[geos-commits] [SCM] GEOS branch master updated. 09ca35b403759c07a98aec829add26364f08a156
git at osgeo.org
git at osgeo.org
Sun Jun 2 22:47:25 PDT 2019
the project "GEOS".
via 09ca35b403759c07a98aec829add26364f08a156 (commit)
from 8cb7ae530008835c8e74cc5461c15683a9642e50 (commit)
revisions in full, below.
commit 09ca35b403759c07a98aec829add26364f08a156
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jun 3 07:32:22 2019 +0200
Fix some doxygen link resolutions
diff --git a/include/geos/algorithm/distance/DiscreteFrechetDistance.h b/include/geos/algorithm/distance/DiscreteFrechetDistance.h
index b1dacee..85cfb1c 100644
--- a/include/geos/algorithm/distance/DiscreteFrechetDistance.h
+++ b/include/geos/algorithm/distance/DiscreteFrechetDistance.h
@@ -62,7 +62,7 @@ namespace distance { // geos::algorithm::distance
/** \brief
* An algorithm for computing a distance metric
* which is an approximation to the Frechet Distance
- * based on a discretization of the input {@link Geometry}.
+ * based on a discretization of the input {@link geom::Geometry}.
* The algorithm computes the Frechet distance restricted to discrete points
* for one of the geometries.
diff --git a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
index 10a8bef..df198cc 100644
--- a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
+++ b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
@@ -59,7 +59,7 @@ namespace distance { // geos::algorithm::distance
/** \brief
* which is an approximation to the Hausdorff Distance
* The algorithm computes the Hausdorff distance restricted to discrete points
diff --git a/include/geos/operation/distance/DistanceOp.h b/include/geos/operation/distance/DistanceOp.h
index e8f45cc..33b831b 100644
--- a/include/geos/operation/distance/DistanceOp.h
+++ b/include/geos/operation/distance/DistanceOp.h
@@ -56,7 +56,7 @@ namespace distance { // geos::operation::distance
* \brief
- * Find two points on two {@link Geometry}s which lie
+ * Find two points on two {@link geom::Geometry}s which lie
* within a given distance, or else are the nearest points
* on the geometries (in which case this also
* provides the distance between the geometries).
@@ -78,8 +78,8 @@ public:
* \brief
* Compute the distance between the nearest points of two geometries.
- * @param g0 a {@link Geometry}
- * @param g1 another {@link Geometry}
+ * @param g0 a {@link geom::Geometry}
+ * @param g1 another {@link geom::Geometry}
* @return the distance between the geometries
* @return 0 if either input geometry is empty
* @throws IllegalArgumentException if either input geometry is null
@@ -96,8 +96,8 @@ public:
* Test whether two geometries lie within a given distance of
* each other.
* @param distance the distance to test
* @return true if g0.distance(g1) <= distance
@@ -110,8 +110,8 @@ public:
* The points are presented in the same order as the input Geometries.
* @return the nearest points in the geometries, ownership to caller.
* A NULL return means one of the geometries is empty.
@@ -126,8 +126,8 @@ public:
* @return the closest points in the geometries, ownership to caller.
@@ -177,7 +177,7 @@ public:
* Report the coordinates of the closest points in the input geometries.
- * @return a pair of {@link Coordinate}s of the closest points
+ * @return a pair of {@link geom::Coordinate}s of the closest points
* as a newly allocated object (ownership to caller)
* @deprecated renamed to nearestPoints
@@ -188,7 +188,7 @@ public:
* Report the coordinates of the nearest points in the input geometries.
- * @return a pair of {@link Coordinate}s of the nearest points
+ * @return a pair of {@link geom::Coordinate}s of the nearest points
diff --git a/include/geos/operation/overlay/snap/GeometrySnapper.h b/include/geos/operation/overlay/snap/GeometrySnapper.h
index d984fa7..224f0da 100644
--- a/include/geos/operation/overlay/snap/GeometrySnapper.h
+++ b/include/geos/operation/overlay/snap/GeometrySnapper.h
@@ -41,7 +41,7 @@ namespace overlay { // geos::operation::overlay
namespace snap { // geos::operation::overlay::snap
/** \brief
- * Snaps the vertices and segments of a {@link Geometry}
+ * Snaps the vertices and segments of a {@link geom::Geometry}
* to another Geometry's vertices.
* A snap distance tolerance is used to control where snapping is performed.
@@ -89,7 +89,7 @@ public:
/** \brief
- * Snaps the vertices in the component {@link LineString}s
+ * Snaps the vertices in the component {@link geom::LineString}s
* of the source geometry to the vertices of the given snap geometry
* with a given snap tolerance
@@ -101,7 +101,7 @@ public:
double snapTolerance);
/** \brief
* of the source geometry to the vertices of itself
* with a given snap tolerance and optionally cleaning the result.
diff --git a/include/geos/operation/union/CascadedPolygonUnion.h b/include/geos/operation/union/CascadedPolygonUnion.h
index c095bf2..dc8cd85 100644
--- a/include/geos/operation/union/CascadedPolygonUnion.h
+++ b/include/geos/operation/union/CascadedPolygonUnion.h
@@ -52,7 +52,8 @@ namespace geounion { // geos::operation::geounion
* \brief
* Provides an efficient method of unioning a collection of
- * {@link Polygonal} geometries.
+ * {@link geom::Polygonal} geometries.
* This algorithm is faster and likely more robust than
* the simple iterated approach of
* repeatedly unioning each polygon to a result geometry.
@@ -103,15 +104,17 @@ public:
* Computes the union of
- * a collection of {@link Polygonal} {@link Geometry}s.
+ * a collection of {@link geom::Polygonal} {@link geom::Geometry}s.
- * @param polys a collection of {@link Polygonal} {@link Geometry}s.
- * ownership of elements _and_ vector are left to caller.
+ * @param polys a collection of {@link geom::Polygonal}
+ * {@link geom::Geometry}s.
+ * ownership of elements _and_ vector are left to caller.
static geom::Geometry* Union(std::vector<geom::Polygon*>* polys);
- * Computes the union of a set of {@link Polygonal} {@link Geometry}s.
+ * Computes the union of a set of {@link geom::Polygonal}
* @tparam T an iterator yelding something castable to const Polygon *
* @param start start iterator
@@ -131,19 +134,21 @@ public:
+ * Ownership of elements _and_ vector are left to caller.
static geom::Geometry* Union(const geom::MultiPolygon* polys);
* Creates a new instance to union
- * the given collection of {@link Geometry}s.
+ * the given collection of {@link geom::Geometry}s.
- * @param geoms a collection of {@link Polygonal} {@link Geometry}s
+ * @param geoms a collection of {@link geom::Polygonal}
CascadedPolygonUnion(std::vector<geom::Polygon*>* polys)
: inputPolys(polys),
diff --git a/include/geos/operation/union/CascadedUnion.h b/include/geos/operation/union/CascadedUnion.h
index 77d6361..ecfa4a7 100644
--- a/include/geos/operation/union/CascadedUnion.h
+++ b/include/geos/operation/union/CascadedUnion.h
@@ -70,15 +70,15 @@ public:
CascadedUnion();
- * Computes the union of a collection of {@link Geometry}s.
+ * Computes the union of a collection of {@link geom::Geometry}s.
- * @param geoms a collection of {@link Geometry}s.
+ * @param geoms a collection of {@link geom::Geometry}s.
static geom::Geometry* Union(std::vector<geom::Geometry*>* geoms);
- * Computes the union of a set of {@link Geometry}s.
+ * Computes the union of a set of {@link geom::Geometry}s.
* @tparam T an iterator yelding something castable to const Geometry *
@@ -98,10 +98,10 @@ public:
- * @param geoms a collection of {@link Geometryal} {@link Geometry}s
CascadedUnion(const std::vector<geom::Geometry*>* geoms)
: inputGeoms(geoms),
diff --git a/include/geos/precision/GeometryPrecisionReducer.h b/include/geos/precision/GeometryPrecisionReducer.h
index 5999839..250c626 100644
--- a/include/geos/precision/GeometryPrecisionReducer.h
+++ b/include/geos/precision/GeometryPrecisionReducer.h
@@ -36,8 +36,8 @@ namespace geos {
namespace precision { // geos.precision
/** \brief
- * Reduces the precision of a {@link Geometry}
- * according to the supplied {@link PrecisionModel},
+ * Reduces the precision of a {@link geom::Geometry}
+ * according to the supplied {@link geom::PrecisionModel},
* ensuring that the result is topologically valid.
class GEOS_DLL GeometryPrecisionReducer {
diff --git a/include/geos/precision/SimpleGeometryPrecisionReducer.h b/include/geos/precision/SimpleGeometryPrecisionReducer.h
index 982d38a..cd8b1b3 100644
--- a/include/geos/precision/SimpleGeometryPrecisionReducer.h
+++ b/include/geos/precision/SimpleGeometryPrecisionReducer.h
@@ -29,8 +29,8 @@ namespace geos {
/** \brief
- * according to the supplied {@link PrecisionModel}, without
+ * according to the supplied {@link geom::PrecisionModel}, without
* attempting to preserve valid topology.
* The topology of the resulting geometry may be invalid if
diff --git a/include/geos/triangulate/DelaunayTriangulationBuilder.h b/include/geos/triangulate/DelaunayTriangulationBuilder.h
index e39e9bf..38379d2 100644
--- a/include/geos/triangulate/DelaunayTriangulationBuilder.h
+++ b/include/geos/triangulate/DelaunayTriangulationBuilder.h
@@ -55,14 +55,18 @@ namespace triangulate { //geos.triangulate
class GEOS_DLL DelaunayTriangulationBuilder {
public:
- * Extracts the unique {@link Coordinate}s from the given {@link Geometry}.
+ * Extracts the unique {@link geom::Coordinate}s from the given
+ * {@link geom::Geometry}.
* @param geom the geometry to extract from
* @return a List of the unique Coordinates. Caller takes ownership of the returned object.
static std::unique_ptr<geom::CoordinateSequence> extractUniqueCoordinates(const geom::Geometry& geom);
- * Converts all {@link Coordinate}s in a collection to {@link Vertex}es.
+ * Converts all {@link geom::Coordinate}s in a collection to
+ * {@link quadedge::Vertex}es.
* @param coords the coordinates to convert
* @return a List of Vertex objects. Call takes ownership of returned object.
@@ -99,7 +103,7 @@ public:
* Sets the sites (vertices) which will be triangulated
- * from a collection of {@link Coordinate}s.
+ * from a collection of {@link geom::Coordinate}s.
* @param geom a CoordinateSequence.
@@ -130,7 +134,7 @@ public:
quadedge::QuadEdgeSubdivision& getSubdivision();
- * Gets the edges of the computed triangulation as a {@link MultiLineString}.
+ * Gets the edges of the computed triangulation as a {@link geom::MultiLineString}.
* @param geomFact the geometry factory to use to create the output
* @return the edges of the triangulation. The caller takes ownership of the returned object.
@@ -138,8 +142,8 @@ public:
std::unique_ptr<geom::MultiLineString> getEdges(const geom::GeometryFactory& geomFact);
- * Gets the faces of the computed triangulation as a {@link GeometryCollection}
- * of {@link Polygon}.
+ * Gets the faces of the computed triangulation as a {@link geom::GeometryCollection}
+ * of {@link geom::Polygon}.
* @return the faces of the triangulation. The caller takes ownership of the returned object.
@@ -147,7 +151,8 @@ public:
std::unique_ptr<geom::GeometryCollection> getTriangles(const geom::GeometryFactory& geomFact);
- * Computes the {@link Envelope} of a collection of {@link Coordinate}s.
+ * Computes the {@link geom::Envelope} of a collection of
+ * {@link geom::Coordinate}s.
* @param coords a List of Coordinates
* @return the envelope of the set of coordinates
diff --git a/include/geos/triangulate/IncrementalDelaunayTriangulator.h b/include/geos/triangulate/IncrementalDelaunayTriangulator.h
index b4ad5fc..340e2e2 100644
--- a/include/geos/triangulate/IncrementalDelaunayTriangulator.h
+++ b/include/geos/triangulate/IncrementalDelaunayTriangulator.h
@@ -33,8 +33,8 @@ class QuadEdgeSubdivision;
- * Computes a Delauanay Triangulation of a set of {@link Vertex}es, using an
- * incrementatal insertion algorithm.
+ * Computes a Delauanay Triangulation of a set of {@link quadedge::Vertex}es,
+ * using an incrementatal insertion algorithm.
* @author JTS: Martin Davis
* @author Benjamin Campbell
@@ -46,7 +46,7 @@ private:
public:
- * Creates a new triangulator using the given {@link QuadEdgeSubdivision}.
+ * Creates a new triangulator using the given {@link quadedge::QuadEdgeSubdivision}.
* The triangulator uses the tolerance of the supplied subdivision.
* @param subdiv
Summary of changes:
.../algorithm/distance/DiscreteFrechetDistance.h | 2 +-
.../algorithm/distance/DiscreteHausdorffDistance.h | 2 +-
include/geos/operation/distance/DistanceOp.h | 22 +++++++++---------
.../geos/operation/overlay/snap/GeometrySnapper.h | 6 ++---
.../geos/operation/union/CascadedPolygonUnion.h | 27 +++++++++++++---------
include/geos/operation/union/CascadedUnion.h | 12 +++++-----
include/geos/precision/GeometryPrecisionReducer.h | 4 ++--
.../precision/SimpleGeometryPrecisionReducer.h | 4 ++--
.../triangulate/DelaunayTriangulationBuilder.h | 19 +++++++++------
.../triangulate/IncrementalDelaunayTriangulator.h | 6 ++---
10 files changed, 57 insertions(+), 47 deletions(-)
hooks/post-receive
More information about the geos-commits
