFactory* getCoordinateSequenceFactory() const;
- // FIXME:
- // Until we tweak all the createMulti* interfaces
- // to support taking iterators we'll have to build
- // a custom vector here.
- std::vector<Geometry*> fromGeoms;
- for (T i=from; i != toofar; ++i) {
- fromGeoms.push_back(const_cast<Geometry*>(g));
+ /// Returns a clone of given Geometry.
+ Geometry* createGeometry(const Geometry* g) const;
+ /// Destroy a Geometry, or release it
+ void destroyGeometry(Geometry* g) const;
- // for an heterogeneous ...
- if ( isHeterogeneous ) {
- return std::unique_ptr<Geometry>( createGeometryCollection(fromGeoms) );
- // At this point we know the collection is not hetereogenous.
- if ( dynamic_cast<const Polygon*>(*from) ) {
- return std::unique_ptr<Geometry>( createMultiPolygon(fromGeoms) );
- } else if ( dynamic_cast<const LineString*>(*from) ) {
- return std::unique_ptr<Geometry>( createMultiLineString(fromGeoms) );
- } else if ( dynamic_cast<const Point*>(*from) ) {
- return std::unique_ptr<Geometry>( createMultiPoint(fromGeoms) );
- // FIXME: Why not to throw an exception? --mloskot
- assert(0); // buildGeomtry encountered an unkwnon geometry type
- return std::unique_ptr<Geometry>(); // nullptr
- /** \brief
- * This function does the same thing of the omonimouse function
- * taking vector pointer instead of reference.
- * The difference is that this version will copy needed data
- * leaving ownership to the caller.
- Geometry* buildGeometry(const std::vector<Geometry *> &geoms) const;
- int getSRID() const;
- /// \brief
- /// Returns the CoordinateSequenceFactory associated
- /// with this GeometryFactory
- const CoordinateSequenceFactory* getCoordinateSequenceFactory() const;
- /// Returns a clone of given Geometry.
- Geometry* createGeometry(const Geometry *g) const;
- /// Destroy a Geometry, or release it
- void destroyGeometry(Geometry *g) const;
- /// Request that the instance is deleted.
- /// It will really be deleted only after last child Geometry is
- /// deleted. Do not use the instance anymore after calling this function
- /// (unless you're a live child!).
- void destroy();
+ /// Request that the instance is deleted.
+ /// It will really be deleted only after last child Geometry is
+ /// deleted. Do not use the instance anymore after calling this function
+ /// (unless you're a live child!).
+ void destroy();
protected:
- * \brief
- GeometryFactory();
- * \brief
- * NOTES:
- GeometryFactory(const PrecisionModel *pm, int newSRID,
- * \brief
- GeometryFactory(CoordinateSequenceFactory *nCoordinateSequenceFactory);
- * \brief
- * implementation.
- GeometryFactory(const PrecisionModel *pm);
- * \brief
- GeometryFactory(const PrecisionModel* pm, int newSRID);
- GeometryFactory(const GeometryFactory &gf);
- /// Destructor
- virtual ~GeometryFactory();
+ * \brief
+ GeometryFactory();
+ * \brief
+ * NOTES:
+ GeometryFactory(const PrecisionModel* pm, int newSRID,
+ * \brief
+ GeometryFactory(CoordinateSequenceFactory* nCoordinateSequenceFactory);
+ * \brief
+ * implementation.
+ GeometryFactory(const PrecisionModel* pm);
+ * \brief
+ GeometryFactory(const PrecisionModel* pm, int newSRID);
+ GeometryFactory(const GeometryFactory& gf);
+ /// Destructor
+ virtual ~GeometryFactory();
private:
- const PrecisionModel* precisionModel;
- int SRID;
- const CoordinateSequenceFactory *coordinateListFactory;
+ const PrecisionModel* precisionModel;
+ int SRID;
+ const CoordinateSequenceFactory* coordinateListFactory;
- mutable int _refCount;
- bool _autoDestroy;
+ mutable int _refCount;
+ bool _autoDestroy;
-friend class Geometry;
+ friend class Geometry;
- void addRef() const;
- void dropRef() const;
+ void addRef() const;
+ void dropRef() const;
diff --git a/include/geos/geom/GeometryFactory.inl b/include/geos/geom/GeometryFactory.inl
index 74e2d14..2bdd6a1 100644
--- a/include/geos/geom/GeometryFactory.inl
+++ b/include/geos/geom/GeometryFactory.inl
@@ -7,7 +7,7 @@
@@ -32,13 +32,13 @@ namespace geom { // geos::geom
INLINE int
GeometryFactory::getSRID() const
- return SRID;
+ return SRID;
INLINE const CoordinateSequenceFactory*
GeometryFactory::getCoordinateSequenceFactory() const
- return coordinateListFactory;
+ return coordinateListFactory;
} // namespace geos::geom
diff --git a/include/geos/geom/GeometryFilter.h b/include/geos/geom/GeometryFilter.h
index 9bbaa5f..7ac4c38 100644
--- a/include/geos/geom/GeometryFilter.h
+++ b/include/geos/geom/GeometryFilter.h
@@ -24,9 +24,9 @@
#include <cassert>
namespace geos {
- class Geometry;
+class Geometry;
namespace geos {
@@ -46,20 +46,29 @@ namespace geom { // geos::geom
class GEOS_DLL GeometryFilter {
public:
- * is applied.
- * NOTE: this are not pure abstract to allow read-only
- * or read-write-only filters to avoid defining a fake
- * version of the not-implemented kind.
- virtual void filter_ro(const Geometry * /*geom*/) { assert(0); }
- virtual void filter_rw(Geometry * /*geom*/) { assert(0); }
+ * is applied.
+ * NOTE: this are not pure abstract to allow read-only
+ * or read-write-only filters to avoid defining a fake
+ * version of the not-implemented kind.
+ virtual void
+ filter_ro(const Geometry* /*geom*/)
+ assert(0);
+ virtual void
+ filter_rw(Geometry* /*geom*/)
+ assert(0);
- virtual ~GeometryFilter() {}
+ virtual
+ ~GeometryFilter() {}
diff --git a/include/geos/geom/IntersectionMatrix.h b/include/geos/geom/IntersectionMatrix.h
index e225f4b..e1c1dcb 100644
--- a/include/geos/geom/IntersectionMatrix.h
+++ b/include/geos/geom/IntersectionMatrix.h
@@ -52,327 +52,327 @@ class GEOS_DLL IntersectionMatrix {
public:
- /** \brief
- * Default constructor.
- * Creates an IntersectionMatrix with Dimension::False
- * dimension values ('F').
- IntersectionMatrix();
- /** \brief
- * Overriden constructor.
- * Creates an IntersectionMatrix with the given dimension symbols.
- * @param elements - reference to string containing pattern
- * of dimension values for elements.
- IntersectionMatrix(const std::string& elements);
- /** \brief
- * Copy constructor.
- * Creates an IntersectionMatrix with the same elements as other.
- * \todo Add assignment operator to make this class fully copyable.
- IntersectionMatrix(const IntersectionMatrix &other);
- /** \brief
- * Returns whether the elements of this IntersectionMatrix
- * satisfies the required dimension symbols.
- * @param requiredDimensionSymbols - nine dimension symbols with
- * which to compare the elements of this IntersectionMatrix.
- * Possible values are {T, F, * , 0, 1, 2}.
- * @return true if this IntersectionMatrix matches the required
- * dimension symbols.
- bool matches(const std::string& requiredDimensionSymbols) const;
- /** \brief
- * Tests if given dimension value satisfies the dimension symbol.
- * @param actualDimensionValue - valid dimension value stored in
- * the IntersectionMatrix.
- * Possible values are {TRUE, FALSE, DONTCARE, 0, 1, 2}.
- * @param requiredDimensionSymbol - a character used in the string
- * representation of an IntersectionMatrix.
- * @return true if the dimension symbol encompasses the
- * dimension value.
- static bool matches(int actualDimensionValue,
- char requiredDimensionSymbol);
- /** \brief
- * Returns true if each of the actual dimension symbols satisfies
- * the corresponding required dimension symbol.
- * @param actualDimensionSymbols - nine dimension symbols to validate.
- * @param requiredDimensionSymbols - nine dimension symbols to
- * validate against.
- * @return true if each of the required dimension symbols encompass
- * the corresponding actual dimension symbol.
- static bool matches(const std::string& actualDimensionSymbols,
- const std::string& requiredDimensionSymbols);
- /** \brief
- * Adds one matrix to another.
- * Addition is defined by taking the maximum dimension value
- * of each position in the summand matrices.
- * @param other - the matrix to add.
- * \todo Why the 'other' matrix is not passed by const-reference?
- void add(IntersectionMatrix* other);
- /** \brief
- * Changes the value of one of this IntersectionMatrixs elements.
- * @param row - the row of this IntersectionMatrix, indicating
- * the interior, boundary or exterior of the first Geometry.
- * @param column - the column of this IntersectionMatrix,
- * indicating the interior, boundary or exterior of the
- * second Geometry.
- * @param dimensionValue - the new value of the element.
- void set(int row, int column, int dimensionValue);
- /** \brief
- * Changes the elements of this IntersectionMatrix to the dimension
- * symbols in dimensionSymbols.
- * @param dimensionSymbols - nine dimension symbols to which to
- * set this IntersectionMatrix elements.
- void set(const std::string& dimensionSymbols);
- /** \brief
- * Changes the specified element to minimumDimensionValue if the
- * element is less.
- * @param column - the column of this IntersectionMatrix, indicating
- * the interior, boundary or exterior of the second Geometry.
- * @param minimumDimensionValue - the dimension value with which
- * to compare the element. The order of dimension values
- * from least to greatest is {DONTCARE, TRUE, FALSE, 0, 1, 2}.
- void setAtLeast(size_t row, size_t column, int minimumDimensionValue);
- /** \brief
- * If row >= 0 and column >= 0, changes the specified element
- * to minimumDimensionValue if the element is less.
- * Does nothing if row <0 or column < 0.
- * @param row -
- * the row of this IntersectionMatrix,
- * first Geometry.
- * @param column -
- * the column of this IntersectionMatrix,
- * the dimension value with which
- void setAtLeastIfValid(int row, int column, int minimumDimensionValue);
- /** \brief
- * For each element in this IntersectionMatrix, changes the element to
- * the corresponding minimum dimension symbol if the element is less.
- * @param minimumDimensionSymbols -
- * nine dimension symbols with which
- * to compare the elements of this IntersectionMatrix.
- * The order of dimension values from least to greatest is
- * {DONTCARE, TRUE, FALSE, 0, 1, 2} .
- void setAtLeast(std::string minimumDimensionSymbols);
- /** \brief
- * Changes the elements of this IntersectionMatrix to dimensionValue.
- * the dimension value to which to set this
- * IntersectionMatrix elements. Possible values {TRUE,
- * FALSE, DONTCARE, 0, 1, 2}.
- void setAll(int dimensionValue);
- /** \brief
- * Returns the value of one of this IntersectionMatrixs elements.
- * @param row -
- * the row of this IntersectionMatrix, indicating the
- * interior, boundary or exterior of the first Geometry.
- * @param column -
- * the column of this IntersectionMatrix, indicating the
- * interior, boundary or exterior of the second Geometry.
- * @return the dimension value at the given matrix position.
- int get(int row, int column) const;
- /** \brief
- * Returns true if this IntersectionMatrix is FF*FF****.
- * @return true if the two Geometrys related by this
- * IntersectionMatrix are disjoint.
- bool isDisjoint() const;
- /** \brief
- * Returns true if isDisjoint returns false.
- * IntersectionMatrix intersect.
- bool isIntersects() const;
- /** \brief
- * Returns true if this IntersectionMatrix is FT*******, F**T*****
- * or F***T****.
- * @param dimensionOfGeometryA - the dimension of the first Geometry.
- * @param dimensionOfGeometryB - the dimension of the second Geometry.
- * @return true if the two Geometry's related by this
- * IntersectionMatrix touch, false if both Geometrys
- * are points.
- bool isTouches(int dimensionOfGeometryA, int dimensionOfGeometryB)
- const;
- /** \brief
- * Returns true if this IntersectionMatrix is:
- * - T*T****** (for a point and a curve, a point and an area or
- * a line and an area)
- * - 0******** (for two curves)
- * @param dimensionOfGeometryA - he dimension of the first Geometry.
- * IntersectionMatrix cross.
- * For this function to return true, the Geometrys must be a point
- * and a curve; a point and a surface; two curves; or a curve and
- * a surface.
- bool isCrosses(int dimensionOfGeometryA, int dimensionOfGeometryB)
- const;
- /** \brief
- * Returns true if this IntersectionMatrix is T*F**F***.
- * @return true if the first Geometry is within the second.
- bool isWithin() const;
- /** \brief
- * Returns true if this IntersectionMatrix is T*****FF*.
- * @return true if the first Geometry contains the second.
- bool isContains() const;
- /** \brief
- * Returns true if this IntersectionMatrix is T*F**FFF*.
- * IntersectionMatrix are equal; the Geometrys must have
- * the same dimension for this function to return true
- bool isEquals(int dimensionOfGeometryA, int dimensionOfGeometryB)
- const;
- /** \brief
- * - T*T***T** (for two points or two surfaces)
- * - 1*T***T** (for two curves)
- * IntersectionMatrix overlap.
- * For this function to return true, the Geometrys must be two points,
- * two curves or two surfaces.
- bool isOverlaps(int dimensionOfGeometryA, int dimensionOfGeometryB)
- const;
- /** \brief
- * Returns true if this IntersectionMatrix is <code>T*****FF*</code>
- * or <code>*T****FF*</code> or <code>***T**FF*</code>
- * or <code>****T*FF*</code>
- * @return <code>true</code> if the first Geometry covers the
- * second
- bool isCovers() const;
- /** \brief
- * Returns true if this IntersectionMatrix is <code>T*F**F***</code>
- * <code>*TF**F***</code> or <code>**FT*F***</code>
- * or <code>**F*TF***</code>
- * @return <code>true</code> if the first Geometry is covered by
- * the second
- bool isCoveredBy() const;
- /** \brief
- * Transposes this IntersectionMatrix.
- * @return this IntersectionMatrix as a convenience.
- * \todo It returns 'this' pointer so why not to return const-pointer?
- * \todo May be it would be better to return copy of transposed matrix?
- IntersectionMatrix* transpose();
- /** \brief
- * Returns a nine-character String representation of this
- * IntersectionMatrix.
- * @return the nine dimension symbols of this IntersectionMatrix
- * in row-major order.
- std::string toString() const;
+ /** \brief
+ * Default constructor.
+ * Creates an IntersectionMatrix with Dimension::False
+ * dimension values ('F').
+ IntersectionMatrix();
+ /** \brief
+ * Overriden constructor.
+ * Creates an IntersectionMatrix with the given dimension symbols.
+ * @param elements - reference to string containing pattern
+ * of dimension values for elements.
+ IntersectionMatrix(const std::string& elements);
+ /** \brief
+ * Copy constructor.
+ * Creates an IntersectionMatrix with the same elements as other.
+ * \todo Add assignment operator to make this class fully copyable.
+ IntersectionMatrix(const IntersectionMatrix& other);
+ /** \brief
+ * Returns whether the elements of this IntersectionMatrix
+ * satisfies the required dimension symbols.
+ * @param requiredDimensionSymbols - nine dimension symbols with
+ * which to compare the elements of this IntersectionMatrix.
+ * Possible values are {T, F, * , 0, 1, 2}.
+ * @return true if this IntersectionMatrix matches the required
+ * dimension symbols.
+ bool matches(const std::string& requiredDimensionSymbols) const;
+ /** \brief
+ * Tests if given dimension value satisfies the dimension symbol.
+ * @param actualDimensionValue - valid dimension value stored in
+ * the IntersectionMatrix.
+ * Possible values are {TRUE, FALSE, DONTCARE, 0, 1, 2}.
+ * @param requiredDimensionSymbol - a character used in the string
+ * representation of an IntersectionMatrix.
+ * @return true if the dimension symbol encompasses the
+ * dimension value.
+ static bool matches(int actualDimensionValue,
+ char requiredDimensionSymbol);
+ /** \brief
+ * Returns true if each of the actual dimension symbols satisfies
+ * the corresponding required dimension symbol.
+ * @param actualDimensionSymbols - nine dimension symbols to validate.
+ * @param requiredDimensionSymbols - nine dimension symbols to
+ * validate against.
+ * @return true if each of the required dimension symbols encompass
+ * the corresponding actual dimension symbol.
+ static bool matches(const std::string& actualDimensionSymbols,
+ const std::string& requiredDimensionSymbols);
+ /** \brief
+ * Adds one matrix to another.
+ * Addition is defined by taking the maximum dimension value
+ * of each position in the summand matrices.
+ * @param other - the matrix to add.
+ * \todo Why the 'other' matrix is not passed by const-reference?
+ void add(IntersectionMatrix* other);
+ /** \brief
+ * Changes the value of one of this IntersectionMatrixs elements.
+ * @param row - the row of this IntersectionMatrix, indicating
+ * the interior, boundary or exterior of the first Geometry.
+ * @param column - the column of this IntersectionMatrix,
+ * indicating the interior, boundary or exterior of the
+ * second Geometry.
+ * @param dimensionValue - the new value of the element.
+ void set(int row, int column, int dimensionValue);
+ /** \brief
+ * Changes the elements of this IntersectionMatrix to the dimension
+ * symbols in dimensionSymbols.
+ * @param dimensionSymbols - nine dimension symbols to which to
+ * set this IntersectionMatrix elements.
+ void set(const std::string& dimensionSymbols);
+ /** \brief
+ * Changes the specified element to minimumDimensionValue if the
+ * element is less.
+ * @param column - the column of this IntersectionMatrix, indicating
+ * the interior, boundary or exterior of the second Geometry.
+ * @param minimumDimensionValue - the dimension value with which
+ * to compare the element. The order of dimension values
+ * from least to greatest is {DONTCARE, TRUE, FALSE, 0, 1, 2}.
+ void setAtLeast(size_t row, size_t column, int minimumDimensionValue);
+ /** \brief
+ * If row >= 0 and column >= 0, changes the specified element
+ * to minimumDimensionValue if the element is less.
+ * Does nothing if row <0 or column < 0.
+ * @param row -
+ * the row of this IntersectionMatrix,
+ * first Geometry.
+ * @param column -
+ * the column of this IntersectionMatrix,
+ * the dimension value with which
+ void setAtLeastIfValid(int row, int column, int minimumDimensionValue);
+ /** \brief
+ * For each element in this IntersectionMatrix, changes the element to
+ * the corresponding minimum dimension symbol if the element is less.
+ * @param minimumDimensionSymbols -
+ * nine dimension symbols with which
+ * to compare the elements of this IntersectionMatrix.
+ * The order of dimension values from least to greatest is
+ * {DONTCARE, TRUE, FALSE, 0, 1, 2} .
+ void setAtLeast(std::string minimumDimensionSymbols);
+ /** \brief
+ * Changes the elements of this IntersectionMatrix to dimensionValue.
+ * the dimension value to which to set this
+ * IntersectionMatrix elements. Possible values {TRUE,
+ * FALSE, DONTCARE, 0, 1, 2}.
+ void setAll(int dimensionValue);
+ /** \brief
+ * Returns the value of one of this IntersectionMatrixs elements.
+ * @param row -
+ * the row of this IntersectionMatrix, indicating the
+ * interior, boundary or exterior of the first Geometry.
+ * @param column -
+ * the column of this IntersectionMatrix, indicating the
+ * interior, boundary or exterior of the second Geometry.
+ * @return the dimension value at the given matrix position.
+ int get(int row, int column) const;
+ /** \brief
+ * Returns true if this IntersectionMatrix is FF*FF****.
+ * @return true if the two Geometrys related by this
+ * IntersectionMatrix are disjoint.
+ bool isDisjoint() const;
+ /** \brief
+ * Returns true if isDisjoint returns false.
+ * IntersectionMatrix intersect.
+ bool isIntersects() const;
+ /** \brief
+ * Returns true if this IntersectionMatrix is FT*******, F**T*****
+ * or F***T****.
+ * @param dimensionOfGeometryA - the dimension of the first Geometry.
+ * @param dimensionOfGeometryB - the dimension of the second Geometry.
+ * @return true if the two Geometry's related by this
+ * IntersectionMatrix touch, false if both Geometrys
+ * are points.
+ bool isTouches(int dimensionOfGeometryA, int dimensionOfGeometryB)
+ const;
+ /** \brief
+ * Returns true if this IntersectionMatrix is:
+ * - T*T****** (for a point and a curve, a point and an area or
+ * a line and an area)
+ * - 0******** (for two curves)
+ * @param dimensionOfGeometryA - he dimension of the first Geometry.
+ * IntersectionMatrix cross.
+ * For this function to return true, the Geometrys must be a point
+ * and a curve; a point and a surface; two curves; or a curve and
+ * a surface.
+ bool isCrosses(int dimensionOfGeometryA, int dimensionOfGeometryB)
+ const;
+ /** \brief
+ * Returns true if this IntersectionMatrix is T*F**F***.
+ * @return true if the first Geometry is within the second.
+ bool isWithin() const;
+ /** \brief
+ * Returns true if this IntersectionMatrix is T*****FF*.
+ * @return true if the first Geometry contains the second.
+ bool isContains() const;
+ /** \brief
+ * Returns true if this IntersectionMatrix is T*F**FFF*.
+ * IntersectionMatrix are equal; the Geometrys must have
+ * the same dimension for this function to return true
+ bool isEquals(int dimensionOfGeometryA, int dimensionOfGeometryB)
+ const;
+ /** \brief
+ * - T*T***T** (for two points or two surfaces)
+ * - 1*T***T** (for two curves)
+ * IntersectionMatrix overlap.
+ * For this function to return true, the Geometrys must be two points,
+ * two curves or two surfaces.
+ bool isOverlaps(int dimensionOfGeometryA, int dimensionOfGeometryB)
+ const;
+ /** \brief
+ * Returns true if this IntersectionMatrix is <code>T*****FF*</code>
+ * or <code>*T****FF*</code> or <code>***T**FF*</code>
+ * or <code>****T*FF*</code>
+ * @return <code>true</code> if the first Geometry covers the
+ * second
+ bool isCovers() const;
+ /** \brief
+ * Returns true if this IntersectionMatrix is <code>T*F**F***</code>
+ * <code>*TF**F***</code> or <code>**FT*F***</code>
+ * or <code>**F*TF***</code>
+ * @return <code>true</code> if the first Geometry is covered by
+ * the second
+ bool isCoveredBy() const;
+ /** \brief
+ * Transposes this IntersectionMatrix.
+ * @return this IntersectionMatrix as a convenience.
+ * \todo It returns 'this' pointer so why not to return const-pointer?
+ * \todo May be it would be better to return copy of transposed matrix?
+ IntersectionMatrix* transpose();
+ /** \brief
+ * Returns a nine-character String representation of this
+ * IntersectionMatrix.
+ * @return the nine dimension symbols of this IntersectionMatrix
+ * in row-major order.
+ std::string toString() const;
private:
- static const int firstDim; // = 3;
+ static const int firstDim; // = 3;
- static const int secondDim; // = 3;
+ static const int secondDim; // = 3;
- // Internal buffer for 3x3 matrix.
- int matrix[3][3];
+ // Internal buffer for 3x3 matrix.
+ int matrix[3][3];
}; // class IntersectionMatrix
-GEOS_DLL std::ostream& operator<< (std::ostream&os, const IntersectionMatrix& im);
+GEOS_DLL std::ostream& operator<< (std::ostream& os, const IntersectionMatrix& im);
diff --git a/include/geos/geom/LineSegment.h b/include/geos/geom/LineSegment.h
index 3c3bf02..073bea8 100644
--- a/include/geos/geom/LineSegment.h
+++ b/include/geos/geom/LineSegment.h
@@ -31,11 +31,11 @@
// Forward declarations
namespace geos {
- namespace geom {
- class GeometryFactory;
- class LineString;
+namespace geom {
+class GeometryFactory;
+class LineString;
namespace geos {
@@ -57,314 +57,314 @@ namespace geom { // geos::geom
class GEOS_DLL LineSegment {
public:
- friend std::ostream& operator<< (std::ostream& o, const LineSegment& l);
- Coordinate p0; /// Segment start
- Coordinate p1; /// Segment end
- LineSegment();
- LineSegment(const LineSegment &ls);
- /// Constructs a LineSegment with the given start and end Coordinates.
- LineSegment(const Coordinate& c0, const Coordinate& c1);
- LineSegment(double x0, double y0, double x1, double y1);
- virtual ~LineSegment();
- void setCoordinates(const Coordinate& c0, const Coordinate& c1);
- // obsoleted, use operator[] instead
- //const Coordinate& getCoordinate(std::size_t i) const;
- const Coordinate& operator[](std::size_t i) const;
- Coordinate& operator[](std::size_t i);
- void setCoordinates(const LineSegment& ls);
- /// Computes the length of the line segment.
- double getLength() const;
- /// Tests whether the segment is horizontal.
- /// @return <code>true</code> if the segment is horizontal
- bool isHorizontal() const;
- /// Tests whether the segment is vertical.
- /// @return <code>true</code> if the segment is vertical
- bool isVertical() const;
- * Determines the orientation of a LineSegment relative to this segment.
- * The concept of orientation is specified as follows:
- * Given two line segments A and L,
- * <ul
- * <li>A is to the left of a segment L if A lies wholly in the
- * closed half-plane lying to the left of L
- * <li>A is to the right of a segment L if A lies wholly in the
- * closed half-plane lying to the right of L
- * <li>otherwise, A has indeterminate orientation relative to L.
- * This happens if A is collinear with L or if A crosses
- * the line determined by L.
- * </ul>
- * @param seg the LineSegment to compare
- * @return 1 if seg is to the left of this segment
- * @return -1 if seg is to the right of this segment
- * @return 0 if seg has indeterminate orientation relative
- * to this segment
- int orientationIndex(const LineSegment& seg) const;
- // TODO: deprecate this
- int orientationIndex(const LineSegment* seg) const;
- /** \brief
- * Determines the orientation index of a Coordinate
- * relative to this segment.
- * The orientation index is as defined in
- * Orientation::index.
- * @return 1 if <code>p</code> is to the left of this segment
- * @return -1 if <code>p</code> is to the right of this segment
- * @return 0 if <code>p</code> is collinear with this segment
- * @see Orientation::index(Coordinate, Coordinate,
- * Coordinate)
- int orientationIndex(const Coordinate& p) const;
- /// Reverses the direction of the line segment.
- void reverse();
- /// Puts the line segment into a normalized form.
- /// This is useful for using line segments in maps and indexes when
- /// topological equality rather than exact equality is desired.
- void normalize();
- /// @return the angle this segment makes with the x-axis (in radians)
- double angle() const;
- /// Computes the midpoint of the segment
- /// @param ret will be set to the midpoint of the segment
- void midPoint(Coordinate& ret) const;
- /// Computes the distance between this line segment and another one.
- double distance(const LineSegment& ls) const;
- /// Computes the distance between this line segment and a point.
- double distance(const Coordinate& p) const;
- /** \brief
- * Computes the perpendicular distance between the (infinite)
- * line defined by this line segment and a point.
- double distancePerpendicular(const Coordinate& p) const;
- /** \brief
- * Computes the Coordinate that lies a given
- * fraction along the line defined by this segment.
- * A fraction of <code>0.0</code> returns the start point of
- * the segment; a fraction of <code>1.0</code> returns the end
- * point of the segment.
- * If the fraction is < 0.0 or > 1.0 the point returned
- * will lie before the start or beyond the end of the segment.
- * @param segmentLengthFraction the fraction of the segment length
- * along the line
- * @param ret will be set to the point at that distance
- void pointAlong(double segmentLengthFraction, Coordinate& ret) const;
- /** \brief
- * Computes the {@link Coordinate} that lies a given
- * fraction along the line defined by this segment and offset from
- * the segment by a given distance.
- * A fraction of <code>0.0</code> offsets
- * from the start point of the segment;
- * a fraction of <code>1.0</code> offsets
- * from the end point of the segment.
- * The computed point is offset to the left of the line
- * if the offset distance is positive, to the right if negative.
- * length along the line
- * @param offsetDistance the distance the point is offset
- * from the segment
- * (positive is to the left, negative is to the right)
- * @param ret will be set to the point at that distance and offset
- * @throws IllegalStateException if the segment has zero length
- void pointAlongOffset(double segmentLengthFraction,
- double offsetDistance,
- Coordinate& ret) const;
- /** \brief
- * Compute the projection factor for the projection of the point p
- * onto this LineSegment.
- * The projection factor is the constant r
- * by which the vector for this segment must be multiplied to
- * equal the vector for the projection of p on the line
- * defined by this segment.
- * The projection factor returned will be in the range
- * (-inf, +inf)
- * @param p the point to compute the factor for
- * @return the projection factor for the point
- double projectionFactor(const Coordinate& p) const;
- /** \brief
- * Computes the fraction of distance (in <tt>[0.0, 1.0]</tt>)
- * that the projection of a point occurs along this line segment.
- * If the point is beyond either ends of the line segment,
- * the closest fractional value (<tt>0.0</tt> or <tt>1.0</tt>)
- * is returned.
- * Essentially, this is the {@link #projectionFactor} clamped to
- * the range <tt>[0.0, 1.0]</tt>.
- * @param inputPt the point
- * @return the fraction along the line segment the projection
- * of the point occurs
- double segmentFraction(const Coordinate& inputPt) const;
- /** \brief
- * Compute the projection of a point onto the line determined
- * by this line segment.
- * Note that the projected point
- * may lie outside the line segment. If this is the case,
- * the projection factor will lie outside the range [0.0, 1.0].
- void project(const Coordinate& p, Coordinate& ret) const;
- /** \brief
- * Project a line segment onto this line segment and return the resulting
- * line segment.
- * The returned line segment will be a subset of
- * the target line line segment. This subset may be null, if
- * the segments are oriented in such a way that there is no projection.
- * Note that the returned line may have zero length (i.e. the same endpoints).
- * This can happen for instance if the lines are perpendicular to one another.
- * @param seg the line segment to project
- * @param ret the projected line segment
- * @return true if there is an overlap, false otherwise
- bool project(const LineSegment& seg, LineSegment& ret) const;
- /// Computes the closest point on this line segment to another point.
- /// @param p the point to find the closest point to
- /// @param ret the Coordinate to which the closest point on the line segment
- /// to the point p will be written
- void closestPoint(const Coordinate& p, Coordinate& ret) const;
- /** \brief
- * Compares this object with the specified object for order.
- * Uses the standard lexicographic ordering for the points in the LineSegment.
- * @param o the LineSegment with which this LineSegment
- * is being compared
- * @return a negative integer, zero, or a positive integer as this
- * LineSegment is less than, equal to, or greater than the
- * specified LineSegment
- int compareTo(const LineSegment& other) const;
- /** \brief
- * Returns <code>true</code> if <code>other</code> is
- * topologically equal to this LineSegment (e.g. irrespective
- * of orientation).
- * @param other a <code>LineSegment</code> with which to do the comparison.
- * @return true if other is a LineSegment
- * with the same values for the x and y ordinates.
- bool equalsTopo(const LineSegment& other) const;
- * Computes the closest points on two line segments.
- * @param p the point to find the closest point to
- * @return a pair of Coordinates which are the closest points on
- * the line segments.
- * The returned CoordinateSequence must be deleted by caller
- CoordinateSequence* closestPoints(const LineSegment& line);
- CoordinateSequence* closestPoints(const LineSegment* line);
- * Computes an intersection point between two segments,
- * if there is one.
- * There may be 0, 1 or many intersection points between two segments.
- * If there are 0, null is returned. If there is 1 or more, a single
- * one is returned (chosen at the discretion of the algorithm).
- * If more information is required about the details of the
- * intersection, the LineIntersector class should be used.
- * @param line
- * @param coord the Coordinate to write the result into
- * @return true if an intersection was found, false otherwise
- bool intersection(const LineSegment& line, Coordinate& coord) const;
- /** \brief
- * Computes the intersection point of the lines defined
- * by two segments, if there is one.
- * There may be 0, 1 or an infinite number of intersection points
- * between two lines.
- * If there is a unique intersection point, it is returned.
- * Otherwise, <tt>null</tt> is returned.
- * intersection, the algorithms::LineIntersector class should
- * be used.
- * @param line a line segment defining a straight line
- * @param ret will be set to the intersection point (if any)
- bool lineIntersection(const LineSegment& line, Coordinate& ret) const;
- * Creates a LineString with the same coordinates as this segment
- * @param gf the geometery factory to use
- * @return a LineString with the same geometry as this segment
- std::unique_ptr<LineString> toGeometry(const GeometryFactory& gf) const;
+ friend std::ostream& operator<< (std::ostream& o, const LineSegment& l);
+ Coordinate p0; /// Segment start
+ Coordinate p1; /// Segment end
+ LineSegment();
+ LineSegment(const LineSegment& ls);
+ /// Constructs a LineSegment with the given start and end Coordinates.
+ LineSegment(const Coordinate& c0, const Coordinate& c1);
+ LineSegment(double x0, double y0, double x1, double y1);
+ virtual ~LineSegment();
+ void setCoordinates(const Coordinate& c0, const Coordinate& c1);
+ // obsoleted, use operator[] instead
+ //const Coordinate& getCoordinate(std::size_t i) const;
+ const Coordinate& operator[](std::size_t i) const;
+ Coordinate& operator[](std::size_t i);
+ void setCoordinates(const LineSegment& ls);
+ /// Computes the length of the line segment.
+ double getLength() const;
+ /// Tests whether the segment is horizontal.
+ /// @return <code>true</code> if the segment is horizontal
+ bool isHorizontal() const;
+ /// Tests whether the segment is vertical.
+ /// @return <code>true</code> if the segment is vertical
+ bool isVertical() const;
+ * Determines the orientation of a LineSegment relative to this segment.
+ * The concept of orientation is specified as follows:
+ * Given two line segments A and L,
+ * <ul
+ * <li>A is to the left of a segment L if A lies wholly in the
+ * closed half-plane lying to the left of L
+ * <li>A is to the right of a segment L if A lies wholly in the
+ * closed half-plane lying to the right of L
+ * <li>otherwise, A has indeterminate orientation relative to L.
+ * This happens if A is collinear with L or if A crosses
+ * the line determined by L.
+ * </ul>
+ * @param seg the LineSegment to compare
+ * @return 1 if seg is to the left of this segment
+ * @return -1 if seg is to the right of this segment
+ * @return 0 if seg has indeterminate orientation relative
+ * to this segment
+ int orientationIndex(const LineSegment& seg) const;
+ // TODO: deprecate this
+ int orientationIndex(const LineSegment* seg) const;
+ /** \brief
+ * Determines the orientation index of a Coordinate
+ * relative to this segment.
+ * The orientation index is as defined in
+ * Orientation::index.
+ * @return 1 if <code>p</code> is to the left of this segment
+ * @return -1 if <code>p</code> is to the right of this segment
+ * @return 0 if <code>p</code> is collinear with this segment
+ * @see Orientation::index(Coordinate, Coordinate,
+ * Coordinate)
+ int orientationIndex(const Coordinate& p) const;
+ /// Reverses the direction of the line segment.
+ void reverse();
+ /// Puts the line segment into a normalized form.
+ /// This is useful for using line segments in maps and indexes when
+ /// topological equality rather than exact equality is desired.
+ void normalize();
+ /// @return the angle this segment makes with the x-axis (in radians)
+ double angle() const;
+ /// Computes the midpoint of the segment
+ /// @param ret will be set to the midpoint of the segment
+ void midPoint(Coordinate& ret) const;
+ /// Computes the distance between this line segment and another one.
+ double distance(const LineSegment& ls) const;
+ /// Computes the distance between this line segment and a point.
+ double distance(const Coordinate& p) const;
+ /** \brief
+ * Computes the perpendicular distance between the (infinite)
+ * line defined by this line segment and a point.
+ double distancePerpendicular(const Coordinate& p) const;
+ /** \brief
+ * Computes the Coordinate that lies a given
+ * fraction along the line defined by this segment.
+ * A fraction of <code>0.0</code> returns the start point of
+ * the segment; a fraction of <code>1.0</code> returns the end
+ * point of the segment.
+ * If the fraction is < 0.0 or > 1.0 the point returned
+ * will lie before the start or beyond the end of the segment.
+ * @param segmentLengthFraction the fraction of the segment length
+ * along the line
+ * @param ret will be set to the point at that distance
+ void pointAlong(double segmentLengthFraction, Coordinate& ret) const;
+ /** \brief
+ * Computes the {@link Coordinate} that lies a given
+ * fraction along the line defined by this segment and offset from
+ * the segment by a given distance.
+ * A fraction of <code>0.0</code> offsets
+ * from the start point of the segment;
+ * a fraction of <code>1.0</code> offsets
+ * from the end point of the segment.
+ * The computed point is offset to the left of the line
+ * if the offset distance is positive, to the right if negative.
+ * length along the line
+ * @param offsetDistance the distance the point is offset
+ * from the segment
+ * (positive is to the left, negative is to the right)
+ * @param ret will be set to the point at that distance and offset
+ * @throws IllegalStateException if the segment has zero length
+ void pointAlongOffset(double segmentLengthFraction,
+ double offsetDistance,
+ Coordinate& ret) const;
+ /** \brief
+ * Compute the projection factor for the projection of the point p
+ * onto this LineSegment.
+ * The projection factor is the constant r
+ * by which the vector for this segment must be multiplied to
+ * equal the vector for the projection of p on the line
+ * defined by this segment.
+ * The projection factor returned will be in the range
+ * (-inf, +inf)
+ * @param p the point to compute the factor for
+ * @return the projection factor for the point
+ double projectionFactor(const Coordinate& p) const;
+ /** \brief
+ * Computes the fraction of distance (in <tt>[0.0, 1.0]</tt>)
+ * that the projection of a point occurs along this line segment.
+ * If the point is beyond either ends of the line segment,
+ * the closest fractional value (<tt>0.0</tt> or <tt>1.0</tt>)
+ * is returned.
+ * Essentially, this is the {@link #projectionFactor} clamped to
+ * the range <tt>[0.0, 1.0]</tt>.
+ * @param inputPt the point
+ * @return the fraction along the line segment the projection
+ * of the point occurs
+ double segmentFraction(const Coordinate& inputPt) const;
+ /** \brief
+ * Compute the projection of a point onto the line determined
+ * by this line segment.
+ * Note that the projected point
+ * may lie outside the line segment. If this is the case,
+ * the projection factor will lie outside the range [0.0, 1.0].
+ void project(const Coordinate& p, Coordinate& ret) const;
+ /** \brief
+ * Project a line segment onto this line segment and return the resulting
+ * line segment.
+ * The returned line segment will be a subset of
+ * the target line line segment. This subset may be null, if
+ * the segments are oriented in such a way that there is no projection.
+ * Note that the returned line may have zero length (i.e. the same endpoints).
+ * This can happen for instance if the lines are perpendicular to one another.
+ * @param seg the line segment to project
+ * @param ret the projected line segment
+ * @return true if there is an overlap, false otherwise
+ bool project(const LineSegment& seg, LineSegment& ret) const;
+ /// Computes the closest point on this line segment to another point.
+ /// @param p the point to find the closest point to
+ /// @param ret the Coordinate to which the closest point on the line segment
+ /// to the point p will be written
+ void closestPoint(const Coordinate& p, Coordinate& ret) const;
+ /** \brief
+ * Compares this object with the specified object for order.
+ * Uses the standard lexicographic ordering for the points in the LineSegment.
+ * @param o the LineSegment with which this LineSegment
+ * is being compared
+ * @return a negative integer, zero, or a positive integer as this
+ * LineSegment is less than, equal to, or greater than the
+ * specified LineSegment
+ int compareTo(const LineSegment& other) const;
+ /** \brief
+ * Returns <code>true</code> if <code>other</code> is
+ * topologically equal to this LineSegment (e.g. irrespective
+ * of orientation).
+ * @param other a <code>LineSegment</code> with which to do the comparison.
+ * @return true if other is a LineSegment
+ * with the same values for the x and y ordinates.
+ bool equalsTopo(const LineSegment& other) const;
+ * Computes the closest points on two line segments.
+ * @param p the point to find the closest point to
+ * @return a pair of Coordinates which are the closest points on
+ * the line segments.
+ * The returned CoordinateSequence must be deleted by caller
+ CoordinateSequence* closestPoints(const LineSegment& line);
+ CoordinateSequence* closestPoints(const LineSegment* line);
+ * Computes an intersection point between two segments,
+ * if there is one.
+ * There may be 0, 1 or many intersection points between two segments.
+ * If there are 0, null is returned. If there is 1 or more, a single
+ * one is returned (chosen at the discretion of the algorithm).
+ * If more information is required about the details of the
+ * intersection, the LineIntersector class should be used.
+ * @param line
+ * @param coord the Coordinate to write the result into
+ * @return true if an intersection was found, false otherwise
+ bool intersection(const LineSegment& line, Coordinate& coord) const;
+ /** \brief
+ * Computes the intersection point of the lines defined
+ * by two segments, if there is one.
+ * There may be 0, 1 or an infinite number of intersection points
+ * between two lines.
+ * If there is a unique intersection point, it is returned.
+ * Otherwise, <tt>null</tt> is returned.
+ * intersection, the algorithms::LineIntersector class should
+ * be used.
+ * @param line a line segment defining a straight line
+ * @param ret will be set to the intersection point (if any)
+ bool lineIntersection(const LineSegment& line, Coordinate& ret) const;
+ * Creates a LineString with the same coordinates as this segment
+ * @param gf the geometery factory to use
+ * @return a LineString with the same geometry as this segment
+ std::unique_ptr<LineString> toGeometry(const GeometryFactory& gf) const;
diff --git a/include/geos/geom/LineSegment.inl b/include/geos/geom/LineSegment.inl
index 5c43324..76724ee 100644
--- a/include/geos/geom/LineSegment.inl
+++ b/include/geos/geom/LineSegment.inl
@@ -33,25 +33,25 @@ namespace geom { // geos::geom
INLINE
LineSegment::LineSegment(const LineSegment& ls)
- p0(ls.p0),
- p1(ls.p1)
+ p0(ls.p0),
+ p1(ls.p1)
INLINE
LineSegment::LineSegment(const Coordinate& c0, const Coordinate& c1)
- p0(c0),
- p1(c1)
+ p0(c0),
+ p1(c1)
INLINE
LineSegment::LineSegment(double x0, double y0, double x1, double y1)
- p0(x0, y0),
- p1(x1, y1)
+ p0(x0, y0),
+ p1(x1, y1)
@@ -68,126 +68,133 @@ LineSegment::~LineSegment()
INLINE double
LineSegment::distancePerpendicular(const Coordinate& p) const
- return algorithm::Distance::pointToLinePerpendicular(p, p0, p1);
+ return algorithm::Distance::pointToLinePerpendicular(p, p0, p1);
INLINE void
LineSegment::pointAlong(double segmentLengthFraction, Coordinate& ret) const
ret = Coordinate(
- p0.x + segmentLengthFraction * (p1.x - p0.x),
- p0.y + segmentLengthFraction * (p1.y - p0.y));
+ p0.x + segmentLengthFraction * (p1.x - p0.x),
+ p0.y + segmentLengthFraction * (p1.y - p0.y));
INLINE double
LineSegment::distance(const LineSegment& ls) const
- return algorithm::Distance::segmentToSegment(p0, p1, ls.p0, ls.p1);
+ return algorithm::Distance::segmentToSegment(p0, p1, ls.p0, ls.p1);
/*public*/
INLINE double
LineSegment::distance(const Coordinate& p) const
- return algorithm::Distance::pointToSegment(p, p0, p1);
+ return algorithm::Distance::pointToSegment(p, p0, p1);
INLINE void
LineSegment::normalize()
- if (p1.compareTo(p0)<0) reverse();
+ if(p1.compareTo(p0) < 0) {
+ reverse();
INLINE void
LineSegment::setCoordinates(const Coordinate& c0, const Coordinate& c1)
- p0=c0; p1=c1;
+ p0 = c0;
+ p1 = c1;
INLINE const Coordinate&
LineSegment::operator[](std::size_t i) const
- if (i==0) return p0;
- assert(i==1);
- return p1;
+ if(i == 0) {
+ return p0;
+ assert(i == 1);
+ return p1;
INLINE Coordinate&
- assert(i==1);
- return p1;
+ if(i == 0) {
+ return p0;
+ assert(i == 1);
+ return p1;
INLINE void
LineSegment::setCoordinates(const LineSegment& ls)
- setCoordinates(ls.p0,ls.p1);
+ setCoordinates(ls.p0, ls.p1);
INLINE double
LineSegment::getLength() const
- return p0.distance(p1);
+ return p0.distance(p1);
INLINE bool
LineSegment::isHorizontal() const
- return p0.y == p1.y;
+ return p0.y == p1.y;
INLINE bool
LineSegment::isVertical() const
- return p0.x == p1.x;
+ return p0.x == p1.x;
INLINE int
LineSegment::orientationIndex(const LineSegment* seg) const
- assert(seg);
- return orientationIndex(*seg);
+ assert(seg);
+ return orientationIndex(*seg);
INLINE int
LineSegment::orientationIndex(const Coordinate& p) const
- return algorithm::Orientation::index(p0, p1, p);
+ return algorithm::Orientation::index(p0, p1, p);
INLINE CoordinateSequence*
LineSegment::closestPoints(const LineSegment* line)
- assert(line);
- return closestPoints(*line);
+ assert(line);
+ return closestPoints(*line);
INLINE double
LineSegment::angle() const
- return std::atan2(p1.y-p0.y,p1.x-p0.x);
+ return std::atan2(p1.y - p0.y, p1.x - p0.x);
INLINE void
LineSegment::midPoint(Coordinate& ret) const
- ret = Coordinate( (p0.x + p1.x) / 2,
- (p0.y + p1.y) / 2 );
+ ret = Coordinate((p0.x + p1.x) / 2,
+ (p0.y + p1.y) / 2);
INLINE std::ostream&
- return o<<"LINESEGMENT("<<l.p0.x<<" "<<l.p0.y<<","<<l.p1.x<<" "<<l.p1.y<<")";
+ return o << "LINESEGMENT(" << l.p0.x << " " << l.p0.y << "," << l.p1.x << " " << l.p1.y << ")";
INLINE bool
operator==(const LineSegment& a, const LineSegment& b)
- return a.p0==b.p0 && a.p1==b.p1;
+ return a.p0 == b.p0 && a.p1 == b.p1;
diff --git a/include/geos/geom/LineString.h b/include/geos/geom/LineString.h
index 25bc13d..16a14ab 100644
--- a/include/geos/geom/LineString.h
+++ b/include/geos/geom/LineString.h
@@ -40,11 +40,11 @@
#endif
namespace geos {
- namespace geom {
- class Coordinate;
- class CoordinateArraySequence;
- class CoordinateSequenceFilter;
+namespace geom {
+class Coordinate;
+class CoordinateArraySequence;
+class CoordinateSequenceFilter;
namespace geos {
@@ -70,155 +70,162 @@ class GEOS_DLL LineString: public virtual Geometry, public Lineal {
public:
- friend class GeometryFactory;
+ friend class GeometryFactory;
- /// A vector of const LineString pointers
- typedef std::vector<const LineString *> ConstVect;
+ /// A vector of const LineString pointers
+ typedef std::vector<const LineString*> ConstVect;
- ~LineString() override;
+ ~LineString() override;
- * \brief
- * Creates and returns a full copy of this {@link LineString} object
- * (including all coordinates contained by it)
- * @return A clone of this instance
- Geometry *clone() const override;
+ * \brief
+ * Creates and returns a full copy of this {@link LineString} object
+ * (including all coordinates contained by it)
+ * @return A clone of this instance
+ Geometry* clone() const override;
- CoordinateSequence* getCoordinates() const override;
+ CoordinateSequence* getCoordinates() const override;
- /// Returns a read-only pointer to internal CoordinateSequence
- const CoordinateSequence* getCoordinatesRO() const;
+ /// Returns a read-only pointer to internal CoordinateSequence
+ const CoordinateSequence* getCoordinatesRO() const;
- virtual const Coordinate& getCoordinateN(size_t n) const;
+ virtual const Coordinate& getCoordinateN(size_t n) const;
- /// Returns line dimension (1)
- Dimension::DimensionType getDimension() const override;
+ /// Returns line dimension (1)
+ Dimension::DimensionType getDimension() const override;
- * \brief
- * Returns Dimension::False for a closed LineString,
- * 0 otherwise (LineString boundary is a MultiPoint)
- int getBoundaryDimension() const override;
+ * \brief
+ * Returns Dimension::False for a closed LineString,
+ * 0 otherwise (LineString boundary is a MultiPoint)
+ int getBoundaryDimension() const override;
- /// Returns coordinate dimension.
- int getCoordinateDimension() const override;
+ /// Returns coordinate dimension.
+ int getCoordinateDimension() const override;
- * \brief
- * Returns a MultiPoint.
- * Empty for closed LineString, a Point for each vertex otherwise.
- Geometry* getBoundary() const override;
+ * \brief
+ * Returns a MultiPoint.
+ * Empty for closed LineString, a Point for each vertex otherwise.
+ Geometry* getBoundary() const override;
- bool isEmpty() const override;
+ bool isEmpty() const override;
- std::size_t getNumPoints() const override;
+ std::size_t getNumPoints() const override;
- virtual Point* getPointN(std::size_t n) const;
+ virtual Point* getPointN(std::size_t n) const;
- /// \brief
- /// Return the start point of the LineString
- /// or NULL if this is an EMPTY LineString.
- virtual Point* getStartPoint() const;
+ /// \brief
+ /// Return the start point of the LineString
+ /// or NULL if this is an EMPTY LineString.
+ virtual Point* getStartPoint() const;
- /// \brief
- /// Return the end point of the LineString
- virtual Point* getEndPoint() const;
+ /// \brief
+ /// Return the end point of the LineString
+ virtual Point* getEndPoint() const;
- virtual bool isClosed() const;
+ virtual bool isClosed() const;
- virtual bool isRing() const;
+ virtual bool isRing() const;
- std::string getGeometryType() const override;
+ std::string getGeometryType() const override;
- GeometryTypeId getGeometryTypeId() const override;
+ GeometryTypeId getGeometryTypeId() const override;
- virtual bool isCoordinate(Coordinate& pt) const;
+ virtual bool isCoordinate(Coordinate& pt) const;
- bool equalsExact(const Geometry *other, double tolerance=0)
- const override;
+ bool equalsExact(const Geometry* other, double tolerance = 0)
+ const override;
- void apply_rw(const CoordinateFilter *filter) override;
+ void apply_rw(const CoordinateFilter* filter) override;
- void apply_ro(CoordinateFilter *filter) const override;
+ void apply_ro(CoordinateFilter* filter) const override;
- void apply_rw(GeometryFilter *filter) override;
+ void apply_rw(GeometryFilter* filter) override;
- void apply_ro(GeometryFilter *filter) const override;
+ void apply_ro(GeometryFilter* filter) const override;
- void apply_rw(GeometryComponentFilter *filter) override;
+ void apply_rw(GeometryComponentFilter* filter) override;
- void apply_ro(GeometryComponentFilter *filter) const override;
+ void apply_ro(GeometryComponentFilter* filter) const override;
- void apply_rw(CoordinateSequenceFilter& filter) override;
+ void apply_rw(CoordinateSequenceFilter& filter) override;
- void apply_ro(CoordinateSequenceFilter& filter) const override;
+ void apply_ro(CoordinateSequenceFilter& filter) const override;
- /** \brief
- * Normalizes a LineString.
- * A normalized linestring
- * has the first point which is not equal to its reflected point
- * less than the reflected point.
- void normalize() override;
+ /** \brief
+ * Normalizes a LineString.
+ * A normalized linestring
+ * has the first point which is not equal to its reflected point
+ * less than the reflected point.
+ void normalize() override;
- //was protected
- int compareToSameClass(const Geometry *ls) const override;
+ //was protected
+ int compareToSameClass(const Geometry* ls) const override;
- const Coordinate* getCoordinate() const override;
+ const Coordinate* getCoordinate() const override;
- double getLength() const override;
+ double getLength() const override;
- * Creates a LineString whose coordinates are in the reverse
- * order of this object's
- * @return a LineString with coordinates in the reverse order
- Geometry* reverse() const override;
+ * Creates a LineString whose coordinates are in the reverse
+ * order of this object's
+ * @return a LineString with coordinates in the reverse order
+ Geometry* reverse() const override;
protected:
- LineString(const LineString &ls);
+ LineString(const LineString& ls);
- /// \brief
- /// Constructs a LineString taking ownership the
- /// given CoordinateSequence.
- LineString(CoordinateSequence *pts, const GeometryFactory *newFactory);
+ /// \brief
+ /// Constructs a LineString taking ownership the
+ /// given CoordinateSequence.
+ LineString(CoordinateSequence* pts, const GeometryFactory* newFactory);
- /// Hopefully cleaner version of the above
- LineString(CoordinateSequence::Ptr pts,
- const GeometryFactory *newFactory);
+ /// Hopefully cleaner version of the above
+ LineString(CoordinateSequence::Ptr pts,
+ const GeometryFactory* newFactory);
- Envelope::Ptr computeEnvelopeInternal() const override;
+ Envelope::Ptr computeEnvelopeInternal() const override;
- CoordinateSequence::Ptr points;
+ CoordinateSequence::Ptr points;
- int getSortIndex() const override { return SORTINDEX_LINESTRING; };
+ int
+ getSortIndex() const override
+ return SORTINDEX_LINESTRING;
private:
- void validateConstruction();
+ void validateConstruction();
struct GEOS_DLL LineStringLT {
- bool operator()(const LineString *ls1, const LineString *ls2) const {
- return ls1->compareTo(ls2)<0;
+ bool
+ operator()(const LineString* ls1, const LineString* ls2) const
+ return ls1->compareTo(ls2) < 0;
inline Geometry*
-LineString::clone() const {
- return new LineString(*this);
+LineString::clone() const
+ return new LineString(*this);
diff --git a/include/geos/geom/Lineal.h b/include/geos/geom/Lineal.h
index ebd8c32..8664367 100644
--- a/include/geos/geom/Lineal.h
+++ b/include/geos/geom/Lineal.h
@@ -34,10 +34,9 @@ namespace geom { // geos::geom
* Identifies {@link Geometry} subclasses which
* are 1-dimensional and with components which are {@link LineString}s.
-class GEOS_DLL Lineal : public virtual Geometry
+class GEOS_DLL Lineal : public virtual Geometry {
protected:
- Lineal(): Geometry(nullptr) {}
+ Lineal(): Geometry(nullptr) {}
diff --git a/include/geos/geom/LinearRing.h b/include/geos/geom/LinearRing.h
index 71ef6f2..43b55d9 100644
--- a/include/geos/geom/LinearRing.h
+++ b/include/geos/geom/LinearRing.h
@@ -29,10 +29,10 @@
namespace geos {
- namespace geom { // geos::geom
- class Coordinate;
+namespace geom { // geos::geom
+class Coordinate;
namespace geos {
@@ -57,63 +57,71 @@ class GEOS_DLL LinearRing : public LineString {
public:
- * The minimum number of vertices allowed in a valid non-empty ring (= 4).
- * Empty rings with 0 vertices are also valid.
- static const unsigned int MINIMUM_VALID_SIZE = 4;
+ * The minimum number of vertices allowed in a valid non-empty ring (= 4).
+ * Empty rings with 0 vertices are also valid.
+ static const unsigned int MINIMUM_VALID_SIZE = 4;
- LinearRing(const LinearRing &lr);
+ LinearRing(const LinearRing& lr);
- * \brief Constructs a <code>LinearRing</code> with the given points.
- * @param points points forming a closed and simple linestring, or
- * <code>null</code> or an empty array to create the empty
- * geometry.
- * This array must not contain <code>null</code> elements.
- * If not null LinearRing will take ownership of points.
- * @param newFactory the GeometryFactory used to create this geometry
- LinearRing(CoordinateSequence* points,
+ * \brief Constructs a <code>LinearRing</code> with the given points.
+ * @param points points forming a closed and simple linestring, or
+ * <code>null</code> or an empty array to create the empty
+ * geometry.
+ * This array must not contain <code>null</code> elements.
+ * If not null LinearRing will take ownership of points.
+ * @param newFactory the GeometryFactory used to create this geometry
+ LinearRing(CoordinateSequence* points,
- LinearRing(CoordinateSequence::Ptr points,
+ LinearRing(CoordinateSequence::Ptr points,
- Geometry *clone() const override { return new LinearRing(*this); }
+ Geometry*
+ clone() const override
+ return new LinearRing(*this);
- ~LinearRing() override;
+ ~LinearRing() override;
- /** \brief
- * Returns <code>Dimension.FALSE</code>, since by definition
- * LinearRings do not have a boundary.
- * @return Dimension::False
+ /** \brief
+ * Returns <code>Dimension.FALSE</code>, since by definition
+ * LinearRings do not have a boundary.
+ * @return Dimension::False
- bool isClosed() const override;
+ bool isClosed() const override;
- void setPoints(CoordinateSequence* cl);
+ void setPoints(CoordinateSequence* cl);
protected:
- int getSortIndex() const override { return SORTINDEX_LINEARRING; };
+ int
+ return SORTINDEX_LINEARRING;
private:
diff --git a/include/geos/geom/Location.h b/include/geos/geom/Location.h
index ebb80dd..24f9a71 100644
--- a/include/geos/geom/Location.h
+++ b/include/geos/geom/Location.h
@@ -34,36 +34,36 @@ namespace geom { // geos::geom
class GEOS_DLL Location {
public:
- enum Value {
+ enum Value {
- * Used for uninitialized location values.
- UNDEF=-1, // Instead of NULL
+ * Used for uninitialized location values.
+ UNDEF = -1, // Instead of NULL
- * DE-9IM row index of the interior of the first geometry and
- * column index of the interior of the second geometry.
- * Location value for the interior of a geometry.
- INTERIOR = 0,
+ * DE-9IM row index of the interior of the first geometry and
+ * column index of the interior of the second geometry.
+ * Location value for the interior of a geometry.
+ INTERIOR = 0,
- * DE-9IM row index of the boundary of the first geometry and
- * column index of the boundary of the second geometry.
- * Location value for the boundary of a geometry.
- BOUNDARY = 1,
+ * DE-9IM row index of the boundary of the first geometry and
+ * column index of the boundary of the second geometry.
+ * Location value for the boundary of a geometry.
+ BOUNDARY = 1,
- * DE-9IM row index of the exterior of the first geometry and
- * column index of the exterior of the second geometry.
- * Location value for the exterior of a geometry.
- EXTERIOR = 2
+ * DE-9IM row index of the exterior of the first geometry and
+ * column index of the exterior of the second geometry.
+ * Location value for the exterior of a geometry.
+ EXTERIOR = 2
- static char toLocationSymbol(int locationValue);
+ static char toLocationSymbol(int locationValue);
diff --git a/include/geos/geom/MultiLineString.h b/include/geos/geom/MultiLineString.h
index d806481..95cd362 100644
--- a/include/geos/geom/MultiLineString.h
+++ b/include/geos/geom/MultiLineString.h
@@ -33,10 +33,10 @@
namespace geos {
- class Coordinate;
+class Coordinate;
namespace geos {
@@ -52,71 +52,75 @@ class GEOS_DLL MultiLineString: public GeometryCollection, public Lineal {
public:
- ~MultiLineString() override;
+ ~MultiLineString() override;
- * \brief
- * Returns Dimension::False if all LineStrings in the collection
- * are closed, 0 otherwise.
+ * \brief
+ * Returns Dimension::False if all LineStrings in the collection
+ * are closed, 0 otherwise.
- /// Returns a (possibly empty) MultiPoint
+ /// Returns a (possibly empty) MultiPoint
- bool isClosed() const;
+ bool isClosed() const;
- bool equalsExact(const Geometry *other, double tolerance=0) const override;
+ bool equalsExact(const Geometry* other, double tolerance = 0) const override;
- * Creates a MultiLineString in the reverse
- * order to this object.
- * Both the order of the component LineStrings
- * and the order of their coordinate sequences
- * are reversed.
- * @return a MultiLineString in the reverse order
+ * Creates a MultiLineString in the reverse
+ * order to this object.
+ * Both the order of the component LineStrings
+ * and the order of their coordinate sequences
+ * are reversed.
+ * @return a MultiLineString in the reverse order
protected:
- * \brief Constructs a <code>MultiLineString</code>.
- * @param newLines
- * The <code>LineStrings</code>s for this
- * <code>MultiLineString</code>, or <code>null</code>
- * or an empty array to create the empty geometry.
- * Elements may be empty <code>LineString</code>s,
- * but not <code>null</code>s.
- * Constructed object will take ownership of
- * the vector and its elements.
- * The GeometryFactory used to create this geometry.
- * Caller must keep the factory alive for the life-time
- * of the constructed MultiLineString.
- MultiLineString(std::vector<Geometry *> *newLines,
- MultiLineString(const MultiLineString &mp);
- int getSortIndex() const override { return SORTINDEX_MULTILINESTRING; };
+ * \brief Constructs a <code>MultiLineString</code>.
+ * @param newLines
+ * The <code>LineStrings</code>s for this
+ * <code>MultiLineString</code>, or <code>null</code>
+ * or an empty array to create the empty geometry.
+ * Elements may be empty <code>LineString</code>s,
+ * but not <code>null</code>s.
+ * Constructed object will take ownership of
+ * the vector and its elements.
+ * The GeometryFactory used to create this geometry.
+ * Caller must keep the factory alive for the life-time
+ * of the constructed MultiLineString.
+ MultiLineString(std::vector<Geometry*>* newLines,
+ MultiLineString(const MultiLineString& mp);
+ int
+ return SORTINDEX_MULTILINESTRING;
diff --git a/include/geos/geom/MultiLineString.inl b/include/geos/geom/MultiLineString.inl
index dca5c81..3820859 100644
--- a/include/geos/geom/MultiLineString.inl
+++ b/include/geos/geom/MultiLineString.inl
@@ -8,7 +8,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -28,18 +28,18 @@
namespace geos {
-INLINE
-MultiLineString::MultiLineString(const MultiLineString &mp)
- Geometry(mp),
- GeometryCollection(mp)
+INLINE
+MultiLineString::MultiLineString(const MultiLineString& mp)
+ Geometry(mp),
+ GeometryCollection(mp)
INLINE Geometry*
MultiLineString::clone() const
- return new MultiLineString(*this);
+ return new MultiLineString(*this);
diff --git a/include/geos/geom/MultiPoint.h b/include/geos/geom/MultiPoint.h
index bc4fbf0..3f2e227 100644
--- a/include/geos/geom/MultiPoint.h
+++ b/include/geos/geom/MultiPoint.h
@@ -32,10 +32,10 @@
#include <vector>
namespace geos {
- class Coordinate;
+class Coordinate;
namespace geos {
@@ -51,69 +51,80 @@ namespace geom { // geos::geom
* Any collection of Points is a valid MultiPoint.
-class GEOS_DLL MultiPoint: public GeometryCollection, public Puntal
+class GEOS_DLL MultiPoint: public GeometryCollection, public Puntal {
public:
- ~MultiPoint() override;
+ ~MultiPoint() override;
- /// Returns point dimension (0)
+ /// Returns point dimension (0)
- /// Returns Dimension::False (Point has no boundary)
+ /// Returns Dimension::False (Point has no boundary)
- /** \brief
- * Gets the boundary of this geometry.
- * Zero-dimensional geometries have no boundary by definition,
- * so an empty GeometryCollection is returned.
- * @return an empty GeometryCollection
- * @see Geometry#getBoundary
+ /** \brief
+ * Gets the boundary of this geometry.
+ * Zero-dimensional geometries have no boundary by definition,
+ * so an empty GeometryCollection is returned.
+ * @return an empty GeometryCollection
+ * @see Geometry#getBoundary
- Geometry *clone() const override { return new MultiPoint(*this); }
+ Geometry*
+ return new MultiPoint(*this);
- Geometry* reverse() const override { return clone(); }
+ Geometry*
+ reverse() const override
+ return clone();
protected:
- * \brief Constructs a <code>MultiPoint</code>.
- * @param newPoints
- * the <code>Point</code>s for this <code>MultiPoint</code>,
- * or <code>null</code> or an empty array to create the empty
- * geometry.
- * Elements may be empty <code>Point</code>s,
- * of the constructed MultiPoint.
- MultiPoint(std::vector<Geometry *> *newPoints, const GeometryFactory *newFactory);
- MultiPoint(const MultiPoint &mp): Geometry(mp), GeometryCollection(mp) {}
- const Coordinate* getCoordinateN(size_t n) const;
- int getSortIndex() const override { return SORTINDEX_MULTIPOINT; };
+ * \brief Constructs a <code>MultiPoint</code>.
+ * @param newPoints
+ * the <code>Point</code>s for this <code>MultiPoint</code>,
+ * or <code>null</code> or an empty array to create the empty
+ * geometry.
+ * Elements may be empty <code>Point</code>s,
+ * of the constructed MultiPoint.
+ MultiPoint(std::vector<Geometry*>* newPoints, const GeometryFactory* newFactory);
+ MultiPoint(const MultiPoint& mp): Geometry(mp), GeometryCollection(mp) {}
+ const Coordinate* getCoordinateN(size_t n) const;
+ int
+ return SORTINDEX_MULTIPOINT;
diff --git a/include/geos/geom/MultiPolygon.h b/include/geos/geom/MultiPolygon.h
index 77771ee..57e72e6 100644
--- a/include/geos/geom/MultiPolygon.h
+++ b/include/geos/geom/MultiPolygon.h
@@ -32,11 +32,11 @@
namespace geos {
- class Coordinate;
- class MultiPoint;
+class Coordinate;
+class MultiPoint;
@@ -56,66 +56,69 @@ namespace geom { // geos::geom
/// This allows the topological point-set semantics
/// to be well-defined.
-class GEOS_DLL MultiPolygon: public GeometryCollection, public Polygonal
+class GEOS_DLL MultiPolygon: public GeometryCollection, public Polygonal {
public:
- ~MultiPolygon() override;
+ ~MultiPolygon() override;
- /// Returns surface dimension (2)
+ /// Returns surface dimension (2)
- /// Returns 1 (MultiPolygon boundary is MultiLineString)
+ /// Returns 1 (MultiPolygon boundary is MultiLineString)
- /** \brief
- * Computes the boundary of this geometry
- * @return a lineal geometry (which may be empty)
+ /** \brief
+ * Computes the boundary of this geometry
+ * @return a lineal geometry (which may be empty)
- Geometry *reverse() const override;
protected:
- * \brief Construct a MultiPolygon
- * @param newPolys
- * the <code>Polygon</code>s for this <code>MultiPolygon</code>,
- * geometry. Elements may be empty <code>Polygon</code>s, but
- * not <code>null</code>s.
- * The polygons must conform to the assertions specified in the
- * <A HREF="http://www.opengis.org/techno/specs.htm">
- * OpenGIS Simple Features Specification for SQL
- * </A>.
- * of the constructed MultiPolygon.
- MultiPolygon(std::vector<Geometry *> *newPolys, const GeometryFactory *newFactory);
- MultiPolygon(const MultiPolygon &mp);
- int getSortIndex() const override { return SORTINDEX_MULTIPOLYGON; };
+ * \brief Construct a MultiPolygon
+ * @param newPolys
+ * the <code>Polygon</code>s for this <code>MultiPolygon</code>,
+ * geometry. Elements may be empty <code>Polygon</code>s, but
+ * not <code>null</code>s.
+ * The polygons must conform to the assertions specified in the
+ * <A HREF="http://www.opengis.org/techno/specs.htm">
+ * OpenGIS Simple Features Specification for SQL
+ * </A>.
+ * of the constructed MultiPolygon.
+ MultiPolygon(std::vector<Geometry*>* newPolys, const GeometryFactory* newFactory);
+ MultiPolygon(const MultiPolygon& mp);
+ int
+ return SORTINDEX_MULTIPOLYGON;
diff --git a/include/geos/geom/MultiPolygon.inl b/include/geos/geom/MultiPolygon.inl
index 8bb340f..e37a7e2 100644
--- a/include/geos/geom/MultiPolygon.inl
+++ b/include/geos/geom/MultiPolygon.inl
@@ -7,7 +7,7 @@
@@ -25,18 +25,18 @@
namespace geos {
-INLINE
-MultiPolygon::MultiPolygon(const MultiPolygon &mp)
- Geometry(mp),
+INLINE
+MultiPolygon::MultiPolygon(const MultiPolygon& mp)
+ Geometry(mp),
INLINE Geometry*
MultiPolygon::clone() const
- return new MultiPolygon(*this);
+ return new MultiPolygon(*this);
} // namespace geos::geom
diff --git a/include/geos/geom/Point.h b/include/geos/geom/Point.h
index e93990c..060cf6e 100644
--- a/include/geos/geom/Point.h
+++ b/include/geos/geom/Point.h
@@ -41,14 +41,14 @@
namespace geos {
- class Coordinate;
- class CoordinateFilter;
- class GeometryComponentFilter;
- class GeometryFilter;
+class Coordinate;
+class CoordinateFilter;
+class GeometryComponentFilter;
+class GeometryFilter;
namespace geos {
@@ -63,110 +63,119 @@ namespace geom { // geos::geom
* (i.e does not have an NaN X or Y ordinate)
-class GEOS_DLL Point : public virtual Geometry, public Puntal
+class GEOS_DLL Point : public virtual Geometry, public Puntal {
public:
- /// A vector of const Point pointers
- typedef std::vector<const Point *> ConstVect;
- ~Point() override;
- * Creates and returns a full copy of this {@link Point} object.
- * (including all coordinates contained by it).
- * @return a clone of this instance
- Geometry *clone() const override { return new Point(*this); }
- CoordinateSequence* getCoordinates(void) const override;
- size_t getNumPoints() const override;
- bool isSimple() const override;
- * @see Geometry::getBoundary
- double getX() const;
- double getY() const;
- double getZ() const;
- void normalize(void) override
- // a Point is always in normalized form
- return clone();
+ /// A vector of const Point pointers
+ typedef std::vector<const Point*> ConstVect;
+ ~Point() override;
+ * Creates and returns a full copy of this {@link Point} object.
+ * (including all coordinates contained by it).
+ * @return a clone of this instance
+ Geometry*
+ return new Point(*this);
+ CoordinateSequence* getCoordinates(void) const override;
+ size_t getNumPoints() const override;
+ bool isSimple() const override;
+ * @see Geometry::getBoundary
+ double getX() const;
+ double getY() const;
+ double getZ() const;
+ void
+ normalize(void) override
+ // a Point is always in normalized form
+ Geometry*
+ return clone();
protected:
- * \brief
- * Creates a Point taking ownership of the given CoordinateSequence
- * (must have 1 element)
- * @param newCoords
- * contains the single coordinate on which to base this
- * <code>Point</code> or <code>null</code> to create
- * the empty geometry.
- Point(CoordinateSequence *newCoords, const GeometryFactory *newFactory);
+ * \brief
+ * Creates a Point taking ownership of the given CoordinateSequence
+ * (must have 1 element)
+ * @param newCoords
+ * contains the single coordinate on which to base this
+ * <code>Point</code> or <code>null</code> to create
+ * the empty geometry.
+ Point(CoordinateSequence* newCoords, const GeometryFactory* newFactory);
- Point(const Point &p);
+ Point(const Point& p);
- int compareToSameClass(const Geometry *p) const override;
+ int compareToSameClass(const Geometry* p) const override;
- int getSortIndex() const override { return SORTINDEX_POINT; };
+ int
+ return SORTINDEX_POINT;
private:
- * The <code>Coordinate</code> wrapped by this <code>Point</code>.
- std::unique_ptr<CoordinateSequence> coordinates;
+ * The <code>Coordinate</code> wrapped by this <code>Point</code>.
+ std::unique_ptr<CoordinateSequence> coordinates;
diff --git a/include/geos/geom/Polygon.h b/include/geos/geom/Polygon.h
index 1c46dc4..dd85752 100644
--- a/include/geos/geom/Polygon.h
+++ b/include/geos/geom/Polygon.h
@@ -35,13 +35,13 @@
namespace geos {
- class Coordinate;
- class LinearRing;
- class LineString;
+class Coordinate;
+class LinearRing;
+class LineString;
namespace geos {
@@ -62,125 +62,132 @@ namespace geom { // geos::geom
* Specification for SQL</A> .
-class GEOS_DLL Polygon: public virtual Geometry, public Polygonal
+class GEOS_DLL Polygon: public virtual Geometry, public Polygonal {
public:
- /// A vector of const Polygon pointers
- typedef std::vector<const Polygon *> ConstVect;
+ /// A vector of const Polygon pointers
+ typedef std::vector<const Polygon*> ConstVect;
- ~Polygon() override;
+ ~Polygon() override;
- * Creates and returns a full copy of this {@link Polygon} object.
- Geometry *clone() const override { return new Polygon(*this); }
+ * Creates and returns a full copy of this {@link Polygon} object.
+ Geometry*
+ return new Polygon(*this);
- /// Returns 1 (Polygon boundary is a MultiLineString)
+ /// Returns 1 (Polygon boundary is a MultiLineString)
- /** \brief
+ /** \brief
- /// Returns the exterior ring (shell)
- const LineString* getExteriorRing() const;
+ /// Returns the exterior ring (shell)
+ const LineString* getExteriorRing() const;
- /// Returns number of interior rings (hole)
- size_t getNumInteriorRing() const;
+ /// Returns number of interior rings (hole)
+ size_t getNumInteriorRing() const;
- /// Get nth interior ring (hole)
- const LineString* getInteriorRingN(std::size_t n) const;
+ /// Get nth interior ring (hole)
+ const LineString* getInteriorRingN(std::size_t n) const;
- Geometry* convexHull() const override;
+ Geometry* convexHull() const override;
- int compareToSameClass(const Geometry *p) const override; //was protected
+ int compareToSameClass(const Geometry* p) const override; //was protected
- double getArea() const override;
+ double getArea() const override;
- /// Returns the perimeter of this <code>Polygon</code>
+ /// Returns the perimeter of this <code>Polygon</code>
- bool isRectangle() const override;
+ bool isRectangle() const override;
protected:
- Polygon(const Polygon &p);
+ Polygon(const Polygon& p);
- * Constructs a <code>Polygon</code> with the given exterior
- * and interior boundaries.
- * @param newShell the outer boundary of the new Polygon,
- * LinearRing if the empty geometry
- * is to be created.
- * @param newHoles the LinearRings defining the inner
- * boundaries of the new Polygon, or
- * null or empty LinearRing
- * if the empty geometry is to be created.
- * Polygon will take ownership of Shell and Holes LinearRings
- Polygon(LinearRing *newShell, std::vector<Geometry *> *newHoles,
+ * Constructs a <code>Polygon</code> with the given exterior
+ * and interior boundaries.
+ * @param newShell the outer boundary of the new Polygon,
+ * LinearRing if the empty geometry
+ * is to be created.
+ * @param newHoles the LinearRings defining the inner
+ * boundaries of the new Polygon, or
+ * null or empty LinearRing
+ * if the empty geometry is to be created.
+ * Polygon will take ownership of Shell and Holes LinearRings
+ Polygon(LinearRing* newShell, std::vector<Geometry*>* newHoles,
- LinearRing *shell;
+ LinearRing* shell;
- std::vector<Geometry *> *holes; //Actually vector<LinearRing *>
+ std::vector<Geometry*>* holes; //Actually vector<LinearRing *>
- int getSortIndex() const override { return SORTINDEX_POLYGON; };
+ int
+ return SORTINDEX_POLYGON;
private:
- void normalize(LinearRing *ring, bool clockwise);
+ void normalize(LinearRing* ring, bool clockwise);
diff --git a/include/geos/geom/Polygonal.h b/include/geos/geom/Polygonal.h
index 8861d06..6b90ecf 100644
--- a/include/geos/geom/Polygonal.h
+++ b/include/geos/geom/Polygonal.h
* are 2-dimensional and with components which are {@link Polygon}s.
-class GEOS_DLL Polygonal : public virtual Geometry
+class GEOS_DLL Polygonal : public virtual Geometry {
protected:
- Polygonal(): Geometry(nullptr) {}
+ Polygonal(): Geometry(nullptr) {}
diff --git a/include/geos/geom/PrecisionModel.h b/include/geos/geom/PrecisionModel.h
index 3358563..d1c39a5 100644
--- a/include/geos/geom/PrecisionModel.h
+++ b/include/geos/geom/PrecisionModel.h
@@ -28,12 +28,12 @@
namespace geos {
- namespace io {
- class Unload;
- namespace geom {
- class Coordinate;
+namespace io {
+class Unload;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -85,237 +85,237 @@ namespace geom { // geos::geom
* JTS methods currently do not handle inputs with different precision models.
class GEOS_DLL PrecisionModel {
-friend class io::Unload;
+ friend class io::Unload;
public:
- /// The types of Precision Model which GEOS supports.
- typedef enum {
- * Fixed Precision indicates that coordinates have a fixed
- * number of decimal places.
- * The number of decimal places is determined by the log10
- * of the scale factor.
- FIXED,
- * Floating precision corresponds to the standard Java
- * double-precision floating-point representation, which is
- * based on the IEEE-754 standard
- FLOATING,
- * Floating single precision corresponds to the standard Java
- * single-precision floating-point representation, which is
- FLOATING_SINGLE
- } Type;
- /// Creates a PrecisionModel with a default precision of FLOATING.
- PrecisionModel(void);
- /// Creates a PrecisionModel specifying an explicit precision model type.
- /// If the model type is FIXED the scale factor will default to 1.
- /// @param nModelType the type of the precision model
- PrecisionModel(Type nModelType);
- /** \brief
- * Creates a <code>PrecisionModel</code> with Fixed precision.
- * Fixed-precision coordinates are represented as precise internal
- * coordinates, which are rounded to the grid defined by the
- * scale factor.
- * @param scale
- * amount by which to multiply a coordinate after subtracting
- * the offset, to obtain a precise coordinate
- * @param offsetX not used.
- * @param offsetY not used.
- * @deprecated offsets are no longer supported, since internal
- * representation is rounded floating point
- PrecisionModel(double newScale, double newOffsetX, double newOffsetY);
- * \brief
- * Creates a PrecisionModel with Fixed precision.
- * internal coordinates which are rounded to the grid defined
- * by the scale factor.
- * @param newScale amount by which to multiply a coordinate
- * after subtracting the offset, to obtain a precise coordinate
- PrecisionModel(double newScale);
- // copy constructor
- PrecisionModel(const PrecisionModel &pm);
- /// destructor
- ~PrecisionModel(void);
- /// The maximum precise value representable in a double.
- /// Since IEE754 double-precision numbers allow 53 bits of mantissa,
- /// the value is equal to 2^53 - 1.
- /// This provides <i>almost</i> 16 decimal digits of precision.
- static const double maximumPreciseValue;
- /** \brief
- * Rounds a numeric value to the PrecisionModel grid.
- * Asymmetric Arithmetic Rounding is used, to provide
- * uniform rounding behaviour no matter where the number is
- * on the number line.
- * <b>Note:</b> Java's <code>Math#rint</code> uses the "Banker's Rounding" algorithm,
- * which is not suitable for precision operations elsewhere in JTS.
- double makePrecise(double val) const;
- /// Rounds the given Coordinate to the PrecisionModel grid.
- void makePrecise(Coordinate& coord) const;
- void makePrecise(Coordinate* coord) const;
- /// Tests whether the precision model supports floating point
- /// @return <code>true</code> if the precision model supports
- /// floating point
- bool isFloating() const;
- /// \brief
- /// Returns the maximum number of significant digits provided by
- /// this precision model.
- /// Intended for use by routines which need to print out precise
- /// values.
- /// @return the maximum number of decimal places provided by this
- /// precision model
- int getMaximumSignificantDigits() const;
- /// Gets the type of this PrecisionModel
- /// @return the type of this PrecisionModel
- Type getType() const;
- /// Returns the multiplying factor used to obtain a precise coordinate.
- double getScale() const;
- /// Returns the x-offset used to obtain a precise coordinate.
- /// @return the amount by which to subtract the x-coordinate before
- /// multiplying by the scale
- /// @deprecated Offsets are no longer used
- double getOffsetX() const;
- /// Returns the y-offset used to obtain a precise coordinate.
- /// @return the amount by which to subtract the y-coordinate before
- double getOffsetY() const;
- /** \brief
- * Sets <code>internal</code> to the precise representation of
- * <code>external</code>.
- * @param external the original coordinate
- * @param internal the coordinate whose values will be changed to the
- * precise representation of <code>external</code>
- * @deprecated use makePrecise instead
- //void toInternal(const Coordinate& external, Coordinate* internal) const;
- * Returns the precise representation of <code>external</code>.
- *@param external the original coordinate
- *@return
- * the coordinate whose values will be changed to the precise
- * representation of <code>external</code>
- //Coordinate* toInternal(const Coordinate& external) const;
- * Returns the external representation of <code>internal</code>.
- *@param internal the original coordinate
- *@return the coordinate whose values will be changed to the
- * external representation of <code>internal</code>
- * @deprecated no longer needed, since internal representation is same as external representation
- //Coordinate* toExternal(const Coordinate& internal) const;
- * Sets <code>external</code> to the external representation of
- * <code>internal</code>.
- * @param internal the original coordinate
- * @param external
- //void toExternal(const Coordinate& internal, Coordinate* external) const;
- std::string toString() const;
- /// \brief
- /// Compares this PrecisionModel object with the specified object
- /// for order.
- /// A PrecisionModel is greater than another if it provides greater
- /// precision.
- /// The comparison is based on the value returned by the
- /// getMaximumSignificantDigits method.
- /// This comparison is not strictly accurate when comparing floating
- /// precision models to fixed models;
- /// however, it is correct when both models are either floating or
- /// fixed.
- /// @param other the PrecisionModel with which this PrecisionModel
- /// is being compared
- /// @return a negative integer, zero, or a positive integer as this
- /// PrecisionModel is less than, equal to, or greater than the
- /// specified PrecisionModel.
- int compareTo(const PrecisionModel* other) const;
+ /// The types of Precision Model which GEOS supports.
+ typedef enum {
+ * Fixed Precision indicates that coordinates have a fixed
+ * number of decimal places.
+ * The number of decimal places is determined by the log10
+ * of the scale factor.
+ FIXED,
+ * Floating precision corresponds to the standard Java
+ * double-precision floating-point representation, which is
+ * based on the IEEE-754 standard
+ FLOATING,
+ * Floating single precision corresponds to the standard Java
+ * single-precision floating-point representation, which is
+ FLOATING_SINGLE
+ } Type;
+ /// Creates a PrecisionModel with a default precision of FLOATING.
+ PrecisionModel(void);
+ /// Creates a PrecisionModel specifying an explicit precision model type.
+ /// If the model type is FIXED the scale factor will default to 1.
+ /// @param nModelType the type of the precision model
+ PrecisionModel(Type nModelType);
+ /** \brief
+ * Creates a <code>PrecisionModel</code> with Fixed precision.
+ * Fixed-precision coordinates are represented as precise internal
+ * coordinates, which are rounded to the grid defined by the
+ * scale factor.
+ * @param scale
+ * amount by which to multiply a coordinate after subtracting
+ * the offset, to obtain a precise coordinate
+ * @param offsetX not used.
+ * @param offsetY not used.
+ * @deprecated offsets are no longer supported, since internal
+ * representation is rounded floating point
+ PrecisionModel(double newScale, double newOffsetX, double newOffsetY);
+ * \brief
+ * Creates a PrecisionModel with Fixed precision.
+ * internal coordinates which are rounded to the grid defined
+ * by the scale factor.
+ * @param newScale amount by which to multiply a coordinate
+ * after subtracting the offset, to obtain a precise coordinate
+ PrecisionModel(double newScale);
+ // copy constructor
+ PrecisionModel(const PrecisionModel& pm);
+ /// destructor
+ ~PrecisionModel(void);
+ /// The maximum precise value representable in a double.
+ /// Since IEE754 double-precision numbers allow 53 bits of mantissa,
+ /// the value is equal to 2^53 - 1.
+ /// This provides <i>almost</i> 16 decimal digits of precision.
+ static const double maximumPreciseValue;
+ /** \brief
+ * Rounds a numeric value to the PrecisionModel grid.
+ * Asymmetric Arithmetic Rounding is used, to provide
+ * uniform rounding behaviour no matter where the number is
+ * on the number line.
+ * <b>Note:</b> Java's <code>Math#rint</code> uses the "Banker's Rounding" algorithm,
+ * which is not suitable for precision operations elsewhere in JTS.
+ double makePrecise(double val) const;
+ /// Rounds the given Coordinate to the PrecisionModel grid.
+ void makePrecise(Coordinate& coord) const;
+ void makePrecise(Coordinate* coord) const;
+ /// Tests whether the precision model supports floating point
+ /// @return <code>true</code> if the precision model supports
+ /// floating point
+ bool isFloating() const;
+ /// \brief
+ /// Returns the maximum number of significant digits provided by
+ /// this precision model.
+ /// Intended for use by routines which need to print out precise
+ /// values.
+ /// @return the maximum number of decimal places provided by this
+ /// precision model
+ int getMaximumSignificantDigits() const;
+ /// Gets the type of this PrecisionModel
+ /// @return the type of this PrecisionModel
+ Type getType() const;
+ /// Returns the multiplying factor used to obtain a precise coordinate.
+ double getScale() const;
+ /// Returns the x-offset used to obtain a precise coordinate.
+ /// @return the amount by which to subtract the x-coordinate before
+ /// multiplying by the scale
+ /// @deprecated Offsets are no longer used
+ double getOffsetX() const;
+ /// Returns the y-offset used to obtain a precise coordinate.
+ /// @return the amount by which to subtract the y-coordinate before
+ double getOffsetY() const;
+ /** \brief
+ * Sets <code>internal</code> to the precise representation of
+ * <code>external</code>.
+ * @param external the original coordinate
+ * @param internal the coordinate whose values will be changed to the
+ * precise representation of <code>external</code>
+ * @deprecated use makePrecise instead
+ //void toInternal(const Coordinate& external, Coordinate* internal) const;
+ * Returns the precise representation of <code>external</code>.
+ *@param external the original coordinate
+ *@return
+ * the coordinate whose values will be changed to the precise
+ * representation of <code>external</code>
+ //Coordinate* toInternal(const Coordinate& external) const;
+ * Returns the external representation of <code>internal</code>.
+ *@param internal the original coordinate
+ *@return the coordinate whose values will be changed to the
+ * external representation of <code>internal</code>
+ * @deprecated no longer needed, since internal representation is same as external representation
+ //Coordinate* toExternal(const Coordinate& internal) const;
+ * Sets <code>external</code> to the external representation of
+ * <code>internal</code>.
+ * @param internal the original coordinate
+ * @param external
+ //void toExternal(const Coordinate& internal, Coordinate* external) const;
+ std::string toString() const;
+ /// \brief
+ /// Compares this PrecisionModel object with the specified object
+ /// for order.
+ /// A PrecisionModel is greater than another if it provides greater
+ /// precision.
+ /// The comparison is based on the value returned by the
+ /// getMaximumSignificantDigits method.
+ /// This comparison is not strictly accurate when comparing floating
+ /// precision models to fixed models;
+ /// however, it is correct when both models are either floating or
+ /// fixed.
+ /// @param other the PrecisionModel with which this PrecisionModel
+ /// is being compared
+ /// @return a negative integer, zero, or a positive integer as this
+ /// PrecisionModel is less than, equal to, or greater than the
+ /// specified PrecisionModel.
+ int compareTo(const PrecisionModel* other) const;
private:
- /** \brief
- * Sets the multiplying factor used to obtain a precise coordinate.
- * This method is private because PrecisionModel is intended to
- * be an immutable (value) type.
- void setScale(double newScale);
- // throw IllegalArgumentException
+ /** \brief
+ * Sets the multiplying factor used to obtain a precise coordinate.
+ * This method is private because PrecisionModel is intended to
+ * be an immutable (value) type.
+ void setScale(double newScale);
+ // throw IllegalArgumentException
- Type modelType;
+ Type modelType;
- double scale;
+ double scale;
diff --git a/include/geos/geom/PrecisionModel.inl b/include/geos/geom/PrecisionModel.inl
index dd2bbe7..4f1fdf6 100644
--- a/include/geos/geom/PrecisionModel.inl
+++ b/include/geos/geom/PrecisionModel.inl
@@ -8,7 +8,7 @@
@@ -28,7 +28,7 @@ namespace geos {
/*public*/
-INLINE
+INLINE
PrecisionModel::~PrecisionModel(void)
@@ -37,15 +37,15 @@ PrecisionModel::~PrecisionModel(void)
INLINE void
PrecisionModel::makePrecise(Coordinate* coord) const
- assert(coord);
- return makePrecise(*coord);
+ assert(coord);
+ return makePrecise(*coord);
/*public*/
INLINE PrecisionModel::Type
PrecisionModel::getType() const
- return modelType;
+ return modelType;
/*public*/
diff --git a/include/geos/geom/Puntal.h b/include/geos/geom/Puntal.h
index a705d8a..7f05ac1 100644
--- a/include/geos/geom/Puntal.h
+++ b/include/geos/geom/Puntal.h
* are 0-dimensional and with components which are {@link Point}s.
-class GEOS_DLL Puntal : public virtual Geometry
+class GEOS_DLL Puntal : public virtual Geometry {
protected:
- Puntal(): Geometry(nullptr) {}
+ Puntal(): Geometry(nullptr) {}
diff --git a/include/geos/geom/Triangle.h b/include/geos/geom/Triangle.h
index 1a78ec8..26f8f2d 100644
--- a/include/geos/geom/Triangle.h
+++ b/include/geos/geom/Triangle.h
@@ -30,61 +30,61 @@ namespace geom { // geos::geom
class GEOS_DLL Triangle {
public:
- Coordinate p0, p1, p2;
- Triangle(const Coordinate& nP0, const Coordinate& nP1, const Coordinate& nP2)
- p0(nP0),
- p1(nP1),
- p2(nP2)
- * The inCentre of a triangle is the point which is equidistant
- * from the sides of the triangle. This is also the point at which the bisectors
- * of the angles meet.
- * @param resultPoint the point into which to write the inCentre of the triangle
- void inCentre(Coordinate& resultPoint);
- * Computes the circumcentre of a triangle. The circumcentre is the centre of
- * the circumcircle, the smallest circle which encloses the triangle. It is
- * also the common intersection point of the perpendicular bisectors of the
- * sides of the triangle, and is the only point which has equal distance to
- * all three vertices of the triangle.
- * <p>
- * The circumcentre does not necessarily lie within the triangle. For example,
- * the circumcentre of an obtuse isoceles triangle lies outside the triangle.
- * <p>
- * This method uses an algorithm due to J.R.Shewchuk which uses normalization
- * to the origin to improve the accuracy of computation. (See <i>Lecture Notes
- * on Geometric Robustness</i>, Jonathan Richard Shewchuk, 1999).
- void circumcentre(Coordinate& resultPoint);
+ Coordinate p0, p1, p2;
+ Triangle(const Coordinate& nP0, const Coordinate& nP1, const Coordinate& nP2)
+ p0(nP0),
+ p1(nP1),
+ p2(nP2)
+ * The inCentre of a triangle is the point which is equidistant
+ * from the sides of the triangle. This is also the point at which the bisectors
+ * of the angles meet.
+ * @param resultPoint the point into which to write the inCentre of the triangle
+ void inCentre(Coordinate& resultPoint);
+ * Computes the circumcentre of a triangle. The circumcentre is the centre of
+ * the circumcircle, the smallest circle which encloses the triangle. It is
+ * also the common intersection point of the perpendicular bisectors of the
+ * sides of the triangle, and is the only point which has equal distance to
+ * all three vertices of the triangle.
+ * <p>
+ * The circumcentre does not necessarily lie within the triangle. For example,
+ * the circumcentre of an obtuse isoceles triangle lies outside the triangle.
+ * <p>
+ * This method uses an algorithm due to J.R.Shewchuk which uses normalization
+ * to the origin to improve the accuracy of computation. (See <i>Lecture Notes
+ * on Geometric Robustness</i>, Jonathan Richard Shewchuk, 1999).
+ void circumcentre(Coordinate& resultPoint);
static const Coordinate circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2);
private:
- * Computes the determinant of a 2x2 matrix. Uses standard double-precision
- * arithmetic, so is susceptible to round-off error.
- * @param m00
- * the [0,0] entry of the matrix
- * @param m01
- * the [0,1] entry of the matrix
- * @param m10
- * the [1,0] entry of the matrix
- * @param m11
- * the [1,1] entry of the matrix
- * @return the determinant
- double det(double m00 , double m01 , double m10 , double m11) const;
+ * Computes the determinant of a 2x2 matrix. Uses standard double-precision
+ * arithmetic, so is susceptible to round-off error.
+ * @param m00
+ * the [0,0] entry of the matrix
+ * @param m01
+ * the [0,1] entry of the matrix
+ * @param m10
+ * the [1,0] entry of the matrix
+ * @param m11
+ * the [1,1] entry of the matrix
+ * @return the determinant
+ double det(double m00, double m01, double m10, double m11) const;
diff --git a/include/geos/geom/prep/AbstractPreparedPolygonContains.h b/include/geos/geom/prep/AbstractPreparedPolygonContains.h
index 3106ca4..d9c00cc 100644
--- a/include/geos/geom/prep/AbstractPreparedPolygonContains.h
+++ b/include/geos/geom/prep/AbstractPreparedPolygonContains.h
@@ -25,13 +25,13 @@
// forward declarations
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
- namespace prep {
- class PreparedPolygon;
+namespace prep {
+class PreparedPolygon;
@@ -62,71 +62,70 @@ namespace prep { // geos::geom::prep
* @author Martin Davis
-class AbstractPreparedPolygonContains : public PreparedPolygonPredicate
+class AbstractPreparedPolygonContains : public PreparedPolygonPredicate {
private:
- // information about geometric situation
- bool hasSegmentIntersection;
- bool hasProperIntersection;
- bool hasNonProperIntersection;
+ // information about geometric situation
+ bool hasSegmentIntersection;
+ bool hasProperIntersection;
+ bool hasNonProperIntersection;
- bool isProperIntersectionImpliesNotContainedSituation( const geom::Geometry * testGeom);
+ bool isProperIntersectionImpliesNotContainedSituation(const geom::Geometry* testGeom);
- * Tests whether a geometry consists of a single polygon with no holes.
- * @return true if the geometry is a single polygon with no holes
- bool isSingleShell( const geom::Geometry & geom);
+ * Tests whether a geometry consists of a single polygon with no holes.
+ * @return true if the geometry is a single polygon with no holes
+ bool isSingleShell(const geom::Geometry& geom);
- void findAndClassifyIntersections( const geom::Geometry * geom);
+ void findAndClassifyIntersections(const geom::Geometry* geom);
protected:
- * This flag controls a difference between contains and covers.
- * For contains the value is true.
- * For covers the value is false.
- bool requireSomePointInInterior;
- * Evaluate the <tt>contains</tt> or <tt>covers</tt> relationship
- * for the given geometry.
- * @param geom the test geometry
- * @return true if the test geometry is contained
- bool eval( const geom::Geometry * geom);
- * Computes the full topological predicate.
- * Used when short-circuit tests are not conclusive.
- * @return true if this prepared polygon has the relationship with the test geometry
- virtual bool fullTopologicalPredicate( const geom::Geometry * geom) =0;
+ * This flag controls a difference between contains and covers.
+ * For contains the value is true.
+ * For covers the value is false.
+ bool requireSomePointInInterior;
+ * Evaluate the <tt>contains</tt> or <tt>covers</tt> relationship
+ * for the given geometry.
+ * @param geom the test geometry
+ * @return true if the test geometry is contained
+ bool eval(const geom::Geometry* geom);
+ * Computes the full topological predicate.
+ * Used when short-circuit tests are not conclusive.
+ * @return true if this prepared polygon has the relationship with the test geometry
+ virtual bool fullTopologicalPredicate(const geom::Geometry* geom) = 0;
public:
- AbstractPreparedPolygonContains( const PreparedPolygon * const p_prepPoly)
- : PreparedPolygonPredicate( p_prepPoly),
- hasSegmentIntersection( false),
- hasProperIntersection( false),
- hasNonProperIntersection( false),
- requireSomePointInInterior(true)
- AbstractPreparedPolygonContains( const PreparedPolygon * const p_prepPoly, bool p_requireSomePointInInterior)
- requireSomePointInInterior(p_requireSomePointInInterior)
- ~AbstractPreparedPolygonContains() override
+ AbstractPreparedPolygonContains(const PreparedPolygon* const p_prepPoly)
+ : PreparedPolygonPredicate(p_prepPoly),
+ hasSegmentIntersection(false),
+ hasProperIntersection(false),
+ hasNonProperIntersection(false),
+ requireSomePointInInterior(true)
+ AbstractPreparedPolygonContains(const PreparedPolygon* const p_prepPoly, bool p_requireSomePointInInterior)
+ requireSomePointInInterior(p_requireSomePointInInterior)
+ ~AbstractPreparedPolygonContains() override
diff --git a/include/geos/geom/prep/BasicPreparedGeometry.h b/include/geos/geom/prep/BasicPreparedGeometry.h
index a084ab6..7157906 100644
--- a/include/geos/geom/prep/BasicPreparedGeometry.h
+++ b/include/geos/geom/prep/BasicPreparedGeometry.h
@@ -30,10 +30,10 @@
#include <string>
namespace geos {
- namespace geom {
- class Geometry;
- class Coordinate;
+namespace geom {
+class Geometry;
+class Coordinate;
@@ -56,122 +56,123 @@ namespace prep { // geos::geom::prep
-class BasicPreparedGeometry: public PreparedGeometry
+class BasicPreparedGeometry: public PreparedGeometry {
private:
- const geom::Geometry * baseGeom;
- Coordinate::ConstVect representativePts;
+ const geom::Geometry* baseGeom;
+ Coordinate::ConstVect representativePts;
protected:
- * Sets the original {@link Geometry} which will be prepared.
- void setGeometry( const geom::Geometry * geom );
- * Determines whether a Geometry g interacts with
- * this geometry by testing the geometry envelopes.
- * @param g a Geometry
- * @return true if the envelopes intersect
- bool envelopesIntersect(const geom::Geometry* g) const;
- * Determines whether the envelope of
- * this geometry covers the Geometry g.
- * @return true if g is contained in this envelope
- bool envelopeCovers(const geom::Geometry* g) const;
+ * Sets the original {@link Geometry} which will be prepared.
+ void setGeometry(const geom::Geometry* geom);
+ * Determines whether a Geometry g interacts with
+ * this geometry by testing the geometry envelopes.
+ * @param g a Geometry
+ * @return true if the envelopes intersect
+ bool envelopesIntersect(const geom::Geometry* g) const;
+ * Determines whether the envelope of
+ * this geometry covers the Geometry g.
+ * @return true if g is contained in this envelope
+ bool envelopeCovers(const geom::Geometry* g) const;
public:
- BasicPreparedGeometry( const Geometry * geom);
- ~BasicPreparedGeometry( ) override;
- const geom::Geometry & getGeometry() const override
- return *baseGeom;
- * Gets the list of representative points for this geometry.
- * One vertex is included for every component of the geometry
- * (i.e. including one for every ring of polygonal geometries)
- * @return a List of Coordinate
- const Coordinate::ConstVect * getRepresentativePoints() const
- return &representativePts;
- * Tests whether any representative of the target geometry
- * intersects the test geometry.
- * This is useful in A/A, A/L, A/P, L/P, and P/P cases.
- * @param repPts the representative points of the target geometry
- * @return true if any component intersects the areal test geometry
- bool isAnyTargetComponentInTest(const geom::Geometry * testGeom) const;
- * Default implementation.
- bool contains(const geom::Geometry * g) const override;
- bool containsProperly(const geom::Geometry * g) const override;
- bool coveredBy(const geom::Geometry * g) const override;
- bool covers(const geom::Geometry * g) const override;
- bool crosses(const geom::Geometry * g) const override;
- * Standard implementation for all geometries.
- * Supports {@link GeometryCollection}s as input.
- bool disjoint(const geom::Geometry * g) const override;
- bool intersects(const geom::Geometry * g) const override;
- bool overlaps(const geom::Geometry * g) const override;
- bool touches(const geom::Geometry * g) const override;
- bool within(const geom::Geometry * g) const override;
- std::string toString();
+ BasicPreparedGeometry(const Geometry* geom);
+ ~BasicPreparedGeometry() override;
+ const geom::Geometry&
+ getGeometry() const override
+ return *baseGeom;
+ * Gets the list of representative points for this geometry.
+ * One vertex is included for every component of the geometry
+ * (i.e. including one for every ring of polygonal geometries)
+ * @return a List of Coordinate
+ const Coordinate::ConstVect*
+ getRepresentativePoints() const
+ return &representativePts;
+ * Tests whether any representative of the target geometry
+ * intersects the test geometry.
+ * This is useful in A/A, A/L, A/P, L/P, and P/P cases.
+ * @param repPts the representative points of the target geometry
+ * @return true if any component intersects the areal test geometry
+ bool isAnyTargetComponentInTest(const geom::Geometry* testGeom) const;
+ * Default implementation.
+ bool contains(const geom::Geometry* g) const override;
+ bool containsProperly(const geom::Geometry* g) const override;
+ bool coveredBy(const geom::Geometry* g) const override;
+ bool covers(const geom::Geometry* g) const override;
+ bool crosses(const geom::Geometry* g) const override;
+ * Standard implementation for all geometries.
+ * Supports {@link GeometryCollection}s as input.
+ bool disjoint(const geom::Geometry* g) const override;
+ bool intersects(const geom::Geometry* g) const override;
+ bool overlaps(const geom::Geometry* g) const override;
+ bool touches(const geom::Geometry* g) const override;
+ bool within(const geom::Geometry* g) const override;
+ std::string toString();
diff --git a/include/geos/geom/prep/PreparedGeometry.h b/include/geos/geom/prep/PreparedGeometry.h
index ebcdc96..4c96382 100644
--- a/include/geos/geom/prep/PreparedGeometry.h
+++ b/include/geos/geom/prep/PreparedGeometry.h
@@ -23,9 +23,9 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
@@ -52,145 +52,146 @@ namespace prep { // geos::geom::prep
class GEOS_DLL PreparedGeometry {
public:
- virtual ~PreparedGeometry() {}
- * Gets the original {@link Geometry} which has been prepared.
- * @return the base geometry
- virtual const geom::Geometry & getGeometry() const =0;
- * Tests whether the base {@link Geometry} contains a given geometry.
- * @param geom the Geometry to test
- * @return true if this Geometry contains the given Geometry
- * @see Geometry#contains(Geometry)
- virtual bool contains(const geom::Geometry *geom) const =0;
- /** \brief
- * Tests whether the base {@link Geometry} properly contains
- * a given geometry.
- * The <code>containsProperly</code> predicate has the following
- * equivalent definitions:
- * - Every point of the other geometry is a point of this
- * geometry's interior.
- * - The DE-9IM Intersection Matrix for the two geometries matches
- * <code>[T**FF*FF*]</code>
+ virtual
+ ~PreparedGeometry() {}
+ * Gets the original {@link Geometry} which has been prepared.
+ * @return the base geometry
+ virtual const geom::Geometry& getGeometry() const = 0;
+ * Tests whether the base {@link Geometry} contains a given geometry.
+ * @param geom the Geometry to test
+ * @return true if this Geometry contains the given Geometry
+ * @see Geometry#contains(Geometry)
+ virtual bool contains(const geom::Geometry* geom) const = 0;
+ /** \brief
+ * Tests whether the base {@link Geometry} properly contains
+ * a given geometry.
+ * The <code>containsProperly</code> predicate has the following
+ * equivalent definitions:
+ * - Every point of the other geometry is a point of this
+ * geometry's interior.
+ * - The DE-9IM Intersection Matrix for the two geometries matches
+ * <code>[T**FF*FF*]</code>
* In other words, if the test geometry has any interaction with
- * the boundary of the target
+ * the boundary of the target
* geometry the result of <tt>containsProperly</tt> is <tt>false</tt>.
* This is different semantics to the {@link Geometry::contains}
- * predicate, * in which test geometries can intersect the target's
- * boundary and still be contained.
+ * predicate, * in which test geometries can intersect the target's
+ * boundary and still be contained.
* The advantage of using this predicate is that it can be computed
* efficiently, since it avoids the need to compute the full
- * topological relationship of the input boundaries in cases where
- * they intersect.
+ * topological relationship of the input boundaries in cases where
+ * they intersect.
* An example use case is computing the intersections
* of a set of geometries with a large polygonal geometry.
* Since <tt>intersection</tt> is a fairly slow operation, it can
- * be more efficient
+ * be more efficient
* to use <tt>containsProperly</tt> to filter out test geometries
- * which lie
+ * which lie
* wholly inside the area. In these cases the intersection is
* known <i>a priori</i> to be exactly the original test geometry.
- * @return true if this Geometry properly contains the given Geometry
- * @see Geometry::contains
- virtual bool containsProperly(const geom::Geometry *geom) const =0;
- * Tests whether the base {@link Geometry} is covered by a given geometry.
- * @return true if this Geometry is covered by the given Geometry
- * @see Geometry#coveredBy(Geometry)
- virtual bool coveredBy(const geom::Geometry *geom) const =0;
- * Tests whether the base {@link Geometry} covers a given geometry.
- * @return true if this Geometry covers the given Geometry
- * @see Geometry#covers(Geometry)
- virtual bool covers(const geom::Geometry *geom) const =0;
- * Tests whether the base {@link Geometry} crosses a given geometry.
- * @return true if this Geometry crosses the given Geometry
- * @see Geometry#crosses(Geometry)
- virtual bool crosses(const geom::Geometry *geom) const =0;
- * Tests whether the base {@link Geometry} is disjoint from a given geometry.
- * @return true if this Geometry is disjoint from the given Geometry
- * @see Geometry#disjoint(Geometry)
- virtual bool disjoint(const geom::Geometry *geom) const =0;
- * Tests whether the base {@link Geometry} intersects a given geometry.
- * @return true if this Geometry intersects the given Geometry
- * @see Geometry#intersects(Geometry)
- virtual bool intersects(const geom::Geometry *geom) const =0;
- * Tests whether the base {@link Geometry} overlaps a given geometry.
- * @return true if this Geometry overlaps the given Geometry
- * @see Geometry#overlaps(Geometry)
- virtual bool overlaps(const geom::Geometry *geom) const =0;
- * Tests whether the base {@link Geometry} touches a given geometry.
- * @return true if this Geometry touches the given Geometry
- * @see Geometry#touches(Geometry)
- virtual bool touches(const geom::Geometry *geom) const =0;
- * Tests whether the base {@link Geometry} is within a given geometry.
- * @return true if this Geometry is within the given Geometry
- * @see Geometry#within(Geometry)
- virtual bool within(const geom::Geometry *geom) const =0;
+ * @return true if this Geometry properly contains the given Geometry
+ * @see Geometry::contains
+ virtual bool containsProperly(const geom::Geometry* geom) const = 0;
+ * Tests whether the base {@link Geometry} is covered by a given geometry.
+ * @return true if this Geometry is covered by the given Geometry
+ * @see Geometry#coveredBy(Geometry)
+ virtual bool coveredBy(const geom::Geometry* geom) const = 0;
+ * Tests whether the base {@link Geometry} covers a given geometry.
+ * @return true if this Geometry covers the given Geometry
+ * @see Geometry#covers(Geometry)
+ virtual bool covers(const geom::Geometry* geom) const = 0;
+ * Tests whether the base {@link Geometry} crosses a given geometry.
+ * @return true if this Geometry crosses the given Geometry
+ * @see Geometry#crosses(Geometry)
+ virtual bool crosses(const geom::Geometry* geom) const = 0;
+ * Tests whether the base {@link Geometry} is disjoint from a given geometry.
+ * @return true if this Geometry is disjoint from the given Geometry
+ * @see Geometry#disjoint(Geometry)
+ virtual bool disjoint(const geom::Geometry* geom) const = 0;
+ * Tests whether the base {@link Geometry} intersects a given geometry.
+ * @return true if this Geometry intersects the given Geometry
+ * @see Geometry#intersects(Geometry)
+ virtual bool intersects(const geom::Geometry* geom) const = 0;
+ * Tests whether the base {@link Geometry} overlaps a given geometry.
+ * @return true if this Geometry overlaps the given Geometry
+ * @see Geometry#overlaps(Geometry)
+ virtual bool overlaps(const geom::Geometry* geom) const = 0;
+ * Tests whether the base {@link Geometry} touches a given geometry.
+ * @return true if this Geometry touches the given Geometry
+ * @see Geometry#touches(Geometry)
+ virtual bool touches(const geom::Geometry* geom) const = 0;
+ * Tests whether the base {@link Geometry} is within a given geometry.
+ * @return true if this Geometry is within the given Geometry
+ * @see Geometry#within(Geometry)
+ virtual bool within(const geom::Geometry* geom) const = 0;
diff --git a/include/geos/geom/prep/PreparedGeometryFactory.h b/include/geos/geom/prep/PreparedGeometryFactory.h
index 9f07386..3260772 100644
--- a/include/geos/geom/prep/PreparedGeometryFactory.h
+++ b/include/geos/geom/prep/PreparedGeometryFactory.h
@@ -24,11 +24,11 @@
#include <geos/geom/prep/PreparedGeometry.h>
namespace geos {
- namespace geom {
- namespace prep {
- class PreparedGeometry;
+namespace geom {
+namespace prep {
+class PreparedGeometry;
@@ -49,39 +49,40 @@ namespace prep { // geos::geom::prep
-class GEOS_DLL PreparedGeometryFactory
+class GEOS_DLL PreparedGeometryFactory {
public:
- * Creates a new {@link PreparedGeometry} appropriate for the argument {@link Geometry}.
- * @param geom the geometry to prepare
- * @return the prepared geometry
- static const PreparedGeometry * prepare(const geom::Geometry * geom)
- PreparedGeometryFactory pf;
- return pf.create(geom);
+ * Creates a new {@link PreparedGeometry} appropriate for the argument {@link Geometry}.
+ * @param geom the geometry to prepare
+ * @return the prepared geometry
+ static const PreparedGeometry*
+ prepare(const geom::Geometry* geom)
+ PreparedGeometryFactory pf;
+ return pf.create(geom);
- * Destroys {@link PreparedGeometry} allocated with the factory.
- * @param geom to be deallocated
- static void destroy(const PreparedGeometry* geom)
+ * Destroys {@link PreparedGeometry} allocated with the factory.
+ * @param geom to be deallocated
+ static void
+ destroy(const PreparedGeometry* geom)
delete geom;
- const PreparedGeometry* create(const geom::Geometry* geom) const;
+ const PreparedGeometry* create(const geom::Geometry* geom) const;
diff --git a/include/geos/geom/prep/PreparedLineString.h b/include/geos/geom/prep/PreparedLineString.h
index d804b80..bf5789e 100644
--- a/include/geos/geom/prep/PreparedLineString.h
+++ b/include/geos/geom/prep/PreparedLineString.h
@@ -24,9 +24,9 @@
#include <geos/noding/SegmentString.h>
namespace geos {
- namespace noding {
- class FastSegmentSetIntersectionFinder;
+namespace noding {
+class FastSegmentSetIntersectionFinder;
namespace geos {
@@ -40,25 +40,24 @@ namespace prep { // geos::geom::prep
* @author mbdavis
-class PreparedLineString : public BasicPreparedGeometry
+class PreparedLineString : public BasicPreparedGeometry {
private:
- noding::FastSegmentSetIntersectionFinder * segIntFinder;
- mutable noding::SegmentString::ConstVect segStrings;
+ noding::FastSegmentSetIntersectionFinder* segIntFinder;
+ mutable noding::SegmentString::ConstVect segStrings;
protected:
public:
- PreparedLineString(const Geometry * geom)
- BasicPreparedGeometry( geom),
- segIntFinder( nullptr)
+ PreparedLineString(const Geometry* geom)
+ BasicPreparedGeometry(geom),
+ segIntFinder(nullptr)
- ~PreparedLineString() override;
+ ~PreparedLineString() override;
- noding::FastSegmentSetIntersectionFinder * getIntersectionFinder();
+ noding::FastSegmentSetIntersectionFinder* getIntersectionFinder();
diff --git a/include/geos/geom/prep/PreparedLineStringIntersects.h b/include/geos/geom/prep/PreparedLineStringIntersects.h
index a1aef89..2196257 100644
--- a/include/geos/geom/prep/PreparedLineStringIntersects.h
+++ b/include/geos/geom/prep/PreparedLineStringIntersects.h
@@ -41,51 +41,51 @@ namespace prep { // geos::geom::prep
-class PreparedLineStringIntersects
+class PreparedLineStringIntersects {
public:
- * Computes the intersects predicate between a {@link PreparedLineString}
- * and a {@link Geometry}.
- * @param prep the prepared linestring
- * @param geom a test geometry
- * @return true if the linestring intersects the geometry
- static bool intersects( PreparedLineString & prep, const geom::Geometry * geom )
- PreparedLineStringIntersects op( prep);
- return op.intersects( geom);
+ * Computes the intersects predicate between a {@link PreparedLineString}
+ * and a {@link Geometry}.
+ * @param prep the prepared linestring
+ * @param geom a test geometry
+ * @return true if the linestring intersects the geometry
+ static bool
+ intersects(PreparedLineString& prep, const geom::Geometry* geom)
+ PreparedLineStringIntersects op(prep);
+ return op.intersects(geom);
* \todo FIXME - mloskot: Why not taking linestring through const reference?
- PreparedLineStringIntersects(PreparedLineString & prep)
- : prepLine( prep)
+ PreparedLineStringIntersects(PreparedLineString& prep)
+ : prepLine(prep)
- * Tests whether this geometry intersects a given geometry.
- * @return true if the test geometry intersects
- bool intersects(const geom::Geometry * g) const;
+ * Tests whether this geometry intersects a given geometry.
+ * @return true if the test geometry intersects
+ bool intersects(const geom::Geometry* g) const;
protected:
- PreparedLineString & prepLine;
+ PreparedLineString& prepLine;
- * Tests whether any representative point of the test Geometry intersects
- * the target geometry.
- * Only handles test geometries which are Puntal (dimension 0)
- * @param geom a Puntal geometry to test
- * @return true if any point of the argument intersects the prepared geometry
- bool isAnyTestPointInTarget(const geom::Geometry * testGeom) const;
+ * Tests whether any representative point of the test Geometry intersects
+ * the target geometry.
+ * Only handles test geometries which are Puntal (dimension 0)
+ * @param geom a Puntal geometry to test
+ * @return true if any point of the argument intersects the prepared geometry
+ bool isAnyTestPointInTarget(const geom::Geometry* testGeom) const;
// Declare type as noncopyable
PreparedLineStringIntersects(const PreparedLineStringIntersects& other) = delete;
diff --git a/include/geos/geom/prep/PreparedPoint.h b/include/geos/geom/prep/PreparedPoint.h
index 6355f07..5c4dd37 100644
--- a/include/geos/geom/prep/PreparedPoint.h
+++ b/include/geos/geom/prep/PreparedPoint.h
@@ -33,22 +33,21 @@ namespace prep { // geos::geom::prep
-class PreparedPoint: public BasicPreparedGeometry
+class PreparedPoint: public BasicPreparedGeometry {
private:
protected:
public:
- PreparedPoint(const Geometry * geom)
- : BasicPreparedGeometry( geom)
- * Tests whether this point intersects a {@link Geometry}.
- * The optimization here is that computing topology for the test
- * geometry is avoided. This can be significant for large geometries.
- bool intersects(const geom::Geometry* g) const override;
+ PreparedPoint(const Geometry* geom)
+ : BasicPreparedGeometry(geom)
+ * Tests whether this point intersects a {@link Geometry}.
+ * The optimization here is that computing topology for the test
+ * geometry is avoided. This can be significant for large geometries.
diff --git a/include/geos/geom/prep/PreparedPolygon.h b/include/geos/geom/prep/PreparedPolygon.h
index 0bfde3d..295397d 100644
--- a/include/geos/geom/prep/PreparedPolygon.h
+++ b/include/geos/geom/prep/PreparedPolygon.h
@@ -24,14 +24,14 @@
namespace geos {
- namespace algorithm {
- namespace locate {
- class PointOnGeometryLocator;
+namespace noding {
+namespace algorithm {
+namespace locate {
+class PointOnGeometryLocator;
namespace geos {
@@ -45,26 +45,25 @@ namespace prep { // geos::geom::prep
* @author mbdavis
-class PreparedPolygon : public BasicPreparedGeometry
+class PreparedPolygon : public BasicPreparedGeometry {
private:
- bool isRectangle;
- mutable noding::FastSegmentSetIntersectionFinder * segIntFinder;
- mutable algorithm::locate::PointOnGeometryLocator * ptOnGeomLoc;
+ bool isRectangle;
+ mutable noding::FastSegmentSetIntersectionFinder* segIntFinder;
+ mutable algorithm::locate::PointOnGeometryLocator* ptOnGeomLoc;
protected:
public:
- PreparedPolygon( const geom::Geometry * geom);
- ~PreparedPolygon( ) override;
+ PreparedPolygon(const geom::Geometry* geom);
+ ~PreparedPolygon() override;
- noding::FastSegmentSetIntersectionFinder * getIntersectionFinder() const;
- algorithm::locate::PointOnGeometryLocator * getPointLocator() const;
+ noding::FastSegmentSetIntersectionFinder* getIntersectionFinder() const;
+ algorithm::locate::PointOnGeometryLocator* getPointLocator() const;
- bool contains( const geom::Geometry* g) const override;
- bool containsProperly( const geom::Geometry* g) const override;
- bool covers( const geom::Geometry* g) const override;
- bool intersects( const geom::Geometry* g) const override;
diff --git a/include/geos/geom/prep/PreparedPolygonContains.h b/include/geos/geom/prep/PreparedPolygonContains.h
index bf76452..c8fe743 100644
--- a/include/geos/geom/prep/PreparedPolygonContains.h
+++ b/include/geos/geom/prep/PreparedPolygonContains.h
@@ -24,13 +24,13 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
- namespace prep {
+namespace prep {
namespace geos {
@@ -51,51 +51,52 @@ namespace prep { // geos::geom::prep
-class PreparedPolygonContains : public AbstractPreparedPolygonContains
+class PreparedPolygonContains : public AbstractPreparedPolygonContains {
public:
- * Creates an instance of this operation.
- * @param prepPoly the PreparedPolygon to evaluate
- PreparedPolygonContains(const PreparedPolygon * const prepPoly);
+ * Creates an instance of this operation.
+ * @param prepPoly the PreparedPolygon to evaluate
+ PreparedPolygonContains(const PreparedPolygon* const prepPoly);
- * Tests whether this PreparedPolygon <tt>contains</tt> a given geometry.
- bool contains(const geom::Geometry * geom)
- return eval(geom);
+ * Tests whether this PreparedPolygon <tt>contains</tt> a given geometry.
+ bool
+ contains(const geom::Geometry* geom)
+ return eval(geom);
- * Computes the </tt>contains</tt> predicate between a {@link PreparedPolygon}
- * @param prep the prepared polygon
- * @return true if the polygon contains the geometry
- static bool contains(const PreparedPolygon * const prep, const geom::Geometry * geom)
- PreparedPolygonContains polyInt(prep);
- return polyInt.contains(geom);
+ * Computes the </tt>contains</tt> predicate between a {@link PreparedPolygon}
+ * @param prep the prepared polygon
+ * @return true if the polygon contains the geometry
+ static bool
+ contains(const PreparedPolygon* const prep, const geom::Geometry* geom)
+ PreparedPolygonContains polyInt(prep);
+ return polyInt.contains(geom);
protected:
- * Computes the full topological <tt>contains</tt> predicate.
- * @return true if this prepared polygon contains the test geometry
- bool fullTopologicalPredicate(const geom::Geometry * geom) override;
+ * Computes the full topological <tt>contains</tt> predicate.
+ * @return true if this prepared polygon contains the test geometry
+ bool fullTopologicalPredicate(const geom::Geometry* geom) override;
diff --git a/include/geos/geom/prep/PreparedPolygonContainsProperly.h b/include/geos/geom/prep/PreparedPolygonContainsProperly.h
index ee36d9e..09a71e1 100644
--- a/include/geos/geom/prep/PreparedPolygonContainsProperly.h
+++ b/include/geos/geom/prep/PreparedPolygonContainsProperly.h
@@ -24,13 +24,13 @@
#include <geos/geom/prep/PreparedPolygonPredicate.h> // inherited
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
- namespace prep {
+namespace prep {
namespace geos {
@@ -56,44 +56,43 @@ namespace prep { // geos::geom::prep
-class PreparedPolygonContainsProperly : public PreparedPolygonPredicate
+class PreparedPolygonContainsProperly : public PreparedPolygonPredicate {
private:
protected:
public:
- * Computes the </tt>containsProperly</tt> predicate between a {@link PreparedPolygon}
- * @return true if the polygon properly contains the geometry
- static
- bool
- containsProperly( const PreparedPolygon * const prep, const geom::Geometry * geom)
- PreparedPolygonContainsProperly polyInt( prep);
- return polyInt.containsProperly( geom);
+ * Computes the </tt>containsProperly</tt> predicate between a {@link PreparedPolygon}
+ * @return true if the polygon properly contains the geometry
+ static
+ bool
+ containsProperly(const PreparedPolygon* const prep, const geom::Geometry* geom)
+ PreparedPolygonContainsProperly polyInt(prep);
+ return polyInt.containsProperly(geom);
- PreparedPolygonContainsProperly( const PreparedPolygon * const prep)
- : PreparedPolygonPredicate( prep)
+ PreparedPolygonContainsProperly(const PreparedPolygon* const prep)
+ : PreparedPolygonPredicate(prep)
- * Tests whether this PreparedPolygon containsProperly a given geometry.
- * @return true if the test geometry is contained properly
- bool
- containsProperly( const geom::Geometry * geom);
+ * Tests whether this PreparedPolygon containsProperly a given geometry.
+ * @return true if the test geometry is contained properly
+ bool
+ containsProperly(const geom::Geometry* geom);
diff --git a/include/geos/geom/prep/PreparedPolygonCovers.h b/include/geos/geom/prep/PreparedPolygonCovers.h
index f633523..494e47b 100644
--- a/include/geos/geom/prep/PreparedPolygonCovers.h
+++ b/include/geos/geom/prep/PreparedPolygonCovers.h
@@ -25,13 +25,13 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
- namespace prep {
+namespace prep {
namespace geos {
@@ -52,53 +52,54 @@ namespace prep { // geos::geom::prep
-class PreparedPolygonCovers : public AbstractPreparedPolygonContains
+class PreparedPolygonCovers : public AbstractPreparedPolygonContains {
private:
protected:
- * Computes the full topological <tt>covers</tt> predicate.
- * @return true if this prepared polygon covers the test geometry
- bool fullTopologicalPredicate( const geom::Geometry * geom) override;
+ * Computes the full topological <tt>covers</tt> predicate.
+ * @return true if this prepared polygon covers the test geometry
public:
- * Computes the </tt>covers</tt> predicate between a {@link PreparedPolygon}
- * @return true if the polygon covers the geometry
- static bool covers(const PreparedPolygon * const prep, const geom::Geometry * geom)
- PreparedPolygonCovers polyInt(prep);
- return polyInt.covers(geom);
+ * Computes the </tt>covers</tt> predicate between a {@link PreparedPolygon}
+ * @return true if the polygon covers the geometry
+ static bool
+ covers(const PreparedPolygon* const prep, const geom::Geometry* geom)
+ PreparedPolygonCovers polyInt(prep);
+ return polyInt.covers(geom);
- PreparedPolygonCovers(const PreparedPolygon * const prep)
- : AbstractPreparedPolygonContains( prep, false)
+ PreparedPolygonCovers(const PreparedPolygon* const prep)
+ : AbstractPreparedPolygonContains(prep, false)
- * Tests whether this PreparedPolygon <tt>covers</tt> a given geometry.
- * @return true if the test geometry is covered
- bool covers( const Geometry * geom)
- return eval( geom);
+ * Tests whether this PreparedPolygon <tt>covers</tt> a given geometry.
+ * @return true if the test geometry is covered
+ bool
+ covers(const Geometry* geom)
diff --git a/include/geos/geom/prep/PreparedPolygonIntersects.h b/include/geos/geom/prep/PreparedPolygonIntersects.h
index e34e18d..c73f4cd 100644
--- a/include/geos/geom/prep/PreparedPolygonIntersects.h
+++ b/include/geos/geom/prep/PreparedPolygonIntersects.h
@@ -24,13 +24,13 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
- namespace prep {
+namespace prep {
namespace geos {
@@ -47,41 +47,41 @@ namespace prep { // geos::geom::prep
-class PreparedPolygonIntersects : public PreparedPolygonPredicate
+class PreparedPolygonIntersects : public PreparedPolygonPredicate {
private:
protected:
public:
- * Computes the intersects predicate between a {@link PreparedPolygon}
- * @return true if the polygon intersects the geometry
- static bool intersects( const PreparedPolygon * const prep, const geom::Geometry * geom)
- PreparedPolygonIntersects polyInt(prep);
- return polyInt.intersects( geom);
+ * Computes the intersects predicate between a {@link PreparedPolygon}
+ * @return true if the polygon intersects the geometry
+ static bool
+ intersects(const PreparedPolygon* const prep, const geom::Geometry* geom)
+ PreparedPolygonIntersects polyInt(prep);
+ return polyInt.intersects(geom);
- PreparedPolygonIntersects( const PreparedPolygon * const prep)
+ PreparedPolygonIntersects(const PreparedPolygon* const prep)
- * Tests whether this PreparedPolygon intersects a given geometry.
- bool intersects( const geom::Geometry * geom);
+ * Tests whether this PreparedPolygon intersects a given geometry.
+ bool intersects(const geom::Geometry* geom);
diff --git a/include/geos/geom/prep/PreparedPolygonPredicate.h b/include/geos/geom/prep/PreparedPolygonPredicate.h
index f340930..bcc1812 100644
--- a/include/geos/geom/prep/PreparedPolygonPredicate.h
+++ b/include/geos/geom/prep/PreparedPolygonPredicate.h
@@ -25,21 +25,21 @@
namespace geos {
- namespace geom {
- class Geometry;
- namespace prep {
+namespace locate {
+namespace geom {
+class Geometry;
+namespace prep {
+namespace noding {
@@ -54,86 +54,87 @@ namespace prep { // geos::geom::prep
* @author mbdavis
-class PreparedPolygonPredicate
+class PreparedPolygonPredicate {
private:
PreparedPolygonPredicate(const PreparedPolygonPredicate& other) = delete;
PreparedPolygonPredicate& operator=(const PreparedPolygonPredicate& rhs) = delete;
protected:
- const PreparedPolygon * const prepPoly;
- /** \brief
- * Tests whether all components of the test Geometry
- * are contained in the target geometry.
- * Handles both linear and point components.
- * @param geom a geometry to test
- * @return true if all components of the argument are contained
- * in the target geometry
- bool isAllTestComponentsInTarget(const geom::Geometry * testGeom) const;
- /** \brief
- * are contained in the interior of the target geometry.
- * @return true if all componenta of the argument are contained in
- * the target geometry interior
- bool isAllTestComponentsInTargetInterior( const geom::Geometry * testGeom) const;
- /** \brief
- * Tests whether any component of the test Geometry intersects
- * the area of the target geometry.
- * Handles test geometries with both linear and point components.
- * @return true if any component of the argument intersects the
- * prepared geometry
- bool isAnyTestComponentInTarget( const geom::Geometry * testGeom) const;
- /** \brief
- * the interior of the target geometry.
- * prepared area geometry interior
- bool isAnyTestComponentInTargetInterior( const geom::Geometry * testGeom) const;
- * Tests whether any component of the target geometry
- * intersects the test geometry (which must be an areal geometry)
- bool isAnyTargetComponentInAreaTest( const geom::Geometry * testGeom, const geom::Coordinate::ConstVect * targetRepPts) const;
+ const PreparedPolygon* const prepPoly;
+ /** \brief
+ * Tests whether all components of the test Geometry
+ * are contained in the target geometry.
+ * Handles both linear and point components.
+ * @param geom a geometry to test
+ * @return true if all components of the argument are contained
+ * in the target geometry
+ bool isAllTestComponentsInTarget(const geom::Geometry* testGeom) const;
+ /** \brief
+ * are contained in the interior of the target geometry.
+ * @return true if all componenta of the argument are contained in
+ * the target geometry interior
+ bool isAllTestComponentsInTargetInterior(const geom::Geometry* testGeom) const;
+ /** \brief
+ * Tests whether any component of the test Geometry intersects
+ * the area of the target geometry.
+ * Handles test geometries with both linear and point components.
+ * @return true if any component of the argument intersects the
+ * prepared geometry
+ bool isAnyTestComponentInTarget(const geom::Geometry* testGeom) const;
+ /** \brief
+ * the interior of the target geometry.
+ * prepared area geometry interior
+ bool isAnyTestComponentInTargetInterior(const geom::Geometry* testGeom) const;
+ * Tests whether any component of the target geometry
+ * intersects the test geometry (which must be an areal geometry)
+ bool isAnyTargetComponentInAreaTest(const geom::Geometry* testGeom,
+ const geom::Coordinate::ConstVect* targetRepPts) const;
public:
- PreparedPolygonPredicate( const PreparedPolygon * const p_prepPoly)
- : prepPoly( p_prepPoly)
- virtual ~PreparedPolygonPredicate()
+ PreparedPolygonPredicate(const PreparedPolygon* const p_prepPoly)
+ : prepPoly(p_prepPoly)
+ virtual
+ ~PreparedPolygonPredicate()
diff --git a/include/geos/geom/util/ComponentCoordinateExtracter.h b/include/geos/geom/util/ComponentCoordinateExtracter.h
index dc86bd4..ddfc9d6 100644
--- a/include/geos/geom/util/ComponentCoordinateExtracter.h
+++ b/include/geos/geom/util/ComponentCoordinateExtracter.h
@@ -34,31 +34,30 @@ namespace util { // geos::geom::util
* @version 1.9
-class ComponentCoordinateExtracter : public GeometryComponentFilter
+class ComponentCoordinateExtracter : public GeometryComponentFilter {
public:
- * Push the linear components from a single geometry into
- * the provided vector.
- * If more than one geometry is to be processed, it is more
- * efficient to create a single ComponentCoordinateFilter instance
- * and pass it to multiple geometries.
- static void getCoordinates(const Geometry &geom, std::vector<const Coordinate*> &ret);
+ * Push the linear components from a single geometry into
+ * the provided vector.
+ * If more than one geometry is to be processed, it is more
+ * efficient to create a single ComponentCoordinateFilter instance
+ * and pass it to multiple geometries.
+ static void getCoordinates(const Geometry& geom, std::vector<const Coordinate*>& ret);
- * Constructs a ComponentCoordinateFilter with a list in which
- * to store Coordinates found.
- ComponentCoordinateExtracter( std::vector<const Coordinate*> &newComps);
+ * Constructs a ComponentCoordinateFilter with a list in which
+ * to store Coordinates found.
+ ComponentCoordinateExtracter(std::vector<const Coordinate*>& newComps);
- void filter_rw( Geometry * geom) override;
+ void filter_rw(Geometry* geom) override;
- void filter_ro( const Geometry * geom) override;
+ void filter_ro(const Geometry* geom) override;
private:
- Coordinate::ConstVect &comps;
+ Coordinate::ConstVect& comps;
ComponentCoordinateExtracter(const ComponentCoordinateExtracter& other) = delete;
diff --git a/include/geos/geom/util/CoordinateOperation.h b/include/geos/geom/util/CoordinateOperation.h
index 8b87cf4..8f5701f 100644
--- a/include/geos/geom/util/CoordinateOperation.h
+++ b/include/geos/geom/util/CoordinateOperation.h
@@ -21,11 +21,11 @@
namespace geos {
- namespace geom {
- class Geometry;
- class CoordinateSequence;
- class GeometryFactory;
+namespace geom {
+class Geometry;
+class CoordinateSequence;
+class GeometryFactory;
@@ -42,25 +42,25 @@ class GEOS_DLL CoordinateOperation: public GeometryEditorOperation {
public:
- * Return a newly created geometry, ownership to caller
- Geometry* edit(const Geometry *geometry,
- const GeometryFactory *factory) override;
+ * Return a newly created geometry, ownership to caller
+ Geometry* edit(const Geometry* geometry,
+ const GeometryFactory* factory) override;
- * Edits the array of Coordinate from a Geometry.
- * @param coordinates the coordinate array to operate on
- * @param geometry the geometry containing the coordinate list
- * @return an edited coordinate array (which may be the same as
- * the input)
- virtual CoordinateSequence* edit(const CoordinateSequence* coordinates,
- const Geometry *geometry)=0;
+ * Edits the array of Coordinate from a Geometry.
+ * @param coordinates the coordinate array to operate on
+ * @param geometry the geometry containing the coordinate list
+ * @return an edited coordinate array (which may be the same as
+ * the input)
+ virtual CoordinateSequence* edit(const CoordinateSequence* coordinates,
+ const Geometry* geometry) = 0;
- ~CoordinateOperation() override {}
+ ~CoordinateOperation() override {}
diff --git a/include/geos/geom/util/Densifier.h b/include/geos/geom/util/Densifier.h
index d93cc3b..364b019 100644
--- a/include/geos/geom/util/Densifier.h
+++ b/include/geos/geom/util/Densifier.h
@@ -57,26 +57,27 @@ namespace util {
class GEOS_DLL Densifier {
public:
- Densifier(const Geometry *inputGeom);
+ Densifier(const Geometry* inputGeom);
- Geometry::Ptr densify(const Geometry *geom, double distanceTolerance);
- void setDistanceTolerance(double distanceTolerance);
- Geometry::Ptr getResultGeometry() const;
+ Geometry::Ptr densify(const Geometry* geom, double distanceTolerance);
+ void setDistanceTolerance(double distanceTolerance);
+ Geometry::Ptr getResultGeometry() const;
private:
- double distanceTolerance;
- const Geometry *inputGeom;
- static std::unique_ptr<Coordinate::Vect> densifyPoints(const Coordinate::Vect pts, double distanceTolerance, const PrecisionModel *precModel);
+ double distanceTolerance;
+ const Geometry* inputGeom;
+ static std::unique_ptr<Coordinate::Vect> densifyPoints(const Coordinate::Vect pts, double distanceTolerance,
+ const PrecisionModel* precModel);
- class GEOS_DLL DensifyTransformer: public GeometryTransformer {
- public:
- DensifyTransformer(double distanceTolerance);
- CoordinateSequence::Ptr transformCoordinates(const CoordinateSequence *coords, const Geometry *parent);
- Geometry::Ptr transformPolygon(const Polygon *geom, const Geometry *parent);
- Geometry::Ptr transformMultiPolygon(const MultiPolygon *geom, const Geometry *parent);
- Geometry *createValidArea(const Geometry *roughAreaGeom);
+ class GEOS_DLL DensifyTransformer: public GeometryTransformer {
+ public:
+ DensifyTransformer(double distanceTolerance);
+ CoordinateSequence::Ptr transformCoordinates(const CoordinateSequence* coords, const Geometry* parent);
+ Geometry::Ptr transformPolygon(const Polygon* geom, const Geometry* parent);
+ Geometry::Ptr transformMultiPolygon(const MultiPolygon* geom, const Geometry* parent);
+ Geometry* createValidArea(const Geometry* roughAreaGeom);
}; // Densifier
diff --git a/include/geos/geom/util/GeometryCombiner.h b/include/geos/geom/util/GeometryCombiner.h
index 1b5f4db..8fcf5be 100644
--- a/include/geos/geom/util/GeometryCombiner.h
+++ b/include/geos/geom/util/GeometryCombiner.h
@@ -23,10 +23,10 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
namespace geos {
@@ -44,8 +44,7 @@ namespace util { // geos.geom.util
* @see GeometryFactory#buildGeometry
-class GeometryCombiner
+class GeometryCombiner {
public:
* Combines a collection of geometries.
diff --git a/include/geos/geom/util/GeometryEditor.h b/include/geos/geom/util/GeometryEditor.h
index 6cf4c84..77cbaa8 100644
--- a/include/geos/geom/util/GeometryEditor.h
+++ b/include/geos/geom/util/GeometryEditor.h
@@ -25,15 +25,15 @@
namespace geos {
- namespace geom {
- class Geometry;
- class GeometryCollection;
- class Polygon;
- namespace util {
- class GeometryEditorOperation;
+namespace geom {
+class Geometry;
+class GeometryCollection;
+class Polygon;
+namespace util {
+class GeometryEditorOperation;
@@ -77,48 +77,48 @@ namespace util { // geos.geom.util
class GEOS_DLL GeometryEditor {
private:
- * The factory used to create the modified Geometry
- const GeometryFactory* factory;
+ * The factory used to create the modified Geometry
+ const GeometryFactory* factory;
- Polygon* editPolygon(const Polygon *polygon,
- GeometryEditorOperation *operation);
+ Polygon* editPolygon(const Polygon* polygon,
+ GeometryEditorOperation* operation);
- GeometryCollection* editGeometryCollection(
- const GeometryCollection *collection,
+ GeometryCollection* editGeometryCollection(
+ const GeometryCollection* collection,
public:
- * Creates a new GeometryEditor object which will create
- * an edited Geometry with the same GeometryFactory as the
- * input Geometry.
- GeometryEditor();
+ * Creates a new GeometryEditor object which will create
+ * an edited Geometry with the same GeometryFactory as the
+ * input Geometry.
+ GeometryEditor();
- * the edited Geometry with the given GeometryFactory
- * @param newFactory the GeometryFactory to create the edited
- * Geometry with
- GeometryEditor(const GeometryFactory *newFactory);
+ * the edited Geometry with the given GeometryFactory
+ * @param newFactory the GeometryFactory to create the edited
+ * Geometry with
+ GeometryEditor(const GeometryFactory* newFactory);
- * Edit the input Geometry with the given edit operation.
- * Clients will create subclasses of GeometryEditorOperation or
- * CoordinateOperation to perform required modifications.
- * @param geometry the Geometry to edit
- * @param operation the edit operation to carry out
- * @return a new Geometry which is the result of the editing
- GeometryEditorOperation *operation); // final
+ * Edit the input Geometry with the given edit operation.
+ * Clients will create subclasses of GeometryEditorOperation or
+ * CoordinateOperation to perform required modifications.
+ * @param geometry the Geometry to edit
+ * @param operation the edit operation to carry out
+ * @return a new Geometry which is the result of the editing
+ GeometryEditorOperation* operation); // final
} // namespace geos.geom.util
diff --git a/include/geos/geom/util/GeometryEditorOperation.h b/include/geos/geom/util/GeometryEditorOperation.h
index 58194e3..4824903 100644
--- a/include/geos/geom/util/GeometryEditorOperation.h
+++ b/include/geos/geom/util/GeometryEditorOperation.h
@@ -20,10 +20,10 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
@@ -38,22 +38,23 @@ namespace util { // geos.geom.util
class GEOS_DLL GeometryEditorOperation {
public:
- * Edits a Geometry by returning a new Geometry with a modification.
- * The returned Geometry might be the same as the Geometry passed in.
- * @param geometry the Geometry to modify
- * @param factory the factory with which to construct the modified
- * Geometry (may be different to the factory of the
- * input geometry)
- * @return a new Geometry which is a modification of the input Geometry
- virtual Geometry* edit(const Geometry *geometry,
- const GeometryFactory *factory)=0;
- virtual ~GeometryEditorOperation() {}
+ * Edits a Geometry by returning a new Geometry with a modification.
+ * The returned Geometry might be the same as the Geometry passed in.
+ * @param geometry the Geometry to modify
+ * @param factory the factory with which to construct the modified
+ * Geometry (may be different to the factory of the
+ * input geometry)
+ * @return a new Geometry which is a modification of the input Geometry
+ virtual Geometry* edit(const Geometry* geometry,
+ const GeometryFactory* factory) = 0;
+ virtual
+ ~GeometryEditorOperation() {}
diff --git a/include/geos/geom/util/GeometryExtracter.h b/include/geos/geom/util/GeometryExtracter.h
index 89073c6..3a3c0f0 100644
--- a/include/geos/geom/util/GeometryExtracter.h
+++ b/include/geos/geom/util/GeometryExtracter.h
@@ -37,57 +37,57 @@ class GEOS_DLL GeometryExtracter {
public:
- * Extracts the components of type <tt>clz</tt> from a {@link Geometry}
- * and adds them to the provided container.
- * @param geom the geometry from which to extract
- * @param list the list to add the extracted elements to
- template <class ComponentType, class TargetContainer>
- static void extract(const Geometry& geom, TargetContainer& lst)
- if ( const ComponentType* p_c = dynamic_cast<const ComponentType*>(&geom) )
- lst.push_back(p_c);
- else if ( const GeometryCollection* p_c1 =
- dynamic_cast<const GeometryCollection*>(&geom) )
+ * Extracts the components of type <tt>clz</tt> from a {@link Geometry}
+ * and adds them to the provided container.
+ * @param geom the geometry from which to extract
+ * @param list the list to add the extracted elements to
+ template <class ComponentType, class TargetContainer>
+ static void
+ extract(const Geometry& geom, TargetContainer& lst)
- GeometryExtracter::Extracter<ComponentType, TargetContainer> extracter(lst);
- p_c1->apply_ro(&extracter);
+ if(const ComponentType* p_c = dynamic_cast<const ComponentType*>(&geom)) {
+ lst.push_back(p_c);
+ else if(const GeometryCollection* p_c1 =
+ dynamic_cast<const GeometryCollection*>(&geom)) {
+ GeometryExtracter::Extracter<ComponentType, TargetContainer> extracter(lst);
+ p_c1->apply_ro(&extracter);
private:
- struct Extracter: public GeometryFilter {
+ struct Extracter: public GeometryFilter {
- * Constructs a filter with a list in which to store the elements found.
- * @param comps the container to extract into (will push_back to it)
- Extracter(TargetContainer& comps) : comps_(comps) {}
+ * Constructs a filter with a list in which to store the elements found.
+ * @param comps the container to extract into (will push_back to it)
+ Extracter(TargetContainer& comps) : comps_(comps) {}
- TargetContainer& comps_;
+ TargetContainer& comps_;
- void filter_ro(const Geometry* geom) override
- if ( const ComponentType* c = dynamic_cast<const ComponentType*>(geom) ) {
- comps_.push_back(c);
+ void
+ filter_ro(const Geometry* geom) override
+ if(const ComponentType* c = dynamic_cast<const ComponentType*>(geom)) {
+ comps_.push_back(c);
- // Declare type as noncopyable
- Extracter(const Extracter& other);
- Extracter& operator=(const Extracter& rhs);
+ // Declare type as noncopyable
+ Extracter(const Extracter& other);
+ Extracter& operator=(const Extracter& rhs);
- GeometryExtracter(const GeometryExtracter& other) = delete;
- GeometryExtracter& operator=(const GeometryExtracter& rhs) = delete;
+ GeometryExtracter(const GeometryExtracter& other) = delete;
+ GeometryExtracter& operator=(const GeometryExtracter& rhs) = delete;
diff --git a/include/geos/geom/util/GeometryTransformer.h b/include/geos/geom/util/GeometryTransformer.h
index c26ac56..b596a08 100644
--- a/include/geos/geom/util/GeometryTransformer.h
+++ b/include/geos/geom/util/GeometryTransformer.h
@@ -31,21 +31,21 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Point;
- class LinearRing;
- class LineString;
- class Polygon;
- class MultiPoint;
- class MultiPolygon;
- class MultiLineString;
- namespace util {
- //class GeometryEditorOperation;
+namespace geom {
+class Geometry;
+class Point;
+class LinearRing;
+class LineString;
+class Polygon;
+class MultiPoint;
+class MultiPolygon;
+class MultiLineString;
+namespace util {
+//class GeometryEditorOperation;
@@ -93,101 +93,101 @@ class GEOS_DLL GeometryTransformer {
public:
- GeometryTransformer();
+ GeometryTransformer();
- virtual ~GeometryTransformer();
+ virtual ~GeometryTransformer();
- std::unique_ptr<Geometry> transform(const Geometry* nInputGeom);
+ std::unique_ptr<Geometry> transform(const Geometry* nInputGeom);
- void setSkipTransformedInvalidInteriorRings(bool b);
+ void setSkipTransformedInvalidInteriorRings(bool b);
protected:
- * Convenience method which provides standard way of
- * creating a {@link CoordinateSequence}
- * @param coords the coordinate array to copy
- * @return a coordinate sequence for the array
- * [final]
- CoordinateSequence::Ptr createCoordinateSequence(
- std::unique_ptr< std::vector<Coordinate> > coords);
+ * Convenience method which provides standard way of
+ * creating a {@link CoordinateSequence}
+ * @param coords the coordinate array to copy
+ * @return a coordinate sequence for the array
+ * [final]
+ CoordinateSequence::Ptr createCoordinateSequence(
+ std::unique_ptr< std::vector<Coordinate> > coords);
- virtual CoordinateSequence::Ptr transformCoordinates(
- const CoordinateSequence* coords,
- const Geometry* parent);
+ virtual CoordinateSequence::Ptr transformCoordinates(
+ const CoordinateSequence* coords,
+ const Geometry* parent);
- virtual Geometry::Ptr transformPoint(
- const Point* geom,
+ virtual Geometry::Ptr transformPoint(
+ const Point* geom,
- virtual Geometry::Ptr transformMultiPoint(
- const MultiPoint* geom,
+ virtual Geometry::Ptr transformMultiPoint(
+ const MultiPoint* geom,
- virtual Geometry::Ptr transformLinearRing(
- const LinearRing* geom,
+ virtual Geometry::Ptr transformLinearRing(
+ const LinearRing* geom,
- virtual Geometry::Ptr transformLineString(
- const LineString* geom,
+ virtual Geometry::Ptr transformLineString(
+ const LineString* geom,
- virtual Geometry::Ptr transformMultiLineString(
- const MultiLineString* geom,
+ virtual Geometry::Ptr transformMultiLineString(
+ const MultiLineString* geom,
- virtual Geometry::Ptr transformPolygon(
- const Polygon* geom,
+ virtual Geometry::Ptr transformPolygon(
+ const Polygon* geom,
- virtual Geometry::Ptr transformMultiPolygon(
- const MultiPolygon* geom,
+ virtual Geometry::Ptr transformMultiPolygon(
+ const MultiPolygon* geom,
- virtual Geometry::Ptr transformGeometryCollection(
- const GeometryCollection* geom,
+ virtual Geometry::Ptr transformGeometryCollection(
+ const GeometryCollection* geom,
private:
- const Geometry* inputGeom;
- // these could eventually be exposed to clients
- * <code>true</code> if empty geometries should not be included in the result
- bool pruneEmptyGeometry;
- * <code>true</code> if a homogenous collection result
- * from a {@link GeometryCollection} should still
- * be a general GeometryCollection
- bool preserveGeometryCollectionType;
- * <code>true</code> if the output from a collection argument should still be a collection
- // bool preserveCollections;
- * <code>true</code> if the type of the input should be preserved
- bool preserveType;
- * <code>true</code> if transformed invalid interior rings should be skipped
- bool skipTransformedInvalidInteriorRings;
- GeometryTransformer(const GeometryTransformer& other) = delete;
- GeometryTransformer& operator=(const GeometryTransformer& rhs) = delete;
+ // these could eventually be exposed to clients
+ * <code>true</code> if empty geometries should not be included in the result
+ bool pruneEmptyGeometry;
+ * <code>true</code> if a homogenous collection result
+ * from a {@link GeometryCollection} should still
+ * be a general GeometryCollection
+ bool preserveGeometryCollectionType;
+ * <code>true</code> if the output from a collection argument should still be a collection
+ // bool preserveCollections;
+ * <code>true</code> if the type of the input should be preserved
+ bool preserveType;
+ * <code>true</code> if transformed invalid interior rings should be skipped
+ bool skipTransformedInvalidInteriorRings;
+ GeometryTransformer(const GeometryTransformer& other) = delete;
+ GeometryTransformer& operator=(const GeometryTransformer& rhs) = delete;
diff --git a/include/geos/geom/util/LinearComponentExtracter.h b/include/geos/geom/util/LinearComponentExtracter.h
index 1c0756f..48a5398 100644
--- a/include/geos/geom/util/LinearComponentExtracter.h
+++ b/include/geos/geom/util/LinearComponentExtracter.h
@@ -35,30 +35,30 @@ class GEOS_DLL LinearComponentExtracter: public GeometryComponentFilter {
private:
- LineString::ConstVect &comps;
+ LineString::ConstVect& comps;
LinearComponentExtracter(const LinearComponentExtracter& other) = delete;
LinearComponentExtracter& operator=(const LinearComponentExtracter& rhs) = delete;
public:
- * efficient to create a single LinearComponentExtracterFilter instance
- static void getLines(const Geometry &geom, std::vector<const LineString*> &ret);
- * Constructs a LinearComponentExtracterFilter with a list in which
- * to store LineStrings found.
- LinearComponentExtracter(std::vector<const LineString*> &newComps);
+ * efficient to create a single LinearComponentExtracterFilter instance
+ static void getLines(const Geometry& geom, std::vector<const LineString*>& ret);
+ * Constructs a LinearComponentExtracterFilter with a list in which
+ * to store LineStrings found.
+ LinearComponentExtracter(std::vector<const LineString*>& newComps);
- void filter_rw(Geometry *geom) override;
- void filter_ro(const Geometry *geom) override;
diff --git a/include/geos/geom/util/PointExtracter.h b/include/geos/geom/util/PointExtracter.h
index df4c3d6..bc3b46d 100644
--- a/include/geos/geom/util/PointExtracter.h
+++ b/include/geos/geom/util/PointExtracter.h
@@ -31,27 +31,27 @@ namespace util { // geos.geom.util
class GEOS_DLL PointExtracter: public GeometryFilter {
public:
- * Returns the Point components from a single geometry.
- * efficient to create a single PointExtracter filter instance
- static void getPoints(const Geometry &geom, Point::ConstVect &ret);
+ * Returns the Point components from a single geometry.
+ * efficient to create a single PointExtracter filter instance
+ static void getPoints(const Geometry& geom, Point::ConstVect& ret);
- * Constructs a PointExtracterFilter with a list in which
- * to store Points found.
- PointExtracter(Point::ConstVect& newComps);
+ * Constructs a PointExtracterFilter with a list in which
+ * to store Points found.
+ PointExtracter(Point::ConstVect& newComps);
private:
- Point::ConstVect& comps;
+ Point::ConstVect& comps;
PointExtracter(const PointExtracter& other) = delete;
diff --git a/include/geos/geom/util/PolygonExtracter.h b/include/geos/geom/util/PolygonExtracter.h
index 176aa2c..1467d2c 100644
--- a/include/geos/geom/util/PolygonExtracter.h
+++ b/include/geos/geom/util/PolygonExtracter.h
@@ -32,24 +32,24 @@ class GEOS_DLL PolygonExtracter: public GeometryFilter {
public:
- * Pushes the Polygon components from a single geometry into
- * efficient to create a single PolygonExtracterFilter instance
- static void getPolygons(const Geometry &geom, std::vector<const Polygon*>& ret);
+ * Pushes the Polygon components from a single geometry into
+ * efficient to create a single PolygonExtracterFilter instance
+ static void getPolygons(const Geometry& geom, std::vector<const Polygon*>& ret);
- * Constructs a PolygonExtracterFilter with a list in which
- * to store Polygons found.
- PolygonExtracter(std::vector<const Polygon*>& newComps);
+ * Constructs a PolygonExtracterFilter with a list in which
+ * to store Polygons found.
+ PolygonExtracter(std::vector<const Polygon*>& newComps);
private:
diff --git a/include/geos/geom/util/ShortCircuitedGeometryVisitor.h b/include/geos/geom/util/ShortCircuitedGeometryVisitor.h
index 90cd5cc..7e0ef9f 100644
--- a/include/geos/geom/util/ShortCircuitedGeometryVisitor.h
+++ b/include/geos/geom/util/ShortCircuitedGeometryVisitor.h
@@ -20,9 +20,9 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
@@ -36,28 +36,28 @@ namespace util { // geos.geom.util
* Last port: geom/util/ShortCircuitedGeometryVisitor.java rev. 1.1 (JTS-1.7)
-class GEOS_DLL ShortCircuitedGeometryVisitor
+class GEOS_DLL ShortCircuitedGeometryVisitor {
private:
- bool done;
+ bool done;
protected:
- virtual void visit(const Geometry &element)=0;
- virtual bool isDone()=0;
+ virtual void visit(const Geometry& element) = 0;
+ virtual bool isDone() = 0;
public:
- ShortCircuitedGeometryVisitor()
- done(false)
+ ShortCircuitedGeometryVisitor()
+ done(false)
- void applyTo(const Geometry &geom);
+ void applyTo(const Geometry& geom);
- virtual ~ShortCircuitedGeometryVisitor() {}
+ virtual
+ ~ShortCircuitedGeometryVisitor() {}
diff --git a/include/geos/geom/util/SineStarFactory.h b/include/geos/geom/util/SineStarFactory.h
index 03c1b8c..e5768b9 100644
--- a/include/geos/geom/util/SineStarFactory.h
+++ b/include/geos/geom/util/SineStarFactory.h
@@ -32,14 +32,14 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Envelope;
- class Polygon;
- class PrecisionModel;
- class LineString;
+namespace geom {
+class Coordinate;
+class Envelope;
+class Polygon;
+class PrecisionModel;
+class LineString;
namespace geos {
@@ -59,54 +59,56 @@ class GEOS_DLL SineStarFactory : public geos::util::GeometricShapeFactory {
protected:
- int numArms;
- double armLengthRatio;
+ int numArms;
+ double armLengthRatio;
public:
- * Creates a factory which will create sine stars using the given
- * {@link GeometryFactory}.
- * @param fact the factory to use. You need to keep the
- * factory alive for the whole SineStarFactory
- * life time.
- SineStarFactory(const geom::GeometryFactory* fact)
- geos::util::GeometricShapeFactory(fact),
- numArms(8),
- armLengthRatio(0.5)
- * Sets the number of arms in the star
- * @param nArms the number of arms to generate
- void setNumArms(int nArms)
- numArms = nArms;
- * Sets the ration of the length of each arm to the distance from the tip
- * of the arm to the centre of the star.
- * Value should be between 0.0 and 1.0
- * @param armLenRatio
- void setArmLengthRatio(double armLenRatio)
+ * Creates a factory which will create sine stars using the given
+ * {@link GeometryFactory}.
+ * @param fact the factory to use. You need to keep the
+ * factory alive for the whole SineStarFactory
+ * life time.
+ SineStarFactory(const geom::GeometryFactory* fact)
+ geos::util::GeometricShapeFactory(fact),
+ numArms(8),
+ armLengthRatio(0.5)
+ * Sets the number of arms in the star
+ * @param nArms the number of arms to generate
+ void
+ setNumArms(int nArms)
+ numArms = nArms;
+ * Sets the ration of the length of each arm to the distance from the tip
+ * of the arm to the centre of the star.
+ * Value should be between 0.0 and 1.0
+ * @param armLenRatio
+ void
+ setArmLengthRatio(double armLenRatio)
armLengthRatio = armLenRatio;
- * Generates the geometry for the sine star
- * @return the geometry representing the sine star
- std::unique_ptr<Polygon> createSineStar() const;
+ * Generates the geometry for the sine star
+ * @return the geometry representing the sine star
+ std::unique_ptr<Polygon> createSineStar() const;
diff --git a/include/geos/geomgraph/Depth.h b/include/geos/geomgraph/Depth.h
index 66a5743..cb247f9 100644
--- a/include/geos/geomgraph/Depth.h
+++ b/include/geos/geomgraph/Depth.h
@@ -28,9 +28,9 @@
namespace geos {
- namespace geomgraph {
- class Label;
+namespace geomgraph {
+class Label;
namespace geos {
@@ -38,25 +38,25 @@ namespace geomgraph { // geos.geomgraph
class GEOS_DLL Depth {
public:
- static int depthAtLocation(int location);
- Depth();
- virtual ~Depth(); // FIXME: shoudn't be virtual!
- int getDepth(int geomIndex,int posIndex) const;
- void setDepth(int geomIndex,int posIndex,int depthValue);
- int getLocation(int geomIndex,int posIndex) const;
- void add(int geomIndex,int posIndex,int location);
- bool isNull() const;
- bool isNull(int geomIndex) const;
- bool isNull(int geomIndex, int posIndex) const;
- int getDelta(int geomIndex) const;
- void normalize();
- void add(const Label& lbl);
- std::string toString() const;
+ static int depthAtLocation(int location);
+ Depth();
+ virtual ~Depth(); // FIXME: shoudn't be virtual!
+ int getDepth(int geomIndex, int posIndex) const;
+ void setDepth(int geomIndex, int posIndex, int depthValue);
+ int getLocation(int geomIndex, int posIndex) const;
+ void add(int geomIndex, int posIndex, int location);
+ bool isNull() const;
+ bool isNull(int geomIndex) const;
+ bool isNull(int geomIndex, int posIndex) const;
+ int getDelta(int geomIndex) const;
+ void normalize();
+ void add(const Label& lbl);
+ std::string toString() const;
private:
- enum {
- NULL_VALUE=-1 //Replaces NULL
- int depth[2][3];
+ enum {
+ NULL_VALUE = -1 //Replaces NULL
+ int depth[2][3];
} // namespace geos.geomgraph
diff --git a/include/geos/geomgraph/DirectedEdge.h b/include/geos/geomgraph/DirectedEdge.h
index ee992d5..74cf390 100644
--- a/include/geos/geomgraph/DirectedEdge.h
+++ b/include/geos/geomgraph/DirectedEdge.h
@@ -31,10 +31,10 @@
namespace geos {
- class Edge;
- class EdgeRing;
+class Edge;
+class EdgeRing;
namespace geos {
@@ -45,140 +45,140 @@ class GEOS_DLL DirectedEdge: public EdgeEnd {
public:
- /** \brief
- * Computes the factor for the change in depth when moving from
- * one location to another.
- * E.g. if crossing from the INTERIOR to the EXTERIOR the depth
- * decreases, so the factor is -1
- static int depthFactor(int currLocation, int nextLocation);
+ /** \brief
+ * Computes the factor for the change in depth when moving from
+ * one location to another.
+ * E.g. if crossing from the INTERIOR to the EXTERIOR the depth
+ * decreases, so the factor is -1
+ static int depthFactor(int currLocation, int nextLocation);
- //DirectedEdge();
- //virtual ~DirectedEdge();
+ //DirectedEdge();
+ //virtual ~DirectedEdge();
- DirectedEdge(Edge *newEdge, bool newIsForward);
+ DirectedEdge(Edge* newEdge, bool newIsForward);
- // this is no different from Base class, no need to override
- //Edge* getEdge();
+ // this is no different from Base class, no need to override
+ //Edge* getEdge();
- void setInResult(bool newIsInResult);
+ void setInResult(bool newIsInResult);
- bool isInResult();
+ bool isInResult();
- bool isVisited();
+ bool isVisited();
- void setVisited(bool newIsVisited);
+ void setVisited(bool newIsVisited);
- void setEdgeRing(EdgeRing *newEdgeRing);
+ void setEdgeRing(EdgeRing* newEdgeRing);
- EdgeRing* getEdgeRing();
+ EdgeRing* getEdgeRing();
- void setMinEdgeRing(EdgeRing *newMinEdgeRing);
+ void setMinEdgeRing(EdgeRing* newMinEdgeRing);
- EdgeRing* getMinEdgeRing();
+ EdgeRing* getMinEdgeRing();
- int getDepth(int position);
+ int getDepth(int position);
- void setDepth(int position, int newDepth);
+ void setDepth(int position, int newDepth);
- int getDepthDelta() const;
+ int getDepthDelta() const;
- /// Marks both DirectedEdges attached to a given Edge.
- /// This is used for edges corresponding to lines, which will only
- /// appear oriented in a single direction in the result.
- void setVisitedEdge(bool newIsVisited);
+ /// Marks both DirectedEdges attached to a given Edge.
+ /// This is used for edges corresponding to lines, which will only
+ /// appear oriented in a single direction in the result.
+ void setVisitedEdge(bool newIsVisited);
- /** \brief
- * Each Edge gives rise to a pair of symmetric DirectedEdges,
- * in opposite directions.
- * @return the DirectedEdge for the same Edge but in the
- * opposite direction
- DirectedEdge* getSym();
+ /** \brief
+ * Each Edge gives rise to a pair of symmetric DirectedEdges,
+ * in opposite directions.
+ * @return the DirectedEdge for the same Edge but in the
+ * opposite direction
+ DirectedEdge* getSym();
- bool isForward();
+ bool isForward();
- void setSym(DirectedEdge *de);
+ void setSym(DirectedEdge* de);
- DirectedEdge* getNext();
+ DirectedEdge* getNext();
- void setNext(DirectedEdge *newNext);
+ void setNext(DirectedEdge* newNext);
- DirectedEdge* getNextMin();
+ DirectedEdge* getNextMin();
- void setNextMin(DirectedEdge *newNextMin);
+ void setNextMin(DirectedEdge* newNextMin);
- /** \brief
- * Tells wheter this edge is a Line
- * This edge is a line edge if
- * - at least one of the labels is a line label
- * - any labels which are not line labels have all Locations = EXTERIOR
- bool isLineEdge();
+ /** \brief
+ * Tells wheter this edge is a Line
+ * This edge is a line edge if
+ * - at least one of the labels is a line label
+ * - any labels which are not line labels have all Locations = EXTERIOR
+ bool isLineEdge();
- /** \brief
- * Tells wheter this edge is an Area
- * This is an interior Area edge if
- * - its label is an Area label for both Geometries
- * - and for each Geometry both sides are in the interior.
- * @return true if this is an interior Area edge
- bool isInteriorAreaEdge();
+ /** \brief
+ * Tells wheter this edge is an Area
+ * This is an interior Area edge if
+ * - its label is an Area label for both Geometries
+ * - and for each Geometry both sides are in the interior.
+ * @return true if this is an interior Area edge
+ bool isInteriorAreaEdge();
- /** \brief
- * Set both edge depths.
- * One depth for a given side is provided.
- * The other is computed depending on the Location transition and the
- * depthDelta of the edge.
- void setEdgeDepths(int position, int newDepth);
+ /** \brief
+ * Set both edge depths.
+ * One depth for a given side is provided.
+ * The other is computed depending on the Location transition and the
+ * depthDelta of the edge.
+ void setEdgeDepths(int position, int newDepth);
- std::string print() const override;
+ std::string print() const override;
- std::string printEdge();
+ std::string printEdge();
protected:
- bool isForwardVar;
+ bool isForwardVar;
private:
- bool isInResultVar;
+ bool isInResultVar;
- bool isVisitedVar;
+ bool isVisitedVar;
- /// the symmetric edge
- DirectedEdge *sym;
+ /// the symmetric edge
+ DirectedEdge* sym;
- /// the next edge in the edge ring for the polygon containing this edge
- DirectedEdge *next;
+ /// the next edge in the edge ring for the polygon containing this edge
+ DirectedEdge* next;
- /// the next edge in the MinimalEdgeRing that contains this edge
- DirectedEdge *nextMin;
+ /// the next edge in the MinimalEdgeRing that contains this edge
+ DirectedEdge* nextMin;
- /// the EdgeRing that this edge is part of
- EdgeRing *edgeRing;
+ /// the EdgeRing that this edge is part of
+ EdgeRing* edgeRing;
- /// the MinimalEdgeRing that this edge is part of
- EdgeRing *minEdgeRing;
+ /// the MinimalEdgeRing that this edge is part of
+ EdgeRing* minEdgeRing;
- /** \brief
- * The depth of each side (position) of this edge.
- * The 0 element of the array is never used.
- int depth[3];
+ /** \brief
+ * The depth of each side (position) of this edge.
+ * The 0 element of the array is never used.
+ int depth[3];
- /// Compute the label in the appropriate orientation for this DirEdge
- void computeDirectedLabel();
+ /// Compute the label in the appropriate orientation for this DirEdge
+ void computeDirectedLabel();
diff --git a/include/geos/geomgraph/DirectedEdge.inl b/include/geos/geomgraph/DirectedEdge.inl
index 3bb06b4..8ccdbd2 100644
--- a/include/geos/geomgraph/DirectedEdge.inl
+++ b/include/geos/geomgraph/DirectedEdge.inl
@@ -9,7 +9,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -30,52 +30,100 @@ namespace geomgraph { // geos::geomgraph
//DirectedEdge::getEdge() { return edge; }
INLINE void
-DirectedEdge::setInResult(bool v) { isInResultVar=v; }
+DirectedEdge::setInResult(bool v)
+ isInResultVar = v;
INLINE bool
-DirectedEdge::isInResult() { return isInResultVar; }
+DirectedEdge::isInResult()
+ return isInResultVar;
INLINE bool
-DirectedEdge::isVisited() { return isVisitedVar; }
+DirectedEdge::isVisited()
+ return isVisitedVar;
INLINE void
-DirectedEdge::setVisited(bool v) { isVisitedVar=v; }
+DirectedEdge::setVisited(bool v)
+ isVisitedVar = v;
INLINE void
-DirectedEdge::setEdgeRing(EdgeRing *er) { edgeRing=er; }
+DirectedEdge::setEdgeRing(EdgeRing* er)
+ edgeRing = er;
INLINE EdgeRing*
-DirectedEdge::getEdgeRing() { return edgeRing; }
+DirectedEdge::getEdgeRing()
+ return edgeRing;
INLINE void
-DirectedEdge::setMinEdgeRing(EdgeRing *mer) { minEdgeRing=mer; }
+DirectedEdge::setMinEdgeRing(EdgeRing* mer)
+ minEdgeRing = mer;
INLINE EdgeRing*
-DirectedEdge::getMinEdgeRing() { return minEdgeRing; }
+DirectedEdge::getMinEdgeRing()
+ return minEdgeRing;
INLINE int
-DirectedEdge::getDepth(int position){ return depth[position]; }
+DirectedEdge::getDepth(int position)
+ return depth[position];
INLINE DirectedEdge*
-DirectedEdge::getSym() { return sym; }
+DirectedEdge::getSym()
+ return sym;
INLINE bool
-DirectedEdge::isForward() { return isForwardVar; }
+DirectedEdge::isForward()
+ return isForwardVar;
INLINE void
-DirectedEdge::setSym(DirectedEdge *de) { sym=de; }
+DirectedEdge::setSym(DirectedEdge* de)
+ sym = de;
-DirectedEdge::getNext() { return next; }
+DirectedEdge::getNext()
+ return next;
INLINE void
-DirectedEdge::setNext(DirectedEdge *newNext) { next=newNext; }
+DirectedEdge::setNext(DirectedEdge* newNext)
+ next = newNext;
-DirectedEdge::getNextMin() { return nextMin; }
+DirectedEdge::getNextMin()
+ return nextMin;
INLINE void
-DirectedEdge::setNextMin(DirectedEdge *nm) { nextMin=nm; }
+DirectedEdge::setNextMin(DirectedEdge* nm)
+ nextMin = nm;
} // namespace geos::geomgraph
diff --git a/include/geos/geomgraph/DirectedEdgeStar.h b/include/geos/geomgraph/DirectedEdgeStar.h
index 6af6bcb..fe1acec 100644
--- a/include/geos/geomgraph/DirectedEdgeStar.h
+++ b/include/geos/geomgraph/DirectedEdgeStar.h
@@ -35,10 +35,10 @@
// Forward declarations
namespace geos {
- class DirectedEdge;
- class EdgeRing;
+class DirectedEdge;
+class EdgeRing;
namespace geos {
@@ -56,106 +56,111 @@ class GEOS_DLL DirectedEdgeStar: public EdgeEndStar {
public:
- DirectedEdgeStar()
- EdgeEndStar(),
- resultAreaEdgeList(nullptr),
- label()
- ~DirectedEdgeStar() override {
- delete resultAreaEdgeList;
- /// Insert a directed edge in the list
- void insert(EdgeEnd *ee) override;
- Label &getLabel() { return label; }
- int getOutgoingDegree();
- int getOutgoingDegree(EdgeRing *er);
- DirectedEdge* getRightmostEdge();
- /** \brief
- * Compute the labelling for all dirEdges in this star, as well
- * as the overall labelling
- void computeLabelling(std::vector<GeometryGraph*> *geom) override; // throw(TopologyException *);
- /** \brief
- * For each dirEdge in the star,
- * merge the label from the sym dirEdge into the label
- void mergeSymLabels();
- /// Update incomplete dirEdge labels from the labelling for the node
- void updateLabelling(const Label& nodeLabel);
- * Traverse the star of DirectedEdges, linking the included edges together.
- * To link two dirEdges, the <next> pointer for an incoming dirEdge
- * is set to the next outgoing edge.
- * DirEdges are only linked if:
- * - they belong to an area (i.e. they have sides)
- * - they are marked as being in the result
- * Edges are linked in CCW order (the order they are stored).
- * This means that rings have their face on the Right
- * (in other words,
- * the topological location of the face is given by the RHS label of the DirectedEdge)
- * PRECONDITION: No pair of dirEdges are both marked as being in the result
- void linkResultDirectedEdges(); // throw(TopologyException *);
- void linkMinimalDirectedEdges(EdgeRing *er);
- void linkAllDirectedEdges();
- /** \brief
- * Traverse the star of edges, maintaing the current location in the result
- * area at this node (if any).
- * If any L edges are found in the interior of the result, mark them as covered.
- void findCoveredLineEdges();
- /** \brief
- * Compute the DirectedEdge depths for a subsequence of the edge array.
- * @return the last depth assigned (from the R side of the last edge visited)
- void computeDepths(DirectedEdge *de);
+ DirectedEdgeStar()
+ EdgeEndStar(),
+ resultAreaEdgeList(nullptr),
+ label()
+ ~DirectedEdgeStar() override
+ delete resultAreaEdgeList;
+ /// Insert a directed edge in the list
+ void insert(EdgeEnd* ee) override;
+ Label&
+ getLabel()
+ return label;
+ int getOutgoingDegree();
+ int getOutgoingDegree(EdgeRing* er);
+ DirectedEdge* getRightmostEdge();
+ /** \brief
+ * Compute the labelling for all dirEdges in this star, as well
+ * as the overall labelling
+ void computeLabelling(std::vector<GeometryGraph*>* geom) override; // throw(TopologyException *);
+ /** \brief
+ * For each dirEdge in the star,
+ * merge the label from the sym dirEdge into the label
+ void mergeSymLabels();
+ /// Update incomplete dirEdge labels from the labelling for the node
+ void updateLabelling(const Label& nodeLabel);
+ * Traverse the star of DirectedEdges, linking the included edges together.
+ * To link two dirEdges, the <next> pointer for an incoming dirEdge
+ * is set to the next outgoing edge.
+ * DirEdges are only linked if:
+ * - they belong to an area (i.e. they have sides)
+ * - they are marked as being in the result
+ * Edges are linked in CCW order (the order they are stored).
+ * This means that rings have their face on the Right
+ * (in other words,
+ * the topological location of the face is given by the RHS label of the DirectedEdge)
+ * PRECONDITION: No pair of dirEdges are both marked as being in the result
+ void linkResultDirectedEdges(); // throw(TopologyException *);
+ void linkMinimalDirectedEdges(EdgeRing* er);
+ void linkAllDirectedEdges();
+ /** \brief
+ * Traverse the star of edges, maintaing the current location in the result
+ * area at this node (if any).
+ * If any L edges are found in the interior of the result, mark them as covered.
+ void findCoveredLineEdges();
+ /** \brief
+ * Compute the DirectedEdge depths for a subsequence of the edge array.
+ * @return the last depth assigned (from the R side of the last edge visited)
+ void computeDepths(DirectedEdge* de);
private:
- * A list of all outgoing edges in the result, in CCW order
- std::vector<DirectedEdge*> *resultAreaEdgeList;
+ * A list of all outgoing edges in the result, in CCW order
+ std::vector<DirectedEdge*>* resultAreaEdgeList;
- Label label;
+ Label label;
- /// \brief
- /// Returned vector is onwed by DirectedEdgeStar object, but
- /// lazily created
- std::vector<DirectedEdge*>* getResultAreaEdges();
+ /// \brief
+ /// Returned vector is onwed by DirectedEdgeStar object, but
+ /// lazily created
+ std::vector<DirectedEdge*>* getResultAreaEdges();
- /// States for linResultDirectedEdges
- enum {
- SCANNING_FOR_INCOMING=1,
- LINKING_TO_OUTGOING
+ /// States for linResultDirectedEdges
+ enum {
+ SCANNING_FOR_INCOMING = 1,
+ LINKING_TO_OUTGOING
- int computeDepths(EdgeEndStar::iterator startIt,
- EdgeEndStar::iterator endIt, int startDepth);
+ int computeDepths(EdgeEndStar::iterator startIt,
+ EdgeEndStar::iterator endIt, int startDepth);
diff --git a/include/geos/geomgraph/Edge.h b/include/geos/geomgraph/Edge.h
index 6067c7e..e91a9ba 100644
--- a/include/geos/geomgraph/Edge.h
+++ b/include/geos/geomgraph/Edge.h
@@ -40,211 +40,245 @@
namespace geos {
- namespace geom {
- class Envelope;
- class IntersectionMatrix;
- class Coordinate;
- class LineIntersector;
- class Node;
- class EdgeEndStar;
- class Label;
- class NodeFactory;
- namespace index {
- class MonotoneChainEdge;
+namespace geom {
+class Envelope;
+class IntersectionMatrix;
+class Coordinate;
+class LineIntersector;
+class Node;
+class EdgeEndStar;
+class Label;
+class NodeFactory;
+namespace index {
+class MonotoneChainEdge;
namespace geos {
/** The edge component of a geometry graph */
-class GEOS_DLL Edge: public GraphComponent{
-using GraphComponent::updateIM;
+class GEOS_DLL Edge: public GraphComponent {
+ using GraphComponent::updateIM;
private:
- std::string name;
+ std::string name;
- /// Lazily-created, owned by Edge.
- index::MonotoneChainEdge *mce;
+ /// Lazily-created, owned by Edge.
+ index::MonotoneChainEdge* mce;
- geom::Envelope *env;
+ geom::Envelope* env;
- bool isIsolatedVar;
+ bool isIsolatedVar;
- Depth depth;
+ Depth depth;
- int depthDelta; // the change in area depth from the R to L side of this edge
+ int depthDelta; // the change in area depth from the R to L side of this edge
public:
- void testInvariant() const {
- assert(pts);
- assert(pts->size() > 1);
- friend std::ostream& operator<< (std::ostream& os, const Edge& el);
- static void updateIM(const Label& lbl, geom::IntersectionMatrix& im);
- /// Externally-set, owned by Edge. FIXME: refuse ownership
- geom::CoordinateSequence* pts;
- EdgeIntersectionList eiList;
- //Edge();
- /// Takes ownership of CoordinateSequence
- Edge(geom::CoordinateSequence* newPts, const Label& newLabel);
- Edge(geom::CoordinateSequence* newPts);
- ~Edge() override;
- virtual size_t getNumPoints() const {
- return pts->getSize();
- virtual void setName(const std::string &newName) {
- name=newName;
- virtual const geom::CoordinateSequence* getCoordinates() const {
- testInvariant();
- return pts;
- virtual const geom::Coordinate& getCoordinate(size_t i) const {
- testInvariant();
- return pts->getAt(i);
- virtual const geom::Coordinate& getCoordinate() const {
- testInvariant();
- return pts->getAt(0);
- virtual Depth &getDepth() {
- testInvariant();
- return depth;
- /** \brief
- * The depthDelta is the change in depth as an edge is crossed from R to L
- * @return the change in depth as the edge is crossed from R to L
- virtual int getDepthDelta() const {
- testInvariant();
- return depthDelta;
- virtual void setDepthDelta(int newDepthDelta) {
- depthDelta=newDepthDelta;
- testInvariant();
- virtual size_t getMaximumSegmentIndex() const {
- testInvariant();
- return getNumPoints()-1;
- virtual EdgeIntersectionList& getEdgeIntersectionList() {
- testInvariant();
- return eiList;
- /// \brief
- /// Return this Edge's index::MonotoneChainEdge,
- /// ownership is retained by this object.
- virtual index::MonotoneChainEdge* getMonotoneChainEdge();
- virtual bool isClosed() const {
- testInvariant();
- return pts->getAt(0)==pts->getAt(getNumPoints()-1);
- /** \brief
- * An Edge is collapsed if it is an Area edge and it consists of
- * two segments which are equal and opposite (eg a zero-width V).
- virtual bool isCollapsed() const;
- virtual Edge* getCollapsedEdge();
- virtual void setIsolated(bool newIsIsolated) {
- isIsolatedVar=newIsIsolated;
- testInvariant();
- bool isIsolated() const override {
- testInvariant();
- return isIsolatedVar;
- /** \brief
- * Adds EdgeIntersections for one or both
- * intersections found for a segment of an edge to the edge intersection list.
- virtual void addIntersections(algorithm::LineIntersector *li, size_t segmentIndex,
- size_t geomIndex);
- /// Add an EdgeIntersection for intersection intIndex.
- /// An intersection that falls exactly on a vertex of the edge is normalized
- /// to use the higher of the two possible segmentIndexes
- virtual void addIntersection(algorithm::LineIntersector *li, size_t segmentIndex,
- size_t geomIndex, size_t intIndex);
- /// Update the IM with the contribution for this component.
- /// A component only contributes if it has a labelling for both
- /// parent geometries
- void computeIM(geom::IntersectionMatrix& im) override {
- updateIM(label, im);
- testInvariant();
- /// return true if the coordinate sequences of the Edges are identical
- virtual bool isPointwiseEqual(const Edge *e) const;
- virtual std::string print() const;
- virtual std::string printReverse() const;
- * equals is defined to be:
- * e1 equals e2
- * <b>iff</b>
- * the coordinates of e1 are the same or the reverse of the coordinates in e2
- virtual bool equals(const Edge& e) const;
- virtual bool equals(const Edge* e) const {
- assert(e);
- return equals(*e);
- virtual geom::Envelope* getEnvelope();
+ void
+ testInvariant() const
+ assert(pts);
+ assert(pts->size() > 1);
+ friend std::ostream& operator<< (std::ostream& os, const Edge& el);
+ static void updateIM(const Label& lbl, geom::IntersectionMatrix& im);
+ /// Externally-set, owned by Edge. FIXME: refuse ownership
+ geom::CoordinateSequence* pts;
+ EdgeIntersectionList eiList;
+ //Edge();
+ /// Takes ownership of CoordinateSequence
+ Edge(geom::CoordinateSequence* newPts, const Label& newLabel);
+ Edge(geom::CoordinateSequence* newPts);
+ ~Edge() override;
+ virtual size_t
+ getNumPoints() const
+ return pts->getSize();
+ virtual void
+ setName(const std::string& newName)
+ name = newName;
+ virtual const geom::CoordinateSequence*
+ getCoordinates() const
+ testInvariant();
+ return pts;
+ virtual const geom::Coordinate&
+ getCoordinate(size_t i) const
+ testInvariant();
+ return pts->getAt(i);
+ getCoordinate() const
+ testInvariant();
+ return pts->getAt(0);
+ virtual Depth&
+ getDepth()
+ testInvariant();
+ return depth;
+ /** \brief
+ * The depthDelta is the change in depth as an edge is crossed from R to L
+ * @return the change in depth as the edge is crossed from R to L
+ virtual int
+ getDepthDelta() const
+ testInvariant();
+ return depthDelta;
+ virtual void
+ setDepthDelta(int newDepthDelta)
+ depthDelta = newDepthDelta;
+ testInvariant();
+ virtual size_t
+ getMaximumSegmentIndex() const
+ testInvariant();
+ return getNumPoints() - 1;
+ virtual EdgeIntersectionList&
+ getEdgeIntersectionList()
+ testInvariant();
+ return eiList;
+ /// \brief
+ /// Return this Edge's index::MonotoneChainEdge,
+ /// ownership is retained by this object.
+ virtual index::MonotoneChainEdge* getMonotoneChainEdge();
+ virtual bool
+ isClosed() const
+ testInvariant();
+ return pts->getAt(0) == pts->getAt(getNumPoints() - 1);
+ /** \brief
+ * An Edge is collapsed if it is an Area edge and it consists of
+ * two segments which are equal and opposite (eg a zero-width V).
+ virtual bool isCollapsed() const;
+ virtual Edge* getCollapsedEdge();
+ virtual void
+ setIsolated(bool newIsIsolated)
+ isIsolatedVar = newIsIsolated;
+ testInvariant();
+ bool
+ isIsolated() const override
+ testInvariant();
+ return isIsolatedVar;
+ /** \brief
+ * Adds EdgeIntersections for one or both
+ * intersections found for a segment of an edge to the edge intersection list.
+ virtual void addIntersections(algorithm::LineIntersector* li, size_t segmentIndex,
+ size_t geomIndex);
+ /// Add an EdgeIntersection for intersection intIndex.
+ /// An intersection that falls exactly on a vertex of the edge is normalized
+ /// to use the higher of the two possible segmentIndexes
+ virtual void addIntersection(algorithm::LineIntersector* li, size_t segmentIndex,
+ size_t geomIndex, size_t intIndex);
+ /// Update the IM with the contribution for this component.
+ /// A component only contributes if it has a labelling for both
+ /// parent geometries
+ void
+ computeIM(geom::IntersectionMatrix& im) override
+ updateIM(label, im);
+ testInvariant();
+ /// return true if the coordinate sequences of the Edges are identical
+ virtual bool isPointwiseEqual(const Edge* e) const;
+ virtual std::string print() const;
+ virtual std::string printReverse() const;
+ * equals is defined to be:
+ * e1 equals e2
+ * <b>iff</b>
+ * the coordinates of e1 are the same or the reverse of the coordinates in e2
+ virtual bool equals(const Edge& e) const;
+ virtual bool
+ equals(const Edge* e) const
+ assert(e);
+ return equals(*e);
+ virtual geom::Envelope* getEnvelope();
//Operators
-inline bool operator==(const Edge &a, const Edge &b) {
- return a.equals(b);
+inline bool
+operator==(const Edge& a, const Edge& b)
+ return a.equals(b);
diff --git a/include/geos/geomgraph/EdgeEnd.h b/include/geos/geomgraph/EdgeEnd.h
index 30344a2..af6e196 100644
--- a/include/geos/geomgraph/EdgeEnd.h
+++ b/include/geos/geomgraph/EdgeEnd.h
@@ -31,13 +31,13 @@
namespace geos {
- namespace algorithm {
- class BoundaryNodeRule;
- class Edge;
- class Node;
+namespace algorithm {
+class BoundaryNodeRule;
+class Edge;
+class Node;
namespace geos {
@@ -57,110 +57,129 @@ class GEOS_DLL EdgeEnd {
public:
- friend std::ostream& operator<< (std::ostream&, const EdgeEnd&);
- EdgeEnd();
- virtual ~EdgeEnd() {}
- * NOTES:
- * - Copies the given Label
- * - keeps a pointer to given Edge, make sure it's
- * not deleted before the EdgeEnd.
- * - copies given Coordinates (maybe we should avoid that)
- EdgeEnd(Edge* newEdge, const geom::Coordinate& newP0,
- const geom::Coordinate& newP1,
- const Label& newLabel);
- * NOTES:
- const geom::Coordinate& newP1);
- Edge* getEdge() { return edge; }
- //virtual Edge* getEdge() { return edge; }
- Label& getLabel() { return label; }
- const Label& getLabel() const { return label; }
- virtual geom::Coordinate& getCoordinate();
- const geom::Coordinate& getCoordinate() const { return p0; }
- virtual geom::Coordinate& getDirectedCoordinate();
- virtual int getQuadrant();
- virtual double getDx();
- virtual double getDy();
- virtual void setNode(Node* newNode);
- virtual Node* getNode();
- virtual int compareTo(const EdgeEnd *e) const;
- * Implements the total order relation:
- * a has a greater angle with the positive x-axis than b
- * Using the obvious algorithm of simply computing the angle
- * is not robust, since the angle calculation is obviously
- * susceptible to roundoff.
- * A robust algorithm is:
- * - first compare the quadrant. If the quadrants
- * are different, it it trivial to determine which vector
- * is "greater".
- * - if the vectors lie in the same quadrant, the
- * computeOrientation function can be used to decide
- * the relative orientation of the vectors.
- virtual int compareDirection(const EdgeEnd *e) const;
- virtual void computeLabel(const algorithm::BoundaryNodeRule& bnr);
+ friend std::ostream& operator<< (std::ostream&, const EdgeEnd&);
+ EdgeEnd();
+ virtual
+ ~EdgeEnd() {}
+ * NOTES:
+ * - Copies the given Label
+ * - keeps a pointer to given Edge, make sure it's
+ * not deleted before the EdgeEnd.
+ * - copies given Coordinates (maybe we should avoid that)
+ EdgeEnd(Edge* newEdge, const geom::Coordinate& newP0,
+ const geom::Coordinate& newP1,
+ const Label& newLabel);
+ * NOTES:
+ const geom::Coordinate& newP1);
+ Edge*
+ getEdge()
+ return edge;
+ //virtual Edge* getEdge() { return edge; }
+ Label&
+ getLabel()
+ return label;
+ const Label&
+ getLabel() const
+ return label;
+ virtual geom::Coordinate& getCoordinate();
+ return p0;
+ virtual geom::Coordinate& getDirectedCoordinate();
+ virtual int getQuadrant();
+ virtual double getDx();
+ virtual double getDy();
+ virtual void setNode(Node* newNode);
+ virtual Node* getNode();
+ virtual int compareTo(const EdgeEnd* e) const;
+ * Implements the total order relation:
+ * a has a greater angle with the positive x-axis than b
+ * Using the obvious algorithm of simply computing the angle
+ * is not robust, since the angle calculation is obviously
+ * susceptible to roundoff.
+ * A robust algorithm is:
+ * - first compare the quadrant. If the quadrants
+ * are different, it it trivial to determine which vector
+ * is "greater".
+ * - if the vectors lie in the same quadrant, the
+ * computeOrientation function can be used to decide
+ * the relative orientation of the vectors.
+ virtual int compareDirection(const EdgeEnd* e) const;
+ virtual void computeLabel(const algorithm::BoundaryNodeRule& bnr);
protected:
- Edge* edge;// the parent edge of this edge end
+ Edge* edge;// the parent edge of this edge end
- Label label;
+ Label label;
- EdgeEnd(Edge* newEdge);
+ EdgeEnd(Edge* newEdge);
- virtual void init(const geom::Coordinate& newP0,
+ virtual void init(const geom::Coordinate& newP0,
private:
- /// the node this edge end originates at
- Node* node;
+ /// the node this edge end originates at
+ Node* node;
- /// points of initial line segment. FIXME: do we need a copy here ?
- geom::Coordinate p0, p1;
+ /// points of initial line segment. FIXME: do we need a copy here ?
+ geom::Coordinate p0, p1;
- /// the direction vector for this edge from its starting point
- double dx, dy;
+ /// the direction vector for this edge from its starting point
+ double dx, dy;
- int quadrant;
+ int quadrant;
struct GEOS_DLL EdgeEndLT {
- bool operator()(const EdgeEnd *s1, const EdgeEnd *s2) const {
- return s1->compareTo(s2)<0;
+ bool
+ operator()(const EdgeEnd* s1, const EdgeEnd* s2) const
+ return s1->compareTo(s2) < 0;
diff --git a/include/geos/geomgraph/EdgeEndStar.h b/include/geos/geomgraph/EdgeEndStar.h
index 1763efc..e376fe6 100644
--- a/include/geos/geomgraph/EdgeEndStar.h
+++ b/include/geos/geomgraph/EdgeEndStar.h
@@ -40,12 +40,12 @@
namespace geos {
- class GeometryGraph;
+class GeometryGraph;
namespace geos {
@@ -63,134 +63,147 @@ namespace geomgraph { // geos.geomgraph
class GEOS_DLL EdgeEndStar {
public:
- typedef std::set<EdgeEnd *, EdgeEndLT> container;
+ typedef std::set<EdgeEnd*, EdgeEndLT> container;
- typedef container::iterator iterator;
- typedef container::const_iterator const_iterator;
- typedef container::reverse_iterator reverse_iterator;
+ typedef container::iterator iterator;
+ typedef container::const_iterator const_iterator;
+ typedef container::reverse_iterator reverse_iterator;
- EdgeEndStar();
+ EdgeEndStar();
- virtual ~EdgeEndStar() {}
+ virtual
+ ~EdgeEndStar() {}
- /** \brief
- * Insert a EdgeEnd into this EdgeEndStar
- virtual void insert(EdgeEnd *e)=0;
+ /** \brief
+ * Insert a EdgeEnd into this EdgeEndStar
+ virtual void insert(EdgeEnd* e) = 0;
- /** \brief
- * @return the coordinate for the node this star is based at
- * or NULL if this is still an unbound star.
- * Be aware that the returned pointer will point to
- * a Coordinate owned by the specific EdgeEnd happening
- * to be the first in the star (ordered CCW)
+ /** \brief
+ * @return the coordinate for the node this star is based at
+ * or NULL if this is still an unbound star.
+ * Be aware that the returned pointer will point to
+ * a Coordinate owned by the specific EdgeEnd happening
+ * to be the first in the star (ordered CCW)
- const geom::Coordinate& getCoordinate() const;
+ const geom::Coordinate& getCoordinate() const;
- virtual std::size_t getDegree();
+ virtual std::size_t getDegree();
- virtual iterator begin();
+ virtual iterator begin();
- virtual iterator end();
+ virtual iterator end();
- virtual reverse_iterator rbegin();
+ virtual reverse_iterator rbegin();
- virtual reverse_iterator rend();
+ virtual reverse_iterator rend();
- virtual const_iterator begin() const { return edgeMap.begin(); }
+ virtual const_iterator
+ begin() const
+ return edgeMap.begin();
- virtual const_iterator end() const { return edgeMap.end(); }
+ end() const
+ return edgeMap.end();
- virtual container &getEdges();
+ virtual container& getEdges();
- virtual EdgeEnd* getNextCW(EdgeEnd *ee);
+ virtual EdgeEnd* getNextCW(EdgeEnd* ee);
- virtual void computeLabelling(std::vector<GeometryGraph*> *geomGraph);
- // throw(TopologyException *);
+ virtual void computeLabelling(std::vector<GeometryGraph*>* geomGraph);
+ // throw(TopologyException *);
- virtual bool isAreaLabelsConsistent(const GeometryGraph& geomGraph);
+ virtual bool isAreaLabelsConsistent(const GeometryGraph& geomGraph);
- virtual void propagateSideLabels(int geomIndex);
+ virtual void propagateSideLabels(int geomIndex);
- //virtual int findIndex(EdgeEnd *eSearch);
- virtual iterator find(EdgeEnd *eSearch);
+ //virtual int findIndex(EdgeEnd *eSearch);
+ virtual iterator find(EdgeEnd* eSearch);
protected:
- /** \brief
- * A map which maintains the edges in sorted order
- * around the node
- EdgeEndStar::container edgeMap;
- /** \brief
- * Insert an EdgeEnd into the map.
- virtual void insertEdgeEnd(EdgeEnd *e) { edgeMap.insert(e); }
+ /** \brief
+ * A map which maintains the edges in sorted order
+ * around the node
+ EdgeEndStar::container edgeMap;
+ /** \brief
+ * Insert an EdgeEnd into the map.
+ virtual void
+ insertEdgeEnd(EdgeEnd* e)
+ edgeMap.insert(e);
private:
- virtual int getLocation(int geomIndex,
- const geom::Coordinate& p,
- std::vector<GeometryGraph*> *geom);
+ virtual int getLocation(int geomIndex,
+ const geom::Coordinate& p,
+ std::vector<GeometryGraph*>* geom);
- /** \brief
- * The location of the point for this star in
- * Geometry i Areas
- int ptInAreaLocation[2];
+ /** \brief
+ * The location of the point for this star in
+ * Geometry i Areas
+ int ptInAreaLocation[2];
- virtual void computeEdgeEndLabels(const algorithm::BoundaryNodeRule&);
+ virtual void computeEdgeEndLabels(const algorithm::BoundaryNodeRule&);
- virtual bool checkAreaLabelsConsistent(int geomIndex);
+ virtual bool checkAreaLabelsConsistent(int geomIndex);
inline std::size_t
EdgeEndStar::getDegree()
- return edgeMap.size();
+ return edgeMap.size();
inline EdgeEndStar::iterator
EdgeEndStar::begin()
- return edgeMap.begin();
inline EdgeEndStar::container&
EdgeEndStar::getEdges()
- return edgeMap;
+ return edgeMap;
inline EdgeEndStar::reverse_iterator
EdgeEndStar::rend()
- return edgeMap.rend();
+ return edgeMap.rend();
EdgeEndStar::end()
- return edgeMap.end();
EdgeEndStar::rbegin()
- return edgeMap.rbegin();
+ return edgeMap.rbegin();
-EdgeEndStar::find(EdgeEnd *eSearch)
+EdgeEndStar::find(EdgeEnd* eSearch)
- return edgeMap.find(eSearch);
+ return edgeMap.find(eSearch);
std::ostream& operator<< (std::ostream&, const EdgeEndStar&);
diff --git a/include/geos/geomgraph/EdgeIntersection.h b/include/geos/geomgraph/EdgeIntersection.h
index cc522f1..61aa498 100644
--- a/include/geos/geomgraph/EdgeIntersection.h
+++ b/include/geos/geomgraph/EdgeIntersection.h
@@ -45,70 +45,92 @@ namespace geomgraph { // geos.geomgraph
class GEOS_DLL EdgeIntersection {
public:
- // the point of intersection
- geom::Coordinate coord;
+ // the point of intersection
+ geom::Coordinate coord;
- // the edge distance of this point along the containing line segment
- double dist;
+ // the edge distance of this point along the containing line segment
+ double dist;
- // the index of the containing line segment in the parent edge
- size_t segmentIndex;
+ // the index of the containing line segment in the parent edge
+ size_t segmentIndex;
- EdgeIntersection(const geom::Coordinate& newCoord,
- size_t newSegmentIndex, double newDist)
- coord(newCoord),
- dist(newDist),
- segmentIndex(newSegmentIndex)
+ EdgeIntersection(const geom::Coordinate& newCoord,
+ size_t newSegmentIndex, double newDist)
+ coord(newCoord),
+ dist(newDist),
+ segmentIndex(newSegmentIndex)
- bool isEndPoint(size_t maxSegmentIndex) const {
- if (segmentIndex==0 && dist==0.0) return true;
- if (segmentIndex==maxSegmentIndex) return true;
- return false;
+ bool
+ isEndPoint(size_t maxSegmentIndex) const
+ if(segmentIndex == 0 && dist == 0.0) {
+ return true;
+ if(segmentIndex == maxSegmentIndex) {
+ return true;
+ return false;
- return coord;
+ return coord;
- size_t getSegmentIndex() const { return segmentIndex; }
+ size_t
+ getSegmentIndex() const
+ return segmentIndex;
- double getDistance() const { return dist; }
+ double
+ getDistance() const
+ return dist;
/// Strict weak ordering operator for EdgeIntersection
/// This is the C++ equivalent of JTS's compareTo
-inline bool operator< (const EdgeIntersection& ei1, const EdgeIntersection& ei2)
+inline bool
+operator< (const EdgeIntersection& ei1, const EdgeIntersection& ei2)
- if ( ei1.segmentIndex < ei2.segmentIndex ) return true;
- if ( ei1.segmentIndex == ei2.segmentIndex )
- if ( ei1.dist < ei2.dist ) return true;
- // TODO: check if the Coordinate matches, or this will
- // be a robustness issue in computin distance
- // See http://trac.osgeo.org/geos/ticket/350
+ if(ei1.segmentIndex < ei2.segmentIndex) {
+ return true;
- return false;
+ if(ei1.segmentIndex == ei2.segmentIndex) {
+ if(ei1.dist < ei2.dist) {
+ return true;
+ // TODO: check if the Coordinate matches, or this will
+ // be a robustness issue in computin distance
+ // See http://trac.osgeo.org/geos/ticket/350
+ return false;
// @deprecated, use strict weak ordering operator
struct GEOS_DLL EdgeIntersectionLessThen {
- bool operator()(const EdgeIntersection *ei1,
- const EdgeIntersection *ei2) const
- return *ei1 < *ei2;
+ bool
+ operator()(const EdgeIntersection* ei1,
+ const EdgeIntersection* ei2) const
+ return *ei1 < *ei2;
/// Output operator
-inline std::ostream& operator<< (std::ostream& os, const EdgeIntersection& e)
+inline std::ostream&
+operator<< (std::ostream& os, const EdgeIntersection& e)
- os << e.coord << " seg # = " << e.segmentIndex << " dist = " << e.dist;
- return os;
+ os << e.coord << " seg # = " << e.segmentIndex << " dist = " << e.dist;
+ return os;
diff --git a/include/geos/geomgraph/EdgeIntersectionList.h b/include/geos/geomgraph/EdgeIntersectionList.h
index 212f8ad..37a8c83 100644
--- a/include/geos/geomgraph/EdgeIntersectionList.h
+++ b/include/geos/geomgraph/EdgeIntersectionList.h
@@ -39,12 +39,12 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Edge;
+namespace geom {
+class Coordinate;
+class Edge;
namespace geos {
@@ -56,54 +56,70 @@ namespace geomgraph { // geos.geomgraph
* Implements splitting an edge with intersections
* into multiple resultant edges.
-class GEOS_DLL EdgeIntersectionList{
+class GEOS_DLL EdgeIntersectionList {
public:
- typedef std::set<EdgeIntersection *, EdgeIntersectionLessThen> container;
+ typedef std::set<EdgeIntersection*, EdgeIntersectionLessThen> container;
private:
- container nodeMap;
+ container nodeMap;
public:
- Edge *edge;
- EdgeIntersectionList(Edge *edge);
- ~EdgeIntersectionList();
- * Adds an intersection into the list, if it isn't already there.
- * The input segmentIndex and dist are expected to be normalized.
- * @return the EdgeIntersection found or added
- EdgeIntersection* add(const geom::Coordinate& coord,
- size_t segmentIndex, double dist);
- iterator begin() { return nodeMap.begin(); }
- iterator end() { return nodeMap.end(); }
- const_iterator begin() const { return nodeMap.begin(); }
- const_iterator end() const { return nodeMap.end(); }
- bool isEmpty() const;
- bool isIntersection(const geom::Coordinate& pt) const;
- * Adds entries for the first and last points of the edge to the list
- void addEndpoints();
- * Creates new edges for all the edges that the intersections in this
- * list split the parent edge into.
- * Adds the edges to the input list (this is so a single list
- * can be used to accumulate all split edges for a Geometry).
- * @param edgeList a list of EdgeIntersections
- void addSplitEdges(std::vector<Edge*> *edgeList);
- Edge *createSplitEdge(EdgeIntersection *ei0, EdgeIntersection *ei1);
- std::string print() const;
+ Edge* edge;
+ EdgeIntersectionList(Edge* edge);
+ ~EdgeIntersectionList();
+ * Adds an intersection into the list, if it isn't already there.
+ * The input segmentIndex and dist are expected to be normalized.
+ * @return the EdgeIntersection found or added
+ EdgeIntersection* add(const geom::Coordinate& coord,
+ size_t segmentIndex, double dist);
+ iterator
+ begin()
+ return nodeMap.begin();
+ iterator
+ end()
+ return nodeMap.end();
+ const_iterator
+ begin() const
+ const_iterator
+ end() const
+ bool isEmpty() const;
+ bool isIntersection(const geom::Coordinate& pt) const;
+ * Adds entries for the first and last points of the edge to the list
+ void addEndpoints();
+ * Creates new edges for all the edges that the intersections in this
+ * list split the parent edge into.
+ * Adds the edges to the input list (this is so a single list
+ * can be used to accumulate all split edges for a Geometry).
+ * @param edgeList a list of EdgeIntersections
+ void addSplitEdges(std::vector<Edge*>* edgeList);
+ Edge* createSplitEdge(EdgeIntersection* ei0, EdgeIntersection* ei1);
+ std::string print() const;
diff --git a/include/geos/geomgraph/EdgeList.h b/include/geos/geomgraph/EdgeList.h
index 526773a..8b4ca0e 100644
--- a/include/geos/geomgraph/EdgeList.h
+++ b/include/geos/geomgraph/EdgeList.h
@@ -38,12 +38,12 @@
namespace geos {
- namespace index {
- class SpatialIndex;
- class Edge;
+namespace index {
+class SpatialIndex;
+class Edge;
namespace geos {
@@ -59,57 +59,62 @@ class GEOS_DLL EdgeList {
private:
- std::vector<Edge*> edges;
- struct OcaCmp {
- bool operator()(
- const noding::OrientedCoordinateArray *oca1,
- const noding::OrientedCoordinateArray *oca2) const
- return *oca1 < *oca2;
- * An index of the edges, for fast lookup.
- * OrientedCoordinateArray objects are owned by us.
- * TODO: optimize by dropping the OrientedCoordinateArray
- * construction as a whole, and use CoordinateSequence
- * directly instead..
- typedef std::map<noding::OrientedCoordinateArray*, Edge*, OcaCmp> EdgeMap;
- EdgeMap ocaMap;
+ std::vector<Edge*> edges;
+ struct OcaCmp {
+ bool
+ operator()(
+ const noding::OrientedCoordinateArray* oca1,
+ const noding::OrientedCoordinateArray* oca2) const
+ return *oca1 < *oca2;
+ * An index of the edges, for fast lookup.
+ * OrientedCoordinateArray objects are owned by us.
+ * TODO: optimize by dropping the OrientedCoordinateArray
+ * construction as a whole, and use CoordinateSequence
+ * directly instead..
+ typedef std::map<noding::OrientedCoordinateArray*, Edge*, OcaCmp> EdgeMap;
+ EdgeMap ocaMap;
public:
- friend std::ostream& operator<< (std::ostream& os, const EdgeList& el);
+ friend std::ostream& operator<< (std::ostream& os, const EdgeList& el);
- EdgeList()
- edges(),
- ocaMap()
+ EdgeList()
+ edges(),
+ ocaMap()
- virtual ~EdgeList();
+ virtual ~EdgeList();
- * Insert an edge unless it is already in the list
- void add(Edge *e);
+ * Insert an edge unless it is already in the list
+ void add(Edge* e);
- void addAll(const std::vector<Edge*> &edgeColl);
+ void addAll(const std::vector<Edge*>& edgeColl);
- std::vector<Edge*> &getEdges() { return edges; }
+ std::vector<Edge*>&
+ getEdges()
+ return edges;
- Edge* findEqualEdge(Edge* e);
+ Edge* findEqualEdge(Edge* e);
- Edge* get(int i);
+ Edge* get(int i);
- int findEdgeIndex(Edge *e);
+ int findEdgeIndex(Edge* e);
- std::string print();
+ std::string print();
- void clearList();
+ void clearList();
diff --git a/include/geos/geomgraph/EdgeNodingValidator.h b/include/geos/geomgraph/EdgeNodingValidator.h
index a8fa391..a8f0118 100644
--- a/include/geos/geomgraph/EdgeNodingValidator.h
+++ b/include/geos/geomgraph/EdgeNodingValidator.h
@@ -35,15 +35,15 @@
namespace geos {
- namespace geom {
- class CoordinateSequence;
- namespace noding {
- class SegmentString;
- class Edge;
+namespace geom {
+class CoordinateSequence;
+namespace noding {
+class SegmentString;
+class Edge;
namespace geos {
@@ -57,51 +57,56 @@ namespace geomgraph { // geos.geomgraph
class GEOS_DLL EdgeNodingValidator {
private:
- std::vector<noding::SegmentString*>& toSegmentStrings(std::vector<Edge*>& edges);
+ std::vector<noding::SegmentString*>& toSegmentStrings(std::vector<Edge*>& edges);
- // Make sure this member is initialized *before*
- // the NodingValidator, as initialization of
- // NodingValidator will use toSegmentString(), that
- // in turn expects this member to be initialized
- std::vector<noding::SegmentString*> segStr;
+ // Make sure this member is initialized *before*
+ // the NodingValidator, as initialization of
+ // NodingValidator will use toSegmentString(), that
+ // in turn expects this member to be initialized
+ std::vector<noding::SegmentString*> segStr;
- std::vector<geom::CoordinateSequence*> newCoordSeq;
+ std::vector<geom::CoordinateSequence*> newCoordSeq;
- noding::FastNodingValidator nv;
+ noding::FastNodingValidator nv;
public:
- /** \brief
- * Checks whether the supplied {@link Edge}s
- * are correctly noded.
- * Throws a {@link TopologyException} if they are not.
- * @param edges a collection of Edges.
- * @throws TopologyException if the SegmentStrings are not
- * correctly noded
- static void checkValid(std::vector<Edge*>& edges)
- EdgeNodingValidator validator(edges);
- validator.checkValid();
- EdgeNodingValidator(std::vector<Edge*>& edges)
- segStr(),
- newCoordSeq(),
- nv(toSegmentStrings(edges))
- ~EdgeNodingValidator();
- void checkValid() { nv.checkValid(); }
+ /** \brief
+ * Checks whether the supplied {@link Edge}s
+ * are correctly noded.
+ * Throws a {@link TopologyException} if they are not.
+ * @param edges a collection of Edges.
+ * @throws TopologyException if the SegmentStrings are not
+ * correctly noded
+ static void
+ checkValid(std::vector<Edge*>& edges)
+ EdgeNodingValidator validator(edges);
+ validator.checkValid();
+ EdgeNodingValidator(std::vector<Edge*>& edges)
+ segStr(),
+ newCoordSeq(),
+ nv(toSegmentStrings(edges))
+ ~EdgeNodingValidator();
+ void
+ checkValid()
+ nv.checkValid();
diff --git a/include/geos/geomgraph/EdgeRing.h b/include/geos/geomgraph/EdgeRing.h
index 97b803a..b6a8bb0 100644
--- a/include/geos/geomgraph/EdgeRing.h
+++ b/include/geos/geomgraph/EdgeRing.h
@@ -38,18 +38,18 @@
namespace geos {
- namespace geom {
- class GeometryFactory;
- class LinearRing;
- class Polygon;
- class Coordinate;
- //class Label;
- class Edge;
+namespace geom {
+class GeometryFactory;
+class LinearRing;
+class Polygon;
+class Coordinate;
+//class Label;
+class Edge;
namespace geos {
@@ -59,142 +59,141 @@ namespace geomgraph { // geos.geomgraph
class GEOS_DLL EdgeRing {
public:
- friend std::ostream& operator<< (std::ostream& os, const EdgeRing& er);
+ friend std::ostream& operator<< (std::ostream& os, const EdgeRing& er);
- EdgeRing(DirectedEdge *newStart,
- const geom::GeometryFactory *newGeometryFactory);
+ EdgeRing(DirectedEdge* newStart,
+ const geom::GeometryFactory* newGeometryFactory);
- virtual ~EdgeRing();
+ virtual ~EdgeRing();
- bool isIsolated();
+ bool isIsolated();
- bool isHole();
+ bool isHole();
- * Return a pointer to the LinearRing owned by
- * this object. Make a copy if you need it beyond
- * this objects's lifetime.
- geom::LinearRing* getLinearRing();
+ * Return a pointer to the LinearRing owned by
+ * this object. Make a copy if you need it beyond
+ * this objects's lifetime.
+ geom::LinearRing* getLinearRing();
- Label& getLabel();
+ Label& getLabel();
- bool isShell();
+ bool isShell();
- EdgeRing *getShell();
+ EdgeRing* getShell();
- void setShell(EdgeRing *newShell);
+ void setShell(EdgeRing* newShell);
- void addHole(EdgeRing *edgeRing);
+ void addHole(EdgeRing* edgeRing);
- * Return a Polygon copying coordinates from this
- * EdgeRing and its holes. Caller must remember
- * to delete the result
- geom::Polygon* toPolygon(const geom::GeometryFactory* geometryFactory);
+ * Return a Polygon copying coordinates from this
+ * EdgeRing and its holes. Caller must remember
+ * to delete the result
+ geom::Polygon* toPolygon(const geom::GeometryFactory* geometryFactory);
- * Compute a LinearRing from the point list previously collected.
- * Test if the ring is a hole (i.e. if it is CCW) and set the hole
- * flag accordingly.
- void computeRing();
+ * Compute a LinearRing from the point list previously collected.
+ * Test if the ring is a hole (i.e. if it is CCW) and set the hole
+ * flag accordingly.
+ void computeRing();
- virtual DirectedEdge* getNext(DirectedEdge *de)=0;
+ virtual DirectedEdge* getNext(DirectedEdge* de) = 0;
- virtual void setEdgeRing(DirectedEdge *de, EdgeRing *er)=0;
+ virtual void setEdgeRing(DirectedEdge* de, EdgeRing* er) = 0;
- * Returns the list of DirectedEdges that make up this EdgeRing
- std::vector<DirectedEdge*>& getEdges();
+ * Returns the list of DirectedEdges that make up this EdgeRing
+ std::vector<DirectedEdge*>& getEdges();
- int getMaxNodeDegree();
+ int getMaxNodeDegree();
- void setInResult();
+ void setInResult();
- * This method will use the computed ring.
- * It will also check any holes, if they have been assigned.
- bool containsPoint(const geom::Coordinate& p);
+ * This method will use the computed ring.
+ * It will also check any holes, if they have been assigned.
+ bool containsPoint(const geom::Coordinate& p);
- // pts are never NULL
- assert(pts);
+ void
+ testInvariant()
+ // pts are never NULL
+ assert(pts);
#ifndef NDEBUG
- // If this is not an hole, check that
- // each hole is not null and
- // has 'this' as it's shell
- if ( ! shell )
- for (std::vector<EdgeRing*>::const_iterator
- it=holes.begin(), itEnd=holes.end();
- it != itEnd;
- ++it)
- EdgeRing* hole=*it;
- assert(hole);
- assert(hole->getShell()==this);
+ // If this is not an hole, check that
+ // each hole is not null and
+ // has 'this' as it's shell
+ if(! shell) {
+ for(std::vector<EdgeRing*>::const_iterator
+ it = holes.begin(), itEnd = holes.end();
+ it != itEnd;
+ ++it) {
+ EdgeRing* hole = *it;
+ assert(hole);
+ assert(hole->getShell() == this);
#endif // ndef NDEBUG
protected:
- DirectedEdge *startDe; // the directed edge which starts the list of edges for this EdgeRing
+ DirectedEdge* startDe; // the directed edge which starts the list of edges for this EdgeRing
- const geom::GeometryFactory *geometryFactory;
+ const geom::GeometryFactory* geometryFactory;
- /// throw(const TopologyException &)
- void computePoints(DirectedEdge *newStart);
+ /// throw(const TopologyException &)
+ void computePoints(DirectedEdge* newStart);
- void mergeLabel(const Label& deLabel);
+ void mergeLabel(const Label& deLabel);
- /** \brief
- * Merge the RHS label from a DirectedEdge into the label for
- * this EdgeRing.
- * The DirectedEdge label may be null.
- * This is acceptable - it results from a node which is NOT
- * an intersection node between the Geometries
- * (e.g. the end node of a LinearRing).
- * In this case the DirectedEdge label does not contribute any
- * information to the overall labelling, and is
- * simply skipped.
- void mergeLabel(const Label& deLabel, int geomIndex);
+ /** \brief
+ * Merge the RHS label from a DirectedEdge into the label for
+ * this EdgeRing.
+ * The DirectedEdge label may be null.
+ * This is acceptable - it results from a node which is NOT
+ * an intersection node between the Geometries
+ * (e.g. the end node of a LinearRing).
+ * In this case the DirectedEdge label does not contribute any
+ * information to the overall labelling, and is
+ * simply skipped.
+ void mergeLabel(const Label& deLabel, int geomIndex);
- void addPoints(Edge *edge, bool isForward, bool isFirstEdge);
+ void addPoints(Edge* edge, bool isForward, bool isFirstEdge);
- /// a list of EdgeRings which are holes in this EdgeRing
- std::vector<EdgeRing*> holes;
+ /// a list of EdgeRings which are holes in this EdgeRing
+ std::vector<EdgeRing*> holes;
private:
- int maxNodeDegree;
+ int maxNodeDegree;
- /// the DirectedEdges making up this EdgeRing
- std::vector<DirectedEdge*> edges;
+ /// the DirectedEdges making up this EdgeRing
+ std::vector<DirectedEdge*> edges;
- // label stores the locations of each geometry on the
- // face surrounded by this ring
- Label label;
+ // label stores the locations of each geometry on the
+ // face surrounded by this ring
+ Label label;
- geom::LinearRing *ring; // the ring created for this EdgeRing
+ geom::LinearRing* ring; // the ring created for this EdgeRing
- bool isHoleVar;
+ bool isHoleVar;
- /// if non-null, the ring is a hole and this EdgeRing is its containing shell
- EdgeRing *shell;
+ /// if non-null, the ring is a hole and this EdgeRing is its containing shell
+ EdgeRing* shell;
- void computeMaxNodeDegree();
+ void computeMaxNodeDegree();
diff --git a/include/geos/geomgraph/GeometryGraph.h b/include/geos/geomgraph/GeometryGraph.h
index d91931b..311b827 100644
--- a/include/geos/geomgraph/GeometryGraph.h
+++ b/include/geos/geomgraph/GeometryGraph.h
@@ -41,27 +41,27 @@
namespace geos {
- namespace geom {
- class LineString;
- class LinearRing;
- class Polygon;
- class Geometry;
- class GeometryCollection;
- class Point;
- class Envelope;
- class Edge;
- class Node;
- namespace index {
- class SegmentIntersector;
- class EdgeSetIntersector;
+namespace geom {
+class LineString;
+class LinearRing;
+class Polygon;
+class Geometry;
+class GeometryCollection;
+class Point;
+class Envelope;
+class Edge;
+class Node;
+namespace index {
+class SegmentIntersector;
+class EdgeSetIntersector;
namespace geos {
@@ -70,89 +70,88 @@ namespace geomgraph { // geos.geomgraph
* A GeometryGraph is a graph that models a given Geometry
-class GEOS_DLL GeometryGraph: public PlanarGraph
-using PlanarGraph::add;
-using PlanarGraph::findEdge;
+class GEOS_DLL GeometryGraph: public PlanarGraph {
+ using PlanarGraph::add;
+ using PlanarGraph::findEdge;
private:
- const geom::Geometry* parentGeom;
+ const geom::Geometry* parentGeom;
- * The lineEdgeMap is a map of the linestring components of the
- * parentGeometry to the edges which are derived from them.
- * This is used to efficiently perform findEdge queries
- * Following the above description there's no need to
- * compare LineStrings other then by pointer value.
+ * The lineEdgeMap is a map of the linestring components of the
+ * parentGeometry to the edges which are derived from them.
+ * This is used to efficiently perform findEdge queries
+ * Following the above description there's no need to
+ * compare LineStrings other then by pointer value.
//std::map<const geom::LineString*,Edge*,geom::LineStringLT> lineEdgeMap;
- std::map<const geom::LineString*, Edge*> lineEdgeMap;
+ std::map<const geom::LineString*, Edge*> lineEdgeMap;
- * If this flag is true, the Boundary Determination Rule will
- * used when deciding whether nodes are in the boundary or not
- bool useBoundaryDeterminationRule;
+ * If this flag is true, the Boundary Determination Rule will
+ * used when deciding whether nodes are in the boundary or not
+ bool useBoundaryDeterminationRule;
- const algorithm::BoundaryNodeRule& boundaryNodeRule;
+ const algorithm::BoundaryNodeRule& boundaryNodeRule;
- * the index of this geometry as an argument to a spatial function
- * (used for labelling)
- int argIndex;
+ * the index of this geometry as an argument to a spatial function
+ * (used for labelling)
+ int argIndex;
- /// Cache for fast responses to getBoundaryPoints
- std::unique_ptr< geom::CoordinateSequence > boundaryPoints;
+ /// Cache for fast responses to getBoundaryPoints
+ std::unique_ptr< geom::CoordinateSequence > boundaryPoints;
- std::unique_ptr< std::vector<Node*> > boundaryNodes;
+ std::unique_ptr< std::vector<Node*> > boundaryNodes;
- bool hasTooFewPointsVar;
+ bool hasTooFewPointsVar;
- geom::Coordinate invalidPoint;
+ geom::Coordinate invalidPoint;
- /// Allocates a new EdgeSetIntersector. Remember to delete it!
- index::EdgeSetIntersector* createEdgeSetIntersector();
+ /// Allocates a new EdgeSetIntersector. Remember to delete it!
+ index::EdgeSetIntersector* createEdgeSetIntersector();
- void add(const geom::Geometry *g);
- // throw(UnsupportedOperationException);
+ void add(const geom::Geometry* g);
+ // throw(UnsupportedOperationException);
- void addCollection(const geom::GeometryCollection *gc);
+ void addCollection(const geom::GeometryCollection* gc);
- void addPoint(const geom::Point *p);
+ void addPoint(const geom::Point* p);
- void addPolygonRing(const geom::LinearRing *lr,
- int cwLeft, int cwRight);
+ void addPolygonRing(const geom::LinearRing* lr,
+ int cwLeft, int cwRight);
- void addPolygon(const geom::Polygon *p);
+ void addPolygon(const geom::Polygon* p);
- void addLineString(const geom::LineString *line);
+ void addLineString(const geom::LineString* line);
- void insertPoint(int argIndex, const geom::Coordinate& coord,
- int onLocation);
+ void insertPoint(int argIndex, const geom::Coordinate& coord,
+ int onLocation);
- /** \brief
- * Adds candidate boundary points using the current
- * algorithm::BoundaryNodeRule.
- * This is used to add the boundary
- * points of dim-1 geometries (Curves/MultiCurves).
- void insertBoundaryPoint(int argIndex, const geom::Coordinate& coord);
+ /** \brief
+ * Adds candidate boundary points using the current
+ * algorithm::BoundaryNodeRule.
+ * This is used to add the boundary
+ * points of dim-1 geometries (Curves/MultiCurves).
+ void insertBoundaryPoint(int argIndex, const geom::Coordinate& coord);
- void addSelfIntersectionNodes(int argIndex);
+ void addSelfIntersectionNodes(int argIndex);
- /** \brief
- * Add a node for a self-intersection.
- * If the node is a potential boundary node (e.g. came from an edge
- * which is a boundary) then insert it as a potential boundary node.
- * Otherwise, just add it as a regular node.
- void addSelfIntersectionNode(int argIndex,
- const geom::Coordinate& coord, int loc);
+ /** \brief
+ * Add a node for a self-intersection.
+ * If the node is a potential boundary node (e.g. came from an edge
+ * which is a boundary) then insert it as a potential boundary node.
+ * Otherwise, just add it as a regular node.
+ void addSelfIntersectionNode(int argIndex,
+ const geom::Coordinate& coord, int loc);
// Declare type as noncopyable
GeometryGraph(const GeometryGraph& other) = delete;
@@ -160,96 +159,101 @@ private:
public:
- static bool isInBoundary(int boundaryCount);
+ static bool isInBoundary(int boundaryCount);
- static int determineBoundary(int boundaryCount);
+ static int determineBoundary(int boundaryCount);
- const algorithm::BoundaryNodeRule& boundaryNodeRule,
- int boundaryCount);
+ const algorithm::BoundaryNodeRule& boundaryNodeRule,
+ int boundaryCount);
- GeometryGraph();
+ GeometryGraph();
- GeometryGraph(int newArgIndex, const geom::Geometry *newParentGeom);
+ GeometryGraph(int newArgIndex, const geom::Geometry* newParentGeom);
- GeometryGraph(int newArgIndex, const geom::Geometry *newParentGeom,
- const algorithm::BoundaryNodeRule& boundaryNodeRule);
+ GeometryGraph(int newArgIndex, const geom::Geometry* newParentGeom,
+ const algorithm::BoundaryNodeRule& boundaryNodeRule);
- ~GeometryGraph() override;
+ ~GeometryGraph() override;
- const geom::Geometry* getGeometry();
+ const geom::Geometry* getGeometry();
- /// Returned object is owned by this GeometryGraph
- std::vector<Node*>* getBoundaryNodes();
+ /// Returned object is owned by this GeometryGraph
+ std::vector<Node*>* getBoundaryNodes();
- void getBoundaryNodes(std::vector<Node*>&bdyNodes);
+ void getBoundaryNodes(std::vector<Node*>& bdyNodes);
- geom::CoordinateSequence* getBoundaryPoints();
+ geom::CoordinateSequence* getBoundaryPoints();
- Edge* findEdge(const geom::LineString *line);
+ Edge* findEdge(const geom::LineString* line);
- void computeSplitEdges(std::vector<Edge*> *edgelist);
+ void computeSplitEdges(std::vector<Edge*>* edgelist);
- void addEdge(Edge *e);
+ void addEdge(Edge* e);
- void addPoint(geom::Coordinate& pt);
+ void addPoint(geom::Coordinate& pt);
- * \brief
- * Compute self-nodes, taking advantage of the Geometry type to
- * minimize the number of intersection tests. (E.g. rings are
- * not tested for self-intersection, since
- * they are assumed to be valid).
- * @param li the LineIntersector to use
- * @param computeRingSelfNodes if <false>, intersection checks are
- * optimized to not test rings for self-intersection
- * @return the SegmentIntersector used, containing information about
- * the intersections found
- index::SegmentIntersector* computeSelfNodes(
- algorithm::LineIntersector *li,
- bool computeRingSelfNodes,
- const geom::Envelope *env=nullptr)
- return computeSelfNodes(*li, computeRingSelfNodes, env);
+ * \brief
+ * Compute self-nodes, taking advantage of the Geometry type to
+ * minimize the number of intersection tests. (E.g. rings are
+ * not tested for self-intersection, since
+ * they are assumed to be valid).
+ * @param li the LineIntersector to use
+ * @param computeRingSelfNodes if <false>, intersection checks are
+ * optimized to not test rings for self-intersection
+ * @return the SegmentIntersector used, containing information about
+ * the intersections found
+ index::SegmentIntersector*
+ computeSelfNodes(
+ algorithm::LineIntersector* li,
+ bool computeRingSelfNodes,
+ const geom::Envelope* env = nullptr)
+ return computeSelfNodes(*li, computeRingSelfNodes, env);
- bool isDoneIfProperInt,
- return computeSelfNodes(*li, computeRingSelfNodes, isDoneIfProperInt, env);
+ computeSelfNodes(
+ bool isDoneIfProperInt,
+ return computeSelfNodes(*li, computeRingSelfNodes, isDoneIfProperInt, env);
- // Quick inline calling the function above, the above should probably
- // be deprecated.
- algorithm::LineIntersector& li,
- bool computeRingSelfNodes, const geom::Envelope *env=nullptr);
+ // Quick inline calling the function above, the above should probably
+ // be deprecated.
+ index::SegmentIntersector* computeSelfNodes(
+ algorithm::LineIntersector& li,
+ bool computeRingSelfNodes, const geom::Envelope* env = nullptr);
- bool computeRingSelfNodes, bool isDoneIfProperInt, const geom::Envelope *env=nullptr);
+ bool computeRingSelfNodes, bool isDoneIfProperInt, const geom::Envelope* env = nullptr);
- index::SegmentIntersector* computeEdgeIntersections(GeometryGraph *g,
- algorithm::LineIntersector *li, bool includeProper,
- const geom::Envelope *env=nullptr);
+ index::SegmentIntersector* computeEdgeIntersections(GeometryGraph* g,
+ algorithm::LineIntersector* li, bool includeProper,
+ const geom::Envelope* env = nullptr);
- std::vector<Edge*> *getEdges();
+ std::vector<Edge*>* getEdges();
- bool hasTooFewPoints();
+ bool hasTooFewPoints();
- const geom::Coordinate& getInvalidPoint();
+ const geom::Coordinate& getInvalidPoint();
- const algorithm::BoundaryNodeRule& getBoundaryNodeRule() const
- { return boundaryNodeRule; }
+ getBoundaryNodeRule() const
+ return boundaryNodeRule;
diff --git a/include/geos/geomgraph/GeometryGraph.inl b/include/geos/geomgraph/GeometryGraph.inl
index e969d0e..18a53c3 100644
--- a/include/geos/geomgraph/GeometryGraph.inl
+++ b/include/geos/geomgraph/GeometryGraph.inl
@@ -9,7 +9,7 @@
@@ -27,18 +27,18 @@ namespace geos {
INLINE void
-GeometryGraph::getBoundaryNodes(std::vector<Node*>&bdyNodes)
+GeometryGraph::getBoundaryNodes(std::vector<Node*>& bdyNodes)
- nodes->getBoundaryNodes(argIndex, bdyNodes);
+ nodes->getBoundaryNodes(argIndex, bdyNodes);
INLINE const geom::Geometry*
GeometryGraph::getGeometry()
- return parentGeom;
+ return parentGeom;
-INLINE
+INLINE
GeometryGraph::~GeometryGraph()
diff --git a/include/geos/geomgraph/GraphComponent.h b/include/geos/geomgraph/GraphComponent.h
index 5790bef..73c190d 100644
--- a/include/geos/geomgraph/GraphComponent.h
+++ b/include/geos/geomgraph/GraphComponent.h
@@ -29,9 +29,9 @@
namespace geos {
- namespace geom {
+namespace geom {
namespace geos {
@@ -46,35 +46,71 @@ namespace geomgraph { // geos.geomgraph
class GEOS_DLL GraphComponent {
public:
- GraphComponent();
+ GraphComponent();
- * GraphComponent copies the given Label.
- GraphComponent(const Label& newLabel);
- virtual ~GraphComponent();
+ * GraphComponent copies the given Label.
+ GraphComponent(const Label& newLabel);
+ virtual ~GraphComponent();
- void setLabel(const Label& newLabel) { label = newLabel; }
+ Label&
+ getLabel()
+ return label;
+ const Label&
+ getLabel() const
+ return label;
+ void
+ setLabel(const Label& newLabel)
+ label = newLabel;
- virtual void setInResult(bool p_isInResult) { isInResultVar=p_isInResult; }
- virtual bool isInResult() const { return isInResultVar; }
- virtual void setCovered(bool isCovered);
- virtual bool isCovered() const { return isCoveredVar; }
- virtual bool isCoveredSet() const { return isCoveredSetVar; }
- virtual bool isVisited() const { return isVisitedVar; }
- virtual void setVisited(bool p_isVisited) { isVisitedVar = p_isVisited; }
- virtual bool isIsolated() const=0;
- virtual void updateIM(geom::IntersectionMatrix& im);
+ virtual void
+ setInResult(bool p_isInResult)
+ isInResultVar = p_isInResult;
+ virtual bool
+ isInResult() const
+ virtual void setCovered(bool isCovered);
+ virtual bool
+ isCovered() const
+ return isCoveredVar;
+ virtual bool
+ isCoveredSet() const
+ return isCoveredSetVar;
+ virtual bool
+ isVisited() const
+ virtual void
+ setVisited(bool p_isVisited)
+ isVisitedVar = p_isVisited;
+ virtual bool isIsolated() const = 0;
+ virtual void updateIM(geom::IntersectionMatrix& im);
protected:
- Label label;
- virtual void computeIM(geom::IntersectionMatrix& im)=0;
+ Label label;
+ virtual void computeIM(geom::IntersectionMatrix& im) = 0;
private:
- bool isCoveredVar;
- bool isCoveredSetVar;
+ bool isCoveredVar;
+ bool isCoveredSetVar;
} // namespace geos.geomgraph
diff --git a/include/geos/geomgraph/Label.h b/include/geos/geomgraph/Label.h
index a1ccfcf..b9a1a07 100644
--- a/include/geos/geomgraph/Label.h
+++ b/include/geos/geomgraph/Label.h
@@ -58,108 +58,108 @@ class GEOS_DLL Label {
public:
- friend std::ostream& operator<< (std::ostream&, const Label&);
+ friend std::ostream& operator<< (std::ostream&, const Label&);
- /** \brief
- * Converts a Label to a Line label
- * (that is, one with no side Locations)
- static Label toLineLabel(const Label& label);
+ /** \brief
+ * Converts a Label to a Line label
+ * (that is, one with no side Locations)
+ static Label toLineLabel(const Label& label);
- /** \brief
- * Construct a Label with a single location for both Geometries.
- Label(int onLoc);
+ /** \brief
+ * Construct a Label with a single location for both Geometries.
+ Label(int onLoc);
- /** \brief
- * Construct a Label with the location specified
- * for the given Geometry.
- * Other geometry location will be set to
- Label(int geomIndex, int onLoc);
+ /** \brief
+ * Construct a Label with the location specified
+ * for the given Geometry.
+ * Other geometry location will be set to
+ * Location::UNDEF.
+ Label(int geomIndex, int onLoc);
- /** \brief
- * Construct a Label with On, Left and Right locations for both Geometries.
- * Initialize the locations for both Geometries to the given values.
- Label(int onLoc, int leftLoc, int rightLoc);
+ /** \brief
+ * Construct a Label with On, Left and Right locations for both Geometries.
+ * Initialize the locations for both Geometries to the given values.
+ Label(int onLoc, int leftLoc, int rightLoc);
- /// Copy ctor
- Label(const Label &l);
+ /// Copy ctor
+ Label(const Label& l);
- Label& operator= (const Label& l);
+ Label& operator= (const Label& l);
- /** \brief
- * Initialize both locations to Location::UNDEF
- * isNull() should return true after this kind of construction
- Label();
+ /** \brief
+ * Initialize both locations to Location::UNDEF
+ * isNull() should return true after this kind of construction
+ Label();
- /** \brief
- * Construct a Label with On, Left and Right locations for the
- * given Geometries.
- * Initialize the locations for the other Geometry to
- Label(int geomIndex, int onLoc, int leftLoc, int rightLoc);
+ /** \brief
+ * Construct a Label with On, Left and Right locations for the
+ * given Geometries.
+ * Initialize the locations for the other Geometry to
+ * Location::UNDEF
+ Label(int geomIndex, int onLoc, int leftLoc, int rightLoc);
- void flip();
+ void flip();
- int getLocation(int geomIndex, int posIndex) const;
+ int getLocation(int geomIndex, int posIndex) const;
- int getLocation(int geomIndex) const;
+ int getLocation(int geomIndex) const;
- void setLocation(int geomIndex, int posIndex, int location);
+ void setLocation(int geomIndex, int posIndex, int location);
- void setLocation(int geomIndex, int location);
+ void setLocation(int geomIndex, int location);
- void setAllLocations(int geomIndex, int location);
+ void setAllLocations(int geomIndex, int location);
- void setAllLocationsIfNull(int geomIndex, int location);
+ void setAllLocationsIfNull(int geomIndex, int location);
- void setAllLocationsIfNull(int location);
+ void setAllLocationsIfNull(int location);
- /** \brief
- * Merge this label with another one.
- * Merging updates any null attributes of this label with the attributes
- * from lbl
- void merge(const Label &lbl);
+ /** \brief
+ * Merge this label with another one.
+ * Merging updates any null attributes of this label with the attributes
+ * from lbl
+ void merge(const Label& lbl);
- int getGeometryCount() const;
+ int getGeometryCount() const;
- bool isNull() const;
+ bool isNull() const;
- bool isNull(int geomIndex) const;
+ bool isNull(int geomIndex) const;
- bool isAnyNull(int geomIndex) const;
+ bool isAnyNull(int geomIndex) const;
- bool isArea() const;
+ bool isArea() const;
- bool isArea(int geomIndex) const;
+ bool isArea(int geomIndex) const;
- bool isLine(int geomIndex) const;
+ bool isLine(int geomIndex) const;
- bool isEqualOnSide(const Label &lbl, int side) const;
+ bool isEqualOnSide(const Label& lbl, int side) const;
- bool allPositionsEqual(int geomIndex, int loc) const;
+ bool allPositionsEqual(int geomIndex, int loc) const;
- /** \brief
- * Converts one GeometryLocation to a Line location
- void toLine(int geomIndex);
+ /** \brief
+ * Converts one GeometryLocation to a Line location
+ void toLine(int geomIndex);
- std::string toString() const;
+ std::string toString() const;
private:
- TopologyLocation elt[2];
+ TopologyLocation elt[2];
diff --git a/include/geos/geomgraph/Node.h b/include/geos/geomgraph/Node.h
index 1072fa6..06da110 100644
--- a/include/geos/geomgraph/Node.h
+++ b/include/geos/geomgraph/Node.h
@@ -43,16 +43,16 @@
namespace geos {
- namespace geom {
- namespace geomgraph {
- class Node;
- class EdgeEnd;
- class Label;
+namespace geom {
+namespace geomgraph {
+class Node;
+class EdgeEndStar;
+class EdgeEnd;
+class Label;
+class NodeFactory;
namespace geos {
@@ -60,93 +60,94 @@ namespace geomgraph { // geos.geomgraph
/** The node component of a geometry graph */
class GEOS_DLL Node: public GraphComponent {
-using GraphComponent::setLabel;
+ using GraphComponent::setLabel;
public:
- friend std::ostream& operator<< (std::ostream& os, const Node& node);
+ friend std::ostream& operator<< (std::ostream& os, const Node& node);
- Node(const geom::Coordinate& newCoord, EdgeEndStar* newEdges);
+ Node(const geom::Coordinate& newCoord, EdgeEndStar* newEdges);
- ~Node() override;
+ ~Node() override;
- virtual const geom::Coordinate& getCoordinate() const;
+ virtual const geom::Coordinate& getCoordinate() const;
- virtual EdgeEndStar* getEdges();
+ virtual EdgeEndStar* getEdges();
- bool isIsolated() const override;
+ bool isIsolated() const override;
- /** \brief
- * Add the edge to the list of edges at this node
- virtual void add(EdgeEnd *e);
+ /** \brief
+ * Add the edge to the list of edges at this node
+ virtual void add(EdgeEnd* e);
- virtual void mergeLabel(const Node& n);
+ virtual void mergeLabel(const Node& n);
- /** \brief
- * To merge labels for two nodes,
- * the merged location for each LabelElement is computed.
- * The location for the corresponding node LabelElement is set
- * to the result, as long as the location is non-null.
- virtual void mergeLabel(const Label& label2);
+ /** \brief
+ * To merge labels for two nodes,
+ * the merged location for each LabelElement is computed.
+ * The location for the corresponding node LabelElement is set
+ * to the result, as long as the location is non-null.
+ virtual void mergeLabel(const Label& label2);
- virtual void setLabel(int argIndex, int onLocation);
+ virtual void setLabel(int argIndex, int onLocation);
- /** \brief
- * Updates the label of a node to BOUNDARY,
- * obeying the mod-2 boundaryDetermination rule.
- virtual void setLabelBoundary(int argIndex);
+ /** \brief
+ * Updates the label of a node to BOUNDARY,
+ * obeying the mod-2 boundaryDetermination rule.
+ virtual void setLabelBoundary(int argIndex);
- * The location for a given eltIndex for a node will be one
- * of { null, INTERIOR, BOUNDARY }.
- * A node may be on both the boundary and the interior of a geometry;
- * in this case, the rule is that the node is considered to be
- * in the boundary.
- * The merged location is the maximum of the two input values.
- virtual int computeMergedLocation(const Label& label2, int eltIndex);
+ * The location for a given eltIndex for a node will be one
+ * of { null, INTERIOR, BOUNDARY }.
+ * A node may be on both the boundary and the interior of a geometry;
+ * in this case, the rule is that the node is considered to be
+ * in the boundary.
+ * The merged location is the maximum of the two input values.
+ virtual int computeMergedLocation(const Label& label2, int eltIndex);
- virtual std::string print();
+ virtual std::string print();
- virtual const std::vector<double> &getZ() const;
+ virtual const std::vector<double>& getZ() const;
- virtual void addZ(double);
+ virtual void addZ(double);
- /** \brief
- * Tests whether any incident edge is flagged as
- * being in the result.
- * This test can be used to determine if the node is in the result,
- * since if any incident edge is in the result, the node must be in
- * the result as well.
- * @return <code>true</code> if any indicident edge in the in
- * the result
- virtual bool isIncidentEdgeInResult() const;
+ /** \brief
+ * Tests whether any incident edge is flagged as
+ * being in the result.
+ * This test can be used to determine if the node is in the result,
+ * since if any incident edge is in the result, the node must be in
+ * the result as well.
+ * @return <code>true</code> if any indicident edge in the in
+ * the result
+ virtual bool isIncidentEdgeInResult() const;
protected:
- void testInvariant() const;
+ void testInvariant() const;
- EdgeEndStar* edges;
+ EdgeEndStar* edges;
- /** \brief
- * Basic nodes do not compute IMs
- void computeIM(geom::IntersectionMatrix& /*im*/) override {}
+ /** \brief
+ * Basic nodes do not compute IMs
+ void
+ computeIM(geom::IntersectionMatrix& /*im*/) override {}
private:
- std::vector<double> zvals;
+ std::vector<double> zvals;
- double ztot;
+ double ztot;
@@ -156,31 +157,28 @@ inline void
Node::testInvariant() const
#ifndef NDEBUG
- if (edges)
- // Each EdgeEnd in the star has this Node's
- // coordinate as first coordinate
- for (EdgeEndStar::iterator
- it=edges->begin(), itEnd=edges->end();
- it != itEnd; it++)
- EdgeEnd* e=*it;
- assert(e);
- assert(e->getCoordinate().equals2D(coord));
+ if(edges) {
+ // Each EdgeEnd in the star has this Node's
+ // coordinate as first coordinate
+ for(EdgeEndStar::iterator
+ it = edges->begin(), itEnd = edges->end();
+ it != itEnd; it++) {
+ EdgeEnd* e = *it;
+ assert(e);
+ assert(e->getCoordinate().equals2D(coord));
#if 0 // We can't rely on numerical stability with FP computations
- // ztot is the sum of doubnle sin zvals vector
- double ztot_check=0.0;
- for (std::vector<double>::const_iterator
- i = zvals.begin(), e = zvals.end();
- i != e;
- i++)
- ztot_check += *i;
- assert(ztot_check == ztot);
+ // ztot is the sum of doubnle sin zvals vector
+ double ztot_check = 0.0;
+ for(std::vector<double>::const_iterator
+ i = zvals.begin(), e = zvals.end();
+ i != e;
+ i++) {
+ ztot_check += *i;
+ assert(ztot_check == ztot);
#endif // 0
#endif
diff --git a/include/geos/geomgraph/NodeFactory.h b/include/geos/geomgraph/NodeFactory.h
index 310c5a0..012023e 100644
--- a/include/geos/geomgraph/NodeFactory.h
+++ b/include/geos/geomgraph/NodeFactory.h
@@ -26,12 +26,12 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Coordinate;
- class Node;
+namespace geom {
+class Coordinate;
+class Node;
namespace geos {
@@ -39,11 +39,12 @@ namespace geomgraph { // geos.geomgraph
class GEOS_DLL NodeFactory {
public:
- virtual Node* createNode(const geom::Coordinate &coord) const;
- static const NodeFactory &instance();
- virtual ~NodeFactory() {}
+ virtual Node* createNode(const geom::Coordinate& coord) const;
+ static const NodeFactory& instance();
+ virtual
+ ~NodeFactory() {}
protected:
- NodeFactory() {}
+ NodeFactory() {}
diff --git a/include/geos/geomgraph/NodeMap.h b/include/geos/geomgraph/NodeMap.h
index 15bca8a..31bb597 100644
--- a/include/geos/geomgraph/NodeMap.h
+++ b/include/geos/geomgraph/NodeMap.h
@@ -38,74 +38,90 @@
namespace geos {
- class Node;
- class EdgeEnd;
- class NodeFactory;
+class Node;
+class EdgeEnd;
+class NodeFactory;
namespace geos {
-class GEOS_DLL NodeMap{
+class GEOS_DLL NodeMap {
public:
- typedef std::map<geom::Coordinate*,Node*,geom::CoordinateLessThen> container;
+ typedef std::map<geom::Coordinate*, Node*, geom::CoordinateLessThen> container;
- typedef std::pair<geom::Coordinate*,Node*> pair;
+ typedef std::pair<geom::Coordinate*, Node*> pair;
- const NodeFactory &nodeFact;
+ const NodeFactory& nodeFact;
- /// \brief
- /// NodeMap will keep a reference to the NodeFactory,
- /// keep it alive for the whole NodeMap lifetime
- NodeMap(const NodeFactory &newNodeFact);
+ /// \brief
+ /// NodeMap will keep a reference to the NodeFactory,
+ /// keep it alive for the whole NodeMap lifetime
+ NodeMap(const NodeFactory& newNodeFact);
- virtual ~NodeMap();
+ virtual ~NodeMap();
- Node* addNode(const geom::Coordinate& coord);
+ Node* addNode(const geom::Coordinate& coord);
- Node* addNode(Node *n);
+ Node* addNode(Node* n);
- void add(EdgeEnd *e);
+ void add(EdgeEnd* e);
- Node *find(const geom::Coordinate& coord) const;
+ Node* find(const geom::Coordinate& coord) const;
+ const_iterator
+ begin() const
+ const_iterator
+ end() const
+ iterator
+ begin()
+ iterator
+ end()
- void getBoundaryNodes(int geomIndex,
- std::vector<Node*>&bdyNodes) const;
+ void getBoundaryNodes(int geomIndex,
+ std::vector<Node*>& bdyNodes) const;
+ void
+ testInvariant()
#ifndef NDEBUG
- // Each Coordinate key is a pointer inside the Node value
- for (iterator it=begin(), itEnd=end(); it != itEnd; ++it)
- pair p = *it;
- geomgraph::Node* n = p.second;
- geom::Coordinate* c = const_cast<geom::Coordinate*>(
- &(n->getCoordinate())
- assert(p.first == c);
+ // Each Coordinate key is a pointer inside the Node value
+ for(iterator it = begin(), itEnd = end(); it != itEnd; ++it) {
+ pair p = *it;
+ geomgraph::Node* n = p.second;
+ geom::Coordinate* c = const_cast<geom::Coordinate*>(
+ &(n->getCoordinate())
+ assert(p.first == c);
#endif
private:
diff --git a/include/geos/geomgraph/PlanarGraph.h b/include/geos/geomgraph/PlanarGraph.h
index 62d8777..b94d9ae 100644
--- a/include/geos/geomgraph/PlanarGraph.h
+++ b/include/geos/geomgraph/PlanarGraph.h
@@ -35,15 +35,15 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Edge;
- class Node;
- class EdgeEnd;
+namespace geom {
+class Coordinate;
+class Edge;
+class Node;
+class EdgeEnd;
+class NodeFactory;
namespace geos {
@@ -75,125 +75,125 @@ namespace geomgraph { // geos.geomgraph
class GEOS_DLL PlanarGraph {
public:
- /** \brief
- * For nodes in the collection (first..last),
- * link the DirectedEdges at the node that are in the result.
- * This allows clients to link only a subset of nodes in the graph,
- * for efficiency (because they know that only a subset is of
- * interest).
- template <typename It>
- static void linkResultDirectedEdges(It first, It last)
+ /** \brief
+ * For nodes in the collection (first..last),
+ * link the DirectedEdges at the node that are in the result.
+ * This allows clients to link only a subset of nodes in the graph,
+ * for efficiency (because they know that only a subset is of
+ * interest).
+ template <typename It>
+ static void
+ linkResultDirectedEdges(It first, It last)
// throw(TopologyException);
- for ( ; first!=last; ++first )
- Node *node=*first;
- assert(node);
- EdgeEndStar* ees = node->getEdges();
- assert(ees);
- DirectedEdgeStar* des = dynamic_cast<DirectedEdgeStar*>(ees);
- assert(des);
- // this might throw an exception
- des->linkResultDirectedEdges();
+ for(; first != last; ++first) {
+ Node* node = *first;
+ assert(node);
+ EdgeEndStar* ees = node->getEdges();
+ assert(ees);
+ DirectedEdgeStar* des = dynamic_cast<DirectedEdgeStar*>(ees);
+ assert(des);
+ // this might throw an exception
+ des->linkResultDirectedEdges();
- PlanarGraph(const NodeFactory &nodeFact);
+ PlanarGraph(const NodeFactory& nodeFact);
- PlanarGraph();
+ PlanarGraph();
- virtual ~PlanarGraph();
+ virtual ~PlanarGraph();
- virtual std::vector<Edge*>::iterator getEdgeIterator();
+ virtual std::vector<Edge*>::iterator getEdgeIterator();
- virtual std::vector<EdgeEnd*>* getEdgeEnds();
+ virtual std::vector<EdgeEnd*>* getEdgeEnds();
- virtual bool isBoundaryNode(int geomIndex, const geom::Coordinate& coord);
+ virtual bool isBoundaryNode(int geomIndex, const geom::Coordinate& coord);
- virtual NodeMap::iterator getNodeIterator();
+ virtual NodeMap::iterator getNodeIterator();
- virtual void getNodes(std::vector<Node*>&);
+ virtual void getNodes(std::vector<Node*>&);
- virtual Node* addNode(Node *node);
+ virtual Node* addNode(Node* node);
- virtual Node* addNode(const geom::Coordinate& coord);
+ virtual Node* addNode(const geom::Coordinate& coord);
- /** \brief
- * @return the node if found; null otherwise
- virtual Node* find(geom::Coordinate& coord);
+ /** \brief
+ * @return the node if found; null otherwise
+ virtual Node* find(geom::Coordinate& coord);
- /** \brief
- * Add a set of edges to the graph. For each edge two DirectedEdges
- * will be created. DirectedEdges are NOT linked by this method.
- virtual void addEdges(const std::vector<Edge*> &edgesToAdd);
+ /** \brief
+ * Add a set of edges to the graph. For each edge two DirectedEdges
+ * will be created. DirectedEdges are NOT linked by this method.
+ virtual void addEdges(const std::vector<Edge*>& edgesToAdd);
- virtual void linkResultDirectedEdges();
+ virtual void linkResultDirectedEdges();
- virtual void linkAllDirectedEdges();
+ virtual void linkAllDirectedEdges();
- /** \brief
- * Returns the EdgeEnd which has edge e as its base edge
- * (MD 18 Feb 2002 - this should return a pair of edges)
- * @return the edge, if found
- * <code>null</code> if the edge was not found
- virtual EdgeEnd* findEdgeEnd(Edge *e);
+ /** \brief
+ * Returns the EdgeEnd which has edge e as its base edge
+ * (MD 18 Feb 2002 - this should return a pair of edges)
+ * @return the edge, if found
+ * <code>null</code> if the edge was not found
+ virtual EdgeEnd* findEdgeEnd(Edge* e);
- /** \brief
- * Returns the edge whose first two coordinates are p0 and p1
- virtual Edge* findEdge(const geom::Coordinate& p0,
- const geom::Coordinate& p1);
+ /** \brief
+ * Returns the edge whose first two coordinates are p0 and p1
+ virtual Edge* findEdge(const geom::Coordinate& p0,
+ const geom::Coordinate& p1);
- /** \brief
- * Returns the edge which starts at p0 and whose first segment is
- * parallel to p1
- virtual Edge* findEdgeInSameDirection(const geom::Coordinate& p0,
+ /** \brief
+ * Returns the edge which starts at p0 and whose first segment is
+ * parallel to p1
+ virtual Edge* findEdgeInSameDirection(const geom::Coordinate& p0,
- virtual std::string printEdges();
+ virtual std::string printEdges();
- virtual NodeMap* getNodeMap();
+ virtual NodeMap* getNodeMap();
protected:
- std::vector<Edge*> *edges;
+ std::vector<Edge*>* edges;
- NodeMap *nodes;
+ NodeMap* nodes;
- std::vector<EdgeEnd*> *edgeEndList;
+ std::vector<EdgeEnd*>* edgeEndList;
- virtual void insertEdge(Edge *e);
+ virtual void insertEdge(Edge* e);
private:
- /** \brief
- * The coordinate pairs match if they define line segments
- * lying in the same direction.
- * E.g. the segments are parallel and in the same quadrant
- * (as opposed to parallel and opposite!).
- bool matchInSameDirection(const geom::Coordinate& p0,
- const geom::Coordinate& p1,
- const geom::Coordinate& ep0,
- const geom::Coordinate& ep1);
+ /** \brief
+ * The coordinate pairs match if they define line segments
+ * lying in the same direction.
+ * E.g. the segments are parallel and in the same quadrant
+ * (as opposed to parallel and opposite!).
+ bool matchInSameDirection(const geom::Coordinate& p0,
+ const geom::Coordinate& p1,
+ const geom::Coordinate& ep0,
+ const geom::Coordinate& ep1);
diff --git a/include/geos/geomgraph/Position.h b/include/geos/geomgraph/Position.h
index 51ad61c..16df86e 100644
--- a/include/geos/geomgraph/Position.h
+++ b/include/geos/geomgraph/Position.h
@@ -34,31 +34,31 @@ namespace geomgraph { // geos.geomgraph
class GEOS_DLL Position {
public:
- enum {
- * An indicator that a Location is <i>on</i>
- * a GraphComponent
- ON=0,
+ enum {
+ * An indicator that a Location is <i>on</i>
+ * a GraphComponent
+ ON = 0,
- * An indicator that a Location is to the
- * <i>left</i> of a GraphComponent
- LEFT,
+ * An indicator that a Location is to the
+ * <i>left</i> of a GraphComponent
+ LEFT,
- * <i>right</i> of a GraphComponent
- RIGHT
+ * <i>right</i> of a GraphComponent
+ RIGHT
- * Returns LEFT if the position is RIGHT, RIGHT if
- * the position is LEFT, or the position otherwise.
- static int opposite(int position);
+ * Returns LEFT if the position is RIGHT, RIGHT if
+ * the position is LEFT, or the position otherwise.
+ static int opposite(int position);
diff --git a/include/geos/geomgraph/Quadrant.h b/include/geos/geomgraph/Quadrant.h
index f1785ab..9992071 100644
--- a/include/geos/geomgraph/Quadrant.h
+++ b/include/geos/geomgraph/Quadrant.h
@@ -28,9 +28,9 @@
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -49,50 +49,50 @@ class GEOS_DLL Quadrant {
public:
- static const int NE = 0;
- static const int NW = 1;
- static const int SW = 2;
- static const int SE = 3;
- * Returns the quadrant of a directed line segment
- * (specified as x and y displacements, which cannot both be 0).
- * @throws IllegalArgumentException if the displacements are both 0
- static int quadrant(double dx, double dy);
- * Returns the quadrant of a directed line segment from p0 to p1.
- * @throws IllegalArgumentException if the points are equal
- static int quadrant(const geom::Coordinate& p0,
- * Returns true if the quadrants are 1 and 3, or 2 and 4
- static bool isOpposite(int quad1, int quad2);
- * Returns the right-hand quadrant of the halfplane defined by
- * the two quadrants,
- * or -1 if the quadrants are opposite, or the quadrant if they
- * are identical.
- static int commonHalfPlane(int quad1, int quad2);
- * Returns whether the given quadrant lies within the given halfplane
- * (specified by its right-hand quadrant).
- static bool isInHalfPlane(int quad, int halfPlane);
- * Returns true if the given quadrant is 0 or 1.
- static bool isNorthern(int quad);
+ static const int NE = 0;
+ static const int NW = 1;
+ static const int SW = 2;
+ static const int SE = 3;
+ * Returns the quadrant of a directed line segment
+ * (specified as x and y displacements, which cannot both be 0).
+ * @throws IllegalArgumentException if the displacements are both 0
+ static int quadrant(double dx, double dy);
+ * Returns the quadrant of a directed line segment from p0 to p1.
+ * @throws IllegalArgumentException if the points are equal
+ static int quadrant(const geom::Coordinate& p0,
+ * Returns true if the quadrants are 1 and 3, or 2 and 4
+ static bool isOpposite(int quad1, int quad2);
+ * Returns the right-hand quadrant of the halfplane defined by
+ * the two quadrants,
+ * or -1 if the quadrants are opposite, or the quadrant if they
+ * are identical.
+ static int commonHalfPlane(int quad1, int quad2);
+ * Returns whether the given quadrant lies within the given halfplane
+ * (specified by its right-hand quadrant).
+ static bool isInHalfPlane(int quad, int halfPlane);
+ * Returns true if the given quadrant is 0 or 1.
+ static bool isNorthern(int quad);
diff --git a/include/geos/geomgraph/TopologyLocation.h b/include/geos/geomgraph/TopologyLocation.h
index 658c7c0..5a568f5 100644
--- a/include/geos/geomgraph/TopologyLocation.h
+++ b/include/geos/geomgraph/TopologyLocation.h
@@ -59,79 +59,79 @@ class GEOS_DLL TopologyLocation {
public:
- friend std::ostream& operator<< (std::ostream&, const TopologyLocation&);
+ friend std::ostream& operator<< (std::ostream&, const TopologyLocation&);
- TopologyLocation();
+ TopologyLocation();
- ~TopologyLocation();
+ ~TopologyLocation();
- TopologyLocation(const std::vector<int> &newLocation);
+ TopologyLocation(const std::vector<int>& newLocation);
- /** \brief
- * Constructs a TopologyLocation specifying how points on, to the
- * left of, and to the right of some GraphComponent relate to some
- * Geometry.
- * Possible values for the
- * parameters are Location::UNDEF, Location::EXTERIOR, Location::BOUNDARY,
- * and Location::INTERIOR.
- * @see Location
- TopologyLocation(int on, int left, int right);
+ /** \brief
+ * Constructs a TopologyLocation specifying how points on, to the
+ * left of, and to the right of some GraphComponent relate to some
+ * Geometry.
+ * Possible values for the
+ * parameters are Location::UNDEF, Location::EXTERIOR, Location::BOUNDARY,
+ * and Location::INTERIOR.
+ * @see Location
+ TopologyLocation(int on, int left, int right);
- TopologyLocation(int on);
+ TopologyLocation(int on);
- TopologyLocation(const TopologyLocation &gl);
+ TopologyLocation(const TopologyLocation& gl);
- TopologyLocation& operator= (const TopologyLocation &gl);
+ TopologyLocation& operator= (const TopologyLocation& gl);
- int get(std::size_t posIndex) const;
+ int get(std::size_t posIndex) const;
- * @return true if all locations are Location::UNDEF
+ * @return true if all locations are Location::UNDEF
- * @return true if any locations is Location::UNDEF
- bool isAnyNull() const;
+ * @return true if any locations is Location::UNDEF
+ bool isAnyNull() const;
- bool isEqualOnSide(const TopologyLocation &le, int locIndex) const;
+ bool isEqualOnSide(const TopologyLocation& le, int locIndex) const;
- bool isLine() const;
+ bool isLine() const;
- void flip();
+ void flip();
- void setAllLocations(int locValue);
+ void setAllLocations(int locValue);
- void setAllLocationsIfNull(int locValue);
+ void setAllLocationsIfNull(int locValue);
- void setLocation(std::size_t locIndex, int locValue);
+ void setLocation(std::size_t locIndex, int locValue);
- void setLocation(int locValue);
+ void setLocation(int locValue);
- /// Warning: returns reference to owned memory
- const std::vector<int> &getLocations() const;
+ /// Warning: returns reference to owned memory
+ const std::vector<int>& getLocations() const;
- void setLocations(int on, int left, int right);
+ void setLocations(int on, int left, int right);
- bool allPositionsEqual(int loc) const;
+ bool allPositionsEqual(int loc) const;
- /** \brief
- * merge updates only the UNDEF attributes of this object
- * with the attributes of another.
- void merge(const TopologyLocation &gl);
+ /** \brief
+ * merge updates only the UNDEF attributes of this object
+ * with the attributes of another.
+ void merge(const TopologyLocation& gl);
private:
- std::vector<int> location;
+ std::vector<int> location;
diff --git a/include/geos/geomgraph/index/EdgeSetIntersector.h b/include/geos/geomgraph/index/EdgeSetIntersector.h
index 349b4e4..8fe90b5 100644
--- a/include/geos/geomgraph/index/EdgeSetIntersector.h
+++ b/include/geos/geomgraph/index/EdgeSetIntersector.h
@@ -21,12 +21,12 @@
namespace geos {
- class Edge;
- namespace index {
+class Edge;
+namespace index {
namespace geos {
@@ -38,25 +38,26 @@ namespace index { // geos::geomgraph::index
class GEOS_DLL EdgeSetIntersector {
public:
- * Computes all self-intersections between edges in a set of edges,
- * allowing client to choose whether self-intersections are computed.
- * @param edges a list of edges to test for intersections
- * @param si the SegmentIntersector to use
- * @param testAllSegments true if self-intersections are to be tested as well
- virtual void computeIntersections(std::vector<Edge*> *edges,
- SegmentIntersector *si, bool testAllSegments)=0;
+ * Computes all self-intersections between edges in a set of edges,
+ * allowing client to choose whether self-intersections are computed.
+ * @param edges a list of edges to test for intersections
+ * @param si the SegmentIntersector to use
+ * @param testAllSegments true if self-intersections are to be tested as well
+ virtual void computeIntersections(std::vector<Edge*>* edges,
+ SegmentIntersector* si, bool testAllSegments) = 0;
- * Computes all mutual intersections between two sets of edges
- virtual void computeIntersections(std::vector<Edge*> *edges0,
- std::vector<Edge*> *edges1,
- SegmentIntersector *si)=0;
+ * Computes all mutual intersections between two sets of edges
+ virtual void computeIntersections(std::vector<Edge*>* edges0,
+ std::vector<Edge*>* edges1,
+ SegmentIntersector* si) = 0;
- virtual ~EdgeSetIntersector(){}
+ virtual
+ ~EdgeSetIntersector() {}
diff --git a/include/geos/geomgraph/index/MonotoneChain.h b/include/geos/geomgraph/index/MonotoneChain.h
index f353136..4611a00 100644
--- a/include/geos/geomgraph/index/MonotoneChain.h
+++ b/include/geos/geomgraph/index/MonotoneChain.h
@@ -28,11 +28,11 @@
namespace geos {
- namespace index {
+namespace index {
namespace geos {
@@ -44,21 +44,23 @@ namespace index { // geos::geomgraph::index
class GEOS_DLL MonotoneChain: public SweepLineEventOBJ {
private:
- MonotoneChainEdge *mce;
- size_t chainIndex;
+ MonotoneChainEdge* mce;
+ size_t chainIndex;
public:
- MonotoneChain(MonotoneChainEdge *newMce, size_t newChainIndex):
- mce(newMce),
- chainIndex(newChainIndex)
+ MonotoneChain(MonotoneChainEdge* newMce, size_t newChainIndex):
+ mce(newMce),
+ chainIndex(newChainIndex)
- ~MonotoneChain() override {}
+ ~MonotoneChain() override {}
- void computeIntersections(MonotoneChain *mc,SegmentIntersector *si) {
- mce->computeIntersectsForChain(chainIndex,*(mc->mce),mc->chainIndex,*si);
+ void
+ computeIntersections(MonotoneChain* mc, SegmentIntersector* si)
+ mce->computeIntersectsForChain(chainIndex, *(mc->mce), mc->chainIndex, *si);
diff --git a/include/geos/geomgraph/index/MonotoneChainEdge.h b/include/geos/geomgraph/index/MonotoneChainEdge.h
index 19ed048..1805439 100644
--- a/include/geos/geomgraph/index/MonotoneChainEdge.h
+++ b/include/geos/geomgraph/index/MonotoneChainEdge.h
@@ -26,15 +26,15 @@
namespace geos {
- namespace geom {
- class Edge;
- namespace index {
+namespace geom {
+class Edge;
+namespace index {
namespace geos {
@@ -43,33 +43,33 @@ namespace index { // geos::geomgraph::index
class GEOS_DLL MonotoneChainEdge {
public:
- //MonotoneChainEdge();
- ~MonotoneChainEdge();
- MonotoneChainEdge(Edge *newE);
- const geom::CoordinateSequence* getCoordinates();
- std::vector<size_t>& getStartIndexes();
- double getMinX(size_t chainIndex);
- double getMaxX(size_t chainIndex);
+ //MonotoneChainEdge();
+ ~MonotoneChainEdge();
+ MonotoneChainEdge(Edge* newE);
+ const geom::CoordinateSequence* getCoordinates();
+ std::vector<size_t>& getStartIndexes();
+ double getMinX(size_t chainIndex);
+ double getMaxX(size_t chainIndex);
- void computeIntersects(const MonotoneChainEdge &mce,
- SegmentIntersector &si);
+ void computeIntersects(const MonotoneChainEdge& mce,
+ SegmentIntersector& si);
- void computeIntersectsForChain(size_t chainIndex0,
- const MonotoneChainEdge &mce, size_t chainIndex1,
+ void computeIntersectsForChain(size_t chainIndex0,
+ const MonotoneChainEdge& mce, size_t chainIndex1,
protected:
- Edge *e;
- const geom::CoordinateSequence* pts; // cache a reference to the coord array, for efficiency
- // the lists of start/end indexes of the monotone chains.
- // Includes the end point of the edge as a sentinel
- std::vector<size_t> startIndex;
- // these envelopes are created once and reused
+ Edge* e;
+ const geom::CoordinateSequence* pts; // cache a reference to the coord array, for efficiency
+ // the lists of start/end indexes of the monotone chains.
+ // Includes the end point of the edge as a sentinel
+ std::vector<size_t> startIndex;
+ // these envelopes are created once and reused
private:
- void computeIntersectsForChain(size_t start0, size_t end0,
- size_t start1, size_t end1,
- SegmentIntersector &ei);
+ void computeIntersectsForChain(size_t start0, size_t end0,
+ size_t start1, size_t end1,
+ SegmentIntersector& ei);
bool overlaps(size_t start0, size_t end0, const MonotoneChainEdge& mce, size_t start1, size_t end1);
diff --git a/include/geos/geomgraph/index/MonotoneChainIndexer.h b/include/geos/geomgraph/index/MonotoneChainIndexer.h
index 1b282ee..616217e 100644
--- a/include/geos/geomgraph/index/MonotoneChainIndexer.h
+++ b/include/geos/geomgraph/index/MonotoneChainIndexer.h
@@ -21,9 +21,9 @@
namespace geos {
- namespace geom {
+namespace geom {
namespace geos {
@@ -31,17 +31,17 @@ namespace geomgraph { // geos::geomgraph
-class GEOS_DLL MonotoneChainIndexer{
+class GEOS_DLL MonotoneChainIndexer {
public:
- MonotoneChainIndexer(){}
+ MonotoneChainIndexer() {}
- void getChainStartIndices(const geom::CoordinateSequence*, std::vector<std::size_t>&);
+ void getChainStartIndices(const geom::CoordinateSequence*, std::vector<std::size_t>&);
private:
- std::size_t findChainEnd(const geom::CoordinateSequence* pts, std::size_t start);
+ std::size_t findChainEnd(const geom::CoordinateSequence* pts, std::size_t start);
diff --git a/include/geos/geomgraph/index/SegmentIntersector.h b/include/geos/geomgraph/index/SegmentIntersector.h
index ec3bf62..5c1aec9 100644
--- a/include/geos/geomgraph/index/SegmentIntersector.h
+++ b/include/geos/geomgraph/index/SegmentIntersector.h
@@ -28,13 +28,13 @@
namespace geos {
- namespace algorithm {
- class LineIntersector;
- class Node;
- class Edge;
+namespace algorithm {
+class LineIntersector;
+class Node;
+class Edge;
namespace geos {
@@ -42,96 +42,97 @@ namespace geomgraph { // geos::geomgraph
-class GEOS_DLL SegmentIntersector{
+class GEOS_DLL SegmentIntersector {
private:
- * These variables keep track of what types of intersections were
- * found during ALL edges that have been intersected.
- bool hasIntersectionVar;
+ * These variables keep track of what types of intersections were
+ * found during ALL edges that have been intersected.
+ bool hasIntersectionVar;
- bool hasProper;
+ bool hasProper;
- bool hasProperInterior;
+ bool hasProperInterior;
- bool isDone;
+ bool isDone;
- bool isDoneWhenProperInt;
+ bool isDoneWhenProperInt;
- // the proper intersection point found
- geom::Coordinate properIntersectionPoint;
+ // the proper intersection point found
+ geom::Coordinate properIntersectionPoint;
- algorithm::LineIntersector *li;
+ algorithm::LineIntersector* li;
- bool includeProper;
+ bool includeProper;
- bool recordIsolated;
+ bool recordIsolated;
- //bool isSelfIntersection;
+ //bool isSelfIntersection;
- //bool intersectionFound;
+ //bool intersectionFound;
- int numIntersections;
+ int numIntersections;
- /// Elements are externally owned
- std::vector<std::vector<Node*>*> bdyNodes;
+ /// Elements are externally owned
+ std::vector<std::vector<Node*>*> bdyNodes;
- bool isTrivialIntersection(Edge *e0, size_t segIndex0,Edge *e1, size_t segIndex1);
+ bool isTrivialIntersection(Edge* e0, size_t segIndex0, Edge* e1, size_t segIndex1);
- bool isBoundaryPoint(algorithm::LineIntersector *li,
- std::vector<std::vector<Node*>*>& tstBdyNodes);
+ bool isBoundaryPoint(algorithm::LineIntersector* li,
+ std::vector<std::vector<Node*>*>& tstBdyNodes);
- std::vector<Node*> *tstBdyNodes);
+ std::vector<Node*>* tstBdyNodes);
public:
- static bool isAdjacentSegments(size_t i1, size_t i2);
+ static bool isAdjacentSegments(size_t i1, size_t i2);
- // testing only
- int numTests;
+ // testing only
+ int numTests;
- //SegmentIntersector();
+ //SegmentIntersector();
- virtual ~SegmentIntersector() {}
+ virtual
+ ~SegmentIntersector() {}
- SegmentIntersector(algorithm::LineIntersector *newLi,
- bool newIncludeProper, bool newRecordIsolated)
- hasIntersectionVar(false),
- hasProper(false),
- hasProperInterior(false),
- isDone(false),
- isDoneWhenProperInt(false),
- li(newLi),
- includeProper(newIncludeProper),
- recordIsolated(newRecordIsolated),
- numIntersections(0),
- bdyNodes(2),
- numTests(0)
+ SegmentIntersector(algorithm::LineIntersector* newLi,
+ bool newIncludeProper, bool newRecordIsolated)
+ hasIntersectionVar(false),
+ hasProper(false),
+ hasProperInterior(false),
+ isDone(false),
+ isDoneWhenProperInt(false),
+ li(newLi),
+ includeProper(newIncludeProper),
+ recordIsolated(newRecordIsolated),
+ numIntersections(0),
+ bdyNodes(2),
+ numTests(0)
- /// \brief
- /// Parameters are externally owned.
- /// Make sure they live for the whole lifetime of this object
- void setBoundaryNodes(std::vector<Node*> *bdyNodes0,
- std::vector<Node*> *bdyNodes1);
+ /// \brief
+ /// Parameters are externally owned.
+ /// Make sure they live for the whole lifetime of this object
+ void setBoundaryNodes(std::vector<Node*>* bdyNodes0,
+ std::vector<Node*>* bdyNodes1);
- geom::Coordinate& getProperIntersectionPoint();
+ geom::Coordinate& getProperIntersectionPoint();
- bool hasIntersection();
+ bool hasIntersection();
- bool hasProperIntersection();
+ bool hasProperIntersection();
- bool hasProperInteriorIntersection();
+ bool hasProperInteriorIntersection();
- void addIntersections(Edge *e0, size_t segIndex0, Edge *e1, size_t segIndex1);
+ void addIntersections(Edge* e0, size_t segIndex0, Edge* e1, size_t segIndex1);
- void setIsDoneIfProperInt(bool isDoneWhenProperInt);
+ void setIsDoneIfProperInt(bool isDoneWhenProperInt);
- bool getIsDone();
+ bool getIsDone();
diff --git a/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h b/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
index 78d41ab..1cd1e32 100644
--- a/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
+++ b/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
@@ -23,12 +23,12 @@
namespace geos {
- class Edge;
- namespace index {
+class Edge;
+namespace index {
namespace geos {
@@ -39,19 +39,19 @@ class GEOS_DLL SimpleEdgeSetIntersector: public EdgeSetIntersector {
public:
- SimpleEdgeSetIntersector();
+ SimpleEdgeSetIntersector();
- void computeIntersections(std::vector<Edge*> *edges,
- SegmentIntersector *si, bool testAllSegments) override;
+ void computeIntersections(std::vector<Edge*>* edges,
+ SegmentIntersector* si, bool testAllSegments) override;
- void computeIntersections(std::vector<Edge*> *edges0,
- std::vector<Edge*> *edges1, SegmentIntersector *si) override;
+ void computeIntersections(std::vector<Edge*>* edges0,
+ std::vector<Edge*>* edges1, SegmentIntersector* si) override;
private:
- int nOverlaps;
+ int nOverlaps;
- void computeIntersects(Edge *e0, Edge *e1, SegmentIntersector *si);
+ void computeIntersects(Edge* e0, Edge* e1, SegmentIntersector* si);
} // namespace geos.geomgraph.index
diff --git a/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h b/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
index 4ebf526..4b3dcee 100644
--- a/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
+++ b/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
@@ -29,13 +29,13 @@
namespace geos {
- class Edge;
- namespace index {
- // class SegmentIntersector;
- class SweepLineEvent;
+class Edge;
+namespace index {
+// class SegmentIntersector;
+class SweepLineEvent;
namespace geos {
@@ -55,38 +55,38 @@ class GEOS_DLL SimpleMCSweepLineIntersector: public EdgeSetIntersector {
public:
- SimpleMCSweepLineIntersector();
+ SimpleMCSweepLineIntersector();
- ~SimpleMCSweepLineIntersector() override;
+ ~SimpleMCSweepLineIntersector() override;
- SegmentIntersector *si) override;
+ SegmentIntersector* si) override;
protected:
- std::vector<SweepLineEvent*> events;
+ std::vector<SweepLineEvent*> events;
- // statistics information
- int nOverlaps;
+ // statistics information
+ int nOverlaps;
private:
- void add(std::vector<Edge*> *edges);
+ void add(std::vector<Edge*>* edges);
- void add(std::vector<Edge*> *edges,void* edgeSet);
+ void add(std::vector<Edge*>* edges, void* edgeSet);
- void add(Edge *edge,void* edgeSet);
+ void add(Edge* edge, void* edgeSet);
- void prepareEvents();
+ void prepareEvents();
- void computeIntersections(SegmentIntersector *si);
+ void computeIntersections(SegmentIntersector* si);
- void processOverlaps(size_t start, size_t end,
- SweepLineEvent *ev0,
- SegmentIntersector *si);
+ void processOverlaps(size_t start, size_t end,
+ SweepLineEvent* ev0,
+ SegmentIntersector* si);
diff --git a/include/geos/geomgraph/index/SimpleSweepLineIntersector.h b/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
index 2e17652..61bb130 100644
--- a/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
+++ b/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
@@ -28,13 +28,13 @@
namespace geos {
- class Edge;
- namespace index {
+class Edge;
+namespace index {
namespace geos {
@@ -52,37 +52,37 @@ class GEOS_DLL SimpleSweepLineIntersector: public EdgeSetIntersector {
public:
- SimpleSweepLineIntersector();
+ SimpleSweepLineIntersector();
- ~SimpleSweepLineIntersector() override;
+ ~SimpleSweepLineIntersector() override;
- bool testAllSegments) override;
+ bool testAllSegments) override;
private:
- int nOverlaps;
+ int nOverlaps;
- void add(std::vector<Edge*> *edges, void* edgeSet);
- void processOverlaps(size_t start, size_t end, SweepLineEvent *ev0,
+ void processOverlaps(size_t start, size_t end, SweepLineEvent* ev0,
diff --git a/include/geos/geomgraph/index/SweepLineEvent.h b/include/geos/geomgraph/index/SweepLineEvent.h
index 854afe3..3f5c6ba 100644
--- a/include/geos/geomgraph/index/SweepLineEvent.h
+++ b/include/geos/geomgraph/index/SweepLineEvent.h
@@ -22,11 +22,11 @@
namespace geos {
- namespace index {
- class SweepLineEventOBJ;
+namespace index {
+class SweepLineEventOBJ;
namespace geos {
@@ -35,66 +35,95 @@ namespace index { // geos::geomgraph::index
//class SweepLineEventLessThen; // needed ??
-class GEOS_DLL SweepLineEvent{
-friend class SweepLineEventLessThen;
+class GEOS_DLL SweepLineEvent {
+ friend class SweepLineEventLessThen;
public:
- enum {
- INSERT_EVENT = 1,
- DELETE_EVENT
+ enum {
+ INSERT_EVENT = 1,
+ DELETE_EVENT
- SweepLineEvent(void* newEdgeSet, double x,
- SweepLineEvent *newInsertEvent,
- SweepLineEventOBJ *newObj);
+ SweepLineEvent(void* newEdgeSet, double x,
+ SweepLineEvent* newInsertEvent,
+ SweepLineEventOBJ* newObj);
- virtual ~SweepLineEvent();
+ virtual ~SweepLineEvent();
- bool isInsert() { return insertEvent==nullptr; }
+ bool
+ isInsert()
+ return insertEvent == nullptr;
- bool isDelete() { return insertEvent!=nullptr; }
+ bool
+ isDelete()
+ return insertEvent != nullptr;
- SweepLineEvent* getInsertEvent() { return insertEvent; }
+ SweepLineEvent*
+ getInsertEvent()
+ return insertEvent;
- size_t getDeleteEventIndex() { return deleteEventIndex; }
+ size_t
+ getDeleteEventIndex()
+ return deleteEventIndex;
- void setDeleteEventIndex(size_t newDeleteEventIndex) {
- deleteEventIndex=newDeleteEventIndex;
+ void
+ setDeleteEventIndex(size_t newDeleteEventIndex)
+ deleteEventIndex = newDeleteEventIndex;
- SweepLineEventOBJ* getObject() const { return obj; }
+ getObject() const
+ return obj;
- int compareTo(SweepLineEvent *sle);
+ int compareTo(SweepLineEvent* sle);
- std::string print();
+ std::string print();
- void* edgeSet; // used for red-blue intersection detection
+ void* edgeSet; // used for red-blue intersection detection
protected:
- SweepLineEventOBJ* obj;
+ SweepLineEventOBJ* obj;
private:
- double xValue;
+ double xValue;
- int eventType;
+ int eventType;
- SweepLineEvent *insertEvent; // null if this is an INSERT_EVENT event
+ SweepLineEvent* insertEvent; // null if this is an INSERT_EVENT event
- size_t deleteEventIndex;
+ size_t deleteEventIndex;
class GEOS_DLL SweepLineEventLessThen {
public:
- bool operator()(const SweepLineEvent *f, const SweepLineEvent *s) const
- if (f->xValue<s->xValue) return true;
- if (f->xValue>s->xValue) return false;
- if (f->eventType<s->eventType) return true;
- return false;
+ bool
+ operator()(const SweepLineEvent* f, const SweepLineEvent* s) const
+ if(f->xValue < s->xValue) {
+ return true;
+ if(f->xValue > s->xValue) {
+ return false;
+ if(f->eventType < s->eventType) {
+ return true;
+ return false;
diff --git a/include/geos/geomgraph/index/SweepLineEventObj.h b/include/geos/geomgraph/index/SweepLineEventObj.h
index 08b7989..c305e03 100644
--- a/include/geos/geomgraph/index/SweepLineEventObj.h
+++ b/include/geos/geomgraph/index/SweepLineEventObj.h
@@ -28,7 +28,8 @@ namespace index { // geos::geomgraph::index
// inherit from it.
class GEOS_DLL SweepLineEventOBJ {
public:
- virtual ~SweepLineEventOBJ(){}
+ virtual
+ ~SweepLineEventOBJ() {}
diff --git a/include/geos/geomgraph/index/SweepLineSegment.h b/include/geos/geomgraph/index/SweepLineSegment.h
index 6e4b5c3..5a91436 100644
--- a/include/geos/geomgraph/index/SweepLineSegment.h
+++ b/include/geos/geomgraph/index/SweepLineSegment.h
@@ -22,15 +22,15 @@
namespace geos {
- namespace geom {
- class CoordinateSequence;
- class Edge;
- namespace index {
+namespace geom {
+class CoordinateSequence;
+class Edge;
+namespace index {
namespace geos {
@@ -39,15 +39,15 @@ namespace index { // geos::geomgraph::index
class GEOS_DLL SweepLineSegment: public SweepLineEventOBJ {
public:
- SweepLineSegment(Edge *newEdge, size_t newPtIndex);
- ~SweepLineSegment() override;
- double getMinX();
- double getMaxX();
- void computeIntersections(SweepLineSegment *ss, SegmentIntersector *si);
+ SweepLineSegment(Edge* newEdge, size_t newPtIndex);
+ ~SweepLineSegment() override;
+ double getMinX();
+ double getMaxX();
+ void computeIntersections(SweepLineSegment* ss, SegmentIntersector* si);
protected:
- Edge *edge;
- size_t ptIndex;
+ Edge* edge;
+ size_t ptIndex;
diff --git a/include/geos/index/ItemVisitor.h b/include/geos/index/ItemVisitor.h
index f906fa3..fbd9402 100644
--- a/include/geos/index/ItemVisitor.h
+++ b/include/geos/index/ItemVisitor.h
@@ -28,9 +28,10 @@ namespace index {
class GEOS_DLL ItemVisitor {
public:
- virtual void visitItem(void *)=0;
+ virtual void visitItem(void*) = 0;
- virtual ~ItemVisitor() {}
+ virtual
+ ~ItemVisitor() {}
} // namespace geos.index
diff --git a/include/geos/index/SpatialIndex.h b/include/geos/index/SpatialIndex.h
index c74f93b..235e1b5 100644
--- a/include/geos/index/SpatialIndex.h
+++ b/include/geos/index/SpatialIndex.h
@@ -21,12 +21,12 @@
namespace geos {
- namespace geom {
- class Envelope;
- namespace index {
- class ItemVisitor;
+namespace geom {
+class Envelope;
+namespace index {
+class ItemVisitor;
namespace geos {
@@ -47,54 +47,55 @@ namespace index {
class GEOS_DLL SpatialIndex {
public:
- virtual ~SpatialIndex() {}
- /** \brief
- * Adds a spatial item with an extent specified by the given Envelope
- * to the index
- * @param itemEnv
- * Envelope of the item, ownership left to caller.
- * TODO: Reference hold by this class ?
- * @param item
- * Opaque item, ownership left to caller.
- * Reference hold by this class.
- virtual void insert(const geom::Envelope *itemEnv, void *item) = 0;
- /** \brief
- * Queries the index for all items whose extents intersect the given search Envelope
- * Note that some kinds of indexes may also return objects which do not in fact
- * intersect the query envelope.
- * @param searchEnv the envelope to query for
- * @return a list of the items found by the query in a newly allocated vector
- //virtual std::vector<void*>* query(const geom::Envelope *searchEnv)=0;
- virtual void query(const geom::Envelope* searchEnv, std::vector<void*>&) = 0;
- /** \brief
- * and applies an ItemVisitor to them.
- * @param visitor a visitor object to apply to the items found
- virtual void query(const geom::Envelope *searchEnv, ItemVisitor& visitor) = 0;
- /** \brief
- * Removes a single item from the tree.
- * @param itemEnv the Envelope of the item to remove
- * @param item the item to remove
- * @return <code>true</code> if the item was found
- virtual bool remove(const geom::Envelope* itemEnv, void* item) = 0;
+ virtual
+ ~SpatialIndex() {}
+ /** \brief
+ * Adds a spatial item with an extent specified by the given Envelope
+ * to the index
+ * @param itemEnv
+ * Envelope of the item, ownership left to caller.
+ * TODO: Reference hold by this class ?
+ * @param item
+ * Opaque item, ownership left to caller.
+ * Reference hold by this class.
+ virtual void insert(const geom::Envelope* itemEnv, void* item) = 0;
+ /** \brief
+ * Queries the index for all items whose extents intersect the given search Envelope
+ * Note that some kinds of indexes may also return objects which do not in fact
+ * intersect the query envelope.
+ * @param searchEnv the envelope to query for
+ * @return a list of the items found by the query in a newly allocated vector
+ //virtual std::vector<void*>* query(const geom::Envelope *searchEnv)=0;
+ virtual void query(const geom::Envelope* searchEnv, std::vector<void*>&) = 0;
+ /** \brief
+ * and applies an ItemVisitor to them.
+ * @param visitor a visitor object to apply to the items found
+ virtual void query(const geom::Envelope* searchEnv, ItemVisitor& visitor) = 0;
+ /** \brief
+ * Removes a single item from the tree.
+ * @param itemEnv the Envelope of the item to remove
+ * @param item the item to remove
+ * @return <code>true</code> if the item was found
+ virtual bool remove(const geom::Envelope* itemEnv, void* item) = 0;
diff --git a/include/geos/index/bintree/Bintree.h b/include/geos/index/bintree/Bintree.h
index 7f28602..10141a7 100644
--- a/include/geos/index/bintree/Bintree.h
+++ b/include/geos/index/bintree/Bintree.h
@@ -25,12 +25,12 @@
namespace geos {
- namespace index {
- namespace bintree {
- class Interval;
- class Root;
+namespace index {
+namespace bintree {
+class Interval;
+class Root;
namespace geos {
@@ -57,65 +57,65 @@ class GEOS_DLL Bintree {
public:
- * Ensure that the Interval for the inserted item has non-zero extents.
- * Use the current minExtent to pad it, if necessary
- * NOTE: in GEOS this function always return a newly allocated object
- * with ownership transferred to caller. TODO: change this ?
- * @param itemInterval
- * Source interval, ownership left to caller, no references hold.
- static Interval* ensureExtent(const Interval *itemInterval,
- double minExtent);
+ * Ensure that the Interval for the inserted item has non-zero extents.
+ * Use the current minExtent to pad it, if necessary
+ * NOTE: in GEOS this function always return a newly allocated object
+ * with ownership transferred to caller. TODO: change this ?
+ * @param itemInterval
+ * Source interval, ownership left to caller, no references hold.
+ static Interval* ensureExtent(const Interval* itemInterval,
+ double minExtent);
- Bintree();
+ Bintree();
- ~Bintree();
+ ~Bintree();
- int depth();
+ int depth();
- int size();
+ int size();
- int nodeSize();
+ int nodeSize();
- /// @param itemInterval
- /// Ownership left to caller, NO reference hold by this class.
- /// @param item
- /// Ownership left to caller, reference kept by this class.
- void insert(Interval *itemInterval, void* item);
+ /// @param itemInterval
+ /// Ownership left to caller, NO reference hold by this class.
+ /// @param item
+ /// Ownership left to caller, reference kept by this class.
+ void insert(Interval* itemInterval, void* item);
- std::vector<void*>* iterator();
+ std::vector<void*>* iterator();
- std::vector<void*>* query(double x);
+ std::vector<void*>* query(double x);
- std::vector<void*>* query(Interval *interval);
+ std::vector<void*>* query(Interval* interval);
- void query(Interval *interval,
- std::vector<void*> *foundItems);
+ void query(Interval* interval,
+ std::vector<void*>* foundItems);
private:
- std::vector<Interval *>newIntervals;
+ std::vector<Interval*>newIntervals;
- Root *root;
+ Root* root;
- * Statistics
- * minExtent is the minimum extent of all items
- * inserted into the tree so far. It is used as a heuristic value
- * to construct non-zero extents for features with zero extent.
- * Start with a non-zero extent, in case the first feature inserted has
- * a zero extent in both directions. This value may be non-optimal, but
- * only one feature will be inserted with this value.
- double minExtent;
+ * Statistics
+ * minExtent is the minimum extent of all items
+ * inserted into the tree so far. It is used as a heuristic value
+ * to construct non-zero extents for features with zero extent.
+ * Start with a non-zero extent, in case the first feature inserted has
+ * a zero extent in both directions. This value may be non-optimal, but
+ * only one feature will be inserted with this value.
+ double minExtent;
- void collectStats(Interval *interval);
+ void collectStats(Interval* interval);
} // namespace geos::index::bintree
diff --git a/include/geos/index/bintree/Interval.h b/include/geos/index/bintree/Interval.h
index 1e4b5d8..f3b717c 100644
--- a/include/geos/index/bintree/Interval.h
+++ b/include/geos/index/bintree/Interval.h
@@ -26,36 +26,36 @@ class GEOS_DLL Interval {
public:
- double min, max;
+ double min, max;
- Interval();
+ Interval();
- ~Interval();
+ ~Interval();
- Interval(double nmin, double nmax);
+ Interval(double nmin, double nmax);
- /// TODO: drop this, rely on copy ctor
- Interval(const Interval *interval);
+ /// TODO: drop this, rely on copy ctor
+ Interval(const Interval* interval);
- void init(double nmin, double nmax);
+ void init(double nmin, double nmax);
- double getMin() const;
+ double getMin() const;
- double getMax() const;
+ double getMax() const;
- double getWidth() const;
+ double getWidth() const;
- void expandToInclude(Interval *interval);
+ void expandToInclude(Interval* interval);
- bool overlaps(const Interval *interval) const;
+ bool overlaps(const Interval* interval) const;
- bool overlaps(double nmin, double nmax) const;
+ bool overlaps(double nmin, double nmax) const;
- bool contains(const Interval *interval) const;
+ bool contains(const Interval* interval) const;
- bool contains(double nmin, double nmax) const;
+ bool contains(double nmin, double nmax) const;
- bool contains(double p) const;
+ bool contains(double p) const;
diff --git a/include/geos/index/bintree/Key.h b/include/geos/index/bintree/Key.h
index 6949d77..3a29110 100644
--- a/include/geos/index/bintree/Key.h
+++ b/include/geos/index/bintree/Key.h
@@ -19,11 +19,11 @@
namespace geos {
- namespace index {
- class Interval;
+namespace index {
+class Interval;
namespace geos {
@@ -40,30 +40,30 @@ class GEOS_DLL Key {
public:
- static int computeLevel(Interval *newInterval);
+ static int computeLevel(Interval* newInterval);
- Key(Interval *newInterval);
+ Key(Interval* newInterval);
- ~Key();
+ ~Key();
- double getPoint();
+ double getPoint();
- int getLevel();
+ int getLevel();
- Interval* getInterval();
+ Interval* getInterval();
- void computeKey(Interval *itemInterval);
+ void computeKey(Interval* itemInterval);
private:
- // the fields which make up the key
- double pt;
- int level;
+ // the fields which make up the key
+ double pt;
+ int level;
- // auxiliary data which is derived from the key for use in computation
- Interval *interval;
+ // auxiliary data which is derived from the key for use in computation
+ Interval* interval;
- void computeInterval(int level, Interval *itemInterval);
+ void computeInterval(int level, Interval* itemInterval);
diff --git a/include/geos/index/bintree/Node.h b/include/geos/index/bintree/Node.h
index 8e92a49..d32bfdc 100644
--- a/include/geos/index/bintree/Node.h
+++ b/include/geos/index/bintree/Node.h
@@ -20,11 +20,11 @@
namespace geos {
- namespace index {
- class Interval;
+namespace index {
+class Interval;
namespace geos {
@@ -36,37 +36,37 @@ class GEOS_DLL Node: public NodeBase {
public:
- static Node* createNode(Interval *itemInterval);
+ static Node* createNode(Interval* itemInterval);
- static Node* createExpanded(Node *node,Interval *addInterval);
+ static Node* createExpanded(Node* node, Interval* addInterval);
- Node(Interval *newInterval,int newLevel);
+ Node(Interval* newInterval, int newLevel);
- ~Node() override;
+ ~Node() override;
- Node* getNode(Interval *searchInterval);
+ Node* getNode(Interval* searchInterval);
- NodeBase* find(Interval *searchInterval);
+ NodeBase* find(Interval* searchInterval);
- void insert(Node *node);
+ void insert(Node* node);
private:
- double centre;
+ double centre;
- int level;
+ int level;
- Node* getSubnode(int index);
+ Node* getSubnode(int index);
- Node* createSubnode(int index);
+ Node* createSubnode(int index);
protected:
- bool isSearchMatch(Interval *itemInterval) override;
+ bool isSearchMatch(Interval* itemInterval) override;
diff --git a/include/geos/index/bintree/NodeBase.h b/include/geos/index/bintree/NodeBase.h
index 43578ed..b4f0d2b 100644
--- a/include/geos/index/bintree/NodeBase.h
+++ b/include/geos/index/bintree/NodeBase.h
@@ -20,12 +20,12 @@
namespace geos {
- namespace index {
- class Node;
- class Interval;
+namespace index {
+class Node;
+class Interval;
namespace geos {
@@ -37,39 +37,39 @@ class GEOS_DLL NodeBase {
public:
- static int getSubnodeIndex(Interval *interval, double centre);
+ static int getSubnodeIndex(Interval* interval, double centre);
- NodeBase();
+ NodeBase();
- virtual ~NodeBase();
+ virtual ~NodeBase();
- virtual std::vector<void*> *getItems();
+ virtual std::vector<void*>* getItems();
- virtual void add(void* item);
+ virtual void add(void* item);
- virtual std::vector<void*>* addAllItems(std::vector<void*> *newItems);
+ virtual std::vector<void*>* addAllItems(std::vector<void*>* newItems);
- virtual std::vector<void*>* addAllItemsFromOverlapping(Interval *interval,
- std::vector<void*> *resultItems);
+ virtual std::vector<void*>* addAllItemsFromOverlapping(Interval* interval,
+ std::vector<void*>* resultItems);
- virtual int depth();
+ virtual int depth();
- virtual int size();
+ virtual int size();
- virtual int nodeSize();
+ virtual int nodeSize();
protected:
- std::vector<void*>* items;
+ std::vector<void*>* items;
- * subnodes are numbered as follows:
- * 0 | 1
- Node* subnode[2];
+ * subnodes are numbered as follows:
+ * 0 | 1
+ Node* subnode[2];
- virtual bool isSearchMatch(Interval *interval)=0;
+ virtual bool isSearchMatch(Interval* interval) = 0;
diff --git a/include/geos/index/bintree/Root.h b/include/geos/index/bintree/Root.h
index ec90980..2f2ef2b 100644
--- a/include/geos/index/bintree/Root.h
+++ b/include/geos/index/bintree/Root.h
@@ -20,12 +20,12 @@
namespace geos {
- namespace index {
- class Interval;
- class Node;
+namespace index {
+class Interval;
+class Node;
namespace geos {
@@ -42,30 +42,34 @@ class GEOS_DLL Root: public NodeBase {
private:
- // the singleton root node is centred at the origin.
- static double origin;
+ // the singleton root node is centred at the origin.
+ static double origin;
- void insertContained(Node *tree,
- Interval *itemInterval,
- void* item);
+ void insertContained(Node* tree,
+ Interval* itemInterval,
+ void* item);
public:
- Root() {}
+ Root() {}
- ~Root() override {}
+ ~Root() override {}
- /// Ownership left to caller, references kept in this class.
- /// @param item
+ /// Ownership left to caller, references kept in this class.
+ /// @param item
protected:
- bool isSearchMatch(Interval* /*interval*/) override { return true; }
+ bool
+ isSearchMatch(Interval* /*interval*/) override
+ return true;
diff --git a/include/geos/index/chain/MonotoneChain.h b/include/geos/index/chain/MonotoneChain.h
index af17385..bab26a5 100644
--- a/include/geos/index/chain/MonotoneChain.h
+++ b/include/geos/index/chain/MonotoneChain.h
@@ -26,17 +26,17 @@
namespace geos {
- namespace geom {
- class Envelope;
- class LineSegment;
- namespace index {
- namespace chain {
- class MonotoneChainSelectAction;
- class MonotoneChainOverlapAction;
+namespace geom {
+class Envelope;
+class LineSegment;
+namespace index {
+namespace chain {
+class MonotoneChainSelectAction;
+class MonotoneChainOverlapAction;
namespace geos {
@@ -82,91 +82,110 @@ namespace chain { // geos::index::chain
* However, it does mean that the queries are not thread-safe.
+class GEOS_DLL MonotoneChain {
public:
- /// @param pts
- /// Ownership left to caller, this class holds a reference.
- /// @param start
- /// @param end
- /// @param context
- MonotoneChain(const geom::CoordinateSequence& pts,
+ /// @param pts
+ /// Ownership left to caller, this class holds a reference.
+ /// @param start
+ /// @param end
+ /// @param context
+ MonotoneChain(const geom::CoordinateSequence& pts,
std::size_t start, std::size_t end, void* context);
- ~MonotoneChain();
- /// Returned envelope is owned by this class
- const geom::Envelope& getEnvelope() const;
- size_t getStartIndex() const { return start; }
- size_t getEndIndex() const { return end; }
- /** \brief
- * Set given LineSegment with points of the segment starting
- * at the given index.
- void getLineSegment(std::size_t index, geom::LineSegment& ls) const;
- * Return the subsequence of coordinates forming this chain.
- * Allocates a new CoordinateSequence to hold the Coordinates
- std::unique_ptr<geom::CoordinateSequence> getCoordinates() const;
- * Determine all the line segments in the chain whose envelopes overlap
- * the searchEnvelope, and process them
- void select(const geom::Envelope& searchEnv,
- MonotoneChainSelectAction& mcs);
- void computeOverlaps(MonotoneChain *mc,
- MonotoneChainOverlapAction *mco);
- void setId(int nId) { id=nId; }
- inline int getId() const { return id; }
- void* getContext() { return context; }
+ ~MonotoneChain();
+ /// Returned envelope is owned by this class
+ const geom::Envelope& getEnvelope() const;
+ size_t
+ getStartIndex() const
+ return start;
+ size_t
+ getEndIndex() const
+ return end;
+ /** \brief
+ * Set given LineSegment with points of the segment starting
+ * at the given index.
+ void getLineSegment(std::size_t index, geom::LineSegment& ls) const;
+ * Return the subsequence of coordinates forming this chain.
+ * Allocates a new CoordinateSequence to hold the Coordinates
+ std::unique_ptr<geom::CoordinateSequence> getCoordinates() const;
+ * Determine all the line segments in the chain whose envelopes overlap
+ * the searchEnvelope, and process them
+ void select(const geom::Envelope& searchEnv,
+ MonotoneChainSelectAction& mcs);
+ void computeOverlaps(MonotoneChain* mc,
+ MonotoneChainOverlapAction* mco);
+ void
+ setId(int nId)
+ id = nId;
+ inline int
+ getId() const
+ return id;
+ void*
+ getContext()
+ return context;
private:
- void computeSelect(const geom::Envelope& searchEnv,
- size_t start0,
- size_t end0,
+ void computeSelect(const geom::Envelope& searchEnv,
+ size_t start0,
+ size_t end0,
- void computeOverlaps(std::size_t start0, std::size_t end0, MonotoneChain& mc,
- std::size_t start1, std::size_t end1,
- MonotoneChainOverlapAction& mco);
+ void computeOverlaps(std::size_t start0, std::size_t end0, MonotoneChain& mc,
+ std::size_t start1, std::size_t end1,
+ MonotoneChainOverlapAction& mco);
bool overlaps(size_t start0, size_t end0, const MonotoneChain& mc, int start1, size_t end1);
- /// Externally owned
- const geom::CoordinateSequence& pts;
+ /// Externally owned
+ const geom::CoordinateSequence& pts;
- /// Owned by this class, lazely created
- mutable geom::Envelope* env;
+ /// Owned by this class, lazely created
+ mutable geom::Envelope* env;
- /// user-defined information
- void* context;
+ /// user-defined information
+ void* context;
- /// Index of chain start vertex into the CoordinateSequence, 0 based.
- size_t start;
+ /// Index of chain start vertex into the CoordinateSequence, 0 based.
+ size_t start;
- /// Index of chain end vertex into the CoordinateSequence, 0 based.
- size_t end;
+ /// Index of chain end vertex into the CoordinateSequence, 0 based.
+ size_t end;
- /// useful for optimizing chain comparisons
- int id;
+ /// useful for optimizing chain comparisons
+ int id;
// Declare type as noncopyable
MonotoneChain(const MonotoneChain& other) = delete;
diff --git a/include/geos/index/chain/MonotoneChainBuilder.h b/include/geos/index/chain/MonotoneChainBuilder.h
index d5e752e..bcd14fe 100644
--- a/include/geos/index/chain/MonotoneChainBuilder.h
+++ b/include/geos/index/chain/MonotoneChainBuilder.h
@@ -26,14 +26,14 @@
namespace geos {
- namespace geom {
- namespace index {
- namespace chain {
- class MonotoneChain;
+namespace geom {
+namespace index {
+namespace chain {
+class MonotoneChain;
namespace geos {
@@ -50,64 +50,65 @@ class GEOS_DLL MonotoneChainBuilder {
public:
- MonotoneChainBuilder(){}
- /** \brief
- * Return a newly-allocated vector of newly-allocated
- * MonotoneChain objects for the given CoordinateSequence.
- * Remember to deep-delete the result.
- static std::unique_ptr<std::vector<std::unique_ptr<MonotoneChain>>> getChains(
- const geom::CoordinateSequence *pts,
- void* context);
- /** \brief
- * Fill the provided vector with newly-allocated MonotoneChain objects
- * for the given CoordinateSequence.
- * Remember to delete vector elements!
- static void getChains(const geom::CoordinateSequence *pts,
- void* context,
- std::vector<std::unique_ptr<MonotoneChain>> & mcList);
- static std::unique_ptr<std::vector<std::unique_ptr<MonotoneChain>>> getChains(const geom::CoordinateSequence *pts)
- return getChains(pts, nullptr);
- /** \brief
- * Fill the given vector with start/end indexes of the monotone chains
- * The last entry in the array points to the end point of the point
- * array,
- * for use as a sentinel.
- static void getChainStartIndices(const geom::CoordinateSequence& pts,
- std::vector<std::size_t>& startIndexList);
+ MonotoneChainBuilder() {}
+ /** \brief
+ * Return a newly-allocated vector of newly-allocated
+ * MonotoneChain objects for the given CoordinateSequence.
+ * Remember to deep-delete the result.
+ static std::unique_ptr<std::vector<std::unique_ptr<MonotoneChain>>> getChains(
+ const geom::CoordinateSequence* pts,
+ void* context);
+ /** \brief
+ * Fill the provided vector with newly-allocated MonotoneChain objects
+ * for the given CoordinateSequence.
+ * Remember to delete vector elements!
+ static void getChains(const geom::CoordinateSequence* pts,
+ void* context,
+ std::vector<std::unique_ptr<MonotoneChain>>& mcList);
+ getChains(const geom::CoordinateSequence* pts)
+ return getChains(pts, nullptr);
+ /** \brief
+ * Fill the given vector with start/end indexes of the monotone chains
+ * The last entry in the array points to the end point of the point
+ * array,
+ * for use as a sentinel.
+ static void getChainStartIndices(const geom::CoordinateSequence& pts,
+ std::vector<std::size_t>& startIndexList);
* Disable copy construction and assignment. Apparently needed to make this
* class compile under MSVC. (See https://stackoverflow.com/q/29565299)
- MonotoneChainBuilder(const MonotoneChainBuilder&) = delete;
- MonotoneChainBuilder& operator=(const MonotoneChainBuilder&) = delete;
+ MonotoneChainBuilder(const MonotoneChainBuilder&) = delete;
+ MonotoneChainBuilder& operator=(const MonotoneChainBuilder&) = delete;
private:
- * Finds the index of the last point in a monotone chain
- * starting at a given point.
- * Any repeated points (0-length segments) will be included
- * in the monotone chain returned.
- * @return the index of the last point in the monotone chain
- * starting at <code>start</code>.
- * NOTE: aborts if 'start' is >= pts.getSize()
- static std::size_t findChainEnd(const geom::CoordinateSequence& pts,
- std::size_t start);
+ * Finds the index of the last point in a monotone chain
+ * starting at a given point.
+ * Any repeated points (0-length segments) will be included
+ * in the monotone chain returned.
+ * @return the index of the last point in the monotone chain
+ * starting at <code>start</code>.
+ * NOTE: aborts if 'start' is >= pts.getSize()
+ static std::size_t findChainEnd(const geom::CoordinateSequence& pts,
+ std::size_t start);
} // namespace geos::index::chain
diff --git a/include/geos/index/chain/MonotoneChainOverlapAction.h b/include/geos/index/chain/MonotoneChainOverlapAction.h
index c9767c9..893e3be 100644
--- a/include/geos/index/chain/MonotoneChainOverlapAction.h
+++ b/include/geos/index/chain/MonotoneChainOverlapAction.h
@@ -25,11 +25,11 @@
namespace geos {
- namespace index {
- namespace chain {
+namespace index {
+namespace chain {
namespace geos {
@@ -44,36 +44,38 @@ class GEOS_DLL MonotoneChainOverlapAction {
protected:
- geom::LineSegment overlapSeg1;
+ geom::LineSegment overlapSeg1;
- geom::LineSegment overlapSeg2;
+ geom::LineSegment overlapSeg2;
public:
- MonotoneChainOverlapAction() {}
- virtual ~MonotoneChainOverlapAction() {}
- * This function can be overridden if the original chains are needed
- * @param start1 the index of the start of the overlapping segment
- * from mc1
- * @param start2 the index of the start of the overlapping segment
- * from mc2
- virtual void overlap(MonotoneChain& mc1, std::size_t start1,
- MonotoneChain& mc2, std::size_t start2);
- * This is a convenience function which can be overridden to
- * obtain the actual line segments which overlap
- * @param seg1
- * @param seg2
- virtual void overlap(const geom::LineSegment& /*seg1*/,
- const geom::LineSegment& /*seg2*/)
+ MonotoneChainOverlapAction() {}
+ virtual
+ ~MonotoneChainOverlapAction() {}
+ * This function can be overridden if the original chains are needed
+ * @param start1 the index of the start of the overlapping segment
+ * from mc1
+ * @param start2 the index of the start of the overlapping segment
+ * from mc2
+ virtual void overlap(MonotoneChain& mc1, std::size_t start1,
+ MonotoneChain& mc2, std::size_t start2);
+ * This is a convenience function which can be overridden to
+ * obtain the actual line segments which overlap
+ * @param seg1
+ * @param seg2
+ virtual void
+ overlap(const geom::LineSegment& /*seg1*/,
+ const geom::LineSegment& /*seg2*/)
diff --git a/include/geos/index/chain/MonotoneChainSelectAction.h b/include/geos/index/chain/MonotoneChainSelectAction.h
index 49bec11..eb7b491 100644
--- a/include/geos/index/chain/MonotoneChainSelectAction.h
+++ b/include/geos/index/chain/MonotoneChainSelectAction.h
@@ -26,11 +26,11 @@
namespace geos {
- namespace index {
- namespace chain {
+namespace index {
+namespace chain {
namespace geos {
@@ -46,24 +46,25 @@ class GEOS_DLL MonotoneChainSelectAction {
protected:
- geom::LineSegment selectedSegment;
+ geom::LineSegment selectedSegment;
public:
- MonotoneChainSelectAction() {}
+ MonotoneChainSelectAction() {}
- virtual ~MonotoneChainSelectAction() {}
+ virtual
+ ~MonotoneChainSelectAction() {}
- /// This function can be overridden if the original chain is needed
- virtual void select(MonotoneChain& mc, size_t start);
+ /// This function can be overridden if the original chain is needed
+ virtual void select(MonotoneChain& mc, size_t start);
- * to obtain the actual line segment which is selected
- * @param seg
- virtual void select(const geom::LineSegment& seg) = 0;
+ * to obtain the actual line segment which is selected
+ * @param seg
+ virtual void select(const geom::LineSegment& seg) = 0;
diff --git a/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h b/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h
index ef7677f..0b7aeba 100644
--- a/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h
+++ b/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h
@@ -22,9 +22,9 @@
// forward declarations
namespace geos {
- namespace index {
+namespace index {
+class ItemVisitor;
@@ -32,21 +32,20 @@ namespace geos {
namespace index {
namespace intervalrtree {
-class IntervalRTreeBranchNode : public IntervalRTreeNode
+class IntervalRTreeBranchNode : public IntervalRTreeNode {
private:
- const IntervalRTreeNode * node1;
- const IntervalRTreeNode * node2;
+ const IntervalRTreeNode* node1;
+ const IntervalRTreeNode* node2;
protected:
public:
- IntervalRTreeBranchNode( const IntervalRTreeNode * n1, const IntervalRTreeNode * n2)
- : IntervalRTreeNode( std::min( n1->getMin(), n2->getMin()), std::max( n1->getMax(), n2->getMax())),
- node1( n1),
- node2( n2)
+ IntervalRTreeBranchNode(const IntervalRTreeNode* n1, const IntervalRTreeNode* n2)
+ : IntervalRTreeNode(std::min(n1->getMin(), n2->getMin()), std::max(n1->getMax(), n2->getMax())),
+ node1(n1),
+ node2(n2)
- void query(double queryMin, double queryMax, index::ItemVisitor * visitor) const override;
+ void query(double queryMin, double queryMax, index::ItemVisitor* visitor) const override;
} // geos::intervalrtree
diff --git a/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h b/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
index b190377..3af6411 100644
--- a/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
+++ b/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
@@ -22,9 +22,9 @@
namespace geos {
- namespace index {
+namespace index {
+class ItemVisitor;
@@ -32,26 +32,25 @@ namespace geos {
namespace index {
-class IntervalRTreeLeafNode : public IntervalRTreeNode
+class IntervalRTreeLeafNode : public IntervalRTreeNode {
private:
- /// externally owned
- void * item;
+ /// externally owned
+ void* item;
protected:
public:
- /// @param item externally owned
- IntervalRTreeLeafNode( double p_min, double p_max, void * p_item)
- : IntervalRTreeNode( p_min, p_max),
- item( p_item)
+ /// @param item externally owned
+ IntervalRTreeLeafNode(double p_min, double p_max, void* p_item)
+ : IntervalRTreeNode(p_min, p_max),
+ item(p_item)
- ~IntervalRTreeLeafNode() override
+ ~IntervalRTreeLeafNode() override
- void query( double queryMin, double queryMax, index::ItemVisitor * visitor) const override;
diff --git a/include/geos/index/intervalrtree/IntervalRTreeNode.h b/include/geos/index/intervalrtree/IntervalRTreeNode.h
index 1dfa07b..6f8bbb7 100644
--- a/include/geos/index/intervalrtree/IntervalRTreeNode.h
+++ b/include/geos/index/intervalrtree/IntervalRTreeNode.h
@@ -22,9 +22,9 @@
namespace geos {
- namespace index {
+namespace index {
+class ItemVisitor;
@@ -32,66 +32,71 @@ namespace geos {
namespace index {
-class IntervalRTreeNode
+class IntervalRTreeNode {
private:
protected:
- double min;
- double max;
+ double min;
+ double max;
- bool intersects( double queryMin, double queryMax) const
- if (min > queryMax || max < queryMin)
- return false;
+ bool
+ intersects(double queryMin, double queryMax) const
+ if(min > queryMax || max < queryMin) {
+ return false;
- return true;
+ return true;
public:
- typedef std::vector<const IntervalRTreeNode *> ConstVect;
- IntervalRTreeNode()
- : min( DoubleInfinity ),
- max( DoubleNegInfinity )
- IntervalRTreeNode( double p_min, double p_max)
- : min( p_min ),
- max( p_max )
- virtual ~IntervalRTreeNode()
- return min;
- return max;
- virtual void query( double queryMin, double queryMax, ItemVisitor * visitor) const =0;
- //std::string toString()
- // return WKTWriter.toLineString(new Coordinate(min, 0), new Coordinate(max, 0));
- //class NodeComparator
- //public:
- static bool compare( const IntervalRTreeNode * n1, const IntervalRTreeNode * n2)
- double mid1 = n1->getMin() + n1->getMax();
- double mid2 = n2->getMin() + n2->getMax();
- return mid1 > mid2;
+ typedef std::vector<const IntervalRTreeNode*> ConstVect;
+ IntervalRTreeNode()
+ : min(DoubleInfinity),
+ max(DoubleNegInfinity)
+ IntervalRTreeNode(double p_min, double p_max)
+ : min(p_min),
+ max(p_max)
+ virtual
+ ~IntervalRTreeNode()
+ double
+ getMin() const
+ return min;
+ double
+ getMax() const
+ return max;
+ virtual void query(double queryMin, double queryMax, ItemVisitor* visitor) const = 0;
+ //std::string toString()
+ // return WKTWriter.toLineString(new Coordinate(min, 0), new Coordinate(max, 0));
+ //class NodeComparator
+ //public:
+ static bool
+ compare(const IntervalRTreeNode* n1, const IntervalRTreeNode* n2)
+ double mid1 = n1->getMin() + n1->getMax();
+ double mid2 = n2->getMin() + n2->getMax();
+ return mid1 > mid2;
diff --git a/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h b/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
index ea8b3f4..2aab524 100644
--- a/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
+++ b/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
@@ -22,9 +22,9 @@
namespace geos {
- namespace index {
+namespace index {
+class ItemVisitor;
namespace geos {
@@ -48,44 +48,46 @@ namespace intervalrtree {
* @author Martin Davis
-class SortedPackedIntervalRTree
+class SortedPackedIntervalRTree {
private:
- std::vector<IntervalRTreeLeafNode> leaves;
- std::vector<IntervalRTreeBranchNode> branches;
- const IntervalRTreeNode * root = nullptr;
- int level = 0;
+ std::vector<IntervalRTreeLeafNode> leaves;
+ std::vector<IntervalRTreeBranchNode> branches;
+ const IntervalRTreeNode* root = nullptr;
+ int level = 0;
- void init();
- void buildLevel( IntervalRTreeNode::ConstVect & src, IntervalRTreeNode::ConstVect & dest);
- const IntervalRTreeNode * buildTree();
+ void init();
+ void buildLevel(IntervalRTreeNode::ConstVect& src, IntervalRTreeNode::ConstVect& dest);
+ const IntervalRTreeNode* buildTree();
protected:
public:
- SortedPackedIntervalRTree() {}
+ SortedPackedIntervalRTree() {}
- SortedPackedIntervalRTree(std::size_t initialCapacity) { leaves.reserve(initialCapacity); }
+ SortedPackedIntervalRTree(std::size_t initialCapacity)
+ leaves.reserve(initialCapacity);
- * Adds an item to the index which is associated with the given interval
- * @param min the lower bound of the item interval
- * @param max the upper bound of the item interval
- * @param item the item to insert, ownership left to caller
- * @throw IllegalStateException if the index has already been queried
- void insert( double min, double max, void * item);
+ * Adds an item to the index which is associated with the given interval
+ * @param min the lower bound of the item interval
+ * @param max the upper bound of the item interval
+ * @param item the item to insert, ownership left to caller
+ * @throw IllegalStateException if the index has already been queried
+ void insert(double min, double max, void* item);
- * Search for intervals in the index which intersect the given closed interval
- * and apply the visitor to them.
- * @param min the lower bound of the query interval
- * @param max the upper bound of the query interval
- * @param visitor the visitor to pass any matched items to
- void query( double min, double max, index::ItemVisitor * visitor);
+ * Search for intervals in the index which intersect the given closed interval
+ * and apply the visitor to them.
+ * @param min the lower bound of the query interval
+ * @param max the upper bound of the query interval
+ * @param visitor the visitor to pass any matched items to
+ void query(double min, double max, index::ItemVisitor* visitor);
diff --git a/include/geos/index/quadtree/DoubleBits.h b/include/geos/index/quadtree/DoubleBits.h
index 6972a98..4fa3351 100644
--- a/include/geos/index/quadtree/DoubleBits.h
+++ b/include/geos/index/quadtree/DoubleBits.h
@@ -45,54 +45,54 @@ class GEOS_DLL DoubleBits {
public:
- static const int EXPONENT_BIAS=1023;
+ static const int EXPONENT_BIAS = 1023;
- static double powerOf2(int exp);
+ static double powerOf2(int exp);
- static int exponent(double d);
+ static int exponent(double d);
- static double truncateToPowerOfTwo(double d);
+ static double truncateToPowerOfTwo(double d);
- static std::string toBinaryString(double d);
+ static std::string toBinaryString(double d);
- static double maximumCommonMantissa(double d1, double d2);
+ static double maximumCommonMantissa(double d1, double d2);
- DoubleBits(double nx);
+ DoubleBits(double nx);
- double getDouble() const;
+ double getDouble() const;
- /// Determines the exponent for the number
- int64 biasedExponent() const;
+ /// Determines the exponent for the number
+ int64 biasedExponent() const;
- int getExponent() const;
+ int getExponent() const;
- void zeroLowerBits(int nBits);
+ void zeroLowerBits(int nBits);
- int getBit(int i) const;
+ int getBit(int i) const;
- /** \brief
- * This computes the number of common most-significant bits in
- * the mantissa.
- * It does not count the hidden bit, which is always 1.
- * It does not determine whether the numbers have the same exponent;
- * if they do not, the value computed by this function is meaningless.
- * @param db
- * @return the number of common most-significant mantissa bits
- int numCommonMantissaBits(const DoubleBits& db) const;
+ /** \brief
+ * This computes the number of common most-significant bits in
+ * the mantissa.
+ * It does not count the hidden bit, which is always 1.
+ * It does not determine whether the numbers have the same exponent;
+ * if they do not, the value computed by this function is meaningless.
+ * @param db
+ * @return the number of common most-significant mantissa bits
+ int numCommonMantissaBits(const DoubleBits& db) const;
- /// A representation of the Double bits formatted for easy readability
- std::string toString() const;
+ /// A representation of the Double bits formatted for easy readability
+ std::string toString() const;
private:
- double x;
+ double x;
- int64 xBits;
+ int64 xBits;
} // namespace geos::index::quadtree
diff --git a/include/geos/index/quadtree/IntervalSize.h b/include/geos/index/quadtree/IntervalSize.h
index 698dcfb..edc7ad8 100644
--- a/include/geos/index/quadtree/IntervalSize.h
+++ b/include/geos/index/quadtree/IntervalSize.h
@@ -40,21 +40,21 @@ namespace quadtree { // geos::index::quadtree
class GEOS_DLL IntervalSize {
public:
- * This value is chosen to be a few powers of 2 less than the
- * number of bits available in the double representation (i.e. 53).
- * This should allow enough extra precision for simple computations
- * to be correct, at least for comparison purposes.
- static const int MIN_BINARY_EXPONENT = -50;
+ * This value is chosen to be a few powers of 2 less than the
+ * number of bits available in the double representation (i.e. 53).
+ * This should allow enough extra precision for simple computations
+ * to be correct, at least for comparison purposes.
+ static const int MIN_BINARY_EXPONENT = -50;
- * Computes whether the interval [min, max] is effectively zero width.
- * I.e. the width of the interval is so much less than the
- * location of the interval that the midpoint of the interval
- * cannot be represented precisely.
- static bool isZeroWidth(double min, double max);
+ * Computes whether the interval [min, max] is effectively zero width.
+ * I.e. the width of the interval is so much less than the
+ * location of the interval that the midpoint of the interval
+ * cannot be represented precisely.
+ static bool isZeroWidth(double min, double max);
diff --git a/include/geos/index/quadtree/Key.h b/include/geos/index/quadtree/Key.h
index a862c03..f003864 100644
--- a/include/geos/index/quadtree/Key.h
+++ b/include/geos/index/quadtree/Key.h
@@ -42,44 +42,44 @@ namespace quadtree { // geos::index::quadtree
public:
- // Doesn't touch the Envelope, might as well be const
- static int computeQuadLevel(const geom::Envelope& env);
+ // Doesn't touch the Envelope, might as well be const
+ static int computeQuadLevel(const geom::Envelope& env);
- // Reference to argument won't be used after construction
- Key(const geom::Envelope& itemEnv);
+ // Reference to argument won't be used after construction
+ Key(const geom::Envelope& itemEnv);
- // used to be virtual, but I don't see subclasses...
- ~Key();
+ // used to be virtual, but I don't see subclasses...
+ ~Key();
- /// Returned object ownership retained by this class
- const geom::Coordinate& getPoint() const;
+ /// Returned object ownership retained by this class
+ const geom::Coordinate& getPoint() const;
- int getLevel() const;
+ int getLevel() const;
- /// Returns newly allocated object (ownership transferred)
- geom::Coordinate* getCentre() const;
+ /// Returns newly allocated object (ownership transferred)
+ geom::Coordinate* getCentre() const;
- * return a square envelope containing the argument envelope,
- * whose extent is a power of two and which is based at a power of 2
- void computeKey(const geom::Envelope& itemEnv);
+ * return a square envelope containing the argument envelope,
+ * whose extent is a power of two and which is based at a power of 2
+ void computeKey(const geom::Envelope& itemEnv);
private:
- // Owned by this class
- geom::Coordinate pt;
+ // Owned by this class
+ geom::Coordinate pt;
- int level;
+ int level;
- geom::Envelope env;
+ geom::Envelope env;
- void computeKey(int level, const geom::Envelope& itemEnv);
+ void computeKey(int level, const geom::Envelope& itemEnv);
diff --git a/include/geos/index/quadtree/Node.h b/include/geos/index/quadtree/Node.h
index 5b01f50..afcd63d 100644
--- a/include/geos/index/quadtree/Node.h
+++ b/include/geos/index/quadtree/Node.h
@@ -34,10 +34,10 @@
// Forward declarations
namespace geos {
- namespace geom {
- //class Coordinate;
- class Envelope;
+namespace geom {
+//class Coordinate;
+class Envelope;
namespace geos {
@@ -56,73 +56,79 @@ class GEOS_DLL Node: public NodeBase {
private:
- std::unique_ptr<geom::Envelope> env;
+ std::unique_ptr<geom::Envelope> env;
- geom::Coordinate centre;
+ geom::Coordinate centre;
- int level;
+ int level;
- * Get the subquad for the index.
- * If it doesn't exist, create it.
- * Ownership of the returned object belongs to this class.
+ * Get the subquad for the index.
+ * If it doesn't exist, create it.
+ * Ownership of the returned object belongs to this class.
- std::unique_ptr<Node> createSubnode(int index);
+ std::unique_ptr<Node> createSubnode(int index);
protected:
- bool isSearchMatch(const geom::Envelope& searchEnv) const override {
- return env->intersects(searchEnv);
+ bool
+ isSearchMatch(const geom::Envelope& searchEnv) const override
+ return env->intersects(searchEnv);
public:
- // Create a node computing level from given envelope
- static std::unique_ptr<Node> createNode(const geom::Envelope& env);
- /// Create a node containing the given node and envelope
- /// @param node if not null, will be inserted to the returned node
- /// @param addEnv minimum envelope to use for the node
- static std::unique_ptr<Node> createExpanded(std::unique_ptr<Node> node,
- const geom::Envelope& addEnv);
- Node(std::unique_ptr<geom::Envelope> nenv, int nlevel)
- env(std::move(nenv)),
- centre((env->getMinX()+env->getMaxX())/2,
- (env->getMinY()+env->getMaxY())/2),
- level(nlevel)
- ~Node() override {}
- /// Return Envelope associated with this node
- /// ownership retained by this object
- geom::Envelope* getEnvelope() { return env.get(); }
- /** \brief
- * Returns the subquad containing the envelope.
- * Creates the subquad if
- * it does not already exist.
- Node* getNode(const geom::Envelope *searchEnv);
- /** \brief
- * Returns the smallest <i>existing</i>
- * node containing the envelope.
- NodeBase* find(const geom::Envelope *searchEnv);
- void insertNode(std::unique_ptr<Node> node);
- std::string toString() const override;
+ // Create a node computing level from given envelope
+ static std::unique_ptr<Node> createNode(const geom::Envelope& env);
+ /// Create a node containing the given node and envelope
+ /// @param node if not null, will be inserted to the returned node
+ /// @param addEnv minimum envelope to use for the node
+ static std::unique_ptr<Node> createExpanded(std::unique_ptr<Node> node,
+ const geom::Envelope& addEnv);
+ Node(std::unique_ptr<geom::Envelope> nenv, int nlevel)
+ env(std::move(nenv)),
+ centre((env->getMinX() + env->getMaxX()) / 2,
+ (env->getMinY() + env->getMaxY()) / 2),
+ level(nlevel)
+ ~Node() override {}
+ /// Return Envelope associated with this node
+ /// ownership retained by this object
+ geom::Envelope*
+ getEnvelope()
+ return env.get();
+ /** \brief
+ * Returns the subquad containing the envelope.
+ * Creates the subquad if
+ * it does not already exist.
+ Node* getNode(const geom::Envelope* searchEnv);
+ /** \brief
+ * Returns the smallest <i>existing</i>
+ * node containing the envelope.
+ NodeBase* find(const geom::Envelope* searchEnv);
+ void insertNode(std::unique_ptr<Node> node);
+ std::string toString() const override;
diff --git a/include/geos/index/quadtree/NodeBase.h b/include/geos/index/quadtree/NodeBase.h
index 4d9d76e..b306834 100644
--- a/include/geos/index/quadtree/NodeBase.h
+++ b/include/geos/index/quadtree/NodeBase.h
@@ -31,16 +31,16 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Envelope;
- namespace index {
- namespace quadtree {
- class Node;
+namespace geom {
+class Coordinate;
+class Envelope;
+namespace index {
+class ItemVisitor;
+namespace quadtree {
+class Node;
namespace geos {
@@ -56,73 +56,73 @@ class GEOS_DLL NodeBase {
private:
- void visitItems(const geom::Envelope* searchEnv,
- ItemVisitor& visitor);
+ void visitItems(const geom::Envelope* searchEnv,
+ ItemVisitor& visitor);
public:
- static int getSubnodeIndex(const geom::Envelope *env,
- const geom::Coordinate& centre);
+ static int getSubnodeIndex(const geom::Envelope* env,
+ const geom::Coordinate& centre);
- NodeBase();
+ NodeBase();
- std::vector<void*>& getItems();
+ std::vector<void*>& getItems();
- /// Add an item to this node.
- /// Ownership of the item is left to caller.
- void add(void* item);
+ /// Add an item to this node.
+ /// Ownership of the item is left to caller.
+ void add(void* item);
- /// Push all node items to the given vector, return the argument
- std::vector<void*>& addAllItems(std::vector<void*>& resultItems) const;
+ /// Push all node items to the given vector, return the argument
+ std::vector<void*>& addAllItems(std::vector<void*>& resultItems) const;
- virtual void addAllItemsFromOverlapping(const geom::Envelope& searchEnv,
- std::vector<void*>& resultItems) const;
+ virtual void addAllItemsFromOverlapping(const geom::Envelope& searchEnv,
+ std::vector<void*>& resultItems) const;
- unsigned int depth() const;
+ unsigned int depth() const;
- size_t size() const;
+ size_t size() const;
- size_t getNodeCount() const;
+ size_t getNodeCount() const;
- virtual std::string toString() const;
+ virtual std::string toString() const;
- virtual void visit(const geom::Envelope* searchEnv, ItemVisitor& visitor);
+ virtual void visit(const geom::Envelope* searchEnv, ItemVisitor& visitor);
- * Removes a single item from this subtree.
- * @param searchEnv the envelope containing the item
- * @return <code>true</code> if the item was found and removed
- bool remove(const geom::Envelope* itemEnv, void* item);
+ * Removes a single item from this subtree.
+ * @param searchEnv the envelope containing the item
+ * @return <code>true</code> if the item was found and removed
+ bool remove(const geom::Envelope* itemEnv, void* item);
- bool hasItems() const;
+ bool hasItems() const;
- bool hasChildren() const;
+ bool hasChildren() const;
- bool isPrunable() const;
+ bool isPrunable() const;
protected:
- /// Actual items are NOT owned by this class
- std::vector<void*> items;
- * subquads are numbered as follows:
- * <pre>
- * 2 | 3
- * 0 | 1
- * </pre>
- * Nodes are owned by this class
- std::array<Node*, 4> subnodes;
- virtual bool isSearchMatch(const geom::Envelope& searchEnv) const=0;
+ /// Actual items are NOT owned by this class
+ std::vector<void*> items;
+ * subquads are numbered as follows:
+ * <pre>
+ * 2 | 3
+ * 0 | 1
+ * </pre>
+ * Nodes are owned by this class
+ std::array<Node*, 4> subnodes;
+ virtual bool isSearchMatch(const geom::Envelope& searchEnv) const = 0;
@@ -131,24 +131,25 @@ protected:
inline bool
NodeBase::hasChildren() const
- for (const auto& subnode : subnodes) {
- if (subnode != nullptr)
- return true;
+ for(const auto& subnode : subnodes) {
+ if(subnode != nullptr) {
+ return true;
- return false;
+ return false;
inline bool
NodeBase::isPrunable() const
- return ! (hasChildren() || hasItems());
+ return !(hasChildren() || hasItems());
inline bool
NodeBase::hasItems() const
- return ! items.empty();
+ return ! items.empty();
diff --git a/include/geos/index/quadtree/Quadtree.h b/include/geos/index/quadtree/Quadtree.h
index d541e40..be07ad2 100644
--- a/include/geos/index/quadtree/Quadtree.h
+++ b/include/geos/index/quadtree/Quadtree.h
@@ -35,11 +35,11 @@
namespace geos {
- namespace index {
- // class Root;
+namespace index {
+// class Root;
namespace geos {
@@ -72,121 +72,122 @@ class GEOS_DLL Quadtree: public SpatialIndex {
private:
- std::vector<std::unique_ptr<geom::Envelope>> newEnvelopes;
+ std::vector<std::unique_ptr<geom::Envelope>> newEnvelopes;
- void collectStats(const geom::Envelope& itemEnv);
+ void collectStats(const geom::Envelope& itemEnv);
- Root root;
+ Root root;
- * Statistics
- * minExtent is the minimum envelope extent of all items
- * to construct non-zero envelopes for features with zero X and/or
- * Y extent.
- double minExtent;
+ * Statistics
+ * minExtent is the minimum envelope extent of all items
+ * to construct non-zero envelopes for features with zero X and/or
+ * Y extent.
+ double minExtent;
public:
- * \brief
- * Ensure that the envelope for the inserted item has non-zero extents.
- * Use the current minExtent to pad the envelope, if necessary.
- * Can return a new Envelope or the given one (casted to non-const).
- static geom::Envelope* ensureExtent(const geom::Envelope *itemEnv,
- * \brief
- * Constructs a Quadtree with zero items.
- Quadtree()
- root(),
- minExtent(1.0)
- ~Quadtree() override = default;
- /// Returns the number of levels in the tree.
- int depth();
- /// Returns the number of items in the tree.
- size_t size();
- void insert(const geom::Envelope *itemEnv, void *item) override;
- /** \brief
- * Queries the tree and returns items which may lie
- * in the given search envelope.
- * Precisely, the items that are returned are all items in the tree
- * whose envelope <b>may</b> intersect the search Envelope.
- * Note that some items with non-intersecting envelopes may be
- * returned as well;
- * the client is responsible for filtering these out.
- * In most situations there will be many items in the tree which do not
- * intersect the search envelope and which are not returned - thus
- * providing improved performance over a simple linear scan.
- * @param searchEnv the envelope of the desired query area.
- * @param ret a vector where items which may intersect the
- * search envelope are pushed
- void query(const geom::Envelope *searchEnv, std::vector<void*>& ret) override;
- /** \brief
- * Queries the tree and visits items which may lie in
- * the given search envelope.
- * Precisely, the items that are visited are all items in the tree
- * visited as well;
- * intersect the search envelope and which are not visited - thus
- * @param visitor a visitor object which is passed the visited items
- void query(const geom::Envelope *searchEnv, ItemVisitor& visitor) override
- * the items that are matched are the items in quads which
- * overlap the search envelope
- root.visit(searchEnv, visitor);
- * @param itemEnv the Envelope of the item to be removed
- * @return <code>true</code> if the item was found (and thus removed)
- bool remove(const geom::Envelope* itemEnv, void* item) override;
- /// Return a list of all items in the Quadtree
- std::vector<void*>* queryAll();
+ * \brief
+ * Ensure that the envelope for the inserted item has non-zero extents.
+ * Use the current minExtent to pad the envelope, if necessary.
+ * Can return a new Envelope or the given one (casted to non-const).
+ static geom::Envelope* ensureExtent(const geom::Envelope* itemEnv,
+ * \brief
+ * Constructs a Quadtree with zero items.
+ Quadtree()
+ root(),
+ minExtent(1.0)
+ ~Quadtree() override = default;
+ /// Returns the number of levels in the tree.
+ int depth();
+ /// Returns the number of items in the tree.
+ size_t size();
+ void insert(const geom::Envelope* itemEnv, void* item) override;
+ /** \brief
+ * Queries the tree and returns items which may lie
+ * in the given search envelope.
+ * Precisely, the items that are returned are all items in the tree
+ * whose envelope <b>may</b> intersect the search Envelope.
+ * Note that some items with non-intersecting envelopes may be
+ * returned as well;
+ * the client is responsible for filtering these out.
+ * In most situations there will be many items in the tree which do not
+ * intersect the search envelope and which are not returned - thus
+ * providing improved performance over a simple linear scan.
+ * @param searchEnv the envelope of the desired query area.
+ * @param ret a vector where items which may intersect the
+ * search envelope are pushed
+ void query(const geom::Envelope* searchEnv, std::vector<void*>& ret) override;
+ /** \brief
+ * Queries the tree and visits items which may lie in
+ * the given search envelope.
+ * Precisely, the items that are visited are all items in the tree
+ * visited as well;
+ * intersect the search envelope and which are not visited - thus
+ * @param visitor a visitor object which is passed the visited items
+ void
+ query(const geom::Envelope* searchEnv, ItemVisitor& visitor) override
+ * the items that are matched are the items in quads which
+ * overlap the search envelope
+ root.visit(searchEnv, visitor);
+ * @param itemEnv the Envelope of the item to be removed
+ * @return <code>true</code> if the item was found (and thus removed)
+ bool remove(const geom::Envelope* itemEnv, void* item) override;
+ /// Return a list of all items in the Quadtree
+ std::vector<void*>* queryAll();
- Quadtree(const Quadtree&) = delete;
- Quadtree& operator=(const Quadtree&) = delete;
+ Quadtree(const Quadtree&) = delete;
+ Quadtree& operator=(const Quadtree&) = delete;
diff --git a/include/geos/index/quadtree/Root.h b/include/geos/index/quadtree/Root.h
index 98342c9..65ed66d 100644
--- a/include/geos/index/quadtree/Root.h
+++ b/include/geos/index/quadtree/Root.h
@@ -25,14 +25,14 @@
namespace geos {
- namespace geom {
- class Envelope;
- namespace index {
- class Node;
+namespace geom {
+class Envelope;
+namespace index {
+class Node;
namespace geos {
@@ -51,32 +51,34 @@ class GEOS_DLL Root: public NodeBase {
private:
- static const geom::Coordinate origin;
+ static const geom::Coordinate origin;
- * insert an item which is known to be contained in the tree rooted at
- * the given QuadNode root. Lower levels of the tree will be created
- * if necessary to hold the item.
- void insertContained(Node *tree, const geom::Envelope *itemEnv,
- void* item);
+ * insert an item which is known to be contained in the tree rooted at
+ * the given QuadNode root. Lower levels of the tree will be created
+ * if necessary to hold the item.
+ void insertContained(Node* tree, const geom::Envelope* itemEnv,
+ void* item);
public:
- Root() {}
+ Root() {}
- * Insert an item into the quadtree this is the root of.
- void insert(const geom::Envelope *itemEnv, void* item);
+ * Insert an item into the quadtree this is the root of.
+ void insert(const geom::Envelope* itemEnv, void* item);
protected:
- bool isSearchMatch(const geom::Envelope& /* searchEnv */) const override {
- return true;
+ bool
+ isSearchMatch(const geom::Envelope& /* searchEnv */) const override
+ return true;
diff --git a/include/geos/index/strtree/AbstractNode.h b/include/geos/index/strtree/AbstractNode.h
index f1802d7..97080db 100644
--- a/include/geos/index/strtree/AbstractNode.h
+++ b/include/geos/index/strtree/AbstractNode.h
@@ -42,47 +42,51 @@ namespace strtree { // geos::index::strtree
class GEOS_DLL AbstractNode: public Boundable {
private:
- std::vector<Boundable*> childBoundables;
- int level;
+ std::vector<Boundable*> childBoundables;
+ int level;
public:
- AbstractNode(int newLevel, size_t capacity = 10);
- ~AbstractNode() override;
- // TODO: change signature to return by ref,
- // document ownership of the return
- inline std::vector<Boundable*>* getChildBoundables() {
- return &childBoundables;
- inline const std::vector<Boundable*>* getChildBoundables() const {
- * Returns a representation of space that encloses this Boundable,
- * preferably not much bigger than this Boundable's boundary yet fast to
- * test for intersection with the bounds of other Boundables.
- * The class of object returned depends on the subclass of
- * AbstractSTRtree.
- * @return an Envelope (for STRtrees), an Interval (for SIRtrees),
- * or other object (for other subclasses of AbstractSTRtree)
- * @see AbstractSTRtree::IntersectsOp
- const void* getBounds() const override;
- int getLevel();
- void addChildBoundable(Boundable *childBoundable);
+ AbstractNode(int newLevel, size_t capacity = 10);
+ ~AbstractNode() override;
+ // TODO: change signature to return by ref,
+ // document ownership of the return
+ inline std::vector<Boundable*>*
+ getChildBoundables()
+ return &childBoundables;
+ inline const std::vector<Boundable*>*
+ getChildBoundables() const
+ * Returns a representation of space that encloses this Boundable,
+ * preferably not much bigger than this Boundable's boundary yet fast to
+ * test for intersection with the bounds of other Boundables.
+ * The class of object returned depends on the subclass of
+ * AbstractSTRtree.
+ * @return an Envelope (for STRtrees), an Interval (for SIRtrees),
+ * or other object (for other subclasses of AbstractSTRtree)
+ * @see AbstractSTRtree::IntersectsOp
+ const void* getBounds() const override;
+ int getLevel();
+ void addChildBoundable(Boundable* childBoundable);
protected:
- virtual void* computeBounds() const=0;
+ virtual void* computeBounds() const = 0;
- mutable void* bounds;
+ mutable void* bounds;
diff --git a/include/geos/index/strtree/AbstractSTRtree.h b/include/geos/index/strtree/AbstractSTRtree.h
index 719ce8b..589be45 100644
--- a/include/geos/index/strtree/AbstractSTRtree.h
+++ b/include/geos/index/strtree/AbstractSTRtree.h
@@ -27,13 +27,13 @@
namespace geos {
- namespace index {
- namespace strtree {
- class Boundable;
- class AbstractNode;
+namespace index {
+class ItemVisitor;
+namespace strtree {
+class Boundable;
+class AbstractNode;
namespace geos {
@@ -48,33 +48,38 @@ typedef std::vector<Boundable*> BoundableList;
/// this class, the plain boundables are held by reference only.
class ItemsList;
-class ItemsListItem
+class ItemsListItem {
public:
enum type {
item_is_geometry,
item_is_list
- ItemsListItem(void *item_)
- : t(item_is_geometry)
+ ItemsListItem(void* item_)
+ : t(item_is_geometry)
item.g = item_;
ItemsListItem(ItemsList* item_)
- : t(item_is_list)
+ : t(item_is_list)
item.l = item_;
- type get_type() const { return t; }
+ type
+ get_type() const
+ return t;
- void* get_geometry() const
+ void*
+ get_geometry() const
assert(t == item_is_geometry);
return item.g;
- ItemsList* get_itemslist() const
+ ItemsList*
+ get_itemslist() const
assert(t == item_is_list);
return item.l;
@@ -87,15 +92,16 @@ public:
} item;
-class ItemsList : public std::vector<ItemsListItem>
+class ItemsList : public std::vector<ItemsListItem> {
private:
typedef std::vector<ItemsListItem> base_type;
- static void delete_item(ItemsListItem& item)
+ static void
+ delete_item(ItemsListItem& item)
- if (ItemsListItem::item_is_list == item.t)
+ if(ItemsListItem::item_is_list == item.t) {
delete item.item.l;
public:
@@ -105,13 +111,15 @@ public:
// lists of items need to be deleted in the end
- void push_back(void* item)
+ void
+ push_back(void* item)
this->base_type::push_back(ItemsListItem(item));
- void push_back_owned(ItemsList* itemList)
+ void
+ push_back_owned(ItemsList* itemList)
this->base_type::push_back(ItemsListItem(itemList));
@@ -132,168 +140,180 @@ public:
class GEOS_DLL AbstractSTRtree {
private:
- bool built;
- BoundableList* itemBoundables;
- * Creates the levels higher than the given level
- * @param boundablesOfALevel
- * the level to build on
- * @param level
- * the level of the Boundables, or -1 if the boundables are item
- * boundables (that is, below level 0)
- * @return the root, which may be a ParentNode or a LeafNode
- virtual AbstractNode* createHigherLevels(
- BoundableList* boundablesOfALevel,
- int level);
- virtual std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input)=0;
- bool remove(const void* searchBounds, AbstractNode& node, void* item);
- bool removeItem(AbstractNode& node, void* item);
+ bool built;
+ BoundableList* itemBoundables;
+ * Creates the levels higher than the given level
+ * @param boundablesOfALevel
+ * the level to build on
+ * @param level
+ * the level of the Boundables, or -1 if the boundables are item
+ * boundables (that is, below level 0)
+ * @return the root, which may be a ParentNode or a LeafNode
+ virtual AbstractNode* createHigherLevels(
+ BoundableList* boundablesOfALevel,
+ int level);
+ virtual std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input) = 0;
+ bool remove(const void* searchBounds, AbstractNode& node, void* item);
+ bool removeItem(AbstractNode& node, void* item);
ItemsList* itemsTree(AbstractNode* node);
protected:
- /** \brief
- * A test for intersection between two bounds, necessary because
- * subclasses of AbstractSTRtree have different implementations of
- * bounds.
- class GEOS_DLL IntersectsOp {
- public:
- * For STRtrees, the bounds will be Envelopes; for
- * SIRtrees, Intervals; for other subclasses of
- * AbstractSTRtree, some other class.
- * @param aBounds the bounds of one spatial object
- * @param bBounds the bounds of another spatial object
- * @return whether the two bounds intersect
- virtual bool intersects(const void* aBounds,
- const void* bBounds)=0;
- virtual ~IntersectsOp() {}
- AbstractNode *root;
- std::vector <AbstractNode *> *nodes;
- // Ownership to caller (TODO: return by unique_ptr)
- virtual AbstractNode* createNode(int level)=0;
- * Sorts the childBoundables then divides them into groups of size M, where
- * M is the node capacity.
- virtual std::unique_ptr<BoundableList> createParentBoundables(
- BoundableList* childBoundables, int newLevel);
- virtual AbstractNode* lastNode(BoundableList* nodeList)
- assert(!nodeList->empty());
- // Cast from Boundable to AbstractNode
- return static_cast<AbstractNode*>(nodeList->back() );
- virtual AbstractNode* getRoot() {
- assert(built);
- return root;
- /// Also builds the tree, if necessary.
- virtual void insert(const void* bounds,void* item);
- void query(const void* searchBounds, std::vector<void*>& foundItems);
+ /** \brief
+ * A test for intersection between two bounds, necessary because
+ * subclasses of AbstractSTRtree have different implementations of
+ * bounds.
+ class GEOS_DLL IntersectsOp {
+ public:
+ * For STRtrees, the bounds will be Envelopes; for
+ * SIRtrees, Intervals; for other subclasses of
+ * AbstractSTRtree, some other class.
+ * @param aBounds the bounds of one spatial object
+ * @param bBounds the bounds of another spatial object
+ * @return whether the two bounds intersect
+ virtual bool intersects(const void* aBounds,
+ const void* bBounds) = 0;
+ virtual
+ ~IntersectsOp() {}
+ AbstractNode* root;
+ std::vector <AbstractNode*>* nodes;
+ // Ownership to caller (TODO: return by unique_ptr)
+ virtual AbstractNode* createNode(int level) = 0;
+ * Sorts the childBoundables then divides them into groups of size M, where
+ * M is the node capacity.
+ virtual std::unique_ptr<BoundableList> createParentBoundables(
+ BoundableList* childBoundables, int newLevel);
+ lastNode(BoundableList* nodeList)
+ assert(!nodeList->empty());
+ // Cast from Boundable to AbstractNode
+ return static_cast<AbstractNode*>(nodeList->back());
+ getRoot()
+ assert(built);
+ return root;
+ /// Also builds the tree, if necessary.
+ virtual void insert(const void* bounds, void* item);
+ void query(const void* searchBounds, std::vector<void*>& foundItems);
#if 0
- std::vector<void*>* query(const void* searchBounds) {
- vector<void*>* matches = new vector<void*>();
- query(searchBounds, *matches);
- return matches;
+ query(const void* searchBounds)
+ vector<void*>* matches = new vector<void*>();
+ query(searchBounds, *matches);
+ return matches;
#endif
- void query(const void* searchBounds, ItemVisitor& visitor);
+ void query(const void* searchBounds, ItemVisitor& visitor);
- void query(const void* searchBounds, const AbstractNode& node, ItemVisitor& visitor);
+ void query(const void* searchBounds, const AbstractNode& node, ItemVisitor& visitor);
- bool remove(const void* itemEnv, void* item);
+ bool remove(const void* itemEnv, void* item);
- std::unique_ptr<BoundableList> boundablesAtLevel(int level);
+ std::unique_ptr<BoundableList> boundablesAtLevel(int level);
- // @@ should be size_t, probably
- std::size_t nodeCapacity;
+ // @@ should be size_t, probably
+ std::size_t nodeCapacity;
- * @return a test for intersection between two bounds,
- * necessary because subclasses
- * of AbstractSTRtree have different implementations of bounds.
- * @see IntersectsOp
- virtual IntersectsOp *getIntersectsOp()=0;
+ * @return a test for intersection between two bounds,
+ * necessary because subclasses
+ * of AbstractSTRtree have different implementations of bounds.
+ * @see IntersectsOp
+ virtual IntersectsOp* getIntersectsOp() = 0;
public:
- * Constructs an AbstractSTRtree with the specified maximum number of child
- * nodes that a node may have
- AbstractSTRtree(std::size_t newNodeCapacity)
- built(false),
- itemBoundables(new BoundableList()),
- nodes(new std::vector<AbstractNode *>()),
- nodeCapacity(newNodeCapacity)
- assert(newNodeCapacity>1);
- static bool compareDoubles(double a, double b) {
- // NOTE - strk:
- // Ternary operation is a workaround for
- // a probable MingW bug, see
- // http://trac.osgeo.org/geos/ticket/293
- return ( a < b ) ? true : false;
- virtual ~AbstractSTRtree();
- * Creates parent nodes, grandparent nodes, and so forth up to the root
- * node, for the data that has been inserted into the tree. Can only be
- * called once, and thus can be called only after all of the data has been
- * inserted into the tree.
- virtual void build();
- * Returns the maximum number of child nodes that a node may have
- virtual std::size_t getNodeCapacity() { return nodeCapacity; }
- virtual void query(const void* searchBounds, const AbstractNode* node, std::vector<void*>* matches);
+ * Constructs an AbstractSTRtree with the specified maximum number of child
+ * nodes that a node may have
+ AbstractSTRtree(std::size_t newNodeCapacity)
+ built(false),
+ itemBoundables(new BoundableList()),
+ nodes(new std::vector<AbstractNode *>()),
+ nodeCapacity(newNodeCapacity)
+ assert(newNodeCapacity > 1);
+ static bool
+ compareDoubles(double a, double b)
+ // NOTE - strk:
+ // Ternary operation is a workaround for
+ // a probable MingW bug, see
+ // http://trac.osgeo.org/geos/ticket/293
+ return (a < b) ? true : false;
+ virtual ~AbstractSTRtree();
+ * Creates parent nodes, grandparent nodes, and so forth up to the root
+ * node, for the data that has been inserted into the tree. Can only be
+ * called once, and thus can be called only after all of the data has been
+ * inserted into the tree.
+ virtual void build();
+ * Returns the maximum number of child nodes that a node may have
+ virtual std::size_t
+ getNodeCapacity()
+ return nodeCapacity;
+ virtual void query(const void* searchBounds, const AbstractNode* node, std::vector<void*>* matches);
* Iterate over all items added thus far. Explicitly does not build
* the tree.
- void iterate(ItemVisitor& visitor);
+ void iterate(ItemVisitor& visitor);
- * @param level -1 to get items
- virtual void boundablesAtLevel(int level, AbstractNode* top,
- BoundableList* boundables);
+ * @param level -1 to get items
+ virtual void boundablesAtLevel(int level, AbstractNode* top,
+ BoundableList* boundables);
* Gets a tree structure (as a nested list)
diff --git a/include/geos/index/strtree/Boundable.h b/include/geos/index/strtree/Boundable.h
index 90809c9..2a0ee4a 100644
--- a/include/geos/index/strtree/Boundable.h
+++ b/include/geos/index/strtree/Boundable.h
@@ -24,21 +24,22 @@ namespace strtree { // geos::index::strtree
/// A spatial object in an AbstractSTRtree.
class GEOS_DLL Boundable {
public:
- * fast to test for intersection with the bounds of other Boundables.
- * on the subclass of AbstractSTRtree.
- virtual const void* getBounds() const=0;
- virtual ~Boundable() {}
+ * fast to test for intersection with the bounds of other Boundables.
+ * on the subclass of AbstractSTRtree.
+ virtual const void* getBounds() const = 0;
+ virtual
+ ~Boundable() {}
diff --git a/include/geos/index/strtree/BoundablePair.h b/include/geos/index/strtree/BoundablePair.h
index 92f0b66..8294a65 100644
--- a/include/geos/index/strtree/BoundablePair.h
+++ b/include/geos/index/strtree/BoundablePair.h
@@ -41,67 +41,69 @@ namespace index {
namespace strtree {
class BoundablePair {
- private:
- const Boundable* boundable1;
- const Boundable* boundable2;
- ItemDistance* itemDistance;
- double mDistance;
+private:
+ const Boundable* boundable1;
+ const Boundable* boundable2;
+ ItemDistance* itemDistance;
+ double mDistance;
- public:
- struct BoundablePairQueueCompare {
- bool operator()(const BoundablePair* a, const BoundablePair* b) {
- return a->getDistance() > b->getDistance();
+public:
+ struct BoundablePairQueueCompare {
+ bool
+ operator()(const BoundablePair* a, const BoundablePair* b)
+ return a->getDistance() > b->getDistance();
- typedef std::priority_queue<BoundablePair*, std::vector<BoundablePair*>, BoundablePairQueueCompare> BoundablePairQueue;
- BoundablePair(const Boundable* boundable1, const Boundable* boundable2, ItemDistance* itemDistance);
+ typedef std::priority_queue<BoundablePair*, std::vector<BoundablePair*>, BoundablePairQueueCompare> BoundablePairQueue;
+ BoundablePair(const Boundable* boundable1, const Boundable* boundable2, ItemDistance* itemDistance);
- * Gets one of the member {@link Boundable}s in the pair
- * (indexed by [0, 1]).
- * @param i the index of the member to return (0 or 1)
- * @return the chosen member
- const Boundable* getBoundable(int i) const;
+ * Gets one of the member {@link Boundable}s in the pair
+ * (indexed by [0, 1]).
+ * @param i the index of the member to return (0 or 1)
+ * @return the chosen member
+ const Boundable* getBoundable(int i) const;
- * Computes the distance between the {@link Boundable}s in this pair.
- * The boundables are either composites or leaves.
- * If either is composite, the distance is computed as the minimum distance
- * between the bounds.
- * If both are leaves, the distance is computed by {@link #itemDistance(ItemBoundable, ItemBoundable)}.
- * @return
- double distance() const;
+ * Computes the distance between the {@link Boundable}s in this pair.
+ * The boundables are either composites or leaves.
+ * If either is composite, the distance is computed as the minimum distance
+ * between the bounds.
+ * If both are leaves, the distance is computed by {@link #itemDistance(ItemBoundable, ItemBoundable)}.
+ * @return
+ double distance() const;
- * Gets the minimum possible distance between the Boundables in
- * this pair.
- * If the members are both items, this will be the
- * exact distance between them.
- * Otherwise, this distance will be a lower bound on
- * the distances between the items in the members.
- * @return the exact or lower bound distance for this pair
- double getDistance() const;
+ * Gets the minimum possible distance between the Boundables in
+ * this pair.
+ * If the members are both items, this will be the
+ * exact distance between them.
+ * Otherwise, this distance will be a lower bound on
+ * the distances between the items in the members.
+ * @return the exact or lower bound distance for this pair
+ double getDistance() const;
- * Tests if both elements of the pair are leaf nodes
- * @return true if both pair elements are leaf nodes
- bool isLeaves() const;
+ * Tests if both elements of the pair are leaf nodes
+ * @return true if both pair elements are leaf nodes
+ bool isLeaves() const;
- static bool isComposite(const Boundable* item);
+ static bool isComposite(const Boundable* item);
- static double area(const Boundable* b);
+ static double area(const Boundable* b);
- void expandToQueue(BoundablePairQueue &, double minDistance);
- void expand(const Boundable* bndComposite, const Boundable* bndOther, BoundablePairQueue & priQ, double minDistance);
+ void expandToQueue(BoundablePairQueue&, double minDistance);
+ void expand(const Boundable* bndComposite, const Boundable* bndOther, BoundablePairQueue& priQ, double minDistance);
diff --git a/include/geos/index/strtree/GeometryItemDistance.h b/include/geos/index/strtree/GeometryItemDistance.h
index 887ea29..d41bc19 100644
--- a/include/geos/index/strtree/GeometryItemDistance.h
+++ b/include/geos/index/strtree/GeometryItemDistance.h
@@ -27,16 +27,16 @@ namespace index {
namespace strtree {
class GEOS_DLL GeometryItemDistance : public ItemDistance {
public:
- * Computes the distance between two {@link Geometry} items,
- * using the {@link Geometry#distance(Geometry)} method.
- * @param item1 an item which is a Geometry
- * @param item2 an item which is a Geometry
- * @return the distance between the geometries
- * @throws ClassCastException if either item is not a Geometry
- double distance(const ItemBoundable* item1, const ItemBoundable* item2) override;
+ * Computes the distance between two {@link Geometry} items,
+ * using the {@link Geometry#distance(Geometry)} method.
+ * @param item1 an item which is a Geometry
+ * @param item2 an item which is a Geometry
+ * @return the distance between the geometries
+ * @throws ClassCastException if either item is not a Geometry
+ double distance(const ItemBoundable* item1, const ItemBoundable* item2) override;
diff --git a/include/geos/index/strtree/Interval.h b/include/geos/index/strtree/Interval.h
index 995a146..67fccb9 100644
--- a/include/geos/index/strtree/Interval.h
+++ b/include/geos/index/strtree/Interval.h
@@ -27,14 +27,14 @@ namespace strtree { // geos::index::strtree
class GEOS_DLL Interval {
public:
- Interval(double newMin, double newMax);
- double getCentre();
- Interval* expandToInclude(const Interval *other);
- bool intersects(const Interval *other) const;
- bool equals(const Interval *o) const;
+ Interval(double newMin, double newMax);
+ double getCentre();
+ Interval* expandToInclude(const Interval* other);
+ bool intersects(const Interval* other) const;
+ bool equals(const Interval* o) const;
private:
- double imin;
- double imax;
+ double imin;
+ double imax;
diff --git a/include/geos/index/strtree/ItemBoundable.h b/include/geos/index/strtree/ItemBoundable.h
index f1cda7a..bf7be99 100644
--- a/include/geos/index/strtree/ItemBoundable.h
+++ b/include/geos/index/strtree/ItemBoundable.h
@@ -29,20 +29,19 @@ namespace strtree { // geos::index::strtree
* \todo TODO: It's unclear who takes ownership of passed newBounds and newItem objects.
-class GEOS_DLL ItemBoundable: public Boundable
+class GEOS_DLL ItemBoundable: public Boundable {
public:
ItemBoundable(const void* newBounds, void* newItem);
- ~ItemBoundable() override = default;
+ ~ItemBoundable() override = default;
- void* getItem() const;
+ void* getItem() const;
private:
- const void* bounds;
- void* item;
+ const void* bounds;
+ void* item;
} // namespace geos::index::strtree
diff --git a/include/geos/index/strtree/ItemDistance.h b/include/geos/index/strtree/ItemDistance.h
index 54de9f4..6a05a12 100644
--- a/include/geos/index/strtree/ItemDistance.h
+++ b/include/geos/index/strtree/ItemDistance.h
@@ -26,16 +26,16 @@ namespace index {
namespace strtree {
class GEOS_DLL ItemDistance {
public:
- * Computes the distance between two items.
- * @param item1
- * @param item2
- * @return the distance between the items
- * @throws IllegalArgumentException if the metric is not applicable to the arguments
- virtual double distance(const ItemBoundable* item1, const ItemBoundable* item2) = 0;
+ * Computes the distance between two items.
+ * @param item1
+ * @param item2
+ * @return the distance between the items
+ * @throws IllegalArgumentException if the metric is not applicable to the arguments
+ virtual double distance(const ItemBoundable* item1, const ItemBoundable* item2) = 0;
diff --git a/include/geos/index/strtree/SIRtree.h b/include/geos/index/strtree/SIRtree.h
index 9e9c275..34be136 100644
--- a/include/geos/index/strtree/SIRtree.h
+++ b/include/geos/index/strtree/SIRtree.h
@@ -39,73 +39,82 @@ namespace strtree { // geos::index::strtree
* @see STRtree
class GEOS_DLL SIRtree: public AbstractSTRtree {
-using AbstractSTRtree::insert;
-using AbstractSTRtree::query;
+ using AbstractSTRtree::insert;
+ using AbstractSTRtree::query;
public:
- /** \brief
- * Constructs an SIRtree with the default node capacity.
- SIRtree();
- /** \brief
- * Constructs an SIRtree with the given maximum number of child nodes
- * that a node may have
- SIRtree(std::size_t nodeCapacity);
- ~SIRtree() override;
- void insert(double x1, double x2, void* item);
- * Returns items whose bounds intersect the given bounds.
- * @param x1 possibly equal to x2
- std::vector<void*>* query(double x1, double x2)
- std::vector<void*>* results = new std::vector<void*>();
- Interval interval(std::min(x1, x2), std::max(x1, x2));
- AbstractSTRtree::query(&interval, *results);
- return results;
- * Returns items whose bounds intersect the given value.
- std::vector<void*>* query(double x) { return query(x,x); }
- * Disable copy construction and assignment. Apparently needed to make this
- * class compile under MSVC. (See https://stackoverflow.com/q/29565299)
- SIRtree(const SIRtree&) = delete;
- SIRtree& operator=(const SIRtree&) = delete;
+ /** \brief
+ * Constructs an SIRtree with the default node capacity.
+ SIRtree();
+ /** \brief
+ * Constructs an SIRtree with the given maximum number of child nodes
+ * that a node may have
+ SIRtree(std::size_t nodeCapacity);
+ ~SIRtree() override;
+ void insert(double x1, double x2, void* item);
+ * Returns items whose bounds intersect the given bounds.
+ * @param x1 possibly equal to x2
+ query(double x1, double x2)
+ std::vector<void*>* results = new std::vector<void*>();
+ Interval interval(std::min(x1, x2), std::max(x1, x2));
+ AbstractSTRtree::query(&interval, *results);
+ return results;
+ * Returns items whose bounds intersect the given value.
+ query(double x)
+ return query(x, x);
+ * Disable copy construction and assignment. Apparently needed to make this
+ * class compile under MSVC. (See https://stackoverflow.com/q/29565299)
+ SIRtree(const SIRtree&) = delete;
+ SIRtree& operator=(const SIRtree&) = delete;
protected:
- class SIRIntersectsOp:public AbstractSTRtree::IntersectsOp {
- public:
- bool intersects(const void* aBounds, const void* bBounds) override;
+ class SIRIntersectsOp: public AbstractSTRtree::IntersectsOp {
+ public:
+ bool intersects(const void* aBounds, const void* bBounds) override;
- /** \brief
- std::unique_ptr<BoundableList> createParentBoundables(
- BoundableList* childBoundables, int newLevel) override;
+ /** \brief
+ std::unique_ptr<BoundableList> createParentBoundables(
+ BoundableList* childBoundables, int newLevel) override;
- AbstractNode* createNode(int level) override;
+ AbstractNode* createNode(int level) override;
- IntersectsOp* getIntersectsOp() override {return intersectsOp;}
+ IntersectsOp*
+ getIntersectsOp() override
+ return intersectsOp;
- std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input) override;
+ std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input) override;
private:
- IntersectsOp* intersectsOp;
- std::vector<std::unique_ptr<Interval>> intervals;
+ IntersectsOp* intersectsOp;
+ std::vector<std::unique_ptr<Interval>> intervals;
diff --git a/include/geos/index/strtree/STRtree.h b/include/geos/index/strtree/STRtree.h
index 70be833..83d7b63 100644
--- a/include/geos/index/strtree/STRtree.h
+++ b/include/geos/index/strtree/STRtree.h
@@ -35,11 +35,11 @@
namespace geos {
- namespace index {
- class Boundable;
+namespace index {
+class Boundable;
namespace geos {
@@ -61,93 +61,105 @@ namespace strtree { // geos::index::strtree
* Databases With Application To GIS. Morgan Kaufmann, San Francisco, 2002.
-class GEOS_DLL STRtree: public AbstractSTRtree, public SpatialIndex
+class GEOS_DLL STRtree: public AbstractSTRtree, public SpatialIndex {
private:
- class GEOS_DLL STRIntersectsOp: public AbstractSTRtree::IntersectsOp {
- public:
+ class GEOS_DLL STRIntersectsOp: public AbstractSTRtree::IntersectsOp {
+ public:
- * Creates the parent level for the given child level. First, orders the items
- * by the x-values of the midpoints, and groups them into vertical slices.
- * For each slice, orders the items by the y-values of the midpoints, and
- * group them into runs of size M (the node capacity). For each run, creates
- * a new (parent) node.
- std::unique_ptr<BoundableList> createParentBoundables(BoundableList* childBoundables, int newLevel) override;
+ * Creates the parent level for the given child level. First, orders the items
+ * by the x-values of the midpoints, and groups them into vertical slices.
+ * For each slice, orders the items by the y-values of the midpoints, and
+ * group them into runs of size M (the node capacity). For each run, creates
+ * a new (parent) node.
+ std::unique_ptr<BoundableList> createParentBoundables(BoundableList* childBoundables, int newLevel) override;
- std::unique_ptr<BoundableList> createParentBoundablesFromVerticalSlices(std::vector<BoundableList*>* verticalSlices, int newLevel);
+ std::unique_ptr<BoundableList> createParentBoundablesFromVerticalSlices(std::vector<BoundableList*>* verticalSlices,
+ int newLevel);
- STRIntersectsOp intersectsOp;
+ STRIntersectsOp intersectsOp;
- std::unique_ptr<BoundableList> createParentBoundablesFromVerticalSlice(
- int newLevel);
+ std::unique_ptr<BoundableList> createParentBoundablesFromVerticalSlice(
+ int newLevel);
- * @param childBoundables Must be sorted by the x-value of
- * the envelope midpoints
- * @return
- std::vector<BoundableList*>* verticalSlices(
- size_t sliceCount);
+ * @param childBoundables Must be sorted by the x-value of
+ * the envelope midpoints
+ * @return
+ std::vector<BoundableList*>* verticalSlices(
+ size_t sliceCount);
protected:
- return &intersectsOp;
+ IntersectsOp*
+ return &intersectsOp;
public:
- ~STRtree() override;
- * Constructs an STRtree with the given maximum number of child nodes that
- * a node may have
- STRtree(std::size_t nodeCapacity=10);
- void insert(const geom::Envelope *itemEnv,void* item) override;
- //static double centreX(const geom::Envelope *e);
- static double avg(double a, double b) {
- return (a + b) / 2.0;
- static double centreY(const geom::Envelope *e) {
- return STRtree::avg(e->getMinY(), e->getMaxY());
- void query(const geom::Envelope *searchEnv, std::vector<void*>& matches) override {
- AbstractSTRtree::query(searchEnv, matches);
- void query(const geom::Envelope *searchEnv, ItemVisitor& visitor) override {
- return AbstractSTRtree::query(searchEnv, visitor);
- const void* nearestNeighbour(const geom::Envelope *env, const void* item, ItemDistance* itemDist);
- std::pair<const void*, const void*> nearestNeighbour(BoundablePair* initBndPair);
- std::pair<const void*, const void*> nearestNeighbour(ItemDistance* itemDist);
- std::pair<const void*, const void*> nearestNeighbour(BoundablePair* initBndPair, double maxDistance);
- std::pair<const void*, const void*> nearestNeighbour(STRtree *tree, ItemDistance *itemDist);
- bool remove(const geom::Envelope *itemEnv, void* item) override {
- return AbstractSTRtree::remove(itemEnv, item);
+ ~STRtree() override;
+ * Constructs an STRtree with the given maximum number of child nodes that
+ * a node may have
+ STRtree(std::size_t nodeCapacity = 10);
+ //static double centreX(const geom::Envelope *e);
+ static double
+ avg(double a, double b)
+ return (a + b) / 2.0;
+ static double
+ centreY(const geom::Envelope* e)
+ return STRtree::avg(e->getMinY(), e->getMaxY());
+ void
+ query(const geom::Envelope* searchEnv, std::vector<void*>& matches) override
+ AbstractSTRtree::query(searchEnv, matches);
+ void
+ return AbstractSTRtree::query(searchEnv, visitor);
+ const void* nearestNeighbour(const geom::Envelope* env, const void* item, ItemDistance* itemDist);
+ std::pair<const void*, const void*> nearestNeighbour(BoundablePair* initBndPair);
+ std::pair<const void*, const void*> nearestNeighbour(ItemDistance* itemDist);
+ std::pair<const void*, const void*> nearestNeighbour(BoundablePair* initBndPair, double maxDistance);
+ std::pair<const void*, const void*> nearestNeighbour(STRtree* tree, ItemDistance* itemDist);
+ bool
+ remove(const geom::Envelope* itemEnv, void* item) override
+ return AbstractSTRtree::remove(itemEnv, item);
diff --git a/include/geos/index/sweepline/SweepLineEvent.h b/include/geos/index/sweepline/SweepLineEvent.h
index c700ea3..4c51f6d 100644
--- a/include/geos/index/sweepline/SweepLineEvent.h
+++ b/include/geos/index/sweepline/SweepLineEvent.h
@@ -20,11 +20,11 @@
namespace geos {
- namespace index {
- namespace sweepline {
- class SweepLineInterval;
+namespace index {
+namespace sweepline {
+class SweepLineInterval;
namespace geos {
@@ -35,48 +35,48 @@ class GEOS_DLL SweepLineEvent {
public:
- enum {
- INSERT_EVENT = 1,
- DELETE_EVENT
+ enum {
+ INSERT_EVENT = 1,
+ DELETE_EVENT
- SweepLineEvent(double x, SweepLineEvent *newInsertEvent,
- SweepLineInterval *newSweepInt);
+ SweepLineEvent(double x, SweepLineEvent* newInsertEvent,
+ SweepLineInterval* newSweepInt);
- bool isInsert();
+ bool isInsert();
- bool isDelete();
+ bool isDelete();
- SweepLineEvent* getInsertEvent();
+ SweepLineEvent* getInsertEvent();
- size_t getDeleteEventIndex();
+ size_t getDeleteEventIndex();
- void setDeleteEventIndex(size_t newDeleteEventIndex);
+ void setDeleteEventIndex(size_t newDeleteEventIndex);
- SweepLineInterval* getInterval();
+ SweepLineInterval* getInterval();
- * ProjectionEvents are ordered first by their x-value, and then by their eventType.
- * It is important that Insert events are sorted before Delete events, so that
- * items whose Insert and Delete events occur at the same x-value will be
- * correctly handled.
- int compareTo(const SweepLineEvent *pe) const;
+ * ProjectionEvents are ordered first by their x-value, and then by their eventType.
+ * It is important that Insert events are sorted before Delete events, so that
+ * items whose Insert and Delete events occur at the same x-value will be
+ * correctly handled.
+ int compareTo(const SweepLineEvent* pe) const;
- //int compareTo(void *o) const;
+ //int compareTo(void *o) const;
private:
- double xValue;
+ double xValue;
- int eventType;
+ int eventType;
- /// null if this is an INSERT_EVENT event
- SweepLineEvent *insertEvent;
+ /// null if this is an INSERT_EVENT event
+ SweepLineEvent* insertEvent;
- size_t deleteEventIndex;
+ size_t deleteEventIndex;
- SweepLineInterval *sweepInt;
+ SweepLineInterval* sweepInt;
@@ -84,7 +84,7 @@ private:
//typedef SweepLineEvent indexSweepLineEvent;
struct GEOS_DLL SweepLineEventLessThen {
- bool operator() (const SweepLineEvent* first, const SweepLineEvent* second) const;
+ bool operator()(const SweepLineEvent* first, const SweepLineEvent* second) const;
//bool isleLessThen(SweepLineEvent *first, SweepLineEvent *second);
diff --git a/include/geos/index/sweepline/SweepLineIndex.h b/include/geos/index/sweepline/SweepLineIndex.h
index 5d885ee..5282188 100644
--- a/include/geos/index/sweepline/SweepLineIndex.h
+++ b/include/geos/index/sweepline/SweepLineIndex.h
@@ -26,13 +26,13 @@
namespace geos {
- namespace index {
- class SweepLineEvent;
- class SweepLineOverlapAction;
+namespace index {
+class SweepLineEvent;
+class SweepLineOverlapAction;
namespace geos {
@@ -48,34 +48,34 @@ class GEOS_DLL SweepLineIndex {
public:
- SweepLineIndex();
+ SweepLineIndex();
- ~SweepLineIndex();
+ ~SweepLineIndex();
- void add(SweepLineInterval *sweepInt);
+ void add(SweepLineInterval* sweepInt);
- void computeOverlaps(SweepLineOverlapAction *action);
+ void computeOverlaps(SweepLineOverlapAction* action);
private:
- // FIXME: make it a real vector rather then a pointer
- std::vector<SweepLineEvent*> events;
+ // FIXME: make it a real vector rather then a pointer
+ std::vector<SweepLineEvent*> events;
- bool indexBuilt;
+ bool indexBuilt;
- // statistics information
- int nOverlaps;
+ // statistics information
+ int nOverlaps;
- * Because Delete Events have a link to their corresponding Insert event,
- * it is possible to compute exactly the range of events which must be
- * compared to a given Insert event object.
- void buildIndex();
+ * Because Delete Events have a link to their corresponding Insert event,
+ * it is possible to compute exactly the range of events which must be
+ * compared to a given Insert event object.
+ void buildIndex();
- void processOverlaps(std::size_t start, std::size_t end,
- SweepLineInterval *s0,
- SweepLineOverlapAction *action);
+ void processOverlaps(std::size_t start, std::size_t end,
+ SweepLineInterval* s0,
+ SweepLineOverlapAction* action);
} // namespace geos:index:sweepline
diff --git a/include/geos/index/sweepline/SweepLineInterval.h b/include/geos/index/sweepline/SweepLineInterval.h
index 164dd01..91f211f 100644
--- a/include/geos/index/sweepline/SweepLineInterval.h
+++ b/include/geos/index/sweepline/SweepLineInterval.h
@@ -23,13 +23,13 @@ namespace sweepline { // geos:index:sweepline
class GEOS_DLL SweepLineInterval {
public:
- SweepLineInterval(double newMin, double newMax, void* newItem=nullptr);
- double getMin();
- double getMax();
- void* getItem();
+ SweepLineInterval(double newMin, double newMax, void* newItem = nullptr);
+ double getMin();
+ double getMax();
+ void* getItem();
private:
- double min, max;
- void* item;
+ double min, max;
+ void* item;
diff --git a/include/geos/index/sweepline/SweepLineOverlapAction.h b/include/geos/index/sweepline/SweepLineOverlapAction.h
index d4fb7cc..9dc825a 100644
--- a/include/geos/index/sweepline/SweepLineOverlapAction.h
+++ b/include/geos/index/sweepline/SweepLineOverlapAction.h
@@ -19,11 +19,11 @@
namespace geos {
- namespace index {
+namespace index {
namespace geos {
@@ -32,9 +32,10 @@ namespace sweepline { // geos:index:sweepline
class GEOS_DLL SweepLineOverlapAction {
public:
- virtual void overlap(SweepLineInterval *s0,SweepLineInterval *s1)=0;
+ virtual void overlap(SweepLineInterval* s0, SweepLineInterval* s1) = 0;
- virtual ~SweepLineOverlapAction() {}
+ virtual
+ ~SweepLineOverlapAction() {}
diff --git a/include/geos/io/ByteOrderDataInStream.h b/include/geos/io/ByteOrderDataInStream.h
index 8596b56..eb79926 100644
--- a/include/geos/io/ByteOrderDataInStream.h
+++ b/include/geos/io/ByteOrderDataInStream.h
@@ -42,32 +42,32 @@ class GEOS_DLL ByteOrderDataInStream {
public:
- ByteOrderDataInStream(std::istream *s=nullptr);
+ ByteOrderDataInStream(std::istream* s = nullptr);
- ~ByteOrderDataInStream();
+ ~ByteOrderDataInStream();
- * Allows a single ByteOrderDataInStream to be reused
- * on multiple istream.
- void setInStream(std::istream *s);
+ * Allows a single ByteOrderDataInStream to be reused
+ * on multiple istream.
+ void setInStream(std::istream* s);
- void setOrder(int order);
+ void setOrder(int order);
- unsigned char readByte(); // throws ParseException
+ unsigned char readByte(); // throws ParseException
- int readInt(); // throws ParseException
+ int readInt(); // throws ParseException
- long readLong(); // throws ParseException
+ long readLong(); // throws ParseException
- double readDouble(); // throws ParseException
+ double readDouble(); // throws ParseException
private:
- int byteOrder;
- std::istream *stream;
+ int byteOrder;
+ std::istream* stream;
- // buffers to hold primitive datatypes
- unsigned char buf[8];
+ // buffers to hold primitive datatypes
+ unsigned char buf[8];
diff --git a/include/geos/io/ByteOrderDataInStream.inl b/include/geos/io/ByteOrderDataInStream.inl
index e2c0746..ab8dcdb 100644
--- a/include/geos/io/ByteOrderDataInStream.inl
+++ b/include/geos/io/ByteOrderDataInStream.inl
@@ -8,7 +8,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -31,10 +31,10 @@ namespace geos {
namespace io {
INLINE
-ByteOrderDataInStream::ByteOrderDataInStream(std::istream *s)
- byteOrder(getMachineByteOrder()),
- stream(s)
+ByteOrderDataInStream::ByteOrderDataInStream(std::istream* s)
+ byteOrder(getMachineByteOrder()),
+ stream(s)
@@ -43,52 +43,56 @@ ByteOrderDataInStream::~ByteOrderDataInStream()
-INLINE void
-ByteOrderDataInStream::setInStream(std::istream *s)
+INLINE void
+ByteOrderDataInStream::setInStream(std::istream* s)
- stream=s;
+ stream = s;
INLINE void
ByteOrderDataInStream::setOrder(int order)
- byteOrder=order;
+ byteOrder = order;
INLINE unsigned char
ByteOrderDataInStream::readByte() // throws ParseException
- stream->read(reinterpret_cast<char *>(buf), 1);
- if ( stream->eof() )
- throw ParseException("Unexpected EOF parsing WKB");
- return buf[0];
+ stream->read(reinterpret_cast<char*>(buf), 1);
+ if(stream->eof()) {
+ throw ParseException("Unexpected EOF parsing WKB");
+ return buf[0];
INLINE int
-ByteOrderDataInStream::readInt()
+ByteOrderDataInStream::readInt()
- stream->read(reinterpret_cast<char *>(buf), 4);
- return ByteOrderValues::getInt(buf, byteOrder);
+ stream->read(reinterpret_cast<char*>(buf), 4);
+ return ByteOrderValues::getInt(buf, byteOrder);
INLINE long
-ByteOrderDataInStream::readLong()
+ByteOrderDataInStream::readLong()
- stream->read(reinterpret_cast<char *>(buf), 8);
- return static_cast<long>(ByteOrderValues::getLong(buf, byteOrder));
+ stream->read(reinterpret_cast<char*>(buf), 8);
+ return static_cast<long>(ByteOrderValues::getLong(buf, byteOrder));
INLINE double
-ByteOrderDataInStream::readDouble()
+ByteOrderDataInStream::readDouble()
- return ByteOrderValues::getDouble(buf, byteOrder);
+ return ByteOrderValues::getDouble(buf, byteOrder);
} // namespace io
diff --git a/include/geos/io/ByteOrderValues.h b/include/geos/io/ByteOrderValues.h
index c7394ed..779cb9b 100644
--- a/include/geos/io/ByteOrderValues.h
+++ b/include/geos/io/ByteOrderValues.h
@@ -38,20 +38,19 @@ class GEOS_DLL ByteOrderValues {
public:
- enum EndianType
+ enum EndianType {
ENDIAN_BIG = 0,
ENDIAN_LITTLE = 1
- static int getInt(const unsigned char *buf, int byteOrder);
- static void putInt(int intValue, unsigned char *buf, int byteOrder);
+ static int getInt(const unsigned char* buf, int byteOrder);
+ static void putInt(int intValue, unsigned char* buf, int byteOrder);
- static int64 getLong(const unsigned char *buf, int byteOrder);
- static void putLong(int64 longValue, unsigned char *buf, int byteOrder);
+ static int64 getLong(const unsigned char* buf, int byteOrder);
+ static void putLong(int64 longValue, unsigned char* buf, int byteOrder);
- static double getDouble(const unsigned char *buf, int byteOrder);
- static void putDouble(double doubleValue, unsigned char *buf, int byteOrder);
+ static double getDouble(const unsigned char* buf, int byteOrder);
+ static void putDouble(double doubleValue, unsigned char* buf, int byteOrder);
diff --git a/include/geos/io/CLocalizer.h b/include/geos/io/CLocalizer.h
index 3b3d55c..a9b6175 100644
--- a/include/geos/io/CLocalizer.h
+++ b/include/geos/io/CLocalizer.h
@@ -34,8 +34,7 @@ namespace io {
* \class CLocalizer io.h geos.h
-class GEOS_DLL CLocalizer
+class GEOS_DLL CLocalizer {
public:
CLocalizer();
diff --git a/include/geos/io/ParseException.h b/include/geos/io/ParseException.h
index bcef225..4b5003a 100644
--- a/include/geos/io/ParseException.h
+++ b/include/geos/io/ParseException.h
@@ -31,23 +31,22 @@ namespace io {
* \class ParseException io.h geos.h
* \brief Notifies a parsing error
-class GEOS_DLL ParseException : public util::GEOSException
+class GEOS_DLL ParseException : public util::GEOSException {
public:
- ParseException();
+ ParseException();
- ParseException(const std::string& msg);
+ ParseException(const std::string& msg);
- ParseException(const std::string& msg, const std::string& var);
+ ParseException(const std::string& msg, const std::string& var);
- ParseException(const std::string& msg, double num);
+ ParseException(const std::string& msg, double num);
- ~ParseException() throw() override {}
+ ~ParseException() throw() override {}
private:
- static std::string stringify(double num);
+ static std::string stringify(double num);
} // namespace io
diff --git a/include/geos/io/StringTokenizer.h b/include/geos/io/StringTokenizer.h
index 7901326..e502c73 100644
--- a/include/geos/io/StringTokenizer.h
+++ b/include/geos/io/StringTokenizer.h
@@ -34,24 +34,24 @@ namespace io {
class GEOS_DLL StringTokenizer {
public:
- enum {
- TT_EOF,
- TT_EOL,
- TT_NUMBER,
- TT_WORD
- //StringTokenizer();
- explicit StringTokenizer(const std::string& txt);
- ~StringTokenizer() {}
- int nextToken();
- int peekNextToken();
- double getNVal();
- std::string getSVal();
+ enum {
+ TT_EOF,
+ TT_EOL,
+ TT_NUMBER,
+ TT_WORD
+ //StringTokenizer();
+ explicit StringTokenizer(const std::string& txt);
+ ~StringTokenizer() {}
+ int nextToken();
+ int peekNextToken();
+ double getNVal();
+ std::string getSVal();
private:
- const std::string &str;
- std::string stok;
- double ntok;
- std::string::const_iterator iter;
+ const std::string& str;
+ std::string stok;
+ double ntok;
+ std::string::const_iterator iter;
// Declare type as noncopyable
StringTokenizer(const StringTokenizer& other) = delete;
diff --git a/include/geos/io/WKBConstants.h b/include/geos/io/WKBConstants.h
index 202b5c8..59ab732 100644
--- a/include/geos/io/WKBConstants.h
+++ b/include/geos/io/WKBConstants.h
@@ -26,19 +26,19 @@ namespace io {
/// Constant values used by the WKB format
namespace WKBConstants {
- /// Big Endian
- const int wkbXDR = 0;
- /// Little Endian
- const int wkbNDR = 1;
- const int wkbPoint = 1;
- const int wkbLineString = 2;
- const int wkbPolygon = 3;
- const int wkbMultiPoint = 4;
- const int wkbMultiLineString = 5;
- const int wkbMultiPolygon = 6;
- const int wkbGeometryCollection = 7;
+/// Big Endian
+const int wkbXDR = 0;
+/// Little Endian
+const int wkbNDR = 1;
+const int wkbPoint = 1;
+const int wkbLineString = 2;
+const int wkbPolygon = 3;
+const int wkbMultiPoint = 4;
+const int wkbMultiLineString = 5;
+const int wkbMultiPolygon = 6;
+const int wkbGeometryCollection = 7;
} // namespace geos::io
diff --git a/include/geos/io/WKBReader.h b/include/geos/io/WKBReader.h
index b9399ba..a12ca39 100644
--- a/include/geos/io/WKBReader.h
+++ b/include/geos/io/WKBReader.h
@@ -38,22 +38,22 @@
namespace geos {
- namespace geom {
- //class GeometryFactory;
- class Coordinate;
- class Geometry;
- class GeometryCollection;
- class Point;
- class LineString;
- class LinearRing;
- class Polygon;
- class MultiPoint;
- class MultiLineString;
- class MultiPolygon;
- class PrecisionModel;
- } // namespace geom
+namespace geom {
+//class GeometryFactory;
+class Coordinate;
+class Geometry;
+class GeometryCollection;
+class Point;
+class LineString;
+class LinearRing;
+class Polygon;
+class MultiPoint;
+class MultiLineString;
+class MultiPolygon;
+class PrecisionModel;
+} // namespace geom
} // namespace geos
@@ -80,82 +80,82 @@ class GEOS_DLL WKBReader {
public:
- WKBReader(geom::GeometryFactory const& f): factory(f) {}
- /// Inizialize parser with default GeometryFactory.
- WKBReader();
- * \brief Reads a Geometry from an istream.
- * @param is the stream to read from
- * @return the Geometry read
- * @throws IOException
- * @throws ParseException
- geom::Geometry* read(std::istream &is);
- // throws IOException, ParseException
- * \brief Reads a Geometry from an istream in hex format.
- geom::Geometry *readHEX(std::istream &is);
- * \brief Print WKB in HEX form to out stream
- * @param is is the stream to read from
- * @param os is the stream to write to
- static std::ostream &printHEX(std::istream &is, std::ostream &os);
+ WKBReader(geom::GeometryFactory const& f): factory(f) {}
+ /// Inizialize parser with default GeometryFactory.
+ WKBReader();
+ * \brief Reads a Geometry from an istream.
+ * @param is the stream to read from
+ * @return the Geometry read
+ * @throws IOException
+ * @throws ParseException
+ geom::Geometry* read(std::istream& is);
+ // throws IOException, ParseException
+ * \brief Reads a Geometry from an istream in hex format.
+ geom::Geometry* readHEX(std::istream& is);
+ * \brief Print WKB in HEX form to out stream
+ * @param is is the stream to read from
+ * @param os is the stream to write to
+ static std::ostream& printHEX(std::istream& is, std::ostream& os);
private:
- const geom::GeometryFactory &factory;
+ const geom::GeometryFactory& factory;
- // for now support the WKB standard only - may be generalized later
- unsigned int inputDimension;
+ // for now support the WKB standard only - may be generalized later
+ unsigned int inputDimension;
- ByteOrderDataInStream dis;
+ ByteOrderDataInStream dis;
- std::vector<double> ordValues;
+ std::vector<double> ordValues;
- geom::Geometry *readGeometry();
+ geom::Geometry* readGeometry();
- geom::Point *readPoint();
+ geom::Point* readPoint();
- geom::LineString *readLineString();
+ geom::LineString* readLineString();
- geom::LinearRing *readLinearRing();
+ geom::LinearRing* readLinearRing();
- geom::Polygon *readPolygon();
+ geom::Polygon* readPolygon();
- geom::MultiPoint *readMultiPoint();
+ geom::MultiPoint* readMultiPoint();
- geom::MultiLineString *readMultiLineString();
+ geom::MultiLineString* readMultiLineString();
- geom::MultiPolygon *readMultiPolygon();
+ geom::MultiPolygon* readMultiPolygon();
- geom::GeometryCollection *readGeometryCollection();
+ geom::GeometryCollection* readGeometryCollection();
- geom::CoordinateSequence *readCoordinateSequence(int); // throws IOException
+ geom::CoordinateSequence* readCoordinateSequence(int); // throws IOException
- void readCoordinate(); // throws IOException
+ void readCoordinate(); // throws IOException
WKBReader(const WKBReader& other) = delete;
diff --git a/include/geos/io/WKBWriter.h b/include/geos/io/WKBWriter.h
index 32a3914..902f303 100644
--- a/include/geos/io/WKBWriter.h
+++ b/include/geos/io/WKBWriter.h
@@ -27,21 +27,21 @@
// Forward declarations
namespace geos {
- namespace geom {
- class CoordinateSequence;
- class Geometry;
- class Point;
- class LineString;
- class LinearRing;
- class Polygon;
- class MultiPoint;
+namespace geom {
+class CoordinateSequence;
+class Geometry;
+class Point;
+class LineString;
+class LinearRing;
+class Polygon;
+class MultiPoint;
} // namespace geos
namespace geos {
@@ -72,9 +72,9 @@ namespace io {
class GEOS_DLL WKBWriter {
public:
- * \brief
- * Initializes writer with target coordinate dimension, endianness
+ * \brief
+ * Initializes writer with target coordinate dimension, endianness
* flag and SRID value.
* @param dims Supported values are 2 or 3. Note that 3 indicates
@@ -84,118 +84,134 @@ public:
* @param incudeSRID true if SRID should be included in WKB (an
* extension).
- WKBWriter(int dims=2, int bo=getMachineByteOrder(), bool includeSRID=false);
- * \brief
- * Destructor.
- virtual ~WKBWriter();
- * \brief
- * Returns the output dimension used by the
- * <code>WKBWriter</code>.
- virtual int getOutputDimension() const { return defaultOutputDimension; }
- * Sets the output dimension used by the <code>WKBWriter</code>.
- * @param newOutputDimension Supported values are 2 or 3.
- * Note that 3 indicates up to 3 dimensions will be written but
- * 2D WKB is still produced for 2D geometries.
- virtual void setOutputDimension(int newOutputDimension);
- * \brief
- * Returns the byte order used by the
- virtual int getByteOrder() const { return byteOrder; }
- * Sets the byte order used by the
- virtual void setByteOrder(int newByteOrder);
- * \brief
- * Returns whether SRID values are output by the
- virtual int getIncludeSRID() const { return includeSRID; }
- * Sets whether SRID values should be output by the
- virtual void setIncludeSRID(int newIncludeSRID) { includeSRID = (0 == newIncludeSRID ? false : true); }
- * \brief Write a Geometry to an ostream.
- * @param g the geometry to write
- * @param os the output stream
- void write(const geom::Geometry &g, std::ostream &os);
- * \brief Write a Geometry to an ostream in binary hex format.
- void writeHEX(const geom::Geometry &g, std::ostream &os);
+ WKBWriter(int dims = 2, int bo = getMachineByteOrder(), bool includeSRID = false);
+ * \brief
+ * Destructor.
+ virtual ~WKBWriter();
+ * \brief
+ * Returns the output dimension used by the
+ * <code>WKBWriter</code>.
+ virtual int
+ getOutputDimension() const
+ return defaultOutputDimension;
+ * Sets the output dimension used by the <code>WKBWriter</code>.
+ * @param newOutputDimension Supported values are 2 or 3.
+ * Note that 3 indicates up to 3 dimensions will be written but
+ * 2D WKB is still produced for 2D geometries.
+ virtual void setOutputDimension(int newOutputDimension);
+ * \brief
+ * Returns the byte order used by the
+ virtual int
+ getByteOrder() const
+ return byteOrder;
+ * Sets the byte order used by the
+ virtual void setByteOrder(int newByteOrder);
+ * \brief
+ * Returns whether SRID values are output by the
+ virtual int
+ getIncludeSRID() const
+ return includeSRID;
+ * Sets whether SRID values should be output by the
+ virtual void
+ setIncludeSRID(int newIncludeSRID)
+ includeSRID = (0 == newIncludeSRID ? false : true);
+ * \brief Write a Geometry to an ostream.
+ * @param g the geometry to write
+ * @param os the output stream
+ void write(const geom::Geometry& g, std::ostream& os);
+ * \brief Write a Geometry to an ostream in binary hex format.
+ void writeHEX(const geom::Geometry& g, std::ostream& os);
private:
- int defaultOutputDimension;
+ int defaultOutputDimension;
int outputDimension;
- int byteOrder;
+ int byteOrder;
- bool includeSRID;
+ bool includeSRID;
- std::ostream *outStream;
+ std::ostream* outStream;
- void writePoint(const geom::Point &p);
+ void writePoint(const geom::Point& p);
- void writeLineString(const geom::LineString &ls);
+ void writeLineString(const geom::LineString& ls);
- void writePolygon(const geom::Polygon &p);
+ void writePolygon(const geom::Polygon& p);
- void writeGeometryCollection(const geom::GeometryCollection &c, int wkbtype);
+ void writeGeometryCollection(const geom::GeometryCollection& c, int wkbtype);
- void writeCoordinateSequence(const geom::CoordinateSequence &cs, bool sized);
+ void writeCoordinateSequence(const geom::CoordinateSequence& cs, bool sized);
- void writeCoordinate(const geom::CoordinateSequence &cs, size_t idx, bool is3d);
+ void writeCoordinate(const geom::CoordinateSequence& cs, size_t idx, bool is3d);
- void writeGeometryType(int geometryType, int SRID);
+ void writeGeometryType(int geometryType, int SRID);
- void writeSRID(int SRID);
+ void writeSRID(int SRID);
- void writeByteOrder();
+ void writeByteOrder();
- void writeInt(int intValue);
+ void writeInt(int intValue);
diff --git a/include/geos/io/WKTReader.h b/include/geos/io/WKTReader.h
index 0d49bb5..1dfd4ff 100644
--- a/include/geos/io/WKTReader.h
+++ b/include/geos/io/WKTReader.h
@@ -28,23 +28,23 @@
namespace geos {
- namespace io {
- class StringTokenizer;
- namespace geom {
- class Coordinate;
- class Geometry;
- class Point;
- class LineString;
- class LinearRing;
- class Polygon;
- class MultiPoint;
+namespace io {
+class StringTokenizer;
+namespace geom {
+class Coordinate;
+class Geometry;
+class Point;
+class LineString;
+class LinearRing;
+class Polygon;
+class MultiPoint;
@@ -57,57 +57,57 @@ namespace io {
class GEOS_DLL WKTReader {
public:
- //WKTReader();
+ //WKTReader();
- * \brief Inizialize parser with given GeometryFactory.
- * Note that all Geometry objects created by the
- * parser will contain a pointer to the given factory
- * so be sure you'll keep the factory alive for the
- * whole WKTReader and created Geometry life.
- WKTReader(const geom::GeometryFactory &gf);
+ * \brief Inizialize parser with given GeometryFactory.
+ * Note that all Geometry objects created by the
+ * parser will contain a pointer to the given factory
+ * so be sure you'll keep the factory alive for the
+ * whole WKTReader and created Geometry life.
+ WKTReader(const geom::GeometryFactory& gf);
- /** @deprecated in 3.4.0 */
- WKTReader(const geom::GeometryFactory *gf);
+ /** @deprecated in 3.4.0 */
+ WKTReader(const geom::GeometryFactory* gf);
- * \brief Inizialize parser with default GeometryFactory.
- WKTReader();
+ * \brief Inizialize parser with default GeometryFactory.
+ WKTReader();
- ~WKTReader();
+ ~WKTReader();
- /// Parse a WKT string returning a Geometry
- geom::Geometry* read(const std::string &wellKnownText);
+ /// Parse a WKT string returning a Geometry
+ geom::Geometry* read(const std::string& wellKnownText);
// Geometry* read(Reader& reader); //Not implemented yet
protected:
- geom::CoordinateSequence* getCoordinates(io::StringTokenizer *tokenizer);
- double getNextNumber(io::StringTokenizer *tokenizer);
- std::string getNextEmptyOrOpener(io::StringTokenizer *tokenizer);
- std::string getNextCloserOrComma(io::StringTokenizer *tokenizer);
- std::string getNextCloser(io::StringTokenizer *tokenizer);
- std::string getNextWord(io::StringTokenizer *tokenizer);
- geom::Geometry* readGeometryTaggedText(io::StringTokenizer *tokenizer);
- geom::Point* readPointText(io::StringTokenizer *tokenizer);
- geom::LineString* readLineStringText(io::StringTokenizer *tokenizer);
- geom::LinearRing* readLinearRingText(io::StringTokenizer *tokenizer);
- geom::MultiPoint* readMultiPointText(io::StringTokenizer *tokenizer);
- geom::Polygon* readPolygonText(io::StringTokenizer *tokenizer);
- geom::MultiLineString* readMultiLineStringText(io::StringTokenizer *tokenizer);
- geom::MultiPolygon* readMultiPolygonText(io::StringTokenizer *tokenizer);
- geom::GeometryCollection* readGeometryCollectionText(io::StringTokenizer *tokenizer);
+ geom::CoordinateSequence* getCoordinates(io::StringTokenizer* tokenizer);
+ double getNextNumber(io::StringTokenizer* tokenizer);
+ std::string getNextEmptyOrOpener(io::StringTokenizer* tokenizer);
+ std::string getNextCloserOrComma(io::StringTokenizer* tokenizer);
+ std::string getNextCloser(io::StringTokenizer* tokenizer);
+ std::string getNextWord(io::StringTokenizer* tokenizer);
+ geom::Geometry* readGeometryTaggedText(io::StringTokenizer* tokenizer);
+ geom::Point* readPointText(io::StringTokenizer* tokenizer);
+ geom::LineString* readLineStringText(io::StringTokenizer* tokenizer);
+ geom::LinearRing* readLinearRingText(io::StringTokenizer* tokenizer);
+ geom::MultiPoint* readMultiPointText(io::StringTokenizer* tokenizer);
+ geom::Polygon* readPolygonText(io::StringTokenizer* tokenizer);
+ geom::MultiLineString* readMultiLineStringText(io::StringTokenizer* tokenizer);
+ geom::MultiPolygon* readMultiPolygonText(io::StringTokenizer* tokenizer);
+ geom::GeometryCollection* readGeometryCollectionText(io::StringTokenizer* tokenizer);
private:
- const geom::GeometryFactory *geometryFactory;
- const geom::PrecisionModel *precisionModel;
+ const geom::GeometryFactory* geometryFactory;
+ const geom::PrecisionModel* precisionModel;
- void getPreciseCoordinate(io::StringTokenizer *tokenizer, geom::Coordinate&, std::size_t &dim );
+ void getPreciseCoordinate(io::StringTokenizer* tokenizer, geom::Coordinate&, std::size_t& dim);
- bool isNumberNext(io::StringTokenizer *tokenizer);
+ bool isNumberNext(io::StringTokenizer* tokenizer);
} // namespace io
diff --git a/include/geos/io/WKTReader.inl b/include/geos/io/WKTReader.inl
index a0f1bc5..2e91a36 100644
--- a/include/geos/io/WKTReader.inl
+++ b/include/geos/io/WKTReader.inl
@@ -7,7 +7,7 @@
@@ -30,10 +30,10 @@ namespace geos {
namespace io {
INLINE
-WKTReader::WKTReader(const geom::GeometryFactory *gf)
- geometryFactory(gf),
- precisionModel(gf->getPrecisionModel())
+WKTReader::WKTReader(const geom::GeometryFactory* gf)
+ geometryFactory(gf),
+ precisionModel(gf->getPrecisionModel())
#if GEOS_DEBUG
std::cerr << "\nGEOS_DEBUG: WKTReader::WKTReader(const GeometryFactory *gf)\n";
@@ -41,10 +41,10 @@ WKTReader::WKTReader(const geom::GeometryFactory *gf)
INLINE
-WKTReader::WKTReader(const geom::GeometryFactory &gf)
- geometryFactory(&gf),
- precisionModel(gf.getPrecisionModel())
+WKTReader::WKTReader(const geom::GeometryFactory& gf)
+ geometryFactory(&gf),
+ precisionModel(gf.getPrecisionModel())
#if GEOS_DEBUG
std::cerr << "\nGEOS_DEBUG: WKTReader::WKTReader(const GeometryFactory &gf)\n";
@@ -53,9 +53,9 @@ WKTReader::WKTReader(const geom::GeometryFactory &gf)
INLINE
WKTReader::WKTReader()
- geometryFactory(geom::GeometryFactory::getDefaultInstance()),
- precisionModel(geometryFactory->getPrecisionModel())
+ geometryFactory(geom::GeometryFactory::getDefaultInstance()),
+ precisionModel(geometryFactory->getPrecisionModel())
#if GEOS_DEBUG
std::cerr << "\nGEOS_DEBUG: WKTReader::WKTReader()\n";
diff --git a/include/geos/io/WKTWriter.h b/include/geos/io/WKTWriter.h
index e034804..ed05fc2 100644
--- a/include/geos/io/WKTWriter.h
+++ b/include/geos/io/WKTWriter.h
@@ -32,23 +32,23 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Geometry;
- class Point;
- class LineString;
- class LinearRing;
- class Polygon;
- class MultiPoint;
- namespace io {
- class Writer;
+namespace geom {
+class Coordinate;
+class Geometry;
+class Point;
+class LineString;
+class LinearRing;
+class Polygon;
+class MultiPoint;
+namespace io {
+class Writer;
@@ -78,190 +78,198 @@ namespace io {
class GEOS_DLL WKTWriter {
public:
- WKTWriter();
- ~WKTWriter();
- //string(count, ch) can be used for this
- //static string stringOfChar(char ch, int count);
- /// Returns WKT string for the given Geometry
- std::string write(const geom::Geometry *geometry);
- // Send Geometry's WKT to the given Writer
- void write(const geom::Geometry *geometry, Writer *writer);
- std::string writeFormatted(const geom::Geometry *geometry);
- void writeFormatted(const geom::Geometry *geometry, Writer *writer);
- * Generates the WKT for a N-point <code>LineString</code>.
- * @param seq the sequence to outpout
- * @return the WKT
- static std::string toLineString(const geom::CoordinateSequence& seq);
- * Generates the WKT for a 2-point <code>LineString</code>.
- * @param p0 the first coordinate
- * @param p1 the second coordinate
- * @return the WKT
- static std::string toLineString(const geom::Coordinate& p0, const geom::Coordinate& p1);
- * Generates the WKT for a <code>Point</code>.
- * @param p0 the point coordinate
- * @return the WKT
- static std::string toPoint(const geom::Coordinate& p0);
- * Sets the rounding precision when writing the WKT
- * a precision of -1 disables it
- * @param p0 the new precision to use
- void setRoundingPrecision(int p0);
- * Enables/disables trimming of unnecessary decimals
- * @param p0 the trim boolean
- void setTrim(bool p0);
- * Enable old style 3D/4D WKT generation.
- * By default the WKBWriter produces new style 3D/4D WKT
- * (ie. "POINT Z (10 20 30)") but if this method is used
- * to turn on old style WKT production then the WKT will
- * be formatted in the style "POINT (10 20 30)".
- * @param useOld3D true or false
- void setOld3D(bool useOld3D ) { old3D = useOld3D; }
- * \brief
- int getOutputDimension() const { return defaultOutputDimension; }
- * written but 2D WKB is still produced for 2D geometries.
- void setOutputDimension(int newOutputDimension);
+ WKTWriter();
+ ~WKTWriter();
+ //string(count, ch) can be used for this
+ //static string stringOfChar(char ch, int count);
+ /// Returns WKT string for the given Geometry
+ std::string write(const geom::Geometry* geometry);
+ // Send Geometry's WKT to the given Writer
+ void write(const geom::Geometry* geometry, Writer* writer);
+ std::string writeFormatted(const geom::Geometry* geometry);
+ void writeFormatted(const geom::Geometry* geometry, Writer* writer);
+ * Generates the WKT for a N-point <code>LineString</code>.
+ * @param seq the sequence to outpout
+ * @return the WKT
+ static std::string toLineString(const geom::CoordinateSequence& seq);
+ * Generates the WKT for a 2-point <code>LineString</code>.
+ * @param p0 the first coordinate
+ * @param p1 the second coordinate
+ * @return the WKT
+ static std::string toLineString(const geom::Coordinate& p0, const geom::Coordinate& p1);
+ * Generates the WKT for a <code>Point</code>.
+ * @param p0 the point coordinate
+ * @return the WKT
+ static std::string toPoint(const geom::Coordinate& p0);
+ * Sets the rounding precision when writing the WKT
+ * a precision of -1 disables it
+ * @param p0 the new precision to use
+ void setRoundingPrecision(int p0);
+ * Enables/disables trimming of unnecessary decimals
+ * @param p0 the trim boolean
+ void setTrim(bool p0);
+ * Enable old style 3D/4D WKT generation.
+ * By default the WKBWriter produces new style 3D/4D WKT
+ * (ie. "POINT Z (10 20 30)") but if this method is used
+ * to turn on old style WKT production then the WKT will
+ * be formatted in the style "POINT (10 20 30)".
+ * @param useOld3D true or false
+ void
+ setOld3D(bool useOld3D)
+ old3D = useOld3D;
+ * \brief
+ int
+ * written but 2D WKB is still produced for 2D geometries.
+ void setOutputDimension(int newOutputDimension);
protected:
- int decimalPlaces;
+ int decimalPlaces;
- void appendGeometryTaggedText(const geom::Geometry *geometry, int level, Writer *writer);
+ void appendGeometryTaggedText(const geom::Geometry* geometry, int level, Writer* writer);
- void appendPointTaggedText(
- const geom::Coordinate* coordinate,
- int level, Writer *writer);
+ void appendPointTaggedText(
+ const geom::Coordinate* coordinate,
+ int level, Writer* writer);
- void appendLineStringTaggedText(
- const geom::LineString *lineString,
+ void appendLineStringTaggedText(
+ const geom::LineString* lineString,
- void appendLinearRingTaggedText(
- const geom::LinearRing *lineString,
+ void appendLinearRingTaggedText(
+ const geom::LinearRing* lineString,
- void appendPolygonTaggedText(
- const geom::Polygon *polygon,
+ void appendPolygonTaggedText(
+ const geom::Polygon* polygon,
- void appendMultiPointTaggedText(
- const geom::MultiPoint *multipoint,
+ void appendMultiPointTaggedText(
+ const geom::MultiPoint* multipoint,
- void appendMultiLineStringTaggedText(
- const geom::MultiLineString *multiLineString,
- int level,Writer *writer);
+ void appendMultiLineStringTaggedText(
+ const geom::MultiLineString* multiLineString,
- void appendMultiPolygonTaggedText(
- const geom::MultiPolygon *multiPolygon,
+ void appendMultiPolygonTaggedText(
+ const geom::MultiPolygon* multiPolygon,
- void appendGeometryCollectionTaggedText(
- const geom::GeometryCollection *geometryCollection,
+ void appendGeometryCollectionTaggedText(
+ const geom::GeometryCollection* geometryCollection,
- void appendPointText(const geom::Coordinate* coordinate, int level,
- Writer *writer);
+ void appendPointText(const geom::Coordinate* coordinate, int level,
+ Writer* writer);
- void appendCoordinate(const geom::Coordinate* coordinate,
- Writer *writer);
+ void appendCoordinate(const geom::Coordinate* coordinate,
+ Writer* writer);
- std::string writeNumber(double d);
+ std::string writeNumber(double d);
- void appendLineStringText(
- int level, bool doIndent, Writer *writer);
+ void appendLineStringText(
+ int level, bool doIndent, Writer* writer);
- void appendPolygonText(
- int level, bool indentFirst, Writer *writer);
+ void appendPolygonText(
+ int level, bool indentFirst, Writer* writer);
- void appendMultiPointText(
- const geom::MultiPoint *multiPoint,
+ void appendMultiPointText(
+ const geom::MultiPoint* multiPoint,
- void appendMultiLineStringText(
- int level, bool indentFirst,Writer *writer);
+ void appendMultiLineStringText(
- void appendMultiPolygonText(
+ void appendMultiPolygonText(
- void appendGeometryCollectionText(
+ void appendGeometryCollectionText(
private:
- enum {
- INDENT = 2
+ enum {
+ INDENT = 2
// static const int INDENT = 2;
- bool isFormatted;
+ bool isFormatted;
- int roundingPrecision;
+ int roundingPrecision;
- bool trim;
+ bool trim;
- int level;
+ int level;
bool old3D;
- const geom::Geometry *geometry,
- bool isFormatted, Writer *writer);
+ const geom::Geometry* geometry,
+ bool isFormatted, Writer* writer);
- void indent(int level, Writer *writer);
+ void indent(int level, Writer* writer);
diff --git a/include/geos/io/Writer.h b/include/geos/io/Writer.h
index ffca1d8..9cfc344 100644
--- a/include/geos/io/Writer.h
+++ b/include/geos/io/Writer.h
@@ -34,13 +34,13 @@ namespace io {
class GEOS_DLL Writer {
public:
- Writer();
- void reserve(std::size_t capacity);
- ~Writer();
- void write(const std::string& txt);
- const std::string& toString();
+ Writer();
+ void reserve(std::size_t capacity);
+ ~Writer();
+ void write(const std::string& txt);
+ const std::string& toString();
private:
- std::string str;
+ std::string str;
diff --git a/include/geos/linearref/ExtractLineByLocation.h b/include/geos/linearref/ExtractLineByLocation.h
index 44a3b43..43e9968 100644
--- a/include/geos/linearref/ExtractLineByLocation.h
+++ b/include/geos/linearref/ExtractLineByLocation.h
@@ -24,65 +24,62 @@
#include <geos/geom/Geometry.h>
#include <geos/linearref/LinearLocation.h>
-namespace geos
-namespace linearref // geos::linearref
+namespace geos {
+namespace linearref { // geos::linearref
* Extracts the subline of a linear {@link Geometry} between
* two {@link LinearLocation}s on the line.
-class ExtractLineByLocation
+class ExtractLineByLocation {
private:
- const geom::Geometry *line;
- geom::Geometry *reverse(const geom::Geometry *linear);
+ const geom::Geometry* line;
+ geom::Geometry* reverse(const geom::Geometry* linear);
- * Assumes input is valid (e.g. start <= end)
- * @param start
- * @param end
- * @return a linear geometry
- geom::LineString* computeLine(const LinearLocation& start, const LinearLocation& end);
+ * Assumes input is valid (e.g. start <= end)
+ * @param start
+ * @param end
+ * @return a linear geometry
+ geom::LineString* computeLine(const LinearLocation& start, const LinearLocation& end);
- * @param start
- * @param end
- geom::Geometry *computeLinear(const LinearLocation& start, const LinearLocation& end);
+ * @param start
+ * @param end
+ geom::Geometry* computeLinear(const LinearLocation& start, const LinearLocation& end);
public:
- * Computes the subline of a {@link LineString} between
- * two {@link LineStringLocation}s on the line.
- * If the start location is after the end location,
- * the computed geometry is reversed.
- * @param line the line to use as the baseline
- * @param start the start location
- * @param end the end location
- * @return the extracted subline
- static geom::Geometry *extract(const geom::Geometry *line, const LinearLocation& start, const LinearLocation& end);
+ * Computes the subline of a {@link LineString} between
+ * two {@link LineStringLocation}s on the line.
+ * If the start location is after the end location,
+ * the computed geometry is reversed.
+ * @param line the line to use as the baseline
+ * @param start the start location
+ * @param end the end location
+ * @return the extracted subline
+ static geom::Geometry* extract(const geom::Geometry* line, const LinearLocation& start, const LinearLocation& end);
- ExtractLineByLocation(const geom::Geometry *line);
+ ExtractLineByLocation(const geom::Geometry* line);
- * Extracts a subline of the input.
- * If <code>end < start</code> the linear geometry computed will be reversed.
- geom::Geometry *extract(const LinearLocation& start, const LinearLocation& end);
+ * Extracts a subline of the input.
+ * If <code>end < start</code> the linear geometry computed will be reversed.
+ geom::Geometry* extract(const LinearLocation& start, const LinearLocation& end);
diff --git a/include/geos/linearref/LengthIndexOfPoint.h b/include/geos/linearref/LengthIndexOfPoint.h
index fb5cdc4..f640394 100644
--- a/include/geos/linearref/LengthIndexOfPoint.h
+++ b/include/geos/linearref/LengthIndexOfPoint.h
@@ -28,10 +28,8 @@
-namespace geos
+namespace geos {
* \brief
@@ -42,48 +40,47 @@ namespace linearref // geos::linearref
* always computes the nearest point closest to
* the start of the geometry.
-class LengthIndexOfPoint
+class LengthIndexOfPoint {
private:
- const geom::Geometry *linearGeom;
+ const geom::Geometry* linearGeom;
- double indexOfFromStart(const geom::Coordinate& inputPt, const double minIndex) const;
+ double indexOfFromStart(const geom::Coordinate& inputPt, const double minIndex) const;
- double segmentNearestMeasure(const geom::LineSegment *seg,
- const geom::Coordinate& inputPt,
- double segmentStartMeasure) const;
+ double segmentNearestMeasure(const geom::LineSegment* seg,
+ const geom::Coordinate& inputPt,
+ double segmentStartMeasure) const;
public:
- static double indexOf(const geom::Geometry *linearGeom, const geom::Coordinate& inputPt);
+ static double indexOf(const geom::Geometry* linearGeom, const geom::Coordinate& inputPt);
- static double indexOfAfter(const geom::Geometry *linearGeom, const geom::Coordinate& inputPt, double minIndex);
+ static double indexOfAfter(const geom::Geometry* linearGeom, const geom::Coordinate& inputPt, double minIndex);
- LengthIndexOfPoint(const geom::Geometry *linearGeom);
+ LengthIndexOfPoint(const geom::Geometry* linearGeom);
- * Find the nearest location along a linear Geometry to a given point.
- * @param inputPt the coordinate to locate
- * @return the location of the nearest point
- double indexOf(const geom::Coordinate& inputPt) const;
+ * Find the nearest location along a linear Geometry to a given point.
+ * @param inputPt the coordinate to locate
+ * @return the location of the nearest point
+ double indexOf(const geom::Coordinate& inputPt) const;
- /** \brief
- * Finds the nearest index along the linear Geometry
- * to a given Coordinate after the specified minimum index.
- * If possible the location returned will be strictly greater than the
- * <code>minLocation</code>.
- * If this is not possible, the
- * value returned will equal <code>minLocation</code>.
- * (An example where this is not possible is when
- * minLocation = [end of line] ).
- * @param minLocation the minimum location for the point location
- double indexOfAfter(const geom::Coordinate& inputPt, double minIndex) const;
+ /** \brief
+ * Finds the nearest index along the linear Geometry
+ * to a given Coordinate after the specified minimum index.
+ * If possible the location returned will be strictly greater than the
+ * <code>minLocation</code>.
+ * If this is not possible, the
+ * value returned will equal <code>minLocation</code>.
+ * (An example where this is not possible is when
+ * minLocation = [end of line] ).
+ * @param minLocation the minimum location for the point location
+ double indexOfAfter(const geom::Coordinate& inputPt, double minIndex) const;
diff --git a/include/geos/linearref/LengthIndexedLine.h b/include/geos/linearref/LengthIndexedLine.h
index ede548e..d0c74b3 100644
--- a/include/geos/linearref/LengthIndexedLine.h
+++ b/include/geos/linearref/LengthIndexedLine.h
@@ -26,10 +26,8 @@
-namespace geos
+namespace geos {
/** \brief
* Supports linear referencing along a linear {@link Geometry}
@@ -42,166 +40,165 @@ namespace linearref // geos::linearref
* themselves) are supported.
-class GEOS_DLL LengthIndexedLine
+class GEOS_DLL LengthIndexedLine {
private:
- LinearLocation locationOf(double index) const;
- LinearLocation locationOf(double index, bool resolveLower) const;
- double positiveIndex(double index) const;
+ LinearLocation locationOf(double index) const;
+ LinearLocation locationOf(double index, bool resolveLower) const;
+ double positiveIndex(double index) const;
public:
- /** \brief
- * Constructs an object which allows a linear {@link Geometry}
- * to be linearly referenced using length as an index.
- * @param linearGeom the linear geometry to reference along
- LengthIndexedLine(const geom::Geometry *linearGeom);
- /** \brief
- * Computes the {@link Coordinate} for the point
- * on the line at the given index.
- * If the index is out of range the first or last point on the
- * line will be returned.
- * The Z-ordinate of the computed point will be interpolated from
- * the Z-ordinates of the line segment containing it, if they exist.
- * @param index the index of the desired point
- * @return the Coordinate at the given index
- geom::Coordinate extractPoint(double index) const;
- * \brief
- * on the line at the given index, offset by the given distance.
- * The computed point is offset to the left of the line if the
- * offset distance is positive, to the right if negative.
- * @param offsetDistance the distance the point is offset from the segment
- * (positive is to the left, negative is to the right)
- geom::Coordinate extractPoint(double index, double offsetDistance) const;
- * Computes the {@link LineString} for the interval
- * on the line between the given indices.
- * If the endIndex lies before the startIndex,
- * @param startIndex the index of the start of the interval
- * @param endIndex the index of the end of the interval
- * @return the linear interval between the indices
- geom::Geometry *extractLine(double startIndex, double endIndex) const;
- * Computes the minimum index for a point on the line.
- * If the line is not simple (i.e. loops back on itself)
- * a single point may have more than one possible index.
- * In this case, the smallest index is returned.
- * The supplied point does not <i>necessarily</i> have to lie precisely
- * on the line, but if it is far from the line the accuracy and
- * performance of this function is not guaranteed.
- * Use {@link #project} to compute a guaranteed result for points
- * which may be far from the line.
- * @param pt a point on the line
- * @return the minimum index of the point
- * @see project
- double indexOf(const geom::Coordinate& pt) const;
- * Finds the index for a point on the line
- * which is greater than the given index.
- * If no such index exists, returns <tt>minIndex</tt>.
- * This method can be used to determine all indexes for
- * a point which occurs more than once on a non-simple line.
- * It can also be used to disambiguate cases where the given point lies
- * slightly off the line and is equidistant from two different
- * points on the line.
- * @param minIndex the value the returned index must be greater than
- * @return the index of the point greater than the given minimum index
- * @see project
- double indexOfAfter(const geom::Coordinate& pt, double minIndex) const;
- * Computes the indices for a subline of the line.
- * (The subline must <b>conform</b> to the line; that is,
- * all vertices in the subline (except possibly the first and last)
- * must be vertices of the line and occcur in the same order).
- * @param subLine a subLine of the line
- * @return a pair of indices for the start and end of the subline.
- double* indicesOf(const geom::Geometry *subLine) const;
- * Computes the index for the closest point on the line to the given point.
- * If more than one point has the closest distance the first one along the line
- * is returned.
- * (The point does not necessarily have to lie precisely on the line.)
- double project(const geom::Coordinate& pt) const;
- * Returns the index of the start of the line
- * @return the start index
- double getStartIndex() const;
- * Returns the index of the end of the line
- * @return the end index
- double getEndIndex() const;
- * Tests whether an index is in the valid index range for the line.
- * @param length the index to test
- * @return <code>true</code> if the index is in the valid range
- bool isValidIndex(double index) const;
- * Computes a valid index for this line
- * by clamping the given index to the valid range of index values
- * @return a valid index value
- double clampIndex(double index) const;
+ /** \brief
+ * Constructs an object which allows a linear {@link Geometry}
+ * to be linearly referenced using length as an index.
+ * @param linearGeom the linear geometry to reference along
+ LengthIndexedLine(const geom::Geometry* linearGeom);
+ /** \brief
+ * Computes the {@link Coordinate} for the point
+ * on the line at the given index.
+ * If the index is out of range the first or last point on the
+ * line will be returned.
+ * The Z-ordinate of the computed point will be interpolated from
+ * the Z-ordinates of the line segment containing it, if they exist.
+ * @param index the index of the desired point
+ * @return the Coordinate at the given index
+ geom::Coordinate extractPoint(double index) const;
+ * \brief
+ * on the line at the given index, offset by the given distance.
+ * The computed point is offset to the left of the line if the
+ * offset distance is positive, to the right if negative.
+ * @param offsetDistance the distance the point is offset from the segment
+ * (positive is to the left, negative is to the right)
+ geom::Coordinate extractPoint(double index, double offsetDistance) const;
+ * Computes the {@link LineString} for the interval
+ * on the line between the given indices.
+ * If the endIndex lies before the startIndex,
+ * @param startIndex the index of the start of the interval
+ * @param endIndex the index of the end of the interval
+ * @return the linear interval between the indices
+ geom::Geometry* extractLine(double startIndex, double endIndex) const;
+ * Computes the minimum index for a point on the line.
+ * If the line is not simple (i.e. loops back on itself)
+ * a single point may have more than one possible index.
+ * In this case, the smallest index is returned.
+ * The supplied point does not <i>necessarily</i> have to lie precisely
+ * on the line, but if it is far from the line the accuracy and
+ * performance of this function is not guaranteed.
+ * Use {@link #project} to compute a guaranteed result for points
+ * which may be far from the line.
+ * @param pt a point on the line
+ * @return the minimum index of the point
+ * @see project
+ double indexOf(const geom::Coordinate& pt) const;
+ * Finds the index for a point on the line
+ * which is greater than the given index.
+ * If no such index exists, returns <tt>minIndex</tt>.
+ * This method can be used to determine all indexes for
+ * a point which occurs more than once on a non-simple line.
+ * It can also be used to disambiguate cases where the given point lies
+ * slightly off the line and is equidistant from two different
+ * points on the line.
+ * @param minIndex the value the returned index must be greater than
+ * @return the index of the point greater than the given minimum index
+ * @see project
+ double indexOfAfter(const geom::Coordinate& pt, double minIndex) const;
+ * Computes the indices for a subline of the line.
+ * (The subline must <b>conform</b> to the line; that is,
+ * all vertices in the subline (except possibly the first and last)
+ * must be vertices of the line and occcur in the same order).
+ * @param subLine a subLine of the line
+ * @return a pair of indices for the start and end of the subline.
+ double* indicesOf(const geom::Geometry* subLine) const;
+ * Computes the index for the closest point on the line to the given point.
+ * If more than one point has the closest distance the first one along the line
+ * is returned.
+ * (The point does not necessarily have to lie precisely on the line.)
+ double project(const geom::Coordinate& pt) const;
+ * Returns the index of the start of the line
+ * @return the start index
+ double getStartIndex() const;
+ * Returns the index of the end of the line
+ * @return the end index
+ double getEndIndex() const;
+ * Tests whether an index is in the valid index range for the line.
+ * @param length the index to test
+ * @return <code>true</code> if the index is in the valid range
+ bool isValidIndex(double index) const;
+ * Computes a valid index for this line
+ * by clamping the given index to the valid range of index values
+ * @return a valid index value
+ double clampIndex(double index) const;
diff --git a/include/geos/linearref/LengthLocationMap.h b/include/geos/linearref/LengthLocationMap.h
index bc4af6b..cb33543 100644
--- a/include/geos/linearref/LengthLocationMap.h
+++ b/include/geos/linearref/LengthLocationMap.h
@@ -34,95 +34,96 @@ namespace linearref { // geos::linearref
* Negative lengths are measured in reverse from end of the linear geometry.
* Out-of-range values are clamped.
-class LengthLocationMap
+class LengthLocationMap {
private:
- LinearLocation getLocationForward(double length) const;
+ LinearLocation getLocationForward(double length) const;
- LinearLocation resolveHigher(const LinearLocation& loc) const;
+ LinearLocation resolveHigher(const LinearLocation& loc) const;
public:
- // TODO: cache computed cumulative length for each vertex
- // TODO: support user-defined measures
- // TODO: support measure index for fast mapping to a location
- * \brief
- * Computes the {@link LinearLocation} for a
- * given length along a linear {@link Geometry}.
- * @param line the linear geometry to use
- * @param length the length index of the location
- * @return the {@link LinearLocation} for the length
- static LinearLocation getLocation(const geom::Geometry *linearGeom, double length)
- LengthLocationMap locater(linearGeom);
- return locater.getLocation(length);
- * \brief
- * @param resolveLower if true lengths are resolved to the
- * lowest possible index
- static LinearLocation getLocation(const geom::Geometry *linearGeom, double length, bool resolveLower)
- return locater.getLocation(length, resolveLower);
- * Computes the length for a given {@link LinearLocation}
- * on a linear {@link Geometry}.
- * @param loc the {@link LinearLocation} index of the location
- * @return the length for the {@link LinearLocation}
- static double getLength(const geom::Geometry *linearGeom, const LinearLocation& loc);
- LengthLocationMap(const geom::Geometry *linearGeom);
- * \brief
- * Compute the {@link LinearLocation} corresponding to a length.
- * Negative lengths are measured in reverse from end of the linear geometry.
- * Out-of-range values are clamped.
- * Ambiguous indexes are resolved to the lowest possible location value,
- * depending on the value of <tt>resolveLower</tt>.
- * @return the corresponding LinearLocation
- LinearLocation getLocation(double length, bool resolveLower) const;
- * \brief
- * Ambiguous indexes are resolved to the lowest possible location value.
- LinearLocation getLocation(double length) const;
- double getLength(const LinearLocation& loc) const;
+ // TODO: cache computed cumulative length for each vertex
+ // TODO: support user-defined measures
+ // TODO: support measure index for fast mapping to a location
+ * \brief
+ * Computes the {@link LinearLocation} for a
+ * given length along a linear {@link Geometry}.
+ * @param line the linear geometry to use
+ * @param length the length index of the location
+ * @return the {@link LinearLocation} for the length
+ static LinearLocation
+ getLocation(const geom::Geometry* linearGeom, double length)
+ LengthLocationMap locater(linearGeom);
+ return locater.getLocation(length);
+ * \brief
+ * @param resolveLower if true lengths are resolved to the
+ * lowest possible index
+ getLocation(const geom::Geometry* linearGeom, double length, bool resolveLower)
+ return locater.getLocation(length, resolveLower);
+ * Computes the length for a given {@link LinearLocation}
+ * on a linear {@link Geometry}.
+ * @param loc the {@link LinearLocation} index of the location
+ * @return the length for the {@link LinearLocation}
+ static double getLength(const geom::Geometry* linearGeom, const LinearLocation& loc);
+ LengthLocationMap(const geom::Geometry* linearGeom);
+ * \brief
+ * Compute the {@link LinearLocation} corresponding to a length.
+ * Negative lengths are measured in reverse from end of the linear geometry.
+ * Out-of-range values are clamped.
+ * Ambiguous indexes are resolved to the lowest possible location value,
+ * depending on the value of <tt>resolveLower</tt>.
+ * @return the corresponding LinearLocation
+ LinearLocation getLocation(double length, bool resolveLower) const;
+ * \brief
+ * Ambiguous indexes are resolved to the lowest possible location value.
+ LinearLocation getLocation(double length) const;
+ double getLength(const LinearLocation& loc) const;
diff --git a/include/geos/linearref/LinearGeometryBuilder.h b/include/geos/linearref/LinearGeometryBuilder.h
index a01c684..ebc0bd8 100644
--- a/include/geos/linearref/LinearGeometryBuilder.h
+++ b/include/geos/linearref/LinearGeometryBuilder.h
@@ -28,10 +28,8 @@
#include <vector>
-namespace geos
+namespace geos {
* Builds a linear geometry ({@link LineString} or {@link MultiLineString})
@@ -39,66 +37,65 @@ namespace linearref // geos::linearref
* @version 1.7
-class LinearGeometryBuilder
+class LinearGeometryBuilder {
private:
- const geom::GeometryFactory* geomFact;
+ const geom::GeometryFactory* geomFact;
- typedef std::vector<geom::Geometry *> GeomPtrVect;
+ typedef std::vector<geom::Geometry*> GeomPtrVect;
- // Geometry elements owned by this class
- GeomPtrVect lines;
+ // Geometry elements owned by this class
+ GeomPtrVect lines;
- bool ignoreInvalidLines;
- bool fixInvalidLines;
- geom::CoordinateSequence* coordList;
+ bool ignoreInvalidLines;
+ bool fixInvalidLines;
+ geom::CoordinateSequence* coordList;
- geom::Coordinate lastPt;
+ geom::Coordinate lastPt;
public:
- LinearGeometryBuilder(const geom::GeometryFactory* geomFact);
- ~LinearGeometryBuilder();
- * Allows invalid lines to be ignored rather than causing Exceptions.
- * An invalid line is one which has only one unique point.
- * @param ignoreShortLines <code>true</code> if short lines are
- * to be ignored
- void setIgnoreInvalidLines(bool ignoreInvalidLines);
- * to be ignored
- void setFixInvalidLines(bool fixInvalidLines);
- * Adds a point to the current line.
- * @param pt the Coordinate to add
- void add(const geom::Coordinate& pt);
- void add(const geom::Coordinate& pt, bool allowRepeatedPoints);
- /// NOTE strk: why return by value ?
- geom::Coordinate getLastCoordinate() const;
- /// Terminate the current LineString.
- void endLine();
- geom::Geometry *getGeometry();
+ LinearGeometryBuilder(const geom::GeometryFactory* geomFact);
+ ~LinearGeometryBuilder();
+ * Allows invalid lines to be ignored rather than causing Exceptions.
+ * An invalid line is one which has only one unique point.
+ * @param ignoreShortLines <code>true</code> if short lines are
+ * to be ignored
+ void setIgnoreInvalidLines(bool ignoreInvalidLines);
+ * to be ignored
+ void setFixInvalidLines(bool fixInvalidLines);
+ * Adds a point to the current line.
+ * @param pt the Coordinate to add
+ void add(const geom::Coordinate& pt);
+ void add(const geom::Coordinate& pt, bool allowRepeatedPoints);
+ /// NOTE strk: why return by value ?
+ geom::Coordinate getLastCoordinate() const;
+ /// Terminate the current LineString.
+ void endLine();
+ geom::Geometry* getGeometry();
} // namespace geos.linearref
diff --git a/include/geos/linearref/LinearIterator.h b/include/geos/linearref/LinearIterator.h
index 2aa1779..be4ffe9 100644
--- a/include/geos/linearref/LinearIterator.h
+++ b/include/geos/linearref/LinearIterator.h
@@ -27,8 +27,8 @@
#include <geos/geom/LineSegment.h>
-namespace geos { namespace linearref
+namespace geos {
/** \brief
* An iterator over the components and coordinates of a linear geometry
@@ -47,112 +47,112 @@ namespace geos { namespace linearref
* @version 1.7
-class LinearIterator
+class LinearIterator {
public:
- * Creates an iterator initialized to the start of a linear Geometry
- * @param linear the linear geometry to iterate over
- LinearIterator(const geom::Geometry *linear);
- * Creates an iterator starting at
- * a {@link LinearLocation} on a linear {@link Geometry}
- * @param start the location to start at
- LinearIterator(const geom::Geometry *linear, const LinearLocation& start);
- * a component and vertex in a linear {@link Geometry}
- * @param componentIndex the component to start at
- * @param vertexIndex the vertex to start at
- LinearIterator(const geom::Geometry *linear, size_t componentIndex, size_t vertexIndex);
- * Tests whether there are any vertices left to iterator over.
- * @return <code>true</code> if there are more vertices to scan
- bool hasNext() const;
- * Moves the iterator ahead to the next vertex and (possibly) linear component.
- void next();
- * Checks whether the iterator cursor is pointing to the
- * endpoint of a component {@link LineString}.
- * @return <code>true</true> if the iterator is at an endpoint
- bool isEndOfLine() const;
- * The component index of the vertex the iterator is currently at.
- * @return the current component index
- size_t getComponentIndex() const;
- * The vertex index of the vertex the iterator is currently at.
- * @return the current vertex index
- size_t getVertexIndex() const;
- * Gets the {@link LineString} component the iterator is current at.
- * @return a linestring
- const geom::LineString* getLine() const;
- * Gets the first {@link Coordinate} of the current segment.
- * (the coordinate of the current vertex).
- * @return a {@link Coordinate}
- geom::Coordinate getSegmentStart() const;
- * Gets the second {@link Coordinate} of the current segment.
- * (the coordinate of the next vertex).
- * If the iterator is at the end of a line, <code>null</code> is returned.
- * @return a {@link Coordinate} or <code>null</code>
- geom::Coordinate getSegmentEnd() const;
+ * Creates an iterator initialized to the start of a linear Geometry
+ * @param linear the linear geometry to iterate over
+ LinearIterator(const geom::Geometry* linear);
+ * Creates an iterator starting at
+ * a {@link LinearLocation} on a linear {@link Geometry}
+ * @param start the location to start at
+ LinearIterator(const geom::Geometry* linear, const LinearLocation& start);
+ * a component and vertex in a linear {@link Geometry}
+ * @param componentIndex the component to start at
+ * @param vertexIndex the vertex to start at
+ LinearIterator(const geom::Geometry* linear, size_t componentIndex, size_t vertexIndex);
+ * Tests whether there are any vertices left to iterator over.
+ * @return <code>true</code> if there are more vertices to scan
+ bool hasNext() const;
+ * Moves the iterator ahead to the next vertex and (possibly) linear component.
+ void next();
+ * Checks whether the iterator cursor is pointing to the
+ * endpoint of a component {@link LineString}.
+ * @return <code>true</true> if the iterator is at an endpoint
+ bool isEndOfLine() const;
+ * The component index of the vertex the iterator is currently at.
+ * @return the current component index
+ size_t getComponentIndex() const;
+ * The vertex index of the vertex the iterator is currently at.
+ * @return the current vertex index
+ size_t getVertexIndex() const;
+ * Gets the {@link LineString} component the iterator is current at.
+ * @return a linestring
+ const geom::LineString* getLine() const;
+ * Gets the first {@link Coordinate} of the current segment.
+ * (the coordinate of the current vertex).
+ * @return a {@link Coordinate}
+ geom::Coordinate getSegmentStart() const;
+ * Gets the second {@link Coordinate} of the current segment.
+ * (the coordinate of the next vertex).
+ * If the iterator is at the end of a line, <code>null</code> is returned.
+ * @return a {@link Coordinate} or <code>null</code>
+ geom::Coordinate getSegmentEnd() const;
private:
- static size_t segmentEndVertexIndex(const LinearLocation& loc);
+ static size_t segmentEndVertexIndex(const LinearLocation& loc);
- const geom::LineString *currentLine;
- size_t vertexIndex;
- size_t componentIndex;
- const geom::Geometry *linear;
- const size_t numLines;
+ const geom::LineString* currentLine;
+ size_t vertexIndex;
+ size_t componentIndex;
+ const geom::Geometry* linear;
+ const size_t numLines;
- * Invariant: currentLine <> null if the iterator is pointing
- * at a valid coordinate
- * @throws IllegalArgumentException if linearGeom is not {@link Lineal}
- void loadCurrentLine();
+ * Invariant: currentLine <> null if the iterator is pointing
+ * at a valid coordinate
+ * @throws IllegalArgumentException if linearGeom is not {@link Lineal}
+ void loadCurrentLine();
LinearIterator(const LinearIterator& other) = delete;
LinearIterator& operator=(const LinearIterator& rhs) = delete;
-}} // namespace geos::linearref
+} // namespace geos::linearref
#endif // GEOS_LINEARREF_LINEARITERATOR_H
diff --git a/include/geos/linearref/LinearLocation.h b/include/geos/linearref/LinearLocation.h
index c129257..2b9da08 100644
--- a/include/geos/linearref/LinearLocation.h
+++ b/include/geos/linearref/LinearLocation.h
@@ -40,203 +40,203 @@ namespace linearref { // geos::linearref
* Various methods are provided to manipulate the location value
* and query the geometry it references.
-class LinearLocation
+class LinearLocation {
private:
- size_t segmentIndex;
- double segmentFraction;
- * Ensures the individual values are locally valid.
- * Does <b>not</b> ensure that the indexes are valid for
- * a particular linear geometry.
- * @see clamp
- void normalize();
+ size_t segmentIndex;
+ double segmentFraction;
+ * Ensures the individual values are locally valid.
+ * Does <b>not</b> ensure that the indexes are valid for
+ * a particular linear geometry.
+ * @see clamp
+ void normalize();
public:
- * Gets a location which refers to the end of a linear {@link Geometry}.
- * @return a new <tt>LinearLocation</tt>
- static LinearLocation getEndLocation(const geom::Geometry* linear);
- * Computes the {@link Coordinate} of a point a given fraction
- * along the line segment <tt>(p0, p1)</tt>.
- * If the fraction is greater than 1.0 the last
- * point of the segment is returned.
- * If the fraction is less than or equal to 0.0 the first point
- * of the segment is returned.
- * The Z ordinate is interpolated from the Z-ordinates of
- * the given points, if they are specified.
- * @param p0 the first point of the line segment
- * @param p1 the last point of the line segment
- * @param frac the length to the desired point
- * @return the <tt>Coordinate</tt> of the desired point
- static geom::Coordinate pointAlongSegmentByFraction(const geom::Coordinate& p0, const geom::Coordinate& p1, double frac);
- * Creates a location referring to the start of a linear geometry
- LinearLocation(size_t segmentIndex = 0, double segmentFraction = 0.0);
- LinearLocation(size_t componentIndex, size_t segmentIndex, double segmentFraction);
- * Ensures the indexes are valid for a given linear {@link Geometry}.
- * @param linear a linear geometry
- void clamp(const geom::Geometry* linear);
- * Snaps the value of this location to
- * the nearest vertex on the given linear {@link Geometry},
- * if the vertex is closer than <tt>minDistance</tt>.
- * @param linearGeom a linear geometry
- * @param minDistance the minimum allowable distance to a vertex
- void snapToVertex(const geom::Geometry* linearGeom, double minDistance);
- * Gets the length of the segment in the given
- * Geometry containing this location.
- * @return the length of the segment
- double getSegmentLength(const geom::Geometry* linearGeom) const;
- * Sets the value of this location to
- * refer the end of a linear geometry
- * @param linear the linear geometry to set
- void setToEnd(const geom::Geometry* linear);
- * Gets the component index for this location.
- * @return the component index
- * Gets the segment index for this location
- * @return the segment index
- size_t getSegmentIndex() const;
- * Gets the segment fraction for this location
- * @return the segment fraction
- double getSegmentFraction() const;
- * Tests whether this location refers to a vertex
- * @return true if the location is a vertex
- bool isVertex() const;
- * Gets the {@link Coordinate} along the
- * given linear {@link Geometry} which is
- * referenced by this location.
- * @param linearGeom the linear geometry referenced by this location
- * @return the <tt>Coordinate</tt> at the location
- geom::Coordinate getCoordinate(const geom::Geometry* linearGeom) const;
- * Gets a {@link LineSegment} representing the segment of the
- * given linear {@link Geometry} which contains this location.
- * @return the <tt>LineSegment</tt> containing the location
- std::unique_ptr<geom::LineSegment> getSegment(const geom::Geometry* linearGeom) const;
- * Tests whether this location refers to a valid
- * location on the given linear {@link Geometry}.
- * @return true if this location is valid
- bool isValid(const geom::Geometry* linearGeom) const;
- * Compares this object with the specified object for order.
- *@param o the <code>LineStringLocation</code> with which this <code>Coordinate</code>
- * is being compared
- *@return a negative integer, zero, or a positive integer as this <code>LineStringLocation</code>
- * is less than, equal to, or greater than the specified <code>LineStringLocation</code>
- int compareTo(const LinearLocation& other) const;
- * Compares this object with the specified index values for order.
- * @param componentIndex1 a component index
- * @param segmentIndex1 a segment index
- * @param segmentFraction1 a segment fraction
- * @return a negative integer, zero, or a positive integer as this <code>LineStringLocation</code>
- * is less than, equal to, or greater than the specified locationValues
- int compareLocationValues(size_t componentIndex1, size_t segmentIndex1, double segmentFraction1) const;
- * Compares two sets of location values for order.
- * @param componentIndex0 a component index
- * @param segmentIndex0 a segment index
- * @param segmentFraction0 a segment fraction
- * @param componentIndex1 another component index
- * @param segmentIndex1 another segment index
- * @param segmentFraction1 another segment fraction
- * as the first set of location values
- * is less than, equal to, or greater than the second set of locationValues
- static int compareLocationValues(
- size_t componentIndex0, size_t segmentIndex0, double segmentFraction0,
- size_t componentIndex1, size_t segmentIndex1, double segmentFraction1);
- * Tests whether two locations
- * are on the same segment in the parent {@link Geometry}.
- * @param loc a location on the same geometry
- * @return true if the locations are on the same segment of the parent geometry
- bool isOnSameSegment(const LinearLocation& loc) const;
- * \brief
- * Tests whether this location is an endpoint of
- * the linear component it refers to.
- * @return true if the location is a component endpoint
- bool isEndpoint(const geom::Geometry& linearGeom) const;
- friend std::ostream& operator<< (std::ostream& out, const LinearLocation& obj );
+ * Gets a location which refers to the end of a linear {@link Geometry}.
+ * @return a new <tt>LinearLocation</tt>
+ static LinearLocation getEndLocation(const geom::Geometry* linear);
+ * Computes the {@link Coordinate} of a point a given fraction
+ * along the line segment <tt>(p0, p1)</tt>.
+ * If the fraction is greater than 1.0 the last
+ * point of the segment is returned.
+ * If the fraction is less than or equal to 0.0 the first point
+ * of the segment is returned.
+ * The Z ordinate is interpolated from the Z-ordinates of
+ * the given points, if they are specified.
+ * @param p0 the first point of the line segment
+ * @param p1 the last point of the line segment
+ * @param frac the length to the desired point
+ * @return the <tt>Coordinate</tt> of the desired point
+ static geom::Coordinate pointAlongSegmentByFraction(const geom::Coordinate& p0, const geom::Coordinate& p1,
+ double frac);
+ * Creates a location referring to the start of a linear geometry
+ LinearLocation(size_t segmentIndex = 0, double segmentFraction = 0.0);
+ LinearLocation(size_t componentIndex, size_t segmentIndex, double segmentFraction);
+ * Ensures the indexes are valid for a given linear {@link Geometry}.
+ * @param linear a linear geometry
+ void clamp(const geom::Geometry* linear);
+ * Snaps the value of this location to
+ * the nearest vertex on the given linear {@link Geometry},
+ * if the vertex is closer than <tt>minDistance</tt>.
+ * @param linearGeom a linear geometry
+ * @param minDistance the minimum allowable distance to a vertex
+ void snapToVertex(const geom::Geometry* linearGeom, double minDistance);
+ * Gets the length of the segment in the given
+ * Geometry containing this location.
+ * @return the length of the segment
+ double getSegmentLength(const geom::Geometry* linearGeom) const;
+ * Sets the value of this location to
+ * refer the end of a linear geometry
+ * @param linear the linear geometry to set
+ void setToEnd(const geom::Geometry* linear);
+ * Gets the component index for this location.
+ * @return the component index
+ * Gets the segment index for this location
+ * @return the segment index
+ size_t getSegmentIndex() const;
+ * Gets the segment fraction for this location
+ * @return the segment fraction
+ double getSegmentFraction() const;
+ * Tests whether this location refers to a vertex
+ * @return true if the location is a vertex
+ bool isVertex() const;
+ * Gets the {@link Coordinate} along the
+ * given linear {@link Geometry} which is
+ * referenced by this location.
+ * @param linearGeom the linear geometry referenced by this location
+ * @return the <tt>Coordinate</tt> at the location
+ geom::Coordinate getCoordinate(const geom::Geometry* linearGeom) const;
+ * Gets a {@link LineSegment} representing the segment of the
+ * given linear {@link Geometry} which contains this location.
+ * @return the <tt>LineSegment</tt> containing the location
+ std::unique_ptr<geom::LineSegment> getSegment(const geom::Geometry* linearGeom) const;
+ * Tests whether this location refers to a valid
+ * location on the given linear {@link Geometry}.
+ * @return true if this location is valid
+ bool isValid(const geom::Geometry* linearGeom) const;
+ * Compares this object with the specified object for order.
+ *@param o the <code>LineStringLocation</code> with which this <code>Coordinate</code>
+ * is being compared
+ *@return a negative integer, zero, or a positive integer as this <code>LineStringLocation</code>
+ * is less than, equal to, or greater than the specified <code>LineStringLocation</code>
+ int compareTo(const LinearLocation& other) const;
+ * Compares this object with the specified index values for order.
+ * @param componentIndex1 a component index
+ * @param segmentIndex1 a segment index
+ * @param segmentFraction1 a segment fraction
+ * @return a negative integer, zero, or a positive integer as this <code>LineStringLocation</code>
+ * is less than, equal to, or greater than the specified locationValues
+ int compareLocationValues(size_t componentIndex1, size_t segmentIndex1, double segmentFraction1) const;
+ * Compares two sets of location values for order.
+ * @param componentIndex0 a component index
+ * @param segmentIndex0 a segment index
+ * @param segmentFraction0 a segment fraction
+ * @param componentIndex1 another component index
+ * @param segmentIndex1 another segment index
+ * @param segmentFraction1 another segment fraction
+ * as the first set of location values
+ * is less than, equal to, or greater than the second set of locationValues
+ static int compareLocationValues(
+ size_t componentIndex0, size_t segmentIndex0, double segmentFraction0,
+ size_t componentIndex1, size_t segmentIndex1, double segmentFraction1);
+ * Tests whether two locations
+ * are on the same segment in the parent {@link Geometry}.
+ * @param loc a location on the same geometry
+ * @return true if the locations are on the same segment of the parent geometry
+ bool isOnSameSegment(const LinearLocation& loc) const;
+ * \brief
+ * Tests whether this location is an endpoint of
+ * the linear component it refers to.
+ * @return true if the location is a component endpoint
+ bool isEndpoint(const geom::Geometry& linearGeom) const;
+ friend std::ostream& operator<< (std::ostream& out, const LinearLocation& obj);
diff --git a/include/geos/linearref/LocationIndexOfLine.h b/include/geos/linearref/LocationIndexOfLine.h
index e7eef5e..ea179d2 100644
--- a/include/geos/linearref/LocationIndexOfLine.h
+++ b/include/geos/linearref/LocationIndexOfLine.h
@@ -24,10 +24,8 @@
-namespace geos
+namespace geos {
* Determines the location of a subline along a linear {@link Geometry}.
@@ -38,37 +36,36 @@ namespace linearref // geos::linearref
* an endpoint of the test line occurs more than once in the input line.
* (However, the common case of a ring is always handled correctly).
-class LocationIndexOfLine
- * MD - this algorithm has been extracted into a class
- * because it is intended to validate that the subline truly is a subline,
- * and also to use the internal vertex information to unambiguously locate the subline.
+class LocationIndexOfLine {
+ * MD - this algorithm has been extracted into a class
+ * because it is intended to validate that the subline truly is a subline,
+ * and also to use the internal vertex information to unambiguously locate the subline.
private:
- const geom::Geometry* linearGeom;
public:
- /** \brief
- * Determines the location of a subline along a linear {@link Geometry}.
- * The location is reported as a pair of {@link LinearLocation}s.
- * <b>Note:</b> Currently this algorithm is not guaranteed to
- * return the correct substring in some situations where
- * an endpoint of the test line occurs more than once in the input line.
- * (However, the common case of a ring is always handled correctly).
- * Caller must take of releasing with delete[]
- static LinearLocation* indicesOf(const geom::Geometry* linearGeom, const geom::Geometry* subLine);
+ /** \brief
+ * Determines the location of a subline along a linear {@link Geometry}.
+ * The location is reported as a pair of {@link LinearLocation}s.
+ * <b>Note:</b> Currently this algorithm is not guaranteed to
+ * return the correct substring in some situations where
+ * an endpoint of the test line occurs more than once in the input line.
+ * (However, the common case of a ring is always handled correctly).
+ * Caller must take of releasing with delete[]
+ static LinearLocation* indicesOf(const geom::Geometry* linearGeom, const geom::Geometry* subLine);
- LocationIndexOfLine(const geom::Geometry* linearGeom);
+ LocationIndexOfLine(const geom::Geometry* linearGeom);
- /// Caller must take of releasing with delete[]
- LinearLocation* indicesOf(const geom::Geometry* subLine) const;
+ /// Caller must take of releasing with delete[]
+ LinearLocation* indicesOf(const geom::Geometry* subLine) const;
diff --git a/include/geos/linearref/LocationIndexOfPoint.h b/include/geos/linearref/LocationIndexOfPoint.h
index 95a8607..330ac85 100644
--- a/include/geos/linearref/LocationIndexOfPoint.h
+++ b/include/geos/linearref/LocationIndexOfPoint.h
@@ -25,10 +25,8 @@
-namespace geos
+namespace geos {
* Computes the {@link LinearLocation} of the point
@@ -37,44 +35,44 @@ namespace linearref // geos::linearref
-class LocationIndexOfPoint
+class LocationIndexOfPoint {
private:
- LinearLocation indexOfFromStart(const geom::Coordinate& inputPt, const LinearLocation* minIndex) const;
+ LinearLocation indexOfFromStart(const geom::Coordinate& inputPt, const LinearLocation* minIndex) const;
public:
- static LinearLocation indexOf(const geom::Geometry *linearGeom, const geom::Coordinate& inputPt);
+ static LinearLocation indexOf(const geom::Geometry* linearGeom, const geom::Coordinate& inputPt);
- static LinearLocation indexOfAfter(const geom::Geometry *linearGeom, const geom::Coordinate& inputPt, const LinearLocation* minIndex);
+ static LinearLocation indexOfAfter(const geom::Geometry* linearGeom, const geom::Coordinate& inputPt,
+ const LinearLocation* minIndex);
- LocationIndexOfPoint(const geom::Geometry *linearGeom);
+ LocationIndexOfPoint(const geom::Geometry* linearGeom);
- * Find the nearest location along a linear {@link Geometry} to a given point.
- LinearLocation indexOf(const geom::Coordinate& inputPt) const;
- * Find the nearest {@link LinearLocation} along the linear {@link Geometry}
- * to a given {@link Coordinate}
- * after the specified minimum {@link LinearLocation}.
- LinearLocation indexOfAfter(const geom::Coordinate& inputPt, const LinearLocation* minIndex) const;
+ * Find the nearest location along a linear {@link Geometry} to a given point.
+ LinearLocation indexOf(const geom::Coordinate& inputPt) const;
+ * Find the nearest {@link LinearLocation} along the linear {@link Geometry}
+ * to a given {@link Coordinate}
+ * after the specified minimum {@link LinearLocation}.
+ LinearLocation indexOfAfter(const geom::Coordinate& inputPt, const LinearLocation* minIndex) const;
diff --git a/include/geos/linearref/LocationIndexedLine.h b/include/geos/linearref/LocationIndexedLine.h
index 95ed1dd..3ea639c 100644
--- a/include/geos/linearref/LocationIndexedLine.h
+++ b/include/geos/linearref/LocationIndexedLine.h
@@ -37,229 +37,241 @@ namespace linearref { // geos::linearref
* along a linear {@link Geometry}
* using {@link LinearLocation}s as the index.
-class GEOS_DLL LocationIndexedLine
+class GEOS_DLL LocationIndexedLine {
private:
- void checkGeometryType()
- if ( ! dynamic_cast<const geom::Lineal*>(linearGeom) )
- throw util::IllegalArgumentException("Input geometry must be linear");
+ void
+ checkGeometryType()
+ if(! dynamic_cast<const geom::Lineal*>(linearGeom)) {
+ throw util::IllegalArgumentException("Input geometry must be linear");
public:
- * \brief
- * Constructs an object which allows linear referencing along
- * a given linear {@link Geometry}.
- LocationIndexedLine(const geom::Geometry *p_linearGeom)
- : linearGeom(p_linearGeom)
- checkGeometryType();
+ * \brief
+ * Constructs an object which allows linear referencing along
+ * a given linear {@link Geometry}.
+ LocationIndexedLine(const geom::Geometry* p_linearGeom)
+ : linearGeom(p_linearGeom)
+ checkGeometryType();
- * \brief
- geom::Coordinate extractPoint(const LinearLocation& index) const
- return index.getCoordinate(linearGeom);
+ * \brief
+ geom::Coordinate
+ extractPoint(const LinearLocation& index) const
+ return index.getCoordinate(linearGeom);
- * \brief
- * The computed point is offset to the left of the line if the offset
- * distance is positive, to the right if negative.
- geom::Coordinate extractPoint(const LinearLocation& index,
- double offsetDistance) const
- geom::Coordinate ret;
- index.getSegment(linearGeom)->pointAlongOffset(
- index.getSegmentFraction(), offsetDistance, ret
- return ret;
+ * \brief
+ * The computed point is offset to the left of the line if the offset
+ * distance is positive, to the right if negative.
+ geom::Coordinate
+ extractPoint(const LinearLocation& index,
+ double offsetDistance) const
+ geom::Coordinate ret;
+ index.getSegment(linearGeom)->pointAlongOffset(
+ index.getSegmentFraction(), offsetDistance, ret
+ return ret;
- * \brief
- geom::Geometry *extractLine(const LinearLocation& startIndex,
- const LinearLocation& endIndex) const
- return ExtractLineByLocation::extract(linearGeom, startIndex, endIndex);
+ * \brief
+ geom::Geometry*
+ extractLine(const LinearLocation& startIndex,
+ const LinearLocation& endIndex) const
+ return ExtractLineByLocation::extract(linearGeom, startIndex, endIndex);
- * \brief
- * Computes the index for a given point on the line.
- * @see project
- LinearLocation indexOf(const geom::Coordinate& pt) const
- return LocationIndexOfPoint::indexOf(linearGeom, pt);
+ * \brief
+ * Computes the index for a given point on the line.
+ * @see project
+ LinearLocation
+ indexOf(const geom::Coordinate& pt) const
+ return LocationIndexOfPoint::indexOf(linearGeom, pt);
- * \brief
- * @see project
- LinearLocation indexOfAfter(const geom::Coordinate& pt,
- const LinearLocation& minIndex) const
- return LocationIndexOfPoint::indexOfAfter(linearGeom, pt, &minIndex);
+ * \brief
+ * @see project
+ LinearLocation
+ indexOfAfter(const geom::Coordinate& pt,
+ const LinearLocation& minIndex) const
+ return LocationIndexOfPoint::indexOfAfter(linearGeom, pt, &minIndex);
- * \brief
- * must be vertices of the line and occur in the same order).
- LinearLocation* indicesOf(const geom::Geometry *subLine) const
- return LocationIndexOfLine::indicesOf(linearGeom, subLine);
+ * \brief
+ * must be vertices of the line and occur in the same order).
+ LinearLocation*
+ indicesOf(const geom::Geometry* subLine) const
+ return LocationIndexOfLine::indicesOf(linearGeom, subLine);
- * \brief
- * the line is returned.
- LinearLocation project(const geom::Coordinate& pt) const
+ * \brief
+ * the line is returned.
+ LinearLocation
+ project(const geom::Coordinate& pt) const
- * \brief
- LinearLocation getStartIndex() const
- return LinearLocation();
+ * \brief
+ LinearLocation
+ getStartIndex() const
+ return LinearLocation();
- * \brief
- LinearLocation getEndIndex() const
- return LinearLocation::getEndLocation(linearGeom);
+ * \brief
+ LinearLocation
+ getEndIndex() const
+ return LinearLocation::getEndLocation(linearGeom);
- * \brief
- bool isValidIndex(const LinearLocation& index) const
- return index.isValid(linearGeom);
+ * \brief
+ bool
+ isValidIndex(const LinearLocation& index) const
+ return index.isValid(linearGeom);
- * \brief
- LinearLocation clampIndex(const LinearLocation& index) const
- LinearLocation loc = index;
- loc.clamp(linearGeom);
- return loc;
+ * \brief
+ LinearLocation
+ clampIndex(const LinearLocation& index) const
+ LinearLocation loc = index;
+ loc.clamp(linearGeom);
+ return loc;
} // geos::linearref
diff --git a/include/geos/noding/BasicSegmentString.h b/include/geos/noding/BasicSegmentString.h
index d009744..aad4bc0 100644
--- a/include/geos/noding/BasicSegmentString.h
+++ b/include/geos/noding/BasicSegmentString.h
@@ -29,9 +29,9 @@
// Forward declarations
namespace geos {
- namespace algorithm {
- //class LineIntersector;
+namespace algorithm {
+//class LineIntersector;
namespace geos {
@@ -51,52 +51,53 @@ class GEOS_DLL BasicSegmentString : public SegmentString {
public:
- /// Construct a BasicSegmentString.
- /// @param newPts CoordinateSequence representing the string,
- /// externally owned
- /// @param newContext the context associated to this SegmentString
- BasicSegmentString(geom::CoordinateSequence *newPts,
- const void* newContext)
- SegmentString(newContext),
- pts(newPts)
- ~BasicSegmentString() override
- /// see dox in SegmentString.h
- size_t size() const override
- return pts->size();
- const geom::Coordinate& getCoordinate(size_t i) const override;
- geom::CoordinateSequence* getCoordinates() const override;
- bool isClosed() const override;
- std::ostream& print(std::ostream& os) const override;
- /** \brief
- * Gets the octant of the segment starting at vertex index.
- * @param index the index of the vertex starting the segment.
- * Must not be the last index in the vertex list
- * @return the octant of the segment at the vertex
- int getSegmentOctant(size_t index) const;
+ /// Construct a BasicSegmentString.
+ /// @param newPts CoordinateSequence representing the string,
+ /// externally owned
+ /// @param newContext the context associated to this SegmentString
+ BasicSegmentString(geom::CoordinateSequence* newPts,
+ const void* newContext)
+ SegmentString(newContext),
+ pts(newPts)
+ ~BasicSegmentString() override
+ /// see dox in SegmentString.h
+ size_t
+ size() const override
+ return pts->size();
+ const geom::Coordinate& getCoordinate(size_t i) const override;
+ geom::CoordinateSequence* getCoordinates() const override;
+ bool isClosed() const override;
+ std::ostream& print(std::ostream& os) const override;
+ /** \brief
+ * Gets the octant of the segment starting at vertex index.
+ * @param index the index of the vertex starting the segment.
+ * Must not be the last index in the vertex list
+ * @return the octant of the segment at the vertex
+ int getSegmentOctant(size_t index) const;
private:
- geom::CoordinateSequence *pts;
+ geom::CoordinateSequence* pts;
diff --git a/include/geos/noding/FastNodingValidator.h b/include/geos/noding/FastNodingValidator.h
index c9b6622..9347007 100644
--- a/include/geos/noding/FastNodingValidator.h
+++ b/include/geos/noding/FastNodingValidator.h
@@ -28,9 +28,9 @@
namespace geos {
- namespace noding {
- class SegmentString;
+namespace noding {
+class SegmentString;
namespace geos {
@@ -57,65 +57,68 @@ namespace noding { // geos.noding
* or request that a suitable {@link TopologyException} be thrown.
-class FastNodingValidator
+class FastNodingValidator {
public:
- FastNodingValidator(std::vector<noding::SegmentString*>& newSegStrings)
- li(), // robust...
- segStrings(newSegStrings),
- segInt(),
- isValidVar(true)
- * Checks for an intersection and
- * reports if one is found.
- * @return true if the arrangement contains an interior intersection
- bool isValid()
- execute();
- return isValidVar;
- * Returns an error message indicating the segments containing
- * the intersection.
- * @return an error message documenting the intersection location
- std::string getErrorMessage() const;
- * Checks for an intersection and throws
- * a TopologyException if one is found.
- * @throws TopologyException if an intersection is found
- void checkValid();
+ FastNodingValidator(std::vector<noding::SegmentString*>& newSegStrings)
+ li(), // robust...
+ segStrings(newSegStrings),
+ segInt(),
+ isValidVar(true)
+ * Checks for an intersection and
+ * reports if one is found.
+ * @return true if the arrangement contains an interior intersection
+ bool
+ isValid()
+ execute();
+ return isValidVar;
+ * Returns an error message indicating the segments containing
+ * the intersection.
+ * @return an error message documenting the intersection location
+ std::string getErrorMessage() const;
+ * Checks for an intersection and throws
+ * a TopologyException if one is found.
+ * @throws TopologyException if an intersection is found
+ void checkValid();
private:
- geos::algorithm::LineIntersector li;
+ geos::algorithm::LineIntersector li;
- std::vector<noding::SegmentString*>& segStrings;
+ std::vector<noding::SegmentString*>& segStrings;
- std::unique_ptr<NodingIntersectionFinder> segInt;
+ std::unique_ptr<NodingIntersectionFinder> segInt;
- bool isValidVar;
+ bool isValidVar;
- void execute()
- if (segInt.get() != nullptr) return;
- checkInteriorIntersections();
+ void
+ execute()
+ if(segInt.get() != nullptr) {
+ return;
+ checkInteriorIntersections();
- void checkInteriorIntersections();
+ void checkInteriorIntersections();
// Declare type as noncopyable
FastNodingValidator(const FastNodingValidator& other) = delete;
diff --git a/include/geos/noding/FastSegmentSetIntersectionFinder.h b/include/geos/noding/FastSegmentSetIntersectionFinder.h
index 2d72ebf..6a4770e 100644
--- a/include/geos/noding/FastSegmentSetIntersectionFinder.h
+++ b/include/geos/noding/FastSegmentSetIntersectionFinder.h
@@ -27,11 +27,11 @@
//forward declarations
namespace geos {
- class SegmentIntersectionDetector;
- class SegmentSetMutualIntersector;
- //class MCIndexSegmentSetMutualIntersector : public SegmentSetMutualIntersector;
+namespace noding {
+class SegmentIntersectionDetector;
+class SegmentSetMutualIntersector;
+//class MCIndexSegmentSetMutualIntersector : public SegmentSetMutualIntersector;
@@ -47,31 +47,31 @@ namespace noding { // geos::noding
* @version 1.7
-class FastSegmentSetIntersectionFinder
+class FastSegmentSetIntersectionFinder {
private:
- std::unique_ptr<MCIndexSegmentSetMutualIntersector> segSetMutInt;
- std::unique_ptr<geos::algorithm::LineIntersector> lineIntersector;
+ std::unique_ptr<MCIndexSegmentSetMutualIntersector> segSetMutInt;
+ std::unique_ptr<geos::algorithm::LineIntersector> lineIntersector;
protected:
public:
- FastSegmentSetIntersectionFinder( SegmentString::ConstVect * baseSegStrings);
+ FastSegmentSetIntersectionFinder(SegmentString::ConstVect* baseSegStrings);
- ~FastSegmentSetIntersectionFinder() = default;
+ ~FastSegmentSetIntersectionFinder() = default;
- * Gets the segment set intersector used by this class.
- * This allows other uses of the same underlying indexed structure.
- * @return the segment set intersector used
- const SegmentSetMutualIntersector * getSegmentSetIntersector() const
- return segSetMutInt.get();
+ * Gets the segment set intersector used by this class.
+ * This allows other uses of the same underlying indexed structure.
+ * @return the segment set intersector used
+ const SegmentSetMutualIntersector*
+ getSegmentSetIntersector() const
+ return segSetMutInt.get();
- bool intersects( SegmentString::ConstVect * segStrings);
- bool intersects( SegmentString::ConstVect * segStrings, SegmentIntersectionDetector * intDetector);
+ bool intersects(SegmentString::ConstVect* segStrings);
+ bool intersects(SegmentString::ConstVect* segStrings, SegmentIntersectionDetector* intDetector);
diff --git a/include/geos/noding/GeometryNoder.h b/include/geos/noding/GeometryNoder.h
index af8a790..07addff 100644
--- a/include/geos/noding/GeometryNoder.h
+++ b/include/geos/noding/GeometryNoder.h
@@ -26,44 +26,43 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Noder;
+namespace geom {
+class Geometry;
+namespace noding {
+class Noder;
namespace geos {
-class GEOS_DLL GeometryNoder
+class GEOS_DLL GeometryNoder {
public:
- static std::unique_ptr<geom::Geometry> node(const geom::Geometry& geom);
+ static std::unique_ptr<geom::Geometry> node(const geom::Geometry& geom);
- GeometryNoder(const geom::Geometry& g);
+ GeometryNoder(const geom::Geometry& g);
- std::unique_ptr<geom::Geometry> getNoded();
+ std::unique_ptr<geom::Geometry> getNoded();
private:
- const geom::Geometry& argGeom;
+ const geom::Geometry& argGeom;
- SegmentString::NonConstVect lineList;
+ SegmentString::NonConstVect lineList;
- static void extractSegmentStrings(const geom::Geometry& g,
- SegmentString::NonConstVect& to);
+ static void extractSegmentStrings(const geom::Geometry& g,
+ SegmentString::NonConstVect& to);
- Noder& getNoder();
+ Noder& getNoder();
- std::unique_ptr<Noder> noder;
+ std::unique_ptr<Noder> noder;
- std::unique_ptr<geom::Geometry> toGeometry(SegmentString::NonConstVect& noded);
+ std::unique_ptr<geom::Geometry> toGeometry(SegmentString::NonConstVect& noded);
- GeometryNoder(GeometryNoder const&); /*= delete*/
- GeometryNoder& operator=(GeometryNoder const&); /*= delete*/
+ GeometryNoder(GeometryNoder const&); /*= delete*/
+ GeometryNoder& operator=(GeometryNoder const&); /*= delete*/
} // namespace geos.noding
diff --git a/include/geos/noding/IntersectionAdder.h b/include/geos/noding/IntersectionAdder.h
index f9b49b3..79cca47 100644
--- a/include/geos/noding/IntersectionAdder.h
+++ b/include/geos/noding/IntersectionAdder.h
@@ -32,15 +32,15 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class LineIntersector;
+namespace geom {
+class Coordinate;
+namespace noding {
+class LineIntersector;
namespace geos {
@@ -59,30 +59,30 @@ class GEOS_DLL IntersectionAdder: public SegmentIntersector {
private:
- * These variables keep track of what types of intersections were
- * found during ALL edges that have been intersected.
- bool hasIntersectionVar;
- bool hasProper;
- bool hasProperInterior;
- bool hasInterior;
- // the proper intersection point found
- const geom::Coordinate* properIntersectionPoint;
- algorithm::LineIntersector& li;
- // bool isSelfIntersection;
- // bool intersectionFound;
- * A trivial intersection is an apparent self-intersection which
- * in fact is simply the point shared by adjacent line segments.
- * Note that closed edges require a special check for the point
- * shared by the beginning and end segments.
- bool isTrivialIntersection(const SegmentString* e0, size_t segIndex0,
- const SegmentString* e1, size_t segIndex1);
+ * These variables keep track of what types of intersections were
+ * found during ALL edges that have been intersected.
+ bool hasIntersectionVar;
+ bool hasProper;
+ bool hasProperInterior;
+ bool hasInterior;
+ // the proper intersection point found
+ const geom::Coordinate* properIntersectionPoint;
+ algorithm::LineIntersector& li;
+ // bool isSelfIntersection;
+ // bool intersectionFound;
+ * A trivial intersection is an apparent self-intersection which
+ * in fact is simply the point shared by adjacent line segments.
+ * Note that closed edges require a special check for the point
+ * shared by the beginning and end segments.
+ bool isTrivialIntersection(const SegmentString* e0, size_t segIndex0,
+ const SegmentString* e1, size_t segIndex1);
IntersectionAdder(const IntersectionAdder& other) = delete;
@@ -90,89 +90,115 @@ private:
public:
- int numIntersections;
- int numInteriorIntersections;
- int numProperIntersections;
- // testing only
- int numTests;
- IntersectionAdder(algorithm::LineIntersector& newLi)
- hasIntersectionVar(false),
- hasProper(false),
- hasProperInterior(false),
- hasInterior(false),
- properIntersectionPoint(nullptr),
- li(newLi),
- numIntersections(0),
- numInteriorIntersections(0),
- numProperIntersections(0),
- numTests(0)
- algorithm::LineIntersector& getLineIntersector() { return li; }
- * @return the proper intersection point, or <code>NULL</code>
- * if none was found
- const geom::Coordinate* getProperIntersectionPoint() {
- return properIntersectionPoint;
- bool hasIntersection() { return hasIntersectionVar; }
- * A proper intersection is an intersection which is interior to
- * at least two line segments. Note that a proper intersection
- * is not necessarily in the interior of the entire Geometry,
- * since another edge may have an endpoint equal to the intersection,
- * which according to SFS semantics can result in the point being
- * on the Boundary of the Geometry.
- bool hasProperIntersection() { return hasProper; }
- * A proper interior intersection is a proper intersection which is
- * <b>not</b> contained in the set of boundary nodes set for this
- * SegmentIntersector.
- bool hasProperInteriorIntersection() { return hasProperInterior; }
- * An interior intersection is an intersection which is
- * in the interior of some segment.
- bool hasInteriorIntersection() { return hasInterior; }
- * This method is called by clients
- * of the {@link SegmentIntersector} class to process
- * intersections for two segments of the SegmentStrings being
- * intersected.
- * Note that some clients (such as MonotoneChains) may optimize away
- * this call for segment pairs which they have determined do not
- * intersect (e.g. by an disjoint envelope test).
- void processIntersections(
- SegmentString* e0, size_t segIndex0,
- SegmentString* e1, size_t segIndex1) override;
- static bool isAdjacentSegments(size_t i1, size_t i2) {
- return (i1 > i2 ? i1 - i2 : i2 - i1) == 1;
- * Always process all intersections
- * @return false always
- bool isDone() const override {
- return false;
+ int numIntersections;
+ int numInteriorIntersections;
+ int numProperIntersections;
+ // testing only
+ int numTests;
+ IntersectionAdder(algorithm::LineIntersector& newLi)
+ hasIntersectionVar(false),
+ hasProper(false),
+ hasProperInterior(false),
+ hasInterior(false),
+ properIntersectionPoint(nullptr),
+ li(newLi),
+ numIntersections(0),
+ numInteriorIntersections(0),
+ numProperIntersections(0),
+ numTests(0)
+ getLineIntersector()
+ return li;
+ * @return the proper intersection point, or <code>NULL</code>
+ * if none was found
+ getProperIntersectionPoint()
+ return properIntersectionPoint;
+ bool
+ hasIntersection()
+ return hasIntersectionVar;
+ * A proper intersection is an intersection which is interior to
+ * at least two line segments. Note that a proper intersection
+ * is not necessarily in the interior of the entire Geometry,
+ * since another edge may have an endpoint equal to the intersection,
+ * which according to SFS semantics can result in the point being
+ * on the Boundary of the Geometry.
+ bool
+ hasProperIntersection()
+ return hasProper;
+ * A proper interior intersection is a proper intersection which is
+ * <b>not</b> contained in the set of boundary nodes set for this
+ * SegmentIntersector.
+ bool
+ hasProperInteriorIntersection()
+ return hasProperInterior;
+ * An interior intersection is an intersection which is
+ * in the interior of some segment.
+ bool
+ hasInteriorIntersection()
+ return hasInterior;
+ * This method is called by clients
+ * of the {@link SegmentIntersector} class to process
+ * intersections for two segments of the SegmentStrings being
+ * intersected.
+ * Note that some clients (such as MonotoneChains) may optimize away
+ * this call for segment pairs which they have determined do not
+ * intersect (e.g. by an disjoint envelope test).
+ void processIntersections(
+ SegmentString* e0, size_t segIndex0,
+ SegmentString* e1, size_t segIndex1) override;
+ static bool
+ isAdjacentSegments(size_t i1, size_t i2)
+ return (i1 > i2 ? i1 - i2 : i2 - i1) == 1;
+ * Always process all intersections
+ * @return false always
+ bool
+ isDone() const override
+ return false;
diff --git a/include/geos/noding/IntersectionFinderAdder.h b/include/geos/noding/IntersectionFinderAdder.h
index 3f2225c..a828fd9 100644
--- a/include/geos/noding/IntersectionFinderAdder.h
+++ b/include/geos/noding/IntersectionFinderAdder.h
@@ -31,15 +31,15 @@
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
+namespace noding {
namespace geos {
@@ -54,50 +54,54 @@ class GEOS_DLL IntersectionFinderAdder: public SegmentIntersector {
public:
- * Creates an intersection finder which finds all proper intersections
- * and stores them in the provided Coordinate array
- * @param li the LineIntersector to use
- * @param v the Vector to push interior intersections to
- IntersectionFinderAdder(algorithm::LineIntersector& newLi,
- std::vector<geom::Coordinate>& v)
- li(newLi),
- interiorIntersections(v)
- * intersections for two segments of the {@link SegmentStrings}
- * being intersected.
- * Note that some clients (such as {@link MonotoneChain}s) may
- * optimize away this call for segment pairs which they have
- * determined do not intersect
- * (e.g. by an disjoint envelope test).
- std::vector<geom::Coordinate>& getInteriorIntersections() {
- return interiorIntersections;
- return false;
+ * Creates an intersection finder which finds all proper intersections
+ * and stores them in the provided Coordinate array
+ * @param li the LineIntersector to use
+ * @param v the Vector to push interior intersections to
+ IntersectionFinderAdder(algorithm::LineIntersector& newLi,
+ std::vector<geom::Coordinate>& v)
+ li(newLi),
+ interiorIntersections(v)
+ * intersections for two segments of the {@link SegmentStrings}
+ * being intersected.
+ * Note that some clients (such as {@link MonotoneChain}s) may
+ * optimize away this call for segment pairs which they have
+ * determined do not intersect
+ * (e.g. by an disjoint envelope test).
+ getInteriorIntersections()
+ return interiorIntersections;
+ bool
+ return false;
private:
- std::vector<geom::Coordinate>& interiorIntersections;
+ std::vector<geom::Coordinate>& interiorIntersections;
IntersectionFinderAdder(const IntersectionFinderAdder& other) = delete;
diff --git a/include/geos/noding/IteratedNoder.h b/include/geos/noding/IteratedNoder.h
index 684d9c9..90cb2ea 100644
--- a/include/geos/noding/IteratedNoder.h
+++ b/include/geos/noding/IteratedNoder.h
@@ -32,9 +32,9 @@
namespace geos {
- namespace geom {
- class PrecisionModel;
+namespace geom {
+class PrecisionModel;
namespace geos {
@@ -55,59 +55,65 @@ namespace noding { // geos::noding
class GEOS_DLL IteratedNoder : public Noder { // implements Noder
private:
- static const int MAX_ITER = 5;
+ static const int MAX_ITER = 5;
- const geom::PrecisionModel *pm;
- algorithm::LineIntersector li;
- std::vector<SegmentString*>* nodedSegStrings;
- int maxIter;
+ const geom::PrecisionModel* pm;
+ algorithm::LineIntersector li;
+ std::vector<SegmentString*>* nodedSegStrings;
+ int maxIter;
- * Node the input segment strings once
- * and create the split edges between the nodes
- void node(std::vector<SegmentString*>* segStrings,
- int *numInteriorIntersections);
+ * Node the input segment strings once
+ * and create the split edges between the nodes
+ void node(std::vector<SegmentString*>* segStrings,
+ int* numInteriorIntersections);
public:
- IteratedNoder(const geom::PrecisionModel *newPm)
- pm(newPm),
- li(pm),
- maxIter(MAX_ITER)
- ~IteratedNoder() override {}
- * Sets the maximum number of noding iterations performed before
- * the noding is aborted.
- * Experience suggests that this should rarely need to be changed
- * from the default.
- * The default is MAX_ITER.
- * @param n the maximum number of iterations to perform
- void setMaximumIterations(int n) { maxIter = n; }
- std::vector<SegmentString*>* getNodedSubstrings() const override {
- return nodedSegStrings;
- * Fully nodes a list of {@link SegmentStrings}, i.e. peforms noding iteratively
- * until no intersections are found between segments.
- * Maintains labelling of edges correctly through
- * the noding.
- * @param segStrings a collection of SegmentStrings to be noded
- * @throws TopologyException if the iterated noding fails to converge.
- void computeNodes(std::vector<SegmentString*>* inputSegmentStrings) override; // throw(GEOSException);
+ IteratedNoder(const geom::PrecisionModel* newPm)
+ pm(newPm),
+ li(pm),
+ maxIter(MAX_ITER)
+ ~IteratedNoder() override {}
+ * Sets the maximum number of noding iterations performed before
+ * the noding is aborted.
+ * Experience suggests that this should rarely need to be changed
+ * from the default.
+ * The default is MAX_ITER.
+ * @param n the maximum number of iterations to perform
+ void
+ setMaximumIterations(int n)
+ maxIter = n;
+ getNodedSubstrings() const override
+ return nodedSegStrings;
+ * Fully nodes a list of {@link SegmentStrings}, i.e. peforms noding iteratively
+ * until no intersections are found between segments.
+ * Maintains labelling of edges correctly through
+ * the noding.
+ * @param segStrings a collection of SegmentStrings to be noded
+ * @throws TopologyException if the iterated noding fails to converge.
+ void computeNodes(std::vector<SegmentString*>* inputSegmentStrings) override; // throw(GEOSException);
} // namespace geos::noding
diff --git a/include/geos/noding/MCIndexNoder.h b/include/geos/noding/MCIndexNoder.h
index f0fd48d..d5ba28c 100644
--- a/include/geos/noding/MCIndexNoder.h
+++ b/include/geos/noding/MCIndexNoder.h
@@ -38,13 +38,13 @@
namespace geos {
- namespace geom {
- class LineSegment;
- class SegmentIntersector;
+namespace geom {
+class LineSegment;
+namespace noding {
+class SegmentIntersector;
namespace geos {
@@ -63,55 +63,59 @@ namespace noding { // geos.noding
class GEOS_DLL MCIndexNoder : public SinglePassNoder {
private:
- std::vector<index::chain::MonotoneChain*> monoChains;
- index::strtree::STRtree index;
- int idCounter;
- // statistics
- int nOverlaps;
+ std::vector<index::chain::MonotoneChain*> monoChains;
+ index::strtree::STRtree index;
+ int idCounter;
+ // statistics
+ int nOverlaps;
- void intersectChains();
+ void intersectChains();
- void add(SegmentString* segStr);
+ void add(SegmentString* segStr);
public:
- MCIndexNoder(SegmentIntersector *nSegInt=nullptr)
- SinglePassNoder(nSegInt),
- idCounter(0),
- nodedSegStrings(nullptr),
- nOverlaps(0)
+ MCIndexNoder(SegmentIntersector* nSegInt = nullptr)
+ SinglePassNoder(nSegInt),
+ idCounter(0),
+ nodedSegStrings(nullptr),
+ nOverlaps(0)
- ~MCIndexNoder() override;
+ ~MCIndexNoder() override;
- /// Return a reference to this instance's std::vector of MonotoneChains
- std::vector<index::chain::MonotoneChain*>& getMonotoneChains() { return monoChains; }
+ /// Return a reference to this instance's std::vector of MonotoneChains
+ std::vector<index::chain::MonotoneChain*>&
+ getMonotoneChains()
+ return monoChains;
- index::SpatialIndex& getIndex();
+ index::SpatialIndex& getIndex();
- std::vector<SegmentString*>* getNodedSubstrings() const override;
+ std::vector<SegmentString*>* getNodedSubstrings() const override;
- class SegmentOverlapAction : public index::chain::MonotoneChainOverlapAction {
- public:
- SegmentOverlapAction(SegmentIntersector& newSi)
- index::chain::MonotoneChainOverlapAction(),
- si(newSi)
+ class SegmentOverlapAction : public index::chain::MonotoneChainOverlapAction {
+ public:
+ SegmentOverlapAction(SegmentIntersector& newSi)
+ index::chain::MonotoneChainOverlapAction(),
+ si(newSi)
- void overlap(index::chain::MonotoneChain& mc1, std::size_t start1,
- index::chain::MonotoneChain& mc2, std::size_t start2) override;
+ void overlap(index::chain::MonotoneChain& mc1, std::size_t start1,
+ index::chain::MonotoneChain& mc2, std::size_t start2) override;
private:
SegmentIntersector& si;
SegmentOverlapAction(const SegmentOverlapAction& other) = delete;
SegmentOverlapAction& operator=(const SegmentOverlapAction& rhs) = delete;
diff --git a/include/geos/noding/MCIndexNoder.inl b/include/geos/noding/MCIndexNoder.inl
index 837197a..5883c4f 100644
--- a/include/geos/noding/MCIndexNoder.inl
+++ b/include/geos/noding/MCIndexNoder.inl
@@ -7,7 +7,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -31,14 +31,14 @@ namespace noding { // geos::noding
INLINE index::SpatialIndex&
MCIndexNoder::getIndex()
- return index;
+ return index;
INLINE std::vector<SegmentString*>*
MCIndexNoder::getNodedSubstrings() const
- assert(nodedSegStrings); // must have colled computeNodes before!
- return NodedSegmentString::getNodedSubstrings(*nodedSegStrings);
+ assert(nodedSegStrings); // must have colled computeNodes before!
+ return NodedSegmentString::getNodedSubstrings(*nodedSegStrings);
diff --git a/include/geos/noding/MCIndexSegmentSetMutualIntersector.h b/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
index d35daca..aed9dc5 100644
--- a/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
+++ b/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
@@ -24,20 +24,20 @@
#include <geos/index/chain/MonotoneChainOverlapAction.h> // inherited
namespace geos {
- namespace index {
- class SpatialIndex;
- namespace chain {
- class MonotoneChain;
- namespace strtree {
- //class STRtree;
+namespace index {
+class SpatialIndex;
+namespace chain {
+class MonotoneChain;
+namespace strtree {
+//class STRtree;
+namespace noding {
//using namespace geos::index::strtree;
@@ -51,75 +51,74 @@ namespace noding { // geos::noding
* @version 1.7
-class MCIndexSegmentSetMutualIntersector : public SegmentSetMutualIntersector
+class MCIndexSegmentSetMutualIntersector : public SegmentSetMutualIntersector {
public:
- MCIndexSegmentSetMutualIntersector();
+ MCIndexSegmentSetMutualIntersector();
- ~MCIndexSegmentSetMutualIntersector() override;
+ ~MCIndexSegmentSetMutualIntersector() override;
- index::SpatialIndex* getIndex()
- return index;
+ index::SpatialIndex*
+ getIndex()
+ return index;
- void setBaseSegments(SegmentString::ConstVect* segStrings) override;
+ void setBaseSegments(SegmentString::ConstVect* segStrings) override;
- // NOTE: re-populates the MonotoneChain vector with newly created chains
- void process(SegmentString::ConstVect* segStrings) override;
+ // NOTE: re-populates the MonotoneChain vector with newly created chains
+ void process(SegmentString::ConstVect* segStrings) override;
private:
- SegmentIntersector & si;
+ SegmentIntersector& si;
public:
- SegmentOverlapAction(SegmentIntersector & p_si) :
- index::chain::MonotoneChainOverlapAction(), si(p_si)
+ SegmentOverlapAction(SegmentIntersector& p_si) :
+ index::chain::MonotoneChainOverlapAction(), si(p_si)
* Disable copy construction and assignment. Apparently needed to make this
* class compile under MSVC. (See https://stackoverflow.com/q/29565299)
- MCIndexSegmentSetMutualIntersector(const MCIndexSegmentSetMutualIntersector&) = delete;
- MCIndexSegmentSetMutualIntersector& operator=(const MCIndexSegmentSetMutualIntersector&) = delete;
+ MCIndexSegmentSetMutualIntersector(const MCIndexSegmentSetMutualIntersector&) = delete;
+ MCIndexSegmentSetMutualIntersector& operator=(const MCIndexSegmentSetMutualIntersector&) = delete;
private:
- typedef std::vector<std::unique_ptr<index::chain::MonotoneChain>> MonoChains;
- MonoChains monoChains;
- * The {@link SpatialIndex} used should be something that supports
- * envelope (range) queries efficiently (such as a {@link Quadtree}
- * or {@link STRtree}.
- index::SpatialIndex * index;
- int indexCounter;
- int processCounter;
- // statistics
- int nOverlaps;
+ typedef std::vector<std::unique_ptr<index::chain::MonotoneChain>> MonoChains;
+ MonoChains monoChains;
- /* memory management helper, holds MonotoneChain objects used
- * in the SpatialIndex. It's cleared when the SpatialIndex is
- MonoChains chainStore;
+ * The {@link SpatialIndex} used should be something that supports
+ * envelope (range) queries efficiently (such as a {@link Quadtree}
+ * or {@link STRtree}.
+ index::SpatialIndex* index;
+ int indexCounter;
+ int processCounter;
+ // statistics
+ int nOverlaps;
+ /* memory management helper, holds MonotoneChain objects used
+ * in the SpatialIndex. It's cleared when the SpatialIndex is
+ MonoChains chainStore;
- void addToIndex( SegmentString * segStr);
+ void addToIndex(SegmentString* segStr);
- void addToMonoChains( SegmentString * segStr);
+ void addToMonoChains(SegmentString* segStr);
diff --git a/include/geos/noding/NodableSegmentString.h b/include/geos/noding/NodableSegmentString.h
index 687057c..4263461 100644
--- a/include/geos/noding/NodableSegmentString.h
+++ b/include/geos/noding/NodableSegmentString.h
@@ -20,9 +20,9 @@
#include <geos/noding/SegmentString.h> // for inheritance
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -34,23 +34,22 @@ namespace noding { // geos::noding
* @author Martin Davis
-class GEOS_DLL NodableSegmentString : public SegmentString
+class GEOS_DLL NodableSegmentString : public SegmentString {
private:
protected:
public:
- NodableSegmentString(const void* newContext)
- SegmentString( newContext )
- * Adds an intersection node for a given point and segment to this segment string.
- * @param intPt the location of the intersection
- * @param segmentIndex the index of the segment containing the intersection
- //virtual void addIntersection( const geom::Coordinate * intPt, int segmentIndex) =0;
+ NodableSegmentString(const void* newContext)
+ * Adds an intersection node for a given point and segment to this segment string.
+ * @param intPt the location of the intersection
+ * @param segmentIndex the index of the segment containing the intersection
+ //virtual void addIntersection( const geom::Coordinate * intPt, int segmentIndex) =0;
diff --git a/include/geos/noding/NodedSegmentString.h b/include/geos/noding/NodedSegmentString.h
index 52b02be..46099b8 100644
--- a/include/geos/noding/NodedSegmentString.h
+++ b/include/geos/noding/NodedSegmentString.h
@@ -54,155 +54,155 @@ namespace noding { // geos::noding
* All noded substrings are initialized with the same context object.
-class GEOS_DLL NodedSegmentString : public NodableSegmentString
+class GEOS_DLL NodedSegmentString : public NodableSegmentString {
public:
// TODO: provide a templated method using an output iterator
template <class II>
- static void getNodedSubstrings(II from, II too_far,
- SegmentString::NonConstVect* resultEdgelist)
+ static void
+ getNodedSubstrings(II from, II too_far,
+ SegmentString::NonConstVect* resultEdgelist)
- for (II i=from; i != too_far; ++i)
- NodedSegmentString * nss = dynamic_cast<NodedSegmentString*>(*i);
+ for(II i = from; i != too_far; ++i) {
+ NodedSegmentString* nss = dynamic_cast<NodedSegmentString*>(*i);
assert(nss);
nss->getNodeList().addSplitEdges(resultEdgelist);
template <class C>
- static void getNodedSubstrings(C *segStrings,
+ static void
+ getNodedSubstrings(C* segStrings,
getNodedSubstrings(segStrings->begin(), segStrings->end(), resultEdgelist);
- static void getNodedSubstrings(const SegmentString::NonConstVect& segStrings,
- SegmentString::NonConstVect* resultEdgeList);
+ static void getNodedSubstrings(const SegmentString::NonConstVect& segStrings,
+ SegmentString::NonConstVect* resultEdgeList);
- /// Returns allocated object
- static SegmentString::NonConstVect* getNodedSubstrings(
- const SegmentString::NonConstVect& segStrings);
+ /// Returns allocated object
+ static SegmentString::NonConstVect* getNodedSubstrings(
+ const SegmentString::NonConstVect& segStrings);
- * Creates a new segment string from a list of vertices.
- * @param newPts CoordinateSequence representing the string,
- * ownership transferred.
- * @param data the user-defined data of this segment string
- * (may be null)
- NodedSegmentString(geom::CoordinateSequence *newPts, const void* newContext)
+ * Creates a new segment string from a list of vertices.
+ * @param newPts CoordinateSequence representing the string,
+ * ownership transferred.
+ * @param data the user-defined data of this segment string
+ * (may be null)
+ NodedSegmentString(geom::CoordinateSequence* newPts, const void* newContext)
: NodableSegmentString(newContext)
, nodeList(this)
, pts(newPts)
- ~NodedSegmentString() override
- delete pts;
- * If an intersection already exists for this exact location, the existing
- * node will be returned.
- * @return the intersection node for the point
- SegmentNode* addIntersectionNode( geom::Coordinate * intPt, std::size_t segmentIndex)
- std::size_t normalizedSegmentIndex = segmentIndex;
- // normalize the intersection point location
- std::size_t nextSegIndex = normalizedSegmentIndex + 1;
- if (nextSegIndex < size())
- geom::Coordinate const& nextPt =
+ ~NodedSegmentString() override
+ delete pts;
+ * If an intersection already exists for this exact location, the existing
+ * node will be returned.
+ * @return the intersection node for the point
+ SegmentNode*
+ addIntersectionNode(geom::Coordinate* intPt, std::size_t segmentIndex)
+ std::size_t normalizedSegmentIndex = segmentIndex;
+ // normalize the intersection point location
+ std::size_t nextSegIndex = normalizedSegmentIndex + 1;
+ if(nextSegIndex < size()) {
+ geom::Coordinate const& nextPt =
getCoordinate(nextSegIndex);
- // Normalize segment index if intPt falls on vertex
- // The check for point equality is 2D only - Z values are ignored
- if ( intPt->equals2D( nextPt ))
- normalizedSegmentIndex = nextSegIndex;
- // Add the intersection point to edge intersection list.
- SegmentNode * ei = getNodeList().add( *intPt, normalizedSegmentIndex);
- return ei;
- SegmentNodeList& getNodeList();
- const SegmentNodeList& getNodeList() const;
- /** \brief
- /** \brief
- * Add {SegmentNode}s for one or both
- * intersections found for a segment of an edge to the edge
- * intersection list.
- void addIntersections(algorithm::LineIntersector *li,
- size_t segmentIndex, size_t geomIndex);
- /** \brief
- * Add an SegmentNode for intersection intIndex.
- * An intersection that falls exactly on a vertex
- * of the SegmentString is normalized
- * to use the higher of the two possible segmentIndexes
- void addIntersection(algorithm::LineIntersector *li,
- size_t geomIndex, size_t intIndex);
- /** \brief
- * An intersection that falls exactly on a vertex of the
- * edge is normalized
- void addIntersection(const geom::Coordinate& intPt,
- size_t segmentIndex);
+ // Normalize segment index if intPt falls on vertex
+ // The check for point equality is 2D only - Z values are ignored
+ if(intPt->equals2D(nextPt)) {
+ normalizedSegmentIndex = nextSegIndex;
+ // Add the intersection point to edge intersection list.
+ SegmentNode* ei = getNodeList().add(*intPt, normalizedSegmentIndex);
+ return ei;
+ SegmentNodeList& getNodeList();
+ const SegmentNodeList& getNodeList() const;
+ size_t
+ /** \brief
+ /** \brief
+ * Add {SegmentNode}s for one or both
+ * intersections found for a segment of an edge to the edge
+ * intersection list.
+ void addIntersections(algorithm::LineIntersector* li,
+ size_t segmentIndex, size_t geomIndex);
+ /** \brief
+ * Add an SegmentNode for intersection intIndex.
+ * An intersection that falls exactly on a vertex
+ * of the SegmentString is normalized
+ * to use the higher of the two possible segmentIndexes
+ void addIntersection(algorithm::LineIntersector* li,
+ size_t geomIndex, size_t intIndex);
+ /** \brief
+ * An intersection that falls exactly on a vertex of the
+ * edge is normalized
+ void addIntersection(const geom::Coordinate& intPt,
+ size_t segmentIndex);
private:
- SegmentNodeList nodeList;
+ SegmentNodeList nodeList;
- static int safeOctant(const geom::Coordinate& p0, const geom::Coordinate& p1);
+ static int safeOctant(const geom::Coordinate& p0, const geom::Coordinate& p1);
diff --git a/include/geos/noding/Noder.h b/include/geos/noding/Noder.h
index 034916d..41625d0 100644
--- a/include/geos/noding/Noder.h
+++ b/include/geos/noding/Noder.h
@@ -24,9 +24,9 @@
namespace geos {
+namespace noding {
namespace geos {
@@ -48,29 +48,30 @@ namespace noding { // geos.noding
class GEOS_DLL Noder {
public:
- /** \brief
- * Computes the noding for a collection of {@link SegmentString}s.
- * Some Noders may add all these nodes to the input SegmentStrings;
- * others may only add some or none at all.
- * @param segStrings a collection of {@link SegmentString}s to node
- virtual void computeNodes(std::vector<SegmentString*>* segStrings)=0;
+ /** \brief
+ * Computes the noding for a collection of {@link SegmentString}s.
+ * Some Noders may add all these nodes to the input SegmentStrings;
+ * others may only add some or none at all.
+ * @param segStrings a collection of {@link SegmentString}s to node
+ virtual void computeNodes(std::vector<SegmentString*>* segStrings) = 0;
- /** \brief
- * Returns a {@link Collection} of fully noded {@link SegmentStrings}.
- * The SegmentStrings have the same context as their parent.
- * @return a newly allocated std::vector of const SegmentStrings.
- * Caller is responsible to delete container and elements.
- virtual std::vector<SegmentString*>* getNodedSubstrings() const=0;
+ /** \brief
+ * Returns a {@link Collection} of fully noded {@link SegmentStrings}.
+ * The SegmentStrings have the same context as their parent.
+ * @return a newly allocated std::vector of const SegmentStrings.
+ * Caller is responsible to delete container and elements.
+ virtual std::vector<SegmentString*>* getNodedSubstrings() const = 0;
- virtual ~Noder() {}
+ virtual
+ ~Noder() {}
protected:
- Noder(){}
+ Noder() {}
diff --git a/include/geos/noding/NodingIntersectionFinder.h b/include/geos/noding/NodingIntersectionFinder.h
index c7d2f26..61ebc8c 100644
--- a/include/geos/noding/NodingIntersectionFinder.h
+++ b/include/geos/noding/NodingIntersectionFinder.h
@@ -22,12 +22,12 @@
namespace geos {
+namespace noding {
namespace geos {
@@ -44,55 +44,57 @@ namespace noding { // geos.noding
* @version 1.7
-class NodingIntersectionFinder: public SegmentIntersector
+class NodingIntersectionFinder: public SegmentIntersector {
public:
- /** \brief
- * Creates an intersection finder which finds an interior intersection
- * if one exists
- NodingIntersectionFinder(algorithm::LineIntersector& newLi)
- li(newLi),
- interiorIntersection(geom::Coordinate::getNull()),
+ /** \brief
+ * Creates an intersection finder which finds an interior intersection
+ * if one exists
+ NodingIntersectionFinder(algorithm::LineIntersector& newLi)
+ li(newLi),
+ interiorIntersection(geom::Coordinate::getNull()),
intersectionCount(0),
isCheckEndSegmentsOnly(false),
findAllIntersections(false),
keepIntersections(true)
- /** \brief
- * Tests whether an intersection was found.
- * @return true if an intersection was found
- bool hasIntersection() const
- return !interiorIntersection.isNull();
- /** \brief
- * Gets the computed location of the intersection.
- * Due to round-off, the location may not be exact.
- * @return the coordinate for the intersection location
- const geom::Coordinate& getInteriorIntersection() const
- return interiorIntersection;
+ /** \brief
+ * Tests whether an intersection was found.
+ * @return true if an intersection was found
+ bool
+ hasIntersection() const
+ return !interiorIntersection.isNull();
+ /** \brief
+ * Gets the computed location of the intersection.
+ * Due to round-off, the location may not be exact.
+ * @return the coordinate for the intersection location
+ getInteriorIntersection() const
+ return interiorIntersection;
* Gets the count of intersections found.
* @return the intersection count
- size_t count() const
+ size_t
+ count() const
return intersectionCount;
@@ -106,7 +108,8 @@ public:
* @param isCheckEndSegmentsOnly whether to test only end segments
- void setCheckEndSegmentsOnly(bool isCESO)
+ void
+ setCheckEndSegmentsOnly(bool isCESO)
isCheckEndSegmentsOnly = isCESO;
@@ -121,47 +124,50 @@ public:
* @param findAllIntersections whether all intersections should be computed
- void setFindAllIntersections(bool fAI)
+ void
+ setFindAllIntersections(bool fAI)
findAllIntersections = fAI;
- /** \brief
- * Gets the endpoints of the intersecting segments.
- * @return an array of the segment endpoints (p00, p01, p10, p11)
- const std::vector<geom::Coordinate>& getIntersectionSegments() const
- return intSegments;
- /** \brief
- * intersections for two segments of the {@link SegmentStrings} being intersected.
- * Note that some clients (such as {@link MonotoneChain}s) may optimize away
- * this call for segment pairs which they have determined do not intersect
+ /** \brief
+ * Gets the endpoints of the intersecting segments.
+ * @return an array of the segment endpoints (p00, p01, p10, p11)
+ const std::vector<geom::Coordinate>&
+ getIntersectionSegments() const
+ return intSegments;
+ /** \brief
+ * intersections for two segments of the {@link SegmentStrings} being intersected.
+ * Note that some clients (such as {@link MonotoneChain}s) may optimize away
+ * this call for segment pairs which they have determined do not intersect
+ bool
private:
- geom::Coordinate interiorIntersection;
+ geom::Coordinate interiorIntersection;
size_t intersectionCount;
bool isCheckEndSegmentsOnly;
bool findAllIntersections;
bool keepIntersections;
- std::vector<geom::Coordinate> intSegments;
+ std::vector<geom::Coordinate> intSegments;
NodingIntersectionFinder(const NodingIntersectionFinder& other) = delete;
diff --git a/include/geos/noding/NodingValidator.h b/include/geos/noding/NodingValidator.h
index 0aad997..b62bafe 100644
--- a/include/geos/noding/NodingValidator.h
+++ b/include/geos/noding/NodingValidator.h
@@ -27,12 +27,12 @@
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
+namespace noding {
namespace geos {
@@ -47,48 +47,48 @@ namespace noding { // geos.noding
class GEOS_DLL NodingValidator {
private:
- const std::vector<SegmentString*>& segStrings;
+ const std::vector<SegmentString*>& segStrings;
- * Checks if a segment string contains a segment
- * pattern a-b-a (which implies a self-intersection)
- void checkCollapses() const;
+ * Checks if a segment string contains a segment
+ * pattern a-b-a (which implies a self-intersection)
+ void checkCollapses() const;
- void checkCollapses(const SegmentString& ss) const;
+ void checkCollapses(const SegmentString& ss) const;
- void checkCollapse(const geom::Coordinate& p0, const geom::Coordinate& p1,
- const geom::Coordinate& p2) const;
+ void checkCollapse(const geom::Coordinate& p0, const geom::Coordinate& p1,
+ const geom::Coordinate& p2) const;
- * Checks all pairs of segments for intersections at an
- * interior point of a segment
+ * Checks all pairs of segments for intersections at an
+ * interior point of a segment
- void checkInteriorIntersections(const SegmentString& ss0,
- const SegmentString& ss1);
+ void checkInteriorIntersections(const SegmentString& ss0,
+ const SegmentString& ss1);
- const SegmentString& e0, size_t segIndex0,
- const SegmentString& e1, size_t segIndex1);
+ const SegmentString& e0, size_t segIndex0,
+ const SegmentString& e1, size_t segIndex1);
- * Checks for intersections between an endpoint of a segment string
- * and an interior vertex of another segment string
- void checkEndPtVertexIntersections() const;
+ * Checks for intersections between an endpoint of a segment string
+ * and an interior vertex of another segment string
+ void checkEndPtVertexIntersections() const;
- void checkEndPtVertexIntersections(const geom::Coordinate& testPt,
- const std::vector<SegmentString*>& segStrings) const;
+ void checkEndPtVertexIntersections(const geom::Coordinate& testPt,
+ const std::vector<SegmentString*>& segStrings) const;
- * @return true if there is an intersection point which is not an
- * endpoint of the segment p0-p1
- bool hasInteriorIntersection(const algorithm::LineIntersector& aLi,
- const geom::Coordinate& p0, const geom::Coordinate& p1) const;
+ * @return true if there is an intersection point which is not an
+ * endpoint of the segment p0-p1
+ bool hasInteriorIntersection(const algorithm::LineIntersector& aLi,
+ const geom::Coordinate& p0, const geom::Coordinate& p1) const;
NodingValidator(const NodingValidator& other) = delete;
@@ -96,13 +96,13 @@ private:
public:
- NodingValidator(const std::vector<SegmentString*>& newSegStrings):
+ NodingValidator(const std::vector<SegmentString*>& newSegStrings):
- ~NodingValidator() {}
+ ~NodingValidator() {}
diff --git a/include/geos/noding/Octant.h b/include/geos/noding/Octant.h
index aab788f..327938f 100644
--- a/include/geos/noding/Octant.h
+++ b/include/geos/noding/Octant.h
@@ -22,9 +22,9 @@
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -48,25 +48,26 @@ namespace noding { // geos.noding
class GEOS_DLL Octant {
private:
- Octant() {} // Can't instanciate it
+ Octant() {} // Can't instanciate it
public:
- * Returns the octant of a directed line segment (specified
- * as x and y displacements, which cannot both be 0).
- static int octant(double dx, double dy);
+ * Returns the octant of a directed line segment (specified
+ * as x and y displacements, which cannot both be 0).
+ static int octant(double dx, double dy);
- * Returns the octant of a directed line segment from p0 to p1.
- static int octant(const geom::Coordinate& p0, const geom::Coordinate& p1);
+ * Returns the octant of a directed line segment from p0 to p1.
+ static int octant(const geom::Coordinate& p0, const geom::Coordinate& p1);
- static int octant(const geom::Coordinate* p0, const geom::Coordinate* p1)
+ static int
+ octant(const geom::Coordinate* p0, const geom::Coordinate* p1)
::geos::ignore_unused_variable_warning(p0);
- return octant(*p0, *p1);
+ return octant(*p0, *p1);
diff --git a/include/geos/noding/OrientedCoordinateArray.h b/include/geos/noding/OrientedCoordinateArray.h
index 4a4dd78..43eb97f 100644
--- a/include/geos/noding/OrientedCoordinateArray.h
+++ b/include/geos/noding/OrientedCoordinateArray.h
@@ -28,12 +28,12 @@
namespace geos {
- namespace geom {
- class CoordinateSequence;
- //class SegmentString;
+namespace geom {
+class CoordinateSequence;
+namespace noding {
+//class SegmentString;
namespace geos {
@@ -43,68 +43,68 @@ namespace noding { // geos.noding
* Allows comparing {@link geom::CoordinateSequence}s
* in an orientation-independent way.
-class GEOS_DLL OrientedCoordinateArray
+class GEOS_DLL OrientedCoordinateArray {
public:
- * Creates a new {@link OrientedCoordinateArray}
- * for the given {@link geom::CoordinateSequence}.
- * @param pts the coordinates to orient
- OrientedCoordinateArray(const geom::CoordinateSequence& p_pts)
- pts(&p_pts),
- orientationVar(orientation(p_pts))
- /** \brief
- * Compares two {@link OrientedCoordinateArray}s for their
- * relative order
- * @return -1 this one is smaller
- * @return 0 the two objects are equal
- * @return 1 this one is greater
- * In JTS, this is used automatically by ordered lists.
- * In C++, operator< would be used instead....
- int compareTo(const OrientedCoordinateArray& o1) const;
+ * Creates a new {@link OrientedCoordinateArray}
+ * for the given {@link geom::CoordinateSequence}.
+ * @param pts the coordinates to orient
+ OrientedCoordinateArray(const geom::CoordinateSequence& p_pts)
+ pts(&p_pts),
+ orientationVar(orientation(p_pts))
+ /** \brief
+ * Compares two {@link OrientedCoordinateArray}s for their
+ * relative order
+ * @return -1 this one is smaller
+ * @return 0 the two objects are equal
+ * @return 1 this one is greater
+ * In JTS, this is used automatically by ordered lists.
+ * In C++, operator< would be used instead....
+ int compareTo(const OrientedCoordinateArray& o1) const;
private:
- static int compareOriented(const geom::CoordinateSequence& pts1,
- bool orientation1,
- const geom::CoordinateSequence& pts2,
- bool orientation2);
+ static int compareOriented(const geom::CoordinateSequence& pts1,
+ bool orientation1,
+ const geom::CoordinateSequence& pts2,
+ bool orientation2);
- * Computes the canonical orientation for a coordinate array.
- * @param pts the array to test
- * @return <code>true</code> if the points are oriented forwards
- * @return <code>false</code if the points are oriented in reverse
- static bool orientation(const geom::CoordinateSequence& pts);
+ * Computes the canonical orientation for a coordinate array.
+ * @param pts the array to test
+ * @return <code>true</code> if the points are oriented forwards
+ * @return <code>false</code if the points are oriented in reverse
+ static bool orientation(const geom::CoordinateSequence& pts);
- /// Externally owned
- const geom::CoordinateSequence* pts;
+ /// Externally owned
+ const geom::CoordinateSequence* pts;
- bool orientationVar;
+ bool orientationVar;
/// Strict weak ordering operator for OrientedCoordinateArray
/// This is the C++ equivalent of JTS's compareTo
-inline bool operator< ( const OrientedCoordinateArray& oca1,
- const OrientedCoordinateArray& oca2 )
+inline bool
+operator< (const OrientedCoordinateArray& oca1,
+ const OrientedCoordinateArray& oca2)
- return oca1.compareTo(oca2)<0;
+ return oca1.compareTo(oca2) < 0;
diff --git a/include/geos/noding/ScaledNoder.h b/include/geos/noding/ScaledNoder.h
index 52decf0..75f256e 100644
--- a/include/geos/noding/ScaledNoder.h
+++ b/include/geos/noding/ScaledNoder.h
@@ -36,13 +36,13 @@
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
+namespace noding {
namespace geos {
@@ -62,57 +62,62 @@ class GEOS_DLL ScaledNoder : public Noder { // , public geom::CoordinateFilter {
public:
- bool isIntegerPrecision() { return (scaleFactor == 1.0); }
+ bool
+ isIntegerPrecision()
+ return (scaleFactor == 1.0);
- ScaledNoder(Noder& n, double nScaleFactor,
- double nOffsetX=0.0, double nOffsetY=0.0)
- noder(n),
- scaleFactor(nScaleFactor),
- offsetX(nOffsetX),
- offsetY(nOffsetY),
- isScaled(nScaleFactor!=1.0)
+ ScaledNoder(Noder& n, double nScaleFactor,
+ double nOffsetX = 0.0, double nOffsetY = 0.0)
+ noder(n),
+ scaleFactor(nScaleFactor),
+ offsetX(nOffsetX),
+ offsetY(nOffsetY),
+ isScaled(nScaleFactor != 1.0)
- ~ScaledNoder() override;
+ ~ScaledNoder() override;
- void computeNodes(std::vector<SegmentString*>* inputSegStr) override;
+ void computeNodes(std::vector<SegmentString*>* inputSegStr) override;
- //void filter(Coordinate& c);
+ //void filter(Coordinate& c);
- void filter_ro(const geom::Coordinate* c)
+ void
+ filter_ro(const geom::Coordinate* c)
::geos::ignore_unused_variable_warning(c);
assert(0);
- void filter_rw(geom::Coordinate* c) const;
+ void filter_rw(geom::Coordinate* c) const;
private:
- Noder& noder;
+ Noder& noder;
- double scaleFactor;
+ double scaleFactor;
- double offsetX;
+ double offsetX;
- double offsetY;
+ double offsetY;
- bool isScaled;
+ bool isScaled;
- void rescale(std::vector<SegmentString*>& segStrings) const;
+ void rescale(std::vector<SegmentString*>& segStrings) const;
- void scale(std::vector<SegmentString*>& segStrings) const;
+ void scale(std::vector<SegmentString*>& segStrings) const;
- class Scaler;
+ class Scaler;
- class ReScaler;
+ class ReScaler;
- friend class ScaledNoder::Scaler;
+ friend class ScaledNoder::Scaler;
- friend class ScaledNoder::ReScaler;
+ friend class ScaledNoder::ReScaler;
mutable std::vector<geom::CoordinateSequence*> newCoordSeq;
diff --git a/include/geos/noding/SegmentIntersectionDetector.h b/include/geos/noding/SegmentIntersectionDetector.h
index 1957dbd..4d8c14f 100644
--- a/include/geos/noding/SegmentIntersectionDetector.h
+++ b/include/geos/noding/SegmentIntersectionDetector.h
@@ -39,128 +39,137 @@ namespace noding { // geos::noding
* @version 1.7
-class SegmentIntersectionDetector : public SegmentIntersector
+class SegmentIntersectionDetector : public SegmentIntersector {
private:
- algorithm::LineIntersector * li;
+ algorithm::LineIntersector* li;
- bool findProper;
- bool findAllTypes;
+ bool findProper;
+ bool findAllTypes;
- bool _hasIntersection;
- bool _hasProperIntersection;
- bool _hasNonProperIntersection;
+ bool _hasIntersection;
+ bool _hasProperIntersection;
+ bool _hasNonProperIntersection;
- const geom::Coordinate * intPt;
- geom::CoordinateSequence * intSegments;
+ const geom::Coordinate* intPt;
+ geom::CoordinateSequence* intSegments;
protected:
public:
- SegmentIntersectionDetector( algorithm::LineIntersector * p_li)
- li( p_li),
- findProper(false),
- findAllTypes(false),
- _hasIntersection(false),
- _hasProperIntersection(false),
- _hasNonProperIntersection(false),
- intPt( nullptr),
- intSegments( nullptr)
- ~SegmentIntersectionDetector() override
- //delete intPt;
- delete intSegments;
- void setFindProper( bool p_findProper)
- this->findProper = p_findProper;
- void setFindAllIntersectionTypes( bool p_findAllTypes)
- this->findAllTypes = p_findAllTypes;
- return _hasIntersection;
- * Tests whether a proper intersection was found.
- * @return true if a proper intersection was found
- bool hasProperIntersection() const
- return _hasProperIntersection;
- * Tests whether a non-proper intersection was found.
- * @return true if a non-proper intersection was found
- bool hasNonProperIntersection() const
- return _hasNonProperIntersection;
- const geom::Coordinate * getIntersection() const
- return intPt;
- const geom::CoordinateSequence * getIntersectionSegments() const
- // If finding all types, we can stop
- // when both possible types have been found.
- if (findAllTypes)
- return _hasProperIntersection && _hasNonProperIntersection;
- // If searching for a proper intersection, only stop if one is found
- if (findProper)
- void processIntersections( noding::SegmentString * e0, size_t segIndex0,
- noding::SegmentString * e1, size_t segIndex1 ) override;
+ SegmentIntersectionDetector(algorithm::LineIntersector* p_li)
+ li(p_li),
+ findProper(false),
+ findAllTypes(false),
+ _hasIntersection(false),
+ _hasProperIntersection(false),
+ _hasNonProperIntersection(false),
+ intPt(nullptr),
+ intSegments(nullptr)
+ ~SegmentIntersectionDetector() override
+ //delete intPt;
+ delete intSegments;
+ void
+ setFindProper(bool p_findProper)
+ this->findProper = p_findProper;
+ void
+ setFindAllIntersectionTypes(bool p_findAllTypes)
+ this->findAllTypes = p_findAllTypes;
+ bool
+ return _hasIntersection;
+ * Tests whether a proper intersection was found.
+ * @return true if a proper intersection was found
+ bool
+ hasProperIntersection() const
+ return _hasProperIntersection;
+ * Tests whether a non-proper intersection was found.
+ * @return true if a non-proper intersection was found
+ bool
+ hasNonProperIntersection() const
+ return _hasNonProperIntersection;
+ getIntersection() const
+ return intPt;
+ bool
+ // If finding all types, we can stop
+ // when both possible types have been found.
+ if(findAllTypes) {
+ return _hasProperIntersection && _hasNonProperIntersection;
+ // If searching for a proper intersection, only stop if one is found
+ if(findProper) {
+ void processIntersections(noding::SegmentString* e0, size_t segIndex0,
+ noding::SegmentString* e1, size_t segIndex1) override;
diff --git a/include/geos/noding/SegmentIntersector.h b/include/geos/noding/SegmentIntersector.h
index f7d4535..5b9139a 100644
--- a/include/geos/noding/SegmentIntersector.h
+++ b/include/geos/noding/SegmentIntersector.h
@@ -22,9 +22,9 @@
namespace geos {
+namespace noding {
namespace geos {
@@ -49,35 +49,38 @@ class GEOS_DLL SegmentIntersector {
public:
- * of the SegmentIntersector interface to process
- virtual void processIntersections(
- SegmentString* e1, size_t segIndex1) = 0;
- * \brief
- * Reports whether the client of this class
- * needs to continue testing all intersections in an arrangement.
- * @return true if there is not need to continue testing segments
- * The default implementation always return false (process all intersections).
- virtual bool isDone() const {
- return false;
- virtual ~SegmentIntersector()
+ * of the SegmentIntersector interface to process
+ virtual void processIntersections(
+ SegmentString* e1, size_t segIndex1) = 0;
+ * \brief
+ * Reports whether the client of this class
+ * needs to continue testing all intersections in an arrangement.
+ * @return true if there is not need to continue testing segments
+ * The default implementation always return false (process all intersections).
+ virtual bool
+ isDone() const
+ return false;
+ virtual
+ ~SegmentIntersector()
protected:
- SegmentIntersector() {}
+ SegmentIntersector() {}
diff --git a/include/geos/noding/SegmentNode.h b/include/geos/noding/SegmentNode.h
index 862230f..5b2bc47 100644
--- a/include/geos/noding/SegmentNode.h
+++ b/include/geos/noding/SegmentNode.h
@@ -30,9 +30,9 @@
namespace geos {
- class NodedSegmentString;
+namespace noding {
+class NodedSegmentString;
namespace geos {
@@ -44,70 +44,76 @@ namespace noding { // geos.noding
class GEOS_DLL SegmentNode {
private:
- const NodedSegmentString& segString;
+ const NodedSegmentString& segString;
- int segmentOctant;
+ int segmentOctant;
- bool isInteriorVar;
+ bool isInteriorVar;
SegmentNode(const SegmentNode& other) = delete;
SegmentNode& operator=(const SegmentNode& rhs) = delete;
public:
- friend std::ostream& operator<< (std::ostream& os, const SegmentNode& n);
- /// the point of intersection (own copy)
- geom::Coordinate coord;
- /// the index of the containing line segment in the parent edge
- size_t segmentIndex;
- /// Construct a node on the given NodedSegmentString
- /// @param ss the parent NodedSegmentString
- /// @param coord the coordinate of the intersection, will be copied
- /// @param nSegmentIndex the index of the segment on parent
- /// NodedSegmentString
- /// where the Node is located.
- /// @param nSegmentOctant
- SegmentNode(const NodedSegmentString& ss,
- const geom::Coordinate& nCoord,
- size_t nSegmentIndex, int nSegmentOctant);
- ~SegmentNode() {}
- /// \brief
- /// Return true if this Node is *internal* (not on the boundary)
- /// of the corresponding segment. Currently only the *first*
- /// segment endpoint is checked, actually.
- bool isInterior() const { return isInteriorVar; }
- bool isEndPoint(unsigned int maxSegmentIndex) const;
- * @return -1 this EdgeIntersection is located before
- * the argument location
- * @return 0 this EdgeIntersection is at the argument location
- * @return 1 this EdgeIntersection is located after the
- * argument location
- int compareTo(const SegmentNode& other);
- //string print() const;
+ friend std::ostream& operator<< (std::ostream& os, const SegmentNode& n);
+ /// the point of intersection (own copy)
+ geom::Coordinate coord;
+ /// the index of the containing line segment in the parent edge
+ size_t segmentIndex;
+ /// Construct a node on the given NodedSegmentString
+ /// @param ss the parent NodedSegmentString
+ /// @param coord the coordinate of the intersection, will be copied
+ /// @param nSegmentIndex the index of the segment on parent
+ /// NodedSegmentString
+ /// where the Node is located.
+ /// @param nSegmentOctant
+ SegmentNode(const NodedSegmentString& ss,
+ const geom::Coordinate& nCoord,
+ size_t nSegmentIndex, int nSegmentOctant);
+ ~SegmentNode() {}
+ /// \brief
+ /// Return true if this Node is *internal* (not on the boundary)
+ /// of the corresponding segment. Currently only the *first*
+ /// segment endpoint is checked, actually.
+ bool
+ isInterior() const
+ return isInteriorVar;
+ bool isEndPoint(unsigned int maxSegmentIndex) const;
+ * @return -1 this EdgeIntersection is located before
+ * the argument location
+ * @return 0 this EdgeIntersection is at the argument location
+ * @return 1 this EdgeIntersection is located after the
+ * argument location
+ int compareTo(const SegmentNode& other);
+ //string print() const;
struct GEOS_DLL SegmentNodeLT {
- bool operator()(SegmentNode *s1, SegmentNode *s2) const {
- return s1->compareTo(*s2)<0;
+ bool
+ operator()(SegmentNode* s1, SegmentNode* s2) const
+ return s1->compareTo(*s2) < 0;
diff --git a/include/geos/noding/SegmentNodeList.h b/include/geos/noding/SegmentNodeList.h
index 872e5ce..8f100fa 100644
--- a/include/geos/noding/SegmentNodeList.h
+++ b/include/geos/noding/SegmentNodeList.h
@@ -37,13 +37,13 @@
namespace geos {
- namespace geom {
+namespace geom {
+namespace noding {
namespace geos {
@@ -55,58 +55,58 @@ namespace noding { // geos::noding
class GEOS_DLL SegmentNodeList {
private:
- std::set<SegmentNode*,SegmentNodeLT> nodeMap;
- // the parent edge
- const NodedSegmentString& edge;
- * Checks the correctness of the set of split edges corresponding
- * to this edge
- * @param splitEdges the split edges for this edge (in order)
- void checkSplitEdgesCorrectness(std::vector<SegmentString*>& splitEdges);
- * Create a new "split edge" with the section of points between
- * (and including) the two intersections.
- * The label for the new edge is the same as the label for the
- * parent edge.
- * ownership of return value is transferred
- SegmentString* createSplitEdge(SegmentNode *ei0, SegmentNode *ei1);
- * Adds nodes for any collapsed edge pairs.
- * Collapsed edge pairs can be caused by inserted nodes, or they
- * can be pre-existing in the edge vertex list.
- * In order to provide the correct fully noded semantics,
- * the vertex at the base of a collapsed pair must also be added
- * as a node.
- void addCollapsedNodes();
- * which are pre-existing in the vertex list.
- void findCollapsesFromExistingVertices(
- std::vector<std::size_t>& collapsedVertexIndexes);
- * Adds nodes for any collapsed edge pairs caused by inserted nodes
- * Collapsed edge pairs occur when the same coordinate is inserted
- * as a node both before and after an existing edge vertex.
- * To provide the correct fully noded semantics,
- * the vertex must be added as a node as well.
- void findCollapsesFromInsertedNodes(
- bool findCollapseIndex(SegmentNode& ei0, SegmentNode& ei1,
- size_t& collapsedVertexIndex);
+ std::set<SegmentNode*, SegmentNodeLT> nodeMap;
+ // the parent edge
+ const NodedSegmentString& edge;
+ * Checks the correctness of the set of split edges corresponding
+ * to this edge
+ * @param splitEdges the split edges for this edge (in order)
+ void checkSplitEdgesCorrectness(std::vector<SegmentString*>& splitEdges);
+ * Create a new "split edge" with the section of points between
+ * (and including) the two intersections.
+ * The label for the new edge is the same as the label for the
+ * parent edge.
+ * ownership of return value is transferred
+ SegmentString* createSplitEdge(SegmentNode* ei0, SegmentNode* ei1);
+ * Adds nodes for any collapsed edge pairs.
+ * Collapsed edge pairs can be caused by inserted nodes, or they
+ * can be pre-existing in the edge vertex list.
+ * In order to provide the correct fully noded semantics,
+ * the vertex at the base of a collapsed pair must also be added
+ * as a node.
+ void addCollapsedNodes();
+ * which are pre-existing in the vertex list.
+ void findCollapsesFromExistingVertices(
+ std::vector<std::size_t>& collapsedVertexIndexes);
+ * Adds nodes for any collapsed edge pairs caused by inserted nodes
+ * Collapsed edge pairs occur when the same coordinate is inserted
+ * as a node both before and after an existing edge vertex.
+ * To provide the correct fully noded semantics,
+ * the vertex must be added as a node as well.
+ void findCollapsesFromInsertedNodes(
+ bool findCollapseIndex(SegmentNode& ei0, SegmentNode& ei1,
+ size_t& collapsedVertexIndex);
SegmentNodeList(const SegmentNodeList& other) = delete;
@@ -114,72 +114,104 @@ private:
public:
- friend std::ostream& operator<< (std::ostream& os, const SegmentNodeList& l);
- typedef std::set<SegmentNode*,SegmentNodeLT> container;
- typedef container::iterator iterator;
- typedef container::const_iterator const_iterator;
- SegmentNodeList(const NodedSegmentString* newEdge): edge(*newEdge) {}
- SegmentNodeList(const NodedSegmentString& newEdge): edge(newEdge) {}
- const NodedSegmentString& getEdge() const { return edge; }
- // TODO: Is this a final class ?
- // Should remove the virtual in that case
- virtual ~SegmentNodeList();
- * Adds an intersection into the list, if it isn't already there.
- * The input segmentIndex is expected to be normalized.
- * @return the SegmentIntersection found or added. It will be
- * destroyed at SegmentNodeList destruction time.
- * @param intPt the intersection Coordinate, will be copied
- SegmentNode* add(const geom::Coordinate& intPt, std::size_t segmentIndex);
- SegmentNode* add(const geom::Coordinate *intPt, std::size_t segmentIndex) {
- return add(*intPt, segmentIndex);
- * returns the set of SegmentNodes
- //replaces iterator()
- // TODO: obsolete this function
- std::set<SegmentNode*,SegmentNodeLT>* getNodes() { return &nodeMap; }
- /// Return the number of nodes in this list
- size_t size() const { return nodeMap.size(); }
- container::iterator begin() { return nodeMap.begin(); }
- container::const_iterator begin() const { return nodeMap.begin(); }
- container::iterator end() { return nodeMap.end(); }
- container::const_iterator end() const { return nodeMap.end(); }
- * Adds entries for the first and last points of the edge to the list
- void addEndpoints();
- * Creates new edges for all the edges that the intersections in this
- * list split the parent edge into.
- * Adds the edges to the input list (this is so a single list
- * can be used to accumulate all split edges for a Geometry).
- void addSplitEdges(std::vector<SegmentString*>& edgeList);
- void addSplitEdges(std::vector<SegmentString*>* edgeList) {
- assert(edgeList);
- addSplitEdges(*edgeList);
- //string print();
+ friend std::ostream& operator<< (std::ostream& os, const SegmentNodeList& l);
+ typedef std::set<SegmentNode*, SegmentNodeLT> container;
+ typedef container::iterator iterator;
+ typedef container::const_iterator const_iterator;
+ SegmentNodeList(const NodedSegmentString* newEdge): edge(*newEdge) {}
+ SegmentNodeList(const NodedSegmentString& newEdge): edge(newEdge) {}
+ getEdge() const
+ return edge;
+ // TODO: Is this a final class ?
+ // Should remove the virtual in that case
+ virtual ~SegmentNodeList();
+ * Adds an intersection into the list, if it isn't already there.
+ * The input segmentIndex is expected to be normalized.
+ * @return the SegmentIntersection found or added. It will be
+ * destroyed at SegmentNodeList destruction time.
+ * @param intPt the intersection Coordinate, will be copied
+ SegmentNode* add(const geom::Coordinate& intPt, std::size_t segmentIndex);
+ SegmentNode*
+ add(const geom::Coordinate* intPt, std::size_t segmentIndex)
+ return add(*intPt, segmentIndex);
+ * returns the set of SegmentNodes
+ //replaces iterator()
+ // TODO: obsolete this function
+ std::set<SegmentNode*, SegmentNodeLT>*
+ getNodes()
+ return &nodeMap;
+ /// Return the number of nodes in this list
+ size_t
+ size() const
+ return nodeMap.size();
+ container::iterator
+ begin()
+ return nodeMap.begin();
+ container::const_iterator
+ begin() const
+ end()
+ return nodeMap.end();
+ end() const
+ * Adds entries for the first and last points of the edge to the list
+ void addEndpoints();
+ * Creates new edges for all the edges that the intersections in this
+ * list split the parent edge into.
+ * Adds the edges to the input list (this is so a single list
+ * can be used to accumulate all split edges for a Geometry).
+ void addSplitEdges(std::vector<SegmentString*>& edgeList);
+ void
+ addSplitEdges(std::vector<SegmentString*>* edgeList)
+ assert(edgeList);
+ addSplitEdges(*edgeList);
+ //string print();
diff --git a/include/geos/noding/SegmentPointComparator.h b/include/geos/noding/SegmentPointComparator.h
index 7579195..48d5e11 100644
--- a/include/geos/noding/SegmentPointComparator.h
+++ b/include/geos/noding/SegmentPointComparator.h
@@ -40,53 +40,78 @@ class GEOS_DLL SegmentPointComparator {
public:
- * Compares two Coordinates for their relative position along a
- * segment lying in the specified Octant.
- * @return -1 node0 occurs first
- * @return 0 the two nodes are equal
- * @return 1 node1 occurs first
- static int compare(int octant, const geom::Coordinate& p0,
- const geom::Coordinate& p1)
- // nodes can only be equal if their coordinates are equal
- if (p0.equals2D(p1)) return 0;
+ * Compares two Coordinates for their relative position along a
+ * segment lying in the specified Octant.
+ * @return -1 node0 occurs first
+ * @return 0 the two nodes are equal
+ * @return 1 node1 occurs first
+ static int
+ compare(int octant, const geom::Coordinate& p0,
+ const geom::Coordinate& p1)
+ // nodes can only be equal if their coordinates are equal
+ if(p0.equals2D(p1)) {
+ return 0;
- int xSign = relativeSign(p0.x, p1.x);
- int ySign = relativeSign(p0.y, p1.y);
+ int xSign = relativeSign(p0.x, p1.x);
+ int ySign = relativeSign(p0.y, p1.y);
- switch (octant) {
- case 0: return compareValue(xSign, ySign);
- case 1: return compareValue(ySign, xSign);
- case 2: return compareValue(ySign, -xSign);
- case 3: return compareValue(-xSign, ySign);
- case 4: return compareValue(-xSign, -ySign);
- case 5: return compareValue(-ySign, -xSign);
- case 6: return compareValue(-ySign, xSign);
- case 7: return compareValue(xSign, -ySign);
- assert(0); // invalid octant value
- return 0;
+ switch(octant) {
+ case 0:
+ return compareValue(xSign, ySign);
+ case 1:
+ return compareValue(ySign, xSign);
+ case 2:
+ return compareValue(ySign, -xSign);
+ case 3:
+ return compareValue(-xSign, ySign);
+ case 4:
+ return compareValue(-xSign, -ySign);
+ case 5:
+ return compareValue(-ySign, -xSign);
+ case 6:
+ return compareValue(-ySign, xSign);
+ case 7:
+ return compareValue(xSign, -ySign);
+ assert(0); // invalid octant value
+ return 0;
- static int relativeSign(double x0, double x1)
- if (x0 < x1) return -1;
- if (x0 > x1) return 1;
- return 0;
+ static int
+ relativeSign(double x0, double x1)
+ if(x0 < x1) {
+ return -1;
+ if(x0 > x1) {
+ return 1;
+ return 0;
- static int compareValue(int compareSign0, int compareSign1)
- if (compareSign0 < 0) return -1;
- if (compareSign0 > 0) return 1;
- if (compareSign1 < 0) return -1;
- if (compareSign1 > 0) return 1;
- return 0;
+ static int
+ compareValue(int compareSign0, int compareSign1)
+ if(compareSign0 < 0) {
+ return -1;
+ if(compareSign0 > 0) {
+ return 1;
+ if(compareSign1 < 0) {
+ return -1;
+ if(compareSign1 > 0) {
+ return 1;
+ return 0;
diff --git a/include/geos/noding/SegmentSetMutualIntersector.h b/include/geos/noding/SegmentSetMutualIntersector.h
index 5668a90..3ef94f8 100644
--- a/include/geos/noding/SegmentSetMutualIntersector.h
+++ b/include/geos/noding/SegmentSetMutualIntersector.h
@@ -34,40 +34,41 @@ namespace noding { // geos::noding
* @version 1.10
-class SegmentSetMutualIntersector
+class SegmentSetMutualIntersector {
public:
: segInt(nullptr)
- virtual ~SegmentSetMutualIntersector() {}
+ virtual
+ ~SegmentSetMutualIntersector() {}
- * Sets the {@link SegmentIntersector} to use with this intersector.
- * The SegmentIntersector will either rocord or add intersection nodes
- * for the input segment strings.
- * @param segInt the segment intersector to use
- void setSegmentIntersector(SegmentIntersector* si)
- segInt = si;
+ * Sets the {@link SegmentIntersector} to use with this intersector.
+ * The SegmentIntersector will either rocord or add intersection nodes
+ * for the input segment strings.
+ * @param segInt the segment intersector to use
+ void
+ setSegmentIntersector(SegmentIntersector* si)
+ segInt = si;
- * @param segStrings0 a collection of {@link SegmentString}s to node
- virtual void setBaseSegments(SegmentString::ConstVect* segStrings) = 0;
+ * @param segStrings0 a collection of {@link SegmentString}s to node
+ virtual void setBaseSegments(SegmentString::ConstVect* segStrings) = 0;
- * Computes the intersections for two collections of {@link SegmentString}s.
- * @param segStrings1 a collection of {@link SegmentString}s to node
- virtual void process(SegmentString::ConstVect* segStrings) = 0;
+ * Computes the intersections for two collections of {@link SegmentString}s.
+ * @param segStrings1 a collection of {@link SegmentString}s to node
+ virtual void process(SegmentString::ConstVect* segStrings) = 0;
protected:
diff --git a/include/geos/noding/SegmentString.h b/include/geos/noding/SegmentString.h
index 750490e..4b64e72 100644
--- a/include/geos/noding/SegmentString.h
+++ b/include/geos/noding/SegmentString.h
@@ -28,9 +28,9 @@
// Forward declarations
namespace geos {
- namespace algorithm {
- class LineIntersector;
+namespace algorithm {
+class LineIntersector;
namespace geos {
@@ -45,57 +45,66 @@ namespace noding { // geos.noding
class GEOS_DLL SegmentString {
public:
- typedef std::vector<const SegmentString*> ConstVect;
- typedef std::vector<SegmentString *> NonConstVect;
- const SegmentString& ss);
- /// Construct a SegmentString.
- /// @param newContext the context associated to this SegmentString
- SegmentString(const void* newContext)
- context(newContext)
- virtual ~SegmentString() {}
- * Gets the user-defined data for this segment string.
- * @return the user-defined data
- const void* getData() const { return context; }
- * Sets the user-defined data for this segment string.
- * @param data an Object containing user-defined data
- void setData(const void* data) { context=data; }
- virtual size_t size() const=0;
- virtual const geom::Coordinate& getCoordinate(size_t i) const=0;
- /// \brief
- /// Return a pointer to the CoordinateSequence associated
- /// with this SegmentString.
- /// Note that the CoordinateSequence is owned by this SegmentString!
- virtual geom::CoordinateSequence* getCoordinates() const=0;
- virtual bool isClosed() const=0;
- virtual std::ostream& print(std::ostream& os) const;
+ typedef std::vector<const SegmentString*> ConstVect;
+ typedef std::vector<SegmentString*> NonConstVect;
+ const SegmentString& ss);
+ /// Construct a SegmentString.
+ /// @param newContext the context associated to this SegmentString
+ SegmentString(const void* newContext)
+ context(newContext)
+ virtual
+ ~SegmentString() {}
+ * Gets the user-defined data for this segment string.
+ * @return the user-defined data
+ const void*
+ getData() const
+ return context;
+ * Sets the user-defined data for this segment string.
+ * @param data an Object containing user-defined data
+ void
+ setData(const void* data)
+ context = data;
+ virtual size_t size() const = 0;
+ virtual const geom::Coordinate& getCoordinate(size_t i) const = 0;
+ /// \brief
+ /// Return a pointer to the CoordinateSequence associated
+ /// with this SegmentString.
+ /// Note that the CoordinateSequence is owned by this SegmentString!
+ virtual geom::CoordinateSequence* getCoordinates() const = 0;
+ virtual bool isClosed() const = 0;
+ virtual std::ostream& print(std::ostream& os) const;
private:
- const void* context;
+ const void* context;
// Declare type as noncopyable
SegmentString(const SegmentString& other) = delete;
diff --git a/include/geos/noding/SegmentStringUtil.h b/include/geos/noding/SegmentStringUtil.h
index 0aed670..99f3297 100644
--- a/include/geos/noding/SegmentStringUtil.h
+++ b/include/geos/noding/SegmentStringUtil.h
@@ -34,38 +34,37 @@ namespace noding { // geos::noding
-class SegmentStringUtil
+class SegmentStringUtil {
public:
- /** \brief
- * Extracts all linear components from a given {@link Geometry}
- * to {@link SegmentString}s.
- * The SegmentString data item is set to be the source Geometry.
- * @param geom the geometry to extract from
- * @param segStr a List of SegmentStrings (output parameter).
- * Ownership of elements pushed to the vector
- * is transferred to caller.
- static void extractSegmentStrings(const geom::Geometry * g,
- SegmentString::ConstVect& segStr)
- geom::LineString::ConstVect lines;
- geom::util::LinearComponentExtracter::getLines(*g, lines);
+ /** \brief
+ * Extracts all linear components from a given {@link Geometry}
+ * to {@link SegmentString}s.
+ * The SegmentString data item is set to be the source Geometry.
+ * @param geom the geometry to extract from
+ * @param segStr a List of SegmentStrings (output parameter).
+ * Ownership of elements pushed to the vector
+ * is transferred to caller.
+ static void
+ extractSegmentStrings(const geom::Geometry* g,
+ SegmentString::ConstVect& segStr)
+ geom::LineString::ConstVect lines;
+ geom::util::LinearComponentExtracter::getLines(*g, lines);
- for (std::size_t i=0, n=lines.size(); i<n; i++)
- geom::LineString* line = (geom::LineString*)(lines[i]);
+ for(std::size_t i = 0, n = lines.size(); i < n; i++) {
+ geom::LineString* line = (geom::LineString*)(lines[i]);
- // we take ownership of the coordinates here
- // TODO: check if this can be optimized by getting
- // the internal CS.
- geom::CoordinateSequence* pts = line->getCoordinates();
+ // we take ownership of the coordinates here
+ // TODO: check if this can be optimized by getting
+ // the internal CS.
+ geom::CoordinateSequence* pts = line->getCoordinates();
- segStr.push_back(new NodedSegmentString(pts, g));
+ segStr.push_back(new NodedSegmentString(pts, g));
diff --git a/include/geos/noding/SimpleNoder.h b/include/geos/noding/SimpleNoder.h
index cb700db..18a288f 100644
--- a/include/geos/noding/SimpleNoder.h
+++ b/include/geos/noding/SimpleNoder.h
@@ -30,9 +30,9 @@
namespace geos {
- namespace noding {
+namespace noding {
namespace geos {
@@ -50,20 +50,22 @@ namespace noding { // geos.noding
class GEOS_DLL SimpleNoder: public SinglePassNoder {
private:
- virtual void computeIntersects(SegmentString *e0, SegmentString *e1);
+ virtual void computeIntersects(SegmentString* e0, SegmentString* e1);
public:
- SimpleNoder(SegmentIntersector* nSegInt=nullptr)
+ SimpleNoder(SegmentIntersector* nSegInt = nullptr)
} // namespace geos.noding
diff --git a/include/geos/noding/SinglePassNoder.h b/include/geos/noding/SinglePassNoder.h
index c18781f..5a800d5 100644
--- a/include/geos/noding/SinglePassNoder.h
+++ b/include/geos/noding/SinglePassNoder.h
@@ -25,10 +25,10 @@
namespace geos {
- class SegmentString;
+namespace noding {
+class SegmentString;
namespace geos {
@@ -51,42 +51,44 @@ class GEOS_DLL SinglePassNoder : public Noder { // implements Noder
protected:
- SegmentIntersector* segInt;
+ SegmentIntersector* segInt;
public:
- SinglePassNoder(SegmentIntersector* nSegInt=nullptr): segInt(nSegInt) {}
- ~SinglePassNoder() override {}
- * Sets the SegmentIntersector to use with this noder.
- * A SegmentIntersector will normally add intersection nodes
- * to the input segment strings, but it may not - it may
- * simply record the presence of intersections.
- * However, some Noders may require that intersections be added.
- * @param newSegInt
- virtual void setSegmentIntersector(SegmentIntersector* newSegInt) {
- segInt = newSegInt;
- void computeNodes(std::vector<SegmentString*>* segStrings) override =0;
- * @return a Collection of SegmentStrings
- std::vector<SegmentString*>* getNodedSubstrings() const override =0;
+ SinglePassNoder(SegmentIntersector* nSegInt = nullptr): segInt(nSegInt) {}
+ ~SinglePassNoder() override {}
+ * Sets the SegmentIntersector to use with this noder.
+ * A SegmentIntersector will normally add intersection nodes
+ * to the input segment strings, but it may not - it may
+ * simply record the presence of intersections.
+ * However, some Noders may require that intersections be added.
+ * @param newSegInt
+ virtual void
+ setSegmentIntersector(SegmentIntersector* newSegInt)
+ segInt = newSegInt;
+ void computeNodes(std::vector<SegmentString*>* segStrings) override = 0;
+ * @return a Collection of SegmentStrings
+ std::vector<SegmentString*>* getNodedSubstrings() const override = 0;
diff --git a/include/geos/noding/snapround/HotPixel.h b/include/geos/noding/snapround/HotPixel.h
index e4b68e0..3d1296f 100644
--- a/include/geos/noding/snapround/HotPixel.h
+++ b/include/geos/noding/snapround/HotPixel.h
@@ -33,15 +33,15 @@
namespace geos {
- namespace geom {
- class Envelope;
+namespace geom {
+class Envelope;
+namespace noding {
namespace geos {
@@ -63,85 +63,85 @@ class GEOS_DLL HotPixel {
private:
- algorithm::LineIntersector& li;
- geom::Coordinate pt;
- const geom::Coordinate& originalPt;
- geom::Coordinate ptScaled;
- mutable geom::Coordinate p0Scaled;
- mutable geom::Coordinate p1Scaled;
- double minx;
- double maxx;
- double miny;
- double maxy;
- /** \brief
- * The corners of the hot pixel
- * In the order:
- * 1 0
- * 2 3
- std::vector<geom::Coordinate> corner;
- /// Owned by this class, constructed on demand
- mutable std::unique_ptr<geom::Envelope> safeEnv;
- void initCorners(const geom::Coordinate& pt);
- double scale(double val) const;
- void copyScaled(const geom::Coordinate& p,
- geom::Coordinate& pScaled) const;
- /** \brief
- * Tests whether the segment p0-p1 intersects the hot pixel
- * tolerance square.
- * Because the tolerance square point set is partially open (along the
- * top and right) the test needs to be more sophisticated than
- * simply checking for any intersection. However, it
- * can take advantage of the fact that because the hot pixel edges
- * do not lie on the coordinate grid. It is sufficient to check
- * if there is at least one of:
- * - a proper intersection with the segment and any hot pixel edge
- * - an intersection between the segment and both the left
- * and bottom edges
- * - an intersection between a segment endpoint and the hot
- * pixel coordinate
- * @param p0
- * @param p1
- * @return
- bool intersectsToleranceSquare(const geom::Coordinate& p0,
- const geom::Coordinate& p1) const;
- /** \brief
- * Test whether the given segment intersects
- * the closure of this hot pixel.
- * This is NOT the test used in the standard snap-rounding
- * algorithm, which uses the partially closed tolerance square
- * instead.
- * This routine is provided for testing purposes only.
- * @param p0 the start point of a line segment
- * @param p1 the end point of a line segment
- * @return <code>true</code> if the segment intersects the
- * closure of the pixel's tolerance square
- bool intersectsPixelClosure(const geom::Coordinate& p0,
- const geom::Coordinate& p1);
- bool intersectsScaled(const geom::Coordinate& p0,
+ algorithm::LineIntersector& li;
+ geom::Coordinate pt;
+ const geom::Coordinate& originalPt;
+ geom::Coordinate ptScaled;
+ mutable geom::Coordinate p0Scaled;
+ mutable geom::Coordinate p1Scaled;
+ double minx;
+ double maxx;
+ double miny;
+ double maxy;
+ /** \brief
+ * The corners of the hot pixel
+ * In the order:
+ * 1 0
+ * 2 3
+ std::vector<geom::Coordinate> corner;
+ /// Owned by this class, constructed on demand
+ mutable std::unique_ptr<geom::Envelope> safeEnv;
+ void initCorners(const geom::Coordinate& pt);
+ double scale(double val) const;
+ void copyScaled(const geom::Coordinate& p,
+ geom::Coordinate& pScaled) const;
+ /** \brief
+ * Tests whether the segment p0-p1 intersects the hot pixel
+ * tolerance square.
+ * Because the tolerance square point set is partially open (along the
+ * top and right) the test needs to be more sophisticated than
+ * simply checking for any intersection. However, it
+ * can take advantage of the fact that because the hot pixel edges
+ * do not lie on the coordinate grid. It is sufficient to check
+ * if there is at least one of:
+ * - a proper intersection with the segment and any hot pixel edge
+ * - an intersection between the segment and both the left
+ * and bottom edges
+ * - an intersection between a segment endpoint and the hot
+ * pixel coordinate
+ * @param p0
+ * @param p1
+ * @return
+ bool intersectsToleranceSquare(const geom::Coordinate& p0,
+ const geom::Coordinate& p1) const;
+ /** \brief
+ * Test whether the given segment intersects
+ * the closure of this hot pixel.
+ * This is NOT the test used in the standard snap-rounding
+ * algorithm, which uses the partially closed tolerance square
+ * instead.
+ * This routine is provided for testing purposes only.
+ * @param p0 the start point of a line segment
+ * @param p1 the end point of a line segment
+ * @return <code>true</code> if the segment intersects the
+ * closure of the pixel's tolerance square
+ bool intersectsPixelClosure(const geom::Coordinate& p0,
+ const geom::Coordinate& p1);
+ bool intersectsScaled(const geom::Coordinate& p0,
HotPixel(const HotPixel& other) = delete;
@@ -149,52 +149,56 @@ private:
public:
- * Creates a new hot pixel.
- * @param pt the coordinate at the centre of the pixel.
- * Will be kept by reference, so make sure to keep it alive.
- * @param scaleFact the scaleFactor determining the pixel size
- * @param li the intersector to use for testing intersection with
- * line segments
- HotPixel(const geom::Coordinate& pt,
- double scaleFact,
- algorithm::LineIntersector& li);
- /// \brief
- /// Return reference to original Coordinate
- /// (the one provided at construction time)
- const geom::Coordinate& getCoordinate() const { return originalPt; }
- /** \brief
- * Returns a "safe" envelope that is guaranteed to contain
- * the hot pixel. Keeps ownership of it.
- * The envelope returned will be larger than the exact envelope of the
- * pixel.
- const geom::Envelope& getSafeEnvelope() const;
- * Tests whether the line segment (p0-p1) intersects this hot pixel.
- * @param p0 the first coordinate of the line segment to test
- * @param p1 the second coordinate of the line segment to test
- * @return true if the line segment intersects this hot pixel
- bool intersects(const geom::Coordinate& p0,
- * Adds a new node (equal to the snap pt) to the specified segment
- * if the segment passes through the hot pixel
- * @param segStr
- * @param segIndex
- * @return true if a node was added to the segment
- bool addSnappedNode(NodedSegmentString& segStr, std::size_t segIndex);
+ * Creates a new hot pixel.
+ * @param pt the coordinate at the centre of the pixel.
+ * Will be kept by reference, so make sure to keep it alive.
+ * @param scaleFact the scaleFactor determining the pixel size
+ * @param li the intersector to use for testing intersection with
+ * line segments
+ HotPixel(const geom::Coordinate& pt,
+ double scaleFact,
+ algorithm::LineIntersector& li);
+ /// \brief
+ /// Return reference to original Coordinate
+ /// (the one provided at construction time)
+ getCoordinate() const
+ return originalPt;
+ /** \brief
+ * Returns a "safe" envelope that is guaranteed to contain
+ * the hot pixel. Keeps ownership of it.
+ * The envelope returned will be larger than the exact envelope of the
+ * pixel.
+ const geom::Envelope& getSafeEnvelope() const;
+ * Tests whether the line segment (p0-p1) intersects this hot pixel.
+ * @param p0 the first coordinate of the line segment to test
+ * @param p1 the second coordinate of the line segment to test
+ * @return true if the line segment intersects this hot pixel
+ bool intersects(const geom::Coordinate& p0,
+ * Adds a new node (equal to the snap pt) to the specified segment
+ * if the segment passes through the hot pixel
+ * @param segStr
+ * @param segIndex
+ * @return true if a node was added to the segment
+ bool addSnappedNode(NodedSegmentString& segStr, std::size_t segIndex);
diff --git a/include/geos/noding/snapround/HotPixel.inl b/include/geos/noding/snapround/HotPixel.inl
index 3ff4872..5f81788 100644
--- a/include/geos/noding/snapround/HotPixel.inl
+++ b/include/geos/noding/snapround/HotPixel.inl
@@ -7,7 +7,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -30,16 +30,16 @@ namespace snapround { // geos::noding::snapround
INLINE double
HotPixel::scale(double val) const
- // Math.round
- //return round(val*scaleFactor);
- return util::round(val*scaleFactor);
+ // Math.round
+ //return round(val*scaleFactor);
+ return util::round(val * scaleFactor);
INLINE void
HotPixel::copyScaled(const geom::Coordinate& p, geom::Coordinate& pScaled) const
- pScaled.x = scale(p.x);
- pScaled.y = scale(p.y);
+ pScaled.x = scale(p.x);
+ pScaled.y = scale(p.y);
} // namespace geos::noding::snapround
diff --git a/include/geos/noding/snapround/MCIndexPointSnapper.h b/include/geos/noding/snapround/MCIndexPointSnapper.h
index 2153617..15dbc30 100644
--- a/include/geos/noding/snapround/MCIndexPointSnapper.h
+++ b/include/geos/noding/snapround/MCIndexPointSnapper.h
@@ -26,15 +26,15 @@
namespace geos {
- namespace index {
- class SpatialIndex;
- namespace snapround {
- class HotPixel;
+namespace index {
+class SpatialIndex;
+namespace noding {
+namespace snapround {
+class HotPixel;
namespace geos {
@@ -51,34 +51,36 @@ class GEOS_DLL MCIndexPointSnapper {
public:
- MCIndexPointSnapper(index::SpatialIndex& nIndex)
- index(nIndex)
- * Snaps (nodes) all interacting segments to this hot pixel.
- * The hot pixel may represent a vertex of an edge,
- * in which case this routine uses the optimization
- * of not noding the vertex itself
- * @param hotPixel the hot pixel to snap to
- * @param parentEdge the edge containing the vertex,
- * if applicable, or <code>null</code>
- * @param vertexIndex the index of the vertex, if applicable, or -1
- * @return <code>true</code> if a node was added for this pixel
- bool snap(HotPixel& hotPixel, SegmentString* parentEdge,
- size_t vertexIndex);
- bool snap(HotPixel& hotPixel) {
- return snap(hotPixel, nullptr, 0);
+ MCIndexPointSnapper(index::SpatialIndex& nIndex)
+ index(nIndex)
+ * Snaps (nodes) all interacting segments to this hot pixel.
+ * The hot pixel may represent a vertex of an edge,
+ * in which case this routine uses the optimization
+ * of not noding the vertex itself
+ * @param hotPixel the hot pixel to snap to
+ * @param parentEdge the edge containing the vertex,
+ * if applicable, or <code>null</code>
+ * @param vertexIndex the index of the vertex, if applicable, or -1
+ * @return <code>true</code> if a node was added for this pixel
+ bool snap(HotPixel& hotPixel, SegmentString* parentEdge,
+ size_t vertexIndex);
+ bool
+ snap(HotPixel& hotPixel)
+ return snap(hotPixel, nullptr, 0);
private:
- index::SpatialIndex& index;
+ index::SpatialIndex& index;
MCIndexPointSnapper(const MCIndexPointSnapper& other) = delete;
diff --git a/include/geos/noding/snapround/MCIndexSnapRounder.h b/include/geos/noding/snapround/MCIndexSnapRounder.h
index 3f9cd03..e8da0d8 100644
--- a/include/geos/noding/snapround/MCIndexSnapRounder.h
+++ b/include/geos/noding/snapround/MCIndexSnapRounder.h
@@ -37,13 +37,13 @@
namespace geos {
- class MCIndexNoder;
+namespace noding {
+class MCIndexNoder;
namespace geos {
@@ -75,71 +75,73 @@ class GEOS_DLL MCIndexSnapRounder: public Noder { // implments Noder
public:
- MCIndexSnapRounder(const geom::PrecisionModel& nPm)
- pm(nPm),
- scaleFactor(nPm.getScale()),
- pointSnapper(nullptr)
- li.setPrecisionModel(&pm);
- std::vector<SegmentString*>* getNodedSubstrings() const override {
- return NodedSegmentString::getNodedSubstrings(*nodedSegStrings);
- void computeNodes(std::vector<SegmentString*>* segStrings) override;
- * Computes nodes introduced as a result of
- * snapping segments to vertices of other segments
- * @param edges the list of segment strings to snap together
- * NOTE: they *must* be instances of NodedSegmentString, or
- * an assertion will fail.
- void computeVertexSnaps(std::vector<SegmentString*>& edges);
+ MCIndexSnapRounder(const geom::PrecisionModel& nPm)
+ pm(nPm),
+ scaleFactor(nPm.getScale()),
+ pointSnapper(nullptr)
+ li.setPrecisionModel(&pm);
+ getNodedSubstrings() const override
+ return NodedSegmentString::getNodedSubstrings(*nodedSegStrings);
+ void computeNodes(std::vector<SegmentString*>* segStrings) override;
+ * Computes nodes introduced as a result of
+ * snapping segments to vertices of other segments
+ * @param edges the list of segment strings to snap together
+ * NOTE: they *must* be instances of NodedSegmentString, or
+ * an assertion will fail.
+ void computeVertexSnaps(std::vector<SegmentString*>& edges);
private:
- /// externally owned
- const geom::PrecisionModel& pm;
+ /// externally owned
+ const geom::PrecisionModel& pm;
- algorithm::LineIntersector li;
+ algorithm::LineIntersector li;
- std::vector<SegmentString*>* nodedSegStrings;
+ std::vector<SegmentString*>* nodedSegStrings;
- std::unique_ptr<MCIndexPointSnapper> pointSnapper;
+ std::unique_ptr<MCIndexPointSnapper> pointSnapper;
- void snapRound(MCIndexNoder& noder, std::vector<SegmentString*>* segStrings);
+ void snapRound(MCIndexNoder& noder, std::vector<SegmentString*>* segStrings);
- * Computes all interior intersections in the collection of SegmentStrings,
- * and push their Coordinate to the provided vector.
- * Does NOT node the segStrings.
- void findInteriorIntersections(MCIndexNoder& noder,
- std::vector<SegmentString*>* segStrings,
- std::vector<geom::Coordinate>& intersections);
+ * Computes all interior intersections in the collection of SegmentStrings,
+ * and push their Coordinate to the provided vector.
+ * Does NOT node the segStrings.
+ void findInteriorIntersections(MCIndexNoder& noder,
+ std::vector<SegmentString*>* segStrings,
+ std::vector<geom::Coordinate>& intersections);
- * Computes nodes introduced as a result of snapping
- * segments to snap points (hot pixels)
- void computeIntersectionSnaps(std::vector<geom::Coordinate>& snapPts);
+ * Computes nodes introduced as a result of snapping
+ * segments to snap points (hot pixels)
+ void computeIntersectionSnaps(std::vector<geom::Coordinate>& snapPts);
- * Performs a brute-force comparison of every segment in each {@link SegmentString}.
- * This has n^2 performance.
- void computeVertexSnaps(NodedSegmentString* e);
+ * Performs a brute-force comparison of every segment in each {@link SegmentString}.
+ * This has n^2 performance.
+ void computeVertexSnaps(NodedSegmentString* e);
- void checkCorrectness(std::vector<SegmentString*>& inputSegmentStrings);
+ void checkCorrectness(std::vector<SegmentString*>& inputSegmentStrings);
MCIndexSnapRounder(const MCIndexSnapRounder& other) = delete;
diff --git a/include/geos/noding/snapround/SimpleSnapRounder.h b/include/geos/noding/snapround/SimpleSnapRounder.h
index e145e84..121082b 100644
--- a/include/geos/noding/snapround/SimpleSnapRounder.h
+++ b/include/geos/noding/snapround/SimpleSnapRounder.h
@@ -32,19 +32,19 @@
namespace geos {
- namespace geom {
- //class PrecisionModel;
- class HotPixel;
+namespace geom {
+//class PrecisionModel;
+namespace noding {
+class HotPixel;
namespace geos {
@@ -74,65 +74,65 @@ class GEOS_DLL SimpleSnapRounder: public Noder { // implements NoderIface
public:
- SimpleSnapRounder(const geom::PrecisionModel& newPm);
+ SimpleSnapRounder(const geom::PrecisionModel& newPm);
- std::vector<SegmentString*>* getNodedSubstrings() const override;
+ std::vector<SegmentString*>* getNodedSubstrings() const override;
- void computeNodes(std::vector<SegmentString*>* inputSegmentStrings) override;
+ void computeNodes(std::vector<SegmentString*>* inputSegmentStrings) override;
- void add(const SegmentString* segStr);
+ void add(const SegmentString* segStr);
- * @param edges the list of segment strings to snap together.
- * Must be NodedSegmentString or an assertion will fail.
- void computeVertexSnaps(const std::vector<SegmentString*>& edges);
+ * @param edges the list of segment strings to snap together.
+ * Must be NodedSegmentString or an assertion will fail.
+ void computeVertexSnaps(const std::vector<SegmentString*>& edges);
private:
- void snapRound(std::vector<SegmentString*>* segStrings,
- * Computes all interior intersections in the vector
- * of SegmentString, and fill the given vector
- * with their Coordinates.
- * @param segStrings a vector of const Coordinates for the intersections
- * @param li the algorithm::LineIntersector to use
- * @param ret the vector to push intersection Coordinates to
- void findInteriorIntersections(std::vector<SegmentString*>& segStrings,
- algorithm::LineIntersector& li, std::vector<geom::Coordinate>& ret);
- /** \brief
- * Computes nodes introduced as a result of snapping segments to
- * snap points (hot pixels)
- * @param li
- void computeSnaps(const std::vector<SegmentString*>& segStrings,
- std::vector<geom::Coordinate>& snapPts);
- void computeSnaps(NodedSegmentString* ss, std::vector<geom::Coordinate>& snapPts);
- /** \brief
- * {@link SegmentString}.
- void computeVertexSnaps(NodedSegmentString* e0, NodedSegmentString* e1);
+ void snapRound(std::vector<SegmentString*>* segStrings,
+ * Computes all interior intersections in the vector
+ * of SegmentString, and fill the given vector
+ * with their Coordinates.
+ * @param segStrings a vector of const Coordinates for the intersections
+ * @param li the algorithm::LineIntersector to use
+ * @param ret the vector to push intersection Coordinates to
+ void findInteriorIntersections(std::vector<SegmentString*>& segStrings,
+ algorithm::LineIntersector& li, std::vector<geom::Coordinate>& ret);
+ /** \brief
+ * Computes nodes introduced as a result of snapping segments to
+ * snap points (hot pixels)
+ * @param li
+ void computeSnaps(const std::vector<SegmentString*>& segStrings,
+ std::vector<geom::Coordinate>& snapPts);
+ void computeSnaps(NodedSegmentString* ss, std::vector<geom::Coordinate>& snapPts);
+ /** \brief
+ * {@link SegmentString}.
+ void computeVertexSnaps(NodedSegmentString* e0, NodedSegmentString* e1);
SimpleSnapRounder(const SimpleSnapRounder& other) = delete;
diff --git a/include/geos/operation/GeometryGraphOperation.h b/include/geos/operation/GeometryGraphOperation.h
index fdc49e4..3ffd79e 100644
--- a/include/geos/operation/GeometryGraphOperation.h
+++ b/include/geos/operation/GeometryGraphOperation.h
@@ -32,16 +32,16 @@
namespace geos {
- class BoundaryNodeRule;
- namespace geom {
- class Geometry;
- class PrecisionModel;
- namespace geomgraph {
- class GeometryGraph;
+class BoundaryNodeRule;
+namespace geom {
+class Geometry;
+class PrecisionModel;
+namespace geomgraph {
+class GeometryGraph;
@@ -53,31 +53,31 @@ class GEOS_DLL GeometryGraphOperation {
public:
- GeometryGraphOperation(const geom::Geometry *g0,
- const geom::Geometry *g1);
+ GeometryGraphOperation(const geom::Geometry* g0,
+ const geom::Geometry* g1);
- const geom::Geometry *g1,
- const algorithm::BoundaryNodeRule& boundaryNodeRule);
+ const geom::Geometry* g1,
+ const algorithm::BoundaryNodeRule& boundaryNodeRule);
- GeometryGraphOperation(const geom::Geometry *g0);
+ GeometryGraphOperation(const geom::Geometry* g0);
- virtual ~GeometryGraphOperation();
+ virtual ~GeometryGraphOperation();
- const geom::Geometry* getArgGeometry(unsigned int i) const;
+ const geom::Geometry* getArgGeometry(unsigned int i) const;
protected:
- const geom::PrecisionModel* resultPrecisionModel;
+ const geom::PrecisionModel* resultPrecisionModel;
- /** \brief
- * The operation args into an array so they can be accessed by index
- std::vector<geomgraph::GeometryGraph*> arg;
+ /** \brief
+ * The operation args into an array so they can be accessed by index
+ std::vector<geomgraph::GeometryGraph*> arg;
- void setComputationPrecision(const geom::PrecisionModel* pm);
+ void setComputationPrecision(const geom::PrecisionModel* pm);
} // namespace geos.operation
diff --git a/include/geos/operation/IsSimpleOp.h b/include/geos/operation/IsSimpleOp.h
index ccc2bca..0af00d7 100644
--- a/include/geos/operation/IsSimpleOp.h
+++ b/include/geos/operation/IsSimpleOp.h
@@ -34,25 +34,25 @@
namespace geos {
- namespace geom {
- class LineString;
- class LinearRing;
- class MultiLineString;
- class MultiPoint;
- class Geometry;
- class Polygon;
- class GeometryCollection;
- struct CoordinateLessThen;
- namespace operation {
- class EndpointInfo;
+namespace geom {
+class LineString;
+class LinearRing;
+class MultiLineString;
+class MultiPoint;
+class Geometry;
+class Polygon;
+class GeometryCollection;
+struct CoordinateLessThen;
+namespace operation {
+class EndpointInfo;
@@ -93,127 +93,127 @@ namespace operation { // geos.operation
* @see algorithm::BoundaryNodeRule
-class GEOS_DLL IsSimpleOp
+class GEOS_DLL IsSimpleOp {
public:
- /** \brief
- * Creates a simplicity checker using the default
- * SFS Mod-2 Boundary Node Rule
- * @deprecated use IsSimpleOp(Geometry)
- IsSimpleOp();
- /** \brief
- * @param geom The geometry to test.
- * Will store a reference: keep it alive.
- IsSimpleOp(const geom::Geometry& geom);
- /** \brief
- * Creates a simplicity checker using a given
- * algorithm::BoundaryNodeRule
- * @param geom the geometry to test
- * @param boundaryNodeRule the rule to use.
- IsSimpleOp(const geom::Geometry& geom,
- * Tests whether the geometry is simple.
- * @return true if the geometry is simple
- bool isSimple();
- * Gets a coordinate for the location where the geometry
- * fails to be simple.
- * (i.e. where it has a non-boundary self-intersection).
- * {@link #isSimple} must be called before this method is called.
- * @return a coordinate for the location of the non-boundary
- * self-intersection. Ownership retained.
- * @return the null coordinate if the geometry is simple
- const geom::Coordinate* getNonSimpleLocation() const
- return nonSimpleLocation.get();
- * Reports whether a geom::LineString is simple.
- * @param geom the lineal geometry to test
- * @deprecated use isSimple()
- bool isSimple(const geom::LineString *geom);
- * Reports whether a geom::MultiLineString is simple.
- bool isSimple(const geom::MultiLineString *geom);
- * A MultiPoint is simple iff it has no repeated points
- bool isSimple(const geom::MultiPoint *mp);
- bool isSimpleLinearGeometry(const geom::Geometry *geom);
+ /** \brief
+ * Creates a simplicity checker using the default
+ * SFS Mod-2 Boundary Node Rule
+ * @deprecated use IsSimpleOp(Geometry)
+ IsSimpleOp();
+ /** \brief
+ * @param geom The geometry to test.
+ * Will store a reference: keep it alive.
+ IsSimpleOp(const geom::Geometry& geom);
+ /** \brief
+ * Creates a simplicity checker using a given
+ * algorithm::BoundaryNodeRule
+ * @param geom the geometry to test
+ * @param boundaryNodeRule the rule to use.
+ IsSimpleOp(const geom::Geometry& geom,
+ * Tests whether the geometry is simple.
+ * @return true if the geometry is simple
+ bool isSimple();
+ * Gets a coordinate for the location where the geometry
+ * fails to be simple.
+ * (i.e. where it has a non-boundary self-intersection).
+ * {@link #isSimple} must be called before this method is called.
+ * @return a coordinate for the location of the non-boundary
+ * self-intersection. Ownership retained.
+ * @return the null coordinate if the geometry is simple
+ getNonSimpleLocation() const
+ return nonSimpleLocation.get();
+ * Reports whether a geom::LineString is simple.
+ * @param geom the lineal geometry to test
+ * @deprecated use isSimple()
+ bool isSimple(const geom::LineString* geom);
+ * Reports whether a geom::MultiLineString is simple.
+ bool isSimple(const geom::MultiLineString* geom);
+ * A MultiPoint is simple iff it has no repeated points
+ bool isSimple(const geom::MultiPoint* mp);
+ bool isSimpleLinearGeometry(const geom::Geometry* geom);
private:
- * For all edges, check if there are any intersections which are
- * NOT at an endpoint.
- * The Geometry is not simple if there are intersections not at
- * endpoints.
- bool hasNonEndpointIntersection(geomgraph::GeometryGraph &graph);
- * Tests that no edge intersection is the endpoint of a closed line.
- * This ensures that closed lines are not touched at their endpoint,
- * which is an interior point according to the Mod-2 rule
- * To check this we compute the degree of each endpoint.
- * The degree of endpoints of closed lines
- * must be exactly 2.
- bool hasClosedEndpointIntersection(geomgraph::GeometryGraph &graph);
- bool computeSimple(const geom::Geometry *geom);
- bool isSimplePolygonal(const geom::Geometry *geom);
- bool isSimpleGeometryCollection(const geom::GeometryCollection *col);
- * Add an endpoint to the map, creating an entry for it if none exists
- void addEndpoint(std::map<const geom::Coordinate*, EndpointInfo*,
- geom::CoordinateLessThen>&endPoints,
- const geom::Coordinate *p, bool isClosed);
- bool isClosedEndpointsInInterior;
- bool isSimpleMultiPoint(const geom::MultiPoint& mp);
- const geom::Geometry* geom;
- std::unique_ptr<geom::Coordinate> nonSimpleLocation;
+ * For all edges, check if there are any intersections which are
+ * NOT at an endpoint.
+ * The Geometry is not simple if there are intersections not at
+ * endpoints.
+ bool hasNonEndpointIntersection(geomgraph::GeometryGraph& graph);
+ * Tests that no edge intersection is the endpoint of a closed line.
+ * This ensures that closed lines are not touched at their endpoint,
+ * which is an interior point according to the Mod-2 rule
+ * To check this we compute the degree of each endpoint.
+ * The degree of endpoints of closed lines
+ * must be exactly 2.
+ bool hasClosedEndpointIntersection(geomgraph::GeometryGraph& graph);
+ bool computeSimple(const geom::Geometry* geom);
+ bool isSimplePolygonal(const geom::Geometry* geom);
+ bool isSimpleGeometryCollection(const geom::GeometryCollection* col);
+ * Add an endpoint to the map, creating an entry for it if none exists
+ void addEndpoint(std::map<const geom::Coordinate*, EndpointInfo*,
+ geom::CoordinateLessThen>& endPoints,
+ const geom::Coordinate* p, bool isClosed);
+ bool isClosedEndpointsInInterior;
+ bool isSimpleMultiPoint(const geom::MultiPoint& mp);
+ const geom::Geometry* geom;
+ std::unique_ptr<geom::Coordinate> nonSimpleLocation;
diff --git a/include/geos/operation/buffer/BufferBuilder.h b/include/geos/operation/buffer/BufferBuilder.h
index 2f9480d..43e3433 100644
--- a/include/geos/operation/buffer/BufferBuilder.h
+++ b/include/geos/operation/buffer/BufferBuilder.h
@@ -36,32 +36,32 @@
namespace geos {
- namespace geom {
- class Geometry;
- class GeometryFactory;
- class Noder;
- class IntersectionAdder;
- class Edge;
- class Label;
- class PlanarGraph;
- namespace buffer {
- class BufferSubgraph;
- namespace overlay {
- class PolygonBuilder;
+namespace geom {
+class Geometry;
+class GeometryFactory;
+namespace noding {
+class Noder;
+class IntersectionAdder;
+class Edge;
+class Label;
+class PlanarGraph;
+namespace buffer {
+class BufferSubgraph;
+namespace overlay {
+class PolygonBuilder;
namespace geos {
@@ -88,59 +88,65 @@ namespace buffer { // geos.operation.buffer
class GEOS_DLL BufferBuilder {
public:
- * Creates a new BufferBuilder
- * @param nBufParams buffer parameters, this object will
- * keep a reference to the passed parameters
- * so caller must make sure the object is
- * kept alive for the whole lifetime of
- * the buffer builder.
- BufferBuilder(const BufferParameters& nBufParams)
- bufParams(nBufParams),
- workingPrecisionModel(nullptr),
- li(nullptr),
- intersectionAdder(nullptr),
- workingNoder(nullptr),
- geomFact(nullptr),
- edgeList()
- ~BufferBuilder();
- * Sets the precision model to use during the curve computation
- * and noding,
- * if it is different to the precision model of the Geometry.
- * If the precision model is less than the precision of the
- * Geometry precision model,
- * the Geometry must have previously been rounded to that precision.
- * @param pm the precision model to use
- void setWorkingPrecisionModel(const geom::PrecisionModel *pm) {
- workingPrecisionModel=pm;
- * Sets the {@link noding::Noder} to use during noding.
- * This allows choosing fast but non-robust noding, or slower
- * but robust noding.
- * @param noder the noder to use
- void setNoder(noding::Noder* newNoder) { workingNoder = newNoder; }
- geom::Geometry* buffer(const geom::Geometry *g, double distance);
- // throw (GEOSException);
+ * Creates a new BufferBuilder
+ * @param nBufParams buffer parameters, this object will
+ * keep a reference to the passed parameters
+ * so caller must make sure the object is
+ * kept alive for the whole lifetime of
+ * the buffer builder.
+ BufferBuilder(const BufferParameters& nBufParams)
+ bufParams(nBufParams),
+ workingPrecisionModel(nullptr),
+ li(nullptr),
+ intersectionAdder(nullptr),
+ workingNoder(nullptr),
+ geomFact(nullptr),
+ edgeList()
+ ~BufferBuilder();
+ * Sets the precision model to use during the curve computation
+ * and noding,
+ * if it is different to the precision model of the Geometry.
+ * If the precision model is less than the precision of the
+ * Geometry precision model,
+ * the Geometry must have previously been rounded to that precision.
+ * @param pm the precision model to use
+ void
+ setWorkingPrecisionModel(const geom::PrecisionModel* pm)
+ workingPrecisionModel = pm;
+ * Sets the {@link noding::Noder} to use during noding.
+ * This allows choosing fast but non-robust noding, or slower
+ * but robust noding.
+ * @param noder the noder to use
+ void
+ setNoder(noding::Noder* newNoder)
+ workingNoder = newNoder;
+ geom::Geometry* buffer(const geom::Geometry* g, double distance);
+ // throw (GEOSException);
* Generates offset curve for linear geometry.
- * @param g non-areal geometry object
+ * @param g non-areal geometry object
* @param distance width of offset
* @param leftSide controls on which side of the input geometry
* offset curve is generated.
@@ -154,84 +160,84 @@ public:
* areal geometries only, is ignored by this routine.
* @note Not in JTS: this is a GEOS extension
- geom::Geometry* bufferLineSingleSided( const geom::Geometry* g,
- double distance, bool leftSide ) ;
+ geom::Geometry* bufferLineSingleSided(const geom::Geometry* g,
+ double distance, bool leftSide) ;
private:
- * Compute the change in depth as an edge is crossed from R to L
- static int depthDelta(const geomgraph::Label& label);
- const BufferParameters& bufParams;
- const geom::PrecisionModel* workingPrecisionModel;
- algorithm::LineIntersector* li;
- noding::IntersectionAdder* intersectionAdder;
- noding::Noder* workingNoder;
- const geom::GeometryFactory* geomFact;
- geomgraph::EdgeList edgeList;
- std::vector<geomgraph::Label *> newLabels;
- void computeNodedEdges(std::vector<noding::SegmentString*>& bufSegStr,
- const geom::PrecisionModel *precisionModel);
- // throw(GEOSException);
- * Inserted edges are checked to see if an identical edge already
- * exists.
- * If so, the edge is not inserted, but its label is merged
- * with the existing edge.
- * The function takes responsability of releasing the Edge parameter
- * memory when appropriate.
- void insertUniqueEdge(geomgraph::Edge *e);
- void createSubgraphs(geomgraph::PlanarGraph *graph,
- std::vector<BufferSubgraph*>& list);
- * Completes the building of the input subgraphs by
- * depth-labelling them,
- * and adds them to the PolygonBuilder.
- * The subgraph list must be sorted in rightmost-coordinate order.
- * @param subgraphList the subgraphs to build
- * @param polyBuilder the PolygonBuilder which will build
- * the final polygons
- void buildSubgraphs(const std::vector<BufferSubgraph*>& subgraphList,
- overlay::PolygonBuilder& polyBuilder);
- /// \brief
- /// Return the externally-set noding::Noder OR a newly created
- /// one using the given precisionModel.
- /// NOTE: if an externally-set noding::Noder is available no
- /// check is performed to ensure it will use the
- /// given PrecisionModel
- noding::Noder* getNoder(const geom::PrecisionModel* precisionModel);
- * Gets the standard result for an empty buffer.
- * Since buffer always returns a polygonal result,
- * this is chosen to be an empty polygon.
- * @return the empty result geometry, transferring ownership to caller.
- geom::Geometry* createEmptyResultGeometry() const;
+ * Compute the change in depth as an edge is crossed from R to L
+ static int depthDelta(const geomgraph::Label& label);
+ const BufferParameters& bufParams;
+ const geom::PrecisionModel* workingPrecisionModel;
+ noding::IntersectionAdder* intersectionAdder;
+ noding::Noder* workingNoder;
+ const geom::GeometryFactory* geomFact;
+ geomgraph::EdgeList edgeList;
+ std::vector<geomgraph::Label*> newLabels;
+ void computeNodedEdges(std::vector<noding::SegmentString*>& bufSegStr,
+ const geom::PrecisionModel* precisionModel);
+ // throw(GEOSException);
+ * Inserted edges are checked to see if an identical edge already
+ * exists.
+ * If so, the edge is not inserted, but its label is merged
+ * with the existing edge.
+ * The function takes responsability of releasing the Edge parameter
+ * memory when appropriate.
+ void insertUniqueEdge(geomgraph::Edge* e);
+ void createSubgraphs(geomgraph::PlanarGraph* graph,
+ std::vector<BufferSubgraph*>& list);
+ * Completes the building of the input subgraphs by
+ * depth-labelling them,
+ * and adds them to the PolygonBuilder.
+ * The subgraph list must be sorted in rightmost-coordinate order.
+ * @param subgraphList the subgraphs to build
+ * @param polyBuilder the PolygonBuilder which will build
+ * the final polygons
+ void buildSubgraphs(const std::vector<BufferSubgraph*>& subgraphList,
+ overlay::PolygonBuilder& polyBuilder);
+ /// \brief
+ /// Return the externally-set noding::Noder OR a newly created
+ /// one using the given precisionModel.
+ /// NOTE: if an externally-set noding::Noder is available no
+ /// check is performed to ensure it will use the
+ /// given PrecisionModel
+ noding::Noder* getNoder(const geom::PrecisionModel* precisionModel);
+ * Gets the standard result for an empty buffer.
+ * Since buffer always returns a polygonal result,
+ * this is chosen to be an empty polygon.
+ * @return the empty result geometry, transferring ownership to caller.
+ geom::Geometry* createEmptyResultGeometry() const;
BufferBuilder(const BufferBuilder& other) = delete;
diff --git a/include/geos/operation/buffer/BufferInputLineSimplifier.h b/include/geos/operation/buffer/BufferInputLineSimplifier.h
index 89d128d..7d5f7d4 100644
--- a/include/geos/operation/buffer/BufferInputLineSimplifier.h
+++ b/include/geos/operation/buffer/BufferInputLineSimplifier.h
@@ -27,10 +27,10 @@
namespace geos {
- namespace geom {
- class CoordinateSequence;
+namespace geom {
+class CoordinateSequence;
namespace geos {
@@ -69,106 +69,105 @@ namespace buffer { // geos.operation.buffer
* @author Martin Davis
-class BufferInputLineSimplifier
+class BufferInputLineSimplifier {
public:
- * Simplify the input coordinate list.
- * If the distance tolerance is positive,
- * concavities on the LEFT side of the line are simplified.
- * If the supplied distance tolerance is negative,
- * concavities on the RIGHT side of the line are simplified.
- * @param inputLine the coordinate sequence to simplify
- * @param distanceTol simplification distance tolerance to use
- * @return a simplified version of the coordinate sequence
- static std::unique_ptr<geom::CoordinateSequence> simplify(
- const geom::CoordinateSequence& inputLine, double distanceTol);
- BufferInputLineSimplifier(const geom::CoordinateSequence& input);
- * @return the simplified coordinate list
- std::unique_ptr<geom::CoordinateSequence> simplify(double distanceTol);
+ * Simplify the input coordinate list.
+ * If the distance tolerance is positive,
+ * concavities on the LEFT side of the line are simplified.
+ * If the supplied distance tolerance is negative,
+ * concavities on the RIGHT side of the line are simplified.
+ * @param inputLine the coordinate sequence to simplify
+ * @param distanceTol simplification distance tolerance to use
+ * @return a simplified version of the coordinate sequence
+ static std::unique_ptr<geom::CoordinateSequence> simplify(
+ const geom::CoordinateSequence& inputLine, double distanceTol);
+ BufferInputLineSimplifier(const geom::CoordinateSequence& input);
+ * @return the simplified coordinate list
+ std::unique_ptr<geom::CoordinateSequence> simplify(double distanceTol);
private:
- * Uses a sliding window containing 3 vertices to detect shallow angles
- * in which the middle vertex can be deleted, since it does not
- * affect the shape of the resulting buffer in a significant way.
- * @return
- bool deleteShallowConcavities();
- * Finds the next non-deleted index,
- * or the end of the point array if none
- * @param index
- * @return the next non-deleted index, if any
- * @return inputLine.size() if there are no more non-deleted indices
- size_t findNextNonDeletedIndex(size_t index) const;
- std::unique_ptr<geom::CoordinateSequence> collapseLine() const;
- bool isDeletable(size_t i0, size_t i1, size_t i2, double distanceTol) const;
- bool isShallowConcavity(const geom::Coordinate& p0,
- const geom::Coordinate& p1,
- const geom::Coordinate& p2,
- double distanceTol) const;
- * Checks for shallowness over a sample of points in the given section.
- * This helps prevents the siplification from incrementally
- * "skipping" over points which are in fact non-shallow.
- * @param p0 start coordinate of section
- * @param p2 end coordinate of section
- * @param i0 start index of section
- * @param i2 end index of section
- * @param distanceTol distance tolerance
- * @return
- bool isShallowSampled(const geom::Coordinate& p0,
- size_t i0, size_t i2, double distanceTol) const;
- bool isShallow(const geom::Coordinate& p0,
- bool isConcave(const geom::Coordinate& p0,
- const geom::Coordinate& p2) const;
- static const int NUM_PTS_TO_CHECK = 10;
- static const int INIT = 0;
- static const int DELETE = 1;
- static const int KEEP = 1;
- const geom::CoordinateSequence& inputLine;
- double distanceTol;
- std::vector<int> isDeleted;
- int angleOrientation;
+ * Uses a sliding window containing 3 vertices to detect shallow angles
+ * in which the middle vertex can be deleted, since it does not
+ * affect the shape of the resulting buffer in a significant way.
+ * @return
+ bool deleteShallowConcavities();
+ * Finds the next non-deleted index,
+ * or the end of the point array if none
+ * @param index
+ * @return the next non-deleted index, if any
+ * @return inputLine.size() if there are no more non-deleted indices
+ size_t findNextNonDeletedIndex(size_t index) const;
+ std::unique_ptr<geom::CoordinateSequence> collapseLine() const;
+ bool isDeletable(size_t i0, size_t i1, size_t i2, double distanceTol) const;
+ bool isShallowConcavity(const geom::Coordinate& p0,
+ const geom::Coordinate& p1,
+ const geom::Coordinate& p2,
+ double distanceTol) const;
+ * Checks for shallowness over a sample of points in the given section.
+ * This helps prevents the siplification from incrementally
+ * "skipping" over points which are in fact non-shallow.
+ * @param p0 start coordinate of section
+ * @param p2 end coordinate of section
+ * @param i0 start index of section
+ * @param i2 end index of section
+ * @param distanceTol distance tolerance
+ * @return
+ bool isShallowSampled(const geom::Coordinate& p0,
+ size_t i0, size_t i2, double distanceTol) const;
+ bool isShallow(const geom::Coordinate& p0,
+ bool isConcave(const geom::Coordinate& p0,
+ const geom::Coordinate& p2) const;
+ static const int NUM_PTS_TO_CHECK = 10;
+ static const int INIT = 0;
+ static const int DELETE = 1;
+ static const int KEEP = 1;
+ const geom::CoordinateSequence& inputLine;
+ double distanceTol;
+ std::vector<int> isDeleted;
+ int angleOrientation;
BufferInputLineSimplifier(const BufferInputLineSimplifier& other) = delete;
diff --git a/include/geos/operation/buffer/BufferOp.h b/include/geos/operation/buffer/BufferOp.h
index eb5b1c9..f7c0111 100644
--- a/include/geos/operation/buffer/BufferOp.h
+++ b/include/geos/operation/buffer/BufferOp.h
@@ -33,10 +33,10 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
namespace geos {
@@ -80,166 +80,166 @@ class GEOS_DLL BufferOp {
private:
- * A number of digits of precision which leaves some computational "headroom"
- * for floating point operations.
- * This value should be less than the decimal precision of double-precision values (16).
- static const int MAX_PRECISION_DIGITS = 12;
+ * A number of digits of precision which leaves some computational "headroom"
+ * for floating point operations.
+ * This value should be less than the decimal precision of double-precision values (16).
+ static const int MAX_PRECISION_DIGITS = 12;
- * Compute a reasonable scale factor to limit the precision of
- * a given combination of Geometry and buffer distance.
- * The scale factor is based on a heuristic.
- * @param g the Geometry being buffered
- * @param distance the buffer distance
- * @param maxPrecisionDigits the mzx # of digits that should be
- * allowed by the precision determined by the
- * computed scale factor
- * @return a scale factor that allows a reasonable amount of
- * precision for the buffer computation
- static double precisionScaleFactor(const geom::Geometry *g,
- double distance, int maxPrecisionDigits);
+ * Compute a reasonable scale factor to limit the precision of
+ * a given combination of Geometry and buffer distance.
+ * The scale factor is based on a heuristic.
+ * @param g the Geometry being buffered
+ * @param distance the buffer distance
+ * @param maxPrecisionDigits the mzx # of digits that should be
+ * allowed by the precision determined by the
+ * computed scale factor
+ * @return a scale factor that allows a reasonable amount of
+ * precision for the buffer computation
+ static double precisionScaleFactor(const geom::Geometry* g,
+ double distance, int maxPrecisionDigits);
- const geom::Geometry *argGeom;
+ const geom::Geometry* argGeom;
- util::TopologyException saveException;
+ util::TopologyException saveException;
- double distance;
+ double distance;
- //int quadrantSegments;
- //int endCapStyle;
- BufferParameters bufParams;
+ //int quadrantSegments;
+ //int endCapStyle;
+ BufferParameters bufParams;
- geom::Geometry* resultGeometry;
+ geom::Geometry* resultGeometry;
- void computeGeometry();
+ void computeGeometry();
- void bufferOriginalPrecision();
+ void bufferOriginalPrecision();
- void bufferReducedPrecision(int precisionDigits);
+ void bufferReducedPrecision(int precisionDigits);
- void bufferReducedPrecision();
+ void bufferReducedPrecision();
- void bufferFixedPrecision(const geom::PrecisionModel& fixedPM);
+ void bufferFixedPrecision(const geom::PrecisionModel& fixedPM);
public:
- enum {
- /// Specifies a round line buffer end cap style.
- /// @deprecated use BufferParameters
- CAP_ROUND = BufferParameters::CAP_ROUND,
- /// Specifies a butt (or flat) line buffer end cap style.
- CAP_BUTT = BufferParameters::CAP_FLAT,
- /// Specifies a square line buffer end cap style.
- CAP_SQUARE = BufferParameters::CAP_SQUARE
- * Computes the buffer for a geometry for a given buffer distance
- * and accuracy of approximation.
- * @param g the geometry to buffer
- * @param quadrantSegments the number of segments used to
- * approximate a quarter circle
- * @return the buffer of the input geometry
- static geom::Geometry* bufferOp(const geom::Geometry *g,
- double distance,
- int quadrantSegments=
- BufferParameters::DEFAULT_QUADRANT_SEGMENTS,
- int endCapStyle=BufferParameters::CAP_ROUND);
- * Initializes a buffer computation for the given geometry
- BufferOp(const geom::Geometry *g)
- argGeom(g),
- bufParams(),
- resultGeometry(nullptr)
- * with the given set of parameters
- * @param params the buffer parameters to use. This class will
- * copy it to private memory.
- BufferOp(const geom::Geometry* g, const BufferParameters& params)
- argGeom(g),
- bufParams(params),
- * Specifies the end cap style of the generated buffer.
- * The styles supported are CAP_ROUND, CAP_BUTT, and CAP_SQUARE.
- * The default is CAP_ROUND.
- * @param endCapStyle the end cap style to specify
- inline void setEndCapStyle(int nEndCapStyle);
- inline void setQuadrantSegments(int nQuadrantSegments);
- * Sets whether the computed buffer should be single-sided.
- * A single-sided buffer is constructed on only one side
- * of each input line.
- * The side used is determined by the sign of the buffer distance:
- * - a positive distance indicates the left-hand side
- * - a negative distance indicates the right-hand side
- * The single-sided buffer of point geometries is
- * the same as the regular buffer.
- * The End Cap Style for single-sided buffers is
- * always ignored,
- * and forced to the equivalent of <tt>CAP_FLAT</tt>.
- * @param isSingleSided true if a single-sided buffer
- * should be constructed
- inline void setSingleSided(bool isSingleSided);
- * Returns the buffer computed for a geometry for a given buffer
- * distance.
- geom::Geometry* getResultGeometry(double nDistance);
+ enum {
+ /// Specifies a round line buffer end cap style.
+ /// @deprecated use BufferParameters
+ CAP_ROUND = BufferParameters::CAP_ROUND,
+ /// Specifies a butt (or flat) line buffer end cap style.
+ CAP_BUTT = BufferParameters::CAP_FLAT,
+ /// Specifies a square line buffer end cap style.
+ CAP_SQUARE = BufferParameters::CAP_SQUARE
+ * Computes the buffer for a geometry for a given buffer distance
+ * and accuracy of approximation.
+ * @param g the geometry to buffer
+ * @param quadrantSegments the number of segments used to
+ * approximate a quarter circle
+ * @return the buffer of the input geometry
+ static geom::Geometry* bufferOp(const geom::Geometry* g,
+ double distance,
+ int quadrantSegments =
+ BufferParameters::DEFAULT_QUADRANT_SEGMENTS,
+ int endCapStyle = BufferParameters::CAP_ROUND);
+ * Initializes a buffer computation for the given geometry
+ BufferOp(const geom::Geometry* g)
+ argGeom(g),
+ bufParams(),
+ resultGeometry(nullptr)
+ * with the given set of parameters
+ * @param params the buffer parameters to use. This class will
+ * copy it to private memory.
+ BufferOp(const geom::Geometry* g, const BufferParameters& params)
+ argGeom(g),
+ bufParams(params),
+ * Specifies the end cap style of the generated buffer.
+ * The styles supported are CAP_ROUND, CAP_BUTT, and CAP_SQUARE.
+ * The default is CAP_ROUND.
+ * @param endCapStyle the end cap style to specify
+ inline void setEndCapStyle(int nEndCapStyle);
+ inline void setQuadrantSegments(int nQuadrantSegments);
+ * Sets whether the computed buffer should be single-sided.
+ * A single-sided buffer is constructed on only one side
+ * of each input line.
+ * The side used is determined by the sign of the buffer distance:
+ * - a positive distance indicates the left-hand side
+ * - a negative distance indicates the right-hand side
+ * The single-sided buffer of point geometries is
+ * the same as the regular buffer.
+ * The End Cap Style for single-sided buffers is
+ * always ignored,
+ * and forced to the equivalent of <tt>CAP_FLAT</tt>.
+ * @param isSingleSided true if a single-sided buffer
+ * should be constructed
+ inline void setSingleSided(bool isSingleSided);
+ * Returns the buffer computed for a geometry for a given buffer
+ * distance.
+ geom::Geometry* getResultGeometry(double nDistance);
@@ -247,19 +247,19 @@ public:
void
BufferOp::setQuadrantSegments(int q)
- bufParams.setQuadrantSegments(q);
+ bufParams.setQuadrantSegments(q);
void
BufferOp::setEndCapStyle(int s)
- bufParams.setEndCapStyle((BufferParameters::EndCapStyle)s);
+ bufParams.setEndCapStyle((BufferParameters::EndCapStyle)s);
void
BufferOp::setSingleSided(bool isSingleSided)
- bufParams.setSingleSided(isSingleSided);
+ bufParams.setSingleSided(isSingleSided);
} // namespace geos::operation::buffer
diff --git a/include/geos/operation/buffer/BufferParameters.h b/include/geos/operation/buffer/BufferParameters.h
index d80a367..6592683 100644
--- a/include/geos/operation/buffer/BufferParameters.h
+++ b/include/geos/operation/buffer/BufferParameters.h
@@ -34,15 +34,15 @@
namespace geos {
- namespace geom {
- class OffsetCurveVertexList;
+namespace geom {
+namespace buffer {
+class OffsetCurveVertexList;
namespace geos {
@@ -54,241 +54,262 @@ namespace buffer { // geos.operation.buffer
* describe how a buffer should be constructed.
-class GEOS_DLL BufferParameters
+class GEOS_DLL BufferParameters {
public:
- /// End cap styles
- enum EndCapStyle {
- CAP_ROUND=1,
- /// Specifies a flat line buffer end cap style.
- CAP_FLAT=2,
- CAP_SQUARE=3
- /// Join styles
- enum JoinStyle {
- /// Specifies a round join style.
- JOIN_ROUND=1,
- /// Specifies a mitre join style.
- JOIN_MITRE=2,
- /// Specifies a bevel join style.
- JOIN_BEVEL=3
- /// \brief
- /// The default number of facets into which to divide a fillet
- /// of 90 degrees.
- /// A value of 8 gives less than 2% max error in the buffer distance.
- /// For a max error of < 1%, use QS = 12.
- /// For a max error of < 0.1%, use QS = 18.
- static const int DEFAULT_QUADRANT_SEGMENTS = 8;
- /// The default mitre limit
- /// Allows fairly pointy mitres.
- static const double DEFAULT_MITRE_LIMIT; // 5.0 (in .cpp file)
- /// Creates a default set of parameters
- BufferParameters();
- /// Creates a set of parameters with the given quadrantSegments value.
- /// @param quadrantSegments the number of quadrant segments to use
- BufferParameters(int quadrantSegments);
- /// \brief
- /// given quadrantSegments and endCapStyle values.
- /// @param endCapStyle the end cap style to use
- BufferParameters(int quadrantSegments, EndCapStyle endCapStyle);
- /// \brief
- /// given parameter values.
- /// @param joinStyle the join style to use
- /// @param mitreLimit the mitre limit to use
- BufferParameters(int quadrantSegments, EndCapStyle endCapStyle,
- JoinStyle joinStyle, double mitreLimit);
- /// Gets the number of quadrant segments which will be used
- /// @return the number of quadrant segments
- int getQuadrantSegments() const { return quadrantSegments; }
- /// \brief
- /// Sets the number of line segments used to approximate
- /// an angle fillet.
- /// - If <tt>quadSegs</tt> >= 1, joins are round,
- /// and <tt>quadSegs</tt> indicates the number of
- /// segments to use to approximate a quarter-circle.
- /// - If <tt>quadSegs</tt> = 0, joins are bevelled (flat)
- /// - If <tt>quadSegs</tt> < 0, joins are mitred, and the value of qs
- /// indicates the mitre ration limit as
- /// <pre>
- /// mitreLimit = |<tt>quadSegs</tt>|
- /// </pre>
- /// For round joins, <tt>quadSegs</tt> determines the maximum
- /// error in the approximation to the true buffer curve.
- /// The default value of 8 gives less than 2% max error in the
- /// buffer distance.
- /// The error is always less than the buffer distance
- /// (in other words, the computed buffer curve is always inside
- /// the true curve).
- /// @param quadrantSegments the number of segments in a
- /// fillet for a quadrant
- void setQuadrantSegments(int quadSegs);
- /// \brief
- /// Computes the maximum distance error due to a given level
- /// of approximation to a true arc.
- /// @param quadSegs the number of segments used to approximate
- /// a quarter-circle
- /// @return the error of approximation
- static double bufferDistanceError(int quadSegs);
- /// Gets the end cap style.
- /// @return the end cap style
- EndCapStyle getEndCapStyle() const { return endCapStyle; }
- /// Specifies the end cap style of the generated buffer.
- /// The styles supported are CAP_ROUND, CAP_BUTT,
- /// and CAP_SQUARE.
- /// The default is CAP_ROUND.
- /// @param style the end cap style to specify
- void setEndCapStyle(EndCapStyle style)
- endCapStyle = style;
- /// Gets the join style.
- /// @return the join style
- JoinStyle getJoinStyle() const { return joinStyle; }
- /// \brief
- /// Sets the join style for outside (reflex) corners between
- /// line segments.
- /// Allowable values are JOIN_ROUND (which is the default),
- /// JOIN_MITRE and JOIN_BEVEL.
- /// @param style the code for the join style
- void setJoinStyle(JoinStyle style)
- joinStyle = style;
- /// Gets the mitre ratio limit.
- /// @return the limit value
- double getMitreLimit() const { return mitreLimit; }
- /// Sets the limit on the mitre ratio used for very sharp corners.
- /// The mitre ratio is the ratio of the distance from the corner
- /// to the end of the mitred offset corner.
- /// When two line segments meet at a sharp angle,
- /// a miter join will extend far beyond the original geometry.
- /// (and in the extreme case will be infinitely far.)
- /// To prevent unreasonable geometry, the mitre limit
- /// allows controlling the maximum length of the join corner.
- /// Corners with a ratio which exceed the limit will be beveled.
- /// @param limit the mitre ratio limit
- void setMitreLimit(double limit)
- mitreLimit = limit;
- * A single-sided buffer is constructed on only one side of each input line.
- * always ignored,
- * @param isSingleSided true if a single-sided buffer should be constructed
- void setSingleSided(bool p_isSingleSided)
- _isSingleSided = p_isSingleSided;
- * Tests whether the buffer is to be generated on a single side only.
- * @return true if the generated buffer is to be single-sided
- bool isSingleSided() const {
- return _isSingleSided;
+ /// End cap styles
+ enum EndCapStyle {
+ CAP_ROUND = 1,
+ /// Specifies a flat line buffer end cap style.
+ CAP_FLAT = 2,
+ CAP_SQUARE = 3
+ /// Join styles
+ enum JoinStyle {
+ /// Specifies a round join style.
+ JOIN_ROUND = 1,
+ /// Specifies a mitre join style.
+ JOIN_MITRE = 2,
+ /// Specifies a bevel join style.
+ JOIN_BEVEL = 3
+ /// \brief
+ /// The default number of facets into which to divide a fillet
+ /// of 90 degrees.
+ /// A value of 8 gives less than 2% max error in the buffer distance.
+ /// For a max error of < 1%, use QS = 12.
+ /// For a max error of < 0.1%, use QS = 18.
+ static const int DEFAULT_QUADRANT_SEGMENTS = 8;
+ /// The default mitre limit
+ /// Allows fairly pointy mitres.
+ static const double DEFAULT_MITRE_LIMIT; // 5.0 (in .cpp file)
+ /// Creates a default set of parameters
+ BufferParameters();
+ /// Creates a set of parameters with the given quadrantSegments value.
+ /// @param quadrantSegments the number of quadrant segments to use
+ BufferParameters(int quadrantSegments);
+ /// \brief
+ /// given quadrantSegments and endCapStyle values.
+ /// @param endCapStyle the end cap style to use
+ BufferParameters(int quadrantSegments, EndCapStyle endCapStyle);
+ /// \brief
+ /// given parameter values.
+ /// @param joinStyle the join style to use
+ /// @param mitreLimit the mitre limit to use
+ BufferParameters(int quadrantSegments, EndCapStyle endCapStyle,
+ JoinStyle joinStyle, double mitreLimit);
+ /// Gets the number of quadrant segments which will be used
+ /// @return the number of quadrant segments
+ int
+ getQuadrantSegments() const
+ return quadrantSegments;
+ /// \brief
+ /// Sets the number of line segments used to approximate
+ /// an angle fillet.
+ /// - If <tt>quadSegs</tt> >= 1, joins are round,
+ /// and <tt>quadSegs</tt> indicates the number of
+ /// segments to use to approximate a quarter-circle.
+ /// - If <tt>quadSegs</tt> = 0, joins are bevelled (flat)
+ /// - If <tt>quadSegs</tt> < 0, joins are mitred, and the value of qs
+ /// indicates the mitre ration limit as
+ /// <pre>
+ /// mitreLimit = |<tt>quadSegs</tt>|
+ /// </pre>
+ /// For round joins, <tt>quadSegs</tt> determines the maximum
+ /// error in the approximation to the true buffer curve.
+ /// The default value of 8 gives less than 2% max error in the
+ /// buffer distance.
+ /// The error is always less than the buffer distance
+ /// (in other words, the computed buffer curve is always inside
+ /// the true curve).
+ /// @param quadrantSegments the number of segments in a
+ /// fillet for a quadrant
+ void setQuadrantSegments(int quadSegs);
+ /// \brief
+ /// Computes the maximum distance error due to a given level
+ /// of approximation to a true arc.
+ /// @param quadSegs the number of segments used to approximate
+ /// a quarter-circle
+ /// @return the error of approximation
+ static double bufferDistanceError(int quadSegs);
+ /// Gets the end cap style.
+ /// @return the end cap style
+ EndCapStyle
+ getEndCapStyle() const
+ return endCapStyle;
+ /// Specifies the end cap style of the generated buffer.
+ /// The styles supported are CAP_ROUND, CAP_BUTT,
+ /// and CAP_SQUARE.
+ /// The default is CAP_ROUND.
+ /// @param style the end cap style to specify
+ void
+ setEndCapStyle(EndCapStyle style)
+ endCapStyle = style;
+ /// Gets the join style.
+ /// @return the join style
+ JoinStyle
+ getJoinStyle() const
+ return joinStyle;
+ /// \brief
+ /// Sets the join style for outside (reflex) corners between
+ /// line segments.
+ /// Allowable values are JOIN_ROUND (which is the default),
+ /// JOIN_MITRE and JOIN_BEVEL.
+ /// @param style the code for the join style
+ void
+ setJoinStyle(JoinStyle style)
+ joinStyle = style;
+ /// Gets the mitre ratio limit.
+ /// @return the limit value
+ double
+ getMitreLimit() const
+ return mitreLimit;
+ /// Sets the limit on the mitre ratio used for very sharp corners.
+ /// The mitre ratio is the ratio of the distance from the corner
+ /// to the end of the mitred offset corner.
+ /// When two line segments meet at a sharp angle,
+ /// a miter join will extend far beyond the original geometry.
+ /// (and in the extreme case will be infinitely far.)
+ /// To prevent unreasonable geometry, the mitre limit
+ /// allows controlling the maximum length of the join corner.
+ /// Corners with a ratio which exceed the limit will be beveled.
+ /// @param limit the mitre ratio limit
+ void
+ setMitreLimit(double limit)
+ mitreLimit = limit;
+ * A single-sided buffer is constructed on only one side of each input line.
+ * always ignored,
+ * @param isSingleSided true if a single-sided buffer should be constructed
+ void
+ setSingleSided(bool p_isSingleSided)
+ _isSingleSided = p_isSingleSided;
+ * Tests whether the buffer is to be generated on a single side only.
+ * @return true if the generated buffer is to be single-sided
+ bool
+ isSingleSided() const
+ return _isSingleSided;
private:
- /// Defaults to DEFAULT_QUADRANT_SEGMENTS;
- int quadrantSegments;
+ /// Defaults to DEFAULT_QUADRANT_SEGMENTS;
+ int quadrantSegments;
- /// Defaults to CAP_ROUND;
- EndCapStyle endCapStyle;
+ /// Defaults to CAP_ROUND;
+ EndCapStyle endCapStyle;
- /// Defaults to JOIN_ROUND;
- JoinStyle joinStyle;
+ /// Defaults to JOIN_ROUND;
+ JoinStyle joinStyle;
- /// Defaults to DEFAULT_MITRE_LIMIT;
- double mitreLimit;
+ /// Defaults to DEFAULT_MITRE_LIMIT;
+ double mitreLimit;
- bool _isSingleSided;
+ bool _isSingleSided;
diff --git a/include/geos/operation/buffer/BufferSubgraph.h b/include/geos/operation/buffer/BufferSubgraph.h
index e1519a6..ed4872a 100644
--- a/include/geos/operation/buffer/BufferSubgraph.h
+++ b/include/geos/operation/buffer/BufferSubgraph.h
@@ -33,17 +33,17 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Coordinate;
- class Envelope;
- namespace algorithm {
- class CGAlgorithms;
- class DirectedEdge;
- class Node;
+namespace geom {
+class Coordinate;
+class Envelope;
+namespace algorithm {
+class CGAlgorithms;
+class DirectedEdge;
+class Node;
namespace geos {
@@ -60,131 +60,138 @@ namespace buffer { // geos.operation.buffer
class GEOS_DLL BufferSubgraph {
private:
- RightmostEdgeFinder finder;
+ RightmostEdgeFinder finder;
- std::vector<geomgraph::DirectedEdge*> dirEdgeList;
+ std::vector<geomgraph::DirectedEdge*> dirEdgeList;
- std::vector<geomgraph::Node*> nodes;
+ std::vector<geomgraph::Node*> nodes;
- geom::Coordinate *rightMostCoord;
+ geom::Coordinate* rightMostCoord;
- geom::Envelope *env;
+ geom::Envelope* env;
- /** \brief
- * Adds all nodes and edges reachable from this node to the subgraph.
- * Uses an explicit stack to avoid a large depth of recursion.
- * @param node a node known to be in the subgraph
- void addReachable(geomgraph::Node *startNode);
+ /** \brief
+ * Adds all nodes and edges reachable from this node to the subgraph.
+ * Uses an explicit stack to avoid a large depth of recursion.
+ * @param node a node known to be in the subgraph
+ void addReachable(geomgraph::Node* startNode);
- /// Adds the argument node and all its out edges to the subgraph
- /// @param node the node to add
- /// @param nodeStack the current set of nodes being traversed
- void add(geomgraph::Node* node, std::vector<geomgraph::Node*>* nodeStack);
+ /// Adds the argument node and all its out edges to the subgraph
+ /// @param node the node to add
+ /// @param nodeStack the current set of nodes being traversed
+ void add(geomgraph::Node* node, std::vector<geomgraph::Node*>* nodeStack);
- void clearVisitedEdges();
+ void clearVisitedEdges();
- /** \brief
- * Compute depths for all dirEdges via breadth-first traversal
- * of nodes in graph
- * @param startEdge edge to start processing with
- // <FIX> MD - use iteration & queue rather than recursion, for speed and robustness
- void computeDepths(geomgraph::DirectedEdge *startEdge);
+ /** \brief
+ * Compute depths for all dirEdges via breadth-first traversal
+ * of nodes in graph
+ * @param startEdge edge to start processing with
+ // <FIX> MD - use iteration & queue rather than recursion, for speed and robustness
+ void computeDepths(geomgraph::DirectedEdge* startEdge);
- void computeNodeDepth(geomgraph::Node *n);
+ void computeNodeDepth(geomgraph::Node* n);
- void copySymDepths(geomgraph::DirectedEdge *de);
+ void copySymDepths(geomgraph::DirectedEdge* de);
- bool contains(std::set<geomgraph::Node*>& nodes, geomgraph::Node *node);
+ bool contains(std::set<geomgraph::Node*>& nodes, geomgraph::Node* node);
public:
- friend std::ostream& operator<< (std::ostream& os, const BufferSubgraph& bs);
- BufferSubgraph();
- ~BufferSubgraph();
- std::vector<geomgraph::DirectedEdge*>* getDirectedEdges();
- std::vector<geomgraph::Node*>* getNodes();
- /** \brief
- * Gets the rightmost coordinate in the edges of the subgraph
- geom::Coordinate* getRightmostCoordinate();
- /** \brief
- * Creates the subgraph consisting of all edges reachable from
- * this node.
- * Finds the edges in the graph and the rightmost coordinate.
- * @param node a node to start the graph traversal from
- void create(geomgraph::Node *node);
- void computeDepth(int outsideDepth);
- /** \brief
- * Find all edges whose depths indicates that they are in the
- * result area(s).
- * Since we want polygon shells to be
- * oriented CW, choose dirEdges with the interior of the result
- * on the RHS.
- * Mark them as being in the result.
- * Interior Area edges are the result of dimensional collapses.
- * They do not form part of the result area boundary.
- void findResultEdges();
- /** \brief
- * BufferSubgraphs are compared on the x-value of their rightmost
- * Coordinate.
- * This defines a partial ordering on the graphs such that:
- * g1 >= g2 <==> Ring(g2) does not contain Ring(g1)
- * where Polygon(g) is the buffer polygon that is built from g.
- * This relationship is used to sort the BufferSubgraphs so
- * that shells are guaranteed to
- * be built before holes.
- int compareTo(BufferSubgraph *);
- /** \brief
- * Computes the envelope of the edges in the subgraph.
- * The envelope is cached after being computed.
- * @return the envelope of the graph.
- geom::Envelope *getEnvelope();
+ friend std::ostream& operator<< (std::ostream& os, const BufferSubgraph& bs);
+ BufferSubgraph();
+ ~BufferSubgraph();
+ std::vector<geomgraph::DirectedEdge*>* getDirectedEdges();
+ std::vector<geomgraph::Node*>* getNodes();
+ /** \brief
+ * Gets the rightmost coordinate in the edges of the subgraph
+ geom::Coordinate* getRightmostCoordinate();
+ /** \brief
+ * Creates the subgraph consisting of all edges reachable from
+ * this node.
+ * Finds the edges in the graph and the rightmost coordinate.
+ * @param node a node to start the graph traversal from
+ void create(geomgraph::Node* node);
+ void computeDepth(int outsideDepth);
+ /** \brief
+ * Find all edges whose depths indicates that they are in the
+ * result area(s).
+ * Since we want polygon shells to be
+ * oriented CW, choose dirEdges with the interior of the result
+ * on the RHS.
+ * Mark them as being in the result.
+ * Interior Area edges are the result of dimensional collapses.
+ * They do not form part of the result area boundary.
+ void findResultEdges();
+ /** \brief
+ * BufferSubgraphs are compared on the x-value of their rightmost
+ * Coordinate.
+ * This defines a partial ordering on the graphs such that:
+ * g1 >= g2 <==> Ring(g2) does not contain Ring(g1)
+ * where Polygon(g) is the buffer polygon that is built from g.
+ * This relationship is used to sort the BufferSubgraphs so
+ * that shells are guaranteed to
+ * be built before holes.
+ int compareTo(BufferSubgraph*);
+ /** \brief
+ * Computes the envelope of the edges in the subgraph.
+ * The envelope is cached after being computed.
+ * @return the envelope of the graph.
+ geom::Envelope* getEnvelope();
// INLINES
inline geom::Coordinate*
-BufferSubgraph::getRightmostCoordinate() {return rightMostCoord;}
+BufferSubgraph::getRightmostCoordinate()
+ return rightMostCoord;
inline std::vector<geomgraph::Node*>*
-BufferSubgraph::getNodes() { return &nodes; }
+BufferSubgraph::getNodes()
+ return &nodes;
inline std::vector<geomgraph::DirectedEdge*>*
-BufferSubgraph::getDirectedEdges() {
- return &dirEdgeList;
+BufferSubgraph::getDirectedEdges()
+ return &dirEdgeList;
-bool BufferSubgraphGT(BufferSubgraph *first, BufferSubgraph *second);
+bool BufferSubgraphGT(BufferSubgraph* first, BufferSubgraph* second);
diff --git a/include/geos/operation/buffer/OffsetCurveBuilder.h b/include/geos/operation/buffer/OffsetCurveBuilder.h
index 52f1d55..684dcfd 100644
--- a/include/geos/operation/buffer/OffsetCurveBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveBuilder.h
@@ -35,10 +35,10 @@
namespace geos {
- namespace geom {
+namespace geom {
namespace geos {
@@ -62,116 +62,117 @@ namespace buffer { // geos.operation.buffer
class GEOS_DLL OffsetCurveBuilder {
public:
- OffsetCurveBuilder(const geom::PrecisionModel *newPrecisionModel,
- const BufferParameters& nBufParams)
- distance(0.0),
- precisionModel(newPrecisionModel),
- * Gets the buffer parameters being used to generate the curve.
- * @return the buffer parameters being used
- const BufferParameters& getBufferParameters() const
- return bufParams;
- * This method handles single points as well as lines.
- * Lines are assumed to <b>not</b> be closed (the function will not
- * fail for closed lines, but will generate superfluous line caps).
- * @param lineList the std::vector to which the newly created
- * CoordinateSequences will be pushed_back.
- * Caller is responsible to delete these new elements.
- void getLineCurve(const geom::CoordinateSequence* inputPts,
- double distance,
- std::vector<geom::CoordinateSequence*>& lineList);
- * @param lineList the std::vector to which newly created
- * Caller will be responsible to delete them.
- * @param leftSide indicates that the left side buffer will be
- * obtained/skipped
- * @param rightSide indicates that the right side buffer will
- * be obtained/skipped
- * NOTE: this is a GEOS extension
- void getSingleSidedLineCurve(const geom::CoordinateSequence* inputPts,
- double distance, std::vector<geom::CoordinateSequence*>& lineList,
- bool leftSide, bool rightSide ) ;
- * This method handles the degenerate cases of single points and lines,
- * as well as rings.
- * @param lineList the std::vector to which CoordinateSequences will
- * be pushed_back
- void getRingCurve(const geom::CoordinateSequence *inputPts, int side,
- double distance,
+ OffsetCurveBuilder(const geom::PrecisionModel* newPrecisionModel,
+ const BufferParameters& nBufParams)
+ distance(0.0),
+ precisionModel(newPrecisionModel),
+ * Gets the buffer parameters being used to generate the curve.
+ * @return the buffer parameters being used
+ getBufferParameters() const
+ return bufParams;
+ * This method handles single points as well as lines.
+ * Lines are assumed to <b>not</b> be closed (the function will not
+ * fail for closed lines, but will generate superfluous line caps).
+ * @param lineList the std::vector to which the newly created
+ * CoordinateSequences will be pushed_back.
+ * Caller is responsible to delete these new elements.
+ void getLineCurve(const geom::CoordinateSequence* inputPts,
+ double distance,
+ std::vector<geom::CoordinateSequence*>& lineList);
+ * @param lineList the std::vector to which newly created
+ * Caller will be responsible to delete them.
+ * @param leftSide indicates that the left side buffer will be
+ * obtained/skipped
+ * @param rightSide indicates that the right side buffer will
+ * be obtained/skipped
+ * NOTE: this is a GEOS extension
+ void getSingleSidedLineCurve(const geom::CoordinateSequence* inputPts,
+ double distance, std::vector<geom::CoordinateSequence*>& lineList,
+ bool leftSide, bool rightSide) ;
+ * This method handles the degenerate cases of single points and lines,
+ * as well as rings.
+ * @param lineList the std::vector to which CoordinateSequences will
+ * be pushed_back
+ void getRingCurve(const geom::CoordinateSequence* inputPts, int side,
+ double distance,
private:
- double distance;
+ double distance;
- const geom::PrecisionModel* precisionModel;
+ const geom::PrecisionModel* precisionModel;
- * Use a value which results in a potential distance error which is
- * significantly less than the error due to
- * the quadrant segment discretization.
- * For QS = 8 a value of 100 is reasonable.
- * This should produce a maximum of 1% distance error.
- static const double SIMPLIFY_FACTOR; // 100.0;
+ * Use a value which results in a potential distance error which is
+ * significantly less than the error due to
+ * the quadrant segment discretization.
+ * For QS = 8 a value of 100 is reasonable.
+ * This should produce a maximum of 1% distance error.
+ static const double SIMPLIFY_FACTOR; // 100.0;
- /** \brief
- * Computes the distance tolerance to use during input
- * line simplification.
- * @return the simplification tolerance
- double simplifyTolerance(double bufDistance);
+ /** \brief
+ * Computes the distance tolerance to use during input
+ * line simplification.
+ * @return the simplification tolerance
+ double simplifyTolerance(double bufDistance);
- void computeLineBufferCurve(const geom::CoordinateSequence& inputPts,
- OffsetSegmentGenerator& segGen);
+ void computeLineBufferCurve(const geom::CoordinateSequence& inputPts,
+ OffsetSegmentGenerator& segGen);
- void computeSingleSidedBufferCurve(const geom::CoordinateSequence& inputPts,
- bool isRightSide,
+ void computeSingleSidedBufferCurve(const geom::CoordinateSequence& inputPts,
+ bool isRightSide,
- void computeRingBufferCurve(const geom::CoordinateSequence& inputPts,
- int side, OffsetSegmentGenerator& segGen);
+ void computeRingBufferCurve(const geom::CoordinateSequence& inputPts,
+ int side, OffsetSegmentGenerator& segGen);
- std::unique_ptr<OffsetSegmentGenerator> getSegGen(double dist);
+ std::unique_ptr<OffsetSegmentGenerator> getSegGen(double dist);
- void computePointCurve(const geom::Coordinate& pt,
+ void computePointCurve(const geom::Coordinate& pt,
// Declare type as noncopyable
diff --git a/include/geos/operation/buffer/OffsetCurveSetBuilder.h b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
index 14ccc3f..5eba19c 100644
--- a/include/geos/operation/buffer/OffsetCurveSetBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
@@ -31,26 +31,26 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Point;
- class LineString;
- class LinearRing;
- class Polygon;
- class Label;
- namespace noding {
- class SegmentString;
- class OffsetCurveBuilder;
+namespace geom {
+class Geometry;
+class Point;
+class LineString;
+class LinearRing;
+class Polygon;
+class Label;
+namespace noding {
+class SegmentString;
+namespace buffer {
+class OffsetCurveBuilder;
namespace geos {
@@ -71,103 +71,103 @@ class GEOS_DLL OffsetCurveSetBuilder {
private:
- // To keep track of newly-created Labels.
- // Labels will be relesed by object dtor
- std::vector<geomgraph::Label*> newLabels;
- const geom::Geometry& inputGeom;
- double distance;
- OffsetCurveBuilder& curveBuilder;
- /// The raw offset curves computed.
- /// This class holds ownership of std::vector elements.
- std::vector<noding::SegmentString*> curveList;
- * Creates a noding::SegmentString for a coordinate list which is a raw
- * offset curve, and adds it to the list of buffer curves.
- * The noding::SegmentString is tagged with a geomgraph::Label
- * giving the topology of the curve.
- * The curve may be oriented in either direction.
- * If the curve is oriented CW, the locations will be:
- * - Left: Location.EXTERIOR
- * - Right: Location.INTERIOR
- * @param coord is raw offset curve, ownership transferred here
- void addCurve(geom::CoordinateSequence *coord, int leftLoc,
- int rightLoc);
- void add(const geom::Geometry& g);
- void addCollection(const geom::GeometryCollection *gc);
- * Add a Point to the graph.
- void addPoint(const geom::Point *p);
- void addLineString(const geom::LineString *line);
- void addPolygon(const geom::Polygon *p);
- * Add an offset curve for a polygon ring.
- * The side and left and right topological location arguments
- * assume that the ring is oriented CW.
- * If the ring is in the opposite orientation,
- * the left and right locations must be interchanged and the side
- * flipped.
- * @param coord the coordinates of the ring (must not contain
- * repeated points)
- * @param offsetDistance the distance at which to create the buffer
- * @param side the side of the ring on which to construct the buffer
- * line
- * @param cwLeftLoc the location on the L side of the ring
- * (if it is CW)
- * @param cwRightLoc the location on the R side of the ring
- * (if it is CW)
- void addPolygonRing(const geom::CoordinateSequence *coord,
- double offsetDistance, int side, int cwLeftLoc,
- int cwRightLoc);
- * The ringCoord is assumed to contain no repeated points.
- * It may be degenerate (i.e. contain only 1, 2, or 3 points).
- * In this case it has no area, and hence has a minimum diameter of 0.
- * @param ring
- * @return
- bool isErodedCompletely(const geom::LinearRing* ringCoord,
- double bufferDistance);
- * Tests whether a triangular ring would be eroded completely by
- * the given buffer distance.
- * This is a precise test. It uses the fact that the inner buffer
- * of a triangle converges on the inCentre of the triangle (the
- * point equidistant from all sides). If the buffer distance is
- * greater than the distance of the inCentre from a side, the
- * triangle will be eroded completely.
- * This test is important, since it removes a problematic case where
- * the buffer distance is slightly larger than the inCentre distance.
- * In this case the triangle buffer curve "inverts" with incorrect
- * topology, producing an incorrect hole in the buffer.
- * @param triCoord
- * @param bufferDistance
- * @return
- bool isTriangleErodedCompletely(const geom::CoordinateSequence *triCoords,
+ // To keep track of newly-created Labels.
+ // Labels will be relesed by object dtor
+ const geom::Geometry& inputGeom;
+ double distance;
+ OffsetCurveBuilder& curveBuilder;
+ /// The raw offset curves computed.
+ /// This class holds ownership of std::vector elements.
+ std::vector<noding::SegmentString*> curveList;
+ * Creates a noding::SegmentString for a coordinate list which is a raw
+ * offset curve, and adds it to the list of buffer curves.
+ * The noding::SegmentString is tagged with a geomgraph::Label
+ * giving the topology of the curve.
+ * The curve may be oriented in either direction.
+ * If the curve is oriented CW, the locations will be:
+ * - Left: Location.EXTERIOR
+ * - Right: Location.INTERIOR
+ * @param coord is raw offset curve, ownership transferred here
+ void addCurve(geom::CoordinateSequence* coord, int leftLoc,
+ int rightLoc);
+ void add(const geom::Geometry& g);
+ void addCollection(const geom::GeometryCollection* gc);
+ * Add a Point to the graph.
+ void addPoint(const geom::Point* p);
+ void addLineString(const geom::LineString* line);
+ void addPolygon(const geom::Polygon* p);
+ * Add an offset curve for a polygon ring.
+ * The side and left and right topological location arguments
+ * assume that the ring is oriented CW.
+ * If the ring is in the opposite orientation,
+ * the left and right locations must be interchanged and the side
+ * flipped.
+ * @param coord the coordinates of the ring (must not contain
+ * repeated points)
+ * @param offsetDistance the distance at which to create the buffer
+ * @param side the side of the ring on which to construct the buffer
+ * line
+ * @param cwLeftLoc the location on the L side of the ring
+ * (if it is CW)
+ * @param cwRightLoc the location on the R side of the ring
+ * (if it is CW)
+ void addPolygonRing(const geom::CoordinateSequence* coord,
+ double offsetDistance, int side, int cwLeftLoc,
+ int cwRightLoc);
+ * The ringCoord is assumed to contain no repeated points.
+ * It may be degenerate (i.e. contain only 1, 2, or 3 points).
+ * In this case it has no area, and hence has a minimum diameter of 0.
+ * @param ring
+ * @return
+ bool isErodedCompletely(const geom::LinearRing* ringCoord,
+ double bufferDistance);
+ * Tests whether a triangular ring would be eroded completely by
+ * the given buffer distance.
+ * This is a precise test. It uses the fact that the inner buffer
+ * of a triangle converges on the inCentre of the triangle (the
+ * point equidistant from all sides). If the buffer distance is
+ * greater than the distance of the inCentre from a side, the
+ * triangle will be eroded completely.
+ * This test is important, since it removes a problematic case where
+ * the buffer distance is slightly larger than the inCentre distance.
+ * In this case the triangle buffer curve "inverts" with incorrect
+ * topology, producing an incorrect hole in the buffer.
+ * @param triCoord
+ * @param bufferDistance
+ * @return
+ bool isTriangleErodedCompletely(const geom::CoordinateSequence* triCoords,
OffsetCurveSetBuilder(const OffsetCurveSetBuilder& other) = delete;
@@ -175,31 +175,31 @@ private:
public:
- /// Constructor
- OffsetCurveSetBuilder(const geom::Geometry& newInputGeom,
- double newDistance, OffsetCurveBuilder& newCurveBuilder);
- /// Destructor
- ~OffsetCurveSetBuilder();
- /** \brief
- * Computes the set of raw offset curves for the buffer.
- * Each offset curve has an attached {@link geomgraph::Label} indicating
- * its left and right location.
- * @return a Collection of SegmentStrings representing the raw
- * buffer curves
- std::vector<noding::SegmentString*>& getCurves();
- /// Add raw curves for a set of CoordinateSequences
- /// @param lineList is a list of CoordinateSequence, ownership
- /// of which is transferred here.
- void addCurves(const std::vector<geom::CoordinateSequence*>& lineList,
- int leftLoc, int rightLoc);
+ /// Constructor
+ OffsetCurveSetBuilder(const geom::Geometry& newInputGeom,
+ double newDistance, OffsetCurveBuilder& newCurveBuilder);
+ /// Destructor
+ ~OffsetCurveSetBuilder();
+ /** \brief
+ * Computes the set of raw offset curves for the buffer.
+ * Each offset curve has an attached {@link geomgraph::Label} indicating
+ * its left and right location.
+ * @return a Collection of SegmentStrings representing the raw
+ * buffer curves
+ std::vector<noding::SegmentString*>& getCurves();
+ /// Add raw curves for a set of CoordinateSequences
+ /// @param lineList is a list of CoordinateSequence, ownership
+ /// of which is transferred here.
+ void addCurves(const std::vector<geom::CoordinateSequence*>& lineList,
+ int leftLoc, int rightLoc);
diff --git a/include/geos/operation/buffer/OffsetSegmentGenerator.h b/include/geos/operation/buffer/OffsetSegmentGenerator.h
index 2d2c8ab..f9974a6 100644
--- a/include/geos/operation/buffer/OffsetSegmentGenerator.h
+++ b/include/geos/operation/buffer/OffsetSegmentGenerator.h
@@ -36,10 +36,10 @@
namespace geos {
- namespace geom {
- class PrecisionModel;
+namespace geom {
+class PrecisionModel;
namespace geos {
@@ -62,285 +62,293 @@ class GEOS_DLL OffsetSegmentGenerator {
public:
- OffsetSegmentGenerator(const geom::PrecisionModel *newPrecisionModel,
- const BufferParameters& bufParams, double distance);
- * Tests whether the input has a narrow concave angle
- * (relative to the offset distance).
- * In this case the generated offset curve will contain self-intersections
- * and heuristic closing segments.
- * This is expected behaviour in the case of buffer curves.
- * For pure offset curves,
- * the output needs to be further treated
- * before it can be used.
- * @return true if the input has a narrow concave angle
- bool hasNarrowConcaveAngle() const
- return _hasNarrowConcaveAngle;
- void initSideSegments(const geom::Coordinate &nS1,
- const geom::Coordinate &nS2, int nSide);
- /// Get coordinates by taking ownership of them
- /// After this call, the coordinates reference in
- /// this object are dropped. Calling twice will
- /// segfault...
- /// FIXME: refactor memory management of this
- void getCoordinates(std::vector<geom::CoordinateSequence*>& to) {
- to.push_back(segList.getCoordinates());
- void closeRing() {
- segList.closeRing();
- /// Adds a CW circle around a point
- void createCircle(const geom::Coordinate &p, double distance);
- /// Adds a CW square around a point
- void createSquare(const geom::Coordinate &p, double distance);
- /// Add first offset point
- void addFirstSegment()
- segList.addPt(offset1.p0);
- /// Add last offset point
- void addLastSegment()
- segList.addPt(offset1.p1);
- void addNextSegment(const geom::Coordinate &p, bool addStartPoint);
- /// \brief
- /// Add an end cap around point p1, terminating a line segment
- /// coming from p0
- void addLineEndCap(const geom::Coordinate &p0,
- const geom::Coordinate &p1);
- void addSegments(const geom::CoordinateSequence& pts, bool isForward)
- segList.addPts(pts, isForward);
+ OffsetSegmentGenerator(const geom::PrecisionModel* newPrecisionModel,
+ const BufferParameters& bufParams, double distance);
+ * Tests whether the input has a narrow concave angle
+ * (relative to the offset distance).
+ * In this case the generated offset curve will contain self-intersections
+ * and heuristic closing segments.
+ * This is expected behaviour in the case of buffer curves.
+ * For pure offset curves,
+ * the output needs to be further treated
+ * before it can be used.
+ * @return true if the input has a narrow concave angle
+ bool
+ hasNarrowConcaveAngle() const
+ return _hasNarrowConcaveAngle;
+ void initSideSegments(const geom::Coordinate& nS1,
+ const geom::Coordinate& nS2, int nSide);
+ /// Get coordinates by taking ownership of them
+ /// After this call, the coordinates reference in
+ /// this object are dropped. Calling twice will
+ /// segfault...
+ /// FIXME: refactor memory management of this
+ void
+ getCoordinates(std::vector<geom::CoordinateSequence*>& to)
+ to.push_back(segList.getCoordinates());
+ void
+ closeRing()
+ segList.closeRing();
+ /// Adds a CW circle around a point
+ void createCircle(const geom::Coordinate& p, double distance);
+ /// Adds a CW square around a point
+ void createSquare(const geom::Coordinate& p, double distance);
+ /// Add first offset point
+ void
+ addFirstSegment()
+ segList.addPt(offset1.p0);
+ /// Add last offset point
+ void
+ addLastSegment()
+ segList.addPt(offset1.p1);
+ void addNextSegment(const geom::Coordinate& p, bool addStartPoint);
+ /// \brief
+ /// Add an end cap around point p1, terminating a line segment
+ /// coming from p0
+ void addLineEndCap(const geom::Coordinate& p0,
+ const geom::Coordinate& p1);
+ void
+ addSegments(const geom::CoordinateSequence& pts, bool isForward)
+ segList.addPts(pts, isForward);
private:
- * Factor which controls how close offset segments can be to
- * skip adding a filler or mitre.
- static const double OFFSET_SEGMENT_SEPARATION_FACTOR; // 1.0E-3;
- * Factor which controls how close curve vertices on inside turns
- * can be to be snapped
- static const double INSIDE_TURN_VERTEX_SNAP_DISTANCE_FACTOR; // 1.0E-3;
- * Factor which controls how close curve vertices can be to be snapped
- static const double CURVE_VERTEX_SNAP_DISTANCE_FACTOR; // 1.0E-6;
- * Factor which determines how short closing segs can be for round buffers
- static const int MAX_CLOSING_SEG_LEN_FACTOR = 80;
- /** \brief
- * the max error of approximation (distance) between a quad segment and
- * the true fillet curve
- double maxCurveSegmentError; // 0.0
- /** \brief
- * The angle quantum with which to approximate a fillet curve
- * (based on the input # of quadrant segments)
- double filletAngleQuantum;
- /// The Closing Segment Factor controls how long "closing
- /// segments" are. Closing segments are added at the middle of
- /// inside corners to ensure a smoother boundary for the buffer
- /// offset curve. In some cases (particularly for round joins
- /// with default-or-better quantization) the closing segments
- /// can be made quite short. This substantially improves
- /// performance (due to fewer intersections being created).
- /// A closingSegFactor of 0 results in lines to the corner vertex.
- /// A closingSegFactor of 1 results in lines halfway
- /// to the corner vertex.
- /// A closingSegFactor of 80 results in lines 1/81 of the way
- /// to the corner vertex (this option is reasonable for the very
- /// common default situation of round joins and quadrantSegs >= 8).
- /// The default is 1.
- int closingSegLengthFactor; // 1;
- /// Owned by this object, destroyed by dtor
- /// This actually gets created multiple times
- /// and each of the old versions is pushed
- /// to the ptLists std::vector to ensure all
- /// created CoordinateSequences are properly
- /// destroyed.
- OffsetSegmentString segList;
- double distance;
- algorithm::LineIntersector li;
- geom::Coordinate s0, s1, s2;
- geom::LineSegment seg0;
- geom::LineSegment seg1;
- geom::LineSegment offset0;
- geom::LineSegment offset1;
- int side;
- bool _hasNarrowConcaveAngle; // =false
- void addCollinear(bool addStartPoint);
- /// The mitre will be beveled if it exceeds the mitre ratio limit.
- /// @param offset0 the first offset segment
- /// @param offset1 the second offset segment
- /// @param distance the offset distance
- void addMitreJoin(const geom::Coordinate& p,
- const geom::LineSegment& offset0,
- const geom::LineSegment& offset1,
- double distance);
- /// Adds a limited mitre join connecting the two reflex offset segments.
- /// A limited mitre is a mitre which is beveled at the distance
- /// determined by the mitre ratio limit.
- /// @param mitreLimit the mitre limit ratio
- void addLimitedMitreJoin(
- double distance, double mitreLimit);
- /// \brief
- /// Adds a bevel join connecting the two offset segments
- /// around a reflex corner.
- void addBevelJoin(const geom::LineSegment& offset0,
- const geom::LineSegment& offset1);
- static const double PI; // 3.14159265358979
- // Not in JTS, used for single-sided buffers
- int endCapIndex;
- void init(double newDistance);
- /// Adds the offset points for an outside (convex) turn
- /// @param orientation
- /// @param addStartPoint
- void addOutsideTurn(int orientation, bool addStartPoint);
- /// Adds the offset points for an inside (concave) turn
- void addInsideTurn(int orientation, bool addStartPoint);
- /** \brief
- * Compute an offset segment for an input segment on a given
- * side and at a given distance.
- * The offset points are computed in full double precision,
- * for accuracy.
- * @param seg the segment to offset
- * @param side the side of the segment the offset lies on
- * @param distance the offset distance
- * @param offset the points computed for the offset segment
- void computeOffsetSegment(const geom::LineSegment& seg,
- int side, double distance,
- geom::LineSegment& offset);
- * Adds points for a circular fillet around a reflex corner.
- * Adds the start and end points
- * @param p base point of curve
- * @param p0 start point of fillet curve
- * @param p1 endpoint of fillet curve
- * @param direction the orientation of the fillet
- * @param radius the radius of the fillet
- void addFillet(const geom::Coordinate &p, const geom::Coordinate &p0,
- const geom::Coordinate &p1,
- int direction, double radius);
- * Adds points for a circular fillet arc between two specified angles.
- * The start and end point for the fillet are not added -
- * the caller must add them if required.
- * @param direction is -1 for a CW angle, 1 for a CCW angle
- void addFillet(const geom::Coordinate &p, double startAngle,
- double endAngle, int direction, double radius);
+ * Factor which controls how close offset segments can be to
+ * skip adding a filler or mitre.
+ static const double OFFSET_SEGMENT_SEPARATION_FACTOR; // 1.0E-3;
+ * Factor which controls how close curve vertices on inside turns
+ * can be to be snapped
+ static const double INSIDE_TURN_VERTEX_SNAP_DISTANCE_FACTOR; // 1.0E-3;
+ * Factor which controls how close curve vertices can be to be snapped
+ static const double CURVE_VERTEX_SNAP_DISTANCE_FACTOR; // 1.0E-6;
+ * Factor which determines how short closing segs can be for round buffers
+ static const int MAX_CLOSING_SEG_LEN_FACTOR = 80;
+ /** \brief
+ * the max error of approximation (distance) between a quad segment and
+ * the true fillet curve
+ double maxCurveSegmentError; // 0.0
+ /** \brief
+ * The angle quantum with which to approximate a fillet curve
+ * (based on the input # of quadrant segments)
+ double filletAngleQuantum;
+ /// The Closing Segment Factor controls how long "closing
+ /// segments" are. Closing segments are added at the middle of
+ /// inside corners to ensure a smoother boundary for the buffer
+ /// offset curve. In some cases (particularly for round joins
+ /// with default-or-better quantization) the closing segments
+ /// can be made quite short. This substantially improves
+ /// performance (due to fewer intersections being created).
+ /// A closingSegFactor of 0 results in lines to the corner vertex.
+ /// A closingSegFactor of 1 results in lines halfway
+ /// to the corner vertex.
+ /// A closingSegFactor of 80 results in lines 1/81 of the way
+ /// to the corner vertex (this option is reasonable for the very
+ /// common default situation of round joins and quadrantSegs >= 8).
+ /// The default is 1.
+ int closingSegLengthFactor; // 1;
+ /// Owned by this object, destroyed by dtor
+ /// This actually gets created multiple times
+ /// and each of the old versions is pushed
+ /// to the ptLists std::vector to ensure all
+ /// created CoordinateSequences are properly
+ /// destroyed.
+ OffsetSegmentString segList;
+ double distance;
+ algorithm::LineIntersector li;
+ geom::Coordinate s0, s1, s2;
+ geom::LineSegment seg0;
+ geom::LineSegment seg1;
+ geom::LineSegment offset0;
+ geom::LineSegment offset1;
+ int side;
+ bool _hasNarrowConcaveAngle; // =false
+ void addCollinear(bool addStartPoint);
+ /// The mitre will be beveled if it exceeds the mitre ratio limit.
+ /// @param offset0 the first offset segment
+ /// @param offset1 the second offset segment
+ /// @param distance the offset distance
+ void addMitreJoin(const geom::Coordinate& p,
+ const geom::LineSegment& offset0,
+ const geom::LineSegment& offset1,
+ double distance);
+ /// Adds a limited mitre join connecting the two reflex offset segments.
+ /// A limited mitre is a mitre which is beveled at the distance
+ /// determined by the mitre ratio limit.
+ /// @param mitreLimit the mitre limit ratio
+ void addLimitedMitreJoin(
+ double distance, double mitreLimit);
+ /// \brief
+ /// Adds a bevel join connecting the two offset segments
+ /// around a reflex corner.
+ void addBevelJoin(const geom::LineSegment& offset0,
+ const geom::LineSegment& offset1);
+ static const double PI; // 3.14159265358979
+ // Not in JTS, used for single-sided buffers
+ int endCapIndex;
+ void init(double newDistance);
+ /// Adds the offset points for an outside (convex) turn
+ /// @param orientation
+ /// @param addStartPoint
+ void addOutsideTurn(int orientation, bool addStartPoint);
+ /// Adds the offset points for an inside (concave) turn
+ void addInsideTurn(int orientation, bool addStartPoint);
+ /** \brief
+ * Compute an offset segment for an input segment on a given
+ * side and at a given distance.
+ * The offset points are computed in full double precision,
+ * for accuracy.
+ * @param seg the segment to offset
+ * @param side the side of the segment the offset lies on
+ * @param distance the offset distance
+ * @param offset the points computed for the offset segment
+ void computeOffsetSegment(const geom::LineSegment& seg,
+ int side, double distance,
+ geom::LineSegment& offset);
+ * Adds points for a circular fillet around a reflex corner.
+ * Adds the start and end points
+ * @param p base point of curve
+ * @param p0 start point of fillet curve
+ * @param p1 endpoint of fillet curve
+ * @param direction the orientation of the fillet
+ * @param radius the radius of the fillet
+ void addFillet(const geom::Coordinate& p, const geom::Coordinate& p0,
+ int direction, double radius);
+ * Adds points for a circular fillet arc between two specified angles.
+ * The start and end point for the fillet are not added -
+ * the caller must add them if required.
+ * @param direction is -1 for a CW angle, 1 for a CCW angle
+ void addFillet(const geom::Coordinate& p, double startAngle,
+ double endAngle, int direction, double radius);
private:
- // An OffsetSegmentGenerator cannot be copied because of member "const BufferParameters& bufParams"
- // Not declaring these functions triggers MSVC warning C4512: "assignment operator could not be generated"
- OffsetSegmentGenerator(const OffsetSegmentGenerator&);
- void operator=(const OffsetSegmentGenerator&);
+ // An OffsetSegmentGenerator cannot be copied because of member "const BufferParameters& bufParams"
+ // Not declaring these functions triggers MSVC warning C4512: "assignment operator could not be generated"
+ OffsetSegmentGenerator(const OffsetSegmentGenerator&);
+ void operator=(const OffsetSegmentGenerator&);
diff --git a/include/geos/operation/buffer/OffsetSegmentString.h b/include/geos/operation/buffer/OffsetSegmentString.h
index 5a3859a..c5f699b 100644
--- a/include/geos/operation/buffer/OffsetSegmentString.h
+++ b/include/geos/operation/buffer/OffsetSegmentString.h
@@ -40,153 +40,173 @@ namespace buffer { // geos.operation.buffer
/// @author Martin Davis
-class OffsetSegmentString
+class OffsetSegmentString {
private:
- geom::CoordinateArraySequence* ptList;
- /** \brief
- * The distance below which two adjacent points on the curve
- * are considered to be coincident.
- * This is chosen to be a small fraction of the offset distance.
- double minimumVertexDistance;
- /** \brief
- * Tests whether the given point is redundant relative to the previous
- * point in the list (up to tolerance)
- * @param pt
- * @return true if the point is redundant
- bool isRedundant(const geom::Coordinate& pt) const
- if (ptList->size() < 1)
- return false;
- const geom::Coordinate& lastPt = ptList->back();
- double ptDist = pt.distance(lastPt);
- if (ptDist < minimumVertexDistance)
- return true;
- return false;
+ geom::CoordinateArraySequence* ptList;
+ /** \brief
+ * The distance below which two adjacent points on the curve
+ * are considered to be coincident.
+ * This is chosen to be a small fraction of the offset distance.
+ double minimumVertexDistance;
+ /** \brief
+ * Tests whether the given point is redundant relative to the previous
+ * point in the list (up to tolerance)
+ * @param pt
+ * @return true if the point is redundant
+ bool
+ isRedundant(const geom::Coordinate& pt) const
+ if(ptList->size() < 1) {
+ return false;
+ const geom::Coordinate& lastPt = ptList->back();
+ double ptDist = pt.distance(lastPt);
+ if(ptDist < minimumVertexDistance) {
+ return true;
+ return false;
public:
- friend std::ostream& operator<< (std::ostream& os, const OffsetSegmentString& node);
- OffsetSegmentString()
- ptList(new geom::CoordinateArraySequence()),
- precisionModel(nullptr),
- minimumVertexDistance (0.0)
- ~OffsetSegmentString()
- delete ptList;
- void reset()
- if ( ptList ) ptList->clear();
- else ptList = new geom::CoordinateArraySequence();
- precisionModel = nullptr;
- minimumVertexDistance = 0.0;
- void setPrecisionModel(const geom::PrecisionModel* nPrecisionModel)
- precisionModel = nPrecisionModel;
- void setMinimumVertexDistance(double nMinVertexDistance)
- minimumVertexDistance = nMinVertexDistance;
- void addPt(const geom::Coordinate& pt)
- assert(precisionModel);
- geom::Coordinate bufPt = pt;
- precisionModel->makePrecise(bufPt);
- // don't add duplicate (or near-duplicate) points
- if (isRedundant(bufPt))
- return;
- // we ask to allow repeated as we checked this ourself
- // (JTS uses a vector for ptList, not a CoordinateSequence,
- // we should do the same)
- ptList->add(bufPt, true);
- void addPts(const geom::CoordinateSequence& pts, bool isForward)
- if ( isForward ) {
- for (size_t i=0, n=pts.size(); i<n; ++i) {
- addPt(pts[i]);
- } else {
- for (size_t i=pts.size(); i>0; --i) {
- addPt(pts[i-1]);
+ friend std::ostream& operator<< (std::ostream& os, const OffsetSegmentString& node);
+ OffsetSegmentString()
+ ptList(new geom::CoordinateArraySequence()),
+ precisionModel(nullptr),
+ minimumVertexDistance(0.0)
+ ~OffsetSegmentString()
+ delete ptList;
+ void
+ reset()
+ if(ptList) {
+ ptList->clear();
+ else {
+ ptList = new geom::CoordinateArraySequence();
+ precisionModel = nullptr;
+ minimumVertexDistance = 0.0;
+ void
+ setPrecisionModel(const geom::PrecisionModel* nPrecisionModel)
+ precisionModel = nPrecisionModel;
+ void
+ setMinimumVertexDistance(double nMinVertexDistance)
+ minimumVertexDistance = nMinVertexDistance;
+ void
+ addPt(const geom::Coordinate& pt)
+ assert(precisionModel);
+ geom::Coordinate bufPt = pt;
+ precisionModel->makePrecise(bufPt);
+ // don't add duplicate (or near-duplicate) points
+ if(isRedundant(bufPt)) {
+ return;
+ // we ask to allow repeated as we checked this ourself
+ // (JTS uses a vector for ptList, not a CoordinateSequence,
+ // we should do the same)
+ ptList->add(bufPt, true);
+ void
+ addPts(const geom::CoordinateSequence& pts, bool isForward)
+ if(isForward) {
+ for(size_t i = 0, n = pts.size(); i < n; ++i) {
+ addPt(pts[i]);
+ else {
+ for(size_t i = pts.size(); i > 0; --i) {
+ addPt(pts[i - 1]);
+ /// Check that points are a ring
+ /// add the startpoint again if they are not
+ void
+ closeRing()
+ return;
+ const geom::Coordinate& startPt = ptList->front();
+ if(startPt.equals(lastPt)) {
+ return;
+ ptList->add(startPt, true);
+ /// segfault...
+ geom::CoordinateSequence*
+ getCoordinates()
+ closeRing();
+ geom::CoordinateSequence* ret = ptList;
+ ptList = nullptr;
+ return ret;
+ inline size_t
+ size() const
+ return ptList ? ptList->size() : 0 ;
- /// Check that points are a ring
- /// add the startpoint again if they are not
- void closeRing()
- if (ptList->size() < 1) return;
- const geom::Coordinate& startPt = ptList->front();
- if (startPt.equals(lastPt)) return;
- ptList->add(startPt, true);
- /// segfault...
- geom::CoordinateSequence* getCoordinates()
- closeRing();
- geom::CoordinateSequence* ret = ptList;
- ptList = nullptr;
- return ret;
- inline size_t size() const { return ptList ? ptList->size() : 0 ; }
-inline std::ostream& operator<< (std::ostream& os,
- const OffsetSegmentString& lst)
+inline std::ostream&
+operator<< (std::ostream& os,
+ const OffsetSegmentString& lst)
- if ( lst.ptList )
- os << *(lst.ptList);
- else
- os << "empty (consumed?)";
- return os;
+ if(lst.ptList) {
+ os << *(lst.ptList);
+ else {
+ os << "empty (consumed?)";
+ return os;
} // namespace geos.operation.buffer
diff --git a/include/geos/operation/buffer/RightmostEdgeFinder.h b/include/geos/operation/buffer/RightmostEdgeFinder.h
index b280b72..2500b61 100644
--- a/include/geos/operation/buffer/RightmostEdgeFinder.h
+++ b/include/geos/operation/buffer/RightmostEdgeFinder.h
@@ -27,11 +27,11 @@
namespace geos {
- namespace geom {
- namespace geomgraph {
+namespace geom {
+namespace geomgraph {
namespace geos {
@@ -48,55 +48,55 @@ class GEOS_DLL RightmostEdgeFinder {
private:
- int minIndex;
+ int minIndex;
- geom::Coordinate minCoord;
+ geom::Coordinate minCoord;
- geomgraph::DirectedEdge *minDe;
+ geomgraph::DirectedEdge* minDe;
- geomgraph::DirectedEdge *orientedDe;
+ geomgraph::DirectedEdge* orientedDe;
- void findRightmostEdgeAtNode();
+ void findRightmostEdgeAtNode();
- void findRightmostEdgeAtVertex();
+ void findRightmostEdgeAtVertex();
- void checkForRightmostCoordinate(geomgraph::DirectedEdge *de);
+ void checkForRightmostCoordinate(geomgraph::DirectedEdge* de);
- int getRightmostSide(geomgraph::DirectedEdge *de, int index);
+ int getRightmostSide(geomgraph::DirectedEdge* de, int index);
- int getRightmostSideOfSegment(geomgraph::DirectedEdge *de, int i);
+ int getRightmostSideOfSegment(geomgraph::DirectedEdge* de, int i);
public:
- /** \brief
- * A RightmostEdgeFinder finds the geomgraph::DirectedEdge with the
- * rightmost coordinate.
- * The geomgraph::DirectedEdge returned is guaranteed to have the R of
- * the world on its RHS.
- RightmostEdgeFinder();
+ /** \brief
+ * A RightmostEdgeFinder finds the geomgraph::DirectedEdge with the
+ * rightmost coordinate.
+ * The geomgraph::DirectedEdge returned is guaranteed to have the R of
+ * the world on its RHS.
+ RightmostEdgeFinder();
- geomgraph::DirectedEdge* getEdge();
+ geomgraph::DirectedEdge* getEdge();
- geom::Coordinate& getCoordinate();
+ geom::Coordinate& getCoordinate();
- /// Note that only Forward DirectedEdges will be checked
- void findEdge(std::vector<geomgraph::DirectedEdge*>* dirEdgeList);
+ /// Note that only Forward DirectedEdges will be checked
+ void findEdge(std::vector<geomgraph::DirectedEdge*>* dirEdgeList);
/*public*/
inline geomgraph::DirectedEdge*
RightmostEdgeFinder::getEdge()
- return orientedDe;
+ return orientedDe;
/*public*/
inline geom::Coordinate&
RightmostEdgeFinder::getCoordinate()
- return minCoord;
+ return minCoord;
diff --git a/include/geos/operation/buffer/SubgraphDepthLocater.h b/include/geos/operation/buffer/SubgraphDepthLocater.h
index aea8238..b4e3ba6 100644
--- a/include/geos/operation/buffer/SubgraphDepthLocater.h
+++ b/include/geos/operation/buffer/SubgraphDepthLocater.h
@@ -27,18 +27,18 @@
namespace geos {
- namespace geom {
- class Coordinate;
- namespace operation {
- namespace buffer {
- class BufferSubgraph;
- class DepthSegment;
+namespace geom {
+class Coordinate;
+namespace operation {
+namespace buffer {
+class BufferSubgraph;
+class DepthSegment;
namespace geos {
@@ -60,57 +60,57 @@ class GEOS_DLL SubgraphDepthLocater {
public:
- SubgraphDepthLocater(std::vector<BufferSubgraph*> *newSubgraphs)
- subgraphs(newSubgraphs)
+ SubgraphDepthLocater(std::vector<BufferSubgraph*>* newSubgraphs)
+ subgraphs(newSubgraphs)
- ~SubgraphDepthLocater() {}
+ ~SubgraphDepthLocater() {}
- int getDepth(const geom::Coordinate &p);
+ int getDepth(const geom::Coordinate& p);
private:
- std::vector<BufferSubgraph*> *subgraphs;
- geom::LineSegment seg;
- * Finds all non-horizontal segments intersecting the stabbing line.
- * The stabbing line is the ray to the right of stabbingRayLeftPt.
- * @param stabbingRayLeftPt the left-hand origin of the stabbing line
- * @param stabbedSegments a vector to which DepthSegments intersecting
- * the stabbing line will be added.
- void findStabbedSegments(const geom::Coordinate &stabbingRayLeftPt,
- std::vector<DepthSegment*>& stabbedSegments);
- * in the list of dirEdges.
- * @param stabbedSegments the current vector of DepthSegments
- * intersecting the stabbing line will be added.
- std::vector<geomgraph::DirectedEdge*> *dirEdges,
- * in the input dirEdge.
- * @param stabbedSegments the current list of DepthSegments intersecting
- geomgraph::DirectedEdge *dirEdge,
+ std::vector<BufferSubgraph*>* subgraphs;
+ geom::LineSegment seg;
+ * Finds all non-horizontal segments intersecting the stabbing line.
+ * The stabbing line is the ray to the right of stabbingRayLeftPt.
+ * @param stabbingRayLeftPt the left-hand origin of the stabbing line
+ * @param stabbedSegments a vector to which DepthSegments intersecting
+ * the stabbing line will be added.
+ void findStabbedSegments(const geom::Coordinate& stabbingRayLeftPt,
+ std::vector<DepthSegment*>& stabbedSegments);
+ * in the list of dirEdges.
+ * @param stabbedSegments the current vector of DepthSegments
+ * intersecting the stabbing line will be added.
+ std::vector<geomgraph::DirectedEdge*>* dirEdges,
+ * in the input dirEdge.
+ * @param stabbedSegments the current list of DepthSegments intersecting
+ geomgraph::DirectedEdge* dirEdge,
diff --git a/include/geos/operation/distance/ConnectedElementLocationFilter.h b/include/geos/operation/distance/ConnectedElementLocationFilter.h
index 046465e..683a0e2 100644
--- a/include/geos/operation/distance/ConnectedElementLocationFilter.h
+++ b/include/geos/operation/distance/ConnectedElementLocationFilter.h
@@ -27,14 +27,14 @@
namespace geos {
- namespace geom {
- class Geometry;
- namespace distance {
- class GeometryLocation;
+namespace geom {
+class Geometry;
+namespace distance {
+class GeometryLocation;
@@ -52,24 +52,24 @@ namespace distance { // geos::operation::distance
class GEOS_DLL ConnectedElementLocationFilter: public geom::GeometryFilter {
private:
- std::vector<GeometryLocation*> *locations;
+ std::vector<GeometryLocation*>* locations;
public:
- * Returns a list containing a point from each Polygon, LineString, and Point
- * found inside the specified geometry. Thus, if the specified geometry is
- * not a GeometryCollection, an empty list will be returned. The elements of the list
- * are {@link com.vividsolutions.jts.operation.distance.GeometryLocation}s.
- static std::vector<GeometryLocation*>* getLocations(const geom::Geometry *geom);
- ConnectedElementLocationFilter(std::vector<GeometryLocation*> *newLocations)
- locations(newLocations)
- void filter_ro(const geom::Geometry *geom) override;
- void filter_rw(geom::Geometry *geom) override;
+ * Returns a list containing a point from each Polygon, LineString, and Point
+ * found inside the specified geometry. Thus, if the specified geometry is
+ * not a GeometryCollection, an empty list will be returned. The elements of the list
+ * are {@link com.vividsolutions.jts.operation.distance.GeometryLocation}s.
+ static std::vector<GeometryLocation*>* getLocations(const geom::Geometry* geom);
+ ConnectedElementLocationFilter(std::vector<GeometryLocation*>* newLocations)
+ locations(newLocations)
+ void filter_ro(const geom::Geometry* geom) override;
+ void filter_rw(geom::Geometry* geom) override;
diff --git a/include/geos/operation/distance/ConnectedElementPointFilter.h b/include/geos/operation/distance/ConnectedElementPointFilter.h
index bf2de98..660e027 100644
--- a/include/geos/operation/distance/ConnectedElementPointFilter.h
+++ b/include/geos/operation/distance/ConnectedElementPointFilter.h
@@ -27,10 +27,10 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Geometry;
+namespace geom {
+class Coordinate;
+class Geometry;
@@ -47,24 +47,24 @@ namespace distance { // geos::operation::distance
class GEOS_DLL ConnectedElementPointFilter: public geom::GeometryFilter {
private:
- std::vector<const geom::Coordinate*> *pts;
+ std::vector<const geom::Coordinate*>* pts;
public:
- * Returns a list containing a Coordinate from each Polygon, LineString, and Point
- static std::vector<const geom::Coordinate*>* getCoordinates(const geom::Geometry *geom);
+ * Returns a list containing a Coordinate from each Polygon, LineString, and Point
+ static std::vector<const geom::Coordinate*>* getCoordinates(const geom::Geometry* geom);
- ConnectedElementPointFilter(std::vector<const geom::Coordinate*> *newPts)
- pts(newPts)
+ ConnectedElementPointFilter(std::vector<const geom::Coordinate*>* newPts)
+ pts(newPts)
- //void filter_rw(geom::Geometry * /*geom*/) {};
+ //void filter_rw(geom::Geometry * /*geom*/) {};
diff --git a/include/geos/operation/distance/DistanceOp.h b/include/geos/operation/distance/DistanceOp.h
index c9f64b4..e8f45cc 100644
--- a/include/geos/operation/distance/DistanceOp.h
+++ b/include/geos/operation/distance/DistanceOp.h
@@ -34,19 +34,19 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Polygon;
- class LineString;
- class Point;
- class Geometry;
- class CoordinateSequence;
+namespace geom {
+class Coordinate;
+class Polygon;
+class LineString;
+class Point;
+class Geometry;
+class CoordinateSequence;
@@ -74,199 +74,199 @@ namespace distance { // geos::operation::distance
class GEOS_DLL DistanceOp {
public:
- * \brief
- * Compute the distance between the nearest points of two geometries.
- * @param g0 a {@link Geometry}
- * @param g1 another {@link Geometry}
- * @return the distance between the geometries
- * @return 0 if either input geometry is empty
- * @throws IllegalArgumentException if either input geometry is null
- static double distance(const geom::Geometry& g0,
- const geom::Geometry& g1);
- /// @deprecated, use the version taking references
- static double distance(const geom::Geometry *g0,
- const geom::Geometry *g1);
- * \brief
- * Test whether two geometries lie within a given distance of
- * each other.
- * @param distance the distance to test
- * @return true if g0.distance(g1) <= distance
- static bool isWithinDistance(const geom::Geometry& g0,
- const geom::Geometry& g1,
- double distance);
- * Compute the the nearest points of two geometries.
- * The points are presented in the same order as the input Geometries.
- * @return the nearest points in the geometries, ownership to caller.
- * A NULL return means one of the geometries is empty.
- static geom::CoordinateSequence* nearestPoints(
- const geom::Geometry *g0,
- * Compute the the closest points of two geometries.
- * @return the closest points in the geometries, ownership to caller.
- * @deprecated renamed to nearestPoints
- static geom::CoordinateSequence* closestPoints(
- /// @deprecated use the one taking references
- DistanceOp(const geom::Geometry *g0, const geom::Geometry *g1);
- * \brief
- * Constructs a DistanceOp that computes the distance and
- * nearest points between the two specified geometries.
- * @param g0 a Geometry
- * @param g1 a Geometry
- DistanceOp(const geom::Geometry& g0, const geom::Geometry& g1);
- * \brief
- * Constructs a DistanceOp that computes the distance and nearest
- * points between the two specified geometries.
- * @param terminateDistance the distance on which to terminate
- * the search
- DistanceOp(const geom::Geometry& g0, const geom::Geometry& g1,
- double terminateDistance);
- ~DistanceOp();
- * Report the distance between the closest points on the input geometries.
- double distance();
- * Report the coordinates of the closest points in the input geometries.
- * @return a pair of {@link Coordinate}s of the closest points
- * as a newly allocated object (ownership to caller)
- geom::CoordinateSequence* closestPoints();
- * Report the coordinates of the nearest points in the input geometries.
- * @return a pair of {@link Coordinate}s of the nearest points
- geom::CoordinateSequence* nearestPoints();
+ * \brief
+ * Compute the distance between the nearest points of two geometries.
+ * @param g0 a {@link Geometry}
+ * @param g1 another {@link Geometry}
+ * @return the distance between the geometries
+ * @return 0 if either input geometry is empty
+ * @throws IllegalArgumentException if either input geometry is null
+ static double distance(const geom::Geometry& g0,
+ const geom::Geometry& g1);
+ /// @deprecated, use the version taking references
+ static double distance(const geom::Geometry* g0,
+ const geom::Geometry* g1);
+ * \brief
+ * Test whether two geometries lie within a given distance of
+ * each other.
+ * @param distance the distance to test
+ * @return true if g0.distance(g1) <= distance
+ static bool isWithinDistance(const geom::Geometry& g0,
+ const geom::Geometry& g1,
+ double distance);
+ * Compute the the nearest points of two geometries.
+ * The points are presented in the same order as the input Geometries.
+ * @return the nearest points in the geometries, ownership to caller.
+ * A NULL return means one of the geometries is empty.
+ static geom::CoordinateSequence* nearestPoints(
+ const geom::Geometry* g0,
+ * Compute the the closest points of two geometries.
+ * @return the closest points in the geometries, ownership to caller.
+ * @deprecated renamed to nearestPoints
+ static geom::CoordinateSequence* closestPoints(
+ /// @deprecated use the one taking references
+ DistanceOp(const geom::Geometry* g0, const geom::Geometry* g1);
+ * \brief
+ * Constructs a DistanceOp that computes the distance and
+ * nearest points between the two specified geometries.
+ * @param g0 a Geometry
+ * @param g1 a Geometry
+ DistanceOp(const geom::Geometry& g0, const geom::Geometry& g1);
+ * \brief
+ * Constructs a DistanceOp that computes the distance and nearest
+ * points between the two specified geometries.
+ * @param terminateDistance the distance on which to terminate
+ * the search
+ DistanceOp(const geom::Geometry& g0, const geom::Geometry& g1,
+ double terminateDistance);
+ ~DistanceOp();
+ * Report the distance between the closest points on the input geometries.
+ double distance();
+ * Report the coordinates of the closest points in the input geometries.
+ * @return a pair of {@link Coordinate}s of the closest points
+ * as a newly allocated object (ownership to caller)
+ geom::CoordinateSequence* closestPoints();
+ * Report the coordinates of the nearest points in the input geometries.
+ * @return a pair of {@link Coordinate}s of the nearest points
+ geom::CoordinateSequence* nearestPoints();
private:
- * Report the locations of the closest points in the input geometries.
- * The locations are presented in the same order as the input
- * Geometries.
- * @return a pair of {@link GeometryLocation}s for the closest points.
- * Ownership of returned object is left to this instance and
- * it's reference will be alive for the whole lifetime of it.
- * NOTE: this is public in JTS, but we aim at API reduction here...
- std::vector<GeometryLocation*>* nearestLocations();
- // input
- std::array<geom::Geometry const*, 2> geom;
- double terminateDistance;
- // working
- algorithm::PointLocator ptLocator;
- // TODO: use unique_ptr
- std::vector<GeometryLocation*> *minDistanceLocation;
- double minDistance;
- // memory management
- std::vector<geom::Coordinate *> newCoords;
- void updateMinDistance(std::vector<GeometryLocation*>& locGeom,
- bool flip);
- void computeMinDistance();
- void computeContainmentDistance();
- void computeInside(std::vector<GeometryLocation*> *locs,
- const std::vector<const geom::Polygon*>& polys,
- std::vector<GeometryLocation*> *locPtPoly);
- void computeInside(GeometryLocation *ptLoc,
- const geom::Polygon *poly,
- * Computes distance between facets (lines and points)
- * of input geometries.
- void computeFacetDistance();
- void computeMinDistanceLines(
- const std::vector<const geom::LineString*>& lines0,
- const std::vector<const geom::LineString*>& lines1,
- std::vector<GeometryLocation*>& locGeom);
- void computeMinDistancePoints(
- const std::vector<const geom::Point*>& points0,
- const std::vector<const geom::Point*>& points1,
- void computeMinDistanceLinesPoints(
- void computeMinDistance(const geom::LineString *line0,
- const geom::LineString *line1,
- void computeMinDistance(const geom::LineString *line,
- const geom::Point *pt,
+ * Report the locations of the closest points in the input geometries.
+ * The locations are presented in the same order as the input
+ * Geometries.
+ * @return a pair of {@link GeometryLocation}s for the closest points.
+ * Ownership of returned object is left to this instance and
+ * it's reference will be alive for the whole lifetime of it.
+ * NOTE: this is public in JTS, but we aim at API reduction here...
+ std::vector<GeometryLocation*>* nearestLocations();
+ // input
+ std::array<geom::Geometry const*, 2> geom;
+ double terminateDistance;
+ // working
+ algorithm::PointLocator ptLocator;
+ // TODO: use unique_ptr
+ std::vector<GeometryLocation*>* minDistanceLocation;
+ double minDistance;
+ // memory management
+ std::vector<geom::Coordinate*> newCoords;
+ void updateMinDistance(std::vector<GeometryLocation*>& locGeom,
+ bool flip);
+ void computeMinDistance();
+ void computeContainmentDistance();
+ void computeInside(std::vector<GeometryLocation*>* locs,
+ const std::vector<const geom::Polygon*>& polys,
+ std::vector<GeometryLocation*>* locPtPoly);
+ void computeInside(GeometryLocation* ptLoc,
+ const geom::Polygon* poly,
+ * Computes distance between facets (lines and points)
+ * of input geometries.
+ void computeFacetDistance();
+ void computeMinDistanceLines(
+ const std::vector<const geom::LineString*>& lines0,
+ const std::vector<const geom::LineString*>& lines1,
+ std::vector<GeometryLocation*>& locGeom);
+ void computeMinDistancePoints(
+ const std::vector<const geom::Point*>& points0,
+ const std::vector<const geom::Point*>& points1,
+ void computeMinDistanceLinesPoints(
+ void computeMinDistance(const geom::LineString* line0,
+ const geom::LineString* line1,
+ void computeMinDistance(const geom::LineString* line,
+ const geom::Point* pt,
diff --git a/include/geos/operation/distance/FacetSequence.h b/include/geos/operation/distance/FacetSequence.h
index 1dbc667..b3790fc 100644
--- a/include/geos/operation/distance/FacetSequence.h
+++ b/include/geos/operation/distance/FacetSequence.h
@@ -24,41 +24,41 @@
#include <geos/geom/Coordinate.h>
namespace geos {
- class FacetSequence {
- private:
- const geom::CoordinateSequence *pts;
- const size_t start;
- const size_t end;
+class FacetSequence {
+private:
+ const geom::CoordinateSequence* pts;
+ const size_t start;
+ const size_t end;
- /* Unlike JTS, we store the envelope in the FacetSequence so that it has a clear owner. This is
- * helpful when making a tree of FacetSequence objects (FacetSequenceTreeBuilder)
- geom::Envelope env;
+ /* Unlike JTS, we store the envelope in the FacetSequence so that it has a clear owner. This is
+ * helpful when making a tree of FacetSequence objects (FacetSequenceTreeBuilder)
+ geom::Envelope env;
- double computeLineLineDistance(const FacetSequence & facetSeq) const;
+ double computeLineLineDistance(const FacetSequence& facetSeq) const;
- double computePointLineDistance(const geom::Coordinate & pt, const FacetSequence & facetSeq) const;
+ double computePointLineDistance(const geom::Coordinate& pt, const FacetSequence& facetSeq) const;
- void computeEnvelope();
+ void computeEnvelope();
- public:
- const geom::Envelope * getEnvelope() const;
+public:
+ const geom::Envelope* getEnvelope() const;
- const geom::Coordinate * getCoordinate(size_t index) const;
+ const geom::Coordinate* getCoordinate(size_t index) const;
- size_t size() const;
+ size_t size() const;
- bool isPoint() const;
+ bool isPoint() const;
- double distance(const FacetSequence & facetSeq) const;
+ double distance(const FacetSequence& facetSeq) const;
- FacetSequence(const geom::CoordinateSequence *pts, size_t start, size_t end);
+ FacetSequence(const geom::CoordinateSequence* pts, size_t start, size_t end);
#endif //GEOS_OPERATION_DISTANCE_FACETSEQUENCE_H
diff --git a/include/geos/operation/distance/FacetSequenceTreeBuilder.h b/include/geos/operation/distance/FacetSequenceTreeBuilder.h
index 8f4ae54..4dc003d 100644
--- a/include/geos/operation/distance/FacetSequenceTreeBuilder.h
+++ b/include/geos/operation/distance/FacetSequenceTreeBuilder.h
@@ -25,24 +25,24 @@
#include <geos/operation/distance/FacetSequence.h>
namespace geos {
- class GEOS_DLL FacetSequenceTreeBuilder {
- private:
- // 6 seems to be a good facet sequence size
- static const int FACET_SEQUENCE_SIZE = 6;
+class GEOS_DLL FacetSequenceTreeBuilder {
+private:
+ // 6 seems to be a good facet sequence size
+ static const int FACET_SEQUENCE_SIZE = 6;
- // Seems to be better to use a minimum node capacity
- static const int STR_TREE_NODE_CAPACITY = 4;
+ // Seems to be better to use a minimum node capacity
+ static const int STR_TREE_NODE_CAPACITY = 4;
- static void addFacetSequences(const geom::CoordinateSequence* pts, std::vector<FacetSequence*> & sections);
- static std::vector<FacetSequence*> * computeFacetSequences(const geom::Geometry* g);
+ static void addFacetSequences(const geom::CoordinateSequence* pts, std::vector<FacetSequence*>& sections);
+ static std::vector<FacetSequence*>* computeFacetSequences(const geom::Geometry* g);
- public:
- static geos::index::strtree::STRtree* build(const geom::Geometry* g);
+public:
+ static geos::index::strtree::STRtree* build(const geom::Geometry* g);
#endif //GEOS_FACETSEQUENCETREEBUILDER_H
diff --git a/include/geos/operation/distance/GeometryLocation.h b/include/geos/operation/distance/GeometryLocation.h
index f787fd4..a8a3913 100644
--- a/include/geos/operation/distance/GeometryLocation.h
+++ b/include/geos/operation/distance/GeometryLocation.h
@@ -25,9 +25,9 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
@@ -49,67 +49,67 @@ namespace distance { // geos::operation::distance
class GEOS_DLL GeometryLocation {
private:
- const geom::Geometry *component;
- size_t segIndex;
- bool inside_area;
- geom::Coordinate pt;
+ const geom::Geometry* component;
+ size_t segIndex;
+ bool inside_area;
+ geom::Coordinate pt;
public:
- /** \brief
- * A Special value of segmentIndex used for locations
- * inside area geometries.
- * These locations are not located on a segment,
- * and thus do not have an associated segment index.
- static const int INSIDE_AREA = -1;
- /** \brief
- * Constructs a GeometryLocation specifying a point on a geometry,
- * as well as the segment that the point is on (or INSIDE_AREA if
- * the point is not on a segment).
- * @param component the component of the geometry containing the point
- * @param segIndex the segment index of the location, or INSIDE_AREA
- * @param pt the coordinate of the location
- GeometryLocation(const geom::Geometry *component,
- size_t segIndex, const geom::Coordinate &pt);
- /** \brief
- * Constructs a GeometryLocation specifying a point inside an
- * area geometry.
- const geom::Coordinate &pt);
- * Returns the geometry component on (or in) which this location occurs.
- const geom::Geometry* getGeometryComponent();
- * Returns the segment index for this location.
- * If the location is inside an
- * area, the index will have the value INSIDE_AREA;
- * @return the segment index for the location, or INSIDE_AREA
- size_t getSegmentIndex();
- * Returns the geom::Coordinate of this location.
- /** \brief
- * Tests whether this location represents a point
- * inside an area geometry.
- bool isInsideArea();
+ /** \brief
+ * A Special value of segmentIndex used for locations
+ * inside area geometries.
+ * These locations are not located on a segment,
+ * and thus do not have an associated segment index.
+ static const int INSIDE_AREA = -1;
+ /** \brief
+ * Constructs a GeometryLocation specifying a point on a geometry,
+ * as well as the segment that the point is on (or INSIDE_AREA if
+ * the point is not on a segment).
+ * @param component the component of the geometry containing the point
+ * @param segIndex the segment index of the location, or INSIDE_AREA
+ * @param pt the coordinate of the location
+ GeometryLocation(const geom::Geometry* component,
+ size_t segIndex, const geom::Coordinate& pt);
+ /** \brief
+ * Constructs a GeometryLocation specifying a point inside an
+ * area geometry.
+ const geom::Coordinate& pt);
+ * Returns the geometry component on (or in) which this location occurs.
+ const geom::Geometry* getGeometryComponent();
+ * Returns the segment index for this location.
+ * If the location is inside an
+ * area, the index will have the value INSIDE_AREA;
+ * @return the segment index for the location, or INSIDE_AREA
+ size_t getSegmentIndex();
+ * Returns the geom::Coordinate of this location.
+ /** \brief
+ * Tests whether this location represents a point
+ * inside an area geometry.
+ bool isInsideArea();
} // namespace geos::operation::distance
diff --git a/include/geos/operation/distance/IndexedFacetDistance.h b/include/geos/operation/distance/IndexedFacetDistance.h
index 5068b33..257d802 100644
--- a/include/geos/operation/distance/IndexedFacetDistance.h
+++ b/include/geos/operation/distance/IndexedFacetDistance.h
@@ -22,26 +22,26 @@
#include <geos/operation/distance/FacetSequenceTreeBuilder.h>
namespace geos {
- class GEOS_DLL IndexedFacetDistance {
- public:
- IndexedFacetDistance(const geom::Geometry * g) :
- cachedTree(FacetSequenceTreeBuilder::build(g))
+class GEOS_DLL IndexedFacetDistance {
+public:
+ IndexedFacetDistance(const geom::Geometry* g) :
+ cachedTree(FacetSequenceTreeBuilder::build(g))
- static double distance(const geom::Geometry * g1, const geom::Geometry * g2);
+ static double distance(const geom::Geometry* g1, const geom::Geometry* g2);
- double getDistance(const geom::Geometry * g) const;
+ double getDistance(const geom::Geometry* g) const;
- ~IndexedFacetDistance();
+ ~IndexedFacetDistance();
- private:
- std::unique_ptr<geos::index::strtree::STRtree> cachedTree;
+private:
+ std::unique_ptr<geos::index::strtree::STRtree> cachedTree;
#endif //GEOS_INDEXEDFACETDISTANCE_H
diff --git a/include/geos/operation/intersection/Rectangle.h b/include/geos/operation/intersection/Rectangle.h
index 4f51906..8536581 100644
--- a/include/geos/operation/intersection/Rectangle.h
+++ b/include/geos/operation/intersection/Rectangle.h
@@ -24,12 +24,12 @@
namespace geos {
- namespace geom {
- class GeometryFactory;
- class Geometry;
- class Polygon;
- class LinearRing;
+namespace geom {
+class GeometryFactory;
+class Geometry;
+class Polygon;
+class LinearRing;
namespace geos {
@@ -48,157 +48,185 @@ namespace intersection { // geos::operation::intersection
-class GEOS_DLL Rectangle
- public:
- * \brief Construct a clipping rectangle
- * @param x1 x-coordinate of the left edge
- * @param y1 y-coordinate of the bottom edge
- * @param x2 x-coordinate of the right edge
- * @param y2 y-coordinate of the right edge
- * @throws IllegalArgumentException if the rectangle is empty
- Rectangle(double x1, double y1, double x2, double y2);
- * \@return the minimum x-coordinate of the rectangle
- double xmin() const { return xMin; }
- * \@return the minimum y-coordinate of the rectangle
- double ymin() const { return yMin; }
- * \@return the maximum x-coordinate of the rectangle
- double xmax() const { return xMax; }
- * \@return the maximum y-coordinate of the rectangle
- double ymax() const { return yMax; }
- * \@return the rectangle as a polygon geometry
- * Ownership transferred to caller
- geom::Polygon* toPolygon(const geom::GeometryFactory &f) const;
- geom::LinearRing* toLinearRing(const geom::GeometryFactory &f) const;
- * @brief Position with respect to a clipping rectangle
- enum Position
- Inside = 1,
- Outside = 2,
- Left = 4,
- Top = 8,
- Right = 16,
- Bottom = 32,
- TopLeft = Top|Left, // 12
- TopRight = Top|Right, // 24
- BottomLeft = Bottom|Left, // 36
- BottomRight = Bottom|Right // 48
- * @brief Test if the given position is on a {@link Rectangle] edge
- * @param pos {@link Rectangle} {@link Position}
- * @return true, if the position is on an edge
- static bool onEdge(Position pos)
- return (pos > Outside);
- * @brief Test if the given positions are on the same {@link Rectangle} edge
- * @param pos1 {@link Rectangle} {@link Position} of first coordinate
- * @param pos2 {@link Rectangle} {@link Position} of second coordinate
- * @return true, if the positions are on the same edge
- static bool onSameEdge(Position pos1, Position pos2)
- return onEdge(Position(pos1 & pos2));
- * @brief Establish position of coordinate with respect to a {@link Rectangle}
- * @param x x-coordinate
- * @param y y-coordinate
- * @return {@link Position} of the coordinate
- Position position(double x, double y) const
- // We assume the point to be inside and test it first
- if(x>xMin && x<xMax && y>yMin && y<yMax)
- return Inside;
- // Next we assume the point to be outside and test it next
- if(x<xMin || x>xMax || y<yMin || y>yMax)
- return Outside;
- // Slower cases
- unsigned int pos = 0;
- if(x==xMin)
- pos |= Left;
- else if(x==xMax)
- pos |= Right;
- if(y==yMin)
- pos |= Bottom;
- else if(y==yMax)
- pos |= Top;
- return Position(pos);
- * @brief Next edge in clock-wise direction
- * @return next {@Rectangle} {@link Position} in clock-wise direction
- static Position nextEdge(Position pos)
- switch(pos)
- case BottomLeft:
- case Left: return Top;
- case TopLeft:
- case Top: return Right;
- case TopRight:
- case Right: return Bottom;
- case BottomRight:
- case Bottom: return Left;
- /* silences compiler warnings, Inside & Outside are not handled explicitly */
- default: return pos;
- private:
- Rectangle();
- double xMin;
- double yMin;
- double xMax;
- double yMax;
+class GEOS_DLL Rectangle {
+public:
+ * \brief Construct a clipping rectangle
+ * @param x1 x-coordinate of the left edge
+ * @param y1 y-coordinate of the bottom edge
+ * @param x2 x-coordinate of the right edge
+ * @param y2 y-coordinate of the right edge
+ * @throws IllegalArgumentException if the rectangle is empty
+ Rectangle(double x1, double y1, double x2, double y2);
+ * \@return the minimum x-coordinate of the rectangle
+ double
+ xmin() const
+ return xMin;
+ * \@return the minimum y-coordinate of the rectangle
+ double
+ ymin() const
+ return yMin;
+ * \@return the maximum x-coordinate of the rectangle
+ double
+ xmax() const
+ return xMax;
+ * \@return the maximum y-coordinate of the rectangle
+ double
+ ymax() const
+ return yMax;
+ * \@return the rectangle as a polygon geometry
+ * Ownership transferred to caller
+ geom::Polygon* toPolygon(const geom::GeometryFactory& f) const;
+ geom::LinearRing* toLinearRing(const geom::GeometryFactory& f) const;
+ * @brief Position with respect to a clipping rectangle
+ enum Position {
+ Inside = 1,
+ Outside = 2,
+ Left = 4,
+ Top = 8,
+ Right = 16,
+ Bottom = 32,
+ TopLeft = Top | Left, // 12
+ TopRight = Top | Right, // 24
+ BottomLeft = Bottom | Left, // 36
+ BottomRight = Bottom | Right // 48
+ * @brief Test if the given position is on a {@link Rectangle] edge
+ * @param pos {@link Rectangle} {@link Position}
+ * @return true, if the position is on an edge
+ static bool
+ onEdge(Position pos)
+ return (pos > Outside);
+ * @brief Test if the given positions are on the same {@link Rectangle} edge
+ * @param pos1 {@link Rectangle} {@link Position} of first coordinate
+ * @param pos2 {@link Rectangle} {@link Position} of second coordinate
+ * @return true, if the positions are on the same edge
+ static bool
+ onSameEdge(Position pos1, Position pos2)
+ return onEdge(Position(pos1 & pos2));
+ * @brief Establish position of coordinate with respect to a {@link Rectangle}
+ * @param x x-coordinate
+ * @param y y-coordinate
+ * @return {@link Position} of the coordinate
+ Position
+ position(double x, double y) const
+ // We assume the point to be inside and test it first
+ if(x > xMin && x < xMax && y > yMin && y < yMax) {
+ return Inside;
+ // Next we assume the point to be outside and test it next
+ if(x < xMin || x > xMax || y < yMin || y > yMax) {
+ return Outside;
+ // Slower cases
+ unsigned int pos = 0;
+ if(x == xMin) {
+ pos |= Left;
+ else if(x == xMax) {
+ pos |= Right;
+ if(y == yMin) {
+ pos |= Bottom;
+ else if(y == yMax) {
+ pos |= Top;
+ return Position(pos);
+ * @brief Next edge in clock-wise direction
+ * @return next {@Rectangle} {@link Position} in clock-wise direction
+ static Position
+ nextEdge(Position pos)
+ switch(pos) {
+ case BottomLeft:
+ case Left:
+ return Top;
+ case TopLeft:
+ case Top:
+ return Right;
+ case TopRight:
+ case Right:
+ return Bottom;
+ case BottomRight:
+ case Bottom:
+ return Left;
+ /* silences compiler warnings, Inside & Outside are not handled explicitly */
+ default:
+ return pos;
+private:
+ Rectangle();
+ double xMin;
+ double yMin;
+ double xMax;
+ double yMax;
}; // class RectangleIntersection
diff --git a/include/geos/operation/intersection/RectangleIntersection.h b/include/geos/operation/intersection/RectangleIntersection.h
index 673ab27..aff9d03 100644
--- a/include/geos/operation/intersection/RectangleIntersection.h
+++ b/include/geos/operation/intersection/RectangleIntersection.h
@@ -26,24 +26,24 @@
namespace geos {
- namespace geom {
- class Point;
- class MultiPoint;
- class Polygon;
- class MultiPolygon;
- class LineString;
- class MultiLineString;
- class Geometry;
- class GeometryCollection;
- class CoordinateSequenceFactory;
- namespace intersection {
- class Rectangle;
- class RectangleIntersectionBuilder;
+namespace geom {
+class Point;
+class MultiPoint;
+class Polygon;
+class MultiPolygon;
+class LineString;
+class MultiLineString;
+class Geometry;
+class GeometryCollection;
+class CoordinateSequenceFactory;
+namespace intersection {
+class Rectangle;
+class RectangleIntersectionBuilder;
namespace geos {
@@ -71,104 +71,103 @@ namespace intersection { // geos::operation::intersection
* be properly closed, or the algorithm may not terminate.
-class GEOS_DLL RectangleIntersection
- public:
- * \brief Clip geometry with a rectangle
- * @param geom a {@link Geometry}
- * @param rect a {@link Rectangle}
- * @return the clipped geometry
- * @return NULL if the geometry is outside the {@link Rectangle}
- static std::unique_ptr<geom::Geometry> clip(const geom::Geometry & geom,
- const Rectangle & rect);
- * \brief Clip boundary of a geometry with a rectangle
- * Any polygon which intersects the rectangle will be converted to
- * a polyline or a multipolyline - including the holes.
- static std::unique_ptr<geom::Geometry> clipBoundary(const geom::Geometry & geom,
+class GEOS_DLL RectangleIntersection {
+public:
+ * \brief Clip geometry with a rectangle
+ * @param geom a {@link Geometry}
+ * @param rect a {@link Rectangle}
+ * @return the clipped geometry
+ * @return NULL if the geometry is outside the {@link Rectangle}
+ static std::unique_ptr<geom::Geometry> clip(const geom::Geometry& geom,
+ const Rectangle& rect);
+ * \brief Clip boundary of a geometry with a rectangle
+ * Any polygon which intersects the rectangle will be converted to
+ * a polyline or a multipolyline - including the holes.
+ static std::unique_ptr<geom::Geometry> clipBoundary(const geom::Geometry& geom,
private:
- RectangleIntersection(const geom::Geometry& geom, const Rectangle& rect);
+ RectangleIntersection(const geom::Geometry& geom, const Rectangle& rect);
- std::unique_ptr<geom::Geometry> clipBoundary();
+ std::unique_ptr<geom::Geometry> clipBoundary();
- std::unique_ptr<geom::Geometry> clip();
+ std::unique_ptr<geom::Geometry> clip();
- const geom::Geometry &_geom;
- const Rectangle &_rect;
- const geom::GeometryFactory *_gf;
- const geom::CoordinateSequenceFactory *_csf;
+ const geom::Geometry& _geom;
+ const Rectangle& _rect;
+ const geom::GeometryFactory* _gf;
+ const geom::CoordinateSequenceFactory* _csf;
- void clip_geom(const geom::Geometry * g,
- RectangleIntersectionBuilder & parts,
- const Rectangle & rect,
- bool keep_polygons);
+ void clip_geom(const geom::Geometry* g,
+ RectangleIntersectionBuilder& parts,
+ const Rectangle& rect,
+ bool keep_polygons);
- void clip_point(const geom::Point * g,
+ void clip_point(const geom::Point* g,
- void clip_multipoint(const geom::MultiPoint * g,
+ void clip_multipoint(const geom::MultiPoint* g,
- void clip_linestring(const geom::LineString * g,
+ void clip_linestring(const geom::LineString* g,
- void clip_multilinestring(const geom::MultiLineString * g,
+ void clip_multilinestring(const geom::MultiLineString* g,
- void clip_polygon(const geom::Polygon * g,
+ void clip_polygon(const geom::Polygon* g,
- void clip_multipolygon(const geom::MultiPolygon * g,
+ void clip_multipolygon(const geom::MultiPolygon* g,
- void clip_geometrycollection(
- const geom::GeometryCollection * g,
+ void clip_geometrycollection(
+ const geom::GeometryCollection* g,
- void clip_polygon_to_linestrings(const geom::Polygon * g,
+ void clip_polygon_to_linestrings(const geom::Polygon* g,
- void clip_polygon_to_polygons(const geom::Polygon * g,
+ void clip_polygon_to_polygons(const geom::Polygon* g,
- * \brief Clip geometry.
- * Returns true if the geometry was fully inside, and does not output
- * anything to RectangleIntersectionBuilder.
- bool clip_linestring_parts(const geom::LineString * gi,
+ * \brief Clip geometry.
+ * Returns true if the geometry was fully inside, and does not output
+ * anything to RectangleIntersectionBuilder.
+ bool clip_linestring_parts(const geom::LineString* gi,
diff --git a/include/geos/operation/intersection/RectangleIntersectionBuilder.h b/include/geos/operation/intersection/RectangleIntersectionBuilder.h
index 154444b..47383e0 100644
--- a/include/geos/operation/intersection/RectangleIntersectionBuilder.h
+++ b/include/geos/operation/intersection/RectangleIntersectionBuilder.h
@@ -29,19 +29,19 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Geometry;
- class Polygon;
- class LineString;
- class Point;
- class Rectangle;
+namespace geom {
+class Coordinate;
+class Geometry;
+class Polygon;
+class LineString;
+class Point;
+class Rectangle;
namespace geos {
@@ -60,97 +60,96 @@ namespace intersection { // geos::operation::intersection
* intended for public use.
-class GEOS_DLL RectangleIntersectionBuilder
- // Regular users are not supposed to use this utility class.
- friend class RectangleIntersection;
+class GEOS_DLL RectangleIntersectionBuilder {
+ // Regular users are not supposed to use this utility class.
+ friend class RectangleIntersection;
public:
- ~RectangleIntersectionBuilder();
+ ~RectangleIntersectionBuilder();
private:
- * \brief Build the result geometry from partial results and clean up
- std::unique_ptr<geom::Geometry> build();
- * \brief Build polygons from parts left by clipping one
- * 1. Build exterior ring(s) from lines
- * 2. Attach polygons as holes to the exterior ring(s)
- void reconnectPolygons(const Rectangle & rect);
- * Reconnect disjointed parts
- * When we clip a LinearRing we may get multiple linestrings.
- * Often the first and last ones can be reconnected to simplify
- * output.
- * Sample clip with a rectangle 0,0 --> 10,10 without reconnecting:
- * Input: POLYGON ((5 10,0 0,10 0,5 10))
- * Output: MULTILINESTRING ((5 10,0 0),(10 0,5 10))
- * Desired: LINESTRING (10 0,5 10,0 0)
- * TODO: If there is a very sharp spike from inside the rectangle
- * outside, and then back in, it is possible that the
- * intersection points at the edge are equal. In this
- * case we could reconnect the linestrings. The task is
- * the same we're already doing for the 1st/last linestrings,
- * we'd just do it for any adjacent pair as well.
- void reconnect();
- void reverseLines();
- * Export parts to another container
- void release(RectangleIntersectionBuilder & parts);
- // Adding Geometry components
- void add(geom::Polygon * g);
- void add(geom::LineString * g);
- void add(geom::Point * g);
- // Trivial methods
- bool empty() const;
- void clear();
- // Added components
- std::list<geom::Polygon *> polygons;
- std::list<geom::LineString *> lines;
- std::list<geom::Point *> points;
- * \brief Close a ring clockwise along rectangle edges
- * Only the 4 corners and x1,y1 need to be considered. The possible
- * cases are:
- * x1,y1
- * corner1 x1,y1
- * corner1 corner2 x1,y1
- * corner1 corner2 corner3 x1,y1
- * corner1 corner2 corner3 corner4 x1,y1
- void close_boundary(
- std::vector<geom::Coordinate> * ring,
- double x1, double y1,
- double x2, double y2);
- void close_ring(const Rectangle & rect, std::vector<geom::Coordinate> * ring);
- RectangleIntersectionBuilder(const geom::GeometryFactory& f)
- : _gf(f) {}
- const geom::GeometryFactory &_gf;
+ * \brief Build the result geometry from partial results and clean up
+ std::unique_ptr<geom::Geometry> build();
+ * \brief Build polygons from parts left by clipping one
+ * 1. Build exterior ring(s) from lines
+ * 2. Attach polygons as holes to the exterior ring(s)
+ void reconnectPolygons(const Rectangle& rect);
+ * Reconnect disjointed parts
+ * When we clip a LinearRing we may get multiple linestrings.
+ * Often the first and last ones can be reconnected to simplify
+ * output.
+ * Sample clip with a rectangle 0,0 --> 10,10 without reconnecting:
+ * Input: POLYGON ((5 10,0 0,10 0,5 10))
+ * Output: MULTILINESTRING ((5 10,0 0),(10 0,5 10))
+ * Desired: LINESTRING (10 0,5 10,0 0)
+ * TODO: If there is a very sharp spike from inside the rectangle
+ * outside, and then back in, it is possible that the
+ * intersection points at the edge are equal. In this
+ * case we could reconnect the linestrings. The task is
+ * the same we're already doing for the 1st/last linestrings,
+ * we'd just do it for any adjacent pair as well.
+ void reconnect();
+ void reverseLines();
+ * Export parts to another container
+ void release(RectangleIntersectionBuilder& parts);
+ // Adding Geometry components
+ void add(geom::Polygon* g);
+ void add(geom::LineString* g);
+ void add(geom::Point* g);
+ // Trivial methods
+ bool empty() const;
+ void clear();
+ // Added components
+ std::list<geom::Polygon*> polygons;
+ std::list<geom::LineString*> lines;
+ std::list<geom::Point*> points;
+ * \brief Close a ring clockwise along rectangle edges
+ * Only the 4 corners and x1,y1 need to be considered. The possible
+ * cases are:
+ * x1,y1
+ * corner1 x1,y1
+ * corner1 corner2 x1,y1
+ * corner1 corner2 corner3 x1,y1
+ * corner1 corner2 corner3 corner4 x1,y1
+ void close_boundary(
+ std::vector<geom::Coordinate>* ring,
+ double x1, double y1,
+ double x2, double y2);
+ void close_ring(const Rectangle& rect, std::vector<geom::Coordinate>* ring);
+ RectangleIntersectionBuilder(const geom::GeometryFactory& f)
+ : _gf(f) {}
+ const geom::GeometryFactory& _gf;
}; // class RectangleIntersectionBuilder
diff --git a/include/geos/operation/linemerge/EdgeString.h b/include/geos/operation/linemerge/EdgeString.h
index d308e6f..4c69e4c 100644
--- a/include/geos/operation/linemerge/EdgeString.h
+++ b/include/geos/operation/linemerge/EdgeString.h
@@ -31,16 +31,16 @@
namespace geos {
- namespace geom {
- class LineString;
- namespace linemerge {
- class LineMergeDirectedEdge;
+namespace geom {
+class LineString;
+namespace linemerge {
+class LineMergeDirectedEdge;
namespace geos {
@@ -54,29 +54,29 @@ namespace linemerge { // geos::operation::linemerge
class GEOS_DLL EdgeString {
private:
- const geom::GeometryFactory *factory;
- std::vector<LineMergeDirectedEdge*> directedEdges;
- geom::CoordinateSequence *coordinates;
- geom::CoordinateSequence* getCoordinates();
+ const geom::GeometryFactory* factory;
+ std::vector<LineMergeDirectedEdge*> directedEdges;
+ geom::CoordinateSequence* coordinates;
+ geom::CoordinateSequence* getCoordinates();
public:
- * \brief
- * Constructs an EdgeString with the given factory used to
- * convert this EdgeString to a LineString
- EdgeString(const geom::GeometryFactory *newFactory);
+ * \brief
+ * Constructs an EdgeString with the given factory used to
+ * convert this EdgeString to a LineString
+ EdgeString(const geom::GeometryFactory* newFactory);
- ~EdgeString();
+ ~EdgeString();
- * Adds a directed edge which is known to form part of this line.
- void add(LineMergeDirectedEdge *directedEdge);
+ * Adds a directed edge which is known to form part of this line.
+ void add(LineMergeDirectedEdge* directedEdge);
- * Converts this EdgeString into a LineString.
- geom::LineString* toLineString();
+ * Converts this EdgeString into a LineString.
+ geom::LineString* toLineString();
} // namespace geos::operation::linemerge
diff --git a/include/geos/operation/linemerge/LineMergeDirectedEdge.h b/include/geos/operation/linemerge/LineMergeDirectedEdge.h
index f6c003d..a19bd22 100644
--- a/include/geos/operation/linemerge/LineMergeDirectedEdge.h
+++ b/include/geos/operation/linemerge/LineMergeDirectedEdge.h
@@ -25,13 +25,13 @@
namespace geos {
- namespace geom {
- class Coordinate;
- //class LineString;
- namespace planargraph {
- class Node;
+namespace geom {
+class Coordinate;
+//class LineString;
+namespace planargraph {
+class Node;
@@ -46,30 +46,30 @@ namespace linemerge { // geos::operation::linemerge
class GEOS_DLL LineMergeDirectedEdge: public planargraph::DirectedEdge {
public:
- * Constructs a LineMergeDirectedEdge connecting the <code>from</code>
- * node to the <code>to</code> node.
- * @param directionPt
- * specifies this DirectedEdge's direction (given by an
- * imaginary line from the <code>from</code> node to
- * <code>directionPt</code>)
- * @param edgeDirection
- * whether this DirectedEdge's direction is the same as or
- * opposite to that of the parent Edge (if any)
- LineMergeDirectedEdge(planargraph::Node *from,
- planargraph::Node *to,
- const geom::Coordinate& directionPt,
- bool edgeDirection);
+ * Constructs a LineMergeDirectedEdge connecting the <code>from</code>
+ * node to the <code>to</code> node.
+ * @param directionPt
+ * specifies this DirectedEdge's direction (given by an
+ * imaginary line from the <code>from</code> node to
+ * <code>directionPt</code>)
+ * @param edgeDirection
+ * whether this DirectedEdge's direction is the same as or
+ * opposite to that of the parent Edge (if any)
+ LineMergeDirectedEdge(planargraph::Node* from,
+ planargraph::Node* to,
+ const geom::Coordinate& directionPt,
+ bool edgeDirection);
- * Returns the directed edge that starts at this directed edge's end point, or null
- * if there are zero or multiple directed edges starting there.
- * @return
- LineMergeDirectedEdge* getNext();
+ * Returns the directed edge that starts at this directed edge's end point, or null
+ * if there are zero or multiple directed edges starting there.
+ * @return
+ LineMergeDirectedEdge* getNext();
diff --git a/include/geos/operation/linemerge/LineMergeEdge.h b/include/geos/operation/linemerge/LineMergeEdge.h
index 52e7666..c1e7e49 100644
--- a/include/geos/operation/linemerge/LineMergeEdge.h
+++ b/include/geos/operation/linemerge/LineMergeEdge.h
@@ -26,9 +26,9 @@
namespace geos {
- namespace geom {
- class LineString;
+namespace geom {
+class LineString;
@@ -42,18 +42,18 @@ namespace linemerge { // geos::operation::linemerge
class GEOS_DLL LineMergeEdge: public planargraph::Edge {
private:
- const geom::LineString *line;
+ const geom::LineString* line;
public:
- * Constructs a LineMergeEdge with vertices given by the specified
- * LineString.
- LineMergeEdge(const geom::LineString *newLine);
+ * Constructs a LineMergeEdge with vertices given by the specified
+ * LineString.
+ LineMergeEdge(const geom::LineString* newLine);
- * Returns the LineString specifying the vertices of this edge.
- const geom::LineString* getLine() const;
+ * Returns the LineString specifying the vertices of this edge.
+ const geom::LineString* getLine() const;
diff --git a/include/geos/operation/linemerge/LineMergeGraph.h b/include/geos/operation/linemerge/LineMergeGraph.h
index 6c932d1..353894b 100644
--- a/include/geos/operation/linemerge/LineMergeGraph.h
+++ b/include/geos/operation/linemerge/LineMergeGraph.h
@@ -33,15 +33,15 @@
namespace geos {
- namespace geom {
- class LineString;
- class Coordinate;
- class Node;
- class Edge;
- class DirectedEdge;
+namespace geom {
+class LineString;
+class Coordinate;
+class Node;
+class Edge;
+class DirectedEdge;
@@ -60,27 +60,27 @@ class GEOS_DLL LineMergeGraph: public planargraph::PlanarGraph {
private:
- planargraph::Node* getNode(const geom::Coordinate &coordinate);
+ planargraph::Node* getNode(const geom::Coordinate& coordinate);
- std::vector<planargraph::Node*> newNodes;
+ std::vector<planargraph::Node*> newNodes;
- std::vector<planargraph::Edge*> newEdges;
+ std::vector<planargraph::Edge*> newEdges;
- std::vector<planargraph::DirectedEdge*> newDirEdges;
+ std::vector<planargraph::DirectedEdge*> newDirEdges;
public:
- /** \brief
- * Adds an Edge, DirectedEdges, and Nodes for the given
- * LineString representation of an edge.
- * Empty lines or lines with all coordinates equal are not added.
- * @param lineString the linestring to add to the graph
- void addEdge(const geom::LineString *lineString);
- ~LineMergeGraph() override;
+ /** \brief
+ * Adds an Edge, DirectedEdges, and Nodes for the given
+ * LineString representation of an edge.
+ * Empty lines or lines with all coordinates equal are not added.
+ * @param lineString the linestring to add to the graph
+ void addEdge(const geom::LineString* lineString);
+ ~LineMergeGraph() override;
diff --git a/include/geos/operation/linemerge/LineMerger.h b/include/geos/operation/linemerge/LineMerger.h
index 4322771..69b980f 100644
--- a/include/geos/operation/linemerge/LineMerger.h
+++ b/include/geos/operation/linemerge/LineMerger.h
@@ -31,20 +31,20 @@
namespace geos {
- namespace geom {
- class LineString;
- class Geometry;
- class Node;
- class EdgeString;
+namespace geom {
+class LineString;
+class Geometry;
+class Node;
+class EdgeString;
@@ -76,61 +76,61 @@ class GEOS_DLL LineMerger {
private:
- LineMergeGraph graph;
+ LineMergeGraph graph;
- std::vector<geom::LineString*> *mergedLineStrings;
+ std::vector<geom::LineString*>* mergedLineStrings;
- std::vector<EdgeString*> edgeStrings;
+ std::vector<EdgeString*> edgeStrings;
- void merge();
+ void merge();
- void buildEdgeStringsForObviousStartNodes();
+ void buildEdgeStringsForObviousStartNodes();
- void buildEdgeStringsForIsolatedLoops();
+ void buildEdgeStringsForIsolatedLoops();
- void buildEdgeStringsForUnprocessedNodes();
+ void buildEdgeStringsForUnprocessedNodes();
- void buildEdgeStringsForNonDegree2Nodes();
+ void buildEdgeStringsForNonDegree2Nodes();
- void buildEdgeStringsStartingAt(planargraph::Node *node);
+ void buildEdgeStringsStartingAt(planargraph::Node* node);
- EdgeString* buildEdgeStringStartingWith(LineMergeDirectedEdge *start);
+ EdgeString* buildEdgeStringStartingWith(LineMergeDirectedEdge* start);
public:
- LineMerger();
- ~LineMerger();
- * \brief
- * Adds a collection of Geometries to be processed.
- * May be called multiple times.
- * Any dimension of Geometry may be added; the constituent
- * linework will be extracted.
- void add(std::vector<geom::Geometry*> *geometries);
- * \brief
- * Adds a Geometry to be processed.
- void add(const geom::Geometry *geometry);
- * \brief
- * Returns the LineStrings built by the merging process.
- * Ownership of vector _and_ its elements to caller.
- std::vector<geom::LineString*>* getMergedLineStrings();
- void add(const geom::LineString *lineString);
+ LineMerger();
+ ~LineMerger();
+ * \brief
+ * Adds a collection of Geometries to be processed.
+ * May be called multiple times.
+ * Any dimension of Geometry may be added; the constituent
+ * linework will be extracted.
+ void add(std::vector<geom::Geometry*>* geometries);
+ * \brief
+ * Adds a Geometry to be processed.
+ void add(const geom::Geometry* geometry);
+ * \brief
+ * Returns the LineStrings built by the merging process.
+ * Ownership of vector _and_ its elements to caller.
+ std::vector<geom::LineString*>* getMergedLineStrings();
+ void add(const geom::LineString* lineString);
diff --git a/include/geos/operation/linemerge/LineSequencer.h b/include/geos/operation/linemerge/LineSequencer.h
index 03e3813..5c6a9f0 100644
--- a/include/geos/operation/linemerge/LineSequencer.h
+++ b/include/geos/operation/linemerge/LineSequencer.h
@@ -37,16 +37,16 @@
namespace geos {
- namespace geom {
- class Geometry;
- class LineString;
- class Subgraph;
- class Node;
+namespace geom {
+class Geometry;
+class LineString;
+class Subgraph;
+class Node;
@@ -99,189 +99,199 @@ namespace linemerge { // geos::operation::linemerge
class GEOS_DLL LineSequencer {
private:
- typedef std::list<planargraph::DirectedEdge*> DirEdgeList;
- typedef std::vector< DirEdgeList* > Sequences;
- unsigned int lineCount;
- bool isRun;
- std::unique_ptr<geom::Geometry> sequencedGeometry;
- bool isSequenceableVar;
- void addLine(const geom::LineString *lineString);
- void computeSequence();
- Sequences* findSequences();
- DirEdgeList* findSequence(planargraph::Subgraph& graph);
- void delAll( Sequences& );
- /// return a newly allocated LineString
- static geom::LineString* reverse(const geom::LineString *line);
- * Builds a geometry ({@link LineString} or {@link MultiLineString} )
- * representing the sequence.
- * @param sequences
- * a vector of vectors of const planarDirectedEdges
- * with LineMergeEdges as their parent edges.
- * Ownership of container _and_ contents retained by caller.
- * @return the sequenced geometry, possibly NULL
- * if no sequence exists
- geom::Geometry* buildSequencedGeometry(const Sequences& sequences);
- static const planargraph::Node* findLowestDegreeNode(
- const planargraph::Subgraph& graph);
- void addReverseSubpath(const planargraph::DirectedEdge *de,
- DirEdgeList& deList,
- DirEdgeList::iterator lit,
- bool expectedClosed);
- * Finds an {@link DirectedEdge} for an unvisited edge (if any),
- * choosing the dirEdge which preserves orientation, if possible.
- * @param node the node to examine
- * @return the dirEdge found, or <code>null</code>
- * if none were unvisited
- static const planargraph::DirectedEdge* findUnvisitedBestOrientedDE(
- const planargraph::Node* node);
- * Computes a version of the sequence which is optimally
- * oriented relative to the underlying geometry.
- * Heuristics used are:
- * - If the path has a degree-1 node which is the start
- * node of an linestring, use that node as the start of the sequence
- * - If the path has a degree-1 node which is the end
- * node of an linestring, use that node as the end of the sequence
- * - If the sequence has no degree-1 nodes, use any node as the start
- * (NOTE: in this case could orient the sequence according to the
- * majority of the linestring orientations)
- * @param seq a List of planarDirectedEdges
- * @return the oriented sequence, possibly same as input if already
- * oriented
- DirEdgeList* orient(DirEdgeList* seq);
- * Reverse the sequence.
- * This requires reversing the order of the dirEdges, and flipping
- * each dirEdge as well
- * @param seq a List of DirectedEdges, in sequential order
- * @return the reversed sequence
- DirEdgeList* reverse(DirEdgeList& seq);
- * Tests whether a complete unique path exists in a graph
- * using Euler's Theorem.
- * @param graph the subgraph containing the edges
- * @return <code>true</code> if a sequence exists
- bool hasSequence(planargraph::Subgraph& graph);
+ typedef std::list<planargraph::DirectedEdge*> DirEdgeList;
+ typedef std::vector< DirEdgeList* > Sequences;
+ unsigned int lineCount;
+ bool isRun;
+ std::unique_ptr<geom::Geometry> sequencedGeometry;
+ bool isSequenceableVar;
+ void addLine(const geom::LineString* lineString);
+ void computeSequence();
+ Sequences* findSequences();
+ DirEdgeList* findSequence(planargraph::Subgraph& graph);
+ void delAll(Sequences&);
+ /// return a newly allocated LineString
+ static geom::LineString* reverse(const geom::LineString* line);
+ * Builds a geometry ({@link LineString} or {@link MultiLineString} )
+ * representing the sequence.
+ * @param sequences
+ * a vector of vectors of const planarDirectedEdges
+ * with LineMergeEdges as their parent edges.
+ * Ownership of container _and_ contents retained by caller.
+ * @return the sequenced geometry, possibly NULL
+ * if no sequence exists
+ geom::Geometry* buildSequencedGeometry(const Sequences& sequences);
+ static const planargraph::Node* findLowestDegreeNode(
+ const planargraph::Subgraph& graph);
+ void addReverseSubpath(const planargraph::DirectedEdge* de,
+ DirEdgeList& deList,
+ DirEdgeList::iterator lit,
+ bool expectedClosed);
+ * Finds an {@link DirectedEdge} for an unvisited edge (if any),
+ * choosing the dirEdge which preserves orientation, if possible.
+ * @param node the node to examine
+ * @return the dirEdge found, or <code>null</code>
+ * if none were unvisited
+ static const planargraph::DirectedEdge* findUnvisitedBestOrientedDE(
+ const planargraph::Node* node);
+ * Computes a version of the sequence which is optimally
+ * oriented relative to the underlying geometry.
+ * Heuristics used are:
+ * - If the path has a degree-1 node which is the start
+ * node of an linestring, use that node as the start of the sequence
+ * - If the path has a degree-1 node which is the end
+ * node of an linestring, use that node as the end of the sequence
+ * - If the sequence has no degree-1 nodes, use any node as the start
+ * (NOTE: in this case could orient the sequence according to the
+ * majority of the linestring orientations)
+ * @param seq a List of planarDirectedEdges
+ * @return the oriented sequence, possibly same as input if already
+ * oriented
+ DirEdgeList* orient(DirEdgeList* seq);
+ * Reverse the sequence.
+ * This requires reversing the order of the dirEdges, and flipping
+ * each dirEdge as well
+ * @param seq a List of DirectedEdges, in sequential order
+ * @return the reversed sequence
+ DirEdgeList* reverse(DirEdgeList& seq);
+ * Tests whether a complete unique path exists in a graph
+ * using Euler's Theorem.
+ * @param graph the subgraph containing the edges
+ * @return <code>true</code> if a sequence exists
+ bool hasSequence(planargraph::Subgraph& graph);
public:
- static geom::Geometry* sequence(const geom::Geometry& geom)
- LineSequencer sequencer;
- sequencer.add(geom);
- return sequencer.getSequencedLineStrings();
- LineSequencer()
- factory(nullptr),
- lineCount(0),
- isRun(false),
- sequencedGeometry(nullptr),
- isSequenceableVar(false)
- * Tests whether a {@link Geometry} is sequenced correctly.
- * {@llink LineString}s are trivially sequenced.
- * {@link MultiLineString}s are checked for correct sequencing.
- * Otherwise, <code>isSequenced</code> is defined
- * to be <code>true</code> for geometries that are not lineal.
- * @param geom the geometry to test
- * @return true if the geometry is sequenced or is not lineal
- static bool isSequenced(const geom::Geometry* geom);
- * Tests whether the arrangement of linestrings has a valid
- * sequence.
- * @return <code>true</code> if a valid sequence exists.
- bool isSequenceable() {
- computeSequence();
- return isSequenceableVar;
- * Adds a {@link Geometry} to be sequenced.
- * @param geometry the geometry to add
- void add(const geom::Geometry& geometry) {
- geometry.applyComponentFilter(*this);
- template <class TargetContainer>
- void add(TargetContainer& geoms)
- for (typename TargetContainer::const_iterator i = geoms.begin(),
- e = geoms.end(); i != e; ++i)
+ static geom::Geometry*
+ sequence(const geom::Geometry& geom)
+ LineSequencer sequencer;
+ sequencer.add(geom);
+ return sequencer.getSequencedLineStrings();
+ LineSequencer()
+ factory(nullptr),
+ lineCount(0),
+ isRun(false),
+ sequencedGeometry(nullptr),
+ isSequenceableVar(false)
+ * Tests whether a {@link Geometry} is sequenced correctly.
+ * {@llink LineString}s are trivially sequenced.
+ * {@link MultiLineString}s are checked for correct sequencing.
+ * Otherwise, <code>isSequenced</code> is defined
+ * to be <code>true</code> for geometries that are not lineal.
+ * @param geom the geometry to test
+ * @return true if the geometry is sequenced or is not lineal
+ static bool isSequenced(const geom::Geometry* geom);
+ * Tests whether the arrangement of linestrings has a valid
+ * sequence.
+ * @return <code>true</code> if a valid sequence exists.
+ bool
+ isSequenceable()
+ computeSequence();
+ return isSequenceableVar;
+ * Adds a {@link Geometry} to be sequenced.
+ * @param geometry the geometry to add
+ void
+ add(const geom::Geometry& geometry)
+ geometry.applyComponentFilter(*this);
+ template <class TargetContainer>
+ void
+ add(TargetContainer& geoms)
+ for(typename TargetContainer::const_iterator i = geoms.begin(),
+ e = geoms.end(); i != e; ++i) {
+ const geom::Geometry* g = *i;
+ add(*g);
+ * Act as a GeometryComponentFilter so to extract
+ * the linearworks
+ void
+ filter(const geom::Geometry* g)
+ if(const geom::LineString* ls = dynamic_cast<const geom::LineString*>(g)) {
+ addLine(ls);
+ * Returns the LineString or MultiLineString
+ * built by the sequencing process, if one exists.
+ * @param release release ownership of computed Geometry
+ * @return the sequenced linestrings,
+ * or <code>null</code> if a valid sequence
+ * does not exist.
+ geom::Geometry*
+ getSequencedLineStrings(bool release = 1)
- const geom::Geometry* g = *i;
- add(*g);
+ if(release) {
+ return sequencedGeometry.release();
+ else {
+ return sequencedGeometry.get();
- * Act as a GeometryComponentFilter so to extract
- * the linearworks
- void filter(const geom::Geometry* g)
- if (const geom::LineString *ls=dynamic_cast<const geom::LineString *>(g))
- addLine(ls);
- * Returns the LineString or MultiLineString
- * built by the sequencing process, if one exists.
- * @param release release ownership of computed Geometry
- * @return the sequenced linestrings,
- * or <code>null</code> if a valid sequence
- * does not exist.
- geom::Geometry*
- getSequencedLineStrings(bool release=1) {
- if (release) return sequencedGeometry.release();
- else return sequencedGeometry.get();
diff --git a/include/geos/operation/overlay/EdgeSetNoder.h b/include/geos/operation/overlay/EdgeSetNoder.h
index ee633f8..f61438c 100644
--- a/include/geos/operation/overlay/EdgeSetNoder.h
+++ b/include/geos/operation/overlay/EdgeSetNoder.h
@@ -25,12 +25,12 @@
namespace geos {
- namespace geomgraph {
- class Edge;
- namespace algorithm {
- class LineIntersector;
+namespace geomgraph {
+class Edge;
+namespace algorithm {
+class LineIntersector;
namespace geos {
@@ -46,21 +46,22 @@ namespace overlay { // geos::operation::overlay
class GEOS_DLL EdgeSetNoder {
private:
- algorithm::LineIntersector *li;
- std::vector<geomgraph::Edge*>* inputEdges;
+ algorithm::LineIntersector* li;
+ std::vector<geomgraph::Edge*>* inputEdges;
public:
- EdgeSetNoder(algorithm::LineIntersector *newLi)
- li(newLi),
- inputEdges(new std::vector<geomgraph::Edge*>())
+ EdgeSetNoder(algorithm::LineIntersector* newLi)
+ li(newLi),
+ inputEdges(new std::vector<geomgraph::Edge*>())
- ~EdgeSetNoder() {
- delete inputEdges; // TODO: avoid heap allocation
+ ~EdgeSetNoder()
+ delete inputEdges; // TODO: avoid heap allocation
- void addEdges(std::vector<geomgraph::Edge*> *edges);
- std::vector<geomgraph::Edge*>* getNodedEdges();
+ void addEdges(std::vector<geomgraph::Edge*>* edges);
+ std::vector<geomgraph::Edge*>* getNodedEdges();
diff --git a/include/geos/operation/overlay/ElevationMatrix.h b/include/geos/operation/overlay/ElevationMatrix.h
index 02d963e..aa38cde 100644
--- a/include/geos/operation/overlay/ElevationMatrix.h
+++ b/include/geos/operation/overlay/ElevationMatrix.h
@@ -35,16 +35,16 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Geometry;
- namespace operation {
- namespace overlay {
- class ElevationMatrixFilter;
- class ElevationMatrix;
+namespace geom {
+class Coordinate;
+class Geometry;
+namespace operation {
+namespace overlay {
+class ElevationMatrixFilter;
+class ElevationMatrix;
namespace geos {
@@ -58,16 +58,15 @@ namespace overlay { // geos::operation::overlay
* values to the matrix.
* filter_rw is used to actually elevate Geometries.
-class GEOS_DLL ElevationMatrixFilter: public geom::CoordinateFilter
+class GEOS_DLL ElevationMatrixFilter: public geom::CoordinateFilter {
public:
- ElevationMatrixFilter(ElevationMatrix &em);
- ~ElevationMatrixFilter() override;
- void filter_rw(geom::Coordinate *c) const override;
- void filter_ro(const geom::Coordinate *c) override;
+ ElevationMatrixFilter(ElevationMatrix& em);
+ ~ElevationMatrixFilter() override;
+ void filter_rw(geom::Coordinate* c) const override;
+ void filter_ro(const geom::Coordinate* c) override;
private:
- ElevationMatrix &em;
- double avgElevation;
+ ElevationMatrix& em;
+ double avgElevation;
// Declare type as noncopyable
ElevationMatrixFilter(const ElevationMatrixFilter& other) = delete;
@@ -78,29 +77,29 @@ private:
class GEOS_DLL ElevationMatrix {
-friend class ElevationMatrixFilter;
+ friend class ElevationMatrixFilter;
public:
- ElevationMatrix(const geom::Envelope &extent, unsigned int rows,
- unsigned int cols);
- ~ElevationMatrix();
- void add(const geom::Geometry *geom);
- void elevate(geom::Geometry *geom) const;
- // set Z value for each cell w/out one
- double getAvgElevation() const;
- ElevationMatrixCell &getCell(const geom::Coordinate &c);
- const ElevationMatrixCell &getCell(const geom::Coordinate &c) const;
- std::string print() const;
+ ElevationMatrix(const geom::Envelope& extent, unsigned int rows,
+ unsigned int cols);
+ ~ElevationMatrix();
+ void add(const geom::Geometry* geom);
+ void elevate(geom::Geometry* geom) const;
+ // set Z value for each cell w/out one
+ double getAvgElevation() const;
+ ElevationMatrixCell& getCell(const geom::Coordinate& c);
+ const ElevationMatrixCell& getCell(const geom::Coordinate& c) const;
+ std::string print() const;
private:
- ElevationMatrixFilter filter;
- void add(const geom::Coordinate &c);
- unsigned int cols;
- unsigned int rows;
- double cellwidth;
- double cellheight;
- mutable bool avgElevationComputed;
- mutable double avgElevation;
- std::vector<ElevationMatrixCell>cells;
+ ElevationMatrixFilter filter;
+ void add(const geom::Coordinate& c);
+ unsigned int cols;
+ unsigned int rows;
+ double cellwidth;
+ double cellheight;
+ mutable bool avgElevationComputed;
+ mutable double avgElevation;
+ std::vector<ElevationMatrixCell>cells;
} // namespace geos::operation::overlay
diff --git a/include/geos/operation/overlay/ElevationMatrixCell.h b/include/geos/operation/overlay/ElevationMatrixCell.h
index 10f1792..d2235fa 100644
--- a/include/geos/operation/overlay/ElevationMatrixCell.h
+++ b/include/geos/operation/overlay/ElevationMatrixCell.h
@@ -30,9 +30,9 @@
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -42,16 +42,16 @@ namespace overlay { // geos::operation::overlay
class GEOS_DLL ElevationMatrixCell {
public:
- ElevationMatrixCell();
- ~ElevationMatrixCell();
- void add(double z);
- double getAvg(void) const;
- double getTotal(void) const;
+ ElevationMatrixCell();
+ ~ElevationMatrixCell();
+ void add(double z);
+ double getAvg(void) const;
+ double getTotal(void) const;
private:
- std::set<double>zvals;
- double ztot;
+ std::set<double>zvals;
+ double ztot;
diff --git a/include/geos/operation/overlay/LineBuilder.h b/include/geos/operation/overlay/LineBuilder.h
index 387da61..e08dc4c 100644
--- a/include/geos/operation/overlay/LineBuilder.h
+++ b/include/geos/operation/overlay/LineBuilder.h
@@ -32,23 +32,23 @@
namespace geos {
- namespace geom {
- class LineString;
- class Edge;
- class PointLocator;
- class OverlayOp;
+namespace geom {
+class LineString;
+class Edge;
+class PointLocator;
+class OverlayOp;
namespace geos {
@@ -64,69 +64,69 @@ class GEOS_DLL LineBuilder {
public:
- LineBuilder(OverlayOp *newOp,
- const geom::GeometryFactory *newGeometryFactory,
- algorithm::PointLocator *newPtLocator);
- ~LineBuilder();
- * @return a list of the LineStrings in the result of the specified overlay operation
- std::vector<geom::LineString*>* build(OverlayOp::OpCode opCode);
- * Collect line edges which are in the result.
- * Line edges are in the result if they are not part of
- * an area boundary, if they are in the result of the overlay operation,
- * and if they are not covered by a result area.
- * @param de the directed edge to test.
- * @param opCode the overlap operation
- * @param edges the list of included line edges.
- void collectLineEdge(geomgraph::DirectedEdge *de,
- OverlayOp::OpCode opCode,
- std::vector<geomgraph::Edge*>* edges);
+ LineBuilder(OverlayOp* newOp,
+ const geom::GeometryFactory* newGeometryFactory,
+ algorithm::PointLocator* newPtLocator);
+ ~LineBuilder();
+ * @return a list of the LineStrings in the result of the specified overlay operation
+ std::vector<geom::LineString*>* build(OverlayOp::OpCode opCode);
+ * Collect line edges which are in the result.
+ * Line edges are in the result if they are not part of
+ * an area boundary, if they are in the result of the overlay operation,
+ * and if they are not covered by a result area.
+ * @param de the directed edge to test.
+ * @param opCode the overlap operation
+ * @param edges the list of included line edges.
+ void collectLineEdge(geomgraph::DirectedEdge* de,
+ OverlayOp::OpCode opCode,
+ std::vector<geomgraph::Edge*>* edges);
private:
- OverlayOp *op;
- const geom::GeometryFactory *geometryFactory;
- algorithm::PointLocator *ptLocator;
- std::vector<geomgraph::Edge*> lineEdgesList;
- std::vector<geom::LineString*>* resultLineList;
- void findCoveredLineEdges();
- void collectLines(OverlayOp::OpCode opCode);
- void buildLines(OverlayOp::OpCode opCode);
- void labelIsolatedLines(std::vector<geomgraph::Edge*> *edgesList);
- * Collect edges from Area inputs which should be in the result but
- * which have not been included in a result area.
- * This happens ONLY:
- * - during an intersection when the boundaries of two
- * areas touch in a line segment
- * - OR as a result of a dimensional collapse.
- void collectBoundaryTouchEdge(geomgraph::DirectedEdge *de,
- * Label an isolated node with its relationship to the target geometry.
- void labelIsolatedLine(geomgraph::Edge *e, int targetIndex);
- * If the given CoordinateSequence has mixed 3d/2d vertexes
- * set Z for all vertexes missing it.
- * The Z value is interpolated between 3d vertexes and copied
- * from a 3d vertex to the end.
- void propagateZ(geom::CoordinateSequence *cs);
+ OverlayOp* op;
+ const geom::GeometryFactory* geometryFactory;
+ algorithm::PointLocator* ptLocator;
+ std::vector<geomgraph::Edge*> lineEdgesList;
+ std::vector<geom::LineString*>* resultLineList;
+ void findCoveredLineEdges();
+ void collectLines(OverlayOp::OpCode opCode);
+ void buildLines(OverlayOp::OpCode opCode);
+ void labelIsolatedLines(std::vector<geomgraph::Edge*>* edgesList);
+ * Collect edges from Area inputs which should be in the result but
+ * which have not been included in a result area.
+ * This happens ONLY:
+ * - during an intersection when the boundaries of two
+ * areas touch in a line segment
+ * - OR as a result of a dimensional collapse.
+ void collectBoundaryTouchEdge(geomgraph::DirectedEdge* de,
+ * Label an isolated node with its relationship to the target geometry.
+ void labelIsolatedLine(geomgraph::Edge* e, int targetIndex);
+ * If the given CoordinateSequence has mixed 3d/2d vertexes
+ * set Z for all vertexes missing it.
+ * The Z value is interpolated between 3d vertexes and copied
+ * from a 3d vertex to the end.
+ void propagateZ(geom::CoordinateSequence* cs);
diff --git a/include/geos/operation/overlay/MaximalEdgeRing.h b/include/geos/operation/overlay/MaximalEdgeRing.h
index bee9505..3a583ac 100644
--- a/include/geos/operation/overlay/MaximalEdgeRing.h
+++ b/include/geos/operation/overlay/MaximalEdgeRing.h
@@ -27,18 +27,18 @@
namespace geos {
- namespace geom {
- //class EdgeRing;
- class MinimalEdgeRing;
+namespace geom {
+//class EdgeRing;
+class MinimalEdgeRing;
namespace geos {
@@ -67,36 +67,36 @@ class GEOS_DLL MaximalEdgeRing: public geomgraph::EdgeRing {
public:
- MaximalEdgeRing(geomgraph::DirectedEdge *start,
- const geom::GeometryFactory *geometryFactory);
- // throw(const TopologyException &)
+ MaximalEdgeRing(geomgraph::DirectedEdge* start,
+ const geom::GeometryFactory* geometryFactory);
+ // throw(const TopologyException &)
- ~MaximalEdgeRing() override;
+ ~MaximalEdgeRing() override;
- geomgraph::DirectedEdge* getNext(geomgraph::DirectedEdge *de) override;
+ geomgraph::DirectedEdge* getNext(geomgraph::DirectedEdge* de) override;
- void setEdgeRing(geomgraph::DirectedEdge* de, geomgraph::EdgeRing* er) override;
+ void setEdgeRing(geomgraph::DirectedEdge* de, geomgraph::EdgeRing* er) override;
- /// \brief
- /// This function returns a newly allocated vector of
- /// pointers to newly allocated MinimalEdgeRing objects.
- /// @deprecated pass the vector yourself instead
- std::vector<MinimalEdgeRing*>* buildMinimalRings();
+ /// \brief
+ /// This function returns a newly allocated vector of
+ /// pointers to newly allocated MinimalEdgeRing objects.
+ /// @deprecated pass the vector yourself instead
+ std::vector<MinimalEdgeRing*>* buildMinimalRings();
- /// \brief
- /// This function pushes pointers to newly allocated MinimalEdgeRing
- /// objects to the provided vector.
- void buildMinimalRings(std::vector<MinimalEdgeRing*>& minEdgeRings);
- void buildMinimalRings(std::vector<EdgeRing*>& minEdgeRings);
+ /// \brief
+ /// This function pushes pointers to newly allocated MinimalEdgeRing
+ /// objects to the provided vector.
+ void buildMinimalRings(std::vector<MinimalEdgeRing*>& minEdgeRings);
+ void buildMinimalRings(std::vector<EdgeRing*>& minEdgeRings);
- /// \brief
- /// For all nodes in this EdgeRing,
- /// link the DirectedEdges at the node to form minimalEdgeRings
- void linkDirectedEdgesForMinimalEdgeRings();
+ /// \brief
+ /// For all nodes in this EdgeRing,
+ /// link the DirectedEdges at the node to form minimalEdgeRings
+ void linkDirectedEdgesForMinimalEdgeRings();
diff --git a/include/geos/operation/overlay/MinimalEdgeRing.h b/include/geos/operation/overlay/MinimalEdgeRing.h
index d80b70e..74f3abd 100644
--- a/include/geos/operation/overlay/MinimalEdgeRing.h
+++ b/include/geos/operation/overlay/MinimalEdgeRing.h
@@ -30,13 +30,13 @@
namespace geos {
- namespace geom {
- class EdgeRing;
+namespace geom {
+class EdgeRing;
namespace geos {
@@ -57,15 +57,15 @@ class GEOS_DLL MinimalEdgeRing: public geomgraph::EdgeRing {
public:
- MinimalEdgeRing(geomgraph::DirectedEdge *start,
+ MinimalEdgeRing(geomgraph::DirectedEdge* start,
- ~MinimalEdgeRing() override;
+ ~MinimalEdgeRing() override;
- void setEdgeRing(geomgraph::DirectedEdge *de,
- geomgraph::EdgeRing *er) override;
+ geomgraph::EdgeRing* er) override;
diff --git a/include/geos/operation/overlay/MinimalEdgeRing.inl b/include/geos/operation/overlay/MinimalEdgeRing.inl
index 2f60d0c..fd6e5d9 100644
--- a/include/geos/operation/overlay/MinimalEdgeRing.inl
+++ b/include/geos/operation/overlay/MinimalEdgeRing.inl
@@ -7,7 +7,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -30,22 +30,22 @@ namespace operation { // geos::operation
INLINE void
-MinimalEdgeRing::setEdgeRing(geomgraph::DirectedEdge *de, geomgraph::EdgeRing *er)
+MinimalEdgeRing::setEdgeRing(geomgraph::DirectedEdge* de, geomgraph::EdgeRing* er)
- de->setMinEdgeRing(er);
+ de->setMinEdgeRing(er);
INLINE geomgraph::DirectedEdge*
-MinimalEdgeRing::getNext(geomgraph::DirectedEdge *de)
+MinimalEdgeRing::getNext(geomgraph::DirectedEdge* de)
- return de->getNextMin();
+ return de->getNextMin();
INLINE
MinimalEdgeRing::~MinimalEdgeRing()
#if GEOS_DEBUG
- std::cerr << "MinimalEdgeRing[" << this << "] dtor" << std::endl;
+ std::cerr << "MinimalEdgeRing[" << this << "] dtor" << std::endl;
#endif
diff --git a/include/geos/operation/overlay/OverlayNodeFactory.h b/include/geos/operation/overlay/OverlayNodeFactory.h
index bd345b8..1b6b5d0 100644
--- a/include/geos/operation/overlay/OverlayNodeFactory.h
+++ b/include/geos/operation/overlay/OverlayNodeFactory.h
@@ -27,12 +27,12 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Node;
+namespace geom {
+class Coordinate;
+class Node;
namespace geos {
@@ -45,9 +45,9 @@ namespace overlay { // geos::operation::overlay
class GEOS_DLL OverlayNodeFactory: public geomgraph::NodeFactory {
public:
- OverlayNodeFactory():geomgraph::NodeFactory() {}
- geomgraph::Node* createNode(const geom::Coordinate &coord) const override;
- static const geomgraph::NodeFactory &instance();
+ OverlayNodeFactory(): geomgraph::NodeFactory() {}
+ geomgraph::Node* createNode(const geom::Coordinate& coord) const override;
+ static const geomgraph::NodeFactory& instance();
diff --git a/include/geos/operation/overlay/OverlayOp.h b/include/geos/operation/overlay/OverlayOp.h
index b3991c7..2e2445e 100644
--- a/include/geos/operation/overlay/OverlayOp.h
+++ b/include/geos/operation/overlay/OverlayOp.h
@@ -36,25 +36,25 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Coordinate;
- class Envelope;
- class Polygon;
- class LineString;
- class Point;
- class Label;
- class Edge;
- class Node;
+namespace geom {
+class Geometry;
+class Coordinate;
+class Envelope;
+class Polygon;
+class LineString;
+class Point;
+class Label;
+class Edge;
+class Node;
namespace geos {
@@ -70,328 +70,332 @@ class GEOS_DLL OverlayOp: public GeometryGraphOperation {
public:
- /// The spatial functions supported by this class.
- /// These operations implement various boolean combinations of
- /// the resultants of the overlay.
- enum OpCode {
- /// The code for the Intersection overlay operation.
- opINTERSECTION = 1,
- /// The code for the Union overlay operation.
- opUNION = 2,
- /// The code for the Difference overlay operation.
- opDIFFERENCE = 3,
- /// The code for the Symmetric Difference overlay operation.
- opSYMDIFFERENCE = 4
- * Computes an overlay operation for the given geometry arguments.
- * @param geom0 the first geometry argument
- * @param geom1 the second geometry argument
- * @param opCode the code for the desired overlay operation
- * @return the result of the overlay operation
- * @throws TopologyException if a robustness problem is encountered
- static geom::Geometry* overlayOp(const geom::Geometry *geom0,
- const geom::Geometry *geom1,
- OpCode opCode);
- //throw(TopologyException *);
- * Tests whether a point with a given topological {@link Label}
- * relative to two geometries is contained in
- * the result of overlaying the geometries using
- * a given overlay operation.
- * The method handles arguments of {@link Location#NONE} correctly
- * @param label the topological label of the point
- * @param opCode the code for the overlay operation to test
- * @return true if the label locations correspond to the overlayOpCode
- static bool isResultOfOp(const geomgraph::Label& label, OpCode opCode);
- /// This method will handle arguments of Location.NULL correctly
- /// @return true if the locations correspond to the opCode
- static bool isResultOfOp(int loc0, int loc1, OpCode opCode);
- /// Construct an OverlayOp with the given Geometry args.
- /// Ownership of passed args will remain to caller, and
- /// the OverlayOp won't change them in any way.
- OverlayOp(const geom::Geometry *g0, const geom::Geometry *g1);
- ~OverlayOp() override; // FIXME: virtual ?
- * Gets the result of the overlay for a given overlay operation.
- * Note: this method can be called once only.
- * @param overlayOpCode the overlay operation to perform
- * @return the compute result geometry
- geom::Geometry* getResultGeometry(OpCode overlayOpCode);
- // throw(TopologyException *);
- * Gets the graph constructed to compute the overlay.
- * @return the overlay graph
- geomgraph::PlanarGraph& getGraph() { return graph; }
- /** \brief
- * This method is used to decide if a point node should be included
- * in the result or not.
- * @return true if the coord point is covered by a result Line
- * or Area geometry
- bool isCoveredByLA(const geom::Coordinate& coord);
- /** \brief
- * This method is used to decide if an L edge should be included
- * @return true if the coord point is covered by a result Area geometry
- bool isCoveredByA(const geom::Coordinate& coord);
- * @return true if the coord is located in the interior or boundary of
- * a geometry in the list.
+ /// The spatial functions supported by this class.
+ /// These operations implement various boolean combinations of
+ /// the resultants of the overlay.
+ enum OpCode {
+ /// The code for the Intersection overlay operation.
+ opINTERSECTION = 1,
+ /// The code for the Union overlay operation.
+ opUNION = 2,
+ /// The code for the Difference overlay operation.
+ opDIFFERENCE = 3,
+ /// The code for the Symmetric Difference overlay operation.
+ opSYMDIFFERENCE = 4
+ * Computes an overlay operation for the given geometry arguments.
+ * @param geom0 the first geometry argument
+ * @param geom1 the second geometry argument
+ * @param opCode the code for the desired overlay operation
+ * @return the result of the overlay operation
+ * @throws TopologyException if a robustness problem is encountered
+ static geom::Geometry* overlayOp(const geom::Geometry* geom0,
+ const geom::Geometry* geom1,
+ OpCode opCode);
+ //throw(TopologyException *);
+ * Tests whether a point with a given topological {@link Label}
+ * relative to two geometries is contained in
+ * the result of overlaying the geometries using
+ * a given overlay operation.
+ * The method handles arguments of {@link Location#NONE} correctly
+ * @param label the topological label of the point
+ * @param opCode the code for the overlay operation to test
+ * @return true if the label locations correspond to the overlayOpCode
+ static bool isResultOfOp(const geomgraph::Label& label, OpCode opCode);
+ /// This method will handle arguments of Location.NULL correctly
+ /// @return true if the locations correspond to the opCode
+ static bool isResultOfOp(int loc0, int loc1, OpCode opCode);
+ /// Construct an OverlayOp with the given Geometry args.
+ /// Ownership of passed args will remain to caller, and
+ /// the OverlayOp won't change them in any way.
+ OverlayOp(const geom::Geometry* g0, const geom::Geometry* g1);
+ ~OverlayOp() override; // FIXME: virtual ?
+ * Gets the result of the overlay for a given overlay operation.
+ * Note: this method can be called once only.
+ * @param overlayOpCode the overlay operation to perform
+ * @return the compute result geometry
+ geom::Geometry* getResultGeometry(OpCode overlayOpCode);
+ // throw(TopologyException *);
+ * Gets the graph constructed to compute the overlay.
+ * @return the overlay graph
+ geomgraph::PlanarGraph&
+ getGraph()
+ return graph;
+ /** \brief
+ * This method is used to decide if a point node should be included
+ * in the result or not.
+ * @return true if the coord point is covered by a result Line
+ * or Area geometry
+ bool isCoveredByLA(const geom::Coordinate& coord);
+ /** \brief
+ * This method is used to decide if an L edge should be included
+ * @return true if the coord point is covered by a result Area geometry
+ bool isCoveredByA(const geom::Coordinate& coord);
+ * @return true if the coord is located in the interior or boundary of
+ * a geometry in the list.
protected:
- /** \brief
- * Insert an edge from one of the noded input graphs.
- * Checks edges that are inserted to see if an
- * identical edge already exists.
- * If so, the edge is not inserted, but its label is merged
- * with the existing edge.
- void insertUniqueEdge(geomgraph::Edge *e);
+ /** \brief
+ * Insert an edge from one of the noded input graphs.
+ * Checks edges that are inserted to see if an
+ * identical edge already exists.
+ * If so, the edge is not inserted, but its label is merged
+ * with the existing edge.
+ void insertUniqueEdge(geomgraph::Edge* e);
private:
- algorithm::PointLocator ptLocator;
- const geom::GeometryFactory *geomFact;
- geom::Geometry *resultGeom;
- geomgraph::PlanarGraph graph;
- geomgraph::EdgeList edgeList;
- std::vector<geom::Polygon*> *resultPolyList;
- std::vector<geom::LineString*> *resultLineList;
- std::vector<geom::Point*> *resultPointList;
- void computeOverlay(OpCode opCode); // throw(TopologyException *);
- void insertUniqueEdges(std::vector<geomgraph::Edge*> *edges, const geom::Envelope *env=nullptr);
- * If either of the GeometryLocations for the existing label is
- * exactly opposite to the one in the labelToMerge,
- * this indicates a dimensional collapse has happened.
- * In this case, convert the label for that Geometry to a Line label
- //Not needed
- //void checkDimensionalCollapse(geomgraph::Label labelToMerge, geomgraph::Label existingLabel);
- /** \brief
- * Update the labels for edges according to their depths.
- * For each edge, the depths are first normalized.
- * Then, if the depths for the edge are equal,
- * this edge must have collapsed into a line edge.
- * If the depths are not equal, update the label
- * with the locations corresponding to the depths
- * (i.e. a depth of 0 corresponds to a Location of EXTERIOR,
- * a depth of 1 corresponds to INTERIOR)
- void computeLabelsFromDepths();
- /** \brief
- * If edges which have undergone dimensional collapse are found,
- * replace them with a new edge which is a L edge
- void replaceCollapsedEdges();
- /** \brief
- * Copy all nodes from an arg geometry into this graph.
- * The node label in the arg geometry overrides any previously
- * computed label for that argIndex.
- * (E.g. a node may be an intersection node with
- * a previously computed label of BOUNDARY,
- * but in the original arg Geometry it is actually
- * in the interior due to the Boundary Determination Rule)
- void copyPoints(int argIndex, const geom::Envelope *env=nullptr);
- /** \brief
- * Compute initial labelling for all DirectedEdges at each node.
- * In this step, DirectedEdges will acquire a complete labelling
- * (i.e. one with labels for both Geometries)
- * only if they
- * are incident on a node which has edges for both Geometries
- void computeLabelling(); // throw(TopologyException *);
- * For nodes which have edges from only one Geometry incident on them,
- * the previous step will have left their dirEdges with no
- * labelling for the other Geometry.
- * However, the sym dirEdge may have a labelling for the other
- * Geometry, so merge the two labels.
- void mergeSymLabels();
- void updateNodeLabelling();
- * Incomplete nodes are nodes whose labels are incomplete.
- * (e.g. the location for one Geometry is NULL).
- * These are either isolated nodes,
- * or nodes which have edges from only a single Geometry incident
- * on them.
- * Isolated nodes are found because nodes in one graph which
- * don't intersect nodes in the other are not completely
- * labelled by the initial process of adding nodes to the nodeList.
- * To complete the labelling we need to check for nodes that
- * lie in the interior of edges, and in the interior of areas.
- * When each node labelling is completed, the labelling of the
- * incident edges is updated, to complete their labelling as well.
- void labelIncompleteNodes();
- /** \brief
- void labelIncompleteNode(geomgraph::Node *n, int targetIndex);
- /** \brief
- * Find all edges whose label indicates that they are in the result
- * area(s), according to the operation being performed.
- * Since we want polygon shells to be
- * oriented CW, choose dirEdges with the interior of the result
- * on the RHS.
- * Mark them as being in the result.
- * Interior Area edges are the result of dimensional collapses.
- * They do not form part of the result area boundary.
- void findResultAreaEdges(OpCode opCode);
- * If both a dirEdge and its sym are marked as being in the result,
- * cancel them out.
- void cancelDuplicateResultEdges();
- bool isCovered(const geom::Coordinate& coord,
- std::vector<geom::Geometry*> *geomList);
- std::vector<geom::Polygon*> *geomList);
- std::vector<geom::LineString*> *geomList);
- * For empty result, what is the correct geometry type to apply to
- * the empty?
- static geom::Dimension::DimensionType resultDimension(OverlayOp::OpCode overlayOpCode,
- const geom::Geometry *g0, const geom::Geometry *g1);
- * Creates an empty result geometry of the appropriate dimension,
- * based on the given overlay operation and the dimensions of the inputs.
- * The created geometry is always an atomic geometry,
- * not a collection.
- * The empty result is constructed using the following rules:
- * * #opINTERSECTION result has the dimension of the lowest input dimension
- * * #opUNION - result has the dimension of the highest input dimension
- * * #opDIFFERENCE - result has the dimension of the left-hand input
- * * #opSYMDIFFERENCE - result has the dimension of the highest input dimension
- static geom::Geometry* createEmptyResult(
- OverlayOp::OpCode overlayOpCode, const geom::Geometry *a,
- const geom::Geometry *b, const geom::GeometryFactory *geomFact);
- * Build a Geometry containing all Geometries in the given vectors.
- * Takes element's ownership, vector control is left to caller.
- geom::Geometry* computeGeometry(
- std::vector<geom::Point*> *nResultPointList,
- std::vector<geom::LineString*> *nResultLineList,
- std::vector<geom::Polygon*> *nResultPolyList,
- OverlayOp::OpCode opCode);
- /// Caches for memory management
- std::vector<geomgraph::Edge *>dupEdges;
- /** \brief
- * Merge Z values of node with those of the segment or vertex in
- * the given Polygon it is on.
- int mergeZ(geomgraph::Node *n, const geom::Polygon *poly) const;
- * the given LineString it is on.
- * @returns 1 if an intersection is found, 0 otherwise.
- int mergeZ(geomgraph::Node *n, const geom::LineString *line) const;
- * Average Z of input geometries
- double avgz[2];
- bool avgzcomputed[2];
- double getAverageZ(int targetIndex);
- static double getAverageZ(const geom::Polygon *poly);
- ElevationMatrix *elevationMatrix;
- /// Throw TopologyException if an obviously wrong result has
- /// been computed.
- void checkObviouslyWrongResult(OpCode opCode);
+ algorithm::PointLocator ptLocator;
+ const geom::GeometryFactory* geomFact;
+ geom::Geometry* resultGeom;
+ geomgraph::PlanarGraph graph;
+ geomgraph::EdgeList edgeList;
+ std::vector<geom::Polygon*>* resultPolyList;
+ std::vector<geom::Point*>* resultPointList;
+ void computeOverlay(OpCode opCode); // throw(TopologyException *);
+ void insertUniqueEdges(std::vector<geomgraph::Edge*>* edges, const geom::Envelope* env = nullptr);
+ * If either of the GeometryLocations for the existing label is
+ * exactly opposite to the one in the labelToMerge,
+ * this indicates a dimensional collapse has happened.
+ * In this case, convert the label for that Geometry to a Line label
+ //Not needed
+ //void checkDimensionalCollapse(geomgraph::Label labelToMerge, geomgraph::Label existingLabel);
+ /** \brief
+ * Update the labels for edges according to their depths.
+ * For each edge, the depths are first normalized.
+ * Then, if the depths for the edge are equal,
+ * this edge must have collapsed into a line edge.
+ * If the depths are not equal, update the label
+ * with the locations corresponding to the depths
+ * (i.e. a depth of 0 corresponds to a Location of EXTERIOR,
+ * a depth of 1 corresponds to INTERIOR)
+ void computeLabelsFromDepths();
+ /** \brief
+ * If edges which have undergone dimensional collapse are found,
+ * replace them with a new edge which is a L edge
+ void replaceCollapsedEdges();
+ /** \brief
+ * Copy all nodes from an arg geometry into this graph.
+ * The node label in the arg geometry overrides any previously
+ * computed label for that argIndex.
+ * (E.g. a node may be an intersection node with
+ * a previously computed label of BOUNDARY,
+ * but in the original arg Geometry it is actually
+ * in the interior due to the Boundary Determination Rule)
+ void copyPoints(int argIndex, const geom::Envelope* env = nullptr);
+ /** \brief
+ * Compute initial labelling for all DirectedEdges at each node.
+ * In this step, DirectedEdges will acquire a complete labelling
+ * (i.e. one with labels for both Geometries)
+ * only if they
+ * are incident on a node which has edges for both Geometries
+ void computeLabelling(); // throw(TopologyException *);
+ * For nodes which have edges from only one Geometry incident on them,
+ * the previous step will have left their dirEdges with no
+ * labelling for the other Geometry.
+ * However, the sym dirEdge may have a labelling for the other
+ * Geometry, so merge the two labels.
+ void mergeSymLabels();
+ void updateNodeLabelling();
+ * Incomplete nodes are nodes whose labels are incomplete.
+ * (e.g. the location for one Geometry is NULL).
+ * These are either isolated nodes,
+ * or nodes which have edges from only a single Geometry incident
+ * on them.
+ * Isolated nodes are found because nodes in one graph which
+ * don't intersect nodes in the other are not completely
+ * labelled by the initial process of adding nodes to the nodeList.
+ * To complete the labelling we need to check for nodes that
+ * lie in the interior of edges, and in the interior of areas.
+ * When each node labelling is completed, the labelling of the
+ * incident edges is updated, to complete their labelling as well.
+ void labelIncompleteNodes();
+ /** \brief
+ void labelIncompleteNode(geomgraph::Node* n, int targetIndex);
+ /** \brief
+ * Find all edges whose label indicates that they are in the result
+ * area(s), according to the operation being performed.
+ * Since we want polygon shells to be
+ * oriented CW, choose dirEdges with the interior of the result
+ * on the RHS.
+ * Mark them as being in the result.
+ * Interior Area edges are the result of dimensional collapses.
+ * They do not form part of the result area boundary.
+ void findResultAreaEdges(OpCode opCode);
+ * If both a dirEdge and its sym are marked as being in the result,
+ * cancel them out.
+ void cancelDuplicateResultEdges();
+ bool isCovered(const geom::Coordinate& coord,
+ std::vector<geom::Geometry*>* geomList);
+ std::vector<geom::Polygon*>* geomList);
+ std::vector<geom::LineString*>* geomList);
+ * For empty result, what is the correct geometry type to apply to
+ * the empty?
+ static geom::Dimension::DimensionType resultDimension(OverlayOp::OpCode overlayOpCode,
+ const geom::Geometry* g0, const geom::Geometry* g1);
+ * Creates an empty result geometry of the appropriate dimension,
+ * based on the given overlay operation and the dimensions of the inputs.
+ * The created geometry is always an atomic geometry,
+ * not a collection.
+ * The empty result is constructed using the following rules:
+ * * #opINTERSECTION result has the dimension of the lowest input dimension
+ * * #opUNION - result has the dimension of the highest input dimension
+ * * #opDIFFERENCE - result has the dimension of the left-hand input
+ * * #opSYMDIFFERENCE - result has the dimension of the highest input dimension
+ static geom::Geometry* createEmptyResult(
+ OverlayOp::OpCode overlayOpCode, const geom::Geometry* a,
+ const geom::Geometry* b, const geom::GeometryFactory* geomFact);
+ * Build a Geometry containing all Geometries in the given vectors.
+ * Takes element's ownership, vector control is left to caller.
+ geom::Geometry* computeGeometry(
+ std::vector<geom::Point*>* nResultPointList,
+ std::vector<geom::LineString*>* nResultLineList,
+ std::vector<geom::Polygon*>* nResultPolyList,
+ OverlayOp::OpCode opCode);
+ /// Caches for memory management
+ std::vector<geomgraph::Edge*>dupEdges;
+ /** \brief
+ * Merge Z values of node with those of the segment or vertex in
+ * the given Polygon it is on.
+ int mergeZ(geomgraph::Node* n, const geom::Polygon* poly) const;
+ * the given LineString it is on.
+ * @returns 1 if an intersection is found, 0 otherwise.
+ int mergeZ(geomgraph::Node* n, const geom::LineString* line) const;
+ * Average Z of input geometries
+ double avgz[2];
+ bool avgzcomputed[2];
+ double getAverageZ(int targetIndex);
+ static double getAverageZ(const geom::Polygon* poly);
+ ElevationMatrix* elevationMatrix;
+ /// Throw TopologyException if an obviously wrong result has
+ /// been computed.
+ void checkObviouslyWrongResult(OpCode opCode);
@@ -400,18 +404,19 @@ private:
struct overlayOp {
- OverlayOp::OpCode opCode;
+ OverlayOp::OpCode opCode;
- overlayOp(OverlayOp::OpCode code)
- opCode(code)
+ overlayOp(OverlayOp::OpCode code)
+ opCode(code)
- geom::Geometry* operator() (const geom::Geometry* g0,
- const geom::Geometry* g1)
- return OverlayOp::overlayOp(g0, g1, opCode);
+ geom::Geometry*
+ operator()(const geom::Geometry* g0,
+ const geom::Geometry* g1)
+ return OverlayOp::overlayOp(g0, g1, opCode);
diff --git a/include/geos/operation/overlay/PointBuilder.h b/include/geos/operation/overlay/PointBuilder.h
index d85b3ee..86a7765 100644
--- a/include/geos/operation/overlay/PointBuilder.h
+++ b/include/geos/operation/overlay/PointBuilder.h
@@ -29,21 +29,21 @@
// Forward declarations
namespace geos {
- namespace geom {
- class GeometryFactory;
- class Point;
- class Node;
- class OverlayOp;
+namespace geom {
+class GeometryFactory;
+class Point;
+class Node;
+class OverlayOp;
namespace geos {
@@ -56,46 +56,46 @@ namespace overlay { // geos::operation::overlay
class GEOS_DLL PointBuilder {
private:
- OverlayOp *op;
- void extractNonCoveredResultNodes(OverlayOp::OpCode opCode);
- * Converts non-covered nodes to Point objects and adds them to
- * the result.
- * A node is covered if it is contained in another element Geometry
- * with higher dimension (e.g. a node point might be contained in
- * a polygon, in which case the point can be eliminated from
- * the result).
- * @param n the node to test
- void filterCoveredNodeToPoint(const geomgraph::Node *);
- /// Allocated a construction time, but not owned.
- /// Make sure you take ownership of it, getting
- /// it from build()
+ OverlayOp* op;
+ void extractNonCoveredResultNodes(OverlayOp::OpCode opCode);
+ * Converts non-covered nodes to Point objects and adds them to
+ * the result.
+ * A node is covered if it is contained in another element Geometry
+ * with higher dimension (e.g. a node point might be contained in
+ * a polygon, in which case the point can be eliminated from
+ * the result).
+ * @param n the node to test
+ void filterCoveredNodeToPoint(const geomgraph::Node*);
+ /// Allocated a construction time, but not owned.
+ /// Make sure you take ownership of it, getting
+ /// it from build()
public:
- PointBuilder(OverlayOp *newOp,
- algorithm::PointLocator *newPtLocator=nullptr)
- op(newOp),
- geometryFactory(newGeometryFactory),
- resultPointList(new std::vector<geom::Point *>())
+ PointBuilder(OverlayOp* newOp,
+ algorithm::PointLocator* newPtLocator = nullptr)
+ op(newOp),
+ geometryFactory(newGeometryFactory),
+ resultPointList(new std::vector<geom::Point *>())
::geos::ignore_unused_variable_warning(newPtLocator);
- * @return a list of the Points in the result of the specified
- * overlay operation
- std::vector<geom::Point*>* build(OverlayOp::OpCode opCode);
+ * @return a list of the Points in the result of the specified
+ * overlay operation
+ std::vector<geom::Point*>* build(OverlayOp::OpCode opCode);
diff --git a/include/geos/operation/overlay/PolygonBuilder.h b/include/geos/operation/overlay/PolygonBuilder.h
index b976d85..aa9e9a0 100644
--- a/include/geos/operation/overlay/PolygonBuilder.h
+++ b/include/geos/operation/overlay/PolygonBuilder.h
@@ -31,23 +31,23 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Coordinate;
- class EdgeRing;
- class Node;
- class PlanarGraph;
- class MaximalEdgeRing;
+namespace geom {
+class Geometry;
+class Coordinate;
+class EdgeRing;
+class Node;
+class PlanarGraph;
+class MaximalEdgeRing;
namespace geos {
@@ -62,142 +62,142 @@ namespace overlay { // geos::operation::overlay
class GEOS_DLL PolygonBuilder {
public:
- PolygonBuilder(const geom::GeometryFactory *newGeometryFactory);
+ PolygonBuilder(const geom::GeometryFactory* newGeometryFactory);
- ~PolygonBuilder();
+ ~PolygonBuilder();
- * Add a complete graph.
- * The graph is assumed to contain one or more polygons,
- * possibly with holes.
- void add(geomgraph::PlanarGraph *graph);
+ * Add a complete graph.
+ * The graph is assumed to contain one or more polygons,
+ * possibly with holes.
+ void add(geomgraph::PlanarGraph* graph);
- * Add a set of edges and nodes, which form a graph.
- void add(const std::vector<geomgraph::DirectedEdge*> *dirEdges,
- const std::vector<geomgraph::Node*> *nodes);
+ * Add a set of edges and nodes, which form a graph.
+ void add(const std::vector<geomgraph::DirectedEdge*>* dirEdges,
+ const std::vector<geomgraph::Node*>* nodes);
- std::vector<geom::Geometry*>* getPolygons();
+ std::vector<geom::Geometry*>* getPolygons();
private:
- std::vector<geomgraph::EdgeRing*> shellList;
- * For all DirectedEdges in result, form them into MaximalEdgeRings
- * @param maxEdgeRings
- * Formed MaximalEdgeRings will be pushed to this vector.
- * Ownership of the elements is transferred to caller.
- void buildMaximalEdgeRings(
- const std::vector<geomgraph::DirectedEdge*> *dirEdges,
- std::vector<MaximalEdgeRing*> &maxEdgeRings);
- void buildMinimalEdgeRings(
- std::vector<MaximalEdgeRing*> &maxEdgeRings,
- std::vector<geomgraph::EdgeRing*> &newShellList,
- std::vector<geomgraph::EdgeRing*> &freeHoleList,
- std::vector<MaximalEdgeRing*> &edgeRings);
- * This method takes a list of MinimalEdgeRings derived from a
- * MaximalEdgeRing, and tests whether they form a Polygon.
- * This is the case if there is a single shell
- * in the list. In this case the shell is returned.
- * The other possibility is that they are a series of connected
- * holes, in which case no shell is returned.
- * @return the shell geomgraph::EdgeRing, if there is one
- * @return NULL, if all the rings are holes
- geomgraph::EdgeRing* findShell(std::vector<MinimalEdgeRing*>* minEdgeRings);
- * This method assigns the holes for a Polygon (formed from a list of
- * MinimalEdgeRings) to its shell.
- * Determining the holes for a MinimalEdgeRing polygon serves two
- * purposes:
- * - it is faster than using a point-in-polygon check later on.
- * - it ensures correctness, since if the PIP test was used the point
- * chosen might lie on the shell, which might return an incorrect
- * result from the PIP test
- void placePolygonHoles(geomgraph::EdgeRing *shell,
- std::vector<MinimalEdgeRing*> *minEdgeRings);
- * For all rings in the input list,
- * determine whether the ring is a shell or a hole
- * and add it to the appropriate list.
- * Due to the way the DirectedEdges were linked,
- * a ring is a shell if it is oriented CW, a hole otherwise.
- void sortShellsAndHoles(std::vector<MaximalEdgeRing*> &edgeRings,
- std::vector<geomgraph::EdgeRing*> &freeHoleList);
- struct FastPIPRing {
- geomgraph::EdgeRing* edgeRing;
- algorithm::locate::IndexedPointInAreaLocator* pipLocator;
- /** \brief
- * This method determines finds a containing shell for all holes
- * which have not yet been assigned to a shell.
- * These "free" holes should all be <b>properly</b> contained in
- * their parent shells, so it is safe to use the
- * <code>findEdgeRingContaining</code> method.
- * This is the case because any holes which are NOT
- * properly contained (i.e. are connected to their
- * parent shell) would have formed part of a MaximalEdgeRing
- * and been handled in a previous step.
- * @throws TopologyException if a hole cannot be assigned to a shell
- void placeFreeHoles(std::vector<FastPIPRing>& newShellList,
- std::vector<geomgraph::EdgeRing*>& freeHoleList);
- // throw(const TopologyException&)
- /** \brief
- * Find the innermost enclosing shell geomgraph::EdgeRing containing the
- * argument geomgraph::EdgeRing, if any.
- * The innermost enclosing ring is the <i>smallest</i> enclosing ring.
- * The algorithm used depends on the fact that:
- * ring A contains ring B iff envelope(ring A)
- * contains envelope(ring B)
- * This routine is only safe to use if the chosen point of the hole
- * is known to be properly contained in a shell
- * (which is guaranteed to be the case if the hole does not touch
- * its shell)
- * @return containing geomgraph::EdgeRing, if there is one
- * @return NULL if no containing geomgraph::EdgeRing is found
- geomgraph::EdgeRing* findEdgeRingContaining(geomgraph::EdgeRing *testEr,
- std::vector<FastPIPRing>& newShellList);
- std::vector<geom::Geometry*>* computePolygons(
- std::vector<geomgraph::EdgeRing*>& newShellList);
- * Checks the current set of shells (with their associated holes) to
- * see if any of them contain the point.
+ std::vector<geomgraph::EdgeRing*> shellList;
+ * For all DirectedEdges in result, form them into MaximalEdgeRings
+ * @param maxEdgeRings
+ * Formed MaximalEdgeRings will be pushed to this vector.
+ * Ownership of the elements is transferred to caller.
+ void buildMaximalEdgeRings(
+ const std::vector<geomgraph::DirectedEdge*>* dirEdges,
+ std::vector<MaximalEdgeRing*>& maxEdgeRings);
+ void buildMinimalEdgeRings(
+ std::vector<MaximalEdgeRing*>& maxEdgeRings,
+ std::vector<geomgraph::EdgeRing*>& newShellList,
+ std::vector<geomgraph::EdgeRing*>& freeHoleList,
+ std::vector<MaximalEdgeRing*>& edgeRings);
+ * This method takes a list of MinimalEdgeRings derived from a
+ * MaximalEdgeRing, and tests whether they form a Polygon.
+ * This is the case if there is a single shell
+ * in the list. In this case the shell is returned.
+ * The other possibility is that they are a series of connected
+ * holes, in which case no shell is returned.
+ * @return the shell geomgraph::EdgeRing, if there is one
+ * @return NULL, if all the rings are holes
+ geomgraph::EdgeRing* findShell(std::vector<MinimalEdgeRing*>* minEdgeRings);
+ * This method assigns the holes for a Polygon (formed from a list of
+ * MinimalEdgeRings) to its shell.
+ * Determining the holes for a MinimalEdgeRing polygon serves two
+ * purposes:
+ * - it is faster than using a point-in-polygon check later on.
+ * - it ensures correctness, since if the PIP test was used the point
+ * chosen might lie on the shell, which might return an incorrect
+ * result from the PIP test
+ void placePolygonHoles(geomgraph::EdgeRing* shell,
+ std::vector<MinimalEdgeRing*>* minEdgeRings);
+ * For all rings in the input list,
+ * determine whether the ring is a shell or a hole
+ * and add it to the appropriate list.
+ * Due to the way the DirectedEdges were linked,
+ * a ring is a shell if it is oriented CW, a hole otherwise.
+ void sortShellsAndHoles(std::vector<MaximalEdgeRing*>& edgeRings,
+ std::vector<geomgraph::EdgeRing*>& freeHoleList);
+ struct FastPIPRing {
+ geomgraph::EdgeRing* edgeRing;
+ algorithm::locate::IndexedPointInAreaLocator* pipLocator;
+ /** \brief
+ * This method determines finds a containing shell for all holes
+ * which have not yet been assigned to a shell.
+ * These "free" holes should all be <b>properly</b> contained in
+ * their parent shells, so it is safe to use the
+ * <code>findEdgeRingContaining</code> method.
+ * This is the case because any holes which are NOT
+ * properly contained (i.e. are connected to their
+ * parent shell) would have formed part of a MaximalEdgeRing
+ * and been handled in a previous step.
+ * @throws TopologyException if a hole cannot be assigned to a shell
+ void placeFreeHoles(std::vector<FastPIPRing>& newShellList,
+ // throw(const TopologyException&)
+ /** \brief
+ * Find the innermost enclosing shell geomgraph::EdgeRing containing the
+ * argument geomgraph::EdgeRing, if any.
+ * The innermost enclosing ring is the <i>smallest</i> enclosing ring.
+ * The algorithm used depends on the fact that:
+ * ring A contains ring B iff envelope(ring A)
+ * contains envelope(ring B)
+ * This routine is only safe to use if the chosen point of the hole
+ * is known to be properly contained in a shell
+ * (which is guaranteed to be the case if the hole does not touch
+ * its shell)
+ * @return containing geomgraph::EdgeRing, if there is one
+ * @return NULL if no containing geomgraph::EdgeRing is found
+ geomgraph::EdgeRing* findEdgeRingContaining(geomgraph::EdgeRing* testEr,
+ std::vector<FastPIPRing>& newShellList);
+ std::vector<geom::Geometry*>* computePolygons(
+ std::vector<geomgraph::EdgeRing*>& newShellList);
+ * Checks the current set of shells (with their associated holes) to
+ * see if any of them contain the point.
diff --git a/include/geos/operation/overlay/snap/GeometrySnapper.h b/include/geos/operation/overlay/snap/GeometrySnapper.h
index 7b65a67..d984fa7 100644
--- a/include/geos/operation/overlay/snap/GeometrySnapper.h
+++ b/include/geos/operation/overlay/snap/GeometrySnapper.h
@@ -27,12 +27,12 @@
namespace geos {
- namespace geom {
- //class PrecisionModel;
- class Geometry;
- class CoordinateSequence;
- struct GeomPtrPair;
+namespace geom {
+//class PrecisionModel;
+class Geometry;
+class CoordinateSequence;
+struct GeomPtrPair;
namespace geos {
@@ -59,89 +59,89 @@ class GEOS_DLL GeometrySnapper {
public:
- typedef std::unique_ptr<geom::Geometry> GeomPtr;
- * Snaps two geometries together with a given tolerance.
- * @param g0 a geometry to snap
- * @param g1 a geometry to snap
- * @param snapTolerance the tolerance to use
- * @param ret the snapped geometries as a pair of smart pointers
- * (output parameter)
- static void snap(const geom::Geometry& g0,
- const geom::Geometry& g1,
- double snapTolerance, geom::GeomPtrPair& ret);
- static GeomPtr snapToSelf(const geom::Geometry& g0,
- double snapTolerance, bool cleanResult);
- * Creates a new snapper acting on the given geometry
- * @param g the geometry to snap
- GeometrySnapper(const geom::Geometry& g)
- srcGeom(g)
- /** \brief
- * Snaps the vertices in the component {@link LineString}s
- * of the source geometry to the vertices of the given snap geometry
- * with a given snap tolerance
- * @param g a geometry to snap the source to
- * @return a new snapped Geometry
- std::unique_ptr<geom::Geometry> snapTo(const geom::Geometry& g,
- double snapTolerance);
- /** \brief
- * of the source geometry to the vertices of itself
- * with a given snap tolerance and optionally cleaning the result.
- * @param cleanResult clean the result
- std::unique_ptr<geom::Geometry> snapToSelf(double snapTolerance,
- bool cleanResult);
- /** \brief
- * Estimates the snap tolerance for a Geometry, taking into account
- * its precision model.
- * @param g a Geometry
- * @return the estimated snap tolerance
- static double computeOverlaySnapTolerance(const geom::Geometry& g);
- static double computeSizeBasedSnapTolerance(const geom::Geometry& g);
- /** \brief
- * Computes the snap tolerance based on input geometries;
- static double computeOverlaySnapTolerance(const geom::Geometry& g1,
- const geom::Geometry& g2);
+ typedef std::unique_ptr<geom::Geometry> GeomPtr;
+ * Snaps two geometries together with a given tolerance.
+ * @param g0 a geometry to snap
+ * @param g1 a geometry to snap
+ * @param snapTolerance the tolerance to use
+ * @param ret the snapped geometries as a pair of smart pointers
+ * (output parameter)
+ static void snap(const geom::Geometry& g0,
+ const geom::Geometry& g1,
+ double snapTolerance, geom::GeomPtrPair& ret);
+ static GeomPtr snapToSelf(const geom::Geometry& g0,
+ double snapTolerance, bool cleanResult);
+ * Creates a new snapper acting on the given geometry
+ * @param g the geometry to snap
+ GeometrySnapper(const geom::Geometry& g)
+ srcGeom(g)
+ /** \brief
+ * Snaps the vertices in the component {@link LineString}s
+ * of the source geometry to the vertices of the given snap geometry
+ * with a given snap tolerance
+ * @param g a geometry to snap the source to
+ * @return a new snapped Geometry
+ std::unique_ptr<geom::Geometry> snapTo(const geom::Geometry& g,
+ double snapTolerance);
+ /** \brief
+ * of the source geometry to the vertices of itself
+ * with a given snap tolerance and optionally cleaning the result.
+ * @param cleanResult clean the result
+ std::unique_ptr<geom::Geometry> snapToSelf(double snapTolerance,
+ bool cleanResult);
+ /** \brief
+ * Estimates the snap tolerance for a Geometry, taking into account
+ * its precision model.
+ * @param g a Geometry
+ * @return the estimated snap tolerance
+ static double computeOverlaySnapTolerance(const geom::Geometry& g);
+ static double computeSizeBasedSnapTolerance(const geom::Geometry& g);
+ /** \brief
+ * Computes the snap tolerance based on input geometries;
+ static double computeOverlaySnapTolerance(const geom::Geometry& g1,
+ const geom::Geometry& g2);
private:
- // eventually this will be determined from the geometry topology
- //static const double snapTol; // = 0.000001;
+ // eventually this will be determined from the geometry topology
+ //static const double snapTol; // = 0.000001;
- static const double snapPrecisionFactor; // = 10e-10
+ static const double snapPrecisionFactor; // = 10e-10
- const geom::Geometry& srcGeom;
+ const geom::Geometry& srcGeom;
- /// Extract target (unique) coordinates
- std::unique_ptr<geom::Coordinate::ConstVect> extractTargetCoordinates(
- const geom::Geometry& g);
+ /// Extract target (unique) coordinates
+ std::unique_ptr<geom::Coordinate::ConstVect> extractTargetCoordinates(
+ const geom::Geometry& g);
GeometrySnapper(const GeometrySnapper& other) = delete;
diff --git a/include/geos/operation/overlay/snap/LineStringSnapper.h b/include/geos/operation/overlay/snap/LineStringSnapper.h
index 16d50d1..58a07b4 100644
--- a/include/geos/operation/overlay/snap/LineStringSnapper.h
+++ b/include/geos/operation/overlay/snap/LineStringSnapper.h
@@ -28,12 +28,12 @@
namespace geos {
- namespace geom {
- //class CoordinateSequence;
- class CoordinateList;
- class Geometry;
+namespace geom {
+//class CoordinateSequence;
+class CoordinateList;
+class Geometry;
namespace geos {
@@ -52,104 +52,106 @@ class GEOS_DLL LineStringSnapper {
public:
- * Creates a new snapper using the given points
- * as source points to be snapped.
- * @param nSrcPts the points to snap
- * @param nSnapTolerance the snap tolerance to use
- LineStringSnapper(const geom::Coordinate::Vect& nSrcPts,
- double nSnapTol)
- srcPts(nSrcPts),
- snapTolerance(nSnapTol),
- allowSnappingToSourceVertices(false)
- size_t s = srcPts.size();
- isClosed = s < 2 ? false : srcPts[0].equals2D(srcPts[s-1]);
- // Snap points are assumed to be all distinct points (a set would be better, uh ?)
- std::unique_ptr<geom::Coordinate::Vect> snapTo(const geom::Coordinate::ConstVect& snapPts);
- void setAllowSnappingToSourceVertices(bool allow) {
- allowSnappingToSourceVertices = allow;
+ * Creates a new snapper using the given points
+ * as source points to be snapped.
+ * @param nSrcPts the points to snap
+ * @param nSnapTolerance the snap tolerance to use
+ LineStringSnapper(const geom::Coordinate::Vect& nSrcPts,
+ double nSnapTol)
+ srcPts(nSrcPts),
+ snapTolerance(nSnapTol),
+ allowSnappingToSourceVertices(false)
+ size_t s = srcPts.size();
+ isClosed = s < 2 ? false : srcPts[0].equals2D(srcPts[s - 1]);
+ // Snap points are assumed to be all distinct points (a set would be better, uh ?)
+ std::unique_ptr<geom::Coordinate::Vect> snapTo(const geom::Coordinate::ConstVect& snapPts);
+ void
+ setAllowSnappingToSourceVertices(bool allow)
+ allowSnappingToSourceVertices = allow;
private:
- const geom::Coordinate::Vect& srcPts;
- double snapTolerance;
- bool allowSnappingToSourceVertices;
- bool isClosed;
- // Modifies first arg
- void snapVertices(geom::CoordinateList& srcCoords,
- const geom::Coordinate::ConstVect& snapPts);
- // Returns snapPts.end() if no snap point is close enough (within snapTol distance)
- geom::Coordinate::ConstVect::const_iterator findSnapForVertex(const geom::Coordinate& pt,
- /** \brief
- * Snap segments of the source to nearby snap vertices.
- * Source segments are "cracked" at a snap vertex.
- * A single input segment may be snapped several times
- * to different snap vertices.
- * For each distinct snap vertex, at most one source segment
- * is snapped to. This prevents "cracking" multiple segments
- * at the same point, which would likely cause
- * topology collapse when being used on polygonal linework.
- * @param srcCoords the coordinates of the source linestring to be snapped
- * the object will be modified (coords snapped)
- * @param snapPts the target snap vertices */
- void snapSegments(geom::CoordinateList& srcCoords,
- /// \brief
- /// Finds a src segment which snaps to (is close to) the given snap
- /// point.
- /// Only a single segment is selected for snapping.
- /// This prevents multiple segments snapping to the same snap vertex,
- /// which would almost certainly cause invalid geometry
- /// to be created.
- /// (The heuristic approach to snapping used here
- /// is really only appropriate when
- /// snap pts snap to a unique spot on the src geometry.)
- /// Also, if the snap vertex occurs as a vertex in the src
- /// coordinate list, no snapping is performed (may be changed
- /// using setAllowSnappingToSourceVertices).
- /// @param from
- /// an iterator to first point of first segment to be checked
- /// @param too_far
- /// an iterator to last point of last segment to be checked
- /// @returns an iterator to the snapped segment or
- /// too_far if no segment needs snapping
- /// (either none within snapTol distance,
- /// or one found on the snapPt)
- geom::CoordinateList::iterator findSegmentToSnap(
- const geom::Coordinate& snapPt,
- geom::CoordinateList::iterator from,
- geom::CoordinateList::iterator too_far);
- geom::CoordinateList::iterator findVertexToSnap(
+ const geom::Coordinate::Vect& srcPts;
+ double snapTolerance;
+ bool allowSnappingToSourceVertices;
+ bool isClosed;
+ // Modifies first arg
+ void snapVertices(geom::CoordinateList& srcCoords,
+ const geom::Coordinate::ConstVect& snapPts);
+ // Returns snapPts.end() if no snap point is close enough (within snapTol distance)
+ geom::Coordinate::ConstVect::const_iterator findSnapForVertex(const geom::Coordinate& pt,
+ /** \brief
+ * Snap segments of the source to nearby snap vertices.
+ * Source segments are "cracked" at a snap vertex.
+ * A single input segment may be snapped several times
+ * to different snap vertices.
+ * For each distinct snap vertex, at most one source segment
+ * is snapped to. This prevents "cracking" multiple segments
+ * at the same point, which would likely cause
+ * topology collapse when being used on polygonal linework.
+ * @param srcCoords the coordinates of the source linestring to be snapped
+ * the object will be modified (coords snapped)
+ * @param snapPts the target snap vertices */
+ void snapSegments(geom::CoordinateList& srcCoords,
+ /// \brief
+ /// Finds a src segment which snaps to (is close to) the given snap
+ /// point.
+ /// Only a single segment is selected for snapping.
+ /// This prevents multiple segments snapping to the same snap vertex,
+ /// which would almost certainly cause invalid geometry
+ /// to be created.
+ /// (The heuristic approach to snapping used here
+ /// is really only appropriate when
+ /// snap pts snap to a unique spot on the src geometry.)
+ /// Also, if the snap vertex occurs as a vertex in the src
+ /// coordinate list, no snapping is performed (may be changed
+ /// using setAllowSnappingToSourceVertices).
+ /// @param from
+ /// an iterator to first point of first segment to be checked
+ /// @param too_far
+ /// an iterator to last point of last segment to be checked
+ /// @returns an iterator to the snapped segment or
+ /// too_far if no segment needs snapping
+ /// (either none within snapTol distance,
+ /// or one found on the snapPt)
+ geom::CoordinateList::iterator findSegmentToSnap(
+ const geom::Coordinate& snapPt,
+ geom::CoordinateList::iterator from,
+ geom::CoordinateList::iterator too_far);
+ geom::CoordinateList::iterator findVertexToSnap(
LineStringSnapper(const LineStringSnapper& other) = delete;
diff --git a/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h b/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
index fc3f78c..8bda9bb 100644
--- a/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
+++ b/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
@@ -25,9 +25,9 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
namespace geos {
@@ -46,59 +46,58 @@ namespace snap { // geos::operation::overlay::snap
* and invalid overlay computations.
-class SnapIfNeededOverlayOp
+class SnapIfNeededOverlayOp {
public:
- static std::unique_ptr<geom::Geometry>
- overlayOp(const geom::Geometry& g0, const geom::Geometry& g1,
- SnapIfNeededOverlayOp op(g0, g1);
- return op.getResultGeometry(opCode);
- intersection(const geom::Geometry& g0, const geom::Geometry& g1)
- return overlayOp(g0, g1, OverlayOp::opINTERSECTION);
- Union(const geom::Geometry& g0, const geom::Geometry& g1)
- return overlayOp(g0, g1, OverlayOp::opUNION);
- difference(const geom::Geometry& g0, const geom::Geometry& g1)
- return overlayOp(g0, g1, OverlayOp::opDIFFERENCE);
- symDifference(const geom::Geometry& g0, const geom::Geometry& g1)
- return overlayOp(g0, g1, OverlayOp::opSYMDIFFERENCE);
- SnapIfNeededOverlayOp(const geom::Geometry& g1, const geom::Geometry& g2)
- geom0(g1),
- geom1(g2)
- GeomPtr getResultGeometry(OverlayOp::OpCode opCode);
+ static std::unique_ptr<geom::Geometry>
+ overlayOp(const geom::Geometry& g0, const geom::Geometry& g1,
+ SnapIfNeededOverlayOp op(g0, g1);
+ return op.getResultGeometry(opCode);
+ intersection(const geom::Geometry& g0, const geom::Geometry& g1)
+ return overlayOp(g0, g1, OverlayOp::opINTERSECTION);
+ Union(const geom::Geometry& g0, const geom::Geometry& g1)
+ return overlayOp(g0, g1, OverlayOp::opUNION);
+ difference(const geom::Geometry& g0, const geom::Geometry& g1)
+ return overlayOp(g0, g1, OverlayOp::opDIFFERENCE);
+ symDifference(const geom::Geometry& g0, const geom::Geometry& g1)
+ return overlayOp(g0, g1, OverlayOp::opSYMDIFFERENCE);
+ SnapIfNeededOverlayOp(const geom::Geometry& g1, const geom::Geometry& g2)
+ geom0(g1),
+ geom1(g2)
+ GeomPtr getResultGeometry(OverlayOp::OpCode opCode);
private:
- const geom::Geometry& geom0;
- const geom::Geometry& geom1;
+ const geom::Geometry& geom0;
+ const geom::Geometry& geom1;
SnapIfNeededOverlayOp(const SnapIfNeededOverlayOp& other) = delete;
diff --git a/include/geos/operation/overlay/snap/SnapOverlayOp.h b/include/geos/operation/overlay/snap/SnapOverlayOp.h
index 4e12434..5dda6b6 100644
--- a/include/geos/operation/overlay/snap/SnapOverlayOp.h
+++ b/include/geos/operation/overlay/snap/SnapOverlayOp.h
@@ -31,10 +31,10 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
namespace geos {
@@ -53,76 +53,75 @@ namespace snap { // geos::operation::overlay::snap
* if the standard overlay code fails to produce a correct result.
-class GEOS_DLL SnapOverlayOp
+class GEOS_DLL SnapOverlayOp {
public:
- SnapOverlayOp op(g0, g1);
- SnapOverlayOp(const geom::Geometry& g1, const geom::Geometry& g2)
- geom0(g1),
- geom1(g2)
- computeSnapTolerance();
+ SnapOverlayOp op(g0, g1);
+ SnapOverlayOp(const geom::Geometry& g1, const geom::Geometry& g2)
+ geom0(g1),
+ geom1(g2)
+ computeSnapTolerance();
private:
- void computeSnapTolerance();
+ void computeSnapTolerance();
- void snap(geom::GeomPtrPair& ret);
+ void snap(geom::GeomPtrPair& ret);
- void removeCommonBits(const geom::Geometry& geom0,
- const geom::Geometry& geom1,
- geom::GeomPtrPair& ret);
+ void removeCommonBits(const geom::Geometry& geom0,
+ const geom::Geometry& geom1,
+ geom::GeomPtrPair& ret);
- // re-adds common bits to the given geom
- void prepareResult(geom::Geometry& geom);
+ // re-adds common bits to the given geom
+ void prepareResult(geom::Geometry& geom);
- std::unique_ptr<precision::CommonBitsRemover> cbr;
+ std::unique_ptr<precision::CommonBitsRemover> cbr;
SnapOverlayOp(const SnapOverlayOp& other) = delete;
diff --git a/include/geos/operation/overlay/validate/FuzzyPointLocator.h b/include/geos/operation/overlay/validate/FuzzyPointLocator.h
index 4799bd5..1215054 100644
--- a/include/geos/operation/overlay/validate/FuzzyPointLocator.h
+++ b/include/geos/operation/overlay/validate/FuzzyPointLocator.h
@@ -34,10 +34,10 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Coordinate;
+namespace geom {
+class Geometry;
+class Coordinate;
namespace geos {
@@ -59,28 +59,28 @@ class GEOS_DLL FuzzyPointLocator {
public:
- FuzzyPointLocator(const geom::Geometry& geom, double nTolerance);
+ FuzzyPointLocator(const geom::Geometry& geom, double nTolerance);
- geom::Location::Value getLocation(const geom::Coordinate& pt);
+ geom::Location::Value getLocation(const geom::Coordinate& pt);
private:
- const geom::Geometry& g;
+ const geom::Geometry& g;
- double tolerance;
+ double tolerance;
- std::unique_ptr<geom::Geometry> linework;
+ std::unique_ptr<geom::Geometry> linework;
- // this function has been obsoleted
- std::unique_ptr<geom::Geometry> getLineWork(const geom::Geometry& geom);
+ // this function has been obsoleted
+ std::unique_ptr<geom::Geometry> getLineWork(const geom::Geometry& geom);
- /// Extracts linework for polygonal components.
- /// @param g the geometry from which to extract
- /// @return a lineal geometry containing the extracted linework
- std::unique_ptr<geom::Geometry> extractLineWork(const geom::Geometry& geom);
+ /// Extracts linework for polygonal components.
+ /// @param g the geometry from which to extract
+ /// @return a lineal geometry containing the extracted linework
+ std::unique_ptr<geom::Geometry> extractLineWork(const geom::Geometry& geom);
// Declare type as noncopyable
FuzzyPointLocator(const FuzzyPointLocator& other) = delete;
diff --git a/include/geos/operation/overlay/validate/OffsetPointGenerator.h b/include/geos/operation/overlay/validate/OffsetPointGenerator.h
index e854106..98ad584 100644
--- a/include/geos/operation/overlay/validate/OffsetPointGenerator.h
+++ b/include/geos/operation/overlay/validate/OffsetPointGenerator.h
@@ -35,12 +35,12 @@
namespace geos {
- namespace geom {
- //class Geometry;
- //class MultiPoint;
- class LineString;
- //class Coordinate;
+namespace geom {
+//class Geometry;
+//class MultiPoint;
+class LineString;
+//class Coordinate;
namespace geos {
@@ -54,23 +54,23 @@ class GEOS_DLL OffsetPointGenerator {
public:
- OffsetPointGenerator(const geom::Geometry& geom, double offset);
+ OffsetPointGenerator(const geom::Geometry& geom, double offset);
- /// Gets the computed offset points.
- std::unique_ptr< std::vector<geom::Coordinate> > getPoints();
+ /// Gets the computed offset points.
+ std::unique_ptr< std::vector<geom::Coordinate> > getPoints();
private:
- double offsetDistance;
+ double offsetDistance;
- std::unique_ptr< std::vector<geom::Coordinate> > offsetPts;
+ std::unique_ptr< std::vector<geom::Coordinate> > offsetPts;
- void extractPoints(const geom::LineString* line);
+ void extractPoints(const geom::LineString* line);
- void computeOffsets(const geom::Coordinate& p0,
- const geom::Coordinate& p1);
+ void computeOffsets(const geom::Coordinate& p0,
+ const geom::Coordinate& p1);
OffsetPointGenerator(const OffsetPointGenerator& other) = delete;
diff --git a/include/geos/operation/overlay/validate/OverlayResultValidator.h b/include/geos/operation/overlay/validate/OverlayResultValidator.h
index a7380b7..a4127b8 100644
--- a/include/geos/operation/overlay/validate/OverlayResultValidator.h
+++ b/include/geos/operation/overlay/validate/OverlayResultValidator.h
@@ -33,10 +33,10 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Coordinate;
+namespace geom {
+class Geometry;
+class Coordinate;
namespace geos {
@@ -65,56 +65,58 @@ class GEOS_DLL OverlayResultValidator {
public:
- static bool isValid(
- const geom::Geometry& geom0,
- const geom::Geometry& result);
+ static bool isValid(
+ const geom::Geometry& geom0,
+ const geom::Geometry& result);
- OverlayResultValidator(
+ OverlayResultValidator(
- bool isValid(OverlayOp::OpCode opCode);
+ bool isValid(OverlayOp::OpCode opCode);
- geom::Coordinate& getInvalidLocation() {
- return invalidLocation;
+ geom::Coordinate&
+ getInvalidLocation()
+ return invalidLocation;
private:
- double boundaryDistanceTolerance;
+ double boundaryDistanceTolerance;
- const geom::Geometry& g0;
+ const geom::Geometry& g0;
- const geom::Geometry& g1;
+ const geom::Geometry& g1;
- const geom::Geometry& gres;
+ const geom::Geometry& gres;
- FuzzyPointLocator fpl0;
+ FuzzyPointLocator fpl0;
- FuzzyPointLocator fpl1;
+ FuzzyPointLocator fpl1;
- FuzzyPointLocator fplres;
+ FuzzyPointLocator fplres;
- geom::Coordinate invalidLocation;
+ geom::Coordinate invalidLocation;
- std::vector<geom::Coordinate> testCoords;
+ std::vector<geom::Coordinate> testCoords;
- void addTestPts(const geom::Geometry& g);
+ void addTestPts(const geom::Geometry& g);
- void addVertices(const geom::Geometry& g);
+ void addVertices(const geom::Geometry& g);
- bool testValid(OverlayOp::OpCode overlayOp);
+ bool testValid(OverlayOp::OpCode overlayOp);
- bool testValid(OverlayOp::OpCode overlayOp, const geom::Coordinate& pt);
+ bool testValid(OverlayOp::OpCode overlayOp, const geom::Coordinate& pt);
- bool isValidResult(OverlayOp::OpCode overlayOp,
- std::vector<geom::Location::Value>& location);
+ bool isValidResult(OverlayOp::OpCode overlayOp,
+ std::vector<geom::Location::Value>& location);
- static double computeBoundaryDistanceTolerance(
- const geom::Geometry& g0, const geom::Geometry& g1);
+ static double computeBoundaryDistanceTolerance(
+ const geom::Geometry& g0, const geom::Geometry& g1);
OverlayResultValidator(const OverlayResultValidator& other) = delete;
diff --git a/include/geos/operation/polygonize/EdgeRing.h b/include/geos/operation/polygonize/EdgeRing.h
index e620411..42cc4e3 100644
--- a/include/geos/operation/polygonize/EdgeRing.h
+++ b/include/geos/operation/polygonize/EdgeRing.h
@@ -32,18 +32,18 @@
namespace geos {
- namespace geom {
- class LineString;
- class LinearRing;
- class Polygon;
- class Geometry;
- class Coordinate;
- namespace planargraph {
- class DirectedEdge;
+namespace geom {
+class LineString;
+class LinearRing;
+class Polygon;
+class Geometry;
+class Coordinate;
+namespace planargraph {
+class DirectedEdge;
namespace geos {
@@ -56,148 +56,148 @@ namespace polygonize { // geos::operation::polygonize
class GEOS_DLL EdgeRing {
private:
- const geom::GeometryFactory *factory;
+ const geom::GeometryFactory* factory;
- typedef std::vector<const planargraph::DirectedEdge*> DeList;
- DeList deList;
+ typedef std::vector<const planargraph::DirectedEdge*> DeList;
+ DeList deList;
- // cache the following data for efficiency
- geom::LinearRing *ring;
- geom::CoordinateSequence *ringPts;
+ // cache the following data for efficiency
+ geom::LinearRing* ring;
+ geom::CoordinateSequence* ringPts;
- typedef std::vector<geom::Geometry*> GeomVect;
- GeomVect *holes;
+ typedef std::vector<geom::Geometry*> GeomVect;
+ GeomVect* holes;
- /** \brief
- * Computes the list of coordinates which are contained in this ring.
- * The coordinatea are computed once only and cached.
- * @return an array of the Coordinate in this ring
- geom::CoordinateSequence* getCoordinates();
+ /** \brief
+ * Computes the list of coordinates which are contained in this ring.
+ * The coordinatea are computed once only and cached.
+ * @return an array of the Coordinate in this ring
+ geom::CoordinateSequence* getCoordinates();
- static void addEdge(const geom::CoordinateSequence *coords,
- bool isForward,
- geom::CoordinateSequence *coordList);
+ static void addEdge(const geom::CoordinateSequence* coords,
+ bool isForward,
+ geom::CoordinateSequence* coordList);
public:
- * \brief
- * Find the innermost enclosing shell EdgeRing
- * containing the argument EdgeRing, if any.
- * ring A contains ring B iff envelope(ring A) contains envelope(ring B)
- * its shell)
- * @return containing EdgeRing, if there is one
- * @return null if no containing EdgeRing is found
- static EdgeRing* findEdgeRingContaining(
- EdgeRing *testEr,
- std::vector<EdgeRing*> *shellList);
- * \brief
- * Finds a point in a list of points which is not contained in
- * another list of points.
- * @param testPts the CoordinateSequence to test
- * @param pts the CoordinateSequence to test the input points against
- * @return a Coordinate reference from <code>testPts</code> which is
- * not in <code>pts</code>, or <code>Coordinate::nullCoord</code>
- static const geom::Coordinate& ptNotInList(
- const geom::CoordinateSequence *testPts,
- const geom::CoordinateSequence *pts);
- /** \brief
- * Tests whether a given point is in an array of points.
- * Uses a value-based test.
- * @param pt a Coordinate for the test point
- * @param pts an array of Coordinate to test
- * @return <code>true</code> if the point is in the array
- static bool isInList(const geom::Coordinate &pt,
- EdgeRing(const geom::GeometryFactory *newFactory);
- ~EdgeRing();
- /** \brief
- * Adds a DirectedEdge which is known to form part of this ring.
- * @param de the DirectedEdge to add. Ownership to the caller.
- void add(const planargraph::DirectedEdge *de);
- /** \brief
- * Tests whether this ring is a hole.
- * Due to the way the edges in the polyongization graph are linked,
- * a ring is a hole if it is oriented counter-clockwise.
- * @return <code>true</code> if this ring is a hole
- bool isHole();
- /** \brief
- * Adds a hole to the polygon formed by this ring.
- * @param hole the LinearRing forming the hole.
- void addHole(geom::LinearRing *hole);
- /** \brief
- * Computes the Polygon formed by this ring and any contained holes.
- * LinearRings ownership is transferred to returned polygon.
- * Subsequent calls to the function will return NULL.
- * @return the Polygon formed by this ring and its holes.
- geom::Polygon* getPolygon();
- /** \brief
- * Tests if the LinearRing ring formed by this edge ring
- * is topologically valid.
- bool isValid();
- /** \brief
- * Gets the coordinates for this ring as a LineString.
- * Used to return the coordinates in this ring
- * as a valid geometry, when it has been detected that the ring
- * is topologically invalid.
- * @return a LineString containing the coordinates in this ring
- geom::LineString* getLineString();
- /** \brief
- * Returns this ring as a LinearRing, or null if an Exception
- * occurs while creating it (such as a topology problem).
- * Ownership of ring is retained by the object.
- * Details of problems are written to standard output.
- geom::LinearRing* getRingInternal();
- /** \brief
- * Caller gets ownership of ring.
- geom::LinearRing* getRingOwnership();
+ * \brief
+ * Find the innermost enclosing shell EdgeRing
+ * containing the argument EdgeRing, if any.
+ * ring A contains ring B iff envelope(ring A) contains envelope(ring B)
+ * its shell)
+ * @return containing EdgeRing, if there is one
+ * @return null if no containing EdgeRing is found
+ static EdgeRing* findEdgeRingContaining(
+ EdgeRing* testEr,
+ std::vector<EdgeRing*>* shellList);
+ * \brief
+ * Finds a point in a list of points which is not contained in
+ * another list of points.
+ * @param testPts the CoordinateSequence to test
+ * @param pts the CoordinateSequence to test the input points against
+ * @return a Coordinate reference from <code>testPts</code> which is
+ * not in <code>pts</code>, or <code>Coordinate::nullCoord</code>
+ static const geom::Coordinate& ptNotInList(
+ const geom::CoordinateSequence* testPts,
+ const geom::CoordinateSequence* pts);
+ /** \brief
+ * Tests whether a given point is in an array of points.
+ * Uses a value-based test.
+ * @param pt a Coordinate for the test point
+ * @param pts an array of Coordinate to test
+ * @return <code>true</code> if the point is in the array
+ static bool isInList(const geom::Coordinate& pt,
+ EdgeRing(const geom::GeometryFactory* newFactory);
+ ~EdgeRing();
+ /** \brief
+ * Adds a DirectedEdge which is known to form part of this ring.
+ * @param de the DirectedEdge to add. Ownership to the caller.
+ void add(const planargraph::DirectedEdge* de);
+ /** \brief
+ * Tests whether this ring is a hole.
+ * Due to the way the edges in the polyongization graph are linked,
+ * a ring is a hole if it is oriented counter-clockwise.
+ * @return <code>true</code> if this ring is a hole
+ bool isHole();
+ /** \brief
+ * Adds a hole to the polygon formed by this ring.
+ * @param hole the LinearRing forming the hole.
+ void addHole(geom::LinearRing* hole);
+ /** \brief
+ * Computes the Polygon formed by this ring and any contained holes.
+ * LinearRings ownership is transferred to returned polygon.
+ * Subsequent calls to the function will return NULL.
+ * @return the Polygon formed by this ring and its holes.
+ geom::Polygon* getPolygon();
+ /** \brief
+ * Tests if the LinearRing ring formed by this edge ring
+ * is topologically valid.
+ bool isValid();
+ /** \brief
+ * Gets the coordinates for this ring as a LineString.
+ * Used to return the coordinates in this ring
+ * as a valid geometry, when it has been detected that the ring
+ * is topologically invalid.
+ * @return a LineString containing the coordinates in this ring
+ geom::LineString* getLineString();
+ /** \brief
+ * Returns this ring as a LinearRing, or null if an Exception
+ * occurs while creating it (such as a topology problem).
+ * Ownership of ring is retained by the object.
+ * Details of problems are written to standard output.
+ geom::LinearRing* getRingInternal();
+ /** \brief
+ * Caller gets ownership of ring.
+ geom::LinearRing* getRingOwnership();
} // namespace geos::operation::polygonize
diff --git a/include/geos/operation/polygonize/PolygonizeDirectedEdge.h b/include/geos/operation/polygonize/PolygonizeDirectedEdge.h
index 1f9f72d..82daef9 100644
--- a/include/geos/operation/polygonize/PolygonizeDirectedEdge.h
+++ b/include/geos/operation/polygonize/PolygonizeDirectedEdge.h
@@ -27,17 +27,17 @@
namespace geos {
- namespace geom {
- //class LineString;
- class Node;
- namespace operation {
- namespace polygonize {
- class EdgeRing;
+namespace geom {
+//class LineString;
+class Node;
+namespace operation {
+namespace polygonize {
+class EdgeRing;
namespace geos {
@@ -55,66 +55,66 @@ class GEOS_DLL PolygonizeDirectedEdge: public planargraph::DirectedEdge {
private:
- EdgeRing *edgeRing;
+ EdgeRing* edgeRing;
- PolygonizeDirectedEdge *next;
+ PolygonizeDirectedEdge* next;
- long label;
+ long label;
public:
- * \brief
- * Constructs a directed edge connecting the <code>from</code> node
- * to the <code>to</code> node.
- * @param directionPt
- * specifies this DirectedEdge's direction (given by an imaginary
- * line from the <code>from</code> node to <code>directionPt</code>)
- * @param edgeDirection
- * whether this DirectedEdge's direction is the same as or
- * opposite to that of the parent Edge (if any)
- PolygonizeDirectedEdge(planargraph::Node *newFrom,
- planargraph::Node *newTo,
- const geom::Coordinate& newDirectionPt,
- bool nEdgeDirection);
- * Returns the identifier attached to this directed edge.
- long getLabel() const;
- * Attaches an identifier to this directed edge.
- void setLabel(long newLabel);
- * Returns the next directed edge in the EdgeRing that this
- * directed edge is a member of.
- PolygonizeDirectedEdge* getNext() const;
- * Sets the next directed edge in the EdgeRing that this
- void setNext(PolygonizeDirectedEdge *newNext);
- * Returns the ring of directed edges that this directed edge is
- * a member of, or null if the ring has not been set.
- * @see #setRing(EdgeRing)
- bool isInRing() const;
- * Sets the ring of directed edges that this directed edge is
- * a member of.
- void setRing(EdgeRing *newEdgeRing);
+ * \brief
+ * Constructs a directed edge connecting the <code>from</code> node
+ * to the <code>to</code> node.
+ * @param directionPt
+ * specifies this DirectedEdge's direction (given by an imaginary
+ * line from the <code>from</code> node to <code>directionPt</code>)
+ * @param edgeDirection
+ * whether this DirectedEdge's direction is the same as or
+ * opposite to that of the parent Edge (if any)
+ PolygonizeDirectedEdge(planargraph::Node* newFrom,
+ planargraph::Node* newTo,
+ const geom::Coordinate& newDirectionPt,
+ bool nEdgeDirection);
+ * Returns the identifier attached to this directed edge.
+ long getLabel() const;
+ * Attaches an identifier to this directed edge.
+ void setLabel(long newLabel);
+ * Returns the next directed edge in the EdgeRing that this
+ * directed edge is a member of.
+ PolygonizeDirectedEdge* getNext() const;
+ * Sets the next directed edge in the EdgeRing that this
+ void setNext(PolygonizeDirectedEdge* newNext);
+ * Returns the ring of directed edges that this directed edge is
+ * a member of, or null if the ring has not been set.
+ * @see #setRing(EdgeRing)
+ bool isInRing() const;
+ * Sets the ring of directed edges that this directed edge is
+ * a member of.
+ void setRing(EdgeRing* newEdgeRing);
diff --git a/include/geos/operation/polygonize/PolygonizeEdge.h b/include/geos/operation/polygonize/PolygonizeEdge.h
index b308cea..2da144f 100644
--- a/include/geos/operation/polygonize/PolygonizeEdge.h
+++ b/include/geos/operation/polygonize/PolygonizeEdge.h
@@ -27,9 +27,9 @@
namespace geos {
- namespace geom {
- class LineString;
+namespace geom {
+class LineString;
namespace geos {
@@ -43,15 +43,15 @@ namespace polygonize { // geos::operation::polygonize
class GEOS_DLL PolygonizeEdge: public planargraph::Edge {
private:
- // Externally owned
- const geom::LineString *line;
+ // Externally owned
+ const geom::LineString* line;
public:
- // Keep the given pointer (won't do anything to it)
- PolygonizeEdge(const geom::LineString *newLine);
+ // Keep the given pointer (won't do anything to it)
+ PolygonizeEdge(const geom::LineString* newLine);
- // Just return what it was given initially
- const geom::LineString* getLine();
+ // Just return what it was given initially
+ const geom::LineString* getLine();
diff --git a/include/geos/operation/polygonize/PolygonizeGraph.h b/include/geos/operation/polygonize/PolygonizeGraph.h
index 21248a1..a8ada5b 100644
--- a/include/geos/operation/polygonize/PolygonizeGraph.h
+++ b/include/geos/operation/polygonize/PolygonizeGraph.h
@@ -33,23 +33,23 @@
namespace geos {
- namespace geom {
- class LineString;
- class Coordinate;
- class Node;
- class Edge;
- class EdgeRing;
- class PolygonizeDirectedEdge;
+namespace geom {
+class LineString;
+class Coordinate;
+class Node;
+class Edge;
+class EdgeRing;
+class PolygonizeDirectedEdge;
namespace geos {
@@ -70,151 +70,151 @@ class GEOS_DLL PolygonizeGraph: public planargraph::PlanarGraph {
public:
- * \brief
- * Deletes all edges at a node
- static void deleteAllEdges(planargraph::Node *node);
- * \brief
- * Create a new polygonization graph.
- PolygonizeGraph(const geom::GeometryFactory *newFactory);
- * \brief
- * Destroy a polygonization graph.
- ~PolygonizeGraph() override;
- * \brief
- * Add a LineString forming an edge of the polygon graph.
- * @param line the line to add
- void addEdge(const geom::LineString *line);
- * \brief
- * Computes the EdgeRings formed by the edges in this graph.
- * @param edgeRingList : the EdgeRing found by the
- * polygonization process will be pushed here.
- void getEdgeRings(std::vector<EdgeRing*>& edgeRingList);
- * \brief
- * Finds and removes all cut edges from the graph.
- * @param cutLines : the list of the LineString forming the removed
- * cut edges will be pushed here.
- * TODO: document ownership of the returned LineStrings
- void deleteCutEdges(std::vector<const geom::LineString*> &cutLines);
- /** \brief
- * Marks all edges from the graph which are "dangles".
- * Dangles are which are incident on a node with degree 1.
- * This process is recursive, since removing a dangling edge
- * may result in another edge becoming a dangle.
- * In order to handle large recursion depths efficiently,
- * an explicit recursion stack is used
- * @param dangleLines : the LineStrings that formed dangles will
- * be push_back'ed here
- void deleteDangles(std::vector<const geom::LineString*> &dangleLines);
+ * \brief
+ * Deletes all edges at a node
+ static void deleteAllEdges(planargraph::Node* node);
+ * \brief
+ * Create a new polygonization graph.
+ PolygonizeGraph(const geom::GeometryFactory* newFactory);
+ * \brief
+ * Destroy a polygonization graph.
+ ~PolygonizeGraph() override;
+ * \brief
+ * Add a LineString forming an edge of the polygon graph.
+ * @param line the line to add
+ void addEdge(const geom::LineString* line);
+ * \brief
+ * Computes the EdgeRings formed by the edges in this graph.
+ * @param edgeRingList : the EdgeRing found by the
+ * polygonization process will be pushed here.
+ void getEdgeRings(std::vector<EdgeRing*>& edgeRingList);
+ * \brief
+ * Finds and removes all cut edges from the graph.
+ * @param cutLines : the list of the LineString forming the removed
+ * cut edges will be pushed here.
+ * TODO: document ownership of the returned LineStrings
+ void deleteCutEdges(std::vector<const geom::LineString*>& cutLines);
+ /** \brief
+ * Marks all edges from the graph which are "dangles".
+ * Dangles are which are incident on a node with degree 1.
+ * This process is recursive, since removing a dangling edge
+ * may result in another edge becoming a dangle.
+ * In order to handle large recursion depths efficiently,
+ * an explicit recursion stack is used
+ * @param dangleLines : the LineStrings that formed dangles will
+ * be push_back'ed here
+ void deleteDangles(std::vector<const geom::LineString*>& dangleLines);
private:
- static int getDegreeNonDeleted(planargraph::Node *node);
- static int getDegree(planargraph::Node *node, long label);
- planargraph::Node* getNode(const geom::Coordinate& pt);
- void computeNextCWEdges();
- * \brief
- * Convert the maximal edge rings found by the initial graph traversal
- * into the minimal edge rings required by JTS polygon topology rules.
- * @param ringEdges
- * the list of start edges for the edgeRings to convert.
- void convertMaximalToMinimalEdgeRings(
- std::vector<PolygonizeDirectedEdge*> &ringEdges);
- * \brief
- * Finds all nodes in a maximal edgering
- * which are self-intersection nodes
- * @param startDE
- * @param label
- * @param intNodes : intersection nodes found will be pushed here
- * the vector won't be cleared before pushing.
- static void findIntersectionNodes( PolygonizeDirectedEdge *startDE,
- long label, std::vector<planargraph::Node*>& intNodes
- * Finds and labels all edgerings in the graph.
- * The edge rings are labelling with unique integers.
- * The labelling allows detecting cut edges.
- * @param dirEdgesIn a list of the DirectedEdges in the graph
- * @param dirEdgesOut each ring found will be pushed here
- static void findLabeledEdgeRings(
- std::vector<planargraph::DirectedEdge*> &dirEdgesIn,
- std::vector<PolygonizeDirectedEdge*> &dirEdgesOut);
- static void label(std::vector<planargraph::DirectedEdge*> &dirEdges, long label);
- static void computeNextCWEdges(planargraph::Node *node);
- * \brief
- * Computes the next edge pointers going CCW around the given node,
- * for the given edgering label.
- * This algorithm has the effect of converting maximal edgerings
- * into minimal edgerings
- static void computeNextCCWEdges(planargraph::Node *node, long label);
- * \brief
- * Traverse a ring of DirectedEdges, accumulating them into a list.
- * This assumes that all dangling directed edges have been removed
- * from the graph, so that there is always a next dirEdge.
- * @param startDE the DirectedEdge to start traversing at
- * @param edgesInRing : the DirectedEdges that form a ring will
- * be pushed here.
- static void findDirEdgesInRing(PolygonizeDirectedEdge *startDE,
- std::vector<planargraph::DirectedEdge*>& edgesInRing);
- EdgeRing* findEdgeRing(PolygonizeDirectedEdge *startDE);
- /* Tese are for memory management */
- std::vector<planargraph::Edge *> newEdges;
- std::vector<planargraph::DirectedEdge *> newDirEdges;
- std::vector<planargraph::Node *> newNodes;
- std::vector<EdgeRing *> newEdgeRings;
- std::vector<geom::CoordinateSequence *> newCoords;
+ static int getDegreeNonDeleted(planargraph::Node* node);
+ static int getDegree(planargraph::Node* node, long label);
+ planargraph::Node* getNode(const geom::Coordinate& pt);
+ void computeNextCWEdges();
+ * \brief
+ * Convert the maximal edge rings found by the initial graph traversal
+ * into the minimal edge rings required by JTS polygon topology rules.
+ * @param ringEdges
+ * the list of start edges for the edgeRings to convert.
+ void convertMaximalToMinimalEdgeRings(
+ std::vector<PolygonizeDirectedEdge*>& ringEdges);
+ * \brief
+ * Finds all nodes in a maximal edgering
+ * which are self-intersection nodes
+ * @param startDE
+ * @param label
+ * @param intNodes : intersection nodes found will be pushed here
+ * the vector won't be cleared before pushing.
+ static void findIntersectionNodes(PolygonizeDirectedEdge* startDE,
+ long label, std::vector<planargraph::Node*>& intNodes
+ * Finds and labels all edgerings in the graph.
+ * The edge rings are labelling with unique integers.
+ * The labelling allows detecting cut edges.
+ * @param dirEdgesIn a list of the DirectedEdges in the graph
+ * @param dirEdgesOut each ring found will be pushed here
+ static void findLabeledEdgeRings(
+ std::vector<planargraph::DirectedEdge*>& dirEdgesIn,
+ std::vector<PolygonizeDirectedEdge*>& dirEdgesOut);
+ static void label(std::vector<planargraph::DirectedEdge*>& dirEdges, long label);
+ static void computeNextCWEdges(planargraph::Node* node);
+ * \brief
+ * Computes the next edge pointers going CCW around the given node,
+ * for the given edgering label.
+ * This algorithm has the effect of converting maximal edgerings
+ * into minimal edgerings
+ static void computeNextCCWEdges(planargraph::Node* node, long label);
+ * \brief
+ * Traverse a ring of DirectedEdges, accumulating them into a list.
+ * This assumes that all dangling directed edges have been removed
+ * from the graph, so that there is always a next dirEdge.
+ * @param startDE the DirectedEdge to start traversing at
+ * @param edgesInRing : the DirectedEdges that form a ring will
+ * be pushed here.
+ static void findDirEdgesInRing(PolygonizeDirectedEdge* startDE,
+ std::vector<planargraph::DirectedEdge*>& edgesInRing);
+ EdgeRing* findEdgeRing(PolygonizeDirectedEdge* startDE);
+ /* Tese are for memory management */
+ std::vector<planargraph::Edge*> newEdges;
+ std::vector<planargraph::DirectedEdge*> newDirEdges;
+ std::vector<planargraph::Node*> newNodes;
+ std::vector<EdgeRing*> newEdgeRings;
+ std::vector<geom::CoordinateSequence*> newCoords;
diff --git a/include/geos/operation/polygonize/Polygonizer.h b/include/geos/operation/polygonize/Polygonizer.h
index 6064db1..b38bdd2 100644
--- a/include/geos/operation/polygonize/Polygonizer.h
+++ b/include/geos/operation/polygonize/Polygonizer.h
@@ -33,17 +33,17 @@
namespace geos {
- namespace geom {
- class Geometry;
- class LineString;
- class Polygon;
- class EdgeRing;
- class PolygonizeGraph;
+namespace geom {
+class Geometry;
+class LineString;
+class Polygon;
+class EdgeRing;
+class PolygonizeGraph;
namespace geos {
@@ -72,147 +72,147 @@ namespace polygonize { // geos::operation::polygonize
class GEOS_DLL Polygonizer {
private:
- * Add every linear element in a geometry into the polygonizer graph.
- class GEOS_DLL LineStringAdder: public geom::GeometryComponentFilter {
- public:
- Polygonizer *pol;
- LineStringAdder(Polygonizer *p);
- //void filter_rw(geom::Geometry *g);
- void filter_ro(const geom::Geometry * g) override;
- // default factory
- LineStringAdder lineStringAdder;
- * Add a linestring to the graph of polygon edges.
- * @param line the {@link LineString} to add
- void add(const geom::LineString *line);
- * Perform the polygonization, if it has not already been carried out.
- void polygonize();
- void findValidRings(const std::vector<EdgeRing*>& edgeRingList,
- std::vector<EdgeRing*>& validEdgeRingList,
- std::vector<geom::LineString*>& invalidRingList);
- void findShellsAndHoles(const std::vector<EdgeRing*>& edgeRingList);
- static void assignHolesToShells(const std::vector<EdgeRing*>& holeList,
- std::vector<EdgeRing*>& shellList);
- static void assignHoleToShell(EdgeRing *holeER,
+ * Add every linear element in a geometry into the polygonizer graph.
+ class GEOS_DLL LineStringAdder: public geom::GeometryComponentFilter {
+ public:
+ Polygonizer* pol;
+ LineStringAdder(Polygonizer* p);
+ //void filter_rw(geom::Geometry *g);
+ void filter_ro(const geom::Geometry* g) override;
+ // default factory
+ LineStringAdder lineStringAdder;
+ * Add a linestring to the graph of polygon edges.
+ * @param line the {@link LineString} to add
+ void add(const geom::LineString* line);
+ * Perform the polygonization, if it has not already been carried out.
+ void polygonize();
+ void findValidRings(const std::vector<EdgeRing*>& edgeRingList,
+ std::vector<EdgeRing*>& validEdgeRingList,
+ std::vector<geom::LineString*>& invalidRingList);
+ void findShellsAndHoles(const std::vector<EdgeRing*>& edgeRingList);
+ static void assignHolesToShells(const std::vector<EdgeRing*>& holeList,
+ std::vector<EdgeRing*>& shellList);
+ static void assignHoleToShell(EdgeRing* holeER,
protected:
- PolygonizeGraph *graph;
+ PolygonizeGraph* graph;
- // initialize with empty collections, in case nothing is computed
- std::vector<const geom::LineString*> dangles;
- std::vector<const geom::LineString*> cutEdges;
- std::vector<geom::LineString*> invalidRingLines;
+ // initialize with empty collections, in case nothing is computed
+ std::vector<const geom::LineString*> dangles;
+ std::vector<const geom::LineString*> cutEdges;
+ std::vector<geom::LineString*> invalidRingLines;
- std::vector<EdgeRing*> holeList;
- std::vector<EdgeRing*> shellList;
- std::vector<geom::Polygon*> *polyList;
+ std::vector<EdgeRing*> holeList;
+ std::vector<EdgeRing*> shellList;
+ std::vector<geom::Polygon*>* polyList;
public:
- /** \brief
- * Create a polygonizer with the same GeometryFactory
- * as the input Geometry
- Polygonizer();
- ~Polygonizer();
- /** \brief
- * Add a collection of geometries to be polygonized.
- * May be called multiple times.
- * Any dimension of Geometry may be added;
- * the constituent linework will be extracted and used
- * @param geomList a list of Geometry with linework to be polygonized
- void add(std::vector<geom::Geometry*> *geomList);
- /** \brief
- void add(std::vector<const geom::Geometry*> *geomList);
- * Add a geometry to the linework to be polygonized.
- * @param g a Geometry with linework to be polygonized
- void add(geom::Geometry *g);
- void add(const geom::Geometry *g);
- /** \brief
- * Gets the list of polygons formed by the polygonization.
- * Ownership of vector is transferred to caller, subsequent
- * calls will return NULL.
- * @return a collection of Polygons
- std::vector<geom::Polygon*>* getPolygons();
- /** \brief
- * Get the list of dangling lines found during polygonization.
- * @return a (possibly empty) collection of pointers to
- * the input LineStrings which are dangles.
- const std::vector<const geom::LineString*>& getDangles();
- /** \brief
- * Get the list of cut edges found during polygonization.
- * the input LineStrings which are cut edges.
- const std::vector<const geom::LineString*>& getCutEdges();
- /** \brief
- * Get the list of lines forming invalid rings found during
- * polygonization.
- * the input LineStrings which form invalid rings
- const std::vector<geom::LineString*>& getInvalidRingLines();
+ /** \brief
+ * Create a polygonizer with the same GeometryFactory
+ * as the input Geometry
+ Polygonizer();
+ ~Polygonizer();
+ /** \brief
+ * Add a collection of geometries to be polygonized.
+ * May be called multiple times.
+ * Any dimension of Geometry may be added;
+ * the constituent linework will be extracted and used
+ * @param geomList a list of Geometry with linework to be polygonized
+ void add(std::vector<geom::Geometry*>* geomList);
+ /** \brief
+ void add(std::vector<const geom::Geometry*>* geomList);
+ * Add a geometry to the linework to be polygonized.
+ * @param g a Geometry with linework to be polygonized
+ void add(geom::Geometry* g);
+ void add(const geom::Geometry* g);
+ /** \brief
+ * Gets the list of polygons formed by the polygonization.
+ * Ownership of vector is transferred to caller, subsequent
+ * calls will return NULL.
+ * @return a collection of Polygons
+ std::vector<geom::Polygon*>* getPolygons();
+ /** \brief
+ * Get the list of dangling lines found during polygonization.
+ * @return a (possibly empty) collection of pointers to
+ * the input LineStrings which are dangles.
+ const std::vector<const geom::LineString*>& getDangles();
+ /** \brief
+ * Get the list of cut edges found during polygonization.
+ * the input LineStrings which are cut edges.
+ const std::vector<const geom::LineString*>& getCutEdges();
+ /** \brief
+ * Get the list of lines forming invalid rings found during
+ * polygonization.
+ * the input LineStrings which form invalid rings
+ const std::vector<geom::LineString*>& getInvalidRingLines();
// This seems to be needed by GCC 2.95.4
-friend class Polygonizer::LineStringAdder;
+ friend class Polygonizer::LineStringAdder;
diff --git a/include/geos/operation/predicate/RectangleContains.h b/include/geos/operation/predicate/RectangleContains.h
index 0cd78d7..60f39fd 100644
--- a/include/geos/operation/predicate/RectangleContains.h
+++ b/include/geos/operation/predicate/RectangleContains.h
@@ -25,14 +25,14 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Envelope;
- class Geometry;
- class Point;
- class Coordinate;
- class LineString;
- //class Polygon;
+namespace geom {
+class Envelope;
+class Geometry;
+class Point;
+class Coordinate;
+class LineString;
+//class Polygon;
namespace geos {
@@ -52,62 +52,63 @@ class GEOS_DLL RectangleContains {
private:
- const geom::Polygon& rectangle;
- const geom::Envelope& rectEnv;
- bool isContainedInBoundary(const geom::Geometry& geom);
- bool isPointContainedInBoundary(const geom::Point& geom);
- /** \brief
- * Tests if a point is contained in the boundary of the target
- * rectangle.
- * @param pt the point to test
- * @return true if the point is contained in the boundary
- bool isPointContainedInBoundary(const geom::Coordinate &pt);
- /** \brief
- * Tests if a linestring is completely contained in the boundary
- * of the target rectangle.
- * @param line the linestring to test
- * @return true if the linestring is contained in the boundary
- bool isLineStringContainedInBoundary(const geom::LineString &line);
- /** \brief
- * Tests if a line segment is contained in the boundary of the
- * target rectangle.
- * @param p0 an endpoint of the segment
- * @param p1 an endpoint of the segment
- * @return true if the line segment is contained in the boundary
- bool isLineSegmentContainedInBoundary(const geom::Coordinate& p0,
+ const geom::Polygon& rectangle;
+ const geom::Envelope& rectEnv;
+ bool isContainedInBoundary(const geom::Geometry& geom);
+ bool isPointContainedInBoundary(const geom::Point& geom);
+ /** \brief
+ * Tests if a point is contained in the boundary of the target
+ * rectangle.
+ * @param pt the point to test
+ * @return true if the point is contained in the boundary
+ bool isPointContainedInBoundary(const geom::Coordinate& pt);
+ /** \brief
+ * Tests if a linestring is completely contained in the boundary
+ * of the target rectangle.
+ * @param line the linestring to test
+ * @return true if the linestring is contained in the boundary
+ bool isLineStringContainedInBoundary(const geom::LineString& line);
+ /** \brief
+ * Tests if a line segment is contained in the boundary of the
+ * target rectangle.
+ * @param p0 an endpoint of the segment
+ * @param p1 an endpoint of the segment
+ * @return true if the line segment is contained in the boundary
+ bool isLineSegmentContainedInBoundary(const geom::Coordinate& p0,
public:
- static bool contains(const geom::Polygon& rect, const geom::Geometry& b)
- RectangleContains rc(rect);
- return rc.contains(b);
- * Create a new contains computer for two geometries.
- * @param rect a rectangular geometry
- RectangleContains(const geom::Polygon& rect)
- rectangle(rect),
- rectEnv(*(rect.getEnvelopeInternal()))
- bool contains(const geom::Geometry& geom);
+ static bool
+ contains(const geom::Polygon& rect, const geom::Geometry& b)
+ RectangleContains rc(rect);
+ return rc.contains(b);
+ * Create a new contains computer for two geometries.
+ * @param rect a rectangular geometry
+ RectangleContains(const geom::Polygon& rect)
+ rectangle(rect),
+ rectEnv(*(rect.getEnvelopeInternal()))
+ bool contains(const geom::Geometry& geom);
RectangleContains(const RectangleContains& other) = delete;
diff --git a/include/geos/operation/predicate/RectangleIntersects.h b/include/geos/operation/predicate/RectangleIntersects.h
index 772b6d7..c8831ff 100644
--- a/include/geos/operation/predicate/RectangleIntersects.h
+++ b/include/geos/operation/predicate/RectangleIntersects.h
@@ -26,10 +26,10 @@
namespace geos {
- namespace geom {
- class Envelope;
- //class Polygon;
+namespace geom {
+class Envelope;
+//class Polygon;
namespace geos {
@@ -53,9 +53,9 @@ class GEOS_DLL RectangleIntersects {
private:
- const geom::Polygon &rectangle;
- const geom::Envelope &rectEnv;
RectangleIntersects(const RectangleIntersects& other) = delete;
@@ -63,32 +63,33 @@ private:
public:
- /** \brief
- * Create a new intersects computer for a rectangle.
- * @param newRect a rectangular geometry
- RectangleIntersects(const geom::Polygon &newRect)
- rectangle(newRect),
- rectEnv(*(newRect.getEnvelopeInternal()))
- bool intersects(const geom::Geometry& geom);
- /** \brief
- * Tests whether a rectangle intersects a given geometry.
- * @param rectangle a rectangular Polygon
- * @param b a Geometry of any type
- * @return true if the geometries intersect
- static bool intersects(const geom::Polygon &rectangle,
- const geom::Geometry &b)
- RectangleIntersects rp(rectangle);
- return rp.intersects(b);
+ /** \brief
+ * Create a new intersects computer for a rectangle.
+ * @param newRect a rectangular geometry
+ RectangleIntersects(const geom::Polygon& newRect)
+ rectangle(newRect),
+ rectEnv(*(newRect.getEnvelopeInternal()))
+ bool intersects(const geom::Geometry& geom);
+ /** \brief
+ * Tests whether a rectangle intersects a given geometry.
+ * @param rectangle a rectangular Polygon
+ * @param b a Geometry of any type
+ * @return true if the geometries intersect
+ static bool
+ intersects(const geom::Polygon& rectangle,
+ const geom::Geometry& b)
+ RectangleIntersects rp(rectangle);
+ return rp.intersects(b);
diff --git a/include/geos/operation/predicate/SegmentIntersectionTester.h b/include/geos/operation/predicate/SegmentIntersectionTester.h
index 30b707c..3a4d49c 100644
--- a/include/geos/operation/predicate/SegmentIntersectionTester.h
+++ b/include/geos/operation/predicate/SegmentIntersectionTester.h
@@ -27,10 +27,10 @@
namespace geos {
- namespace geom {
- class LineString;
+namespace geom {
+class LineString;
namespace geos {
@@ -49,46 +49,46 @@ class GEOS_DLL SegmentIntersectionTester {
private:
- /// \brief
- /// For purposes of intersection testing,
- /// don't need to set precision model
- algorithm::LineIntersector li; // Robust
+ /// \brief
+ /// For purposes of intersection testing,
+ /// don't need to set precision model
+ algorithm::LineIntersector li; // Robust
- bool hasIntersectionVar;
+ bool hasIntersectionVar;
- geom::Coordinate pt10;
- geom::Coordinate pt11;
- geom::Coordinate pt00;
- geom::Coordinate pt01;
+ geom::Coordinate pt10;
+ geom::Coordinate pt11;
+ geom::Coordinate pt00;
+ geom::Coordinate pt01;
public:
- SegmentIntersectionTester(): hasIntersectionVar(false) {}
- bool hasIntersectionWithLineStrings(const geom::LineString &line,
- const std::vector<const geom::LineString *>& lines);
- bool hasIntersection(const geom::LineString &line,
- const geom::LineString &testLine);
- * Tests the segments of a LineString against the segs in
- * another LineString for intersection.
- * Uses the envelope of the query LineString
- * to filter before testing segments directly.
- * This is optimized for the case when the query
- * LineString is a rectangle.
- * Testing shows this is somewhat faster than not checking the envelope.
- * @param line
- * @param testLine
- * @return
- bool hasIntersectionWithEnvelopeFilter(const geom::LineString &line,
+ SegmentIntersectionTester(): hasIntersectionVar(false) {}
+ bool hasIntersectionWithLineStrings(const geom::LineString& line,
+ const std::vector<const geom::LineString*>& lines);
+ bool hasIntersection(const geom::LineString& line,
+ const geom::LineString& testLine);
+ * Tests the segments of a LineString against the segs in
+ * another LineString for intersection.
+ * Uses the envelope of the query LineString
+ * to filter before testing segments directly.
+ * This is optimized for the case when the query
+ * LineString is a rectangle.
+ * Testing shows this is somewhat faster than not checking the envelope.
+ * @param line
+ * @param testLine
+ * @return
+ bool hasIntersectionWithEnvelopeFilter(const geom::LineString& line,
diff --git a/include/geos/operation/relate/EdgeEndBuilder.h b/include/geos/operation/relate/EdgeEndBuilder.h
index fcb165c..eacb6a0 100644
--- a/include/geos/operation/relate/EdgeEndBuilder.h
+++ b/include/geos/operation/relate/EdgeEndBuilder.h
@@ -25,15 +25,15 @@
namespace geos {
- namespace geom {
- class IntersectionMatrix;
- class Coordinate;
- namespace geomgraph {
- class Edge;
- class EdgeIntersection;
- class EdgeEnd;
+namespace geom {
+class IntersectionMatrix;
+class Coordinate;
+namespace geomgraph {
+class Edge;
+class EdgeIntersection;
+class EdgeEnd;
@@ -47,22 +47,22 @@ namespace relate { // geos::operation::relate
class GEOS_DLL EdgeEndBuilder {
public:
- EdgeEndBuilder() {}
+ EdgeEndBuilder() {}
- std::vector<geomgraph::EdgeEnd*> *computeEdgeEnds(std::vector<geomgraph::Edge*> *edges);
- void computeEdgeEnds(geomgraph::Edge *edge,std::vector<geomgraph::EdgeEnd*> *l);
+ std::vector<geomgraph::EdgeEnd*>* computeEdgeEnds(std::vector<geomgraph::Edge*>* edges);
+ void computeEdgeEnds(geomgraph::Edge* edge, std::vector<geomgraph::EdgeEnd*>* l);
protected:
- void createEdgeEndForPrev(geomgraph::Edge *edge,
- std::vector<geomgraph::EdgeEnd*> *l,
- geomgraph::EdgeIntersection *eiCurr,
- geomgraph::EdgeIntersection *eiPrev);
+ void createEdgeEndForPrev(geomgraph::Edge* edge,
+ std::vector<geomgraph::EdgeEnd*>* l,
+ geomgraph::EdgeIntersection* eiCurr,
+ geomgraph::EdgeIntersection* eiPrev);
- void createEdgeEndForNext(geomgraph::Edge *edge,
- geomgraph::EdgeIntersection *eiNext);
+ void createEdgeEndForNext(geomgraph::Edge* edge,
+ geomgraph::EdgeIntersection* eiNext);
} // namespace geos:operation:relate
diff --git a/include/geos/operation/relate/EdgeEndBundle.h b/include/geos/operation/relate/EdgeEndBundle.h
index 490cff3..95dc021 100644
--- a/include/geos/operation/relate/EdgeEndBundle.h
+++ b/include/geos/operation/relate/EdgeEndBundle.h
@@ -27,12 +27,12 @@
namespace geos {
- namespace algorithm {
- class BoundaryNodeRule;
- namespace geom {
+namespace algorithm {
+class BoundaryNodeRule;
+namespace geom {
@@ -44,61 +44,60 @@ namespace relate { // geos::operation::relate
* A collection of geomgraph::EdgeEnd objects which
* originate at the same point and have the same direction.
-class GEOS_DLL EdgeEndBundle: public geomgraph::EdgeEnd
+class GEOS_DLL EdgeEndBundle: public geomgraph::EdgeEnd {
public:
- EdgeEndBundle(geomgraph::EdgeEnd *e);
- ~EdgeEndBundle() override;
- std::vector<geomgraph::EdgeEnd*>* getEdgeEnds();
- void insert(geomgraph::EdgeEnd *e);
+ EdgeEndBundle(geomgraph::EdgeEnd* e);
+ ~EdgeEndBundle() override;
+ std::vector<geomgraph::EdgeEnd*>* getEdgeEnds();
+ void insert(geomgraph::EdgeEnd* e);
- void computeLabel(const algorithm::BoundaryNodeRule& bnr) override;
+ void computeLabel(const algorithm::BoundaryNodeRule& bnr) override;
- * \brief
- * Update the IM with the contribution for the computed label for
- * the EdgeStubs.
- void updateIM(geom::IntersectionMatrix& im);
+ * \brief
+ * Update the IM with the contribution for the computed label for
+ * the EdgeStubs.
+ void updateIM(geom::IntersectionMatrix& im);
- std::string print() const override;
+ std::string print() const override;
protected:
- std::vector<geomgraph::EdgeEnd*> *edgeEnds;
+ std::vector<geomgraph::EdgeEnd*>* edgeEnds;
- * Compute the overall ON location for the list of EdgeStubs.
- * (This is essentially equivalent to computing the self-overlay of
- * a single Geometry)
- * edgeStubs can be either on the boundary (eg Polygon edge)
- * OR in the interior (e.g. segment of a LineString)
- * of their parent Geometry.
- * In addition, GeometryCollections use a algorithm::BoundaryNodeRule
- * to determine whether a segment is on the boundary or not.
- * Finally, in GeometryCollections it can occur that an edge
- * is both
- * on the boundary and in the interior (e.g. a LineString segment
- * lying on
- * top of a Polygon edge.) In this case the Boundary is
- * given precendence.
- * These observations result in the following rules for computing
- * the ON location:
- * - if there are an odd number of Bdy edges, the attribute is Bdy
- * - if there are an even number >= 2 of Bdy edges, the attribute
- * is Int
- * - if there are any Int edges, the attribute is Int
- * - otherwise, the attribute is NULL.
- void computeLabelOn(int geomIndex,
- const algorithm::BoundaryNodeRule& boundaryNodeRule);
+ * Compute the overall ON location for the list of EdgeStubs.
+ * (This is essentially equivalent to computing the self-overlay of
+ * a single Geometry)
+ * edgeStubs can be either on the boundary (eg Polygon edge)
+ * OR in the interior (e.g. segment of a LineString)
+ * of their parent Geometry.
+ * In addition, GeometryCollections use a algorithm::BoundaryNodeRule
+ * to determine whether a segment is on the boundary or not.
+ * Finally, in GeometryCollections it can occur that an edge
+ * is both
+ * on the boundary and in the interior (e.g. a LineString segment
+ * lying on
+ * top of a Polygon edge.) In this case the Boundary is
+ * given precendence.
+ * These observations result in the following rules for computing
+ * the ON location:
+ * - if there are an odd number of Bdy edges, the attribute is Bdy
+ * - if there are an even number >= 2 of Bdy edges, the attribute
+ * is Int
+ * - if there are any Int edges, the attribute is Int
+ * - otherwise, the attribute is NULL.
+ void computeLabelOn(int geomIndex,
+ const algorithm::BoundaryNodeRule& boundaryNodeRule);
- void computeLabelSides(int geomIndex);
- void computeLabelSide(int geomIndex,int side);
+ void computeLabelSides(int geomIndex);
+ void computeLabelSide(int geomIndex, int side);
diff --git a/include/geos/operation/relate/EdgeEndBundleStar.h b/include/geos/operation/relate/EdgeEndBundleStar.h
index 9118b24..e5b97a7 100644
--- a/include/geos/operation/relate/EdgeEndBundleStar.h
+++ b/include/geos/operation/relate/EdgeEndBundleStar.h
@@ -25,12 +25,12 @@
namespace geos {
- namespace geom {
- class EdgeEnd;
+namespace geom {
+class EdgeEnd;
@@ -48,16 +48,16 @@ namespace relate { // geos::operation::relate
class GEOS_DLL EdgeEndBundleStar: public geomgraph::EdgeEndStar {
public:
- /// Creates a new empty EdgeEndBundleStar
- EdgeEndBundleStar() {}
+ /// Creates a new empty EdgeEndBundleStar
+ EdgeEndBundleStar() {}
- ~EdgeEndBundleStar() override;
- void insert(geomgraph::EdgeEnd *e) override;
+ ~EdgeEndBundleStar() override;
+ void insert(geomgraph::EdgeEnd* e) override;
- * Update the IM with the contribution for the EdgeStubs around the node.
+ * Update the IM with the contribution for the EdgeStubs around the node.
diff --git a/include/geos/operation/relate/RelateComputer.h b/include/geos/operation/relate/RelateComputer.h
index 02a7515..874ae2b 100644
--- a/include/geos/operation/relate/RelateComputer.h
+++ b/include/geos/operation/relate/RelateComputer.h
@@ -38,19 +38,19 @@
namespace geos {
- namespace geom {
- class Geometry;
- class GeometryGraph;
- class Edge;
- class EdgeEnd;
- class Node;
- namespace index {
- class SegmentIntersector;
+namespace geom {
+class Geometry;
+class GeometryGraph;
+class Edge;
+class EdgeEnd;
+class Node;
+namespace index {
+class SegmentIntersector;
@@ -74,87 +74,87 @@ namespace relate { // geos::operation::relate
class GEOS_DLL RelateComputer {
public:
- RelateComputer(std::vector<geomgraph::GeometryGraph*> *newArg);
- ~RelateComputer();
+ RelateComputer(std::vector<geomgraph::GeometryGraph*>* newArg);
+ ~RelateComputer();
- geom::IntersectionMatrix* computeIM();
+ geom::IntersectionMatrix* computeIM();
private:
- algorithm::PointLocator ptLocator;
- /// the arg(s) of the operation
- std::vector<geomgraph::GeometryGraph*> *arg;
- geomgraph::NodeMap nodes;
- /// this intersection matrix will hold the results compute for the relate
- std::unique_ptr<geom::IntersectionMatrix> im;
- std::vector<geomgraph::Edge*> isolatedEdges;
- /// the intersection point found (if any)
- geom::Coordinate invalidPoint;
- void insertEdgeEnds(std::vector<geomgraph::EdgeEnd*> *ee);
- void computeProperIntersectionIM(
- geomgraph::index::SegmentIntersector *intersector,
- geom::IntersectionMatrix *imX);
- void copyNodesAndLabels(int argIndex);
- void computeIntersectionNodes(int argIndex);
- void labelIntersectionNodes(int argIndex);
- * If the Geometries are disjoint, we need to enter their dimension and
- * boundary dimension in the Ext rows in the IM
- void computeDisjointIM(geom::IntersectionMatrix *imX);
- void labelNodeEdges();
- * update the IM with the sum of the IMs for each component
- void updateIM(geom::IntersectionMatrix& imX);
- * Processes isolated edges by computing their labelling and adding them
- * to the isolated edges list.
- * Isolated edges are guaranteed not to touch the boundary of the target
- * (since if they
- * did, they would have caused an intersection to be computed and hence would
- * not be isolated)
- void labelIsolatedEdges(int thisIndex,int targetIndex);
- * Label an isolated edge of a graph with its relationship to the target
- * geometry.
- * If the target has dim 2 or 1, the edge can either be in the interior
- * or the exterior.
- * If the target has dim 0, the edge must be in the exterior
- void labelIsolatedEdge(geomgraph::Edge *e,int targetIndex,
- const geom::Geometry *target);
- * Isolated nodes are nodes whose labels are incomplete
- * (e.g. the location for one Geometry is null).
- * This is the case because nodes in one graph which don't intersect
- * nodes in the other are not completely labelled by the initial process
- * of adding nodes to the nodeList.
- * To complete the labelling we need to check for nodes that lie in the
- * interior of edges, and in the interior of areas.
- void labelIsolatedNodes();
- * Label an isolated node with its relationship to the target geometry.
- void labelIsolatedNode(geomgraph::Node *n,int targetIndex);
+ algorithm::PointLocator ptLocator;
+ /// the arg(s) of the operation
+ std::vector<geomgraph::GeometryGraph*>* arg;
+ geomgraph::NodeMap nodes;
+ /// this intersection matrix will hold the results compute for the relate
+ std::unique_ptr<geom::IntersectionMatrix> im;
+ std::vector<geomgraph::Edge*> isolatedEdges;
+ /// the intersection point found (if any)
+ geom::Coordinate invalidPoint;
+ void insertEdgeEnds(std::vector<geomgraph::EdgeEnd*>* ee);
+ void computeProperIntersectionIM(
+ geomgraph::index::SegmentIntersector* intersector,
+ geom::IntersectionMatrix* imX);
+ void copyNodesAndLabels(int argIndex);
+ void computeIntersectionNodes(int argIndex);
+ void labelIntersectionNodes(int argIndex);
+ * If the Geometries are disjoint, we need to enter their dimension and
+ * boundary dimension in the Ext rows in the IM
+ void computeDisjointIM(geom::IntersectionMatrix* imX);
+ void labelNodeEdges();
+ * update the IM with the sum of the IMs for each component
+ void updateIM(geom::IntersectionMatrix& imX);
+ * Processes isolated edges by computing their labelling and adding them
+ * to the isolated edges list.
+ * Isolated edges are guaranteed not to touch the boundary of the target
+ * (since if they
+ * did, they would have caused an intersection to be computed and hence would
+ * not be isolated)
+ void labelIsolatedEdges(int thisIndex, int targetIndex);
+ * Label an isolated edge of a graph with its relationship to the target
+ * geometry.
+ * If the target has dim 2 or 1, the edge can either be in the interior
+ * or the exterior.
+ * If the target has dim 0, the edge must be in the exterior
+ void labelIsolatedEdge(geomgraph::Edge* e, int targetIndex,
+ const geom::Geometry* target);
+ * Isolated nodes are nodes whose labels are incomplete
+ * (e.g. the location for one Geometry is null).
+ * This is the case because nodes in one graph which don't intersect
+ * nodes in the other are not completely labelled by the initial process
+ * of adding nodes to the nodeList.
+ * To complete the labelling we need to check for nodes that lie in the
+ * interior of edges, and in the interior of areas.
+ void labelIsolatedNodes();
+ * Label an isolated node with its relationship to the target geometry.
+ void labelIsolatedNode(geomgraph::Node* n, int targetIndex);
diff --git a/include/geos/operation/relate/RelateNode.h b/include/geos/operation/relate/RelateNode.h
index 7d9c43f..6c0fdcd 100644
--- a/include/geos/operation/relate/RelateNode.h
+++ b/include/geos/operation/relate/RelateNode.h
@@ -25,13 +25,13 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class EdgeEndStar;
+namespace geom {
+class Coordinate;
+class EdgeEndStar;
@@ -47,18 +47,18 @@ class GEOS_DLL RelateNode: public geomgraph::Node {
public:
- RelateNode(const geom::Coordinate& coord, geomgraph::EdgeEndStar *edges);
+ RelateNode(const geom::Coordinate& coord, geomgraph::EdgeEndStar* edges);
- ~RelateNode() override;
+ ~RelateNode() override;
- * Update the IM with the contribution for the EdgeEnds incident on this node.
- void updateIMFromEdges(geom::IntersectionMatrix& im);
+ * Update the IM with the contribution for the EdgeEnds incident on this node.
+ void updateIMFromEdges(geom::IntersectionMatrix& im);
protected:
- void computeIM(geom::IntersectionMatrix& im) override;
+ void computeIM(geom::IntersectionMatrix& im) override;
diff --git a/include/geos/operation/relate/RelateNodeFactory.h b/include/geos/operation/relate/RelateNodeFactory.h
index 60e38e2..2152fe0 100644
--- a/include/geos/operation/relate/RelateNodeFactory.h
+++ b/include/geos/operation/relate/RelateNodeFactory.h
@@ -25,12 +25,12 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Node;
+namespace geom {
+class Coordinate;
+class Node;
@@ -43,10 +43,10 @@ namespace relate { // geos::operation::relate
class GEOS_DLL RelateNodeFactory: public geomgraph::NodeFactory {
public:
- geomgraph::Node* createNode(const geom::Coordinate &coord) const override;
- static const geomgraph::NodeFactory &instance();
+ geomgraph::Node* createNode(const geom::Coordinate& coord) const override;
+ static const geomgraph::NodeFactory& instance();
private:
- RelateNodeFactory() {}
+ RelateNodeFactory() {}
diff --git a/include/geos/operation/relate/RelateNodeGraph.h b/include/geos/operation/relate/RelateNodeGraph.h
index b57785c..88ee2f4 100644
--- a/include/geos/operation/relate/RelateNodeGraph.h
+++ b/include/geos/operation/relate/RelateNodeGraph.h
@@ -26,17 +26,17 @@
namespace geos {
- namespace geom {
- class Coordinate;
- struct CoordinateLessThen;
- //class EdgeEndStar;
- class Node;
- class EdgeEnd;
- class NodeMap;
+namespace geom {
+class Coordinate;
+struct CoordinateLessThen;
+//class EdgeEndStar;
+class Node;
+class EdgeEnd;
+class NodeMap;
@@ -69,25 +69,25 @@ class GEOS_DLL RelateNodeGraph {
public:
- RelateNodeGraph();
+ RelateNodeGraph();
- virtual ~RelateNodeGraph();
+ virtual ~RelateNodeGraph();
- std::map<geom::Coordinate*, geomgraph::Node*,
- geom::CoordinateLessThen> &getNodeMap();
+ std::map<geom::Coordinate*, geomgraph::Node*,
+ geom::CoordinateLessThen>& getNodeMap();
- void build(geomgraph::GeometryGraph *geomGraph);
+ void build(geomgraph::GeometryGraph* geomGraph);
- void computeIntersectionNodes(geomgraph::GeometryGraph *geomGraph,
- int argIndex);
+ void computeIntersectionNodes(geomgraph::GeometryGraph* geomGraph,
+ int argIndex);
- void copyNodesAndLabels(geomgraph::GeometryGraph *geomGraph,int argIndex);
+ void copyNodesAndLabels(geomgraph::GeometryGraph* geomGraph, int argIndex);
private:
- geomgraph::NodeMap *nodes;
+ geomgraph::NodeMap* nodes;
diff --git a/include/geos/operation/relate/RelateOp.h b/include/geos/operation/relate/RelateOp.h
index b3b99f6..389dae6 100644
--- a/include/geos/operation/relate/RelateOp.h
+++ b/include/geos/operation/relate/RelateOp.h
@@ -26,13 +26,13 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
@@ -58,75 +58,75 @@ class GEOS_DLL RelateOp: public GeometryGraphOperation {
public:
- /** \brief
- * Computes the geom::IntersectionMatrix for the spatial relationship
- * between two geom::Geometry objects, using the default (OGC SFS)
- * Boundary Node Rule
- * @param a a Geometry to test. Ownership left to caller.
- * @param b a Geometry to test. Ownership left to caller.
- * @return the IntersectonMatrix for the spatial relationship
- * between the geometries. Ownership transferred.
- static geom::IntersectionMatrix* relate(
- const geom::Geometry *a,
- const geom::Geometry *b);
- /** \brief
- * between two geom::Geometry objects, using a specified
- * @param boundaryNodeRule the Boundary Node Rule to use.
- const geom::Geometry *b,
- /** \brief
- * Creates a new Relate operation, using the default (OGC SFS)
- * Boundary Node Rule.
- * @param g0 a Geometry to relate. Ownership left to caller.
- * @param g1 another Geometry to relate. Ownership to caller.
- RelateOp(const geom::Geometry *g0,
- const geom::Geometry *g1);
- /** \brief
- * Creates a new Relate operation with a specified
- const geom::Geometry *g1,
- ~RelateOp() override;
- /** \brief
- * Gets the IntersectionMatrix for the spatial relationship
- * between the input geometries.
- * @return the geom::IntersectionMatrix for the spatial
- * relationship between the input geometries.
- * Ownership transferred.
- geom::IntersectionMatrix* getIntersectionMatrix();
+ /** \brief
+ * Computes the geom::IntersectionMatrix for the spatial relationship
+ * between two geom::Geometry objects, using the default (OGC SFS)
+ * Boundary Node Rule
+ * @param a a Geometry to test. Ownership left to caller.
+ * @param b a Geometry to test. Ownership left to caller.
+ * @return the IntersectonMatrix for the spatial relationship
+ * between the geometries. Ownership transferred.
+ static geom::IntersectionMatrix* relate(
+ const geom::Geometry* a,
+ const geom::Geometry* b);
+ /** \brief
+ * between two geom::Geometry objects, using a specified
+ * @param boundaryNodeRule the Boundary Node Rule to use.
+ const geom::Geometry* b,
+ /** \brief
+ * Creates a new Relate operation, using the default (OGC SFS)
+ * Boundary Node Rule.
+ * @param g0 a Geometry to relate. Ownership left to caller.
+ * @param g1 another Geometry to relate. Ownership to caller.
+ RelateOp(const geom::Geometry* g0,
+ const geom::Geometry* g1);
+ /** \brief
+ * Creates a new Relate operation with a specified
+ const geom::Geometry* g1,
+ ~RelateOp() override;
+ /** \brief
+ * Gets the IntersectionMatrix for the spatial relationship
+ * between the input geometries.
+ * @return the geom::IntersectionMatrix for the spatial
+ * relationship between the input geometries.
+ * Ownership transferred.
+ geom::IntersectionMatrix* getIntersectionMatrix();
private:
- RelateComputer relateComp;
+ RelateComputer relateComp;
diff --git a/include/geos/operation/sharedpaths/SharedPathsOp.h b/include/geos/operation/sharedpaths/SharedPathsOp.h
index e2d3d14..3247352 100644
--- a/include/geos/operation/sharedpaths/SharedPathsOp.h
+++ b/include/geos/operation/sharedpaths/SharedPathsOp.h
@@ -32,11 +32,11 @@
namespace geos {
- namespace geom {
- class LineString;
- class Geometry;
- class GeometryFactory;
+namespace geom {
+class LineString;
+class Geometry;
+class GeometryFactory;
@@ -61,96 +61,97 @@ namespace sharedpaths { // geos.operation.sharedpaths
* e Postgis (CIG 0494241492)"
-class GEOS_DLL SharedPathsOp
+class GEOS_DLL SharedPathsOp {
public:
- /// LineString vector (list of edges)
- typedef std::vector<geom::LineString*> PathList;
- /// Find paths shared between two linear geometries
- /// @param g1
- /// First geometry. Must be linear.
- /// @param g2
- /// Second geometry. Must be linear.
- /// @param sameDir
- /// Shared edges having the same direction are pushed
- /// onto this vector. They'll be of type LineString.
- /// Ownership of the edges is tranferred.
- /// @param oppositeDir
- /// Shared edges having the opposite direction are pushed
- /// onto this vector. They'll be of type geom::LineString.
- static void sharedPathsOp(const geom::Geometry& g1,
- const geom::Geometry& g2,
- PathList& sameDirection,
- PathList& oppositeDirection);
- /// Constructor
- /// @param g1
- /// @param g2
- SharedPathsOp(const geom::Geometry& g1, const geom::Geometry& g2);
- /// Get shared paths
- void getSharedPaths(PathList& sameDirection, PathList& oppositeDirection);
- /// Delete all edges in the list
- static void clearEdges(PathList& from);
+ /// LineString vector (list of edges)
+ typedef std::vector<geom::LineString*> PathList;
+ /// Find paths shared between two linear geometries
+ /// @param g1
+ /// First geometry. Must be linear.
+ /// @param g2
+ /// Second geometry. Must be linear.
+ /// @param sameDir
+ /// Shared edges having the same direction are pushed
+ /// onto this vector. They'll be of type LineString.
+ /// Ownership of the edges is tranferred.
+ /// @param oppositeDir
+ /// Shared edges having the opposite direction are pushed
+ /// onto this vector. They'll be of type geom::LineString.
+ static void sharedPathsOp(const geom::Geometry& g1,
+ const geom::Geometry& g2,
+ PathList& sameDirection,
+ PathList& oppositeDirection);
+ /// Constructor
+ /// @param g1
+ /// @param g2
+ SharedPathsOp(const geom::Geometry& g1, const geom::Geometry& g2);
+ /// Get shared paths
+ void getSharedPaths(PathList& sameDirection, PathList& oppositeDirection);
+ /// Delete all edges in the list
+ static void clearEdges(PathList& from);
private:
- /// Get all the linear intersections
- /// Ownership of linestring pushed to the given container
- /// is transferred to caller. See clearEdges for a deep
- /// release if you need one.
- void findLinearIntersections(PathList& to);
- /// Check if the given edge goes forward or backward on the given line.
- /// PRECONDITION: It is assumed the edge fully lays on the geometry
- bool isForward(const geom::LineString& edge,
- const geom::Geometry& geom);
- /// Check if the given edge goes in the same direction over
- /// the two geometries.
- bool isSameDirection(const geom::LineString& edge) {
- return (isForward(edge, _g1) == isForward(edge, _g2));
- /// Throw an IllegalArgumentException if the geom is not linear
- void checkLinealInput(const geom::Geometry& g);
- const geom::Geometry& _g1;
- const geom::Geometry& _g2;
- const geom::GeometryFactory& _gf;
- // Declare type as noncopyable
- SharedPathsOp(const SharedPathsOp& other) = delete;
- SharedPathsOp& operator=(const SharedPathsOp& rhs) = delete;
+ /// Get all the linear intersections
+ /// Ownership of linestring pushed to the given container
+ /// is transferred to caller. See clearEdges for a deep
+ /// release if you need one.
+ void findLinearIntersections(PathList& to);
+ /// Check if the given edge goes forward or backward on the given line.
+ /// PRECONDITION: It is assumed the edge fully lays on the geometry
+ bool isForward(const geom::LineString& edge,
+ const geom::Geometry& geom);
+ /// Check if the given edge goes in the same direction over
+ /// the two geometries.
+ bool
+ isSameDirection(const geom::LineString& edge)
+ return (isForward(edge, _g1) == isForward(edge, _g2));
+ /// Throw an IllegalArgumentException if the geom is not linear
+ void checkLinealInput(const geom::Geometry& g);
+ const geom::Geometry& _g1;
+ const geom::Geometry& _g2;
+ const geom::GeometryFactory& _gf;
+ // Declare type as noncopyable
+ SharedPathsOp(const SharedPathsOp& other) = delete;
+ SharedPathsOp& operator=(const SharedPathsOp& rhs) = delete;
diff --git a/include/geos/operation/union/CascadedPolygonUnion.h b/include/geos/operation/union/CascadedPolygonUnion.h
index 775fd7e..c095bf2 100644
--- a/include/geos/operation/union/CascadedPolygonUnion.h
+++ b/include/geos/operation/union/CascadedPolygonUnion.h
@@ -31,18 +31,18 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Polygon;
- class MultiPolygon;
- class Envelope;
- namespace index {
- namespace strtree {
- class ItemsList;
+namespace geom {
+class Geometry;
+class Polygon;
+class MultiPolygon;
+class Envelope;
+namespace index {
+namespace strtree {
+class ItemsList;
namespace geos {
@@ -68,8 +68,7 @@ namespace geounion { // geos::operation::geounion
* where there is <i>no</i> overlap between the input geometries.
* However, this case is likely rare in practice.
-class GEOS_DLL CascadedPolygonUnion
+class GEOS_DLL CascadedPolygonUnion {
private:
std::vector<geom::Polygon*>* inputPolys;
geom::GeometryFactory const* geomFactory;
@@ -119,14 +118,15 @@ public:
* @param end end iterator
template <class T>
- static geom::Geometry* Union(T start, T end)
+ static geom::Geometry*
+ Union(T start, T end)
- std::vector<geom::Polygon*> polys;
- for (T i=start; i!=end; ++i) {
- const geom::Polygon* p = dynamic_cast<const geom::Polygon*>(*i);
- polys.push_back(const_cast<geom::Polygon*>(p));
- return Union(&polys);
+ std::vector<geom::Polygon*> polys;
+ for(T i = start; i != end; ++i) {
+ const geom::Polygon* p = dynamic_cast<const geom::Polygon*>(*i);
+ polys.push_back(const_cast<geom::Polygon*>(p));
+ return Union(&polys);
@@ -146,8 +146,8 @@ public:
* ownership of elements _and_ vector are left to caller.
CascadedPolygonUnion(std::vector<geom::Polygon*>* polys)
- : inputPolys(polys),
- geomFactory(nullptr)
+ : inputPolys(polys),
+ geomFactory(nullptr)
@@ -178,7 +178,7 @@ private:
* @return the union of the list section
geom::Geometry* binaryUnion(GeometryListHolder* geoms, std::size_t start,
- std::size_t end);
+ std::size_t end);
* Reduces a tree of geometries to a list of geometries
@@ -222,20 +222,20 @@ private:
* @return the union of the inputs
geom::Geometry* unionUsingEnvelopeIntersection(geom::Geometry* g0,
- geom::Geometry* g1, geom::Envelope const& common);
+ geom::Geometry* g1, geom::Envelope const& common);
geom::Geometry* extractByEnvelope(geom::Envelope const& env,
- geom::Geometry* geom, std::vector<geom::Geometry*>& disjointGeoms);
+ geom::Geometry* geom, std::vector<geom::Geometry*>& disjointGeoms);
void extractByEnvelope(geom::Envelope const& env,
- std::vector<geom::Geometry*>& intersectingGeoms,
- std::vector<geom::Geometry*>& disjointGeoms);
+ std::vector<geom::Geometry*>& intersectingGeoms,
+ std::vector<geom::Geometry*>& disjointGeoms);
- std::vector<geom::Geometry*>& sourceGeoms,
+ std::vector<geom::Geometry*>& sourceGeoms,
* Encapsulates the actual unioning of two polygonal geometries.
diff --git a/include/geos/operation/union/CascadedUnion.h b/include/geos/operation/union/CascadedUnion.h
index e01b8e5..77d6361 100644
--- a/include/geos/operation/union/CascadedUnion.h
+++ b/include/geos/operation/union/CascadedUnion.h
@@ -28,17 +28,17 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Geometry;
- class Envelope;
- namespace index {
- class ItemsList;
+namespace geom {
+class Geometry;
+class Geometry;
+class Envelope;
+namespace index {
+class ItemsList;
namespace geos {
@@ -52,8 +52,7 @@ namespace geounion { // geos::operation::geounion
* This algorithm is more robust than the simple iterated approach
* of repeatedly unioning each geometry to a result geometry.
-class GEOS_DLL CascadedUnion
+class GEOS_DLL CascadedUnion {
private:
const std::vector<geom::Geometry*>* inputGeoms;
@@ -86,14 +85,15 @@ public:
template <class T>
- std::vector<geom::Geometry*> polys;
- const geom::Geometry* p = dynamic_cast<const geom::Geometry*>(*i);
- polys.push_back(const_cast<geom::Geometry*>(p));
+ std::vector<geom::Geometry*> polys;
+ const geom::Geometry* p = dynamic_cast<const geom::Geometry*>(*i);
+ polys.push_back(const_cast<geom::Geometry*>(p));
@@ -104,8 +104,8 @@ public:
CascadedUnion(const std::vector<geom::Geometry*>* geoms)
- : inputGeoms(geoms),
+ : inputGeoms(geoms),
@@ -136,7 +136,7 @@ private:
- std::size_t end);
+ std::size_t end);
@@ -177,10 +177,10 @@ private:
diff --git a/include/geos/operation/union/GeometryListHolder.h b/include/geos/operation/union/GeometryListHolder.h
index e88f968..1498da0 100644
--- a/include/geos/operation/union/GeometryListHolder.h
+++ b/include/geos/operation/union/GeometryListHolder.h
@@ -18,9 +18,9 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
namespace geos {
@@ -31,8 +31,7 @@ namespace geounion { // geos::operation::geounion
* \brief Helper class holding Geometries, part of which are held by reference
* others are held exclusively.
-class GeometryListHolder : public std::vector<geom::Geometry*>
+class GeometryListHolder : public std::vector<geom::Geometry*> {
private:
typedef std::vector<geom::Geometry*> base_type;
@@ -41,21 +40,24 @@ public:
~GeometryListHolder()
std::for_each(ownedItems.begin(), ownedItems.end(),
- &GeometryListHolder::deleteItem);
+ &GeometryListHolder::deleteItem);
// items need to be deleted in the end
- void push_back_owned(geom::Geometry* item)
+ void
+ push_back_owned(geom::Geometry* item)
this->base_type::push_back(item);
ownedItems.push_back(item);
- geom::Geometry* getGeometry(std::size_t index)
+ geom::Geometry*
+ getGeometry(std::size_t index)
- if (index >= this->base_type::size())
- return nullptr;
- return (*this)[index];
+ if(index >= this->base_type::size()) {
+ return nullptr;
+ return (*this)[index];
private:
diff --git a/include/geos/operation/union/PointGeometryUnion.h b/include/geos/operation/union/PointGeometryUnion.h
index 31bbec3..8ed31c4 100644
--- a/include/geos/operation/union/PointGeometryUnion.h
+++ b/include/geos/operation/union/PointGeometryUnion.h
@@ -25,11 +25,11 @@
namespace geos {
- namespace geom {
- class Geometry;
- class Puntal;
+namespace geom {
+class Geometry;
+class Puntal;
namespace geos {
@@ -44,28 +44,27 @@ namespace geounion { // geos::operation::geounion
* Does not copy any component geometries.
-class GEOS_DLL PointGeometryUnion
+class GEOS_DLL PointGeometryUnion {
public:
- static std::unique_ptr<geom::Geometry> Union(
- const geom::Puntal& pointGeom,
- const geom::Geometry& otherGeom);
+ static std::unique_ptr<geom::Geometry> Union(
+ const geom::Puntal& pointGeom,
+ const geom::Geometry& otherGeom);
- PointGeometryUnion(const geom::Puntal& pointGeom,
+ PointGeometryUnion(const geom::Puntal& pointGeom,
- std::unique_ptr<geom::Geometry> Union() const;
+ std::unique_ptr<geom::Geometry> Union() const;
private:
- const geom::Geometry& pointGeom;
- const geom::Geometry& otherGeom;
- const geom::GeometryFactory* geomFact;
+ const geom::Geometry& pointGeom;
+ const geom::Geometry& otherGeom;
+ const geom::GeometryFactory* geomFact;
- // Declared as non-copyable
- PointGeometryUnion(const PointGeometryUnion& other);
- PointGeometryUnion& operator=(const PointGeometryUnion& rhs);
+ // Declared as non-copyable
+ PointGeometryUnion(const PointGeometryUnion& other);
+ PointGeometryUnion& operator=(const PointGeometryUnion& rhs);
} // namespace geos::operation::union
diff --git a/include/geos/operation/union/UnaryUnionOp.h b/include/geos/operation/union/UnaryUnionOp.h
index 832e173..e44e735 100644
--- a/include/geos/operation/union/UnaryUnionOp.h
+++ b/include/geos/operation/union/UnaryUnionOp.h
@@ -39,10 +39,10 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
namespace geos {
@@ -82,136 +82,142 @@ namespace geounion { // geos::operation::geounion
* MultiPolygons (although the polygon components must all still be
* individually valid.)
-class GEOS_DLL UnaryUnionOp
+class GEOS_DLL UnaryUnionOp {
public:
- template <typename T>
- static std::unique_ptr<geom::Geometry> Union(const T& geoms)
- UnaryUnionOp op(geoms);
- return op.Union();
- template <class T>
- static std::unique_ptr<geom::Geometry> Union(const T& geoms,
- geom::GeometryFactory& geomFact)
- UnaryUnionOp op(geoms, geomFact);
- static std::unique_ptr<geom::Geometry> Union(const geom::Geometry& geom)
- UnaryUnionOp op(geom);
- UnaryUnionOp(const T& geoms, geom::GeometryFactory& geomFactIn)
- geomFact(&geomFactIn)
- extractGeoms(geoms);
- UnaryUnionOp(const T& geoms)
- geomFact(nullptr)
- UnaryUnionOp(const geom::Geometry& geom)
- geomFact(geom.getFactory())
- extract(geom);
- * \brief
- * Gets the union of the input geometries.
- * If no input geometries were provided, a POINT EMPTY is returned.
- * @return a Geometry containing the union
- * @return an empty GEOMETRYCOLLECTION if no geometries were provided
- * in the input
- std::unique_ptr<geom::Geometry> Union();
+ template <typename T>
+ Union(const T& geoms)
+ UnaryUnionOp op(geoms);
+ return op.Union();
+ template <class T>
+ Union(const T& geoms,
+ geom::GeometryFactory& geomFact)
+ UnaryUnionOp op(geoms, geomFact);
+ Union(const geom::Geometry& geom)
+ UnaryUnionOp op(geom);
+ UnaryUnionOp(const T& geoms, geom::GeometryFactory& geomFactIn)
+ geomFact(&geomFactIn)
+ extractGeoms(geoms);
+ UnaryUnionOp(const T& geoms)
+ geomFact(nullptr)
+ UnaryUnionOp(const geom::Geometry& geom)
+ geomFact(geom.getFactory())
+ extract(geom);
+ * \brief
+ * Gets the union of the input geometries.
+ * If no input geometries were provided, a POINT EMPTY is returned.
+ * @return a Geometry containing the union
+ * @return an empty GEOMETRYCOLLECTION if no geometries were provided
+ * in the input
+ std::unique_ptr<geom::Geometry> Union();
private:
- void extractGeoms(const T& geoms)
- for (typename T::const_iterator
- i=geoms.begin(),
- e=geoms.end();
- i!=e;
- ++i)
- const geom::Geometry* geom = *i;
- extract(*geom);
- void extract(const geom::Geometry& geom)
- using namespace geom::util;
- if ( ! geomFact ) geomFact = geom.getFactory();
- GeometryExtracter::extract<geom::Polygon>(geom, polygons);
- GeometryExtracter::extract<geom::LineString>(geom, lines);
- GeometryExtracter::extract<geom::Point>(geom, points);
- * Computes a unary union with no extra optimization,
- * and no short-circuiting.
- * Due to the way the overlay operations
- * are implemented, this is still efficient in the case of linear
- * and puntal geometries.
- * Uses robust version of overlay operation
- * to ensure identical behaviour to the <tt>union(Geometry)</tt> operation.
- * @param g0 a geometry
- * @return the union of the input geometry
- std::unique_ptr<geom::Geometry> unionNoOpt(const geom::Geometry& g0)
- using geos::operation::overlay::OverlayOp;
- //using geos::operation::overlay::snap::SnapIfNeededOverlayOp;
- if ( ! empty.get() ) {
- empty.reset( geomFact->createEmptyGeometry() );
+ void
+ extractGeoms(const T& geoms)
+ for(typename T::const_iterator
+ i = geoms.begin(),
+ e = geoms.end();
+ i != e;
+ ++i) {
+ const geom::Geometry* geom = *i;
+ extract(*geom);
+ void
+ extract(const geom::Geometry& geom)
+ using namespace geom::util;
+ if(! geomFact) {
+ geomFact = geom.getFactory();
+ GeometryExtracter::extract<geom::Polygon>(geom, polygons);
+ GeometryExtracter::extract<geom::LineString>(geom, lines);
+ GeometryExtracter::extract<geom::Point>(geom, points);
- //return SnapIfNeededOverlayOp::overlayOp(g0, *empty, OverlayOp::opUNION);
- return BinaryOp(&g0, empty.get(), overlay::overlayOp(OverlayOp::opUNION));
- * Computes the union of two geometries,
- * either of both of which may be null.
- * @param g0 a Geometry (ownership transferred)
- * @param g1 a Geometry (ownership transferred)
- * @return the union of the input(s)
- * @return null if both inputs are null
- std::unique_ptr<geom::Geometry> unionWithNull(std::unique_ptr<geom::Geometry> g0,
- std::unique_ptr<geom::Geometry> g1);
- std::vector<const geom::Polygon*> polygons;
- std::vector<const geom::LineString*> lines;
- std::vector<const geom::Point*> points;
- std::unique_ptr<geom::Geometry> empty;
+ * Computes a unary union with no extra optimization,
+ * and no short-circuiting.
+ * Due to the way the overlay operations
+ * are implemented, this is still efficient in the case of linear
+ * and puntal geometries.
+ * Uses robust version of overlay operation
+ * to ensure identical behaviour to the <tt>union(Geometry)</tt> operation.
+ * @param g0 a geometry
+ * @return the union of the input geometry
+ unionNoOpt(const geom::Geometry& g0)
+ using geos::operation::overlay::OverlayOp;
+ //using geos::operation::overlay::snap::SnapIfNeededOverlayOp;
+ if(! empty.get()) {
+ empty.reset(geomFact->createEmptyGeometry());
+ //return SnapIfNeededOverlayOp::overlayOp(g0, *empty, OverlayOp::opUNION);
+ return BinaryOp(&g0, empty.get(), overlay::overlayOp(OverlayOp::opUNION));
+ * Computes the union of two geometries,
+ * either of both of which may be null.
+ * @param g0 a Geometry (ownership transferred)
+ * @param g1 a Geometry (ownership transferred)
+ * @return the union of the input(s)
+ * @return null if both inputs are null
+ std::unique_ptr<geom::Geometry> unionWithNull(std::unique_ptr<geom::Geometry> g0,
+ std::unique_ptr<geom::Geometry> g1);
+ std::vector<const geom::Polygon*> polygons;
+ std::vector<const geom::LineString*> lines;
+ std::vector<const geom::Point*> points;
+ std::unique_ptr<geom::Geometry> empty;
diff --git a/include/geos/operation/valid/ConnectedInteriorTester.h b/include/geos/operation/valid/ConnectedInteriorTester.h
index 76a2786..4e101ba 100644
--- a/include/geos/operation/valid/ConnectedInteriorTester.h
+++ b/include/geos/operation/valid/ConnectedInteriorTester.h
@@ -34,20 +34,20 @@
namespace geos {
- namespace geom {
- //class Coordinate;
- class Geometry;
- class CoordinateSequence;
- class LineString;
- class PlanarGraph;
- class EdgeRing;
- class DirectedEdge;
- class EdgeEnd;
+namespace geom {
+//class Coordinate;
+class Geometry;
+class CoordinateSequence;
+class LineString;
+class PlanarGraph;
+class EdgeRing;
+class DirectedEdge;
+class EdgeEnd;
namespace geos {
@@ -70,68 +70,68 @@ namespace valid { // geos::operation::valid
class GEOS_DLL ConnectedInteriorTester {
public:
- ConnectedInteriorTester(geomgraph::GeometryGraph &newGeomGraph);
- ~ConnectedInteriorTester();
- geom::Coordinate& getCoordinate();
- bool isInteriorsConnected();
- static const geom::Coordinate& findDifferentPoint(
- const geom::CoordinateSequence *coord,
- const geom::Coordinate& pt);
+ ConnectedInteriorTester(geomgraph::GeometryGraph& newGeomGraph);
+ ~ConnectedInteriorTester();
+ geom::Coordinate& getCoordinate();
+ bool isInteriorsConnected();
+ static const geom::Coordinate& findDifferentPoint(
+ const geom::CoordinateSequence* coord,
+ const geom::Coordinate& pt);
protected:
- void visitLinkedDirectedEdges(geomgraph::DirectedEdge *start);
+ void visitLinkedDirectedEdges(geomgraph::DirectedEdge* start);
private:
- geom::GeometryFactory::Ptr geometryFactory;
- geomgraph::GeometryGraph &geomGraph;
- /// Save a coordinate for any disconnected interior found
- /// the coordinate will be somewhere on the ring surrounding
- /// the disconnected interior
- geom::Coordinate disconnectedRingcoord;
- /// Used to track MaximalEdgeRings allocations
- std::vector<geomgraph::EdgeRing*> maximalEdgeRings;
- void setInteriorEdgesInResult(geomgraph::PlanarGraph &graph);
- * \brief
- * Form DirectedEdges in graph into Minimal EdgeRings.
- * Minimal Edgerings must be used, because only they are
- * guaranteed to provide a correct isHole computation.
- * @param minEdgeRings : newly allocated minimal edge rings will
- * be push_back'ed here.
- * deletion responsibility is left to caller.
- void buildEdgeRings(std::vector<geomgraph::EdgeEnd*> *dirEdges,
- std::vector<geomgraph::EdgeRing*>& minEdgeRings);
- * Mark all the edges for the edgeRings corresponding to the shells
- * of the input polygons. Note only ONE ring gets marked for each shell.
- void visitShellInteriors(const geom::Geometry *g, geomgraph::PlanarGraph &graph);
- void visitInteriorRing(const geom::LineString *ring, geomgraph::PlanarGraph &graph);
- * Check if any shell ring has an unvisited edge.
- * A shell ring is a ring which is not a hole and which has the interior
- * of the parent area on the RHS.
- * (Note that there may be non-hole rings with the interior on the LHS,
- * since the interior of holes will also be polygonized into CW rings
- * by the linkAllDirectedEdges() step)
- * @return true if there is an unvisited edge in a non-hole ring
- bool hasUnvisitedShellEdge(std::vector<geomgraph::EdgeRing*> *edgeRings);
+ geom::GeometryFactory::Ptr geometryFactory;
+ geomgraph::GeometryGraph& geomGraph;
+ /// Save a coordinate for any disconnected interior found
+ /// the coordinate will be somewhere on the ring surrounding
+ /// the disconnected interior
+ geom::Coordinate disconnectedRingcoord;
+ /// Used to track MaximalEdgeRings allocations
+ std::vector<geomgraph::EdgeRing*> maximalEdgeRings;
+ void setInteriorEdgesInResult(geomgraph::PlanarGraph& graph);
+ * \brief
+ * Form DirectedEdges in graph into Minimal EdgeRings.
+ * Minimal Edgerings must be used, because only they are
+ * guaranteed to provide a correct isHole computation.
+ * @param minEdgeRings : newly allocated minimal edge rings will
+ * be push_back'ed here.
+ * deletion responsibility is left to caller.
+ void buildEdgeRings(std::vector<geomgraph::EdgeEnd*>* dirEdges,
+ std::vector<geomgraph::EdgeRing*>& minEdgeRings);
+ * Mark all the edges for the edgeRings corresponding to the shells
+ * of the input polygons. Note only ONE ring gets marked for each shell.
+ void visitShellInteriors(const geom::Geometry* g, geomgraph::PlanarGraph& graph);
+ void visitInteriorRing(const geom::LineString* ring, geomgraph::PlanarGraph& graph);
+ * Check if any shell ring has an unvisited edge.
+ * A shell ring is a ring which is not a hole and which has the interior
+ * of the parent area on the RHS.
+ * (Note that there may be non-hole rings with the interior on the LHS,
+ * since the interior of holes will also be polygonized into CW rings
+ * by the linkAllDirectedEdges() step)
+ * @return true if there is an unvisited edge in a non-hole ring
+ bool hasUnvisitedShellEdge(std::vector<geomgraph::EdgeRing*>* edgeRings);
ConnectedInteriorTester(const ConnectedInteriorTester& other) = delete;
diff --git a/include/geos/operation/valid/ConsistentAreaTester.h b/include/geos/operation/valid/ConsistentAreaTester.h
index d02fc4c..ac31408 100644
--- a/include/geos/operation/valid/ConsistentAreaTester.h
+++ b/include/geos/operation/valid/ConsistentAreaTester.h
@@ -28,17 +28,17 @@
namespace geos {
- class LineIntersector;
- namespace operation {
- namespace relate {
- class RelateNodeGraph;
+class LineIntersector;
+namespace operation {
+namespace relate {
+class RelateNodeGraph;
namespace geos {
@@ -83,65 +83,65 @@ namespace valid { // geos::operation::valid
class GEOS_DLL ConsistentAreaTester {
private:
- /// Not owned
- geomgraph::GeometryGraph *geomGraph;
+ /// Not owned
+ geomgraph::GeometryGraph* geomGraph;
- relate::RelateNodeGraph nodeGraph;
+ relate::RelateNodeGraph nodeGraph;
- * Check all nodes to see if their labels are consistent.
- * If any are not, return false
- bool isNodeEdgeAreaLabelsConsistent();
+ * Check all nodes to see if their labels are consistent.
+ * If any are not, return false
+ bool isNodeEdgeAreaLabelsConsistent();
public:
- * Creates a new tester for consistent areas.
- * @param geomGraph the topology graph of the area geometry.
- * Caller keeps responsibility for its deletion
- ConsistentAreaTester(geomgraph::GeometryGraph *newGeomGraph);
- ~ConsistentAreaTester();
- * @return the intersection point, or <code>null</code>
- * if none was found
- geom::Coordinate& getInvalidPoint();
- /** \brief
- * Check all nodes to see if their labels are consistent with
- * area topology.
- * @return <code>true</code> if this area has a consistent node
- * labelling
- bool isNodeConsistentArea();
- * Checks for two duplicate rings in an area.
- * Duplicate rings are rings that are topologically equal
- * (that is, which have the same sequence of points up to point order).
- * If the area is topologically consistent (determined by calling the
- * <code>isNodeConsistentArea</code>,
- * duplicate rings can be found by checking for EdgeBundles which contain
- * more than one geomgraph::EdgeEnd.
- * (This is because topologically consistent areas cannot have two rings sharing
- * the same line segment, unless the rings are equal).
- * The start point of one of the equal rings will be placed in
- * invalidPoint.
- * @return true if this area Geometry is topologically consistent but has two duplicate rings
- bool hasDuplicateRings();
+ * Creates a new tester for consistent areas.
+ * @param geomGraph the topology graph of the area geometry.
+ * Caller keeps responsibility for its deletion
+ ConsistentAreaTester(geomgraph::GeometryGraph* newGeomGraph);
+ ~ConsistentAreaTester();
+ * @return the intersection point, or <code>null</code>
+ * if none was found
+ geom::Coordinate& getInvalidPoint();
+ /** \brief
+ * Check all nodes to see if their labels are consistent with
+ * area topology.
+ * @return <code>true</code> if this area has a consistent node
+ * labelling
+ bool isNodeConsistentArea();
+ * Checks for two duplicate rings in an area.
+ * Duplicate rings are rings that are topologically equal
+ * (that is, which have the same sequence of points up to point order).
+ * If the area is topologically consistent (determined by calling the
+ * <code>isNodeConsistentArea</code>,
+ * duplicate rings can be found by checking for EdgeBundles which contain
+ * more than one geomgraph::EdgeEnd.
+ * (This is because topologically consistent areas cannot have two rings sharing
+ * the same line segment, unless the rings are equal).
+ * The start point of one of the equal rings will be placed in
+ * invalidPoint.
+ * @return true if this area Geometry is topologically consistent but has two duplicate rings
+ bool hasDuplicateRings();
diff --git a/include/geos/operation/valid/IsValidOp.h b/include/geos/operation/valid/IsValidOp.h
index 09bb588..a4e3762 100644
--- a/include/geos/operation/valid/IsValidOp.h
+++ b/include/geos/operation/valid/IsValidOp.h
@@ -62,7 +62,7 @@ class GEOS_DLL IsValidOp {
friend class Unload;
private:
/// the base Geometry to be validated
- const geom::Geometry *parentGeometry;
+ const geom::Geometry* parentGeometry;
bool isChecked;
@@ -72,14 +72,14 @@ private:
// This is the version using 'isChecked' flag
void checkValid();
- void checkValid(const geom::Geometry *g);
- void checkValid(const geom::Point *g);
- void checkValid(const geom::LinearRing *g);
- void checkValid(const geom::LineString *g);
- void checkValid(const geom::Polygon *g);
- void checkValid(const geom::MultiPolygon *g);
- void checkValid(const geom::GeometryCollection *gc);
- void checkConsistentArea(geomgraph::GeometryGraph *graph);
+ void checkValid(const geom::Geometry* g);
+ void checkValid(const geom::Point* g);
+ void checkValid(const geom::LinearRing* g);
+ void checkValid(const geom::LineString* g);
+ void checkValid(const geom::Polygon* g);
+ void checkValid(const geom::MultiPolygon* g);
+ void checkValid(const geom::GeometryCollection* gc);
+ void checkConsistentArea(geomgraph::GeometryGraph* graph);
@@ -90,7 +90,7 @@ private:
* @param graph the topology graph of the geometry
- void checkNoSelfIntersectingRings(geomgraph::GeometryGraph *graph);
+ void checkNoSelfIntersectingRings(geomgraph::GeometryGraph* graph);
* check that a ring does not self-intersect, except at its endpoints.
@@ -99,9 +99,9 @@ private:
* If any occur more than once, that must be a self-intersection.
void checkNoSelfIntersectingRing(
- geomgraph::EdgeIntersectionList &eiList);
+ geomgraph::EdgeIntersectionList& eiList);
- void checkTooFewPoints(geomgraph::GeometryGraph *graph);
+ void checkTooFewPoints(geomgraph::GeometryGraph* graph);
* Test that each hole is inside the polygon shell.
@@ -114,8 +114,8 @@ private:
* @param p the polygon to be tested for hole inclusion
* @param graph a geomgraph::GeometryGraph incorporating the polygon
- void checkHolesInShell(const geom::Polygon *p,
- geomgraph::GeometryGraph *graph);
+ void checkHolesInShell(const geom::Polygon* p,
+ geomgraph::GeometryGraph* graph);
* Tests that no hole is nested inside another hole.
@@ -129,8 +129,8 @@ private:
* (checked by <code>checkRelateConsistency</code>)
- void checkHolesNotNested(const geom::Polygon *p,
+ void checkHolesNotNested(const geom::Polygon* p,
* Tests that no element polygon is wholly in the interior of another
@@ -146,8 +146,8 @@ private:
* may touch at one or more vertices, they cannot touch at
* ALL vertices.
- void checkShellsNotNested(const geom::MultiPolygon *mp,
+ void checkShellsNotNested(const geom::MultiPolygon* mp,
* Check if a shell is incorrectly nested within a polygon.
@@ -160,9 +160,9 @@ private:
* E.g. they cannot partially overlap (this has been previously
* checked by <code>checkRelateConsistency</code>
- void checkShellNotNested(const geom::LinearRing *shell,
- const geom::Polygon *p,
+ void checkShellNotNested(const geom::LinearRing* shell,
+ const geom::Polygon* p,
* This routine checks to see if a shell is properly contained
@@ -174,20 +174,20 @@ private:
* a Coordinate which is not inside the hole if it is not
- const geom::Coordinate *checkShellInsideHole(
- const geom::LinearRing *shell,
- const geom::LinearRing *hole,
+ const geom::Coordinate* checkShellInsideHole(
+ const geom::LinearRing* shell,
+ const geom::LinearRing* hole,
- void checkConnectedInteriors(geomgraph::GeometryGraph &graph);
+ void checkConnectedInteriors(geomgraph::GeometryGraph& graph);
- void checkInvalidCoordinates(const geom::CoordinateSequence *cs);
+ void checkInvalidCoordinates(const geom::CoordinateSequence* cs);
- void checkInvalidCoordinates(const geom::Polygon *poly);
+ void checkInvalidCoordinates(const geom::Polygon* poly);
- void checkClosedRings(const geom::Polygon *poly);
+ void checkClosedRings(const geom::Polygon* poly);
- void checkClosedRing(const geom::LinearRing *ring);
+ void checkClosedRing(const geom::LinearRing* ring);
bool isSelfTouchingRingFormingHoleValid;
@@ -198,10 +198,10 @@ public:
* @return the point found, or NULL if none found
- static const geom::Coordinate *findPtNotNode(
- const geom::CoordinateSequence *testCoords,
- const geom::LinearRing *searchRing,
+ static const geom::Coordinate* findPtNotNode(
+ const geom::CoordinateSequence* testCoords,
+ const geom::LinearRing* searchRing,
* Checks whether a coordinate is valid for processing.
@@ -211,7 +211,7 @@ public:
* @param coord the coordinate to validate
* @return <code>true</code> if the coordinate is valid
- static bool isValid(const geom::Coordinate &coord);
+ static bool isValid(const geom::Coordinate& coord);
* Tests whether a {@link Geometry} is valid.
@@ -219,9 +219,9 @@ public:
* @param geom the Geometry to test
* @return true if the geometry is valid
- static bool isValid(const geom::Geometry &geom);
+ static bool isValid(const geom::Geometry& geom);
- IsValidOp(const geom::Geometry *geom)
+ IsValidOp(const geom::Geometry* geom)
parentGeometry(geom),
isChecked(false),
@@ -230,7 +230,8 @@ public:
/// TODO: validErr can't be a pointer!
- virtual ~IsValidOp()
+ virtual
+ ~IsValidOp()
delete validErr;
@@ -265,7 +266,8 @@ public:
* @param isValid states whether geometry with this condition is valid
- void setSelfTouchingRingFormingHoleValid(bool p_isValid)
+ void
+ setSelfTouchingRingFormingHoleValid(bool p_isValid)
isSelfTouchingRingFormingHoleValid = p_isValid;
diff --git a/include/geos/operation/valid/QuadtreeNestedRingTester.h b/include/geos/operation/valid/QuadtreeNestedRingTester.h
index 3eaee53..698a64a 100644
--- a/include/geos/operation/valid/QuadtreeNestedRingTester.h
+++ b/include/geos/operation/valid/QuadtreeNestedRingTester.h
@@ -33,18 +33,18 @@
namespace geos {
- namespace geom {
- class LinearRing;
- class Coordinate;
- namespace index {
- namespace quadtree {
- class Quadtree;
+namespace geom {
+class LinearRing;
+class Coordinate;
+namespace index {
+namespace quadtree {
+class Quadtree;
namespace geos {
@@ -60,36 +60,36 @@ namespace valid { // geos::operation::valid
class GEOS_DLL QuadtreeNestedRingTester {
public:
- /// Caller retains ownership of GeometryGraph
- QuadtreeNestedRingTester(geomgraph::GeometryGraph* newGraph);
+ /// Caller retains ownership of GeometryGraph
+ QuadtreeNestedRingTester(geomgraph::GeometryGraph* newGraph);
- ~QuadtreeNestedRingTester();
+ ~QuadtreeNestedRingTester();
- * Be aware that the returned Coordinate (if != NULL)
- * will point to storage owned by one of the LinearRing
- * previously added. If you destroy them, this
- * will point to an invalid memory address.
- geom::Coordinate* getNestedPoint();
+ * Be aware that the returned Coordinate (if != NULL)
+ * will point to storage owned by one of the LinearRing
+ * previously added. If you destroy them, this
+ * will point to an invalid memory address.
+ geom::Coordinate* getNestedPoint();
- void add(const geom::LinearRing* ring);
+ void add(const geom::LinearRing* ring);
- bool isNonNested();
+ bool isNonNested();
private:
- geomgraph::GeometryGraph* graph; // used to find non-node vertices
+ geomgraph::GeometryGraph* graph; // used to find non-node vertices
- std::vector<const geom::LinearRing*> rings;
+ std::vector<const geom::LinearRing*> rings;
- geom::Envelope totalEnv;
+ geom::Envelope totalEnv;
- index::quadtree::Quadtree* qt;
+ index::quadtree::Quadtree* qt;
- geom::Coordinate* nestedPt;
+ geom::Coordinate* nestedPt;
- void buildQuadtree();
+ void buildQuadtree();
} // namespace geos::operation::valid
diff --git a/include/geos/operation/valid/RepeatedPointTester.h b/include/geos/operation/valid/RepeatedPointTester.h
index 7901677..5abefe6 100644
--- a/include/geos/operation/valid/RepeatedPointTester.h
+++ b/include/geos/operation/valid/RepeatedPointTester.h
@@ -26,15 +26,15 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Geometry;
- class Polygon;
- class MultiLineString;
- class GeometryCollection;
+namespace geom {
+class Geometry;
+class Polygon;
+class MultiLineString;
+class GeometryCollection;
namespace geos {
@@ -48,16 +48,16 @@ namespace valid { // geos::operation::valid
class GEOS_DLL RepeatedPointTester {
public:
- RepeatedPointTester() {}
- bool hasRepeatedPoint(const geom::Geometry *g);
- bool hasRepeatedPoint(const geom::CoordinateSequence *coord);
+ RepeatedPointTester() {}
+ bool hasRepeatedPoint(const geom::Geometry* g);
+ bool hasRepeatedPoint(const geom::CoordinateSequence* coord);
private:
- geom::Coordinate repeatedCoord;
- bool hasRepeatedPoint(const geom::Polygon *p);
- bool hasRepeatedPoint(const geom::GeometryCollection *gc);
- bool hasRepeatedPoint(const geom::MultiPolygon *gc);
- bool hasRepeatedPoint(const geom::MultiLineString *gc);
+ geom::Coordinate repeatedCoord;
+ bool hasRepeatedPoint(const geom::Polygon* p);
+ bool hasRepeatedPoint(const geom::GeometryCollection* gc);
+ bool hasRepeatedPoint(const geom::MultiPolygon* gc);
+ bool hasRepeatedPoint(const geom::MultiLineString* gc);
diff --git a/include/geos/operation/valid/SimpleNestedRingTester.h b/include/geos/operation/valid/SimpleNestedRingTester.h
index 2ec3e4b..d6d7de1 100644
--- a/include/geos/operation/valid/SimpleNestedRingTester.h
+++ b/include/geos/operation/valid/SimpleNestedRingTester.h
@@ -32,13 +32,13 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class LinearRing;
+namespace geom {
+class Coordinate;
+class LinearRing;
namespace geos {
@@ -53,35 +53,40 @@ namespace valid { // geos::operation::valid
class GEOS_DLL SimpleNestedRingTester {
private:
- geomgraph::GeometryGraph *graph; // used to find non-node vertices
- std::vector<geom::LinearRing*> rings;
- geom::Coordinate *nestedPt;
+ std::vector<geom::LinearRing*> rings;
public:
- SimpleNestedRingTester(geomgraph::GeometryGraph *newGraph)
- graph(newGraph),
- rings(),
- nestedPt(nullptr)
+ SimpleNestedRingTester(geomgraph::GeometryGraph* newGraph)
+ graph(newGraph),
+ rings(),
+ nestedPt(nullptr)
- ~SimpleNestedRingTester() {
+ ~SimpleNestedRingTester()
- void add(geom::LinearRing *ring) {
- rings.push_back(ring);
+ void
+ add(geom::LinearRing* ring)
+ rings.push_back(ring);
- geom::Coordinate *getNestedPoint() {
- return nestedPt;
+ geom::Coordinate*
+ getNestedPoint()
+ return nestedPt;
} // namespace geos.operation.valid
diff --git a/include/geos/operation/valid/SweeplineNestedRingTester.h b/include/geos/operation/valid/SweeplineNestedRingTester.h
index 86e21f6..71ba081 100644
--- a/include/geos/operation/valid/SweeplineNestedRingTester.h
+++ b/include/geos/operation/valid/SweeplineNestedRingTester.h
@@ -35,19 +35,19 @@
namespace geos {
- namespace geom {
- class LinearRing;
- class Envelope;
- class Coordinate;
- namespace index {
- namespace sweepline {
- class SweepLineIndex;
+namespace geom {
+class LinearRing;
+class Envelope;
+class Coordinate;
+namespace index {
+namespace sweepline {
+class SweepLineIndex;
namespace geos {
@@ -62,50 +62,56 @@ namespace valid { // geos::operation::valid
class GEOS_DLL SweeplineNestedRingTester {
private:
- index::sweepline::SweepLineIndex *sweepLine;
- void buildIndex();
+ index::sweepline::SweepLineIndex* sweepLine;
+ void buildIndex();
public:
- SweeplineNestedRingTester(geomgraph::GeometryGraph *newGraph)
- graph(newGraph),
- rings(),
- sweepLine(new index::sweepline::SweepLineIndex()),
- nestedPt(nullptr)
- ~SweeplineNestedRingTester()
- delete sweepLine;
- geom::Coordinate *getNestedPoint() { return nestedPt; }
- void add(geom::LinearRing* ring) {
- bool isInside(geom::LinearRing *innerRing, geom::LinearRing *searchRing);
- class OverlapAction: public index::sweepline::SweepLineOverlapAction {
- public:
- bool isNonNested;
- OverlapAction(SweeplineNestedRingTester *p);
- void overlap(index::sweepline::SweepLineInterval *s0,
- index::sweepline::SweepLineInterval *s1) override;
- private:
- SweeplineNestedRingTester *parent;
+ SweeplineNestedRingTester(geomgraph::GeometryGraph* newGraph)
+ graph(newGraph),
+ rings(),
+ sweepLine(new index::sweepline::SweepLineIndex()),
+ nestedPt(nullptr)
+ ~SweeplineNestedRingTester()
+ delete sweepLine;
+ geom::Coordinate*
+ getNestedPoint()
+ return nestedPt;
+ void
+ bool isInside(geom::LinearRing* innerRing, geom::LinearRing* searchRing);
+ class OverlapAction: public index::sweepline::SweepLineOverlapAction {
+ public:
+ bool isNonNested;
+ OverlapAction(SweeplineNestedRingTester* p);
+ void overlap(index::sweepline::SweepLineInterval* s0,
+ index::sweepline::SweepLineInterval* s1) override;
+ private:
+ SweeplineNestedRingTester* parent;
diff --git a/include/geos/operation/valid/TopologyValidationError.h b/include/geos/operation/valid/TopologyValidationError.h
index 9e2048b..f290899 100644
--- a/include/geos/operation/valid/TopologyValidationError.h
+++ b/include/geos/operation/valid/TopologyValidationError.h
@@ -40,33 +40,33 @@ namespace valid { // geos::operation::valid
class GEOS_DLL TopologyValidationError {
public:
- enum errorEnum {
- eError,
- eRepeatedPoint,
- eHoleOutsideShell,
- eNestedHoles,
- eDisconnectedInterior,
- eSelfIntersection,
- eRingSelfIntersection,
- eNestedShells,
- eDuplicatedRings,
- eTooFewPoints,
- eInvalidCoordinate,
- eRingNotClosed
+ enum errorEnum {
+ eError,
+ eRepeatedPoint,
+ eHoleOutsideShell,
+ eNestedHoles,
+ eDisconnectedInterior,
+ eSelfIntersection,
+ eRingSelfIntersection,
+ eNestedShells,
+ eDuplicatedRings,
+ eTooFewPoints,
+ eInvalidCoordinate,
+ eRingNotClosed
- TopologyValidationError(int newErrorType, const geom::Coordinate& newPt);
- TopologyValidationError(int newErrorType);
- std::string getMessage();
- int getErrorType();
- std::string toString();
+ TopologyValidationError(int newErrorType, const geom::Coordinate& newPt);
+ TopologyValidationError(int newErrorType);
+ std::string getMessage();
+ int getErrorType();
+ std::string toString();
private:
- // Used const char* to reduce dynamic allocations
- static const char* errMsg[];
- int errorType;
- geom::Coordinate pt;
+ // Used const char* to reduce dynamic allocations
+ static const char* errMsg[];
+ int errorType;
+ geom::Coordinate pt;
diff --git a/include/geos/planargraph/DirectedEdge.h b/include/geos/planargraph/DirectedEdge.h
index 25944ec..cb08f3b 100644
--- a/include/geos/planargraph/DirectedEdge.h
+++ b/include/geos/planargraph/DirectedEdge.h
@@ -25,10 +25,10 @@
namespace geos {
- namespace planargraph {
- class Edge;
- class Node;
+namespace planargraph {
+class Edge;
+class Node;
namespace geos {
@@ -47,185 +47,185 @@ class GEOS_DLL DirectedEdge: public GraphComponent {
public:
- friend std::ostream& operator << (std::ostream&, const DirectedEdge&);
+ friend std::ostream& operator << (std::ostream&, const DirectedEdge&);
- typedef std::list<DirectedEdge *> NonConstList;
- typedef std::list<const DirectedEdge *> ConstList;
- typedef std::vector<DirectedEdge *> NonConstVect;
+ typedef std::list<DirectedEdge*> NonConstList;
+ typedef std::list<const DirectedEdge*> ConstList;
+ typedef std::vector<DirectedEdge*> NonConstVect;
protected:
- Edge* parentEdge;
- Node* from;
- Node* to;
- geom::Coordinate p0, p1;
- DirectedEdge* sym; // optional
- bool edgeDirection;
- int quadrant;
- double angle;
+ Edge* parentEdge;
+ Node* from;
+ Node* to;
+ geom::Coordinate p0, p1;
+ DirectedEdge* sym; // optional
+ bool edgeDirection;
+ int quadrant;
+ double angle;
public:
- typedef std::vector<const DirectedEdge *> ConstVect;
- typedef std::vector<DirectedEdge *> Vect;
- * \brief
- * Returns a List containing the parent Edge (possibly null)
- * for each of the given DirectedEdges.
- * NOTE: ownership of the returned vector is left to
- * the caller, see the equivalent function taking a vector
- * reference to avoid this.
- static std::vector<Edge*>* toEdges(
- std::vector<DirectedEdge*>& dirEdges);
- * \brief
- * Add parent Edge (possibly null) of each of the given DirectedEdges
- * to the given parentEdges vector.
- * NOTE: parents are pushed to the parentEdges vector, make sure
- * it is empty if index-based corrispondence is important.
- static void toEdges( std::vector<DirectedEdge*>& dirEdges,
- std::vector<Edge*>& parentEdges);
- * \brief Constructs a DirectedEdge connecting the <code>from</code>
- * node to the <code>to</code> node.
- * @param directionPt specifies this DirectedEdge's direction
- * (given by an imaginary line from the
- * <code>from</code> node to
- * <code>directionPt</code>)
- * @param edgeDirection whether this DirectedEdge's direction
- * is the same as or opposite to that of the
- * parent Edge (if any)
- DirectedEdge(Node *newFrom, Node *newTo,
- const geom::Coordinate &directionPt,
- bool newEdgeDirection);
- * \brief Returns this DirectedEdge's parent Edge,
- * or null if it has none.
- Edge* getEdge() const;
- * \brief Associates this DirectedEdge with an Edge
- * (possibly null, indicating no associated Edge).
- void setEdge(Edge* newParentEdge);
- * \brief Returns 0, 1, 2, or 3, indicating the quadrant in which
- * this DirectedEdge's orientation lies.
- int getQuadrant() const;
- * \brief Returns a point to which an imaginary line is drawn
- * from the from-node to specify this DirectedEdge's orientation.
- const geom::Coordinate& getDirectionPt() const;
- * \brief Returns whether the direction of the parent Edge (if any)
- * is the same as that of this Directed Edge.
- bool getEdgeDirection() const;
- * \brief Returns the node from which this DirectedEdge leaves.
- Node* getFromNode() const;
- * \brief Returns the node to which this DirectedEdge goes.
- Node* getToNode() const;
- * \brief
- * Returns the coordinate of the from-node.
- geom::Coordinate& getCoordinate() const;
- * \brief
- * Returns the angle that the start of this DirectedEdge makes
- * with the positive x-axis, in radians.
- double getAngle() const;
- * \brief
- * Returns the symmetric DirectedEdge -- the other DirectedEdge
- * associated with this DirectedEdge's parent Edge.
- DirectedEdge* getSym() const;
- * \brief
- * Sets this DirectedEdge's symmetric DirectedEdge, which runs
- * in the opposite direction.
- void setSym(DirectedEdge *newSym);
- * \brief
- * Returns 1 if this DirectedEdge has a greater angle with the
- * positive x-axis than b", 0 if the DirectedEdges are collinear,
- * and -1 otherwise.
- * Using the obvious algorithm of simply computing the angle is
- * not robust, since the angle calculation is susceptible to roundoff.
- * A robust algorithm is:
- * - first compare the quadrants.
- * If the quadrants are different, it it
- * trivial to determine which std::vector is "greater".
- * - if the vectors lie in the same quadrant, the robust
- * Orientation::index(Coordinate, Coordinate, Coordinate)
- * function can be used to decide the relative orientation of
- * the vectors.
- int compareTo(const DirectedEdge* obj) const;
- * \brief
- * If the quadrants are different, it it trivial to determine
- * which std::vector is "greater".
- * the vectors.
- int compareDirection(const DirectedEdge *e) const;
- * \brief
- * Prints a detailed string representation of this DirectedEdge
- * to the given PrintStream.
- std::string print() const;
+ typedef std::vector<const DirectedEdge*> ConstVect;
+ typedef std::vector<DirectedEdge*> Vect;
+ * \brief
+ * Returns a List containing the parent Edge (possibly null)
+ * for each of the given DirectedEdges.
+ * NOTE: ownership of the returned vector is left to
+ * the caller, see the equivalent function taking a vector
+ * reference to avoid this.
+ static std::vector<Edge*>* toEdges(
+ std::vector<DirectedEdge*>& dirEdges);
+ * \brief
+ * Add parent Edge (possibly null) of each of the given DirectedEdges
+ * to the given parentEdges vector.
+ * NOTE: parents are pushed to the parentEdges vector, make sure
+ * it is empty if index-based corrispondence is important.
+ static void toEdges(std::vector<DirectedEdge*>& dirEdges,
+ std::vector<Edge*>& parentEdges);
+ * \brief Constructs a DirectedEdge connecting the <code>from</code>
+ * node to the <code>to</code> node.
+ * @param directionPt specifies this DirectedEdge's direction
+ * (given by an imaginary line from the
+ * <code>from</code> node to
+ * <code>directionPt</code>)
+ * @param edgeDirection whether this DirectedEdge's direction
+ * is the same as or opposite to that of the
+ * parent Edge (if any)
+ DirectedEdge(Node* newFrom, Node* newTo,
+ const geom::Coordinate& directionPt,
+ bool newEdgeDirection);
+ * \brief Returns this DirectedEdge's parent Edge,
+ * or null if it has none.
+ Edge* getEdge() const;
+ * \brief Associates this DirectedEdge with an Edge
+ * (possibly null, indicating no associated Edge).
+ void setEdge(Edge* newParentEdge);
+ * \brief Returns 0, 1, 2, or 3, indicating the quadrant in which
+ * this DirectedEdge's orientation lies.
+ int getQuadrant() const;
+ * \brief Returns a point to which an imaginary line is drawn
+ * from the from-node to specify this DirectedEdge's orientation.
+ const geom::Coordinate& getDirectionPt() const;
+ * \brief Returns whether the direction of the parent Edge (if any)
+ * is the same as that of this Directed Edge.
+ bool getEdgeDirection() const;
+ * \brief Returns the node from which this DirectedEdge leaves.
+ Node* getFromNode() const;
+ * \brief Returns the node to which this DirectedEdge goes.
+ Node* getToNode() const;
+ * \brief
+ * Returns the coordinate of the from-node.
+ geom::Coordinate& getCoordinate() const;
+ * \brief
+ * Returns the angle that the start of this DirectedEdge makes
+ * with the positive x-axis, in radians.
+ double getAngle() const;
+ * \brief
+ * Returns the symmetric DirectedEdge -- the other DirectedEdge
+ * associated with this DirectedEdge's parent Edge.
+ DirectedEdge* getSym() const;
+ * \brief
+ * Sets this DirectedEdge's symmetric DirectedEdge, which runs
+ * in the opposite direction.
+ void setSym(DirectedEdge* newSym);
+ * \brief
+ * Returns 1 if this DirectedEdge has a greater angle with the
+ * positive x-axis than b", 0 if the DirectedEdges are collinear,
+ * and -1 otherwise.
+ * Using the obvious algorithm of simply computing the angle is
+ * not robust, since the angle calculation is susceptible to roundoff.
+ * A robust algorithm is:
+ * - first compare the quadrants.
+ * If the quadrants are different, it it
+ * trivial to determine which std::vector is "greater".
+ * - if the vectors lie in the same quadrant, the robust
+ * Orientation::index(Coordinate, Coordinate, Coordinate)
+ * function can be used to decide the relative orientation of
+ * the vectors.
+ int compareTo(const DirectedEdge* obj) const;
+ * \brief
+ * If the quadrants are different, it it trivial to determine
+ * which std::vector is "greater".
+ * the vectors.
+ int compareDirection(const DirectedEdge* e) const;
+ * \brief
+ * Prints a detailed string representation of this DirectedEdge
+ * to the given PrintStream.
+ std::string print() const;
/// Strict Weak comparator function for containers
-bool pdeLessThan(DirectedEdge *first, DirectedEdge * second);
+bool pdeLessThan(DirectedEdge* first, DirectedEdge* second);
/// Output operator
diff --git a/include/geos/planargraph/DirectedEdgeStar.h b/include/geos/planargraph/DirectedEdgeStar.h
index e1eca5d..919d316 100644
--- a/include/geos/planargraph/DirectedEdgeStar.h
+++ b/include/geos/planargraph/DirectedEdgeStar.h
@@ -27,13 +27,13 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Edge;
+namespace geom {
+class Coordinate;
+class Edge;
namespace geos {
@@ -44,92 +44,101 @@ class GEOS_DLL DirectedEdgeStar {
protected:
private:
- * \brief The underlying list of outgoing DirectedEdges
- mutable std::vector<DirectedEdge*> outEdges;
- mutable bool sorted;
- void sortEdges() const;
+ * \brief The underlying list of outgoing DirectedEdges
+ mutable std::vector<DirectedEdge*> outEdges;
+ mutable bool sorted;
+ void sortEdges() const;
public:
- * \brief Constructs a DirectedEdgeStar with no edges.
- DirectedEdgeStar(): sorted(false) {}
- virtual ~DirectedEdgeStar() {}
- * \brief Adds a new member to this DirectedEdgeStar.
- void add(DirectedEdge *de);
- * \brief Drops a member of this DirectedEdgeStar.
- void remove(DirectedEdge *de);
- * \brief Returns an Iterator over the DirectedEdges,
- * in ascending order by angle with the positive x-axis.
- std::vector<DirectedEdge*>::iterator iterator() { return begin(); }
- /// Returns an iterator to first DirectedEdge
- std::vector<DirectedEdge*>::iterator begin();
- /// Returns an iterator to one-past last DirectedEdge
- std::vector<DirectedEdge*>::iterator end();
- /// Returns an const_iterator to first DirectedEdge
- std::vector<DirectedEdge*>::const_iterator begin() const;
- /// Returns an const_iterator to one-past last DirectedEdge
- std::vector<DirectedEdge*>::const_iterator end() const;
- * \brief Returns the number of edges around the Node associated
- * with this DirectedEdgeStar.
- std::size_t getDegree() const { return outEdges.size(); }
- * \brief Returns the coordinate for the node at wich this
- * star is based
- * \brief Returns the DirectedEdges, in ascending order
- * by angle with the positive x-axis.
- std::vector<DirectedEdge*>& getEdges();
- * \brief Returns the zero-based index of the given Edge,
- * after sorting in ascending order by angle with the
- * positive x-axis.
- int getIndex(const Edge *edge);
- * \brief Returns the zero-based index of the given DirectedEdge,
- int getIndex(const DirectedEdge *dirEdge);
- * \brief Returns the remainder when i is divided by the number of
- * edges in this DirectedEdgeStar.
- int getIndex(int i) const;
- * \brief Returns the DirectedEdge on the left-hand side
- * of the given DirectedEdge (which must be a member of this
- * DirectedEdgeStar).
- DirectedEdge* getNextEdge(DirectedEdge *dirEdge);
+ * \brief Constructs a DirectedEdgeStar with no edges.
+ DirectedEdgeStar(): sorted(false) {}
+ virtual
+ ~DirectedEdgeStar() {}
+ * \brief Adds a new member to this DirectedEdgeStar.
+ void add(DirectedEdge* de);
+ * \brief Drops a member of this DirectedEdgeStar.
+ void remove(DirectedEdge* de);
+ * \brief Returns an Iterator over the DirectedEdges,
+ * in ascending order by angle with the positive x-axis.
+ std::vector<DirectedEdge*>::iterator
+ iterator()
+ return begin();
+ /// Returns an iterator to first DirectedEdge
+ std::vector<DirectedEdge*>::iterator begin();
+ /// Returns an iterator to one-past last DirectedEdge
+ std::vector<DirectedEdge*>::iterator end();
+ /// Returns an const_iterator to first DirectedEdge
+ std::vector<DirectedEdge*>::const_iterator begin() const;
+ /// Returns an const_iterator to one-past last DirectedEdge
+ std::vector<DirectedEdge*>::const_iterator end() const;
+ * \brief Returns the number of edges around the Node associated
+ * with this DirectedEdgeStar.
+ std::size_t
+ getDegree() const
+ return outEdges.size();
+ * \brief Returns the coordinate for the node at wich this
+ * star is based
+ * \brief Returns the DirectedEdges, in ascending order
+ * by angle with the positive x-axis.
+ std::vector<DirectedEdge*>& getEdges();
+ * \brief Returns the zero-based index of the given Edge,
+ * after sorting in ascending order by angle with the
+ * positive x-axis.
+ int getIndex(const Edge* edge);
+ * \brief Returns the zero-based index of the given DirectedEdge,
+ int getIndex(const DirectedEdge* dirEdge);
+ * \brief Returns the remainder when i is divided by the number of
+ * edges in this DirectedEdgeStar.
+ int getIndex(int i) const;
+ * \brief Returns the DirectedEdge on the left-hand side
+ * of the given DirectedEdge (which must be a member of this
+ * DirectedEdgeStar).
+ DirectedEdge* getNextEdge(DirectedEdge* dirEdge);
} // namespace geos::planargraph
diff --git a/include/geos/planargraph/Edge.h b/include/geos/planargraph/Edge.h
index e16c7b3..089b3df 100644
--- a/include/geos/planargraph/Edge.h
+++ b/include/geos/planargraph/Edge.h
@@ -31,12 +31,12 @@
namespace geos {
- class DirectedEdgeStar;
- class Edge;
- class Node;
+class DirectedEdgeStar;
+class Edge;
+class Node;
namespace geos {
@@ -55,82 +55,82 @@ class GEOS_DLL Edge: public GraphComponent {
public:
- friend std::ostream& operator<< (std::ostream& os, const Node&);
+ friend std::ostream& operator<< (std::ostream& os, const Node&);
- /// Set of const Edges pointers
- typedef std::set<const Edge *> ConstSet;
+ /// Set of const Edges pointers
+ typedef std::set<const Edge*> ConstSet;
- /// Set of non-const Edges pointers
- typedef std::set<Edge *> NonConstSet;
+ /// Set of non-const Edges pointers
+ typedef std::set<Edge*> NonConstSet;
- /// Vector of non-const Edges pointers
- typedef std::vector<Edge *> NonConstVect;
+ /// Vector of non-const Edges pointers
+ typedef std::vector<Edge*> NonConstVect;
- /// Vector of const Edges pointers
- typedef std::vector<const Edge *> ConstVect;
+ /// Vector of const Edges pointers
+ typedef std::vector<const Edge*> ConstVect;
protected:
- /** \brief The two DirectedEdges associated with this Edge */
- std::vector<DirectedEdge*> dirEdge;
+ /** \brief The two DirectedEdges associated with this Edge */
+ std::vector<DirectedEdge*> dirEdge;
- * \brief Constructs an Edge whose DirectedEdges are not yet set.
- * Be sure to call setDirectedEdges(DirectedEdge, DirectedEdge)
+ * \brief Constructs an Edge whose DirectedEdges are not yet set.
+ * Be sure to call setDirectedEdges(DirectedEdge, DirectedEdge)
public:
- /** \brief
- * Constructs a Edge whose DirectedEdges are
- * not yet set.
- * Be sure to call
- * {@link setDirectedEdges(DirectedEdge, DirectedEdge)}
- Edge(): dirEdge() {}
- * \brief Constructs an Edge initialized with the given DirectedEdges.
- * For each DirectedEdge: sets the Edge, sets the symmetric
- * DirectedEdge, and adds this Edge to its from-Node.
- Edge(DirectedEdge *de0, DirectedEdge *de1)
- dirEdge()
- setDirectedEdges(de0, de1);
- * \brief Initializes this Edge's two DirectedEdges.
- * sets the Edge, sets the symmetric DirectedEdge, and
- * adds this Edge to its from-Node.
- void setDirectedEdges(DirectedEdge *de0, DirectedEdge *de1);
- * \brief Returns one of the DirectedEdges associated with this Edge.
- * @param i 0 or 1
- DirectedEdge* getDirEdge(int i);
- * \brief Returns the DirectedEdge that starts from the given node,
- * or null if the node is not one of the two nodes associated
- * with this Edge.
- DirectedEdge* getDirEdge(Node *fromNode);
- * \brief If <code>node</code> is one of the two nodes associated
- * with this Edge, returns the other node; otherwise returns null.
- Node* getOppositeNode(Node *node);
+ /** \brief
+ * Constructs a Edge whose DirectedEdges are
+ * not yet set.
+ * Be sure to call
+ * {@link setDirectedEdges(DirectedEdge, DirectedEdge)}
+ Edge(): dirEdge() {}
+ * \brief Constructs an Edge initialized with the given DirectedEdges.
+ * For each DirectedEdge: sets the Edge, sets the symmetric
+ * DirectedEdge, and adds this Edge to its from-Node.
+ Edge(DirectedEdge* de0, DirectedEdge* de1)
+ dirEdge()
+ setDirectedEdges(de0, de1);
+ * \brief Initializes this Edge's two DirectedEdges.
+ * sets the Edge, sets the symmetric DirectedEdge, and
+ * adds this Edge to its from-Node.
+ void setDirectedEdges(DirectedEdge* de0, DirectedEdge* de1);
+ * \brief Returns one of the DirectedEdges associated with this Edge.
+ * @param i 0 or 1
+ DirectedEdge* getDirEdge(int i);
+ * \brief Returns the DirectedEdge that starts from the given node,
+ * or null if the node is not one of the two nodes associated
+ * with this Edge.
+ DirectedEdge* getDirEdge(Node* fromNode);
+ * \brief If <code>node</code> is one of the two nodes associated
+ * with this Edge, returns the other node; otherwise returns null.
+ Node* getOppositeNode(Node* node);
/// Print a Edge
diff --git a/include/geos/planargraph/GraphComponent.h b/include/geos/planargraph/GraphComponent.h
index ce74610..675ef5d 100644
--- a/include/geos/planargraph/GraphComponent.h
+++ b/include/geos/planargraph/GraphComponent.h
@@ -47,109 +47,134 @@ class GEOS_DLL GraphComponent {
protected:
- /// Variable holding ''marked'' status
- bool isMarkedVar;
+ /// Variable holding ''marked'' status
+ bool isMarkedVar;
- /// Variable holding ''visited'' status
- bool isVisitedVar;
+ /// Variable holding ''visited'' status
+ bool isVisitedVar;
public:
- GraphComponent()
- isMarkedVar(false),
- isVisitedVar(false)
- virtual ~GraphComponent() {}
- /** \brief
- * Tests if a component has been visited during the course
- * of a graph algorithm.
- * @return <code>true</code> if the component has been visited
- virtual bool isVisited() const { return isVisitedVar; }
- /** \brief
- * Sets the visited flag for this component.
- * @param isVisited the desired value of the visited flag
- virtual void setVisited(bool p_isVisited) { isVisitedVar=p_isVisited; }
- /** \brief
- * Sets the Visited state for the elements of a container,
- * from start to end iterator.
- * @param start the start element
- * @param end one past the last element
- * @param visited the state to set the visited flag to
- static void setVisited(T start, T end, bool visited) {
- for(T i=start; i!=end; ++i) {
- (*i)->setVisited(visited);
- /** \brief
- * Sets the Visited state for the values of each map
- * container element, from start to end iterator.
- static void setVisitedMap(T start, T end, bool visited) {
- i->second->setVisited(visited);
- /** \brief
- * Sets the Marked state for the elements of a container,
- * @param marked the state to set the marked flag to
- static void setMarked(T start, T end, bool marked) {
- (*i)->setMarked(marked);
- /** \brief
- * Sets the Marked state for the values of each map
- * @param marked the state to set the visited flag to
- static void setMarkedMap(T start, T end, bool marked) {
- i->second->setMarked(marked);
- /** \brief
- * Tests if a component has been marked at some point
- * during the processing involving this graph.
- * @return <code>true</code> if the component has been marked
- virtual bool isMarked() const { return isMarkedVar; }
- /** \brief
- * Sets the marked flag for this component.
- * @param isMarked the desired value of the marked flag
- virtual void setMarked(bool p_isMarked) { isMarkedVar=p_isMarked; }
+ GraphComponent()
+ isMarkedVar(false),
+ isVisitedVar(false)
+ virtual
+ ~GraphComponent() {}
+ /** \brief
+ * Tests if a component has been visited during the course
+ * of a graph algorithm.
+ * @return <code>true</code> if the component has been visited
+ virtual bool
+ isVisited() const
+ return isVisitedVar;
+ /** \brief
+ * Sets the visited flag for this component.
+ * @param isVisited the desired value of the visited flag
+ virtual void
+ setVisited(bool p_isVisited)
+ isVisitedVar = p_isVisited;
+ /** \brief
+ * Sets the Visited state for the elements of a container,
+ * from start to end iterator.
+ * @param start the start element
+ * @param end one past the last element
+ * @param visited the state to set the visited flag to
+ static void
+ setVisited(T start, T end, bool visited)
+ (*i)->setVisited(visited);
+ /** \brief
+ * Sets the Visited state for the values of each map
+ * container element, from start to end iterator.
+ static void
+ setVisitedMap(T start, T end, bool visited)
+ i->second->setVisited(visited);
+ /** \brief
+ * Sets the Marked state for the elements of a container,
+ * @param marked the state to set the marked flag to
+ static void
+ setMarked(T start, T end, bool marked)
+ (*i)->setMarked(marked);
+ /** \brief
+ * Sets the Marked state for the values of each map
+ * @param marked the state to set the visited flag to
+ static void
+ setMarkedMap(T start, T end, bool marked)
+ i->second->setMarked(marked);
+ /** \brief
+ * Tests if a component has been marked at some point
+ * during the processing involving this graph.
+ * @return <code>true</code> if the component has been marked
+ virtual bool
+ isMarked() const
+ return isMarkedVar;
+ /** \brief
+ * Sets the marked flag for this component.
+ * @param isMarked the desired value of the marked flag
+ virtual void
+ setMarked(bool p_isMarked)
+ isMarkedVar = p_isMarked;
diff --git a/include/geos/planargraph/Node.h b/include/geos/planargraph/Node.h
index 5a96ac9..721de4c 100644
--- a/include/geos/planargraph/Node.h
+++ b/include/geos/planargraph/Node.h
@@ -24,10 +24,10 @@
namespace geos {
- //class DirectedEdgeStar;
+//class DirectedEdgeStar;
namespace geos {
@@ -45,84 +45,103 @@ namespace planargraph { // geos.planargraph
class GEOS_DLL Node: public GraphComponent {
protected:
- /// The location of this Node
+ /// The location of this Node
- /// The collection of DirectedEdges that leave this Node
- DirectedEdgeStar *deStar;
+ /// The collection of DirectedEdges that leave this Node
+ DirectedEdgeStar* deStar;
public:
- friend std::ostream& operator << (std::ostream& os, const Node&);
- /** \brief
- * Returns all Edges that connect the two nodes (which are
- * assumed to be different).
- * Note: returned vector is newly allocated, ownership to
- * the caller.
- static std::vector<Edge*>* getEdgesBetween(Node *node0,
- Node *node1);
- /// Constructs a Node with the given location.
- Node(const geom::Coordinate& newPt)
- pt(newPt)
- { deStar=new DirectedEdgeStar(); }
- ~Node() override {
- delete deStar;
- * \brief
- * Constructs a Node with the given location and
- * collection of outgoing DirectedEdges.
- * Takes ownership of the given DirectedEdgeStar!!
- Node(geom::Coordinate& newPt, DirectedEdgeStar *newDeStar)
- pt(newPt),
- deStar(newDeStar)
- * \brief Returns the location of this Node.
- geom::Coordinate& getCoordinate() {
- return pt;
- * \brief Adds an outgoing DirectedEdge to this Node.
- void addOutEdge(DirectedEdge *de) {
- deStar->add(de);
- * \brief Returns the collection of DirectedEdges that
- * leave this Node.
- DirectedEdgeStar* getOutEdges() { return deStar; }
- const DirectedEdgeStar* getOutEdges() const { return deStar; }
- * \brief Returns the number of edges around this Node.
- size_t getDegree() const {
- return deStar->getDegree();
- * the positive x-axis.
- int getIndex(Edge *edge) {
- return deStar->getIndex(edge);
+ friend std::ostream& operator << (std::ostream& os, const Node&);
+ /** \brief
+ * Returns all Edges that connect the two nodes (which are
+ * assumed to be different).
+ * Note: returned vector is newly allocated, ownership to
+ * the caller.
+ static std::vector<Edge*>* getEdgesBetween(Node* node0,
+ Node* node1);
+ /// Constructs a Node with the given location.
+ Node(const geom::Coordinate& newPt)
+ pt(newPt)
+ deStar = new DirectedEdgeStar();
+ ~Node() override
+ delete deStar;
+ * \brief
+ * Constructs a Node with the given location and
+ * collection of outgoing DirectedEdges.
+ * Takes ownership of the given DirectedEdgeStar!!
+ Node(geom::Coordinate& newPt, DirectedEdgeStar* newDeStar)
+ pt(newPt),
+ deStar(newDeStar)
+ * \brief Returns the location of this Node.
+ geom::Coordinate&
+ getCoordinate()
+ return pt;
+ * \brief Adds an outgoing DirectedEdge to this Node.
+ void
+ addOutEdge(DirectedEdge* de)
+ deStar->add(de);
+ * \brief Returns the collection of DirectedEdges that
+ * leave this Node.
+ DirectedEdgeStar*
+ getOutEdges()
+ return deStar;
+ const DirectedEdgeStar*
+ getOutEdges() const
+ return deStar;
+ * \brief Returns the number of edges around this Node.
+ size_t
+ getDegree() const
+ return deStar->getDegree();
+ * the positive x-axis.
+ int
+ getIndex(Edge* edge)
+ return deStar->getIndex(edge);
diff --git a/include/geos/planargraph/NodeMap.h b/include/geos/planargraph/NodeMap.h
index 327524a..2a67fe4 100644
--- a/include/geos/planargraph/NodeMap.h
+++ b/include/geos/planargraph/NodeMap.h
@@ -29,12 +29,12 @@
namespace geos {
- class Edge;
- class Node;
+class Edge;
+class Node;
namespace geos {
@@ -47,73 +47,83 @@ namespace planargraph { // geos.planargraph
class GEOS_DLL NodeMap {
public:
- typedef std::map<geom::Coordinate, Node*, geom::CoordinateLessThen> container;
+ typedef std::map<geom::Coordinate, Node*, geom::CoordinateLessThen> container;
private:
- container nodeMap;
+ container nodeMap;
public:
- * \brief Constructs a NodeMap without any Nodes.
- NodeMap();
- container& getNodeMap();
- virtual ~NodeMap();
- * \brief
- * Adds a node to the std::map, replacing any that is already
- * at that location.
- * @return the added node
- Node* add(Node *n);
- * \brief
- * Removes the Node at the given location, and returns it
- * (or null if no Node was there).
- Node* remove(geom::Coordinate& pt);
- * \brief
- * Returns the Node at the given location,
- * or null if no Node was there.
- Node* find(const geom::Coordinate& coord);
- * \brief
- * Returns an Iterator over the Nodes in this NodeMap,
- * sorted in ascending order
- container::iterator iterator() {
- return nodeMap.begin();
- container::iterator begin() {
- container::const_iterator begin() const {
- container::iterator end() {
- return nodeMap.end();
- container::const_iterator end() const {
- * \brief
- * Returns the Nodes in this NodeMap, sorted in ascending order
- * @param nodes : the nodes are push_back'ed here
- void getNodes(std::vector<Node*>& nodes);
+ * \brief Constructs a NodeMap without any Nodes.
+ NodeMap();
+ container& getNodeMap();
+ virtual ~NodeMap();
+ * \brief
+ * Adds a node to the std::map, replacing any that is already
+ * at that location.
+ * @return the added node
+ Node* add(Node* n);
+ * \brief
+ * Removes the Node at the given location, and returns it
+ * (or null if no Node was there).
+ Node* remove(geom::Coordinate& pt);
+ * \brief
+ * Returns the Node at the given location,
+ * or null if no Node was there.
+ Node* find(const geom::Coordinate& coord);
+ * \brief
+ * Returns an Iterator over the Nodes in this NodeMap,
+ * sorted in ascending order
+ container::iterator
+ iterator()
+ return nodeMap.begin();
+ begin()
+ container::const_iterator
+ begin() const
+ end()
+ return nodeMap.end();
+ end() const
+ * \brief
+ * Returns the Nodes in this NodeMap, sorted in ascending order
+ * @param nodes : the nodes are push_back'ed here
+ void getNodes(std::vector<Node*>& nodes);
diff --git a/include/geos/planargraph/PlanarGraph.h b/include/geos/planargraph/PlanarGraph.h
index 8bbb321..2172c11 100644
--- a/include/geos/planargraph/PlanarGraph.h
+++ b/include/geos/planargraph/PlanarGraph.h
@@ -31,14 +31,14 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Edge;
- class Node;
+namespace geom {
+class Coordinate;
+class Edge;
+class Node;
namespace geos {
@@ -61,187 +61,218 @@ class GEOS_DLL PlanarGraph {
protected:
- std::vector<Edge*> edges;
- std::vector<DirectedEdge*> dirEdges;
- NodeMap nodeMap;
- * \brief
- * Adds a node to the std::map, replacing any that is already at that
- * location.
- * Only subclasses can add Nodes, to ensure Nodes are
- * of the right type.
- void add(Node *node) {
- nodeMap.add(node);
- * \brief
- * Adds the Edge and its DirectedEdges with this PlanarGraph.
- * Assumes that the Edge has already been created with its associated
- * DirectEdges.
- * Only subclasses can add Edges, to ensure the edges added are of
- * the right class.
- void add(Edge *edge);
- * \brief
- * Adds the Edge to this PlanarGraph.
- * Only subclasses can add DirectedEdges,
- * to ensure the edges added are of the right class.
- void add(DirectedEdge *dirEdge) {
- dirEdges.push_back(dirEdge);
+ std::vector<Edge*> edges;
+ std::vector<DirectedEdge*> dirEdges;
+ NodeMap nodeMap;
+ * \brief
+ * Adds a node to the std::map, replacing any that is already at that
+ * location.
+ * Only subclasses can add Nodes, to ensure Nodes are
+ * of the right type.
+ void
+ add(Node* node)
+ nodeMap.add(node);
+ * \brief
+ * Adds the Edge and its DirectedEdges with this PlanarGraph.
+ * Assumes that the Edge has already been created with its associated
+ * DirectEdges.
+ * Only subclasses can add Edges, to ensure the edges added are of
+ * the right class.
+ void add(Edge* edge);
+ * \brief
+ * Adds the Edge to this PlanarGraph.
+ * Only subclasses can add DirectedEdges,
+ * to ensure the edges added are of the right class.
+ void
+ add(DirectedEdge* dirEdge)
+ dirEdges.push_back(dirEdge);
public:
- typedef std::vector<Edge *> EdgeContainer;
- typedef EdgeContainer::iterator EdgeIterator;
- * \brief
- * Constructs a PlanarGraph without any Edges, DirectedEdges, or Nodes.
- PlanarGraph() {}
- virtual ~PlanarGraph() {}
- * \brief
- Node* findNode(const geom::Coordinate& pt) {
- return nodeMap.find(pt);
- * \brief
- * Returns an Iterator over the Nodes in this PlanarGraph.
- NodeMap::container::iterator nodeIterator() {
- NodeMap::container::iterator nodeBegin() {
- NodeMap::container::const_iterator nodeBegin() const {
- NodeMap::container::iterator nodeEnd() {
- NodeMap::container::const_iterator nodeEnd() const {
- * \brief
- * Returns the Nodes in this PlanarGraph.
- void getNodes(std::vector<Node*>& nodes) { nodeMap.getNodes(nodes); }
- * \brief
- * Returns an Iterator over the DirectedEdges in this PlanarGraph,
- * in the order in which they were added.
- * @see add(Edge)
- * @see add(DirectedEdge)
- std::vector<DirectedEdge*>::iterator dirEdgeIterator() {
- return dirEdges.begin();
- /// Alias for edgeBegin()
- std::vector<Edge*>::iterator edgeIterator() {
- return edges.begin();
- /// Returns an iterator to first Edge in this graph.
- /// Edges are stored in the order they were added.
- /// @see add(Edge)
- std::vector<Edge*>::iterator edgeBegin() {
- /// Returns an iterator to one-past last Edge in this graph.
- std::vector<Edge*>::iterator edgeEnd() {
- return edges.end();
- * \brief
- * Returns the Edges that have been added to this PlanarGraph
- * @see #add(Edge)
- std::vector<Edge*>* getEdges() {
- return &edges;
- * \brief
- * Removes an Edge and its associated DirectedEdges from their
- * from-Nodes and from this PlanarGraph.
- * Note: This method does not remove the Nodes associated
- * with the Edge, even if the removal of the Edge reduces the
- * degree of a Node to zero.
- void remove(Edge *edge);
- * \brief
- * Removes DirectedEdge from its from-Node and from this PlanarGraph.
- * Note:
- * This method does not remove the Nodes associated with the
- * DirectedEdge, even if the removal of the DirectedEdge reduces
- * the degree of a Node to zero.
- * \brief
- * Removes a node from the graph, along with any associated
- * DirectedEdges and Edges.
- void remove(Node *node);
- * \brief
- * Returns all Nodes with the given number of Edges around it.
- * The return value is a newly allocated vector of existing nodes
- std::vector<Node*>* findNodesOfDegree(std::size_t degree);
- * \brief
- * Get all Nodes with the given number of Edges around it.
- * Found nodes are pushed to the given vector
- void findNodesOfDegree(std::size_t degree, std::vector<Node*>& to);
+ typedef std::vector<Edge*> EdgeContainer;
+ typedef EdgeContainer::iterator EdgeIterator;
+ * \brief
+ * Constructs a PlanarGraph without any Edges, DirectedEdges, or Nodes.
+ PlanarGraph() {}
+ virtual
+ ~PlanarGraph() {}
+ * \brief
+ Node*
+ findNode(const geom::Coordinate& pt)
+ return nodeMap.find(pt);
+ * \brief
+ * Returns an Iterator over the Nodes in this PlanarGraph.
+ NodeMap::container::iterator
+ nodeIterator()
+ nodeBegin()
+ NodeMap::container::const_iterator
+ nodeBegin() const
+ nodeEnd()
+ nodeEnd() const
+ * \brief
+ * Returns the Nodes in this PlanarGraph.
+ void
+ getNodes(std::vector<Node*>& nodes)
+ nodeMap.getNodes(nodes);
+ * \brief
+ * Returns an Iterator over the DirectedEdges in this PlanarGraph,
+ * in the order in which they were added.
+ * @see add(Edge)
+ * @see add(DirectedEdge)
+ dirEdgeIterator()
+ return dirEdges.begin();
+ /// Alias for edgeBegin()
+ std::vector<Edge*>::iterator
+ edgeIterator()
+ return edges.begin();
+ /// Returns an iterator to first Edge in this graph.
+ /// Edges are stored in the order they were added.
+ /// @see add(Edge)
+ edgeBegin()
+ /// Returns an iterator to one-past last Edge in this graph.
+ edgeEnd()
+ return edges.end();
+ * \brief
+ * Returns the Edges that have been added to this PlanarGraph
+ * @see #add(Edge)
+ std::vector<Edge*>*
+ getEdges()
+ return &edges;
+ * \brief
+ * Removes an Edge and its associated DirectedEdges from their
+ * from-Nodes and from this PlanarGraph.
+ * Note: This method does not remove the Nodes associated
+ * with the Edge, even if the removal of the Edge reduces the
+ * degree of a Node to zero.
+ void remove(Edge* edge);
+ * \brief
+ * Removes DirectedEdge from its from-Node and from this PlanarGraph.
+ * Note:
+ * This method does not remove the Nodes associated with the
+ * DirectedEdge, even if the removal of the DirectedEdge reduces
+ * the degree of a Node to zero.
+ * \brief
+ * Removes a node from the graph, along with any associated
+ * DirectedEdges and Edges.
+ void remove(Node* node);
+ * \brief
+ * Returns all Nodes with the given number of Edges around it.
+ * The return value is a newly allocated vector of existing nodes
+ std::vector<Node*>* findNodesOfDegree(std::size_t degree);
+ * \brief
+ * Get all Nodes with the given number of Edges around it.
+ * Found nodes are pushed to the given vector
+ void findNodesOfDegree(std::size_t degree, std::vector<Node*>& to);
diff --git a/include/geos/planargraph/Subgraph.h b/include/geos/planargraph/Subgraph.h
index 2d8dd08..c724f7a 100644
--- a/include/geos/planargraph/Subgraph.h
+++ b/include/geos/planargraph/Subgraph.h
@@ -28,11 +28,11 @@
namespace geos {
- class Edge;
+class PlanarGraph;
+class Edge;
namespace geos {
@@ -50,96 +50,121 @@ namespace planargraph { // geos.planargraph
/// @@ Actually we'll be copying Coordinates in NodeMap.
/// I guess that'll need to be changed soon.
-class GEOS_DLL Subgraph
+class GEOS_DLL Subgraph {
public:
- * Creates a new subgraph of the given PlanarGraph
- * @param parent the parent graph
- Subgraph(PlanarGraph &parent)
- parentGraph(parent)
- * Gets the {@link PlanarGraph} which this subgraph
- * is part of.
- * @return the parent PlanarGraph
- PlanarGraph& getParent() const { return parentGraph; }
- * Adds an {@link Edge} to the subgraph.
- * The associated {@link DirectedEdge}s and {@link planarNode}s
- * are also added.
- * @param e the edge to add
- * @return a pair with first element being an iterator
- * to the Edge in set and second element
- * being a boolean value indicating wheter
- * the Edge has been inserted now or was
- * already in the set.
- std::pair<std::set<Edge*>::iterator, bool> add(Edge *e);
- * Returns an iterator over the DirectedEdge in this graph,
- * @return an iterator over the directed edges
- * @see add(Edge)
- std::vector<const DirectedEdge*>::iterator getDirEdgeBegin() {
- * Returns an {@link Iterator} over the {@link Edge}s in this
- * graph, in the order in which they were added.
- * @return an iterator over the edges
- * @see add(Edge)
- std::set<Edge*>::iterator edgeBegin() { return edges.begin(); }
- std::set<Edge*>::iterator edgeEnd() { return edges.end(); }
- * Returns a iterators over the planarNodesMap::container
- * in this graph.
- * Tests whether an {@link Edge} is contained in this subgraph
- * @param e the edge to test
- * @return <code>true</code> if the edge is contained in this subgraph
- bool contains(Edge *e) { return (edges.find(e) != edges.end()); }
+ * Creates a new subgraph of the given PlanarGraph
+ * @param parent the parent graph
+ Subgraph(PlanarGraph& parent)
+ parentGraph(parent)
+ * Gets the {@link PlanarGraph} which this subgraph
+ * is part of.
+ * @return the parent PlanarGraph
+ PlanarGraph&
+ getParent() const
+ return parentGraph;
+ * Adds an {@link Edge} to the subgraph.
+ * The associated {@link DirectedEdge}s and {@link planarNode}s
+ * are also added.
+ * @param e the edge to add
+ * @return a pair with first element being an iterator
+ * to the Edge in set and second element
+ * being a boolean value indicating wheter
+ * the Edge has been inserted now or was
+ * already in the set.
+ std::pair<std::set<Edge*>::iterator, bool> add(Edge* e);
+ * Returns an iterator over the DirectedEdge in this graph,
+ * @return an iterator over the directed edges
+ * @see add(Edge)
+ std::vector<const DirectedEdge*>::iterator
+ getDirEdgeBegin()
+ * Returns an {@link Iterator} over the {@link Edge}s in this
+ * graph, in the order in which they were added.
+ * @return an iterator over the edges
+ * @see add(Edge)
+ std::set<Edge*>::iterator
+ edgeBegin()
+ edgeEnd()
+ * Returns a iterators over the planarNodesMap::container
+ * in this graph.
+ nodeBegin()
+ nodeEnd() const
+ nodeEnd()
+ nodeBegin() const
+ * Tests whether an {@link Edge} is contained in this subgraph
+ * @param e the edge to test
+ * @return <code>true</code> if the edge is contained in this subgraph
+ bool
+ contains(Edge* e)
+ return (edges.find(e) != edges.end());
protected:
- PlanarGraph &parentGraph;
- std::set<Edge*> edges;
- std::vector<const DirectedEdge*> dirEdges;
- NodeMap nodeMap;
+ PlanarGraph& parentGraph;
+ std::set<Edge*> edges;
+ std::vector<const DirectedEdge*> dirEdges;
+ NodeMap nodeMap;
// Declare type as noncopyable
Subgraph(const Subgraph& other) = delete;
diff --git a/include/geos/planargraph/algorithm/ConnectedSubgraphFinder.h b/include/geos/planargraph/algorithm/ConnectedSubgraphFinder.h
index d77c6b4..0505650 100644
--- a/include/geos/planargraph/algorithm/ConnectedSubgraphFinder.h
+++ b/include/geos/planargraph/algorithm/ConnectedSubgraphFinder.h
@@ -24,11 +24,11 @@
namespace geos {
- class PlanarGraph;
- class Subgraph;
- class Node;
+class PlanarGraph;
+class Subgraph;
+class Node;
namespace geos {
@@ -40,48 +40,47 @@ namespace algorithm { // geos::planargraph::algorithm
* <b>Note:</b> uses the <code>isVisited</code> flag on the nodes.
-class GEOS_DLL ConnectedSubgraphFinder
+class GEOS_DLL ConnectedSubgraphFinder {
public:
- ConnectedSubgraphFinder(PlanarGraph& newGraph)
- graph(newGraph)
- /// \brief
- /// Store newly allocated connected Subgraphs into the
- /// given std::vector
- /// Caller take responsibility in releasing memory associated
- /// with the subgraphs themself.
- void getConnectedSubgraphs(std::vector<Subgraph *>& dest);
+ ConnectedSubgraphFinder(PlanarGraph& newGraph)
+ graph(newGraph)
+ /// \brief
+ /// Store newly allocated connected Subgraphs into the
+ /// given std::vector
+ /// Caller take responsibility in releasing memory associated
+ /// with the subgraphs themself.
+ void getConnectedSubgraphs(std::vector<Subgraph*>& dest);
private:
- PlanarGraph& graph;
+ PlanarGraph& graph;
- /// Returns a newly allocated Subgraph
- Subgraph* findSubgraph(Node* node);
+ /// Returns a newly allocated Subgraph
+ Subgraph* findSubgraph(Node* node);
- * Adds all nodes and edges reachable from this node to the subgraph.
- * Uses an explicit stack to avoid a large depth of recursion.
- * @param node a node known to be in the subgraph
- void addReachable(Node* node, Subgraph* subgraph);
+ * Adds all nodes and edges reachable from this node to the subgraph.
+ * Uses an explicit stack to avoid a large depth of recursion.
+ * @param node a node known to be in the subgraph
+ void addReachable(Node* node, Subgraph* subgraph);
- * Adds the argument node and all its out edges to the subgraph.
- * @param node the node to add
- * @param nodeStack the current set of nodes being traversed
- void addEdges(Node* node, std::stack<Node *>& nodeStack,
- Subgraph* subgraph);
+ * Adds the argument node and all its out edges to the subgraph.
+ * @param node the node to add
+ * @param nodeStack the current set of nodes being traversed
+ void addEdges(Node* node, std::stack<Node*>& nodeStack,
+ Subgraph* subgraph);
ConnectedSubgraphFinder(const ConnectedSubgraphFinder& other) = delete;
diff --git a/include/geos/precision/CommonBits.h b/include/geos/precision/CommonBits.h
index 10637bd..4ffe9c9 100644
--- a/include/geos/precision/CommonBits.h
+++ b/include/geos/precision/CommonBits.h
@@ -34,61 +34,61 @@ class GEOS_DLL CommonBits {
private:
- bool isFirst;
+ bool isFirst;
- int commonMantissaBitsCount;
+ int commonMantissaBitsCount;
- int64 commonBits;
+ int64 commonBits;
- int64 commonSignExp;
+ int64 commonSignExp;
public:
- /** \brief
- * Computes the bit pattern for the sign and exponent of a
- * double-precision number.
- * @param num
- * @return the bit pattern for the sign and exponent
- static int64 signExpBits(int64 num);
- /** \brief
- * This computes the number of common most-significant
- * bits in the mantissas of two double-precision numbers.
- * It does not count the hidden bit, which is always 1.
- * It does not determine whether the numbers have the same
- * exponent - if they do not, the value computed by this
- * function is meaningless.
- * @param db
- * @return the number of common most-significant mantissa bits
- static int numCommonMostSigMantissaBits(int64 num1, int64 num2);
- /** \brief
- * Zeroes the lower n bits of a bitstring.
- * @param bits the bitstring to alter
- * @param i the number of bits to zero
- * @return the zeroed bitstring
- static int64 zeroLowerBits(int64 bits, int nBits);
- /** \brief
- * Extracts the i'th bit of a bitstring.
- * @param bits the bitstring to extract from
- * @param i the bit to extract
- * @return the value of the extracted bit
- static int getBit(int64 bits, int i);
- CommonBits();
- void add(double num);
- double getCommon();
+ /** \brief
+ * Computes the bit pattern for the sign and exponent of a
+ * double-precision number.
+ * @param num
+ * @return the bit pattern for the sign and exponent
+ static int64 signExpBits(int64 num);
+ /** \brief
+ * This computes the number of common most-significant
+ * bits in the mantissas of two double-precision numbers.
+ * It does not count the hidden bit, which is always 1.
+ * It does not determine whether the numbers have the same
+ * exponent - if they do not, the value computed by this
+ * function is meaningless.
+ * @param db
+ * @return the number of common most-significant mantissa bits
+ static int numCommonMostSigMantissaBits(int64 num1, int64 num2);
+ /** \brief
+ * Zeroes the lower n bits of a bitstring.
+ * @param bits the bitstring to alter
+ * @param i the number of bits to zero
+ * @return the zeroed bitstring
+ static int64 zeroLowerBits(int64 bits, int nBits);
+ /** \brief
+ * Extracts the i'th bit of a bitstring.
+ * @param bits the bitstring to extract from
+ * @param i the bit to extract
+ * @return the value of the extracted bit
+ static int getBit(int64 bits, int i);
+ CommonBits();
+ void add(double num);
+ double getCommon();
diff --git a/include/geos/precision/CommonBitsOp.h b/include/geos/precision/CommonBitsOp.h
index af16b8a..9240388 100644
--- a/include/geos/precision/CommonBitsOp.h
+++ b/include/geos/precision/CommonBitsOp.h
@@ -27,12 +27,12 @@
#endif
namespace geos {
- namespace geom {
- class Geometry;
- namespace precision {
- //class CommonBitsRemover;
+namespace geom {
+class Geometry;
+namespace precision {
+//class CommonBitsRemover;
namespace geos {
@@ -51,117 +51,117 @@ class GEOS_DLL CommonBitsOp {
private:
- bool returnToOriginalPrecision;
+ bool returnToOriginalPrecision;
- std::unique_ptr<CommonBitsRemover> cbr;
+ std::unique_ptr<CommonBitsRemover> cbr;
- /** \brief
- * Computes a copy of the input Geometry with the calculated
- * common bits removed from each coordinate.
- * @param geom0 the Geometry to remove common bits from
- * @return a copy of the input Geometry with common bits removed
- * (caller takes responsibility of its deletion)
- geom::Geometry* removeCommonBits(const geom::Geometry *geom0);
+ /** \brief
+ * Computes a copy of the input Geometry with the calculated
+ * common bits removed from each coordinate.
+ * @param geom0 the Geometry to remove common bits from
+ * @return a copy of the input Geometry with common bits removed
+ * (caller takes responsibility of its deletion)
+ geom::Geometry* removeCommonBits(const geom::Geometry* geom0);
- /** \brief
- void removeCommonBits(
- const geom::Geometry* geom0,
- const geom::Geometry* geom1,
- std::unique_ptr<geom::Geometry>& rgeom0,
- std::unique_ptr<geom::Geometry>& rgeom1);
+ /** \brief
+ void removeCommonBits(
+ const geom::Geometry* geom0,
+ const geom::Geometry* geom1,
+ std::unique_ptr<geom::Geometry>& rgeom0,
+ std::unique_ptr<geom::Geometry>& rgeom1);
public:
- * Creates a new instance of class, which reshifts result Geometry
- CommonBitsOp();
- * Creates a new instance of class, specifying whether
- * the result {@link Geometry}s should be reshifted.
- * @param returnToOriginalPrecision
- CommonBitsOp(bool nReturnToOriginalPrecision);
- * Computes the set-theoretic intersection of two Geometry,
- * using enhanced precision.
- * @param geom0 the first Geometry
- * @param geom1 the second Geometry
- * @return the Geometry representing the set-theoretic
- * intersection of the input Geometries.
- geom::Geometry* intersection(
- const geom::Geometry *geom0,
- const geom::Geometry *geom1);
- * Computes the set-theoretic union of two Geometry,
- * @return the Geometry representing the set-theoretic union
- * of the input Geometries.
- geom::Geometry* Union(
- * Computes the set-theoretic difference of two Geometry,
- * @param geom1 the second Geometry, to be subtracted from the first
- * @return the Geometry representing the set-theoretic difference
- geom::Geometry* difference(
- * Computes the set-theoretic symmetric difference of two geometries,
- * @return the Geometry representing the set-theoretic symmetric
- * difference of the input Geometries.
- geom::Geometry* symDifference(
- * Computes the buffer a geometry,
- * @param geom0 the Geometry to buffer
- * @param distance the buffer distance
- * @return the Geometry representing the buffer of the input Geometry.
- geom::Geometry* buffer(
- double distance);
- * If required, returning the result to the orginal precision
- * if required.
- * In this current implementation, no rounding is performed on the
- * reshifted result geometry, which means that it is possible
- * that the returned Geometry is invalid.
- * @param result the result Geometry to modify
- * @return the result Geometry with the required precision
- geom::Geometry* computeResultPrecision(
- geom::Geometry *result);
+ * Creates a new instance of class, which reshifts result Geometry
+ CommonBitsOp();
+ * Creates a new instance of class, specifying whether
+ * the result {@link Geometry}s should be reshifted.
+ * @param returnToOriginalPrecision
+ CommonBitsOp(bool nReturnToOriginalPrecision);
+ * Computes the set-theoretic intersection of two Geometry,
+ * using enhanced precision.
+ * @param geom0 the first Geometry
+ * @param geom1 the second Geometry
+ * @return the Geometry representing the set-theoretic
+ * intersection of the input Geometries.
+ geom::Geometry* intersection(
+ const geom::Geometry* geom1);
+ * Computes the set-theoretic union of two Geometry,
+ * @return the Geometry representing the set-theoretic union
+ * of the input Geometries.
+ geom::Geometry* Union(
+ * Computes the set-theoretic difference of two Geometry,
+ * @param geom1 the second Geometry, to be subtracted from the first
+ * @return the Geometry representing the set-theoretic difference
+ geom::Geometry* difference(
+ * Computes the set-theoretic symmetric difference of two geometries,
+ * @return the Geometry representing the set-theoretic symmetric
+ * difference of the input Geometries.
+ geom::Geometry* symDifference(
+ * Computes the buffer a geometry,
+ * @param geom0 the Geometry to buffer
+ * @param distance the buffer distance
+ * @return the Geometry representing the buffer of the input Geometry.
+ geom::Geometry* buffer(
+ double distance);
+ * If required, returning the result to the orginal precision
+ * if required.
+ * In this current implementation, no rounding is performed on the
+ * reshifted result geometry, which means that it is possible
+ * that the returned Geometry is invalid.
+ * @param result the result Geometry to modify
+ * @return the result Geometry with the required precision
+ geom::Geometry* computeResultPrecision(
+ geom::Geometry* result);
} // namespace geos.precision
diff --git a/include/geos/precision/CommonBitsRemover.h b/include/geos/precision/CommonBitsRemover.h
index c071932..a723b1f 100644
--- a/include/geos/precision/CommonBitsRemover.h
+++ b/include/geos/precision/CommonBitsRemover.h
@@ -20,13 +20,13 @@
namespace geos {
- namespace geom {
- class Geometry;
- class CommonBitsRemover;
- class CommonCoordinateFilter;
+namespace geom {
+class Geometry;
+class CommonBitsRemover;
+class CommonCoordinateFilter;
namespace geos {
@@ -41,49 +41,49 @@ class GEOS_DLL CommonBitsRemover {
private:
- geom::Coordinate commonCoord;
+ geom::Coordinate commonCoord;
- CommonCoordinateFilter *ccFilter;
+ CommonCoordinateFilter* ccFilter;
public:
- CommonBitsRemover();
- ~CommonBitsRemover();
- * Add a geometry to the set of geometries whose common bits are
- * being computed. After this method has executed the
- * common coordinate reflects the common bits of all added
- * geometries.
- * @param geom a Geometry to test for common bits
- void add(const geom::Geometry *geom);
- * The common bits of the Coordinates in the supplied Geometries.
- geom::Coordinate& getCommonCoordinate();
- /** \brief
- * Removes the common coordinate bits from a Geometry.
- * The coordinates of the Geometry are changed.
- * @param geom the Geometry from which to remove the common
- * coordinate bits
- * @return the shifted Geometry
- geom::Geometry* removeCommonBits(geom::Geometry *geom);
- /** \brief
- * Adds the common coordinate bits back into a Geometry.
- * @param geom the Geometry to which to add the common coordinate bits
- geom::Geometry* addCommonBits(geom::Geometry *geom);
+ CommonBitsRemover();
+ ~CommonBitsRemover();
+ * Add a geometry to the set of geometries whose common bits are
+ * being computed. After this method has executed the
+ * common coordinate reflects the common bits of all added
+ * geometries.
+ * @param geom a Geometry to test for common bits
+ void add(const geom::Geometry* geom);
+ * The common bits of the Coordinates in the supplied Geometries.
+ geom::Coordinate& getCommonCoordinate();
+ /** \brief
+ * Removes the common coordinate bits from a Geometry.
+ * The coordinates of the Geometry are changed.
+ * @param geom the Geometry from which to remove the common
+ * coordinate bits
+ * @return the shifted Geometry
+ geom::Geometry* removeCommonBits(geom::Geometry* geom);
+ /** \brief
+ * Adds the common coordinate bits back into a Geometry.
+ * @param geom the Geometry to which to add the common coordinate bits
+ geom::Geometry* addCommonBits(geom::Geometry* geom);
diff --git a/include/geos/precision/EnhancedPrecisionOp.h b/include/geos/precision/EnhancedPrecisionOp.h
index 50f691e..df8ba79 100644
--- a/include/geos/precision/EnhancedPrecisionOp.h
+++ b/include/geos/precision/EnhancedPrecisionOp.h
@@ -24,9 +24,9 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
namespace geos {
@@ -41,67 +41,67 @@ class GEOS_DLL EnhancedPrecisionOp {
public:
- /** \brief
- * Geometrys, using enhanced precision.
- static geom::Geometry* intersection(
+ /** \brief
+ * Geometrys, using enhanced precision.
+ static geom::Geometry* intersection(
- * Computes the set-theoretic union of two Geometrys,
- * union of the input Geometries.
- static geom::Geometry* Union(
+ * Computes the set-theoretic union of two Geometrys,
+ * union of the input Geometries.
+ static geom::Geometry* Union(
- * Computes the set-theoretic difference of two Geometrys,
- static geom::Geometry* difference(
+ * Computes the set-theoretic difference of two Geometrys,
+ static geom::Geometry* difference(
- static geom::Geometry* symDifference(
+ static geom::Geometry* symDifference(
- * Computes the buffer of a Geometry, using enhanced precision.
- * This method should no longer be necessary, since the buffer
- * algorithm now is highly robust.
- static geom::Geometry* buffer(
- const geom::Geometry *geom,
- double distance);
+ * Computes the buffer of a Geometry, using enhanced precision.
+ * This method should no longer be necessary, since the buffer
+ * algorithm now is highly robust.
+ static geom::Geometry* buffer(
+ const geom::Geometry* geom,
+ double distance);
diff --git a/include/geos/precision/GeometryPrecisionReducer.h b/include/geos/precision/GeometryPrecisionReducer.h
index 861c327..5999839 100644
--- a/include/geos/precision/GeometryPrecisionReducer.h
+++ b/include/geos/precision/GeometryPrecisionReducer.h
@@ -25,11 +25,11 @@
// Forward declarations
namespace geos {
- namespace geom {
- class PrecisionModel;
- class GeometryFactory;
- class Geometry;
+namespace geom {
+class PrecisionModel;
+class GeometryFactory;
+class Geometry;
namespace geos {
@@ -44,116 +44,121 @@ class GEOS_DLL GeometryPrecisionReducer {
private:
- // Externally owned
- const geom::GeometryFactory *newFactory;
+ // Externally owned
+ const geom::GeometryFactory* newFactory;
- const geom::PrecisionModel &targetPM;
+ const geom::PrecisionModel& targetPM;
- bool removeCollapsed;
+ bool removeCollapsed;
- bool isPointwise;
+ bool isPointwise;
- std::unique_ptr<geom::Geometry> reducePointwise( const geom::Geometry& geom );
+ std::unique_ptr<geom::Geometry> reducePointwise(const geom::Geometry& geom);
- std::unique_ptr<geom::Geometry> fixPolygonalTopology(
- const geom::Geometry& geom );
+ std::unique_ptr<geom::Geometry> fixPolygonalTopology(
+ const geom::Geometry& geom);
- geom::GeometryFactory::Ptr createFactory(
- const geom::GeometryFactory& oldGF,
- const geom::PrecisionModel& newPM );
+ geom::GeometryFactory::Ptr createFactory(
+ const geom::GeometryFactory& oldGF,
+ const geom::PrecisionModel& newPM);
- GeometryPrecisionReducer(GeometryPrecisionReducer const&); /*= delete*/
- GeometryPrecisionReducer& operator=(GeometryPrecisionReducer const&); /*= delete*/
+ GeometryPrecisionReducer(GeometryPrecisionReducer const&); /*= delete*/
+ GeometryPrecisionReducer& operator=(GeometryPrecisionReducer const&); /*= delete*/
public:
- * Convenience method for doing precision reduction
- * on a single geometry,
- * with collapses removed
- * and keeping the geometry precision model the same,
- * and preserving polygonal topology.
- * @param g the geometry to reduce
- * @param precModel the precision model to use
- * @return the reduced geometry
- static std::unique_ptr<geom::Geometry> reduce(
- const geom::Geometry &g,
- const geom::PrecisionModel &precModel )
- GeometryPrecisionReducer reducer(precModel);
- return reducer.reduce(g);
- * but NOT preserving valid polygonal topology.
- static std::unique_ptr<geom::Geometry> reducePointwise(
- reducer.setPointwise(true);
- GeometryPrecisionReducer(const geom::PrecisionModel &pm)
- newFactory(nullptr),
- targetPM(pm),
- removeCollapsed(true),
- isPointwise(false)
- * \brief
- * Create a reducer that will change the precision model of the
- * new reduced Geometry
- * @param gf the factory for the created Geometry.
- * Its PrecisionModel will be used for the reduction.
- * NOTE: ownership left to caller must be kept alive for
- * the whole lifetime of the returned Geometry.
- GeometryPrecisionReducer(const geom::GeometryFactory &gf);
- * Sets whether the reduction will result in collapsed components
- * being removed completely, or simply being collapsed to an (invalid)
- * Geometry of the same type.
- * @param remove if <code>true</code> collapsed components will be removed
- void setRemoveCollapsedComponents(bool remove) {
- removeCollapsed = remove;
- /** \brief
- * Sets whether the precision reduction will be done
- * in pointwise fashion only.
- * Pointwise precision reduction reduces the precision
- * of the individual coordinates only, but does
- * not attempt to recreate valid topology.
- * This is only relevant for geometries containing polygonal components.
- * @param pointwise if reduction should be done pointwise only
- void setPointwise(bool pointwise)
- isPointwise = pointwise;
- std::unique_ptr<geom::Geometry> reduce(const geom::Geometry& geom);
+ * Convenience method for doing precision reduction
+ * on a single geometry,
+ * with collapses removed
+ * and keeping the geometry precision model the same,
+ * and preserving polygonal topology.
+ * @param g the geometry to reduce
+ * @param precModel the precision model to use
+ * @return the reduced geometry
+ static std::unique_ptr<geom::Geometry>
+ reduce(
+ const geom::Geometry& g,
+ const geom::PrecisionModel& precModel)
+ GeometryPrecisionReducer reducer(precModel);
+ return reducer.reduce(g);
+ * but NOT preserving valid polygonal topology.
+ reducePointwise(
+ reducer.setPointwise(true);
+ GeometryPrecisionReducer(const geom::PrecisionModel& pm)
+ newFactory(nullptr),
+ targetPM(pm),
+ removeCollapsed(true),
+ isPointwise(false)
+ * \brief
+ * Create a reducer that will change the precision model of the
+ * new reduced Geometry
+ * @param gf the factory for the created Geometry.
+ * Its PrecisionModel will be used for the reduction.
+ * NOTE: ownership left to caller must be kept alive for
+ * the whole lifetime of the returned Geometry.
+ GeometryPrecisionReducer(const geom::GeometryFactory& gf);
+ * Sets whether the reduction will result in collapsed components
+ * being removed completely, or simply being collapsed to an (invalid)
+ * Geometry of the same type.
+ * @param remove if <code>true</code> collapsed components will be removed
+ void
+ setRemoveCollapsedComponents(bool remove)
+ removeCollapsed = remove;
+ /** \brief
+ * Sets whether the precision reduction will be done
+ * in pointwise fashion only.
+ * Pointwise precision reduction reduces the precision
+ * of the individual coordinates only, but does
+ * not attempt to recreate valid topology.
+ * This is only relevant for geometries containing polygonal components.
+ * @param pointwise if reduction should be done pointwise only
+ void
+ setPointwise(bool pointwise)
+ isPointwise = pointwise;
+ std::unique_ptr<geom::Geometry> reduce(const geom::Geometry& geom);
diff --git a/include/geos/precision/MinimumClearance.h b/include/geos/precision/MinimumClearance.h
index d33ac9b..9fcd226 100644
--- a/include/geos/precision/MinimumClearance.h
+++ b/include/geos/precision/MinimumClearance.h
@@ -26,31 +26,31 @@
namespace geos {
class GEOS_DLL MinimumClearance {
- private:
- const geom::Geometry* inputGeom;
- double minClearance;
- std::unique_ptr<geom::CoordinateSequence> minClearancePts;
- void compute();
- public:
- MinimumClearance(const geom::Geometry* g);
- * Gets the Minimum Clearance distance.
- * @return the value of the minimum clearance distance
- * or <tt>DBL_MAX</tt> if no Minimum Clearance distance exists
- double getDistance();
- * Gets a LineString containing two points
- * which are at the Minimum Clearance distance.
- * or <tt>LINESTRING EMPTY</tt> if no Minimum Clearance distance exists
- std::unique_ptr<geom::LineString> getLine();
+private:
+ const geom::Geometry* inputGeom;
+ double minClearance;
+ std::unique_ptr<geom::CoordinateSequence> minClearancePts;
+ void compute();
+public:
+ MinimumClearance(const geom::Geometry* g);
+ * Gets the Minimum Clearance distance.
+ * @return the value of the minimum clearance distance
+ * or <tt>DBL_MAX</tt> if no Minimum Clearance distance exists
+ double getDistance();
+ * Gets a LineString containing two points
+ * which are at the Minimum Clearance distance.
+ * or <tt>LINESTRING EMPTY</tt> if no Minimum Clearance distance exists
+ std::unique_ptr<geom::LineString> getLine();
diff --git a/include/geos/precision/PrecisionReducerCoordinateOperation.h b/include/geos/precision/PrecisionReducerCoordinateOperation.h
index 90cb5ee..195c502 100644
--- a/include/geos/precision/PrecisionReducerCoordinateOperation.h
+++ b/include/geos/precision/PrecisionReducerCoordinateOperation.h
@@ -23,43 +23,42 @@
namespace geos {
- namespace geom {
- class CoordinateSequence;
- class Geometry;
+namespace geom {
+class CoordinateSequence;
+class Geometry;
namespace geos {
namespace precision { // geos.precision
class PrecisionReducerCoordinateOperation :
- public geom::util::CoordinateOperation
-using CoordinateOperation::edit;
+ public geom::util::CoordinateOperation {
+ using CoordinateOperation::edit;
private:
- const geom::PrecisionModel& targetPM;
PrecisionReducerCoordinateOperation(PrecisionReducerCoordinateOperation const&); /*= delete*/
PrecisionReducerCoordinateOperation& operator=(PrecisionReducerCoordinateOperation const&); /*= delete*/
public:
- PrecisionReducerCoordinateOperation( const geom::PrecisionModel& pm,
- bool doRemoveCollapsed )
- targetPM(pm),
- removeCollapsed(doRemoveCollapsed)
+ PrecisionReducerCoordinateOperation(const geom::PrecisionModel& pm,
+ bool doRemoveCollapsed)
+ targetPM(pm),
+ removeCollapsed(doRemoveCollapsed)
- /// Ownership of returned CoordinateSequence to caller
- /// virtual function
- geom::CoordinateSequence* edit(const geom::CoordinateSequence *coordinates,
- const geom::Geometry *geom) override;
+ /// Ownership of returned CoordinateSequence to caller
+ /// virtual function
+ geom::CoordinateSequence* edit(const geom::CoordinateSequence* coordinates,
+ const geom::Geometry* geom) override;
diff --git a/include/geos/precision/SimpleGeometryPrecisionReducer.h b/include/geos/precision/SimpleGeometryPrecisionReducer.h
index c212ee5..83e1367 100644
--- a/include/geos/precision/SimpleGeometryPrecisionReducer.h
+++ b/include/geos/precision/SimpleGeometryPrecisionReducer.h
@@ -19,10 +19,10 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
namespace geos {
@@ -45,42 +45,42 @@ class GEOS_DLL SimpleGeometryPrecisionReducer {
private:
- const geom::PrecisionModel *newPrecisionModel;
+ const geom::PrecisionModel* newPrecisionModel;
- //bool changePrecisionModel;
+ //bool changePrecisionModel;
public:
- SimpleGeometryPrecisionReducer(const geom::PrecisionModel *pm);
- * @param removeCollapsed if <code>true</code> collapsed
- * components will be removed
- void setRemoveCollapsedComponents(bool nRemoveCollapsed);
- * Sets whether the {@link PrecisionModel} of the new reduced Geometry
- * will be changed to be the {@link PrecisionModel} supplied to
- * specify the reduction. The default is to not change the
- * precision model
- * @param changePrecisionModel if <code>true</code> the precision
- * model of the created Geometry will be the
- * the precisionModel supplied in the constructor.
- //void setChangePrecisionModel(bool nChangePrecisionModel);
- const geom::PrecisionModel* getPrecisionModel();
- bool getRemoveCollapsed();
- geom::Geometry* reduce(const geom::Geometry *geom);
+ SimpleGeometryPrecisionReducer(const geom::PrecisionModel* pm);
+ * @param removeCollapsed if <code>true</code> collapsed
+ * components will be removed
+ void setRemoveCollapsedComponents(bool nRemoveCollapsed);
+ * Sets whether the {@link PrecisionModel} of the new reduced Geometry
+ * will be changed to be the {@link PrecisionModel} supplied to
+ * specify the reduction. The default is to not change the
+ * precision model
+ * @param changePrecisionModel if <code>true</code> the precision
+ * model of the created Geometry will be the
+ * the precisionModel supplied in the constructor.
+ //void setChangePrecisionModel(bool nChangePrecisionModel);
+ const geom::PrecisionModel* getPrecisionModel();
+ bool getRemoveCollapsed();
+ geom::Geometry* reduce(const geom::Geometry* geom);
diff --git a/include/geos/profiler.h b/include/geos/profiler.h
index b6f951a..853d598 100644
--- a/include/geos/profiler.h
+++ b/include/geos/profiler.h
@@ -26,10 +26,10 @@
#include <sys/time.h>
extern "C" {
- extern _CRTIMP void __cdecl _tzset (void);
- __MINGW_IMPORT int _daylight;
- __MINGW_IMPORT long _timezone;
- __MINGW_IMPORT char *_tzname[2];
+ extern _CRTIMP void __cdecl _tzset(void);
+ __MINGW_IMPORT int _daylight;
+ __MINGW_IMPORT long _timezone;
+ __MINGW_IMPORT char* _tzname[2];
#endif
@@ -65,74 +65,82 @@ namespace util {
class GEOS_DLL Profile {
public:
- /** \brief Create a named profile */
- Profile(std::string name);
- /** \brief Destructor */
- ~Profile();
- /** \brief start a new timer */
- void start() {
- gettimeofday(&starttime, nullptr);
- /** \brief stop current timer */
- void stop()
- gettimeofday(&stoptime, nullptr);
- double elapsed = static_cast<double>(
- 1000000 * (stoptime.tv_sec - starttime.tv_sec)
- + (stoptime.tv_usec - starttime.tv_usec));
- timings.push_back(elapsed);
- totaltime += elapsed;
- if ( timings.size() == 1 ) max = min = elapsed;
- else
- if ( elapsed > max ) max = elapsed;
- if ( elapsed < min ) min = elapsed;
- avg = totaltime / static_cast<double>(timings.size());
- /** \brief Return Max stored timing */
- double getMax() const;
- /** \brief Return Min stored timing */
- double getMin() const;
- /** \brief Return total timing */
- double getTot() const;
- /** \brief Return average timing */
- double getAvg() const;
- /** \brief Return number of timings */
- size_t getNumTimings() const;
- /** \brief Profile name */
- std::string name;
+ /** \brief Create a named profile */
+ Profile(std::string name);
+ /** \brief Destructor */
+ ~Profile();
+ /** \brief start a new timer */
+ void
+ start()
+ gettimeofday(&starttime, nullptr);
+ /** \brief stop current timer */
+ void
+ stop()
+ gettimeofday(&stoptime, nullptr);
+ double elapsed = static_cast<double>(
+ 1000000 * (stoptime.tv_sec - starttime.tv_sec)
+ + (stoptime.tv_usec - starttime.tv_usec));
+ timings.push_back(elapsed);
+ totaltime += elapsed;
+ if(timings.size() == 1) {
+ max = min = elapsed;
+ else {
+ if(elapsed > max) {
+ max = elapsed;
+ if(elapsed < min) {
+ min = elapsed;
+ avg = totaltime / static_cast<double>(timings.size());
+ /** \brief Return Max stored timing */
+ double getMax() const;
+ /** \brief Return Min stored timing */
+ double getMin() const;
+ /** \brief Return total timing */
+ double getTot() const;
+ /** \brief Return average timing */
+ double getAvg() const;
+ /** \brief Return number of timings */
+ size_t getNumTimings() const;
+ /** \brief Profile name */
+ std::string name;
private:
- /* \brief current start and stop times */
- struct timeval starttime, stoptime;
+ /* \brief current start and stop times */
+ struct timeval starttime, stoptime;
- /* \brief actual times */
- std::vector<double> timings;
+ /* \brief actual times */
+ std::vector<double> timings;
- /* \brief total time */
- double totaltime;
+ /* \brief total time */
+ double totaltime;
- /* \brief max time */
- double max;
+ /* \brief max time */
+ double max;
- double min;
+ double min;
- double avg;
+ double avg;
@@ -146,34 +154,34 @@ class GEOS_DLL Profiler {
public:
- Profiler();
- ~Profiler();
- * \brief
- * Return the singleton instance of the
- * profiler.
- static Profiler *instance(void);
- * \brief
- * Start timer for named task. The task is
- * created if does not exist.
- void start(std::string name);
- * \brief
- * Stop timer for named task.
- * Elapsed time is registered in the given task.
- void stop(std::string name);
- /** \brief get Profile of named task */
- Profile *get(std::string name);
- std::map<std::string, Profile *> profs;
+ Profiler();
+ ~Profiler();
+ * \brief
+ * Return the singleton instance of the
+ * profiler.
+ static Profiler* instance(void);
+ * \brief
+ * Start timer for named task. The task is
+ * created if does not exist.
+ void start(std::string name);
+ * \brief
+ * Stop timer for named task.
+ * Elapsed time is registered in the given task.
+ void stop(std::string name);
+ /** \brief get Profile of named task */
+ Profile* get(std::string name);
+ std::map<std::string, Profile*> profs;
diff --git a/include/geos/simplify/DouglasPeuckerLineSimplifier.h b/include/geos/simplify/DouglasPeuckerLineSimplifier.h
index 4bc39d3..6d67482 100644
--- a/include/geos/simplify/DouglasPeuckerLineSimplifier.h
+++ b/include/geos/simplify/DouglasPeuckerLineSimplifier.h
@@ -30,9 +30,9 @@
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -46,46 +46,46 @@ class GEOS_DLL DouglasPeuckerLineSimplifier {
public:
- typedef std::vector<short int> BoolVect;
- typedef std::unique_ptr<BoolVect> BoolVectAutoPtr;
+ typedef std::vector<short int> BoolVect;
+ typedef std::unique_ptr<BoolVect> BoolVectAutoPtr;
- typedef std::vector<geom::Coordinate> CoordsVect;
- typedef std::unique_ptr<CoordsVect> CoordsVectAutoPtr;
+ typedef std::vector<geom::Coordinate> CoordsVect;
+ typedef std::unique_ptr<CoordsVect> CoordsVectAutoPtr;
- /** \brief
- * Returns a newly allocated Coordinate vector, wrapped
- * into an unique_ptr
- static CoordsVectAutoPtr simplify(
- const CoordsVect& nPts,
- double distanceTolerance);
+ /** \brief
+ * Returns a newly allocated Coordinate vector, wrapped
+ * into an unique_ptr
+ static CoordsVectAutoPtr simplify(
+ const CoordsVect& nPts,
+ double distanceTolerance);
- DouglasPeuckerLineSimplifier(const CoordsVect& nPts);
+ DouglasPeuckerLineSimplifier(const CoordsVect& nPts);
- /** \brief
- * Sets the distance tolerance for the simplification.
- * All vertices in the simplified linestring will be within this
- * distance of the original linestring.
- * @param nDistanceTolerance the approximation tolerance to use
- void setDistanceTolerance(double nDistanceTolerance);
+ /** \brief
+ * Sets the distance tolerance for the simplification.
+ * All vertices in the simplified linestring will be within this
+ * distance of the original linestring.
+ * @param nDistanceTolerance the approximation tolerance to use
+ void setDistanceTolerance(double nDistanceTolerance);
- /** \brief
- CoordsVectAutoPtr simplify();
+ /** \brief
+ CoordsVectAutoPtr simplify();
private:
- const CoordsVect& pts;
- BoolVectAutoPtr usePt;
- double distanceTolerance;
+ const CoordsVect& pts;
+ BoolVectAutoPtr usePt;
+ double distanceTolerance;
- void simplifySection(std::size_t i, std::size_t j);
+ void simplifySection(std::size_t i, std::size_t j);
DouglasPeuckerLineSimplifier(const DouglasPeuckerLineSimplifier& other) = delete;
diff --git a/include/geos/simplify/DouglasPeuckerSimplifier.h b/include/geos/simplify/DouglasPeuckerSimplifier.h
index d6c80f5..0190072 100644
--- a/include/geos/simplify/DouglasPeuckerSimplifier.h
+++ b/include/geos/simplify/DouglasPeuckerSimplifier.h
@@ -24,9 +24,9 @@
namespace geos {
- namespace geom {
- class Geometry;
+namespace geom {
+class Geometry;
namespace geos {
@@ -51,32 +51,32 @@ class GEOS_DLL DouglasPeuckerSimplifier {
public:
- static std::unique_ptr<geom::Geometry> simplify(
- const geom::Geometry* geom,
- double tolerance);
+ static std::unique_ptr<geom::Geometry> simplify(
+ double tolerance);
- DouglasPeuckerSimplifier(const geom::Geometry* geom);
+ DouglasPeuckerSimplifier(const geom::Geometry* geom);
- /** \brief
- * All vertices in the simplified geometry will be within this
- * distance of the original geometry.
- * The tolerance value must be non-negative. A tolerance value
- * of zero is effectively a no-op.
- * @param distanceTolerance the approximation tolerance to use
- void setDistanceTolerance(double tolerance);
+ /** \brief
+ * All vertices in the simplified geometry will be within this
+ * distance of the original geometry.
+ * The tolerance value must be non-negative. A tolerance value
+ * of zero is effectively a no-op.
+ * @param distanceTolerance the approximation tolerance to use
+ void setDistanceTolerance(double tolerance);
- std::unique_ptr<geom::Geometry> getResultGeometry();
+ std::unique_ptr<geom::Geometry> getResultGeometry();
private:
diff --git a/include/geos/simplify/LineSegmentIndex.h b/include/geos/simplify/LineSegmentIndex.h
index 307e9a8..aa25133 100644
--- a/include/geos/simplify/LineSegmentIndex.h
+++ b/include/geos/simplify/LineSegmentIndex.h
@@ -36,12 +36,12 @@
namespace geos {
- namespace geom {
- class LineSegment;
- namespace simplify {
- class TaggedLineString;
+namespace geom {
+class LineSegment;
+namespace simplify {
+class TaggedLineString;
namespace geos {
@@ -51,32 +51,32 @@ class GEOS_DLL LineSegmentIndex {
public:
- LineSegmentIndex() = default;
+ LineSegmentIndex() = default;
- ~LineSegmentIndex() = default;
+ ~LineSegmentIndex() = default;
- void add(const TaggedLineString& line);
+ void add(const TaggedLineString& line);
- void add(const geom::LineSegment* seg);
+ void add(const geom::LineSegment* seg);
- void remove(const geom::LineSegment* seg);
+ void remove(const geom::LineSegment* seg);
- std::unique_ptr< std::vector<geom::LineSegment*> >
- query(const geom::LineSegment* seg);
+ std::unique_ptr< std::vector<geom::LineSegment*> >
+ query(const geom::LineSegment* seg);
private:
- index::quadtree::Quadtree index;
+ index::quadtree::Quadtree index;
- std::vector<std::unique_ptr<geom::Envelope>> newEnvelopes;
+ std::vector<std::unique_ptr<geom::Envelope>> newEnvelopes;
* Disable copy construction and assignment. Apparently needed to make this
* class compile under MSVC. (See https://stackoverflow.com/q/29565299)
- LineSegmentIndex(const LineSegmentIndex&) = delete;
- LineSegmentIndex& operator=(const LineSegmentIndex&) = delete;
+ LineSegmentIndex(const LineSegmentIndex&) = delete;
+ LineSegmentIndex& operator=(const LineSegmentIndex&) = delete;
} // namespace geos::simplify
diff --git a/include/geos/simplify/TaggedLineSegment.h b/include/geos/simplify/TaggedLineSegment.h
index 46bd2e5..d4be09a 100644
--- a/include/geos/simplify/TaggedLineSegment.h
+++ b/include/geos/simplify/TaggedLineSegment.h
@@ -35,10 +35,10 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Geometry;
+namespace geom {
+class Coordinate;
+class Geometry;
namespace geos {
@@ -51,30 +51,29 @@ namespace simplify { // geos::simplify
* Used to index the segments in a geometry and recover the segment locations
* from the index.
-class GEOS_DLL TaggedLineSegment: public geom::LineSegment
+class GEOS_DLL TaggedLineSegment: public geom::LineSegment {
public:
- TaggedLineSegment(const geom::Coordinate& p0,
- const geom::Coordinate& p1,
- const geom::Geometry* parent,
- size_t index);
+ TaggedLineSegment(const geom::Coordinate& p0,
+ const geom::Coordinate& p1,
+ const geom::Geometry* parent,
+ size_t index);
- const geom::Coordinate& p1);
+ const geom::Coordinate& p1);
- TaggedLineSegment(const TaggedLineSegment& ls);
+ TaggedLineSegment(const TaggedLineSegment& ls);
- const geom::Geometry* getParent() const;
+ const geom::Geometry* getParent() const;
- size_t getIndex() const;
+ size_t getIndex() const;
private:
- const geom::Geometry* parent;
+ const geom::Geometry* parent;
- size_t index;
+ size_t index;
diff --git a/include/geos/simplify/TaggedLineString.h b/include/geos/simplify/TaggedLineString.h
index d21a904..1a3c8bf 100644
--- a/include/geos/simplify/TaggedLineString.h
+++ b/include/geos/simplify/TaggedLineString.h
@@ -36,16 +36,16 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Geometry;
- class LineString;
- class LinearRing;
- class TaggedLineSegment;
+namespace geom {
+class Coordinate;
+class Geometry;
+class LineString;
+class LinearRing;
+class TaggedLineSegment;
namespace geos {
@@ -61,63 +61,63 @@ class GEOS_DLL TaggedLineString {
public:
- typedef std::vector<geom::Coordinate> CoordVect;
+ typedef std::vector<geom::Coordinate> CoordVect;
- typedef std::unique_ptr<CoordVect> CoordVectPtr;
+ typedef std::unique_ptr<CoordVect> CoordVectPtr;
- typedef geom::CoordinateSequence CoordSeq;
+ typedef geom::CoordinateSequence CoordSeq;
- typedef std::unique_ptr<geom::CoordinateSequence> CoordSeqPtr;
+ typedef std::unique_ptr<geom::CoordinateSequence> CoordSeqPtr;
- TaggedLineString(const geom::LineString* nParentLine,
- std::size_t minimumSize=2);
+ TaggedLineString(const geom::LineString* nParentLine,
+ std::size_t minimumSize = 2);
- ~TaggedLineString();
+ ~TaggedLineString();
- std::size_t getMinimumSize() const;
+ std::size_t getMinimumSize() const;
- const geom::LineString* getParent() const;
+ const geom::LineString* getParent() const;
- const CoordSeq* getParentCoordinates() const;
+ const CoordSeq* getParentCoordinates() const;
- CoordSeqPtr getResultCoordinates() const;
+ CoordSeqPtr getResultCoordinates() const;
- std::size_t getResultSize() const;
+ std::size_t getResultSize() const;
- TaggedLineSegment* getSegment(std::size_t i);
+ TaggedLineSegment* getSegment(std::size_t i);
- const TaggedLineSegment* getSegment(std::size_t i) const;
+ const TaggedLineSegment* getSegment(std::size_t i) const;
- std::vector<TaggedLineSegment*>& getSegments();
+ std::vector<TaggedLineSegment*>& getSegments();
- const std::vector<TaggedLineSegment*>& getSegments() const;
+ const std::vector<TaggedLineSegment*>& getSegments() const;
- void addToResult(std::unique_ptr<TaggedLineSegment> seg);
+ void addToResult(std::unique_ptr<TaggedLineSegment> seg);
- std::unique_ptr<geom::Geometry> asLineString() const;
+ std::unique_ptr<geom::Geometry> asLineString() const;
- std::unique_ptr<geom::Geometry> asLinearRing() const;
+ std::unique_ptr<geom::Geometry> asLinearRing() const;
private:
- const geom::LineString* parentLine;
+ const geom::LineString* parentLine;
- // TaggedLineSegments owned by this object
- std::vector<TaggedLineSegment*> segs;
+ // TaggedLineSegments owned by this object
+ std::vector<TaggedLineSegment*> segs;
- std::vector<TaggedLineSegment*> resultSegs;
+ std::vector<TaggedLineSegment*> resultSegs;
- std::size_t minimumSize;
+ std::size_t minimumSize;
- void init();
+ void init();
- static CoordVectPtr extractCoordinates(
- const std::vector<TaggedLineSegment*>& segs);
+ static CoordVectPtr extractCoordinates(
+ const std::vector<TaggedLineSegment*>& segs);
- // Copying is turned off
- TaggedLineString(const TaggedLineString&);
- TaggedLineString& operator= (const TaggedLineString&);
+ // Copying is turned off
+ TaggedLineString(const TaggedLineString&);
+ TaggedLineString& operator= (const TaggedLineString&);
diff --git a/include/geos/simplify/TaggedLineStringSimplifier.h b/include/geos/simplify/TaggedLineStringSimplifier.h
index dae0571..b1166f5 100644
--- a/include/geos/simplify/TaggedLineStringSimplifier.h
+++ b/include/geos/simplify/TaggedLineStringSimplifier.h
@@ -36,18 +36,18 @@
namespace geos {
- namespace algorithm {
- class LineIntersector;
- namespace geom {
- class LineSegmentIndex;
+namespace algorithm {
+class LineIntersector;
+namespace geom {
+class LineSegment;
+class LineSegmentIndex;
namespace geos {
@@ -64,100 +64,100 @@ class GEOS_DLL TaggedLineStringSimplifier {
public:
- TaggedLineStringSimplifier(LineSegmentIndex* inputIndex,
- LineSegmentIndex* outputIndex);
+ TaggedLineStringSimplifier(LineSegmentIndex* inputIndex,
+ LineSegmentIndex* outputIndex);
- /** \brief
- * @param d the approximation tolerance to use
- void setDistanceTolerance(double d);
+ /** \brief
+ * @param d the approximation tolerance to use
+ void setDistanceTolerance(double d);
- * Simplifies the given {@link TaggedLineString}
- * using the distance tolerance specified.
- * @param line the linestring to simplify
- void simplify(TaggedLineString* line);
+ * Simplifies the given {@link TaggedLineString}
+ * using the distance tolerance specified.
+ * @param line the linestring to simplify
+ void simplify(TaggedLineString* line);
private:
- // externally owned
- LineSegmentIndex* inputIndex;
+ // externally owned
+ LineSegmentIndex* inputIndex;
- LineSegmentIndex* outputIndex;
+ LineSegmentIndex* outputIndex;
- std::unique_ptr<algorithm::LineIntersector> li;
+ std::unique_ptr<algorithm::LineIntersector> li;
- /// non-const as segments are possibly added to it
- TaggedLineString* line;
+ /// non-const as segments are possibly added to it
+ TaggedLineString* line;
- const geom::CoordinateSequence* linePts;
+ const geom::CoordinateSequence* linePts;
- void simplifySection(std::size_t i, std::size_t j,
- std::size_t depth);
+ void simplifySection(std::size_t i, std::size_t j,
+ std::size_t depth);
- static std::size_t findFurthestPoint(
- const geom::CoordinateSequence* pts,
- std::size_t i, std::size_t j,
- double& maxDistance);
+ static std::size_t findFurthestPoint(
+ const geom::CoordinateSequence* pts,
+ std::size_t i, std::size_t j,
+ double& maxDistance);
- bool hasBadIntersection(const TaggedLineString* parentLine,
- const std::pair<std::size_t, std::size_t>& sectionIndex,
- const geom::LineSegment& candidateSeg);
+ bool hasBadIntersection(const TaggedLineString* parentLine,
+ const std::pair<std::size_t, std::size_t>& sectionIndex,
+ const geom::LineSegment& candidateSeg);
- bool hasBadInputIntersection(const TaggedLineString* parentLine,
+ bool hasBadInputIntersection(const TaggedLineString* parentLine,
- bool hasBadOutputIntersection(const geom::LineSegment& candidateSeg);
+ bool hasBadOutputIntersection(const geom::LineSegment& candidateSeg);
- bool hasInteriorIntersection(const geom::LineSegment& seg0,
- const geom::LineSegment& seg1) const;
+ bool hasInteriorIntersection(const geom::LineSegment& seg0,
+ const geom::LineSegment& seg1) const;
- std::unique_ptr<TaggedLineSegment> flatten(
- std::size_t start, std::size_t end);
+ std::unique_ptr<TaggedLineSegment> flatten(
+ std::size_t start, std::size_t end);
- /** \brief
- * Tests whether a segment is in a section of a TaggedLineString
- * @param line
- * @param sectionIndex
- * @param seg
- * @return
- static bool isInLineSection(
- const TaggedLineString* parentLine,
- const TaggedLineSegment* seg);
+ /** \brief
+ * Tests whether a segment is in a section of a TaggedLineString
+ * @param line
+ * @param sectionIndex
+ * @param seg
+ * @return
+ static bool isInLineSection(
+ const TaggedLineString* parentLine,
+ const TaggedLineSegment* seg);
- /** \brief
- * Remove the segs in the section of the line
- * @param line
- * @param pts
- * @param sectionStartIndex
- * @param sectionEndIndex
- void remove(const TaggedLineString* line,
- std::size_t end);
+ /** \brief
+ * Remove the segs in the section of the line
+ * @param line
+ * @param pts
+ * @param sectionStartIndex
+ * @param sectionEndIndex
+ void remove(const TaggedLineString* line,
+ std::size_t end);
inline void
TaggedLineStringSimplifier::setDistanceTolerance(double d)
- distanceTolerance = d;
+ distanceTolerance = d;
diff --git a/include/geos/simplify/TaggedLinesSimplifier.h b/include/geos/simplify/TaggedLinesSimplifier.h
index 11c2ce7..d8fa3f7 100644
--- a/include/geos/simplify/TaggedLinesSimplifier.h
+++ b/include/geos/simplify/TaggedLinesSimplifier.h
@@ -41,9 +41,9 @@
namespace geos {
namespace geos {
@@ -57,59 +57,60 @@ class GEOS_DLL TaggedLinesSimplifier {
public:
- TaggedLinesSimplifier();
- /** \brief
- * @param tolerance the approximation tolerance to use
- * Simplify a set of {@link TaggedLineString}s
- * @param iterator_type
- * an iterator, must support assignment, increment,
- * inequality and dereference operators.
- * Dereference operator must return a TaggedLineString*
- * @param begin iterator to the first element
- * to be simplified.
- * @param end an iterator to one-past-last element
- template <class iterator_type>
- void simplify(
- iterator_type begin,
- iterator_type end)
- // add lines to the index
- for (iterator_type it=begin; it != end; ++it) {
- assert(*it);
- inputIndex->add(*(*it));
- // Simplify lines
- assert(*it);
- simplify(*(*it));
+ TaggedLinesSimplifier();
+ /** \brief
+ * @param tolerance the approximation tolerance to use
+ * Simplify a set of {@link TaggedLineString}s
+ * @param iterator_type
+ * an iterator, must support assignment, increment,
+ * inequality and dereference operators.
+ * Dereference operator must return a TaggedLineString*
+ * @param begin iterator to the first element
+ * to be simplified.
+ * @param end an iterator to one-past-last element
+ template <class iterator_type>
+ void
+ simplify(
+ iterator_type begin,
+ iterator_type end)
+ // add lines to the index
+ for(iterator_type it = begin; it != end; ++it) {
+ assert(*it);
+ inputIndex->add(*(*it));
+ // Simplify lines
+ assert(*it);
+ simplify(*(*it));
private:
- void simplify(TaggedLineString& line);
+ void simplify(TaggedLineString& line);
- std::unique_ptr<LineSegmentIndex> inputIndex;
+ std::unique_ptr<LineSegmentIndex> inputIndex;
- std::unique_ptr<LineSegmentIndex> outputIndex;
+ std::unique_ptr<LineSegmentIndex> outputIndex;
- std::unique_ptr<TaggedLineStringSimplifier> taggedlineSimplifier;
+ std::unique_ptr<TaggedLineStringSimplifier> taggedlineSimplifier;
diff --git a/include/geos/simplify/TopologyPreservingSimplifier.h b/include/geos/simplify/TopologyPreservingSimplifier.h
index 8c38140..afba135 100644
--- a/include/geos/simplify/TopologyPreservingSimplifier.h
+++ b/include/geos/simplify/TopologyPreservingSimplifier.h
@@ -55,36 +55,35 @@ namespace simplify { // geos::simplify
* (although they may touch at fewer points)
-class GEOS_DLL TopologyPreservingSimplifier
+class GEOS_DLL TopologyPreservingSimplifier {
public:
- TopologyPreservingSimplifier(const geom::Geometry* geom);
+ TopologyPreservingSimplifier(const geom::Geometry* geom);
- /** \brief
+ /** \brief
private:
- std::unique_ptr<TaggedLinesSimplifier> lineSimplifier;
+ std::unique_ptr<TaggedLinesSimplifier> lineSimplifier;
diff --git a/include/geos/timeval.h b/include/geos/timeval.h
index 7985394..3ece94e 100644
--- a/include/geos/timeval.h
+++ b/include/geos/timeval.h
@@ -51,15 +51,15 @@ struct timezone {
#if !defined(_WIN32_WCE)
-__inline int gettimeofday(struct timeval *tv, struct timezone *tz)
+__inline int
+gettimeofday(struct timeval* tv, struct timezone* tz)
FILETIME ft;
LARGE_INTEGER li;
__int64 t;
static int tzflag;
- if (tv)
+ if(tv) {
GetSystemTimeAsFileTime(&ft);
li.LowPart = ft.dwLowDateTime;
li.HighPart = ft.dwHighDateTime;
@@ -70,10 +70,8 @@ __inline int gettimeofday(struct timeval *tv, struct timezone *tz)
tv->tv_usec = (long)(t % 1000000);
- if (tz)
- if (!tzflag)
+ if(tz) {
+ if(!tzflag) {
_tzset();
tzflag++;
@@ -86,19 +84,19 @@ __inline int gettimeofday(struct timeval *tv, struct timezone *tz)
#else
+__inline int
- SYSTEMTIME st;
+ SYSTEMTIME st;
FILETIME ft;
LARGE_INTEGER li;
TIME_ZONE_INFORMATION tzi;
__int64 t;
static int tzflag;
- if (tv)
- GetSystemTime(&st);
- SystemTimeToFileTime(&st, &ft);
+ if(tv) {
+ GetSystemTime(&st);
+ SystemTimeToFileTime(&st, &ft);
t = li.QuadPart; /* In 100-nanosecond intervals */
@@ -108,22 +106,18 @@ __inline int gettimeofday(struct timeval *tv, struct timezone *tz)
- if (tz)
+ if(tz) {
GetTimeZoneInformation(&tzi);
tz->tz_minuteswest = tzi.Bias;
- if (tzi.StandardDate.wMonth != 0)
- tz->tz_minuteswest += tzi.StandardBias * 60;
+ if(tzi.StandardDate.wMonth != 0) {
+ tz->tz_minuteswest += tzi.StandardBias * 60;
- if (tzi.DaylightDate.wMonth != 0)
+ if(tzi.DaylightDate.wMonth != 0) {
tz->tz_dsttime = 1;
- else
+ else {
tz->tz_dsttime = 0;
diff --git a/include/geos/triangulate/DelaunayTriangulationBuilder.h b/include/geos/triangulate/DelaunayTriangulationBuilder.h
index 6b887cc..9d9fda3 100644
--- a/include/geos/triangulate/DelaunayTriangulationBuilder.h
+++ b/include/geos/triangulate/DelaunayTriangulationBuilder.h
@@ -23,19 +23,19 @@
namespace geos {
- namespace geom{
- class Geometry;
- class MultiLineString;
- class GeometryCollection;
- class Envelope;
- namespace triangulate {
- namespace quadedge {
- class QuadEdgeSubdivision;
+namespace geom {
+class Geometry;
+class MultiLineString;
+class GeometryCollection;
+class Envelope;
+namespace triangulate {
+namespace quadedge {
+class QuadEdgeSubdivision;
namespace geos {
@@ -51,103 +51,103 @@ namespace triangulate { //geos.triangulate
* @author Benjamin Campbell
-class GEOS_DLL DelaunayTriangulationBuilder
+class GEOS_DLL DelaunayTriangulationBuilder {
public:
- * Extracts the unique {@link Coordinate}s from the given {@link Geometry}.
- * @param geom the geometry to extract from
- * @return a List of the unique Coordinates. Caller takes ownership of the returned object.
- static geom::CoordinateSequence* extractUniqueCoordinates(const geom::Geometry& geom);
- static void unique(geom::CoordinateSequence& coords);
- * Converts all {@link Coordinate}s in a collection to {@link Vertex}es.
- * @param coords the coordinates to convert
- * @return a List of Vertex objects. Call takes ownership of returned object.
- static IncrementalDelaunayTriangulator::VertexList* toVertices(const geom::CoordinateSequence &coords);
+ * Extracts the unique {@link Coordinate}s from the given {@link Geometry}.
+ * @param geom the geometry to extract from
+ * @return a List of the unique Coordinates. Caller takes ownership of the returned object.
+ static geom::CoordinateSequence* extractUniqueCoordinates(const geom::Geometry& geom);
+ static void unique(geom::CoordinateSequence& coords);
+ * Converts all {@link Coordinate}s in a collection to {@link Vertex}es.
+ * @param coords the coordinates to convert
+ * @return a List of Vertex objects. Call takes ownership of returned object.
+ static IncrementalDelaunayTriangulator::VertexList* toVertices(const geom::CoordinateSequence& coords);
private:
- geom::CoordinateSequence* siteCoords;
- double tolerance;
- quadedge::QuadEdgeSubdivision *subdiv;
+ geom::CoordinateSequence* siteCoords;
+ double tolerance;
+ quadedge::QuadEdgeSubdivision* subdiv;
public:
- * Creates a new triangulation builder.
- DelaunayTriangulationBuilder();
- ~DelaunayTriangulationBuilder();
- * Sets the sites (vertices) which will be triangulated.
- * All vertices of the given geometry will be used as sites.
- * @param geom the geometry from which the sites will be extracted.
- void setSites(const geom::Geometry& geom);
- * from a collection of {@link Coordinate}s.
- * @param geom a CoordinateSequence.
- void setSites(const geom::CoordinateSequence& coords);
- * Sets the snapping tolerance which will be used
- * to improved the robustness of the triangulation computation.
- * A tolerance of 0.0 specifies that no snapping will take place.
- * @param tolerance the tolerance distance to use
- inline void setTolerance(double p_tolerance)
- this->tolerance = p_tolerance;
+ * Creates a new triangulation builder.
+ DelaunayTriangulationBuilder();
+ ~DelaunayTriangulationBuilder();
+ * Sets the sites (vertices) which will be triangulated.
+ * All vertices of the given geometry will be used as sites.
+ * @param geom the geometry from which the sites will be extracted.
+ void setSites(const geom::Geometry& geom);
+ * from a collection of {@link Coordinate}s.
+ * @param geom a CoordinateSequence.
+ void setSites(const geom::CoordinateSequence& coords);
+ * Sets the snapping tolerance which will be used
+ * to improved the robustness of the triangulation computation.
+ * A tolerance of 0.0 specifies that no snapping will take place.
+ * @param tolerance the tolerance distance to use
+ inline void
+ setTolerance(double p_tolerance)
+ this->tolerance = p_tolerance;
private:
- void create();
+ void create();
public:
- * Gets the {@link quadedge::QuadEdgeSubdivision} which models the computed triangulation.
- * @return the subdivision containing the triangulation
- quadedge::QuadEdgeSubdivision& getSubdivision();
- * Gets the edges of the computed triangulation as a {@link MultiLineString}.
- * @param geomFact the geometry factory to use to create the output
- * @return the edges of the triangulation. The caller takes ownership of the returned object.
- std::unique_ptr<geom::MultiLineString> getEdges(const geom::GeometryFactory &geomFact);
- * Gets the faces of the computed triangulation as a {@link GeometryCollection}
- * of {@link Polygon}.
- * @return the faces of the triangulation. The caller takes ownership of the returned object.
- std::unique_ptr<geom::GeometryCollection> getTriangles(const geom::GeometryFactory& geomFact);
- * Computes the {@link Envelope} of a collection of {@link Coordinate}s.
- * @param coords a List of Coordinates
- * @return the envelope of the set of coordinates
- static geom::Envelope envelope(const geom::CoordinateSequence& coords);
+ * Gets the {@link quadedge::QuadEdgeSubdivision} which models the computed triangulation.
+ * @return the subdivision containing the triangulation
+ quadedge::QuadEdgeSubdivision& getSubdivision();
+ * Gets the edges of the computed triangulation as a {@link MultiLineString}.
+ * @param geomFact the geometry factory to use to create the output
+ * @return the edges of the triangulation. The caller takes ownership of the returned object.
+ std::unique_ptr<geom::MultiLineString> getEdges(const geom::GeometryFactory& geomFact);
+ * Gets the faces of the computed triangulation as a {@link GeometryCollection}
+ * of {@link Polygon}.
+ * @return the faces of the triangulation. The caller takes ownership of the returned object.
+ std::unique_ptr<geom::GeometryCollection> getTriangles(const geom::GeometryFactory& geomFact);
+ * Computes the {@link Envelope} of a collection of {@link Coordinate}s.
+ * @param coords a List of Coordinates
+ * @return the envelope of the set of coordinates
+ static geom::Envelope envelope(const geom::CoordinateSequence& coords);
diff --git a/include/geos/triangulate/IncrementalDelaunayTriangulator.h b/include/geos/triangulate/IncrementalDelaunayTriangulator.h
index e28dad0..b4ad5fc 100644
--- a/include/geos/triangulate/IncrementalDelaunayTriangulator.h
+++ b/include/geos/triangulate/IncrementalDelaunayTriangulator.h
@@ -28,8 +28,8 @@ namespace geos {
- class QuadEdge;
+class QuadEdge;
@@ -39,46 +39,45 @@ namespace quadedge {
* @author JTS: Martin Davis
-class GEOS_DLL IncrementalDelaunayTriangulator
+class GEOS_DLL IncrementalDelaunayTriangulator {
private:
- bool isUsingTolerance;
+ bool isUsingTolerance;
public:
- * Creates a new triangulator using the given {@link QuadEdgeSubdivision}.
- * The triangulator uses the tolerance of the supplied subdivision.
- * @param subdiv
- * a subdivision in which to build the TIN
- IncrementalDelaunayTriangulator(quadedge::QuadEdgeSubdivision *subdiv);
+ * Creates a new triangulator using the given {@link QuadEdgeSubdivision}.
+ * The triangulator uses the tolerance of the supplied subdivision.
+ * @param subdiv
+ * a subdivision in which to build the TIN
+ IncrementalDelaunayTriangulator(quadedge::QuadEdgeSubdivision* subdiv);
- typedef std::list<quadedge::Vertex> VertexList;
+ typedef std::list<quadedge::Vertex> VertexList;
- * Inserts all sites in a collection. The inserted vertices <b>MUST</b> be
- * unique up to the provided tolerance value. (i.e. no two vertices should be
- * closer than the provided tolerance value). They do not have to be rounded
- * to the tolerance grid, however.
- * @param vertices a Collection of Vertex
- * @throws LocateFailureException if the location algorithm
- * fails to converge in a reasonable number of iterations
- void insertSites(const VertexList& vertices);
+ * Inserts all sites in a collection. The inserted vertices <b>MUST</b> be
+ * unique up to the provided tolerance value. (i.e. no two vertices should be
+ * closer than the provided tolerance value). They do not have to be rounded
+ * to the tolerance grid, however.
+ * @param vertices a Collection of Vertex
+ * @throws LocateFailureException if the location algorithm
+ * fails to converge in a reasonable number of iterations
+ void insertSites(const VertexList& vertices);
- * Inserts a new point into a subdivision representing a Delaunay
- * triangulation, and fixes the affected edges so that the result
- * is still a Delaunay triangulation.
- * <p>
- * @return a quadedge containing the inserted vertex
- quadedge::QuadEdge& insertSite(const quadedge::Vertex &v);
+ * Inserts a new point into a subdivision representing a Delaunay
+ * triangulation, and fixes the affected edges so that the result
+ * is still a Delaunay triangulation.
+ * <p>
+ * @return a quadedge containing the inserted vertex
+ quadedge::QuadEdge& insertSite(const quadedge::Vertex& v);
} //namespace geos.triangulate
diff --git a/include/geos/triangulate/VoronoiDiagramBuilder.h b/include/geos/triangulate/VoronoiDiagramBuilder.h
index dad3761..37df492 100644
--- a/include/geos/triangulate/VoronoiDiagramBuilder.h
+++ b/include/geos/triangulate/VoronoiDiagramBuilder.h
@@ -25,11 +25,11 @@
#include <iostream>
namespace geos {
- namespace geom{
- class Geometry;
+namespace geom {
+class Geometry;
@@ -43,89 +43,89 @@ namespace triangulate { //geos.triangulate
* @author Martin Davis
-class GEOS_DLL VoronoiDiagramBuilder{
+class GEOS_DLL VoronoiDiagramBuilder {
public:
- * Creates a new Voronoi diagram builder.
- VoronoiDiagramBuilder();
- ~VoronoiDiagramBuilder();
- * Sets the sites (point or vertices) which will be diagrammed.
- * @param coords a collection of Coordinates.
- * Sets the envelope to clip the diagram to.
- * The diagram will be clipped to the larger
- * of this envelope or an envelope surrounding the sites.
- * @param clipEnv the clip envelope; must be kept alive by
- * caller until done with this instance;
- * set to 0 for no clipping.
- void setClipEnvelope(const geom::Envelope* clipEnv);
- void setTolerance(double tolerance);
- * Gets the {@link QuadEdgeSubdivision} which models the computed diagram.
- std::unique_ptr<quadedge::QuadEdgeSubdivision> getSubdivision();
- * Gets the faces of the computed diagram as a {@link GeometryCollection}
- * of {@link Polygon}s, clipped as specified.
- * @return the faces of the diagram
- std::unique_ptr<geom::GeometryCollection> getDiagram(const geom::GeometryFactory& geomFact);
- * of {@link LineString}s, clipped as specified.
- std::unique_ptr<geom::Geometry> getDiagramEdges(const geom::GeometryFactory& geomFact);
+ * Creates a new Voronoi diagram builder.
+ VoronoiDiagramBuilder();
+ ~VoronoiDiagramBuilder();
+ * Sets the sites (point or vertices) which will be diagrammed.
+ * @param coords a collection of Coordinates.
+ * Sets the envelope to clip the diagram to.
+ * The diagram will be clipped to the larger
+ * of this envelope or an envelope surrounding the sites.
+ * @param clipEnv the clip envelope; must be kept alive by
+ * caller until done with this instance;
+ * set to 0 for no clipping.
+ void setClipEnvelope(const geom::Envelope* clipEnv);
+ void setTolerance(double tolerance);
+ * Gets the {@link QuadEdgeSubdivision} which models the computed diagram.
+ std::unique_ptr<quadedge::QuadEdgeSubdivision> getSubdivision();
+ * Gets the faces of the computed diagram as a {@link GeometryCollection}
+ * of {@link Polygon}s, clipped as specified.
+ * @return the faces of the diagram
+ std::unique_ptr<geom::GeometryCollection> getDiagram(const geom::GeometryFactory& geomFact);
+ * of {@link LineString}s, clipped as specified.
+ std::unique_ptr<geom::Geometry> getDiagramEdges(const geom::GeometryFactory& geomFact);
private:
- std::unique_ptr<geom::CoordinateSequence> siteCoords;
- double tolerance;
- std::unique_ptr<quadedge::QuadEdgeSubdivision> subdiv;
- const geom::Envelope* clipEnv; // externally owned
- geom::Envelope diagramEnv;
+ std::unique_ptr<geom::CoordinateSequence> siteCoords;
+ double tolerance;
+ std::unique_ptr<quadedge::QuadEdgeSubdivision> subdiv;
+ const geom::Envelope* clipEnv; // externally owned
+ geom::Envelope diagramEnv;
- void create();
+ void create();
- static std::unique_ptr<geom::GeometryCollection>
- clipGeometryCollection(const geom::GeometryCollection& geom, const geom::Envelope& clipEnv);
+ static std::unique_ptr<geom::GeometryCollection>
+ clipGeometryCollection(const geom::GeometryCollection& geom, const geom::Envelope& clipEnv);
diff --git a/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h b/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
index e7c9e65..a2e7fe7 100644
--- a/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
+++ b/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
@@ -40,24 +40,24 @@ class QuadEdgeSubdivision;
class LastFoundQuadEdgeLocator : public QuadEdgeLocator {
private:
- QuadEdgeSubdivision* subdiv;
- QuadEdge* lastEdge;
+ QuadEdgeSubdivision* subdiv;
+ QuadEdge* lastEdge;
public:
- LastFoundQuadEdgeLocator(QuadEdgeSubdivision *subdiv);
+ LastFoundQuadEdgeLocator(QuadEdgeSubdivision* subdiv);
private:
- virtual void init();
+ virtual void init();
- virtual QuadEdge* findEdge();
+ virtual QuadEdge* findEdge();
public:
- * Locates an edge e, such that either v is on e, or e is an edge of a triangle containing v.
- * The search starts from the last located edge amd proceeds on the general direction of v.
- * @return The caller _does not_ take ownership of the returned object.
- QuadEdge* locate(const Vertex &v) override;
+ * Locates an edge e, such that either v is on e, or e is an edge of a triangle containing v.
+ * The search starts from the last located edge amd proceeds on the general direction of v.
+ * @return The caller _does not_ take ownership of the returned object.
+ QuadEdge* locate(const Vertex& v) override;
} //namespace geos.triangulate.quadedge
diff --git a/include/geos/triangulate/quadedge/LocateFailureException.h b/include/geos/triangulate/quadedge/LocateFailureException.h
index ec143d8..1f3a479 100644
--- a/include/geos/triangulate/quadedge/LocateFailureException.h
+++ b/include/geos/triangulate/quadedge/LocateFailureException.h
@@ -29,7 +29,7 @@ namespace quadedge { //geos.triangulate.quadedge
class GEOS_DLL LocateFailureException : public geos::util::GEOSException {
public:
- LocateFailureException(std::string const&msg);
+ LocateFailureException(std::string const& msg);
diff --git a/include/geos/triangulate/quadedge/QuadEdge.h b/include/geos/triangulate/quadedge/QuadEdge.h
index 7515b6a..0dd0de1 100644
--- a/include/geos/triangulate/quadedge/QuadEdge.h
+++ b/include/geos/triangulate/quadedge/QuadEdge.h
@@ -50,308 +50,344 @@ namespace quadedge { //geos.triangulate.quadedge
class GEOS_DLL QuadEdge {
public:
- * Creates a new QuadEdge quartet from {@link Vertex} o to {@link Vertex} d.
- * @param o
- * the origin Vertex
- * @param d
- * the destination Vertex
- * @return the new QuadEdge* The caller is reponsible for
- * freeing the returned pointer
- static std::unique_ptr<QuadEdge> makeEdge(const Vertex &o, const Vertex &d);
- * Creates a new QuadEdge connecting the destination of a to the origin of
- * b, in such a way that all three have the same left face after the
- * connection is complete. Additionally, the data pointers of the new edge
- * are set.
- static std::unique_ptr<QuadEdge> connect(QuadEdge &a, QuadEdge &b);
- * Splices two edges together or apart.
- * Splice affects the two edge rings around the origins of a and b, and, independently, the two
- * edge rings around the left faces of <tt>a</tt> and <tt>b</tt>.
- * In each case, (i) if the two rings are distinct,
- * Splice will combine them into one, or (ii) if the two are the same ring, Splice will break it
- * into two separate pieces. Thus, Splice can be used both to attach the two edges together, and
- * to break them apart.
- * @param a an edge to splice
- * @param b an edge to splice
- static void splice(QuadEdge &a, QuadEdge &b);
- * Turns an edge counterclockwise inside its enclosing quadrilateral.
- * @param e the quadedge to turn
- static void swap(QuadEdge &e);
+ * Creates a new QuadEdge quartet from {@link Vertex} o to {@link Vertex} d.
+ * @param o
+ * the origin Vertex
+ * @param d
+ * the destination Vertex
+ * @return the new QuadEdge* The caller is reponsible for
+ * freeing the returned pointer
+ static std::unique_ptr<QuadEdge> makeEdge(const Vertex& o, const Vertex& d);
+ * Creates a new QuadEdge connecting the destination of a to the origin of
+ * b, in such a way that all three have the same left face after the
+ * connection is complete. Additionally, the data pointers of the new edge
+ * are set.
+ static std::unique_ptr<QuadEdge> connect(QuadEdge& a, QuadEdge& b);
+ * Splices two edges together or apart.
+ * Splice affects the two edge rings around the origins of a and b, and, independently, the two
+ * edge rings around the left faces of <tt>a</tt> and <tt>b</tt>.
+ * In each case, (i) if the two rings are distinct,
+ * Splice will combine them into one, or (ii) if the two are the same ring, Splice will break it
+ * into two separate pieces. Thus, Splice can be used both to attach the two edges together, and
+ * to break them apart.
+ * @param a an edge to splice
+ * @param b an edge to splice
+ static void splice(QuadEdge& a, QuadEdge& b);
+ * Turns an edge counterclockwise inside its enclosing quadrilateral.
+ * @param e the quadedge to turn
+ static void swap(QuadEdge& e);
private:
- //// the dual of this edge, directed from right to left
- QuadEdge *_rot;
- Vertex vertex; // The vertex that this edge represents
- QuadEdge *next; // A reference to a connected edge
- void* data;
- bool isAlive;
- * Quadedges must be made using {@link makeEdge},
- * to ensure proper construction.
- QuadEdge();
+ //// the dual of this edge, directed from right to left
+ QuadEdge* _rot;
+ Vertex vertex; // The vertex that this edge represents
+ QuadEdge* next; // A reference to a connected edge
+ void* data;
+ bool isAlive;
+ * Quadedges must be made using {@link makeEdge},
+ * to ensure proper construction.
+ QuadEdge();
public:
- virtual ~QuadEdge();
- * Free the QuadEdge quartet associated with this QuadEdge by a connect()
- * or makeEdge() call.
- * DO NOT call this function on a QuadEdge that was not returned
- * by connect() or makeEdge().
- virtual void free();
- * Gets the primary edge of this quadedge and its <tt>sym</tt>.
- * The primary edge is the one for which the origin
- * and destination coordinates are ordered
- * according to the standard {@link Coordinate} ordering
- * @return the primary quadedge
- const QuadEdge& getPrimary() const;
- * Sets the external data value for this edge.
- * @param data an object containing external data
- virtual void setData(void* data);
- * Gets the external data value for this edge.
- * @return the data object
- virtual void* getData();
- * Marks this quadedge as being deleted.
- * This does not free the memory used by
- * this quadedge quartet, but indicates
- * that this quadedge quartet no longer participates
- * in a subdivision.
- * NOTE: called "delete" in JTS
- void remove();
- * Tests whether this edge has been deleted.
- * @return true if this edge has not been deleted.
- inline bool isLive() {
- return isAlive;
- * Sets the connected edge
- * @param nextEdge edge
- inline void setNext(QuadEdge *p_next) {
- this->next = p_next;
- * QuadEdge Algebra
- * Gets the dual of this edge, directed from its right to its left.
- * @return the rotated edge
- inline QuadEdge& rot() const {
- return *_rot;
- * Gets the dual of this edge, directed from its left to its right.
- * @return the inverse rotated edge.
- inline QuadEdge& invRot() const {
- return rot().sym();
- * Gets the edge from the destination to the origin of this edge.
- * @return the sym of the edge
- inline QuadEdge& sym() const {
- return rot().rot();
- * Gets the next CCW edge around the origin of this edge.
- * @return the next linked edge.
- inline QuadEdge& oNext() const {
- return *next;
- * Gets the next CW edge around (from) the origin of this edge.
- * @return the previous edge.
- inline QuadEdge& oPrev() const {
- return rot().oNext().rot();
- * Gets the next CCW edge around (into) the destination of this edge.
- * @return the next destination edge.
- inline QuadEdge& dNext() const {
- return sym().oNext().sym();
- * Gets the next CW edge around (into) the destination of this edge.
- * @return the previous destination edge.
- inline QuadEdge& dPrev() const {
- return invRot().oNext().invRot();
- * Gets the CCW edge around the left face following this edge.
- * @return the next left face edge.
- inline QuadEdge& lNext() const {
- return invRot().oNext().rot();
- * Gets the CCW edge around the left face before this edge.
- * @return the previous left face edge.
- inline QuadEdge& lPrev() const {
- return oNext().sym();
- * Gets the edge around the right face ccw following this edge.
- * @return the next right face edge.
- inline QuadEdge& rNext() {
- return rot().oNext().invRot();
- * Gets the edge around the right face ccw before this edge.
- * @return the previous right face edge.
- inline QuadEdge& rPrev() {
- return sym().oNext();
- * Data Access
- * Sets the vertex for this edge's origin
- * @param o the origin vertex
- inline void setOrig(const Vertex &o) {
- vertex = o;
- * Sets the vertex for this edge's destination
- * @param d the destination vertex
- inline void setDest(const Vertex &d) {
- sym().setOrig(d);
- * Gets the vertex for the edge's origin
- * @return the origin vertex
- const Vertex& orig() const {
- return vertex;
- * Gets the vertex for the edge's destination
- * @return the destination vertex
- const Vertex& dest() const {
- return sym().orig();
- * Gets the length of the geometry of this quadedge.
- * @return the length of the quadedge
- inline double getLength() const {
- return orig().getCoordinate().distance(dest().getCoordinate());
- * Tests if this quadedge and another have the same line segment geometry,
- * regardless of orientation.
- * @param qe a quadege
- * @return true if the quadedges are based on the same line segment regardless of orientation
- bool equalsNonOriented(const QuadEdge &qe) const;
- * with the same orientation.
- bool equalsOriented(const QuadEdge &qe) const;
- * Creates a {@link LineSegment} representing the
- * geometry of this edge.
- * @return a LineSegment
- std::unique_ptr<geom::LineSegment> toLineSegment() const;
+ virtual ~QuadEdge();
+ * Free the QuadEdge quartet associated with this QuadEdge by a connect()
+ * or makeEdge() call.
+ * DO NOT call this function on a QuadEdge that was not returned
+ * by connect() or makeEdge().
+ virtual void free();
+ * Gets the primary edge of this quadedge and its <tt>sym</tt>.
+ * The primary edge is the one for which the origin
+ * and destination coordinates are ordered
+ * according to the standard {@link Coordinate} ordering
+ * @return the primary quadedge
+ const QuadEdge& getPrimary() const;
+ * Sets the external data value for this edge.
+ * @param data an object containing external data
+ virtual void setData(void* data);
+ * Gets the external data value for this edge.
+ * @return the data object
+ virtual void* getData();
+ * Marks this quadedge as being deleted.
+ * This does not free the memory used by
+ * this quadedge quartet, but indicates
+ * that this quadedge quartet no longer participates
+ * in a subdivision.
+ * NOTE: called "delete" in JTS
+ void remove();
+ * Tests whether this edge has been deleted.
+ * @return true if this edge has not been deleted.
+ inline bool
+ isLive()
+ return isAlive;
+ * Sets the connected edge
+ * @param nextEdge edge
+ inline void
+ setNext(QuadEdge* p_next)
+ this->next = p_next;
+ * QuadEdge Algebra
+ * Gets the dual of this edge, directed from its right to its left.
+ * @return the rotated edge
+ inline QuadEdge&
+ rot() const
+ return *_rot;
+ * Gets the dual of this edge, directed from its left to its right.
+ * @return the inverse rotated edge.
+ inline QuadEdge&
+ invRot() const
+ return rot().sym();
+ * Gets the edge from the destination to the origin of this edge.
+ * @return the sym of the edge
+ inline QuadEdge&
+ sym() const
+ return rot().rot();
+ * Gets the next CCW edge around the origin of this edge.
+ * @return the next linked edge.
+ inline QuadEdge&
+ oNext() const
+ return *next;
+ * Gets the next CW edge around (from) the origin of this edge.
+ * @return the previous edge.
+ inline QuadEdge&
+ oPrev() const
+ return rot().oNext().rot();
+ * Gets the next CCW edge around (into) the destination of this edge.
+ * @return the next destination edge.
+ inline QuadEdge&
+ dNext() const
+ return sym().oNext().sym();
+ * Gets the next CW edge around (into) the destination of this edge.
+ * @return the previous destination edge.
+ inline QuadEdge&
+ dPrev() const
+ return invRot().oNext().invRot();
+ * Gets the CCW edge around the left face following this edge.
+ * @return the next left face edge.
+ inline QuadEdge&
+ lNext() const
+ return invRot().oNext().rot();
+ * Gets the CCW edge around the left face before this edge.
+ * @return the previous left face edge.
+ inline QuadEdge&
+ lPrev() const
+ return oNext().sym();
+ * Gets the edge around the right face ccw following this edge.
+ * @return the next right face edge.
+ inline QuadEdge&
+ rNext()
+ return rot().oNext().invRot();
+ * Gets the edge around the right face ccw before this edge.
+ * @return the previous right face edge.
+ inline QuadEdge&
+ rPrev()
+ return sym().oNext();
+ * Data Access
+ * Sets the vertex for this edge's origin
+ * @param o the origin vertex
+ inline void
+ setOrig(const Vertex& o)
+ vertex = o;
+ * Sets the vertex for this edge's destination
+ * @param d the destination vertex
+ inline void
+ setDest(const Vertex& d)
+ sym().setOrig(d);
+ * Gets the vertex for the edge's origin
+ * @return the origin vertex
+ const Vertex&
+ orig() const
+ return vertex;
+ * Gets the vertex for the edge's destination
+ * @return the destination vertex
+ const Vertex&
+ dest() const
+ return sym().orig();
+ * Gets the length of the geometry of this quadedge.
+ * @return the length of the quadedge
+ inline double
+ getLength() const
+ return orig().getCoordinate().distance(dest().getCoordinate());
+ * Tests if this quadedge and another have the same line segment geometry,
+ * regardless of orientation.
+ * @param qe a quadege
+ * @return true if the quadedges are based on the same line segment regardless of orientation
+ bool equalsNonOriented(const QuadEdge& qe) const;
+ * with the same orientation.
+ bool equalsOriented(const QuadEdge& qe) const;
+ * Creates a {@link LineSegment} representing the
+ * geometry of this edge.
+ * @return a LineSegment
+ std::unique_ptr<geom::LineSegment> toLineSegment() const;
diff --git a/include/geos/triangulate/quadedge/QuadEdgeLocator.h b/include/geos/triangulate/quadedge/QuadEdgeLocator.h
index a5983b1..5d8dc68 100644
--- a/include/geos/triangulate/quadedge/QuadEdgeLocator.h
+++ b/include/geos/triangulate/quadedge/QuadEdgeLocator.h
@@ -38,8 +38,8 @@ class QuadEdge;
class QuadEdgeLocator {
public:
- virtual ~QuadEdgeLocator() = 0; //not implemented
- virtual QuadEdge* locate(const Vertex &v) = 0; //not implemented
+ virtual ~QuadEdgeLocator() = 0; //not implemented
+ virtual QuadEdge* locate(const Vertex& v) = 0; //not implemented
diff --git a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
index e37f43b..ce5a49c 100644
--- a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
+++ b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
@@ -33,13 +33,13 @@ namespace geos {
namespace geom {
- class GeometryFactory;
- class Coordinate;
- class Geometry;
- class Envelope;
+class GeometryFactory;
+class Coordinate;
+class Geometry;
+class Envelope;
@@ -78,416 +78,428 @@ const double EDGE_COINCIDENCE_TOL_FACTOR = 1000;
class GEOS_DLL QuadEdgeSubdivision {
public:
- typedef std::vector<QuadEdge*> QuadEdgeList;
- * Gets the edges for the triangle to the left of the given {@link QuadEdge}.
- * @param startQE
- * @param triEdge
- * @throws IllegalArgumentException
- * if the edges do not form a triangle
- static void getTriangleEdges(const QuadEdge &startQE,
- const QuadEdge* triEdge[3]);
+ typedef std::vector<QuadEdge*> QuadEdgeList;
+ * Gets the edges for the triangle to the left of the given {@link QuadEdge}.
+ * @param startQE
+ * @param triEdge
+ * @throws IllegalArgumentException
+ * if the edges do not form a triangle
+ static void getTriangleEdges(const QuadEdge& startQE,
+ const QuadEdge* triEdge[3]);
private:
- QuadEdgeList quadEdges;
- QuadEdgeList createdEdges;
- QuadEdge* startingEdges[3];
- double tolerance;
- double edgeCoincidenceTolerance;
- Vertex frameVertex[3];
- geom::Envelope frameEnv;
- std::unique_ptr<QuadEdgeLocator> locator;
+ QuadEdgeList quadEdges;
+ QuadEdgeList createdEdges;
+ QuadEdge* startingEdges[3];
+ double tolerance;
+ double edgeCoincidenceTolerance;
+ Vertex frameVertex[3];
+ geom::Envelope frameEnv;
+ std::unique_ptr<QuadEdgeLocator> locator;
public:
- * Creates a new instance of a quad-edge subdivision based on a frame triangle
- * that encloses a supplied bounding box. A new super-bounding box that
- * contains the triangle is computed and stored.
- * @param env
- * the bouding box to surround
- * the tolerance value for determining if two sites are equal
- QuadEdgeSubdivision(const geom::Envelope &env, double tolerance);
- virtual ~QuadEdgeSubdivision();
+ * Creates a new instance of a quad-edge subdivision based on a frame triangle
+ * that encloses a supplied bounding box. A new super-bounding box that
+ * contains the triangle is computed and stored.
+ * @param env
+ * the bouding box to surround
+ * the tolerance value for determining if two sites are equal
+ QuadEdgeSubdivision(const geom::Envelope& env, double tolerance);
+ virtual ~QuadEdgeSubdivision();
private:
- virtual void createFrame(const geom::Envelope &env);
+ virtual void createFrame(const geom::Envelope& env);
- virtual void initSubdiv(QuadEdge* initEdges[3]);
+ virtual void initSubdiv(QuadEdge* initEdges[3]);
public:
- * Gets the vertex-equality tolerance value
- * used in this subdivision
- * @return the tolerance value
- inline double getTolerance() const {
- return tolerance;
- * Gets the envelope of the Subdivision (including the frame).
- inline const geom::Envelope& getEnvelope() const {
- return frameEnv;
- * Gets the collection of base {@link QuadEdge}s (one for every pair of
- * vertices which is connected).
- * @return a QuadEdgeList
- inline const QuadEdgeList& getEdges() const {
- return quadEdges;
- * Sets the {@link QuadEdgeLocator} to use for locating containing triangles
- * in this subdivision.
- * @param locator
- * a QuadEdgeLocator
- inline void setLocator(std::unique_ptr<QuadEdgeLocator> p_locator) {
- this->locator = std::move(p_locator);
- * Creates a new quadedge, recording it in the edges list.
- * @param o
- * @param d
- * @return
- virtual QuadEdge& makeEdge(const Vertex &o, const Vertex &d);
- * Creates a new QuadEdge connecting the destination of a to the origin of b,
- * in such a way that all three have the same left face after the connection
- * is complete. The quadedge is recorded in the edges list.
- * @param a
- * @param b
- * @return
- virtual QuadEdge& connect(QuadEdge &a, QuadEdge &b);
- * Deletes a quadedge from the subdivision. Linked quadedges are updated to
- * reflect the deletion.
- * @param e
- * the quadedge to delete
- void remove(QuadEdge &e);
- * Locates an edge of a triangle which contains a location
- * specified by a Vertex v.
- * The edge returned has the
- * property that either v is on e, or e is an edge of a triangle containing v.
- * The search starts from startEdge amd proceeds on the general direction of v.
- * <p>
- * This locate algorithm relies on the subdivision being Delaunay. For
- * non-Delaunay subdivisions, this may loop for ever.
- * @param v the location to search for
- * @param startEdge an edge of the subdivision to start searching at
- * @returns a QuadEdge which contains v, or is on the edge of a triangle containing v
- * if the location algorithm fails to converge in a reasonable
- * number of iterations. The returned pointer should not be
- * freed be the caller.
- QuadEdge* locateFromEdge(const Vertex &v,
- const QuadEdge &startEdge) const;
- * Finds a quadedge of a triangle containing a location
- * specified by a {@link Vertex}, if one exists.
- * @param x the vertex to locate
- * @return a quadedge on the edge of a triangle which touches or contains the location
- * @return null if no such triangle exists. The returned pointer should not be
- inline QuadEdge* locate(const Vertex &v) const {
- return locator->locate(v);
- * specified by a {@link Coordinate}, if one exists.
- * @param p the Coordinate to locate
- inline QuadEdge* locate(const geom::Coordinate &p) {
- return locator->locate(Vertex(p));
- * Locates the edge between the given vertices, if it exists in the
- * subdivision.
- * @param p0 a coordinate
- * @param p1 another coordinate
- * @return the edge joining the coordinates, if present
- * @return null if no such edge exists
- * @return the caller _should not_ free the returned pointer
- QuadEdge* locate(const geom::Coordinate &p0, const geom::Coordinate &p1);
- * Inserts a new site into the Subdivision, connecting it to the vertices of
- * the containing triangle (or quadrilateral, if the split point falls on an
- * existing edge).
- * <p>
- * This method does NOT maintain the Delaunay condition. If desired, this must
- * be checked and enforced by the caller.
- * <p>
- * This method does NOT check if the inserted vertex falls on an edge. This
- * must be checked by the caller, since this situation may cause erroneous
- * triangulation
- * @param v
- * the vertex to insert
- * @return a new quad edge terminating in v
- QuadEdge& insertSite(const Vertex &v);
- * Tests whether a QuadEdge is an edge incident on a frame triangle vertex.
- * @param e
- * the edge to test
- * @return true if the edge is connected to the frame triangle
- bool isFrameEdge(const QuadEdge &e) const;
- * Tests whether a QuadEdge is an edge on the border of the frame facets and
- * the internal facets. E.g. an edge which does not itself touch a frame
- * vertex, but which touches an edge which does.
- * @param e
- * @return true if the edge is on the border of the frame
- bool isFrameBorderEdge(const QuadEdge &e) const;
- * Tests whether a vertex is a vertex of the outer triangle.
- * @param v
- * the vertex to test
- * @return true if the vertex is an outer triangle vertex
- bool isFrameVertex(const Vertex &v) const;
- * Tests whether a {@link Coordinate} lies on a {@link QuadEdge}, up to a
- * tolerance determined by the subdivision tolerance.
- * @param e
- * a QuadEdge
- * @param p
- * a point
- * @return true if the vertex lies on the edge
- bool isOnEdge(const QuadEdge &e, const geom::Coordinate &p) const;
- * Tests whether a {@link Vertex} is the start or end vertex of a
- * {@link QuadEdge}, up to the subdivision tolerance distance.
- * @param e
- * @param v
- * @return true if the vertex is a endpoint of the edge
- bool isVertexOfEdge(const QuadEdge &e, const Vertex &v) const;
- * Gets all primary quadedges in the subdivision.
- * A primary edge is a {@link QuadEdge}
- * which occupies the 0'th position in its array of associated quadedges.
- * These provide the unique geometric edges of the triangulation.
- * @param includeFrame true if the frame edges are to be included
- * @return a List of QuadEdges. The caller takes ownership of the returned QuadEdgeList but not the
- * items it contains.
- std::unique_ptr<QuadEdgeList> getPrimaryEdges(bool includeFrame);
- * Visitors
- void visitTriangles(TriangleVisitor *triVisitor, bool includeFrame);
+ * Gets the vertex-equality tolerance value
+ * used in this subdivision
+ * @return the tolerance value
+ inline double
+ getTolerance() const
+ return tolerance;
+ * Gets the envelope of the Subdivision (including the frame).
+ inline const geom::Envelope&
+ getEnvelope() const
+ return frameEnv;
+ * Gets the collection of base {@link QuadEdge}s (one for every pair of
+ * vertices which is connected).
+ * @return a QuadEdgeList
+ inline const QuadEdgeList&
+ getEdges() const
+ return quadEdges;
+ * Sets the {@link QuadEdgeLocator} to use for locating containing triangles
+ * in this subdivision.
+ * @param locator
+ * a QuadEdgeLocator
+ inline void
+ setLocator(std::unique_ptr<QuadEdgeLocator> p_locator)
+ this->locator = std::move(p_locator);
+ * Creates a new quadedge, recording it in the edges list.
+ * @param o
+ * @param d
+ * @return
+ virtual QuadEdge& makeEdge(const Vertex& o, const Vertex& d);
+ * Creates a new QuadEdge connecting the destination of a to the origin of b,
+ * in such a way that all three have the same left face after the connection
+ * is complete. The quadedge is recorded in the edges list.
+ * @param a
+ * @param b
+ * @return
+ virtual QuadEdge& connect(QuadEdge& a, QuadEdge& b);
+ * Deletes a quadedge from the subdivision. Linked quadedges are updated to
+ * reflect the deletion.
+ * @param e
+ * the quadedge to delete
+ void remove(QuadEdge& e);
+ * Locates an edge of a triangle which contains a location
+ * specified by a Vertex v.
+ * The edge returned has the
+ * property that either v is on e, or e is an edge of a triangle containing v.
+ * The search starts from startEdge amd proceeds on the general direction of v.
+ * <p>
+ * This locate algorithm relies on the subdivision being Delaunay. For
+ * non-Delaunay subdivisions, this may loop for ever.
+ * @param v the location to search for
+ * @param startEdge an edge of the subdivision to start searching at
+ * @returns a QuadEdge which contains v, or is on the edge of a triangle containing v
+ * if the location algorithm fails to converge in a reasonable
+ * number of iterations. The returned pointer should not be
+ * freed be the caller.
+ QuadEdge* locateFromEdge(const Vertex& v,
+ const QuadEdge& startEdge) const;
+ * Finds a quadedge of a triangle containing a location
+ * specified by a {@link Vertex}, if one exists.
+ * @param x the vertex to locate
+ * @return a quadedge on the edge of a triangle which touches or contains the location
+ * @return null if no such triangle exists. The returned pointer should not be
+ inline QuadEdge*
+ locate(const Vertex& v) const
+ return locator->locate(v);
+ * specified by a {@link Coordinate}, if one exists.
+ * @param p the Coordinate to locate
+ inline QuadEdge*
+ locate(const geom::Coordinate& p)
+ return locator->locate(Vertex(p));
+ * Locates the edge between the given vertices, if it exists in the
+ * subdivision.
+ * @param p0 a coordinate
+ * @param p1 another coordinate
+ * @return the edge joining the coordinates, if present
+ * @return null if no such edge exists
+ * @return the caller _should not_ free the returned pointer
+ QuadEdge* locate(const geom::Coordinate& p0, const geom::Coordinate& p1);
+ * Inserts a new site into the Subdivision, connecting it to the vertices of
+ * the containing triangle (or quadrilateral, if the split point falls on an
+ * existing edge).
+ * <p>
+ * This method does NOT maintain the Delaunay condition. If desired, this must
+ * be checked and enforced by the caller.
+ * <p>
+ * This method does NOT check if the inserted vertex falls on an edge. This
+ * must be checked by the caller, since this situation may cause erroneous
+ * triangulation
+ * @param v
+ * the vertex to insert
+ * @return a new quad edge terminating in v
+ QuadEdge& insertSite(const Vertex& v);
+ * Tests whether a QuadEdge is an edge incident on a frame triangle vertex.
+ * @param e
+ * the edge to test
+ * @return true if the edge is connected to the frame triangle
+ bool isFrameEdge(const QuadEdge& e) const;
+ * Tests whether a QuadEdge is an edge on the border of the frame facets and
+ * the internal facets. E.g. an edge which does not itself touch a frame
+ * vertex, but which touches an edge which does.
+ * @param e
+ * @return true if the edge is on the border of the frame
+ bool isFrameBorderEdge(const QuadEdge& e) const;
+ * Tests whether a vertex is a vertex of the outer triangle.
+ * @param v
+ * the vertex to test
+ * @return true if the vertex is an outer triangle vertex
+ bool isFrameVertex(const Vertex& v) const;
+ * Tests whether a {@link Coordinate} lies on a {@link QuadEdge}, up to a
+ * tolerance determined by the subdivision tolerance.
+ * @param e
+ * a QuadEdge
+ * @param p
+ * a point
+ * @return true if the vertex lies on the edge
+ bool isOnEdge(const QuadEdge& e, const geom::Coordinate& p) const;
+ * Tests whether a {@link Vertex} is the start or end vertex of a
+ * {@link QuadEdge}, up to the subdivision tolerance distance.
+ * @param e
+ * @param v
+ * @return true if the vertex is a endpoint of the edge
+ bool isVertexOfEdge(const QuadEdge& e, const Vertex& v) const;
+ * Gets all primary quadedges in the subdivision.
+ * A primary edge is a {@link QuadEdge}
+ * which occupies the 0'th position in its array of associated quadedges.
+ * These provide the unique geometric edges of the triangulation.
+ * @param includeFrame true if the frame edges are to be included
+ * @return a List of QuadEdges. The caller takes ownership of the returned QuadEdgeList but not the
+ * items it contains.
+ std::unique_ptr<QuadEdgeList> getPrimaryEdges(bool includeFrame);
+ * Visitors
+ void visitTriangles(TriangleVisitor* triVisitor, bool includeFrame);
private:
- typedef std::stack<QuadEdge*> QuadEdgeStack;
- typedef std::set<QuadEdge*> QuadEdgeSet;
- typedef std::list< geom::CoordinateSequence*> TriList;
- * The quadedges forming a single triangle.
- * Only one visitor is allowed to be active at a
- * time, so this is safe.
- QuadEdge* triEdges[3];
- * Stores the edges for a visited triangle. Also pushes sym (neighbour) edges
- * on stack to visit later.
- * @param edge
- * @param edgeStack
- * @return the visited triangle edges
- * @return null if the triangle should not be visited (for instance, if it is
- * outer)
- QuadEdge** fetchTriangleToVisit(QuadEdge *edge, QuadEdgeStack &edgeStack, bool includeFrame,
- QuadEdgeSet &visitedEdges);
- * Gets the coordinates for each triangle in the subdivision as an array.
- * true if the frame triangles should be included
- * @param triList a list of Coordinate[4] representing each triangle
- void getTriangleCoordinates(TriList* triList, bool includeFrame);
+ typedef std::stack<QuadEdge*> QuadEdgeStack;
+ typedef std::set<QuadEdge*> QuadEdgeSet;
+ typedef std::list< geom::CoordinateSequence*> TriList;
+ * The quadedges forming a single triangle.
+ * Only one visitor is allowed to be active at a
+ * time, so this is safe.
+ QuadEdge* triEdges[3];
+ * Stores the edges for a visited triangle. Also pushes sym (neighbour) edges
+ * on stack to visit later.
+ * @param edge
+ * @param edgeStack
+ * @return the visited triangle edges
+ * @return null if the triangle should not be visited (for instance, if it is
+ * outer)
+ QuadEdge** fetchTriangleToVisit(QuadEdge* edge, QuadEdgeStack& edgeStack, bool includeFrame,
+ QuadEdgeSet& visitedEdges);
+ * Gets the coordinates for each triangle in the subdivision as an array.
+ * true if the frame triangles should be included
+ * @param triList a list of Coordinate[4] representing each triangle
+ void getTriangleCoordinates(TriList* triList, bool includeFrame);
private:
- class TriangleCoordinatesVisitor;
- class TriangleCircumcentreVisitor;
+ class TriangleCoordinatesVisitor;
+ class TriangleCircumcentreVisitor;
public:
- * Gets the geometry for the edges in the subdivision as a {@link MultiLineString}
- * containing 2-point lines.
- * @param geomFact the GeometryFactory to use
- * @return a MultiLineString. The caller takes ownership of the returned object.
- std::unique_ptr<geom::MultiLineString> getEdges(const geom::GeometryFactory& geomFact);
- * Gets the geometry for the triangles in a triangulated subdivision as a {@link GeometryCollection}
- * of triangular {@link Polygon}s.
- * @return a GeometryCollection of triangular Polygons. The caller takes ownership of the returned object.
- std::unique_ptr<geom::GeometryCollection> getTriangles(const geom::GeometryFactory &geomFact);
- * Gets the cells in the Voronoi diagram for this triangulation.
- * The cells are returned as a {@link GeometryCollection} of {@link Polygon}s
- * The userData of each polygon is set to be the {@link Coordinate}
- * of the cell site. This allows easily associating external
- * data associated with the sites to the cells.
- * @param geomFact a geometry factory
- * @return a GeometryCollection of Polygons
- std::unique_ptr<geom::GeometryCollection> getVoronoiDiagram(const geom::GeometryFactory& geomFact);
- * The cells are returned as a {@link GeometryCollection} of {@link LineString}s
- std::unique_ptr<geom::MultiLineString> getVoronoiDiagramEdges(const geom::GeometryFactory& geomFact);
- * Gets a List of {@link Polygon}s for the Voronoi cells
- * of this triangulation.
- * @return a List of Polygons
- std::unique_ptr< std::vector<geom::Geometry*> > getVoronoiCellPolygons(const geom::GeometryFactory& geomFact);
- * Gets a List of {@link LineString}s for the Voronoi cells
- * The userData of each LineString is set to be the {@link Coordinate}
- * @return a List of LineString
- std::unique_ptr< std::vector<geom::Geometry*> > getVoronoiCellEdges(const geom::GeometryFactory& geomFact);
- * Gets a collection of {@link QuadEdge}s whose origin
- * vertices are a unique set which includes
- * all vertices in the subdivision.
- * The frame vertices can be included if required.
- * This is useful for algorithms which require traversing the
- * subdivision starting at all vertices.
- * Returning a quadedge for each vertex
- * is more efficient than
- * the alternative of finding the actual vertices
- * using {@link #getVertices} and then locating
- * quadedges attached to them.
- * @param includeFrame true if the frame vertices should be included
- * @return a collection of QuadEdge with the vertices of the subdivision as their origins
- std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList> getVertexUniqueEdges(bool includeFrame);
- * Gets the Voronoi cell around a site specified
- * by the origin of a QuadEdge.
- * The userData of the polygon is set to be the {@link Coordinate}
- * of the site. This allows attaching external
- * data associated with the site to this cell polygon.
- * @param qe a quadedge originating at the cell site
- * @param geomFact a factory for building the polygon
- * @return a polygon indicating the cell extent
- std::unique_ptr<geom::Geometry> getVoronoiCellPolygon(QuadEdge* qe ,const geom::GeometryFactory& geomFact);
- * Gets the Voronoi cell edge around a site specified
- * The userData of the LineString is set to be the {@link Coordinate}
- std::unique_ptr<geom::Geometry> getVoronoiCellEdge(QuadEdge* qe ,const geom::GeometryFactory& geomFact);
+ * Gets the geometry for the edges in the subdivision as a {@link MultiLineString}
+ * containing 2-point lines.
+ * @param geomFact the GeometryFactory to use
+ * @return a MultiLineString. The caller takes ownership of the returned object.
+ * Gets the geometry for the triangles in a triangulated subdivision as a {@link GeometryCollection}
+ * of triangular {@link Polygon}s.
+ * @return a GeometryCollection of triangular Polygons. The caller takes ownership of the returned object.
+ * Gets the cells in the Voronoi diagram for this triangulation.
+ * The cells are returned as a {@link GeometryCollection} of {@link Polygon}s
+ * The userData of each polygon is set to be the {@link Coordinate}
+ * of the cell site. This allows easily associating external
+ * data associated with the sites to the cells.
+ * @param geomFact a geometry factory
+ * @return a GeometryCollection of Polygons
+ std::unique_ptr<geom::GeometryCollection> getVoronoiDiagram(const geom::GeometryFactory& geomFact);
+ * The cells are returned as a {@link GeometryCollection} of {@link LineString}s
+ std::unique_ptr<geom::MultiLineString> getVoronoiDiagramEdges(const geom::GeometryFactory& geomFact);
+ * Gets a List of {@link Polygon}s for the Voronoi cells
+ * of this triangulation.
+ * @return a List of Polygons
+ std::unique_ptr< std::vector<geom::Geometry*> > getVoronoiCellPolygons(const geom::GeometryFactory& geomFact);
+ * Gets a List of {@link LineString}s for the Voronoi cells
+ * The userData of each LineString is set to be the {@link Coordinate}
+ * @return a List of LineString
+ std::unique_ptr< std::vector<geom::Geometry*> > getVoronoiCellEdges(const geom::GeometryFactory& geomFact);
+ * Gets a collection of {@link QuadEdge}s whose origin
+ * vertices are a unique set which includes
+ * all vertices in the subdivision.
+ * The frame vertices can be included if required.
+ * This is useful for algorithms which require traversing the
+ * subdivision starting at all vertices.
+ * Returning a quadedge for each vertex
+ * is more efficient than
+ * the alternative of finding the actual vertices
+ * using {@link #getVertices} and then locating
+ * quadedges attached to them.
+ * @param includeFrame true if the frame vertices should be included
+ * @return a collection of QuadEdge with the vertices of the subdivision as their origins
+ std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList> getVertexUniqueEdges(bool includeFrame);
+ * Gets the Voronoi cell around a site specified
+ * by the origin of a QuadEdge.
+ * The userData of the polygon is set to be the {@link Coordinate}
+ * of the site. This allows attaching external
+ * data associated with the site to this cell polygon.
+ * @param qe a quadedge originating at the cell site
+ * @param geomFact a factory for building the polygon
+ * @return a polygon indicating the cell extent
+ std::unique_ptr<geom::Geometry> getVoronoiCellPolygon(QuadEdge* qe, const geom::GeometryFactory& geomFact);
+ * Gets the Voronoi cell edge around a site specified
+ * The userData of the LineString is set to be the {@link Coordinate}
+ std::unique_ptr<geom::Geometry> getVoronoiCellEdge(QuadEdge* qe, const geom::GeometryFactory& geomFact);
diff --git a/include/geos/triangulate/quadedge/TrianglePredicate.h b/include/geos/triangulate/quadedge/TrianglePredicate.h
index 86c394b..2218f43 100644
--- a/include/geos/triangulate/quadedge/TrianglePredicate.h
+++ b/include/geos/triangulate/quadedge/TrianglePredicate.h
@@ -38,73 +38,72 @@ class Coordinate;
-class TrianglePredicate
+class TrianglePredicate {
public:
- * Tests if a point is inside the circle defined by
- * the triangle with vertices a, b, c (oriented counter-clockwise).
- * This test uses simple
- * double-precision arithmetic, and thus may not be robust.
- * @param a a vertex of the triangle
- * @param b a vertex of the triangle
- * @param c a vertex of the triangle
- * @param P the point to test
- * @return true if this point is inside the circle defined by the points a, b, c
- static bool isInCircleNonRobust(
- const Coordinate &a, const Coordinate &b, const Coordinate &c,
- const Coordinate &p);
+ * Tests if a point is inside the circle defined by
+ * the triangle with vertices a, b, c (oriented counter-clockwise).
+ * This test uses simple
+ * double-precision arithmetic, and thus may not be robust.
+ * @param a a vertex of the triangle
+ * @param b a vertex of the triangle
+ * @param c a vertex of the triangle
+ * @param P the point to test
+ * @return true if this point is inside the circle defined by the points a, b, c
+ static bool isInCircleNonRobust(
+ const Coordinate& a, const Coordinate& b, const Coordinate& c,
+ const Coordinate& p);
- * double-precision arithmetic, and thus is not 10% robust.
- * However, by using normalization to the origin
- * it provides improved robustness and increased performance.
- * <p>
- * Based on code by J.R.Shewchuk.
- static bool isInCircleNormalized(
+ * double-precision arithmetic, and thus is not 10% robust.
+ * However, by using normalization to the origin
+ * it provides improved robustness and increased performance.
+ * <p>
+ * Based on code by J.R.Shewchuk.
+ static bool isInCircleNormalized(
private:
- * Computes twice the area of the oriented triangle (a, b, c), i.e., the area is positive if the
- * triangle is oriented counterclockwise.
- static double triArea(const Coordinate &a,
- const Coordinate &b, const Coordinate &c);
+ * Computes twice the area of the oriented triangle (a, b, c), i.e., the area is positive if the
+ * triangle is oriented counterclockwise.
+ static double triArea(const Coordinate& a,
+ const Coordinate& b, const Coordinate& c);
public:
- * This method uses more robust computation.
- static bool isInCircleRobust(
+ * This method uses more robust computation.
+ static bool isInCircleRobust(
} // namespace geos.geom
diff --git a/include/geos/triangulate/quadedge/TriangleVisitor.h b/include/geos/triangulate/quadedge/TriangleVisitor.h
index 859e4b8..966f8ca 100644
--- a/include/geos/triangulate/quadedge/TriangleVisitor.h
+++ b/include/geos/triangulate/quadedge/TriangleVisitor.h
@@ -39,7 +39,7 @@ public:
* @param triEdges an array of the 3 quad edges in a triangle (in CCW order)
virtual void visit(QuadEdge* triEdges[3]) = 0;
- virtual ~TriangleVisitor() = 0 ;
+ virtual ~TriangleVisitor() = 0 ;
private:
diff --git a/include/geos/triangulate/quadedge/Vertex.h b/include/geos/triangulate/quadedge/Vertex.h
index 8c5becd..17eb663 100644
--- a/include/geos/triangulate/quadedge/Vertex.h
+++ b/include/geos/triangulate/quadedge/Vertex.h
@@ -30,7 +30,7 @@
namespace geos {
- class QuadEdge;
+class QuadEdge;
@@ -60,223 +60,253 @@ namespace quadedge { //geos.triangulate.quadedge
class GEOS_DLL Vertex {
public:
- static const int LEFT = 0;
- static const int RIGHT = 1;
- static const int BEYOND = 2;
- static const int BEHIND = 3;
- static const int BETWEEN = 4;
- static const int ORIGIN = 5;
- static const int DESTINATION = 6;
+ static const int LEFT = 0;
+ static const int RIGHT = 1;
+ static const int BEYOND = 2;
+ static const int BEHIND = 3;
+ static const int BETWEEN = 4;
+ static const int ORIGIN = 5;
+ static const int DESTINATION = 6;
private:
- geom::Coordinate p;
+ geom::Coordinate p;
public:
- Vertex(double _x, double _y);
- Vertex(double _x, double _y, double _z);
- Vertex(const geom::Coordinate &_p);
- Vertex();
- inline double getX() const {
- return p.x;
- inline double getY() const {
- return p.y;
- inline double getZ() const {
- return p.z;
- inline void setZ(double _z) {
- p.z = _z;
- inline const geom::Coordinate& getCoordinate() const {
- return p;
- inline bool equals(const Vertex &_x) const
- if (p.x == _x.getX() && p.y == _x.getY())
- return true;
- return false;
- inline bool equals(const Vertex &_x, double tolerance) const
- if (p.distance(_x.getCoordinate()) < tolerance)
- return true;
- return false;
- virtual int classify(const Vertex &p0, const Vertex &p1);
- * Computes the cross product k = u X v.
- * @param v a vertex
- * @return returns the magnitude of u X v
- inline double crossProduct(const Vertex &v) const
- return (p.x * v.getY() - p.y * v.getX());
- * Computes the inner or dot product
- * @param v, a vertex
- * @return returns the dot product u.v
- inline double dot(Vertex v) const
- return (p.x * v.getX() + p.y * v.getY());
- * Computes the scalar product c(v)
- * @return returns the scaled vector
- inline std::unique_ptr<Vertex> times(double c) const {
- return std::unique_ptr<Vertex>(new Vertex(c * p.x, c * p.y));
- /* Vector addition */
- inline std::unique_ptr<Vertex> sum(Vertex v) const {
- return std::unique_ptr<Vertex>(new Vertex(p.x + v.getX(), p.y + v.getY()));
- /* and subtraction */
- inline std::unique_ptr<Vertex> sub(const Vertex &v) const {
- return std::unique_ptr<Vertex>(new Vertex(p.x - v.getX(), p.y - v.getY()));
- /* magnitude of vector */
- inline double magn() const {
- return (sqrt(p.x * p.x + p.y * p.y));
- /* returns k X v (cross product). this is a vector perpendicular to v */
- inline std::unique_ptr<Vertex> cross() const {
- return std::unique_ptr<Vertex>(new Vertex(p.y, -p.x));
- * Geometric primitives /
- * Tests if the vertex is inside the circle defined by
- * @return true if this vertex is in the circumcircle of (a,b,c)
- virtual bool isInCircle(const Vertex &a, const Vertex &b, const Vertex &c) const;
- * Tests whether the triangle formed by this vertex and two
- * other vertices is in CCW orientation.
- * @returns true if the triangle is oriented CCW
- inline bool isCCW(const Vertex &b, const Vertex &c) const
- // is equal to the signed area of the triangle
- return (b.p.x - p.x) * (c.p.y - p.y)
- - (b.p.y - p.y) * (c.p.x - p.x) > 0;
- bool rightOf(const QuadEdge &e) const;
- bool leftOf(const QuadEdge &e) const;
+ Vertex(double _x, double _y);
+ Vertex(double _x, double _y, double _z);
+ Vertex(const geom::Coordinate& _p);
+ Vertex();
+ inline double
+ getX() const
+ return p.x;
+ inline double
+ getY() const
+ return p.y;
+ inline double
+ getZ() const
+ return p.z;
+ inline void
+ setZ(double _z)
+ p.z = _z;
+ inline const geom::Coordinate&
+ getCoordinate() const
+ return p;
+ inline bool
+ equals(const Vertex& _x) const
+ if(p.x == _x.getX() && p.y == _x.getY()) {
+ return true;
+ return false;
+ inline bool
+ equals(const Vertex& _x, double tolerance) const
+ if(p.distance(_x.getCoordinate()) < tolerance) {
+ return true;
+ return false;
+ virtual int classify(const Vertex& p0, const Vertex& p1);
+ * Computes the cross product k = u X v.
+ * @param v a vertex
+ * @return returns the magnitude of u X v
+ inline double
+ crossProduct(const Vertex& v) const
+ return (p.x * v.getY() - p.y * v.getX());
+ * Computes the inner or dot product
+ * @param v, a vertex
+ * @return returns the dot product u.v
+ inline double
+ dot(Vertex v) const
+ return (p.x * v.getX() + p.y * v.getY());
+ * Computes the scalar product c(v)
+ * @return returns the scaled vector
+ inline std::unique_ptr<Vertex>
+ times(double c) const
+ return std::unique_ptr<Vertex>(new Vertex(c * p.x, c * p.y));
+ /* Vector addition */
+ sum(Vertex v) const
+ return std::unique_ptr<Vertex>(new Vertex(p.x + v.getX(), p.y + v.getY()));
+ /* and subtraction */
+ sub(const Vertex& v) const
+ return std::unique_ptr<Vertex>(new Vertex(p.x - v.getX(), p.y - v.getY()));
+ /* magnitude of vector */
+ inline double
+ magn() const
+ return (sqrt(p.x * p.x + p.y * p.y));
+ /* returns k X v (cross product). this is a vector perpendicular to v */
+ cross() const
+ return std::unique_ptr<Vertex>(new Vertex(p.y, -p.x));
+ * Geometric primitives /
+ * Tests if the vertex is inside the circle defined by
+ * @return true if this vertex is in the circumcircle of (a,b,c)
+ virtual bool isInCircle(const Vertex& a, const Vertex& b, const Vertex& c) const;
+ * Tests whether the triangle formed by this vertex and two
+ * other vertices is in CCW orientation.
+ * @returns true if the triangle is oriented CCW
+ inline bool
+ isCCW(const Vertex& b, const Vertex& c) const
+ // is equal to the signed area of the triangle
+ return (b.p.x - p.x) * (c.p.y - p.y)
+ - (b.p.y - p.y) * (c.p.x - p.x) > 0;
+ bool rightOf(const QuadEdge& e) const;
+ bool leftOf(const QuadEdge& e) const;
private:
- static std::unique_ptr<algorithm::HCoordinate> bisector(const Vertex &a, const Vertex &b);
- inline double distance(const Vertex &v1, const Vertex &v2)
- return sqrt(pow(v2.getX() - v1.getX(), 2.0)
- + pow(v2.getY() - v1.getY(), 2.0));
- * Computes the value of the ratio of the circumradius to shortest edge. If smaller than some
- * given tolerance B, the associated triangle is considered skinny. For an equal lateral
- * triangle this value is 0.57735. The ratio is related to the minimum triangle angle theta by:
- * circumRadius/shortestEdge = 1/(2sin(theta)).
- * @param b second vertex of the triangle
- * @param c third vertex of the triangle
- * @return ratio of circumradius to shortest edge.
- virtual double circumRadiusRatio(const Vertex &b, const Vertex &c);
- * returns a new vertex that is mid-way between this vertex and another end point.
- * @param a the other end point.
- * @return the point mid-way between this and that.
- virtual std::unique_ptr<Vertex> midPoint(const Vertex &a);
- * Computes the centre of the circumcircle of this vertex and two others.
- * @param b
- * @param c
- * @return the Coordinate which is the circumcircle of the 3 points.
- virtual std::unique_ptr<Vertex> circleCenter(const Vertex &b, const Vertex &c) const;
- * For this vertex enclosed in a triangle defined by three verticies v0, v1 and v2, interpolate
- * a z value from the surrounding vertices.
- virtual double interpolateZValue(const Vertex &v0, const Vertex &v1,
- const Vertex &v2) const;
- * Interpolates the Z-value (height) of a point enclosed in a triangle
- * whose vertices all have Z values.
- * The containing triangle must not be degenerate
- * (in other words, the three vertices must enclose a
- * non-zero area).
- * @param p the point to interpolate the Z value of
- * @param v0 a vertex of a triangle containing the p
- * @param v1 a vertex of a triangle containing the p
- * @param v2 a vertex of a triangle containing the p
- * @return the interpolated Z-value (height) of the point
- static double interpolateZ(const geom::Coordinate &p, const geom::Coordinate &v0,
- const geom::Coordinate &v1, const geom::Coordinate &v2);
- * Computes the interpolated Z-value for a point p lying on the segment p0-p1
- * @param p
- * @param p0
- * @param p1
- * @return the interpolated Z value
- static double interpolateZ(const geom::Coordinate &p, const geom::Coordinate &p0,
- const geom::Coordinate &p1);
+ static std::unique_ptr<algorithm::HCoordinate> bisector(const Vertex& a, const Vertex& b);
+ inline double
+ distance(const Vertex& v1, const Vertex& v2)
+ return sqrt(pow(v2.getX() - v1.getX(), 2.0)
+ + pow(v2.getY() - v1.getY(), 2.0));
+ * Computes the value of the ratio of the circumradius to shortest edge. If smaller than some
+ * given tolerance B, the associated triangle is considered skinny. For an equal lateral
+ * triangle this value is 0.57735. The ratio is related to the minimum triangle angle theta by:
+ * circumRadius/shortestEdge = 1/(2sin(theta)).
+ * @param b second vertex of the triangle
+ * @param c third vertex of the triangle
+ * @return ratio of circumradius to shortest edge.
+ virtual double circumRadiusRatio(const Vertex& b, const Vertex& c);
+ * returns a new vertex that is mid-way between this vertex and another end point.
+ * @param a the other end point.
+ * @return the point mid-way between this and that.
+ virtual std::unique_ptr<Vertex> midPoint(const Vertex& a);
+ * Computes the centre of the circumcircle of this vertex and two others.
+ * @param b
+ * @param c
+ * @return the Coordinate which is the circumcircle of the 3 points.
+ virtual std::unique_ptr<Vertex> circleCenter(const Vertex& b, const Vertex& c) const;
+ * For this vertex enclosed in a triangle defined by three verticies v0, v1 and v2, interpolate
+ * a z value from the surrounding vertices.
+ virtual double interpolateZValue(const Vertex& v0, const Vertex& v1,
+ const Vertex& v2) const;
+ * Interpolates the Z-value (height) of a point enclosed in a triangle
+ * whose vertices all have Z values.
+ * The containing triangle must not be degenerate
+ * (in other words, the three vertices must enclose a
+ * non-zero area).
+ * @param p the point to interpolate the Z value of
+ * @param v0 a vertex of a triangle containing the p
+ * @param v1 a vertex of a triangle containing the p
+ * @param v2 a vertex of a triangle containing the p
+ * @return the interpolated Z-value (height) of the point
+ static double interpolateZ(const geom::Coordinate& p, const geom::Coordinate& v0,
+ const geom::Coordinate& v1, const geom::Coordinate& v2);
+ * Computes the interpolated Z-value for a point p lying on the segment p0-p1
+ * @param p
+ * @param p0
+ * @param p1
+ * @return the interpolated Z value
+ static double interpolateZ(const geom::Coordinate& p, const geom::Coordinate& p0,
+ const geom::Coordinate& p1);
-inline bool operator<(const Vertex& v1, const Vertex& v2) {
- return v1.getCoordinate() < v2.getCoordinate();
+inline bool
+operator<(const Vertex& v1, const Vertex& v2)
+ return v1.getCoordinate() < v2.getCoordinate();
diff --git a/include/geos/unload.h b/include/geos/unload.h
index 662683c..6124ec8 100644
--- a/include/geos/unload.h
+++ b/include/geos/unload.h
@@ -20,13 +20,12 @@
namespace geos {
namespace io {
-class GEOS_DLL Unload
+class GEOS_DLL Unload {
private:
- Unload(void) {}
- ~Unload(void) {}
+ Unload(void) {}
+ ~Unload(void) {}
public:
- static void Release();
+ static void Release();
diff --git a/include/geos/util.h b/include/geos/util.h
index a53d746..cad5c5a 100644
--- a/include/geos/util.h
+++ b/include/geos/util.h
@@ -35,10 +35,10 @@
// Private macros definition
-namespace geos
- template<class T>
- void ignore_unused_variable_warning(T const& ) {}
+namespace geos {
+template<class T>
+void
+ignore_unused_variable_warning(T const&) {}
diff --git a/include/geos/util/Assert.h b/include/geos/util/Assert.h
index aa3964d..67b680b 100644
--- a/include/geos/util/Assert.h
+++ b/include/geos/util/Assert.h
@@ -21,9 +21,9 @@
// Forward declarations
namespace geos {
- namespace geom {
- class Coordinate;
+namespace geom {
+class Coordinate;
namespace geos {
@@ -32,27 +32,34 @@ namespace util { // geos.util
class GEOS_DLL Assert {
public:
- static void isTrue(bool assertion, const std::string& message);
+ static void isTrue(bool assertion, const std::string& message);
- static void isTrue(bool assertion) {
- isTrue(assertion, std::string());
+ static void
+ isTrue(bool assertion)
+ isTrue(assertion, std::string());
- static void equals(const geom::Coordinate& expectedValue,
- const geom::Coordinate& actualValue,
- const std::string& message);
+ static void equals(const geom::Coordinate& expectedValue,
+ const geom::Coordinate& actualValue,
+ const std::string& message);
- const geom::Coordinate& actualValue)
- equals(expectedValue, actualValue, std::string());
+ static void
+ equals(const geom::Coordinate& expectedValue,
+ const geom::Coordinate& actualValue)
+ equals(expectedValue, actualValue, std::string());
- static void shouldNeverReachHere(const std::string& message);
+ static void shouldNeverReachHere(const std::string& message);
- static void shouldNeverReachHere() { shouldNeverReachHere(std::string()); }
+ static void
+ shouldNeverReachHere()
+ shouldNeverReachHere(std::string());
} // namespace geos.util
diff --git a/include/geos/util/AssertionFailedException.h b/include/geos/util/AssertionFailedException.h
index 7142c69..a41c8d4 100644
--- a/include/geos/util/AssertionFailedException.h
+++ b/include/geos/util/AssertionFailedException.h
@@ -31,17 +31,17 @@ class GEOS_DLL AssertionFailedException: public GEOSException {
public:
- AssertionFailedException()
- GEOSException("AssertionFailedException", "")
+ AssertionFailedException()
+ GEOSException("AssertionFailedException", "")
- AssertionFailedException(const std::string& msg)
- GEOSException("AssertionFailedException", msg)
+ AssertionFailedException(const std::string& msg)
+ GEOSException("AssertionFailedException", msg)
- ~AssertionFailedException() throw() override {}
+ ~AssertionFailedException() throw() override {}
diff --git a/include/geos/util/CoordinateArrayFilter.h b/include/geos/util/CoordinateArrayFilter.h
index 520841c..e7c4d12 100644
--- a/include/geos/util/CoordinateArrayFilter.h
+++ b/include/geos/util/CoordinateArrayFilter.h
@@ -35,24 +35,26 @@ namespace util { // geos::util
class GEOS_DLL CoordinateArrayFilter: public geom::CoordinateFilter {
private:
- geom::Coordinate::ConstVect &pts; // target vector reference
+ geom::Coordinate::ConstVect& pts; // target vector reference
public:
- * Constructs a CoordinateArrayFilter.
- * @param target The destination vector.
- CoordinateArrayFilter(geom::Coordinate::ConstVect& target)
- pts(target)
- virtual ~CoordinateArrayFilter() {}
- virtual void filter_ro(const geom::Coordinate *coord)
- pts.push_back(coord);
+ * Constructs a CoordinateArrayFilter.
+ * @param target The destination vector.
+ CoordinateArrayFilter(geom::Coordinate::ConstVect& target)
+ pts(target)
+ virtual
+ ~CoordinateArrayFilter() {}
+ virtual void
+ filter_ro(const geom::Coordinate* coord)
+ pts.push_back(coord);
diff --git a/include/geos/util/GEOSException.h b/include/geos/util/GEOSException.h
index a1ead30..1ecfaaa 100644
--- a/include/geos/util/GEOSException.h
+++ b/include/geos/util/GEOSException.h
@@ -39,20 +39,20 @@ class GEOS_DLL GEOSException: public std::runtime_error {
public:
- GEOSException()
- std::runtime_error("Unknown error")
+ GEOSException()
+ std::runtime_error("Unknown error")
- GEOSException(std::string const& msg)
- std::runtime_error(msg)
+ GEOSException(std::string const& msg)
+ std::runtime_error(msg)
- GEOSException(std::string const& name, std::string const& msg)
- std::runtime_error(name + ": "+msg)
+ GEOSException(std::string const& name, std::string const& msg)
+ std::runtime_error(name + ": " + msg)
diff --git a/include/geos/util/GeometricShapeFactory.h b/include/geos/util/GeometricShapeFactory.h
index 4bc2d3f..b6f0ded 100644
--- a/include/geos/util/GeometricShapeFactory.h
+++ b/include/geos/util/GeometricShapeFactory.h
@@ -33,14 +33,14 @@
namespace geos {
- namespace geom {
- class Coordinate;
- class Envelope;
- class Polygon;
- class PrecisionModel;
- class LineString;
+namespace geom {
+class Coordinate;
+class Envelope;
+class Polygon;
+class PrecisionModel;
+class LineString;
namespace geos {
@@ -65,128 +65,129 @@ namespace util { // geos::util
class GEOS_DLL GeometricShapeFactory {
protected:
- class Dimensions {
- public:
- Dimensions();
- geom::Coordinate base;
- geom::Coordinate centre;
- double width;
- double height;
- void setBase(const geom::Coordinate& newBase);
- void setCentre(const geom::Coordinate& newCentre);
- void setSize(double size);
- void setWidth(double nWidth);
- void setHeight(double nHeight);
- // Return newly-allocated object, ownership transferred
- geom::Envelope* getEnvelope() const;
- const geom::GeometryFactory* geomFact; // externally owned
- const geom::PrecisionModel* precModel; // externally owned
- Dimensions dim;
- int nPts;
- geom::Coordinate coord(double x, double y) const;
+ class Dimensions {
+ public:
+ Dimensions();
+ geom::Coordinate base;
+ geom::Coordinate centre;
+ double width;
+ double height;
+ void setBase(const geom::Coordinate& newBase);
+ void setCentre(const geom::Coordinate& newCentre);
+ void setSize(double size);
+ void setWidth(double nWidth);
+ void setHeight(double nHeight);
+ // Return newly-allocated object, ownership transferred
+ geom::Envelope* getEnvelope() const;
+ const geom::GeometryFactory* geomFact; // externally owned
+ const geom::PrecisionModel* precModel; // externally owned
+ Dimensions dim;
+ int nPts;
+ geom::Coordinate coord(double x, double y) const;
public:
- * \brief
- * Create a shape factory which will create shapes using the given
- * GeometryFactory.
- * @param factory the factory to use. You need to keep the
- * factory alive for the whole GeometricShapeFactory
- * life time.
- GeometricShapeFactory(const geom::GeometryFactory *factory);
- virtual ~GeometricShapeFactory() {}
- * \brief Creates an elliptical arc, as a LineString.
- * The arc is always created in a counter-clockwise direction.
- * @param startAng start angle in radians
- * @param angExtent size of angle in radians
- * @return an elliptical arc
- geom::LineString* createArc(double startAng, double angExtent);
- * \brief Creates an elliptical arc polygon.
- * The polygon is formed from the specified arc of an ellipse
- * and the two radii connecting the endpoints to the centre of
- * the ellipse.
- * @return an elliptical arc polygon
- geom::Polygon* createArcPolygon(double startAng, double angExt);
- * \brief Creates a circular Polygon.
- * @return a circle
- geom::Polygon* createCircle();
- * \brief Creates a rectangular Polygon.
- * @return a rectangular Polygon
- geom::Polygon* createRectangle();
- * \brief
- * Sets the location of the shape by specifying the base coordinate
- * (which in most cases is the * lower left point of the envelope
- * containing the shape).
- * @param base the base coordinate of the shape
- void setBase(const geom::Coordinate& base);
- * \brief
- * Sets the location of the shape by specifying the centre of
- * the shape's bounding box
- * @param centre the centre coordinate of the shape
- void setCentre(const geom::Coordinate& centre);
- * \brief Sets the height of the shape.
- * @param height the height of the shape
- void setHeight(double height);
- * \brief Sets the total number of points in the created Geometry
- void setNumPoints(int nNPts);
- * \brief
- * Sets the size of the extent of the shape in both x and y directions.
- * @param size the size of the shape's extent
- * \brief Sets the width of the shape.
- * @param width the width of the shape
- void setWidth(double width);
+ * \brief
+ * Create a shape factory which will create shapes using the given
+ * GeometryFactory.
+ * @param factory the factory to use. You need to keep the
+ * factory alive for the whole GeometricShapeFactory
+ * life time.
+ GeometricShapeFactory(const geom::GeometryFactory* factory);
+ virtual
+ ~GeometricShapeFactory() {}
+ * \brief Creates an elliptical arc, as a LineString.
+ * The arc is always created in a counter-clockwise direction.
+ * @param startAng start angle in radians
+ * @param angExtent size of angle in radians
+ * @return an elliptical arc
+ geom::LineString* createArc(double startAng, double angExtent);
+ * \brief Creates an elliptical arc polygon.
+ * The polygon is formed from the specified arc of an ellipse
+ * and the two radii connecting the endpoints to the centre of
+ * the ellipse.
+ * @return an elliptical arc polygon
+ geom::Polygon* createArcPolygon(double startAng, double angExt);
+ * \brief Creates a circular Polygon.
+ * @return a circle
+ geom::Polygon* createCircle();
+ * \brief Creates a rectangular Polygon.
+ * @return a rectangular Polygon
+ geom::Polygon* createRectangle();
+ * \brief
+ * Sets the location of the shape by specifying the base coordinate
+ * (which in most cases is the * lower left point of the envelope
+ * containing the shape).
+ * @param base the base coordinate of the shape
+ void setBase(const geom::Coordinate& base);
+ * \brief
+ * Sets the location of the shape by specifying the centre of
+ * the shape's bounding box
+ * @param centre the centre coordinate of the shape
+ void setCentre(const geom::Coordinate& centre);
+ * \brief Sets the height of the shape.
+ * @param height the height of the shape
+ void setHeight(double height);
+ * \brief Sets the total number of points in the created Geometry
+ void setNumPoints(int nNPts);
+ * \brief
+ * Sets the size of the extent of the shape in both x and y directions.
+ * @param size the size of the shape's extent
+ * \brief Sets the width of the shape.
+ * @param width the width of the shape
+ void setWidth(double width);
diff --git a/include/geos/util/IllegalArgumentException.h b/include/geos/util/IllegalArgumentException.h
index f58a7d2..f47647d 100644
--- a/include/geos/util/IllegalArgumentException.h
+++ b/include/geos/util/IllegalArgumentException.h
@@ -33,17 +33,17 @@ namespace util { // geos::util
class GEOS_DLL IllegalArgumentException: public GEOSException {
public:
- IllegalArgumentException()
- GEOSException("IllegalArgumentException", "")
+ IllegalArgumentException()
+ GEOSException("IllegalArgumentException", "")
- IllegalArgumentException(const std::string& msg)
- GEOSException("IllegalArgumentException", msg)
+ IllegalArgumentException(const std::string& msg)
+ GEOSException("IllegalArgumentException", msg)
- ~IllegalArgumentException() throw() override {}
+ ~IllegalArgumentException() throw() override {}
} // namespace geos::util
diff --git a/include/geos/util/IllegalStateException.h b/include/geos/util/IllegalStateException.h
index d23281f..60f8ed3 100644
--- a/include/geos/util/IllegalStateException.h
+++ b/include/geos/util/IllegalStateException.h
@@ -26,17 +26,17 @@ namespace util { // geos::util
/// Indicates an illegal state
class GEOS_DLL IllegalStateException: public GEOSException {
public:
- IllegalStateException()
- GEOSException("IllegalStateException", "")
+ IllegalStateException()
+ GEOSException("IllegalStateException", "")
- IllegalStateException(const std::string& msg)
- GEOSException("IllegalStateException", msg)
+ IllegalStateException(const std::string& msg)
+ GEOSException("IllegalStateException", msg)
- ~IllegalStateException() throw() override {}
+ ~IllegalStateException() throw() override {}
diff --git a/include/geos/util/Interrupt.h b/include/geos/util/Interrupt.h
index 4b02d42..a3e564b 100644
--- a/include/geos/util/Interrupt.h
+++ b/include/geos/util/Interrupt.h
@@ -27,42 +27,42 @@ class GEOS_DLL Interrupt {
public:
- typedef void (Callback)(void);
- * Request interruption of operations
- * Operations will be terminated by a GEOSInterrupt
- * exception at first occasion.
- static void request();
- /** Cancel a pending interruption request */
- static void cancel();
- /** Check if an interruption request is pending */
- static bool check();
- /** \brief
- * Register a callback that will be invoked
- * before checking for interruption requests.
- * NOTE that interruption request checking may happen
- * frequently so any callback would better be quick.
- * The callback can be used to call Interrupt::request()
- static Callback* registerCallback(Callback *cb);
- * Invoke the callback, if any. Process pending interruption, if any.
- static void process();
- /* Perform the actual interruption (simply throw an exception) */
- static void interrupt();
+ typedef void (Callback)(void);
+ * Request interruption of operations
+ * Operations will be terminated by a GEOSInterrupt
+ * exception at first occasion.
+ static void request();
+ /** Cancel a pending interruption request */
+ static void cancel();
+ /** Check if an interruption request is pending */
+ static bool check();
+ /** \brief
+ * Register a callback that will be invoked
+ * before checking for interruption requests.
+ * NOTE that interruption request checking may happen
+ * frequently so any callback would better be quick.
+ * The callback can be used to call Interrupt::request()
+ static Callback* registerCallback(Callback* cb);
+ * Invoke the callback, if any. Process pending interruption, if any.
+ static void process();
+ /* Perform the actual interruption (simply throw an exception) */
+ static void interrupt();
diff --git a/include/geos/util/Machine.h b/include/geos/util/Machine.h
index 4d31fa3..c509ca4 100644
--- a/include/geos/util/Machine.h
+++ b/include/geos/util/Machine.h
@@ -18,10 +18,11 @@
* Check endianness of current machine.
* @return 0 for big_endian | xdr; 1 == little_endian | ndr
-inline int getMachineByteOrder()
+inline int
+getMachineByteOrder()
- static int endian_check = 1; // don't modify !!
- return *((char *)&endian_check);
+ static int endian_check = 1; // don't modify !!
+ return *((char*)&endian_check);
#endif
diff --git a/include/geos/util/TopologyException.h b/include/geos/util/TopologyException.h
index f87fd54..ed4d473 100644
--- a/include/geos/util/TopologyException.h
+++ b/include/geos/util/TopologyException.h
@@ -34,26 +34,30 @@ namespace util { // geos.util
class GEOS_DLL TopologyException: public GEOSException {
public:
- TopologyException()
- GEOSException("TopologyException", "")
- TopologyException(const std::string& msg)
- GEOSException("TopologyException", msg)
- TopologyException(const std::string& msg, const geom::Coordinate& newPt)
- GEOSException("TopologyException", msg + " at " + newPt.toString()),
- pt(newPt)
- ~TopologyException() throw() override {}
- geom::Coordinate& getCoordinate() { return pt; }
+ TopologyException()
+ GEOSException("TopologyException", "")
+ TopologyException(const std::string& msg)
+ GEOSException("TopologyException", msg)
+ TopologyException(const std::string& msg, const geom::Coordinate& newPt)
+ GEOSException("TopologyException", msg + " at " + newPt.toString()),
+ pt(newPt)
+ ~TopologyException() throw() override {}
+ geom::Coordinate&
+ getCoordinate()
+ return pt;
private:
- geom::Coordinate pt;
+ geom::Coordinate pt;
diff --git a/include/geos/util/UniqueCoordinateArrayFilter.h b/include/geos/util/UniqueCoordinateArrayFilter.h
index b25804f..09023ff 100644
--- a/include/geos/util/UniqueCoordinateArrayFilter.h
+++ b/include/geos/util/UniqueCoordinateArrayFilter.h
@@ -39,42 +39,41 @@ namespace util { // geos::util
* Last port: util/UniqueCoordinateArrayFilter.java rev. 1.17
-class GEOS_DLL UniqueCoordinateArrayFilter: public geom::CoordinateFilter
+class GEOS_DLL UniqueCoordinateArrayFilter: public geom::CoordinateFilter {
public:
- * @param target The destination set.
- UniqueCoordinateArrayFilter(geom::Coordinate::ConstVect &target)
- : pts(target)
+ * @param target The destination set.
+ UniqueCoordinateArrayFilter(geom::Coordinate::ConstVect& target)
+ : pts(target)
- * Destructor.
- * Virtual dctor promises appropriate behaviour when someone will
- * delete a derived-class object via a base-class pointer.
- * http://www.parashift.com/c++-faq-lite/virtual-functions.html#faq-20.7
- ~UniqueCoordinateArrayFilter() override {}
+ * Destructor.
+ * Virtual dctor promises appropriate behaviour when someone will
+ * delete a derived-class object via a base-class pointer.
+ * http://www.parashift.com/c++-faq-lite/virtual-functions.html#faq-20.7
+ ~UniqueCoordinateArrayFilter() override {}
- * Performs a filtering operation with or on coord in "read-only" mode.
- * @param coord The "read-only" Coordinate to which
- * the filter is applied.
- void filter_ro(const geom::Coordinate *coord) override
- if ( uniqPts.insert(coord).second )
+ * Performs a filtering operation with or on coord in "read-only" mode.
+ * @param coord The "read-only" Coordinate to which
+ * the filter is applied.
+ void
+ filter_ro(const geom::Coordinate* coord) override
+ if(uniqPts.insert(coord).second) {
private:
- geom::Coordinate::ConstVect &pts; // target set reference
- geom::Coordinate::ConstSet uniqPts; // unique points set
+ geom::Coordinate::ConstVect& pts; // target set reference
+ geom::Coordinate::ConstSet uniqPts; // unique points set
// Declare type as noncopyable
UniqueCoordinateArrayFilter(const UniqueCoordinateArrayFilter& other) = delete;
diff --git a/include/geos/util/UnsupportedOperationException.h b/include/geos/util/UnsupportedOperationException.h
index 95b2715..e3939ca 100644
--- a/include/geos/util/UnsupportedOperationException.h
+++ b/include/geos/util/UnsupportedOperationException.h
@@ -35,17 +35,17 @@ namespace util { // geos::util
class GEOS_DLL UnsupportedOperationException: public GEOSException {
public:
- UnsupportedOperationException()
- GEOSException("UnsupportedOperationException", "")
+ UnsupportedOperationException()
+ GEOSException("UnsupportedOperationException", "")
- UnsupportedOperationException(const std::string& msg)
- GEOSException("UnsupportedOperationException", msg)
+ UnsupportedOperationException(const std::string& msg)
+ GEOSException("UnsupportedOperationException", msg)
- ~UnsupportedOperationException() throw() override {}
+ ~UnsupportedOperationException() throw() override {}
diff --git a/include/geos/util/math.h b/include/geos/util/math.h
index 54e2d9a..cc323d2 100644
--- a/include/geos/util/math.h
+++ b/include/geos/util/math.h
@@ -16,7 +16,8 @@
#ifndef GEOS_UTIL_MATH_H
#define GEOS_UTIL_MATH_H
-namespace geos { namespace util {
+namespace geos {
+namespace util {
/// Symmetric Rounding Algorithm
double sym_round(double val);
@@ -31,11 +32,13 @@ double rint_vc(double val);
/// @note Always use this rounding method, to easy easy switching
/// between different rounding method for the whole codebase.
-inline double round(double val)
+inline double
+round(double val)
- return java_math_round(val);
+ return java_math_round(val);
-}} // namespace geos::util
+} // namespace geos::util
#endif // GEOS_UTIL_MATH_H
diff --git a/src/algorithm/Angle.cpp b/src/algorithm/Angle.cpp
index c05e758..24d0070 100644
--- a/src/algorithm/Angle.cpp
+++ b/src/algorithm/Angle.cpp
@@ -25,7 +25,7 @@ namespace geos {
namespace algorithm { // geos.algorithm
namespace {
- const double PI = 3.14159265358979323846;
+const double PI = 3.14159265358979323846;
const double Angle::PI_TIMES_2 = 2.0 * PI;
@@ -36,14 +36,14 @@ const double Angle::PI_OVER_4 = PI / 4.0;
double
Angle::toDegrees(double radians)
- return (radians * 180) / (PI);
+ return (radians * 180) / (PI);
/* public static */
double
Angle::toRadians(double angleDegrees)
- return (angleDegrees * PI) / 180.0;
+ return (angleDegrees * PI) / 180.0;
/* public static */
@@ -51,16 +51,16 @@ double
Angle::angle(const geom::Coordinate& p0,
- double dx = p1.x - p0.x;
- double dy = p1.y - p0.y;
- return atan2(dy, dx);
+ double dx = p1.x - p0.x;
+ double dy = p1.y - p0.y;
+ return atan2(dy, dx);
/* public static */
double
Angle::angle(const geom::Coordinate& p)
- return atan2(p.y, p.x);
+ return atan2(p.y, p.x);
/* public static */
@@ -69,13 +69,13 @@ Angle::isAcute(const geom::Coordinate& p0,
const geom::Coordinate& p1,
const geom::Coordinate& p2)
- // relies on fact that A dot B is positive iff A ang B is acute
- double dx0 = p0.x - p1.x;
- double dy0 = p0.y - p1.y;
- double dx1 = p2.x - p1.x;
- double dy1 = p2.y - p1.y;
- double dotprod = dx0 * dx1 + dy0 * dy1;
- return dotprod > 0;
+ // relies on fact that A dot B is positive iff A ang B is acute
+ double dx0 = p0.x - p1.x;
+ double dy0 = p0.y - p1.y;
+ double dx1 = p2.x - p1.x;
+ double dy1 = p2.y - p1.y;
+ double dotprod = dx0 * dx1 + dy0 * dy1;
+ return dotprod > 0;
/* public static */
@@ -84,13 +84,13 @@ Angle::isObtuse(const geom::Coordinate& p0,
- // relies on fact that A dot B is negative iff A ang B is obtuse
- return dotprod < 0;
+ // relies on fact that A dot B is negative iff A ang B is obtuse
+ return dotprod < 0;
/* public static */
@@ -99,10 +99,10 @@ Angle::angleBetween(const geom::Coordinate& tip1,
const geom::Coordinate& tail,
const geom::Coordinate& tip2)
- double a1 = angle(tail, tip1);
- double a2 = angle(tail, tip2);
+ double a1 = angle(tail, tip1);
+ double a2 = angle(tail, tip2);
- return diff(a1, a2);
+ return diff(a1, a2);
/* public static */
@@ -111,16 +111,18 @@ Angle::angleBetweenOriented(const geom::Coordinate& tip1,
- double angDel = a2 - a1;
- // normalize, maintaining orientation
- if (angDel <= -PI)
- return angDel + PI_TIMES_2;
- if (angDel > PI)
- return angDel - PI_TIMES_2;
- return angDel;
+ double angDel = a2 - a1;
+ // normalize, maintaining orientation
+ if(angDel <= -PI) {
+ return angDel + PI_TIMES_2;
+ if(angDel > PI) {
+ return angDel - PI_TIMES_2;
+ return angDel;
/* public static */
@@ -128,75 +130,82 @@ double
Angle::interiorAngle(const geom::Coordinate& p0, const geom::Coordinate& p1,
- double anglePrev = angle(p1, p0);
- double angleNext = angle(p1, p2);
- return fabs(angleNext - anglePrev);
+ double anglePrev = angle(p1, p0);
+ double angleNext = angle(p1, p2);
+ return fabs(angleNext - anglePrev);
/* public static */
int
Angle::getTurn(double ang1, double ang2)
- double crossproduct = sin(ang2 - ang1);
- if (crossproduct > 0) {
- return COUNTERCLOCKWISE;
- if (crossproduct < 0) {
- return CLOCKWISE;
- return NONE;
+ double crossproduct = sin(ang2 - ang1);
+ if(crossproduct > 0) {
+ return COUNTERCLOCKWISE;
+ if(crossproduct < 0) {
+ return CLOCKWISE;
+ return NONE;
/* public static */
double
Angle::normalize(double angle)
- while (angle > PI)
- angle -= PI_TIMES_2;
- while (angle <= -PI)
- angle += PI_TIMES_2;
- return angle;
+ while(angle > PI) {
+ angle -= PI_TIMES_2;
+ while(angle <= -PI) {
+ angle += PI_TIMES_2;
+ return angle;
/* public static */
double
Angle::normalizePositive(double angle)
- if (angle < 0.0) {
- while (angle < 0.0)
- // in case round-off error bumps the value over
- if (angle >= PI_TIMES_2)
- angle = 0.0;
- else {
- while (angle >= PI_TIMES_2)
- // in case round-off error bumps the value under
- if (angle < 0.0)
- angle = 0.0;
- return angle;
+ if(angle < 0.0) {
+ while(angle < 0.0) {
+ // in case round-off error bumps the value over
+ if(angle >= PI_TIMES_2) {
+ angle = 0.0;
+ else {
+ while(angle >= PI_TIMES_2) {
+ // in case round-off error bumps the value under
+ if(angle < 0.0) {
+ angle = 0.0;
+ return angle;
/* public static */
double
Angle::diff(double ang1, double ang2)
- double delAngle;
+ double delAngle;
- if (ang1 < ang2) {
- delAngle = ang2 - ang1;
- } else {
- delAngle = ang1 - ang2;
+ if(ang1 < ang2) {
+ delAngle = ang2 - ang1;
+ else {
+ delAngle = ang1 - ang2;
- if (delAngle > PI) {
- delAngle = (2 * PI) - delAngle;
+ if(delAngle > PI) {
+ delAngle = (2 * PI) - delAngle;
- return delAngle;
+ return delAngle;
} // namespace geos.algorithm
diff --git a/src/algorithm/Area.cpp b/src/algorithm/Area.cpp
index 021bbf3..81c76bb 100644
--- a/src/algorithm/Area.cpp
+++ b/src/algorithm/Area.cpp
@@ -26,25 +26,26 @@ namespace algorithm { // geos.algorithm
/* public static */
double
-Area::ofRing(const std::vector<geom::Coordinate> &ring)
+Area::ofRing(const std::vector<geom::Coordinate>& ring)
return std::abs(ofRingSigned(ring));
/* public static */
double
-Area::ofRing(const geom::CoordinateSequence *ring)
+Area::ofRing(const geom::CoordinateSequence* ring)
/* public static */
double
-Area::ofRingSigned(const std::vector<geom::Coordinate> &ring)
+Area::ofRingSigned(const std::vector<geom::Coordinate>& ring)
size_t rlen = ring.size();
- if (rlen < 3)
+ if(rlen < 3) {
return 0.0;
double sum = 0.0;
@@ -52,7 +53,7 @@ Area::ofRingSigned(const std::vector<geom::Coordinate> &ring)
* http://en.wikipedia.org/wiki/Shoelace_formula
double x0 = ring[0].x;
- for (size_t i = 1; i < rlen - 1; i++) {
+ for(size_t i = 1; i < rlen - 1; i++) {
double x = ring[i].x - x0;
double y1 = ring[i + 1].y;
double y2 = ring[i - 1].y;
@@ -63,11 +64,12 @@ Area::ofRingSigned(const std::vector<geom::Coordinate> &ring)
/* public static */
double
-Area::ofRingSigned(const geom::CoordinateSequence *ring)
+Area::ofRingSigned(const geom::CoordinateSequence* ring)
size_t n = ring->size();
- if (n < 3)
+ if(n < 3) {
return 0.0;
* Based on the Shoelace formula.
@@ -78,7 +80,7 @@ Area::ofRingSigned(const geom::CoordinateSequence *ring)
double x0 = p1.x;
p2.x -= x0;
double sum = 0.0;
- for (size_t i = 1; i < n - 1; i++) {
+ for(size_t i = 1; i < n - 1; i++) {
p0.y = p1.y;
p1.x = p2.x;
p1.y = p2.y;
diff --git a/src/algorithm/BoundaryNodeRule.cpp b/src/algorithm/BoundaryNodeRule.cpp
index 1603696..c7417b9 100644
--- a/src/algorithm/BoundaryNodeRule.cpp
+++ b/src/algorithm/BoundaryNodeRule.cpp
@@ -41,14 +41,14 @@ namespace {
* @author Martin Davis
* @version 1.7
-class Mod2BoundaryNodeRule : public BoundaryNodeRule
+class Mod2BoundaryNodeRule : public BoundaryNodeRule {
public:
- bool isInBoundary(int boundaryCount) const override
- // the "Mod-2 Rule"
- return boundaryCount % 2 == 1;
+ bool
+ isInBoundary(int boundaryCount) const override
+ // the "Mod-2 Rule"
+ return boundaryCount % 2 == 1;
@@ -79,12 +79,12 @@ public:
* @version 1.7
-class EndPointBoundaryNodeRule : public BoundaryNodeRule
- return boundaryCount > 0;
+class EndPointBoundaryNodeRule : public BoundaryNodeRule {
+ bool
+ return boundaryCount > 0;
@@ -97,12 +97,12 @@ class EndPointBoundaryNodeRule : public BoundaryNodeRule
* @version 1.7
-class MultiValentEndPointBoundaryNodeRule : public BoundaryNodeRule
- return boundaryCount > 1;
+class MultiValentEndPointBoundaryNodeRule : public BoundaryNodeRule {
+ bool
+ return boundaryCount > 1;
@@ -114,12 +114,12 @@ class MultiValentEndPointBoundaryNodeRule : public BoundaryNodeRule
* @version 1.7
-class MonoValentEndPointBoundaryNodeRule : public BoundaryNodeRule
- return boundaryCount == 1;
+class MonoValentEndPointBoundaryNodeRule : public BoundaryNodeRule {
+ bool
+ return boundaryCount == 1;
Mod2BoundaryNodeRule mod2Rule;
@@ -130,31 +130,36 @@ MonoValentEndPointBoundaryNodeRule monoValentRule;
} // anonymous namespace
//const BoundaryNodeRule& BoundaryNodeRule::MOD2_BOUNDARY_RULE = mod2Rule;
-const BoundaryNodeRule& BoundaryNodeRule::getBoundaryRuleMod2()
+const BoundaryNodeRule&
+BoundaryNodeRule::getBoundaryRuleMod2()
return mod2Rule;
//const BoundaryNodeRule& BoundaryNodeRule::ENDPOINT_BOUNDARY_RULE = endPointRule;
-const BoundaryNodeRule& BoundaryNodeRule::getBoundaryEndPoint()
+BoundaryNodeRule::getBoundaryEndPoint()
return endPointRule;
//const BoundaryNodeRule& BoundaryNodeRule::MULTIVALENT_ENDPOINT_BOUNDARY_RULE = multiValentRule;
-const BoundaryNodeRule& BoundaryNodeRule::getBoundaryMultivalentEndPoint()
+BoundaryNodeRule::getBoundaryMultivalentEndPoint()
return multiValentRule;
//const BoundaryNodeRule& BoundaryNodeRule::MONOVALENT_ENDPOINT_BOUNDARY_RULE = monoValentRule;
-const BoundaryNodeRule& BoundaryNodeRule::getBoundaryMonovalentEndPoint()
+BoundaryNodeRule::getBoundaryMonovalentEndPoint()
return monoValentRule;
//const BoundaryNodeRule& BoundaryNodeRule::OGC_SFS_BOUNDARY_RULE = BoundaryNodeRule::MOD2_BOUNDARY_RULE;
-const BoundaryNodeRule& BoundaryNodeRule::getBoundaryOGCSFS()
+BoundaryNodeRule::getBoundaryOGCSFS()
return getBoundaryRuleMod2();
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index 8bcf3e9..2fe8a55 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -33,14 +33,17 @@ namespace {
double constexpr DP_SAFE_EPSILON = 1e-15;
-inline int OrientationDD(DD const& dd)
+inline int
+OrientationDD(DD const& dd)
static DD const zero(0.0);
- if (dd < zero)
+ if(dd < zero) {
return CGAlgorithmsDD::RIGHT;
- if (dd > zero)
+ if(dd > zero) {
return CGAlgorithmsDD::LEFT;
return CGAlgorithmsDD::STRAIGHT;
@@ -54,19 +57,21 @@ inline int OrientationDD(DD const& dd)
namespace geos {
namespace algorithm { // geos::algorithm
-int CGAlgorithmsDD::orientationIndex(const Coordinate& p1,
- const Coordinate& p2,
- const Coordinate& q)
+int
+CGAlgorithmsDD::orientationIndex(const Coordinate& p1,
+ const Coordinate& p2,
+ const Coordinate& q)
- if (std::isnan(q.x) || std::isnan(q.y) || !std::isfinite(q.x) || !std::isfinite(q.y)) {
+ if(std::isnan(q.x) || std::isnan(q.y) || !std::isfinite(q.x) || !std::isfinite(q.y)) {
throw util::IllegalArgumentException("CGAlgorithmsDD::orientationIndex encountered NaN/Inf numbers");
// fast filter for orientation index
// avoids use of slow extended-precision arithmetic in many cases
int index = orientationIndexFilter(p1, p2, q);
- if (index <= 1)
+ if(index <= 1) {
return index;
// normalize coordinates
DD dx1 = DD(p2.x) + DD(-p1.x);
@@ -81,7 +86,8 @@ int CGAlgorithmsDD::orientationIndex(const Coordinate& p1,
return OrientationDD(d);
-int CGAlgorithmsDD::signOfDet2x2(DD &x1, DD &y1, DD &x2, DD &y2)
+int
+CGAlgorithmsDD::signOfDet2x2(DD& x1, DD& y1, DD& x2, DD& y2)
DD mx1y2(x1 * y2);
DD my1x2(y1 * x2);
@@ -89,10 +95,11 @@ int CGAlgorithmsDD::signOfDet2x2(DD &x1, DD &y1, DD &x2, DD &y2)
-int CGAlgorithmsDD::signOfDet2x2(double dx1, double dy1, double dx2, double dy2)
+int
+CGAlgorithmsDD::signOfDet2x2(double dx1, double dy1, double dx2, double dy2)
- if (std::isnan(dx1) || std::isnan(dy1) || std::isnan(dx2) || std::isnan(dy2) ||
- !std::isfinite(dx1) || !std::isfinite(dy1) || !std::isfinite(dx2) || !std::isfinite(dy2)) {
+ if(std::isnan(dx1) || std::isnan(dy1) || std::isnan(dx2) || std::isnan(dy2) ||
+ !std::isfinite(dx1) || !std::isfinite(dy1) || !std::isfinite(dx2) || !std::isfinite(dy2)) {
throw util::IllegalArgumentException("CGAlgorithmsDD::signOfDet2x2 encountered NaN/Inf numbers");
DD x1(dx1);
@@ -102,25 +109,26 @@ int CGAlgorithmsDD::signOfDet2x2(double dx1, double dy1, double dx2, double dy2)
return CGAlgorithmsDD::signOfDet2x2(x1, y1, x2, y2);
-int CGAlgorithmsDD::orientationIndexFilter(const Coordinate& pa,
- const Coordinate& pb,
- const Coordinate& pc)
+int
+CGAlgorithmsDD::orientationIndexFilter(const Coordinate& pa,
+ const Coordinate& pb,
+ const Coordinate& pc)
double detsum;
double const detleft = (pa.x - pc.x) * (pb.y - pc.y);
double const detright = (pa.y - pc.y) * (pb.x - pc.x);
double const det = detleft - detright;
- if (detleft > 0.0) {
- if (detright <= 0.0) {
+ if(detleft > 0.0) {
+ if(detright <= 0.0) {
return orientation(det);
else {
detsum = detleft + detright;
- else if (detleft < 0.0) {
- if (detright >= 0.0) {
+ else if(detleft < 0.0) {
+ if(detright >= 0.0) {
else {
@@ -132,15 +140,16 @@ int CGAlgorithmsDD::orientationIndexFilter(const Coordinate& pa,
double const errbound = DP_SAFE_EPSILON * detsum;
- if ((det >= errbound) || (-det >= errbound)) {
+ if((det >= errbound) || (-det >= errbound)) {
return CGAlgorithmsDD::FAILURE;
-void CGAlgorithmsDD::intersection(const Coordinate& p1, const Coordinate& p2,
- const Coordinate& q1, const Coordinate& q2,
- Coordinate &rv)
+void
+CGAlgorithmsDD::intersection(const Coordinate& p1, const Coordinate& p2,
+ const Coordinate& q1, const Coordinate& q2,
+ Coordinate& rv)
DD q1x(q1.x);
DD q1y(q1.y);
diff --git a/src/algorithm/Centroid.cpp b/src/algorithm/Centroid.cpp
index f217420..8f65682 100644
--- a/src/algorithm/Centroid.cpp
+++ b/src/algorithm/Centroid.cpp
@@ -37,157 +37,162 @@ namespace algorithm { // geos.algorithm
bool
Centroid::getCentroid(const Geometry& geom, Coordinate& pt)
- Centroid cent(geom);
- return cent.getCentroid(pt);
+ Centroid cent(geom);
+ return cent.getCentroid(pt);
/* public */
bool
Centroid::getCentroid(Coordinate& cent) const
- if (std::abs(areasum2) > 0.0) {
- cent.x = cg3.x / 3 / areasum2;
- cent.y = cg3.y / 3 / areasum2;
- else if (totalLength > 0.0) {
- // if polygon was degenerate, compute linear centroid instead
- cent.x = lineCentSum.x / totalLength;
- cent.y = lineCentSum.y / totalLength;
- else if (ptCount > 0){
- cent.x = ptCentSum.x / ptCount;
- cent.y = ptCentSum.y / ptCount;
- else {
- return false;
- return true;
+ if(std::abs(areasum2) > 0.0) {
+ cent.x = cg3.x / 3 / areasum2;
+ cent.y = cg3.y / 3 / areasum2;
+ else if(totalLength > 0.0) {
+ // if polygon was degenerate, compute linear centroid instead
+ cent.x = lineCentSum.x / totalLength;
+ cent.y = lineCentSum.y / totalLength;
+ else if(ptCount > 0) {
+ cent.x = ptCentSum.x / ptCount;
+ cent.y = ptCentSum.y / ptCount;
+ else {
+ return false;
+ return true;
/* private */
void
Centroid::add(const Geometry& geom)
- if (geom.isEmpty()) return;
- if (const Point* pt = dynamic_cast<const Point*>(&geom)) {
- addPoint(*pt->getCoordinate());
- else if (const LineString* ls = dynamic_cast<const LineString*>(&geom)) {
- addLineSegments(*ls->getCoordinatesRO());
- else if (const Polygon* p = dynamic_cast<const Polygon*>(&geom)) {
- add(*p);
- else if (const GeometryCollection* g = dynamic_cast<const GeometryCollection*>(&geom)) {
- for (size_t i = 0; i < g->getNumGeometries(); i++) {
- add(*g->getGeometryN(i));
+ if(geom.isEmpty()) {
+ return;
+ if(const Point* pt = dynamic_cast<const Point*>(&geom)) {
+ addPoint(*pt->getCoordinate());
+ else if(const LineString* ls = dynamic_cast<const LineString*>(&geom)) {
+ addLineSegments(*ls->getCoordinatesRO());
+ else if(const Polygon* p = dynamic_cast<const Polygon*>(&geom)) {
+ add(*p);
+ else if(const GeometryCollection* g = dynamic_cast<const GeometryCollection*>(&geom)) {
+ for(size_t i = 0; i < g->getNumGeometries(); i++) {
+ add(*g->getGeometryN(i));
/* private */
void
Centroid::setAreaBasePoint(const Coordinate& basePt)
- areaBasePt.reset( new Coordinate(basePt) );
+ areaBasePt.reset(new Coordinate(basePt));
/* private */
void
Centroid::add(const Polygon& poly)
- addShell(*poly.getExteriorRing()->getCoordinatesRO());
- for (size_t i = 0; i < poly.getNumInteriorRing(); i++) {
- addHole(*poly.getInteriorRingN(i)->getCoordinatesRO());
+ addShell(*poly.getExteriorRing()->getCoordinatesRO());
+ for(size_t i = 0; i < poly.getNumInteriorRing(); i++) {
+ addHole(*poly.getInteriorRingN(i)->getCoordinatesRO());
/* private */
void
Centroid::addShell(const CoordinateSequence& pts)
- size_t len = pts.size();
- if (len > 0)
- setAreaBasePoint(pts[0]);
- bool isPositiveArea = ! Orientation::isCCW(&pts);
- for (size_t i = 0; i < len - 1; ++i) {
- addTriangle(*areaBasePt, pts[i], pts[i+1], isPositiveArea);
- addLineSegments(pts);
+ size_t len = pts.size();
+ if(len > 0) {
+ setAreaBasePoint(pts[0]);
+ bool isPositiveArea = ! Orientation::isCCW(&pts);
+ for(size_t i = 0; i < len - 1; ++i) {
+ addTriangle(*areaBasePt, pts[i], pts[i + 1], isPositiveArea);
+ addLineSegments(pts);
/* private */
void
Centroid::addHole(const CoordinateSequence& pts)
- bool isPositiveArea = Orientation::isCCW(&pts);
- for (size_t i = 0, e = pts.size() - 1; i < e; ++i) {
+ bool isPositiveArea = Orientation::isCCW(&pts);
+ for(size_t i = 0, e = pts.size() - 1; i < e; ++i) {
/* private */
void
Centroid::addTriangle(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2, bool isPositiveArea)
- double sign = (isPositiveArea) ? 1.0 : -1.0;
- centroid3( p0, p1, p2, triangleCent3 );
- double a2 = area2( p0, p1, p2 );
- cg3.x += sign * a2 * triangleCent3.x;
- cg3.y += sign * a2 * triangleCent3.y;
- areasum2 += sign * a2;
+ double sign = (isPositiveArea) ? 1.0 : -1.0;
+ centroid3(p0, p1, p2, triangleCent3);
+ double a2 = area2(p0, p1, p2);
+ cg3.x += sign * a2 * triangleCent3.x;
+ cg3.y += sign * a2 * triangleCent3.y;
+ areasum2 += sign * a2;
/* static private */
void
-Centroid::centroid3(const Coordinate& p1, const Coordinate& p2, const Coordinate& p3, Coordinate& c )
+Centroid::centroid3(const Coordinate& p1, const Coordinate& p2, const Coordinate& p3, Coordinate& c)
- c.x = p1.x + p2.x + p3.x;
- c.y = p1.y + p2.y + p3.y;
- return;
+ c.x = p1.x + p2.x + p3.x;
+ c.y = p1.y + p2.y + p3.y;
+ return;
double
-Centroid::area2(const Coordinate& p1, const Coordinate& p2, const Coordinate& p3 )
+Centroid::area2(const Coordinate& p1, const Coordinate& p2, const Coordinate& p3)
- return
- (p2.x - p1.x) * (p3.y - p1.y) -
- (p3.x - p1.x) * (p2.y - p1.y);
+ return
+ (p2.x - p1.x) * (p3.y - p1.y) -
+ (p3.x - p1.x) * (p2.y - p1.y);
/* private */
void
Centroid::addLineSegments(const CoordinateSequence& pts)
- size_t npts = pts.size();
- double lineLen = 0.0;
- for (size_t i = 0; i < npts - 1; i++) {
- double segmentLen = pts[i].distance(pts[i + 1]);
- if (segmentLen == 0.0)
- continue;
- lineLen += segmentLen;
- double midx = (pts[i].x + pts[i + 1].x) / 2;
- lineCentSum.x += segmentLen * midx;
- double midy = (pts[i].y + pts[i + 1].y) / 2;
- lineCentSum.y += segmentLen * midy;
- totalLength += lineLen;
- if (lineLen == 0.0 && npts > 0)
- addPoint(pts[0]);
+ size_t npts = pts.size();
+ double lineLen = 0.0;
+ for(size_t i = 0; i < npts - 1; i++) {
+ double segmentLen = pts[i].distance(pts[i + 1]);
+ if(segmentLen == 0.0) {
+ continue;
+ lineLen += segmentLen;
+ double midx = (pts[i].x + pts[i + 1].x) / 2;
+ lineCentSum.x += segmentLen * midx;
+ double midy = (pts[i].y + pts[i + 1].y) / 2;
+ lineCentSum.y += segmentLen * midy;
+ totalLength += lineLen;
+ if(lineLen == 0.0 && npts > 0) {
+ addPoint(pts[0]);
/* private */
void
Centroid::addPoint(const Coordinate& pt)
- ptCount += 1;
- ptCentSum.x += pt.x;
- ptCentSum.y += pt.y;
+ ptCount += 1;
+ ptCentSum.x += pt.x;
+ ptCentSum.y += pt.y;
diff --git a/src/algorithm/ConvexHull.cpp b/src/algorithm/ConvexHull.cpp
index 40cb11b..0d8f650 100644
--- a/src/algorithm/ConvexHull.cpp
+++ b/src/algorithm/ConvexHull.cpp
@@ -52,346 +52,347 @@ class RadiallyLessThen {
private:
- const Coordinate *origin;
- int
- polarCompare(const Coordinate *o, const Coordinate *p,
- const Coordinate *q)
- double dxp=p->x-o->x;
- double dyp=p->y-o->y;
- double dxq=q->x-o->x;
- double dyq=q->y-o->y;
- int orient = Orientation::index(*o, *p, *q);
- if (orient == Orientation::COUNTERCLOCKWISE) return 1;
- if (orient == Orientation::CLOCKWISE) return -1;
- // points are collinear - check distance
- double op = dxp * dxp + dyp * dyp;
- double oq = dxq * dxq + dyq * dyq;
- if (op < oq) {
- return -1;
- if (op > oq) {
- return 1;
- return 0;
+ const Coordinate* origin;
+ int
+ polarCompare(const Coordinate* o, const Coordinate* p,
+ const Coordinate* q)
+ double dxp = p->x - o->x;
+ double dyp = p->y - o->y;
+ double dxq = q->x - o->x;
+ double dyq = q->y - o->y;
+ int orient = Orientation::index(*o, *p, *q);
+ if(orient == Orientation::COUNTERCLOCKWISE) {
+ return 1;
+ if(orient == Orientation::CLOCKWISE) {
+ return -1;
+ // points are collinear - check distance
+ double op = dxp * dxp + dyp * dyp;
+ double oq = dxq * dxq + dyq * dyq;
+ if(op < oq) {
+ return -1;
+ if(op > oq) {
+ return 1;
+ return 0;
public:
- RadiallyLessThen(const Coordinate *c): origin(c) {}
+ RadiallyLessThen(const Coordinate* c): origin(c) {}
- bool operator() (const Coordinate *p1, const Coordinate *p2)
- return ( polarCompare(origin, p1, p2) == -1 );
+ bool
+ operator()(const Coordinate* p1, const Coordinate* p2)
+ return (polarCompare(origin, p1, p2) == -1);
} // unnamed namespace
/* private */
-CoordinateSequence *
-ConvexHull::toCoordinateSequence(Coordinate::ConstVect &cv)
+CoordinateSequence*
+ConvexHull::toCoordinateSequence(Coordinate::ConstVect& cv)
- const CoordinateSequenceFactory *csf =
- geomFactory->getCoordinateSequenceFactory();
+ const CoordinateSequenceFactory* csf =
+ geomFactory->getCoordinateSequenceFactory();
- // Create a new Coordinate::Vect for feeding it to
- // the CoordinateSequenceFactory
- Coordinate::Vect *vect=new Coordinate::Vect();
+ // Create a new Coordinate::Vect for feeding it to
+ // the CoordinateSequenceFactory
+ Coordinate::Vect* vect = new Coordinate::Vect();
- size_t n=cv.size();
- vect->reserve(n); // avoid multiple reallocs
+ size_t n = cv.size();
+ vect->reserve(n); // avoid multiple reallocs
- for (size_t i=0; i<n; ++i)
- vect->push_back(*(cv[i])); // Coordinate copy
+ for(size_t i = 0; i < n; ++i) {
+ vect->push_back(*(cv[i])); // Coordinate copy
- return csf->create(vect); // takes ownership of the vector
+ return csf->create(vect); // takes ownership of the vector
/* private */
void
-ConvexHull::computeOctPts(const Coordinate::ConstVect &p_inputPts,
- Coordinate::ConstVect &pts)
+ConvexHull::computeOctPts(const Coordinate::ConstVect& p_inputPts,
+ Coordinate::ConstVect& pts)
- // Initialize all slots with first input coordinate
- pts = Coordinate::ConstVect(8, p_inputPts[0]);
- for (size_t i=1, n=p_inputPts.size(); i<n; ++i)
- if (p_inputPts[i]->x < pts[0]->x) {
- pts[0] = p_inputPts[i];
- if (p_inputPts[i]->x - p_inputPts[i]->y < pts[1]->x - pts[1]->y) {
- pts[1] = p_inputPts[i];
- if (p_inputPts[i]->y > pts[2]->y) {
- pts[2] = p_inputPts[i];
- if (p_inputPts[i]->x + p_inputPts[i]->y > pts[3]->x + pts[3]->y) {
- pts[3] = p_inputPts[i];
- if (p_inputPts[i]->x > pts[4]->x) {
- pts[4] = p_inputPts[i];
- if (p_inputPts[i]->x - p_inputPts[i]->y > pts[5]->x - pts[5]->y) {
- pts[5] = p_inputPts[i];
- if (p_inputPts[i]->y < pts[6]->y) {
- pts[6] = p_inputPts[i];
- if (p_inputPts[i]->x + p_inputPts[i]->y < pts[7]->x + pts[7]->y) {
- pts[7] = p_inputPts[i];
+ // Initialize all slots with first input coordinate
+ pts = Coordinate::ConstVect(8, p_inputPts[0]);
+ for(size_t i = 1, n = p_inputPts.size(); i < n; ++i) {
+ if(p_inputPts[i]->x < pts[0]->x) {
+ pts[0] = p_inputPts[i];
+ if(p_inputPts[i]->x - p_inputPts[i]->y < pts[1]->x - pts[1]->y) {
+ pts[1] = p_inputPts[i];
+ if(p_inputPts[i]->y > pts[2]->y) {
+ pts[2] = p_inputPts[i];
+ if(p_inputPts[i]->x + p_inputPts[i]->y > pts[3]->x + pts[3]->y) {
+ pts[3] = p_inputPts[i];
+ if(p_inputPts[i]->x > pts[4]->x) {
+ pts[4] = p_inputPts[i];
+ if(p_inputPts[i]->x - p_inputPts[i]->y > pts[5]->x - pts[5]->y) {
+ pts[5] = p_inputPts[i];
+ if(p_inputPts[i]->y < pts[6]->y) {
+ pts[6] = p_inputPts[i];
+ if(p_inputPts[i]->x + p_inputPts[i]->y < pts[7]->x + pts[7]->y) {
+ pts[7] = p_inputPts[i];
/* private */
bool
-ConvexHull::computeOctRing(const Coordinate::ConstVect &p_inputPts,
- Coordinate::ConstVect &dest)
+ConvexHull::computeOctRing(const Coordinate::ConstVect& p_inputPts,
+ Coordinate::ConstVect& dest)
- computeOctPts(p_inputPts, dest);
+ computeOctPts(p_inputPts, dest);
- // Remove consecutive equal Coordinates
- // unique() returns an iterator to the end of the resulting
- // sequence, we erase from there to the end.
- dest.erase( std::unique(dest.begin(),dest.end()), dest.end() );
+ // Remove consecutive equal Coordinates
+ // unique() returns an iterator to the end of the resulting
+ // sequence, we erase from there to the end.
+ dest.erase(std::unique(dest.begin(), dest.end()), dest.end());
- // points must all lie in a line
- if ( dest.size() < 3 ) return false;
+ // points must all lie in a line
+ if(dest.size() < 3) {
+ return false;
- // close ring
- dest.push_back(dest[0]);
+ // close ring
+ dest.push_back(dest[0]);
- return true;
+ return true;
/* private */
void
-ConvexHull::reduce(Coordinate::ConstVect &pts)
+ConvexHull::reduce(Coordinate::ConstVect& pts)
- Coordinate::ConstVect polyPts;
- if ( ! computeOctRing(pts, polyPts) ) {
- // unable to compute interior polygon for some reason
- return;
- // add points defining polygon
- Coordinate::ConstSet reducedSet;
- reducedSet.insert(polyPts.begin(), polyPts.end());
- * Add all unique points not in the interior poly.
- * CGAlgorithms.isPointInRing is not defined for points
- * actually on the ring, but this doesn't matter since
- * the points of the interior polygon are forced to be
- * in the reduced set.
- * @@TIP: there should be a std::algo for this
- for (size_t i=0, n=pts.size(); i<n; ++i)
- if ( !PointLocation::isInRing(*(pts[i]), polyPts) )
- reducedSet.insert(pts[i]);
- inputPts.assign(reducedSet.begin(), reducedSet.end());
- if ( inputPts.size() < 3 ) padArray3(inputPts);
+ Coordinate::ConstVect polyPts;
+ if(! computeOctRing(pts, polyPts)) {
+ // unable to compute interior polygon for some reason
+ return;
+ // add points defining polygon
+ Coordinate::ConstSet reducedSet;
+ reducedSet.insert(polyPts.begin(), polyPts.end());
+ * Add all unique points not in the interior poly.
+ * CGAlgorithms.isPointInRing is not defined for points
+ * actually on the ring, but this doesn't matter since
+ * the points of the interior polygon are forced to be
+ * in the reduced set.
+ * @@TIP: there should be a std::algo for this
+ for(size_t i = 0, n = pts.size(); i < n; ++i) {
+ if(!PointLocation::isInRing(*(pts[i]), polyPts)) {
+ reducedSet.insert(pts[i]);
+ inputPts.assign(reducedSet.begin(), reducedSet.end());
+ if(inputPts.size() < 3) {
+ padArray3(inputPts);
/* private */
void
-ConvexHull::padArray3(geom::Coordinate::ConstVect &pts)
+ConvexHull::padArray3(geom::Coordinate::ConstVect& pts)
- for (size_t i = pts.size(); i < 3; ++i) {
- pts.push_back(pts[0]);
+ for(size_t i = pts.size(); i < 3; ++i) {
+ pts.push_back(pts[0]);
Geometry*
ConvexHull::getConvexHull()
- size_t nInputPts=inputPts.size();
- if (nInputPts==0) // Return an empty geometry
- return geomFactory->createEmptyGeometry();
- if (nInputPts==1) // Return a Point
- // Copy the Coordinate from the ConstVect
- return geomFactory->createPoint(*(inputPts[0]));
- if (nInputPts==2) // Return a LineString
- // Copy all Coordinates from the ConstVect
- CoordinateSequence *cs = toCoordinateSequence(inputPts);
- return geomFactory->createLineString(cs);
- // use heuristic to reduce points, if large
- if (nInputPts > 50 )
- reduce(inputPts);
+ size_t nInputPts = inputPts.size();
+ if(nInputPts == 0) { // Return an empty geometry
+ return geomFactory->createEmptyGeometry();
+ if(nInputPts == 1) { // Return a Point
+ // Copy the Coordinate from the ConstVect
+ return geomFactory->createPoint(*(inputPts[0]));
+ if(nInputPts == 2) { // Return a LineString
+ // Copy all Coordinates from the ConstVect
+ CoordinateSequence* cs = toCoordinateSequence(inputPts);
+ return geomFactory->createLineString(cs);
+ // use heuristic to reduce points, if large
+ if(nInputPts > 50) {
+ reduce(inputPts);
GEOS_CHECK_FOR_INTERRUPTS();
- // sort points for Graham scan.
- preSort(inputPts);
+ // sort points for Graham scan.
+ preSort(inputPts);
- // Use Graham scan to find convex hull.
- Coordinate::ConstVect cHS;
- grahamScan(inputPts, cHS);
+ // Use Graham scan to find convex hull.
+ Coordinate::ConstVect cHS;
+ grahamScan(inputPts, cHS);
- return lineOrPolygon(cHS);
+ return lineOrPolygon(cHS);
/* private */
void
-ConvexHull::preSort(Coordinate::ConstVect &pts)
+ConvexHull::preSort(Coordinate::ConstVect& pts)
- // find the lowest point in the set. If two or more points have
- // the same minimum y coordinate choose the one with the minimum x.
- // This focal point is put in array location pts[0].
- for(size_t i=1, n=pts.size(); i<n; ++i)
- const Coordinate *p0=pts[0]; // this will change
- const Coordinate *pi=pts[i];
- if ( (pi->y<p0->y) || ((pi->y==p0->y) && (pi->x<p0->x)) )
- const Coordinate *t=p0;
- pts[0]=pi;
- pts[i]=t;
- // sort the points radially around the focal point.
+ // find the lowest point in the set. If two or more points have
+ // the same minimum y coordinate choose the one with the minimum x.
+ // This focal point is put in array location pts[0].
+ for(size_t i = 1, n = pts.size(); i < n; ++i) {
+ const Coordinate* p0 = pts[0]; // this will change
+ const Coordinate* pi = pts[i];
+ if((pi->y < p0->y) || ((pi->y == p0->y) && (pi->x < p0->x))) {
+ const Coordinate* t = p0;
+ pts[0] = pi;
+ pts[i] = t;
+ // sort the points radially around the focal point.
std::sort(pts.begin(), pts.end(), RadiallyLessThen(pts[0]));
/*private*/
void
-ConvexHull::grahamScan(const Coordinate::ConstVect &c,
- Coordinate::ConstVect &ps)
+ConvexHull::grahamScan(const Coordinate::ConstVect& c,
+ Coordinate::ConstVect& ps)
- ps.push_back(c[0]);
- ps.push_back(c[1]);
- ps.push_back(c[2]);
- for(size_t i=3, n=c.size(); i<n; ++i)
- const Coordinate *p = ps.back(); ps.pop_back();
- while (!ps.empty() &&
- Orientation::index(
- *(ps.back()), *p, *(c[i])) > 0)
- p = ps.back(); ps.pop_back();
- ps.push_back(p);
- ps.push_back(c[i]);
+ ps.push_back(c[0]);
+ ps.push_back(c[1]);
+ ps.push_back(c[2]);
+ for(size_t i = 3, n = c.size(); i < n; ++i) {
+ const Coordinate* p = ps.back();
+ ps.pop_back();
+ while(!ps.empty() &&
+ Orientation::index(
+ *(ps.back()), *p, *(c[i])) > 0) {
+ p = ps.back();
+ ps.pop_back();
+ ps.push_back(p);
+ ps.push_back(c[i]);
/*private*/
bool
-ConvexHull::isBetween(const Coordinate &c1, const Coordinate &c2, const Coordinate &c3)
+ConvexHull::isBetween(const Coordinate& c1, const Coordinate& c2, const Coordinate& c3)
- if (Orientation::index(c1, c2, c3)!=0) {
- return false;
- if (c1.x!=c3.x) {
- if (c1.x<=c2.x && c2.x<=c3.x) {
- return true;
- if (c3.x<=c2.x && c2.x<=c1.x) {
- return true;
- if (c1.y!=c3.y) {
- if (c1.y<=c2.y && c2.y<=c3.y) {
- return true;
- if (c3.y<=c2.y && c2.y<=c1.y) {
- return true;
- return false;
+ if(Orientation::index(c1, c2, c3) != 0) {
+ return false;
+ if(c1.x != c3.x) {
+ if(c1.x <= c2.x && c2.x <= c3.x) {
+ return true;
+ if(c3.x <= c2.x && c2.x <= c1.x) {
+ return true;
+ if(c1.y != c3.y) {
+ if(c1.y <= c2.y && c2.y <= c3.y) {
+ return true;
+ if(c3.y <= c2.y && c2.y <= c1.y) {
+ return true;
+ return false;
/* private */
Geometry*
-ConvexHull::lineOrPolygon(const Coordinate::ConstVect &input)
+ConvexHull::lineOrPolygon(const Coordinate::ConstVect& input)
- Coordinate::ConstVect cleaned;
- cleanRing(input, cleaned);
- if (cleaned.size()==3) { // shouldn't this be 2 ??
- cleaned.resize(2);
- CoordinateSequence *cl1=toCoordinateSequence(cleaned);
- LineString *ret = geomFactory->createLineString(cl1);
- return ret;
- CoordinateSequence *cl2=toCoordinateSequence(cleaned);
- LinearRing *linearRing=geomFactory->createLinearRing(cl2);
- return geomFactory->createPolygon(linearRing,nullptr);
+ Coordinate::ConstVect cleaned;
+ cleanRing(input, cleaned);
+ if(cleaned.size() == 3) { // shouldn't this be 2 ??
+ cleaned.resize(2);
+ CoordinateSequence* cl1 = toCoordinateSequence(cleaned);
+ LineString* ret = geomFactory->createLineString(cl1);
+ return ret;
+ CoordinateSequence* cl2 = toCoordinateSequence(cleaned);
+ LinearRing* linearRing = geomFactory->createLinearRing(cl2);
+ return geomFactory->createPolygon(linearRing, nullptr);
/*private*/
void
-ConvexHull::cleanRing(const Coordinate::ConstVect &original,
- Coordinate::ConstVect &cleaned)
+ConvexHull::cleanRing(const Coordinate::ConstVect& original,
+ Coordinate::ConstVect& cleaned)
- size_t npts=original.size();
+ size_t npts = original.size();
- const Coordinate *last = original[npts-1];
+ const Coordinate* last = original[npts - 1];
- //util::Assert::equals(*(original[0]), *last);
- assert(last);
- assert(original[0]->equals2D(*last));
+ //util::Assert::equals(*(original[0]), *last);
+ assert(last);
+ assert(original[0]->equals2D(*last));
- const Coordinate *prev = nullptr;
- for (size_t i=0; i<npts-1; ++i)
- const Coordinate *curr = original[i];
- const Coordinate *next = original[i+1];
+ const Coordinate* prev = nullptr;
+ for(size_t i = 0; i < npts - 1; ++i) {
+ const Coordinate* curr = original[i];
+ const Coordinate* next = original[i + 1];
- // skip consecutive equal coordinates
- if (curr->equals2D(*next)) continue;
+ // skip consecutive equal coordinates
+ if(curr->equals2D(*next)) {
+ continue;
- if ( prev != nullptr && isBetween(*prev, *curr, *next) )
- continue;
+ if(prev != nullptr && isBetween(*prev, *curr, *next)) {
+ continue;
- cleaned.push_back(curr);
- prev=curr;
+ cleaned.push_back(curr);
+ prev = curr;
- cleaned.push_back(last);
+ cleaned.push_back(last);
diff --git a/src/algorithm/Distance.cpp b/src/algorithm/Distance.cpp
index f1b4bef..f55a3df 100644
--- a/src/algorithm/Distance.cpp
+++ b/src/algorithm/Distance.cpp
@@ -29,11 +29,11 @@ namespace algorithm { // geos.algorithm
/*public static*/
double
Distance::pointToSegment(const geom::Coordinate& p,
- const geom::Coordinate& A,
- const geom::Coordinate& B)
+ const geom::Coordinate& A,
+ const geom::Coordinate& B)
/* if start==end, then use pt distance */
- if (A == B) {
+ if(A == B) {
return p.distance(A);
@@ -52,11 +52,15 @@ Distance::pointToSegment(const geom::Coordinate& p,
0<r<1 P is interior to AB
- double r = ((p.x-A.x)*(B.x-A.x)+(p.y-A.y)*(B.y-A.y))/
- ((B.x-A.x)*(B.x-A.x)+(B.y-A.y)*(B.y-A.y));
+ double r = ((p.x - A.x) * (B.x - A.x) + (p.y - A.y) * (B.y - A.y)) /
+ ((B.x - A.x) * (B.x - A.x) + (B.y - A.y) * (B.y - A.y));
- if (r <= 0.0) return p.distance(A);
- if (r >= 1.0) return p.distance(B);
+ if(r <= 0.0) {
+ return p.distance(A);
+ if(r >= 1.0) {
+ return p.distance(B);
(2)
@@ -67,16 +71,16 @@ Distance::pointToSegment(const geom::Coordinate& p,
Then the distance from C to P = |s|*L.
- double s=((A.y-p.y)*(B.x-A.x)-(A.x-p.x)*(B.y-A.y))/
+ double s = ((A.y - p.y) * (B.x - A.x) - (A.x - p.x) * (B.y - A.y)) /
- return fabs(s)*sqrt(((B.x-A.x)*(B.x-A.x)+(B.y-A.y)*(B.y-A.y)));
+ return fabs(s) * sqrt(((B.x - A.x) * (B.x - A.x) + (B.y - A.y) * (B.y - A.y)));
/*public static*/
double
Distance::pointToLinePerpendicular(const geom::Coordinate& p,
- const geom::Coordinate& A, const geom::Coordinate& B)
+ const geom::Coordinate& A, const geom::Coordinate& B)
use comp.graphics.algorithms method
@@ -89,21 +93,25 @@ Distance::pointToLinePerpendicular(const geom::Coordinate& p,
- double s = ((A.y - p.y) *(B.x - A.x) - (A.x - p.x)*(B.y - A.y))
- return fabs(s)*sqrt(((B.x - A.x) * (B.x - A.x) + (B.y - A.y) * (B.y - A.y)));
/*public static*/
double
Distance::segmentToSegment(const geom::Coordinate& A,
- const geom::Coordinate& B, const geom::Coordinate& C,
- const geom::Coordinate& D)
+ const geom::Coordinate& B, const geom::Coordinate& C,
+ const geom::Coordinate& D)
/* Check for zero-length segments */
- if (A == B) return pointToSegment(A,C,D);
- if (C == D) return pointToSegment(D,A,B);
+ if(A == B) {
+ return pointToSegment(A, C, D);
+ if(C == D) {
+ return pointToSegment(D, A, B);
/* AB and CD are line segments */
@@ -134,25 +142,25 @@ Distance::segmentToSegment(const geom::Coordinate& A,
If the numerator in eqn 1 is also zero, AB & CD are collinear.
- double r_top=(A.y-C.y)*(D.x-C.x)-(A.x-C.x)*(D.y-C.y);
- double r_bot=(B.x-A.x)*(D.y-C.y)-(B.y-A.y)*(D.x-C.x);
- double s_top=(A.y-C.y)*(B.x-A.x)-(A.x-C.x)*(B.y-A.y);
- double s_bot=(B.x-A.x)*(D.y-C.y)-(B.y-A.y)*(D.x-C.x);
+ double r_top = (A.y - C.y) * (D.x - C.x) - (A.x - C.x) * (D.y - C.y);
+ double r_bot = (B.x - A.x) * (D.y - C.y) - (B.y - A.y) * (D.x - C.x);
+ double s_top = (A.y - C.y) * (B.x - A.x) - (A.x - C.x) * (B.y - A.y);
+ double s_bot = (B.x - A.x) * (D.y - C.y) - (B.y - A.y) * (D.x - C.x);
- if ((r_bot==0) || (s_bot==0)) {
- return std::min(pointToSegment(A,C,D),
- std::min(pointToSegment(B,C,D),
- std::min(pointToSegment(C,A,B), pointToSegment(D,A,B))));
+ if((r_bot == 0) || (s_bot == 0)) {
+ return std::min(pointToSegment(A, C, D),
+ std::min(pointToSegment(B, C, D),
+ std::min(pointToSegment(C, A, B), pointToSegment(D, A, B))));
- double s=s_top/s_bot;
- double r=r_top/r_bot;
+ double s = s_top / s_bot;
+ double r = r_top / r_bot;
- if ((r<0) || (r>1) || (s<0) || (s>1)) {
+ if((r < 0) || (r > 1) || (s < 0) || (s > 1)) {
/* no intersection */
return 0.0; /* intersection exists */
@@ -161,21 +169,21 @@ Distance::segmentToSegment(const geom::Coordinate& A,
/*public static*/
double
Distance::pointToSegmentString(const geom::Coordinate& p,
- const geom::CoordinateSequence *seq)
+ const geom::CoordinateSequence* seq)
- if (seq->size() == 0) {
+ if(seq->size() == 0) {
"Line array must contain at least one vertex");
/* this handles the case of length = 1 */
double minDistance = p.distance(seq->getAt(0));
- for (std::size_t i = 0; i < seq->size()-1; i++) {
+ for(std::size_t i = 0; i < seq->size() - 1; i++) {
const geom::Coordinate& si = seq->getAt(i);
- const geom::Coordinate& si1 = seq->getAt(i+1);
+ const geom::Coordinate& si1 = seq->getAt(i + 1);
double dist = pointToSegment(p, si, si1);
- if (dist < minDistance) {
+ if(dist < minDistance) {
minDistance = dist;
diff --git a/src/algorithm/HCoordinate.cpp b/src/algorithm/HCoordinate.cpp
index 6fc8e82..7b9f86a 100644
--- a/src/algorithm/HCoordinate.cpp
+++ b/src/algorithm/HCoordinate.cpp
@@ -40,105 +40,104 @@ namespace algorithm { // geos.algorithm
/*public static*/
void
-HCoordinate::intersection(const Coordinate &p1, const Coordinate &p2,
- const Coordinate &q1, const Coordinate &q2, Coordinate &ret)
+HCoordinate::intersection(const Coordinate& p1, const Coordinate& p2,
+ const Coordinate& q1, const Coordinate& q2, Coordinate& ret)
#if GEOS_DEBUG
- cerr << __FUNCTION__ << ":" << endl
- << setprecision(20)
- << " p1: " << p1 << endl
- << " p2: " << p2 << endl
- << " q1: " << q1 << endl
- << " q2: " << q2 << endl;
+ cerr << __FUNCTION__ << ":" << endl
+ << setprecision(20)
+ << " p1: " << p1 << endl
+ << " p2: " << p2 << endl
+ << " q1: " << q1 << endl
+ << " q2: " << q2 << endl;
#endif
- // unrolled computation
+ // unrolled computation
- double px = p1.y - p2.y;
- double py = p2.x - p1.x;
- double pw = p1.x * p2.y - p2.x * p1.y;
+ double px = p1.y - p2.y;
+ double py = p2.x - p1.x;
+ double pw = p1.x * p2.y - p2.x * p1.y;
- double qx = q1.y - q2.y;
- double qy = q2.x - q1.x;
- double qw = q1.x * q2.y - q2.x * q1.y;
+ double qx = q1.y - q2.y;
+ double qy = q2.x - q1.x;
+ double qw = q1.x * q2.y - q2.x * q1.y;
- double x = py * qw - qy * pw;
- double y = qx * pw - px * qw;
- double w = px * qy - qx * py;
+ double x = py * qw - qy * pw;
+ double y = qx * pw - px * qw;
+ double w = px * qy - qx * py;
- double xInt = x/w;
- double yInt = y/w;
+ double xInt = x / w;
+ double yInt = y / w;
- if ( (!std::isfinite(xInt)) || (!std::isfinite(yInt)) )
- throw NotRepresentableException();
+ if((!std::isfinite(xInt)) || (!std::isfinite(yInt))) {
+ throw NotRepresentableException();
- ret = Coordinate(xInt, yInt);
+ ret = Coordinate(xInt, yInt);
/*public*/
HCoordinate::HCoordinate()
- x(0.0),
- y(0.0),
- w(1.0)
+ x(0.0),
+ y(0.0),
+ w(1.0)
/*public*/
HCoordinate::HCoordinate(double _x, double _y, double _w)
- x(_x),
- y(_y),
- w(_w)
+ x(_x),
+ y(_y),
+ w(_w)
/*public*/
HCoordinate::HCoordinate(const Coordinate& p)
- x(p.x),
- y(p.y),
- w(1.0)
+ x(p.x),
+ y(p.y),
+ w(1.0)
/*public*/
HCoordinate::HCoordinate(const Coordinate& p1, const Coordinate& p2)
- // optimization when it is known that w = 1
- x ( p1.y - p2.y ),
- y ( p2.x - p1.x ),
- w ( p1.x * p2.y - p2.x * p1.y )
+ // optimization when it is known that w = 1
+ x(p1.y - p2.y),
+ y(p2.x - p1.x),
+ w(p1.x * p2.y - p2.x * p1.y)
/*public*/
HCoordinate::HCoordinate(const Coordinate& p1, const Coordinate& p2,
- const Coordinate& q1, const Coordinate& q2)
+ const Coordinate& q1, const Coordinate& q2)
- x = py * qw - qy * pw;
- y = qx * pw - px * qw;
- w = px * qy - qx * py;
+ x = py * qw - qy * pw;
+ y = qx * pw - px * qw;
+ w = px * qy - qx * py;
/*public*/
-HCoordinate::HCoordinate(const HCoordinate &p1, const HCoordinate &p2)
- x( p1.y*p2.w - p2.y*p1.w ),
- y( p2.x*p1.w - p1.x*p2.w ),
- w( p1.x*p2.y - p2.x*p1.y )
+HCoordinate::HCoordinate(const HCoordinate& p1, const HCoordinate& p2)
+ x(p1.y * p2.w - p2.y * p1.w),
+ y(p2.x * p1.w - p1.x * p2.w),
@@ -146,35 +145,36 @@ HCoordinate::HCoordinate(const HCoordinate &p1, const HCoordinate &p2)
double
HCoordinate::getX() const
- double a = x/w;
- if ( !std::isfinite(a) ) {
- return a;
+ double a = x / w;
+ if(!std::isfinite(a)) {
+ return a;
/*public*/
double
HCoordinate::getY() const
- double a = y/w;
- return a;
+ double a = y / w;
+ return a;
/*public*/
void
-HCoordinate::getCoordinate(Coordinate &ret) const
+HCoordinate::getCoordinate(Coordinate& ret) const
- ret = Coordinate(static_cast<double>(getX()), static_cast<double>(getY()));
+ ret = Coordinate(static_cast<double>(getX()), static_cast<double>(getY()));
-std::ostream& operator<< (std::ostream& o, const HCoordinate& c)
+std::ostream&
+operator<< (std::ostream& o, const HCoordinate& c)
- return o << "(" << c.x << ", "
- << c.y << ") [w: " << c.w << "]";
+ return o << "(" << c.x << ", "
+ << c.y << ") [w: " << c.w << "]";
diff --git a/src/algorithm/InteriorPointArea.cpp b/src/algorithm/InteriorPointArea.cpp
index f1938d8..5eaa674 100644
--- a/src/algorithm/InteriorPointArea.cpp
+++ b/src/algorithm/InteriorPointArea.cpp
@@ -41,87 +41,97 @@ namespace algorithm { // geos.algorithm
// file-statics
namespace {
- double avg(double a, double b){return (a+b)/2.0;}
- * Finds a safe bisector Y ordinate
- * by projecting to the Y axis
- * and finding the Y-ordinate interval
- * which contains the centre of the Y extent.
- * The centre of this interval is returned as the bisector Y-ordinate.
- * @author mdavis
- class SafeBisectorFinder
- public:
- static double getBisectorY(const Polygon& poly)
- SafeBisectorFinder finder(poly);
- return finder.getBisectorY();
- SafeBisectorFinder(const Polygon& nPoly)
- : poly(nPoly)
+double
+avg(double a, double b)
+ return (a + b) / 2.0;
+ * Finds a safe bisector Y ordinate
+ * by projecting to the Y axis
+ * and finding the Y-ordinate interval
+ * which contains the centre of the Y extent.
+ * The centre of this interval is returned as the bisector Y-ordinate.
+ * @author mdavis
+class SafeBisectorFinder {
+public:
+ static double
+ getBisectorY(const Polygon& poly)
+ SafeBisectorFinder finder(poly);
+ return finder.getBisectorY();
+ SafeBisectorFinder(const Polygon& nPoly)
+ : poly(nPoly)
+ // initialize using extremal values
+ hiY = poly.getEnvelopeInternal()->getMaxY();
+ loY = poly.getEnvelopeInternal()->getMinY();
+ centreY = avg(loY, hiY);
+ double
+ getBisectorY()
- // initialize using extremal values
- hiY = poly.getEnvelopeInternal()->getMaxY();
- loY = poly.getEnvelopeInternal()->getMinY();
- centreY = avg(loY, hiY);
- double getBisectorY()
- process(*poly.getExteriorRing());
- process(*poly.getInteriorRingN(i));
- double bisectY = avg(hiY, loY);
- return bisectY;
- private:
- const Polygon& poly;
- double centreY;
- double hiY;
- double loY;
- void process(const LineString& line) {
- const CoordinateSequence* seq = line.getCoordinatesRO();
- for (std::size_t i = 0, s = seq->size(); i < s; i++) {
- double y = seq->getY(i);
- updateInterval(y);
- void updateInterval(double y) {
- if (y <= centreY) {
- if (y > loY)
- loY = y;
- else if (y > centreY) {
- if (y < hiY) {
- hiY = y;
+ process(*poly.getExteriorRing());
+ process(*poly.getInteriorRingN(i));
+ double bisectY = avg(hiY, loY);
+ return bisectY;
+private:
+ const Polygon& poly;
+ double centreY;
+ double hiY;
+ double loY;
+ void
+ process(const LineString& line)
+ const CoordinateSequence* seq = line.getCoordinatesRO();
+ for(std::size_t i = 0, s = seq->size(); i < s; i++) {
+ double y = seq->getY(i);
+ updateInterval(y);
+ void
+ updateInterval(double y)
+ if(y <= centreY) {
+ if(y > loY) {
+ loY = y;
+ else if(y > centreY) {
+ if(y < hiY) {
+ hiY = y;
SafeBisectorFinder(SafeBisectorFinder const&); /*= delete*/
SafeBisectorFinder& operator=(SafeBisectorFinder const&); /*= delete*/
/*public*/
-InteriorPointArea::InteriorPointArea(const Geometry *g)
+InteriorPointArea::InteriorPointArea(const Geometry* g)
- foundInterior=false;
- maxWidth=0.0;
- factory=g->getFactory();
- add(g);
+ foundInterior = false;
+ maxWidth = 0.0;
+ factory = g->getFactory();
+ add(g);
/*public*/
@@ -133,115 +143,119 @@ InteriorPointArea::~InteriorPointArea()
bool
InteriorPointArea::getInteriorPoint(Coordinate& ret) const
- if ( ! foundInterior ) return false;
+ if(! foundInterior) {
+ return false;
- ret=interiorPoint;
- return true;
+ ret = interiorPoint;
+ return true;
/*public*/
void
-InteriorPointArea::add(const Geometry *geom)
+InteriorPointArea::add(const Geometry* geom)
- const Polygon *poly = dynamic_cast<const Polygon*>(geom);
- if ( poly ) {
- addPolygon(geom);
- return;
- const GeometryCollection *gc = dynamic_cast<const GeometryCollection*>(geom);
- if ( gc )
- for(std::size_t i=0, n=gc->getNumGeometries(); i<n; i++) {
- add(gc->getGeometryN(i));
+ const Polygon* poly = dynamic_cast<const Polygon*>(geom);
+ if(poly) {
+ addPolygon(geom);
+ return;
+ const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(geom);
+ if(gc) {
+ for(std::size_t i = 0, n = gc->getNumGeometries(); i < n; i++) {
+ add(gc->getGeometryN(i));
/*private*/
void
-InteriorPointArea::addPolygon(const Geometry *geometry)
+InteriorPointArea::addPolygon(const Geometry* geometry)
- if (geometry->isEmpty()) return;
- Coordinate intPt;
- double width;
- unique_ptr<LineString> bisector ( horizontalBisector(geometry) );
- if ( bisector->getLength() == 0.0 ) {
- width = 0;
- intPt = bisector->getCoordinateN(0);
- else {
- unique_ptr<Geometry> intersections ( bisector->intersection(geometry) );
- const Geometry *widestIntersection = widestGeometry(intersections.get());
- const Envelope *env = widestIntersection->getEnvelopeInternal();
- width=env->getWidth();
- env->centre(intPt);
- if (!foundInterior || width>maxWidth) {
- interiorPoint = intPt;
- maxWidth = width;
- foundInterior=true;
+ if(geometry->isEmpty()) {
+ return;
+ Coordinate intPt;
+ double width;
+ unique_ptr<LineString> bisector(horizontalBisector(geometry));
+ if(bisector->getLength() == 0.0) {
+ width = 0;
+ intPt = bisector->getCoordinateN(0);
+ else {
+ unique_ptr<Geometry> intersections(bisector->intersection(geometry));
+ const Geometry* widestIntersection = widestGeometry(intersections.get());
+ const Envelope* env = widestIntersection->getEnvelopeInternal();
+ width = env->getWidth();
+ env->centre(intPt);
+ if(!foundInterior || width > maxWidth) {
+ interiorPoint = intPt;
+ maxWidth = width;
+ foundInterior = true;
//@return if geometry is a collection, the widest sub-geometry; otherwise,
//the geometry itself
const Geometry*
-InteriorPointArea::widestGeometry(const Geometry *geometry)
+InteriorPointArea::widestGeometry(const Geometry* geometry)
- const GeometryCollection *gc = dynamic_cast<const GeometryCollection*>(geometry);
- if ( gc ) {
- return widestGeometry(gc);
- } else {
- return geometry;
+ const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(geometry);
+ if(gc) {
+ return widestGeometry(gc);
+ else {
+ return geometry;
const Geometry*
-InteriorPointArea::widestGeometry(const GeometryCollection* gc) {
- if (gc->isEmpty()) {
- return gc;
- const Geometry* p_widestGeometry=gc->getGeometryN(0);
- // scan remaining geom components to see if any are wider
- for(std::size_t i=1, n=gc->getNumGeometries(); i<n; i++) // start at 1
- const Envelope *env1(gc->getGeometryN(i)->getEnvelopeInternal());
- const Envelope *env2(p_widestGeometry->getEnvelopeInternal());
- if (env1->getWidth()>env2->getWidth()) {
- p_widestGeometry=gc->getGeometryN(i);
- return p_widestGeometry;
+InteriorPointArea::widestGeometry(const GeometryCollection* gc)
+ if(gc->isEmpty()) {
+ return gc;
+ const Geometry* p_widestGeometry = gc->getGeometryN(0);
+ // scan remaining geom components to see if any are wider
+ for(std::size_t i = 1, n = gc->getNumGeometries(); i < n; i++) { // start at 1
+ const Envelope* env1(gc->getGeometryN(i)->getEnvelopeInternal());
+ const Envelope* env2(p_widestGeometry->getEnvelopeInternal());
+ if(env1->getWidth() > env2->getWidth()) {
+ p_widestGeometry = gc->getGeometryN(i);
+ return p_widestGeometry;
/* private */
LineString*
-InteriorPointArea::horizontalBisector(const Geometry *geometry)
+InteriorPointArea::horizontalBisector(const Geometry* geometry)
- const Envelope *envelope=geometry->getEnvelopeInternal();
- * Original algorithm. Fails when geometry contains a horizontal
- * segment at the Y midpoint.
- // Assert: for areas, minx <> maxx
- //double avgY=avg(envelope->getMinY(),envelope->getMaxY());
- double bisectY = SafeBisectorFinder::getBisectorY(*dynamic_cast<const Polygon *>(geometry));
- vector<Coordinate>*cv=new vector<Coordinate>(2);
- (*cv)[0].x = envelope->getMinX();
- (*cv)[0].y = bisectY;
- (*cv)[1].x = envelope->getMaxX();
- (*cv)[1].y = bisectY;
- CoordinateSequence *cl = factory->getCoordinateSequenceFactory()->create(cv);
- LineString *ret = factory->createLineString(cl);
- return ret;
+ const Envelope* envelope = geometry->getEnvelopeInternal();
+ * Original algorithm. Fails when geometry contains a horizontal
+ * segment at the Y midpoint.
+ // Assert: for areas, minx <> maxx
+ //double avgY=avg(envelope->getMinY(),envelope->getMaxY());
+ double bisectY = SafeBisectorFinder::getBisectorY(*dynamic_cast<const Polygon*>(geometry));
+ vector<Coordinate>* cv = new vector<Coordinate>(2);
+ (*cv)[0].x = envelope->getMinX();
+ (*cv)[0].y = bisectY;
+ (*cv)[1].x = envelope->getMaxX();
+ (*cv)[1].y = bisectY;
+ CoordinateSequence* cl = factory->getCoordinateSequenceFactory()->create(cv);
+ LineString* ret = factory->createLineString(cl);
+ return ret;
diff --git a/src/algorithm/InteriorPointLine.cpp b/src/algorithm/InteriorPointLine.cpp
index c199503..4de12ad 100644
--- a/src/algorithm/InteriorPointLine.cpp
+++ b/src/algorithm/InteriorPointLine.cpp
@@ -38,18 +38,19 @@ using namespace geos::geom;
namespace geos {
-InteriorPointLine::InteriorPointLine(const Geometry *g)
+InteriorPointLine::InteriorPointLine(const Geometry* g)
- minDistance=DoubleMax;
- hasInterior=false;
- if ( g->getCentroid(centroid) )
+ minDistance = DoubleMax;
+ hasInterior = false;
+ if(g->getCentroid(centroid)) {
#if GEOS_DEBUG
- std::cerr << "Centroid: " << centroid << std::endl;
+ std::cerr << "Centroid: " << centroid << std::endl;
#endif
- addInterior(g);
- if (!hasInterior) addEndpoints(g);
+ addInterior(g);
+ if(!hasInterior) {
+ addEndpoints(g);
InteriorPointLine::~InteriorPointLine()
@@ -64,31 +65,29 @@ InteriorPointLine::~InteriorPointLine()
* @param geom the geometry to add
void
-InteriorPointLine::addInterior(const Geometry *geom)
+InteriorPointLine::addInterior(const Geometry* geom)
- const LineString *ls = dynamic_cast<const LineString*>(geom);
- if ( ls ) {
- addInterior(ls->getCoordinatesRO());
- return;
- if ( gc )
- addInterior(gc->getGeometryN(i));
+ const LineString* ls = dynamic_cast<const LineString*>(geom);
+ if(ls) {
+ addInterior(ls->getCoordinatesRO());
+ return;
+ if(gc) {
+ addInterior(gc->getGeometryN(i));
void
-InteriorPointLine::addInterior(const CoordinateSequence *pts)
+InteriorPointLine::addInterior(const CoordinateSequence* pts)
- const std::size_t n=pts->getSize()-1;
- for(std::size_t i=1; i<n; ++i)
- add(pts->getAt(i));
+ const std::size_t n = pts->getSize() - 1;
+ for(std::size_t i = 1; i < n; ++i) {
+ add(pts->getAt(i));
/* private
@@ -99,31 +98,32 @@ InteriorPointLine::addInterior(const CoordinateSequence *pts)
void
-InteriorPointLine::addEndpoints(const Geometry *geom)
+InteriorPointLine::addEndpoints(const Geometry* geom)
- if ( ls ) {
- addEndpoints(ls->getCoordinatesRO());
- return;
- if ( gc )
- addEndpoints(gc->getGeometryN(i));
+ if(ls) {
+ addEndpoints(ls->getCoordinatesRO());
+ return;
+ if(gc) {
+ addEndpoints(gc->getGeometryN(i));
void
-InteriorPointLine::addEndpoints(const CoordinateSequence *pts)
+InteriorPointLine::addEndpoints(const CoordinateSequence* pts)
- size_t npts = pts->size();
- if ( npts ) {
- add(pts->getAt(0));
- if ( npts > 1 ) add(pts->getAt(npts-1));
+ size_t npts = pts->size();
+ if(npts) {
+ add(pts->getAt(0));
+ if(npts > 1) {
+ add(pts->getAt(npts - 1));
/*private*/
@@ -131,26 +131,28 @@ void
InteriorPointLine::add(const Coordinate& point)
- double dist=point.distance(centroid);
+ double dist = point.distance(centroid);
#if GEOS_DEBUG
- std::cerr << "point " << point << " dist " << dist << ", minDistance " << minDistance << std::endl;
+ std::cerr << "point " << point << " dist " << dist << ", minDistance " << minDistance << std::endl;
#endif
- if (!hasInterior || dist<minDistance) {
- interiorPoint=point;
+ if(!hasInterior || dist < minDistance) {
+ interiorPoint = point;
#if GEOS_DEBUG
- std::cerr << " is new InteriorPoint" << std::endl;
+ std::cerr << " is new InteriorPoint" << std::endl;
#endif
- minDistance=dist;
- hasInterior=true;
+ minDistance = dist;
+ hasInterior = true;
bool
InteriorPointLine::getInteriorPoint(Coordinate& ret) const
- if ( ! hasInterior ) return false;
- return true;
+ if(! hasInterior) {
+ return false;
+ return true;
diff --git a/src/algorithm/InteriorPointPoint.cpp b/src/algorithm/InteriorPointPoint.cpp
index 22c8c25..7f953ae 100644
--- a/src/algorithm/InteriorPointPoint.cpp
+++ b/src/algorithm/InteriorPointPoint.cpp
@@ -31,55 +31,57 @@ namespace geos {
/*public*/
-InteriorPointPoint::InteriorPointPoint(const Geometry *g)
+InteriorPointPoint::InteriorPointPoint(const Geometry* g)
- if ( ! g->getCentroid(centroid) ) {
- } else {
- hasInterior=true;
- add(g);
+ if(! g->getCentroid(centroid)) {
+ else {
+ add(g);
/*private*/
void
-InteriorPointPoint::add(const Geometry *geom)
+InteriorPointPoint::add(const Geometry* geom)
- const Point *po = dynamic_cast<const Point*>(geom);
- if ( po ) {
- add(po->getCoordinate());
- return;
+ const Point* po = dynamic_cast<const Point*>(geom);
+ if(po) {
+ add(po->getCoordinate());
+ return;
- if ( gc )
+ if(gc) {
/*private*/
void
-InteriorPointPoint::add(const Coordinate *point)
+InteriorPointPoint::add(const Coordinate* point)
- assert ( point ); // we wouldn't been called if this was an empty geom
- double dist=point->distance(centroid);
- if (dist<minDistance) {
- interiorPoint=*point;
- minDistance=dist;
+ assert(point); // we wouldn't been called if this was an empty geom
+ double dist = point->distance(centroid);
+ interiorPoint = *point;
/*public*/
bool
InteriorPointPoint::getInteriorPoint(Coordinate& ret) const
- return true;
+ return false;
+ return true;
diff --git a/src/algorithm/Length.cpp b/src/algorithm/Length.cpp
index 4d4ceb6..caf87e6 100644
--- a/src/algorithm/Length.cpp
+++ b/src/algorithm/Length.cpp
@@ -26,21 +26,22 @@ namespace algorithm { // geos.algorithm
/* public static */
double
-Length::ofLine(const geom::CoordinateSequence *pts)
+Length::ofLine(const geom::CoordinateSequence* pts)
// optimized for processing CoordinateSequences
size_t n = pts->size();
- if (n <= 1)
+ if(n <= 1) {
return 0.0;
double len = 0.0;
- const geom::Coordinate &p = pts->getAt(0);
+ const geom::Coordinate& p = pts->getAt(0);
double x0 = p.x;
double y0 = p.y;
- for (size_t i = 1; i < n; i++) {
- const geom::Coordinate &pi = pts->getAt(i);
+ for(size_t i = 1; i < n; i++) {
+ const geom::Coordinate& pi = pts->getAt(i);
double x1 = pi.x;
double y1 = pi.y;
double dx = x1 - x0;
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index f3b6cfb..2be486f 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -73,28 +73,29 @@ namespace { // anonymous
* @param q2 an endpoint of segment Q
* @return the nearest endpoint to the other segment
-Coordinate nearestEndpoint(const Coordinate& p1, const Coordinate& p2,
+Coordinate
+nearestEndpoint(const Coordinate& p1, const Coordinate& p2,
- Coordinate nearestPt = p1;
- double minDist = Distance::pointToSegment(p1, q1, q2);
- double dist = Distance::pointToSegment(p2, q1, q2);
- if (dist < minDist) {
- minDist = dist;
- nearestPt = p2;
- dist = Distance::pointToSegment(q1, p1, p2);
- minDist = dist;
- nearestPt = q1;
- dist = Distance::pointToSegment(q2, p1, p2);
- minDist = dist;
- nearestPt = q2;
- return nearestPt;
+ Coordinate nearestPt = p1;
+ double minDist = Distance::pointToSegment(p1, q1, q2);
+ double dist = Distance::pointToSegment(p2, q1, q2);
+ if(dist < minDist) {
+ minDist = dist;
+ nearestPt = p2;
+ dist = Distance::pointToSegment(q1, p1, p2);
+ minDist = dist;
+ nearestPt = q1;
+ dist = Distance::pointToSegment(q2, p1, p2);
+ minDist = dist;
+ nearestPt = q2;
+ return nearestPt;
@@ -102,687 +103,796 @@ Coordinate nearestEndpoint(const Coordinate& p1, const Coordinate& p2,
/*public static*/
double
-LineIntersector::computeEdgeDistance(const Coordinate& p,const Coordinate& p0,const Coordinate& p1)
+LineIntersector::computeEdgeDistance(const Coordinate& p, const Coordinate& p0, const Coordinate& p1)
- double dx=fabs(p1.x-p0.x);
- double dy=fabs(p1.y-p0.y);
- double dist=-1.0; // sentinel value
- if (p==p0) {
- dist=0.0;
- } else if (p==p1) {
- if (dx>dy)
- dist=dx;
- else
- dist=dy;
- } else {
- double pdx=fabs(p.x - p0.x);
- double pdy=fabs(p.y - p0.y);
- if (dx > dy)
- dist = pdx;
- else
- dist = pdy;
- // <FIX>
- // hack to ensure that non-endpoints always have a non-zero distance
- if (dist == 0.0 && !(p==p0)) {
- dist=std::max(pdx,pdy);
- assert(!(dist == 0.0 && !(p==p0))); // Bad distance calculation
- return dist;
+ double dx = fabs(p1.x - p0.x);
+ double dy = fabs(p1.y - p0.y);
+ double dist = -1.0; // sentinel value
+ if(p == p0) {
+ dist = 0.0;
+ else if(p == p1) {
+ if(dx > dy) {
+ dist = dx;
+ else {
+ dist = dy;
+ else {
+ double pdx = fabs(p.x - p0.x);
+ double pdy = fabs(p.y - p0.y);
+ if(dx > dy) {
+ dist = pdx;
+ else {
+ dist = pdy;
+ // <FIX>
+ // hack to ensure that non-endpoints always have a non-zero distance
+ if(dist == 0.0 && !(p == p0)) {
+ dist = std::max(pdx, pdy);
+ assert(!(dist == 0.0 && !(p == p0))); // Bad distance calculation
+ return dist;
/*public*/
void
-LineIntersector::computeIntersection(const Coordinate& p1,const Coordinate& p2,const Coordinate& p3,const Coordinate& p4)
+LineIntersector::computeIntersection(const Coordinate& p1, const Coordinate& p2, const Coordinate& p3,
+ const Coordinate& p4)
- inputLines[0][0]=&p1;
- inputLines[0][1]=&p2;
- inputLines[1][0]=&p3;
- inputLines[1][1]=&p4;
- result=computeIntersect(p1,p2,p3,p4);
- //numIntersects++;
+ inputLines[0][0] = &p1;
+ inputLines[0][1] = &p2;
+ inputLines[1][0] = &p3;
+ inputLines[1][1] = &p4;
+ result = computeIntersect(p1, p2, p3, p4);
+ //numIntersects++;
/*public*/
string
LineIntersector::toString() const
- string str=inputLines[0][0]->toString()+"_"
- +inputLines[0][1]->toString()+" "
- +inputLines[1][0]->toString()+"_"
- +inputLines[1][1]->toString()+" : ";
- if (isEndPoint()) {
- str+=" endpoint";
- if (isProperVar) {
- str+=" proper";
- if (isCollinear()) {
- str+=" collinear";
- return str;
+ string str = inputLines[0][0]->toString() + "_"
+ + inputLines[0][1]->toString() + " "
+ + inputLines[1][0]->toString() + "_"
+ + inputLines[1][1]->toString() + " : ";
+ if(isEndPoint()) {
+ str += " endpoint";
+ if(isProperVar) {
+ str += " proper";
+ if(isCollinear()) {
+ str += " collinear";
+ return str;
/*public static*/
bool
-LineIntersector::isSameSignAndNonZero(double a,double b)
+LineIntersector::isSameSignAndNonZero(double a, double b)
- if (a==0 || b==0) {
- return false;
- return (a<0 && b<0) || (a>0 && b>0);
+ if(a == 0 || b == 0) {
+ return false;
+ return (a < 0 && b < 0) || (a > 0 && b > 0);
/*private*/
void
-LineIntersector::computeIntLineIndex() {
- computeIntLineIndex(0);
- computeIntLineIndex(1);
+LineIntersector::computeIntLineIndex()
+ computeIntLineIndex(0);
+ computeIntLineIndex(1);
/*public*/
bool
LineIntersector::isIntersection(const Coordinate& pt) const
- for (size_t i=0; i < result; ++i) {
- if (intPt[i].equals2D(pt)) {
- return true;
- return false;
+ for(size_t i = 0; i < result; ++i) {
+ if(intPt[i].equals2D(pt)) {
+ return true;
+ return false;
/*public*/
const Coordinate&
-LineIntersector::getIntersectionAlongSegment(int segmentIndex,int intIndex)
+LineIntersector::getIntersectionAlongSegment(int segmentIndex, int intIndex)
- // lazily compute int line array
- computeIntLineIndex();
- return intPt[intLineIndex[segmentIndex][intIndex]];
+ // lazily compute int line array
+ computeIntLineIndex();
+ return intPt[intLineIndex[segmentIndex][intIndex]];
/*public*/
int
-LineIntersector::getIndexAlongSegment(int segmentIndex,int intIndex)
+LineIntersector::getIndexAlongSegment(int segmentIndex, int intIndex)
- return intLineIndex[segmentIndex][intIndex];
+ return intLineIndex[segmentIndex][intIndex];
/*private*/
void
LineIntersector::computeIntLineIndex(int segmentIndex)
- double dist0=getEdgeDistance(segmentIndex,0);
- double dist1=getEdgeDistance(segmentIndex,1);
- if (dist0>dist1) {
- intLineIndex[segmentIndex][0]=0;
- intLineIndex[segmentIndex][1]=1;
- } else {
- intLineIndex[segmentIndex][0]=1;
- intLineIndex[segmentIndex][1]=0;
+ double dist0 = getEdgeDistance(segmentIndex, 0);
+ double dist1 = getEdgeDistance(segmentIndex, 1);
+ if(dist0 > dist1) {
+ intLineIndex[segmentIndex][0] = 0;
+ intLineIndex[segmentIndex][1] = 1;
+ else {
+ intLineIndex[segmentIndex][0] = 1;
+ intLineIndex[segmentIndex][1] = 0;
/*public*/
double
-LineIntersector::getEdgeDistance(size_t segmentIndex,size_t intIndex) const
+LineIntersector::getEdgeDistance(size_t segmentIndex, size_t intIndex) const
- double dist=computeEdgeDistance(intPt[intIndex],
- *inputLines[segmentIndex][0],
- *inputLines[segmentIndex][1]);
- return dist;
+ double dist = computeEdgeDistance(intPt[intIndex],
+ *inputLines[segmentIndex][0],
+ *inputLines[segmentIndex][1]);
+ return dist;
/*public*/
bool
LineIntersector::isInteriorIntersection()
- if (isInteriorIntersection(0)) return true;
- if (isInteriorIntersection(1)) return true;
- return false;
+ if(isInteriorIntersection(0)) {
+ return true;
+ if(isInteriorIntersection(1)) {
+ return true;
+ return false;
/*public*/
bool
LineIntersector::isInteriorIntersection(int inputLineIndex)
- for (size_t i = 0; i < result; ++i)
- if (!(intPt[i].equals2D(*inputLines[inputLineIndex][0])
- || intPt[i].equals2D(*inputLines[inputLineIndex][1])))
- return true;
- return false;
+ if(!(intPt[i].equals2D(*inputLines[inputLineIndex][0])
+ || intPt[i].equals2D(*inputLines[inputLineIndex][1]))) {
+ return true;
+ return false;
/*public static*/
double
-LineIntersector::interpolateZ(const Coordinate &p,
- const Coordinate &p1, const Coordinate &p2)
+LineIntersector::interpolateZ(const Coordinate& p,
+ const Coordinate& p1, const Coordinate& p2)
#if GEOS_DEBUG
- cerr<<"LineIntersector::interpolateZ("<<p.toString()<<", "<<p1.toString()<<", "<<p2.toString()<<")"<<endl;
+ cerr << "LineIntersector::interpolateZ(" << p.toString() << ", " << p1.toString() << ", " << p2.toString() << ")" <<
+ endl;
#endif
- if ( std::isnan(p1.z) )
+ if(std::isnan(p1.z)) {
#if GEOS_DEBUG
- cerr<<" p1 do not have a Z"<<endl;
+ cerr << " p1 do not have a Z" << endl;
#endif
- return p2.z; // might be DoubleNotANumber again
+ return p2.z; // might be DoubleNotANumber again
- if ( std::isnan(p2.z) )
+ if(std::isnan(p2.z)) {
#if GEOS_DEBUG
- cerr<<" p2 do not have a Z"<<endl;
+ cerr << " p2 do not have a Z" << endl;
#endif
- return p1.z; // might be DoubleNotANumber again
+ return p1.z; // might be DoubleNotANumber again
- if (p==p1)
+ if(p == p1) {
#if GEOS_DEBUG
- cerr<<" p==p1, returning "<<p1.z<<endl;
+ cerr << " p==p1, returning " << p1.z << endl;
#endif
- return p1.z;
- if (p==p2)
+ return p1.z;
+ if(p == p2) {
#if GEOS_DEBUG
- cerr<<" p==p2, returning "<<p2.z<<endl;
+ cerr << " p==p2, returning " << p2.z << endl;
#endif
- return p2.z;
+ return p2.z;
- //double zgap = fabs(p2.z - p1.z);
- double zgap = p2.z - p1.z;
- if ( ! zgap )
+ //double zgap = fabs(p2.z - p1.z);
+ double zgap = p2.z - p1.z;
+ if(! zgap) {
#if GEOS_DEBUG
- cerr<<" no zgap, returning "<<p2.z<<endl;
-#endif
- return p2.z;
- double xoff = (p2.x-p1.x);
- double yoff = (p2.y-p1.y);
- double seglen = (xoff*xoff+yoff*yoff);
- xoff = (p.x-p1.x);
- yoff = (p.y-p1.y);
- double pdist = (xoff*xoff+yoff*yoff);
- double fract = sqrt(pdist/seglen);
- double zoff = zgap*fract;
- //double interpolated = p1.z < p2.z ? p1.z+zoff : p1.z-zoff;
- double interpolated = p1.z+zoff;
+ cerr << " no zgap, returning " << p2.z << endl;
+#endif
+ return p2.z;
+ double xoff = (p2.x - p1.x);
+ double yoff = (p2.y - p1.y);
+ double seglen = (xoff * xoff + yoff * yoff);
+ xoff = (p.x - p1.x);
+ yoff = (p.y - p1.y);
+ double pdist = (xoff * xoff + yoff * yoff);
+ double fract = sqrt(pdist / seglen);
+ double zoff = zgap * fract;
+ //double interpolated = p1.z < p2.z ? p1.z+zoff : p1.z-zoff;
+ double interpolated = p1.z + zoff;
#if GEOS_DEBUG
- cerr<<" zgap:"<<zgap<<" seglen:"<<seglen<<" pdist:"<<pdist
- <<" fract:"<<fract<<" z:"<<interpolated<<endl;
+ cerr << " zgap:" << zgap << " seglen:" << seglen << " pdist:" << pdist
+ << " fract:" << fract << " z:" << interpolated << endl;
#endif
- return interpolated;
+ return interpolated;
/*public*/
void
-LineIntersector::computeIntersection(const Coordinate& p,const Coordinate& p1,const Coordinate& p2)
+LineIntersector::computeIntersection(const Coordinate& p, const Coordinate& p1, const Coordinate& p2)
- isProperVar=false;
- // do between check first, since it is faster than the orientation test
- if(Envelope::intersects(p1,p2,p)) {
- if ((Orientation::index(p1,p2,p)==0)&&
- (Orientation::index(p2,p1,p)==0)) {
- isProperVar=true;
- if ((p==p1)||(p==p2)) // 2d only test
+ isProperVar = false;
+ // do between check first, since it is faster than the orientation test
+ if(Envelope::intersects(p1, p2, p)) {
+ if((Orientation::index(p1, p2, p) == 0) &&
+ (Orientation::index(p2, p1, p) == 0)) {
+ isProperVar = true;
+ if((p == p1) || (p == p2)) { // 2d only test
#if COMPUTE_Z
- intPt[0]=p;
+ intPt[0] = p;
#if GEOS_DEBUG
- cerr<<"RobustIntersector::computeIntersection(Coordinate,Coordinate,Coordinate) calling interpolateZ"<<endl;
-#endif
- double z = interpolateZ(p, p1, p2);
- if ( !std::isnan(z) )
- if ( std::isnan(intPt[0].z) )
- intPt[0].z = z;
- else
- intPt[0].z = (intPt[0].z+z)/2;
+ cerr << "RobustIntersector::computeIntersection(Coordinate,Coordinate,Coordinate) calling interpolateZ" << endl;
+#endif
+ double z = interpolateZ(p, p1, p2);
+ if(!std::isnan(z)) {
+ if(std::isnan(intPt[0].z)) {
+ intPt[0].z = z;
+ else {
+ intPt[0].z = (intPt[0].z + z) / 2;
#endif // COMPUTE_Z
- result=POINT_INTERSECTION;
- return;
- result = NO_INTERSECTION;
+ result = POINT_INTERSECTION;
+ return;
+ result = NO_INTERSECTION;
/* public static */
bool
LineIntersector::hasIntersection(const Coordinate& p, const Coordinate& p1, const Coordinate& p2)
- return true;
- return false;
+ return true;
+ return false;
/*private*/
int
-LineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,const Coordinate& q1,const Coordinate& q2)
+LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2, const Coordinate& q1,
+ const Coordinate& q2)
#if GEOS_DEBUG
- cerr<<"LineIntersector::computeIntersect called"<<endl;
- cerr<<" p1:"<<p1.toString()<<" p2:"<<p2.toString()<<" q1:"<<q1.toString()<<" q2:"<<q2.toString()<<endl;
+ cerr << "LineIntersector::computeIntersect called" << endl;
+ cerr << " p1:" << p1.toString() << " p2:" << p2.toString() << " q1:" << q1.toString() << " q2:" << q2.toString() <<
+ endl;
#endif // GEOS_DEBUG
- // first try a fast test to see if the envelopes of the lines intersect
- if (!Envelope::intersects(p1,p2,q1,q2))
+ // first try a fast test to see if the envelopes of the lines intersect
+ if(!Envelope::intersects(p1, p2, q1, q2)) {
#if GEOS_DEBUG
- cerr<<" NO_INTERSECTION"<<endl;
+ cerr << " NO_INTERSECTION" << endl;
#endif
- return NO_INTERSECTION;
+ return NO_INTERSECTION;
- // for each endpoint, compute which side of the other segment it lies
- // if both endpoints lie on the same side of the other segment,
- // the segments do not intersect
- int Pq1=Orientation::index(p1,p2,q1);
- int Pq2=Orientation::index(p1,p2,q2);
+ // for each endpoint, compute which side of the other segment it lies
+ // if both endpoints lie on the same side of the other segment,
+ // the segments do not intersect
+ int Pq1 = Orientation::index(p1, p2, q1);
+ int Pq2 = Orientation::index(p1, p2, q2);
- if ((Pq1>0 && Pq2>0) || (Pq1<0 && Pq2<0))
+ if((Pq1 > 0 && Pq2 > 0) || (Pq1 < 0 && Pq2 < 0)) {
#if GEOS_DEBUG
#endif
- int Qp1=Orientation::index(q1,q2,p1);
- int Qp2=Orientation::index(q1,q2,p2);
+ int Qp1 = Orientation::index(q1, q2, p1);
+ int Qp2 = Orientation::index(q1, q2, p2);
- if ((Qp1>0 && Qp2>0)||(Qp1<0 && Qp2<0)) {
+ if((Qp1 > 0 && Qp2 > 0) || (Qp1 < 0 && Qp2 < 0)) {
#if GEOS_DEBUG
#endif
- bool collinear=Pq1==0 && Pq2==0 && Qp1==0 && Qp2==0;
- if (collinear) {
+ bool collinear = Pq1 == 0 && Pq2 == 0 && Qp1 == 0 && Qp2 == 0;
+ if(collinear) {
#if GEOS_DEBUG
- cerr<<" computingCollinearIntersection"<<endl;
-#endif
- return computeCollinearIntersection(p1,p2,q1,q2);
- * At this point we know that there is a single intersection point
- * (since the lines are not collinear).
- * Check if the intersection is an endpoint.
- * If it is, copy the endpoint as
- * the intersection point. Copying the point rather than
- * computing it ensures the point has the exact value,
- * which is important for robustness. It is sufficient to
- * simply check for an endpoint which is on the other line,
- * since at this point we know that the inputLines must
- * intersect.
- if (Pq1==0 || Pq2==0 || Qp1==0 || Qp2==0) {
+ cerr << " computingCollinearIntersection" << endl;
+#endif
+ return computeCollinearIntersection(p1, p2, q1, q2);
+ * At this point we know that there is a single intersection point
+ * (since the lines are not collinear).
+ * Check if the intersection is an endpoint.
+ * If it is, copy the endpoint as
+ * the intersection point. Copying the point rather than
+ * computing it ensures the point has the exact value,
+ * which is important for robustness. It is sufficient to
+ * simply check for an endpoint which is on the other line,
+ * since at this point we know that the inputLines must
+ * intersect.
+ if(Pq1 == 0 || Pq2 == 0 || Qp1 == 0 || Qp2 == 0) {
#if COMPUTE_Z
- int hits=0;
- double z=0.0;
-#endif
- /* Check for two equal endpoints.
- * This is done explicitly rather than by the orientation tests
- * below in order to improve robustness.
- * (A example where the orientation tests fail
- * to be consistent is:
- * LINESTRING ( 19.850257749638203 46.29709338043669,
- * 20.31970698357233 46.76654261437082 )
- * and
- * LINESTRING ( -48.51001596420236 -22.063180333403878,
- * 19.850257749638203 46.29709338043669 )
- * which used to produce the result:
- * (20.31970698357233, 46.76654261437082, NaN)
- if ( p1.equals2D(q1) || p1.equals2D(q2) ) {
- intPt[0]=p1;
+ int hits = 0;
+ double z = 0.0;
+#endif
+ /* Check for two equal endpoints.
+ * This is done explicitly rather than by the orientation tests
+ * below in order to improve robustness.
+ * (A example where the orientation tests fail
+ * to be consistent is:
+ * LINESTRING ( 19.850257749638203 46.29709338043669,
+ * 20.31970698357233 46.76654261437082 )
+ * and
+ * LINESTRING ( -48.51001596420236 -22.063180333403878,
+ * 19.850257749638203 46.29709338043669 )
+ * which used to produce the result:
+ * (20.31970698357233, 46.76654261437082, NaN)
+ if(p1.equals2D(q1) || p1.equals2D(q2)) {
+ intPt[0] = p1;
#if COMPUTE_Z
- if ( !std::isnan(p1.z) )
- z += p1.z;
- hits++;
-#endif
- else if ( p2.equals2D(q1) || p2.equals2D(q2) ) {
- intPt[0]=p2;
+ if(!std::isnan(p1.z)) {
+ z += p1.z;
+ hits++;
+#endif
+ else if(p2.equals2D(q1) || p2.equals2D(q2)) {
+ intPt[0] = p2;
#if COMPUTE_Z
- if ( !std::isnan(p2.z) )
- z += p2.z;
- hits++;
-#endif
- * Now check to see if any endpoint lies on the interior of the other segment.
- else if (Pq1==0) {
- intPt[0]=q1;
+ if(!std::isnan(p2.z)) {
+ z += p2.z;
+ hits++;
+#endif
+ * Now check to see if any endpoint lies on the interior of the other segment.
+ else if(Pq1 == 0) {
+ intPt[0] = q1;
#if COMPUTE_Z
- if ( !std::isnan(q1.z) )
- z += q1.z;
- hits++;
-#endif
- else if (Pq2==0) {
- intPt[0]=q2;
+ if(!std::isnan(q1.z)) {
+ z += q1.z;
+ hits++;
+#endif
+ else if(Pq2 == 0) {
+ intPt[0] = q2;
#if COMPUTE_Z
- if ( !std::isnan(q2.z) )
- z += q2.z;
- hits++;
-#endif
- else if (Qp1==0) {
- intPt[0]=p1;
+ if(!std::isnan(q2.z)) {
+ z += q2.z;
+ hits++;
+#endif
+ else if(Qp1 == 0) {
+ intPt[0] = p1;
#if COMPUTE_Z
- z += p1.z;
- hits++;
-#endif
- else if (Qp2==0) {
- intPt[0]=p2;
+ z += p1.z;
+ hits++;
+#endif
+ else if(Qp2 == 0) {
+ intPt[0] = p2;
#if COMPUTE_Z
- z += p2.z;
- hits++;
+ z += p2.z;
+ hits++;
#endif
#if COMPUTE_Z
#if GEOS_DEBUG
- cerr<<"LineIntersector::computeIntersect: z:"<<z<<" hits:"<<hits<<endl;
+ cerr << "LineIntersector::computeIntersect: z:" << z << " hits:" << hits << endl;
- if ( hits ) intPt[0].z = z/hits;
+ if(hits) {
+ intPt[0].z = z / hits;
#endif // COMPUTE_Z
- } else {
- isProperVar=true;
- intersection(p1, p2, q1, q2, intPt[0]);
+ else {
+ intersection(p1, p2, q1, q2, intPt[0]);
#if GEOS_DEBUG
- cerr<<" POINT_INTERSECTION; intPt[0]:"<<intPt[0].toString()<<endl;
+ cerr << " POINT_INTERSECTION; intPt[0]:" << intPt[0].toString() << endl;
- return POINT_INTERSECTION;
+ return POINT_INTERSECTION;
/*private*/
int
-LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordinate& p2,const Coordinate& q1,const Coordinate& q2)
+LineIntersector::computeCollinearIntersection(const Coordinate& p1, const Coordinate& p2, const Coordinate& q1,
#if COMPUTE_Z
- double ztot;
- int hits;
- double p2z;
- double p1z;
- double q1z;
- double q2z;
+ double ztot;
+ int hits;
+ double p2z;
+ double p1z;
+ double q1z;
+ double q2z;
#endif // COMPUTE_Z
#if GEOS_DEBUG
- cerr<<"LineIntersector::computeCollinearIntersection called"<<endl;
+ cerr << "LineIntersector::computeCollinearIntersection called" << endl;
+ endl;
- bool p1q1p2=Envelope::intersects(p1,p2,q1);
- bool p1q2p2=Envelope::intersects(p1,p2,q2);
- bool q1p1q2=Envelope::intersects(q1,q2,p1);
- bool q1p2q2=Envelope::intersects(q1,q2,p2);
+ bool p1q1p2 = Envelope::intersects(p1, p2, q1);
+ bool p1q2p2 = Envelope::intersects(p1, p2, q2);
+ bool q1p1q2 = Envelope::intersects(q1, q2, p1);
+ bool q1p2q2 = Envelope::intersects(q1, q2, p2);
- if (p1q1p2 && p1q2p2) {
+ if(p1q1p2 && p1q2p2) {
#if GEOS_DEBUG
- cerr<<" p1q1p2 && p1q2p2"<<endl;
+ cerr << " p1q1p2 && p1q2p2" << endl;
#endif
- intPt[0]=q1;
+ intPt[0] = q1;
#if COMPUTE_Z
- ztot=0;
- hits=0;
- q1z = interpolateZ(q1, p1, p2);
- if (!std::isnan(q1z)) { ztot+=q1z; hits++; }
- if (!std::isnan(q1.z)) { ztot+=q1.z; hits++; }
- if ( hits ) intPt[0].z = ztot/hits;
-#endif
- intPt[1]=q2;
+ ztot = 0;
+ hits = 0;
+ q1z = interpolateZ(q1, p1, p2);
+ if(!std::isnan(q1z)) {
+ ztot += q1z;
+ hits++;
+ ztot += q1.z;
+ hits++;
+ if(hits) {
+ intPt[0].z = ztot / hits;
+#endif
+ intPt[1] = q2;
#if COMPUTE_Z
- ztot=0;
- hits=0;
- q2z = interpolateZ(q2, p1, p2);
- if (!std::isnan(q2z)) { ztot+=q2z; hits++; }
- if (!std::isnan(q2.z)) { ztot+=q2.z; hits++; }
- if ( hits ) intPt[1].z = ztot/hits;
+ ztot = 0;
+ hits = 0;
+ q2z = interpolateZ(q2, p1, p2);
+ if(!std::isnan(q2z)) {
+ ztot += q2z;
+ hits++;
+ ztot += q2.z;
+ hits++;
+ if(hits) {
+ intPt[1].z = ztot / hits;
#endif
#if GEOS_DEBUG
- cerr<<" intPt[0]: "<<intPt[0].toString()<<endl;
- cerr<<" intPt[1]: "<<intPt[1].toString()<<endl;
+ cerr << " intPt[0]: " << intPt[0].toString() << endl;
+ cerr << " intPt[1]: " << intPt[1].toString() << endl;
#endif
- return COLLINEAR_INTERSECTION;
- if (q1p1q2 && q1p2q2) {
+ return COLLINEAR_INTERSECTION;
+ if(q1p1q2 && q1p2q2) {
#if GEOS_DEBUG
- cerr<<" q1p1q2 && q1p2q2"<<endl;
+ cerr << " q1p1q2 && q1p2q2" << endl;
#endif
- intPt[0]=p1;
+ intPt[0] = p1;
#if COMPUTE_Z
- ztot=0;
- hits=0;
- p1z = interpolateZ(p1, q1, q2);
- if (!std::isnan(p1z)) { ztot+=p1z; hits++; }
- if (!std::isnan(p1.z)) { ztot+=p1.z; hits++; }
-#endif
- intPt[1]=p2;
+ ztot = 0;
+ hits = 0;
+ p1z = interpolateZ(p1, q1, q2);
+ if(!std::isnan(p1z)) {
+ ztot += p1z;
+ hits++;
+ ztot += p1.z;
+ hits++;
+ if(hits) {
+#endif
+ intPt[1] = p2;
#if COMPUTE_Z
- ztot=0;
- hits=0;
- p2z = interpolateZ(p2, q1, q2);
- if (!std::isnan(p2z)) { ztot+=p2z; hits++; }
- if (!std::isnan(p2.z)) { ztot+=p2.z; hits++; }
-#endif
- if (p1q1p2 && q1p1q2) {
+ ztot = 0;
+ hits = 0;
+ p2z = interpolateZ(p2, q1, q2);
+ if(!std::isnan(p2z)) {
+ ztot += p2z;
+ hits++;
+ ztot += p2.z;
+ hits++;
+ if(hits) {
+#endif
+ if(p1q1p2 && q1p1q2) {
#if GEOS_DEBUG
- cerr<<" p1q1p2 && q1p1q2"<<endl;
+ cerr << " p1q1p2 && q1p1q2" << endl;
#endif
- intPt[0]=q1;
+ intPt[0] = q1;
#if COMPUTE_Z
- ztot=0;
- hits=0;
-#endif
- intPt[1]=p1;
+ ztot = 0;
+ hits = 0;
+ ztot += q1z;
+ hits++;
+ ztot += q1.z;
+ hits++;
+ if(hits) {
+#endif
+ intPt[1] = p1;
#if COMPUTE_Z
- ztot=0;
- hits=0;
+ ztot = 0;
+ hits = 0;
+ ztot += p1z;
+ hits++;
+ ztot += p1.z;
+ hits++;
+ if(hits) {
#endif
#if GEOS_DEBUG
#endif
- return (q1==p1) && !p1q2p2 && !q1p2q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
- if (p1q1p2 && q1p2q2) {
+ return (q1 == p1) && !p1q2p2 && !q1p2q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
+ if(p1q1p2 && q1p2q2) {
#if GEOS_DEBUG
- cerr<<" p1q1p2 && q1p2q2"<<endl;
+ cerr << " p1q1p2 && q1p2q2" << endl;
#endif
- intPt[0]=q1;
+ intPt[0] = q1;
#if COMPUTE_Z
- ztot=0;
- hits=0;
-#endif
- intPt[1]=p2;
+ ztot = 0;
+ hits = 0;
+ ztot += q1z;
+ hits++;
+ ztot += q1.z;
+ hits++;
+ if(hits) {
+#endif
+ intPt[1] = p2;
#if COMPUTE_Z
- ztot=0;
- hits=0;
+ ztot = 0;
+ hits = 0;
+ ztot += p2z;
+ hits++;
+ ztot += p2.z;
+ hits++;
+ if(hits) {
#endif
#if GEOS_DEBUG
#endif
- return (q1==p2) && !p1q2p2 && !q1p1q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
- if (p1q2p2 && q1p1q2) {
+ return (q1 == p2) && !p1q2p2 && !q1p1q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
+ if(p1q2p2 && q1p1q2) {
#if GEOS_DEBUG
- cerr<<" p1q2p2 && q1p1q2"<<endl;
+ cerr << " p1q2p2 && q1p1q2" << endl;
#endif
- intPt[0]=q2;
+ intPt[0] = q2;
#if COMPUTE_Z
- ztot=0;
- hits=0;
-#endif
- intPt[1]=p1;
+ ztot = 0;
+ hits = 0;
+ ztot += q2z;
+ hits++;
+ ztot += q2.z;
+ hits++;
+ if(hits) {
+#endif
+ intPt[1] = p1;
#if COMPUTE_Z
- ztot=0;
- hits=0;
+ ztot = 0;
+ hits = 0;
+ ztot += p1z;
+ hits++;
+ ztot += p1.z;
+ hits++;
+ if(hits) {
#endif
#if GEOS_DEBUG
#endif
- return (q2==p1) && !p1q1p2 && !q1p2q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
- if (p1q2p2 && q1p2q2) {
+ return (q2 == p1) && !p1q1p2 && !q1p2q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
+ if(p1q2p2 && q1p2q2) {
#if GEOS_DEBUG
- cerr<<" p1q2p2 && q1p2q2"<<endl;
+ cerr << " p1q2p2 && q1p2q2" << endl;
#endif
- intPt[0]=q2;
+ intPt[0] = q2;
#if COMPUTE_Z
- ztot=0;
- hits=0;
-#endif
- intPt[1]=p2;
+ ztot = 0;
+ hits = 0;
+ ztot += q2z;
+ hits++;
+ ztot += q2.z;
+ hits++;
+ if(hits) {
+#endif
+ intPt[1] = p2;
#if COMPUTE_Z
- ztot=0;
- hits=0;
+ ztot = 0;
+ hits = 0;
+ ztot += p2z;
+ hits++;
+ ztot += p2.z;
+ hits++;
+ if(hits) {
#endif
#if GEOS_DEBUG
#endif
- return (q2==p2) && !p1q1p2 && !q1p1q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
+ return (q2 == p2) && !p1q1p2 && !q1p1q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
/*private*/
void
LineIntersector::intersection(const Coordinate& p1,
- const Coordinate& p2, const Coordinate& q1, const Coordinate& q2,
- Coordinate &intPtOut) const
+ const Coordinate& p2, const Coordinate& q1, const Coordinate& q2,
+ Coordinate& intPtOut) const
- intersectionWithNormalization(p1, p2, q1, q2, intPtOut);
- * Due to rounding it can happen that the computed intersection is
- * outside the envelopes of the input segments. Clearly this
- * is inconsistent.
- * This code checks this condition and forces a more reasonable answer
- * MD - May 4 2005 - This is still a problem. Here is a failure case:
- * LINESTRING (2089426.5233462777 1180182.3877339689,
- * 2085646.6891757075 1195618.7333999649)
- * LINESTRING (1889281.8148903656 1997547.0560044837,
- * 2259977.3672235999 483675.17050843034)
- * int point = (2097408.2633752143,1144595.8008114607)
- if (! isInSegmentEnvelopes(intPtOut))
- //intPt = CentralEndpointIntersector::getIntersection(p1, p2, q1, q2);
- intPtOut = nearestEndpoint(p1, p2, q1, q2);
+ intersectionWithNormalization(p1, p2, q1, q2, intPtOut);
+ * Due to rounding it can happen that the computed intersection is
+ * outside the envelopes of the input segments. Clearly this
+ * is inconsistent.
+ * This code checks this condition and forces a more reasonable answer
+ * MD - May 4 2005 - This is still a problem. Here is a failure case:
+ * LINESTRING (2089426.5233462777 1180182.3877339689,
+ * 2085646.6891757075 1195618.7333999649)
+ * LINESTRING (1889281.8148903656 1997547.0560044837,
+ * 2259977.3672235999 483675.17050843034)
+ * int point = (2097408.2633752143,1144595.8008114607)
+ if(! isInSegmentEnvelopes(intPtOut)) {
+ //intPt = CentralEndpointIntersector::getIntersection(p1, p2, q1, q2);
+ intPtOut = nearestEndpoint(p1, p2, q1, q2);
#if GEOS_DEBUG
- cerr << "Intersection outside segment envelopes, snapped to "
- << intPt.toString() << endl;
+ cerr << "Intersection outside segment envelopes, snapped to "
+ << intPt.toString() << endl;
#endif
- if (precisionModel!=nullptr) {
- precisionModel->makePrecise(intPtOut);
+ if(precisionModel != nullptr) {
+ precisionModel->makePrecise(intPtOut);
#if COMPUTE_Z
- double ztot = 0;
- double zvals = 0;
- double zp = interpolateZ(intPtOut, p1, p2);
- double zq = interpolateZ(intPtOut, q1, q2);
- if ( !std::isnan(zp)) { ztot += zp; zvals++; }
- if ( !std::isnan(zq)) { ztot += zq; zvals++; }
- if ( zvals ) intPtOut.z = ztot/zvals;
+ double ztot = 0;
+ double zvals = 0;
+ double zp = interpolateZ(intPtOut, p1, p2);
+ double zq = interpolateZ(intPtOut, q1, q2);
+ if(!std::isnan(zp)) {
+ ztot += zp;
+ zvals++;
+ if(!std::isnan(zq)) {
+ ztot += zq;
+ zvals++;
+ if(zvals) {
+ intPtOut.z = ztot / zvals;
#endif // COMPUTE_Z
@@ -790,121 +900,128 @@ LineIntersector::intersection(const Coordinate& p1,
/*private*/
void
LineIntersector::intersectionWithNormalization(const Coordinate& p1,
- Coordinate n1=p1;
- Coordinate n2=p2;
- Coordinate n3=q1;
- Coordinate n4=q2;
- Coordinate normPt;
- normalizeToEnvCentre(n1, n2, n3, n4, normPt);
+ Coordinate n1 = p1;
+ Coordinate n2 = p2;
+ Coordinate n3 = q1;
+ Coordinate n4 = q2;
+ Coordinate normPt;
+ normalizeToEnvCentre(n1, n2, n3, n4, normPt);
- safeHCoordinateIntersection(n1, n2, n3, n4, intPtOut);
+ safeHCoordinateIntersection(n1, n2, n3, n4, intPtOut);
- intPtOut.x += normPt.x;
- intPtOut.y += normPt.y;
+ intPtOut.x += normPt.x;
+ intPtOut.y += normPt.y;
/*private*/
double
-LineIntersector::smallestInAbsValue(double x1,double x2,double x3,double x4) const
+LineIntersector::smallestInAbsValue(double x1, double x2, double x3, double x4) const
- double x=x1;
- double xabs=fabs(x);
- if(fabs(x2)<xabs) {
- x=x2;
- xabs=fabs(x2);
- if(fabs(x3)<xabs) {
- x=x3;
- xabs=fabs(x3);
- if(fabs(x4)<xabs) {
- x=x4;
- return x;
+ double x = x1;
+ double xabs = fabs(x);
+ if(fabs(x2) < xabs) {
+ x = x2;
+ xabs = fabs(x2);
+ if(fabs(x3) < xabs) {
+ x = x3;
+ xabs = fabs(x3);
+ if(fabs(x4) < xabs) {
+ x = x4;
+ return x;
/*private*/
bool
LineIntersector::isInSegmentEnvelopes(const Coordinate& pt) const
- Envelope env0(*inputLines[0][0], *inputLines[0][1]);
- Envelope env1(*inputLines[1][0], *inputLines[1][1]);
- return env0.contains(pt) && env1.contains(pt);
+ Envelope env0(*inputLines[0][0], *inputLines[0][1]);
+ Envelope env1(*inputLines[1][0], *inputLines[1][1]);
+ return env0.contains(pt) && env1.contains(pt);
/*private*/
void
-LineIntersector::normalizeToEnvCentre(Coordinate &n00, Coordinate &n01,
- Coordinate &n10, Coordinate &n11, Coordinate &normPt) const
+LineIntersector::normalizeToEnvCentre(Coordinate& n00, Coordinate& n01,
+ Coordinate& n10, Coordinate& n11, Coordinate& normPt) const
- double minX0 = n00.x < n01.x ? n00.x : n01.x;
- double minY0 = n00.y < n01.y ? n00.y : n01.y;
- double maxX0 = n00.x > n01.x ? n00.x : n01.x;
- double maxY0 = n00.y > n01.y ? n00.y : n01.y;
- double minX1 = n10.x < n11.x ? n10.x : n11.x;
- double minY1 = n10.y < n11.y ? n10.y : n11.y;
- double maxX1 = n10.x > n11.x ? n10.x : n11.x;
- double maxY1 = n10.y > n11.y ? n10.y : n11.y;
- double intMinX = minX0 > minX1 ? minX0 : minX1;
- double intMaxX = maxX0 < maxX1 ? maxX0 : maxX1;
- double intMinY = minY0 > minY1 ? minY0 : minY1;
- double intMaxY = maxY0 < maxY1 ? maxY0 : maxY1;
- double intMidX = (intMinX + intMaxX) / 2.0;
- double intMidY = (intMinY + intMaxY) / 2.0;
- normPt.x = intMidX;
- normPt.y = intMidY;
- n00.x -= normPt.x; n00.y -= normPt.y;
- n01.x -= normPt.x; n01.y -= normPt.y;
- n10.x -= normPt.x; n10.y -= normPt.y;
- n11.x -= normPt.x; n11.y -= normPt.y;
+ double minX0 = n00.x < n01.x ? n00.x : n01.x;
+ double minY0 = n00.y < n01.y ? n00.y : n01.y;
+ double maxX0 = n00.x > n01.x ? n00.x : n01.x;
+ double maxY0 = n00.y > n01.y ? n00.y : n01.y;
+ double minX1 = n10.x < n11.x ? n10.x : n11.x;
+ double minY1 = n10.y < n11.y ? n10.y : n11.y;
+ double maxX1 = n10.x > n11.x ? n10.x : n11.x;
+ double maxY1 = n10.y > n11.y ? n10.y : n11.y;
+ double intMinX = minX0 > minX1 ? minX0 : minX1;
+ double intMaxX = maxX0 < maxX1 ? maxX0 : maxX1;
+ double intMinY = minY0 > minY1 ? minY0 : minY1;
+ double intMaxY = maxY0 < maxY1 ? maxY0 : maxY1;
+ double intMidX = (intMinX + intMaxX) / 2.0;
+ double intMidY = (intMinY + intMaxY) / 2.0;
+ normPt.x = intMidX;
+ normPt.y = intMidY;
+ n00.x -= normPt.x;
+ n00.y -= normPt.y;
+ n01.x -= normPt.x;
+ n01.y -= normPt.y;
+ n10.x -= normPt.x;
+ n10.y -= normPt.y;
+ n11.x -= normPt.x;
+ n11.y -= normPt.y;
#if COMPUTE_Z
- // Only do this if input does have Z
- // See https://trac.osgeo.org/geos/ticket/811
- if( std::isnan(n00.z) ) return;
- double minZ0 = n00.z < n01.z ? n00.z : n01.z;
- double minZ1 = n10.z < n11.z ? n10.z : n11.z;
- double maxZ0 = n00.z > n01.z ? n00.z : n01.z;
- double maxZ1 = n10.z > n11.z ? n10.z : n11.z;
- double intMinZ = minZ0 > minZ1 ? minZ0 : minZ1;
- double intMaxZ = maxZ0 < maxZ1 ? maxZ0 : maxZ1;
- double intMidZ = (intMinZ + intMaxZ) / 2.0;
- normPt.z = intMidZ;
- n00.z -= normPt.z;
- n01.z -= normPt.z;
- n10.z -= normPt.z;
- n11.z -= normPt.z;
+ // Only do this if input does have Z
+ // See https://trac.osgeo.org/geos/ticket/811
+ if(std::isnan(n00.z)) {
+ return;
+ double minZ0 = n00.z < n01.z ? n00.z : n01.z;
+ double minZ1 = n10.z < n11.z ? n10.z : n11.z;
+ double maxZ0 = n00.z > n01.z ? n00.z : n01.z;
+ double maxZ1 = n10.z > n11.z ? n10.z : n11.z;
+ double intMinZ = minZ0 > minZ1 ? minZ0 : minZ1;
+ double intMaxZ = maxZ0 < maxZ1 ? maxZ0 : maxZ1;
+ double intMidZ = (intMinZ + intMaxZ) / 2.0;
+ normPt.z = intMidZ;
+ n00.z -= normPt.z;
+ n01.z -= normPt.z;
+ n10.z -= normPt.z;
+ n11.z -= normPt.z;
#endif
/*private*/
void
LineIntersector::safeHCoordinateIntersection(const Coordinate& p1,
- const Coordinate& q2, Coordinate& intPtOut) const
+ const Coordinate& q2, Coordinate& intPtOut) const
- try {
- HCoordinate::intersection(p1, p2, q1, q2, intPtOut);
+ try {
+ HCoordinate::intersection(p1, p2, q1, q2, intPtOut);
#if GEOS_DEBUG
- cerr<<" HCoordinate found intersection h:"<<intPt.toString()<<endl;
+ cerr << " HCoordinate found intersection h:" << intPt.toString() << endl;
#endif
- } catch (const NotRepresentableException& /* e */) {
- // compute an approximate result
+ catch(const NotRepresentableException& /* e */) {
+ // compute an approximate result
} // namespace geos.algorithm
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index 0928d66..59b1084 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -49,11 +49,13 @@ MinimumBoundingCircle::getCircle()
//TODO: or maybe even ensure that the returned geometry contains ALL the input points?
compute();
- if (centre.isNull())
+ if(centre.isNull()) {
return input->getFactory()->createPolygon();
- Point *centrePoint = input->getFactory()->createPoint(centre);
- if (radius == 0.0)
+ Point* centrePoint = input->getFactory()->createPoint(centre);
+ if(radius == 0.0) {
return centrePoint;
return centrePoint->buffer(radius);
@@ -62,16 +64,16 @@ Geometry*
MinimumBoundingCircle::getFarthestPoints()
compute();
- switch (extremalPts.size()) {
- case 0:
- return input->getFactory()->createLineString();
- case 1:
- return input->getFactory()->createPoint(centre);
+ switch(extremalPts.size()) {
+ case 0:
+ return input->getFactory()->createLineString();
+ case 1:
+ return input->getFactory()->createPoint(centre);
size_t dims = input->getDimension();
size_t len = 2;
- CoordinateSequence *cs = input->getFactory()->getCoordinateSequenceFactory()->create(len, dims);
+ CoordinateSequence* cs = input->getFactory()->getCoordinateSequenceFactory()->create(len, dims);
cs->add(extremalPts[0], true);
cs->add(extremalPts[extremalPts.size() - 1], true);
return input->getFactory()->createLineString(cs);
@@ -82,15 +84,15 @@ Geometry*
MinimumBoundingCircle::getDiameter()
compute();
- case 0:
- case 1:
+ case 0:
+ case 1:
size_t len = 2;
// TODO: handle case of 3 extremal points, by computing a line from one of
// them through the centre point with len = 2*radius
@@ -126,29 +128,30 @@ MinimumBoundingCircle::getRadius()
void
MinimumBoundingCircle::computeCentre()
- case 0: {
- centre.setNull();
- break;
- case 1: {
- centre = extremalPts[0];
- break;
- case 2: {
- double xAvg = (extremalPts[0].x + extremalPts[1].x) / 2.0;
- double yAvg = (extremalPts[0].y + extremalPts[1].y) / 2.0;
- Coordinate c(xAvg, yAvg);
- centre = c;
- break;
- case 3: {
- centre = Triangle::circumcentre(extremalPts[0], extremalPts[1], extremalPts[2]);
- break;
- default: {
- util::GEOSException("Logic failure in MinimumBoundingCircle algorithm!");\
+ case 0: {
+ centre.setNull();
+ break;
+ case 1: {
+ centre = extremalPts[0];
+ break;
+ case 2: {
+ double xAvg = (extremalPts[0].x + extremalPts[1].x) / 2.0;
+ double yAvg = (extremalPts[0].y + extremalPts[1].y) / 2.0;
+ Coordinate c(xAvg, yAvg);
+ centre = c;
+ break;
+ case 3: {
+ centre = Triangle::circumcentre(extremalPts[0], extremalPts[1], extremalPts[2]);
+ break;
+ default: {
+ util::GEOSException("Logic failure in MinimumBoundingCircle algorithm!");
@@ -156,12 +159,15 @@ MinimumBoundingCircle::computeCentre()
void
MinimumBoundingCircle::compute()
- if (!extremalPts.empty()) return;
+ if(!extremalPts.empty()) {
+ return;
computeCirclePoints();
computeCentre();
- if (!centre.isNull())
+ if(!centre.isNull()) {
radius = centre.distance(extremalPts[0]);
/*private*/
@@ -169,10 +175,10 @@ void
MinimumBoundingCircle::computeCirclePoints()
// handle degenerate or trivial cases
- if (input->isEmpty()) {
+ if(input->isEmpty()) {
return;
- if (input->getNumPoints() == 1) {
+ if(input->getNumPoints() == 1) {
extremalPts.push_back(*(input->getCoordinate()));
return;
@@ -181,21 +187,21 @@ MinimumBoundingCircle::computeCirclePoints()
* The problem is simplified by reducing to the convex hull.
* Computing the convex hull also has the useful effect of eliminating duplicate points
- Geometry *convexHull = input->convexHull();
+ Geometry* convexHull = input->convexHull();
- CoordinateSequence *cs = convexHull->getCoordinates();
+ CoordinateSequence* cs = convexHull->getCoordinates();
std::vector<Coordinate> pts;
cs->toVector(pts);
// strip duplicate final point, if any
- if (pts.front().equals2D(pts.back())) {
+ if(pts.front().equals2D(pts.back())) {
pts.pop_back();
* Optimization for the trivial case where the CH has fewer than 3 points
- if (pts.size() <= 2) {
+ if(pts.size() <= 2) {
extremalPts = pts;
return;
@@ -214,22 +220,22 @@ MinimumBoundingCircle::computeCirclePoints()
* with a correct result.
size_t i = 0, n = pts.size();
- while (i++ < n) {
+ while(i++ < n) {
Coordinate R = pointWithMinAngleWithSegment(pts, P, Q);
// if PRQ is obtuse, then MBC is determined by P and Q
- if (algorithm::Angle::isObtuse(P, R, Q)) {
+ if(algorithm::Angle::isObtuse(P, R, Q)) {
extremalPts.push_back(P);
extremalPts.push_back(Q);
return;
// if RPQ is obtuse, update baseline and iterate
- if (algorithm::Angle::isObtuse(R, P, Q)) {
+ if(algorithm::Angle::isObtuse(R, P, Q)) {
P = R;
continue;
// if RQP is obtuse, update baseline and iterate
- if (algorithm::Angle::isObtuse(R, Q, P)) {
+ if(algorithm::Angle::isObtuse(R, Q, P)) {
Q = R;
continue;
@@ -248,9 +254,10 @@ Coordinate
MinimumBoundingCircle::lowestPoint(std::vector<Coordinate>& pts)
Coordinate min = pts[0];
- for (auto pt: pts) {
- if (pt.y < min.y)
+ for(auto pt : pts) {
+ if(pt.y < min.y) {
min = pt;
return min;
@@ -263,20 +270,24 @@ MinimumBoundingCircle::pointWitMinAngleWithX(std::vector<Coordinate>& pts, Coord
double minSin = std::numeric_limits<double>::max();
Coordinate minAngPt;
minAngPt.setNull();
- for (auto p: pts) {
+ for(auto p : pts) {
- if (p == P) continue;
+ if(p == P) {
+ continue;
* The sin of the angle is a simpler proxy for the angle itself
double dx = p.x - P.x;
double dy = p.y - P.y;
- if (dy < 0) dy = -dy;
+ if(dy < 0) {
+ dy = -dy;
double len = sqrt(dx * dx + dy * dy);
double sin = dy / len;
- if (sin < minSin) {
+ if(sin < minSin) {
minSin = sin;
minAngPt = p;
@@ -292,12 +303,16 @@ MinimumBoundingCircle::pointWithMinAngleWithSegment(std::vector<Coordinate>& pts
double minAng = std::numeric_limits<double>::max();
minAngPt.setNull();
- if (p == Q) continue;
+ if(p == P) {
+ continue;
+ if(p == Q) {
+ continue;
double ang = Angle::angleBetween(P, p, Q);
- if (ang < minAng) {
+ if(ang < minAng) {
minAng = ang;
minAngPt = p;
diff --git a/src/algorithm/MinimumDiameter.cpp b/src/algorithm/MinimumDiameter.cpp
index 1c51f1e..692da52 100644
--- a/src/algorithm/MinimumDiameter.cpp
+++ b/src/algorithm/MinimumDiameter.cpp
@@ -68,13 +68,13 @@ namespace algorithm { // geos.algorithm
MinimumDiameter::MinimumDiameter(const Geometry* newInputGeom)
- minBaseSeg=new LineSegment();
- minWidthPt=nullptr;
- minPtIndex=0;
- minWidth=0.0;
- inputGeom=newInputGeom;
- isConvex=false;
- convexHullPts=nullptr;
+ minBaseSeg = new LineSegment();
+ minWidthPt = nullptr;
+ minPtIndex = 0;
+ minWidth = 0.0;
+ inputGeom = newInputGeom;
+ isConvex = false;
+ convexHullPts = nullptr;
@@ -89,19 +89,19 @@ MinimumDiameter::MinimumDiameter(const Geometry* newInputGeom)
MinimumDiameter::MinimumDiameter(const Geometry* newInputGeom, const bool newIsConvex)
- minWidth=0.0;
- isConvex=newIsConvex;
+ minWidth = 0.0;
+ isConvex = newIsConvex;
MinimumDiameter::~MinimumDiameter()
- delete minBaseSeg;
- delete minWidthPt;
- delete convexHullPts;
+ delete minBaseSeg;
+ delete minWidthPt;
+ delete convexHullPts;
@@ -112,8 +112,8 @@ MinimumDiameter::~MinimumDiameter()
double
MinimumDiameter::getLength()
- computeMinimumDiameter();
- return minWidth;
+ computeMinimumDiameter();
+ return minWidth;
@@ -124,8 +124,8 @@ MinimumDiameter::getLength()
Coordinate*
MinimumDiameter::getWidthCoordinate()
- return minWidthPt;
+ return minWidthPt;
@@ -134,13 +134,14 @@ MinimumDiameter::getWidthCoordinate()
* @return the segment forming the base of the minimum diameter
LineString*
-MinimumDiameter::getSupportingSegment() {
- const GeometryFactory *fact = inputGeom->getFactory();
- CoordinateSequence* cl=fact->getCoordinateSequenceFactory()->create();
- cl->add(minBaseSeg->p0);
- cl->add(minBaseSeg->p1);
- return fact->createLineString(cl);
+MinimumDiameter::getSupportingSegment()
+ const GeometryFactory* fact = inputGeom->getFactory();
+ CoordinateSequence* cl = fact->getCoordinateSequenceFactory()->create();
+ cl->add(minBaseSeg->p0);
+ cl->add(minBaseSeg->p1);
+ return fact->createLineString(cl);
@@ -151,81 +152,81 @@ MinimumDiameter::getSupportingSegment() {
LineString*
MinimumDiameter::getDiameter()
- // return empty linestring if no minimum width calculated
- if (minWidthPt==nullptr)
- return inputGeom->getFactory()->createLineString(nullptr);
- Coordinate basePt;
- minBaseSeg->project(*minWidthPt, basePt);
- CoordinateSequence* cl=inputGeom->getFactory()->getCoordinateSequenceFactory()->create();
- cl->add(basePt);
- cl->add(*minWidthPt);
- return inputGeom->getFactory()->createLineString(cl);
+ // return empty linestring if no minimum width calculated
+ if(minWidthPt == nullptr) {
+ return inputGeom->getFactory()->createLineString(nullptr);
+ Coordinate basePt;
+ minBaseSeg->project(*minWidthPt, basePt);
+ CoordinateSequence* cl = inputGeom->getFactory()->getCoordinateSequenceFactory()->create();
+ cl->add(basePt);
+ cl->add(*minWidthPt);
+ return inputGeom->getFactory()->createLineString(cl);
/* private */
void
MinimumDiameter::computeMinimumDiameter()
- // check if computation is cached
- if (minWidthPt!=nullptr)
- return;
- if (isConvex)
- computeWidthConvex(inputGeom);
- else {
- ConvexHull ch(inputGeom);
- Geometry* convexGeom=ch.getConvexHull();
- computeWidthConvex(convexGeom);
- delete convexGeom;
+ // check if computation is cached
+ if(minWidthPt != nullptr) {
+ return;
+ if(isConvex) {
+ computeWidthConvex(inputGeom);
+ else {
+ ConvexHull ch(inputGeom);
+ Geometry* convexGeom = ch.getConvexHull();
+ computeWidthConvex(convexGeom);
+ delete convexGeom;
/* private */
void
-MinimumDiameter::computeWidthConvex(const Geometry *geom)
+MinimumDiameter::computeWidthConvex(const Geometry* geom)
- //System.out.println("Input = " + geom);
- if (typeid(*geom)==typeid(Polygon))
- const Polygon* p = dynamic_cast<const Polygon*>(geom);
- convexHullPts=p->getExteriorRing()->getCoordinates();
- else
- convexHullPts=geom->getCoordinates();
- // special cases for lines or points or degenerate rings
- switch(convexHullPts->getSize())
- case 0:
- minWidth=0.0;
- minBaseSeg=nullptr;
- break;
- case 1:
- minWidth = 0.0;
- minWidthPt=new Coordinate(convexHullPts->getAt(0));
- minBaseSeg->p0=convexHullPts->getAt(0);
- minBaseSeg->p1=convexHullPts->getAt(0);
- break;
- case 2:
- case 3:
- minWidth = 0.0;
- minBaseSeg->p1=convexHullPts->getAt(1);
- break;
- default:
- computeConvexRingMinDiameter(convexHullPts);
+ //System.out.println("Input = " + geom);
+ if(typeid(*geom) == typeid(Polygon)) {
+ const Polygon* p = dynamic_cast<const Polygon*>(geom);
+ convexHullPts = p->getExteriorRing()->getCoordinates();
+ else {
+ convexHullPts = geom->getCoordinates();
+ // special cases for lines or points or degenerate rings
+ switch(convexHullPts->getSize()) {
+ case 0:
+ minWidth = 0.0;
+ minBaseSeg = nullptr;
+ break;
+ case 1:
+ minWidth = 0.0;
+ minWidthPt = new Coordinate(convexHullPts->getAt(0));
+ minBaseSeg->p0 = convexHullPts->getAt(0);
+ minBaseSeg->p1 = convexHullPts->getAt(0);
+ break;
+ case 2:
+ case 3:
+ minWidth = 0.0;
+ minBaseSeg->p1 = convexHullPts->getAt(1);
+ break;
+ default:
+ computeConvexRingMinDiameter(convexHullPts);
@@ -238,159 +239,173 @@ MinimumDiameter::computeWidthConvex(const Geometry *geom)
void
MinimumDiameter::computeConvexRingMinDiameter(const CoordinateSequence* pts)
- minWidth=DoubleMax;
- unsigned int currMaxIndex=1;
- LineSegment seg;
- // compute the max distance for all segments in the ring, and pick the minimum
- const std::size_t npts=pts->getSize();
- for (std::size_t i=1; i<npts; ++i) {
- seg.p0=pts->getAt(i-1);
- seg.p1=pts->getAt(i);
- currMaxIndex=findMaxPerpDistance(pts, &seg, currMaxIndex);
+ minWidth = DoubleMax;
+ unsigned int currMaxIndex = 1;
+ LineSegment seg;
+ // compute the max distance for all segments in the ring, and pick the minimum
+ const std::size_t npts = pts->getSize();
+ for(std::size_t i = 1; i < npts; ++i) {
+ seg.p0 = pts->getAt(i - 1);
+ seg.p1 = pts->getAt(i);
+ currMaxIndex = findMaxPerpDistance(pts, &seg, currMaxIndex);
unsigned int
-MinimumDiameter::findMaxPerpDistance(const CoordinateSequence *pts,
- LineSegment* seg, unsigned int startIndex)
+MinimumDiameter::findMaxPerpDistance(const CoordinateSequence* pts,
+ LineSegment* seg, unsigned int startIndex)
- double maxPerpDistance=seg->distancePerpendicular(pts->getAt(startIndex));
- double nextPerpDistance = maxPerpDistance;
- unsigned int maxIndex = startIndex;
- unsigned int nextIndex = maxIndex;
- while (nextPerpDistance >= maxPerpDistance) {
- maxPerpDistance = nextPerpDistance;
- maxIndex=nextIndex;
- nextIndex=getNextIndex(pts, maxIndex);
- nextPerpDistance = seg->distancePerpendicular(pts->getAt(nextIndex));
- // found maximum width for this segment - update global min dist if appropriate
- if (maxPerpDistance < minWidth) {
- minPtIndex = maxIndex;
- minWidth = maxPerpDistance;
- minWidthPt = new Coordinate(pts->getAt(minPtIndex));
- minBaseSeg = new LineSegment(*seg);
+ double maxPerpDistance = seg->distancePerpendicular(pts->getAt(startIndex));
+ double nextPerpDistance = maxPerpDistance;
+ unsigned int maxIndex = startIndex;
+ unsigned int nextIndex = maxIndex;
+ while(nextPerpDistance >= maxPerpDistance) {
+ maxPerpDistance = nextPerpDistance;
+ maxIndex = nextIndex;
+ nextIndex = getNextIndex(pts, maxIndex);
+ nextPerpDistance = seg->distancePerpendicular(pts->getAt(nextIndex));
+ // found maximum width for this segment - update global min dist if appropriate
+ if(maxPerpDistance < minWidth) {
+ minPtIndex = maxIndex;
+ minWidth = maxPerpDistance;
+ minWidthPt = new Coordinate(pts->getAt(minPtIndex));
+ minBaseSeg = new LineSegment(*seg);
// System.out.println(minBaseSeg);
// System.out.println(minWidth);
- return maxIndex;
+ return maxIndex;
unsigned int
-MinimumDiameter::getNextIndex(const CoordinateSequence *pts,
- unsigned int index)
+MinimumDiameter::getNextIndex(const CoordinateSequence* pts,
+ unsigned int index)
- if (++index >= pts->getSize()) index = 0;
- return index;
+ if(++index >= pts->getSize()) {
+ index = 0;
+ return index;
-Geometry* MinimumDiameter::getMinimumRectangle()
+Geometry*
+MinimumDiameter::getMinimumRectangle()
- if ( !minBaseSeg || !convexHullPts )
- //return empty polygon
- return inputGeom->getFactory()->createPolygon();
- // check if minimum rectangle is degenerate (a point or line segment)
- if (minWidth == 0.0) {
- if (minBaseSeg->p0.equals2D(minBaseSeg->p1)) {
- return inputGeom->getFactory()->createPoint(minBaseSeg->p0);
- return minBaseSeg->toGeometry(*inputGeom->getFactory()).release();
- // deltas for the base segment of the minimum diameter
- double dx = minBaseSeg->p1.x - minBaseSeg->p0.x;
- double dy = minBaseSeg->p1.y - minBaseSeg->p0.y;
- double minPara = DoubleMax;
- double maxPara = -DoubleMax;
- double minPerp = DoubleMax;
- double maxPerp = -DoubleMax;
- // compute maxima and minima of lines parallel and perpendicular to base segment
- std::size_t const n=convexHullPts->getSize();
- for (std::size_t i = 0; i < n; ++i) {
- double paraC = computeC(dx, dy, convexHullPts->getAt(i));
- if (paraC > maxPara) maxPara = paraC;
- if (paraC < minPara) minPara = paraC;
- double perpC = computeC(-dy, dx, convexHullPts->getAt(i));
- if (perpC > maxPerp) maxPerp = perpC;
- if (perpC < minPerp) minPerp = perpC;
- // compute lines along edges of minimum rectangle
- LineSegment maxPerpLine = computeSegmentForLine(-dx, -dy, maxPerp);
- LineSegment minPerpLine = computeSegmentForLine(-dx, -dy, minPerp);
- LineSegment maxParaLine = computeSegmentForLine(-dy, dx, maxPara);
- LineSegment minParaLine = computeSegmentForLine(-dy, dx, minPara);
- // compute vertices of rectangle (where the para/perp max & min lines intersect)
- Coordinate p0, p1, p2, p3;
- maxParaLine.lineIntersection(maxPerpLine, p0);
- minParaLine.lineIntersection(maxPerpLine, p1);
- minParaLine.lineIntersection(minPerpLine, p2);
- maxParaLine.lineIntersection(minPerpLine, p3);
- const CoordinateSequenceFactory *csf =
- inputGeom->getFactory()->getCoordinateSequenceFactory();
- geom::CoordinateSequence *seq = csf->create(5, 2);
- seq->setAt(p0, 0);
- seq->setAt(p1, 1);
- seq->setAt(p2, 2);
- seq->setAt(p3, 3);
- seq->setAt(p0, 4); // close
- LinearRing* shell = inputGeom->getFactory()->createLinearRing( seq );
- return inputGeom->getFactory()->createPolygon( shell, nullptr );
+ if(!minBaseSeg || !convexHullPts) {
+ //return empty polygon
+ return inputGeom->getFactory()->createPolygon();
+ // check if minimum rectangle is degenerate (a point or line segment)
+ if(minWidth == 0.0) {
+ if(minBaseSeg->p0.equals2D(minBaseSeg->p1)) {
+ return inputGeom->getFactory()->createPoint(minBaseSeg->p0);
+ return minBaseSeg->toGeometry(*inputGeom->getFactory()).release();
+ // deltas for the base segment of the minimum diameter
+ double dx = minBaseSeg->p1.x - minBaseSeg->p0.x;
+ double dy = minBaseSeg->p1.y - minBaseSeg->p0.y;
+ double minPara = DoubleMax;
+ double maxPara = -DoubleMax;
+ double minPerp = DoubleMax;
+ double maxPerp = -DoubleMax;
+ // compute maxima and minima of lines parallel and perpendicular to base segment
+ std::size_t const n = convexHullPts->getSize();
+ for(std::size_t i = 0; i < n; ++i) {
+ double paraC = computeC(dx, dy, convexHullPts->getAt(i));
+ if(paraC > maxPara) {
+ maxPara = paraC;
+ if(paraC < minPara) {
+ minPara = paraC;
+ double perpC = computeC(-dy, dx, convexHullPts->getAt(i));
+ if(perpC > maxPerp) {
+ maxPerp = perpC;
+ if(perpC < minPerp) {
+ minPerp = perpC;
+ // compute lines along edges of minimum rectangle
+ LineSegment maxPerpLine = computeSegmentForLine(-dx, -dy, maxPerp);
+ LineSegment minPerpLine = computeSegmentForLine(-dx, -dy, minPerp);
+ LineSegment maxParaLine = computeSegmentForLine(-dy, dx, maxPara);
+ LineSegment minParaLine = computeSegmentForLine(-dy, dx, minPara);
+ // compute vertices of rectangle (where the para/perp max & min lines intersect)
+ Coordinate p0, p1, p2, p3;
+ maxParaLine.lineIntersection(maxPerpLine, p0);
+ minParaLine.lineIntersection(maxPerpLine, p1);
+ minParaLine.lineIntersection(minPerpLine, p2);
+ maxParaLine.lineIntersection(minPerpLine, p3);
+ const CoordinateSequenceFactory* csf =
+ inputGeom->getFactory()->getCoordinateSequenceFactory();
+ geom::CoordinateSequence* seq = csf->create(5, 2);
+ seq->setAt(p0, 0);
+ seq->setAt(p1, 1);
+ seq->setAt(p2, 2);
+ seq->setAt(p3, 3);
+ seq->setAt(p0, 4); // close
+ LinearRing* shell = inputGeom->getFactory()->createLinearRing(seq);
+ return inputGeom->getFactory()->createPolygon(shell, nullptr);
-double MinimumDiameter::computeC(double a, double b, const Coordinate& p)
+double
+MinimumDiameter::computeC(double a, double b, const Coordinate& p)
- return a * p.y - b * p.x;
+ return a * p.y - b * p.x;
-LineSegment MinimumDiameter::computeSegmentForLine(double a, double b, double c)
+LineSegment
+MinimumDiameter::computeSegmentForLine(double a, double b, double c)
- Coordinate p0;
- Coordinate p1;
- * Line eqn is ax + by = c
- * Slope is a/b.
- * If slope is steep, use y values as the inputs
- if (fabs(b) > fabs(a) ) {
- p0 = Coordinate(0.0, c/b);
- p1 = Coordinate(1.0, c/b - a/b);
- else {
- p0 = Coordinate(c/a, 0.0);
- p1 = Coordinate(c/a - b/a, 1.0);
- return LineSegment(p0, p1);
+ Coordinate p0;
+ Coordinate p1;
+ * Line eqn is ax + by = c
+ * Slope is a/b.
+ * If slope is steep, use y values as the inputs
+ if(fabs(b) > fabs(a)) {
+ p0 = Coordinate(0.0, c / b);
+ p1 = Coordinate(1.0, c / b - a / b);
+ else {
+ p0 = Coordinate(c / a, 0.0);
+ p1 = Coordinate(c / a - b / a, 1.0);
+ return LineSegment(p0, p1);
-Geometry *MinimumDiameter::getMinimumRectangle(Geometry *geom)
+Geometry*
+MinimumDiameter::getMinimumRectangle(Geometry* geom)
- MinimumDiameter md( geom );
- return md.getMinimumRectangle();
+ MinimumDiameter md(geom);
+ return md.getMinimumRectangle();
-Geometry *MinimumDiameter::getMinimumDiameter(Geometry *geom)
+Geometry*
+MinimumDiameter::getMinimumDiameter(Geometry* geom)
- return md.getDiameter();
+ return md.getDiameter();
diff --git a/src/algorithm/NotRepresentableException.cpp b/src/algorithm/NotRepresentableException.cpp
index 311107f..2ca729c 100644
--- a/src/algorithm/NotRepresentableException.cpp
+++ b/src/algorithm/NotRepresentableException.cpp
@@ -20,18 +20,18 @@ namespace geos {
NotRepresentableException::NotRepresentableException()
- GEOSException(
- "NotRepresentableException",
- "Projective point not representable on the Cartesian plane.")
+ GEOSException(
+ "NotRepresentableException",
+ "Projective point not representable on the Cartesian plane.")
NotRepresentableException::NotRepresentableException(std::string msg)
- GEOSException(
- "NotRepresentableException", msg)
+ GEOSException(
+ "NotRepresentableException", msg)
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index de1d7bd..a2139b5 100644
--- a/src/algorithm/Orientation.cpp
+++ b/src/algorithm/Orientation.cpp
@@ -31,30 +31,30 @@ namespace algorithm { // geos.algorithm
/* public static */
int
-Orientation::index(const geom::Coordinate &p1, const geom::Coordinate &p2,
- const geom::Coordinate &q)
+Orientation::index(const geom::Coordinate& p1, const geom::Coordinate& p2,
+ const geom::Coordinate& q)
return CGAlgorithmsDD::orientationIndex(p1, p2, q);
/* public static */
bool
-Orientation::isCCW(const geom::CoordinateSequence *ring)
+Orientation::isCCW(const geom::CoordinateSequence* ring)
// sanity check
- if (ring->getSize() < 4) {
+ if(ring->getSize() < 4) {
throw util::IllegalArgumentException("Ring has fewer than 4 points, so orientation cannot be determined");
// # of points without closing endpoint
- const std::size_t nPts = ring->getSize()-1;
+ const std::size_t nPts = ring->getSize() - 1;
// find highest point
- const geom::Coordinate *hiPt = &ring->getAt(0);
+ const geom::Coordinate* hiPt = &ring->getAt(0);
size_t hiIndex = 0;
- for (std::size_t i = 1; i <= nPts; ++i) {
- const geom::Coordinate *p = &ring->getAt(i);
- if (p->y > hiPt->y) {
+ for(std::size_t i = 1; i <= nPts; ++i) {
+ const geom::Coordinate* p = &ring->getAt(i);
+ if(p->y > hiPt->y) {
hiPt = p;
hiIndex = i;
@@ -63,21 +63,22 @@ Orientation::isCCW(const geom::CoordinateSequence *ring)
// find distinct point before highest point
auto iPrev = hiIndex;
do {
- if (iPrev == 0)
+ if(iPrev == 0) {
iPrev = nPts;
iPrev = iPrev - 1;
- while (ring->getAt(iPrev) == *hiPt && iPrev != hiIndex);
+ while(ring->getAt(iPrev) == *hiPt && iPrev != hiIndex);
// find distinct point after highest point
auto iNext = hiIndex;
do {
iNext = (iNext + 1) % nPts;
- while (ring->getAt(iNext)==*hiPt && iNext != hiIndex);
+ while(ring->getAt(iNext) == *hiPt && iNext != hiIndex);
- const geom::Coordinate *prev=&ring->getAt(iPrev);
- const geom::Coordinate *next=&ring->getAt(iNext);
+ const geom::Coordinate* prev = &ring->getAt(iPrev);
+ const geom::Coordinate* next = &ring->getAt(iNext);
* This check catches cases where the ring contains an A-B-A
@@ -86,8 +87,8 @@ Orientation::isCCW(const geom::CoordinateSequence *ring)
* (including the case where the input array has fewer than 4 elements),
* or it contains coincident line segments.
- if (prev->equals2D(*hiPt) || next->equals2D(*hiPt) ||
- prev->equals2D(*next)) {
+ if(prev->equals2D(*hiPt) || next->equals2D(*hiPt) ||
+ prev->equals2D(*next)) {
return false;
// MD - don't bother throwing exception,
// since this isn't a complete check for ring validity
@@ -108,7 +109,7 @@ Orientation::isCCW(const geom::CoordinateSequence *ring)
bool isCCW = false;
- if (disc == 0) {
+ if(disc == 0) {
// poly is CCW if prev x is right of next x
isCCW = (prev->x > next->x);
diff --git a/src/algorithm/PointLocation.cpp b/src/algorithm/PointLocation.cpp
index 682c0c1..03dd7cf 100644
--- a/src/algorithm/PointLocation.cpp
+++ b/src/algorithm/PointLocation.cpp
@@ -35,15 +35,16 @@ bool
PointLocation::isOnLine(const geom::Coordinate& p, const geom::CoordinateSequence* pt)
size_t ptsize = pt->getSize();
- if (ptsize == 0)
+ if(ptsize == 0) {
return false;
- const geom::Coordinate *pp = &(pt->getAt(0));
- for(size_t i = 1; i < ptsize; ++i)
- const geom::Coordinate &p1 = pt->getAt(i);
- if (LineIntersector::hasIntersection(p, *pp, p1))
+ const geom::Coordinate* pp = &(pt->getAt(0));
+ for(size_t i = 1; i < ptsize; ++i) {
+ const geom::Coordinate& p1 = pt->getAt(i);
+ if(LineIntersector::hasIntersection(p, *pp, p1)) {
return true;
pp = &p1;
return false;
@@ -51,32 +52,32 @@ PointLocation::isOnLine(const geom::Coordinate& p, const geom::CoordinateSequenc
/* public static */
bool
-PointLocation::isInRing(const geom::Coordinate &p,
- const std::vector<const geom::Coordinate*> &ring)
+PointLocation::isInRing(const geom::Coordinate& p,
+ const std::vector<const geom::Coordinate*>& ring)
return PointLocation::locateInRing(p, ring) != geom::Location::EXTERIOR;
/* public static */
bool
- const geom::CoordinateSequence *ring)
+ const geom::CoordinateSequence* ring)
return PointLocation::locateInRing(p, *ring) != geom::Location::EXTERIOR;
/* public static */
int
-PointLocation::locateInRing(const geom::Coordinate &p,
+PointLocation::locateInRing(const geom::Coordinate& p,
return RayCrossingCounter::locatePointInRing(p, ring);
/* public static */
int
- const geom::CoordinateSequence &ring)
+ const geom::CoordinateSequence& ring)
diff --git a/src/algorithm/PointLocator.cpp b/src/algorithm/PointLocator.cpp
index ff57507..a32143f 100644
--- a/src/algorithm/PointLocator.cpp
+++ b/src/algorithm/PointLocator.cpp
@@ -39,69 +39,70 @@ namespace algorithm { // geos.algorithm
int
-PointLocator::locate(const Coordinate& p, const Geometry *geom)
+PointLocator::locate(const Coordinate& p, const Geometry* geom)
- if (geom->isEmpty()) return Location::EXTERIOR;
+ if(geom->isEmpty()) {
+ return Location::EXTERIOR;
- const LineString *ls_geom = dynamic_cast<const LineString *>(geom);
- if (ls_geom) return locate(p, ls_geom);
+ const LineString* ls_geom = dynamic_cast<const LineString*>(geom);
+ if(ls_geom) {
+ return locate(p, ls_geom);
- const Polygon *poly_geom = dynamic_cast<const Polygon *>(geom);
- if (poly_geom) return locate(p, poly_geom);
+ const Polygon* poly_geom = dynamic_cast<const Polygon*>(geom);
+ if(poly_geom) {
+ return locate(p, poly_geom);
- isIn=false;
- numBoundaries=0;
- computeLocation(p,geom);
- if (geomgraph::GeometryGraph::isInBoundary(numBoundaries)) return Location::BOUNDARY;
- if (numBoundaries>0 || isIn) return Location::INTERIOR;
- return Location::EXTERIOR;
+ isIn = false;
+ numBoundaries = 0;
+ computeLocation(p, geom);
+ if(geomgraph::GeometryGraph::isInBoundary(numBoundaries)) {
+ return Location::BOUNDARY;
+ if(numBoundaries > 0 || isIn) {
+ return Location::INTERIOR;
/* private */
void
-PointLocator::computeLocation(const Coordinate& p, const Geometry *geom)
+PointLocator::computeLocation(const Coordinate& p, const Geometry* geom)
- if (const Point *pt=dynamic_cast<const Point*>(geom))
- updateLocationInfo(locate(p, pt));
- else if (const LineString *ls=dynamic_cast<const LineString*>(geom))
- updateLocationInfo(locate(p, ls));
- else if (const Polygon *po=dynamic_cast<const Polygon*>(geom))
- updateLocationInfo(locate(p, po));
- else if (const MultiLineString *mls=dynamic_cast<const MultiLineString *>(geom))
- for(std::size_t i=0, n=mls->getNumGeometries(); i<n; ++i)
- const LineString *l=dynamic_cast<const LineString *>(mls->getGeometryN(i));
- updateLocationInfo(locate(p,l));
- else if (const MultiPolygon *mpo=dynamic_cast<const MultiPolygon *>(geom))
- for(std::size_t i=0, n=mpo->getNumGeometries(); i<n; ++i)
- const Polygon *p_po=dynamic_cast<const Polygon *>(
