[geos-commits] [SCM] GEOS branch master updated. bd4e378a3e0adec55a4e36fab001039fb72f3ce2
git at osgeo.org
git at osgeo.org
Thu Jul 25 19:26:41 PDT 2019
the project "GEOS".
via bd4e378a3e0adec55a4e36fab001039fb72f3ce2 (commit)
via 56417ce550e64eb4c1bf90f9959d74f34b6a296c (commit)
via 9520ab2f0fb036990271bcb70e0fcea3d4c671ea (commit)
via 92d9e66a58aaa2ef44412986d6fb83b5840d972e (commit)
via 8343c2cd19f5ce7bc729d97c3e79aea46c3de85c (commit)
via cc91e6dd19c9fb1884caa3ae052e02e0e2bdfcf8 (commit)
via ac9f3d5a6a669af6e49f21a7f5d2940488e8b1b8 (commit)
via c95d2b06c15ef81d94a2e8a782bd6875b7a69f50 (commit)
via 3e0ac6270eb5786b646efec5e2b7c85cb6de9633 (commit)
from 58fcec4990e79be7ab4a4300a3035cc73f203876 (commit)
revisions in full, below.
commit bd4e378a3e0adec55a4e36fab001039fb72f3ce2
Merge: 56417ce cc91e6d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Jul 25 15:03:12 2019 -0700
Merge branch 'jts-448' of github.com:pramsey/geos into jts-448
commit 56417ce550e64eb4c1bf90f9959d74f34b6a296c
Date: Thu Jul 25 13:43:02 2019 -0700
Add filter to only use DD math is we are in the "danger zone" for circumcenter, namely that we have a potential equally-sided right triangle on our hands.
diff --git a/include/geos/geom/Triangle.h b/include/geos/geom/Triangle.h
index fb93f8d..77cc51d 100644
--- a/include/geos/geom/Triangle.h
+++ b/include/geos/geom/Triangle.h
@@ -67,6 +67,8 @@ public:
void circumcentre(Coordinate& resultPoint);
void circumcentreDD(Coordinate& resultPoint);
+ bool isIsoceles();
static const Coordinate circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2);
private:
diff --git a/src/geom/Triangle.cpp b/src/geom/Triangle.cpp
index c495815..008fc28 100644
--- a/src/geom/Triangle.cpp
+++ b/src/geom/Triangle.cpp
@@ -20,6 +20,18 @@ namespace geos {
namespace geom { // geos::geom
+bool
+Triangle::isIsoceles()
+ double len0 = p1.distance(p2);
+ double len1 = p0.distance(p2);
+ double len2 = p0.distance(p1);
+ if (len0 == len1 || len1 == len2 || len2 == len0)
+ return true;
+ else
+ return false;
void
Triangle::inCentre(Coordinate& result)
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index a72c6ea..c4e32c0 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -421,7 +421,10 @@ public:
Triangle triangle(triEdges[0]->orig().getCoordinate(),
triEdges[1]->orig().getCoordinate(), triEdges[2]->orig().getCoordinate());
Coordinate cc;
- triangle.circumcentreDD(cc);
+ if (triangle.isIsoceles())
+ triangle.circumcentreDD(cc);
+ else
+ triangle.circumcentre(cc);
Vertex ccVertex(cc);
commit 9520ab2f0fb036990271bcb70e0fcea3d4c671ea
Date: Thu Jul 25 13:16:34 2019 -0700
Add actual test case
diff --git a/tests/unit/triangulate/VoronoiTest.cpp b/tests/unit/triangulate/VoronoiTest.cpp
index a7539db..3a6948e 100644
--- a/tests/unit/triangulate/VoronoiTest.cpp
+++ b/tests/unit/triangulate/VoronoiTest.cpp
@@ -12,6 +12,7 @@
#include <geos/io/WKTWriter.h>
#include <geos/io/WKTReader.h>
+#include <geos/io/WKBReader.h>
#include <geos/geom/GeometryCollection.h>
#include <geos/geom/GeometryFactory.h>
@@ -41,15 +42,29 @@ typedef group::object object;
group test_voronoidiag_group("geos::triangulate::Voronoi");
+std::unique_ptr<Geometry>
+readTextOrHex(const char* wkt)
+ WKTReader wktreader;
+ WKBReader wkbreader;
+ std::string wktstr(wkt);
+ if ("01" == wktstr.substr(0, 2) || "00" == wktstr.substr(0, 2))
+ std::stringstream is(wkt);
+ return wkbreader.readHEX(is);
+ else
+ return wktreader.read(wktstr);
//helper function for funning triangulation
void
runVoronoi(const char* sitesWkt, const char* expectedWkt, const double tolerance)
- WKTReader reader;
WKTWriter writer;
geos::triangulate::VoronoiDiagramBuilder builder;
- std::unique_ptr<Geometry> sites(reader.read(sitesWkt));
- std::unique_ptr<Geometry> expected(reader.read(expectedWkt));
+ std::unique_ptr<Geometry> sites(readTextOrHex(sitesWkt));
+ std::unique_ptr<Geometry> expected(readTextOrHex(expectedWkt));
std::unique_ptr<GeometryCollection> results;
const GeometryFactory& geomFact(*GeometryFactory::getDefaultInstance());
builder.setSites(*sites);
@@ -204,5 +219,19 @@ void object::test<9>
runVoronoi(wkt, expected, 100);
+//Validity issue and DD calculation
+template<>
+template<>
+void object::test<10>
+ const char* wkt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
1E856B85A51C414160E5D022DB354001010000807B14AE470BA20741B81E856B85A51C414160E5D022DB35400101000080A70D74DA08A20741B81E856B85A51C414160E5D022DB35400101000080D4063A6D06A20741B81E856B85A51C414160E5D022DB354001010000807B14AE470BA207411F85EB1184A51C414160E5D022DB35400101000080A70D74DA08A207411F85EB1184A51C414160E5D022DB35400101000080D4063A6D06A207411F85EB1184A51C414160E5D022DB3540";
+ const char* expected =
+ "GEOMETRYCOLLECTION EMPTY";
+ runVoronoi(wkt, expected, 100);
} // namespace tut
commit 92d9e66a58aaa2ef44412986d6fb83b5840d972e
Date: Thu Jul 25 12:17:25 2019 -0700
Fix up mistakes in drafting and add simple unit test
index 26f8f2d..fb93f8d 100644
@@ -65,6 +65,7 @@ public:
* @param resultPoint the point into which to write the inCentre of the triangle
+ void circumcentreDD(Coordinate& resultPoint);
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index f477285..7d884a9 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -196,18 +196,18 @@ CGAlgorithmsDD::intersection(const Coordinate& p1, const Coordinate& p2,
Coordinate
CGAlgorithmsDD::circumcentreDD(const Coordinate& a, const Coordinate& b, const Coordinate& c)
- DD ax = DD(a.x) + DD(-c.x);
- DD ay = DD(a.y) + DD(-c.y);
- DD bx = DD(b.x) + DD(-c.x);
- DD by = DD(b.y) + DD(-c.y);
+ DD ax = DD(a.x) - DD(c.x);
+ DD ay = DD(a.y) - DD(c.y);
+ DD bx = DD(b.x) - DD(c.x);
+ DD by = DD(b.y) - DD(c.y);
- DD denom = detDD(ax, ay, bx, by);
+ DD denom = DD(2) * detDD(ax, ay, bx, by);
DD asqr = (ax * ax) + (ay * ay);
DD bsqr = (bx * bx) + (by * by);
DD numx = detDD(ay, asqr, by, bsqr);
DD numy = detDD(ax, asqr, bx, bsqr);
double ccx = (DD(c.x) - (numx / denom)).ToDouble();
- double ccy = (DD(c.y) - (numy / denom)).ToDouble();
+ double ccy = (DD(c.y) + (numy / denom)).ToDouble();
Coordinate cc(ccx, ccy);
return cc;
index 6552745..c495815 100644
@@ -14,6 +14,7 @@
#include <geos/geom/Triangle.h>
#include <geos/geom/Coordinate.h>
+#include <geos/algorithm/CGAlgorithmsDD.h>
namespace geos {
@@ -53,6 +54,12 @@ Triangle::circumcentre(Coordinate& result)
result = Coordinate(ccx, ccy);
+void
+Triangle::circumcentreDD(Coordinate& result)
+ result = algorithm::CGAlgorithmsDD::circumcentreDD(p0, p1, p2);
/* public static */
const Coordinate
Triangle::circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2)
@@ -63,7 +70,7 @@ Triangle::circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordin
return c;
+/* private */
double
Triangle::det(double m00, double m01, double m10, double m11) const
index 6ea08b2..a72c6ea 100644
@@ -421,7 +421,7 @@ public:
Coordinate cc;
- triangle.circumcentre(cc);
diff --git a/src/util/math.cpp b/src/util/math.cpp
index 3931dc3..a154df6 100644
--- a/src/util/math.cpp
+++ b/src/util/math.cpp
@@ -12,7 +12,7 @@
-#include "geos/util.h"
+#include <geos/util.h>
#include <cmath>
namespace geos {
@@ -115,6 +115,7 @@ rint_vc(double val)
} // namespace geos.util
} // namespace geos
diff --git a/tests/unit/geom/TriangleTest.cpp b/tests/unit/geom/TriangleTest.cpp
index 0ab6511..c375819 100644
--- a/tests/unit/geom/TriangleTest.cpp
+++ b/tests/unit/geom/TriangleTest.cpp
@@ -6,6 +6,8 @@
// geos
// std
#include <cmath>
@@ -28,6 +30,7 @@ struct test_triangle_data {
test_triangle_data()
: a(3, 3), b(9, 3), c(6, 6), d(-4, -2), e(-8, -2), f(-4, -4)
typedef test_group<test_triangle_data> group;
@@ -173,4 +176,29 @@ void object::test<6>
// std::cout << "CicumCenter of triangle DEF:: " << c2.x << " " << c2.y << std::endl;
+// Test circumcentreDD()
+template<>
+template<>
+void object::test<7>
+ using geos::geom::Triangle;
+ using geos::geom::Coordinate;
+ using geos::algorithm::CGAlgorithmsDD;
+ Coordinate x1(193600.80333333334, 469345.355);
+ Coordinate x2(193600.80333333334, 469345.0175);
+ Coordinate x3(193601.10666666666, 469345.0175);
+ Coordinate y1(193600.80333333334, 469345.355);
+ Coordinate y2(193601.10666666666, 469345.0175);
+ Coordinate y3(193601.10666666666, 469345.355);
+ Coordinate cc1 = CGAlgorithmsDD::circumcentreDD(x1, x2, x3);
+ Coordinate cc2 = CGAlgorithmsDD::circumcentreDD(y1, y2, y3);
+ ensure(cc1 == cc2);
} // namespace tut
commit 8343c2cd19f5ce7bc729d97c3e79aea46c3de85c
Date: Wed Jul 24 15:05:53 2019 -0700
First draft of circumcenterDD support
from JTS https://github.com/locationtech/jts/pull/448
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index 8b2cb50..7f586f9 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -116,10 +116,35 @@ public:
static int signOfDet2x2(double dx1, double dy1, double dx2, double dy2);
+ static DD detDD(double x1, double y1, double x2, double y2);
+ static DD detDD(const DD& x1, const DD& y1, const DD& x2, const DD& y2);
+ * Computes the circumcentre of a triangle. The circumcentre is the centre of
+ * the circumcircle, the smallest circle which encloses the triangle. It is
+ * also the common intersection point of the perpendicular bisectors of the
+ * sides of the triangle, and is the only point which has equal distance to
+ * all three vertices of the triangle.
+ * <p>
+ * The circumcentre does not necessarily lie within the triangle. For example,
+ * the circumcentre of an obtuse isosceles triangle lies outside the triangle.
+ * <p>
+ * This method uses {@link DD} extended-precision arithmetic to
+ * provide more accurate results than {@link #circumcentre(Coordinate, Coordinate, Coordinate)}
+ * @param a
+ * a vertex of the triangle
+ * @param b
+ * @param c
+ * @return the circumcentre of the triangle
+ static geom::Coordinate circumcentreDD(const geom::Coordinate& a, const geom::Coordinate& b, const geom::Coordinate& c);
protected:
- static int signOfDet2x2(DD& x1, DD& y1, DD& x2, DD& y2);
+ static int signOfDet2x2(const DD& x1, const DD& y1, const DD& x2, const DD& y2);
index 2fe8a55..f477285 100644
@@ -87,7 +87,7 @@ CGAlgorithmsDD::orientationIndex(const Coordinate& p1,
int
-CGAlgorithmsDD::signOfDet2x2(DD& x1, DD& y1, DD& x2, DD& y2)
+CGAlgorithmsDD::signOfDet2x2(const DD& x1, const DD& y1, const DD& x2, const DD& y2)
DD mx1y2(x1 * y2);
DD my1x2(y1 * x2);
@@ -192,6 +192,39 @@ CGAlgorithmsDD::intersection(const Coordinate& p1, const Coordinate& p2,
rv.y = y.ToDouble();
+/* public static */
+Coordinate
+CGAlgorithmsDD::circumcentreDD(const Coordinate& a, const Coordinate& b, const Coordinate& c)
+ DD ax = DD(a.x) + DD(-c.x);
+ DD ay = DD(a.y) + DD(-c.y);
+ DD bx = DD(b.x) + DD(-c.x);
+ DD by = DD(b.y) + DD(-c.y);
+ DD denom = detDD(ax, ay, bx, by);
+ DD asqr = (ax * ax) + (ay * ay);
+ DD bsqr = (bx * bx) + (by * by);
+ DD numx = detDD(ay, asqr, by, bsqr);
+ DD numy = detDD(ax, asqr, bx, bsqr);
+ double ccx = (DD(c.x) - (numx / denom)).ToDouble();
+ double ccy = (DD(c.y) - (numy / denom)).ToDouble();
+ Coordinate cc(ccx, ccy);
+ return cc;
+DD
+CGAlgorithmsDD::detDD(double x1, double y1, double x2, double y2)
+ return detDD(DD(x1), DD(y1), DD(x2), DD(y2));
+DD
+CGAlgorithmsDD::detDD(const DD& x1, const DD& y1, const DD& x2, const DD& y2)
+ return (x1 * y2) - (y1 * x2);
} // namespace geos::algorithm
} // namespace geos
commit cc91e6dd19c9fb1884caa3ae052e02e0e2bdfcf8
private:
+bool
+ return true;
+ else
+ return false;
void
Coordinate cc;
+ else
commit ac9f3d5a6a669af6e49f21a7f5d2940488e8b1b8
@@ -12,6 +12,7 @@
+ else
void
- WKTReader reader;
WKTWriter writer;
+template<>
+template<>
} // namespace tut
commit c95d2b06c15ef81d94a2e8a782bd6875b7a69f50
Coordinate
return cc;
@@ -14,6 +14,7 @@
namespace geos {
+void
/* public static */
const Coordinate
return c;
+/* private */
double
Coordinate cc;
@@ -12,7 +12,7 @@
#include <cmath>
namespace geos {
} // namespace geos
@@ -6,6 +6,8 @@
// geos
// std
#include <cmath>
+template<>
+template<>
} // namespace tut
commit 3e0ac6270eb5786b646efec5e2b7c85cb6de9633
+ * <p>
+ * <p>
+ * @param a
+ * @param b
+ * @param c
protected:
int
DD mx1y2(x1 * y2);
DD my1x2(y1 * x2);
+Coordinate
+ return cc;
+DD
+DD
} // namespace geos
Summary of changes:
include/geos/algorithm/CGAlgorithmsDD.h | 27 +++++++++++++++++-
include/geos/geom/Triangle.h | 3 ++
src/algorithm/CGAlgorithmsDD.cpp | 35 +++++++++++++++++++++++-
src/geom/Triangle.cpp | 21 +++++++++++++-
src/triangulate/quadedge/QuadEdgeSubdivision.cpp | 5 +++-
src/util/math.cpp | 3 +-
tests/unit/geom/TriangleTest.cpp | 28 +++++++++++++++++++
tests/unit/triangulate/VoronoiTest.cpp | 35 ++++++++++++++++++++++--
8 files changed, 149 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits
