[geos-commits] [SCM] GEOS branch master updated. 67d8a2789de13ba8dd7865d3d43f9d3d60325783
git at osgeo.org
git at osgeo.org
Wed Jun 12 07:42:48 PDT 2019
the project "GEOS".
via 67d8a2789de13ba8dd7865d3d43f9d3d60325783 (commit)
from ea8bde0b96494978e31624d7693eb8aebb148271 (commit)
revisions in full, below.
commit 67d8a2789de13ba8dd7865d3d43f9d3d60325783
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed Jun 12 10:42:27 2019 -0400
Fix incorrect return from OutermostLocationFilter
diff --git a/src/geom/prep/PreparedPolygonPredicate.cpp b/src/geom/prep/PreparedPolygonPredicate.cpp
index 886193c..cd6d4c5 100644
--- a/src/geom/prep/PreparedPolygonPredicate.cpp
+++ b/src/geom/prep/PreparedPolygonPredicate.cpp
@@ -98,7 +98,7 @@ struct OutermostLocationFilter : public GeometryComponentFilter {
if (outermost_loc == Location::UNDEF || outermost_loc == Location::INTERIOR) {
outermost_loc = loc;
- } else if (Location::EXTERIOR) {
+ } else if (loc == Location::EXTERIOR) {
done = true;
diff --git a/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml b/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
index c4e2a8d..b8a8cb4 100644
--- a/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
+++ b/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
@@ -116,6 +116,20 @@
</case>
<case>
+ <desc>A/mP - one point on boundary, one point interior, one point exterior
+ </desc>
+ <a>
+ POLYGON ((10 10, 60 100, 110 10, 10 10))
+ </a>
+ <b>
+ MULTIPOINT ((10 10), (20 20), (20 40))
+ </b>
+ <test> <op name="contains" arg1="A" arg2="B"> false </op> </test>
+ <test> <op name="covers" arg1="A" arg2="B"> false </op> </test>
+ <test> <op name="intersects" arg1="A" arg2="B"> true </op> </test>
+</case>
+<case>
<desc>mA/L
A has 2 shells touching at one vertex and one non-vertex.
B passes between the shells, but is wholely contained
Summary of changes:
src/geom/prep/PreparedPolygonPredicate.cpp | 2 +-
.../tests/general/TestPreparedPolygonPredicate.xml | 14 ++++++++++++++
2 files changed, 15 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
