[geos-commits] [SCM] GEOS branch master updated. 314960229dc44d5379aed57aed94c5190384c883
git at osgeo.org
git at osgeo.org
Fri Feb 15 15:23:53 PST 2019
the project "GEOS".
via 314960229dc44d5379aed57aed94c5190384c883 (commit)
from d4b4def27b34dd8811af7cbee7b74f2f902217f7 (commit)
revisions in full, below.
commit 314960229dc44d5379aed57aed94c5190384c883
Author: mdavis <mtnclimb at gmail.com>
Date: Fri Feb 15 15:23:53 2019 -0800
Add InteriorPoint Area perf test, Profile enhancement (#63)
diff --git a/include/geos/profiler.h b/include/geos/profiler.h
index 853d598..c447704 100644
--- a/include/geos/profiler.h
+++ b/include/geos/profiler.h
@@ -112,6 +112,9 @@ public:
/** \brief Return total timing */
double getTot() const;
+ /** \brief Return total timing */
+ std::string getTotFormatted() const;
/** \brief Return average timing */
double getAvg() const;
diff --git a/src/util/Profiler.cpp b/src/util/Profiler.cpp
index f3b7ca2..a8cb156 100644
--- a/src/util/Profiler.cpp
+++ b/src/util/Profiler.cpp
@@ -58,6 +58,19 @@ Profile::getTot() const
return totaltime;
+std::string
+Profile::getTotFormatted() const
+ long usec = (long) totaltime;
+ std::string fmt = to_string(usec);
+ int insertPosition = fmt.length() - 3;
+ while (insertPosition > 0) {
+ fmt.insert(insertPosition, ",");
+ insertPosition-=3;
+ return fmt + " usec";
size_t
Profile::getNumTimings() const
diff --git a/tests/perf/CMakeLists.txt b/tests/perf/CMakeLists.txt
index 4354dee..78c55ad 100644
--- a/tests/perf/CMakeLists.txt
+++ b/tests/perf/CMakeLists.txt
@@ -24,6 +24,7 @@ if(GEOS_ENABLE_TESTS)
# add_test(perf_class_sizes ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_class_sizes)
+ add_subdirectory(algorithm)
add_subdirectory(operation)
add_subdirectory(capi)
diff --git a/tests/perf/algorithm/CMakeLists.txt b/tests/perf/algorithm/CMakeLists.txt
new file mode 100644
index 0000000..7272dd0
--- /dev/null
+++ b/tests/perf/algorithm/CMakeLists.txt
@@ -0,0 +1,17 @@
+# CMake configuration for GEOS perf/operation/predicate tests
+# Copyright (C) 2017 Mateusz Loskot <mateusz at loskot.net>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU Lesser General Public Licence as published
+# by the Free Software Foundation.
+# See the COPYING file for more information.
+add_executable(perf_interiorpoint_area InteriorPointAreaPerfTest.cpp)
+target_link_libraries(perf_interiorpoint_area geos)
diff --git a/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp b/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
index 0000000..1381265
--- /dev/null
+++ b/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
@@ -0,0 +1,139 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2011 Sandro Santilli <strk at kbt.io>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: perf/operation/predicate/RectangleIntersectsPerfTest.java r378 (JTS-1.12)
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/util/GeometricShapeFactory.h>
+#include <geos/precision/SimpleGeometryPrecisionReducer.h>
+#include <geos/geom/util/SineStarFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/Point.h>
+#include <geos/profiler.h>
+#include <iostream>
+#include <vector>
+#include <cmath>
+#include <sstream>
+#include <memory>
+using namespace geos::geom;
+using namespace geos::io;
+using namespace std;
+class InteriorPointAreaPerfTest {
+public:
+ InteriorPointAreaPerfTest()
+ pm(),
+ fact(GeometryFactory::create(&pm, 0))
+ showHeader();
+ void
+ test(int nPts)
+ Coordinate origin(ORG_X, ORG_Y);
+ std::unique_ptr<Polygon> sinePoly =
+ createSineStar(origin, SIZE, nPts);
+ * Make the geometry "crinkly" by rounding off the points.
+ * This defeats the MonotoneChain optimization in the full relate
+ * algorithm, and provides a more realistic test.
+ using geos::precision::SimpleGeometryPrecisionReducer;
+ PrecisionModel p_pm(SIZE);
+ SimpleGeometryPrecisionReducer reducer(&p_pm);
+ std::unique_ptr<Geometry> sinePolyCrinkly(reducer.reduce(sinePoly.get()));
+ sinePoly.reset();
+ //cout << sinePolyCrinkly->toText() << endl;
+ test(*sinePolyCrinkly);
+ const double ORG_X = 100.0;
+ const double ORG_Y = 100.0;
+ const double SIZE = 100.0;
+ const int N_ARMS = 20;
+ const double ARM_RATIO = 0.3;
+ const int N_ITER = 100;
+private:
+ PrecisionModel pm;
+ GeometryFactory::Ptr fact;
+ void
+ showHeader() {
+ cout << "Interior Point Area perf test" << endl;
+ cout << "# Iterations: " << N_ITER << endl;
+ cout << "SineStar: origin: ("
+ << ORG_X << ", " << ORG_Y
+ << ") size: " << SIZE
+ << " # arms: " << N_ARMS
+ << " arm ratio: " << ARM_RATIO
+ << endl;
+ void
+ test(geos::geom::Geometry& poly)
+ typedef vector<const Geometry*>::size_type size_type;
+ geos::util::Profile sw("");
+ sw.start();
+ for(int i = 0; i < N_ITER; i++) {
+ std::unique_ptr<geos::geom::Point> pt( poly.getInteriorPoint() );
+ sw.stop();
+ cout << poly.getNumPoints() << " points: " << sw.getTotFormatted() << endl;
+ createSineStar(const Coordinate& origin,
+ double size, int nPts)
+ using geos::geom::util::SineStarFactory;
+ SineStarFactory gsf(fact.get());
+ gsf.setCentre(origin);
+ gsf.setSize(size);
+ gsf.setNumPoints(nPts);
+ gsf.setArmLengthRatio( ARM_RATIO );
+ gsf.setNumArms( N_ARMS );
+ std::unique_ptr<Polygon> poly = gsf.createSineStar();
+ return poly;
+int
+main()
+ InteriorPointAreaPerfTest tester;
+ tester.test(1000);
+ tester.test(10000);
+ tester.test(100000);
+ tester.test(1000000);
diff --git a/tests/perf/algorithm/Makefile.am b/tests/perf/algorithm/Makefile.am
index 0000000..d7560d6
--- /dev/null
+++ b/tests/perf/algorithm/Makefile.am
@@ -0,0 +1,18 @@
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+prefix=@prefix@
+top_srcdir=@top_srcdir@
+top_builddir=@top_builddir@
+noinst_PROGRAMS = InteriorPointAreaPerfTest
+LIBS = $(top_builddir)/src/libgeos.la
+InteriorPointAreaPerfTest_SOURCES = InteriorPointAreaPerfTest.cpp
+InteriorPointAreaPerfTest_LDADD = $(LIBS)
+AM_CPPFLAGS = -I$(top_srcdir)/include
+AM_CPPFLAGS += -I$(top_srcdir)/src/io/markup
+EXTRA_DIST = CMakeLists.txt
Summary of changes:
include/geos/profiler.h | 3 +
src/util/Profiler.cpp | 13 +++
tests/perf/CMakeLists.txt | 1 +
tests/perf/{operation => algorithm}/CMakeLists.txt | 8 +-
.../InteriorPointAreaPerfTest.cpp} | 107 ++++++++-------------
.../{operation/buffer => algorithm}/Makefile.am | 7 +-
6 files changed, 67 insertions(+), 72 deletions(-)
copy tests/perf/{operation => algorithm}/CMakeLists.txt (70%)
copy tests/perf/{operation/predicate/RectangleIntersectsPerfTest.cpp => algorithm/InteriorPointAreaPerfTest.cpp} (50%)
copy tests/perf/{operation/buffer => algorithm}/Makefile.am (55%)
hooks/post-receive
More information about the geos-commits
