[geos-commits] [SCM] GEOS branch master updated. 8cb7ae530008835c8e74cc5461c15683a9642e50
git at osgeo.org
git at osgeo.org
Sun Jun 2 22:02:31 PDT 2019
the project "GEOS".
via 8cb7ae530008835c8e74cc5461c15683a9642e50 (commit)
via ab5b821dec0d233a64d5f915adca3b44473d5e1e (commit)
from 62a53152ea083e3c6e45db5893a950e97fa3dfd5 (commit)
revisions in full, below.
commit 8cb7ae530008835c8e74cc5461c15683a9642e50
Author: nila <n_larsson at yahoo.com>
Date: Thu May 30 18:13:10 2019 +0200
updated to Doxygen 1.8.14
diff --git a/doc/Doxyfile.in b/doc/Doxyfile.in
index 5798cc6..ef93b77 100644
--- a/doc/Doxyfile.in
+++ b/doc/Doxyfile.in
@@ -1,944 +1,2449 @@
-# Doxyfile 1.2.15
+# Doxyfile 1.8.14
# This file describes the settings to be used by the documentation system
-# doxygen (www.doxygen.org) for a project
+# doxygen (www.doxygen.org) for a project.
-# All text after a hash (#) is considered a comment and will be ignored
+# All text after a double hash (##) is considered a comment and is placed in
+# front of the TAG it is preceding.
+# All text after a single hash (#) is considered a comment and will be ignored.
# The format is:
-# TAG = value [value, ...]
-# For lists items can also be appended using:
-# TAG += value [value, ...]
-# Values that contain spaces should be placed between quotes (" ")
+# TAG = value [value, ...]
+# For lists, items can also be appended using:
+# TAG += value [value, ...]
+# Values that contain spaces should be placed between quotes (\" \").
-# General configuration options
+# Project related configuration options
-# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
-# by quotes) that should identify the project.
-PROJECT_NAME = GEOS
-# The PROJECT_NUMBER tag can be used to enter a project or revision number.
-# This could be handy for archiving the generated documentation or
-# if some version control system is used.
-PROJECT_NUMBER = @VERSION@
-# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
-# base path where the generated documentation will be put.
-# If a relative path is entered, it will be relative to the location
-# where doxygen was started. If left blank the current directory will be used.
+# This tag specifies the encoding used for all characters in the config file
+# that follow. The default is UTF-8 which is also the encoding used for all text
+# before the first occurrence of this tag. Doxygen uses libiconv (or the iconv
+# built into libc) for the transcoding. See
+# https://www.gnu.org/software/libiconv/ for the list of possible encodings.
+# The default value is: UTF-8.
-OUTPUT_DIRECTORY = doxygen_docs
+DOXYFILE_ENCODING = UTF-8
-# The OUTPUT_LANGUAGE tag is used to specify the language in which all
-# documentation generated by doxygen is written. Doxygen will use this
-# information to generate all constant output in the proper language.
-# The default language is English, other supported languages are:
-# Brazilian, Chinese, Croatian, Czech, Danish, Dutch, Finnish, French,
-# German, Greek, Hungarian, Italian, Japanese, Korean, Norwegian, Polish,
-# Portuguese, Romanian, Russian, Slovak, Slovene, Spanish and Swedish.
+# The PROJECT_NAME tag is a single word (or a sequence of words surrounded by
+# double-quotes, unless you are using Doxywizard) that should identify the
+# project for which the documentation is generated. This name is used in the
+# title of most generated pages and in a few other places.
+# The default value is: My Project.
-OUTPUT_LANGUAGE = English
+PROJECT_NAME = GEOS
-# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
-# documentation are documented, even if no documentation was available.
-# Private class members and static file members will be hidden unless
-# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
-EXTRACT_ALL = NO
+# The PROJECT_NUMBER tag can be used to enter a project or revision number. This
+# could be handy for archiving the generated documentation or if some version
+# control system is used.
-# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
-# will be included in the documentation.
+PROJECT_NUMBER = @VERSION@
-EXTRACT_PRIVATE = NO
+# Using the PROJECT_BRIEF tag one can provide an optional one line description
+# for a project that appears at the top of each page and should give viewer a
+# quick idea about the purpose of the project. Keep the description short.
-# If the EXTRACT_STATIC tag is set to YES all static members of a file
+PROJECT_BRIEF =
-EXTRACT_STATIC = NO
+# With the PROJECT_LOGO tag one can specify a logo or an icon that is included
+# in the documentation. The maximum height of the logo should not exceed 55
+# pixels and the maximum width should not exceed 200 pixels. Doxygen will copy
+# the logo to the output directory.
-# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
-# defined locally in source files will be included in the documentation.
-# If set to NO only classes defined in header files are included.
-EXTRACT_LOCAL_CLASSES = NO
+PROJECT_LOGO =
-# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
-# undocumented members of documented classes, files or namespaces.
-# If set to NO (the default) these members will be included in the
-# various overviews, but no documentation section is generated.
-# This option has no effect if EXTRACT_ALL is enabled.
+# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute) path
+# into which the generated documentation will be written. If a relative path is
+# entered, it will be relative to the location where doxygen was started. If
+# left blank the current directory will be used.
-HIDE_UNDOC_MEMBERS = NO
+OUTPUT_DIRECTORY = doxygen_docs
-# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
-# undocumented classes that are normally visible in the class hierarchy.
-# If set to NO (the default) these class will be included in the various
-# overviews. This option has no effect if EXTRACT_ALL is enabled.
+# If the CREATE_SUBDIRS tag is set to YES then doxygen will create 4096 sub-
+# directories (in 2 levels) under the output directory of each output format and
+# will distribute the generated files over these directories. Enabling this
+# option can be useful when feeding doxygen a huge amount of source files, where
+# putting all generated files in the same directory would otherwise causes
+# performance problems for the file system.
+# The default value is: NO.
+CREATE_SUBDIRS = NO
+# If the ALLOW_UNICODE_NAMES tag is set to YES, doxygen will allow non-ASCII
+# characters to appear in the names of generated files. If set to NO, non-ASCII
+# characters will be escaped, for example _xE3_x81_x84 will be used for Unicode
+# U+3044.
+ALLOW_UNICODE_NAMES = NO
+# The OUTPUT_LANGUAGE tag is used to specify the language in which all
+# documentation generated by doxygen is written. Doxygen will use this
+# information to generate all constant output in the proper language.
+# Possible values are: Afrikaans, Arabic, Armenian, Brazilian, Catalan, Chinese,
+# Chinese-Traditional, Croatian, Czech, Danish, Dutch, English (United States),
+# Esperanto, Farsi (Persian), Finnish, French, German, Greek, Hungarian,
+# Indonesian, Italian, Japanese, Japanese-en (Japanese with English messages),
+# Korean, Korean-en (Korean with English messages), Latvian, Lithuanian,
+# Macedonian, Norwegian, Persian (Farsi), Polish, Portuguese, Romanian, Russian,
+# Serbian, Serbian-Cyrillic, Slovak, Slovene, Spanish, Swedish, Turkish,
+# Ukrainian and Vietnamese.
+# The default value is: English.
-HIDE_UNDOC_CLASSES = YES
+OUTPUT_LANGUAGE = English
-# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
-# include brief member descriptions after the members that are listed in
-# the file and class documentation (similar to JavaDoc).
-# Set to NO to disable this.
+# If the BRIEF_MEMBER_DESC tag is set to YES, doxygen will include brief member
+# descriptions after the members that are listed in the file and class
+# documentation (similar to Javadoc). Set to NO to disable this.
+# The default value is: YES.
BRIEF_MEMBER_DESC = YES
-# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
-# the brief description of a member or function before the detailed description.
-# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
+# If the REPEAT_BRIEF tag is set to YES, doxygen will prepend the brief
+# description of a member or function before the detailed description
+# Note: If both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
# brief descriptions will be completely suppressed.
REPEAT_BRIEF = YES
-# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
-# Doxygen will generate a detailed section even if there is only a brief
+# This tag implements a quasi-intelligent brief description abbreviator that is
+# used to form the text in various listings. Each string in this list, if found
+# as the leading text of the brief description, will be stripped from the text
+# and the result, after processing the whole list, is used as the annotated
+# text. Otherwise, the brief description is used as-is. If left blank, the
+# following values are used ($name is automatically replaced with the name of
+# the entity):The $name class, The $name widget, The $name file, is, provides,
+# specifies, contains, represents, a, an and the.
+ABBREVIATE_BRIEF = "The $name class" \
+ "The $name widget" \
+ "The $name file" \
+ is \
+ provides \
+ specifies \
+ contains \
+ represents \
+ a \
+ an \
+ the
+# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
+# doxygen will generate a detailed section even if there is only a brief
# description.
ALWAYS_DETAILED_SEC = NO
-# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all inherited
-# members of a class in the documentation of that class as if those members were
-# ordinary class members. Constructors, destructors and assignment operators of
-# the base classes will not be shown.
+# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all
+# inherited members of a class in the documentation of that class as if those
+# members were ordinary class members. Constructors, destructors and assignment
+# operators of the base classes will not be shown.
INLINE_INHERITED_MEMB = NO
-# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
-# path before files name in the file list and in the header files. If set
-# to NO the shortest path that makes the file name unique will be used.
+# If the FULL_PATH_NAMES tag is set to YES, doxygen will prepend the full path
+# before files name in the file list and in the header files. If set to NO the
+# shortest path that makes the file name unique will be used
FULL_PATH_NAMES = NO
-# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
-# can be used to strip a user defined part of the path. Stripping is
-# only done if one of the specified strings matches the left-hand part of
-# the path. It is allowed to use relative paths in the argument list.
+# The STRIP_FROM_PATH tag can be used to strip a user-defined part of the path.
+# Stripping is only done if one of the specified strings matches the left-hand
+# part of the path. The tag can be used to show relative paths in the file list.
+# If left blank the directory from which doxygen is run is used as the path to
+# strip.
+# Note that you can specify absolute paths here, but also relative paths, which
+# will be relative from the directory where doxygen is started.
+# This tag requires that the tag FULL_PATH_NAMES is set to YES.
-STRIP_FROM_PATH =
+STRIP_FROM_PATH =
-# The INTERNAL_DOCS tag determines if documentation
-# that is typed after a \internal command is included. If the tag is set
-# to NO (the default) then the documentation will be excluded.
-# Set it to YES to include the internal documentation.
+# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of the
+# path mentioned in the documentation of a class, which tells the reader which
+# header file to include in order to use a class. If left blank only the name of
+# the header file containing the class definition is used. Otherwise one should
+# specify the list of include paths that are normally passed to the compiler
+# using the -I flag.
-INTERNAL_DOCS = NO
+STRIP_FROM_INC_PATH =
-# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
-# doxygen to hide any special comment blocks from generated source code
-# fragments. Normal C and C++ comments will always remain visible.
+# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter (but
+# less readable) file names. This can be useful is your file systems doesn't
+# support long names like on DOS, Mac, or CD-ROM.
-STRIP_CODE_COMMENTS = YES
+SHORT_NAMES = NO
-# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
-# file names in lower case letters. If set to YES upper case letters are also
-# allowed. This is useful if you have classes or files whose names only differ
-# in case and if your file system supports case sensitive file names. Windows
-# users are adviced to set this option to NO.
+# If the JAVADOC_AUTOBRIEF tag is set to YES then doxygen will interpret the
+# first line (until the first dot) of a Javadoc-style comment as the brief
+# description. If set to NO, the Javadoc-style will behave just like regular Qt-
+# style comments (thus requiring an explicit @brief command for a brief
+# description.)
-CASE_SENSE_NAMES = YES
+JAVADOC_AUTOBRIEF = NO
-# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
-# (but less readable) file names. This can be useful is your file systems
-# doesn't support long names like on DOS, Mac, or CD-ROM.
+# If the QT_AUTOBRIEF tag is set to YES then doxygen will interpret the first
+# line (until the first dot) of a Qt-style comment as the brief description. If
+# set to NO, the Qt-style will behave just like regular Qt-style comments (thus
+# requiring an explicit \brief command for a brief description.)
-SHORT_NAMES = NO
+QT_AUTOBRIEF = NO
-# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
-# will show members with their full class and namespace scopes in the
-# documentation. If set to YES the scope will be hidden.
+# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make doxygen treat a
+# multi-line C++ special comment block (i.e. a block of //! or /// comments) as
+# a brief description. This used to be the default behavior. The new default is
+# to treat a multi-line C++ comment block as a detailed description. Set this
+# tag to YES if you prefer the old behavior instead.
+# Note that setting this tag to YES also means that rational rose comments are
+# not recognized any more.
-HIDE_SCOPE_NAMES = NO
+MULTILINE_CPP_IS_BRIEF = NO
-# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
-# will generate a verbatim copy of the header file for each class for
-# which an include is specified. Set to NO to disable this.
+# If the INHERIT_DOCS tag is set to YES then an undocumented member inherits the
+# documentation from any documented member that it re-implements.
-VERBATIM_HEADERS = YES
+INHERIT_DOCS = YES
-# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
-# will put list of the files that are included by a file in the documentation
-# of that file.
+# If the SEPARATE_MEMBER_PAGES tag is set to YES then doxygen will produce a new
+# page for each member. If set to NO, the documentation of a member will be part
+# of the file/class/namespace that contains it.
-SHOW_INCLUDE_FILES = YES
+SEPARATE_MEMBER_PAGES = NO
-# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
-# will interpret the first line (until the first dot) of a JavaDoc-style
-# comment as the brief description. If set to NO, the JavaDoc
-# comments will behave just like the Qt-style comments (thus requiring an
-# explict @brief command for a brief description.
+# The TAB_SIZE tag can be used to set the number of spaces in a tab. Doxygen
+# uses this value to replace tabs by spaces in code fragments.
+# Minimum value: 1, maximum value: 16, default value: 4.
-JAVADOC_AUTOBRIEF = NO
+TAB_SIZE = 8
-# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
-# member inherits the documentation from any documented member that it
-# reimplements.
+# This tag can be used to specify a number of aliases that act as commands in
+# the documentation. An alias has the form:
+# name=value
+# For example adding
+# "sideeffect=@par Side Effects:\n"
+# will allow you to put the command \sideeffect (or @sideeffect) in the
+# documentation, which will result in a user-defined paragraph with heading
+# "Side Effects:". You can put \n's in the value part of an alias to insert
+# newlines (in the resulting output). You can put ^^ in the value part of an
+# alias to insert a newline as if a physical newline was in the original file.
-INHERIT_DOCS = YES
+ALIASES =
-# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
-# is inserted in the documentation for inline members.
+# This tag can be used to specify a number of word-keyword mappings (TCL only).
+# A mapping has the form "name=value". For example adding "class=itcl::class"
+# will allow you to use the command class in the itcl::class meaning.
-INLINE_INFO = YES
+TCL_SUBST =
-# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
-# will sort the (detailed) documentation of file and class members
-# alphabetically by member name. If set to NO the members will appear in
-# declaration order.
+# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
+# only. Doxygen will then generate output that is more tailored for C. For
+# instance, some of the names that are used will be different. The list of all
+# members will be omitted, etc.
-SORT_MEMBER_DOCS = YES
+OPTIMIZE_OUTPUT_FOR_C = NO
+# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java or
+# Python sources only. Doxygen will then generate output that is more tailored
+# for that language. For instance, namespaces will be presented as packages,
+# qualified scopes will look different, etc.
-# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
-# tag is set to YES, then doxygen will reuse the documentation of the first
-# member in the group (if any) for the other members of the group. By default
+OPTIMIZE_OUTPUT_JAVA = NO
+# Set the OPTIMIZE_FOR_FORTRAN tag to YES if your project consists of Fortran
+# sources. Doxygen will then generate output that is tailored for Fortran.
+OPTIMIZE_FOR_FORTRAN = NO
+# Set the OPTIMIZE_OUTPUT_VHDL tag to YES if your project consists of VHDL
+# sources. Doxygen will then generate output that is tailored for VHDL.
+OPTIMIZE_OUTPUT_VHDL = NO
+# Doxygen selects the parser to use depending on the extension of the files it
+# parses. With this tag you can assign which parser to use for a given
+# extension. Doxygen has a built-in mapping, but you can override or extend it
+# using this tag. The format is ext=language, where ext is a file extension, and
+# language is one of the parsers supported by doxygen: IDL, Java, Javascript,
+# C#, C, C++, D, PHP, Objective-C, Python, Fortran (fixed format Fortran:
+# FortranFixed, free formatted Fortran: FortranFree, unknown formatted Fortran:
+# Fortran. In the later case the parser tries to guess whether the code is fixed
+# or free formatted code, this is the default for Fortran type files), VHDL. For
+# instance to make doxygen treat .inc files as Fortran files (default is PHP),
+# and .f files as C (default is Fortran), use: inc=Fortran f=C.
+# Note: For files without extension you can use no_extension as a placeholder.
+# Note that for custom extensions you also need to set FILE_PATTERNS otherwise
+# the files are not read by doxygen.
+EXTENSION_MAPPING =
+# If the MARKDOWN_SUPPORT tag is enabled then doxygen pre-processes all comments
+# according to the Markdown format, which allows for more readable
+# documentation. See http://daringfireball.net/projects/markdown/ for details.
+# The output of markdown processing is further processed by doxygen, so you can
+# mix doxygen, HTML, and XML commands with Markdown formatting. Disable only in
+# case of backward compatibilities issues.
+MARKDOWN_SUPPORT = YES
+# When the TOC_INCLUDE_HEADINGS tag is set to a non-zero value, all headings up
+# to that level are automatically included in the table of contents, even if
+# they do not have an id attribute.
+# Note: This feature currently applies only to Markdown headings.
+# Minimum value: 0, maximum value: 99, default value: 0.
+# This tag requires that the tag MARKDOWN_SUPPORT is set to YES.
+TOC_INCLUDE_HEADINGS = 0
+# When enabled doxygen tries to link words that correspond to documented
+# classes, or namespaces to their corresponding documentation. Such a link can
+# be prevented in individual cases by putting a % sign in front of the word or
+# globally by setting AUTOLINK_SUPPORT to NO.
+AUTOLINK_SUPPORT = YES
+# If you use STL classes (i.e. std::string, std::vector, etc.) but do not want
+# to include (a tag file for) the STL sources as input, then you should set this
+# tag to YES in order to let doxygen match functions declarations and
+# definitions whose arguments contain STL classes (e.g. func(std::string);
+# versus func(std::string) {}). This also make the inheritance and collaboration
+# diagrams that involve STL classes more complete and accurate.
+BUILTIN_STL_SUPPORT = NO
+# If you use Microsoft's C++/CLI language, you should set this option to YES to
+# enable parsing support.
+CPP_CLI_SUPPORT = NO
+# Set the SIP_SUPPORT tag to YES if your project consists of sip (see:
+# https://www.riverbankcomputing.com/software/sip/intro) sources only. Doxygen
+# will parse them like normal C++ but will assume all classes use public instead
+# of private inheritance when no explicit protection keyword is present.
+SIP_SUPPORT = NO
+# For Microsoft's IDL there are propget and propput attributes to indicate
+# getter and setter methods for a property. Setting this option to YES will make
+# doxygen to replace the get and set methods by a property in the documentation.
+# This will only work if the methods are indeed getting or setting a simple
+# type. If this is not the case, or you want to show the methods anyway, you
+# should set this option to NO.
+IDL_PROPERTY_SUPPORT = YES
+# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
+# tag is set to YES then doxygen will reuse the documentation of the first
+# member in the group (if any) for the other members of the group. By default
# all members of a group must be documented explicitly.
DISTRIBUTE_GROUP_DOC = NO
-# The TAB_SIZE tag can be used to set the number of spaces in a tab.
-# Doxygen uses this value to replace tabs by spaces in code fragments.
+# If one adds a struct or class to a group and this option is enabled, then also
+# any nested class or struct is added to the same group. By default this option
+# is disabled and one has to add nested compounds explicitly via \ingroup.
-TAB_SIZE = 8
+GROUP_NESTED_COMPOUNDS = NO
+# Set the SUBGROUPING tag to YES to allow class member groups of the same type
+# (for instance a group of public functions) to be put as a subgroup of that
+# type (e.g. under the Public Functions section). Set it to NO to prevent
+# subgrouping. Alternatively, this can be done per class using the
+# \nosubgrouping command.
+SUBGROUPING = YES
+# When the INLINE_GROUPED_CLASSES tag is set to YES, classes, structs and unions
+# are shown inside the group in which they are included (e.g. using \ingroup)
+# instead of on a separate page (for HTML and Man pages) or section (for LaTeX
+# and RTF).
+# Note that this feature does not work in combination with
+# SEPARATE_MEMBER_PAGES.
+INLINE_GROUPED_CLASSES = NO
+# When the INLINE_SIMPLE_STRUCTS tag is set to YES, structs, classes, and unions
+# with only public data fields or simple typedef fields will be shown inline in
+# the documentation of the scope in which they are defined (i.e. file,
+# namespace, or group documentation), provided this scope is documented. If set
+# to NO, structs, classes, and unions are shown on a separate page (for HTML and
+# Man pages) or section (for LaTeX and RTF).
+INLINE_SIMPLE_STRUCTS = NO
+# When TYPEDEF_HIDES_STRUCT tag is enabled, a typedef of a struct, union, or
+# enum is documented as struct, union, or enum with the name of the typedef. So
+# typedef struct TypeS {} TypeT, will appear in the documentation as a struct
+# with name TypeT. When disabled the typedef will appear as a member of a file,
+# namespace, or class. And the struct will be named TypeS. This can typically be
+# useful for C code in case the coding convention dictates that all compound
+# types are typedef'ed and only the typedef is referenced, never the tag name.
+TYPEDEF_HIDES_STRUCT = NO
+# The size of the symbol lookup cache can be set using LOOKUP_CACHE_SIZE. This
+# cache is used to resolve symbols given their name and scope. Since this can be
+# an expensive process and often the same symbol appears multiple times in the
+# code, doxygen keeps a cache of pre-resolved symbols. If the cache is too small
+# doxygen will become slower. If the cache is too large, memory is wasted. The
+# cache size is given by this formula: 2^(16+LOOKUP_CACHE_SIZE). The valid range
+# is 0..9, the default is 0, corresponding to a cache size of 2^16=65536
+# symbols. At the end of a run doxygen will report the cache usage and suggest
+# the optimal cache size from a speed point of view.
+# Minimum value: 0, maximum value: 9, default value: 0.
+LOOKUP_CACHE_SIZE = 0
+# Build related configuration options
+# If the EXTRACT_ALL tag is set to YES, doxygen will assume all entities in
+# documentation are documented, even if no documentation was available. Private
+# class members and static file members will be hidden unless the
+# EXTRACT_PRIVATE respectively EXTRACT_STATIC tags are set to YES.
+# Note: This will also disable the warnings about undocumented members that are
+# normally produced when WARNINGS is set to YES.
+EXTRACT_ALL = NO
+# If the EXTRACT_PRIVATE tag is set to YES, all private members of a class will
+# be included in the documentation.
+EXTRACT_PRIVATE = NO
+# If the EXTRACT_PACKAGE tag is set to YES, all members with package or internal
+# scope will be included in the documentation.
+EXTRACT_PACKAGE = NO
+# If the EXTRACT_STATIC tag is set to YES, all static members of a file will be
+# included in the documentation.
+EXTRACT_STATIC = NO
+# If the EXTRACT_LOCAL_CLASSES tag is set to YES, classes (and structs) defined
+# locally in source files will be included in the documentation. If set to NO,
+# only classes defined in header files are included. Does not have any effect
+# for Java sources.
+EXTRACT_LOCAL_CLASSES = NO
+# This flag is only useful for Objective-C code. If set to YES, local methods,
+# which are defined in the implementation section but not in the interface are
+# included in the documentation. If set to NO, only methods in the interface are
+# included.
+EXTRACT_LOCAL_METHODS = NO
+# If this flag is set to YES, the members of anonymous namespaces will be
+# extracted and appear in the documentation as a namespace called
+# 'anonymous_namespace{file}', where file will be replaced with the base name of
+# the file that contains the anonymous namespace. By default anonymous namespace
+# are hidden.
+EXTRACT_ANON_NSPACES = NO
+# If the HIDE_UNDOC_MEMBERS tag is set to YES, doxygen will hide all
+# undocumented members inside documented classes or files. If set to NO these
+# members will be included in the various overviews, but no documentation
+# section is generated. This option has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_MEMBERS = NO
+# If the HIDE_UNDOC_CLASSES tag is set to YES, doxygen will hide all
+# undocumented classes that are normally visible in the class hierarchy. If set
+# to NO, these classes will be included in the various overviews. This option
+# has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_CLASSES = YES
+# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, doxygen will hide all friend
+# (class|struct|union) declarations. If set to NO, these declarations will be
+HIDE_FRIEND_COMPOUNDS = NO
-# The GENERATE_TODOLIST tag can be used to enable (YES) or
-# disable (NO) the todo list. This list is created by putting \todo
-# commands in the documentation.
+# If the HIDE_IN_BODY_DOCS tag is set to YES, doxygen will hide any
+# documentation blocks found inside the body of a function. If set to NO, these
+# blocks will be appended to the function's detailed documentation block.
+HIDE_IN_BODY_DOCS = NO
+# The INTERNAL_DOCS tag determines if documentation that is typed after a
+# \internal command is included. If the tag is set to NO then the documentation
+# will be excluded. Set it to YES to include the internal documentation.
+INTERNAL_DOCS = NO
+# If the CASE_SENSE_NAMES tag is set to NO then doxygen will only generate file
+# names in lower-case letters. If set to YES, upper-case letters are also
+# allowed. This is useful if you have classes or files whose names only differ
+# in case and if your file system supports case sensitive file names. Windows
+# and Mac users are advised to set this option to NO.
+# The default value is: system dependent.
+CASE_SENSE_NAMES = YES
+# If the HIDE_SCOPE_NAMES tag is set to NO then doxygen will show members with
+# their full class and namespace scopes in the documentation. If set to YES, the
+# scope will be hidden.
+HIDE_SCOPE_NAMES = NO
+# If the HIDE_COMPOUND_REFERENCE tag is set to NO (default) then doxygen will
+# append additional text to a page's title, such as Class Reference. If set to
+# YES the compound reference will be hidden.
+HIDE_COMPOUND_REFERENCE= NO
+# If the SHOW_INCLUDE_FILES tag is set to YES then doxygen will put a list of
+# the files that are included by a file in the documentation of that file.
+SHOW_INCLUDE_FILES = YES
+# If the SHOW_GROUPED_MEMB_INC tag is set to YES then Doxygen will add for each
+# grouped member an include statement to the documentation, telling the reader
+# which file to include in order to use the member.
+SHOW_GROUPED_MEMB_INC = NO
+# If the FORCE_LOCAL_INCLUDES tag is set to YES then doxygen will list include
+# files with double quotes in the documentation rather than with sharp brackets.
+FORCE_LOCAL_INCLUDES = NO
+# If the INLINE_INFO tag is set to YES then a tag [inline] is inserted in the
+# documentation for inline members.
+INLINE_INFO = YES
+# If the SORT_MEMBER_DOCS tag is set to YES then doxygen will sort the
+# (detailed) documentation of file and class members alphabetically by member
+# name. If set to NO, the members will appear in declaration order.
+SORT_MEMBER_DOCS = YES
+# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the brief
+# descriptions of file, namespace and class members alphabetically by member
+# name. If set to NO, the members will appear in declaration order. Note that
+# this will also influence the order of the classes in the class list.
+SORT_BRIEF_DOCS = NO
+# If the SORT_MEMBERS_CTORS_1ST tag is set to YES then doxygen will sort the
+# (brief and detailed) documentation of class members so that constructors and
+# destructors are listed first. If set to NO the constructors will appear in the
+# respective orders defined by SORT_BRIEF_DOCS and SORT_MEMBER_DOCS.
+# Note: If SORT_BRIEF_DOCS is set to NO this option is ignored for sorting brief
+# member documentation.
+# Note: If SORT_MEMBER_DOCS is set to NO this option is ignored for sorting
+# detailed member documentation.
+SORT_MEMBERS_CTORS_1ST = NO
+# If the SORT_GROUP_NAMES tag is set to YES then doxygen will sort the hierarchy
+# of group names into alphabetical order. If set to NO the group names will
+# appear in their defined order.
+SORT_GROUP_NAMES = NO
+# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be sorted by
+# fully-qualified names, including namespaces. If set to NO, the class list will
+# be sorted only by class name, not including the namespace part.
+# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
+# Note: This option applies only to the class list, not to the alphabetical
+# list.
+SORT_BY_SCOPE_NAME = NO
+# If the STRICT_PROTO_MATCHING option is enabled and doxygen fails to do proper
+# type resolution of all parameters of a function it will reject a match between
+# the prototype and the implementation of a member function even if there is
+# only one candidate or it is obvious which candidate to choose by doing a
+# simple string match. By disabling STRICT_PROTO_MATCHING doxygen will still
+# accept a match between prototype and implementation in such cases.
+STRICT_PROTO_MATCHING = NO
+# The GENERATE_TODOLIST tag can be used to enable (YES) or disable (NO) the todo
+# list. This list is created by putting \todo commands in the documentation.
GENERATE_TODOLIST = YES
-# The GENERATE_TESTLIST tag can be used to enable (YES) or
-# disable (NO) the test list. This list is created by putting \test
+# The GENERATE_TESTLIST tag can be used to enable (YES) or disable (NO) the test
+# list. This list is created by putting \test commands in the documentation.
GENERATE_TESTLIST = YES
-# The GENERATE_BUGLIST tag can be used to enable (YES) or
-# disable (NO) the bug list. This list is created by putting \bug
+# The GENERATE_BUGLIST tag can be used to enable (YES) or disable (NO) the bug
+# list. This list is created by putting \bug commands in the documentation.
GENERATE_BUGLIST = YES
-# This tag can be used to specify a number of aliases that acts
-# as commands in the documentation. An alias has the form "name=value".
-# For example adding "sideeffect=\par Side Effects:\n" will allow you to
-# put the command \sideeffect (or @sideeffect) in the documentation, which
-# will result in a user defined paragraph with heading "Side Effects:".
-# You can put \n's in the value part of an alias to insert newlines.
+# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or disable (NO)
+# the deprecated list. This list is created by putting \deprecated commands in
-ALIASES =
+GENERATE_DEPRECATEDLIST= YES
-# The ENABLED_SECTIONS tag can be used to enable conditional
-# documentation sections, marked by \if sectionname ... \endif.
+# The ENABLED_SECTIONS tag can be used to enable conditional documentation
+# sections, marked by \if <section_label> ... \endif and \cond <section_label>
+# ... \endcond blocks.
-ENABLED_SECTIONS =
+ENABLED_SECTIONS =
-# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
-# the initial value of a variable or define consist of for it to appear in
-# the documentation. If the initializer consists of more lines than specified
-# here it will be hidden. Use a value of 0 to hide initializers completely.
-# The appearance of the initializer of individual variables and defines in the
-# documentation can be controlled using \showinitializer or \hideinitializer
-# command in the documentation regardless of this setting.
+# The MAX_INITIALIZER_LINES tag determines the maximum number of lines that the
+# initial value of a variable or macro / define can have for it to appear in the
+# documentation. If the initializer consists of more lines than specified here
+# it will be hidden. Use a value of 0 to hide initializers completely. The
+# appearance of the value of individual variables and macros / defines can be
+# controlled using \showinitializer or \hideinitializer command in the
+# documentation regardless of this setting.
+# Minimum value: 0, maximum value: 10000, default value: 30.
MAX_INITIALIZER_LINES = 30
-# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
-# only. Doxygen will then generate output that is more tailored for C.
-# For instance some of the names that are used will be different. The list
-# of all members will be omitted, etc.
+# Set the SHOW_USED_FILES tag to NO to disable the list of files generated at
+# the bottom of the documentation of classes and structs. If set to YES, the
+# list will mention the files that were used to generate the documentation.
-OPTIMIZE_OUTPUT_FOR_C = NO
+SHOW_USED_FILES = YES
-# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java sources
-# only. Doxygen will then generate output that is more tailored for Java.
-# For instance namespaces will be presented as packages, qualified scopes
-# will look different, etc.
+# Set the SHOW_FILES tag to NO to disable the generation of the Files page. This
+# will remove the Files entry from the Quick Index and from the Folder Tree View
+# (if specified).
-OPTIMIZE_OUTPUT_JAVA = NO
+SHOW_FILES = YES
-# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
-# at the bottom of the documentation of classes and structs. If set to YES the
-# list will mention the files that were used to generate the documentation.
+# Set the SHOW_NAMESPACES tag to NO to disable the generation of the Namespaces
+# page. This will remove the Namespaces entry from the Quick Index and from the
+# Folder Tree View (if specified).
-SHOW_USED_FILES = YES
+SHOW_NAMESPACES = YES
+# The FILE_VERSION_FILTER tag can be used to specify a program or script that
+# doxygen should invoke to get the current version for each file (typically from
+# the version control system). Doxygen will invoke the program by executing (via
+# popen()) the command command input-file, where command is the value of the
+# FILE_VERSION_FILTER tag, and input-file is the name of an input file provided
+# by doxygen. Whatever the program writes to standard output is used as the file
+# version. For an example see the documentation.
+FILE_VERSION_FILTER =
+# The LAYOUT_FILE tag can be used to specify a layout file which will be parsed
+# by doxygen. The layout file controls the global structure of the generated
+# output files in an output format independent way. To create the layout file
+# that represents doxygen's defaults, run doxygen with the -l option. You can
+# optionally specify a file name after the option, if omitted DoxygenLayout.xml
+# will be used as the name of the layout file.
+# Note that if you run doxygen from a directory containing a file called
+# DoxygenLayout.xml, doxygen will parse it automatically even if the LAYOUT_FILE
+# tag is left empty.
+LAYOUT_FILE =
+# The CITE_BIB_FILES tag can be used to specify one or more bib files containing
+# the reference definitions. This must be a list of .bib files. The .bib
+# extension is automatically appended if omitted. This requires the bibtex tool
+# to be installed. See also https://en.wikipedia.org/wiki/BibTeX for more info.
+# For LaTeX the style of the bibliography can be controlled using
+# LATEX_BIB_STYLE. To use this feature you need bibtex and perl available in the
+# search path. See also \cite for info how to create references.
+CITE_BIB_FILES =
-# configuration options related to warning and progress messages
+# Configuration options related to warning and progress messages
-# The QUIET tag can be used to turn on/off the messages that are generated
-# by doxygen. Possible values are YES and NO. If left blank NO is used.
+# The QUIET tag can be used to turn on/off the messages that are generated to
+# standard output by doxygen. If QUIET is set to YES this implies that the
+# messages are off.
QUIET = NO
-# The WARNINGS tag can be used to turn on/off the warning messages that are
-# generated by doxygen. Possible values are YES and NO. If left blank
-# NO is used.
+# The WARNINGS tag can be used to turn on/off the warning messages that are
+# generated to standard error (stderr) by doxygen. If WARNINGS is set to YES
+# this implies that the warnings are on.
+# Tip: Turn warnings on while writing the documentation.
WARNINGS = YES
-# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
-# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
-# automatically be disabled.
+# If the WARN_IF_UNDOCUMENTED tag is set to YES then doxygen will generate
+# warnings for undocumented members. If EXTRACT_ALL is set to YES then this flag
+# will automatically be disabled.
WARN_IF_UNDOCUMENTED = YES
-# The WARN_FORMAT tag determines the format of the warning messages that
-# doxygen can produce. The string should contain the $file, $line, and $text
-# tags, which will be replaced by the file and line number from which the
-# warning originated and the warning text.
+# If the WARN_IF_DOC_ERROR tag is set to YES, doxygen will generate warnings for
+# potential errors in the documentation, such as not documenting some parameters
+# in a documented function, or documenting parameters that don't exist or using
+# markup commands wrongly.
+WARN_IF_DOC_ERROR = YES
+# This WARN_NO_PARAMDOC option can be enabled to get warnings for functions that
+# are documented, but have no documentation for their parameters or return
+# value. If set to NO, doxygen will only warn about wrong or incomplete
+# parameter documentation, but not about the absence of documentation.
+WARN_NO_PARAMDOC = NO
+# If the WARN_AS_ERROR tag is set to YES then doxygen will immediately stop when
+# a warning is encountered.
+WARN_AS_ERROR = NO
+# The WARN_FORMAT tag determines the format of the warning messages that doxygen
+# can produce. The string should contain the $file, $line, and $text tags, which
+# will be replaced by the file and line number from which the warning originated
+# and the warning text. Optionally the format may contain $version, which will
+# be replaced by the version of the file (if it could be obtained via
+# FILE_VERSION_FILTER)
+# The default value is: $file:$line: $text.
WARN_FORMAT = "$file:$line: $text"
-# The WARN_LOGFILE tag can be used to specify a file to which warning
-# and error messages should be written. If left blank the output is written
-# to stderr.
+# The WARN_LOGFILE tag can be used to specify a file to which warning and error
+# messages should be written. If left blank the output is written to standard
+# error (stderr).
-WARN_LOGFILE =
+WARN_LOGFILE =
-# configuration options related to the input files
+# Configuration options related to the input files
-# The INPUT tag can be used to specify the files and/or directories that contain
-# documented source files. You may enter file names like "myfile.cpp" or
-# directories like "/usr/src/myproject". Separate the files or directories
-# with spaces.
+# The INPUT tag is used to specify the files and/or directories that contain
+# documented source files. You may enter file names like myfile.cpp or
+# directories like /usr/src/myproject. Separate the files or directories with
+# spaces. See also FILE_PATTERNS and EXTENSION_MAPPING
+# Note: If this tag is empty the current directory is searched.
+INPUT = @srcdir@/../src \
+ @srcdir@/../include \
+ @srcdir@/../capi
-INPUT = @srcdir@/../src @srcdir@/../include @srcdir@/../capi
+# This tag can be used to specify the character encoding of the source files
+# that doxygen parses. Internally doxygen uses the UTF-8 encoding. Doxygen uses
+# libiconv (or the iconv built into libc) for the transcoding. See the libiconv
+# documentation (see: https://www.gnu.org/software/libiconv/) for the list of
+# possible encodings.
-# If the value of the INPUT tag contains directories, you can use the
-# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# and *.h) to filter out the source-files in the directories. If left
-# blank the following patterns are tested:
-# *.c *.cc *.cxx *.cpp *.c++ *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh *.hxx *.hpp
-# *.h++ *.idl *.odl
+INPUT_ENCODING = UTF-8
+# If the value of the INPUT tag contains directories, you can use the
+# FILE_PATTERNS tag to specify one or more wildcard patterns (like *.cpp and
+# *.h) to filter out the source-files in the directories.
+# Note that for custom extensions or not directly supported extensions you also
+# need to set EXTENSION_MAPPING for the extension otherwise the files are not
+# read by doxygen.
+# If left blank the following patterns are tested:*.c, *.cc, *.cxx, *.cpp,
+# *.c++, *.java, *.ii, *.ixx, *.ipp, *.i++, *.inl, *.idl, *.ddl, *.odl, *.h,
+# *.hh, *.hxx, *.hpp, *.h++, *.cs, *.d, *.php, *.php4, *.php5, *.phtml, *.inc,
+# *.m, *.markdown, *.md, *.mm, *.dox, *.py, *.pyw, *.f90, *.f95, *.f03, *.f08,
+# *.f, *.for, *.tcl, *.vhd, *.vhdl, *.ucf and *.qsf.
FILE_PATTERNS = *.h
-# The RECURSIVE tag can be used to turn specify whether or not subdirectories
-# should be searched for input files as well. Possible values are YES and NO.
-# If left blank NO is used.
+# The RECURSIVE tag can be used to specify whether or not subdirectories should
+# be searched for input files as well.
RECURSIVE = YES
-# The EXCLUDE tag can be used to specify files and/or directories that should
-# excluded from the INPUT source files. This way you can easily exclude a
+# The EXCLUDE tag can be used to specify files and/or directories that should be
+# excluded from the INPUT source files. This way you can easily exclude a
# subdirectory from a directory tree whose root is specified with the INPUT tag.
+# Note that relative paths are relative to the directory from which doxygen is
+# run.
-EXCLUDE =
+EXCLUDE =
-# The EXCLUDE_SYMLINKS tag can be used select whether or not files or directories
-# that are symbolic links (a Unix filesystem feature) are excluded from the input.
+# The EXCLUDE_SYMLINKS tag can be used to select whether or not files or
+# directories that are symbolic links (a Unix file system feature) are excluded
+# from the input.
EXCLUDE_SYMLINKS = NO
-# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
+# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
# certain files from those directories.
+# Note that the wildcards are matched against the file with absolute path, so to
+# exclude all test directories for example use the pattern */test/*
+EXCLUDE_PATTERNS = */examples/* \
+ */test/* \
+ */bigtest/* \
+ */io/markup/* \
+ config.h \
+ acconfig.h \
+ CoordinateList.cpp \
+ NonRobustLineIntersector.cpp \
+ RobustLineIntersector.cpp
+# The EXCLUDE_SYMBOLS tag can be used to specify one or more symbol names
+# (namespaces, classes, functions, etc.) that should be excluded from the
+# output. The symbol name can be a fully qualified name, a word, or if the
+# wildcard * is used, a substring. Examples: ANamespace, AClass,
+# AClass::ANamespace, ANamespace::*Test
+# exclude all test directories use the pattern */test/*
-EXCLUDE_PATTERNS = */examples/* */test/* */bigtest/* */io/markup/* config.h acconfig.h CoordinateList.cpp NonRobustLineIntersector.cpp RobustLineIntersector.cpp
+EXCLUDE_SYMBOLS =
-# The EXAMPLE_PATH tag can be used to specify one or more files or
-# directories that contain example code fragments that are included (see
-# the \include command).
+# The EXAMPLE_PATH tag can be used to specify one or more files or directories
+# that contain example code fragments that are included (see the \include
+# command).
-EXAMPLE_PATH =
+EXAMPLE_PATH =
-# If the value of the EXAMPLE_PATH tag contains directories, you can use the
-# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# blank all files are included.
+# If the value of the EXAMPLE_PATH tag contains directories, you can use the
+# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp and
+# *.h) to filter out the source-files in the directories. If left blank all
+# files are included.
-EXAMPLE_PATTERNS =
+EXAMPLE_PATTERNS =
-# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
-# searched for input files to be used with the \include or \dontinclude
-# commands irrespective of the value of the RECURSIVE tag.
-# Possible values are YES and NO. If left blank NO is used.
+# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
+# searched for input files to be used with the \include or \dontinclude commands
+# irrespective of the value of the RECURSIVE tag.
EXAMPLE_RECURSIVE = NO
-# The IMAGE_PATH tag can be used to specify one or more files or
-# directories that contain image that are included in the documentation (see
-# the \image command).
+# The IMAGE_PATH tag can be used to specify one or more files or directories
+# that contain images that are to be included in the documentation (see the
+# \image command).
-IMAGE_PATH =
+IMAGE_PATH =
-# The INPUT_FILTER tag can be used to specify a program that doxygen should
-# invoke to filter for each input file. Doxygen will invoke the filter program
-# by executing (via popen()) the command <filter> <input-file>, where <filter>
-# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
-# input file. Doxygen will then use the output that the filter program writes
-# to standard output.
+# The INPUT_FILTER tag can be used to specify a program that doxygen should
+# invoke to filter for each input file. Doxygen will invoke the filter program
+# by executing (via popen()) the command:
+# <filter> <input-file>
+# where <filter> is the value of the INPUT_FILTER tag, and <input-file> is the
+# name of an input file. Doxygen will then use the output that the filter
+# program writes to standard output. If FILTER_PATTERNS is specified, this tag
+# will be ignored.
+# Note that the filter must not add or remove lines; it is applied before the
+# code is scanned, but not when the output code is generated. If lines are added
+# or removed, the anchors will not be placed correctly.
+# properly processed by doxygen.
+INPUT_FILTER =
+# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
+# basis. Doxygen will compare the file name with each pattern and apply the
+# filter if there is a match. The filters are a list of the form: pattern=filter
+# (like *.cpp=my_cpp_filter). See INPUT_FILTER for further information on how
+# filters are used. If the FILTER_PATTERNS tag is empty or if none of the
+# patterns match the file name, INPUT_FILTER is applied.
-INPUT_FILTER =
+FILTER_PATTERNS =
-# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
-# INPUT_FILTER) will be used to filter the input files when producing source
-# files to browse.
+# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
+# INPUT_FILTER) will also be used to filter the input files that are used for
+# producing the source files to browse (i.e. when SOURCE_BROWSER is set to YES).
FILTER_SOURCE_FILES = NO
+# The FILTER_SOURCE_PATTERNS tag can be used to specify source filters per file
+# pattern. A pattern will override the setting for FILTER_PATTERN (if any) and
+# it is also possible to disable source filtering for a specific pattern using
+# *.ext= (so without naming a filter).
+# This tag requires that the tag FILTER_SOURCE_FILES is set to YES.
+FILTER_SOURCE_PATTERNS =
+# If the USE_MDFILE_AS_MAINPAGE tag refers to the name of a markdown file that
+# is part of the input, its contents will be placed on the main page
+# (index.html). This can be useful if you have a project on for instance GitHub
+# and want to reuse the introduction page also for the doxygen output.
+USE_MDFILE_AS_MAINPAGE =
-# configuration options related to source browsing
+# Configuration options related to source browsing
-# If the SOURCE_BROWSER tag is set to YES then a list of source files will
-# be generated. Documented entities will be cross-referenced with these sources.
+# If the SOURCE_BROWSER tag is set to YES then a list of source files will be
+# generated. Documented entities will be cross-referenced with these sources.
+# Note: To get rid of all source code in the generated output, make sure that
+# also VERBATIM_HEADERS is set to NO.
SOURCE_BROWSER = NO
-# Setting the INLINE_SOURCES tag to YES will include the body
-# of functions and classes directly in the documentation.
+# Setting the INLINE_SOURCES tag to YES will include the body of functions,
+# classes and enums directly into the documentation.
INLINE_SOURCES = NO
-# If the REFERENCED_BY_RELATION tag is set to YES (the default)
-# then for each documented function all documented
-# functions referencing it will be listed.
+# Setting the STRIP_CODE_COMMENTS tag to YES will instruct doxygen to hide any
+# special comment blocks from generated source code fragments. Normal C, C++ and
+# Fortran comments will always remain visible.
+STRIP_CODE_COMMENTS = YES
+# If the REFERENCED_BY_RELATION tag is set to YES then for each documented
+# function all documented functions referencing it will be listed.
REFERENCED_BY_RELATION = YES
-# If the REFERENCES_RELATION tag is set to YES (the default)
-# then for each documented function all documented entities
-# called/used by that function will be listed.
+# If the REFERENCES_RELATION tag is set to YES then for each documented function
+# all documented entities called/used by that function will be listed.
REFERENCES_RELATION = YES
+# If the REFERENCES_LINK_SOURCE tag is set to YES and SOURCE_BROWSER tag is set
+# to YES then the hyperlinks from functions in REFERENCES_RELATION and
+# REFERENCED_BY_RELATION lists will link to the source code. Otherwise they will
+# link to the documentation.
+REFERENCES_LINK_SOURCE = YES
+# If SOURCE_TOOLTIPS is enabled (the default) then hovering a hyperlink in the
+# source code will show a tooltip with additional information such as prototype,
+# brief description and links to the definition and documentation. Since this
+# will make the HTML file larger and loading of large files a bit slower, you
+# can opt to disable this feature.
+# This tag requires that the tag SOURCE_BROWSER is set to YES.
+SOURCE_TOOLTIPS = YES
+# If the USE_HTAGS tag is set to YES then the references to source code will
+# point to the HTML generated by the htags(1) tool instead of doxygen built-in
+# source browser. The htags tool is part of GNU's global source tagging system
+# (see https://www.gnu.org/software/global/global.html). You will need version
+# 4.8.6 or higher.
+# To use it do the following:
+# - Install the latest version of global
+# - Enable SOURCE_BROWSER and USE_HTAGS in the config file
+# - Make sure the INPUT points to the root of the source tree
+# - Run doxygen as normal
+# Doxygen will invoke htags (and that will in turn invoke gtags), so these
+# tools must be available from the command line (i.e. in the search path).
+# The result: instead of the source browser generated by doxygen, the links to
+# source code will now point to the output of htags.
+USE_HTAGS = NO
+# If the VERBATIM_HEADERS tag is set the YES then doxygen will generate a
+# verbatim copy of the header file for each class for which an include is
+# specified. Set to NO to disable this.
+# See also: Section \class.
+VERBATIM_HEADERS = YES
-# configuration options related to the alphabetical class index
+# Configuration options related to the alphabetical class index
-# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
-# of all compounds will be generated. Enable this if the project
-# contains a lot of classes, structs, unions or interfaces.
+# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index of all
+# compounds will be generated. Enable this if the project contains a lot of
+# classes, structs, unions or interfaces.
ALPHABETICAL_INDEX = NO
-# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
-# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
-# in which this list will be split (can be a number in the range [1..20])
+# The COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns in
+# which the alphabetical index list will be split.
+# Minimum value: 1, maximum value: 20, default value: 5.
+# This tag requires that the tag ALPHABETICAL_INDEX is set to YES.
COLS_IN_ALPHA_INDEX = 5
-# In case all classes in a project start with a common prefix, all
-# classes will be put under the same header in the alphabetical index.
-# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
-# should be ignored while generating the index headers.
+# In case all classes in a project start with a common prefix, all classes will
+# be put under the same header in the alphabetical index. The IGNORE_PREFIX tag
+# can be used to specify a prefix (or a list of prefixes) that should be ignored
+# while generating the index headers.
-IGNORE_PREFIX =
+IGNORE_PREFIX =
-# configuration options related to the HTML output
+# Configuration options related to the HTML output
-# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
-# generate HTML output.
+# If the GENERATE_HTML tag is set to YES, doxygen will generate HTML output
GENERATE_HTML = YES
-# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
-# If a relative path is entered the value of OUTPUT_DIRECTORY will be
-# put in front of it. If left blank `html' will be used as the default path.
+# The HTML_OUTPUT tag is used to specify where the HTML docs will be put. If a
+# relative path is entered the value of OUTPUT_DIRECTORY will be put in front of
+# it.
+# The default directory is: html.
+# This tag requires that the tag GENERATE_HTML is set to YES.
HTML_OUTPUT = html
-# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
-# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
-# doxygen will generate files with .html extension.
+# The HTML_FILE_EXTENSION tag can be used to specify the file extension for each
+# generated HTML page (for example: .htm, .php, .asp).
+# The default value is: .html.
HTML_FILE_EXTENSION = .html
-# The HTML_HEADER tag can be used to specify a personal HTML header for
-# each generated HTML page. If it is left blank doxygen will generate a
+# The HTML_HEADER tag can be used to specify a user-defined HTML header file for
+# each generated HTML page. If the tag is left blank doxygen will generate a
# standard header.
+# To get valid HTML the header file that includes any scripts and style sheets
+# that doxygen needs, which is dependent on the configuration options used (e.g.
+# the setting GENERATE_TREEVIEW). It is highly recommended to start with a
+# default header using
+# doxygen -w html new_header.html new_footer.html new_stylesheet.css
+# YourConfigFile
+# and then modify the file new_header.html. See also section "Doxygen usage"
+# for information on how to generate the default header that doxygen normally
+# uses.
+# Note: The header is subject to change so you typically have to regenerate the
+# default header when upgrading to a newer version of doxygen. For a description
+# of the possible markers and block names see the documentation.
+HTML_HEADER =
+# The HTML_FOOTER tag can be used to specify a user-defined HTML footer for each
+# generated HTML page. If the tag is left blank doxygen will generate a standard
+# footer. See HTML_HEADER for more information on how to generate a default
+# footer and what special commands can be used inside the footer. See also
+# section "Doxygen usage" for information on how to generate the default footer
+# that doxygen normally uses.
+HTML_FOOTER =
+# The HTML_STYLESHEET tag can be used to specify a user-defined cascading style
+# sheet that is used by each HTML page. It can be used to fine-tune the look of
+# the HTML output. If left blank doxygen will generate a default style sheet.
+# See also section "Doxygen usage" for information on how to generate the style
+# sheet that doxygen normally uses.
+# Note: It is recommended to use HTML_EXTRA_STYLESHEET instead of this tag, as
+# it is more robust and this tag (HTML_STYLESHEET) will in the future become
+# obsolete.
+HTML_STYLESHEET =
+# The HTML_EXTRA_STYLESHEET tag can be used to specify additional user-defined
+# cascading style sheets that are included after the standard style sheets
+# created by doxygen. Using this option one can overrule certain style aspects.
+# This is preferred over using HTML_STYLESHEET since it does not replace the
+# standard style sheet and is therefore more robust against future updates.
+# Doxygen will copy the style sheet files to the output directory.
+# Note: The order of the extra style sheet files is of importance (e.g. the last
+# style sheet in the list overrules the setting of the previous ones in the
+# list). For an example see the documentation.
+HTML_EXTRA_STYLESHEET =
+# The HTML_EXTRA_FILES tag can be used to specify one or more extra images or
+# other source files which should be copied to the HTML output directory. Note
+# that these files will be copied to the base HTML output directory. Use the
+# $relpath^ marker in the HTML_HEADER and/or HTML_FOOTER files to load these
+# files. In the HTML_STYLESHEET file, use the file name only. Also note that the
+# files will be copied as-is; there are no commands or markers available.
+HTML_EXTRA_FILES =
+# The HTML_COLORSTYLE_HUE tag controls the color of the HTML output. Doxygen
+# will adjust the colors in the style sheet and background images according to
+# this color. Hue is specified as an angle on a colorwheel, see
+# https://en.wikipedia.org/wiki/Hue for more information. For instance the value
+# 0 represents red, 60 is yellow, 120 is green, 180 is cyan, 240 is blue, 300
+# purple, and 360 is red again.
+# Minimum value: 0, maximum value: 359, default value: 220.
+HTML_COLORSTYLE_HUE = 220
+# The HTML_COLORSTYLE_SAT tag controls the purity (or saturation) of the colors
+# in the HTML output. For a value of 0 the output will use grayscales only. A
+# value of 255 will produce the most vivid colors.
+# Minimum value: 0, maximum value: 255, default value: 100.
+HTML_COLORSTYLE_SAT = 100
+# The HTML_COLORSTYLE_GAMMA tag controls the gamma correction applied to the
+# luminance component of the colors in the HTML output. Values below 100
+# gradually make the output lighter, whereas values above 100 make the output
+# darker. The value divided by 100 is the actual gamma applied, so 80 represents
+# a gamma of 0.8, The value 220 represents a gamma of 2.2, and 100 does not
+# change the gamma.
+# Minimum value: 40, maximum value: 240, default value: 80.
+HTML_COLORSTYLE_GAMMA = 80
-HTML_HEADER =
+# If the HTML_TIMESTAMP tag is set to YES then the footer of each generated HTML
+# page will contain the date and time when the page was generated. Setting this
+# to YES can help to show when doxygen was last run and thus if the
+# documentation is up to date.
-# The HTML_FOOTER tag can be used to specify a personal HTML footer for
-# standard footer.
+HTML_TIMESTAMP = NO
-HTML_FOOTER =
+# If the HTML_DYNAMIC_MENUS tag is set to YES then the generated HTML
+# documentation will contain a main index with vertical navigation menus that
+# are dynamically created via Javascript. If disabled, the navigation index will
+# consists of multiple levels of tabs that are statically embedded in every HTML
+# page. Disable this option to support browsers that do not have Javascript,
+# like the Qt help browser.
+HTML_DYNAMIC_MENUS = YES
+# If the HTML_DYNAMIC_SECTIONS tag is set to YES then the generated HTML
+# documentation will contain sections that can be hidden and shown after the
+# page has loaded.
+HTML_DYNAMIC_SECTIONS = NO
+# With HTML_INDEX_NUM_ENTRIES one can control the preferred number of entries
+# shown in the various tree structured indices initially; the user can expand
+# and collapse entries dynamically later on. Doxygen will expand the tree to
+# such a level that at most the specified number of entries are visible (unless
+# a fully collapsed tree already exceeds this amount). So setting the number of
+# entries 1 will produce a full collapsed tree by default. 0 is a special value
+# representing an infinite number of entries and will result in a full expanded
+# tree by default.
+# Minimum value: 0, maximum value: 9999, default value: 100.
+HTML_INDEX_NUM_ENTRIES = 100
+# If the GENERATE_DOCSET tag is set to YES, additional index files will be
+# generated that can be used as input for Apple's Xcode 3 integrated development
+# environment (see: https://developer.apple.com/tools/xcode/), introduced with
+# OSX 10.5 (Leopard). To create a documentation set, doxygen will generate a
+# Makefile in the HTML output directory. Running make will produce the docset in
+# that directory and running make install will install the docset in
+# ~/Library/Developer/Shared/Documentation/DocSets so that Xcode will find it at
+# startup. See https://developer.apple.com/tools/creatingdocsetswithdoxygen.html
+# for more information.
+GENERATE_DOCSET = NO
+# This tag determines the name of the docset feed. A documentation feed provides
+# an umbrella under which multiple documentation sets from a single provider
+# (such as a company or product suite) can be grouped.
+# The default value is: Doxygen generated docs.
+# This tag requires that the tag GENERATE_DOCSET is set to YES.
+DOCSET_FEEDNAME = "Doxygen generated docs"
+# This tag specifies a string that should uniquely identify the documentation
+# set bundle. This should be a reverse domain-name style string, e.g.
+# com.mycompany.MyDocSet. Doxygen will append .docset to the name.
+# The default value is: org.doxygen.Project.
+DOCSET_BUNDLE_ID = org.doxygen.Project
+# The DOCSET_PUBLISHER_ID tag specifies a string that should uniquely identify
+# the documentation publisher. This should be a reverse domain-name style
+# string, e.g. com.mycompany.MyDocSet.documentation.
+# The default value is: org.doxygen.Publisher.
+DOCSET_PUBLISHER_ID = org.doxygen.Publisher
+# The DOCSET_PUBLISHER_NAME tag identifies the documentation publisher.
+# The default value is: Publisher.
+DOCSET_PUBLISHER_NAME = Publisher
+# If the GENERATE_HTMLHELP tag is set to YES then doxygen generates three
+# additional HTML index files: index.hhp, index.hhc, and index.hhk. The
+# index.hhp is a project file that can be read by Microsoft's HTML Help Workshop
+# (see: http://www.microsoft.com/en-us/download/details.aspx?id=21138) on
+# Windows.
+# The HTML Help Workshop contains a compiler that can convert all HTML output
+# generated by doxygen into a single compiled HTML file (.chm). Compiled HTML
+# files are now used as the Windows 98 help format, and will replace the old
+# Windows help format (.hlp) on all Windows platforms in the future. Compressed
+# HTML files also contain an index, a table of contents, and you can search for
+# words in the documentation. The HTML workshop also contains a viewer for
+# compressed HTML files.
+# The default value is: NO.
-# The HTML_STYLESHEET tag can be used to specify a user defined cascading
-# style sheet that is used by each HTML page. It can be used to
-# fine-tune the look of the HTML output. If the tag is left blank doxygen
-# will generate a default style sheet
+GENERATE_HTMLHELP = NO
-HTML_STYLESHEET =
+# The CHM_FILE tag can be used to specify the file name of the resulting .chm
+# file. You can add a path in front of the file if the result should not be
+# written to the html output directory.
+# This tag requires that the tag GENERATE_HTMLHELP is set to YES.
-# If the HTML_TIMESTAMP tag is set to YES then the footer of each generated HTML
-# page will contain the date and time when the page was generated. Setting
-# this to NO can help when comparing the output of multiple runs.
+CHM_FILE =
-HTML_TIMESTAMP = NO
+# The HHC_LOCATION tag can be used to specify the location (absolute path
+# including file name) of the HTML help compiler (hhc.exe). If non-empty,
+# doxygen will try to run the HTML help compiler on the generated index.hhp.
+# The file has to be specified with full path.
-# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
-# files or namespaces will be aligned in HTML using tables. If set to
-# NO a bullet list will be used.
+HHC_LOCATION =
-HTML_ALIGN_MEMBERS = YES
+# The GENERATE_CHI flag controls if a separate .chi index file is generated
+# (YES) or that it should be included in the master .chm file (NO).
-# If the GENERATE_HTMLHELP tag is set to YES, additional index files
-# will be generated that can be used as input for tools like the
-# Microsoft HTML help workshop to generate a compressed HTML help file (.chm)
-# of the generated HTML documentation.
+GENERATE_CHI = NO
-GENERATE_HTMLHELP = NO
+# The CHM_INDEX_ENCODING is used to encode HtmlHelp index (hhk), content (hhc)
+# and project file content.
-# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
-# controls if a separate .chi index file is generated (YES) or that
-# it should be included in the master .chm file (NO).
+CHM_INDEX_ENCODING =
-GENERATE_CHI = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
-# controls whether a binary table of contents is generated (YES) or a
-# normal table of contents (NO) in the .chm file.
+# The BINARY_TOC flag controls whether a binary table of contents is generated
+# (YES) or a normal table of contents (NO) in the .chm file. Furthermore it
+# enables the Previous and Next buttons.
BINARY_TOC = NO
-# The TOC_EXPAND flag can be set to YES to add extra items for group members
-# to the contents of the Html help documentation and to the tree view.
+# The TOC_EXPAND flag can be set to YES to add extra items for group members to
+# the table of contents of the HTML help documentation and to the tree view.
TOC_EXPAND = NO
-# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
-# top of each HTML page. The value NO (the default) enables the index and
-# the value YES disables it.
+# If the GENERATE_QHP tag is set to YES and both QHP_NAMESPACE and
+# QHP_VIRTUAL_FOLDER are set, an additional index file will be generated that
+# can be used as input for Qt's qhelpgenerator to generate a Qt Compressed Help
+# (.qch) of the generated HTML documentation.
-DISABLE_INDEX = NO
+GENERATE_QHP = NO
-# This tag can be used to set the number of enum values (range [1..20])
-# that doxygen will group on one line in the generated HTML documentation.
+# If the QHG_LOCATION tag is specified, the QCH_FILE tag can be used to specify
+# the file name of the resulting .qch file. The path specified is relative to
+# the HTML output folder.
+# This tag requires that the tag GENERATE_QHP is set to YES.
-ENUM_VALUES_PER_LINE = 4
+QCH_FILE =
+# The QHP_NAMESPACE tag specifies the namespace to use when generating Qt Help
+# Project output. For more information please see Qt Help Project / Namespace
+# (see: http://doc.qt.io/qt-4.8/qthelpproject.html#namespace).
+QHP_NAMESPACE = org.doxygen.Project
+# The QHP_VIRTUAL_FOLDER tag specifies the namespace to use when generating Qt
+# Help Project output. For more information please see Qt Help Project / Virtual
+# Folders (see: http://doc.qt.io/qt-4.8/qthelpproject.html#virtual-folders).
+# The default value is: doc.
+QHP_VIRTUAL_FOLDER = doc
+# If the QHP_CUST_FILTER_NAME tag is set, it specifies the name of a custom
+# filter to add. For more information please see Qt Help Project / Custom
+# Filters (see: http://doc.qt.io/qt-4.8/qthelpproject.html#custom-filters).
+QHP_CUST_FILTER_NAME =
-# If the GENERATE_TREEVIEW tag is set to YES, a side panel will be
-# generated containing a tree-like index structure (just like the one that
-# is generated for HTML Help). For this to work a browser that supports
-# JavaScript and frames is required (for instance Mozilla, Netscape 4.0+,
-# or Internet explorer 4.0+). Note that for large projects the tree generation
-# can take a very long time. In such cases it is better to disable this feature.
-# Windows users are probably better off using the HTML help feature.
+# The QHP_CUST_FILTER_ATTRS tag specifies the list of the attributes of the
+# custom filter to add. For more information please see Qt Help Project / Custom
+QHP_CUST_FILTER_ATTRS =
+# The QHP_SECT_FILTER_ATTRS tag specifies the list of the attributes this
+# project's filter section matches. Qt Help Project / Filter Attributes (see:
+# http://doc.qt.io/qt-4.8/qthelpproject.html#filter-attributes).
+QHP_SECT_FILTER_ATTRS =
+# The QHG_LOCATION tag can be used to specify the location of Qt's
+# qhelpgenerator. If non-empty doxygen will try to run qhelpgenerator on the
+# generated .qhp file.
+QHG_LOCATION =
+# If the GENERATE_ECLIPSEHELP tag is set to YES, additional index files will be
+# generated, together with the HTML files, they form an Eclipse help plugin. To
+# install this plugin and make it available under the help contents menu in
+# Eclipse, the contents of the directory containing the HTML and XML files needs
+# to be copied into the plugins directory of eclipse. The name of the directory
+# within the plugins directory should be the same as the ECLIPSE_DOC_ID value.
+# After copying Eclipse needs to be restarted before the help appears.
+GENERATE_ECLIPSEHELP = NO
+# A unique identifier for the Eclipse help plugin. When installing the plugin
+# the directory name containing the HTML and XML files should also have this
+# name. Each documentation set should have its own identifier.
+# This tag requires that the tag GENERATE_ECLIPSEHELP is set to YES.
+ECLIPSE_DOC_ID = org.doxygen.Project
+# If you want full control over the layout of the generated HTML pages it might
+# be necessary to disable the index and replace it with your own. The
+# DISABLE_INDEX tag can be used to turn on/off the condensed index (tabs) at top
+# of each HTML page. A value of NO enables the index and the value YES disables
+# it. Since the tabs in the index contain the same information as the navigation
+# tree, you can set this option to YES if you also set GENERATE_TREEVIEW to YES.
+DISABLE_INDEX = NO
+# The GENERATE_TREEVIEW tag is used to specify whether a tree-like index
+# structure should be generated to display hierarchical information. If the tag
+# value is set to YES, a side panel will be generated containing a tree-like
+# index structure (just like the one that is generated for HTML Help). For this
+# to work a browser that supports JavaScript, DHTML, CSS and frames is required
+# (i.e. any modern browser). Windows users are probably better off using the
+# HTML help feature. Via custom style sheets (see HTML_EXTRA_STYLESHEET) one can
+# further fine-tune the look of the index. As an example, the default style
+# sheet generated by doxygen has an example that shows how to put an image at
+# the root of the tree instead of the PROJECT_NAME. Since the tree basically has
+# the same information as the tab index, you could consider setting
+# DISABLE_INDEX to YES when enabling this option.
GENERATE_TREEVIEW = NO
-# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
-# used to set the initial width (in pixels) of the frame in which the tree
-# is shown.
+# The ENUM_VALUES_PER_LINE tag can be used to set the number of enum values that
+# doxygen will group on one line in the generated HTML documentation.
+# Note that a value of 0 will completely suppress the enum values from appearing
+# in the overview section.
+# Minimum value: 0, maximum value: 20, default value: 4.
+ENUM_VALUES_PER_LINE = 4
+# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be used
+# to set the initial width (in pixels) of the frame in which the tree is shown.
+# Minimum value: 0, maximum value: 1500, default value: 250.
TREEVIEW_WIDTH = 250
+# If the EXT_LINKS_IN_WINDOW option is set to YES, doxygen will open links to
+# external symbols imported via tag files in a separate window.
+EXT_LINKS_IN_WINDOW = NO
+# Use this tag to change the font size of LaTeX formulas included as images in
+# the HTML documentation. When you change the font size after a successful
+# doxygen run you need to manually remove any form_*.png images from the HTML
+# output directory to force them to be regenerated.
+# Minimum value: 8, maximum value: 50, default value: 10.
+FORMULA_FONTSIZE = 10
+# Use the FORMULA_TRANSPARENT tag to determine whether or not the images
+# generated for formulas are transparent PNGs. Transparent PNGs are not
+# supported properly for IE 6.0, but are supported on all modern browsers.
+# Note that when changing this option you need to delete any form_*.png files in
+# the HTML output directory before the changes have effect.
+# The default value is: YES.
+FORMULA_TRANSPARENT = YES
+# Enable the USE_MATHJAX option to render LaTeX formulas using MathJax (see
+# https://www.mathjax.org) which uses client side Javascript for the rendering
+# instead of using pre-rendered bitmaps. Use this if you do not have LaTeX
+# installed or if you want to formulas look prettier in the HTML output. When
+# enabled you may also need to install MathJax separately and configure the path
+# to it using the MATHJAX_RELPATH option.
+USE_MATHJAX = NO
+# When MathJax is enabled you can set the default output format to be used for
+# the MathJax output. See the MathJax site (see:
+# http://docs.mathjax.org/en/latest/output.html) for more details.
+# Possible values are: HTML-CSS (which is slower, but has the best
+# compatibility), NativeMML (i.e. MathML) and SVG.
+# The default value is: HTML-CSS.
+# This tag requires that the tag USE_MATHJAX is set to YES.
+MATHJAX_FORMAT = HTML-CSS
+# When MathJax is enabled you need to specify the location relative to the HTML
+# output directory using the MATHJAX_RELPATH option. The destination directory
+# should contain the MathJax.js script. For instance, if the mathjax directory
+# is located at the same level as the HTML output directory, then
+# MATHJAX_RELPATH should be ../mathjax. The default value points to the MathJax
+# Content Delivery Network so you can quickly see the result without installing
+# MathJax. However, it is strongly recommended to install a local copy of
+# MathJax from https://www.mathjax.org before deployment.
+# The default value is: https://cdnjs.cloudflare.com/ajax/libs/mathjax/2.7.2/.
+MATHJAX_RELPATH = https://cdnjs.cloudflare.com/ajax/libs/mathjax/2.7.2/
+# The MATHJAX_EXTENSIONS tag can be used to specify one or more MathJax
+# extension names that should be enabled during MathJax rendering. For example
+# MATHJAX_EXTENSIONS = TeX/AMSmath TeX/AMSsymbols
+MATHJAX_EXTENSIONS =
+# The MATHJAX_CODEFILE tag can be used to specify a file with javascript pieces
+# of code that will be used on startup of the MathJax code. See the MathJax site
+# (see: http://docs.mathjax.org/en/latest/output.html) for more details. For an
+# example see the documentation.
+MATHJAX_CODEFILE =
+# When the SEARCHENGINE tag is enabled doxygen will generate a search box for
+# the HTML output. The underlying search engine uses javascript and DHTML and
+# should work on any modern browser. Note that when using HTML help
+# (GENERATE_HTMLHELP), Qt help (GENERATE_QHP), or docsets (GENERATE_DOCSET)
+# there is already a search function so this one should typically be disabled.
+# For large projects the javascript based search engine can be slow, then
+# enabling SERVER_BASED_SEARCH may provide a better solution. It is possible to
+# search using the keyboard; to jump to the search box use <access key> + S
+# (what the <access key> is depends on the OS and browser, but it is typically
+# <CTRL>, <ALT>/<option>, or both). Inside the search box use the <cursor down
+# key> to jump into the search results window, the results can be navigated
+# using the <cursor keys>. Press <Enter> to select an item or <escape> to cancel
+# the search. The filter options can be selected when the cursor is inside the
+# search box by pressing <Shift>+<cursor down>. Also here use the <cursor keys>
+# to select a filter and <Enter> or <escape> to activate or cancel the filter
+# option.
+SEARCHENGINE = NO
+# When the SERVER_BASED_SEARCH tag is enabled the search engine will be
+# implemented using a web server instead of a web client using Javascript. There
+# are two flavors of web server based searching depending on the EXTERNAL_SEARCH
+# setting. When disabled, doxygen will generate a PHP script for searching and
+# an index file used by the script. When EXTERNAL_SEARCH is enabled the indexing
+# and searching needs to be provided by external tools. See the section
+# "External Indexing and Searching" for details.
+# This tag requires that the tag SEARCHENGINE is set to YES.
+SERVER_BASED_SEARCH = NO
+# When EXTERNAL_SEARCH tag is enabled doxygen will no longer generate the PHP
+# script for searching. Instead the search results are written to an XML file
+# which needs to be processed by an external indexer. Doxygen will invoke an
+# external search engine pointed to by the SEARCHENGINE_URL option to obtain the
+# search results.
+# Doxygen ships with an example indexer (doxyindexer) and search engine
+# (doxysearch.cgi) which are based on the open source search engine library
+# Xapian (see: https://xapian.org/).
+# See the section "External Indexing and Searching" for details.
+EXTERNAL_SEARCH = NO
+# The SEARCHENGINE_URL should point to a search engine hosted by a web server
+# which will return the search results when EXTERNAL_SEARCH is enabled.
+# Xapian (see: https://xapian.org/). See the section "External Indexing and
+# Searching" for details.
+SEARCHENGINE_URL =
+# When SERVER_BASED_SEARCH and EXTERNAL_SEARCH are both enabled the unindexed
+# search data is written to a file for indexing by an external tool. With the
+# SEARCHDATA_FILE tag the name of this file can be specified.
+# The default file is: searchdata.xml.
+SEARCHDATA_FILE = searchdata.xml
+# EXTERNAL_SEARCH_ID tag can be used as an identifier for the project. This is
+# useful in combination with EXTRA_SEARCH_MAPPINGS to search through multiple
+# projects and redirect the results back to the right project.
+EXTERNAL_SEARCH_ID =
+# The EXTRA_SEARCH_MAPPINGS tag can be used to enable searching through doxygen
+# projects other than the one defined by this configuration file, but that are
+# all added to the same external search index. Each project needs to have a
+# unique id set via EXTERNAL_SEARCH_ID. The search mapping then maps the id of
+# to a relative location where the documentation can be found. The format is:
+# EXTRA_SEARCH_MAPPINGS = tagname1=loc1 tagname2=loc2 ...
+EXTRA_SEARCH_MAPPINGS =
-# configuration options related to the LaTeX output
+# Configuration options related to the LaTeX output
-# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
-# generate Latex output.
+# If the GENERATE_LATEX tag is set to YES, doxygen will generate LaTeX output.
GENERATE_LATEX = NO
-# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
-# put in front of it. If left blank `latex' will be used as the default path.
+# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put. If a
+# it.
+# The default directory is: latex.
+# This tag requires that the tag GENERATE_LATEX is set to YES.
LATEX_OUTPUT = latex
-# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be invoked. If left blank `latex' will be used as the default command name.
+# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
+# invoked.
+# Note that when enabling USE_PDFLATEX this option is only used for generating
+# bitmaps for formulas in the HTML output, but not in the Makefile that is
+# written to the output directory.
+# The default file is: latex.
LATEX_CMD_NAME = latex
-# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
-# generate index for LaTeX. If left blank `makeindex' will be used as the
-# default command name.
+# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to generate
+# index for LaTeX.
+# The default file is: makeindex.
MAKEINDEX_CMD_NAME = makeindex
-# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
-# LaTeX documents. This may be useful for small projects and may help to
-# save some trees in general.
+# If the COMPACT_LATEX tag is set to YES, doxygen generates more compact LaTeX
+# documents. This may be useful for small projects and may help to save some
+# trees in general.
COMPACT_LATEX = NO
-# The PAPER_TYPE tag can be used to set the paper type that is used
-# by the printer. Possible values are: a4, a4wide, letter, legal and
-# executive. If left blank a4wide will be used.
+# The PAPER_TYPE tag can be used to set the paper type that is used by the
+# printer.
+# Possible values are: a4 (210 x 297 mm), letter (8.5 x 11 inches), legal (8.5 x
+# 14 inches) and executive (7.25 x 10.5 inches).
+# The default value is: a4.
PAPER_TYPE = a4wide
-# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
-# packages that should be included in the LaTeX output.
+# The EXTRA_PACKAGES tag can be used to specify one or more LaTeX package names
+# that should be included in the LaTeX output. The package can be specified just
+# by its name or with the correct syntax as to be used with the LaTeX
+# \usepackage command. To get the times font for instance you can specify :
+# EXTRA_PACKAGES=times or EXTRA_PACKAGES={times}
+# To use the option intlimits with the amsmath package you can specify:
+# EXTRA_PACKAGES=[intlimits]{amsmath}
+# If left blank no extra packages will be included.
+EXTRA_PACKAGES =
+# The LATEX_HEADER tag can be used to specify a personal LaTeX header for the
+# generated LaTeX document. The header should contain everything until the first
+# chapter. If it is left blank doxygen will generate a standard header. See
+# section "Doxygen usage" for information on how to let doxygen write the
+# default header to a separate file.
+# Note: Only use a user-defined header if you know what you are doing! The
+# following commands have a special meaning inside the header: $title,
+# $datetime, $date, $doxygenversion, $projectname, $projectnumber,
+# $projectbrief, $projectlogo. Doxygen will replace $title with the empty
+# string, for the replacement values of the other commands the user is referred
+# to HTML_HEADER.
+LATEX_HEADER =
+# The LATEX_FOOTER tag can be used to specify a personal LaTeX footer for the
+# generated LaTeX document. The footer should contain everything after the last
+# chapter. If it is left blank doxygen will generate a standard footer. See
+# LATEX_HEADER for more information on how to generate a default footer and what
+# special commands can be used inside the footer.
+# Note: Only use a user-defined footer if you know what you are doing!
+LATEX_FOOTER =
-EXTRA_PACKAGES =
+# The LATEX_EXTRA_STYLESHEET tag can be used to specify additional user-defined
+# LaTeX style sheets that are included after the standard style sheets created
+# by doxygen. Using this option one can overrule certain style aspects. Doxygen
+# will copy the style sheet files to the output directory.
+# list).
-# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
-# the generated latex document. The header should contain everything until
-# the first chapter. If it is left blank doxygen will generate a
-# standard header. Notice: only use this tag if you know what you are doing!
+LATEX_EXTRA_STYLESHEET =
-LATEX_HEADER =
+# The LATEX_EXTRA_FILES tag can be used to specify one or more extra images or
+# other source files which should be copied to the LATEX_OUTPUT output
+# directory. Note that the files will be copied as-is; there are no commands or
+# markers available.
-# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
-# is prepared for conversion to pdf (using ps2pdf). The pdf file will
-# contain links (just like the HTML output) instead of page references
-# This makes the output suitable for online browsing using a pdf viewer.
+LATEX_EXTRA_FILES =
+# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated is
+# prepared for conversion to PDF (using ps2pdf or pdflatex). The PDF file will
+# contain links (just like the HTML output) instead of page references. This
+# makes the output suitable for online browsing using a PDF viewer.
PDF_HYPERLINKS = NO
-# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
-# plain latex in the generated Makefile. Set this option to YES to get a
+# If the USE_PDFLATEX tag is set to YES, doxygen will use pdflatex to generate
+# the PDF file directly from the LaTeX files. Set this option to YES, to get a
# higher quality PDF documentation.
USE_PDFLATEX = NO
-# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
-# command to the generated LaTeX files. This will instruct LaTeX to keep
-# running if errors occur, instead of asking the user for help.
-# This option is also used when generating formulas in HTML.
+# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \batchmode
+# command to the generated LaTeX files. This will instruct LaTeX to keep running
+# if errors occur, instead of asking the user for help. This option is also used
+# when generating formulas in HTML.
LATEX_BATCHMODE = NO
+# If the LATEX_HIDE_INDICES tag is set to YES then doxygen will not include the
+# index chapters (such as File Index, Compound Index, etc.) in the output.
+LATEX_HIDE_INDICES = NO
+# If the LATEX_SOURCE_CODE tag is set to YES then doxygen will include source
+# code with syntax highlighting in the LaTeX output.
+# Note that which sources are shown also depends on other settings such as
+# SOURCE_BROWSER.
+LATEX_SOURCE_CODE = NO
+# The LATEX_BIB_STYLE tag can be used to specify the style to use for the
+# bibliography, e.g. plainnat, or ieeetr. See
+# https://en.wikipedia.org/wiki/BibTeX and \cite for more info.
+# The default value is: plain.
+LATEX_BIB_STYLE = plain
+# If the LATEX_TIMESTAMP tag is set to YES then the footer of each generated
+# to NO can help when comparing the output of multiple runs.
+LATEX_TIMESTAMP = NO
-# configuration options related to the RTF output
+# Configuration options related to the RTF output
-# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
-# The RTF output is optimised for Word 97 and may not look very pretty with
-# other RTF readers or editors.
+# If the GENERATE_RTF tag is set to YES, doxygen will generate RTF output. The
+# RTF output is optimized for Word 97 and may not look too pretty with other RTF
+# readers/editors.
GENERATE_RTF = NO
-# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
-# put in front of it. If left blank `rtf' will be used as the default path.
+# The RTF_OUTPUT tag is used to specify where the RTF docs will be put. If a
+# it.
+# The default directory is: rtf.
+# This tag requires that the tag GENERATE_RTF is set to YES.
RTF_OUTPUT = rtf
-# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
-# RTF documents. This may be useful for small projects and may help to
+# If the COMPACT_RTF tag is set to YES, doxygen generates more compact RTF
COMPACT_RTF = NO
-# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
-# will contain hyperlink fields. The RTF file will
-# contain links (just like the HTML output) instead of page references.
-# This makes the output suitable for online browsing using WORD or other
-# programs which support those fields.
-# Note: wordpad (write) and others do not support links.
+# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated will
+# contain hyperlink fields. The RTF file will contain links (just like the HTML
+# output) instead of page references. This makes the output suitable for online
+# browsing using Word or some other Word compatible readers that support those
+# fields.
+# Note: WordPad (write) and others do not support links.
RTF_HYPERLINKS = NO
-# Load stylesheet definitions from file. Syntax is similar to doxygen's
-# config file, i.e. a series of assigments. You only have to provide
-# replacements, missing definitions are set to their default value.
+# Load stylesheet definitions from file. Syntax is similar to doxygen's config
+# file, i.e. a series of assignments. You only have to provide replacements,
+# missing definitions are set to their default value.
+# default style sheet that doxygen normally uses.
+RTF_STYLESHEET_FILE =
-RTF_STYLESHEET_FILE =
+# Set optional variables used in the generation of an RTF document. Syntax is
+# similar to doxygen's config file. A template extensions file can be generated
+# using doxygen -e rtf extensionFile.
-# Set optional variables used in the generation of an rtf document.
-# Syntax is similar to doxygen's config file.
+RTF_EXTENSIONS_FILE =
-RTF_EXTENSIONS_FILE =
+# If the RTF_SOURCE_CODE tag is set to YES then doxygen will include source code
+# with syntax highlighting in the RTF output.
+# SOURCE_BROWSER.
+RTF_SOURCE_CODE = NO
-# configuration options related to the man page output
+# Configuration options related to the man page output
-# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
-# generate man pages
+# If the GENERATE_MAN tag is set to YES, doxygen will generate man pages for
+# classes and files.
GENERATE_MAN = NO
-# The MAN_OUTPUT tag is used to specify where the man pages will be put.
-# put in front of it. If left blank `man' will be used as the default path.
+# The MAN_OUTPUT tag is used to specify where the man pages will be put. If a
+# it. A directory man3 will be created inside the directory specified by
+# MAN_OUTPUT.
+# The default directory is: man.
+# This tag requires that the tag GENERATE_MAN is set to YES.
MAN_OUTPUT = man
-# The MAN_EXTENSION tag determines the extension that is added to
-# the generated man pages (default is the subroutine's section .3)
+# The MAN_EXTENSION tag determines the extension that is added to the generated
+# man pages. In case the manual section does not start with a number, the number
+# 3 is prepended. The dot (.) at the beginning of the MAN_EXTENSION tag is
+# optional.
+# The default value is: .3.
MAN_EXTENSION = .3
-# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
-# then it will generate one additional man file for each entity
-# documented in the real man page(s). These additional files
-# only source the real man page, but without them the man command
-# would be unable to find the correct page. The default is NO.
+# The MAN_SUBDIR tag determines the name of the directory created within
+# MAN_OUTPUT in which the man pages are placed. If defaults to man followed by
+# MAN_EXTENSION with the initial . removed.
+MAN_SUBDIR =
+# If the MAN_LINKS tag is set to YES and doxygen generates man output, then it
+# will generate one additional man file for each entity documented in the real
+# man page(s). These additional files only source the real man page, but without
+# them the man command would be unable to find the correct page.
MAN_LINKS = NO
-# configuration options related to the XML output
+# Configuration options related to the XML output
-# If the GENERATE_XML tag is set to YES Doxygen will
-# generate an XML file that captures the structure of
-# the code including all documentation. Note that this
-# feature is still experimental and incomplete at the
-# moment.
+# If the GENERATE_XML tag is set to YES, doxygen will generate an XML file that
+# captures the structure of the code including all documentation.
GENERATE_XML = NO
+# The XML_OUTPUT tag is used to specify where the XML pages will be put. If a
+# it.
+# The default directory is: xml.
+# This tag requires that the tag GENERATE_XML is set to YES.
+XML_OUTPUT = xml
+# If the XML_PROGRAMLISTING tag is set to YES, doxygen will dump the program
+# listings (including syntax highlighting and cross-referencing information) to
+# the XML output. Note that enabling this will significantly increase the size
+# of the XML output.
+XML_PROGRAMLISTING = YES
-# configuration options for the AutoGen Definitions output
+# Configuration options related to the DOCBOOK output
-# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
-# generate an AutoGen Definitions (see autogen.sf.net) file
-# that captures the structure of the code including all
-# documentation. Note that this feature is still experimental
-# and incomplete at the moment.
+# If the GENERATE_DOCBOOK tag is set to YES, doxygen will generate Docbook files
+# that can be used to generate PDF.
+GENERATE_DOCBOOK = NO
+# The DOCBOOK_OUTPUT tag is used to specify where the Docbook pages will be put.
+# If a relative path is entered the value of OUTPUT_DIRECTORY will be put in
+# front of it.
+# The default directory is: docbook.
+# This tag requires that the tag GENERATE_DOCBOOK is set to YES.
+DOCBOOK_OUTPUT = docbook
+# If the DOCBOOK_PROGRAMLISTING tag is set to YES, doxygen will include the
+# program listings (including syntax highlighting and cross-referencing
+# information) to the DOCBOOK output. Note that enabling this will significantly
+# increase the size of the DOCBOOK output.
+DOCBOOK_PROGRAMLISTING = NO
+# Configuration options for the AutoGen Definitions output
+# If the GENERATE_AUTOGEN_DEF tag is set to YES, doxygen will generate an
+# AutoGen Definitions (see http://autogen.sourceforge.net/) file that captures
+# the structure of the code including all documentation. Note that this feature
+# is still experimental and incomplete at the moment.
GENERATE_AUTOGEN_DEF = NO
-# Configuration options related to the preprocessor
+# Configuration options related to the Perl module output
-# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
-# evaluate all C-preprocessor directives found in the sources and include
-# files.
+# If the GENERATE_PERLMOD tag is set to YES, doxygen will generate a Perl module
+# file that captures the structure of the code including all documentation.
+# Note that this feature is still experimental and incomplete at the moment.
+GENERATE_PERLMOD = NO
+# If the PERLMOD_LATEX tag is set to YES, doxygen will generate the necessary
+# Makefile rules, Perl scripts and LaTeX code to be able to generate PDF and DVI
+# output from the Perl module output.
+# This tag requires that the tag GENERATE_PERLMOD is set to YES.
+PERLMOD_LATEX = NO
+# If the PERLMOD_PRETTY tag is set to YES, the Perl module output will be nicely
+# formatted so it can be parsed by a human reader. This is useful if you want to
+# understand what is going on. On the other hand, if this tag is set to NO, the
+# size of the Perl module output will be much smaller and Perl will parse it
+# just the same.
+PERLMOD_PRETTY = YES
+# The names of the make variables in the generated doxyrules.make file are
+# prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX. This is useful
+# so different doxyrules.make files included by the same Makefile don't
+# overwrite each other's variables.
+PERLMOD_MAKEVAR_PREFIX =
+# Configuration options related to the preprocessor
+# If the ENABLE_PREPROCESSING tag is set to YES, doxygen will evaluate all
+# C-preprocessor directives found in the sources and include files.
ENABLE_PREPROCESSING = YES
-# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
-# names in the source code. If set to NO (the default) only conditional
-# compilation will be performed. Macro expansion can be done in a controlled
-# way by setting EXPAND_ONLY_PREDEF to YES.
+# If the MACRO_EXPANSION tag is set to YES, doxygen will expand all macro names
+# in the source code. If set to NO, only conditional compilation will be
+# performed. Macro expansion can be done in a controlled way by setting
+# EXPAND_ONLY_PREDEF to YES.
+# This tag requires that the tag ENABLE_PREPROCESSING is set to YES.
MACRO_EXPANSION = NO
-# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
-# then the macro expansion is limited to the macros specified with the
-# PREDEFINED and EXPAND_AS_PREDEFINED tags.
+# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES then
+# the macro expansion is limited to the macros specified with the PREDEFINED and
+# EXPAND_AS_DEFINED tags.
EXPAND_ONLY_PREDEF = NO
-# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
-# in the INCLUDE_PATH (see below) will be search if a #include is found.
+# If the SEARCH_INCLUDES tag is set to YES, the include files in the
+# INCLUDE_PATH will be searched if a #include is found.
SEARCH_INCLUDES = YES
-# The INCLUDE_PATH tag can be used to specify one or more directories that
-# contain include files that are not input files but should be processed by
-# the preprocessor.
+# The INCLUDE_PATH tag can be used to specify one or more directories that
+# contain include files that are not input files but should be processed by the
+# preprocessor.
+# This tag requires that the tag SEARCH_INCLUDES is set to YES.
-INCLUDE_PATH =
+INCLUDE_PATH =
-# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
-# patterns (like *.h and *.hpp) to filter out the header-files in the
-# directories. If left blank, the patterns specified with FILE_PATTERNS will
-# be used.
+# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
+# patterns (like *.h and *.hpp) to filter out the header-files in the
+# directories. If left blank, the patterns specified with FILE_PATTERNS will be
+# used.
-INCLUDE_FILE_PATTERNS =
+INCLUDE_FILE_PATTERNS =
-# The PREDEFINED tag can be used to specify one or more macro names that
-# are defined before the preprocessor is started (similar to the -D option of
-# gcc). The argument of the tag is a list of macros of the form: name
-# or name=definition (no spaces). If the definition and the = are
-# omitted =1 is assumed.
+# The PREDEFINED tag can be used to specify one or more macro names that are
+# defined before the preprocessor is started (similar to the -D option of e.g.
+# gcc). The argument of the tag is a list of macros of the form: name or
+# name=definition (no spaces). If the definition and the "=" are omitted, "=1"
+# is assumed. To prevent a macro definition from being undefined via #undef or
+# recursively expanded use the := operator instead of the = operator.
-PREDEFINED =
+PREDEFINED =
-# If the MACRO_EXPANSION and EXPAND_PREDEF_ONLY tags are set to YES then
-# this tag can be used to specify a list of macro names that should be expanded.
-# The macro definition that is found in the sources will be used.
-# Use the PREDEFINED tag if you want to use a different macro definition.
+# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then this
+# tag can be used to specify a list of macro names that should be expanded. The
+# macro definition that is found in the sources will be used. Use the PREDEFINED
+# tag if you want to use a different macro definition that overrules the
+# definition found in the source code.
-EXPAND_AS_DEFINED =
+EXPAND_AS_DEFINED =
-# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
-# doxygen's preprocessor will remove all function-like macros that are alone
-# on a line and do not end with a semicolon. Such function macros are typically
-# used for boiler-plate code, and will confuse the parser if not removed.
+# If the SKIP_FUNCTION_MACROS tag is set to YES then doxygen's preprocessor will
+# remove all references to function-like macros that are alone on a line, have
+# an all uppercase name, and do not end with a semicolon. Such function macros
+# are typically used for boiler-plate code, and will confuse the parser if not
+# removed.
SKIP_FUNCTION_MACROS = YES
-# Configuration::addtions related to external references
+# Configuration options related to external references
-# The TAGFILES tag can be used to specify one or more tagfiles.
+# The TAGFILES tag can be used to specify one or more tag files. For each tag
+# file the location of the external documentation should be added. The format of
+# a tag file without this location is as follows:
+# TAGFILES = file1 file2 ...
+# Adding location for the tag files is done as follows:
+# TAGFILES = file1=loc1 "file2 = loc2" ...
+# where loc1 and loc2 can be relative or absolute paths or URLs. See the
+# section "Linking to external documentation" for more information about the use
+# of tag files.
+# Note: Each tag file must have a unique name (where the name does NOT include
+# the path). If a tag file is not located in the directory in which doxygen is
+# run, you must also specify the path to the tagfile here.
-TAGFILES =
+TAGFILES =
-# When a file name is specified after GENERATE_TAGFILE, doxygen will create
-# a tag file that is based on the input files it reads.
+# When a file name is specified after GENERATE_TAGFILE, doxygen will create a
+# tag file that is based on the input files it reads. See section "Linking to
+# external documentation" for more information about the usage of tag files.
-GENERATE_TAGFILE =
+GENERATE_TAGFILE =
-# If the ALLEXTERNALS tag is set to YES all external classes will be listed
-# in the class index. If set to NO only the inherited external classes
-# will be listed.
+# If the ALLEXTERNALS tag is set to YES, all external class will be listed in
+# the class index. If set to NO, only the inherited external classes will be
+# listed.
ALLEXTERNALS = NO
-# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
-# in the modules index. If set to NO, only the current project's groups will
-# be listed.
+# If the EXTERNAL_GROUPS tag is set to YES, all external groups will be listed
+# in the modules index. If set to NO, only the current project's groups will be
+# listed.
EXTERNAL_GROUPS = YES
-# The PERL_PATH should be the absolute path and name of the perl script
-# interpreter (i.e. the result of `which perl').
+# If the EXTERNAL_PAGES tag is set to YES, all external pages will be listed in
+# the related pages index. If set to NO, only the current project's pages will
+# be listed.
+EXTERNAL_PAGES = YES
+# The PERL_PATH should be the absolute path and name of the perl script
+# interpreter (i.e. the result of 'which perl').
+# The default file (with absolute path) is: /usr/bin/perl.
PERL_PATH = /usr/bin/perl
-# Configuration options related to the dot tool
+# Configuration options related to the dot tool
-# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
-# generate a inheritance diagram (in Html, RTF and LaTeX) for classes with base or
-# super classes. Setting the tag to NO turns the diagrams off. Note that this
-# option is superceded by the HAVE_DOT option below. This is only a fallback. It is
-# recommended to install and use dot, since it yield more powerful graphs.
+# If the CLASS_DIAGRAMS tag is set to YES, doxygen will generate a class diagram
+# (in HTML and LaTeX) for classes with base or super classes. Setting the tag to
+# NO turns the diagrams off. Note that this option also works with HAVE_DOT
+# disabled, but it is recommended to install and use dot, since it yields more
+# powerful graphs.
CLASS_DIAGRAMS = YES
-# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
-# available from the path. This tool is part of Graphviz, a graph visualization
-# toolkit from AT&T and Lucent Bell Labs. The other options in this section
-# have no effect if this option is set to NO (the default)
+# You can define message sequence charts within doxygen comments using the \msc
+# command. Doxygen will then run the mscgen tool (see:
+# http://www.mcternan.me.uk/mscgen/)) to produce the chart and insert it in the
+# documentation. The MSCGEN_PATH tag allows you to specify the directory where
+# the mscgen tool resides. If left empty the tool is assumed to be found in the
+# default search path.
+MSCGEN_PATH =
+# You can include diagrams made with dia in doxygen documentation. Doxygen will
+# then run dia to produce the diagram and insert it in the documentation. The
+# DIA_PATH tag allows you to specify the directory where the dia binary resides.
+# If left empty dia is assumed to be found in the default search path.
+DIA_PATH =
+# If set to YES the inheritance and collaboration graphs will hide inheritance
+# and usage relations if the target is undocumented or is not a class.
+HIDE_UNDOC_RELATIONS = YES
+# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
+# available from the path. This tool is part of Graphviz (see:
+# http://www.graphviz.org/), a graph visualization toolkit from AT&T and Lucent
+# Bell Labs. The other options in this section have no effect if this option is
+# set to NO
HAVE_DOT = NO
-# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# will generate a graph for each documented class showing the direct and
-# indirect inheritance relations. Setting this tag to YES will force the
-# the CLASS_DIAGRAMS tag to NO.
+# The DOT_NUM_THREADS specifies the number of dot invocations doxygen is allowed
+# to run in parallel. When set to 0 doxygen will base this on the number of
+# processors available in the system. You can set it explicitly to a value
+# larger than 0 to get control over the balance between CPU load and processing
+# speed.
+# Minimum value: 0, maximum value: 32, default value: 0.
+# This tag requires that the tag HAVE_DOT is set to YES.
+DOT_NUM_THREADS = 0
+# When you want a differently looking font in the dot files that doxygen
+# generates you can specify the font name using DOT_FONTNAME. You need to make
+# sure dot is able to find the font, which can be done by putting it in a
+# standard location or by setting the DOTFONTPATH environment variable or by
+# setting DOT_FONTPATH to the directory containing the font.
+# The default value is: Helvetica.
+DOT_FONTNAME = Helvetica
+# The DOT_FONTSIZE tag can be used to set the size (in points) of the font of
+# dot graphs.
+# Minimum value: 4, maximum value: 24, default value: 10.
+DOT_FONTSIZE = 10
+# By default doxygen will tell dot to use the default font as specified with
+# DOT_FONTNAME. If you specify a different font using DOT_FONTNAME you can set
+# the path where dot can find it using this tag.
+DOT_FONTPATH =
+# If the CLASS_GRAPH tag is set to YES then doxygen will generate a graph for
+# each documented class showing the direct and indirect inheritance relations.
+# Setting this tag to YES will force the CLASS_DIAGRAMS tag to NO.
CLASS_GRAPH = YES
-# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# indirect implementation dependencies (inheritance, containment, and
-# class references variables) of the class with other documented classes.
+# If the COLLABORATION_GRAPH tag is set to YES then doxygen will generate a
+# graph for each documented class showing the direct and indirect implementation
+# dependencies (inheritance, containment, and class references variables) of the
+# class with other documented classes.
COLLABORATION_GRAPH = YES
-# If set to YES, the inheritance and collaboration graphs will show the
-# relations between templates and their instances.
+# If the GROUP_GRAPHS tag is set to YES then doxygen will generate a graph for
+# groups, showing the direct groups dependencies.
-TEMPLATE_RELATIONS = YES
+GROUP_GRAPHS = YES
-# If set to YES, the inheritance and collaboration graphs will hide
-# inheritance and usage relations if the target is undocumented
-# or is not a class.
+# If the UML_LOOK tag is set to YES, doxygen will generate inheritance and
+# collaboration diagrams in a style similar to the OMG's Unified Modeling
+# Language.
-HIDE_UNDOC_RELATIONS = YES
+UML_LOOK = NO
+# If the UML_LOOK tag is enabled, the fields and methods are shown inside the
+# class node. If there are many fields or methods and many nodes the graph may
+# become too big to be useful. The UML_LIMIT_NUM_FIELDS threshold limits the
+# number of items for each type to make the size more manageable. Set this to 0
+# for no limit. Note that the threshold may be exceeded by 50% before the limit
+# is enforced. So when you set the threshold to 10, up to 15 fields may appear,
+# but if the number exceeds 15, the total amount of fields shown is limited to
+# 10.
+# Minimum value: 0, maximum value: 100, default value: 10.
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
-# tags are set to YES then doxygen will generate a graph for each documented
-# file showing the direct and indirect include dependencies of the file with
-# other documented files.
+UML_LIMIT_NUM_FIELDS = 10
+# If the TEMPLATE_RELATIONS tag is set to YES then the inheritance and
+# collaboration graphs will show the relations between templates and their
+# instances.
+TEMPLATE_RELATIONS = YES
+# If the INCLUDE_GRAPH, ENABLE_PREPROCESSING and SEARCH_INCLUDES tags are set to
+# YES then doxygen will generate a graph for each documented file showing the
+# direct and indirect include dependencies of the file with other documented
+# files.
INCLUDE_GRAPH = YES
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
-# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
-# documented header file showing the documented files that directly or
-# indirectly include this file.
+# If the INCLUDED_BY_GRAPH, ENABLE_PREPROCESSING and SEARCH_INCLUDES tags are
+# set to YES then doxygen will generate a graph for each documented file showing
+# the direct and indirect include dependencies of the file with other documented
+# files.
INCLUDED_BY_GRAPH = YES
-# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
-# will graphical hierarchy of all classes instead of a textual one.
+# If the CALL_GRAPH tag is set to YES then doxygen will generate a call
+# dependency graph for every global function or class method.
+# Note that enabling this option will significantly increase the time of a run.
+# So in most cases it will be better to enable call graphs for selected
+# functions only using the \callgraph command. Disabling a call graph can be
+# accomplished by means of the command \hidecallgraph.
+CALL_GRAPH = NO
+# If the CALLER_GRAPH tag is set to YES then doxygen will generate a caller
+# So in most cases it will be better to enable caller graphs for selected
+# functions only using the \callergraph command. Disabling a caller graph can be
+# accomplished by means of the command \hidecallergraph.
+CALLER_GRAPH = NO
+# If the GRAPHICAL_HIERARCHY tag is set to YES then doxygen will graphical
+# hierarchy of all classes instead of a textual one.
GRAPHICAL_HIERARCHY = YES
-# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
-# generated by dot. Possible values are png, jpg, or gif
-# If left blank png will be used.
+# If the DIRECTORY_GRAPH tag is set to YES then doxygen will show the
+# dependencies a directory has on other directories in a graphical way. The
+# dependency relations are determined by the #include relations between the
+# files in the directories.
+DIRECTORY_GRAPH = YES
+# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
+# generated by dot. For an explanation of the image formats see the section
+# output formats in the documentation of the dot tool (Graphviz (see:
+# http://www.graphviz.org/)).
+# Note: If you choose svg you need to set HTML_FILE_EXTENSION to xhtml in order
+# to make the SVG files visible in IE 9+ (other browsers do not have this
+# requirement).
+# Possible values are: png, jpg, gif, svg, png:gd, png:gd:gd, png:cairo,
+# png:cairo:gd, png:cairo:cairo, png:cairo:gdiplus, png:gdiplus and
+# png:gdiplus:gdiplus.
+# The default value is: png.
DOT_IMAGE_FORMAT = png
-# The tag DOT_PATH can be used to specify the path where the dot tool can be
-# found. If left blank, it is assumed the dot tool can be found on the path.
+# If DOT_IMAGE_FORMAT is set to svg, then this option can be set to YES to
+# enable generation of interactive SVG images that allow zooming and panning.
+# Note that this requires a modern browser other than Internet Explorer. Tested
+# and working are Firefox, Chrome, Safari, and Opera.
+# Note: For IE 9+ you need to set HTML_FILE_EXTENSION to xhtml in order to make
+# the SVG files visible. Older versions of IE do not have SVG support.
+INTERACTIVE_SVG = NO
-DOT_PATH =
+# The DOT_PATH tag can be used to specify the path where the dot tool can be
+# found. If left blank, it is assumed the dot tool can be found in the path.
-# The DOTFILE_DIRS tag can be used to specify one or more directories that
-# contain dot files that are included in the documentation (see the
-# \dotfile command).
+DOT_PATH =
-DOTFILE_DIRS =
+# The DOTFILE_DIRS tag can be used to specify one or more directories that
+# contain dot files that are included in the documentation (see the \dotfile
+# command).
-# The MAX_DOT_GRAPH_WIDTH tag can be used to set the maximum allowed width
-# (in pixels) of the graphs generated by dot. If a graph becomes larger than
-# this value, doxygen will try to truncate the graph, so that it fits within
-# the specified constraint. Beware that most browsers cannot cope with very
-# large images.
+DOTFILE_DIRS =
-MAX_DOT_GRAPH_WIDTH = 1024
+# The MSCFILE_DIRS tag can be used to specify one or more directories that
+# contain msc files that are included in the documentation (see the \mscfile
+# command).
-# The MAX_DOT_GRAPH_HEIGHT tag can be used to set the maximum allows height
-# large images.
+MSCFILE_DIRS =
-MAX_DOT_GRAPH_HEIGHT = 1024
+# The DIAFILE_DIRS tag can be used to specify one or more directories that
+# contain dia files that are included in the documentation (see the \diafile
+# command).
-# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
-# generate a legend page explaining the meaning of the various boxes and
-# arrows in the dot generated graphs.
+DIAFILE_DIRS =
-GENERATE_LEGEND = YES
+# When using plantuml, the PLANTUML_JAR_PATH tag should be used to specify the
+# path where java can find the plantuml.jar file. If left blank, it is assumed
+# PlantUML is not used or called during a preprocessing step. Doxygen will
+# generate a warning when it encounters a \startuml command in this case and
+# will not generate output for the diagram.
-# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
-# remove the intermedate dot files that are used to generate
-# the various graphs.
+PLANTUML_JAR_PATH =
-DOT_CLEANUP = YES
+# When using plantuml, the PLANTUML_CFG_FILE tag can be used to specify a
+# configuration file for plantuml.
-# Configuration::addtions related to the search engine
+PLANTUML_CFG_FILE =
-# The SEARCHENGINE tag specifies whether or not a search engine should be
-# used. If set to NO the values of all tags below this one will be ignored.
+# When using plantuml, the specified paths are searched for files specified by
+# the !include statement in a plantuml block.
-SEARCHENGINE = NO
+PLANTUML_INCLUDE_PATH =
-# The CGI_NAME tag should be the name of the CGI script that
-# starts the search engine (doxysearch) with the correct parameters.
-# A script with this name will be generated by doxygen.
+# The DOT_GRAPH_MAX_NODES tag can be used to set the maximum number of nodes
+# that will be shown in the graph. If the number of nodes in a graph becomes
+# larger than this value, doxygen will truncate the graph, which is visualized
+# by representing a node as a red box. Note that doxygen if the number of direct
+# children of the root node in a graph is already larger than
+# DOT_GRAPH_MAX_NODES then the graph will not be shown at all. Also note that
+# the size of a graph can be further restricted by MAX_DOT_GRAPH_DEPTH.
+# Minimum value: 0, maximum value: 10000, default value: 50.
-#CGI_NAME = search.cgi
+DOT_GRAPH_MAX_NODES = 50
-# The CGI_URL tag should be the absolute URL to the directory where the
-# cgi binaries are located. See the documentation of your http daemon for
-# details.
+# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the graphs
+# generated by dot. A depth value of 3 means that only nodes reachable from the
+# root by following a path via at most 3 edges will be shown. Nodes that lay
+# further from the root node will be omitted. Note that setting this option to 1
+# or 2 may greatly reduce the computation time needed for large code bases. Also
+# note that the size of a graph can be further restricted by
+# DOT_GRAPH_MAX_NODES. Using a depth of 0 means no depth restriction.
+# Minimum value: 0, maximum value: 1000, default value: 0.
-#CGI_URL =
+MAX_DOT_GRAPH_DEPTH = 0
-# The DOC_URL tag should be the absolute URL to the directory where the
-# documentation is located. If left blank the absolute path to the
-# documentation, with file:// prepended to it, will be used.
+# Set the DOT_TRANSPARENT tag to YES to generate images with a transparent
+# background. This is disabled by default, because dot on Windows does not seem
+# to support this out of the box.
+# Warning: Depending on the platform used, enabling this option may lead to
+# badly anti-aliased labels on the edges of a graph (i.e. they become hard to
+# read).
-#DOC_URL =
+DOT_TRANSPARENT = NO
-# The DOC_ABSPATH tag should be the absolute path to the directory where the
-# documentation is located. If left blank the directory on the local machine
-# will be used.
+# Set the DOT_MULTI_TARGETS tag to YES to allow dot to generate multiple output
+# files in one run (i.e. multiple -o and -T options on the command line). This
+# makes dot run faster, but since only newer versions of dot (>1.8.10) support
+# this, this feature is disabled by default.
-#DOC_ABSPATH =
+DOT_MULTI_TARGETS = NO
-# The BIN_ABSPATH tag must point to the directory where the doxysearch binary
-# is installed.
+# If the GENERATE_LEGEND tag is set to YES doxygen will generate a legend page
+# explaining the meaning of the various boxes and arrows in the dot generated
+# graphs.
-#BIN_ABSPATH = /usr/local/bin/
+GENERATE_LEGEND = YES
-# The EXT_DOC_PATHS tag can be used to specify one or more paths to
-# documentation generated for other projects. This allows doxysearch to search
-# the documentation for these projects as well.
+# If the DOT_CLEANUP tag is set to YES, doxygen will remove the intermediate dot
+# files that are used to generate the various graphs.
-#EXT_DOC_PATHS =
+DOT_CLEANUP = YES
commit ab5b821dec0d233a64d5f915adca3b44473d5e1e
Author: nila <n_larsson at yahoo.com>
Date: Thu May 30 15:01:41 2019 +0200
Hide doxygen generated doc files from git
diff --git a/.gitignore b/.gitignore
index d2df64a..943930e 100644
--- a/.gitignore
+++ b/.gitignore
@@ -61,6 +61,7 @@ configure
depcomp
doc/Doxyfile
doc/example
+doc/doxygen_docs
include/config.h
include/config.h.in
authors.git
Summary of changes:
.gitignore | 1 +
doc/Doxyfile.in | 2613 +++++++++++++++++++++++++++++++++++++++++++------------
2 files changed, 2060 insertions(+), 554 deletions(-)
hooks/post-receive
More information about the geos-commits
