[geos-commits] [SCM] GEOS branch master updated. d6364a4fc1d386d076b59f045fb382e7532fab96
git at osgeo.org
git at osgeo.org
Sat Jun 8 18:26:38 PDT 2019
the project "GEOS".
via d6364a4fc1d386d076b59f045fb382e7532fab96 (commit)
via 7ee79a3f3d866623176ed1d4c5d164a58377f825 (commit)
via dee35dd2b99396585f704c0efa0e18d2b618a430 (commit)
from 2da5dc33519659272f86197751e4f0aa8656290b (commit)
revisions in full, below.
commit d6364a4fc1d386d076b59f045fb382e7532fab96
Merge: 2da5dc3 7ee79a3
Author: Daniel Baston <dbaston at gmail.com>
Date: Sat Jun 8 21:25:55 2019 -0400
Merge branch 'remove-coordseq-add'
commit 7ee79a3f3d866623176ed1d4c5d164a58377f825
Date: Tue Jun 4 17:05:14 2019 -0400
Move CoordinateSequence::add variants to CoordinateArraySequence
Making this change removes the assumption that any CoordinateSequence is
resizable, which opens the door to a CoordinateSequence that is blocked
by a raw block of memory (such as a PostGIS POINTARRAY).
The default CoordinateArraySequence constructor now creates a
CoordinateSequence of unknown dimension (dimension determined when the
first Coordinate is assigned) rather than of dimension 3. This is for
consistency with the behavior of the CoordinateArraySequenceFactory.
diff --git a/doc/example.cpp b/doc/example.cpp
index a7c18fa..c1294ba 100644
--- a/doc/example.cpp
+++ b/doc/example.cpp
@@ -233,7 +233,7 @@ LineString*
create_ushaped_linestring(double xoffset, double yoffset, double side)
// We will use a coordinate list to build the linestring
- CoordinateSequence* cl = new CoordinateArraySequence();
+ CoordinateArraySequence* cl = new CoordinateArraySequence();
cl->add(Coordinate(xoffset, yoffset));
cl->add(Coordinate(xoffset, yoffset + side));
@@ -260,7 +260,7 @@ LinearRing*
create_square_linearring(double xoffset, double yoffset, double side)
// We will use a coordinate list to build the linearring
diff --git a/include/geos/geom/CoordinateArraySequence.h b/include/geos/geom/CoordinateArraySequence.h
index 67fdf12..25b0db8 100644
--- a/include/geos/geom/CoordinateArraySequence.h
+++ b/include/geos/geom/CoordinateArraySequence.h
@@ -84,9 +84,16 @@ public:
vect->clear();
- void add(const Coordinate& c) override;
- void add(const Coordinate& c, bool allowRepeated) override;
+ /// Add a Coordinate to the list
+ void add(const Coordinate& c);
+ * \brief Add a coordinate
+ * @param c the coordinate to add
+ * @param allowRepeated if set to false, repeated coordinates
+ * are collapsed
+ void add(const Coordinate& c, bool allowRepeated);
/** \brief
* Inserts the specified coordinate at the specified position in
@@ -99,7 +106,9 @@ public:
* NOTE: this is a CoordinateList interface in JTS
- void add(std::size_t i, const Coordinate& coord, bool allowRepeated) override;
+ void add(std::size_t i, const Coordinate& coord, bool allowRepeated);
+ void add(const CoordinateSequence* cl, bool allowRepeated, bool direction);
void setAt(const Coordinate& c, std::size_t pos) override;
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index 711f06a..082d3a2 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -126,52 +126,9 @@ public:
virtual void toVector(std::vector<Coordinate>& coords) const = 0;
- * \brief Add an array of coordinates
- * @param vc the coordinates
- * @param allowRepeated if set to false, repeated coordinates
- * are collapsed
- void add(const std::vector<Coordinate>* vc, bool allowRepeated);
- /** \brief
- * Add an array of coordinates
- * @param cl the coordinates
- * if set to false, repeated coordinates are collapsed
- * @param direction if false, the array is added in reverse order
- void add(const CoordinateSequence* cl, bool allowRepeated,
- bool direction);
- * \brief Add a coordinate
- * @param c the coordinate to add
- * are collapsed
- virtual void add(const Coordinate& c, bool allowRepeated);
- /** \brief
- * Inserts the specified coordinate at the specified position in
- * this list.
- * @param i the position at which to insert
- * @param coord the coordinate to insert
- * @param allowRepeated if set to false, repeated coordinates are
- * collapsed
- * NOTE: this is a CoordinateList interface in JTS
- virtual void add(std::size_t i, const Coordinate& coord, bool allowRepeated) = 0;
/// Returns <code>true</code> it list contains no coordinates.
virtual bool isEmpty() const = 0;
- /// Add a Coordinate to the list
- virtual void add(const Coordinate& c) = 0;
/// Copy Coordinate c to position pos
virtual void setAt(const Coordinate& c, std::size_t pos) = 0;
diff --git a/include/geos/geomgraph/EdgeRing.h b/include/geos/geomgraph/EdgeRing.h
index d384f12..d6d5167 100644
--- a/include/geos/geomgraph/EdgeRing.h
+++ b/include/geos/geomgraph/EdgeRing.h
@@ -44,7 +44,7 @@ class GeometryFactory;
class LinearRing;
class Polygon;
class Coordinate;
-class CoordinateSequence;
+class CoordinateArraySequence;
namespace geomgraph {
class DirectedEdge;
@@ -181,7 +181,7 @@ private:
/// the DirectedEdges making up this EdgeRing
std::vector<DirectedEdge*> edges;
- geom::CoordinateSequence* pts;
+ geom::CoordinateArraySequence* pts;
// label stores the locations of each geometry on the
// face surrounded by this ring
diff --git a/include/geos/linearref/LinearGeometryBuilder.h b/include/geos/linearref/LinearGeometryBuilder.h
index 0a7c0b4..b96750a 100644
--- a/include/geos/linearref/LinearGeometryBuilder.h
+++ b/include/geos/linearref/LinearGeometryBuilder.h
@@ -48,7 +48,7 @@ private:
bool ignoreInvalidLines;
bool fixInvalidLines;
- geom::CoordinateSequence* coordList;
+ geom::CoordinateArraySequence* coordList;
geom::Coordinate lastPt;
diff --git a/include/geos/noding/SegmentIntersectionDetector.h b/include/geos/noding/SegmentIntersectionDetector.h
index 4d8c14f..c892d83 100644
--- a/include/geos/noding/SegmentIntersectionDetector.h
+++ b/include/geos/noding/SegmentIntersectionDetector.h
@@ -20,7 +20,7 @@
#include <geos/noding/SegmentIntersector.h>
#include <geos/algorithm/LineIntersector.h>
#include <geos/geom/Coordinate.h>
-#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateArraySequence.h>
#include <geos/noding/SegmentString.h>
namespace geos {
@@ -51,7 +51,7 @@ private:
bool _hasNonProperIntersection;
const geom::Coordinate* intPt;
- geom::CoordinateSequence* intSegments;
+ geom::CoordinateArraySequence* intSegments;
protected:
public:
diff --git a/include/geos/operation/linemerge/EdgeString.h b/include/geos/operation/linemerge/EdgeString.h
index 4c69e4c..a79d17b 100644
--- a/include/geos/operation/linemerge/EdgeString.h
+++ b/include/geos/operation/linemerge/EdgeString.h
@@ -33,6 +33,7 @@
namespace geos {
namespace geom {
class LineString;
@@ -56,7 +57,7 @@ class GEOS_DLL EdgeString {
private:
const geom::GeometryFactory* factory;
std::vector<LineMergeDirectedEdge*> directedEdges;
- geom::CoordinateSequence* coordinates;
+ geom::CoordinateArraySequence* coordinates;
geom::CoordinateSequence* getCoordinates();
public:
diff --git a/include/geos/operation/polygonize/EdgeRing.h b/include/geos/operation/polygonize/EdgeRing.h
index 494ace1..5371a19 100644
--- a/include/geos/operation/polygonize/EdgeRing.h
+++ b/include/geos/operation/polygonize/EdgeRing.h
@@ -72,7 +72,7 @@ private:
// cache the following data for efficiency
std::unique_ptr<geom::LinearRing> ring;
- std::unique_ptr<geom::CoordinateSequence> ringPts;
+ std::unique_ptr<geom::CoordinateArraySequence> ringPts;
std::unique_ptr<algorithm::locate::PointOnGeometryLocator> ringLocator;
std::unique_ptr<std::vector<geom::Geometry*>> holes;
@@ -94,7 +94,7 @@ private:
static void addEdge(const geom::CoordinateSequence* coords,
bool isForward,
- geom::CoordinateSequence* coordList);
+ geom::CoordinateArraySequence* coordList);
algorithm::locate::PointOnGeometryLocator* getLocator() {
if (ringLocator == nullptr) {
diff --git a/include/geos/operation/valid/RepeatedPointRemover.h b/include/geos/operation/valid/RepeatedPointRemover.h
index 9c5583e..03e3c36 100644
--- a/include/geos/operation/valid/RepeatedPointRemover.h
+++ b/include/geos/operation/valid/RepeatedPointRemover.h
@@ -15,7 +15,7 @@
#ifndef GEOS_OP_VALID_REPEATEDPOINTREMOVER_H
#define GEOS_OP_VALID_REPEATEDPOINTREMOVER_H
namespace geos {
namespace operation {
@@ -32,7 +32,7 @@ namespace valid {
/// \param seq
/// \return
public:
- static std::unique_ptr<geom::CoordinateSequence> removeRepeatedPoints(const geom::CoordinateSequence* seq);
+ static std::unique_ptr<geom::CoordinateArraySequence> removeRepeatedPoints(const geom::CoordinateSequence* seq);
diff --git a/src/geom/CoordinateArraySequence.cpp b/src/geom/CoordinateArraySequence.cpp
index a43a5d8..733fae0 100644
--- a/src/geom/CoordinateArraySequence.cpp
+++ b/src/geom/CoordinateArraySequence.cpp
@@ -32,7 +32,7 @@ namespace geom { // geos::geom
CoordinateArraySequence::CoordinateArraySequence():
vect(new vector<Coordinate>()),
- dimension(3)
+ dimension(0)
@@ -131,6 +131,24 @@ CoordinateArraySequence::add(const Coordinate& c, bool allowRepeated)
vect->push_back(c);
+void
+CoordinateArraySequence::add(const CoordinateSequence* cl, bool allowRepeated, bool direction)
+ // FIXME: don't rely on negative values for 'j' (the reverse case)
+ const auto npts = cl->size();
+ if(direction) {
+ for(size_t i = 0; i < npts; ++i) {
+ add(cl->getAt(i), allowRepeated);
+ else {
+ for(auto j = npts; j > 0; --j) {
+ add(cl->getAt(j - 1), allowRepeated);
/*public*/
void
CoordinateArraySequence::add(size_t i, const Coordinate& coord,
diff --git a/src/geom/CoordinateSequence.cpp b/src/geom/CoordinateSequence.cpp
index 9e9e244..7e8ac69 100644
--- a/src/geom/CoordinateSequence.cpp
+++ b/src/geom/CoordinateSequence.cpp
@@ -179,53 +179,6 @@ CoordinateSequence::equals(const CoordinateSequence* cl1,
return true;
-/*public*/
-void
-CoordinateSequence::add(const vector<Coordinate>* vc, bool allowRepeated)
- assert(vc);
- for(size_t i = 0; i < vc->size(); ++i) {
- add((*vc)[i], allowRepeated);
-/*public*/
-void
-CoordinateSequence::add(const Coordinate& c, bool allowRepeated)
- if(!allowRepeated) {
- std::size_t npts = getSize();
- if(npts >= 1) {
- const Coordinate& last = getAt(npts - 1);
- if(last.equals2D(c)) {
- return;
- add(c);
-/*public*/
-void
-CoordinateSequence::add(const CoordinateSequence* cl,
- bool allowRepeated, bool direction)
- // FIXME: don't rely on negative values for 'j' (the reverse case)
- const auto npts = cl->size();
- if(direction) {
- for(size_t i = 0; i < npts; ++i) {
- add(cl->getAt(i), allowRepeated);
- else {
- for(auto j = npts; j > 0; --j) {
- add(cl->getAt(j - 1), allowRepeated);
void
CoordinateSequence::expandEnvelope(Envelope& env) const
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 779f46b..e6c3022 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -20,7 +20,7 @@
#include <geos/algorithm/Area.h>
#include <geos/algorithm/Orientation.h>
-#include <geos/util/IllegalArgumentException.h>
+#include <geos/util.h>
#include <geos/geom/Polygon.h>
#include <geos/geom/LinearRing.h>
@@ -29,7 +29,7 @@
#include <geos/geom/Dimension.h>
#include <geos/geom/Envelope.h>
#include <geos/geom/CoordinateSequenceFactory.h>
#include <geos/geom/CoordinateSequenceFilter.h>
#include <geos/geom/GeometryFilter.h>
#include <geos/geom/GeometryComponentFilter.h>
@@ -332,13 +332,12 @@ Polygon::normalize(LinearRing* ring, bool clockwise)
return;
- auto seqFactory = ring->getFactory()->getCoordinateSequenceFactory();
- std::unique_ptr<std::vector<Coordinate>> coords(new std::vector<Coordinate>());
+ auto coords = detail::make_unique<std::vector<Coordinate>>();
ring->getCoordinatesRO()->toVector(*coords);
coords->erase(coords->end() - 1); // remove last point (repeated)
- std::unique_ptr<CoordinateSequence> uniqueCoordinates = seqFactory->create(coords.release());
+ auto uniqueCoordinates = detail::make_unique<CoordinateArraySequence>(coords.release());
const Coordinate* minCoordinate = uniqueCoordinates->minCoordinate();
CoordinateSequence::scroll(uniqueCoordinates.get(), minCoordinate);
diff --git a/src/geomgraph/EdgeRing.cpp b/src/geomgraph/EdgeRing.cpp
index 1b63505..d24e4c0 100644
--- a/src/geomgraph/EdgeRing.cpp
+++ b/src/geomgraph/EdgeRing.cpp
@@ -30,6 +30,7 @@
#include <geos/geomgraph/Label.h>
#include <geos/geomgraph/Position.h>
#include <geos/geom/GeometryFactory.h>
@@ -55,7 +56,7 @@ EdgeRing::EdgeRing(DirectedEdge* newStart,
holes(),
maxNodeDegree(-1),
edges(),
- pts(newGeometryFactory->getCoordinateSequenceFactory()->create().release()),
+ pts(new CoordinateArraySequence()),
label(Location::UNDEF), // new Label(Location::UNDEF)),
ring(nullptr),
isHoleVar(false),
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index b1c64fb..b697292 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -32,8 +32,10 @@
#include <geos/geom/MultiPolygon.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/inline.h>
#include <sstream>
#include <string>
@@ -81,7 +83,7 @@ WKTReader::getCoordinates(StringTokenizer* tokenizer)
Coordinate coord;
getPreciseCoordinate(tokenizer, coord, dim);
- auto coordinates = geometryFactory->getCoordinateSequenceFactory()->create((size_t)0, dim);
+ auto coordinates = detail::make_unique<CoordinateArraySequence>(0, dim);
coordinates->add(coord);
nextToken = getNextCloserOrComma(tokenizer);
@@ -91,7 +93,7 @@ WKTReader::getCoordinates(StringTokenizer* tokenizer)
- return coordinates;
+ return std::move(coordinates);
@@ -295,9 +297,7 @@ WKTReader::readMultiPointText(StringTokenizer* tokenizer)
size_t dim;
// Try to parse deprecated form "MULTIPOINT(0 0, 1 1)"
- const CoordinateSequenceFactory* csf = \
- geometryFactory->getCoordinateSequenceFactory();
- auto coords = csf->create();
+ auto coords = detail::make_unique<CoordinateArraySequence>();
do {
Coordinate coord;
diff --git a/src/operation/buffer/BufferInputLineSimplifier.cpp b/src/operation/buffer/BufferInputLineSimplifier.cpp
index 5d1d9d1..3acd552 100644
--- a/src/operation/buffer/BufferInputLineSimplifier.cpp
+++ b/src/operation/buffer/BufferInputLineSimplifier.cpp
@@ -21,6 +21,7 @@
#include <geos/geom/CoordinateArraySequence.h> // for constructing the return
#include <geos/algorithm/Distance.h> // for use
#include <geos/algorithm/Orientation.h> // for use
#include <memory>
#include <cmath>
@@ -127,8 +128,7 @@ BufferInputLineSimplifier::findNextNonDeletedIndex(size_t index) const
BufferInputLineSimplifier::collapseLine() const
- std::unique_ptr<geom::CoordinateSequence> coordList(
- new CoordinateArraySequence());
+ auto coordList = detail::make_unique<CoordinateArraySequence>();
for(size_t i = 0, n = inputLine.size(); i < n; ++i) {
if(isDeleted[i] != DELETE) {
@@ -136,7 +136,7 @@ BufferInputLineSimplifier::collapseLine() const
- return coordList;
+ return std::move(coordList);
/* private */
diff --git a/src/operation/linemerge/EdgeString.cpp b/src/operation/linemerge/EdgeString.cpp
index 9a23590..c76af8a 100644
--- a/src/operation/linemerge/EdgeString.cpp
+++ b/src/operation/linemerge/EdgeString.cpp
@@ -24,6 +24,7 @@
#include <geos/geom/LineString.h>
#include <vector>
@@ -66,7 +67,7 @@ EdgeString::getCoordinates()
if(coordinates == nullptr) {
int forwardDirectedEdges = 0;
int reverseDirectedEdges = 0;
- coordinates = factory->getCoordinateSequenceFactory()->create().release();
+ coordinates = new CoordinateArraySequence();
for(std::size_t i = 0, e = directedEdges.size(); i < e; ++i) {
LineMergeDirectedEdge* directedEdge = directedEdges[i];
if(directedEdge->getEdgeDirection()) {
diff --git a/src/operation/polygonize/EdgeRing.cpp b/src/operation/polygonize/EdgeRing.cpp
index dc223ec..527a2a9 100644
--- a/src/operation/polygonize/EdgeRing.cpp
+++ b/src/operation/polygonize/EdgeRing.cpp
@@ -20,6 +20,7 @@
#include <geos/operation/polygonize/EdgeRing.h>
#include <geos/operation/polygonize/PolygonizeEdge.h>
#include <geos/planargraph/DirectedEdge.h>
@@ -221,7 +222,7 @@ const CoordinateSequence*
EdgeRing::getCoordinates()
if(ringPts == nullptr) {
- ringPts = factory->getCoordinateSequenceFactory()->create();
+ ringPts = detail::make_unique<CoordinateArraySequence>(0, 0);
for(const auto& de : deList) {
auto edge = dynamic_cast<PolygonizeEdge*>(de->getEdge());
addEdge(edge->getLine()->getCoordinatesRO(),
@@ -274,7 +275,7 @@ EdgeRing::getRingOwnership()
/*private*/
void
EdgeRing::addEdge(const CoordinateSequence* coords, bool isForward,
- CoordinateSequence* coordList)
+ CoordinateArraySequence* coordList)
const std::size_t npts = coords->getSize();
if(isForward) {
diff --git a/src/operation/valid/RepeatedPointRemover.cpp b/src/operation/valid/RepeatedPointRemover.cpp
index 906dc8d..ef22766 100644
--- a/src/operation/valid/RepeatedPointRemover.cpp
+++ b/src/operation/valid/RepeatedPointRemover.cpp
@@ -22,14 +22,12 @@ namespace geos {
namespace valid {
-std::unique_ptr<geom::CoordinateSequence>
+std::unique_ptr<geom::CoordinateArraySequence>
RepeatedPointRemover::removeRepeatedPoints(const geom::CoordinateSequence* seq) {
using geom::Coordinate;
- auto seqFactory = geom::CoordinateArraySequenceFactory::instance();
if (seq->isEmpty()) {
- return std::unique_ptr<geom::CoordinateSequence>(seqFactory->create());
+ return detail::make_unique<geom::CoordinateArraySequence>(0, seq->getDimension());
auto pts = detail::make_unique<std::vector<Coordinate>>();
@@ -47,7 +45,7 @@ RepeatedPointRemover::removeRepeatedPoints(const geom::CoordinateSequence* seq)
prevPt = nextPt;
- return std::unique_ptr<geom::CoordinateSequence>(seqFactory->create(pts.release(), seq->getDimension()));
+ return detail::make_unique<geom::CoordinateArraySequence>(pts.release(), seq->getDimension());
diff --git a/tests/bigtest/GeometryTestFactory.cpp b/tests/bigtest/GeometryTestFactory.cpp
index 59907dd..b286413 100644
--- a/tests/bigtest/GeometryTestFactory.cpp
+++ b/tests/bigtest/GeometryTestFactory.cpp
@@ -34,7 +34,7 @@ CoordinateSequence*
GeometryTestFactory::createBox(double minx, double miny, int nSide, double segLen)
int i;
- CoordinateSequence* pts = new CoordinateArraySequence();
+ CoordinateArraySequence* pts = new CoordinateArraySequence();
double maxx = minx + nSide * segLen;
double maxy = miny + nSide * segLen;
@@ -72,7 +72,7 @@ GeometryTestFactory::createBox(double minx, double miny, int nSide, double segLe
CoordinateSequence*
GeometryTestFactory::createCircle(double basex, double basey, double size, int nPts)
- CoordinateSequence* pts = new CoordinateArraySequence(nPts + 1);
+ CoordinateArraySequence* pts = new CoordinateArraySequence(nPts + 1);
double len = size / 2.0;
for(int i = 0; i < nPts; i++) {
@@ -116,7 +116,7 @@ GeometryTestFactory::createSineStar(double basex, double basey, double size, dou
//int nPts2=nArmPt*nArms;
double starAng = 0.0;
@@ -128,15 +128,13 @@ GeometryTestFactory::createSineStar(double basex, double basey, double size, dou
double y = len * sin(starAng + iArmPt * angInc / nArmPt) + basey;
// FIXME - mloskot: Number of problems here:
- // - new'd Coordinate definitely leaks
// - add() method makes a copy
- // - why temporarily used Coordinate is allocated on the heap?!?
- pts->add(*(new Coordinate(x, y)));
+ pts->add(Coordinate(x, y));
starAng += angInc;
// FIXME - mloskot: The same problems as above
- pts->add(*(new Coordinate(pts->getAt(0))));
+ pts->add(pts->getAt(0));
return pts;
diff --git a/tests/unit/algorithm/RobustLineIntersectorTest.cpp b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
index 8828429..20f0941 100644
--- a/tests/unit/algorithm/RobustLineIntersectorTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
@@ -248,7 +248,7 @@ void object::test<13>
using geos::geom::LineString;
GeometryFactory::Ptr factory = GeometryFactory::create();
- CoordinateSequence* cs = new CoordinateArraySequence();
+ CoordinateArraySequence* cs = new CoordinateArraySequence();
cs->add(p1);
cs->add(p2);
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index 346dfba..39b49ef 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -94,8 +94,9 @@ void object::test<2>
ensure(!point->isEmpty());
// currently the empty CoordinateArraySequence constructor
- // produces a dimension 3 sequence.
- ensure(point->getCoordinateDimension() == 3);
+ // produces a dimension 0 sequence. The dimension is then
+ // autodetected when the first point is inserted.
+ ensure(point->getCoordinateDimension() == 2);
// Test of user's constructor throwing IllegalArgumentException
diff --git a/tests/unit/noding/BasicSegmentStringTest.cpp b/tests/unit/noding/BasicSegmentStringTest.cpp
index 0efb635..cc49126 100644
--- a/tests/unit/noding/BasicSegmentStringTest.cpp
+++ b/tests/unit/noding/BasicSegmentStringTest.cpp
@@ -6,8 +6,9 @@
#include <geos/noding/BasicSegmentString.h>
#include <geos/noding/Octant.h>
#include <geos/geom/CoordinateArraySequenceFactory.h>
// std
#include <memory>
@@ -62,7 +63,7 @@ template<>
void object::test<1>
- CoordinateSequenceAutoPtr cs(csFactory->create((size_t)0, 2));
+ auto cs = geos::detail::make_unique<geos::geom::CoordinateArraySequence>(0, 2);
ensure(nullptr != cs.get());
@@ -107,7 +108,7 @@ template<>
@@ -144,7 +145,7 @@ template<>
void object::test<3>
diff --git a/tests/unit/noding/NodedSegmentStringTest.cpp b/tests/unit/noding/NodedSegmentStringTest.cpp
index 6886ad0..21b3af2 100644
--- a/tests/unit/noding/NodedSegmentStringTest.cpp
+++ b/tests/unit/noding/NodedSegmentStringTest.cpp
@@ -6,8 +6,9 @@
#include <geos/noding/NodedSegmentString.h>
// std
#include <memory>
@@ -98,7 +99,7 @@ template<>
@@ -134,7 +135,7 @@ template<>
@@ -207,7 +208,7 @@ void object::test<5>
geos::geom::Coordinate p1(10, 0);
cs->add(p0);
cs->add(p1);
diff --git a/tests/unit/noding/SegmentNodeTest.cpp b/tests/unit/noding/SegmentNodeTest.cpp
index 6459055..d3cc2b7 100644
--- a/tests/unit/noding/SegmentNodeTest.cpp
+++ b/tests/unit/noding/SegmentNodeTest.cpp
@@ -6,8 +6,9 @@
#include <geos/noding/SegmentNode.h>
// std
#include <memory>
@@ -53,7 +54,7 @@ void object::test<1>
// Create coordinates sequence
const size_t coords_size = 2;
- CoordSeqPtr cs(factory_->create((size_t)0, coords_size));
+ auto cs = geos::detail::make_unique<geos::geom::CoordinateArraySequence>(0, coords_size);
@@ -102,7 +103,7 @@ void object::test<2>
@@ -145,7 +146,7 @@ void object::test<3>
@@ -188,7 +189,7 @@ void object::test<4>
diff --git a/tests/unit/operation/valid/IsValidTest.cpp b/tests/unit/operation/valid/IsValidTest.cpp
index 0697e71..06938f3 100644
--- a/tests/unit/operation/valid/IsValidTest.cpp
+++ b/tests/unit/operation/valid/IsValidTest.cpp
@@ -56,7 +56,7 @@ template<>
cs->add(Coordinate(0.0, 0.0));
cs->add(Coordinate(1.0, geos::DoubleNotANumber));
GeomPtr line(factory_->createLineString(cs));
commit dee35dd2b99396585f704c0efa0e18d2b618a430
Date: Tue Jun 4 11:27:41 2019 -0400
Remove some trivial uses of CoordinateSequence::add
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index 6594537..521515a 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -71,11 +71,11 @@ MinimumBoundingCircle::getFarthestPoints()
return input->getFactory()->createPoint(centre);
- size_t dims = input->getDimension();
+ size_t dims = input->getCoordinateDimension();
size_t len = 2;
auto cs = input->getFactory()->getCoordinateSequenceFactory()->create(len, dims);
- cs->add(extremalPts[0], true);
- cs->add(extremalPts[extremalPts.size() - 1], true);
+ cs->setAt(extremalPts[0], 0);
+ cs->setAt(extremalPts[extremalPts.size() - 1], 1);
return input->getFactory()->createLineString(cs.release());
@@ -90,13 +90,13 @@ MinimumBoundingCircle::getDiameter()
case 1:
size_t len = 2;
// TODO: handle case of 3 extremal points, by computing a line from one of
// them through the centre point with len = 2*radius
- cs->add(extremalPts[1], true);
+ cs->setAt(extremalPts[1], 1);
diff --git a/src/algorithm/MinimumDiameter.cpp b/src/algorithm/MinimumDiameter.cpp
index 65884d6..762d3a9 100644
--- a/src/algorithm/MinimumDiameter.cpp
+++ b/src/algorithm/MinimumDiameter.cpp
@@ -137,9 +137,9 @@ MinimumDiameter::getSupportingSegment()
computeMinimumDiameter();
const GeometryFactory* fact = inputGeom->getFactory();
- auto cl = fact->getCoordinateSequenceFactory()->create();
- cl->add(minBaseSeg->p0);
- cl->add(minBaseSeg->p1);
+ auto cl = fact->getCoordinateSequenceFactory()->create(2);
+ cl->setAt(minBaseSeg->p0, 0);
+ cl->setAt(minBaseSeg->p1, 1);
return fact->createLineString(cl.release());
@@ -160,9 +160,9 @@ MinimumDiameter::getDiameter()
Coordinate basePt;
minBaseSeg->project(*minWidthPt, basePt);
- auto cl = inputGeom->getFactory()->getCoordinateSequenceFactory()->create();
- cl->add(basePt);
- cl->add(*minWidthPt);
+ auto cl = inputGeom->getFactory()->getCoordinateSequenceFactory()->create(2);
+ cl->setAt(basePt, 0);
+ cl->setAt(*minWidthPt, 1);
return inputGeom->getFactory()->createLineString(cl.release());
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index b738e5e..c958227 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -277,22 +277,27 @@ GeometryFactory::toGeometry(const Envelope* envelope) const
return createPoint(coord);
auto cl = CoordinateArraySequenceFactory::instance()->
- create((size_t) 0, 2);
+ create((size_t) 5, 2);
coord.x = envelope->getMinX();
coord.y = envelope->getMinY();
- cl->add(coord);
+ cl->setAt(coord, 0);
coord.x = envelope->getMaxX();
- cl->add(coord);
+ cl->setAt(coord, 1);
coord.y = envelope->getMaxY();
- cl->add(coord);
+ cl->setAt(coord, 2);
- cl->add(coord);
+ cl->setAt(coord, 3);
- cl->add(coord);
+ cl->setAt(coord, 4);
Polygon* p = createPolygon(createLinearRing(cl.release()), nullptr);
return p;
diff --git a/src/geom/LineSegment.cpp b/src/geom/LineSegment.cpp
index 00072ce..6ad41b9 100644
--- a/src/geom/LineSegment.cpp
+++ b/src/geom/LineSegment.cpp
@@ -313,9 +313,9 @@ LineSegment::pointAlongOffset(double segmentLengthFraction,
std::unique_ptr<LineString>
LineSegment::toGeometry(const GeometryFactory& gf) const
- cl->add(p0);
- cl->add(p1);
+ CoordinateSequence* cl = new CoordinateArraySequence(2);
+ cl->setAt(p0, 0);
+ cl->setAt(p1, 1);
return std::unique_ptr<LineString>(
gf.createLineString(cl) // ownership transferred
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index 635a201..6ea08b2 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -470,10 +470,10 @@ QuadEdgeSubdivision::getEdges(const geom::GeometryFactory& geomFact)
int i = 0;
for(QuadEdgeSubdivision::QuadEdgeList::iterator it = p_quadEdges->begin(); it != p_quadEdges->end(); ++it) {
QuadEdge* qe = *it;
- auto coordSeq = coordSeqFact->create((std::vector<geom::Coordinate>*)nullptr);;
+ auto coordSeq = coordSeqFact->create(2);
- coordSeq->add(qe->orig().getCoordinate());
- coordSeq->add(qe->dest().getCoordinate());
+ coordSeq->setAt(qe->orig().getCoordinate(), 0);
+ coordSeq->setAt(qe->dest().getCoordinate(), 1);
edges[i++] = static_cast<Geometry*>(geomFact.createLineString(coordSeq.release()));
Summary of changes:
doc/example.cpp | 4 +-
include/geos/geom/CoordinateArraySequence.h | 17 ++++++--
include/geos/geom/CoordinateSequence.h | 43 --------------------
include/geos/geomgraph/EdgeRing.h | 4 +-
include/geos/linearref/LinearGeometryBuilder.h | 2 +-
include/geos/noding/SegmentIntersectionDetector.h | 4 +-
include/geos/operation/linemerge/EdgeString.h | 3 +-
include/geos/operation/polygonize/EdgeRing.h | 4 +-
.../geos/operation/valid/RepeatedPointRemover.h | 4 +-
src/algorithm/MinimumBoundingCircle.cpp | 12 +++---
src/algorithm/MinimumDiameter.cpp | 12 +++---
src/geom/CoordinateArraySequence.cpp | 20 ++++++++-
src/geom/CoordinateSequence.cpp | 47 ----------------------
src/geom/GeometryFactory.cpp | 17 +++++---
src/geom/LineSegment.cpp | 6 +--
src/geom/Polygon.cpp | 11 +++--
src/geomgraph/EdgeRing.cpp | 3 +-
src/io/WKTReader.cpp | 10 ++---
src/operation/buffer/BufferInputLineSimplifier.cpp | 6 +--
src/operation/linemerge/EdgeString.cpp | 3 +-
src/operation/polygonize/EdgeRing.cpp | 5 ++-
src/operation/valid/RepeatedPointRemover.cpp | 8 ++--
src/triangulate/quadedge/QuadEdgeSubdivision.cpp | 6 +--
tests/bigtest/GeometryTestFactory.cpp | 12 +++---
tests/unit/algorithm/RobustLineIntersectorTest.cpp | 2 +-
tests/unit/geom/PointTest.cpp | 5 ++-
tests/unit/noding/BasicSegmentStringTest.cpp | 9 +++--
tests/unit/noding/NodedSegmentStringTest.cpp | 11 ++---
tests/unit/noding/SegmentNodeTest.cpp | 11 ++---
tests/unit/operation/valid/IsValidTest.cpp | 2 +-
30 files changed, 124 insertions(+), 179 deletions(-)
hooks/post-receive
More information about the geos-commits
