[geos-commits] [SCM] GEOS branch master updated. 47c50306157577e9a923ab532a9361eb65bd2074
git at osgeo.org
git at osgeo.org
Mon Jun 3 05:24:29 PDT 2019
the project "GEOS".
via 47c50306157577e9a923ab532a9361eb65bd2074 (commit)
via 73851a3508f759c6692577862ab54fc762900d33 (commit)
via 62a875357de7b971debc7e7f85a5a7ed462dc649 (commit)
from 09ca35b403759c07a98aec829add26364f08a156 (commit)
revisions in full, below.
commit 47c50306157577e9a923ab532a9361eb65bd2074
Merge: 09ca35b 73851a3
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Jun 3 08:23:26 2019 -0400
Merge branch 'voronoi-perf'
diff --cc include/geos/triangulate/DelaunayTriangulationBuilder.h
index 38379d2,e42d967..3f79bd6
--- a/include/geos/triangulate/DelaunayTriangulationBuilder.h
+++ b/include/geos/triangulate/DelaunayTriangulationBuilder.h
@@@ -64,13 -62,11 +64,13 @@@ public
static std::unique_ptr<geom::CoordinateSequence> extractUniqueCoordinates(const geom::Geometry& geom);
- * Converts all {@link Coordinate}s in a collection to {@link Vertex}es.
+ * Converts all {@link geom::Coordinate}s in a collection to
+ * {@link quadedge::Vertex}es.
* @param coords the coordinates to convert
- * @return a List of Vertex objects. Call takes ownership of returned object.
+ * @return a List of Vertex objects.
- static IncrementalDelaunayTriangulator::VertexList* toVertices(const geom::CoordinateSequence& coords);
+ static IncrementalDelaunayTriangulator::VertexList toVertices(const geom::CoordinateSequence& coords);
* Returns a CoordinateSequence containing only the unique coordinates of its input.
commit 73851a3508f759c6692577862ab54fc762900d33
Date: Wed May 29 21:30:58 2019 -0400
Improve performance of VoronoiDiagramBuilder
- Ensure vertices are inserted in sorted order
- Reduce manual memory allocation
- Remove some unnecessary copying
- Use unordered_set instead of set
Overall performance improvement is about 20-30% using the random points
benchmark for the case of a Geometry input. The improvement is > 5x for
the case of a CoordinateSequence input due to a performance bug
(vertices not sorted) that may have been recently introduced.
diff --git a/include/geos/triangulate/DelaunayTriangulationBuilder.h b/include/geos/triangulate/DelaunayTriangulationBuilder.h
index e39e9bf..e42d967 100644
@@ -64,9 +64,9 @@ public:
@@ -78,7 +78,7 @@ public:
private:
std::unique_ptr<geom::CoordinateSequence> siteCoords;
double tolerance;
- quadedge::QuadEdgeSubdivision* subdiv;
+ std::unique_ptr<quadedge::QuadEdgeSubdivision> subdiv;
public:
@@ -87,7 +87,7 @@ public:
DelaunayTriangulationBuilder();
- ~DelaunayTriangulationBuilder();
+ ~DelaunayTriangulationBuilder() = default;
* Sets the sites (vertices) which will be triangulated.
diff --git a/include/geos/triangulate/IncrementalDelaunayTriangulator.h b/include/geos/triangulate/IncrementalDelaunayTriangulator.h
index b4ad5fc..058ec2b 100644
--- a/include/geos/triangulate/IncrementalDelaunayTriangulator.h
+++ b/include/geos/triangulate/IncrementalDelaunayTriangulator.h
@@ -54,7 +54,7 @@ public:
IncrementalDelaunayTriangulator(quadedge::QuadEdgeSubdivision* subdiv);
- typedef std::list<quadedge::Vertex> VertexList;
+ typedef std::vector<quadedge::Vertex> VertexList;
* Inserts all sites in a collection. The inserted vertices <b>MUST</b> be
diff --git a/include/geos/triangulate/VoronoiDiagramBuilder.h b/include/geos/triangulate/VoronoiDiagramBuilder.h
index 37df492..81f47f4 100644
--- a/include/geos/triangulate/VoronoiDiagramBuilder.h
+++ b/include/geos/triangulate/VoronoiDiagramBuilder.h
@@ -125,7 +125,7 @@ private:
void create();
static std::unique_ptr<geom::GeometryCollection>
- clipGeometryCollection(const geom::GeometryCollection& geom, const geom::Envelope& clipEnv);
+ clipGeometryCollection(std::vector<std::unique_ptr<geom::Geometry>> & geoms, const geom::Envelope& clipEnv);
diff --git a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
index ce5a49c..eb16295 100644
--- a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
+++ b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
@@ -22,7 +22,7 @@
#include <memory>
#include <list>
#include <stack>
-#include <set>
+#include <unordered_set>
#include <vector>
#include <geos/geom/MultiLineString.h>
@@ -353,8 +353,8 @@ public:
private:
typedef std::stack<QuadEdge*> QuadEdgeStack;
- typedef std::set<QuadEdge*> QuadEdgeSet;
- typedef std::list< geom::CoordinateSequence*> TriList;
+ typedef std::unordered_set<QuadEdge*> QuadEdgeSet;
+ typedef std::vector<geom::CoordinateSequence*> TriList;
* The quadedges forming a single triangle.
@@ -443,7 +443,7 @@ public:
* @param geomFact a geometry factory
* @return a List of Polygons
- std::unique_ptr< std::vector<geom::Geometry*> > getVoronoiCellPolygons(const geom::GeometryFactory& geomFact);
+ std::vector<std::unique_ptr<geom::Geometry>> getVoronoiCellPolygons(const geom::GeometryFactory& geomFact);
* Gets a List of {@link LineString}s for the Voronoi cells
@@ -486,7 +486,7 @@ public:
* @param geomFact a factory for building the polygon
* @return a polygon indicating the cell extent
- std::unique_ptr<geom::Geometry> getVoronoiCellPolygon(QuadEdge* qe, const geom::GeometryFactory& geomFact);
+ std::unique_ptr<geom::Geometry> getVoronoiCellPolygon(const QuadEdge* qe, const geom::GeometryFactory& geomFact);
* Gets the Voronoi cell edge around a site specified
@@ -499,7 +499,7 @@ public:
- std::unique_ptr<geom::Geometry> getVoronoiCellEdge(QuadEdge* qe, const geom::GeometryFactory& geomFact);
+ std::unique_ptr<geom::Geometry> getVoronoiCellEdge(const QuadEdge* qe, const geom::GeometryFactory& geomFact);
diff --git a/src/triangulate/DelaunayTriangulationBuilder.cpp b/src/triangulate/DelaunayTriangulationBuilder.cpp
index 389aa9e..684a4e9 100644
--- a/src/triangulate/DelaunayTriangulationBuilder.cpp
+++ b/src/triangulate/DelaunayTriangulationBuilder.cpp
@@ -62,15 +62,14 @@ DelaunayTriangulationBuilder::unique(const CoordinateSequence* seq) {
-IncrementalDelaunayTriangulator::VertexList*
+IncrementalDelaunayTriangulator::VertexList
DelaunayTriangulationBuilder::toVertices(
const CoordinateSequence& coords)
- IncrementalDelaunayTriangulator::VertexList* vertexList =
- new IncrementalDelaunayTriangulator::VertexList();
+ IncrementalDelaunayTriangulator::VertexList vertexList(coords.size());
- for(size_t iter = 0; iter < coords.size(); ++iter) {
- vertexList->push_back(quadedge::Vertex(coords.getAt(iter)));
+ for(size_t i = 0; i < coords.size(); i++) {
+ vertexList[i] = quadedge::Vertex(coords.getAt(i));
return vertexList;
@@ -80,13 +79,6 @@ DelaunayTriangulationBuilder::DelaunayTriangulationBuilder() :
-DelaunayTriangulationBuilder::~DelaunayTriangulationBuilder()
- if(subdiv) {
- delete subdiv;
void
DelaunayTriangulationBuilder::setSites(const Geometry& geom)
@@ -110,11 +102,12 @@ DelaunayTriangulationBuilder::create()
Envelope siteEnv;
siteCoords ->expandEnvelope(siteEnv);
- IncrementalDelaunayTriangulator::VertexList* vertices = toVertices(*siteCoords);
- subdiv = new quadedge::QuadEdgeSubdivision(siteEnv, tolerance);
- IncrementalDelaunayTriangulator triangulator = IncrementalDelaunayTriangulator(subdiv);
- triangulator.insertSites(*vertices);
- delete vertices;
+ auto vertices = toVertices(*siteCoords);
+ std::sort(vertices.begin(), vertices.end()); // Best performance from locator when inserting points near each other
+ subdiv.reset(new quadedge::QuadEdgeSubdivision(siteEnv, tolerance));
+ IncrementalDelaunayTriangulator triangulator = IncrementalDelaunayTriangulator(subdiv.get());
+ triangulator.insertSites(vertices);
quadedge::QuadEdgeSubdivision&
@@ -144,12 +137,7 @@ geom::Envelope
DelaunayTriangulationBuilder::envelope(const geom::CoordinateSequence& coords)
Envelope env;
- std::vector<Coordinate> coord_vector;
- coords.toVector(coord_vector);
- for(std::vector<Coordinate>::iterator it = coord_vector.begin() ; it != coord_vector.end() ; ++it) {
- const Coordinate& coord = *it;
- env.expandToInclude(coord);
+ coords.expandEnvelope(env);
return env;
diff --git a/src/triangulate/IncrementalDelaunayTriangulator.cpp b/src/triangulate/IncrementalDelaunayTriangulator.cpp
index 8ca0d0b..7becab8 100644
--- a/src/triangulate/IncrementalDelaunayTriangulator.cpp
+++ b/src/triangulate/IncrementalDelaunayTriangulator.cpp
@@ -36,9 +36,8 @@ IncrementalDelaunayTriangulator::IncrementalDelaunayTriangulator(
void
IncrementalDelaunayTriangulator::insertSites(const VertexList& vertices)
- for(VertexList::const_iterator x = vertices.begin();
- x != vertices.end(); ++x) {
- insertSite(*x);
+ for(const auto& vertex : vertices) {
+ insertSite(vertex);
diff --git a/src/triangulate/VoronoiDiagramBuilder.cpp b/src/triangulate/VoronoiDiagramBuilder.cpp
index a65b7c8..702e43c 100644
--- a/src/triangulate/VoronoiDiagramBuilder.cpp
+++ b/src/triangulate/VoronoiDiagramBuilder.cpp
@@ -86,13 +86,12 @@ VoronoiDiagramBuilder::create()
diagramEnv.expandToInclude(clipEnv);
- std::unique_ptr<IncrementalDelaunayTriangulator::VertexList> vertices(
- DelaunayTriangulationBuilder::toVertices(*siteCoords)
+ auto vertices = DelaunayTriangulationBuilder::toVertices(*siteCoords);
subdiv.reset(new quadedge::QuadEdgeSubdivision(diagramEnv, tolerance));
IncrementalDelaunayTriangulator triangulator(subdiv.get());
@@ -107,8 +106,15 @@ std::unique_ptr<geom::GeometryCollection>
VoronoiDiagramBuilder::getDiagram(const geom::GeometryFactory& geomFact)
create();
- std::unique_ptr<geom::GeometryCollection> polys = subdiv->getVoronoiDiagram(geomFact);
- return clipGeometryCollection(*polys, diagramEnv);
+ auto polys = subdiv->getVoronoiCellPolygons(geomFact);
+ auto ret = clipGeometryCollection(polys, diagramEnv);
+ if (ret == nullptr) {
+ return std::unique_ptr<geom::GeometryCollection>(geomFact.createGeometryCollection());
+ return ret;
@@ -125,28 +131,36 @@ VoronoiDiagramBuilder::getDiagramEdges(const geom::GeometryFactory& geomFact)
-VoronoiDiagramBuilder::clipGeometryCollection(const geom::GeometryCollection& geom, const geom::Envelope& clipEnv)
+VoronoiDiagramBuilder::clipGeometryCollection(std::vector<std::unique_ptr<Geometry>> & geoms, const geom::Envelope& clipEnv)
- std::unique_ptr<geom::Geometry> clipPoly(geom.getFactory()->toGeometry(&clipEnv));
+ if (geoms.empty()) {
+ return nullptr;
+ auto gfact = geoms[0]->getFactory();
+ std::unique_ptr<geom::Geometry> clipPoly(gfact->toGeometry(&clipEnv));
std::unique_ptr< std::vector<Geometry*> >clipped(new std::vector<Geometry*>);
- for(std::size_t i = 0 ; i < geom.getNumGeometries() ; i++) {
- const Geometry* g = geom.getGeometryN(i);
+ for(auto& g : geoms) {
std::unique_ptr<Geometry> result;
// don't clip unless necessary
if(clipEnv.contains(g->getEnvelopeInternal())) {
- result = g->clone();
+ result = std::move(g);
// TODO: check if userData is correctly cloned here?
else if(clipEnv.intersects(g->getEnvelopeInternal())) {
- result = clipPoly->intersection(g);
- result->setUserData(((Geometry*)g)->getUserData()); // TODO: needed ?
+ result = clipPoly->intersection(g.get());
+ result->setUserData(g->getUserData()); // TODO: needed ?
if(result.get() && !result->isEmpty()) {
clipped->push_back(result.release());
- return std::unique_ptr<GeometryCollection>(geom.getFactory()->createGeometryCollection(clipped.release()));
+ return std::unique_ptr<GeometryCollection>(gfact->createGeometryCollection(clipped.release()));
} //namespace geos.triangulate
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index 62cd765..75fd1bb 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -517,8 +517,15 @@ QuadEdgeSubdivision::getTriangles(const GeometryFactory& geomFact)
QuadEdgeSubdivision::getVoronoiDiagram(const geom::GeometryFactory& geomFact)
- std::unique_ptr< std::vector<geom::Geometry*> > vorCells = getVoronoiCellPolygons(geomFact);
- return std::unique_ptr<GeometryCollection>(geomFact.createGeometryCollection(vorCells.release()));
+ auto vorCells = getVoronoiCellPolygons(geomFact);
+ // TODO remove loop when GeometryFactory API handles unique_ptr
+ std::unique_ptr<std::vector<Geometry*>> rawCells(new std::vector<Geometry*>(vorCells.size()));
+ for (size_t i = 0; i < rawCells->size(); i++) {
+ (*rawCells)[i] = vorCells[i].release();
+ return std::unique_ptr<GeometryCollection>(geomFact.createGeometryCollection(rawCells.release()));
std::unique_ptr<geom::MultiLineString>
@@ -528,22 +535,20 @@ QuadEdgeSubdivision::getVoronoiDiagramEdges(const geom::GeometryFactory& geomFac
return std::unique_ptr<MultiLineString>(geomFact.createMultiLineString(vorCells.release()));
-std::unique_ptr< std::vector<geom::Geometry*> >
+std::vector<std::unique_ptr<geom::Geometry>>
QuadEdgeSubdivision::getVoronoiCellPolygons(const geom::GeometryFactory& geomFact)
- std::unique_ptr< std::vector<geom::Geometry*> > cells(new std::vector<geom::Geometry*>);
- TriangleCircumcentreVisitor* tricircumVisitor = new TriangleCircumcentreVisitor();
- visitTriangles((TriangleVisitor*)tricircumVisitor, true);
+ std::vector<std::unique_ptr<geom::Geometry>> cells;
+ TriangleCircumcentreVisitor tricircumVisitor;
- std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList> edges = getVertexUniqueEdges(false);
+ visitTriangles((TriangleVisitor*) &tricircumVisitor, true);
- for(QuadEdgeSubdivision::QuadEdgeList::iterator it = edges->begin() ; it != edges->end() ; ++it) {
- QuadEdge* qe = *it;
- std::unique_ptr<geom::Geometry> poly = getVoronoiCellPolygon(qe, geomFact);
+ std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList> edges = getVertexUniqueEdges(false);
- cells->push_back(poly.release());
+ for(const QuadEdge* qe : *edges) {
+ cells.push_back(getVoronoiCellPolygon(qe, geomFact));
- delete tricircumVisitor;
return cells;
@@ -551,50 +556,48 @@ std::unique_ptr< std::vector<geom::Geometry*> >
QuadEdgeSubdivision::getVoronoiCellEdges(const geom::GeometryFactory& geomFact)
std::unique_ptr<geom::Geometry> poly = getVoronoiCellEdge(qe, geomFact);
return cells;
-QuadEdgeSubdivision::getVoronoiCellPolygon(QuadEdge* qe, const geom::GeometryFactory& geomFact)
+QuadEdgeSubdivision::getVoronoiCellPolygon(const QuadEdge* qe, const geom::GeometryFactory& geomFact)
- std::vector<Coordinate> cellPts;
- QuadEdge* startQE = qe;
+ std::unique_ptr<std::vector<Coordinate>> cellPts(new std::vector<Coordinate>());
+ const QuadEdge* startQE = qe;
do {
- Coordinate cc = qe->rot().orig().getCoordinate();
- if(cellPts.empty() || cellPts.back() != cc) { // no duplicates
- cellPts.push_back(cc);
+ const Coordinate& cc = qe->rot().orig().getCoordinate();
+ if(cellPts->empty() || cellPts->back() != cc) { // no duplicates
+ cellPts->push_back(cc);
qe = &qe->oPrev();
while(qe != startQE);
- //CoordList from a vector of Coordinates.
- geom::CoordinateList coordList(cellPts);
- //for checking close ring in CoordList class:
- coordList.closeRing();
- if(coordList.size() < 4) {
- coordList.insert(coordList.end(), *(coordList.end()), true);
+ // Close the ring
+ if (cellPts->front() != cellPts->back()) {
+ cellPts->push_back(cellPts->front());
+ if (cellPts->size() < 4) {
+ cellPts->push_back(cellPts->back());
- std::unique_ptr<Coordinate::Vect> pts = coordList.toCoordinateArray();
std::unique_ptr<geom::Geometry> cellPoly(
- geomFact.createPolygon(geomFact.createLinearRing(new geom::CoordinateArraySequence(pts.release())), nullptr));
+ geomFact.createPolygon(geomFact.createLinearRing(new geom::CoordinateArraySequence(cellPts.release())), nullptr));
+ // FIXME why is this returning a pointer to a local variable?
Vertex v = startQE->orig();
Coordinate c(0, 0);
c = v.getCoordinate();
@@ -603,30 +606,29 @@ QuadEdgeSubdivision::getVoronoiCellPolygon(QuadEdge* qe, const geom::GeometryFac
-QuadEdgeSubdivision::getVoronoiCellEdge(QuadEdge* qe, const geom::GeometryFactory& geomFact)
+QuadEdgeSubdivision::getVoronoiCellEdge(const QuadEdge* qe, const geom::GeometryFactory& geomFact)
do {
qe = &qe->oPrev();
+ // Close the ring
std::unique_ptr<geom::Geometry> cellEdge(
- geomFact.createLineString(new geom::CoordinateArraySequence(pts.release())));
+ geomFact.createLineString(new geom::CoordinateArraySequence(cellPts.release())));
Coordinate c(0, 0);
@@ -638,21 +640,20 @@ std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList>
QuadEdgeSubdivision::getVertexUniqueEdges(bool includeFrame)
std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList> edges(new QuadEdgeList());
- std::set<Vertex> visitedVertices;
- for(QuadEdgeSubdivision::QuadEdgeList::iterator it = quadEdges.begin() ; it != quadEdges.end() ; ++it) {
- QuadEdge* qe = (QuadEdge*)(*it);
- Vertex v = qe->orig();
+ std::set<Vertex> visitedVertices; // TODO unordered_set of Vertex* ?
+ for(QuadEdge* qe : quadEdges) {
+ const Vertex& v = qe->orig();
if(visitedVertices.find(v) == visitedVertices.end()) { //if v not found
visitedVertices.insert(v);
if(includeFrame || ! QuadEdgeSubdivision::isFrameVertex(v)) {
edges->push_back(qe);
QuadEdge* qd = &(qe->sym());
- Vertex vd = qd->orig();
+ const Vertex& vd = qd->orig();
if(visitedVertices.find(vd) == visitedVertices.end()) {
visitedVertices.insert(vd);
diff --git a/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp b/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
index 2506747..79f53cd 100644
--- a/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
+++ b/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
@@ -94,10 +94,10 @@ void object::test<2>
double expandBy = std::max(Env.getWidth(), Env.getHeight());
Env.expandBy(expandBy);
- IncrementalDelaunayTriangulator::VertexList* vertices = DelaunayTriangulationBuilder::toVertices(*siteCoords);
+ IncrementalDelaunayTriangulator::VertexList vertices = DelaunayTriangulationBuilder::toVertices(*siteCoords);
subdiv = new quadedge::QuadEdgeSubdivision(Env, 0);
IncrementalDelaunayTriangulator triangulator(subdiv);
//Test for getVoronoiDiagram::
const GeometryFactory& geomFact(*GeometryFactory::getDefaultInstance());
@@ -112,7 +112,6 @@ void object::test<2>
ensure(polys->equalsExact(expected, 1e-7));
delete sites;
delete subdiv;
- delete vertices;
delete expected;
// ensure(polys->getCoordinateDimension() == expected->getCoordinateDimension());
@@ -141,12 +140,10 @@ template<> template<> void object::test<3>
new quadedge::QuadEdgeSubdivision(env, 10)
+ auto vertices(DelaunayTriangulationBuilder::toVertices(*siteCoords));
commit 62a875357de7b971debc7e7f85a5a7ed462dc649
Date: Wed May 29 21:26:18 2019 -0400
Add Voronoi perf test
diff --git a/benchmarks/algorithm/CMakeLists.txt b/benchmarks/algorithm/CMakeLists.txt
index 5a0703e..2aad3ab 100644
--- a/benchmarks/algorithm/CMakeLists.txt
+++ b/benchmarks/algorithm/CMakeLists.txt
@@ -12,3 +12,6 @@
add_executable(perf_interiorpoint_area InteriorPointAreaPerfTest.cpp)
target_link_libraries(perf_interiorpoint_area geos)
+add_executable(perf_voronoi VoronoiPerfTest.cpp)
+target_link_libraries(perf_voronoi geos)
diff --git a/benchmarks/algorithm/VoronoiPerfTest.cpp b/benchmarks/algorithm/VoronoiPerfTest.cpp
new file mode 100644
index 0000000..9ab6789
--- /dev/null
+++ b/benchmarks/algorithm/VoronoiPerfTest.cpp
@@ -0,0 +1,91 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2019 Daniel Baston <dbaston at gmail.com>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#include <geos/triangulate/DelaunayTriangulationBuilder.h>
+#include <geos/triangulate/VoronoiDiagramBuilder.h>
+#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/profiler.h>
+#include <algorithm>
+#include <random>
+#include <vector>
+#include <memory>
+class VoronoiPerfTest {
+public:
+ void test(size_t num_points) {
+ using namespace geos::geom;
+ std::default_random_engine e(12345);
+ std::uniform_real_distribution<> dis(0, 100);
+ std::unique_ptr<std::vector<Coordinate>> coords(new std::vector<Coordinate>(num_points));
+ std::generate(coords->begin(), coords->end(), [&dis, &e]() {
+ return Coordinate(dis(e), dis(e));
+ CoordinateArraySequence seq(coords.release());
+ auto geom = gfact->createLineString(seq.clone());
+ voronoi(seq);
+ voronoi(*geom);
+ delaunay(seq);
+ delaunay(*geom);
+ std::cout << std::endl;
+private:
+ decltype(geos::geom::GeometryFactory::create()) gfact = geos::geom::GeometryFactory::create();
+ template<typename T>
+ void voronoi(const T & sites) {
+ geos::util::Profile sw(std::string("Voronoi from ") + typeid(T).name());
+ sw.start();
+ geos::triangulate::VoronoiDiagramBuilder vdb;
+ vdb.setSites(sites);
+ auto result = vdb.getDiagram(*gfact);
+ sw.stop();
+ std::cout << sw.name << ": " << result->getNumGeometries() << ": " << sw.getTotFormatted() << std::endl;
+ void delaunay(const T & seq) {
+ geos::util::Profile sw(std::string("Delaunay from ") + typeid(T).name());
+ sw.start();
+ geos::triangulate::DelaunayTriangulationBuilder dtb;
+ dtb.setSites(seq);
+ auto result = dtb.getTriangles(*gfact);
+ sw.stop();
+int main() {
+ VoronoiPerfTest tester;
+ //tester.test(100);
+ //tester.test(1000);
+ //tester.test(10000);
+ for (auto i = 0; i < 5; i++) {
+ tester.test(100000);
\ No newline at end of file
Summary of changes:
benchmarks/algorithm/CMakeLists.txt | 3 +
benchmarks/algorithm/VoronoiPerfTest.cpp | 91 ++++++++++++++++++
.../triangulate/DelaunayTriangulationBuilder.h | 8 +-
.../triangulate/IncrementalDelaunayTriangulator.h | 2 +-
include/geos/triangulate/VoronoiDiagramBuilder.h | 2 +-
.../triangulate/quadedge/QuadEdgeSubdivision.h | 12 +--
src/triangulate/DelaunayTriangulationBuilder.cpp | 34 +++----
.../IncrementalDelaunayTriangulator.cpp | 5 +-
src/triangulate/VoronoiDiagramBuilder.cpp | 42 ++++++---
src/triangulate/quadedge/QuadEdgeSubdivision.cpp | 105 +++++++++++----------
.../quadedge/QuadEdgeSubdivisionTest.cpp | 11 +--
11 files changed, 204 insertions(+), 111 deletions(-)
create mode 100644 benchmarks/algorithm/VoronoiPerfTest.cpp
hooks/post-receive
More information about the geos-commits
