[geos-commits] [SCM] GEOS branch master updated. d1556af8cddca70ef7872c9b157907cdf07a1f8a
git at osgeo.org
git at osgeo.org
Thu Jun 13 18:53:34 PDT 2019
the project "GEOS".
via d1556af8cddca70ef7872c9b157907cdf07a1f8a (commit)
from 36d1c69636062de78688cb7e995eccbc27785287 (commit)
revisions in full, below.
commit d1556af8cddca70ef7872c9b157907cdf07a1f8a
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Jun 13 21:52:31 2019 -0400
Fix memory leak on GeometryCollection::getCoordinate
Add tests to ensure all Geometry types have the same behavior when
calling getCoordinate on an empty geometry.
Fixes #918
diff --git a/src/geom/GeometryCollection.cpp b/src/geom/GeometryCollection.cpp
index 51809c9..e07d6e0 100644
--- a/src/geom/GeometryCollection.cpp
+++ b/src/geom/GeometryCollection.cpp
@@ -270,14 +270,12 @@ GeometryCollection::compareToSameClass(const Geometry* g) const
const Coordinate*
GeometryCollection::getCoordinate() const
- // should use unique_ptr here or return NULL or throw an exception !
- // --strk;
for(size_t i = 0; i < geometries->size(); ++i) {
if(!(*geometries)[i]->isEmpty()) {
return (*geometries)[i]->getCoordinate();
- return new Coordinate();
+ return nullptr;
diff --git a/tests/unit/geom/GeometryCollectionTest.cpp b/tests/unit/geom/GeometryCollectionTest.cpp
index b2cf106..54ec1f8 100644
--- a/tests/unit/geom/GeometryCollectionTest.cpp
+++ b/tests/unit/geom/GeometryCollectionTest.cpp
@@ -81,4 +81,16 @@ void object::test<2>
std::unique_ptr<Geometry> clone(geom_col->clone());
ensure_equals(clone->getGeometryN(0)->getSRID(), 2);
+template<>
+template<>
+void object::test<3>
+ // getCoordinate() returns nullptr for empty geometry
+ auto gf = GeometryFactory::create();
+ std::unique_ptr<geos::geom::Geometry> g(gf->createGeometryCollection());
+ ensure(g->getCoordinate() == nullptr);
} // namespace tut
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index 91d640f..a04cbd1 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -512,5 +512,17 @@ void object::test<25>
factory_->destroyGeometry(geo);
+template<>
+template<>
+void object::test<26>
+ auto gf = geos::geom::GeometryFactory::create();
+ std::unique_ptr<geos::geom::Geometry> g(gf->createLineString());
} // namespace tut
diff --git a/tests/unit/geom/LinearRingTest.cpp b/tests/unit/geom/LinearRingTest.cpp
index 42600d6..9a912d7 100644
--- a/tests/unit/geom/LinearRingTest.cpp
+++ b/tests/unit/geom/LinearRingTest.cpp
@@ -448,4 +448,16 @@ void object::test<30>
const std::string type("LinearRing");
ensure_equals(ring_->getGeometryType(), type);
+template<>
+template<>
+void object::test<31>
+ std::unique_ptr<geos::geom::Geometry> g(gf->createLinearRing());
} // namespace tut
diff --git a/tests/unit/geom/MultiLineStringTest.cpp b/tests/unit/geom/MultiLineStringTest.cpp
index 0d25f87..e2a43b9 100644
--- a/tests/unit/geom/MultiLineStringTest.cpp
+++ b/tests/unit/geom/MultiLineStringTest.cpp
@@ -3,6 +3,7 @@
#include <tut/tut.hpp>
// geos
+#include <geos/geom/GeometryFactory.h>
#include <geos/geom/MultiLineString.h>
namespace tut {
@@ -24,13 +25,16 @@ group test_multilinestring_group("geos::geom::MultiLineString");
// Test Cases
-// Test of default constructor
template<>
template<>
void object::test<1>
- //inform("Test not implemented!");
+ std::unique_ptr<geos::geom::Geometry> g(gf->createMultiLineString());
} // namespace tut
diff --git a/tests/unit/geom/MultiPointTest.cpp b/tests/unit/geom/MultiPointTest.cpp
index 1202587..a2bace0 100644
--- a/tests/unit/geom/MultiPointTest.cpp
+++ b/tests/unit/geom/MultiPointTest.cpp
@@ -392,5 +392,17 @@ void object::test<28>
+template<>
+template<>
+void object::test<29>
+ std::unique_ptr<geos::geom::Geometry> g(gf->createMultiPoint());
} // namespace tut
diff --git a/tests/unit/geom/MultiPolygonTest.cpp b/tests/unit/geom/MultiPolygonTest.cpp
index 12ba16a..90ad0c6 100644
--- a/tests/unit/geom/MultiPolygonTest.cpp
+++ b/tests/unit/geom/MultiPolygonTest.cpp
@@ -3,6 +3,7 @@
// geos
#include <geos/geom/MultiPolygon.h>
namespace tut {
@@ -24,13 +25,16 @@ group test_multipolygon_group("geos::geom::MultiPolygon");
// Test Cases
template<>
template<>
+ std::unique_ptr<geos::geom::Geometry> g(gf->createMultiPolygon());
} // namespace tut
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index 39b49ef..a935f42 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -564,5 +564,17 @@ void object::test<40>
delete p;
+template<>
+template<>
+void object::test<41>
+ std::unique_ptr<geos::geom::Geometry> g(gf->createPoint());
} // namespace tut
diff --git a/tests/unit/geom/PolygonTest.cpp b/tests/unit/geom/PolygonTest.cpp
index 8713e0d..21f3279 100644
--- a/tests/unit/geom/PolygonTest.cpp
+++ b/tests/unit/geom/PolygonTest.cpp
@@ -591,4 +591,16 @@ void object::test<39>
ensure(gBuffer->getNumPoints() == poly_->getNumPoints());
+template<>
+template<>
+void object::test<40>
+ std::unique_ptr<geos::geom::Geometry> g(gf->createPolygon());
} // namespace tut
Summary of changes:
src/geom/GeometryCollection.cpp | 4 +---
tests/unit/geom/GeometryCollectionTest.cpp | 12 ++++++++++++
tests/unit/geom/LineStringTest.cpp | 12 ++++++++++++
tests/unit/geom/LinearRingTest.cpp | 12 ++++++++++++
tests/unit/geom/MultiLineStringTest.cpp | 8 ++++++--
tests/unit/geom/MultiPointTest.cpp | 12 ++++++++++++
tests/unit/geom/MultiPolygonTest.cpp | 8 ++++++--
tests/unit/geom/PointTest.cpp | 12 ++++++++++++
tests/unit/geom/PolygonTest.cpp | 12 ++++++++++++
9 files changed, 85 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
