[geos-commits] [SCM] GEOS branch master updated. ea8bde0b96494978e31624d7693eb8aebb148271
git at osgeo.org
git at osgeo.org
Tue Jun 11 16:52:28 PDT 2019
the project "GEOS".
via ea8bde0b96494978e31624d7693eb8aebb148271 (commit)
via 8c4251685c937d6847ef92eee489a584a5c673ea (commit)
via 24861420afdef90559dc06f10377a9b26afd6f1c (commit)
via f378ac5348002ce611a360eaf59a8bb281ecfa7b (commit)
via a2030535758d04aa64e6fb2ad21eb1d413aad4b9 (commit)
via 2a07cac2ad2e7c3efadd31d0abf3a95565313997 (commit)
via 513ca427ad712d3aeaebb6c1ff5d7f7fac37001e (commit)
via 52cf6c4d8a5db5db3d0aba3e7358c5f8d98e337a (commit)
via c8735c3674b5613890c51be8180c193a61a73c81 (commit)
via 4010bac2d20d87a4b5888fb0f0a30c084e5c6a6c (commit)
via 9d85434cb937f2e837e2c10cbee44817a4cd81e6 (commit)
via 64f3ec8663bd210144fe2fc563688e7cb0f42f94 (commit)
via 4d61fb5d4739fdb84975792d29465a009bca0550 (commit)
from d6364a4fc1d386d076b59f045fb382e7532fab96 (commit)
revisions in full, below.
commit ea8bde0b96494978e31624d7693eb8aebb148271
Merge: d6364a4 8c42516
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Jun 11 19:52:04 2019 -0400
Merge branch 'pip-performance'
commit 8c4251685c937d6847ef92eee489a584a5c673ea
Date: Mon Jun 10 20:19:20 2019 -0400
Factor out AbstractPreparedPolygonContains::evalPointTestGeom
diff --git a/include/geos/geom/prep/AbstractPreparedPolygonContains.h b/include/geos/geom/prep/AbstractPreparedPolygonContains.h
index d9c00cc..9325bfa 100644
--- a/include/geos/geom/prep/AbstractPreparedPolygonContains.h
+++ b/include/geos/geom/prep/AbstractPreparedPolygonContains.h
@@ -99,6 +99,16 @@ protected:
bool eval(const geom::Geometry* geom);
+ * Evaluate the <tt>contains</tt> or <tt>covers</tt> relationship
+ * for the given Puntal geometry.
+ * @param geom the test geometry
+ * @param outermostLoc outermost Location of all points in geom
+ * @return true if the test geometry is contained/covered in the target
+ bool evalPointTestGeom(const geom::Geometry* geom, geom::Location::Value outermostLoc);
* Computes the full topological predicate.
* Used when short-circuit tests are not conclusive.
diff --git a/src/geom/prep/AbstractPreparedPolygonContains.cpp b/src/geom/prep/AbstractPreparedPolygonContains.cpp
index 5f736b6..2cf2c6a 100644
--- a/src/geom/prep/AbstractPreparedPolygonContains.cpp
+++ b/src/geom/prep/AbstractPreparedPolygonContains.cpp
@@ -111,38 +111,17 @@ AbstractPreparedPolygonContains::eval(const geom::Geometry* geom)
// in a quick negative result.
auto outermostLoc = getOutermostTestComponentLocation(geom);
+ // Short-circuit for (Multi)Points
+ if (geom->getDimension() == 0) {
+ return evalPointTestGeom(geom, outermostLoc);
if (outermostLoc == Location::EXTERIOR) {
// If a point of any test components does not lie in target,
// result is false
return false;
- // Short-circuit for (Multi)Points
- // For the Covers predicate, we can return true
- // since no Points are on the exterior of the Polygon.
- // For the Contains predicate, we need to test if any
- // of those points lie in the interior of the target
- // geometry.
- // If so, the test is contained.
- // If not, all points are on the boundary of the area,
- // which implies not contained.
- if (geom->getDimension() == 0) {
- if (requireSomePointInInterior && outermostLoc == Location::BOUNDARY) {
- if (geom->getNumGeometries() > 1) {
- return isAnyTestComponentInTargetInterior(geom);
- } else {
- // We only had one point, so if it was on the
- // boundary, it is not contained.
- return false;
- } else {
- return true;
// Check if there is any intersection between the line segments
// in target and test.
// In some important cases, finding a proper interesection implies that the
@@ -202,6 +181,37 @@ AbstractPreparedPolygonContains::eval(const geom::Geometry* geom)
return true;
+bool AbstractPreparedPolygonContains::evalPointTestGeom(const Geometry *geom,
+ Location::Value outermostLoc) {
+ // If we had a point on the ourside of the polygon,
+ // we aren't covered or contained.
+ if (outermostLoc == Location::EXTERIOR) {
+ return false;
+ // For the Covers predicate, we can return true
+ // since no Points are on the exterior of the target
+ // geometry.
+ if (!requireSomePointInInterior) {
+ return true;
+ // For the Contains predicate, we need to test if any
+ // of those points lie in the interior of the target
+ // geometry.
+ if (outermostLoc == Location::INTERIOR) {
+ return true;
+ if (geom->getNumGeometries() > 1) {
+ // for MultiPoint, try to find at least one point
+ // in interior
+ return isAnyTestComponentInTargetInterior(geom);
+ return false;
// public:
commit 24861420afdef90559dc06f10377a9b26afd6f1c
Date: Mon Jun 10 17:17:19 2019 -0400
Rename location filters
diff --git a/src/geom/prep/PreparedPolygonPredicate.cpp b/src/geom/prep/PreparedPolygonPredicate.cpp
index c79cd88..886193c 100644
--- a/src/geom/prep/PreparedPolygonPredicate.cpp
+++ b/src/geom/prep/PreparedPolygonPredicate.cpp
@@ -38,8 +38,8 @@ namespace prep { // geos.geom.prep
// protected:
-struct AnyMatchingLocationFilter : public GeometryComponentFilter {
- explicit AnyMatchingLocationFilter(algorithm::locate::PointOnGeometryLocator* locator, int loc) :
+struct LocationMatchingFilter : public GeometryComponentFilter {
+ explicit LocationMatchingFilter(algorithm::locate::PointOnGeometryLocator* locator, int loc) :
pt_locator(locator), test_loc(loc), found(false) {}
algorithm::locate::PointOnGeometryLocator* pt_locator;
@@ -60,8 +60,8 @@ struct AnyMatchingLocationFilter : public GeometryComponentFilter {
-struct AnyNotMatchingLocationFilter : public GeometryComponentFilter {
- explicit AnyNotMatchingLocationFilter(algorithm::locate::PointOnGeometryLocator* locator, int loc) :
+struct LocationNotMatchingFilter : public GeometryComponentFilter {
+ explicit LocationNotMatchingFilter(algorithm::locate::PointOnGeometryLocator* locator, int loc) :
@@ -126,7 +126,7 @@ bool
PreparedPolygonPredicate::isAllTestComponentsInTargetInterior(
const geom::Geometry* testGeom) const
- AnyNotMatchingLocationFilter filter(prepPoly->getPointLocator(), geom::Location::INTERIOR);
+ LocationNotMatchingFilter filter(prepPoly->getPointLocator(), geom::Location::INTERIOR);
testGeom->apply_ro(&filter);
return !filter.found;
@@ -136,7 +136,7 @@ bool
PreparedPolygonPredicate::isAnyTestComponentInTarget(
- AnyNotMatchingLocationFilter filter(prepPoly->getPointLocator(), geom::Location::EXTERIOR);
+ LocationNotMatchingFilter filter(prepPoly->getPointLocator(), geom::Location::EXTERIOR);
return filter.found;
@@ -146,7 +146,7 @@ bool
PreparedPolygonPredicate::isAnyTestComponentInTargetInterior(
- AnyMatchingLocationFilter filter(prepPoly->getPointLocator(), geom::Location::INTERIOR);
+ LocationMatchingFilter filter(prepPoly->getPointLocator(), geom::Location::INTERIOR);
commit f378ac5348002ce611a360eaf59a8bb281ecfa7b
Date: Mon Jun 10 15:09:56 2019 -0400
Avoid relying on numeric ordering of Location
index f798efb..c79cd88 100644
@@ -26,7 +26,6 @@
#include <geos/algorithm/locate/PointOnGeometryLocator.h>
#include <geos/algorithm/locate/SimplePointInAreaLocator.h>
// std
-#include <algorithm> // std::max
#include <cstddef>
namespace geos {
@@ -86,29 +85,31 @@ struct AnyNotMatchingLocationFilter : public GeometryComponentFilter {
struct OutermostLocationFilter : public GeometryComponentFilter {
explicit OutermostLocationFilter(algorithm::locate::PointOnGeometryLocator* locator) :
- max_loc(geom::Location::UNDEF),
- found(false) {}
+ outermost_loc(geom::Location::UNDEF),
+ done(false) {}
- bool found;
+ Location::Value outermost_loc;
+ bool done;
void filter_ro(const Geometry* g) override {
const Coordinate* pt = g->getCoordinate();
auto loc = static_cast<Location::Value>(pt_locator->locate(pt));
- max_loc = std::max(max_loc, loc);
- if (max_loc == geom::Location::EXTERIOR) {
- found = true;
+ if (outermost_loc == Location::UNDEF || outermost_loc == Location::INTERIOR) {
+ outermost_loc = loc;
+ } else if (Location::EXTERIOR) {
+ done = true;
bool isDone() override {
- return found;
+ return done;
- return max_loc;
+ return outermost_loc;
commit a2030535758d04aa64e6fb2ad21eb1d413aad4b9
Date: Sun Jun 9 22:03:47 2019 -0400
Clarify PIP short-circuits in PreparedPolygonPredicate
diff --git a/include/geos/geom/prep/PreparedPolygonPredicate.h b/include/geos/geom/prep/PreparedPolygonPredicate.h
index d100ebe..d983982 100644
--- a/include/geos/geom/prep/PreparedPolygonPredicate.h
+++ b/include/geos/geom/prep/PreparedPolygonPredicate.h
@@ -22,6 +22,7 @@
#define GEOS_GEOM_PREP_PREPAREDPOLYGONPREDICATE_H
#include <geos/geom/Coordinate.h>
+#include <geos/geom/Location.h>
// forward declarations
namespace geos {
@@ -64,16 +65,13 @@ protected:
const PreparedPolygon* const prepPoly;
/** \brief
- * Tests whether all components of the test Geometry
- * are contained in the target geometry.
- * Handles both linear and point components.
+ * Returns the outermost Location among a test point from each
+ * components of the test geometry.
* @param testGeom a geometry to test
- * @return true if all components of the argument are contained
- * in the target geometry
+ * @return the outermost Location
- bool isAllTestComponentsInTarget(const geom::Geometry* testGeom) const;
+ geom::Location::Value getOutermostTestComponentLocation(const geom::Geometry* testGeom) const;
/** \brief
index 4cc8f58..5f736b6 100644
@@ -109,25 +109,38 @@ AbstractPreparedPolygonContains::eval(const geom::Geometry* geom)
// Do point-in-poly tests first, since they are cheaper and may result
- // If a point of any test components does not lie in target,
- // result is false
- if (!requireSomePointInInterior || geom->getGeometryTypeId() != GEOS_POINT) {
- bool isAllInTargetArea = isAllTestComponentsInTarget(geom);
- if (!isAllInTargetArea) {
- return false;
+ auto outermostLoc = getOutermostTestComponentLocation(geom);
+ // If a point of any test components does not lie in target,
+ // result is false
+ return false;
- // If the test geometry consists of only Points,
- // then it is now sufficient to test if any of those
- // points lie in the interior of the target geometry.
+ // since no Points are on the exterior of the Polygon.
+ // geometry.
- if(requireSomePointInInterior && geom->getDimension() == 0) {
- bool isAnyInTargetInterior = isAnyTestComponentInTargetInterior(geom);
- return isAnyInTargetInterior;
+ if (requireSomePointInInterior && outermostLoc == Location::BOUNDARY) {
+ } else {
+ // We only had one point, so if it was on the
+ // boundary, it is not contained.
+ return false;
+ } else {
+ return true;
index 5944f47..f798efb 100644
@@ -26,6 +26,7 @@
// std
+#include <algorithm> // std::max
#include <cstddef>
namespace geos {
@@ -82,13 +83,42 @@ struct AnyNotMatchingLocationFilter : public GeometryComponentFilter {
-bool
-PreparedPolygonPredicate::isAllTestComponentsInTarget(const geom::Geometry* testGeom) const
+struct OutermostLocationFilter : public GeometryComponentFilter {
+ explicit OutermostLocationFilter(algorithm::locate::PointOnGeometryLocator* locator) :
+ pt_locator(locator),
+ max_loc(geom::Location::UNDEF),
+ found(false) {}
+ algorithm::locate::PointOnGeometryLocator* pt_locator;
+ Location::Value max_loc;
+ bool found;
+ void filter_ro(const Geometry* g) override {
+ const Coordinate* pt = g->getCoordinate();
+ auto loc = static_cast<Location::Value>(pt_locator->locate(pt));
+ max_loc = std::max(max_loc, loc);
+ if (max_loc == geom::Location::EXTERIOR) {
+ found = true;
+ bool isDone() override {
+ return found;
+ Location::Value getOutermostLocation() {
+ return max_loc;
+Location::Value
+PreparedPolygonPredicate::getOutermostTestComponentLocation(const geom::Geometry* testGeom) const
- AnyMatchingLocationFilter filter(prepPoly->getPointLocator(), geom::Location::EXTERIOR);
+ OutermostLocationFilter filter(prepPoly->getPointLocator());
- return !filter.found;
+ return filter.getOutermostLocation();
bool
commit 2a07cac2ad2e7c3efadd31d0abf3a95565313997
Date: Sun Jun 9 22:03:36 2019 -0400
Add some prepared polygon predicate tests
diff --git a/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml b/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
index 04ca2e6..c4e2a8d 100644
--- a/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
+++ b/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
@@ -18,7 +18,21 @@
</case>
<case>
- <desc>A/P - point equal to start point of polygon
+ <desc>A/P - point in polygon interior
+ </desc>
+ <a>
+ POLYGON ((10 10, 60 100, 110 10, 10 10))
+ </a>
+ <b>
+ POINT (20 20)
+ </b>
+ <test> <op name="contains" arg1="A" arg2="B"> true </op> </test>
+ <test> <op name="covers" arg1="A" arg2="B"> true </op> </test>
+ <test> <op name="intersects" arg1="A" arg2="B"> true </op> </test>
+</case>
+<case>
+ <desc>A/P - point outside of polygon
</desc>
<a>
@@ -32,6 +46,76 @@
</case>
<case>
+ <desc>A/mP - both points equal to polygon vertices
+ </desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT ((10 10), (60 100))
+ </b>
+ <test> <op name="contains" arg1="A" arg2="B"> false </op> </test>
+</case>
+<case>
+ <desc>A/mP - both points in polygon interior
+ </desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT ((20 20), (21 21))
+ </b>
+</case>
+<case>
+ <desc>A/mP - one point interior, one point equal to a polygon vertex
+ </desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT ((60 100), (21 21))
+ </b>
+</case>
+<case>
+ <desc>A/mP - one point interior, one point exterior
+ </desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT ((20 20), (500 500))
+ </b>
+ <test> <op name="covers" arg1="A" arg2="B"> false </op> </test>
+</case>
+<case>
+ <desc>A/mP - one point equal to a polygon vertex, one point exterior
+ </desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT ((10 10), (500 500))
+ </b>
+</case>
+<case>
<desc>mA/L
A has 2 shells touching at one vertex and one non-vertex.
B passes between the shells, but is wholely contained
commit 513ca427ad712d3aeaebb6c1ff5d7f7fac37001e
Date: Thu Jun 6 20:26:56 2019 -0400
Add GeometryComponentFilter::isDone()
diff --git a/include/geos/geom/GeometryComponentFilter.h b/include/geos/geom/GeometryComponentFilter.h
index 514b64f..4e485fe 100644
--- a/include/geos/geom/GeometryComponentFilter.h
+++ b/include/geos/geom/GeometryComponentFilter.h
@@ -52,6 +52,8 @@ public:
virtual void filter_rw(Geometry* geom);
virtual void filter_ro(const Geometry* geom);
+ virtual bool isDone() { return false; }
virtual
~GeometryComponentFilter() {}
diff --git a/src/geom/GeometryCollection.cpp b/src/geom/GeometryCollection.cpp
index e00a63f..51809c9 100644
--- a/src/geom/GeometryCollection.cpp
+++ b/src/geom/GeometryCollection.cpp
@@ -310,7 +310,7 @@ void
GeometryCollection::apply_rw(GeometryComponentFilter* filter)
filter->filter_rw(this);
- for(size_t i = 0; i < geometries->size(); ++i) {
+ for(size_t i = 0; i < geometries->size() && !filter->isDone(); ++i) {
(*geometries)[i]->apply_rw(filter);
@@ -319,7 +319,7 @@ void
GeometryCollection::apply_ro(GeometryComponentFilter* filter) const
filter->filter_ro(this);
(*geometries)[i]->apply_ro(filter);
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 779f46b..586a6dd 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -394,7 +394,7 @@ Polygon::apply_ro(GeometryComponentFilter* filter) const
shell->apply_ro(filter);
- for(size_t i = 0, n = holes->size(); i < n; ++i) {
+ for(size_t i = 0, n = holes->size(); i < n && !filter->isDone(); ++i) {
(*holes)[i]->apply_ro(filter);
@@ -404,7 +404,7 @@ Polygon::apply_rw(GeometryComponentFilter* filter)
shell->apply_rw(filter);
(*holes)[i]->apply_rw(filter);
index 261312e..5944f47 100644
@@ -47,14 +47,17 @@ struct AnyMatchingLocationFilter : public GeometryComponentFilter {
bool found;
- auto pt = g->getCoordinate();
- if (!found) {
- const int loc = pt_locator->locate(pt);
- if (loc == test_loc) {
- found = true;
+ const int loc = pt_locator->locate(pt);
+ if (loc == test_loc) {
+ found = true;
+ return found;
@@ -66,14 +69,17 @@ struct AnyNotMatchingLocationFilter : public GeometryComponentFilter {
bool found;
- if (!found) {
- if (loc != test_loc) {
- found = true;
+ if (loc != test_loc) {
+ found = true;
+ return found;
bool
diff --git a/tests/unit/geom/GeometryComponentFilterTest.cpp b/tests/unit/geom/GeometryComponentFilterTest.cpp
index 7af0830..29127c7 100644
--- a/tests/unit/geom/GeometryComponentFilterTest.cpp
+++ b/tests/unit/geom/GeometryComponentFilterTest.cpp
@@ -4,6 +4,8 @@
#include <tut/tut.hpp>
// geos
#include <geos/geom/Geometry.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/LineString.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/GeometryComponentFilter.h>
#include <geos/io/WKTReader.h>
@@ -35,6 +37,34 @@ group test_geometrycomponentfilter_group("geos::geom::GeometryComponentFilter");
// Test Cases
+class NumPointsInFirstNComponents : public geos::geom::GeometryComponentFilter {
+public:
+ NumPointsInFirstNComponents(size_t n) : components_remaining(n), num_points(0) {}
+ void
+ filter_ro(const geos::geom::Geometry* g) override {
+ num_points += g->getNumPoints();
+ components_remaining--;
+ void
+ filter_rw(geos::geom::Geometry* g) override {
+ filter_ro(g);
+ size_t numPoints() {
+ return num_points;
+ return components_remaining == 0;
+private:
+ size_t components_remaining;
+ size_t num_points;
// Split components into two categories: Lineal and all other types
template<>
template<>
@@ -94,4 +124,62 @@ void object::test<1>
ensure_equals(lineal.size() + nonlineal.size(), 8ul);
+template<>
+template<>
+void object::test<2>()
+ // Test isDone() behavior for collections
+ // collection of 4 geometries
+ GeometryPtr g(reader.read("GEOMETRYCOLLECTION("
+ "POINT(0 0),"
+ "LINESTRING(0 0,1 1,1 2),"
+ "POLYGON((0 0,4 0,4 4,0 4,0 0)),"
+ "MULTILINESTRING((0 0,1 1,1 2),(2 3,3 2,5 4)))"));
+ auto filter = NumPointsInFirstNComponents(3);
+ g->apply_ro(&filter);
+ // Current GeometryComponentFilter semantics have the filter visit the entire collection
+ // in addition to each of its components. So the first 3 components are the the entire collection,
+ // the Point, and the LineString
+ ensure_equals(g->getNumPoints() + g->getGeometryN(0)->getNumPoints() + g->getGeometryN(1)->getNumPoints(),
+ filter.numPoints());
+ // isDone() behavior should be the same in apply_rw scenario.
+ filter = NumPointsInFirstNComponents(2);
+ g->apply_rw(&filter);
+ ensure_equals(g->getNumPoints() + g->getGeometryN(0)->getNumPoints(),
+template<>
+template<>
+void object::test<3>()
+ // Test isDone() behavior for polygons
+ GeometryPtr g(reader.read("POLYGON((0 0, 100 0, 100 100, 0 100, 0 0)," // 5 pt exterior ring
+ "(1 1, 2 1, 2 2, 1 1)," // 4 pt interior ring
+ "(5 5, 5 8, 8 8, 7 7, 6 6, 5 5))")); // 6 pt interior ring
+ auto poly = dynamic_cast<geos::geom::Polygon*>(g.get());
+ poly->apply_ro(&filter);
+ // Current GeometryComponentFilter semantics have the filter visit the entire polygon
+ // in addition to each of its rings. So the first 3 components are the the entire polygon,
+ // the the exterior ring, and the first interior ring.
+ ensure_equals(poly->getNumPoints() + poly->getExteriorRing()->getNumPoints() + poly->getInteriorRingN(0)->getNumPoints(),
+ ensure_equals(poly->getNumPoints() + poly->getExteriorRing()->getNumPoints(),
} // namespace tut
commit 52cf6c4d8a5db5db3d0aba3e7358c5f8d98e337a
Date: Thu Jun 6 12:45:59 2019 -0400
Use custom GeometryComponentFilter in PreparedPolygonPredicate to avoid creating vectors
index 5a1c7c3..261312e 100644
@@ -20,6 +20,7 @@
#include <geos/geom/prep/PreparedPolygonPredicate.h>
#include <geos/geom/prep/PreparedPolygon.h>
+#include <geos/geom/CoordinateFilter.h>
#include <geos/geom/util/ComponentCoordinateExtracter.h>
@@ -37,76 +38,81 @@ namespace prep { // geos.geom.prep
// protected:
+struct AnyMatchingLocationFilter : public GeometryComponentFilter {
+ explicit AnyMatchingLocationFilter(algorithm::locate::PointOnGeometryLocator* locator, int loc) :
+ pt_locator(locator), test_loc(loc), found(false) {}
+ const int test_loc;
+ bool found;
+ auto pt = g->getCoordinate();
+ if (!found) {
+ found = true;
+struct AnyNotMatchingLocationFilter : public GeometryComponentFilter {
+ explicit AnyNotMatchingLocationFilter(algorithm::locate::PointOnGeometryLocator* locator, int loc) :
+ bool found;
+ if (!found) {
+ found = true;
bool
- geom::Coordinate::ConstVect pts;
- geom::util::ComponentCoordinateExtracter::getCoordinates(*testGeom, pts);
- for(std::size_t i = 0, ni = pts.size(); i < ni; i++) {
- const geom::Coordinate* pt = pts[i];
- const int loc = prepPoly->getPointLocator()->locate(pt);
- if(geom::Location::EXTERIOR == loc) {
- return false;
- return true;
+ AnyMatchingLocationFilter filter(prepPoly->getPointLocator(), geom::Location::EXTERIOR);
+ testGeom->apply_ro(&filter);
+ return !filter.found;
bool
- if(geom::Location::INTERIOR != loc) {
- return false;
- return true;
+ AnyNotMatchingLocationFilter filter(prepPoly->getPointLocator(), geom::Location::INTERIOR);
bool
+ AnyNotMatchingLocationFilter filter(prepPoly->getPointLocator(), geom::Location::EXTERIOR);
- const Coordinate* pt = pts[i];
- if(geom::Location::EXTERIOR != loc) {
- return true;
- return false;
+ return filter.found;
bool
- if (testGeom->getGeometryTypeId() == GEOS_POINT) {
- // Avoid creating a vector to store a single point
- return prepPoly->getPointLocator()->locate(testGeom->getCoordinate()) == geom::Location::INTERIOR;
+ AnyMatchingLocationFilter filter(prepPoly->getPointLocator(), geom::Location::INTERIOR);
- if(geom::Location::INTERIOR == loc) {
- return true;
- return false;
bool
commit c8735c3674b5613890c51be8180c193a61a73c81
Date: Wed Jun 5 21:52:25 2019 -0400
Add Point short-circuit to PreparedPolygonPredicate::isAnyTestComponentInTargetInterior
index faff645..5a1c7c3 100644
@@ -91,6 +91,11 @@ bool
+ if (testGeom->getGeometryTypeId() == GEOS_POINT) {
+ // Avoid creating a vector to store a single point
+ return prepPoly->getPointLocator()->locate(testGeom->getCoordinate()) == geom::Location::INTERIOR;
commit 4010bac2d20d87a4b5888fb0f0a30c084e5c6a6c
Date: Wed Jun 5 21:47:48 2019 -0400
Avoid performing envelope test against Points
This causes an Envelope to be created and allocated for each point.
diff --git a/src/geom/prep/BasicPreparedGeometry.cpp b/src/geom/prep/BasicPreparedGeometry.cpp
index f3d62c6..436b316 100644
--- a/src/geom/prep/BasicPreparedGeometry.cpp
+++ b/src/geom/prep/BasicPreparedGeometry.cpp
@@ -40,12 +40,20 @@ BasicPreparedGeometry::setGeometry(const geom::Geometry* geom)
bool
BasicPreparedGeometry::envelopesIntersect(const geom::Geometry* g) const
+ if (g->getGeometryTypeId() == GEOS_POINT) {
+ return baseGeom->getEnvelopeInternal()->intersects(*(g->getCoordinate()));
return baseGeom->getEnvelopeInternal()->intersects(g->getEnvelopeInternal());
bool
BasicPreparedGeometry::envelopeCovers(const geom::Geometry* g) const
+ return baseGeom->getEnvelopeInternal()->covers(g->getCoordinate());
return baseGeom->getEnvelopeInternal()->covers(g->getEnvelopeInternal());
commit 9d85434cb937f2e837e2c10cbee44817a4cd81e6
Date: Wed Jun 5 21:33:24 2019 -0400
Avoid double-testing all positive PIP results in
index 49bfe6f..4cc8f58 100644
@@ -112,9 +112,11 @@ AbstractPreparedPolygonContains::eval(const geom::Geometry* geom)
// result is false
- if(!isAllInTargetArea) {
- return false;
+ if (!requireSomePointInInterior || geom->getGeometryTypeId() != GEOS_POINT) {
+ bool isAllInTargetArea = isAllTestComponentsInTarget(geom);
+ if (!isAllInTargetArea) {
+ return false;
commit 64f3ec8663bd210144fe2fc563688e7cb0f42f94
Date: Wed Jun 5 21:22:21 2019 -0400
Use adaptive OrientationIndex in RayCrossingCounter
Provides a roughly 20% gain in GEOSPreparedContains benchmark.
diff --git a/include/geos/algorithm/RayCrossingCounter.h b/include/geos/algorithm/RayCrossingCounter.h
index fe5dc88..fbbebcc 100644
--- a/include/geos/algorithm/RayCrossingCounter.h
+++ b/include/geos/algorithm/RayCrossingCounter.h
@@ -92,22 +92,6 @@ public:
static int locatePointInRing(const geom::Coordinate& p,
const std::vector<const geom::Coordinate*>& ring);
- /** \brief
- * Returns the index of the direction of the point <code>q</code>
- * relative to a vector specified by <code>p1-p2</code>.
- * @param p1 the origin point of the vector
- * @param p2 the final point of the vector
- * @param q the point to compute the direction to
- * @return 1 if q is counter-clockwise (left) from p1-p2
- * @return -1 if q is clockwise (right) from p1-p2
- * @return 0 if q is collinear with p1-p2
- static int orientationIndex(const geom::Coordinate& p1,
- const geom::Coordinate& p2,
- const geom::Coordinate& q);
RayCrossingCounter(const geom::Coordinate& p_point)
: point(p_point),
crossingCount(0),
diff --git a/src/algorithm/RayCrossingCounter.cpp b/src/algorithm/RayCrossingCounter.cpp
index 6593bb0..a4ae339 100644
--- a/src/algorithm/RayCrossingCounter.cpp
+++ b/src/algorithm/RayCrossingCounter.cpp
@@ -75,21 +75,6 @@ RayCrossingCounter::locatePointInRing(const geom::Coordinate& point,
return rcc.getLocation();
-/*public static*/
-int
-RayCrossingCounter::orientationIndex(const geom::Coordinate& p1,
- const geom::Coordinate& p2, const geom::Coordinate& q)
- // travelling along p1->p2, turn counter clockwise to get to q return 1,
- // travelling along p1->p2, turn clockwise to get to q return -1,
- // p1, p2 and q are colinear return 0.
- double dx1 = p2.x - p1.x;
- double dy1 = p2.y - p1.y;
- double dx2 = q.x - p2.x;
- double dy2 = q.y - p2.y;
- return CGAlgorithmsDD::signOfDet2x2(dx1, dy1, dx2, dy2);
void
RayCrossingCounter::countSegment(const geom::Coordinate& p1,
const geom::Coordinate& p2)
@@ -138,7 +123,7 @@ RayCrossingCounter::countSegment(const geom::Coordinate& p1,
((p2.y > point.y) && (p1.y <= point.y))) {
// For an upward edge, orientationIndex will be positive when p1->p2
// crosses ray. Conversely, downward edges should have negative sign.
- int sign = orientationIndex(p1, p2, point);
+ int sign = CGAlgorithmsDD::orientationIndex(p1, p2, point);
if(sign == 0) {
isPointOnSegment = true;
return;
commit 4d61fb5d4739fdb84975792d29465a009bca0550
Date: Wed Jun 5 21:20:54 2019 -0400
Add GEOSPreparedContains perf test
diff --git a/benchmarks/capi/CMakeLists.txt b/benchmarks/capi/CMakeLists.txt
index 7a5d849..4fdf0e3 100644
--- a/benchmarks/capi/CMakeLists.txt
+++ b/benchmarks/capi/CMakeLists.txt
@@ -16,3 +16,6 @@ target_include_directories(perf_memleak_mp_prep
$<BUILD_INTERFACE:${CMAKE_SOURCE_DIR}/include>
$<BUILD_INTERFACE:${CMAKE_BINARY_DIR}/include>)
target_link_libraries(perf_memleak_mp_prep PRIVATE geos_c)
+add_executable(perf_geospreparedcontains GEOSPreparedContainsPerfTest.cpp)
+target_link_libraries(perf_geospreparedcontains PRIVATE geos geos_c)
\ No newline at end of file
diff --git a/benchmarks/capi/GEOSPreparedContainsPerfTest.cpp b/benchmarks/capi/GEOSPreparedContainsPerfTest.cpp
new file mode 100644
index 0000000..c0c9ccd
--- /dev/null
+++ b/benchmarks/capi/GEOSPreparedContainsPerfTest.cpp
@@ -0,0 +1,114 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2019 Daniel Baston <dbaston at gmail.com>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#include <geos/profiler.h>
+#include <geos_c.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/util/SineStarFactory.h>
+#include <random>
+#include <vector>
+#include <memory>
+#include <fstream>
+#include <iostream>
+#include <sstream>
+class GEOSPreparedContainsPerfTest {
+public:
+ void test(const GEOSGeometry* g, size_t num_points) {
+ using namespace geos::geom;
+ double xmin, xmax, ymin, ymax;
+ GEOSGeom_getXMin(g, &xmin);
+ GEOSGeom_getXMax(g, &xmax);
+ GEOSGeom_getYMin(g, &ymin);
+ GEOSGeom_getYMax(g, &ymax);
+ std::default_random_engine e(12345);
+ std::uniform_real_distribution<> xdist(xmin, xmax);
+ std::uniform_real_distribution<> ydist(ymin, ymax);
+ std::vector<Coordinate> coords(num_points);
+ std::generate(coords.begin(), coords.end(), [&xdist, &ydist, &e]() {
+ return Coordinate(xdist(e), ydist(e));
+ geos::util::Profile sw("GEOSPreparedContains");
+ sw.start();
+ size_t hits = 0;
+ auto prep = GEOSPrepare(g);
+ for (const auto& c : coords) {
+ auto seq = GEOSCoordSeq_create(1, 2);
+ GEOSCoordSeq_setX(seq, 0, c.x);
+ GEOSCoordSeq_setY(seq, 0, c.y);
+ auto pt = GEOSGeom_createPoint(seq);
+ if (GEOSPreparedContains(prep, pt)) {
+ hits++;
+ GEOSGeom_destroy(pt);
+ GEOSPreparedGeom_destroy(prep);
+ sw.stop();
+ std::cout << sw.name << ": " << hits << " hits from " << num_points << " points in " << sw.getTotFormatted() << std::endl;
+int main(int argc, char** argv) {
+ if (argc != 3) {
+ std::cout << "perf_geospreparedcontins performs a specified number of point-in-polygon tests" << std::endl;
+ std::cout << "on randomly generated points from the bounding box of a single geometry provided" << std::endl;
+ std::cout << "in a file as WKT." << std::endl;
+ std::cout << std::endl;
+ std::cout << "Usage: perf_geospreparedcontins [wktfile] [n]" << std::endl;
+ return 0;
+ GEOSPreparedContainsPerfTest tester;
+ int n = std::atoi(argv[2]);
+ std::cout << "Performing " << n << " point-in-polygon tests." << std::endl;
+ std::string fname{argv[1]};
+ std::cout << "Reading shape from " << fname << std::endl;
+ std::ifstream f(fname);
+ std::stringstream buff;
+ buff << f.rdbuf();
+ f.close();
+ std::string wkt = buff.str();
+ buff.clear();
+ initGEOS(nullptr, nullptr);
+ GEOSGeometry* g = GEOSGeomFromWKT(wkt.c_str());
+ wkt.clear();
+ tester.test(g, n);
+ GEOSGeom_destroy(g);
Summary of changes:
benchmarks/capi/CMakeLists.txt | 3 +
benchmarks/capi/GEOSPreparedContainsPerfTest.cpp | 114 ++++++++++++++++++
include/geos/algorithm/RayCrossingCounter.h | 16 ---
include/geos/geom/GeometryComponentFilter.h | 2 +
.../geom/prep/AbstractPreparedPolygonContains.h | 10 ++
include/geos/geom/prep/PreparedPolygonPredicate.h | 12 +-
src/algorithm/RayCrossingCounter.cpp | 17 +--
src/geom/GeometryCollection.cpp | 4 +-
src/geom/Polygon.cpp | 4 +-
src/geom/prep/AbstractPreparedPolygonContains.cpp | 55 ++++++---
src/geom/prep/BasicPreparedGeometry.cpp | 8 ++
src/geom/prep/PreparedPolygonPredicate.cpp | 134 ++++++++++++++-------
tests/unit/geom/GeometryComponentFilterTest.cpp | 88 ++++++++++++++
.../tests/general/TestPreparedPolygonPredicate.xml | 86 ++++++++++++-
14 files changed, 451 insertions(+), 102 deletions(-)
create mode 100644 benchmarks/capi/GEOSPreparedContainsPerfTest.cpp
hooks/post-receive
More information about the geos-commits
