[geos-commits] [SCM] GEOS branch master updated. d4b4def27b34dd8811af7cbee7b74f2f902217f7
Thu Feb 14 15:35:53 PST 2019
the project "GEOS".
       via  d4b4def27b34dd8811af7cbee7b74f2f902217f7 (commit)
      from  8d02a094bc8e3b661bf9bb0a9b0a648f0a73a362 (commit)
revisions in full, below.
commit d4b4def27b34dd8811af7cbee7b74f2f902217f7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Feb 14 15:35:40 2019 -0800
    Remove vestigial references to io/markup
diff --git a/src/io/Makefile.am b/src/io/Makefile.am
index a45ea4e..a94cb10 100644
--- a/src/io/Makefile.am
+++ b/src/io/Makefile.am
@@ -1,11 +1,10 @@
-# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
-#SUBDIRS = markup
 noinst_LTLIBRARIES = libio.la
-AM_CPPFLAGS = -I$(top_srcdir)/include
+AM_CPPFLAGS = -I$(top_srcdir)/include
 libio_la_SOURCES = \
 	ParseException.cpp \
@@ -20,4 +19,4 @@ libio_la_SOURCES = \
 	Unload.cpp \
 	CLocalizer.cpp
-libio_la_LIBADD =
+libio_la_LIBADD =
diff --git a/tests/bigtest/CMakeLists.txt b/tests/bigtest/CMakeLists.txt
index 9734b38..d4e25fa 100644
--- a/tests/bigtest/CMakeLists.txt
+++ b/tests/bigtest/CMakeLists.txt
@@ -17,7 +17,6 @@ set(STATUS_RESULT "OFF")
 if(GEOS_ENABLE_TESTS)
   include_directories(${CMAKE_CURRENT_SOURCE_DIR})
-  include_directories(${CMAKE_CURRENT_SOURCE_DIR}/src/io/markup)
   add_executable(test_bug234 bug234.cpp)
diff --git a/tests/bigtest/Makefile.am b/tests/bigtest/Makefile.am
index a502df3..b06e4e0 100644
--- a/tests/bigtest/Makefile.am
+++ b/tests/bigtest/Makefile.am
@@ -1,5 +1,5 @@
 prefix=@prefix@
 top_srcdir=@top_srcdir@
@@ -18,7 +18,6 @@ bug234_SOURCES = bug234.cpp
 bug234_LDADD = $(LIBS)
-AM_CPPFLAGS += -I$(top_srcdir)/src/io/markup
 EXTRA_DIST = CMakeLists.txt
diff --git a/tests/perf/operation/buffer/CMakeLists.txt b/tests/perf/operation/buffer/CMakeLists.txt
index da2840a..57d2bd4 100644
--- a/tests/perf/operation/buffer/CMakeLists.txt
+++ b/tests/perf/operation/buffer/CMakeLists.txt
@@ -11,8 +11,6 @@
-include_directories(${CMAKE_CURRENT_SOURCE_DIR}/src/io/markup)
 add_executable(perf_iterated_buffer IteratedBufferStressTest.cpp)
 target_link_libraries(perf_iterated_buffer geos)
diff --git a/tests/perf/operation/buffer/Makefile.am b/tests/perf/operation/buffer/Makefile.am
index 8f1574e..f270b5f 100644
--- a/tests/perf/operation/buffer/Makefile.am
+++ b/tests/perf/operation/buffer/Makefile.am
@@ -13,6 +13,5 @@ IteratedBufferStressTest_SOURCES = IteratedBufferStressTest.cpp
 IteratedBufferStressTest_LDADD = $(LIBS)
diff --git a/tests/perf/operation/predicate/CMakeLists.txt b/tests/perf/operation/predicate/CMakeLists.txt
index 71e9f51..4260149 100644
--- a/tests/perf/operation/predicate/CMakeLists.txt
+++ b/tests/perf/operation/predicate/CMakeLists.txt
@@ -11,7 +11,6 @@
 add_executable(perf_rectangle_intersects RectangleIntersectsPerfTest.cpp)
diff --git a/tests/perf/operation/predicate/Makefile.am b/tests/perf/operation/predicate/Makefile.am
index 4c7cd20..621456e 100644
--- a/tests/perf/operation/predicate/Makefile.am
+++ b/tests/perf/operation/predicate/Makefile.am
@@ -13,6 +13,5 @@ RectangleIntersectsPerfTest_SOURCES = RectangleIntersectsPerfTest.cpp
 RectangleIntersectsPerfTest_LDADD = $(LIBS)
Summary of changes:
 src/io/Makefile.am                            | 7 +++----
 tests/bigtest/CMakeLists.txt                  | 1 -
 tests/bigtest/Makefile.am                     | 3 +--
 tests/perf/operation/buffer/CMakeLists.txt    | 2 --
 tests/perf/operation/buffer/Makefile.am       | 1 -
 tests/perf/operation/predicate/CMakeLists.txt | 1 -
 tests/perf/operation/predicate/Makefile.am    | 1 -
 7 files changed, 4 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
