[geos-commits] [SCM] GEOS branch master updated. 3133734b73aec52c70643c41fc43f19cfb5f680f
git at osgeo.org
git at osgeo.org
Sat Jul 27 00:05:06 PDT 2019
the project "GEOS".
via 3133734b73aec52c70643c41fc43f19cfb5f680f (commit)
from bd4e378a3e0adec55a4e36fab001039fb72f3ce2 (commit)
revisions in full, below.
commit 3133734b73aec52c70643c41fc43f19cfb5f680f
Author: nila <n_larsson at yahoo.com>
Date: Sat Jul 27 00:46:14 2019 +0200
fix bad doxygen links
and in addition some minor stylistic changes to the comments
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index 7f586f9..258361b 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -21,8 +21,11 @@
#include <geos/export.h>
#include <geos/algorithm/ttmath/ttmath.h>
-// Close to DoubleDouble equivalent used by JTS
-// Usage: ttmath::Big<exponent, mantissa>
+/// \file CGAlgorithmsDD.h
+/// \brief Close to DoubleDouble equivalent used by JTS
+/// Usage: `ttmath::Big<exponent, mantissa>`
typedef ttmath::Big<TTMATH_BITS(32), TTMATH_BITS(128)> DD;
//typedef ttmath::Big<TTMATH_BITS(64), TTMATH_BITS(128)> DD;
//typedef ttmath::Big<TTMATH_BITS(32), TTMATH_BITS(256)> DD;
@@ -38,10 +41,8 @@ class CoordinateSequence;
namespace geos {
namespace algorithm { // geos::algorithm
-* \brief
-* Implements basic computational geometry algorithms using extended precision float-point arithmetic.
+/// Implements basic computational geometry algorithms using extended precision float-point arithmetic.
class GEOS_DLL CGAlgorithmsDD {
public:
@@ -59,9 +60,9 @@ public:
FAILURE = 2
- * Returns the index of the direction of the point <code>q</code> relative to
- * a vector specified by <code>p1-p2</code>.
+ /** \brief
+ * Returns the index of the direction of the point `q` relative to
+ * a vector specified by `p1-p2`.
* @param p1 the origin point of the vector
* @param p2 the final point of the vector
@@ -74,25 +75,25 @@ public:
static int orientationIndex(const geom::Coordinate& p1,
const geom::Coordinate& p2,
const geom::Coordinate& q);
- * A filter for computing the orientation index of three coordinates.
- * <p>
- * If the orientation can be computed safely using standard DP
- * arithmetic, this routine returns the orientation index.
- * Otherwise, a value i > 1 is returned.
- * In this case the orientation index must
- * be computed using some other more robust method.
- * The filter is fast to compute, so can be used to
- * avoid the use of slower robust methods except when they are really needed,
- * thus providing better average performance.
- * <p>
- * Uses an approach due to Jonathan Shewchuk, which is in the public domain.
- * @param pa a coordinate
- * @param pb a coordinate
- * @param pc a coordinate
- * @return the orientation index if it can be computed safely
- * @return i > 1 if the orientation index cannot be computed safely
+ /** \brief
+ * A filter for computing the orientation index of three coordinates.
+ * If the orientation can be computed safely using standard DP arithmetic,
+ * this routine returns the orientation index. Otherwise, a value `i > 1` is
+ * returned. In this case the orientation index must be computed using some
+ * other more robust method.
+ * The filter is fast to compute, so can be used to avoid the use of slower
+ * robust methods except when they are really needed, thus providing better
+ * average performance.
+ * Uses an approach due to Jonathan Shewchuk, which is in the public domain.
+ * @param pa a coordinate
+ * @param pb a coordinate
+ * @param pc a coordinate
+ * @return the orientation index if it can be computed safely
+ * @return `i > 1` if the orientation index cannot be computed safely
static int orientationIndexFilter(const geom::Coordinate& pa,
const geom::Coordinate& pb,
@@ -119,27 +120,29 @@ public:
static DD detDD(double x1, double y1, double x2, double y2);
static DD detDD(const DD& x1, const DD& y1, const DD& x2, const DD& y2);
- * Computes the circumcentre of a triangle. The circumcentre is the centre of
- * the circumcircle, the smallest circle which encloses the triangle. It is
- * also the common intersection point of the perpendicular bisectors of the
- * sides of the triangle, and is the only point which has equal distance to
- * all three vertices of the triangle.
- * <p>
- * The circumcentre does not necessarily lie within the triangle. For example,
- * the circumcentre of an obtuse isosceles triangle lies outside the triangle.
- * <p>
- * This method uses {@link DD} extended-precision arithmetic to
- * provide more accurate results than {@link #circumcentre(Coordinate, Coordinate, Coordinate)}
- * @param a
- * a vertex of the triangle
- * @param b
- * @param c
- * @return the circumcentre of the triangle
+ /** \brief
+ * Computes the circumcentre of a triangle.
+ * The circumcentre is the centre of the circumcircle, the smallest circle
+ * which encloses the triangle. It is also the common intersection point of
+ * the perpendicular bisectors of the sides of the triangle, and is the only
+ * point which has equal distance to all three vertices of the triangle.
+ * The circumcentre does not necessarily lie within the triangle. For example,
+ * the circumcentre of an obtuse isosceles triangle lies outside the triangle.
+ * This method uses @ref DD extended-precision arithmetic to provide more accurate
+ * results than [circumcentre(Coordinate, Coordinate, Coordinate)]
+ * (@ref geos::geom::Triangle::circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2)).
+ * @param a
+ * a vertex of the triangle
+ * @param b
+ * @param c
+ * @return the circumcentre of the triangle
static geom::Coordinate circumcentreDD(const geom::Coordinate& a, const geom::Coordinate& b, const geom::Coordinate& c);
protected:
diff --git a/include/geos/geom/Triangle.h b/include/geos/geom/Triangle.h
index 77cc51d..13cec65 100644
--- a/include/geos/geom/Triangle.h
+++ b/include/geos/geom/Triangle.h
@@ -39,28 +39,30 @@ public:
p2(nP2)
+ /** \brief
* The inCentre of a triangle is the point which is equidistant
- * from the sides of the triangle. This is also the point at which the bisectors
- * of the angles meet.
+ * from the sides of the triangle.
+ * This is also the point at which the bisectors of the angles meet.
* @param resultPoint the point into which to write the inCentre of the triangle
void inCentre(Coordinate& resultPoint);
- * <p>
+ /** \brief
* the circumcentre of an obtuse isoceles triangle lies outside the triangle.
- * <p>
* This method uses an algorithm due to J.R.Shewchuk which uses normalization
- * to the origin to improve the accuracy of computation. (See <i>Lecture Notes
- * on Geometric Robustness</i>, Jonathan Richard Shewchuk, 1999).
+ * to the origin to improve the accuracy of computation. (See *Lecture Notes
+ * on Geometric Robustness*, Jonathan Richard Shewchuk, 1999).
@@ -69,6 +71,7 @@ public:
bool isIsoceles();
+ /// Computes the circumcentre of a triangle.
static const Coordinate circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2);
private:
Summary of changes:
include/geos/algorithm/CGAlgorithmsDD.h | 101 ++++++++++++++++----------------
include/geos/geom/Triangle.h | 29 +++++----
2 files changed, 68 insertions(+), 62 deletions(-)
hooks/post-receive
More information about the geos-commits
