[geos-commits] [SCM] GEOS branch master updated. 2da5dc33519659272f86197751e4f0aa8656290b
git at osgeo.org
git at osgeo.org
Sat Jun 8 18:23:47 PDT 2019
the project "GEOS".
via 2da5dc33519659272f86197751e4f0aa8656290b (commit)
via 44d77a23c63f9b532d84d4d8e516130f9ad12051 (commit)
via 4aeef3b90c4cce0d2747ab8081ca2cac0e4cd187 (commit)
via 72404597eb2cdce65f844feea0389040554fa985 (commit)
from dfb77838cfe82098d41106efaaf232657e604553 (commit)
revisions in full, below.
commit 2da5dc33519659272f86197751e4f0aa8656290b
Merge: dfb7783 44d77a2
Author: Daniel Baston <dbaston at gmail.com>
Date: Sat Jun 8 21:23:33 2019 -0400
Merge branch 'cpp11-profiler'
commit 44d77a23c63f9b532d84d4d8e516130f9ad12051
Date: Thu Jun 6 22:13:55 2019 -0400
More informative timing output in VoronoiPerfTest
diff --git a/benchmarks/algorithm/VoronoiPerfTest.cpp b/benchmarks/algorithm/VoronoiPerfTest.cpp
index 9ab6789..df90128 100644
--- a/benchmarks/algorithm/VoronoiPerfTest.cpp
+++ b/benchmarks/algorithm/VoronoiPerfTest.cpp
@@ -49,33 +49,34 @@ public:
private:
decltype(geos::geom::GeometryFactory::create()) gfact = geos::geom::GeometryFactory::create();
+ geos::util::Profiler* profiler = geos::util::Profiler::instance();
template<typename T>
void voronoi(const T & sites) {
- geos::util::Profile sw(std::string("Voronoi from ") + typeid(T).name());
- sw.start();
+ auto sw = profiler->get(std::string("Voronoi from ") + typeid(T).name());
+ sw->start();
geos::triangulate::VoronoiDiagramBuilder vdb;
vdb.setSites(sites);
auto result = vdb.getDiagram(*gfact);
- sw.stop();
- std::cout << sw.name << ": " << result->getNumGeometries() << ": " << sw.getTotFormatted() << std::endl;
+ sw->stop();
+ std::cout << sw->name << ": " << result->getNumGeometries() << ": " << *sw << std::endl;
void delaunay(const T & seq) {
- geos::util::Profile sw(std::string("Delaunay from ") + typeid(T).name());
- sw.start();
+ auto sw = profiler->get(std::string("Delaunay from ") + typeid(T).name());
+ sw->start();
geos::triangulate::DelaunayTriangulationBuilder dtb;
dtb.setSites(seq);
auto result = dtb.getTriangles(*gfact);
- sw.stop();
+ sw->stop();
commit 4aeef3b90c4cce0d2747ab8081ca2cac0e4cd187
Date: Thu Jun 6 22:13:00 2019 -0400
Remove manual memory management in Profiler
diff --git a/include/geos/profiler.h b/include/geos/profiler.h
index e50a9c9..c98e3b4 100644
--- a/include/geos/profiler.h
+++ b/include/geos/profiler.h
@@ -50,7 +50,7 @@ public:
Profile(std::string name);
/** \brief Destructor */
- ~Profile();
+ ~Profile() = default;
/** \brief start a new timer */
void
@@ -136,8 +136,8 @@ class GEOS_DLL Profiler {
public:
- Profiler();
- ~Profiler();
+ Profiler() = default;
+ ~Profiler() = default;
* \brief
@@ -163,7 +163,7 @@ public:
/** \brief get Profile of named task */
Profile* get(std::string name);
- std::map<std::string, Profile*> profs;
+ std::map<std::string, std::unique_ptr<Profile>> profs;
diff --git a/src/util/Profiler.cpp b/src/util/Profiler.cpp
index 0208df2..4b65799 100644
--- a/src/util/Profiler.cpp
+++ b/src/util/Profiler.cpp
@@ -29,10 +29,6 @@ Profile::Profile(string newname) :
totaltime(timeunit::zero())
-Profile::~Profile()
double
Profile::getMax() const
@@ -78,29 +74,17 @@ Profile::getNumTimings() const
return timings.size();
-Profiler::Profiler()
-Profiler::~Profiler()
- map<string, Profile*>::const_iterator it;
- for(it = profs.begin(); it != profs.end(); ++it) {
- delete it->second;
void
Profiler::start(string name)
- Profile* prof = get(name);
+ auto prof = get(name);
prof->start();
void
Profiler::stop(string name)
- map<string, Profile*>::iterator iter = profs.find(name);
+ auto iter = profs.find(name);
if(iter == profs.end()) {
cerr << name << ": no such Profile started";
return;
@@ -111,16 +95,12 @@ Profiler::stop(string name)
Profile*
Profiler::get(string name)
- Profile* prof;
- if(iter == profs.end()) {
- prof = new Profile(name);
- profs.insert(pair<string, Profile*>(name, prof));
- else {
- prof = iter->second;
+ auto& prof = profs[name];
+ if (prof == nullptr) {
+ prof.reset(new Profile(name));
- return prof;
+ return prof.get();
Profiler*
@@ -144,9 +124,8 @@ operator<< (ostream& os, const Profile& prof)
ostream&
operator<< (ostream& os, const Profiler& prof)
- for(it = prof.profs.begin(); it != prof.profs.end(); ++it) {
- os << *(it->second) << endl;
+ for(const auto& entry : prof.profs) {
+ os << *(entry.second) << endl;
return os;
commit 72404597eb2cdce65f844feea0389040554fa985
Date: Thu Jun 6 20:56:54 2019 -0400
Use C++11 std::chrono for Profiler
This avoids the need for compiler-specific tests and headers, and
anecdotally seems to provide more repeatable measurements.
diff --git a/include/geos/Makefile.am b/include/geos/Makefile.am
index 8fa3be0..cc55c4a 100644
--- a/include/geos/Makefile.am
+++ b/include/geos/Makefile.am
@@ -50,7 +50,6 @@ geos_HEADERS = \
precision.h \
profiler.h \
spatialIndex.h \
- timeval.h \
unload.h \
util.h
index c447704..e50a9c9 100644
@@ -15,29 +15,8 @@
#ifndef GEOS_PROFILER_H
#define GEOS_PROFILER_H
-#include <stdlib.h> /** need this to correctly detect MINGW64 **/
#include <geos/export.h>
-/* For MingW builds with __STRICT_ANSI__ (-ansi) */
-/** MINGW64 doesn't have a config.h **/
-#if defined(__MINGW32__) && !defined(__MINGW64_VERSION_MAJOR)
-/* Allow us to check for presence of gettimeofday in MingW */
-#include <config.h>
-#include <sys/time.h>
-extern "C" {
- extern _CRTIMP void __cdecl _tzset(void);
- __MINGW_IMPORT int _daylight;
- __MINGW_IMPORT long _timezone;
- __MINGW_IMPORT char* _tzname[2];
-#endif
-#if defined(_MSC_VER) || defined(__MINGW32__) && !defined(HAVE_GETTIMEOFDAY) && !defined(__MINGW64_VERSION_MAJOR)
-#include <geos/timeval.h>
-#else
-#endif
+#include <chrono>
#include <map>
#include <memory>
@@ -65,6 +44,8 @@ namespace util {
class GEOS_DLL Profile {
public:
+ using timeunit = std::chrono::microseconds;
/** \brief Create a named profile */
@@ -75,19 +56,18 @@ public:
void
start()
- gettimeofday(&starttime, nullptr);
+ starttime = std::chrono::high_resolution_clock::now();
/** \brief stop current timer */
void
stop()
- gettimeofday(&stoptime, nullptr);
- double elapsed = static_cast<double>(
- 1000000 * (stoptime.tv_sec - starttime.tv_sec)
- + (stoptime.tv_usec - starttime.tv_usec));
+ stoptime = std::chrono::high_resolution_clock::now();
+ auto elapsed = std::chrono::duration_cast<timeunit>(stoptime - starttime);
timings.push_back(elapsed);
totaltime += elapsed;
if(timings.size() == 1) {
max = min = elapsed;
@@ -100,7 +80,8 @@ public:
min = elapsed;
- avg = totaltime / static_cast<double>(timings.size());
+ avg = static_cast<double>(totaltime.count()) / static_cast<double>(timings.size());
/** \brief Return Max stored timing */
@@ -126,25 +107,23 @@ public:
private:
/* \brief current start and stop times */
- struct timeval starttime, stoptime;
+ std::chrono::high_resolution_clock::time_point starttime, stoptime;
/* \brief actual times */
- std::vector<double> timings;
+ std::vector<timeunit> timings;
/* \brief total time */
- double totaltime;
+ timeunit totaltime;
/* \brief max time */
- double max;
+ timeunit max;
- double min;
+ timeunit min;
- /* \brief max time */
+ /* \brief avg time */
double avg;
diff --git a/include/geos/timeval.h b/include/geos/timeval.h
deleted file mode 100644
index 3ece94e..0000000
--- a/include/geos/timeval.h
+++ /dev/null
@@ -1,130 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2006 Wu Yongwei
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Note: This code is in the public domain, see
- * http://wyw.dcweb.cn/time.htm
-#ifndef GEOS_TIMEVAL_H
-#define GEOS_TIMEVAL_H
-#if !defined(_WIN32)
-#error This header is dedicated to Windows platform only
-#endif
-#ifndef WIN32_LEAN_AND_MEAN
-#define WIN32_LEAN_AND_MEAN
-#endif
-#ifndef NOMINMAX
-#define NOMINMAX
-#endif
-#ifndef STRICT
-#define STRICT
-#endif
-#include <winsock2.h>
-#include <time.h>
-#if defined(_MSC_VER) || defined(__BORLANDC__)
-#define EPOCHFILETIME (116444736000000000i64)
-#else
-#define EPOCHFILETIME (116444736000000000LL)
-#endif
-struct timezone {
- int tz_minuteswest; /* minutes W of Greenwich */
- int tz_dsttime; /* type of dst correction */
-#if !defined(_WIN32_WCE)
-__inline int
-gettimeofday(struct timeval* tv, struct timezone* tz)
- FILETIME ft;
- LARGE_INTEGER li;
- __int64 t;
- static int tzflag;
- if(tv) {
- GetSystemTimeAsFileTime(&ft);
- li.LowPart = ft.dwLowDateTime;
- li.HighPart = ft.dwHighDateTime;
- t = li.QuadPart; /* In 100-nanosecond intervals */
- t -= EPOCHFILETIME; /* Offset to the Epoch time */
- t /= 10; /* In microseconds */
- tv->tv_sec = (long)(t / 1000000);
- tv->tv_usec = (long)(t % 1000000);
- if(tz) {
- if(!tzflag) {
- _tzset();
- tzflag++;
- tz->tz_minuteswest = _timezone / 60;
- tz->tz_dsttime = _daylight;
- return 0;
-#else
-__inline int
- SYSTEMTIME st;
- FILETIME ft;
- LARGE_INTEGER li;
- TIME_ZONE_INFORMATION tzi;
- __int64 t;
- if(tv) {
- GetSystemTime(&st);
- SystemTimeToFileTime(&st, &ft);
- if(tz) {
- GetTimeZoneInformation(&tzi);
- tz->tz_minuteswest = tzi.Bias;
- if(tzi.StandardDate.wMonth != 0) {
- tz->tz_minuteswest += tzi.StandardBias * 60;
- if(tzi.DaylightDate.wMonth != 0) {
- tz->tz_dsttime = 1;
- else {
- tz->tz_dsttime = 0;
- return 0;
-#endif /* _WIN32_WCE */
-#endif /* GEOS_TIMEVAL_H */
index 1ff532d..0208df2 100644
@@ -16,6 +16,7 @@
#include <iostream>
#include <map>
#include <string>
+#include <sstream>
#include <utility>
using namespace std;
@@ -23,12 +24,10 @@ using namespace std;
namespace geos {
namespace util { // geos.util
-Profile::Profile(string newname)
- name = newname;
- totaltime = 0;
- min = max = avg = 0;
+Profile::Profile(string newname) :
+ name(newname),
+ totaltime(timeunit::zero())
Profile::~Profile()
@@ -37,13 +36,13 @@ Profile::~Profile()
double
- return max;
+ return static_cast<double>(max.count());
double
Profile::getMin() const
- return min;
+ return static_cast<double>(min.count());
double
@@ -55,14 +54,16 @@ Profile::getAvg() const
double
Profile::getTot() const
- return totaltime;
+ return static_cast<double>(totaltime.count());
std::string
Profile::getTotFormatted() const
- long usec = (long) totaltime;
- std::string fmt = to_string(usec);
+ std::stringstream usec;
+ usec << totaltime.count();
+ std::string fmt = usec.str();
int insertPosition = static_cast<int>(fmt.length()) - 3;
while (insertPosition > 0) {
fmt.insert(insertPosition, ",");
Summary of changes:
benchmarks/algorithm/VoronoiPerfTest.cpp | 17 ++--
include/geos/Makefile.am | 1 -
include/geos/profiler.h | 59 +++++---------
include/geos/timeval.h | 130 -------------------------------
src/util/Profiler.cpp | 62 +++++----------
5 files changed, 49 insertions(+), 220 deletions(-)
delete mode 100644 include/geos/timeval.h
hooks/post-receive
More information about the geos-commits
